06-Layer 3—IP Routing Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Router Command Reference-R8630Pxx-6W10006-Layer 3—IP Routing Command Reference
05-IS-IS commands
05-IS-IS commands 2.45 MB
IS-IS commands· 1
address-family ipv4· 1
address-family ipv6· 1
advertise application link-attributes· 2
advertise link-attributes· 5
advertise-definition enable· 6
affinity exclude-any· 7
affinity include-all 8
affinity include-any· 9
affinity-map· 9
area-authentication send-only· 10
area-authentication-mode· 11
auto-cost enable· 13
bandwidth-reference· 14
bfd all-interfaces adjust-cost 15
bfd all-interfaces enable· 16
bfd all-interfaces session-restrict-adj 17
bfd all-interfaces template· 19
bier enable· 20
bier fast-reroute enable· 21
bier sub-sub-tlv-type· 22
circuit-cost 23
color-mapping· 24
cost-style· 25
default-route-advertise· 26
display isis· 27
display isis event-log graceful-restart 38
display isis event-log hello· 39
display isis event-log lsp· 44
display isis event-log non-stop-routing· 47
display isis event-log peer 48
display isis event-log route-record· 50
display isis event-log spf 58
display isis event-log updated-lsp· 80
display isis flex-algo route· 83
display isis flex-algo spf-tree· 86
display isis frr summary· 90
display isis global-flex-algo· 92
display isis global-statistics· 94
display isis graceful-restart status· 95
display isis interface· 97
display isis interface hello-sent 109
display isis local-flex-algo· 110
display isis lsdb· 112
display isis lsdb statistics· 131
display isis mesh-group· 132
display isis name-table· 133
display isis non-stop-routing status· 134
display isis packet 134
display isis peer 144
display isis peer hello-received· 148
display isis peer lsp-purge-received· 149
display isis redistribute· 151
display isis route· 153
display isis route bier 163
display isis savnet sav-table· 166
display isis spf-tree· 167
display isis spf-tree bier 183
display isis statistics· 188
display isis troubleshooting· 190
display osi 194
display osi statistics· 196
distribute· 197
domain-authentication send-only· 198
domain-authentication-mode· 199
event-log route-record size· 201
event-log size· 202
event-log updated-lsp size· 203
exclude-srlg· 203
fast-reroute· 204
fast-reroute enable· 205
fast-reroute microloop-avoidance enable· 206
fast-reroute microloop-avoidance rib-update-delay· 207
fast-reroute primary-path-detect bfd· 208
fast-reroute remote-lfa maximum-cost 209
fast-reroute remote-lfa prefix-list 210
fast-reroute remote-lfa tunnel ldp· 211
fast-reroute tiebreaker (flexible algorithm view) 212
fast-reroute tiebreaker (IS-IS IPv4 unicast address family view/IS-IS IPv6 unicast address family view) 213
fast-reroute ti-lfa enable· 215
filter-policy export 215
filter-policy import 217
flash-flood· 219
flex-algo (IS-IS view) 219
flex-algo (segment routing view) 221
flex-algo algorithm·· 221
graceful-restart 222
graceful-restart suppress-sa· 222
graceful-restart t1· 223
graceful-restart t2· 224
graceful-restart t3· 225
ignore-att 226
import-bier 226
import-route· 227
import-route isis level-1 into level-2· 230
import-route isis level-2 into level-1· 231
import-route isisv6 level-1 into level-2· 233
import-route isisv6 level-2 into level-1· 234
import-route limit 235
import-route no-route-calculate· 235
inter-level-tilfa level-1 enable· 236
isis· 237
isis affinity flex-algo· 238
isis authentication send-only· 239
isis authentication-mode· 240
isis bfd adjust-cost 242
isis bfd adjust-cost exclude· 243
isis bfd enable· 244
isis bfd exclude· 245
isis bfd session-restrict-adj 246
isis bfd session-restrict-adj exclude· 247
isis bfd template· 248
isis circuit-level 249
isis circuit-type p2p· 250
isis cost 251
isis cost-fallback· 251
isis dis-name· 252
isis dis-priority· 253
isis enable· 254
isis fast-reroute lfa-backup exclude· 255
isis fast-reroute remote-lfa disable· 255
isis ipv6 bfd adjust-cost 256
isis ipv6 bfd adjust-cost exclude· 257
isis ipv6 bfd enable· 258
isis ipv6 bfd exclude· 259
isis ipv6 bfd session-restrict-adj 260
isis ipv6 bfd session-restrict-adj exclude· 261
isis ipv6 bfd template· 262
isis ipv6 cost 263
isis ipv6 cost-fallback· 264
isis ipv6 enable· 265
isis ipv6 fast-reroute lfa-backup exclude· 265
isis ipv6 link-tag· 266
isis ipv6 member-port suppress-flapping· 267
isis ipv6 member-port suppress-flapping adjust-cost 269
isis ipv6 metric-delay normalize interval 270
isis ipv6 peer suppress-flapping· 272
isis ipv6 peer suppress-flapping adjust-cost 274
isis ipv6 prefix-suppression· 275
isis ipv6 primary-path-detect bfd· 276
isis ipv6 primary-path-detect bfd exclude· 277
isis ipv6 tag· 278
isis link-delay· 279
isis link-loss· 280
isis link-quality adjust-cost 281
isis lsp-flood-control 282
isis member-port link-delay· 283
isis member-port link-loss· 285
isis member-port suppress-flapping· 286
isis member-port suppress-flapping adjust-cost 288
isis mesh-group· 289
isis metric-delay normalize interval 290
isis mib-binding· 292
isis peer hold-max-cost duration· 293
isis peer suppress-flapping· 294
isis peer suppress-flapping adjust-cost 296
isis peer-ip-check· 297
isis prefix-suppression· 297
isis primary-path-detect bfd· 298
isis primary-path-detect bfd exclude· 299
isis ipv6 savnet enable· 300
isis silent 301
isis small-hello· 301
isis tag· 302
isis te-metric flex-algo· 303
isis timer csnp· 304
isis timer hello· 305
isis timer holding-multiplier 305
isis timer lsp· 306
isis timer retransmit 307
isis troubleshooting max-number 308
is-level 308
is-name· 309
is-name map· 310
isolate enable· 310
ispf enable· 312
link-tag inherit enable· 312
log-peer-change· 313
lsp-fragments-extend· 314
lsp-length originate· 314
lsp-length receive· 315
maximum load-balancing· 315
metric-bandwidth advertisement enable· 316
metric-bandwidth suppression· 318
metric-delay advertisement enable· 318
metric-delay normalize interval 320
metric-delay suppression· 322
metric-link-loss advertisement enable· 323
metric-link-loss suppression· 325
metric-type· 326
multi-instance enable· 327
multi-topology· 328
network-entity· 329
overload adjust-cost 330
pic· 331
preference· 332
prefix-priority· 332
priority· 333
reset isis all 334
reset isis event-log· 335
reset isis event-log graceful-restart 335
reset isis event-log lsp· 336
reset isis event-log non-stop-routing· 336
reset isis event-log route-record· 337
reset isis event-log spf 337
reset isis event-log updated-lsp· 338
reset isis packet 338
reset isis peer 339
reset isis troubleshooting· 339
reset osi statistics· 339
savnet enable· 340
segment-routing microloop-avoidance enable· 341
segment-routing microloop-avoidance rib-update-delay· 342
segment-routing microloop-avoidance strict-sid-only· 343
set-att 344
set-overload· 345
shutdown process· 348
snmp context-name· 348
snmp-agent trap enable isis· 349
snmp-agent trap isis adjacency-state-change extended· 350
summary· 351
te attribute enable· 352
timer aging-lsp-lifetime· 353
timer lsp-arrival 354
timer lsp-flood suppress-flapping· 355
timer lsp-generation· 356
timer lsp-generation suppress-flapping· 357
timer lsp-max-age· 358
timer lsp-refresh· 358
timer lsp-remaining-lifetime refresh· 359
timer purge-zero-lsp route-calculate-delay· 361
timer route-calculate suppress-flapping· 361
timer spf 362
virtual-system·· 363
IS-IS commands
address-family ipv4
Use address-family ipv4 to create the IS-IS IPv4 address family and enter its view.
Use undo address-family ipv4 to delete the IS-IS IPv4 address family and all configurations in the view.
undo address-family ipv4 [ unicast ]
No IS-IS IPv4 address family exists.
IS-IS view
unicast: Specifies the unicast address family (the default).
# Create the IS-IS IPv4 address family and enter its view.
[Sysname] isis 100
[Sysname-isis-100] address-family ipv4
[Sysname-isis-100-ipv4]
address-family ipv6
Use address-family ipv6 to create the IS-IS IPv6 address family and enter its view.
Use undo address-family ipv6 to remove the IS-IS IPv6 address family and all configurations in the view.
undo address-family ipv6 [ unicast ]
No IS-IS IPv6 address family exists.
IS-IS view
This command enables IPv6 for an IS-IS process.
# Create the IS-IS IPv6 address family and enter its view.
[Sysname] isis 100
[Sysname-isis-100] address-family ipv6
[Sysname-isis-100-ipv6]
Use advertise application link-attributes to enable IS-IS to advertise application-specific link attributes (ASLA).
Use undo advertise application link-attributes to disable IS-IS from advertising application-specific link attributes.
advertise application link-attributes { bandwidth | delay | link-loss | unidirectional-bandwidth | srlg | te } [ asla-only ]
undo advertise application link-attributes { bandwidth | delay | link-loss | unidirectional-bandwidth | srlg |te }
advertise application link-attributes { te [ suppression ] | srlg [ suppression ] } *
undo advertise application link-attributes { te [ suppression ] | srlg [ suppression ] } *
IS-IS does not advertise any application-specific link attributes.
IS-IS IPv4 address family view
IS-IS IPv6 address family view
bandwidth: Advertises link bandwidth information defined by RFC 5305. Bandwidth information defined by RFC 5305 is static, and bandwidth information defined by RFC 8570 is dynamic.
delay: Advertises link delay information.
link-loss: Advertises link loss information.
unidirectional-bandwidth: Advertises link bandwidth information defined by RFC 8570.
srlg: Advertises link SRLG attribute information.
te: Advertises the TE attribute, link delay, and link bandwidth.
asla-only: Allows IS-IS to advertise link attribute information through only ASLA sub-TLVs, and prevents IS-IS from advertising link attribute information through Shared Risk Link Group TLVs and Extended IS Reachability TLVs. If you do not specify the asla-only keyword, IS-IS can advertise link attribute information through ASLA sub-TLVs, Shared Risk Link Group TLVs, or Extended IS Reachability TLVs.
te suppression: Suppresses IS-IS from advertising TE attributes, link delay information, and link bandwidth information. If you do not specify the suppression keyword, the command does not suppress IS-IS from advertising TE attributes, link delay, and bandwidth information.
srlg suppression: Suppresses IS-IS from advertising SRLG attribute information. If you do not specify the suppression keyword, the command does not suppress IS-IS from advertising SRLG attribute information.
Application scenarios
If the flexible algorithm uses link delay metric, you must enable IS-IS link delay advertisement, so link attribute sub-sub-TLVs can carry link attribute information.
Operating mechanism
IS-IS advertises application-specific link attributes in ASLA sub-TLVs for use by specific applications. In the current software version, IS-IS only advertises link attributes for use by flexible algorithms. This feature is required when the flexible algorithm uses link delay metric or TE metric for path calculation. After you enable this feature, each ASLA sub-TLV will carry a link attribute sub-sub-TLV that can contain the TE attributes, delay, bandwidth, and SRLG attribute of a link.
Recommended configuration
IS-IS also advertises TE attribute and SRLG attribute information through Extended IS Reachability TLVs and Shared Risk Link Group TLVs, respectively. To reduce the LSDB size, specify the asla-only keyword when executing this command, so that IS-IS advertises link attribute information only through ASLA sub-TLVs. Table 1 shows the impact of the asla-only keyword.
Table 1 Impact of the asla-only keyword on link attribute information advertisement
Advertised link attribute information
Without the asla-only keyword
With the asla-only keyword
bandwidth
Both ASLA sub-TLVs and Extended IS Reachability TLVs advertise the following bandwidth information defined by RFC 5305:
·     Type 9—Maximum Link Bandwidth.
·     Type 10—Maximum Reservable Link Bandwidth.
·     Type 11—Unreserved Bandwidth.
Only ASLA sub-TLVs advertise the following bandwidth information defined by RFC 5305:
delay
Both ASLA sub-TLVs and Extended IS Reachability TLVs advertise the following link delay information defined by RFC 8570:
·     Type 33—Unidirectional Link Delay.
·     Type 34—Min/Max Unidirectional Link Delay.
·     Type 35—Unidirectional Delay Variation.
Only ASLA sub-TLVs advertise the following link delay information defined by RFC 8570:
link-loss
Both ASLA sub-TLVs and Extended IS Reachability TLVs advertise the following link loss information defined by RFC 8570:
·     Type 36—Unidirectional Link Loss.
Only ASLA sub-TLVs advertise the following link loss information defined by RFC 8570:
srlg
ASLA sub-TLVs advertise the SRLG attribute information defined by RFC 8919.
Shared Risk Link Group TLVs advertise the SRLG attribute information defined by RFC 5307 and RFC 6119.
Only ASLA sub-TLVs advertise the SRLG attribute information defined by RFC 8919.
te
ASLA sub-TLVs advertise the TE attribute information, link delay information, and bandwidth information defined by RFC 8919.
Extended IS Reachability TLVs advertise the following information:
·     TE attribute information defined by RFC 5305.
