- 13-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-NTP commands
- 05-PTP commands
- 06-Network synchronization commands
- 07-PoE commands
- 08-SNMP commands
- 09-RMON commands
- 10-SmartMC commands
- 11-AON Ethernet system commands
- 12-EPA commands
- 13-ONVIF commands
- 14-CWMP commands
- 15-EAA commands
- 16-Process monitoring and maintenance commands
- 17-Sampler commands
- 18-NetStream commands
- 19-IPv6 NetStream commands
- 20-sFlow commands
- 21-Information center commands
- 22-GOLD commands
- 23-Packet capture commands
- 24-VCF fabric commands
- 25-Cloud connection commands
- 26-eMDI commands
- 27-SQA commands
- 28-Performance management commands
- 29-TCP connection trace commands
- 30-NetAnalysis commands
- 31-NETCONF commands
- 32-Mirroring commands
07-PoE commands | 274.14 KB |
PoE commands
Only the LSCM2GV48SC0, LSCM2GV48SD0, and LSCM2YSV16TSV32SD0 interface module support PoE.
apply poe-profile
Use apply poe-profile to apply a PoE profile to a power interface (PI).
Use undo apply poe-profile to restore the default.
apply poe-profile { index index | name profile-name }
undo apply poe-profile { index index | name profile-name }
No PoE profile is applied to PIs.
PI view
index index: Specifies a PoE profile by its index number in the range of 1 to 100.
name profile-name: Specifies a PoE profile by its name, a case-sensitive string of 1 to 15 characters.
# Apply the PoE profile named forIPphone to Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] apply poe-profile name forIPphone
apply poe-profile interface
display poe-profile
Use apply poe-profile interface to apply a PoE profile to PIs.
Use undo apply poe-profile interface to remove the PoE profile application from PIs.
apply poe-profile { index index | name profile-name } interface interface-range
undo apply poe-profile { index index | name profile-name } interface interface-range
No PoE profile is applied to a PI.
interface-range: Specifies a range of Ethernet interfaces in the form of interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number represents the interface type and interface number. The start interface number must be smaller than the end interface number. If an interface in the specified range does not support PoE, it is ignored when the PoE profile is applied.
[Sysname] apply poe-profile name forIPphone interface ten-gigabitethernet 3/0/1
# Apply the PoE profile with index number 1 to PIs Ten-GigabitEthernet 3/0/2 to Ten-GigabitEthernet 3/0/6.
[Sysname] apply poe-profile index 1 interface ten-gigabitethernet 3/0/2 to ten-gigabitethernet 3/0/6
apply poe-profile
display poe-profile interface
display poe device
Use display poe device to display brief PSE information.
In standalone mode:
display poe device [ slot slot-number ]
In IRF mode:
display poe device [ chassis chassis-number [ slot slot-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays brief PSE information for all MPUs. (In standalone mode.)
chassis chassis-number [ slot slot-number ]: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify an IRF member device, this command displays brief PSE information for all MPUs. If you specify an IRF member device but does not specify a card, this command displays brief PSE information for all MPUs on the IRF member device. (In IRF mode.)
Only the default MDC supports this command.
# Display brief PSE information.
<Sysname> display poe device
Chassis 1:
PSE ID Slot No. SSlot No. PortNum MaxPower(W) State Model
1 0 0 48 1440.0 On LSCM2GV48SC0
PSE ID |
ID of the PSE. |
Slot No. |
Slot number of the PSE. |
SSlot No. |
Sub-slot number of the PSE. |
PortNum |
Number of PIs on the PSE. |
MaxPower(W) |
Maximum power of the PSE. |
State |
PSE status: · On—The PSE is supplying power. · Off—The PSE is not supplying power. · Faulty—The PSE has failed. |
Model |
PSE model. |
display poe interface
Use display poe interface to display power supplying information for PIs.
display poe interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power supplying information for all PIs.
