12-Network Management and Monitoring Configuration Guide
HomeSupportRouters5G IPRAN Access RoutersConfigure & DeployConfiguration GuidesH3C RA5100-G Routers Configuration Guides-R7752-6W10112-Network Management and Monitoring Configuration Guide
01-GOLD configuration
01-GOLD configuration 80.06 KB
Configuring GOLD·· 1
About GOLD·· 1
Types of GOLD diagnostics· 1
GOLD diagnostic tests· 1
GOLD tasks at a glance· 1
Configuring monitoring diagnostics· 2
Configuring the log buffer size· 2
Display and maintenance commands for GOLD·· 2
GOLD configuration examples· 3
Example: Configuring GOLD·· 3
Configuring GOLD
About GOLD
Generic Online Diagnostics (GOLD) performs the following operations:
·     Runs diagnostic tests on a device to inspect device ports, RAM, chip, connectivity, forwarding paths, and control paths for hardware faults.
·     Reports the problems to the system.
Among the GOLD diagnostics, the device supports only monitoring diagnostics.
·     Monitoring diagnostics—Run diagnostic tests periodically when the system is in operation and record test results. Monitoring diagnostics execute only non-disruptive tests.
Each kind of diagnostics runs its diagnostic tests. The parameters of a diagnostic test include test name, type, description, attribute (disruptive or non-disruptive), default status, and execution interval.
Support for the diagnostic tests and default values for a test's parameters depend on the device model. You can modify part of the parameters by using the commands provided by this document.
The diagnostic tests are released with the system software image of the device. All enabled diagnostic tests run in the background. You can use the display commands to view test results and logs to verify hardware faults.
To configure GOLD, perform the following tasks:
1.     Configuring diagnostics
¡     Configuring monitoring diagnostics
2.     (Optional.) Configuring the log buffer size
The system automatically executes monitoring diagnostic tests that are enabled by default after the device starts. Use the diagnostic monitor enable command to enable monitoring diagnostic tests that are disabled by default.
2.     Enable monitoring diagnostics.
diagnostic monitor enable [ test test-name ]
By default, the monitoring diagnostic tests vary in enabling status. To view the enabling status of a monitoring diagnostic test, execute the display diagnostic content command.
3.     Set an execution interval for monitoring diagnostic tests.
diagnostic monitor interval [ test test-name ] time interval
By default, the execution interval varies by monitoring diagnostic test. To display the execution interval of a monitoring diagnostic test, execute the display diagnostic content command.
The configured interval cannot be smaller than the minimum execution interval of the tests. Use the display diagnostic content verbose command to view the minimum execution interval of the tests.
GOLD saves test results in the form of logs. You can use the display diagnostic event-log command to view the logs.
2.     Configure the maximum number of GOLD logs that can be saved.
diagnostic event-log size number
By default, GOLD saves 512 log entries at most.
When the number of logs exceeds the configured log buffer size, the system deletes the oldest entries.
Display test content.
display diagnostic content [ verbose ]
Display GOLD logs.
display diagnostic event-log [ error | info ]
Display test results.
display diagnostic result [ test test-name ] [ verbose ]
Clear GOLD logs.
reset diagnostic event-log
Clear test results.
reset diagnostic result [ test test-name ]
Support for the diagnostic tests depends on the device model. Monitoring diagnostic test MonitorTest in the following configuration examples is for illustration only.
Enable monitoring diagnostic test MonitorTest, and set its execution interval to 1 minute.
# View the default status and execution interval of the test.
<Sysname> display diagnostic content verbose
Diagnostic test suite attributes:
#B/*: Bootup test/NA
#O/*: Ondemand test/NA
#M/*: Monitoring test/NA
#D/*: Disruptive test/Non-disruptive test
#P/*: Per port test/NA
#A/I/*: Monitoring test is active/Monitoring test is inactive/NA
Test name        : MonitorTest
Test attributes  : **M*PI
Test interval    : 00:00:10
Min interval     : 00:00:10
Correct-action   : -NA-
Description       : A Real-time test, disabled by default that checks link status between ports.
Exec             : -NA-
# Enable test MonitorTest.
[Sysname] diagnostic monitor enable test MonitorTest
# Set the execution interval to 1 minute.
[Sysname] diagnostic monitor interval test MonitorTest time 0:1:0
# View the test configuration.
[Sysname] display diagnostic content verbose
Test attributes  : **M*PA
Test interval    : 00:01:00
Exec             : -NA-
# View the test result.
[Sysname] display diagnostic result verbose
  Total run count          : 1247
  Total failure count      : 0
  Consecutive failure count: 0
  Last execution time      : Mon Feb 25 18:09:21 2019
  First failure time       : -NA-
  Last failure time        : -NA-
  Last pass time           : Mon Feb 25 18:09:21 2019
  Last execution result    : Success
  Last failure reason      : -NA-
  Next execution time      : Mon Feb 25 18:10:21 2019
  Port link status : Normal
