12-Network Management and Monitoring Configuration Guide
HomeSupportRouters5G IPRAN Access RoutersConfigure & DeployConfiguration GuidesH3C RA5100-G Routers Configuration Guides-R7752-6W10112-Network Management and Monitoring Configuration Guide
04-NQA configuration
04-NQA configuration 423.77 KB
Configuring NQA·· 1
About NQA· 1
NQA architecture· 1
NQA operating mechanism·· 1
Restrictions and guidelines: NQA configuration· 1
NQA tasks at a glance· 2
Configuring the NQA server 2
Enabling the NQA client 2
Configuring NQA operations on the NQA client 3
Configuring the Y.1564 operation· 3
Configuring path quality analysis operations· 8
Display and maintenance commands for NQA· 12
NQA operation configuration examples· 13
Example: Configuring the path quality analysis operation· 13
Example: Configuring Y.1564 operation on a Layer 3 Ethernet network· 15
Configuring TWAMP Light 0
About TWAMP Light 0
TWAMP Light architecture· 0
TWAMP Light operating mechanism·· 0
Threshold monitoring· 1
Protocols and standards· 1
Restrictions and guidelines: TWAMP Light configuration· 1
TWAMP Light tasks at a glance· 1
Configuring the TWAMP Light server 2
Configuring the TWAMP Light client 2
Restrictions and guidelines· 2
Creating a test session on the TWAMP Light client 2
Configuring the IP address and port number for the TWAMP Light test session· 3
Configuring other parameters for the TWAMP Light probe packets· 4
Configuring threshold monitoring· 4
Starting the test on the TWAMP Light sender 5
Stopping the test on the TWAMP Light sender 5
Display and maintenance commands for TWAMP Light 6
TWAMP Light configuration examples· 6
Example: Configuring TWAMP Light test on a common Layer 3 network· 6
Example: Configuring TWAMP Light test on an L2VPN network· 8
Example: Configuring TWAMP Light test on an L3VPN network· 10
Configuring NQA
About NQA
Network quality analyzer (NQA) allows you to measure network performance, verify the service levels for IP services and applications, and troubleshoot network problems.
NQA architecture
An NQA operation contains a set of parameters such as the operation type, destination IP address, and port number to define how the operation is performed. Each NQA operation is identified by the combination of the administrator name and the operation tag.
As shown in Figure 1, the NQA architecture contains the following parts:
·     NQA client—Sends probe packets to the NQA destination device by simulating IP services and applications to measure network performance. You can configure the NQA client to run the operation at scheduled time periods.
·     NQA server—Destination device of the NQA operation. It receives, processes, and responds to the probe packets sent by the NQA client.
Figure 1 Network diagram
The NQA client and NQA server interact as follows:
1.     The NQA client constructs probe packets of the operation type, and sends them to the NQA server.
2.     The NQA server processes the probe packets and sends back reply packets.
3.     Upon receiving the replies, the NQA client calculates the packet loss ratio and round-trip time to determine the network performance and service quality.
After an NQA operation starts, the NQA client repeats the operation at the specified interval.
An NQA operation can contain multiple probes. You can set the number of probes the NQA client performs in an operation.
To avoid probe failures, follow these restrictions and guidelines when configuring the listening ports on the NQA client and NQA server:
·     Do not specify a well-known port.
·     Make sure the specified port number is not used by any services on the device.
¡     To obtain the IPv4 addresses and the port numbers in use on this device, see the Local Addr:port field in the output from the display tcp and display udp commands.
¡     To obtain the IPv6 addresses and the port numbers in use on this device, see the LAddr->port field in the output from the display ipv6 tcp and display ipv6 udp commands.
The destination port configured for the operation (with the destination port command) on the NQA client must be the same as the listening port configured on the server.
During the initial startup phase, the device might not have generated route entries or ARP table entries to reach the destination address of the operation, or the probe packet output interface might not be up, which can result in NQA operation failure.
For latency operation results to be accurate, synchronize time between the source and the destination with an accuracy higher than or equal to the operation result calculation accuracy.
To configure NQA, perform the following tasks:
1.     Configuring the NQA server
2.     Enabling the NQA client
3.     Configuring NQA operations
¡     Configuring NQA operations on the NQA client
Follow these restrictions and guidelines to determine the configuration on the destination device:
·     To perform path quality analysis and Y.1564 operations, you must enable the NQA server on the destination device and packet reflection.
Table 1 Enter system view.
Table 2 Configure a reflector on the NQA server.
nqa reflector reflector-id interface interface-type interface-number [ service-instance instance-id ] [ { ip | ipv6 } { destination address1 [ to address2 ] | source address1 [ to address2 ] } * | source-port port-number1 [ to port-number2 ] | destination-port port-number1 [ to port-number2 ] | destination-mac mac-address1 [ to mac-address2 ] | source-mac mac-address1 [ to mac-address2 ] | vlan vlan-id1 [ to vlan-id2 ] | exchange-port | vpn-instance vpn-instance-name ] *
By default, no reflector is configured on the device.
2.     Enable the NQA server.
nqa server enable
By default, the NQA server is disabled.
2.     Enable the NQA client.
nqa agent enable
By default, the NQA client is enabled.
The NQA client configuration takes effect after you enable the NQA client.
The Y.1564 operation tests whether the service running over the link meets the performance level guaranteed in the service level agreement (SLA).
Service Acceptance Criteria
The Service Acceptance Criteria (SAC) is a set of criteria used to ensure that a service meets its functionality and quality requirement guaranteed in the SLA.
The SAC used by Y.1564 are defined in ITU-T Y.1564 and include the following performance criteria:
·     Information Rate (IR).
·     Frame Loss Ratio (FLR).
