- 06-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-EIGRP commands
- 07-BGP commands
- 08-Policy-based routing commands
- 09-IPv6 static routing commands
- 10-RIPng commands
- 11-OSPFv3 commands
- 12-IPv6 policy-based routing commands
- 13-Routing policy commands
- 14-DCN commands
12-IPv6 policy-based routing commands | 208.53 KB |
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
ipv6 policy-based-route-log enable
reset ipv6 policy-based-route statistics
apply access-vpn vpn-instance
Use apply access-vpn vpn-instance to set VPN instances.
Use undo apply access-vpn vpn-instance to remove VPN instances.
apply access-vpn vpn-instance vpn-instance-name
undo apply access-vpn vpn-instance [ vpn-instance-name ]
No VPN instances are specified for a node.
IPv6 policy node view
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
Application scenarios
You can specify a maximum of n VPN instances for a node. The matching packets are forwarded according to the forwarding table of the first available VPN instance.
With a VPN instance specified, the undo apply access-vpn vpn-instance command removes the VPN instance.
Without any VPN instance specified, the undo apply access-vpn vpn-instance command removes all VPN instances.
# Set VPN 1 for node 10. (VPN 1 already exists. )
[Sysname] ipv6 policy-based-route policy1 permit node 10
[Sysname-pbr6-policy1-10] apply access-vpn vpn-instance vpn1
apply default-next-hop
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-16>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-16> ]
No default next hops are set.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the default next hop belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the default next hop belongs to the public network, do not specify this option.
ipv6-address: Specifies the IPv6 address of the default next hop.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-16>: Indicates that you can specify up to 16 default next hops.
You can specify multiple default next hops for backup or load sharing in one command line or by executing this command multiple times.
· If the apply loadshare default-next-hop command is not configured on the policy node, multiple default next hops operate in primary/backup mode. PBR selects the first available default next hop according to the configuration order as the primary next hop to guide packet forwarding.
· If the apply loadshare default-next-hop command is configured on the policy node, multiple default next hops operate in load sharing mode. PBR load shares packets in round robin manner, starting from the first configured default next hop. PBR performs per-packet load sharing for packets that do not match any fast forwarding entry, and performs per-flow load sharing for packets that match a fast forwarding entry.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1:1::1:1.
[Sysname] ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply default-next-hop 1:1::1:1 direct
apply default-srv6-be
Use apply default-srv6-be to configure packet forwarding in default SRv6 BE mode.
Use undo apply default-srv6-be to remove the configuration.
apply default-srv6-be remote-sid { remote-sid locator-prefix-len }&<1-2>
undo apply default-srv6-be remote-sid [ { remote-sid locator-prefix-len }&<1-2> ]
Packet are not forwarded in default SRv6 BE mode.
remote-sid remote-sid: Specifies the default SRv6 BE destination node SID.
locator-prefix-len: Specifies the locator length for the destination node SID, in the range of 32 to 120.
&<1-2>: Indicates that the argument before it can be entered up to two times.
You can use the remote-sid and locator-prefix-len arguments to uniquely identify a locator. The device performs SRv6 encapsulation for matching packets (encapsulates an IPv6 header with the default SRv6 BE destination node SID used as the destination address), and forwards them through the IGP route associated with the locator.
You can specify up to two destination node SIDs for the default SRv6 BE mode for backup in one command line or by executing this command multiple times. When you specify up to two SIDs, you cannot specify new SIDs.
With a default SRv6 BE destination node SID specified, the undo form of the command removes the specified default SRv6 BE destination node SID. Without any default SRv6 BE destination node SIDs specified, the undo form of the command removes all configured default SRv6 BE destination node SIDs.
# Configure packet forwarding in default SRv6 BE mode. Specify the default SRv6 BE destination node SID as 1000::1 and the locator length as 32.
[Sysname-pbr6-aa-1] apply default-srv6-be remote-sid 1000::1 32
apply default-srv6-policy
Use apply default-srv6-policy to set default SRv6 TE policies.