# Display power supplying information for Ten-GigabitEthernet 3/0/1.
<Sysname> display poe interface ten-gigabitethernet 3/0/1
PoE Status : Enabled
Power Priority : Low
Oper : Off
IEEE Class : 0
Detection Status : Searching
Power Mode : Signal
Current Power : 0 mW
Average Power : 0 mW
Peak Power : 0 mW
Max Power : 30000 mW
Electric Current : 0 mA
Voltage : 0.0 V
PD Description :
Legacy PD Detection : Disabled
PoE force power Status : Disabled
PoE Status |
PoE status: · Enabled. · Disabled. |
Power Priority |
Power supply priority: · Critical (highest). · High. · Low. |
Oper |
Operating status: · Off—PoE is disabled. · On—Power is being supplied to the PI correctly. · Power-lack—Remaining guaranteed power is insufficient for a critical PI. · Power-deny—The PSE refuses to supply power. The power required by the PD is higher than the configured power. · Power-itself—The PD is using another power supply. · Power-limit—The PSE is supplying power to the PD based on the configured power though the PD requires more power than the configured power. |
IEEE Class |
PD power class by which the PI supplies power to the PD. If the PI does not support supplying power to the PD, this field displays a hyphen (-). |
Detection Status |
Power detection status: · Disabled—The PoE function is disabled. · Searching—The PI is searching for the PD. · Delivering power—The PI is supplying power to the PD. · Fault—A fault occurred during the test. · Test—The PI is supplying power forcibly to the PD. · Other fault—A fault has caused the PSE to enter the idle status. · PD disconnected—The PD is disconnected. |
Power Mode |
Power transmission mode: · Signal—Power is transmitted over the signal pairs of a twisted pair cable. · Spare—Power is transmitted over the spare pairs of a twisted pair cable. The device does not support this power transmission mode. |
Current Power |
Current power, including PD consumption power and transmission loss. |
Average Power |
Average power. |
Peak Power |
Peak power. |
Max Power |
Maximum power. |
Electric Current |
Current. |
Voltage |
Voltage. |
PD Description |
Type and location description for the PD connected to the PI. |
Legacy PD Detection |
Whether non-standard PD detection is enabled: · Enabled. · Disabled. |
PoE force power Status |
Whether forced power supply is enabled: · Enabled. · Disabled. |
PD High Inrush |
Whether to allow high inrush current to the PD. · Enabled: Allowed. · Disabled: Disallowed. |
# Display power supplying information for all PIs.
Interface PoE Priority CurPower Oper IEEE Detection
(W) Class Status
XGE3/0/1 Enabled Low 4.4 On 1 Delivering Power
XGE3/0/2 Enabled Critical 0.0 On - Disabled
XGE3/0/3 Enabled Low 0.0 On - Disabled
XGE3/0/4 Enabled Critical 0.0 On - Searching
XGE3/0/5 Enabled Low 4.0 On 2 Delivering Power
XGE3/0/6 Enabled Low 0.0 On - Disabled
XGE3/0/7 Disabled Low 0.0 Off - Fault
--- On State Ports: 2; Used: 8.4(W); Remaining: 0.0(W) ---
Interface name. |
PoE |
Priority |
Power priority: · Critical (highest). · High. · Low. |
CurPower |
Current power. |
Oper |
IEEE Class |
Detection Status |
Power detection status: · Disabled—PoE function is disabled. · Searching—The PI is searching for the PD. · Delivering Power—The PI is supplying power for the PD. · Fault—A fault occurred during the test. · Test—The PI is undergoing a test. · Other fault—A fault has caused the PSE to enter the idle status. · PD disconnected—The PD is disconnected. |
On State Ports |
Number of PIs that are supplying power. |
Used |
Power consumed by the current PI. |
Remaining |
Total remaining power of all PSEs configured with a maximum power. This field displays 0 if no PSE is configured with a maximum power (all PSEs participate in dynamic power allocation). |
display poe interface power
Use display poe interface power to display power information for PIs.
display poe interface power [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power information for all PIs.
# Display power information for Ten-GigabitEthernet 3/0/1.
<Sysname> display poe interface power ten-gigabitethernet 3/0/1
Interface Current Peak Max PD Description
(W) (W) (W)
XGE3/0/1 0.0 0.0 30.0
# Display power information for all PIs.
(W) (W) (W)
XGE3/0/1 4.4 4.5 30.0 IP Phone in Room 309 for Peter Smith
XGE3/0/2 4.4 4.5 30.0 IP Phone in Room 409 for Peter Pan
XGE3/0/3 15.0 15.3 30.0 Access Point in Room 509 for Peter
XGE3/0/4 0.0 0.0 30.0 IP Phone in Room 609 for Peter John
XGE3/0/5 0.0 0.0 30.0 IP Phone in Room 709 for Jack
XGE3/0/6 0.0 0.0 30.0 IP Phone in Room 809 for Alien
--- On State Ports: 3; Used: 23.8(W); Remaining: 0.0(W) ---
Interface name. |
CurPower |
Current power. |
PeakPower |
Peak power. |
MaxPower |
Maximum power. |
PD Description |
Type and location description for the PD connected to a PI. |
On State Ports |
Used |
Power consumed by all PIs. |
Remaining |
display poe power-usage
Use display poe power-usage to display power usage statistics for PoE power supplies and PSEs.