·     Frame Transfer Delay (FTD).
·     Frame Delay Variation (FDV).
You must configure the thresholds for all the Y.1564 service acceptance criteria in the Y.1564 operation.
Test phases in the Y.1564 operation
The Y.1564 operation contains the following test phases:
Table 1 Service configuration test phase.
The service configuration tests verify that the network is configured correctly to deliver the service and can process the traffic as intended.
2.     Service performance test phase.
The service performance test validates the quality of the service over time.
The service configuration test phase is further divided into the following phases:
Table 1 CIR test.
The CIR test uses a step load test method. Test packets are transmitted at an initial rate of CIR/N, where N is the step count configured for the CIR test. The packet transmission rate is increased by CIR/N per step until the CIR is reached.
For each step up to the CIR, the FLR, FTD, and FDV are calculated. If the FLR, FTD, and FDV are within the SAC thresholds, the step is considered passed and the test will proceed to the next step. If 100% of the CIR is reached successfully within the SAC thresholds, the CIR test is passed and the operation will proceed to the PIR test.
If the FLR, FTD, and FDV at any step are not within the SAC thresholds, the CIR test is considered failed, and the Y.1564 operation is terminated.
2.     PIR test.
The PIR test tests whether the device can transmit packets at both the CIR and PIR or at a rate exceeding the CIR with the FLR within the FLR threshold.
The PIR test can operate in color-aware mode or non-color aware mode.
¡     Color-aware mode—The PIR test transmits green packets at a rate equal to the CIR and yellow packets at a rate equal to the PIR. After the test is complete, the FLR, FTD, and FDV for green packets are calculated. If the FLR, FTD, and FDV are within the SAC thresholds, the PIR test is considered passed. If the FLR, FTD, and FDV are not within the SAC thresholds, the PIR test is considered failed, and the Y.1564 operation is terminated.
¡     Non-color-aware mode—The PIR test transmits packets at a rate equal to CIR + PIR. After the test is complete, the information rate (IR) is calculated. If CIR * (1 – FLRSAC) ≤ IR ≤ CIR + PIR, the PIR test is considered passed. Otherwise, the PIR test is considered failed, and the Y.1564 operation is terminated.
FLRSAC is the FLR threshold specified in the Y.1564 operation.
3.     Traffic policing test.
The traffic policing test can operate in color-aware mode or non-color aware mode.
¡     Color-aware mode—The test transmits green packets at the CIR and yellow packets at 125% * PIR or 25% * CIR + PIR, if PIR < 20% * CIR. The test is considered passed if the FLR, FTD, and FDV for green packets are within the SAC thresholds and CIR * (1 – FLRSAC) ≤ IR ≤ CIR + PIR + M. Otherwise, the test is considered failed, and the Y.1564 operation is terminated.
FLRSAC is the FLR threshold specified in the Y.1564 operation. M is calculated as follows: M= (CIR + PIR) * 1%.
¡     Non-color-aware mode—The test transmits packets at a rate equal to CIR + 125% * PIR or 125%*CIR + PIR, if PIR < 20% * CIR. The test is considered passed if the CIR * (1 – FLRSAC) ≤ IR ≤ CIR + PIR + M. Otherwise, the test is considered failed, and the Y.1564 operation is terminated.
In the service performance test phase, test packets are sent directly at the configured CIR, and the FLR, FTP, and FDV are calculated after the test is complete. If the FLR, FTD, and FDV are within the SAC thresholds, the test is considered passed.
Restrictions and guidelines for Y.1564 operation configuration
To view the results of a Y.1564 operation, use the display nqa result command. The display nqa history or display nqa statistics command does not display the results of Y.1564 operations.
For Y.1564 operations to start successfully, configure the source and destination IP addresses as follows:
·     In a Layer 3 Ethernet and L3VPN network, configure both source and destination IP addresses.
·     In other networks, you must configure both of them or none of them. If they are configured, make sure the source and destination IP addresses are of the same IP version.
Configuring a Y.1564 operation
2.     Create an NQA operation and enter NQA operation view.
nqa entry admin-name operation-tag
3.     Specify the Y.1564 operation type and enter Y.1564 operation view.
type y1564
4.     Specify the IP address and port for the Y.1564 operation.
a.     Specify the source IP address for the probe packets.
IPv4:
source ip ipv4-address1 [ to ipv4-address2 ]
By default, the source IPv4 address is not specified.
IPv6:
source ipv6 ipv6-address1 [ to ipv6-address2 ]
By default, the source IPv6 address is not specified.
b.     Specify the destination IP address for the probe packets.
IPv4:
destination ip ipv4-address1 [ to ipv4-address2 ]
By default, the destination IPv4 address is not specified.
IPv6:
destination ipv6 ipv6-address1 [ to ipv6-address2 ]
By default, the destination IPv6 address is not specified.
c.     Specify the source AC or source interface for the probe packets.
source interface interface-type interface-number [ service-instance instance-id ]
The service-instance keyword is required for the L2VPN network.
By default, the source AC or source interface is not specified.
The specified source interface must be up.
For more information about the AC interface, see VPLS in MPLS Configuration Guide.
d.     Specify the egress interface for the probe packets.
out interface interface-type interface-number
By default, the egress interface is not specified.
This task is required when the NQA client is a Layer 3 Ethernet gateway or an L3VPN gateway.
e.     Specify the source port number for the probe packets.
source port port-number1 [ to port-number2 ]
By default, the source port number is 49184.
For the operation to succeed, make sure the specified port number is not used by any services on the device. As a best practice, use the default value.
f.     Specify the destination port number for the probe packets.
destination port port-number1 [ to port-number2 ]
By default, the destination port number is 7.
g.     Specify the source MAC address for the probe packets.
source mac mac-address1 [ to mac-address2 ]
By default, the source MAC address for the probe packets is the MAC address of the egress port.
