01-ACL configuration | 218.84 KB |
Comments and remarks for rules
Restrictions and guidelines: ACL configuration
Configuring an IPv4 advanced ACL
Configuring an IPv6 advanced ACL
Configuring a user-defined ACL
Configuring the QoS and ACL resource hardware mode
Configuring packet filtering with ACLs
About packet filtering with ACLs
Applying an ACL to filter packets globally
Applying an ACL to an interface for packet filtering
Configuring the applicable scope of packet filtering on a VLAN interface
Configuring logging and SNMP notifications for packet filtering
Setting the packet filtering default action
Display and maintenance commands for ACL
Example: Configuring interface-based packet filter
Configuring ACLs
User-defined ACLs are available only on the S5130S-HI-G switch series.
About ACLs
An access control list (ACL) is a set of rules for identifying traffic based on criteria such as source IP address, destination IP address, and port number. The rules are also called permit or deny statements.
ACLs are primarily used for packet filtering. You can also use ACLs in QoS, security, routing, and other modules for identifying traffic. The packet drop or forwarding decisions depend on the modules that use ACLs.
Numbering and naming ACLs
When creating an ACL, you must assign it a number or name for identification. You can specify an existing ACL by its number or name. Each ACL type has a unique range of ACL numbers.
For basic or advanced ACLs with the same number, you must use the ipv6 keyword to distinguish them. For ACLs with the same name, you must use the ipv6, mac, and user-defined keywords to distinguish them.
ACL types
Type |
ACL number |
IP version |
Match criteria |
Basic ACLs |
2000 to 2999 |
IPv4 |
Source IPv4 address. |
IPv6 |
Source IPv6 address. |
Advanced ACLs |
3000 to 3999 |
IPv4 |
Source IPv4 address, destination IPv4 address, packet priority, protocol number, and other Layer 3 and Layer 4 header fields. |
IPv6 |
Source IPv6 address, destination IPv6 address, packet priority, protocol number, and other Layer 3 and Layer 4 header fields. |
Layer 2 ACLs |
4000 to 4999 |
IPv4 and IPv6 |
Layer 2 header fields, such as source and destination MAC addresses, 802.1p priority, and link layer protocol type. |
User-defined ACLs |
5000 to 5999 |
IPv4 and IPv6 |
User specified matching patterns in protocol headers. |
Match order
The rules in an ACL are sorted in a specific order. When a packet matches a rule, the device stops the match process and performs the action defined in the rule. If an ACL contains overlapping or conflicting rules, the matching result and action to take depend on the rule order.
The following ACL match orders are available:
· config—Sorts ACL rules in ascending order of rule ID. A rule with a lower ID is matched before a rule with a higher ID. If you use this method, check the rules and their order carefully.
NOTE: The match order of user-defined ACLs can only be config. |
· auto—Sorts ACL rules in depth-first order. Depth-first ordering makes sure any subset of a rule is always matched before the rule. The following table lists the sequence of tie breakers that depth-first ordering uses to sort rules for each type of ACL.
Table 1 Sort ACL rules in depth-first order
ACL type |
Sequence of tie breakers |
IPv4 basic ACL |
1. VPN instance. 2. More 0s in the source IPv4 address wildcard (more 0s means a narrower IPv4 address range). 3. Rule configured earlier. |
IPv4 advanced ACL |
1. VPN instance. 2. Specific protocol number. 3. More 0s in the source IPv4 address wildcard mask. 4. More 0s in the destination IPv4 address wildcard. 5. Narrower TCP/UDP service port number range. 6. Rule configured earlier. |
IPv6 basic ACL |
1. VPN instance. 2. Longer prefix for the source IPv6 address (a longer prefix means a narrower IPv6 address range). 3. Rule configured earlier. |
IPv6 advanced ACL |
1. VPN instance. 2. Specific protocol number. 3. Longer prefix for the source IPv6 address. 4. Longer prefix for the destination IPv6 address. 5. Narrower TCP/UDP service port number range. 6. Rule configured earlier. |
Layer 2 ACL |
1. More 1s in the source MAC address mask (more 1s means a smaller MAC address). 2. More 1s in the destination MAC address mask. 3. Rule configured earlier. |
A wildcard mask, also called an inverse mask, is a 32-bit binary number represented in dotted decimal notation. In contrast to a network mask, the 0 bits in a wildcard mask represent "do care" bits, and the 1 bits represent "don't care" bits. If the "do care" bits in an IP address are identical to the "do care" bits in an IP address criterion, the IP address matches the criterion. All "don't care" bits are ignored. The 0s and 1s in a wildcard mask can be noncontiguous. For example, 0.255.0.255 is a valid wildcard mask.