In standalone mode:
In IRF mode:
display poe power-usage [ chassis chassis-number ]
chassis chassis-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays information about all PoE power supplies and PSEs in the IRF fabric. (In IRF mode.)
# Display power usage statistics for the PoE power supply and all PSEs.
<Sysname> display poe power-usage
Chassis 1:
PoE Current Power : 257 W
PoE Max Power : 6700 W
PoE Max Guaranteed Power : 6700 W
PoE Remaining Allocable Power : 6389 W
PoE Remaining Guaranteed Power : 6610 W
Powered PoE Ports : 11
Statistics by PSE:
PSE ID Max Current Peak Average Remaining Powered
(W) (W) (W) (W) Guaranteed(W) Ports
1 1440.0 59.8 68.3 59.8 70.7 3
4 1440.0 0.0 49.5 0.0 37.0 0
7 1440.0 74.4 74.7 74.4 120.0 3
16 1440.0 49.0 49.4 49.0 90.0 2
19 1440.0 49.7 49.9 49.7 90.0 2
22 1440.0 25.0 49.9 25.0 60.0 1
Table 5 Command output
PoE Current Power |
Total power that has been consumed by PSEs. |
PoE Max Power |
Maximum PoE power. |
PoE Max Guaranteed Power |
Maximum power that can be supplied to critical PSEs. Typically, the maximum guaranteed PoE power is equal to the maximum PoE power. |
PoE Mandatory Guaranteed Power |
Mandatory guaranteed PoE power, which is the power used by cards in Fault state. If the state of a card is Fault, the card might be starting up. |
PoE Remaining Allocable Power |
Remaining allocable PoE power = Maximum PoE power – Mandatory guaranteed power – Total maximum power of all PoE-enabled PSEs. |
PoE Remaining Guaranteed Power |
Remaining guaranteed PoE power = Maximum guaranteed PoE power – Mandatory guaranteed power – Total maximum power of all critical PSEs. |
Powered PoE Ports |
PSE ID |
ID of the PSE. |
Max |
Current |
Current power of the PSE. |
Peak |
Peak power of the PSE. |
Average |
Average power of the PSE. |
Remaining Guaranteed |
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE Typically, the maximum guaranteed PSE power is equal to the maximum PSE power. |
Powered Ports |
Number of PIs that are receiving power from the PSE. |
display poe pse
Use display poe pse to display detailed PSE information.
display poe pse [ pse-id ]
pse-id: Specifies a PSE by its ID. If you do not specify a PSE, this command displays detailed PSE information about all PSEs.
# Display detailed PSE information.
<Sysname> display poe pse
PSE ID : 1
Slot NO. : 1
SSlot NO. : 0
PSE Model : LSCM2GV48SC0
PSE Status : Enabled
PSE Fast Power Supply : Disabled
PSE Preempted : No
Current Power : 59.8 W
Average Power : 59.8 W
Peak Power : 68.3 W
Max Power : 1440.0 W
Remaining Guaranteed Power : 70.7 W
PSE CPLD Version : -
PSE Software Version : 140
PSE Hardware Version : 57649
PSE Legacy PD Detection : Disabled
Power Utilization Threshold : 80
PSE Power Policy : Priority
PD Power Policy : Priority
PD Disconnect-Detection Mode : AC
PD High Inrush : Disabled
Table 6 Command output
PSE ID |
ID of the PSE. |
Slot No. |
SSlot No. |
Sublsot number of the PSE. |
PSE Status |
PoE status of the PSE: · Enabled. · Disabled. |
PSE Fast Power Supply |
Whether PSE fast power supply is enabled: · Enabled. · Disabled. |
Preempted |
Power preemption status for the PSE: · No—The system has sufficient power for the PSE. · Yes—The system has supplied power to other PSEs and does not have sufficient power for this PSE. |
Power Priority |
Power priority of the PSE. |
Current Power |
Average Power |
Peak Power |
Max Power |
Maximum power configured for the PSE. |
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE. |
PSE CPLD Version |
PSE CPLD version number. |
PSE Software Version |
PSE software version number. |
PSE Hardware Version |
PSE hardware version number. |
Nonstandard PD detection status: · Enabled. · Disabled. |
Power Utilization Threshold |
PSE power alarm threshold. |
PSE Power Policy |
PSE power management policy mode. |
PD Power Policy |
PD power management policy mode. |
PD Disconnect-Detection Mode |
PD disconnection detection mode. This field is not supported in the current software version. |
PD High Inrush |
Whether inrush current drawn by PDs is allowed: · Enabled—Allowed. · Disabled—Not allowed. |
display poe pse interface
Use display poe pse interface to display the PoE status of all PIs on a PSE.
display poe pse pse-id interface
pse pse-id: Specifies a PSE ID. To display PSE ID and slot mappings, use the display poe device command.