·     Link delay information and bandwidth information defined by RFC 8570.
Only ASLA sub-TLVs advertise the TE attribute information, link delay information, and bandwidth information defined by RFC 8919.
Both ASLA sub-TLVs and Extended IS Reachability TLVs advertise the following bandwidth information defined by RFC 8570:
·     Type 37—Unidirectional Residual Bandwidth.
·     Type 38—Unidirectional Available Bandwidth.
·     Type 39—Unidirectional Utilized Bandwidth.
Only ASLA sub-TLVs advertise the following bandwidth information defined by RFC 8570:
In the current software version, this command only enables IS-IS to advertise application-specific link attributes for the flexible algorithm.
This command is configurable only when the link cost style is wide, compatible, or wide-compatible.
If the flexible algorithm uses link delay metric, link attribute sub-sub-TLVs can carry link attribute information only after you enable IS-IS link delay advertisement.
If the flexible algorithm uses the TE metric reported by MPLS TE, link attribute sub-sub-TLVs can carry link attribute information only after the following requirements are met:
·     MPLS TE is enabled for each node that participates in path calculation for that flexible algorithm.
·     MPLS and MPLS TE are enabled on each interface that participates in path calculation for that flexible algorithm.
·     TE is enabled for IS-IS. To enable TE, perform one of the following tasks:
¡     Use the te attribute enable command to enable TE for IS-IS.
¡     Use the router-id command to enable IPv6 TE.
·     Use advertise application link-attributes to enable ASLA advertisement for IS-IS.
When the flexible algorithm uses the TE metric reported by interfaces, configure only the isis te-metric flex-algo command.
To suppress IS-IS from advertising TE attribute information, link delay information, and bandwidth information in Extended IS Reachability TLVs, use one of the following commands:
·     advertise application link-attributes te asla-only
·     advertise application link-attributes te suppression
To suppress IS-IS from advertising SRLG attribute information in Shared Risk Link Group TLVs, use one of the following commands:
·     advertise application link-attributes srlg asla-only
·     advertise application link-attributes srlg suppression
# Enable IS-IS to advertise application-specific link attributes, including TE attributes, link delay, link bandwidth, and SRLG attribute.
[Sysname] isis 1
[Sysname-isis-1] cost-style wide
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] advertise application link-attributes te srlg
cost-style
router-id (Segment Routing Command Reference)
te attribute enable
Use advertise link-attributes to enable IS-IS to advertise link attributes in LSPs.
Use undo advertise link-attributes to restore the default.
IS-IS does not advertise link attributes in LSPs.
To have link delay advertisement and link bandwidth advertisement take effect, you must enable IS-IS to advertise link attributes in LSPs.
Link attributes advertised in LSPs include the following:
·     IP address.
·     Link delay information. (The attribute is included after you enable link delay advertisement by using the metric-delay advertisement enable command.)
·     Link bandwidth information. (The attribute is included after you enable link bandwidth advertisement by using the metric-bandwidth advertisement enable command.)
Multiple P2P neighbors might exist between two devices. To ensure correct route calculation, configure each device to advertise IP address of the local interface to its neighbors by using the advertise link-attributes or router-id command.
You can execute this command only when the link cost style is wide, compatible or wide-compatible.
# Enable IS-IS process 1 to advertise link attributes in LSPs.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] advertise link-attributes
cost-style
Use advertise-definition enable to enable FAD advertisement on a node.
Use undo advertise-definition enable to disable FAD advertisement on a node.
FAD advertisement is disabled on a node.
Flexible algorithm view
A node can participate in the path calculation of a flexible algorithm only after it is configured with that flexible algorithm. For the devices in an IS-IS routing domain, they can use a flexible algorithm only if a node in that domain advertises FAD.
Operating mechanism
This feature enables a node to advertise its FAD.
If a node does not advertise its FAD (for example, flexible algorithm 128), it can participate in flexible algorithm 128 only when it meets the following requirements:
1.     The node receives the definitions of flexible algorithm 128 advertised by neighbors, and selects an FAD with the highest priority.
2.     The metric type in the selected FAD is supported by the node.
# Enable FAD advertisement for flexible algorithm 128.
[Sysname] isis 1
[Sysname-isis-1] flex-algo 128
[Sysname-isis-1-flex-algo-128] advertise-definition enable
cost-style
Use affinity exclude-any to specify the exclude-any constraint for a flexible algorithm.
Use undo affinity exclude-any to restore the default.
affinity exclude-any affinity-name&<1-32>
The flexible algorithm topology excludes no links.
affinity-name&<1-32>: Specifies affinity attributes by their names. The affinity attribute name must be a case-sensitive string of 1 to 32 characters. &<1-32> indicates that you can specify a maximum of 32 affinity attribute names.
A link will be excluded from the flexible algorithm topology if it has an affinity attribute that is included in the exclude-any constraint.
This feature is available when the link cost style is wide, compatible, or wide-compatible.
The specified affinity attribute names must already exist.
# Exclude links with affinity attribute red from the topology of flexible algorithm 128.
[Sysname] isis 1
[Sysname-isis-1-flex-algo-128] affinity exclude-any red
affinity-map
cost-style
Use affinity include-all to specify the include-all constraint for a flexible algorithm.
Use undo affinity include-all to restore the default.
affinity include-all affinity-name&<1-32>
A link will be excluded from the flexible algorithm topology if it does not have all the affinity attributes that are included in the include-all constraint.
# Exclude links that do not have affinity attributes red and blue from the topology of flexible algorithm 128.
[Sysname] isis 1
[Sysname-isis-1-flex-algo-128] affinity include-all red blue
affinity-map
cost-style
Use affinity include-any to specify the include-any constraint for a flexible algorithm.
Use undo affinity include-any to restore the default.
affinity include-any affinity-name&<1-32>
A link will be excluded from the flexible algorithm topology if it does not have any affinity attribute that is included in the include-any constraint.
# Include links with affinity attribute red in the topology of flexible algorithm 128.
[Sysname] isis 1
[Sysname-isis-1-flex-algo-128] affinity include-any red
affinity-map
cost-style
affinity-map
Use affinity-map to map an affinity attribute name to an affinity bit.
Use affinity-map to remove the configuration.
affinity-map affinity-name bit-position bit
undo affinity-map affinity-name
No affinity attribute name is mapped to an affinity bit.
IS-IS view
affinity-name: Specifies an affinity attribute name, a case-sensitive string of 1 to 32 characters.
bit: Specifies an affinity bit by its number. The value range for this argument is 0 to 255.
IS-IS supports a maximum of 256 affinity bits. They are numbered from 0 to 255. You can use this feature to map different affinity attribute names to these bits. For example, after you use the affinity-map blue bit-position 3 command, affinity attribute name blue is mapped to affinity bit 3.
After you map a name to each affinity bit, you can specify the affinity attributes of a link or defines flexible algorithm topologies by using affinity attribute names.
To avoid configuration failure, follow these guidelines:
·     You cannot map different affinity attribute names to the same affinity bit.
·     Perform this task only when the link cost style is wide, compatible, or wide-compatible.
# Map affinity attribute name red to affinity bit 1.
[Sysname] isis 1
[Sysname-isis-1] affinity-map red bit-position 1
cost-style
Use area-authentication send-only to configure IS-IS not to check the authentication information in the received Level-1 packets, including LSPs, CSNPs, and PSNPs.
Use undo area-authentication send-only to restore the default.
When area authentication mode and key are configured, a Level-1 or Level-1-2 router checks the authentication information in the received packets.
IS-IS view
When area authentication mode and key are configured, a Level-1 or Level-1-2 router adds the key in the specified mode into transmitted Level-1 packets (including LSPs, CSNPs, and PSNPs). It also checks the key in the received Level-1 packets.
To prevent packet exchange failure in case of an authentication key change, configure IS-IS not to check the authentication information in the received packets.
# Configure IS-IS not to check the authentication information in the received packets.
[Sysname] isis 1
[Sysname-isis-1] area-authentication send-only
Use area-authentication-mode to specify an area authentication mode and a key.
Use undo area-authentication-mode to restore the default.
area-authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ ip | osi ]
No area authentication mode or key is configured.
IS-IS view
gca: Specifies the Generic Cryptographic Authentication (GCA) mode.
key-id: Uniquely identifies an SA in the range of 1 to 65535. The sender inserts the Key ID into the authentication TLV, and the receiver authenticates the packet by using the SA that is selected based on the Key ID.
hmac-sha-1: Specifies the HMAC-SHA-1 algorithm.
hmac-sha-224: Specifies the HMAC-SHA-224 algorithm.
hmac-sha-256: Specifies the HMAC-SHA-256 algorithm.
hmac-sha-384: Specifies the HMAC-SHA-384 algorithm.
hmac-sha-512: Specifies the HMAC-SHA-512 algorithm.
nonstandard: Specifies the nonstandard GCA mode.
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. In simple authentication mode and GCA authentication mode, the plaintext form of the key is a case-sensitive string of 1 to 16 characters, and the encrypted form is a case-sensitive string of 33 to 53 characters. In MD5 authentication mode, the plaintext form of the key is a case-sensitive string of 1 to 255 characters, and the encrypted form is a case-sensitive string of 33 to 373 characters.
keychain: Specifies the keychain authentication mode.
keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters.
ip: Checks IP-related fields in LSPs.
osi: Checks OSI-related fields in LSPs.
Area authentication enables IS-IS to discard routes from untrusted routers.
The key in the specified mode is inserted into all outbound Level-1 packets (LSP, CSNP, and PSNP) and is used to authenticate inbound Level-1 packets.
IS-IS keychain authentication supports the HMAC-MD5 and HMAC-SM3 authentication algorithms. If the HMAC-MD5 algorithm is used, the key ID can be any value in the range supported by the key-id argument. If the HMAC-SM3 algorithm is used, the key ID must be in the range of 0 to 65535.
When keychain authentication is used, IS-IS receives and sends packets as follows:
·     Before IS-IS sends a Level-1 packet, it uses the valid send key obtained from the keychain to authenticate the packet. If no valid send key exists or the valid send key does not use the HMAC-MD5 or HMAC-SM3 algorithm, the authentication fails and the packet does not contain authentication information.
·     After IS-IS receives a Level-1 packet, it processes the packet as follows:
¡     If the authentication algorithm of the packet is HMAC-MD5, IS-IS uses a valid accept key obtained from the keychain to authenticate the packet. If no valid accept key exists or all valid accept keys fail to authenticate the packet, the authentication fails and the packet is discarded.
¡     If the authentication algorithm of the packet is HMAC-SM3, IS-IS uses the key ID of the received packet to obtain the corresponding valid accept key from the keychain. Then, IS-IS uses the accept key to authenticate the packet. If IS-IS cannot find a valid accept key based on the key ID of the received packet or the packet fails the authentication, the packet is discarded.
Routers in an area must have the same authentication mode and key.
If neither ip nor osi is specified, OSI-related fields are checked.
When you specify the GCA mode, follow these guidelines:
·     If you do not specify the nonstandard keyword, the device can communicate only with devices (including non-H3C devices) that use the GCA mode.
·     If you specify the nonstandard keyword, the device can communicate only with devices that use the nonstandard GCA mode.
In MD5 authentication mode, execute the undo area-authentication-mode command before version switch if the key lengths supported by the two versions are different.
# Set the area authentication mode to simple, and set the plaintext key to 123456.
[Sysname] isis 1
[Sysname-isis-1] area-authentication-mode simple plain 123456
auto-cost enable
Use auto-cost enable to enable automatic link cost calculation.
Use undo auto-cost enable to disable automatic link cost calculation.
auto-cost enable
Automatic link cost calculation is disabled.
IS-IS view
After automatic link cost calculation is enabled, the link cost is automatically calculated based on the bandwidth reference value of an interface. When the cost-style is wide or wide-compatible, the cost value of an interface is calculated by using the following formula: Cost = (Reference bandwidth value / Link bandwidth) × 10. For other cost styles, Table 2 applies.
Table 2 Automatic cost calculation scheme for cost styles other than wide and wide-compatible
Interface bandwidth
Cost
≤10 Mbps
60
≤100 Mbps
50
≤155 Mbps
40
≤622 Mbps
30
≤2500 Mbps
20
>2500 Mbps
10
# Enable automatic link cost calculation for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] auto-cost enable
bandwidth-reference
cost-style
isis cost
isis ipv6 cost
bandwidth-reference
Use bandwidth-reference to set the bandwidth reference value for automatic link cost calculation.
Use undo bandwidth-reference to restore the default.
bandwidth-reference value
The bandwidth reference value is 100 Mbps.
IS-IS view
value: Specifies the bandwidth reference value in the range of 1 to 2147483648 Mbps.
# Set the bandwidth reference of IS-IS process 1 to 200 Mbps.
[Sysname] isis 1
[Sysname-isis-1] bandwidth-reference 200
auto-cost enable
isis cost
Use bfd all-interfaces adjust-cost to enable BFD session state-based interface cost adjustment for an IS-IS process.
Use undo bfd all-interfaces adjust-cost to disable BFD session state-based interface cost adjustment for an IS-IS process.
bfd all-interfaces adjust-cost { cost-offset | max }
BFD session state-based interface cost adjustment is disabled.
cost-offset: Specifies the interface cost adjustment value. The value range for this argument is 1 to 16777213. When the BFD session goes down, the interface cost is cost-offset plus the original interface cost, and cannot exceed 16777214.
max: Sets the interface cost to the maximum value (16777214) when the BFD session goes down.
IMPORTANT
IMPORTANT:
For the bfd all-interfaces adjust-cost command to take effect on an IS-IS process, enable BFD for that IS-IS process first.