Use undo apply default-srv6-policy to remove default SRv6 TE policies.
apply default-srv6-policy { endpoint color [ { sid | vpnsid } sid [ compress-16 block block-length flavor { coc-next | next [ wlib ] } ] ] }&<1-2>
undo apply default-srv6-policy [ { endpoint color }&<1-2> ]
No default SRv6 TE policies are set.
endpoint: Specifies a default SRv6 TE policy by its endpoint IPv6 address.
color: Specifies a default SRv6 TE policy by its color attribute value in the range of 0 to 4294967295.
sid: Indicates that the SRv6 SID of the destination node is a public network SID.
vpnsid: Indicates that the SRv6 SID of the destination node is a VPN SID.
sid: Specifies the SRv6 SID of the destination node in IPv6 address format.
compress-16: Compresses the specified SRv6 SID into 16 bits through G-SRv6 and encapsulates it in an SRv6 packet when configuring a default SRv6 TE policy to guide traffic forwarding. If you do not specify this keyword, the SID will be encapsulated in the SRv6 packet in the standard 128-bit format.
block block-value: Specifies the length of the common prefix when using 16-bit G-SRv6 compression. The block-value argument represents the common prefix length in the range of 16 to 88.
flavor: Specifies the flavor carried by the SID.
coc-next: Specifies the flavor carried by the SID as COC and NEXT.
next: Specifies the flavor carried by the SID as NEXT.
wlib: Indicates that the specified SID must be allocated from the W-LIB space of the COC16-type locator in wlib mode and must carry the NEXT flavor. If you specify this keyword, the device encapsulates this SID with 32 bits of information, including the 16-bit compressed Function portion and the extended 16-bit W-LIB space portion. If you do not specify this keyword, the device encapsulates only the 16-bit compressed Function portion.
&<1-2>: Indicates that you can specify up to two default SRv6 TE policies.
You can specify multiple default SRv6 TE policies for backup in one command line or by executing this command multiple times. The first available default SRv6 TE policy selected according to configuration order will be used to forward matching packets.
Without any default SRv6 TE policy specified, the undo apply default-srv6-policy command removes all default SRv6 TE policies.
Use the { sid | vpnsid } sid option on the source node to specify the SRv6 SID of the destination node and its attribute information (public network SID or VPN SID). The attribute information is not encapsulated in packets and does not affect packet forwarding.
When encapsulating packets matching the default SRv6 TE policy, the source node adds the SRv6 SID of the destination node to the SRH header of the packets. The SRv6 SID is added after the SID list of the default SRv6 TE policy. Upon receiving the packets forwarded based on the default SRv6 TE policy, the destination node uses the specified SRv6 SID to perform an SRv6 local SID forwarding table lookup to forward the packets.
When configuring a default SRv6 TE policy to guide traffic forwarding, you can specify an SID to forward the traffic to the endpoint node of the SRv6 TE policy and then forward it to another network or node. If the SID value on the endpoint node is a VPN SID, such as local End.DT4 SID, the traffic can be forwarded to the private network associated with the VPN SID. If the SID value on the endpoint node is a local End SID or End.X SID, the traffic will continue to be forwarded to other public network nodes based on the SID.
When you configure this command with compression parameters such as compress-16 to perform normal compression and encapsulation for the specified SID, make sure the following settings are consistent:
· Length of the common prefix (block-value) for the SID configured in this command and the common prefix value of the specified length.
· Length and value of the common prefix for the last SID in the SID list of the SRv6 TE policy.
If the previous condition is not met, compression and encapsulation cannot be performed. The SID will still be normally encapsulated in the SRv6 packet in the 128-bit format. When the SID is compressed and encapsulated, the 16-bit compressed Function portion of the SID will be encapsulated in the SRv6 packet. If the wlib keyword is specified, in addition to the 16-bit compressed Function portion, the extended 16-bit W-LIB portion will also be encapsulated in the SRv6 packet. For more information about the 16-bit G-SRv6 compression solution, see SRv6 configuration in the Segment Routing Configuration Guide.
The sid argument specified in this command for configuring the default SRv6 TE policy to guide traffic forwarding is a local SID on the endpoint node of the SRv6 TE policy. To use the SID to correctly guide traffic forwarding, make sure the SID meets the following requirements:
· The SID exists on the endpoint node of the SRv6 TE policy.
· The function and flavor configured for the SID in this command meet the service requirements.