# Display the status of all PIs on PSE 4.
<Sysname> display poe pse 4 interface
(W) Class Status
XGE3/0/2 Enabled Critical 0.0 Power-lack - Disabled
XGE3/0/3 Enabled Low 0.0 Power-deny - Disabled
XGE3/0/5 Enabled Low 4.0 Power-limit 2 Delivering Power
XGE3/0/6 Enabled Low 0.0 Power-itself - Disabled
--- On State Ports: 2; Used: 8.4(W); Remaining: 0.0 (W) ---
Table 7 Command output
Interface name. |
PoE |
Priority |
Priority: · Critical (highest). · High. · Low. |
CurPower |
Current power. |
Oper |
IEEE Class |
Detection Status |
Power detection status: · Disabled—PoE function is disabled. · Searching—The PI is searching for the PD. · Delivering Power—The PI is supplying power to the PD. · Fault—A fault occurred during the test. · Test—The PI is undergoing a test. · Other Fault—A fault has caused the PSE to enter the idle status. · PD Disconnected—The PD is disconnected. |
On State Ports |
Used |
Power consumed by PIs on the PSE. |
Remaining |
Remaining power of the PSE. This field displays 0 for a PSE that participates in dynamic power allocation. |
display poe pse interface power
Use display poe pse interface power to display power information for PIs on a PSE.
display poe pse pse-id interface power
pse pse-id: Specifies a PSE by its ID. To display PSE ID and slot mappings, use the display poe device command.
# Display power information for PIs on PSE 4.
<Sysname> display poe pse 4 interface power
(W) (W) (W)
XGE3/0/25 4.4 4.5 4.6 IP Phone on Room 309 for Peter Smith
XGE3/0/26 4.4 4.5 15.4 IP Phone on Room 409 for Peter Pan
XGE3/0/27 15.0 15.3 15.4 Access Point on Room 509 for Peter
XGE3/0/28 0.0 0.0 5.0 IP Phone on Room 609 for Peter John
XGE3/0/29 0.0 0.0 4.0 IP Phone on Room 709 for Jack
XGE3/0/30 0.0 0.0 5.0 IP Phone on Room 809 for Alien
Table 8 Command output
Interface name. |
Current |
Current power. |
Peak |
Peak power. |
Max |
Maximum power. |
PD Description |
Type and location description for the PD connected with a PI. |
On State Ports |
Used |
Remaining |
display poe-power
Use display poe-power to display PoE power information.
In standalone mode:
display poe-power
In IRF mode:
display poe-power [ chassis chassis-number ]
# Display PoE power information.
<Sysname> display poe-power
PoE Average Power : 257 W
PoE Peak Power : 257 W
PoE Nominal Power : 6700 W
PoE Current Electric Current : 0.00 A
PoE Current Voltage : 0.00 V
PoE Lower Input Threshold : 90.00 V
PoE Upper Input Threshold : 264.00 V
PoE Lower Output Threshold : 47.00 V
PoE Upper Output Threshold : 55.00 V
PoE Power Supplies : 1
PoE Power Supply 1:
Manufacturer : NONE
Type : NONE
Status : Normal
Table 9 Command output
PoE Current Power |
Current PoE power. |
PoE Average Power |
Average PoE power. |
PoE Peak Power |
Peak PoE power. |
PoE Max Power |
PoE Nominal Power |
Nominal PoE power. |
PoE Current Electric Current |
Current PoE current. |
PoE Current Voltage |
Current PoE voltage. |
PoE Lower Input Threshold |
AC input under-voltage threshold. |
PoE Upper Input Threshold |
AC input over-voltage threshold. |
PoE Lower Output Threshold |
DC output under-voltage threshold. |
PoE Upper Output Threshold |
DC output over-voltage threshold. |
PoE Hardware Version |
PoE hardware version number. |
PoE Software Version |
PoE software version number. |
PoE Power Supplies |
Number of PoE power supply units. |
Manufacturer |
Manufacturer of the PoE power. This field displays NONE if the device cannot obtain manufacturer information. |
Type |
Type of the PoE power. This field displays NONE if the device cannot obtain type information. |
Status |
PoE power status: · Normal—The PoE power supply is operating correctly. · Absent—The PoE power supply is not present. · Off—The PoE power is turned off. · Active—The active PoE power supply is operating correctly. · Standby—The standby PoE power supply is operating correctly. · Balanced—The PoE power supply is operating in load balancing mode. · Redundant—The PoE power supply is operating in redundancy mode. · Alarm—An alarm was triggered. · Faulty—A fault occurred. |
display poe-profile
Use display poe-profile to display information about the PoE profile.
display poe-profile [ index index | name profile-name ]
If you do not specify a profile, the command displays information about all PoE profiles.