After you enable BFD for IS-IS link failure detection, the IS-IS neighbor relationship goes down when the BFD session is down and comes up when the BFD session is up. When the BFD session state changes frequently, IS-IS neighbor relationship flapping will occur. The running of services (such as BGP) that rely on IS-IS might be interrupted. To resolve this issue, use one of the following commands to enable BFD session state-based interface cost adjustment for IS-IS:
·     bfd all-interfaces adjust-cost
·     isis bfd adjust-cost
·     isis ipv6 bfd adjust-cost
These commands are different as follows:
·     The bfd all-interfaces adjust-cost command takes effect on all interfaces in an IPv4 or IPv6 IS-IS process. After you execute this command, IS-IS adjusts the interface cost value as follows:
¡     When the BFD session on an interface in the IS-IS process goes down, IS-IS increases the cost value for the interface.
¡     When the BFD session on an interface in the IS-IS process comes up again, IS-IS restores the cost value for the interface to the original value.
·     The isis bfd adjust-cost and isis ipv6 bfd adjust-cost commands take effect only on one IS-IS interface. To enable BFD session state-based interface cost adjustment on a single interface, perform the following tasks:
a.     Make sure the IS-IS process to which the interface belongs is not enabled with BFD session state-based interface cost adjustment.
b.     You can use the undo bfd all-interfaces adjust-cost command to disable this feature for an IS-IS process.
c.     Use the isis bfd adjust-cost or isis ipv6 bfd adjust-cost command to enable this feature on the interface.
·     For an IS-IS interface, the configuration of the isis bfd adjust-cost or isis ipv6 bfd adjust-cost command takes precedence over that of the bfd all-interfaces adjust-cost command.
# Enable BFD session state-based interface cost adjustment for IS-IS process 1, and set the interface cost adjustment value to 100.
[Sysname] isis 1
[Sysname-isis-1-ipv4] bfd all-interfaces adjust-cost 100
Use bfd all-interfaces enable to enable BFD for an IS-IS process.
Use undo bfd all-interfaces enable to disable BFD for an IS-IS process.
BFD is disabled for an IS-IS process.
IS-IS exchanges hello packets at specific intervals with its neighbors to detect neighbor state changes. If IS-IS does not receive any hello packets from a neighbor within the advertised neighbor relationship hold time, it considers the neighbor down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval and the default hold time is 30 seconds. This mechanism is not efficient at neighbor state change detection. Serious packet loss might occur when a neighbor goes down.
To resolve this issue, use this command to enable BFD for the IS-IS process. BFD provides a single mechanism to quickly detect and monitor the connectivity of links between IS-IS neighbors, reducing route convergence time.
You can use the bfd all-interfaces enable, isis bfd enable, or isis ipv6 bfd enable command to enable IS-IS BFD. These commands are different as follows:
·     The bfd all-interfaces enable command enables BFD on all interfaces in an IPv4 or IPv6 IS-IS process.
·     The isis bfd enable and isis ipv6 bfd enable commands take effect only on one IS-IS interface. To enable BFD on a single IS-IS interface, perform the following tasks:
a.     Make sure the IS-IS process to which the interface belongs is not enabled with BFD.
b.     You can use the undo bfd all-interfaces enable command to disable BFD for an IS-IS process.
c.     Use the isis bfd enable or isis ipv6 bfd enable command to enable BFD on the IS-IS interface.
# Enable BFD for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] bfd all-interfaces enable
isis bfd enable
Use bfd all-interfaces session-restrict-adj to enable BFD session state-based control of adjacency establishment and maintenance for an IS-IS process.
Use undo bfd all-interfaces session-restrict-adj to disable BFD session state-based control of adjacency establishment and maintenance for an IS-IS process.
BFD session state-based control of adjacency establishment and maintenance is disabled for an IS-IS process.
When BFD detects a Layer 3 forwarding failure between two devices, the BFD session goes down, causing the IPv4 IS-IS adjacency to go down. If Layer 2 forwarding is still available, the devices still can exchange IS-IS packets and re-establish the adjacency. This might cause traffic loss. To avoid the issue, execute this command on both the local and remote devices.
Operating mechanism
This command enables the interfaces in these IS-IS processes to carry BFD-enabled TLVs in hello packets. After the BFD session between the two devices goes down, the devices do not establish an adjacency if the exchanged BFD-enabled TLVs are identical.
If you configure this command for an existing adjacency, the BFD session state does not affect the adjacency relationship within the hold time. This mechanism avoids adjacency flappings during BFD session establishment.
If the IS-IS neighbor relationship goes down because of Layer 2 forwarding failure between the devices, the interface-associated BFD session state is not affected. That is, when the IS-IS neighbor state changes from up to down, the associated BFD session state does not go down.
IMPORTANT
IMPORTANT:
For the bfd all-interfaces session-restrict-adj command to take effect on an IS-IS process, enable BFD for that IS-IS process first.
You can use one of the following commands to enable BFD session state-based control of IS-IS adjacency establishment and maintenance:
·     bfd all-interfaces session-restrict-adj
·     isis bfd session-restrict-adj
·     isis ipv6 bfd session-restrict-adj
·     The bfd all-interfaces session-restrict-adj command takes effect on all interfaces in an IPv4 or IPv6 IS-IS process.
·     The isis bfd session-restrict-adj and isis ipv6 bfd session-restrict-adj commands take effect only on one IS-IS interface. To enable BFD session state-based control of adjacency establishment and maintenance on a single IS-IS interface, perform the following tasks:
a.     Make sure the IS-IS process to which the IS-IS interface belongs is not enabled with BFD session state-based control of adjacency establishment and maintenance.
b.     You can use the undo bfd all-interfaces session-restrict-adj command to disable this feature for an IS-IS process.
c.     Use the isis bfd session-restrict-adj or isis ipv6 bfd session-restrict-adj command to enable this feature on the IS-IS interface.
# Enable BFD session state-based control of adjacency establishment and maintenance for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] bfd all-interfaces session-restrict-adj
Use bfd all-interfaces template to apply a BFD template to an IS-IS process.
Use undo bfd all-interfaces template to restore the default.
bfd all-interfaces template template-name
No BFD template is applied to an IS-IS process. The system uses the default BFD detection parameters to establish BFD sessions with neighbors.
template-name: Specifies the name of a BFD template, a case-sensitive string of 1 to 63 characters.
After you enable BFD for IS-IS and apply a BFD template, IS-IS notifies BFD of the following information when using BFD to detect the link to a neighbor:
·     Destination address.
·     Source address.
·     Detection parameters defined in the BFD template.
BFD establishes a BFD session based on the information received. By editing detection parameters for the template, you can adjust the speed at which IS-IS detects link failures. For more information about BFD templates, see BFD configuration in High Availability Configuration Guide.
This command takes effect only when BFD is enabled for IS-IS and the specified BFD template exists.
You can use the bfd all-interfaces template, isis bfd template, or isis ipv6 bfd template command to apply a BFD template. These commands are different as follows:
·     The bfd all-interfaces template command takes effect on all interfaces in an IPv4 or IPv6 IS-IS process.
·     The isis bfd template or isis ipv6 bfd template command takes effect on a specific IS-IS interface.
·     The interface-specific template configuration by the isis bfd template or isis ipv6 bfd template command takes precedence over the process-specific template configuration by the bfd all-interfaces template command.
# Apply BFD template TEMP1 to IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] bfd all-interfaces template TEMP1
bfd template (High Availability Command Reference)
isis bfd enable
isis bfd template
bier enable
Use bier enable to enable Bit Index Explicit Replication (BIER) for an IS-IS process.
Use undo bier enable to disable BIER for an IS-IS process.
bier enable
undo bier enable
IS-IS BIER is disabled.
IS-IS view
BIER enables a node to generate a BFR ID-based forwarding table for multicast packet forwarding. For more information about BIER and the relationship between this command and BIER, see BIER configuration in BIER Configuration Guide.
With BIER enabled, IS-IS floods the BFR IDs of BIER edge devices and other information (for example, IP address of the node) in LSPs. After receiving the LSP, each node generates a bit index forwarding table to forward BIER packets by their bit strings.
When you enable IS-IS BIER, follow these guidelines:
·     This feature is available only when the link cost style is wide, compatible, or wide-compatible. To restore the link cost style to narrow by using the undo cost-style command, disable IS-IS BIER first.
·     The bier enable command takes effect only after you enable BIER by using the bier command.
·     You can enable BIER only for IS-IS processes running on the public network.
·     You can enable BIER for multiple IS-IS processes on the same device.
# Enable BIER for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] bier enable
bier (BIER Command Reference)
cost-style
Use bier fast-reroute enable to enable BIER FRR for an IS-IS process.
Use undo bier fast-reroute enable to disable BIER FRR for an IS-IS process.
BIER FRR is disabled for an IS-IS process.
IS-IS view
Use this feature to calculate the backup paths from a BFR to the other BFR prefixes in a sub-domain. When the intermediate node or primary path fails, the traffic will quickly switch to the backup path, minimizing traffic loss.
·     Only the BIER MSR6 encapsulation type is supported.
·     The bier fast-reroute enable command takes effect only after you enable BIER by using the bier enable command.
·     BIER FRR supports only node protection and link protection.
·     BIER FRR does not support the following scenarios:
¡     ECMP-shared FRR scenario—Use the LFA algorithm to calculate a shared backup next hop for multiple load-sharing primary paths.
¡     ECMP FRR scenario—Use the LFA algorithm to calculate a separate backup next hop for each one of the multiple load-sharing primary paths. The calculated backup next hops might be different.
[Sysname] isis 1
[Sysname-isis-1] bier fast-reroute enable
bier enable
cost-style
fast-reroute
Use bier sub-sub-tlv-type to configure sub-sub-TLV type values for the BIER Info Sub-TLVs advertised by an IS-IS process.
Use undo bier sub-sub-tlv-type to restore the default.
bier sub-sub-tlv-type g-bier-bsl g-bier-bsl-value g-bier-mpra g-bier-mpra-value bierv6-bsl bierv6-bsl-value bierv6-end-bier bierv6-end-bier-value
When an IS-IS process advertises BIER Info Sub-TLVs in LSPs, it uses the following sub-sub-TLV type values:
·     The type value for G-BIER BSL sub-sub-TLVs and MSR6 sub-sub-TLVs is six.
·     The type value for MPRA sub-sub-TLVs is seven.
·     The type value for BIERv6 BSL sub-sub-TLVs is two.
·     The type value for End.BIER sub-sub-TLVs is three.
IS-IS view
g-bier-bsl-value: Specifies the type value for G-BIER BSL sub-sub-TLVs and MSR6 sub-sub-TLVs. The value range for this argument is 2 to 255.
g-bier-mpra-value: Specifies the type value for MPRA sub-sub-TLVs and MSR6 sub-sub-TLVs. The value range for this argument is 2 to 255.
bierv6-bsl-value: Specifies the type value for BIERv6 BSL sub-sub-TLVs. The value range for this argument is 2 to 255.
bierv6-end-bier-value: Specifies the type value for End.BIER sub-sub-TLVs. The value range for this argument is 2 to 255.
After you enable BIER for an IS-IS process, the process advertises IS-IS Reachability Prefix TLVs that carry BIER Info Sub-TLVs in LSPs. Each BIER Info Sub-TLV contains BIER information (such as BFR prefix, sub-domain, and BFR ID) and can carry different sub-sub-TLVs to advertise scenario-specific packet encapsulation information.
For some sub-sub-TLVs, their type values might vary by vendor. When the type values for the same sub-sub-TLV on two devices, the devices cannot communicate with each other. To ensure communication with devices from other vendors, use this command to change the type values for the following sub-sub-TLVs as needed:
·     G-BIER BSL sub-sub-TLVThis sub-sub-TLV is used in the G-BIER or MSR6 scenario. It carries G-BIER or MSR6 encapsulation information.
·     MPRA sub-sub-TLV—This sub-sub-TLV is used in the G-BIER or MSR6 scenario. It carries the multicast policy reserved address (MPRA) used for BIER-based forwarding or carries the IPv6 address used for BIER-based forwarding (also known as End.RGB address).
·     BIERv6 BSL sub-sub-TLV—This sub-sub-TLV is used in the BIERv6 scenario. It carries BIERv6 encapsulation information.
·     End.BIER sub-sub-TLV—This sub-sub-TLV is used for End.BIER information advertisement in the BIERv6 scenario.
# Configure IS-IS process 1 to advertise BIER Info Sub-TLVs with specific sub-sub-TLV type values. The type value is two for G-BIER BSL sub-sub-TLVs, seven for MPRA sub-sub-TLVs, six for BIERv6 BSL sub-sub-TLVs, and three for End.BIER sub-sub-TLVs.
[Sysname] isis 1
[Sysname-isis-1] bier sub-sub-tlv-type g-bier-bsl 2 g-bier-mpra 7 bierv6-bsl 6 bierv6-end-bier 3
bier enable
circuit-cost
Use circuit-cost to set a global IS-IS link cost.
Use undo circuit-cost to remove the configuration.
circuit-cost cost-value [ level-1 | level-2 ]
undo circuit-cost [ level-1 | level-2 ]
No global link cost is configured.
IS-IS view
cost-value: Specifies the link cost value. The value range varies by cost style.
·     For styles narrow, narrow-compatible, and compatible, the cost value is in the range of 1 to 63.
·     For styles wide and wide-compatible, the cost value is in the range of 1 to 16777215. If the cost value is set to 16777215, the neighbor TLVs generated from the related links are used only for transmitting TE information and cannot be used for route calculation.
level-1: Applies the link cost to Level-1.
level-2: Applies the link cost to Level-2.