This task is required for the operatioin in a Layer 2 Ethernet and L2VPN network.
h.     Specify the destination MAC address for the probe packets.
destination mac mac-address1 [ to mac-address2 ]
By default, the destination MAC address is 0023-8900-0001.
This task is required for the operation in a Layer 2 Ethernet and L2VPN network.
5.     Specify the basic parameters for the Y.1564 operations.
¡     (Optional.) Specify the description for the Y.1564 operation.
By default, the description is not specified.
¡     Set the CIR and PIR.
bandwidth cir cir-value [ pir pir-value ]
By default, the CIR and PIR are not specified.
¡     Set the size of the probe packets.
frame-size size&<1-7>
By default, the probe packet size is 512 bytes.
¡     Set the FDV threshold.
allowed-jitter jitter
By default, the FDV threshold is not specified.
¡     Set the FLR threshold.
allowed-frame-loss count
By default, the FLR threshold is not specified.
¡     Set the FTD threshold.
allowed-transfer-delay delay
By default, the FTD threshold is not specified.
¡     Set the ToS value in the IP header of the probe packets..
tos value
By default, the ToS value is 0.
6.     Enable tests in the Y.1564 operation. Choose one option as needed:
¡     Enable the CIR test.
cir-test enable [ step-count count ] [ step-duration duration ]
By default, the CIR test is enabled.
¡     Enable the PIR test.
pir-test enable [ duration duration ]
By default, the PIR test is enabled.
¡     Enable the traffic policing test.
traffic-policing-test enable [ duration duration ]
By default, the traffic policing test is disabled.
¡     Enable the service performance test.
performance-test enable [ duration duration ]
By default, the service performance test is enabled.
7.     (Optional.) Enable the PIR test and traffic policing test to operate in color-aware mode.
color-aware-mode enable [ 8021p green value1 [ to value2 ] yellow value1 [ to value2 ] | dscp green value1 [ to value2 ] yellow value1 [ to value2 ] ]
By default, the PIR test and traffic policing test operate in non-color-aware mode.
8.     (Optional.) Specify the ID of the VLAN to which the probe packets belong.
By default, no VLAN ID is specified.
9.     Specify the VPN instance where the operation is performed..
By default, no VPN instance is specified.
This task is required for the operation in an L3VPN network.
10.     (Optional.) Enable the port exchange between the source port and destination port.
exchange-port enable
By default, the port exchange is disabled.
11.     (Optional.) Specify the 802.1p priority for the probe packets.
priority 8021p value
By default, the 802.1p priority of the probe packets is 0.
12.     Set the probe timeout time.
probe timeout timeout
The default setting is 3000 milliseconds.
Configuring a Y.1564 operation group
You can bind multiple Y.1564 operations to a Y.1564 operation group. If you start or stop the Y.1564 operation group, all the Y.1564 operations in the group start or stop.
After a Y.1564 operation group starts, the device performs the service configuration tests for the Y.1564 operations in the group one by one. After completing the service configuration tests for all the Y.1564 operations, the device proceeds to perform the service performance tests.
To configure a Y.1564 operation group:
2.     Create a Y.1564 operation group and enter its view.
nqa y1564 group group-name
3.     Bind a Y.1564 operation to the Y.1564 operation group.
bind nqa-entry admin-name operation-tag
By default, a Y.1564 operation group does not contain any Y.1564 operations.
Configuring the NQA client to upload the Y.1564 operation results to an FTP server
2.     Configure the FTP server to which the NQA client uploads the operation results.
nqa report-ftp url url [ username username ] [ password { cipher | simple } string ]
By default , no FTP server is configured.
Starting a Y.1564 operation group or a Y.1564 operation
Starting a Y.1564 operation group starts all Y.1564 operations in the group.
A Y.1564 operation requires all bandwidth of the link over which the operation is performed. Before a Y.1564 operation starts, suspend all the services that are transmitting data over the link.
The Y.1564 operation cannot run simultaneously with other NQA operations over the same link.
While a Y.1564 operation is running on the NQA client, you cannot start another Y.1564 operation or start a Y.1564 operation group.
To start a Y.1564 operation group or a Y.1564 operation:
2.     Enter Y.1564 operation group view or Y.1564 operation view.
¡     Enter Y.1564 operation group view.
¡     Enter Y.1564 operation view.
3.     Start the Y.1564 operation group or Y.1564 operation.
Start
Stopping a Y.1564 operation group or a Y.1564 operation
3.     (Optional.) Stop the Y.1564 operation group or Y.1564 operation.
stop
The Y.1564 operation will automatically stop after all test items have been completed. You can use this command to abort the test. If the test is aborted, the ongoing operation will not have any results.
As shown in Figure 2, a path quality analysis operation tests the path quality from source to destination over a network. The path quality indexes that can be tested include frame loss ratio, latency, and throughput.
Figure 2 Path quality analysis operation on an MPLS L2VPN network
In each path quality analysis probe, the NQA client sends packets of a fixed size at a specific speed to the destination device for the specified probe duration.
For each type of path quality analysis operation, you can specify a list of packet sizes by using the frame-size command. The NQA client uses the listed packet sizes in turn to send packets. Packets per probe are of the same size.
Frame loss operation
Table 1 The NQA client sends probe packets of the first listed packet size to the destination device at the initial sending speed for the first probe.
2.     When the destination device receives the probe packets, it sends back response packets.
3.     The NQA client calculates and records the frame loss ratio for the first probe by using the following formula:
Frame loss ratio = (sent packets – received packets) × 100 / sent packets
4.     After the specified probe interval, the NQA client starts another probe to test the frame loss ratio by sending packets of the second listed packet size.