# Display information about all PoE profiles.
<Sysname> display poe-profile
PoE Profile Index ApplyNum Interfaces Configuration
forIPphone 1 4 XGE3/0/1 poe enable
XGE3/0/2 poe priority critical
XGE3/0/3
XGE3/0/4
forAP 2 2 XGE3/0/5 poe enable
XGE3/0/6 poe max-power 14000
--- Total PoE profiles: 2, total ports: 6 ---
# Display information about the PoE profile with index number 1.
<Sysname> display poe-profile index 1
forIPphone 1 6 XGE3/0/1 poe enable
XGE3/0/3
XGE3/0/4
XGE3/0/5
XGE3/0/6
--- Total ports: 6 ---
PoE Profile |
Name of the PoE profile. |
Index |
Index number of the PoE profile. |
ApplyNum |
Number of PIs to which the PoE profile is applied. |
Interfaces |
Interface name of the PI to which the PoE configuration is applied. |
Configuration |
Configurations of the PoE profile. |
Total PoE profiles |
Number of PoE profiles. |
Total ports |
Number of PIs to which all PoE profiles are applied. |
Use display poe-profile interface to display information about the PoE profile on a PI.
display poe-profile interface interface-type interface-number
# Display information about the PoE profile on Ten-GigabitEthernet 3/0/1.
<Sysname> display poe-profile interface ten-gigabitethernet 3/0/1
PoEProfile Index ApplyNum Interface Effective configuration
Table 11 Command output
PoE Profile |
Index |
ApplyNum |
Interfaces |
Configuration |
poe detection-mode
Use poe detection-mode to configure the PD detection mode.
Use undo poe detection-mode to restore the default.
poe detection-mode { none | simple | strict }
The PD detection mode is strict.
PI view
none: Enables the device to supply power to PDs that are correctly connected to the device without causing short circuit or open circuit.
simple: Enables the device to supply power to PDs that comply with basic requirements of 802.3af or 802.3at.
strict: Enables the device to supply power to PDs that comply with all requirements of 802.3af or 802.3at.
CAUTION: A non-PD device might be damaged when power is supplied to it. To avoid device damage, do not specify the none keyword when the PI connects to a non-PD device. |
To configure the detection mode for nonstandard PDs, first execute the poe legacy enable command to enable detection for nonstandard PDs.
# Configure the simple detection mode for Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] poe detection-mode simple
poe legacy enable
poe enable
Use poe enable to enable PoE on a PI.
Use undo poe enable to disable PoE on a PI.
poe enable
undo poe enable
PoE is disabled on a PI.
PI view
PoE profile view
If a PoE profile has been applied to a PI, remove the application before configuring the PI in PoE profile view.
If a PI has been configured, remove the configuration before configuring the PI in PI view.
# Enable PoE on a PI in PI view.
[Sysname-Ten-GigabitEthernet3/0/1] poe enable
# Enable PoE on a PI in PoE profile view.
[Sysname] poe-profile abc
[Sysname-poe-profile-abc-1] poe enable
poe-profile
poe enable pse
Use poe enable pse to enable PoE for a PSE.
Use undo poe enable pse to disable PoE for the PSE.
poe enable pse pse-id
undo poe enable pse pse-id
PoE is disabled on PSEs.
# Enable PoE for PSE 4.
[Sysname] poe enable pse 4
display poe pse
poe fast-on enable
Use poe fast-on enable to enable fast PoE for a PSE.
Use undo poe fast-on enable to disable fast PoE for the PSE.
poe fast-on enable pse pse-id
undo poe fast-on enable pse pse-id
Fast PoE is disabled on a PSE. PIs on the PSE supply power to PDs only after the PSE has started up.
Fast PoE enables a PI on a PSE to supply power to PDs immediately after the PSE is powered on.
You must re-configure this command if you modified other PoE settings after configuring this command.
# Enable fast PoE for PSE 4.
[Sysname] poe fast-on enable pse 4
display poe pse
poe force-power
Use poe force-power to enable forced PoE power supply.
Use undo poe force-power to disable forced PoE power supply.
poe force-power
Forced PoE power supply is disabled.
