- 17-Network Management and Monitoring Command Reference
- 01-EAA commands
- 02-Event MIB commands
- 03-Flow log commands
- 04-NetStream commands
- 05-RMON commands
- 07-Mirroring commands
- 08-Process placement commands
- 09-Track commands
- 10-Interface collaboration commands
- 11-System maintenance and debugging commands
- 12-NQA commands
- 13-SNMP commands
- 14-Fast log output commands
- 15-Information center commands
- 16-NETCONF commands
- 17-Process monitoring and maintenance commands
- 18-BFD commands
- 19-NTP commands
14-Fast log output commands | 336.42 KB |
Fast log output commands (v2) (recommended)
customlog character-encoding utf-8
display customlog host v2 kernel
display customlog host v2 statistics
reset customlog host v2 statistics
Non-default vSystems do not support some of the fast log output commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
The device supports configuring fast log output using either v1 or v2 commands. As a best practice, use v2, as it allows for more convenient maintenance of the types of fast logs to be sent.
The module command in fast log output (v2) provides a set of parameters for all service modules. However, whether the configured parameters can take effect on a specific service module depends on whether the device supports that service module. For example, if the device does not support NAT, the device will not generate NAT-related fast logs, even if NAT fast log output parameters have been configured in the commands.
broker
Use broker to specify a Kafka broker.
Use undo broker to restore the default.
broker { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number]
undo broker { hostname | ipv4-address | ipv6 ipv6-address }
No Kafka broker is specified.
Kafka server view
context-admin
hostname: Specifies a hostname for the Kafka broker, a case-insensitive string of 1 to 253 characters. The hostname can contain letters, numbers, hyphens (-), underscores (_), and dots (.).
ipv4-address: Specifies an IP address for the Kafka broker.
ipv6 ipv6-address: Specifies an IPv6 address for the Kafka broker.
port port-number: Specifies a port number of the Kafka broker for receiving logs, in the range of 1 to 65535. The default port number is 9092. For the Kafka broker to receive logs, make sure the port number is the same as that configured for the broker on the Kafka server side.
Non-default vSystems do not support this command.
A broker is a member of a Kafka server cluster. After you configure the IP address and port of a broker for receiving logs on the device side, the device will send logs in Kafka format to the specified address.
# Specify a Kafka broker with IP address 1.1.1.1 and port number 9092 in Kafka server ABC.
[Sysname] kafka-server ABC
[Sysname- kafka-server-ABC] broker 1.1.1.1 port 9092
kafka-server
Use customlog character-encoding utf-8 to configure fast log output to use the UTF-8 encoding.
Use undo customlog character-encoding to restore the default.
Fast log output uses the GB18030 encoding.
context-admin
vsys-admin
For the log host to correctly display Chinese characters in received log messages, make sure the fast log output module uses the same character set encoding as the log host. Fast log output supports using GB18030 and UTF-8 encodings.
# Configure fast log output to use the UTF-8 encoding.
[Sysname] customlog character-encoding utf-8
customlog host v2
Use customlog host v2 to configure a log host for fast log output and enter its view, or enter the view of an existing log host.
Use undo customlog host v2 to delete a log host for fast log output.
customlog host v2 [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ]
undo customlog host v2 [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ]
No log hosts are configured for fast log output.
context-admin
vsys-admin
vpn-instance vpn-instance-name: Specifies the VPN instance to which the log host belongs. The vpn-instance-name argument specifies an MPLS L3VPN name, a case-sensitive string of 1 to 31 characters. If the log host is on the public network, do not specify this option.
hostname: Specifies a log host by its host name, a case-insensitive string of 1 to 253 characters. Valid characters are letters, digits, hyphens (-), underscores (_), and dot (.).
ipv4-address: Specifies a log host by its IPv4 address.
ipv6 ipv6-address: Specifies a log host by its IPv6 address.
port port-number: Specifies the port number on which the log host receives log data. The value range is 1 to 65535 and the default is 514. The setting must be the same as the port number configured on the log host. Otherwise, the log host cannot receive logs.
You can specify a maximum of 10 log hosts for fast log output.
The log host resources on the device are shared by the customlog host v2 command and the customlog host command. If the customlog host command has already specified 10 log hosts, you cannot use the customlog host v2 command to specify additional log hosts, and vice versa.
Compared to the log hosts configured with the customlog host command, those configured with the customlog host v2 command allow for easier maintenance of the types of fast output logs to be sent.
If you specify a log host by the host name, you must also use the ip host or ipv6 host command to specify the corresponding IP address for the host name. Failure to do so will result in the specified log host being unable to receive log messages.
You cannot specify the local host as a log host.
# Configure the log host with an IP address of 1.1.1.1 and a port number of 1000 for fast log output, and enter log host view.
[Sysname] customlog host v2 1.1.1.1 port 1000
[Sysname-customlog-host-v2-1.1.1.1/1000]
customlog host
ip host (Layer 3—IP Services Command Reference)
ipv6 host (Layer 3—IP Services Command Reference)
customlog host v2 test
Use customlog host v2 test to send a specified number and type of test logs.
In standalone mode:
customlog host v2 test count number { aft | anti-virus | attack-defense | audit | data-filter | dga | file-filter | iot-access-control | iot-flow-control | iot-format-check | iot-signal-control | ips | keepalive | loadbalance { global-intelligent-dns | local-intelligent-dns | outbound-link-lb | server-lb | transparent-dns-proxy } | nat | sandbox | scd | security-policy | security-policy-config | session | sslvpn | traffic-policy | trusted-access iam { authorization | notification } | url-filter | waf } [ slot slot-number [ cpu cpu-number ] ] [ kernel ]
In IRF mode:
customlog host v2 test count number { aft | anti-virus | attack-defense | audit | data-filter | dga | file-filter | iot-access-control | iot-flow-control | iot-format-check | iot-signal-control | ips | keepalive | loadbalance { global-intelligent-dns | local-intelligent-dns | outbound-link-lb | server-lb | transparent-dns-proxy } | nat | sandbox | scd | security-policy | security-policy-config | session | sslvpn | traffic-policy | trusted-access iam { authorization | notification } | url-filter | waf } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ kernel ]
No test log number or type is specified.
context-admin
vsys-admin
count: Specifies the number of test logs to be sent for the test. The value range for the number argument is 1 to 100.
aft: Sends logs from the AFT module to the log host.
anti-virus: Sends logs from the anti-virus module to the log host.
attack-defense: Sends logs from the attack detection and prevention module to the log host.
audit: Sends logs from the application audit and management module to the log host.
data-filter: Sends logs from the data filtering module to the log host.
dga: Sends logs from the DGA detection module to the log host.
file-filter: Sends logs from the file filtering module to the log host.
iot-access-control: Sends logs from the access control module for IoT device security management to the log host.
iot-flow-control: Sends logs from the standard traffic control module for IoT device security management to the log host.
iot-format-check: Send logs from the standard format check module for IoT device security management to the log host.
iot-signal-control: Sends logs from the sensitive signal control module for IoT device security management to the log host.
ips: Send logs from the intrusion prevention system (IPS) module to the log host.
keepalive: Sends logs from the keepalive module to the log host.
loadbalance { global-intelligent-dns | local-intelligent-dns | outbound-link-lb | server-lb | transparent-dns-proxy }: Sends logs from a load balancing module to the log host. If you do not specify a load balancing module, the device can send logs from all load balancing-related modules to the log host.