5.     The process continues until all listed packet sizes are tested.
Throughput operation
3.     The NQA client calculates and records the frame loss ratio for the probe.
4.     The NQA client adjusts the packet sending speed (based on the configured granularity) and sends the probe packets of the same size for another probe.
5.     The client repeats steps 3 through 4 until it determines the maximum packet sending speed at which it can send the packets with an acceptable frame loss ratio. The acceptable frame loss ratio must not be higher than the specified maximum acceptable frame loss ratio.
The maximum packet sending speed is recorded as the throughput for the specific packet size.
6.     The NQA client follows the same procedure to determine the throughput for subsequent packet sizes in the packet size list.
7.     The process stops when the last listed packet size is tested.
Latency operation
2.     When the NQA client receives a response packet from the destination device, the client calculates the round-trip time (latency) for the packet.
3.     When the first probe duration expires, the NQA client calculates the average latency for the first packet size by using the following formula:
Average latency = Sum of all latency values / sent packets
4.     The NQA client starts another probe to test the latency for packets of the second listed packet size.
5.     The process stops when the last listed packet size is tested.
The display nqa history command does not display the results or statistics of path quality analysis operations. To view the results or statistics of path quality analysis operations, use the display nqa result or display nqa statistics command.
For path quality analysis operations and Y.1564 operations to start successfully, configure the source and destination IP addresses as follows:
Configuring the path quality analysis operation parameters
2.     (Optional.) Configure the FTP server to which the NQA client uploads the operation results.
By default, no FTP server is configured.
Only the path quality analysis operation supports uploading operation results to the FTP server.
3.     Create an NQA operation and enter NQA operation view.
4.     Specify a path quality analysis operation type and enter its view. Choose the options to configure as needed:
¡     Specify the frame loss operation type.
type frame-loss
¡     Specify the throughput operation type.
type throughput
¡     Specify the latency operation type.
type latency
5.     Specify the addresses and port numbers for the path quality analysis operation.
IPv4:
By default, the source IPv4 address is 198.19.65.1.
IPv6:
IPv4:
By default, the destination IPv4 address is 198.18.65.1.
IPv6:
The service-instance keyword is required for the operation in an L2VPN network.
d.     Specify the source port number for the probe packets.
By default , the source port number is 49184.
e.     Specify the destination port number for the probe packets.
f.     Specify the source MAC address for the probe packets.
By default, the source MAC address for the probe packets is not specified.
g.     Specify the destination MAC address for the probe packets.
6.     Specify the basic parameters for the Y.1564 operations.
By default, the probe packet size is 1518 bytes.
¡     Specify the initial packet sending speed.
speed init init-speed
By default, the initial frame sending speed is 100000 kbps.
The frame loss and latency operations use the specified initial packet sending speed for all probes.
The throughput operation starts the first probe at the specified initial packet sending speed and adjusts the speed according to the configured granularity for each subsequent probe.
¡     Specify the granularity for adjusting the packet sending speed.
speed granularity value
The default setting is 1000 kbps.
This command is available only in throughput operation view.
¡     Specify the maximum acceptable frame loss ratio.
allowed-loss-ratio ratio
By default, the maximum acceptable frame loss ratio is 1/10000.
tos value
7.     (Optional.) Configure the probe parameters for the path quality analysis operation.
¡     Set the interval between consecutive probes.
probe interval interval
The default probe interval is 4 seconds.
¡     Specify the probe duration in seconds.
probe duration time
The default probe duration is 60 seconds.
¡     Set the probe timeout time.
8.     Specify the VPN instance where the operation is performed.
9.     (Optional.) Specify the 802.1p priority for the probe packets.
Configuring an RFC2544 operation group
You can bind multiple RFC2544 operations to a NQA RFC2544 operation group. By starting the operation group, you can start all the path quality analysis operations in the group.
After an RFC2544 operation group starts, the device performs operations in the group the one by one.
2.     Create an RFC2544 operation group and enter its view.
nqa rfc2544 group group-name
3.     Bind an RFC2544 operation to the RFC2544 operation group.
By default, an RFC2544 operation group does not contain any RFC2544 operations.
You can repeat this command to bind multiple operations to the RFC2544 operation group.
Starting the path quality analysis operation
2.     Enter NQA operation view or RFC2544 operation group view.
¡     Enter NQA operation view.
¡     Enter RFC2544 operation group view.
¡     nqa rfc2544 group group-name
3.     Start the operation.
start
Stopping the operation
¡     Enter RFC2544 operation group.
3.     Stop the path quality analysis operation.
stop
Execute display commands in any view on the NQA client.
Display the most recent result of the NQA operation.
display nqa result [ admin-name operation-tag ]
Display NQA path quality analysis operation group information.
display nqa rfc2544 group [ brief | name group-name | result [ group-name ] ]
Display Y.1564 operation group information.
display nqa y1564 group [ brief | name group-name ]
Execute display commands in any view on the NQA server.
Display a reflector of a path quality analysis or Y.1564 operation
display nqa reflector [ reflector-id ]
Display NQA server status.
display nqa server
This example uses the throughput operation. You can configure the frame loss or latency operation in the same way the throughput operation is configured.
As shown in Figure 3, configure a throughput operation to test the throughput of the network path from Device A to Device B over an MPLS L2VPN network.
Figure 3 Network diagram
Table 1 Set up and configure the MPLS L2VPN network. (Details not shown.)