PI view
CAUTION: This command enables the device to supply power to a PD directly without performing a detection of the PD. To avoid damaging the PD, make sure the power provided by the device meets the PD specifications before executing this command. |
Before supplying power to a PD, the device performs a detection of the PD. It supplies power to the PD only after the PD passes the detection. If the PD fails the detection but the power provided by the device meets the PD specifications, you can execute this command to enable forced power supply to the PD.
# Enable forced PoE power supply.
[Sysname-Ten-GigabitEthernet3/0/1] poe force-power
The PD might be damaged if the power provided by the device does not meet the PD power specifications. Continue? [Y/N]:y
poe high-inrush enable
Use poe high-inrush enable to allow inrush current drawn by PDs.
Use undo poe high-inrush enable to restore the default.
poe high-inrush enable pse pse-id
undo poe high-inrush enable pse pse-id
Inrush current drawn by PDs is not allowed.
PI view
CAUTION: Inrush current might damage the device components. Use this command with caution. |
Inrush current might occur at PD startup and trigger PSE self-protection, As a result, the PSE stops supplying power to the PDs. To continue power supply to the PDs, configure this feature to allow inrush current drawn by PDs.
IEEE 802.3af and IEEE 802.3at define specifications for inrush current. The device supports the IEEE 802.3at specifications for inrush current.
# Allow inrush current drawn by PDs.
[Sysname-Ten-GigabitEthernet3/0/1] poe high-inrush enable pse 4
display poe pse
poe legacy enable (interface view)
Use poe legacy enable to enable nonstandard PD detection for a PI.
Use undo poe legacy enable to disable nonstandard PD detection for a PI.
poe legacy enable
Nonstandard PD detection is disabled for a PI.
Interface view
The device supports PSE-based and PI-based nonstandard PD detection. If you enable nonstandard PD detection both in system view and interface view, the configuration in system view takes effect.
As a best practice for disabling nonstandard PD detection for all PIs successfully in one operation, disable this feature in both system view and interface view.
# Enable nonstandard PD detection for a PI.
[Sysname-GigabitEthernet1/0/1] poe legacy enable
poe legacy enable (system view)
Use poe legacy enable to enable the PSE to detect nonstandard PDs.
Use undo poe legacy enable to disable the PSE from detecting nonstandard PDs.
poe legacy enable pse pse-id
undo poe legacy enable pse pse-id
Nonstandard PD detection is disabled.
# Enable PSE 4 to detect nonstandard PDs.
[Sysname] poe legacy enable pse 4
display poe pse
poe max-power
Use poe max-power to set the maximum PI power.
Use undo poe max-power to restore the default.
poe max-power max-power
undo poe max-power
The maximum PI power is 30000 milliwatts.
PI view
PoE profile view
max-power: Sets the maximum PI power in milliwatts. The value range is 1000 to 30000.
# Set the maximum PI power to 12000 milliwatts in PI view.
[Sysname-Ten-GigabitEthernet3/0/1] poe max-power 12000
# Set the maximum PI power to 12000 milliwatts in PoE profile view.
[Sysname-poe-profile-abc-1] poe max-power 12000
poe max-power (system view)
poe power max-value
Use poe max-power to set the maximum PSE power.
poe pse pse-id max-power max-power
undo poe pse pse-id max-power
The maximum PSE power is 1440 W.
max-power: Sets the maximum PSE power in watts. The value is in the range of 37 to 1440.
To avoid the PSE power overload situation, make sure the total power of all PSEs is less than the maximum PoE power.
The maximum power of the PSE must be greater than or equal to the total maximum power of all its critical PIs on the PSE to guarantee these PIs power.
# Set the maximum power of PSE 4 to 150 watts.
[Sysname] poe pse 4 max-power 150
poe max-power (interface view)
poe priority pse
poe mode
Use poe mode to configure a PoE power transmission mode.
Use undo poe mode to restore the default.
poe mode { signal | spare }
undo poe mode
PI view
PoE profile view
signal: Specifies the signal pair transmission mode, which uses signal pairs (pins 1, 2, 3, and 6) of a twisted pair cable to transmit power.
spare: Specifies the spare pair transmission mode, which uses the spare pairs 4, 5, 7, and 8 of the twisted pair cable to transmit power. The device does not support this mode.
# Specify the signal pair power transmission mode in PI view.
[Sysname-Ten-GigabitEthernet3/0/1] poe mode signal
# Specify the signal pair power transmission mode in PoE profile view.
[Sysname-poe-profile-abc-1] poe mode signal
poe-profile
poe pd-description
Use poe pd-description to configure a description for the PD that connects to a PI.