· global-intelligent-dns: Specifies the LB global intelligent DNS module.
· local-intelligent-dns: Specifies the LB local intelligent DNS module.
· outbound-link-lb: Specifies the outbound link load balancing module.
· server-lb: Specifies the server load balancing module.
· transparent-dns-proxy: Specifies the LB DNS transparent proxy module.
nat: Sends logs from the NAT module to the log host.
sandbox: Sends logs from the sandbox module to the log host.
scd: Sends logs from the server connection detection module to the log host.
security-policy: Sends security policy packet matching logs to the log host.
security-policy-config: Sends security policy configuration logs to the log host.
session: Sends the session management module logs to the log host.
sslvpn: Sends the SSL VPN module logs to the log host.
traffic-policy: Sends the bandwidth management module logs to the log host.
trusted-access iam { authorization | notification }: Sends logs from the IAM trusted access control module to the log host. If you do not specify any parameters, the command sends logs from the IAM trusted access module to the log host.
· authorization: Specifies the authorization logs of the IAM trusted access control module.
· notification: Specifies the notification logs of the IAM trusted access control module.
url-filter: Sends logs from the URL filtering module to the log host.
waf: Sends logs from the WAF module to the log host.
slot slot-number: Specifies a card by its slot number. The specified card will send the test logs. If you do not specify this option, the active MPU sends the test logs. (In standalone mode.) In standalone mode:
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. The specified card on the specified IRF member device will send the test logs. If you do not specify this option, the global active MPU will send the test logs.(In IRF mode.) In IRF mode:
cpu cpu-number: Specifies a CPU by its number. The specified CPU will send the test logs. This option is available only if multiple CPUs are available on the specified slot.
kernel: Sends the test logs in kernel mode.
After a log host is configured for fast log output, use this command to generate a specific type of test logs and check if the log host can receive these test logs normally.
The log host does not reply to the device after it receives the test logs. You need to check the test result on the log host.
# Send test logs for the SSL VPN module.
<Sysname> customlog host v2 test count 1 sslvpn
customlog host v2
customlog host source
Use customlog host source to specify a source IP address for fast log output.
Use undo customlog host source to restore the default.
customlog host source interface-type interface-number
The source IP address of fast output logs is the primary IP address of the outgoing interface.
context-admin
vsys-admin
interface-type interface-number: Specifies a source interface by its type and number. The interface's primary IP address will be used as the source IP address of fast output logs.
Configure this command when you need to filter logs according to their source IP addresses on the log host.
The customlog host source command takes effect only after the customlog format and customlog host commands are configured.
# Use the IP address of Loopback 0 as the source IP address of fast output logs.
[Sysname] interface loopback 0
[Sysname-LoopBack0] ip address 2.2.2.2 32
[Sysname-LoopBack0] quit
[Sysname] customlog host source loopback 0
customlog kafka-server
Use customlog kafka-server to enable output of fast logs to a Kafka server.
Use undo customlog kafka-server to disable output of fast logs to a Kafka server.
customlog kafka-server server-name topic topic-name export dpi ips
undo customlog kafka-server server-name topic topic-name export
Output of fast logs to a Kafka server is disabled.
context-admin
server-name: Specifies a name for the Kafka server, a case-sensitive string of 1 to 15 characters. Valid characters are letters, digits, and underscores (_).
topic topic-name: Specifies a topic for the logs output to the Kafka server, a case-sensitive string of 1 to 249 characters. The topic can contain letters, numbers, hyphens (-), and underscores (_).
export: Specifies the type of logs to be output to the Kafka server.
dpi: Specifies the DPI module.
ips: Specifies the IPS module.
This command takes effect only when you have enabled fast log output for the corresponding modules using the customlog format command.
# Enable fast output of IPS logs to Kafka server ABC.
[Sysname] customlog kafka-server ABC topic TP1 export dpi ips
kafka-server
customlog language
Use customlog language to specify a language for fast log output.
Use undo customlog language to restore the default.
customlog language { chinese | english }
Fast logs are output in English.
context-admin
chinese: Specifies the language to Chinese.
english: Specifies the language to English.
Only some fields in the fast logs of certain service modules can be output in Chinese. The following fields in the service module logs support fast output in Chinese:
· Session logs: Application and Category.
· Audit logs: Application.
· URL filtering logs: Application, URLCategory, and URLParentCategory.
· IPS logs: Application, AttackName, Category, and SubCategory.
· Anti-virus logs: Application.
· WAF logs: Application, AttackName, Category, SubCategory, and SrcLocation.
· Sandbox logs: Application.
For IPS logs, you can use the customlog language chinese or log language chinese command to specify the language for fast log output to Chinese.
For more information about the log language chinese command, see DPI engine commands in DPI Command Reference.
# Specify the language for fast log output to Chinese.
[Sysname] customlog language chinese
log language chinese (DPI Command Reference)
customlog timestamp
Use customlog timestamp localtime to configure the timestamp of fast output logs to show the system time.
Use undo customlog timestamp localtime to restore the default.
The timestamp of fast output logs shows the Greenwich Mean Time (GMT).
context-admin
vsys-admin
# Configure the timestamp of fast output logs to show the system time.
[Sysname] customlog timestamp localtime
customlog with-sn
Use customlog with-sn to configure the device to carry its serial number in fast output logs.
Use undo customlog with-sn to restore the default.
customlog with-sn
The device does not carry its serial number in fast output logs.
context-admin
This feature enables a device to add a serial number (SN) field to fast output log messages, helping users to identify the devices that sent the log messages.
This feature is not applicable to fast output logs in TELECOM, CMCC, and UNICOM formats.
# Configure the device to carry its serial number in fast output logs.
[Sysname] customlog with-sn
Use display customlog host v2 kernel to display running kernel information for the specified log host.
