13-Network Management and Monitoring Command Reference
HomeSupportSwitchesS7500X-G SeriesReference GuidesCommand ReferencesH3C S7500X-G Switch Series Command References-R7761Pxx-6W10013-Network Management and Monitoring Command Reference
11-AON Ethernet system commands
11-AON Ethernet system commands 260.14 KB
Only the default MDC supports AON Ethernet system commands. For more information about MDC, see Virtual Technologies Configuration Guide.
description
Use description to configure a description for an AON node (also called iOptic node) or AON node configuration template.
An AON node or AON node configuration template does not have a description.
AON node view
The system name of an AON node can contain only 1 to 31 characters. To manage AON nodes efficiently, you can also configure the IDs, geographic locations, and IP addresses as descriptions for them.
# Configure the description for AON node 1 as in room 1001-1-1.
[Sysname] smartmc light-unit 1
[Sysname-lu-1] description in room 1001-1-1
display smartmc light-unit
Use display smartmc light-unit to display AON node information.
display smartmc light-unit [ id | name name ] [ verbose ]
id: Specifies the ID of an AON node. The value range for this argument is 1 to 63 when an MPU prefixed with LSCM1 is installed, 1 to 127 when an MPU prefixed with LSCM2 is installed, and 1 to 511 when an MPU prefixed with LSCM3 is installed.
name: Specifies the name of an AON node, a string of 1 to 31 characters.
verbose: Displays detailed information about AON nodes. If you do not specify this keyword, the command displays brief information about AON nodes.
# Display brief information about AON nodes.
<Sysname> display smartmc light-unit
ID   SN            MAC address     Status   Version match  Name
1    1273712783123 201c-e7c3-0300  Normal   NO             S1
ID
ID of the AON node.
SN
Serial number of the AON node.
MAC address
MAC address of the AON node.
Status
Running status of the AON node:
·     Normal—The AON node is online.
·     Registering—The AON node is registering a CoAP channel with the AON aggregation (also called iOptic host).
·     Channel Ready—The CoAP channel has been created.
·     Smoothing—The AON node is synchronizing configuration from the AON aggregation.
·     Updating—The AON node is upgrading the software.
·     Offline—The AON node is offline.
Version match
Whether the AON node software version matches the AON aggregation:
·     YES—Match.
·     NO—Not match.
·     UNKNOWN—The product does not support version verification.
Name
Name of the AON node.
# Display detailed information about AON node 1.
<Sysname> display smartmc light-unit 1 verbose
Description           : LU_for_office
Status                : Offline
SN                    : 12312312231
MAC address           : 00e0-4c00-0000
IP address            : 172.16.0.1
Boot image version    : 1.0524.0
System image version  : ES4200 B02 V1.2.2
PoE image version     : 1.0524.0
Uptime                : 2 days, 3 hours, 4 minutes
Version match         : YES
ID
ID of the AON node.
Name
Description of the AON node.
Status
·     Registering—The AON node is registering a CoAP channel with the AON aggregation.
SN
MAC address
IP address
IP address of the AON node.
Boot image version
Version of the boot software package running on the AON node.
Version of the system software package running on the AON node.
PoE image version
Version of the PoE firmware running on the AON node.
Uptime
Uptime of the AON node.
Version match
·     YES—Match.
·     NO—Not match.
display smartmc light-unit configuration history
Use display smartmc light-unit configuration history to display the configuration deployed from the AON aggregation to AON nodes.
Application scenarios
The AON aggregation (the device) incorporates AON nodes that have registered with it. After you configure AON nodes on the AON aggregation, the AON aggregation deploys the configuration to the AON nodes. Execute this command on the AON aggregation to display the configuration deployed to the AON nodes.
The Command field in the command output displays only the keywords in the deployed commands, and does not display the parameters in the commands. The commands can be in do or undo form.
# Display the configuration deployed from the AON aggregation to AON nodes.
<Sysname> display smartmc light-unit configuration history
RecordTime           ID      Command            Operation  Result
2023-07-03 10:20:04  1       port hybrid pvid   Merge      Succeed
2023-07-03 10:19:23  2       vlan mode          Merge      Failed
2023-07-03 10:18:45  2       isolate            Merge      Succeed
2023-07-03 09:58:03  1       port hybrid vlan   Replace    Failed
2023-07-03 09:58:03  1       shutdown           Replace    Failed
RecordTime
Time when the configuration was deployed.
ID
ID of an AON node.
Keywords in the command deployed to the AON node. The command can be in do or undo form.