Use undo poe pd-description to restore the default.
poe pd-description text
No description is configured for the PD that connects to a PI.
PI view
text: Configures a description for the PD connected to the PI, a case-sensitive string of 1 to 80 characters.
# Configure the description for the PD as IP Phone for Room 101.
[Sysname-Ten-GigabitEthernet3/0/1] poe pd-description IP Phone For Room 101
poe pd-policy priority
Use poe pd-policy priority to enable PI power management.
Use undo poe pd-policy priority to restore the default.
PI power management is disabled.
If PI power management is disabled, the PSE does not supply power to new PDs when PSE power overload occurs.
If PI power management is enabled, when a PSE is overloaded, the PSE allocates power to PDs based on the priority of their PIs.
# Enable PI power management.
[Sysname] poe pd-policy priority
poe priority
poe power max-value
Use poe power max-value to configure the maximum PoE power.
Use undo poe power max-value to restore the default.
In standalone mode:
poe power max-value max-power
In IRF mode:
poe power chassis chassis-number max-value max-power
undo poe power chassis chassis-number max-value
The maximum PoE power is the total maximum power of all operating power modules in the power frame.
max-power: Sets the maximum PoE power in watts. The value range is 1 to 6700. To accommodate transient peak power surges, the actual maximum power available is 5% higher than the configured maximum power.
chassis chassis-number: Specifies an IRF member by its ID. (In IRF mode.)
The configured maximum PoE power must be smaller than the rated PoE power.
# Set the maximum PoE power to 2000 watts.
[Sysname] poe power max-value 2000
poe power-delay
Use poe power-delay to enable PoE delay.
Use undo poe power-delay to disable PoE delay.
poe power-delay time
PoE delay is disabled.
time: Specifies the delay time in the range of 1 to 3600, in seconds.
By default, the device executes the poe enable command and supplies power to an interface immediately when any one of the following conditions is met:
· The poe enable command is configured.
· The device reboots with the poe enable command in the configuration file.
· The interface comes up and the PoE module resumes PoE power supply to the interface.
The poe power-delay creates a PoE delay timer after the poe enable command is executed and allows the PoE module to supply power to the PI only after the timer expires.
The undo poe enable command is executed immediately upon configuration and is not affected by the poe power-delay command.
# Enable PoE delay and set the delay time to 30 seconds.
[Sysname] poe power-delay 30
poe enable
poe priority (interface view)
Use poe priority to set the power supply priority for a PI.
Use undo poe priority to restore the default.
poe priority { critical | high | low }
undo poe priority
The power supply priority of a PI is low.
PI view
PoE profile view
critical: Sets the power supply priority to critical. The PI with critical power priority operates in guaranteed mode. Power is first supplied to the PD connected to the critical PI.
high: Sets the power supply priority to high.
low: Sets the power supply priority to low.
When the PoE power is insufficient, power is first supplied to PIs with higher priority.
For PIs with same power supply priority, the PI with the smallest ID is allocated with power first.
# Set the power supply priority of the PI to critical in PI view.
[Sysname-Ten-GigabitEthernet3/0/1] poe priority critical
# Set the power supply priority of the PI to critical in PoE profile view.
[Sysname-poe-profile-abc-1] poe priority critical
[Sysname-poe-profile-abc-1] quit
[Sysname-Ten-GigabitEthernet3/0/1] apply poe-profile name abc
poe priority (system view)
Use poe priority to set the power supply priority for a PSE.
poe priority { critical | high | low } pse pse-id
undo poe priority pse pse-id
The power supply priority of a PSE is low.
critical: Sets the power supply priority to critical. The PSE with critical power priority operates in guaranteed mode, and power is supplied to it first.
If PSE power management is disabled, the system does not supply power to new PSEs when PoE power overload occurs.
If PSE power management is enabled, when PSE power overload occurs, the system supplies power to a PSE with higher priority. For multiple PSEs with the same priority, the PSE with a smaller ID gets power supplied first.
For example, if PoE is enabled for a PSE, and the PSE has higher priority, the system performs the following operations:
· Stops supplying power to a PSE with lower priority.
· Supplies power to the PSE that has higher priority.
# Set the power supply priority of PSE 4 to critical.
[Sysname] poe priority critical pse 4
poe pse-policy priority
Use poe pse-policy priority to enable PSE power management.
Use undo poe pse-policy priority to disable PSE power management.
PSE power management is disabled.
If PSE power management is enabled, the system supplies power based on the PSE priority and PSE ID when a new PSE causes PoE power overload.