2.     Configure Device B:
# Configure a reflector on the NQA server for the path quality analysis operations.
[DeviceB] nqa reflector 1 interface gigabitethernet 1/0/7 ip destination 10.2.2.2 source 10.1.1.1 destination-mac 2-2-2 source-mac 1-1-1
# Enable the NQA server.
[DeviceB] nqa server enable
3.     Configure Device A:
# Create a throughput operation.
[DeviceA] nqa entry admin test1
[DeviceA-nqa-admin-test1] type throughput
# Specify 1-1-1 as the source MAC address for the probe packets.
[DeviceA-nqa-admin-test1-throughput] source mac 1-1-1
# Specify 2-2-2 as the destination MAC address for the probe packets.
[DeviceA-nqa-admin-test1-path-jitter] destination mac 2-2-2
# Specify the AC interface to be used as the source interface for the probe packets. This example uses the AC interface in Ethernet service instance 1 on GigabitEthernet 1/0/1.
[DeviceA-nqa-admin-test1-throughput] source interface gigabitethernet 1/0/6
# Specify a packet size list of 64 bytes, 512 bytes, 1024 bytes, and 1280 bytes.
[DeviceA-nqa-admin-test1-throughput] frame-size 64 512 1024 1280
# Start the path quality analysis operation. The reflector will automatically stop the operation after it is completed.
[DeviceA-nqa-admin-test1-throughput] start
[DeviceA-nqa-admin-test1-throughput] quit
# Display the result of the throughput operation.
[DeviceA] display nqa result
NQA entry (admin admin, tag test1) test results:
  Basic results     :
    Initial speed(Kbps)    : 100000
    Speed granularity(Kbps): 1000
    Probe duration(s)      : 60
    Probe interval(s)      : 4
    Allowed-loss-ratio     : 1/10000
  Throughput results:
    Frame size(Byte): 64
      Current speed(Kbps): -
      Frame-loss(Loss/Tx): -
      Status             : Failed
      Time               : 2015-03-17 07:20:40.8
    Frame size(Byte): 512
      Current speed(Kbps): 4000
      Frame-loss(Loss/Tx): 0/10000
      Status             : Succeeded
      Time               : 2015-03-17 07:21:40.8
    Frame size(Byte): 1024
      Current speed(Kbps): 8000
      Status             : Succeeded
      Time               : 2015-03-17 07:22:52.8
    Frame size(Byte): 1280
      Current speed(Kbps): 10000
      Status             : Succeeded
      Time               : 2015-03-17 07:23:45.8
    Frame size(Byte): 1518
      Status             : Succeeded
      Time               : 2015-03-17 07:24:45.8
As shown in Figure 4, configure a Y.1564 operation to test the service quality from Device A to Device B over a Layer 3 Ethernet network.
Figure 4 Network diagram
Table 1 Assign IP addresses to interfaces, as shown in Figure 4. (Details not shown.)
2.     Configure static routes or a routing protocol to make sure the devices can reach each other. (Details not shown.)
3.     Configure Device B:
# Configure an NQA reflector on the NQA server for the Y.1564 operation.
[DeviceB] nqa reflector 1 interface gigabitethernet 1/0/7 ip destination 10.2.2.2 source 10.1.1.1 destination-port 20000 source-port 10000
4.     Configure Device A:
# Create a Y.1564 operation.
[DeviceA-nqa-admin-test1] type y1564
# Specify 10.1.1.1 as the source IP address for the probe packets.
[DeviceA-nqa-admin-test1-y1564] source ip 10.1.1.1
# Specify 10.2.2.2 as the destination IP address for the probe packets.
[DeviceA-nqa-admin-test1-y1564] destination ip 10.2.2.2
# Specify 10000 as the source port number for the probe packets.
[DeviceA-nqa-admin-test1-y1564] source port 10000
# Specify 20000 as the destination port number for the probe packets.
[DeviceA-nqa-admin-test1-y1564] destination port 20000
# Specify GigabitEthernet 1/0/1 as the source interface for the probe packets.
[DeviceA-nqa-admin-test1-y1564] source interface gigabitethernet 1/0/6
# Configure the Y.1564 operation basic parameters.
[DeviceA-nqa-admin-test1-y1564] bandwidth cir 10000 pir 1000
[DeviceA-nqa-admin-test1-y1564] allowed-jitter 1000
[DeviceA-nqa-admin-test1-y1564] allowed-frame-loss 20
[DeviceA-nqa-admin-test1-y1564] allowed-transfer-delay 10000
# Enable the traffic policing test.
[DeviceA-nqa-admin-test1-y1564] traffic-policing-test enable
# Start the Y.1564 operation.
[DeviceA-nqa-admin-test1-y1564] start
[DeviceA-nqa-admin-test1-y1564] quit
The operation duration relates to the configured test items and the item duration.
# Display the result of the Y.1564 operation.
  Status                    : In progress
  Last test                 : Traffic policing test
  Estimated total time (s)  : 909
  Actual test time used (s) : 24
  Detailed test results:
    CIR test (with the step of 1):
      Start time                : 2018-11-03 13:39:10.3
      End time                  : 2018-11-03 13:39:13.5
      Status                    : Succeeded
      Min/Max/Average IR (kbps) : 9998/10002/10000
      Min/Max/Average FTD (us)  : 347/351/349
      Min/Max/Average FDV (us)  : 47/51/49
      FL count/FLR              : 2/0.002%
      Packets out of order      : 0
      Severely Err Secs/AVAIL   : 0/100.000%
    PIR test (color-blind):
      Start time                : 2018-11-03 13:39:13.5
      End time                  : 2018-11-03 13:39:16.7
      Status                    : Succeeded
      Min/Max/Average IR (kbps) : 10998/11002/11000
      Min/Max/Average FTD (us)  : 582/586/584
      Min/Max/Average FDV (us)  : 82/86/84
      FL count/FLR              : 2/0.002%0
    Traffic policing test (color-blind):
      Start time                : 2018-11-03 13:39:16.7
      End time                  : 2018-11-03 13:39:19.9
      Status                    : Succeeded
      Min/Max/Average IR (kbps) : 10123/10127/10125
      Min/Max/Average FTD (us)  : 169/173/171
      Min/Max/Average FDV (us)  : 69/73/71
      FL count/FLR              : 6/0.006%
About TWAMP Light
Two-Way Active Measurement Protocol (TWAMP) defines a standard to measure the network performance between network devices on an IP network. It uses UDP packets to measure the two-way Frame Transfer Delay (FTD), Frame Delay Variation (FDV), and Frame Loss Ratio (FLR). The TWAMP Light provides a simple structure of TWAMP. It simplifies the control protocol for establishing performance measurement sessions and improves test performance.