An ACL can have multiple rules. To identify rules, you can add a comment for each rule one by one, or add the same remark for multiple rules.
· For rules requiring different identification, you can add a comment for a particular rule or add a different comment for each rule.
· For a range of rules requiring the same identification, you can insert a remark before the start rule and a remark after the end rule. This configuration mode eliminates the need for configuring a comment for each rule one by one and improves configuration efficiency.
Rule numbering
ACL rules can be manually numbered or automatically numbered. This section describes how automatic ACL rule numbering works.
Rule numbering step
If you do not assign an ID to the rule you are creating, the system automatically assigns it a rule ID. The rule numbering step sets the increment by which the system automatically numbers rules. For example, the default ACL rule numbering step is 5. If you do not assign IDs to rules you are creating, they are automatically numbered 0, 5, 10, 15, and so on. The wider the numbering step, the more rules you can insert between two rules.
By introducing a gap between rules rather than contiguously numbering rules, you have the flexibility of inserting rules in an ACL. This feature is important for a config-order ACL, where ACL rules are matched in ascending order of rule ID.
The rule numbering step sets the increment by which the system numbers rules automatically. If you do not specify a rule ID when creating an ACL rule, the system automatically assigns it a rule ID. This rule ID is the nearest higher multiple of the numbering step to the current highest rule ID, starting from the start rule ID. For example, if the rule numbering step is 5 and the current highest rule ID is 12, the rule is numbered 15.
The wider the numbering step, the more rules you can insert between two rules. Whenever the step or start rule ID changes, the rules are renumbered, starting from the start rule ID. For example, if there are five rules numbered 0, 5, 9, 10, and 15, changing the step from 5 to 2 causes the rules to be renumbered 0, 2, 4, 6, and 8.
Automatic rule numbering and renumbering
The ID automatically assigned to an ACL rule takes the nearest higher multiple of the numbering step to the current highest rule ID, starting with 0.
For example, if the step is 5, and there are five rules numbered 0, 5, 9, 10, and 12, the newly defined rule is numbered 15. If the ACL does not contain a rule, the first rule is numbered 0.
Whenever the step changes, the rules are renumbered, starting from 0. For example, changing the step from 5 to 2 renumbers rules 5, 10, 13, and 15 as rules 0, 2, 4, and 6.
For an ACL of the match order auto, rules are sorted in depth-first order, and are renumbered based on the match order. For example, rules are in the match order of 0, 10, and 5. Changing the numbering step to 2 renumbers rules 0, 10, and 5 (not 0, 5, and 10) as rules 0, 2, 4.
Fragment filtering with ACLs
Traditional packet filtering matches only first fragments of packets, and allows all subsequent non-first fragments to pass through. Attackers can fabricate non-first fragments to attack networks.
To avoid risks, the ACL feature is designed as follows:
· Filters all fragments by default, including non-first fragments.
· Allows for matching criteria modification for efficiency. For example, you can configure the ACL to filter only non-first fragments.
· If you create a numbered ACL, you can enter the view of the ACL by using either of the following commands:
¡ acl [ ipv6 ] number acl-number.
¡ acl { [ ipv6 ] { advanced | basic } | mac | user-defined } acl-number.
· If you create a ACL by using the acl [ ipv6 ] number acl-number name acl-name command, you can enter the view of the ACL by using either of the following commands:
¡ acl [ ipv6 ] name acl-name (for only basic ACLs and advanced ACLs).
¡ acl [ ipv6 ] number acl-number [ name acl-name ].
¡ acl { [ ipv6 ] { advanced | basic } | mac | user-defined } name acl-name.
· If you create a named ACL by using the acl { [ ipv6 ] { advanced | basic } | mac | user-defined } name acl-name command, you can enter the view of the ACL by using either of the following commands:
ACL tasks at a glance
To configure an ACL, perform the following tasks:
· Configure ACLs according to the characteristics of the packets to be matched
¡ Configuring a user-defined ACL
· (Optional.) Copying an ACL
· (Optional.) Configuring the QoS and ACL resource hardware mode
· (Optional.) Configuring packet filtering with ACLs
Configuring a basic ACL
About basic ACLs
Basic ACLs match packets based only on source IP addresses.