For example, to forward traffic to the endpoint node of the default SRv6 TE policy and then to the VPN, make sure the specified SID is a VPN SID such as End.DT4 SID on the endpoint node. In addition to forwarding traffic to the default SRv6 TE policy, if you need to compress and encapsulate the SID list of the SRv6 TE policy and the specified SID, make sure the specified SID is allocated from the COC16-type locator on the endpoint node.
# Specify a default SRv6 TE policy with destination node IPv6 address 1000::1, color attribute value 10, and destination node SRv6 SID 2000::2.
[Sysname-pbr6-aa-1] apply default-srv6-policy 1000::1 10 sid 2000::2
apply loadshare
Use apply loadshare to enable load sharing among multiple next hops or default next hops.
Use undo apply loadshare to restore the default.
apply loadshare { default-next-hop | next-hop }
undo apply loadshare { default-next-hop | next-hop }
Multiple next hops or default next hops operate in primary/backup mode.
default-next-hop: Enables load sharing among multiple default next hops.
next-hop: Enables load sharing among multiple next hops.
Multiple next hop or default next hop options operate in either primary/backup or load sharing mode.
· Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple next hops are configured, the first configured next hop is selected. When the selected next hop fails, the next available next hop takes over.
· Load sharing mode—Matching traffic is distributed across the available options. They load share traffic in proportion to their weight. By default, all next hops have the same weight and traffic is evenly distributed among them.
# Enable load sharing among multiple next hops.
[Sysname-pbr6-aa-11] apply next-hop 1::1 2::2
[Sysname-pbr6-aa-11] apply loadshare next-hop
# Enable load sharing among multiple default next hops.
[Sysname-pbr6-aa-11] apply default-next-hop 1::1 2::2
[Sysname-pbr6-aa-11] apply loadshare default-next-hop
apply next-hop
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] } &<1-16>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-16> ]
No next hops are set.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the next hop belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the next hop belongs to the public network, do not specify this option.
ipv6-address: Specifies the IPv6 address of the next hop.
direct: Specifies that the next hop must be directly connected to take effect.
&<1-16>: Indicates that you can specify up to 16 next hops.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times.
· If the apply loadshare next-hop command is not configured on the policy node, multiple next hops operate in primary/backup mode. PBR selects the first available next hop according to the configuration order as the primary next hop to guide packet forwarding.
· If the apply loadshare next-hop command is configured on the policy node, multiple next hops operate in load sharing mode. PBR load shares packets in round robin manner, starting from the first configured next hop. PBR performs per-packet load sharing for packets that do not match any fast forwarding entry, and performs per-flow load sharing for packets that match a fast forwarding entry.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1::1.
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }
undo apply output-interface [ { interface-type interface-number } ]
No output interfaces are set.
You can specify multiple output interfaces for backup or load sharing in one command line or by executing this command multiple times.
· If the apply loadshare output-interface command is not configured on the policy node, multiple output interfaces operate in primary/backup mode. PBR selects the first available output interface according to the configuration order as the primary output interface to guide packet forwarding.
· If the apply loadshare output-interface command is configured on the policy node, multiple output interfaces operate in load sharing mode. PBR load shares packets in round robin manner, starting from the first configured output interface. PBR performs per-packet load sharing for packets that do not match any fast forwarding entry, and performs per-flow load sharing for packets that match a fast forwarding entry.
This command must be used together with the apply next-hop command. If you only configure this command, the configuration does not take effect.
The output interface must be P2P type. Using a non-P2P output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and NBMA interfaces such as Ethernet and virtual-template interfaces. Supported tunnel interfaces include only GRE tunnel interfaces, IPv4 over IPv4 tunnel interfaces, IPv4 over IPv6 tunnel interfaces, IPsec tunnel interfaces, and MPLS TE tunnel interfaces.
With an output interface specified, the undo apply output-interface command removes the output interface.
Without any output interface specified, the undo apply output-interface command removes all output interfaces.
# Specify Ten-GigabitEthernet 3/0/1 as the output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply output-interface ten-gigabitethernet 3/0/1
apply precedence
Use apply precedence to set a precedence for IPv6 packets.
Use undo apply precedence to restore the default.
No precedence is set for IPv6 packets.
type: Specifies the precedence type for IPv6 packets.
value: Specifies the precedence for IPv6 packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IPv6 packets.