If no level is specified, the specified cost applies to both Level-1 and Level-2.
# Set the global Level-1 link cost to 11 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] circuit-cost 11 level-1
cost-style
isis cost
color-mapping
Use color-mapping to map a color attribute to a flexible algorithm.
Use undo color-mapping to remove the mapping between a color attribute and a flexible algorithm.
color-mapping color-value flex-algo flex-algo-id
undo color-mapping color-value flex-algo flex-algo-id
A color attribute is not mapped to any flexible algorithm.
SR flexible algorithm view
color-value: Specifies a color attribute value in the range of 0 to 4294967295.
flex-algo-id: Specifies a flexible algorithm ID in the range of 128 to 255.
Execute this command to forward packets through the path calculated by the specified flexible algorithm in an SR MPLS network where multiple paths exist between the source and destination nodes.
After you execute this command, an SR node processes a received BGP route that carries the color attribute as follows:
1.     Finds the flexible algorithm mapped to the color attribute.
2.     Finds the path calculated by the flexible algorithm based on the destination address of the BGP route.
3.     Iterates the BGP route to the path.
Then, the SR node will forward packets that match the BGP route through the path.
If a BGP route received by the SR node does not carry the extended community attribute, you can perform either of the following tasks to specify a color attribute for the route:
·     Add a color value to the route by using a routing policy.
·     Execute the default-color command to specify a default color value for the route.
A color attribute can be mapped to only one flexible algorithm, but a flexible algorithm can be mapped to multiple color attributes.
# Map color attribute 11 to flexible algorithm 128.
[Sysname] segment-routing
[Sysname-segment-routing] flex-algo
[Sysname-sr-flex-algo] color-mapping 11 flex-algo 128
flex-algo
cost-style
Use cost-style to set a cost style.
Use undo cost-style to restore the default.
undo cost-style
The IS-IS cost style is narrow.
IS-IS view
narrow: Receives and sends only narrow cost style packets. The narrow cost is in the range of 1 to 63.
wide: Receives and sends only wide cost style packets. The wide cost is in the range of 1 to 16777215.
compatible: Receives and sends both wide and narrow cost style packets.
narrow-compatible: Receives both narrow and wide cost style packets, but sends only narrow cost style packets.
wide-compatible: Receives both narrow and wide cost style packets, but sends only wide cost style packets.
relax-spf-limit: Allows receiving routes with a cost greater than 1023. If you do not specify this keyword, routes with a cost bigger than 1023 will be discarded. This keyword is available only when compatible or narrow-compatible is used.
# Configure the router to send only narrow cost style packets, but receive both narrow and wide cost style packets.
[Sysname] isis 1
[Sysname-isis-1] cost-style narrow-compatible
circuit-cost
isis cost
Use default-route-advertise to advertise a default route of 0.0.0.0/0.
Use undo default-route-advertise to restore the default.
default-route-advertise [ avoid-learning | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
undo default-route-advertise [ route-policy route-policy-name ]
Default route advertisement is disabled.
avoid-learning: Avoids learning the default route received in LSPs or generated by using the ATT bit to avoid routing loops.
level-1: Advertises a Level-1 default route.
level-1-2: Advertises both Level-1 and Level-2 default routes.
level-2: Advertises a Level-2 default route.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
tag tag: Specifies the tag value for the default route, in the range of 1 to 4294967295.
If no level is specified, a Level-2 default route is advertised.
The Level-1 default route is advertised to other routers in the same area, and the Level-2 default route is advertised to all the Level-2 and Level-1-2 routers.
You can use a routing policy to specify a level for the default route. The apply isis level-1 command in routing policy view can generate a Level-1 default route. The apply isis level-2 command in routing policy view can generate a Level-2 default route. The apply isis level-1-2 command in routing policy view can generate both a Level-1 default route and Level-2 default route.
The tag value specified in the routing policy takes precedence over the tag value specified in this command.
# Configure IS-IS process 1 to advertise a Level-2 default route.
[Sysname] isis 1
[Sysname-isis-1-ipv4] default-route-advertise
display isis
Use display isis to display configuration information for an IS-IS process.
display isis [ process-id ]
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays configuration information for all IS-IS processes.
# Display IS-IS configuration information.
<Sysname> display isis
          IS-IS(1) Protocol Information
Instance identifier             : 10
Network entity                  : 10.0000.0000.0001.00
IS level                        : level-1-2
Cost style                      : Wide
Isolation                       : Disabled
BIER                            : Disabled
BIER fast reroute               : Disabled
G-BIER sub-sub-tlv type         : BSL 6, MPRA 7
BIERv6 sub-sub-tlv type         : BSL 2, End.BIER 3
MSR6   sub-sub-tlv type         : BSL 6, End.RGB 7
Process state                   : Admin-down
Process mode                    : Lite
Microloop-avoidance
    level-1                     : Disabled
    level-2                     : Disabled
Microloop-avoidance RIB-update-delay
    level-1                     : 5000
    level-2                     : 5000
Fast-reroute remote-LFA
    level-1                     : Disabled
    level-2                     : Disabled
Link-state                      : Link-state
    Instance ID                 : 10
    Level-1                     : Enabled
    Level-2                     : Enabled
Link attribute advertisement    : Enabled
Metric-delay advertisement
    level-1                     : Enabled
    level-2                     : Enabled
Metric-delay advertisement suppression
    Timer                       : 120
    Percent Threshold           : 10
    Absolute Threshold          : 1000
Metric-bandwidth advertisement
    level-1                     : Enabled
    level-2                     : Enabled
Metric-bandwidth advertisement suppression
    Timer                       : 120
Metric-link-loss advertisement
    level-1                     : Enabled
    level-2                     : Enabled
Metric-link-loss advertisement suppression
    Timer                       : 120
Preference                      : 15
LSP length receive              : 1497
LSP length originate
    level-1                     : 1497
    level-2                     : 1497
Maximum imported routes         : 1000
BFD                             : Enabled
BFD session-restrict-adj        : Enabled
BFD adjust cost                 : Maximum
BFD template                    : TEMP1
Primary path detection mode     : Ctrl
Overload send SA bit            : Disabled
Overload route delay distribute : Disabled
Overload adjust route metric    : Disabled
Overload adjust link cost       : Disabled
Timers
    LSP-max-age                 : 1200
    LSP-refresh                 : 900
    SPF mode                    : Normal
    SPF intervals               : 5 50 200
    LSP RLT-refresh             : 1600
Advertise application specific link attributes
    TE                          : Disabled
    SRLG                        : Disabled
    Bandwidth                   : Disabled
    Delay                       : Disabled
    Link-Loss                   : Disabled
    Unidirectional-Bandwidth    : Disabled
Inter-level-tilfa level-1       : Enabled
    Prefer                      : Disabled
Metric-delay normalize
    Interval                    : 20 ms
    Offset                      : 5 ms
IPv6 enabled
    Fast reroute                : Disabled
    Microloop-avoidance
        level-1                 : Enabled
        level-2                 : Enabled
        level-1                 : 5000
        level-2                 : 5000
    Preference                  : 15
    BFD                         : Enabled
    BFD template                : TEMP2
    SPF mode                    : Normal
    Link attribute advertisement: Disabled
        level-1                 : Disabled
        level-2                 : Disabled
        Timer                   : 120
        level-1                 : Disabled
        level-2                 : Disabled
        Timer                   : 120
        level-1                 : Enabled
        level-2                 : Enabled
        Timer                   : 120
    Link tag inheritance        : Disabled
    Advertise application specific link-attributes
        TE                      : Enabled
        SRLG                    : Enabled
        Interval                : 20 ms
        Offset                  : 5 ms
Segment routing IPv4
    MPLS                        : Disabled
    Adjacency                   : Disabled
    Member-port adjacency       : Disabled
    Configured SRGB             : 18000 190000
    Effective SRGB              : 18000 190000
    Level-1 tunnel count        : 0
    Level-2 tunnel count        : 0
    Local block                 : 15000 15999
    Fast-reroute TI-LFA
        level-1                 : Disabled
        level-2                 : Disabled
    Node-protecting preference
        level-1                 : 40
        level-2                 : 40
    Lowest-cost preference
        level-1                 : 20
        level-2                 : 20
    SRLG preference
        level-1                 : 10
        level-2                 : 10
    Non-ECMP preference
        level-1                 : 15
        level-2                 : 15
    SR microloop avoidance
        level-1                 : Disabled
        level-2                 : Disabled
    SR microloop avoidance RIB-update-delay
        level-1                 : 5000
        level-2                 : 5000
    SR microloop avoidance strict-sid-only      : Disabled
    SR adjacency label deletion delay
        State                   : Enabled
        Delay time              : 1900 sec
Segment routing IPv6
    SRv6                        : Enabled
    SRv6 SRH compression
        level-1                 : Enabled
        level-2                 : Enabled
    Fast-reroute TI-LFA
        level-1                 : Disabled
        level-2                 : Disabled
    Fast-reroute TI-LFA Encaps  : Disabled
        level-1                 : 40
        level-2                 : 40
        level-1                 : 20
        level-2                 : 20
    SRLG preference
        level-1                 : 10
        level-2                 : 10
    Non-ECMP preference
        level-1                 : 15
        level-2                 : 15
        level-1                 : Disabled
        level-2                 : Disabled
        level-1                 : 5000
        level-2                 : 5000
    SR microloop avoidance Encaps               : Disabled
    End.X SID deletion delay
        State                   : Enabled
        Delay time              : 100 sec
    SRv6 locator admin tag      : 100
Instance identifier
Multi-instance process ID.
Network-entity
Network entity name.
IS level
IS-IS routing level.
Cost style
Cost style.
IPv6 router ID
IPv6 router ID.
Isolation
Whether IS-IS isolation is enabled.
Process state
IS-IS process state. If you shut down the process by using the shutdown process command, this field displays Admin-down. If the process is not shut down, this field is not displayed.
BIER
Whether BIER is enabled.
BIER fast reroute
Whether BIER FRR is enabled.
IS-IS G-BIER sub-sub-TLV type values:
·     BSL—Type value for G-BIER BSL sub-sub-TLVs. The sub-sub-TLV carries G-BIER encapsulation information.
·     MPRA—Type value for MPRA sub-sub-TLVs. The sub-sub-TLV carries the multicast policy reserved address (MPRA).
IS-IS BIERv6 sub-sub-TLV type values:
·     BSL—Type value for BIERv6 BSL sub-sub-TLVs. The sub-sub-TLV carries BIERv6 encapsulation information.
·     End.BIER—Type value for End.BIER sub-sub-TLVs. The sub-sub-TLV carries End.BIER encapsulation information.
IS-IS MSR6 sub-sub-TLV type values:
·     BSL—Type value for MSR6 BSL sub-sub-TLVs. The sub-sub-TLV carries MSR6 encapsulation information.
·     End.BIER—Type value for End.RGB sub-sub-TLVs. The sub-sub-TLV carries End.RGB address information.
Fast reroute
IS-IS FRR status:
·     Disabled—IS-IS FRR is disabled.
·     LFA level-1-2—IS-IS FRR automatically calculates a backup next hop only for non-ECMP routes.
·     Route-policy—IS-IS FRR specifies a backup next hop by using a routing policy.
·     LFA ecmp-shared—IS-IS FRR automatically calculates a backup next hop for all routes, including ECMP routes. ECMP routes share one backup next hop.
·     LFA ecmp-frr—IS-IS FRR automatically calculates a backup next hop for all routes, including ECMP routes. IS-IS FRR calculates a backup next hop independently for each ECMP route.
Process mode
Process mode:
·     Lite—Lightweight IS-IS process.
·     Normal—Traditional IS-IS process.
SRv6-policy AutoRoute
Whether automatic route advertisement is enabled for the SRv6 TE policy or SRv6 TE policy group.
·     Disabled—Not enabled.
·     level-1—Enabled at Level 1.
·     level-2—Enabled at Level 2.
·     level-1-2—Enabled at Level 1-2.
Microloop-avoidance
Microloop avoidance status: Disabled or Enabled.
Microloop avoidance RIB-update-delay timer.
Remote LFA FRR status: Disabled or Enabled.
Link-state distribution
IS-IS link state information advertisement.
·     Link-stateThe device advertises IS-IS link state information to all protocols, such as BGP, SR-MPLS TE policy.
·     BGP-LS—The device advertises IS-IS link state information to only BGP.
·     SR-DB—The device advertises IS-IS link state information to only the segment routing database.
Instance ID
IS-IS instance ID.
Link attribute advertisement status: Disabled or Enabled.
Link delay advertisement status:
·     Disabled.
·     Enabled.
·     Enabled, include member-port—Enable link delay advertisement for Layer 3 aggregation group member interfaces and IPv6 IS-IS interfaces.
Information about link delay advertisement suppression:
·     Timer—Link delay advertisement suppression timer in seconds.
·     Percent threshold—Suppression threshold for the delay variation ratio in percentage.
·     Absolute threshold—Suppression threshold for the absolute value of the delay variation in microseconds.
This field is not displayed if IS-IS link delay advertisement is disabled.
Link bandwidth advertisement status:
·     Disabled.
·     Enabled.
·     Enabled, include member-port—Enable link bandwidth advertisement for Layer 3 aggregation group member interfaces and IPv6 IS-IS interfaces.
Link bandwidth advertisement suppression timer in seconds. This field is not displayed if link bandwidth advertisement is disabled.
Link loss advertisement status:
·     Disabled.
·     Enabled.
·     Enabled, include member-port—Enable link loss advertisement for Layer 3 aggregation group member interfaces and IPv6 IS-IS interfaces.