Basic ACLs can be used in the following scenarios:
· To improve security when the device acts as an FTP or TFTP server, you can use basic ACLs to allow only matching clients to access the server. For more information, see FTP and TFTP configuration in Fundamentals Configuration Guide.
· In a multicast scenario, you can use basic ACLs in a multicast source policy to receive or forward only matching multicast packets. For more information about multicast source policy, see PIM configuration and IPv6 PIM configuration in IP Multicast Configuration Guide.
· To filter routes in a routing policy, you can use basic ACLs to receive or send matching routes. For more information about routing policy, see Layer 3—IP Routing Configuration Guide.
· To take different QoS actions on different traffic types, you can use basic ACLs to classify traffic. For more information about traffic classes, see "Configuring QoS."
Configuring an IPv4 basic ACL
1. Enter system view.
2. Create an IPv4 basic ACL and enter its view. Choose one option as needed:
¡ Create an IPv4 basic ACL by specifying an ACL number.
acl number acl-number [ name acl-name ] [ match-order { auto | config } ]
¡ Create an IPv4 basic ACL by specifying the basic keyword.
acl basic { acl-number | name acl-name } [ match-order { auto | config } ]
3. (Optional.) Configure a description for the IPv4 basic ACL.
By default, an IPv4 basic ACL does not have a description.
4. (Optional.) Set the rule numbering step.
step step-value [ start start-value ]
By default, the rule numbering step is 5 and the start rule ID is 0.
5. Create or edit a rule.
rule [ rule-id ] { deny | permit } [ counting | fragment | [ flow-logging | logging ] | source { source-address source-wildcard | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
The flow-logging or logging keyword takes effect only when the module (for example, packet filtering) that uses the ACL supports logging.
6. (Optional.) Add or edit a rule comment.
rule rule-id comment text
By default, no rule comment is configured.
7. (Optional.) Add a rule remark.
rule [ rule-id ] remark text
By default, no rule remark is configured.
Configuring an IPv6 basic ACL
2. Create an IPv6 basic ACL view and enter its view. Choose one option as needed:
¡ Create an IPv6 basic ACL by specifying an ACL number.
acl ipv6 number acl-number [ name acl-name ] [ match-order { auto | config } ]
¡ Create an IPv6 basic ACL by specifying the basic keyword.
acl ipv6 basic { acl-number | name acl-name } [ match-order { auto | config } ]
3. (Optional.) Configure a description for the IPv6 basic ACL.
By default, an IPv6 basic ACL does not have a description.
rule [ rule-id ] { deny | permit } [ counting | fragment | [ flow-logging | logging ] | routing [ type routing-type ] | source { source-address source-prefix | source-address/source-prefix | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
Configuring an advanced ACL
About advanced ACLs
Advanced ACLs can be used in the following scenarios:
· When the device acts as an FTP or TFTP server, you can use advanced ACLs to allow only matching clients to access the server. For more information, see FTP and TFTP configuration in Fundamentals Configuration Guide.
· In a multicast scenario, you can use advanced ACLs in a multicast source policy to receive or forward only matching multicast packets. For more information about multicast source policy, see PIM configuration and IPv6 PIM configuration in IP Multicast Configuration Guide.
· To filter routes in a routing policy, you can use advanced ACLs to receive or send matching routes. For more information about routing policy, see Layer 3—IP Routing Configuration Guide.
· To take different QoS actions on different traffic types, you can use advanced ACLs to classify traffic. For more information about traffic classification see "Configuring QoS."
Advanced ACLs match packets based on the following criteria:
· Source IP addresses.
· Destination IP addresses.
· Packet priorities.
· Local QoS IDs.
· Protocol types.
· Other protocol header information, such as TCP/UDP source and destination port numbers, TCP flags, ICMP message types, and ICMP message codes.
· Encapsulation types.
· Inner source IPv4 addresses.
· Inner destination IPv4 addresses.
· Inner protocol types.
· Other inner protocol header information, such as inner TCP/UDP source and destination port numbers.
Compared to basic ACLs, advanced ACLs allow more flexible and accurate filtering.
2. Create an IPv4 advanced ACL and enter its view. Choose one option as needed:
¡ Create a numbered IPv4 advanced ACL by specifying an ACL number.
¡ Create an IPv4 advanced ACL by specifying the advanced keyword.
acl advanced { acl-number | name acl-name } [ match-order { auto | config } ]
3. (Optional.) Configure a description for the IPv4 advanced ACL.