Table 1 IP precedences and the corresponding types
Precedence value |
Precedence type |
0 |
routine |
1 |
priority |
2 |
immediate |
3 |
flash |
4 |
flash-override |
5 |
critical |
6 |
internet |
7 |
network |
# Set the precedence to 5 (critical) for IPv6 packets.
[Sysname-pbr6-aa-11] apply precedence critical
apply srv6-be
Use apply srv6-be to configure packet forwarding in SRv6 BE mode.
Use undo apply srv6-be to remove the configuration.
apply srv6-be remote-sid { remote-sid locator-prefix-len }&<1-2>
undo apply srv6-be remote-sid [ { remote-sid locator-prefix-len }&<1-2> ]
Packet are not forwarded in SRv6 BE mode.
remote-sid remote-sid: Specifies the SRv6 BE destination node SID.
You can use the remote-sid and locator-prefix-len arguments to uniquely identify a locator. The device performs SRv6 encapsulation for matching packets (encapsulates an IPv6 header with the SRv6 BE destination node SID used as the destination address), and forwards them through the IGP route associated with the locator.
You can specify up to two destination node SIDs for the SRv6 BE mode for backup in one command line or by executing this command multiple times. When you specify up to two SIDs, you cannot specify new SIDs.
With an SRv6 BE destination node SID specified, the undo form of the command removes the specified SRv6 BE destination node SID. Without any SRv6 BE destination node SIDs specified, the undo form of the command removes all configured SRv6 BE destination node SIDs.
# Configure packet forwarding in SRv6 BE mode. Specify the SRv6 BE destination node SID as 1000::1 and the locator length as 32.
[Sysname-pbr6-aa-1] apply srv6-be remote-sid 1000::1 32
apply srv6-policy
Use apply srv6-policy to set SRv6 TE policies.
Use undo apply srv6-policy to remove SRv6 TE policies.
apply srv6-policy { endpoint color [ { sid | vpnsid } sid [ compress-16 block block-length flavor { coc-next | next [ wlib ] } ] ] }&<1-2>
undo apply srv6-policy [ { endpoint color }&<1-2> ]
No SRv6 TE policies are set.
endpoint: Specifies an SRv6 TE policy by its endpoint IPv6 address.
color: Specifies an SRv6 TE policy by its color attribute value in the range of 0 to 4294967295.
compress-16: Compresses the specified SRv6 SID into 16 bits through G-SRv6 and encapsulates it in an SRv6 packet when configuring an SRv6 TE policy to guide traffic forwarding. If you do not specify this keyword, the SID will be encapsulated in the SRv6 packet in the standard 128-bit format.
&<1-2>: Indicates that you can specify up to two SRv6 TE policies.
You can specify multiple SRv6 TE policies for backup in one command line or by executing this command multiple times. The first available SRv6 TE policy selected according to configuration order will be used to forward matching packets.
Without any SRv6 TE policy specified, the undo apply srv6-policy command removes all SRv6 TE policies.
When encapsulating packets matching the SRv6 TE policy, the source node adds the SRv6 SID of the destination node to the SRH header of the packets. The SRv6 SID is added after the SID list of the SRv6 TE policy. Upon receiving the packets forwarded based on the SRv6 TE policy, the destination node uses the specified SRv6 SID to perform an SRv6 local SID forwarding table lookup to forward the packets.
When configuring an SRv6 TE policy to guide traffic forwarding, you can specify an SID to forward the traffic to the endpoint node of the SRv6 TE policy and then forward it to another network or node. If the SID value on the endpoint node is a VPN SID, such as local End.DT4 SID, the traffic can be forwarded to the private network associated with the VPN SID. If the SID value on the endpoint node is a local End SID or End.X SID, the traffic will continue to be forwarded to other public network nodes based on the SID.
The sid argument specified in this command for configuring the SRv6 TE policy to guide traffic forwarding is a local SID on the endpoint node of the SRv6 TE policy. To use the SID to correctly guide traffic forwarding, make sure the SID meets the following requirements:
For example, to forward traffic to the endpoint node of the SRv6 TE policy and then to the VPN, make sure the specified SID is a VPN SID such as End.DT4 SID on the endpoint node. In addition to forwarding traffic to the SRv6 TE policy, if you need to compress and encapsulate the SID list of the SRv6 TE policy and the specified SID, make sure the specified SID is allocated from the COC16-type locator on the endpoint node.