# Enable PSE power management.
[Sysname] poe pse-policy priority
poe reset enable
Use poe reset enable to enable PI power cycling upon a system warm reboot.
Use undo poe pse-policy priority to disable PI power cycling upon a system warm reboot.
poe reset enable
undo poe reset enable
PI power cycling upon a system warm reboot is disabled.
During the system warm reboot process (upon execution of the reboot command), the PIs continue supplying power to the PDs but data connections between the PDs and the device are interrupted. After the system reboots, PDs might not re-initiate data connections with the device. Power cycling PIs upon a system warm reboot allows the PDs to re-establish data connections with the device.
# Enable PI power cycling upon a system warm reboot.
[Sysname] poe reset enable
poe temperature-protection
Use poe temperature-protection enable to enable PoE over-temperature protection.
Use undo poe temperature-protection enable to disable the feature.
PoE over-temperature protection is enabled.
If PoE over-temperature protection is enabled, the device performs the following operations:
· Disables PoE on all ports when the temperature exceeds the upper limit.
· Disables PoE on all ports when the temperature drops below the lower limit.
# Disable PoE over-temperature protection.
[Sysname] undo poe temperature-protection enable
poe track-shutdown
Use poe track-shutdown to disable PoE on shutdown interfaces.
Use undo poe track-shutdown to restore the default.
poe track-shutdown
PoE is not disabled on shutdown interfaces.
By default, the device continues supplying power to an interface after the interface is shut down by the shutdown command or by an upper layer module such as monitor link. As a result, the PD connected to the shutdown interface operates continuously but fails to access the network.
This command disables the PoE module from supplying power to an interface after the interface is shut down. After the interface comes up, the PoE module resumes power supply to the interface.
The command does not power off an interface that has been shut down but is supplying power to a PD.
# Disable PoE on shutdown interfaces.
[Sysname] poe track-shutdown
poe enable
poe update
Use poe update to upgrade the PSE firmware when the device is operating.
poe update { full | refresh } filename pse pse-id
full: Upgrades the PSE firmware in full mode.
refresh: Upgrades the PSE firmware in refresh mode.
filename: Specifies the name of the upgrade file, a case-insensitive string of 1 to 64 characters. The specified file must be in the root directory of the file system of the device.
pse pse-id: Specifies a PSE by its ID. If you do not specify a PSE, all PSEs are upgraded.
You can upgrade the PSE firmware in service in either of the following modes:
· Refresh mode—Updates the PSE firmware without deleting it. You can use the refresh mode in most cases.
· Full mode—Deletes the current PSE firmware and reloads a new one. Use the full mode if the PSE firmware is damaged and you cannot execute any PoE commands.
# Upgrade the firmware of PSE 4 in service.
[Sysname] poe update refresh POE-168.bin pse 4
This command will refresh the PSE firmware. Continue? [Y/N]:y
poe utilization-threshold
Use poe utilization-threshold to configure a power alarm threshold for the PSE.
Use undo poe utilization-threshold to restore the default power alarm threshold of the PSE.
poe utilization-threshold value pse pse-id
undo poe utilization-threshold pse pse-id
The power alarm threshold for the PSE is 80%.
value: Specifies alarm threshold as a percentage of 1 to 99.
If PSE power usage crosses the threshold multiple times in succession, the system sends notification messages only for the first crossing. For more information, see "Configuring SNMP."
# Set the power alarm threshold of PSE 4 to 90%.
[Sysname] poe utilization-threshold 90 pse 4
poe-profile
Use poe-profile to create a PoE profile and enter its view, or enter the view of an existing PoE profile.
Use undo poe-profile to delete a PoE profile.
poe-profile profile-name [ index ]
undo poe-profile { index index | name profile-name }
No PoE profiles exist.
profile-name: Specifies a PoE profile name, a case-sensitive string of 1 to 15 characters. A PoE configuration file name begins with a letter and must not contain reserved keywords including undo, all, name, interface, user, poe, disable, max-power, mode, priority, or enable.
index: Specifies the index number of a PoE profile, in the range of 1 to 100.
To configure PIs in batches, use the PoE profile.
If you do not specify a profile index, the system automatically assigns an index (starting from 1) to the PoE profile.
If a PoE profile is applied, use the undo apply poe-profile command to remove the application before deleting the PoE profile.
# Create a PoE profile, name it abc, and specify the index number as 3.
[Sysname] poe-profile abc 3
[Sysname-poe-profile-abc-3]
# Create a PoE profile and name it def. Do not specify the index number.
[Sysname] poe-profile def
[Sysname-poe-profile-def-1]
apply poe-profile
poe enable
poe mode
poe priority