Information about link loss advertisement suppression:
·     Timer—Link loss advertisement suppression timer in seconds.
·     Percent threshold—Suppression threshold for the link loss variation ratio in percentage.
·     Absolute threshold—Suppression threshold for the absolute value of the link loss variation in microseconds.
This field is not displayed if IS-IS link loss advertisement is disabled.
Whether IPv6 IS-IS link tag inheritance is enabled.
Application-specific link attribute advertisement.
·     TEWhether IS-IS advertises the TE attribute, link delay, and link bandwidth.
·     SRLG—Whether IS-IS advertises the SRLG attribute.
Preference
IS-IS route preference.
LSP length receive
Maximum LSP that can be received.
Maximum LSP that can be generated.
Maximum number of redistributed Level-1/Level-2 IPv4/IPv6 routes.
BFD
BFD is enabled for the IS-IS process.
This field is available only when BFD is enabled for the IS-IS process.
BFD session state-based control of adjacency establishment and maintenance is enabled for the IS-IS process.
This field is available only when this feature is enabled for the IS-IS process.
BFD adjust cost
Interface cost adjustment parameters:
·     cost-offsetInterface cost adjustment value. The value range for cost-offset is 1 to 16777213. When the BFD session goes down, the interface cost is cost-offset plus the original interface cost.
·     Maximum—Maximum interface cost value (16777214). When the BFD session goes down, IS-IS will adjust the interface cost to the maximum.
This field is available only when BFD session state-based interface cost adjustment is enabled for the IS-IS process.
BFD template
BFD template applied to the IS-IS process. If no template is applied, this field is not displayed.
BFD is used for primary link failure detection in the IS-IS process. Primary link failure detection modes include:
·     Ctrl—BFD control packet mode.
·     Echo—BFD echo packet mode.
This field is available only when BFD is used for primary link failure detection in the IS-IS process.
Whether the device sends hello packets with the SA bit set, in overload state:
·     Disabled—When the device enters the overload state, it does not set the SA bit in hello packets before advertising them.
·     Enabled, duration time1 (time2 left)—When the device enters the overload state, it sets the SA bit in hello packets before advertising them until time1 elapses. The time2 argument represents the remaining time during which the device sets the SA bit in the advertised hello packets. The measurement unit for time1 and time2 is second.
Whether the device delays route advertisement, in overload state:
·     Disabled—When the device enters the overload state, it does not delay route advertisement.
·     Enabled, delay time1 (time2 left)—When the device enters the overload state, it delays route advertisement until time1 elapses. The time2 argument represents the remaining time during which route advertisement is delayed. The measurement unit for time1 and time2 is second.
Whether the device sets the cost value to the maximum for the advertised routes, in overload state:
·     Disabled—When the device enters the overload state, it does not set the cost value to the maximum for the advertised routes.
·     Enabled, maximum—When the device enters the overload state, it sets the cost value to the maximum for the advertised routes.
Whether the device adjusts the cost value for all IS-IS interfaces, in overload state:
·     Disabled—When the device enters the overload state, it does not adjust the cost value for all IS-IS interfaces.
·     Enabled, max—When the device enters the overload state, it sets the cost value to the maximum for all IS-IS interfaces.
·     Enabled, offset xx—When the device enters the overload state, it adjusts the cost value for all IS-IS interfaces. The new interface cost value equals offset xx plus the original interface cost. Offset xx represents the interface cost adjustment value.
Timers
Timers:
·     LSP-max-age—Maximum life period of LSPs.
·     LSP-refresh—Refresh interval of LSPs.
·     SPF mode—SPF interval calculation mode.
·     SPF intervals—Interval between SPF calculations.
·     LSP RLT-refresh—IS-IS LSP initial age configured by using the timer lsp-remaining-lifetime refresh command. If IS-IS uses the original ages of LSPs, this field displays Disabled.
IS-IS ASLA advertisement settings.
TE
The Asla-only attribute indicates that IS-IS is suppressed from advertising TE attribute information, link delay information, and bandwidth information in Extended IS Reachability TLVs.
SRLG
The Asla-only attribute indicates that IS-IS is suppressed from advertising SRLG attribute information in Shared Risk Link Group TLVs.
Bandwidth
Whether IS-IS advertises the link bandwidth information defined by RFC 5305.
The Asla-only attribute indicates that IS-IS is suppressed from advertising the link bandwidth information defined by RFC 5305 in Extended IS Reachability TLVs.
Delay
Whether IS-IS advertises link delay information.
The Asla-only attribute indicates that IS-IS is suppressed from advertising link delay information in Extended IS Reachability TLVs.
Link-Loss
Whether IS-IS advertises link loss information.
The Asla-only attribute indicates that IS-IS is suppressed from advertising link loss information in Extended IS Reachability TLVs.
Whether IS-IS advertises the link bandwidth information defined by RFC 8570.
The Asla-only attribute indicates that IS-IS is suppressed from advertising the link bandwidth information defined by RFC 8570 in Extended IS Reachability TLVs.
Whether Level-1 TI-LFA can use a Level-2 path as the backup path:
·     Disabled—Level-1 TI-LFA cannot use a Level-2 path as the backup path.
·     Enabled—Level-1 TI-LFA can use a Level-2 path as the backup path.
Prefer
Whether Level-1 TI-LFA prefers Level-2 paths during backup path selection:
·     Disabled—Level-1 TI-LFA prefers Level-1 paths during backup path selection.
·     Enabled—Level-1 TI-LFA prefers Level-2 paths during backup path selection.
Link delay normalization configuration for IS-IS:
·     Interval—Interval value for link delay normalization, in milliseconds.
·     Offset—Offset value for link delay normalization, in milliseconds.
When IS-IS does not normalize link delay values, both the Interval and Offset fields display 0.
IPv6 enabled
IPv6 is enabled.
Multi-topology
IPv6 unicast topology mode:
·     Standard—IPv6 unicast topology standard mode.
·     Compatible—IPv6 unicast topology compatible mode.
Overload status
Overload bit status:
·     Overloaded manually—The overload bit is set manually.
·     Overloaded on startup—The overload bit is set on system startup.
·     Overloaded on startup waiting for nbr system-id up timeout1—The overload bit is set within the timeout1 interval waiting the neighbor system-id to come up.
·     Overloaded on startup after nbr system-id up timeout1—The overload bit is set within the timeout1 interval after the neighbor system-id comes up.
·     Overloaded for memory shortageThe overload bit is set for memory shortage.
·     Overloaded for graceful starting—The overload bit is set during the GR starting period.
·     Overloaded for isolation—The overload bit is set for IS-IS isolation.
IPv4 segment routing is supported.
MPLS
SR-MPLS status: Disabled or Enabled.
Adjacency
Adjacency label allocation status: Disabled or Enabled.
Whether adjacency label allocation is enabled on member interfaces:
·     Disabled.
·     Enabled.
Configured SRGB
Configured SRGB range. This field is displayed when SRGB is configured.
Effective SRGB
SRGB range that takes effect.
Local block
Minimum and maximum label values of the SRLB.
Fast-reroute TI-LFA
Topology independent LFA (TI-LFA) FRR status: Disabled or Enabled.
Priority of the node-protection backup path selection policy.
Priority of the lowest-cost backup path selection policy.
SRLG preference
Priority of the shared risk link group (SRLG)-disjoint backup path selection policy.
Non-ECMP preference
Priority of the non-ECMP backup path selection policy.
SR microloop avoidance status: Disabled or Enabled.
SR microloop avoidance RIB-update-delay timer.
Whether to encapsulate strict SIDs for SR microloop avoidance.
Configuration information about SR adjacency label deletion:
·     State—Enabling state of SR adjacency label deletion.
·     Delay time—Delay time for SR adjacency label deletion, in seconds.
IPv6 segment routing is supported.
SRv6
Whether SRv6 is enabled.
Whether SRv6 SRH compression is enabled.
Fast-reroute TI-LFA encaps
Whether TI-LFA FRR is enabled to use the encap encapsulation mode.
SR microloop avoidance encaps
Whether SR microloop avoidance is enabled to use the encap encapsulation mode.
Information about dynamic End.X SID deletion delay.
Status of dynamic End.X SID deletion delay: Disabled or Enabled.
Delay time
End.X SID deletion delay timer in seconds.
Administrative tag of the SRv6 locator. If no administrative tag is configured, this field is not displayed.
Number of Level-1 SR tunnels.
Number of Level-2 SR tunnels.
display isis event-log graceful-restart
Use display isis event-log graceful-restart to display IS-IS GR log information.
display isis event-log graceful-restart slot slot-number
slot slot-number: Specifies a card by its slot number.
# Display IS-IS GR log information for the specified slot.
<Sysname> display isis event-log graceful-restart slot 0
IS-IS loginfo :
Sep 18 08:48:24 2015 slot 0 Process 1 enter GR restarting phase(Initialization).
Sep 18 08:48:24 2015 slot 0 Process 1 enter GR phase (LSDB synchronization).
Sep 18 08:48:24 2015 slot 0 Process 1 enter GR phase (TE tunnel prepare).
Sep 18 08:48:24 2015 slot 0 Process 1 enter GR phase (First SPF computation).
Sep 18 08:48:25 2015 slot 0 Process 1 enter GR phase (Redistribution).
Sep 18 08:48:25 2015 slot 0 Process 1 enter GR phase (Second SPF computation).
Sep 18 08:48:25 2015 slot 0 Process 1 enter GR phase (LSP stability).
Sep 18 08:48:25 2015 slot 0 Process 1 enter GR phase (LSP generation).
Sep 18 08:48:25 2015 slot 0 Process 1 enter GR phase (Finish).
Sep 18 08:48:25 2015 slot 0 Process 1 GR complete.
GR phase
GR phase:
·     Initialization.
·     LSDB synchronization.
·     TE tunnel prepare—Preparing for TE tunnel computation.
·     First SPF computation.
·     Redistribution.
·     Second SPF computation.
·     LSP stability—Ready to generate LSPs.
·     LSP generation.
·     Finish.
display isis event-log hello
Use display isis event-log hello to display IS-IS log information about received or sent hello packets.
display isis event-log hello { peer-change | received-abnormal | received-dropped | sent-abnormal | sent-failed } [ process-id ]
peer-change: Specifies log information for hello packets received or sent during neighbor state change.
received-abnormal: Specifies log information for abnormally received hello packets, which were received at intervals greater than or equal to 0.5 times the holdtime (number of missed hello packets multiplied by the hello interval).
received-dropped: Specifies log information for received hello packets that were dropped.
sent-abnormal: Specifies log information for abnormally sent hello packets, which were sent at intervals greater than or equal to 1.5 times the hello interval.
sent-failed: Specifies log information for hello packets that failed to be sent.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays IS-IS log information for all processes.
# Display log information for hello packets received or sent during neighbor state change.
<Sysname> display isis event-log hello peer-change
                            Hello logs for IS-IS(1)
 Interface: XGE3/0/1; NbrSystemID: 0000.0000.0002
 Level-2 peer Up->Down at 2019-11-21 15:10:10:207
 First 3 hello packets sent:
   2019-11-21 11:34:33:311, succeeded
   2019-11-21 11:34:33:323, succeeded
   2019-11-21 11:34:41:057, succeeded
 Last 3 hello packets sent:
   2019-11-21 15:09:44:106, succeeded
   2019-11-21 15:09:54:075, succeeded
   2019-11-21 15:10:03:203, succeeded
 First 3 hello packets received:
   2019-11-21 11:34:33:321
   2019-11-21 11:34:33:978
   2019-11-21 11:34:43:524
 Last 3 hello packets received:
   2019-11-21 15:10:01:063
   2019-11-21 15:10:04:370
   2019-11-21 15:10:07:851
 Level-1 peer Up->Down at 2019-11-21 15:10:10:206
   2019-11-21 11:34:33:310, succeeded
   2019-11-21 11:34:33:320, succeeded
   2019-11-21 11:34:42:845, succeeded
   2019-11-21 15:09:50:074, succeeded
   2019-11-21 15:09:57:643, succeeded
   2019-11-21 15:10:05:665, succeeded
   2019-11-21 11:34:33:313
   2019-11-21 11:34:35:738
   2019-11-21 11:34:44:346
   2019-11-21 15:10:01:062
   2019-11-21 15:10:07:847
Table 5 Command output
Interface that sent or received the hello packets.
NbrSystemID
System ID of the neighbor.
Time and result (succeeded or failed) for sending the first three hello packets. For a packet that failed to be sent, an error code is displayed in the errno field.
Time and result (succeeded or failed) for sending the last three hello packets before neighbor state change. For a packet that failed to be sent, an error code is displayed in the errno field.
Time when the first three hello packets were received.
Time when the last three hello packets were received before neighbor state change.
# Display log information about hello packets that failed to be sent.
<Sysname> display isis event-log hello sent-failed
Date: 2019-06-06 Time: 14:51:20:121  Interface: XGE3/0/1
PDU type: L1 hello; errno: 132
PDU type: L2 hello; errno: 132
Date: 2019-06-06 Time: 11:20:20:116  Interface: XGE3/0/2
PDU type: P2P hello; errno: 132
Table 6 Command output
Date
Date for the hello packet sending failure, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time for the hello packet sending failure, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
Interface that sent the hello packet.
PDU type
Type of the hello packet that failed to be sent.
errno
Error code for the hello packet sending failure.