Operation
Action performed by the configuration:
·     Merge—Merge the existing configuration.
·     Replace—Replace the existing configuration.
Result
Configuration deployment result:
·     Succeed.
·     Failed.
·     Waiting—The configuration is being deployed and the result is unknown.
display smartmc light-unit poe
Use display smartmc light-unit poe to display information about the PoE power supply status of an AON node.
display smartmc light-unit { id | name name } poe
name name: Specifies the name of an AON node, a string of 1 to 31 characters.
# Display information about the PoE power supply status of AON node 1.
<Sysname> display smartmc light-unit 1 poe
PoE information :
 PoE Current Power                  : 1870   mW
 PoE Remaining Power                : 1000   mW
 PoE Peak Power                     : 2350   mW
 PoE Max Power                      : 2000   mW
 PoE Current Voltage                : 24.00  mV
 PSE reset times                    : 0
 PoE failure                        : NO
PoE Current Power
Current PoE power, in milliwatts.
PoE Remaining Power
Available PoE power, in milliwatts.
PoE Peak Power
Peak PoE power, in milliwatts.
PoE Max Power
Maximum PoE power, in milliwatts.
PoE Current Voltage
Current PoE voltage, in millivolts.
PoE reset times
Number of PSE chip resets.
PoE failure
Whether the PoE firmware has anomalies:
·     NO.
·     YES.
display smartmc light-unit poe port
Use display smartmc light-unit poe port to display power supply information for PIs on an AON node.
display smartmc light-unit { id | name name } poe port [ port-id ]
port-id: Specifies an interface ID. The value range for this argument is 1 to 34.
# Display power supply information for PIs on AON node 1.
<Sysname> display smartmc light-unit 1 poe port
PoE information of Port 1:
 PoE Status                        : Enabled
 PD class                          : High
 Detection Status                  : Delivering power
 Power-up mode                     : af
 Reference power                   : 10234  mW
 Current Power                     : 11592  mW
 Average Power                     : 11610  mW
 Peak Power                        : 11684  mW
 Electric Current                  : 244    mA
 Power Voltage                     : 51.7   mV
 PoE force power Status            : Disabled
PoE information of Port 2:
PD class                          : High
 Power Priority                    : Critical
 Power-up mode                     : af
Table 5 Command output
Power supply information for a PI on the AON node.
PoE Status
PoE status:
·     Enabled.
·     Disabled.
PD class
Power supply priority:
·     High.
·     Medium.
·     Low.
Detection Status
Power detection status:
·     Disabled—PoE is disabled.
·     Searching—The PI is searching for the PD.
·     Delivering power—The PI is supplying power for the PD.
·     Fault—A fault occurred during the test.
·     Test—The PI is undergoing a test.
·     Other fault—A fault has caused the PSE to enter idle status.
·     PD disconnected—The PD is disconnected.
Power-up mode
Power supply mode:
·     NONE—The PI is not supplying power.
·     AF—802.3af (PoE) mode.
·     AT—802.3at (PoE+) mode.
Reference power
Reference power, in milliwatts.
Current Power
Current power in milliwatts, including PD consumption power and transmission loss.
Average Power
Average power, in milliwatts.
Peak Power
Peak power, in milliwatts.
Electric Current
Current electric current, in milliamps.
Power Voltage
Current voltage, in millivolts.
Enabling status of forced power supply:
·     Enabled.
·     Disabled.
display smartmc light-unit port
Use display smartmc light-unit port to display information about interfaces on an AON node.
display smartmc light-unit { id | name name } port [ port-id | brief | uplink ]
uplink: Displays information about the uplink aggregate interface on the AON node.
# Display brief information about all interfaces on AON node 1.
<Sysname> display smartmc light-unit 1 port brief
Link: ADM - administratively down;
Speed: (a) - auto
Interface       Link  Speed     Duplex Type PVID Uplink
Port 1          UP    1G(a)     F(a)   A    1    No
Port 2          DOWN  1G(a)     F(a)   A    1    No
Port 3          ADM   1G(a)     F(a)   A    1    Yes
Table 6 Command output
Brief information about Layer 2 interfaces.
Physical link state of the interface: ADM. The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
Speed: (a) - auto
Speed of the interface.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
Link type of the interface:
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     BLOCK—The interface is in blocked state and cannot receive any packets. The loop detection feature on the AON node detected a loop on the interface and blocked the interface. The interface will restore to normal state after you check the physical connection of the AON node and remove the loop.
Speed
Speed of the interface, in Mbps:
·     Auto.
·     10.
·     100.
·     200.
·     1000.
·     2000.