# Specify an SRv6 TE policy with destination node IPv6 address 1000::1, color attribute value 10, and destination node SRv6 SID 2000::2.
[Sysname-pbr6-aa-1] apply srv6-policy 1000::1 10 sid 2000::2
Use display ipv6 policy-based-route to display IPv6 PBR policy information.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all IPv6 PBR policies.
# Display all IPv6 policy information.
<Sysname> display ipv6 policy-based-route
Policy name: aaa
node 1 permit:
if-match acl 2000
apply next-hop 1000::1 (active)
apply next-hop 2000::1 (inactive)
node 5 permit:
if-match acl 3500
apply srv6-policy 1000::1 10 sid 2000::2(NID: 2150629377)
apply default-srv6-policy 3000::3 20 vpnsid 4000::4(NID: 2149580801)
node 11 permit:
if-match acl 3001
apply srv6-be remote-sid 2002::1 32 (NibID: 0x2a000001, VNID: 0x12a000001)
apply default-srv6-be remote-sid 2001::2 32 (NibID: 0x2a000002, VNID: 0x22a000002)
node 1 permit |
The match mode of Node 1 is permit. |
if-match acl |
Compares IPv6 packets with the IPv6 ACL. |
apply next-hop (active) |
Specifies a next hop for permitted IPv6 packets. This field also displays the state of the next hop. · active—The next hop is reachable. · inactive—The next hop is unreachable. |
apply srv6-policy 1000::1 10 sid 2000::2(NID: 2150629377) |
Specifies an SRv6 TE policy for permitted IPv6 packets. Associated information about the SRv6 TE policy include: · Destination node IPv6 address 1000::1. · Color attribute value 10. · Destination node SRv6 SID 2000::2. · Next Hop Label Forwarding Entry (NHLFE) index 2150629377. |
apply default-srv6-policy 3000::3 20 vpnsid 4000::4(NID: 2149580801) |
Specifies a default SRv6 TE policy for permitted IPv6 packets. Associated information about the SRv6 TE policy include: · Destination node IPv6 address 3000::3. · Color attribute value 20. · Destination node SRv6 SID 4000::4. · NHLFE index 2149580801. |
apply srv6-be remote-sid 2002::1 32 (NibID: 0x2a000001, VNID: 0x12a000001) |
Forwards permitted packets in SRv6 BE mode. Associated information about the SRv6 BE mode include: · Destination node SID 2002::1. · Locator length 32. · NIB ID 0x2a000001. · VN entry ID 0x12a000001. |
apply default-srv6-be remote-sid 2001::2 32 (NibID: 0x2a000002, VNID: 0x22a000002) |
Forwards permitted packets in default SRv6 BE mode. Associated information about the default SRv6 BE mode include: · Destination node SID 2001::2. · Locator length 32. · NIB ID 0x2a000002. · VN entry ID 0x22a000002. |
Use display ipv6 policy-based-route interface to display IPv6 interface PBR configuration and statistics.
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 interface PBR configuration and statistics on the active MPU.
# Display IPv6 PBR configuration and statistics on Ten-GigabitEthernet 3/0/1.
<Sysname> display ipv6 policy-based-route interface ten-gigabitethernet 3/0/1
Policy based routing information for interface Ten-GigabitEthernet3/0/1:
Policy name: aaa
node 0 deny(not support):
Matches: 0, bytes: 0
node 1 permit:
if-match acl 3999
node 2 permit(no resource):
if-match acl 2000
apply output-interface Ten-GigabitEthernet3/0/2 track 1 (down)
apply output-interface Ten-GigabitEthernet3/0/3 track 2 (inactive)
node 5 permit:
if-match acl 3101
node 8 permit:
if-match acl 3200
node 9 permit:
if-match acl 3300
Total matches: 0, total bytes: 0
Policy based routing information for interface XXXX |
IPv6 PBR configuration and statistics on the interface. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. To successfully issue the policy, you must remove the policy from the interface and then apply it on the interface again. NOTE: The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
node 0 deny node 2 permit |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. NOTE: The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
if-match acl |
apply output-interface track 1 (down) |
Specifies an output interface for permitted IPv6 packets. The interface status includes the following: · inactive—The interface is not in position. · down—The interface is down at network layer. |
Specifies an SRv6 TE policy for permitted IPv6 packets. Associated information about the SRv6 TE policy include: · Destination node IPv6 address 1000::1. · Color attribute value 10. · Destination node SRv6 SID 2000::2. · NHLFE index 2150629377. |
Matches |
Number of successful matches on the node. If the device does not support counting successful matches on a node, this field displays N/A. If match counting is disabled on the node, this field is not displayed. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. NOTE: The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
bytes |
Number of matching bytes on the node. This field displays N/A if the device does not support counting matching bytes on a node. This field is not displayed if match counting is disabled on the node. |
Total matches |
Total number of successful matches on all nodes. This field displays N/A if the device does not support counting successful matches on a node. This field is not displayed if match counting is disabled on all nodes. |
total bytes |
Total number of matching bytes on all nodes. This field displays N/A if the device does not support counting matching bytes on a node. This field is not displayed if match counting is disabled on all nodes. |
Use display ipv6 policy-based-route local to display IPv6 local PBR configuration and statistics.