# Display log information for abnormally sent hello packets.
<Sysname> display isis event-log hello sent-abnormal
Date: 2019-06-06 Time: 11:21:12:121  Interface: XGE3/0/1
PDU type: L1 hello, last one sent: 2019-06-06 11:20:51:916
Date: 2019-06-06 Time: 11:56:21:312  Interface: XGE3/0/2
PDU type: P2P hello, last one sent: 2019-06-06 11:56:02:691
Table 7 Command output
Date
Date when the hello packet was sent, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time when the hello packet was sent, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
PDU type
Type of the hello packet.
last one sent
Time when the last hello packet was sent before the hello packet was sent.
# Display log information about received hello packets that were dropped.
<Sysname> display isis event-log hello received-dropped
Date: 2019-06-06 Time: 14:51:22:791  Interface: XGE3/0/1
PDU type: L1 hello, NbrSystemID: 0000.0000.0001
Drop reason: Excessive area addresses
Date: 2019-06-06 Time: 14:51:20:121  Interface: XGE3/0/2
PDU type: P2P hello, NbrSystemID: 0000.0000.0003
Drop reason: Duplicate system ID
Table 8 Command output
Date
Date when the received hello packet was dropped, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time when the received hello packet was dropped, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
Interface that received the hello packet.
PDU type
Packet type.
NbrSystemID
Drop reason
Reason for dropping the hello packet:
·     Bad packet length.
·     Bad header length.
·     Jumbo packet.
·     Bad protocol description.
·     Bad protocol ID.
·     Bad protocol version.
·     Unknown packet type.
·     Bad max area count.
·     Bad system ID length.
·     Bad circuit type.
·     Bad auth TLV.
·     Bad area address TLV.
·     Auth failure.
·     Excessive area addresses.
·     Bad NBR TLV.
·     Excessive auth TLVs.
·     Excessive IF Addr TLVs.
·     Excessive IF addresses.
·     Bad IF address TLV.
·     Duplicate system ID.
·     Bad TLV length.
·     Bad IP address.
·     Duplicate IP address.
·     Mismatched area address.
·     Mismatched protocol.
·     Mismatched network type.
·     Bad IPv6 address TLV.
·     Bad IPv6 address.
·     Duplicate IPv6 address.
·     Bad MT ID TLV.
·     SNPA conflict (LAN).
·     Excessive NBR SNPAs (LAN).
·     Mismatched level (LAN).
·     Bad 3-Way option TLV (P2P).
·     No common MT ID (P2P).
·     Bad circuit ID (P2P).
·     Bad BFD TLV.
·     Bad global IPv6 address TLV.
·     Bad multi instance TLV.
# Display log information about abnormally received hello packets.
<Sysname> display isis event-log hello received-abnormal
               Hello logs for IS-IS(vpna-1)
Date: 2019-06-06 Time: 10:12:22:121  Interface: XGE3/0/1
Last one received: 2019-06-06 10:12:01:212
Last one received: 2019-06-06 14:51:05:113
Table 9 Command output
Date
Date when the hello packet was received, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time when the hello packet was received, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
PDU type
Packet type.
NbrSystemID
Last one received
Time when the last hello packet was received before the hello packet was received.
reset isis event-log hello
display isis event-log lsp
Use display isis event-log lsp to display IS-IS LSP log information.
display isis event-log lsp { purged [ generated | received ] | refreshed } [ level-1 | level-2 ] [ process-id ] [ from time1 date1 [ to time2 date2 ] ]
purged: Displays log information about purge LSPs.
generated: Displays log information about purge LSP generation.
received: Displays log information about purge LSP reception.
refreshed: Displays log information about refresh LSPs, including generated and received LSPs.
level-1: Displays Level-1 LSP log information.
level-2: Displays Level-2 LSP log information.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays LSP log information for all IS-IS processes.
from time1 date1: Specifies the start time. The time1 argument represents the hour, in the range of 0 to 24. The date1 argument represents the date in MM/DD/YYYY or YYYY/MM/DD format. MM represents the month, in the range of 1 to 12. DD represents the day and its value range depends on the specified month. YYYY represents the year, in the range of 2000 to 2035.
to time2 date2: Specifies the end time. The time2 argument represents the hour, in the range of 0 to 24. The date2 argument represents the date in MM/DD/YYYY or YYYY/MM/DD format. MM represents the month, in the range of 1 to 12. DD represents the day and its value range depends on the specified month. YYYY represents the year, in the range of 2000 to 2035. If you do not specify any end time, the time when this command is executed is specified as the end time.
If you use the display isis event-log lsp purged command without specifying the generated or received keyword, the command displays log information about both purge LSP generation and purge LSP reception.
If you do not specify a level, the command displays both Level-1 and Level-2 LSP log information.
# Display log information about both purge LSP generation and purge LSP reception.
<Sysname> display isis event-log lsp purged
                              LSP log for IS-IS(1)
                                Level-1 LSP log
Date       Time         LSP ID               Seq Num    Event
2017-07-31 10:19:48:026 1111.1111.1111.01-00 0x00000001 Generated LSP purge pkt
2017-07-31 10:19:48:026 1111.1111.1111.01-00 0x00000001 Received LSP purge pkt
2017-07-31 10:15:29:030 2222.2222.2222.01-00 0x00000005 Generated LSP purge pkt
                                Level-2 LSP log
# Display log information about purge LSP generation.
<Sysname> display isis event-log lsp purged generated
                     Level-1 generated LSP purge packet log
2022-01-18 08:39:39:655 0000.0000.0006.00-00 0x0000000b
2022-01-18 08:39:39:653 0000.0000.0002.01-00 0x00000001
2022-01-18 08:39:39:652 0000.0000.0002.00-00 0x0000000b
# Display log information about purge LSP reception.
<Sysname> display isis event-log lsp purged received
                     Level-1 received LSP purge packet log
Date       Time         LSP ID               Seq Num    Interface
2022-01-18 08:39:41:061 0000.0000.0006.00-00 0x0000000b XGE3/0/1
2022-01-18 08:39:41:061 0000.0000.0002.01-00 0x00000001 XGE3/0/1
2022-01-18 08:39:41:061 0000.0000.0002.00-00 0x0000000b XGE3/0/1
# Display log information about refresh LSPs.
<Sysname> display isis event-log lsp refreshed
                                Level-1 LSP log
2022-01-18 08:30:57:365 0000.0000.0001.00-00 0x0000000a Generated LSP
2022-01-18 08:30:50:676 0000.0000.0006.00-00 0x00000007 Received LSP
2022-01-18 08:30:48:462 0000.0000.0002.00-00 0x00000007 Received LSP
2022-01-18 08:30:05:375 0000.0000.0001.00-00 0x00000009 Generated LSP
2022-01-18 08:30:05:275 0000.0000.0001.00-00 0x00000008 Generated LSP
2022-01-18 08:29:21:943 0000.0000.0002.01-00 0x00000001 Received LSP
2022-01-18 08:29:21:943 0000.0000.0002.00-00 0x00000006 Received LSP
2022-01-18 08:29:21:515 0000.0000.0001.00-00 0x00000007 Generated LSP
                                Level-2 LSP log
2022-01-18 08:32:50:529 0000.0000.0006.00-00 0x0000000c Received LSP
2022-01-18 08:32:48:516 0000.0000.0002.00-00 0x0000000b Received LSP
2022-01-18 08:30:57:365 0000.0000.0001.00-00 0x0000000c Generated LSP
2022-01-18 08:30:50:676 0000.0000.0006.00-00 0x0000000b Received LSP
2022-01-18 08:30:48:462 0000.0000.0002.00-00 0x0000000a Received LSP
2022-01-18 08:30:05:769 0000.0000.0002.00-00 0x00000009 Received LSP
2022-01-18 08:30:05:750 0000.0000.0006.00-00 0x0000000a Received LSP
2022-01-18 08:30:05:410 0000.0000.0006.00-00 0x00000009 Received LSP
2022-01-18 08:30:05:403 0000.0000.0002.00-00 0x00000008 Received LSP
2022-01-18 08:30:05:375 0000.0000.0001.00-00 0x0000000b Generated LSP
Table 10 Command output
Date
Date of the LSP change, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time of the LSP change, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
LSPID
LSP ID.
Seq Num
LSP sequence number.
Interface that received the purge LSP.
Event
LSP change event:
·     Received LSP.
·     Generated LSP.
reset isis event-log lsp
display isis event-log non-stop-routing
Use display isis event-log non-stop-routing to display IS-IS NSR log information.
display isis event-log non-stop-routing slot slot-number
# Display IS-IS NSR log information for the specified slot.
<Sysname> display isis event-log non-stop-routing slot 0
IS-IS loginfo :
Jan  6 10:22:04 2019 slot 3 Enter HA Block status
Jan  6 10:22:04 2019 slot 3 Exit HA Block status
Jan  6 10:22:54 2019 slot 3 Start upgrade.
Jan  6 10:22:54 2019 slot 3 Process 100 enter NSR phase (Initialization).
Jan  6 10:22:54 2019 slot 3 Process 100 enter NSR phase (Smooth).
Jan  6 10:22:54 2019 slot 3 Ten-GigaEthernet3/1/1 send first hello.
Jan  6 10:22:54 2019 slot 3 Process 100 enter NSR phase (TE tunnel prepare).
Jan  6 10:22:54 2019 slot 3 Process 100 enter NSR phase (First SPF computation).
Jan  6 10:22:54 2019 slot 3 Process 100 enter NSR phase (Redistribution).
Jan  6 10:22:54 2019 slot 3 Process 100 enter NSR phase (Second SPF computation).
Jan  6 10:22:54 2019 slot 3 Process 100 enter NSR phase (LSP stability).
Jan  6 10:22:54 2019 slot 3 Process 100 enter NSR phase (LSP generation).
Jan  6 10:22:54 2019 slot 3 Process 100 enter NSR phase (Finish).
Jan  6 10:22:54 2019 slot 3 Process 100 NSR complete.
Jan  6 10:22:54 2019 slot 3 Upgrade complete.
Table 11 Command output
NSR phase
NSR phase:
·     Start upgrade.
·     Initialization.
·     Smooth.
·     Ten-GigabitEthernet3/0/1 send first hello.
·     Redistribution.
·     LSP generation.
·     Finish.
·     NSR complete.
·     Upgrade complete.
display isis event-log peer
Use display isis event-log peer to display neighbor state change log information.
display isis event-log peer [ process-id ]
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays neighbor state change log information for all IS-IS processes.
# Display neighbor state change log information for IS-IS process 1.
<Sysname> display isis event-log peer 1
                             Peer Log for IS-IS(1)
Date       Time     NbrSystemId    Type Reason                 Interface
2019-11-21 15:10:10 0000.0000.0002 L2   CircuitDown            GE1/0/1
2019-11-21 15:10:10 0000.0000.0002 L1   CircuitDown            GE1/0/1
Table 12 Command output
Date
Date when the neighbor state changed, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time when the neighbor state changed, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
NbrSystemId
Link type:
·     L1—Level-1 link.
·     L2—Level-2 link.
·     L1L2—Level-1-2 link.
Reason
Reason why the neighbor state changed:
·     ProcessReset.
·     ProcessResetGR.
·     ProcessLevelChange.
·     ProcessDeleted.
·     ProcessStopped.
·     LSPSequenceExceed.
·     AreaDeleted.
·     PeerReset.
·     HoldtimeExried.
·     BFDDown.
·     BFDAdminDown.
·     BFDLocalCfgChange.
·     BFDRemoteCfgChange.
·     IPv6TopoloyModeChange.
·     WaitDeleteBFDTLVTimeout.
·     CircuitIPv4Down.
·     CircuitIPv6Down.
·     PeerIPv4Disabled.
·     PeerIPv6Disabled.
·     CircuitDown.
·     CircuitDelete.
·     CircuitSilent.
·     CircuitTypeMismatch.
·     CircuitParamChange.
·     CircuitLevelChange.
·     CircuitIPv4Disabled.
·     CircuitIPv6Disabled.
·     IPv4AddressDelete.
·     IPv6AddressDelete.
·     IIHProtocloMismatch.
·     IIHAreaMismatch.
·     IIHCircuitTypeMismatch.
·     IIHNoSNPA.
·     IIHNoLocalSNPA.
·     SNPAConflict.
·     GRDown.
·     SystemIdChanged.
·     CircuitIdChanged.
·     ExtendedCircuitIdChanged
·     ThreeWayStateDown.
Local interface connected to the neighbor.
reset isis event-log peer
display isis event-log route-record
Use display isis event-log route-record to display log information about route changes in the IP routing table.
display isis event-log route-record { add | delete | modify } [ ipv4 | ipv6 ] [ level-1 | level-2 ] [ process-id ] [ verbose ]
add: Displays route adding log information.
delete: Displays route deletion log information.
modify: Displays route update log information.
ipv4: Displays log information about route changes in the IPv4 routing table.
ipv6: Displays log information about route changes in the IPv6 routing table.
level-1: Displays log information about Level-1 route changes in the IP routing table.
level-2: Displays log information about Level-2 route changes in the IP routing table.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays log information about route changes in the IP routing table for all IS-IS processes.
verbose: Displays detailed log information about route changes in the IP routing table. If you do not specify this keyword, the command displays brief log information about route changes in the IP routing table.
A route change occurs in the IP routing table when the IS-IS process adds, updates, or deletes a route.
If you specify neither the ipv4 nor ipv6 keyword, the command displays log information about route changes in the IPv4 routing table.
If you do not specify a level, the command displays log information about Level-1 route changes and Level-1 route changes in the IP routing table.