In standalone mode:
display customlog host v2 kernel [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display customlog host v2 kernel [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
vsys-admin
vsys-operator
hostname: Specifies a log host by its host name, a case-insensitive string of 1 to 253 characters. Valid characters are letters, digits, hyphens (-), underscores (_), and dots (.).
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays the running kernel information of the active MPU.(In standalone mode.) In standalone mode:
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the running kernel information of the global active MPU.(In IRF mode.) In IRF mode:
cpu cpu-number: Specifies a CPU by its number. The command will display the specified running kernel information on the specified CPU. This option is available only if multiple CPUs are available on the specified slot.
After a log host is configured for fast log output, use this command to display kernel data information for the log host.
This command can display information about logs of a specified type sent from the specified chassis, card, or CPU to a specific log host.
If the command output contains fast log output information for a module and a log host, but the log host does not receive the specified logs, check if the module has generated logs and if network faults or restrictions exist between the device and the log host.
If the command output contains no fast log output configuration for a module or a log host, it might be because the fast log output for that module is not configured, or the configured log host name failed to be resolved to an IP address. In the latter case, use the ip host or ipv6 host command to specify an IP address for the host name.
# Display running kernel information for a log host.
<Sysname> display customlog host v2 kernel 1.1.1.1
Fast-output log host:
SrcIP: 10.153.230.143
DstIP: 1.1.1.1
Hostname:
Port: 514
VPN-instance:
Rate limit: Enabled
Output log format:
SSL VPN: Standard
Fast-output log host |
Parameters of the log host configured for fast log output. |
SrcIP |
Source IP address used by the device to send logs to the log host, which can be an IPv4 or IPv6 address. |
DstIP |
IP address of the log host, which can be an IPv4 or IPv6 address. A hyphen (-) indicates that the IP address of the log host was not resolved through the host name. |
Hostname |
Host name of the log host. |
Port |
Port number of the log host. |
VPN-instance |
VPN instance for the log host. |
Rate limit |
When the log host output interface is a management port, log output rate limiting is automatically enabled. |
Log type and output format |
Log type (module) and log output format. · SSL VPN: Logs of the SSL VPN module, output in standard format. · attack-defense: Logs of the attack detection and prevention module, output in standard format. · security-policy: Logs for security policy packet matching, which can be output in the following formats: ¡ Standard format. ¡ SGCC format. · security-policy-config: Logs for security policy configurations, output in SGCC format. · aft: AFT logs, which can be output in the following formats: ¡ Standard format. ¡ CMCC format. ¡ Unicom format. ¡ Telecom format. · nat: NAT logs, which can be output in the following formats: ¡ Standard format. ¡ CMCC format. ¡ Unicom format. ¡ Telecom format. ¡ TelecomNVI format. · scd: SCD logs, output in standard format. · Session: Session logs, output in standard format. · dpi audit: Logs of the application audit and management module, output in standard format. · dpi url-filter: URL filtering logs output in standard format. · dpi netshare: Logs of the NetShare control module, output in standard format. · dpi ips: IPS logs output in standard format. · dpi ips-sgcc: IPS logs output in SGCC format. · dpi reputation: Logs of the reputation module, output in standard format. · dpi waf: Logs of the WAF module, output in standard format. · dpi sandbox: Logs of the sandbox module, output in standard format. · dpi traffic-policy: Logs of the bandwidth management module, output in standard format. · dpi terminal: Logs of the terminal identification module, output in standard format. · dpi anti-virus: Logs of the anti-virus module, output in standard format. · dpi data-filter: Logs of the data filtering module, output in standard format. · dpi file-filter: Logs of the file filtering module, output in standard format. · dpi dga: Logs of the DGA detection module, output in standard format. · dpi iot-access-control: Logs of the IoT device access control module, output in standard format. · dpi iot-flow-control: Logs of the IoT device flow control module, output in standard format. · dpi iot-format-check: Logs of the IoT device format check module, output in standard format. · dpi iot-signal-control: Logs of the IoT device signaling control module, output in standard format. · loadbalance global-intelligent-dns: Logs of the LB global intelligent DNS module, output in standard format. · loadbalance transparent-dns-proxy: Logs of the LB DNS transparent proxy module, output in standard format. · load balance local-intelligent-dns: Logs of the LB local intelligent DNS module, output in standard format. · loadbalance outbound-link-lb: Logs of the outbound link load balancing module, output in standard format. · loadbalance server-lb: Logs of the LB server load balancing module, output in standard format. · trusted-access iam authentication: Logs of the trusted access IAM authentication module, output in standard format. · trusted-access iam notification: Logs of the trusted access IAM notification module, output in standard format. · keepalive: Logs of the keepalive module, output in SGCC format. |
customlog host v2
Use display customlog host v2 statistics to display statistics related to fast log output.
In standalone mode:
display customlog host v2 [ send-failed ] statistics [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display customlog host v2 [ send-failed ] statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
vsys-admin
vsys-operator
send-failed: Displays statistics for logs that failed to be sent. If you do not specify this keyword, the command displays statistics for successfully sent logs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays statistics for logs sent by all cards.(In standalone mode.) In standalone mode:
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays statistics for logs sent by all cards on all member devices.(In IRF mode.) In IRF mode:
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
Use this command to view the statistics of fast output logs sent from the device to the log host after the device has been sending logs to the log host for a period of time.
# Display fast log output statistics for logs successfully sent.
<Sysname> display customlog host v2 statistics
Slot 2:
Fast-output log host IP/port(hostname)/VPN-instance: 1.1.1.1/514(logserver)/abc
Log sending rate : 0
Log statistics by log type:
sslvpn user-login : 0
sslvpn packet-drop : 0
sslvpn AllocAddress : 0
sslvpn resource-access : 0
attack-defense : 0
scd : 0
session : 0
nat-match : 0
nat444-sessionA : 0
nat444-sessionW : 0
nat444-portA : 0
nat444-portW : 0
nat444-portF : 0
aft-match : 0
aft-sessionA : 0
aft-sessionW : 0
aft-portA : 0
aft-portW : 0
aft-portF : 0
security-policy matches : 0
security-policy config : 0
dpi audit : 0
dpi url-filter : 0
dpi netshare : 0
dpi ips : 0
dpi ips-sgcc : 0
dpi reputation : 0
dpi waf : 0
dpi sandbox : 0
dpi traffic-policy : 0
dpi terminal : 0
dpi anti-virus : 0
dpi data-filter : 0
dpi file-filter : 0
dpi dga : 0
dpi iot-access-control : 0
dpi iot-flow-control : 0
dpi iot-format-check : 0
dpi iot-signal-control : 0
loadbalance server-lb : 0
loadbalance global-intelligent-dns : 0
loadbalance transparent-dns-proxy : 0
loadbalance local-intelligent-dns : 0
loadbalance outbound-link-lb : 0
trusted-access iam authentication : 0
trusted-access iam notification : 0
keepalive : 0
# Display fast log output statistics for logs that failed to be sent.
<Sysname> display customlog host v2 send-failed statistics
Slot 2:
Send-failed log statistics by log type:
attack-defense : 0
scd : 0
session : 0
nat-match : 0
nat444-sessionA : 0
nat444-sessionW : 0
nat444-portA : 0
nat444-portW : 0
nat444-portF : 0
aft-match : 0
aft-sessionA : 0
aft-sessionW : 0
aft-portA : 0
aft-portW : 0
aft-portF : 0
dpi audit : 0
dpi url-filter : 0
dpi netshare : 0
dpi ips : 0
dpi ips-sgcc : 0
dpi reputation : 0
dpi waf : 0
dpi sandbox : 0
dpi terminal : 0
dpi anti-virus : 0
dpi data-filter : 0
dpi file-filter : 0
dpi dga : 0
keepalive : 0
Fast-output log host IP/port(hostname)/VPN-instance |
IP address, port number (host name), and associated VPN instance of the log host for fast log output. The IP address can be either an IPv4 or IPv6 address. If the host name (domain name) for the log host is not configured, the host name will not be displayed. If no VPN instance is specified for the log host, the VPN instance will not be displayed. |
Log sending rate |
Log sending rate |
Log statistics by log type |
Statistics by log type for successfully sent fast logs: · sslvpn user-login—Number of fast logs sent for SSL VPN login and logout events. · sslvpn packet-drop—Number of fast logs sent for SSL VPN packet drops. · sslvpn AllocAddress—Number of fast logs sent for SSL VPN address requests. · sslvpn resource-access—Number of fast logs sent for SSL VPN resource access. · attack-defense: Number of fast logs sent for attack detection and prevention. · security-policy matches—Number of fast logs sent for security policy matches. · security-policy config—Number of fast logs sent for security policy configurations. · scd—Number of fast logs sent for SCD. · session—Number of fast logs sent for sessions. · nat_match—Number of fast logs sent for NAT in the standard format. · nat444_sessionA: Number of fast logs sent for new NAT444 sessions. · nat444_sessionW: Number of fast logs sent for deleted NAT444 sessions. · nat444_portA—Number of fast logs sent for NAT444 user port block allocations. · nat444_portW—Number of fast logs sent for NAT444 user port block withdrawals. · nat444_portF—Number of fast logs sent for NAT444 user port block alarms. · aft_match—Number of fast logs in standard format sent for AFT. · aft_sessionA—Number of fast logs sent for AFT new sessions. · aft_sessionW—Number of fast logs sent for AFT deleted sessions. · aft_portA—Number of fast logs sent for AFT user port block allocations. · aft_portW—Number of fast logs sent for AFT user port block withdrawals. · aft_portF—Number of fast logs sent for AFT user port block alarms. · adi audit—Number of fast logs sent for the application audit and management module. · dpi url-filter—Number of fast logs sent for the URL filtering module. · dpi netshare—Number of fast logs sent for the NetShare control module. · dpi ips—Number of fast logs sent for the IPS module. · dpi ips-sgcc—Number of fast logs in SGCC format sent for the IPS module. · dpi reputation—Number of fast logs sent for the reputation module. · dpi waf—Number of fast logs sent for the WAF module. · dpi sandbox—Number of fast logs sent for the sandbox module. · dpi traffic-policy—Number of fast logs sent for the bandwidth management module. · dpi terminal—Number of fast logs sent for the terminal identification module. · dpi anti-virus—Number of fast logs sent for the anti-virus module · dpi data-filter—Number of fast logs sent for the data filtering module. · dpi file-filter—Number of fast logs sent for the file filtering module. · dpi dga—Number of fast logs sent for the DGA detection module. · dpi iot-access-control: Number of fast logs sent for the IoT device access control module. · dpi iot-flow-control—Number of fast logs sent for IoT device flow control module. · dpi iot-format-check—Number of fast logs sent for the IoT device format check module. · dpi iot-signal-control—Number of fast logs sent for the IoT device signaling control module. · loadbalance server-lb—Number of fast logs sent for the server load balancing module. · loadbalance global-intelligent-dns—Number of fast logs sent for the global intelligent DNS module. · loadbalance transparent-dns-proxy—Number of fast logs sent for the DNS transparent proxy module. · loadbalance local-intelligent-dns—Number of fast logs sent for the local intelligent DNS module. · loadbalance outbound-link-lb—Number of fast logs sent for the outbound link load balancing module. · trusted-access iam authentication—Number of fast logs sent for IAM authentication. · trusted-access iam notification—Number of fast logs sent for IAM notifications · keepalive—Number of fast logs sent for the keepalive module. |
Send-failed log statistics by log type |
Statistics by log type for fast logs that failed to be sent: · sslvpn user-login—Number of fast logs that failed to be sent for SSL VPN login and logout events. · sslvpn packet-drop—Number of fast logs that failed to be sent for SSL VPN packet drops. · sslvpn AllocAddress—Number of fast logs that failed to be sent for SSL VPN address requests. · sslvpn resource-access—Number of fast logs that failed to be sent for SSL VPN resource access. · attack-defense: Number of fast logs that failed to be sent for attack detection and prevention. · security-policy matches—Number of fast logs that failed to be sent for security policy matches. · security-policy-config—Number of fast logs that that failed to be sent for security policy configurations. · scd—Number of SCD fast logs that failed to be sent. · session—Number of session fast logs that failed to be sent. · nat_match—Number of fast logs that failed to be sent for NAT in the standard format. · nat444_sessionA—Number of fast logs that failed to be sent for NAT444 new sessions. · nat444_sessionW—Number of fast logs that failed to be sent for NAT444 deleted sessions. · nat444_portA—Number of fast logs that failed to be sent for NAT444 user port block allocations. · nat444_portW—Number of fast logs that failed to be sent for NAT444 user port block withdrawals. · nat444_portF—Number of fast logs that failed to be sent for NAT444 user port block alarms. · aft_match—Number of fast logs in standard format that failed to be sent for AFT. · aft_sessionA—Number of fast logs that failed to be sent for AFT new sessions. · aft_sessionw—Number of fast logs that failed to be sent for AFT deleted sessions. · aft_portA—Number of fast logs that failed to be sent for AFT user port block allocations. · aft_portW—Number of fast logs that failed to be sent for AFT user port block withdrawals. · aft_portF—Number of fast logs that failed to be sent for AFT user port block alarms. · dpi audit—Number of fast logs that failed to be sent for the application audit and management module. · dpi url-filter—Number of fast logs that failed to be sent for the URL filtering module. · dpi netshare—Number of fast logs that failed to be sent for the NetShare control module. · dpi ips—Number of fast logs that failed to be sent for the IPS module. · dpi ips-sgcc—Number of fast logs in SGCC format that failed to be sent for the IPS module. · dpi reputation—Number of fast logs that failed to be sent for the reputation module. · dpi waf—Number of fast logs that failed to be sent for the WAF module. · dpi sandbox—Number of fast logs that failed to be sent for