By default, an IPv4 advanced ACL does not have a description.
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { dest-address dest-wildcard | any } | destination-port operator port1 [ port2 ] | { dscp dscp | { precedence precedence | tos tos } * } | [ any-fragment | first-fragment | fragment | non-fragment | non-or-first-fragment ] | icmp-type { icmp-type [ icmp-code ] | icmp-message } | [ flow-logging | logging ] | qos-local-id local-id-value | source { source-address source-wildcard | any } | source-port operator port1 [ port2 ] | time-range time-range-name | vpn-instance vpn-instance-name ] *
The following keywords are not available on the S5130S-EI-G, S5100-D-G, or S5500-D-G switch series:
¡ any-fragment
¡ first-fragment
¡ non-fragment
¡ non-or-first-fragment
2. Create an IPv6 advanced ACL and enter its view. Choose one option as needed:
¡ Create a numbered IPv6 advanced ACL by specifying an ACL number.
¡ Create an IPv6 advanced ACL by specifying the advanced keyword.
acl ipv6 advanced { acl-number | name acl-name } [ match-order { auto | config } ]
3. (Optional.) Configure a description for the IPv6 advanced ACL.
By default, an IPv6 advanced ACL does not have a description.
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { dest-address dest-prefix | dest-address/dest-prefix | any } | destination-port operator port1 [ port2 ] | | dscp dscp | flow-label flow-label-value | fragment | icmp6-type { icmp6-type icmp6-code | icmp6-message } | [ flow-logging | logging ]| qos-local-id local-id-value | routing [ type routing-type ] | hop-by-hop [ type hop-type ] | source { source-address source-prefix | source-address/source-prefix | any } | source-port operator port1 [ port2 ] | time-range time-range-name | vpn-instance vpn-instance-name ] *
¡ any-fragment
¡ first-fragment
¡ non-fragment
Configuring a Layer 2 ACL
Layer 2 ACLs can be used in the following scenarios:
· To improve security when the device acts as a Telnet server, you can use Layer 2 ACLs to allow only matching clients to access the server. For more information, see login management in Fundamentals Configuration Guide.
· To take different QoS actions on different traffic types, you can use Layer 2 ACLs to classify traffic. For more information about traffic classes, see "Configuring QoS."
Layer 2 ACLs, also called Ethernet frame header ACLs, match packets based on Layer 2 Ethernet header fields, such as:
· Source MAC address.
· Destination MAC address.
· 802.1p priority (VLAN priority).
· Link layer protocol type.
· Encapsulation type.
2. Create a Layer 2 ACL and enter its view. Choose one option as needed:
¡ Create a Layer 2 ACL by specifying an ACL number.
¡ Create a Layer 2 ACL by specifying the mac keyword.
acl mac { acl-number | name acl-name } [ match-order { auto | config } ]
3. (Optional.) Configure a description for the Layer 2 ACL.
By default, a Layer 2 ACL does not have a description.
rule [ rule-id ] { deny | permit } [ cos dot1p | counting | dest-mac dest-address dest-mask | type protocol-type protocol-type-mask | source-mac source-address source-mask | time-range time-range-name ] *
User-defined ACLs allow you to customize rules based on information in protocol headers. You can define a user-defined ACL to match packets. A specific number of bytes after an offset (relative to the specified header) are compared against a match pattern after being ANDed with a match pattern mask.
2. Create a user-defined ACL and enter its view. Choose one option as needed:
¡ Create a user-defined ACL by specifying an ACL number.
¡ Create a user-defined ACL by specifying the user-defined keyword.
acl user-defined { acl-number | name acl-name }
3. (Optional.) Configure a description for the user-defined ACL.
By default, a user-defined ACL does not have a description.
4. Create or edit a rule.
Command set 1:
rule [ rule-id ] { deny | permit } [ { { ipv4 | ipv6 | l2 | l4 } rule-string rule-mask offset }&<1-8> ] [ counting | time-range time-range-name ] *
Command set 2:
rule [ rule-id ] { deny | permit } [ ipv6-protocol ] protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | destination { dest-address dest-wildcard | any } | destination-port { operator port1 [ port2 ] } | { { precedence precedence | tos tos } * | dscp dscp } | source { source-address source-wildcard | any } | source-port { operator port1 [ port2 ] } | vpn-instance vpn-instance-name ] * [ { { ipv4 | ipv6 | l2 | l4 } rule-string rule-mask offset }&<1-8> ] [ counting | time-range time-range-name ] *
5. (Optional.) Add or edit a rule comment.