·     2500.
·     5000.
·     10000.
·     20000.
Duplex
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode.
·     F—Full duplex.
·     H—Half duplex.
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
PVID
Port VLAN ID (PVID) of the interface.
Uplink
Whether the interface is an uplink interface:
·     No.
·     Yes.
# Display detailed information about all interfaces on AON node 1.
Port name: Port 1
Current state: DOWN
Link speed type is autonegotiation, Link duplex type is autonegotiation
PVID: 1
Port link-type: Hybrid
 Tagged VLANs:   None
 Untagged VLANs: 1(default vlan)
Last 60 seconds input : 0 packets/sec 0 bytes/sec
 Last 60 seconds output : 0 packets/sec 0 bytes/sec
 Input (total):  0 packets
         0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses,
         0 jumbos, 0 discards
 Input:  0 input errors, 0 input CRC
 Output (total): 0 packets
 Output: 0 output errors, 0 output CRC
Table 7 Command output
Port name
Interface ID.
Current state
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
XXbps-speed mode
The interface is operating at XX bps. This field depends on your configuration and the link parameter negotiation result.
Unknown-speed mode
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected.
half-duplex mode
The interface is operating in half duplex mode. This field depends on your configuration and the link parameter negotiation result.
full-duplex mode
The interface is operating in full duplex mode. This field depends on your configuration and the link parameter negotiation result.
unknown-duplex mode
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected.
PVID
Port VLAN ID of the interface.
Port link-type
·     access.
·     trunk.
·     hybrid.
Tagged VLANs
VLANs for which the interface sends packets with VLAN tags.
UnTagged VLANs
VLANs for which the interface sends packets without VLAN tags.
Last 60 seconds input : 0 packets/sec 0 bytes/sec -%
 Last 60 seconds output : 0 packets/sec 0 bytes/sec -%
Average inbound or outbound traffic rate (in pps and Bps), and the ratio of the actual rate to the interface bandwidth.
The two fields on the first line represent the inbound traffic statistics (in packets) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcast packets.
·     Number of inbound multicast packets.
·     Number of inbound pause frames.
The two fields on the third line represent:
·     Number of inbound jumbo frames.
·     Number of dropped inbound packets.
A hyphen (-) indicates that the statistical item is not supported.
The number of inbound error packets.
The number of inbound frames that had a normal length, but contained CRC errors.
Outbound traffic statistics (in packets) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
·     Number of outbound unicast packets.
·     Number of outbound broadcast packets.
·     Number of outbound multicast packets.
·     Number of outbound pause frames.
·     Number of outbound jumbo frames.
·     Number of dropped outbound packets.
The number of outbound error packets.
The number of outbound frames that had a normal length, but contained CRC errors.
display smartmc light-unit transceiver
Use display smartmc light-unit transceiver to display key parameters of transceiver modules on an AON node.
display smartmc light-unit { id | name name } transceiver port [ port-id ]
# Display the key parameters of transceiver modules on AON node 1.
<Sysname> display smartmc light-unit 1 transceiver port
Port 1 transceiver information:
  Transfer type                 : 1000_BASE_SX_SFP
  Transfer distance(m)          : 550(50um),270(62.5um)
  Vendor name                   : H3C
  Manufacturing date            : 2023-11-01
  Serial number                 : 213410A0000054000251
    Temp.(C)   Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36         3.31        6.13      -35.64          -5.19
  Alarm thresholds:
          Temp(C)   Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    High  50         3.55        1.44      -10.00         5.00
    Low   30         3.01        1.01      -30.00         0.00
  Warning thresholds:
           RX power(dBM)  TX power(dBM)
    High   -15.00         4.00
    Low    -25.00         1.00
Table 8 Command output
Transceiver type
Transceiver module model.
Transfer distance(xx)
Transmission distance, where xx indicates the distance unit:
·     km—Kilometers, for single-mode transceiver modules.
·     m—Meters, for other transceiver modules.
If the transceiver module supports multiple types of transmission media, this field displays the transmission distances for all the types, which are separated by commas. The corresponding transmission medium is enclosed in the brackets following the transmission distance value. Available transmission media:
·     9um—9/125 µm single-mode fiber (SMF).
·     50um—50/125 µm OM2 multimode fiber (MMF).
·     62.5um—62.5/125 µm OM1 MMF.
·     CX4—CX4 cable.
·     OM3—50 µm OM3 MMF.
·     OM4—50 µm OM4 MMF.
·     OM5—50 µm OM5 MMF.
·     STACK—Stack cable.