# Display brief log information about IPv4 route adding.
<Sysname> display isis event-log route-record add
                         Route-record log for IS-IS(1)
                          Level-1 add-route-record log
Index      Destination                     NextHop                        Flags
1          2.2.2.2                         Direct                         0x10c1
3          192.168.24.0                    Direct                         0x10c1
                          Level-2 add-route-record log
5          4.4.4.4                         192.168.24.4                   0x41
# Display brief log information about IPv4 route update.
<Sysname> display isis event-log route-record modify
                        Level-2 modify-route-record log
21         46.1.1.0                        192.168.24.10                  0x41
# Display brief log information about IPv4 route deletion.
<Sysname> display isis event-log route-record delete
                        Level-2 delete-route-record log
7          4.4.4.4                         192.168.24.4                   0x41
11         4.4.4.4                         192.168.24.4                   0x41
15         4.4.4.4                         192.168.24.4                   0x41
22         46.1.1.0                        192.168.24.10                  0x41
23         46.1.1.4                        192.168.24.10                  0x41
Table 13 Command output
Index
Index of the log message.
Destination
Destination address of the route.
NextHop
Next hop of the route.
Flags
Flags of the route.
# Display detailed log information about IPv4 route adding.
<Sysname> display isis event-log route-record add verbose
Destination: 192.168.24.0                  Index       : 72
Interface  : XGE3/0/1                      NextHop     : Direct
InLabel    : 4294967295                    InLabel Flag: -/-/-/-/-/-
Flags      : 0x10c1                        Cost        : 10
OutLabel   : 4294967295                    OutLabelFlag: -
Nib ID     : 0x14000000
Destination: 4.4.4.4                       Index       : 73
Interface  : Loop0                         NextHop     : Direct
Flags      : 0x10c1                        Cost        : 0
Nib ID     : 0x14000001
Destination: 192.168.46.0                  Index       : 78
Interface  : XGE3/0/2                      NextHop     : Direct
Nib ID     : 0x14000004
      InLabel flags: R-Readvertisement, N-Node SID, P-no PHP
                     E-Explicit null, V-Value, L-Local
      OutLabelFlags: E-Explicit null, I-Implicit null, N-Normal, P-SR label prefer
Destination: 2.2.2.2                       Index       : 76
Interface  : XGE3/0/1                      NextHop     : 192.168.24.2
InLabel    : 4294967295                    InLabel Flag: -/N/-/-/-/-
Flags      : 0x41                          Cost        : 10
Nib ID     : 0x14000002
# Display detailed log information about IPv4 route update.
<Sysname> display isis event-log route-record modify verbose
Destination: 46.1.1.0                      Index       : 21
Interface  : XGE3/0/1                      NextHop     : 192.168.24.10
Flags      : 0x41                          Cost        : 30
Nib ID     : 0x14000002
# Display detailed log information about IPv4 route deletion.
<Sysname> display isis event-log route-record delete verbose
                        Level-1 delete-route-record log
Destination: 4.4.4.4                       Index       : 66
Flags      : 0x41                          Cost        : 0
Nib ID     : 0x14000002
Destination: 192.168.24.0                  Index       : 67
Nib ID     : 0x14000001
Destination: 2.2.2.2                       Index       : 70
Nib ID     : 0x14000003
Table 14 Command output
Destination
Index
Output interface of the route.
NextHop
InLabel
Incoming label.
InLabel Flag
Incoming label flag:
·     R—Re-advertisement flag. This flag indicates that inter-level route propagation or route redistribution exists.
·     N—Node-SID flag. This flag indicates that the prefix SID is the SID to an SR node. If this flag is not set, the prefix SID is the SID to a group of SR nodes.
·     P—No-PHP flag. This flag indicates that the penultimate node cannot pop the prefix SID.
·     E—Explicit null flag. This flag indicates that the upstream neighbor must replace the prefix SID with an explicit null flag before forwarding the packets.
·     V—Value/Index flag. This flag indicates that the prefix SID is an absolute value. If this flag is not set, the prefix SID is an index value.
·     L—Local/global flag. This flag indicates that the prefix SID has local significance. If this flag is not set, the prefix SID has global significance.
Flags
Flags of the route.
Cost
Cost value of the route.
OutLabel
Outgoing label.
OutLabelFlag
Outgoing label flag:
·     E—Explicit null flag. This flag indicates that the upstream neighbor must replace the SID with an explicit null flag before forwarding the packets.
·     I—Implicit null flag. This flag indicates that the upstream neighbor must replace the SID with an implicit null flag before forwarding the packets. This flag is not supported in the current software version.
·     N—Normal flag. This flag indicates that the outgoing label is valid and is not an explicit null flag or implicit null flag.
·     PSR label preferred flag. This flag indicates that SR labels take precedence over LDP labels during packet forwarding.
Nib ID
ID assigned by the routing management module (next hop index).
# Display brief log information about IPv6 route adding.
<Sysname> display isis event-log route-record add ipv6
1          2000::                          Direct                         0x10c1
2          1001::                          Direct                         0x10c1
3          2002::                          Direct                         0x10c1
4          1000::                          FE80::2C31:6DFF:FE16:105       0x41
5          3012::                          FE80::2C31:6DFF:FE16:105       0x41
6          23::                            Direct                         0x10c1
8          23::                            FE80::2C31:6DFF:FE16:105       0x41
# Display brief log information about IPv6 route update.
<Sysname> display isis event-log route-record modify ipv6
15         2000::                          FE80::3851:D9FF:FE85:406       0x41
# Display brief log information about IPv6 route deletion.
<Sysname> display isis event-log route-record delete ipv6
12         66::66                          FE80::3851:E9FF:FE7A:605       0x41
20         66::66                          FE80::3A51:E97A:600:0          0x41
22         2000::                          ::                             0x41
25         2000::                          FE80::3851:E9FF:FE7A:605       0x41
14         10:1::                          FE80::3851:CEFF:FE23:206       0x41
Table 15 Command output
Index
Destination
NextHop
Flags
Flags of the route.
# Display detailed log information about IPv6 route adding.
<Sysname> display isis event-log route-record add ipv6 verbose
Destination: 10:1::                                        Index: 2
Interface  : NULL0                                          Cost: 0
NextHop    : Direct
Flags      : 0x10c1
Nib ID     : 0x24000000
Destination: 1::                                           Index: 4
Interface  : XGE3/0/1                                       Cost: 10
NextHop    : Direct
Flags      : 0x10c1
Nib ID     : 0x24000001
Destination: 2::9                                          Index: 7
NextHop    : FE80::3851:D9FF:FE85:406
Flags      : 0x41
Nib ID     : 0x24000002
Destination: 46::                                          Index: 9
Interface  : XGE3/0/1                                       Cost: 20
Flags      : 0x41
Nib ID     : 0x24000002
Destination: 66::66                                        Index: 10
Flags      : 0x41
Nib ID     : 0x24000002
Destination: 2000::                                        Index: 13
Flags      : 0x41
Nib ID     : 0x24000002
# Display detailed log information about IPv6 route update.
<Sysname> display isis event-log route-record modify ipv6 verbose
Destination: 2000::                                        Index: 15
Interface  : XGE3/0/1                                       Cost: 30
Flags      : 0x41
Nib ID     : 0x24000002
# Display detailed log information about IPv6 route deletion.
<Sysname> display isis event-log route-record delete ipv6 verbose
Destination: 66::66                                        Index: 12
Interface  : XGE3/0/2                                       Cost: 10
NextHop    : FE80::3851:E9FF:FE7A:605
Flags      : 0x41
Nib ID     : 0x24000005
Destination: 2000::                                        Index: 25
Interface  : XGE3/0/2                                       Cost: 20
Flags      : 0x41
Nib ID     : 0x24000006
Destination: 10:1::                                        Index: 14
NextHop    : FE80::3851:CEFF:FE23:206
Flags      : 0x41
Nib ID     : 0x24000002
Table 16 Command output
Destination
Index
Index of the route.
NextHop
Flags
Flags of the route.
Cost
Nib ID
reset isis event-log route-record
display isis event-log spf
Use display isis event-log spf to display IS-IS route calculation log information.
display isis event-log spf [ ipv4 | ipv6 ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv4: Displays IS-IS IPv4 route calculation log information.
ipv6: Displays IS-IS IPv6 route calculation log information.
level-1: Displays Level-1 route calculation log information.
level-2: Displays Level-2 route calculation log information.
verbose: Displays detailed route calculation log information. If you do not specify this keyword, the command displays brief route calculation log information.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays route calculation log information for all IS-IS processes.
If you specify neither the ipv4 nor ipv6 keyword, the command displays IS-IS IPv4 route calculation log information for the public network.
If you do not specify a level, the command displays both Level-1 and Level-2 route calculation log information.
# Display brief IS-IS route calculation log information.
<Sysname> display isis event-log spf
                              SPF Log for IS-IS(1)
                                Level-1 SPF Log
Date       Time     Duration   Count      Trigger event
2018-12-07 11:11:45 0.003      2          LDP label changed
2018-12-07 11:11:10 0          2          Remote LFA configuration changed
2018-12-07 11:10:45 0          4          Interface metric changed
2018-12-07 09:26:40 0          4          LSP updated
2018-12-07 09:26:28 0          2          DIS changed
2018-12-07 09:26:21 0.001      2          LSP updated
2018-12-07 09:26:07 0.001      3          Direct route changed
                                Level-2 SPF Log
2018-12-07 09:26:21 0          2          LSP updated
2018-12-07 09:26:07 0          3          Direct route changed
# Display detailed IS-IS route calculation log information.
<Sysname> display isis event-log spf verbose
                                Level-1 SPF Log
 Log date      : 2018-12-07 11:10:45
 Log key       : 5
 Trigger count : 4
 Trigger event : Interface metric changed
 SPF details   :
   Phase             Duration     Description
   TE tunnel ADJ     0            TE SPF nodes: 0
   Topology          0            SPF nodes: 3
   BSPF              0            Candidate NBRs: 1
   TI/R-LFA prepare  0            TI/R-LFA links: 0, TI/R-LFA nodes: 0
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   LFA               0            LFA SPF nodes: 1
   BIER topology     0
   Area              0            Area addresses: 1
   PRC               0            Add: 0 modify: 1 delete: 0
                                  Last 10 routes:
                                  1.1.1.0/24
   Route summary     0            Summary route nodes: 0
   Total             0
 Log date      : 2018-12-07 09:26:40
 Log key       : 4
 Trigger count : 4
 Trigger event : LSP updated
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   BIER topology     0
   PRC               0            Add: 0 modify: 0 delete: 0
   Total             0
 Log date      : 2018-12-07 09:26:28
 Log key       : 3
 Trigger count : 2
 Trigger event : DIS changed
 SPF details   :
   Topology          0            SPF links changed: 1
   BSPF              0            Candidate NBRs: 0
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   LFA               0            LFA SPF nodes: 0
   BIER topology     0
   Area              0            Area addresses: 0
   Total             0
 Log date      : 2018-12-07 09:26:21
 Log key       : 2
 Trigger count : 2
 SPF details   :
   Topology          0            SPF nodes: 0
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   BIER topology     0
   PRC               0.001        Add: 0 modify: 0 delete: 0
   Total             0.001
 Log date      : 2018-12-07 09:26:07
 Log key       : 1
 Trigger count : 3
 Trigger event : Direct route changed
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   BIER topology     0
   PRC               0.001        Add: 1 modify: 0 delete: 0
                               Last 10 routes:
                               1.1.1.0/24
   Total             0.001
                                Level-2 SPF Log
 Log key       : 5
 Trigger count : 4
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   BIER topology     0
   Total             0
 Log key       : 4
 Trigger count : 4
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   BIER topology     0
   Total             0
 Log key       : 3
 Trigger count : 2
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   BIER topology     0
   Total             0
 Log key       : 2
 Trigger count : 2
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   BIER topology     0
   Total             0
 Log key       : 1
 Trigger count : 3
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   BIER topology     0
   Total             0
Table 17 Command output
Date
Start date of route calculation.
Time
Start time of route calculation.
Duration
Route calculation duration in seconds. The value is accurate to six decimal places.
Count
Number of events that trigger the current route calculation.
Trigger event
Type of the most recent event that triggers route calculation:
·     NextHop changed.
·     DIS changed.
·     Interface metric changed.
·     SPF link changed.
·     Default route changed.
·     Summary route changed.
·     TE tunnel updated.
·     TE tunnel metric changed.
·     IPv6 mode changed.
·     FRR configuration changed.
·     Prefix priority configuration changed.
·     Route preference changed.
·     ISPF configuration changed.
·     Import filter policy changed.
·     ECMP configuration changed.
·     PIC configuration changed.
·     Interface LFA exclude changed.
·     ATT configuration changed.
·     GR/NSR first SPF.
·     GR over.
·     T3 timeout.
·     Direct route changed.
·     Logic interface changed.
·     Route leakage configuration changed.
·     NSR over.
·     Entered overload state.
·     Exited overload state.
·     Area address changed.
·     Route policy changed.
·     Redistributed route updated.
·     LSP updated.
·     MT disabled.
·     MT enabled.
·     TE tunnel configuration changed.
·     TE tunnel destination changed.
·     RIB smooth.
·     Remote LFA configuration changed.
·     LDP label changed.
Log date
Generation time of the route calculation logs.
Log key
Route calculation log key.
Trigger count
SPF details
Detailed information about the route calculation phases.
Phase
Route calculation phase:
·     TE tunnel ADJ—TE tunnel adjacency calculation.
·     Topology—Topology calculation.
·     BSPF—Backup SPF calculation.
·     TI/R-LFA prepare—TI-LFA/Remote LFA calculation preparation.
·     Link PSPF—SPF calculation after PSPF convergence for link protection.
·     Link PQ—P space and Q space calculation for link protection.
·     Node PSPF—SPF calculation after PSPF convergence for node protection.
