08-ACL and QoS Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C S5100[S5500]-D-G&S5130S-G[-V2] @CG@-R8336Pxx-6W10008-ACL and QoS Configuration Guide
04-Time range configuration
04-Time range configuration 65.68 KB
Configuring time ranges
About time ranges
You can implement a service based on the time of the day by applying a time range to it. A time-based service takes effect only in time periods specified by the time range. For example, you can implement time-based ACL rules by applying a time range to them.
The following basic types of time ranges are available:
·     Periodic time range—Recurs periodically on a day or days of the week.
·     Absolute time range—Represents only a period of time and does not recur.
The active period of a time range is calculated as follows:
1.     Combining all periodic statements.
2.     Combining all absolute statements.
3.     Taking the intersection of the two statement sets as the active period of the time range.
Restrictions and guidelines: Time range configuration
When you configure the ACL hardware mode, follow these restrictions and guidelines:
·     If a time range does not exist, the service based on the time range does not take effect.
·     You can create a maximum of 1024 time ranges, each with a maximum of 32 periodic statements and 12 absolute statements.
2.     Create or edit a time range.
time-range time-range-name { start-time to end-time days [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
If an existing time range name is provided, this command adds a statement to the time range.
Display and maintenance commands for time ranges
Execute the display command in any view.
Display time range configuration and status.
display time-range { time-range-name | all }
Time range configuration examples
Example: Configuring a time range
As shown in Figure 1, configure an ACL on the device to allow Host A to access the server only during 8:00 and 18:00 on working days from June 2015 to the end of the year.
Figure 1 Network diagram
# Create a periodic time range during 8:00 and 18:00 on working days from June 2015 to the end of the year.
[Device] time-range work 8:0 to 18:0 working-day from 0:0 6/1/2015 to 24:00 12/31/2015
# Create an IPv4 basic ACL numbered 2001, and configure a rule in the ACL to permit packets only from 192.168.1.2/32 during the time range work.
[Device] acl basic 2001
[Device-acl-ipv4-basic-2001] rule permit source 192.168.1.2 0 time-range work
[Device-acl-ipv4-basic-2001] rule deny source any time-range work
[Device-acl-ipv4-basic-2001] quit
# Apply IPv4 basic ACL 2001 to filter outgoing packets on GigabitEthernet 1/0/2.
[Device-GigabitEthernet1/0/2] packet-filter 2001 outbound
# Verify that the time range work is active on the device.
[Device] display time-range all
Current time is 13:58:35 6/19/2015 Friday
Time-range : work (Active)
 08:00 to 18:00 working-day
 from 00:00 6/1/2015 to 00:00 1/1/2016
