- 17-Network Management and Monitoring Command Reference
- 01-EAA commands
- 02-Event MIB commands
- 03-Flow log commands
- 04-NetStream commands
- 05-RMON commands
- 07-Mirroring commands
- 08-Process placement commands
- 09-Track commands
- 10-Interface collaboration commands
- 11-System maintenance and debugging commands
- 12-NQA commands
- 13-SNMP commands
- 14-Fast log output commands
- 15-Information center commands
- 16-NETCONF commands
- 17-Process monitoring and maintenance commands
- 18-BFD commands
- 19-NTP commands
00-Preface | 110.38 KB |
Preface
This command reference describes commands that help you get started with the device. It includes the following feature modules: System maintenance and debugging, NQA, NTP, EAA, Process monitoring and maintenance, NETCONF, Information center, SNMP, NetStream, RMON, Flow log, Event MIB, Packet capture, Fast log output, Mirroring, GOLD, BFD, Track, Interface collaboration and Process placement.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