the sandbox module. · dpi traffic-policy—Number of fast logs that failed to be sent for the bandwidth management module. · dpi terminal—Number of fast logs that failed to be sent for the terminal identification module. · dpi anti-virus—Number of fast logs that failed to be sent for the anti-virus module. · dpi data-filter—Number of fast logs that failed to be sent for the data filtering module. · dpi file-filter—Number of fast logs that failed to be sent for the file filtering module. · dpi dga—Number of fast logs that failed to be sent for the DGA detection module. · dpi iot-access-control: Number of fast logs that failed to be sent for the IoT device access control module. · dpi iot-flow-control—Number of fast logs that failed to be sent for IoT device flow control module. · dpi iot-format-check—Number of fast logs that failed to be sent for the IoT device format check module. · dpi iot-signal-control—Number of fast logs that failed to be sent for the IoT device signaling control module. · loadbalance server-lb—Number of fast logs that failed to be sent for the server load balancing module. · loadbalance global-intelligent-dns—Number of fast logs that failed to be sent for the global intelligent DNS module. · loadbalance transparent-dns-proxy—Number of fast logs that failed to be sent for the DNS transparent proxy module. · loadbalance local-intelligent-dns—Number of fast logs that failed to be sent for the local intelligent DNS module. · loadbalance outbound-link-lb—Number of fast logs that failed to be sent for the outbound link load balancing module. · trusted-access iam authentication—Number of fast logs that failed to be sent for the trusted access IAM authentication module. · trusted-access iam notification—Number of fast logs that failed to be sent for the trusted access IAM notification module. · keepalive—Number of fast logs that failed to be sent for the keepalive module. |
customlog host v2
kafka-server
Use kafka-server to create a Kafka server and enter its view, or enter the view of an existing Kafka server.
Use undo kafka-server to delete a Kafka server.
undo kafka-server server-name
No Kafka server exists.
context-admin
server-name: Specifies a name for the Kafka server, a case-sensitive string of 1 to 15 characters. The hostname can contain letters, numbers, and underscores (_).
A Kafka server is a server for receiving fast logs in Kafka format. When you have deployed a Kafka log server in the network, you can create a Kafka server on the device to send fast logs in Kafka format to the Kafka log server.
# Create a Kafka server named ABC.
module aft
Use module aft to enable fast log output from the AFT module to the log host.
Use undo module to disable fast log output from the AFT module to the log host.
module aft [ cmcc | unicom | telecom ]
undo module aft
Fast log output from the AFT module to the log host is disabled.
Log host view
context-admin
vsys-admin
cmcc: Outputs logs from the AFT module in CMCC format.
unicom: Outputs logs from the AFT module in UNICOM format.
telecom: Outputs logs from the AFT module in TELECOM format.
If you do not specify any parameters, the device will output logs from the AFT module in standard format.
# Enable fast log output from the AFT module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module aft
module anti-virus
Use module anti-virus to enable fast log output from the anti-virus module to the log host.
Use undo module anti-virus to disable fast log output from the anti-virus module to the log host.
module anti-virus
Fast log output from the anti-virus module to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the anti-virus module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module anti-virus
module attack-defense
Use module attack-defense to enable fast log output from the attack detection and prevention module to the log host.
Use undo module attack-defense to disable fast log output from the attack detection and prevention module to the log host.
Fast log output from the attack detection and prevention module to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the attack detection and prevention module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module attack-defense
module audit
Use module audit to enable fast log output from the application audit and management module to the log host.
Use undo module audit to disable fast log output from the application audit and management module to the log host.
module audit
undo module audit
Fast log output from the application audit and management module to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the application audit and management module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module audit
module data-filter
Use module data-filter to enable fast log output from the data filtering module to the log host.
Use undo module data-filter to disable fast log output from the data filtering module to the log host.
module data-filter
Fast log output from the data filtering module to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the data filtering module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module data-filter
module dga
Use module dga to enable fast log output from the DGA detection module to the log host.
Use undo module dga to disable fast log output from the DGA detection module to the log host.
module dga
undo module dga
Fast log output from the DGA detection module to the log host is disabled.
Log host view
context-admin
# Enable fast log output from the DGA detection module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module dga
module file-filter
Use module file-filter to enable fast log output from the file filtering module to the log host.
Use undo module file-filter to disable fast log output from the file filtering module to the log host.
module file-filter
Fast log output from the file filtering module to the log host is disabled.
Log host view
context-admin
vsys-admin
You can only configure only one type of fast log at a time. Multiple types will be displayed on multiple lines.
# Enable fast log output from the file filtering module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module file-filter
module iot-access-control
Use module iot-access-control to enable fast log output from the device access control module in IoT device security management to the log host.
Use undo module iot-access-control to disable fast log output from the device access control module in IoT device security management to the log host.
Fast log output from the device access control module in IoT device security management to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the device access control module for IoT device security management to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module iot-access-control
module iot-flow-control
Use module iot-flow-control to enable fast log output from the standard traffic control module for IoT device security management to the log host.
Use undo module iot-flow-control to disable fast log output from the standard traffic control module for IoT device security management to the log host.
Fast log output from the standard traffic control module for IoT device security management to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the standard traffic control module for IoT device security management to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module iot-flow-control
module iot-format-check
Use module iot-format-check to enable fast log output from the standard format check module for IoT device security management to the log host.
Use undo module iot-format-check to disable fast log output from the standard format check module for IoT device security management to the log host.
Fast log output from the standard format check module for IoT device security management to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the standard format check module for IoT device security management to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module iot-format-check
module iot-signal-control
Use module iot-signal-control to enable fast log output from the sensitive signal control module for IoT device security management to the log host.
Use undo module iot-signal-control to disable fast log output from the sensitive signal control module for IoT device security management to the log host.