TWAMP Light uses the client-server model.
Figure 5 describes the TWAMP Light roles and the typical network diagram.
On the client, the following roles are configured:
·     TWAMP Light client—Configures TWAMP Light test sessions.
·     TWAMP Light sender—Starts and stops TWAMP Light test sessions, and collect statistics.
On the server, the TWAMP Light responder, also known as the destination device, is configured. The responder reflects the packets back to the TWAMP Light sender. You must enable the NQA server on the destination device, and create the TWAMP Light responder and test sessions.
Figure 5 Network diagram
A TWAMP Light test contains a set of parameters for a test session such as the source IP address and destination IP address.
Each TWAMP Light test session is uniquely identified by the test session ID. You can create and run multiple test sessions on one TWAMP Light client.
The TWAMP Light client and TWAMP Light responder interact as follows:
1.     The TWAMP Light client constructs TWAMP Light test packets, and sends them to the TWAMP Light responder.
2.     The TWAMP Light responder reflects the test packets to the TWAMP Light client.
3.     Upon receiving the reflected packets, the TWAMP Light client calculates the packet loss ratio and round-trip time to determine the service quality from source to destination.
After a TWAMP Light test starts, the TWAMP light client runs the tests permanently or repeats the test at the specified interval. Each test sends one test packet. You can set the test duration and number of test packets to be sent.
Threshold monitoring enables the TWAMP Light client to take a predefined action when the TWAMP Light test performance metrics violate the specified thresholds.
The TWAMP Light test monitors the following metrics:
·     Two-way frame delay variation.
·     Two-way frame transfer delay.
·     Two-way frame loss rate.
In a TWAMP test, the device monitors the test result, and starts the monitoring time when either of the following conditions is met:
·     The monitoring result goes beyond the threshold upper limit.
·     The monitoring result drops below the threshold lower limit from a monitoring result higher than the lower limit.
If either condition is always true during the monitoring time, a threshold violation occurs and a trap or inform message is generated and sent to the NMS. You set the monitoring time by using the corresponding command.
·     RFC 5357, A Two-Way Active Measurement Protocol (TWAMP)
When performing a TWAMP test and a TWAMP Light test simultaneously on a device, make sure the combination of the destination address, port number, and VPN instance for one test is not completely the same as the other. This can avoid inaccurate test results caused by invalid service packets.
To avoid probe failures, follow these restrictions and guidelines when configuring the listening port on the TWAMP Light server and TWAMP Light client:
The destination port configured for the operation (with the destination port command) on the TWAMP Light client must be the same as the listening port configured on the server.
To configure TWAMP Light, perform the following tasks:
Table 1 Configuring the TWAMP Light server
2.     Configuring the TWAMP Light client
3.     (Optional.) Configuring threshold monitoring
4.     Starting the test on the TWAMP Light sender
5.     (Optional.) Stopping the test on the TWAMP Light sender
nqa server enable
3.     Enable the TWAMP Light responder on the NQA server and enter its view.
nqa twamp-light responder
4.     Create a test session on the TWAMP Light responder.
test-session session-id [ interface interface-type interface-number [ service-instance instance-id ] ] { destination-mac mac-address source-mac mac-address | { ip | ipv6 } destination address source address destination-port port-number source-port port-number [ vpn-instance vpn-instance-name ] } * [ description text | timestamp-format { ntp | ptp } | vlan vlan-id ] *
In the TWAMP Light test, a test session is identified by the combination of its address and port number. To ensure the test result, you cannot specify the same combination of address and port number for multiple test sessions.
nqa agent enable
After the NQA client is enabled, the TWAMP Light test session configuration can takes effect.
2.     Enter TWAMP Light client view.
nqa twamp-light client
3.     Create a test session on the TWAMP Light client and enter the client-session view.
4.     (Optional.) Specify the description for the probe packets.
By default, no description is specified.
3.     Enter TWAMP Light client test-session view.
4.     Specify the source IP address for the probe packets.
IPv4:
source ip ip-address
By default, no source IPv4 address for the probe packets is specified.
IPv6:
By default, no source IPv6 address for the probe packets is specified.
5.     Specify the destination IP address for the probe packets.
IPv4:
By default, no destination IPv4 address for the probe packets is specified.
IPv6:
By default, no destination IPv6 address for the probe packets is specified.
6.     Specify the source interface for the probe packets.
By default, no source interface for the probe packets is specified.
7.     Specify the source port number for the probe packets.
By default, no source port number for the probe packets is specified.
For TWAMP Light tests, you must configure this command. For the probe operation to succeed, make sure the specified port number is not used by any services on the device.
8.     Specify the destination port number for the probe packets.
By default, no destination port number for the probe packets is specified.
9.     Specify the source MAC address for the probe packets.
By default, no source MAC address for the probe packets is specified.
10.     Specify the destination MAC address for the probe packets.
By default, no destination MAC address for the probe packets is specified.
11.     (Optional.) Specify the VPN instance where the test is performed.