·     TP—Twisted pair cable.
Vendor name
Name of the vendor.
Manufacturing date
Manufacturing date of the transceiver module.
Serial number
Serial number of the transceiver module.
Temp.(C)
Temperature in Celsius degrees, accurate to 1°C.
Voltage(V)
Voltage in volts, accurate to 0.01 V.
Bias(mA)
Bias current in milli-amperes, accurate to 0.01 mA.
RX power(dBm)
Receive power in dBm, accurate to 0.01 dBm.
TX power(dBm)
Transmit power in dBm, accurate to 0.01 dBm.
High
Upper alarm threshold or upper warning threshold.
Low
Lower alarm threshold or lower warning threshold.
display smartmc light-unit upgrade-info
Use display smartmc light-unit upgrade-info to display upgrade information about an AON node.
display smartmc light-unit { id | name name } upgrade-info
# Display upgrade information about AON node 1.
<Sysname> display smartmc light-unit 1 upgrade-info
Auto upgrade : Enabled
ID    IP address        MAC address     Status      Update time       Update file
1     192.168.56.1      82dd-a434-0200  Finished    Immediately       bootloader.ipe
2     192.168.56.103    5caf-2e5f-0100  Finished    Immediately       bootloader.ipe
Table 9 Command output
Auto upgrade
Enabling status of automatic upgrade:
·     Enabled.
·     Disabled.
ID
ID of the AON node.
MacAddress
IpAddress
Status
Upgrade state:
·     Waiting—The AON node is waiting for downloading the upgrade file.
·     Download-failed—The AON node failed to download the upgrade file.
·     Download-finished—The AON node has downloaded the upgrade file.
·     Downloading—The AON node is downloading the upgrade file.
·     Updating—The AON node is upgrading.
·     Finished—The AON node has finished upgrading.
·     Failed—The AON node failed to upgrade.
·     Unknown—The upgrade state of the AON node is unknown.
UpdateFile
Name of the upgrade file.
UpdateTime
Upgrade time:
·     Immediately—Upgrade at once.
·     Delay(m)—Upgrade after the specified delay.
·     Time(HH:MM)—Upgrade at the specified time.
isolate enable
Use isolate enable to enable interface isolation for an AON node.
Use undo isolate enable to disable interface isolation for an AON node.
isolate enable
undo isolate enable
Interface isolation is disabled for an AON node.
AON node view
This feature prevents the endpoints connected to an AON node from accessing each other at Layer 2 to enhance LAN security.
Operating mechanism
By default, all interfaces on an AON node belong to the same VLAN and the endpoints connected to the interfaces can access each other at Layer 2.
This feature isolates the interfaces on an AON node and enables the endpoints connected to the AON node to forward packets through the AON aggregation. This allows you to manage the traffic of AON nodes on the AON aggregation, which enhances LAN security.
# Enable interface isolation for AON node 1.
[Sysname-lu-1] isolate enable
loopback-test internal
Use loopback-test internal to perform an internal loopback test for an interface of an AON node.
loopback-test internal port port-id
AON node view
Use this feature to identify whether the interfaces on an AON node can forward packets correctly.
Operating mechanism
After you configure this feature on an interface of an AON node, the interface returns the packets to be forwarded to the device, allowing the packets to loop through the internal line. Then, you can identify whether the Ethernet forwarding path within the device can operate correctly.
# Perform an internal loopback test for interface 1 of AON node 1. The interface passed the test.
[Sysname-lu-1] loopback-test internal port 1
Loopback test passed.
# Perform an internal loopback test for interface 3 of AON node 1. The interface failed the test.
[Sysname-lu-1] loopback-test internal port 3
Loopback test failed.
name
Use name to configure a name for an AON node.
Use undo name to delete the name of an AON node.
name sysname
undo name
The AON aggregation uses the MAC address of an AON node as its name.
AON node view
sysname: Specifies the name of an AON node, a string of 1 to 31 characters.
In the AON Ethernet system, each AON node is uniquely identified by its ID. However, the AON node ID, a string of digits, is difficult to remember. To resolve such an issue, you can configure a name for each AON node for easier management.
To enter the configuration view of an AON node, configure a name for that AON node and then execute the smartmc light-unit name name command.
Restrictions and Guidelines
Do not configure the name of an AON node as the MAC address of another AON node.
# Configure the name of AON node 1 as fortest.
[Sysname-lu-1] name fortest
poe enable
Use poe enable to enable PoE for PIs on an AON node.
Use undo poe enable to disable PoE for PIs on an AON node.
poe enable port port-id-list
undo poe enable port port-id-list
PoE is enabled for PIs on an AON node.