Fast log output from the sensitive signal control module for IoT device security management to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the sensitive signal control module for IoT device security management to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module iot-signal-control
module ips
Use module ips to enable fast log output from the IPS module to the log host.
Use undo module ips to disable fast log output from the IPS module to the log host.
module ips [ sgcc { policy-hit | signature-update } ]
undo module ips [ sgcc { policy-hit | signature-update } ]
Fast log output from the IPS module to the log host is disabled.
Log host view
context-admin
vsys-admin
sgcc { policy-hit | signature-update }: Specifies the SGCC format for the specified type of IPS logs. If you do not specify the sgcc keyword, the standard format is used for fast output of the IPS policy hit logs.
· policy-hit: Specifies the IPS policy hit logs.
· signature-update: Specifies the IPS signature update logs.
# Enable fast log output from the IPS module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module ips
module keepalive
Use module keepalive to enable fast log output from the keepalive module to the log host.
Use undo module keepalive to disable fast log output from the keepalive module to the log host.
module keepalive sgcc
Fast log output from the keepalive module to the log host is disabled.
Log host view
context-admin
sgcc: Outputs logs from the keepalive module in SGCC format.
[Sysname-customhost-host-v2-1.1.1.1/1000] module sslvpn
module loadbalance
Use module loadbalance to enable fast log output from LB modules to the log host.
Use undo module loadbalance to disable fast log output from LB modules to the log host.
module loadbalance [ global-intelligent-dns | local-intelligent-dns | outbound-link-lb | server-lb | transparent-dns-proxy ] *
undo module loadbalance [ global-intelligent-dns | local-intelligent-dns | outbound-link-lb | server-lb | transparent-dns-proxy ] *
Fast log output from LB modules to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from all LB modules to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module loadbalance
module nat
Use module nat to enable fast log output from the NAT module to the log host.
Use undo module nat to disable fast log output from the NAT module to the log host.
module nat [ cmcc | telecom | telecom-vni | unicom ]
undo module nat
Fast log output for the NAT module is disabled.
Log host view
context-admin
vsys-admin
cmcc: Outputs logs from the NAT module in CMCC format.
unicom: Outputs logs from the NAT module in UNICOM format.
telecom: Outputs logs of the NAT module in TELECOM format.
telecom-vni: Outputs logs of the NAT module in TELECOM format with VNI (VXLAN ID).
If you do not specify any parameters, the device will output logs from the NAT module in standard format.
# Enable fast log output in CMCC format from the NAT module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module nat cmcc
module netshare
Use module netshare to enable fast log output from the NetShare control module to the log host.
Use undo module netshare to disable fast log output from the NetShare control module to the log host.
module netshare
Fast log output from the NetShare control module to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the NetShare control module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module netshare
module reputation
Use module reputation to enable fast log output from the IP reputation, domain reputation, and URL reputation module to the log host.
Use undo module reputation to disable fast log output from the IP reputation, domain reputation, and URL reputation module to the log host.
module reputation
Fast log output from the IP reputation, domain reputation, and URL reputation module to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the IP reputation, domain reputation, and URL reputation module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module reputation
module sandbox
Use module sandbox to enable fast log output from the sandbox module to the log host.
Use undo module sandbox to disable fast log output from the sandbox module to the log host.
module sandbox
undo module sandbox
Fast log output from the sandbox module to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the sandbox module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module sandbox
module scd
Use module scd to enable fast log output from the server connection detection module to the log host.
Use undo module scd to disable fast log output from the server connection detection module to the log host.
module scd
undo module scd
Fast log output from the server connection detection module to the log host is disabled.
Log host view
context-admin
# Enable fast log output from the server connection detection module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module scd
module security-policy
Use module security-policy to enable fast log output of security policy packet matching logs to the log host.
Use undo module security-policy to disable fast log output of security policy packet matching logs to the log host.
module security-policy [ sgcc ]
Fast log output of security policy packet matching logs to the log host is disabled.
Log host view
context-admin
vsys-admin
sgcc: Outputs fast logs in SGCC format for security policy packet matching. If you do not specify this keyword, the output uses the standard format.
# Enable fast log output of security policy packet matching logs to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module security-policy
module security-policy-config
Use module security-policy-config to enable fast log output of security policy configuration logs to the log host.
Use undo module security-policy-config to disable fast log output of security policy configuration logs to the log host.
module security-policy-config sgcc
Fast log output of security policy configuration logs to the log host is disabled.
Log host view
context-admin
sgcc: Outputs fast logs in SGCC format for security policy configurations.
# Enable fast log output of security policy configuration logs in SGCC format to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module security-policy-config sgcc
module session
Use module session to enable fast log output from the session management module to the log host.
Use undo module session to disable fast log output from the session management module to the log host.
module session
undo module session
Fast log output from the session management module to the log host is disabled.
Log host view
context-admin
vsys-admin
session: Sends logs from the session management module to the log host.
# Enable fast log output from the session management module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module session
module sslvpn
Use module sslvpn to enable fast log output from the SSL VPN module to the log host.
Use undo module sslvpn to disable fast log output from the SSL VPN module to the log host.
module sslvpn
undo module sslvpn
Fast log output from the SSL VPN module to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the SSL VPN module to the log host at IP address 1.1.1.1 on port 1000.
module terminal
Use module terminal to enable fast log output from the terminal identification module to the log host.
Use undo module terminal to disable fast log output from the terminal identification module to the log host.
module terminal
Fast log output from the terminal identification module to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the terminal identification module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module terminal
module traffic-policy
Use module traffic-policy to enable fast log output from the bandwidth management module to the log host.
Use undo module traffic-policy to disable fast log output from the bandwidth management module to the log host.
Fast log output from the bandwidth management module to the log host is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from bandwidth management module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module traffic-policy
module trusted-access iam
Use module trusted-access iam to enable fast log output from the IAM trusted access control module to the log host.
Use undo module trusted-access iam to disable fast log output from the IAM trusted access control module to the log host.
module trusted-access iam [ authorization | notification ] *
undo module trusted-access iam [ authorization | notification ] *
Fast log output from the IAM trusted access control module to the log host is disabled.
Log host view
context-admin
vsys-admin
authorization: Specifies the authorization logs of the IAM trusted access module.
notification: Specifies the notification logs of the IAM trusted access module.
# Enable fast log output from the IAM trusted access control module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module trusted-access iam authorization
module url-filter
Use module url-filter to enable fast log output from the URL filtering module to the log host.