6. (Optional.) Add a rule remark.
Copying an ACL
You can create an ACL by copying an existing ACL (source ACL). The new ACL (destination ACL) has the same properties and content as the source ACL, but uses a different number or name than the source ACL.
To successfully copy an ACL, make sure:
· The destination ACL is the same type as the source ACL.
· The source ACL already exists, but the destination ACL does not.
2. Copy an existing ACL to create a new ACL.
acl [ ipv6 | mac | user-defined ] copy { source-acl-number | name source-acl-name } to { dest-acl-number | name dest-acl-name }
Different chips produce different packet matching results for QoS and ACL resources. Perform this task to enhance matching capabilities of QoS and ACL resources.
This feature occupies more QoS and ACL resources when an ACL is applied.
This feature is not available on the S5130S-EI-G, S5100-D-G, or S5500-D-G switch series.
2. Configure the QoS and ACL resource hardware mode.
qos-acl resource hardware-mode hardware-mode-value
By default, no QoS and ACL resource hardware mode is configured.
This section describes procedures for using an ACL to filtering packets. For example, you can apply an ACL to an interface to filter incoming or outgoing packets.
You can apply a maximum of four ACLs to the same direction globally: one IPv4 ACL, one IPv6 ACL, one Layer 2 ACL, and one user-defined ACL.
2. Apply an ACL globally.
packet-filter [ ipv6 | mac | user-defined ] { acl-number | name acl-name } global { inbound | outbound } [ hardware-count ]
By default, global packet filtering is not configured.
To the same direction of an interface, you can apply a maximum of four ACLs: one IPv4 ACL, one IPv6 ACL, one Layer 2 ACL, and one user-defined ACL.
An ACL applied to the outbound direction of a VLAN interface cannot match untagged packets.
Only VLAN interfaces support the extend keyword.
If equal-cost routes exist from the device to the network accessed through a VLAN interface, the VLAN interface does not support the extend keyword.
The packet filtering feature on a VLAN interface that uses expanded ACL resources and the packet-filter filter all command are mutually exclusive.
If you apply an ACL to the outbound direction of a VLAN interface with the extend keyword and execute the packet-filter default deny command, the deny action takes effect on only Layer 3 packets on that VLAN interface.
2. Enter interface view.
3. Apply an ACL to the interface to filter packets.
packet-filter [ ipv6 | mac | user-defined ] { acl-number | name acl-name } { inbound | outbound [ extend ] } [ hardware-count ]
By default, an interface does not filter packets.
The extend keyword is available only on the S5130S-HI-G switch series.
You can configure the packet filtering on a VLAN interface to filter the following packets:
· Packets forwarded at Layer 3 by the VLAN interface.
· All packets, including packets forwarded at Layer 3 by the VLAN interface and packets forwarded at Layer 2 by the physical ports associated with the VLAN interface.
2. Create a VLAN interface and enter its view.
interface vlan-interface vlan-interface-id
If the VLAN interface already exists, you directly enter its view.
By default, no VLAN interface exists.
3. Specify the applicable scope of packet filtering on the VLAN interface.
packet-filter filter [ route | all ]
By default, the packet filtering filters packets forwarded at Layer 3.
You can configure the ACL module to generate log entries or SNMP notifications for packet filtering and output them to the information center or SNMP module at the output interval. When the first packet of a flow matches an ACL rule, the output interval starts. At the end of the interval, the device outputs a log entry or notification to record the number of matching packets and the matched ACL rule during the interval.
For more information about the information center and SNMP, see Network Management and Monitoring Configuration Guide.
2. Set the interval for outputting packet filtering logs or notifications.
acl { logging | trap } interval interval
The default setting is 0 minutes. By default, the device does not generate log entries or SNMP notifications for packet filtering.
2. Set the packet filtering default action to deny.
By default, the packet filter permits packets that do not match any ACL rule to pass.