By default, no VPN instance is specified. The test is performed on the public network.
4.     Specify the timestamp format for the TWAMP Light test session.
By default, the timestamp format for the TWAMP Light test is PTP.
5.     Specify the payload parameters for the TWAMP Light test.
¡     Set the payload size for each probe packet.
data-size size
The default payload size is 142 bytes.
¡     Specify the payload fill string for each probe packet.
hex-data-fill { 00 | 55 | aa | ff }
The default payload fill string is all-zero.
6.     (Optional.) Specify the priority for the probe packets.
¡     Specify the 802.1p priority for the probe packets.
tos value
The default setting is 0.
7.     (Optional.) Bind an interface as the output interface for a TWAMP Light test session.
test-session session-id bind interface interface-type interface-number
By default, no interface is specified as the output interface for a TWAMP Light test session.
2.     Enable the TWAMP Light client and enter its view.
4.     Configure a reaction entry. Choose the following tasks as needed:
¡     Configure a reaction entry for monitoring the two-way delay.
reaction item-number checked-element two-way-delay threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
By default, no reaction entry is configured for monitoring the two-way delay.
¡     Configure a reaction entry for monitoring the two-way packet loss.
reaction item-number checked-element two-way-loss threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
By default, no reaction entry is configured for monitoring the two-way packet loss.
¡     Configure a reaction entry for monitoring the two-way jitter.
reaction item-number checked-element two-way-jitter threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
By default, no reaction entry is configured for monitoring the two-way jitter.
In the TWAMP Light test, a test session is identified by the combination of source IP address, source port number, destination IP address, and destination port number. To ensure the test result, do not specify the same combination for multiple test sessions.
2.     Enable the TWAMP Light sender and enter its view.
nqa twamp-light sender
3.     Start a TWAMP Light test.
start test-session session-id { permanent | duration duration | packet-count count } [ tx-interval { 10 | 100 | 1000 | 10000 | 30000 } ] [ time-out timeout ] [ [ statistics-interval statistics-interval ] monitor-time time ]
2.     Enter the TWAMP Light sender view.
3.     Stop the TWAMP Light test.
stop { all | test-session session-id }
Execute display commands in any view and reset commands in user view on the TWAMP Light client.
Display test session statistics on the TWAMP Light client, including two-way delay, two-way jitter, and two-way packet loss.
display nqa twamp-light client statistics { two-way-delay | two-way-loss } test-session session-id
Display the current monitoring results of reaction entries for the TWAMP Light test sessions.
display nqa twamp-light client test-session reaction counters [ session-id [ item-number ] ]
Display test session information on the TWAMP Light client.
display nqa twamp-light client [ test-session session-id | verbose ]
Clear statistics of TWAMP Light test sessions.
reset nqa twamp-light statistics { all | test-session session-id }
Execute display commands in any view on the TWAMP Light responder.
Display test sessions on the TWAMP Light responder.
display nqa twamp-light responder [ test-session session-id ]
As shown in Figure 6, configure a TWAMP Light test to measure the service quality from Device A to Device B.
Figure 6 Network diagram
Table 1 Assign IP addresses to interfaces, as shown in Figure 6. (Details not shown.)
# Create test session 1 on the TWAMP Light responder with the destination IP address 10.2.2.2, source IP address 10.1.1.1, destination port 20000, and source port 10000.
[DeviceB] nqa twamp-light responder
[DeviceB-twamp-light-responder] test-session 1 ip destination 10.2.2.2 source 10.1.1.1 destination-port 20000 source-port 10000
[DeviceB-twamp-light-responder] quit
# Create test session 1 on the TWAMP Light client.
[DeviceA] nqa twamp-light client
[DeviceA-nqa-twamp-light-client] test-session 1
[DeviceA-nqa-twamp-light-client-session1] source ip 10.1.1.1
[DeviceA-nqa-twamp-light-client-session1] destination ip 10.2.2.2
[DeviceA-nqa-twamp-light-client-session1] source port 10000
[DeviceA-nqa-twamp-light-client-session1] destination port 20000
[DeviceA-nqa-twamp-light-client-session1] quit
[DeviceA-nqa-twamp-light-client] quit
# Create a TWAMP Light sender and enter its view.
[DeviceA] nqa twamp-light sender
# Start the TWAMP Light test with the packet sending interval, statistics collection interval, and monitoring time set to 100, 10000, and 20000 in milliseconds, respectively.
[DeviceA-nqa-twamp-light-sender] start test-session 1 permanent tx-interval 100 statistics-interval 10000 monitor-time 20000
[DeviceA-nqa-twamp-light-sender] quit
# Display information about test session 1.
[DeviceA] display nqa twamp-light client
Brief information about all test sessions:
Total sessions: 1
Active sessions: 1
ID    Status     Source IP/Port         Destination IP/Port
1     Active     10.1.1.1/10000         10.2.2.2/20000
# Display test session statistics about two-way packet loss for test session 1.
[DeviceA] display nqa twamp-light client statistics two-way-loss test-session 1
Latest two-way loss statistics:
    Index      Loss count      Loss ratio      Error count  Error ratio
    11006      5               50.0000%        0            0.0000%
    11007      3               30.0000%        0            0.0000%
    11008      4               40.0000%        0            0.0000%
    11009      8               80.0000%        0            0.0000%
Average loss count :          5      Average loss ratio :  55.3333%
Maximum loss count :         10      Maximum loss ratio : 100.0000%
Minimum loss count :          1      Minimum loss ratio :  10.0000%
Average error count:          0      Average error ratio:   0.0000%
Maximum error count:          0      Maximum error ratio:   0.0000%
Minimum error count:          0      Minimum error ratio:   0.0000%
As shown in Figure 6, create an L2VPN between PE 1 and PE 2 over the backbone to allow communication between CE 1 and CE 2. Configure a TWAMP Light test to measure the service quality from PE 1 to PE 2.