Use undo module url-filter to disable fast log output from the URL filtering module to the log host.
module url-filter [ unicom ]
undo module url-filter [ unicom ]
Fast log output from the URL filtering module to the log host is disabled.
Log host view
context-admin
vsys-admin
unicom: Outputs logs from the URL filtering module in UNICOM format.
# Enable fast log output in UNICOM format from the URL filtering module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module url-filter unicom
module waf
Use module waf to enable fast log output from the WAF module to the log host.
Use undo module waf to disable fast log output from the WAF module to the log host.
module waf
undo module waf
Fast log output for the WAF module is disabled.
Log host view
context-admin
vsys-admin
# Enable fast log output from the WAF module to the log host at IP address 1.1.1.1 on port 1000.
[Sysname-customhost-host-v2-1.1.1.1/1000] module waf
Use reset customlog host v2 statistics to clear statistics related to fast log output.
In standalone mode:
reset customlog host v2 statistics [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset customlog host v2 statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
vsys-admin
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears statistics for logs sent by all cards.In standalone mode:(In standalone mode.) In standalone mode:
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears statistics for logs sent by all cards on all member devices.In IRF mode:(In IRF mode.) In IRF mode:
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot. Support for this option depends on the device model.
# Clear the statistics for fast log output.
<Sysname> reset customlog host v2 statistics
vpn-instance
Use vpn-instance to associate a VPN instance with a Kafka server.
Use undo vpn-instance to restore the default.
undo vpn-instance
A Kafka server is associated with the public network.
Kafka server view
context-admin
vpn-instance-name: Specifies a VPN instance, a case-sensitive string of 1 to 31 characters.
Each Kafka server can be associated with only one VPN instance. If the VPN instance specified by this command does not exist, the Kafka server does not take effect. Once the VPN instance is created, the Kafka server takes effect.
# Associate VPN instance vpn1 with Kafka server ABC.
[Sysname- kafka-server-ABC] vpn-instance vpn1
kafka-server
Fast log output commands (v1)
broker
Kafka server view
context-admin
kafka-server
context-admin
vsys-admin
customlog format
Use customlog format to enable fast log output.
Use undo customlog format to restore the default.
customlog format { aft | aft-cmcc | aft-telecom | aft-unicom | attack-defense | cntm | dns | dpi [ anti-virus | audit | data-filter | file-filter | iot-access-control| iot-flow-control | iot-format-check | iot-signal-control | ips [ sgcc { policy-hit | signature-update } | cmcc-kafka ] | netshare | reputation | sandbox | terminal | traffic-policy | url-filter [ unicom ] | waf | dga ] | keepalive sgcc | lb [ dns-proxy | gslb | inbound | outbound | slb ] | nat { cmcc | telecom [ with-vni ] | unicom } | packet-filter [ sgcc ] | scd | security-policy sgcc | session | trusted-access { csap | iam [ authorization | notification ] } | wlan }
undo customlog format { aft | aft-cmcc | aft-telecom | aft-unicom | attack-defense | cntm | dns | dpi [ anti-virus | audit | data-filter | file-filter | iot-access-control| iot-flow-control | iot-format-check | iot-signal-control | ips | netshare | reputation | sandbox | terminal | traffic-policy | url-filter [ unicom ] | waf | dga ] * | keepalive | lb [ dns-proxy | gslb | inbound | outbound |slb ] * | nat | packet-filter | scd | security-policy | session | trusted-access { csap | iam [ authorization | notification ] } | wlan } *
Fast log output is disabled.
context-admin
vsys-admin
aft: Enables fast log output for the AFT module.
attack-defense: Enables fast log output for the attack defense module.
dns: Enables fast log output for the DNS module.
dpi: Enables fast log output for a DPI-related module. If you do not specify a DIP module keyword, this command enables fast log output for all the DPI-related modules.
anti-virus: Specifies the anti-virus module.
audit: Specifies the application audit and management module.
cntm: Specifies the content moderation module.
data-filter: Specifies the data filtering module.
file-filter: Specifies the file filtering module.
iot-access-control: Specifies the device access control module for IoT device security management.
iot-flow-control: Specifies the standard traffic control module for IoT device security management.
iot-format-check: Specifies the standard format check module for IoT device security management.
iot-signal-control: Specifies the sensitive signal control module for IoT device security management.
sgcc: Specifies the SGCC format for the specified type of IPS logs. If you do not specify this keyword, the standard format is used for fast output of the IPS logs.
cmcc-kafka: Specifies the CMCC-Kafka format for the IPS policy hit logs. If you configure this keyword, you must also configure fast output of logs to Kafka servers. For more information about this feature, see the configuration guide.
netshare: Specifies the NetShare control module.
reputation: Specifies the IP reputation, domain reputation, and URL reputation modules.
sandbox: Specifies the sandbox module.
terminal: Specifies the terminal identification module.
traffic-policy: Specifies the bandwidth management module.
url-filter: Specifies the URL filtering module.
unicom: Specifies the UNICOM format for fast output URL filtering logs. If you do not specify this keyword, the standard format is used to output the logs.
waf: Specifies the Web application firewall module.
dga: Specifies the DGA detection module.
keepalive: Enables fast log output of keepalive logs. After this keyword is specified, the device sends keepalive logs to the log host periodically. If the log host cannot receive the keepalive logs in a specific period of time, the log host determines that the device is down. Non-default vSystems do not support this parameter.
lb: Enables fast log output for a load balancing module. If you do not specify a load balancing module, this command enables fast log output for all load balancing-related modules.
· dns-proxy: Specifies the transparent DNS proxy module.
· gslb: Specifies the global server load balancing module.
· inbound: Specifies the inbound link load balancing module.
· outbound: Specifies the outbound link load balancing module.
· slb: Specifies the server load balancing module.
nat: Enables fast log output in a specific format for the NAT module.
· cmcc: Specifies the CMCC format.
· telecom: Specifies the TELECOM format.
· unicom: Specifies the UNICOM format.
with-vni: Carries VNI (VXLAN ID) information in NAT logs.
packet-filter: Enables fast output of packet matching logs for the packet filter, object policy, and security policy modules.
scd: Enables fast log output for the service connection detection module.
security-policy: Enables fast log output of security policy configuration logs for the security policy module. Non-default vSystems do not support this parameter.
session: Enables fast log output for the session management module.
sgcc: Specifies the SGCC format for the specified type of logs. If you do not specify this keyword, the standard format is used for fast output of the logs. Non-default vSystems do not support this parameter.
trusted-access: Enables fast log output for the trusted access module.
· csap: Specifies the CSAP trusted access module.