AON node view
port port-id-list: Specifies a list of up to 10 PI items. Each item specifies a PI ID or a range of PI IDs in the form of port-id1 to port-id2. The value for the port-id2 argument cannot be lower than the value for the port-id1 argument. The value range for PI IDs is 1 to 34.
Enabled with PoE, the PIs on an AON node can provide PoE power for PDs if they support PoE output.
# Enable PoE for PI 1 on AON node 1.
[Sysname-lu-1] poe enable port 1
poe force-power
Use poe force-power to enable forced PoE power supply for PIs on an AON node.
Use undo poe force-power to disable forced PoE power supply for PIs on an AON node.
poe force-power port port-id-list
undo poe force-power port port-id-list
Forced PoE power supply is disabled on PIs of an AON node.
AON node view
CAUTION
CAUTION:
This command enables an AON node to supply power to a PD directly without performing a detection of the PD. To avoid damaging the PD, make sure the power provided by the AON node meets the PD specifications before executing this command.
Before supplying power to a PD, an AON node performs a detection of the PD by default. It supplies power to the PD only after the PD passes the detection. If the PD fails the detection but the power provided by the AON node meets the PD specifications, you can execute this command to enable forced power supply to the PD.
# Enable forced PoE power supply for PI 1 on AON node 1.
[Sysname-lu-1] poe force-power port 1
poe standard
Use poe standard to specify a PoE standard for PIs on an AON node.
Use undo poe standard to restore the default.
poe standard { af | at } port port-id-list
undo poe standard port port-id-list
The IEEE 802.3af standard is used.
AON node view
af: Specifies the IEEE 802.3af standard.
at: Specifies the IEEE 802.3at standard.
Operating mechanism
IEEE released 802.3af (PoE) and 802.3at (PoE+) standards in chronological sequence. The standards are backward compatible but forwards incompatible. Before supplying power to a PD, a PI will detect the PD, determine the power class for the PD based on its power requirement, and supply power to the PD based on the power class.
·     802.3af—Defines four power classes 0 to 3 and provides a maximum power of 12.95 W.
·     802.3at—Adds class 4 in addition to the four power classes defined by 802.3af and provides a maximum power of 25.5 W.
Specify a PoE standard based on the power requirement of the PD. If the maximum power allowed by the standard is less than that required by the PD, the PI will not supply power to the PD.
# Specify the PoE standard as IEEE 802.3af for PI 1 on AON node 1.
[Sysname-lu-1] poe standard af port 1
port hybrid pvid
Use port hybrid pvid to set the PVID of hybrid interfaces on an AON node.
Use undo port hybrid pvid to restore the default.
port { uplink | port-id-list } * hybrid pvid vlan vlan-id
undo port { uplink | port-id-list } * hybrid pvid vlan
The interfaces on an AON node do not check VLAN information for packets and transparently transmit all the packets.
AON node view
uplink: Specifies the uplink aggregate interface.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
Operating mechanism
An AON node uses a physical interface as the uplink interface to connect to an AON aggregation. For AON nodes that have two uplink interfaces, they can aggregate the two interfaces automatically. Support for auto uplink interface aggregation depends on the model and software version of AON nodes. An AON aggregation can automatically identify whether an AON node supports uplink interface aggregation. Use the uplink keyword or port-id-list argument as prompted.
·     For AON nodes that aggregate uplink interfaces automatically, the two uplink interfaces operate as follows:
¡     In versions earlier than a specific version, the two interfaces back up each other, but only one interface is active for packet forwarding at the same time. In this case, the uplink keyword is not supported. Use the port-id-list argument when you configure VLANs for AON nodes.
¡     In a specific version and later versions, the two interfaces back up each other, and can forward traffic at the same time for load balancing. In this case, use the uplink keyword when you configure VLANs for AON nodes. To avoid configuration failures, do not use the port-id-list argument.
-     If you upgrade a device from a version that does not support the uplink keyword to a version that supports the uplink keyword, the port-id-list configuration in the configuration file still takes effect for backward compatibility.
-     If you downgrade a device from a version that supports the uplink keyword to a version that does not support the uplink keyword, and then upgrade the device back to a version that supports the keyword, the configuration file of the device contains both the uplink and port-id-list configurations. In this case, the uplink configuration takes effect.
For information about the version from which an AON node supports uplink interface aggregation, see the documentation for the AON node.
·     For AON nodes that do not support uplink interface aggregation, the two interfaces back up each other, but only one interface is active for packet forwarding at the same time. Use the port-id-list argument when you configure VLANs for AON nodes.