Task |
Command |
Display ACL configuration and match statistics. |
display acl [ ipv6 | mac | user-defined ] { acl-number | all | name acl-name } |
Display ACL application information for packet filtering. |
display packet-filter { global | interface [ interface-type interface-number ] } [ inbound | outbound ] [ slot slot-number ] |
Display match statistics for packet filtering ACLs. |
display packet-filter statistics { global | interface interface-type interface-number } { inbound | outbound } [ [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] [ brief ] |
Display the accumulated statistics for packet filtering ACLs. |
display packet-filter statistics sum { inbound | outbound } [ ipv6 | mac | user-defined ] { acl-number | name acl-name } [ brief ] |
Display detailed ACL packet filtering information. |
display packet-filter verbose { global | interface interface-type interface-number } { inbound | outbound } [ [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] [ slot slot-number ] |
Display QoS and ACL resource usage. |
display qos-acl resource [ slot slot-number ] |
Clear ACL statistics. |
reset acl [ ipv6 | mac | user-defined ] counter { acl-number | all | name acl-name } |
Clear match statistics for packet filtering ACLs. |
reset packet-filter statistics { global | interface [ interface-type interface-number ] } { inbound | outbound } [ [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] |
ACL configuration examples
A company interconnects its departments through the device. Configure a packet filter to:
· Permit access from the President's office at any time to the financial database server.
· Permit access from the Finance department to the database server only during working hours (from 8:00 to 18:00) on working days.
· Deny access from any other department to the database server.
Figure 1 Network diagram
# Create a periodic time range from 8:00 to 18:00 on working days.
[Device] sysname Device
[Device] time-range work 08:0 to 18:00 working-day
# Assign IP addresses to interfaces.
[Device-GigabitEthernet1/0/1] ip address 192.168.0.1 24
[Device-GigabitEthernet1/0/1] ip address 192.168.1.1 24
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] ip address 192.168.2.1 24
[Device-GigabitEthernet1/0/3] quit
[Device] interface gigabitethernet 1/0/4
[Device-GigabitEthernet1/0/4] ip address 192.168.3.1 24
[Device-GigabitEthernet1/0/4] quit
# Configure IS-IS.
[Device] isis 1
[Device-isis-1] network-entity 00.0000.0000.0001.00
[Device-isis-1] is-level level-2
[Device-isis-1] cost-style wide
[Device-isis-1] address-family ipv4
[Device-isis-1-ipv4] quit
[Device-isis-1] quit
[Device-GigabitEthernet1/0/1] isis enable 1
[Device-GigabitEthernet1/0/2] isis enable 1
[Device-GigabitEthernet1/0/3] isis enable 1
[Device-GigabitEthernet1/0/4] isis enable 1
# Create an IPv4 advanced ACL numbered 3000.
[Device] acl advanced 3000
# Configure a rule to permit access from the President's office to the financial database server.
[Device-acl-ipv4-adv-3000] rule permit ip source 192.168.1.0 0.0.0.255 destination 192.168.0.100 0
# Configure a rule to permit access from the Finance department to the database server during working hours.
[Device-acl-ipv4-adv-3000] rule permit ip source 192.168.2.0 0.0.0.255 destination 192.168.0.100 0 time-range work
# Configure a rule to deny access to the financial database server.
[Device-acl-ipv4-adv-3000] rule deny ip source any destination 192.168.0.100 0
# Apply IPv4 advanced ACL 3000 to filter outgoing packets on interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] packet-filter 3000 outbound
# Verify that a PC in the Finance department can ping the database server during working hours. (All PCs in this example use Windows XP).
C:\> ping 192.168.0.100
Pinging 192.168.0.100 with 32 bytes of data:
Reply from 192.168.0.100: bytes=32 time=1ms TTL=255
Reply from 192.168.0.100: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.0.100:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
# Verify that a PC in the Marketing department cannot ping the database server during working hours.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
# Display configuration and match statistics for IPv4 advanced ACL 3000 on the device during working hours.
[Device] display acl 3000
Advanced IPv4 ACL 3000, 3 rules,
ACL's step is 5
rule 0 permit ip source 192.168.1.0 0.0.0.255 destination 192.168.0.100 0
rule 5 permit ip source 192.168.2.0 0.0.0.255 destination 192.168.0.100 0 time-range work (Active)
rule 10 deny ip destination 192.168.0.100 0
The output shows that rule 5 is active. Rule 5 and rule 10 have been matched four times as the result of the ping operations.
Configuration file
sysname Device
isis 1
is-level level-2
cost-style wide
address-family ipv4 unicast
ip address 192.168.0.1 255.255.255.0
isis enable 1
port link-mode route
combo enable copper
isis enable 1
ip address 192.168.2.1 255.255.255.0
isis enable 1
ip address 192.168.3.1 255.255.255.0
isis enable 1
time-range work 08:00 to 18:00 working-day
acl advanced 3000