Figure 7 Network diagram
Table 1 Assign IP addresses to interfaces. (Details not shown.)
2.     Configure static routes or a routing protocol and create an L2VPN to make sure the devices can reach each other. For more information about creating an L2VPN, see MPLS L2VPN in MPLS Configuration Guide.
3.     Configure PE 2 as the TWAMP Light responder:
<PE2> system-view
[PE2] nqa server enable
# Create test session 1 on the TWAMP Light responder with the destination IP address 4.4.4.2, source IP address 4.4.4.1, destination port 8888, and source port 7777.
[PE2] nqa twamp-light responder
[PE2-nqa-twamp-light-responder] test-session 1 interface gigabitethernet 1/0/6 ip destination 4.4.4.2 source 4.4.4.1 destination-port 8888 source-port 7777 destination-mac 1-1-2 source-mac 1-1-1
[PE2-nqa-twamp-light-responder] quit
4.     Configure PE 1:
# Specify PE 1 as the TWAMP Light client.
<PE1> system-view
[PE1] nqa twamp-light client
# Specify a destination IP address (any valid IP address except the one on the connected interface of PE 2), destination MAC address (any valid MAC address), and destination port number (any valid port number) for the probe packets.
[PE1-nqa-twamp-light-client] test-session 1
[PE1-nqa-twamp-light-client-session1] destination ip 4.4.4.2
[PE1-nqa-twamp-light-client-session1] destination mac 0001-0001-0002
[PE1-nqa-twamp-light-client-session1] destination port 8888
# Specify GigabitEthernet1/0/6 as the source interface for the probe packets. Specify a source IP address (any valid IP address except the one on the connected interface of PE 1), source MAC address (any valid MAC address), and source port number (any valid port number) for the probe packets.
[PE1-nqa-twamp-light-client-session1] source interface gigabitethernet 1/0/1
[PE1-nqa-twamp-light-client-session1] source ip 4.4.4.1
[PE1-nqa-twamp-light-client-session1] source mac 0001-0001-0001
[PE1-nqa-twamp-light-client-session1] source port 7777
[PE1-nqa-twamp-light-client-session1] quit
[PE1-nqa-twamp-light-client] quit
5.     Start the TWAMP Light test.
[PE1] nqa twamp-light sender
[PE1-nqa-twamp-light-sender] start test-session 1 permanent
[PE1-nqa-twamp-light-sender] quit
[PE1] display nqa twamp-light client
Total sessions: 1
Active sessions: 1
1     Active     4.4.4.1/7777           4.4.4.2/8888
[PE1] display nqa twamp-light client statistics two-way-loss test-session 1
    1          0               0.0000%         0            0.0000%
    2          0               0.0000%         0            0.0000%
    3          0               0.0000%         0            0.0000%
    4          0               0.0000%         0            0.0000%
Average loss count :          0      Average loss ratio :  0.0000%
Maximum loss count :          0      Maximum loss ratio :  0.0000%
Minimum loss count :          0      Minimum loss ratio :  0.0000%
# Display test session statistics about two-way delay for test session 1.
[PE1] display nqa twamp-light client statistics two-way-delay test-session 1
Latest two-way delay statistics(us):
    Index    Delay(Avg)    Jitter(Avg)    SD-jitter(Avg)    DS-jitter(Avg)
    1        46            1              2                 1
    2        46            1              2                 1
    3        46            0              1                 1
    4        46            0              1                 1
Average delay    :  46      Average jitter  :  1
Maximum delay    :  46      Maximum jitter  :  1
Minimum delay    :  46      Minimum jitter  :  0
Average SD jitter:  1      Average DS jitter:  1
Maximum SD jitter:  1      Maximum DS jitter:  1
Minimum SD jitter:  0      Minimum DS jitter:  0
As shown in Figure 6, create an L3VPN between PE 1 and PE 2 over the backbone to allow communication between CE 1 and CE 2. Configure a TWAMP Light test to measure the service quality from PE 1 to PE 2.
Figure 8 Network diagram
2.     Configure static routes or a routing protocol and create an L3VPN to make sure the devices can reach each other. For more information about creating an L3VPN, see MPLS L3VPN in MPLS Configuration Guide.
# Create test session 1 on the TWAMP Light responder with the destination IP address 100.100.2.1, source IP address 100.100.1.1, destination port 10000, and source port 20000.
[PE2-nqa-twamp-light-responder] test-session 1 ip destination 100.100.2.1 source 100.100.1.1 destination-port 10000 source-port 20000 vpn-instance 1
4.     Configure PE 1:
<PE1> system-view
# Specify 100.100.2.1 as the destination IP address and 10000 as the destination port number (use any valid port number) for the probe packets.
[PE1-nqa-twamp-light-client-session1] destination ip 100.100.2.1
[PE1-nqa-twamp-light-client-session1] destination port 10000
# Specify 100.100.1.1 as the source IP address and 20000 as the source port number for the probe packets. Specify VPN instance 1 as the VPN instance where the test is performed
[PE1-nqa-twamp-light-client-session1] source ip 100.100.1.1
[PE1-nqa-twamp-light-client-session1] source port 20000
[PE1-nqa-twamp-light-client-session1] vpn-instance 1
5.     Start the TWAMP Light test on PE 1.
Total sessions: 1
Active sessions: 1
1     Active     100.100.1.1/20000      100.100.2.1/10000
    1        46            1              2                 1
    2        46            1              2                 1
    3        46            0              1                 1
    4        46            0              1                 1