You can use a nonexistent VLAN as the PVID of a hybrid interface. When you delete the PVID of a hybrid interface by using the undo vlan command, the PVID setting of the interface does not change.
This command takes effect on an AON node only when its VLAN mode is manual. The default VLAN mode for an AON node is transparent.
To enable a hybrid interface to transmit packets from its PVID, you must assign the hybrid interface to the PVID by using the port hybrid vlan command.
As a best practice, set the same PVID for a hybrid interface on the AON node and the hybrid interface on the connected AON aggregation.
If you degrade the AON aggregation to a version that does not support this command, delete the command first to avoid any configuration conflict in the future upgrade.
# Set the PVID of PI 1 on AON node 1 to VLAN 100, and assign PI 1 to VLAN 100 as an untagged member.
[Sysname-lu-1] port 1 hybrid pvid vlan 100
[Sysname-lu-1] port 1 hybrid vlan 100 untagged
port hybrid vlan
vlan mode
port hybrid vlan
Use port hybrid vlan to assign hybrid interfaces on an AON node to the specified VLANs.
Use undo port hybrid vlan to remove hybrid interfaces on an AON node from the specified VLANs.
port { uplink | port-id-list } * hybrid vlan vlan-id-list { tagged | untagged }
undo port { uplink | port-id-list } * hybrid vlan vlan-id-list
AON node view
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument cannot be lower than the value for the vlan-id1 argument.
tagged: Configures the interface as a tagged member of the specified VLANs. A tagged member of a VLAN sends packets from the VLAN without removing VLAN tags.
untagged: Configures the interface as an untagged member of the specified VLANs. An untagged member of a VLAN sends packets from the VLAN after removing VLAN tags.
Operating mechanism
A hybrid interface can allow multiple VLANs. If you execute this command multiple times on a hybrid interface, the hybrid interface allows all the specified VLANs.
# Assign PI 1 on AON node 1 to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member.
[Sysname-lu-1] port 1 hybrid vlan 2 4 50 to 100 tagged
port hybrid pvid
vlan mode
reboot
Use reboot to reboot an AON node.
reboot
AON node view
Use this command to reboot an AON node when it is faulty.
# Reboot AON node 1.
[Sysname-lu-1] reboot
This command will reboot the light unit. Continue? [Y/N]:y
Now rebooting light unit 1
Reboot light unit success.
reset smartmc light-unit configuration history
Use reset smartmc light-unit configuration history to clear the configuration deployed from the AON aggregation to AON nodes.
Use this command to clear the deployed configuration for the AON aggregation to record new configuration.
# Clear the configuration deployed from the AON aggregation to AON nodes.
[Sysname] reset smartmc light-unit configuration history
restart poe port
Use restart poe port to restart PoE on PIs of an AON node.
restart poe port port-id-list
AON node view
When an AON node has a PoE power supply issue, you can use this command to restart PoE to resolve the issue.
# Restart PoE on PI 1 of AON node 1.
[Sysname-lu-1] restart poe port 1
shutdown
Use shutdown to shut down interfaces on an AON node.
Use undo shutdown to bring up interfaces on an AON node.
shutdown port port-id-list
undo shutdown port port-id-list
The interfaces on an AON node are up.
AON node view
CAUTION
CAUTION:
Executing the shutdown command disconnects the links of the specified interfaces and interrupts communication. Use this command with caution.
Some interface settings might require an interface restart before they can take effect.
The AON Ethernet system automatically discovers and records the uplink interfaces of AON nodes. Do not use this command to shut down the uplink interfaces of AON nodes.
# Bring up interface 1 on AON node 1.
[Sysname-lu-1] undo shutdown port 1
smartmc auto-upgrade enable
Use smartmc auto-upgrade enable to enable automatic upgrade for AON nodes.
Use undo smartmc auto-upgrade enable to disable automatic upgrade for AON nodes.
Automatic upgrade is disabled for AON nodes.
Operating mechanism
Configured with this feature, the AON aggregation automatically identifies whether the software version of an onboarding AON node is compatible with its own. If they are not compatible, the AON node software is automatically upgraded.
1.     Execute the display version command on the AON aggregation to obtain its running software version.
2.     Obtain the most recent software version of the AON nodes that is compatible with the AON aggregation software version based on the release notes of the AON aggregation.
3.     Upload the startup software package of the AON nodes to the AON aggregation. For the automatic upgrade feature to take effect, make sure the AON aggregation has the startup software package of the AON nodes.