display ipv6 policy-based-route local [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 local PBR configuration and statistics on the active MPU.
# Display IPv6 local PBR configuration and statistics.
<Sysname> display ipv6 policy-based-route local
Policy based routing information for local:
Policy name: aaa
node 0 deny:
node 1 permit:
if-match acl 3999
node 2 permit:
if-match acl 2000
apply next-hop 1::1 (active)
node 5 permit:
if-match acl 3101
apply next-hop 2::2 (active)
node 8 permit:
if-match acl 3200
node 9 permit:
if-match acl 3300
Policy based routing information for local |
IPv6 local PBR configuration and statistics. |
node 0 deny/node 2 permit |
Match mode of the node, permit or deny. |
if-match acl |
Compares packets with the IPv6 ACL. |
Specifies a next hop for permitted packets. This field also displays the state of the next hop. · active—The next hop is reachable. · inactive—The next hop is unreachable. |
Specifies an SRv6 TE policy for permitted packets. Associated information about the SRv6 TE policy include: · Destination node IPv6 address 1000::1. · Color attribute value 10. · Destination node SRv6 SID 2000::2. · NHLFE index 2150629377. |
Specifies a default SRv6 TE policy for permitted packets. Associated information about the SRv6 TE policy include: · Destination node IPv6 address 3000::3. · Color attribute value 20. · Destination node SRv6 SID 4000::4. · NHLFE index 2149580801. |
Matches |
Number of successful matches on the node. This field displays N/A if the device does not support counting successful matches on a node. This field is not displayed if match counting is disabled on the node. |
bytes |
Total matches |
total bytes |
ipv6 local policy-based-route
Use display ipv6 policy-based-route setup to display IPv6 PBR configuration.
# Display IPv6 PBR configuration.
<Sysname> display ipv6 policy-based-route setup
Policy name Type Interface
pr01 Forward Ten-GigabitEthernet 3/0/1
pr02 Local N/A
Table 5 Command output
Policy name |
Policy name. |
Type |
Type of the PBR: · Forward—Interface PBR. · Local—Local PBR. |
Interface where the policy is applied. For IPv6 local PBR, this field displays N/A. |
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999. The value range of a basic ACL is 2000 to 2999 and that of an advanced ACL is 3000 to 3999.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all.
If the specified ACL does not exist or has no rules configured, all packets will match the ACL.
If the vpn-instance keyword is specified for an ACL rule, the rule applies to only VPN packets. If the vpn-instance keyword is not specified, the rule applies to only public network packets.
# Configure Node 10 of policy aa to permit the packets matching ACL 2000.
[Sysname] ipv6 policy-based-route aa permit node 10
[Sysname-pbr6-aa-10] if-match acl 2000
# Configure Node 10 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr6-aa-10] if-match acl name aaa
if-match qos-local-id
Use if-match qos-local-id to set a local QoS ID match criterion.
Use undo if-match qos-local-id to restore the default.
if-match qos-local-id local-id-value [ qppb-manipulation ]
No local QoS ID match criterion is set.
local-id-value: Specifies a local QoS ID in the range of 1 to 4095.
qppb-manipulation: Applies the match criterion only to QPPB when the device acts as a BGP receiver. A received packet matches the policy node if the local QoS ID obtained from its matching route entry is identical to the specified local QoS ID criterion. For more information about QPPB, see ACL and QoS Configuration Guide.