· iam: Specifies the IAM trusted access module. If you specify this keyword without the authorization or notification keyword, this command enables fast output for all logs of the IAM trusted access module.
¡ authorization: Specifies the authorization logs.
¡ notification: Specifies the notification logs.
wlan: Enables fast log output for the WLAN module.
Application scenarios
The fast log output feature enables fast output of logs to log hosts.
Typically, logs generated by a service module are first sent to the information center, which then outputs the logs to the specified destination (such as to log hosts). When fast log output is configured, logs of service modules are sent directly to log hosts instead of to the information center. Compared to outputting logs to the information center, fast log output saves system resources.
This command provides a set of parameters for all service modules. However, whether the configured parameters can take effect on a specific service module depends on whether the device supports that service module. For example, if the device does not support NAT, the device will not generate NAT-related fast logs, even if NAT fast log output parameters have been configured in the commands.
Fast log output, flow log, and information center are exclusive from one another. When the customlog format command is configured, the specified service module uses only the fast log output method. For more information about flow log, see "Configuring flow log." For more information about the information center, see "Configuring the information center."
Fast log output, flow log, and information center are exclusive from one another. When the customlog format command is configured, the specified service module uses only the fast log output method. For more information about flow log, see "Configuring flow log." For more information about the information center, see System Management Configuration Guide.
You cannot specify both the standard format and SGCC format for IPS logs. If you configure both formats, the last specified format takes effect. However, you can configure either of the two formats and the CMCC-Kafka format for IPS logs.
To output logs of the NAT module to a log host, you must specify the log format required by the log host in the customlog format and customlog host commands. Logs of other modules can be output only in one format. You do not need to specify the format for these logs.
You can configure the device to carry VNI information in NAT logs only if you specify the TELECOM format. NAT logs that carry the VNI field use a new format different from the TELECOM format.
For more information about a service module, see the service module configuration in the related configuration guide.
# Enable fast log output for the session management module.
<Sysname> system
[Sysname] customlog format session
customlog host
Use customlog host to configure fast log output parameters.
Use undo customlog host to remove the fast log output configuration.
customlog host [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] [ facility local-number ] export { aft | attack-defense | cmcc-sessionlog | cmcc-userlog | cntm | dns | dpi [ anti-virus | audit | data-filter | file-filter | iot-access-control | iot-flow-control | iot-format-check | iot-signal-control | ips | netshare | reputation | sandbox | terminal | traffic-policy | url-filter | waf | dga ] * | | keepalive | lb [ dns-proxy | gslb | inbound | outbound | slb ] * | packet-filter | scd | security-policy | session | telecom-sessionlog | telecom-userlog | trusted-access { csap | iam [ authorization | notification ] } * | unicom-sessionlog | unicom-userlog } *
undo customlog host [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ]
Fast log output parameters are not configured.
context-admin
vsys-admin
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the log host belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the log host is on the public network, do not specify this option.
hostname: Specifies a log host by its name, a case-insensitive string of 1 to 253 characters. The host name can contain letters, digits, hyphens (-), underscores (_), and dots (.).
ipv4-address: Specifies a log host by its IPv4 address.
ipv6 ipv6-address: Specifies a log host by its IPv6 address.
port port-number: Specifies the port number of the log host. The value range is 1 to 65535, and the default is 514. The setting must be the same as the port number configured on the log host. Otherwise, the log host cannot receive logs.
facility local-number: Specifies a logging facility value in the range of local0 to local7. A logging facility is primarily used for marking different log sources on a log host, and for searching and filtering logs from corresponding log sources. If you do not configure a facility for a log host, the value for the Facility field in the log headers output by each service module is used as the logging facility. For the AFT and NAT modules, logs output in CMCC and UNICOM formats will have a facility value of Local1, while logs output in TELECOM format will have a facility value of Local0.
export: Specifies a source module for fast log output.
aft: Outputs logs of the AFT module to the log host.
attack-defense: Outputs logs of the attack defense module to the log host.
cmcc-sessionlog: Outputs NAT session logs in CMCC format to the log host.
cmcc-userlog: Outputs NAT444 user logs in CMCC format to the log host.
dns: Outputs logs of the DNS module to the log host.
dpi: Outputs logs of a DPI-related module to the log host. If you specify the dpi keyword without a DPI module keyword, this command outputs logs of all the DPI-related modules to the log host.
reputation: Specifies the IP reputation and URL reputation modules.
keepalive: Outputs keepalive logs to the log host. Non-default vSystems do not support this parameter.
lb: Outputs logs of a load balancing module to the log host. If you do not specify a load balancing module, this command outputs logs of all load balancing modules to the log host.
· gslb: Specifies the global load balancing module.
packet-filter: Outputs packet matching logs of the packet filter, object policy, and security policy modules to the log host.
scd: Outputs logs of the server connection detection module to the log host.
security-policy: Outputs security policy configuration logs of the security policy module to the log host. Non-default vSystems do not support this parameter.
session: Outputs logs of the session management module to the log host.
telecom-sessionlog: Outputs NAT session logs in TELECOM format to the log host.
telecom-userlog: Outputs NAT444 user logs in TELECOM format to the log host.
unicom-sessionlog: Outputs NAT session logs in UNICOM format to the log host.
unicom-userlog: Outputs NAT444 user logs in UNICOM format to the log host.
trusted-access: Outputs logs of a trusted access module to the log host.
· iam: Specifies the IAM trusted access module. If you specify this keyword without the authorization or notification keyword, this command outputs all logs of the IAM trusted access module to the log host.
¡ notification: Specifies the event notification logs.
The customlog host command takes effect only after the customlog format command is configured.
To output NAT logs to a log host, you must specify the log format required by the log host in the customlog format and customlog host commands.
You can specify a maximum of 10 log hosts for fast log output.
The log host resources on the device are shared by the customlog host v2 command and the customlog host command. If the customlog host v2 command has already specified 10 log hosts, you cannot use the customlog host command to specify additional log hosts, and vice versa.
The facility local-number option takes effect only on the logs output in standard format from each service module as well as the AFT and NAT logs output in a carrier-customized format.
You cannot specify the local host as a log host.
# Output logs of the session management module to the log host at 1.1.1.1.
[Sysname] customlog host 1.1.1.1 port 1000 export session
context-admin
vsys-admin
context-admin
Non-default vSystems do not support this command.
kafka-server
customlog language
context-admin
customlog timestamp
context-admin
vsys-admin
customlog with-sn
customlog with-sn
context-admin
kafka-server
context-admin
[Sysname] kafka-server ABC
vpn-instance
undo vpn-instance
Kafka server view
context-admin
kafka-server