In a distributed deployment scenario, you must also upload the target AON node version to the AON aggregation.
If you do not enable this feature and the AON node software version is incompatible with that of the AON aggregation, an AON node can still come online and forward packets. To avoid affecting AON node management on the AON aggregation, upgrade the AON node immediately.
# Enable automatic upgrade for AON nodes.
[Sysname] smartmc auto-upgrade enable
smartmc bind tc
Use smartmc bind tc to bind an AON node ID to an AON node.
Use undo smartmc bind tc to unbind an AON node ID from an AON node.
smartmc bind tc tc-id mac-address mac-address
undo smartmc bind tc tc-id
An AON node ID is not bound to an AON node.
tc tc-id: Specifies an AON node ID. The value range for this argument is 1 to 63 when an MPU prefixed with LSCM1 is installed, 1 to 127 when an MPU prefixed with LSCM2 is installed, and 1 to 511 when an MPU prefixed with LSCM3 is installed.
mac-address mac-address: Specifies a MAC address in the format of H-H-H.
When an AON node registers with the AON aggregation, the AON aggregation automatically allocates an ID to that AON node. In the AON Ethernet system, this ID uniquely identifies that AON node. Then, the AON aggregation automatically generates this command to record the mappings between the ID and the MAC address of the AON node. This command is used for the AON Ethernet system within the device, which is not configurable.
smartmc enable
Use smartmc enable to enable SmartMC for the AON aggregation.
Use undo smartmc enable to disable SmartMC for the AON aggregation.
smartmc tm username username password { cipher | simple } string enable
undo smartmc enable
SmartMC is disabled for the AON aggregation.
Operating mechanism
An AON aggregation and its connected AON nodes form an AON Ethernet system. The members in the AON Ethernet system discover each other at Layer 2 through SmartMC. In this way, the AON Ethernet system is also a SmartMC network. With this feature configured, the AON aggregation acts as the topology master (TM), and the AON nodes act as topology clients (TCs). Enabled with the AON node mode, an AON node is automatically enabled with SmartMC and operates as a TC. In the AON Ethernet system, you only need to enable the AON node mode on AON nodes and no other settings are required for them. For information about the factory default mode of an AON node, see its product documentation. For more information about SmartMC, see Network Management and Monitoring Configuration Guide.
An AON aggregation supports both the SmartMC and AON Ethernet system features. For information about configuring a pure SmartMC network, see Network Management and Monitoring Configuration Guide. For information about configuring an AON Ethernet, see the configuration guide. Do not deploy both networks on an AON aggregation. An AON aggregation broadcasts scanning packets to discover TCs and determines the network type based on the type of the first TC that responds to the scanning packet.
A SmartMC network can have only one management device.
Changing the management device to a member device or disabling SmartMC for the management device clears the running configuration related to SmartMC.
The SmartMC feature consumes certain ACL resources. If the ACL resources are insufficient, SmartMC will fail to be enabled. To resolve such an issue, perform the following tasks:
1.     Obtain the ACL configuration and running status by using the display acl command.
2.     Delete unnecessary ACLs by using the undo acl command as required.
3.     Enable SmartMC again.
For more information about ACL, see ACL and QoS Configuration Guide.
When you enable SmartMC, the device identifies whether HTTP port 80, HTTPS port 443, and CoAP port 5683 are in use. If any of these ports is occupied, SmartMC will fail to be enabled.
If you execute this command multiple times, the most recent configuration takes effect. You can use the smartmc enable command to enable SmartMC on an AON Ethernet or SmartMC network. The SmartMC network requires a username and password, but the AON Ethernet does not.
# Enable SmartMC for the AON aggregation.
[Sysname] smartmc tm username test password simple hello12345 enable
smartmc light-unit
Use smartmc light-unit to enter the view of an AON node.
Use undo smartmc light-unit to delete an AON node.
undo smartmc light-unit { id | name name }
id: Specifies an AON node by its ID. An AON node is uniquely identified by its ID. The value range for this argument is 1 to 63 when an MPU prefixed with LSCM1 is installed, 1 to 127 when an MPU prefixed with LSCM2 is installed, and 1 to 511 when an MPU prefixed with LSCM3 is installed.
name name: Specifies an AON node by its name, a string of 1 to 31 characters.
Use this feature to configure the parameters, such as the name, description, interface VLANs, and PoE settings of an AON node.