# Match packets with local QoS ID 200.
[Sysname-pbr6-aa-11] if-match qos-local-id 200
Use ipv6 local policy-based-route to configure IPv6 local PBR based on a specified policy.
Use undo ipv6 local policy-based-route to restore the default.
No policy is specified for IPv6 local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified IPv6 policy must already exist.
Use this command to guide forwarding of the packets generated by the device.
Before you configure this command, make sure the specified IPv6 PBR policy already exists. If the IPv6 PBR policy does not exist, this command cannot take effect.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR is used to route locally generated packets except the packets destined for the sender. This feature might affect local services. Do not configure IPv6 local PBR unless doing so is required.
# Configure IPv6 local PBR based on policy aaa.
[Sysname] ipv6 local policy-based-route aaa
Use ipv6 policy-based-route to configure IPv6 interface PBR by applying an IPv6 policy to an interface.
Use undo ipv6 policy-based-route to restore the default.
ipv6 policy-based-route policy-name [ share-mode ]
No IPv6 is applied to an interface.
Interface view
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
share-mode: Applies the IPv6 policy in resource sharing mode. In this mode, all interfaces on an interface card with the same IPv6 policy applied share one hardware resource. If you do not specify this keyword, each interface occupies one independent hardware resource. You can apply only one ACL, QoS policy, or PBR policy with the share-mode keyword specified to one direction of an interface. For information about ACL and QoS policies, see ACL commands and QoS policy commands in ACL and QoS Command Reference.
Use this command to guide forwarding of the packets on an interface.
You can apply only one policy to an interface. Before you can apply a new IPv6 interface PBR policy to an interface, you must first remove the current policy from the interface.
Typically, an IPv6 policy on different interfaces of a card uses different hardware resources. To avoid resource usage overhead, you can set the resource sharing mode when applying the policy to each interface. This mode allows the policy on different interfaces of the card to use the same hardware resources.
You can apply only one policy to an interface. Before you apply a new policy, remove the current policy from the interface.
You can set only one mode for the policy on an interface. Before you change the mode of the policy, you must first remove the current policy from the interface.
# Apply policy aaa to Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] ipv6 policy-based-route aaa
Use ipv6 policy-based-route to create an IPv6 policy node and enter its view, or enter the view of an existing IPv6 policy node.
Use undo ipv6 policy-based-route to delete an IPv6 policy or IPv6 policy node.
undo ipv6 policy-based-route policy-name [ deny | node node-number | permit ]
No IPv6 policy nodes exist.
policy-name: Specifies a policy name, a case-sensitive string of 1 to 19 characters.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies the number of the IPv6 policy node. A smaller number has a higher priority. The value range for the node-number argument is 0 to 255.
To delete an IPv6 policy that has already applied to an interface, you must delete the policy from the interface first.
If a policy node is specified, the undo ipv6 policy-based-route command deletes the specified policy node. If a match mode is specified, the command deletes all nodes configured with the match mode. If no node is specified, the command deletes the whole policy.
# Create permit-mode Node 10 for IPv6 policy aaa and enter its view.
[Sysname] ipv6 policy-based-route aaa permit node 10
[Sysname-pbr6-aaa-10]
Use ipv6 policy-based-route-log enable to enable the IPv6 PBR logging feature.
Use undo ipv6 policy-based-route-log enable to disable the IPv6 PBR logging feature.
The IPv6 PBR logging feature is disabled.
The IPv6 PBR logging feature helps the administrator locate and fix faults. The feature logs IPv6 PBR events and sends the logs to the information center. The information center processes the logs according to output rules. For more information about the information center, see Network Management and Monitoring Configuration Guide.
Excessive IPv6 PBR log messages degrade the performance of the device. To avoid this problem, disable the IPv6 PBR logging feature.
# Enable the IPv6 PBR logging feature.
[Sysname] ipv6 policy-based-route-log enable
Use reset ipv6 policy-based-route statistics to clear IPv6 PBR statistics.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears IPv6 PBR statistics for all policies.
# Clear all IPv6 PBR statistics.
<Sysname> reset ipv6 policy-based-route statistics