Operating mechanism
The AON aggregation automatically allocates IDs to AON nodes as follows:
1.     Enabled with SmartMC, the AON aggregation automatically broadcasts a discovery packet to discover AON nodes.
2.     Upon receiving the discovery packets, the AON nodes automatically register with the AON aggregation.
3.     The AON aggregation automatically allocates an ID to each AON node. An AON node has only one ID and is uniquely identified by it. The AON aggregation can manage AON nodes.
To view the mappings between AON nodes and their IDs, use the display smartmc light-unit command.
You can enter the view of an AON node by using its ID to configure its name. Then, you can enter the view of the AON node by either its ID or name to configure its description, interface VLANs, and PoE settings.
You can enter the view of an AON node only when the AON node is in normal state.
When an AON node is in idle or offline state, you can delete it by using the undo smartmc light-unit command.
# Enter the view of AON node 1.
[Syaname-lu-1]
smartmc management-vlan
Use smartmc management-vlan to configure the SmartMC management VLAN.
Use undo smartmc management-vlan to restore the default.
smartmc management-vlan vlan-id
The SmartMC management VLAN is VLAN 1.
vlan-id: Specifies the SmartMC management VLAN ID, in the range of 1 to 4094. Before you specify a VLAN as the SmartMC management VLAN, create that VLAN.
Use the SmartMC management VLAN to separate the management packets from other service packets in the AON Ethernet system.
Operating mechanism
An AON Ethernet system is set up as follows:
1.     Enabled with SmartMC, the AON aggregation broadcasts a SmartMC scanning packet to discover AON nodes. Upon receiving the scanning packet, an AON node sends a response to register with the AON aggregation.
2.     If the SmartMC management VLAN is configured, the AON aggregation establishes the CoAP session with the AON node in the SmartMC management VLAN.
3.     By default, the AON aggregation actively establishes a CoAP session (management channel) with the AON node in VLAN 1.
4.     The AON aggregation sends a successful registration packet to the AON node and the AON node joins the AON Ethernet system.
The SmartMC management VLAN is dedicated to transmitting protocol packets for the AON Ethernet system management plane. Broadcast packets are restricted within the management VLAN, effectively separating protocol packets on the AON Ethernet system management plane from the service packets and other protocol packets. This facilitates the construction and maintenance of the AON Ethernet and enhances its security.
When the device runs as a SmartMC TC, the system automatically deletes this configuration.
To modify the SmartMC management VLAN, make sure SmartMC is disabled. If you modify the SmartMC management VLAN when SmartMC is enabled, the modification does not take effect. For the modification to take effect, first disable SmartMC and enable SmartMC again.
This command is supported only when the device acts as an AON aggregation. When the device also acts as the TM in a SmartMC network, if you change the SmartMC management VLAN to a VLAN other than VLAN 1, TCs cannot come online.
# Configure the SmartMC management VLAN as VLAN 2.
[Sysname] smartmc management-vlan 2
vlan mode
Use vlan mode to specify the VLAN mode for an AON node.
Use undo vlan mode to restore the default.
vlan mode { manual | transparent }
undo vlan mode
The VLAN mode for an AON node is transparent.
AON node view
manual: Specifies the manual mode. In this mode, you can edit the VLAN settings of an interface. By default, an interface uses PVID VLAN 1, which is added to the permitted VLAN list of the interface as an untagged member.
transparent: Specifies the transparent mode.
Operating mechanism
An AON node supports the following VLAN modes:
·     Transparent mode—In this mode, the AON node forwards packets based on the destination MAC address no matter whether service packets carry the VLAN tag or their VLAN IDs or not. In transparent mode, you cannot edit the VLAN settings of interfaces on the AON node. To configure VLANs based on MAC addresses or subnets for service packets, perform the configuration on the interface that connects the AON aggregation to the AON node.
·     Manual mode—In this mode, an interface operates in hybrid mode and VLANs are configured based on interfaces. After you switch the VLAN mode to manual, the interface uses PVID VLAN 1, which is added to the permitted VLAN list of the interface as an untagged member. To change the PVID of the interface, use the port hybrid pvid command. To assign the interface to specified VLANs, use the port hybrid vlan command.
In transparent mode, user traffic cannot be isolated based on VLANs on an AON node. To isolate user traffic, configure the interface isolation feature for the AON node or isolate user traffic on the AON aggregation.
# Configure the VLAN mode for AON node 1 as manual.
[Sysname-lu-1] vlan mode manual
# Configure the VLAN mode for AON node 1 as transparent.
[Sysname-lu-1] vlan mode transparent
This operation will clear the VLAN configuration of the remote-unit. Continue? [Y/N]:y
isolate enable
port hybrid pvid
port hybrid vlan