·     Node PQ—P space and Q space calculation for node protection.
·     LFA—LFA calculation.
·     BIER topology—BIER topology calculation.
·     Area—Area calculation.
·     PRC—Prefix calculation.
·     Route summary—Route summarization calculation.
Route calculation phase description:
·     TE SPF nodes—Number of SPF nodes for TE tunnel adjacency calculation.
·     SPF nodes—Number of SPF nodes for topology calculation.
·     Candidate NBRs—Number of candidate neighbors.
·     TI/R-LFA links—Number of TI-LFA/remote LFA protected links.
·     TI/R-LFA nodes—Number of TI-LFA/remote LFA protected nodes.
·     LFA SPF nodes—Number of SPF nodes for LFA calculation.
·     Area addresses—Number of area addresses.
·     Add, modify, and delete—Prefix calculation summary.
·     Last 10 routes—10 routes that are most recently calculated.
·     Summary route nodes—Number of summarized routes.
Total
Total duration time of all route calculation phases.
# Display brief IPv6 IS-IS route calculation log information.
<Sysname> display isis event-log spf ipv6
                                Level-1 SPF Log
2015-09-07 11:10:45 0          4          Interface metric changed
2015-09-07 09:26:40 0          4          LSP updated
2015-09-07 09:26:28 0          2          DIS changed
2015-09-07 09:26:21 0.001     2          LSP updated
2015-09-07 09:26:07 0.001     3          Direct route changed
                                Level-2 SPF Log
2015-09-07 09:26:21 0          2          LSP updated
2015-09-07 09:26:07 0          3          Direct route changed
# Display detailed IPv6 IS-IS route calculation log information.
<Sysname> display isis event-log spf ipv6 verbose
                                Level-1 SPF Log
 Log date      : 2015-09-07 02:18:09
 Log key       : 10
 Trigger count : 2
 SPF details   :
   TI-LFA prepare    0            TI-LFA links: 0, TI-LFA nodes: 0
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
 Log key       : 9
 Trigger count : 2
 Trigger event : NextHop changed
 SPF details   :
   Topology          0.003        SPF nodes: 3
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0.003
 Log date      : 2011-01-01 02:17:40
 Log key       : 8
 Trigger count : 2
 Trigger event : Logic interface changed
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   PRC               0.005        Add: 1 modify: 0 delete: 0
                                  Last 10 routes:
                                  10::/64
   SAVNET            0
   Total             0.005
 Log date      : 2015-09-07 02:17:38
 Log key       : 7
 Trigger count : 1
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
 Log date      : 2015-09-07 02:17:33
 Log key       : 6
 Trigger count : 5
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   PRC               0.003        Add: 0 modify: 0 delete: 1
                                  Last 10 routes:
                                  3::/24
   SAVNET            0
   Total             0.003
 Log date      : 2015-09-07 02:17:21
 Log key       : 5
 Trigger count : 1
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   PRC               0.006        Add: 1 modify: 0 delete: 0
                                  Last 10 routes:
                                  3::/24
   SAVNET            0
   Total             0.006
 Log date      : 2015-09-07 02:17:11
 Log key       : 4
 Trigger count : 1
 Trigger event : IPv6 mode changed
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
 Log date      : 2015-09-07 01:09:33
 Log key       : 3
 Trigger count : 2
 SPF details   :
   Topology          0.001        SPF nodes: 3
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0.001
 Log date      : 2015-09-07 01:09:25
 Log key       : 2
 Trigger count : 2
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
 Log date      : 2015-09-07 01:08:49
 Log key       : 1
 Trigger count : 1
 Trigger event : Area address changed
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
                                Level-2 SPF Log
 Log key       : 10
 Trigger count : 2
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
 Log key       : 9
 Trigger count : 2
 SPF details   :
   Topology          0.002        SPF nodes: 3
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   Route summary     0.001        Summary route nodes: 0
   SAVNET            0
   Total             0.003
 Log date      : 2015-09-07 02:17:40
 Log key       : 8
 Trigger count : 2
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
 Log key       : 7
 Trigger count : 1
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
 Log key       : 6
 Trigger count : 5
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0.001
 Log key       : 5
 Trigger count : 1
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
 Log key       : 4
 Trigger count : 1
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0.001
 Log key       : 3
 Trigger count : 2
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
 Log key       : 2
 Trigger count : 2
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
 Log key       : 1
 Trigger count : 1
 SPF details   :
   Link PSPF         0
   Link PQ           0
   Node PSPF         0
   Node PQ           0
   SRLG Link PSPF    0
   SRLG Link PQ      0
   SRLG Node PSPF    0
   SRLG Node PQ      0
   BIER topology     0
   SAVNET            0
   Total             0
Table 18 Command output
Date
Time
Duration
Count
Trigger event
·     NextHop changed.
·     DIS changed.
·     SPF link changed.
·     GR/NSR first SPF.
·     GR over.
·     T3 timeout.
·     NSR over.
·     LSP updated.
·     MT disabled.
·     MT enabled.
·     RIB smooth.
Log date
Log key
Trigger count
SPF details
Phase
·     TI-LFA prepare—TI-LFA calculation preparation.
·     SRLG Link PSPF—SPF calculation after PSPF convergence for link protection, with the SRLG constraints taken into account.
·     SRLG Link PQ—P space and Q space calculation for link protection, with the SRLG constraints taken into account.
·     SRLG Node PSPF—SPF calculation after PSPF convergence for node protection, with the SRLG constraints taken into account.
·     SRLG Node PQ—P space and Q space calculation for node protection, with the SRLG constraints taken into account.
·     SAVNET—SAVNET calculation.
·     TI-LFA links—Number of TI-LFA protected links.
·     TI-LFA nodes—Number of TI-LFA protected nodes.
Total
reset isis event-log spf
display isis event-log updated-lsp
Use display isis event-log updated-lsp to display log information about LSP update.
display isis event-log updated-lsp [ history [ hour-range hour-range1 to hour-range2 ] ] [ system-id system-id ] [ level-1 | level-2 ] [ process-id ]
history: Displays LSP-update log information by log generation frequency. After the device starts running, the device records LSP-update log information every 15 minutes. This command displays LSP-update log information generated after the device starts running and before you use this command. If you do not specify this keyword, this command displays LSP-update log information by advertisement source.
hour-range hour-range1 to hour-range2: Displays LSP-update log information generated during the specified time range. The value range for the hour-range1 and hour-range2 arguments is 0 to 24 hours. If you do not specify this option, this command displays all existing LSP-update log information.
system-id system-id: Specifies an advertisement source by its system ID. A system ID is a hexadecimal string in xxxx.xxxx.xxxx format. If you do not specify any advertisement source, this command displays LSP-update log information for all advertisement sources.
level-1: Displays Level-1 LSP-update log information.
level-2: Displays Level-2 LSP-update log information.
process-id: Specifies an IS-IS process  by its ID. The value range for this argument is 1 to 65535. If you do not specify any IS-IS process, this command displays LSP-update log information for all IS-IS processes.
After the device starts running, it only records the most recent 24 hours' LSP-update log information.
If you do not specify the level-1 or level-2 keyword, this command displays both Level-1 and Level-2 LSP-update log information.
# Display LSP-update log information for IS-IS process 1 by advertisement source.
<Sysname> display isis event-log updated-lsp 1
                Updated LSP statistics information for IS-IS(1)
                               Level-1 statistics
System ID: 0000.0000.0001
              New             Old             Equal           Purge
Last hour    :11              22              33              11
Last 24 hours:311             322             333             131
System ID: 0000.0000.0002
              New             Old             Equal           Purge
System ID: 0000.0000.0003
              New             Old             Equal           Purge
System ID: 0000.0000.0004
              New             Old             Equal           Purge
                              Level-2 statistics
              New             Old             Equal           Purge
              New             Old             Equal           Purge
Last Hour    :11              22              33              11
Last 24 Hours:311             322             333             131
              New             Old             Equal           Purge
              New             Old             Equal           Purge
# Display LSP-update log information for IS-IS process 1 by log generation frequency.
<Sysname> display isis event-log updated-lsp history 1
                               Level-1 statistics
2022/01/18  07:15 - 07:30
   system ID          New          Old          Equal        Purge
   0000.0000.0001     10           20           14           6
   0000.0000.0002     10           20           14           6
   0000.0000.0003     10           20           14           6
   0000.0000.0004     10           20           14           6
   0000.0000.0005     10           20           14           6
   0000.0000.0006     10           20           14           6
   0000.0000.0007     10           20           14           6
2022/01/18  07:00 - 07:15
                               Level-2 statistics
2022/01/18  07:30 - 07:45
   0000.0000.2001     2            0            0            0
   0000.0000.4001     2            0            0            0
Table 19 Command output
System ID
System ID of the advertisement source.
Last hour
Number of LSP-update log messages generated during the last one hour.
Last 24 hours
Number of LSP-update log messages generated during the last 24 hours.
New
Number of received LSPs that were newer than those in the local LSDB.
Old
Number of received LSPs that were older than those in the local LSDB.
Equal
Number of received LSPs that were at the same age as those in the local LSDB.
Purge
Number of log messages generated for purge LSPs.
reset isis event-log updated-lsp
display isis flex-algo route
Use display isis flex-algo route to display information about routes calculated by a flexible algorithm.
display isis flex-algo flex-algo-id route [ level-1 | level-2 ] [ process-id ] [ verbose ]
flex-algo-id: Specifies a flexible algorithm by its ID. The value range for this argument is 128 to 255.
level-1: Specifies Level-1 routes.
level-2: Specifies Level-2 routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays routes calculated by the specified flexible algorithm for all IS-IS processes that use that flexible algorithm.
verbose: Displays detailed information about routes calculated by the specified flexible algorithm. If you do not specify this keyword, the command displays brief information about these routes.
If you do not specify the level-1 or level-2 keyword, the command displays information about Level-1 and Level-2 routes.
# Display brief information about routes calculated by flexible algorithm 255.
<Sysname> display isis flex-algo 255 route
                      Flex Algo Route Information for IS-IS(2)
                            Level-1 Flex Algo Route
 Destination : 1::                                     PrefixLen: 64
 Flag        : D/-/-                                   Cost     : 0
 Next hop    : Direct                                  Interface: NULL0
 Destination : 2000:2:2:1::                            PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 10
 Next hop    : FE80::2AFC:CEFF:FE65:206                Interface: XGE3/0/1
Table 20 Command output
Flexible algorithm route information for IS-IS process 2.
IS-IS Level-1 routing information.
Level-2 Flex Algo Route
IS-IS Level-2 routing information.
Destination
IPv6 destination prefix.
PrefixLen
Prefix length.
Flag
Route flag:
·     D—This is a direct route.
·     R—The route has been added into the routing table.
·     L—The route has been advertised in an LSP.
·     U—Route leaking flag, indicating that the Level-1 route is from Level-2. U means the route will not be returned to Level-2.
Cost
Route cost.
NextHop
Next hop. Direct means the route is directly connected.
Output interface.
# Display detailed information about routes calculated by flexible algorithm 255.
<Sysname> display isis flex-algo 255 route verbose
                   Flex Algo Route Information for IS-IS(10)
 IPv6 dest   : 1000:3:3:1::/64
 Admin tag   : -                           Src count   : 1
 Algorithm   : 255
 Priority    : Low
 Nexthop     : Direct
 NexthopFlag : -
 Interface   : NULL0                       Delay Flag : N/A
 Nib ID      : 0x0
 FirstFlushTime: N/A                       LatestUpdateTime: N/A
 IPv6 dest   : 2000:2:2:1::/64
 Algorithm   : 255
 Priority    : Low
 Nexthop     : FE80::2AFC:CEFF:FE65:206
 NexthopFlag : -
 Interface   : XGE3/0/1                       Delay Flag : N/A
 TI-LFA:
  BkNextHop : FE80::2ADF:D9FF:FEE3:707
  LsIndex    : 0x80000001
  Backup label stack(top->bottom): {4001::1:0:0}
 Nib ID      : 0x24000005
 FirstFlushTime: 00h00m09s                 LatestUpdateTime: 00h00m09s
Table 21 Command output
Flexible algorithm route information for IS-IS process 10.
IPv6 dest
IPv6 destination address and prefix.
Flag
Route flag:
·     D—The route is a direct route.
·     U—Route leaking flag, indicating the Level-1 route is from Level-2. U means the route will not be returned to Level-2.
Cost
Route cost.
Admin tag
Administrative tag.
Src count
Number of advertisement sources.
Algorithm
Flexible algorithm ID.
Priority
Route convergence priority. Options include critical, high, medium, and low.
Nexthop
NexthopFlag
Next hop flag. A value of D indicates that the next hop is directly connected to the advertisement source.
Output interface.
Delay Flag
Microloop avoidance delay flag:
·     D—Microloop avoidance is configured. Route convergence is delayed.
·     N/A—Microloop avoidance is not configured or the microloop avoidance RIB-update-delay timer has expired. Route convergence is in progress.
TI-LFA
TI-LFA backup information.
BKNextHop
Backup next hop.
LsIndex
Label stack index.
Backup Label stack(top->bottom)
Backup path label stack. N/A indicates that no label stack exists.
Nib ID
Next hop index assigned by the routing management module.
FirstFlushTime
Interval between the following timepoints:
·     When IS-IS installed the flex-algo route into the IP routing table for the first time.
·     When the display isis flex-algo route verbose command was executed.
The value of this field is in the format of hh:mm:ss. hh represents the hours, mm represents the minutes, and ss represents the seconds.
If the route is not flushed to the RIB, this field displays N/A.
LatestUpdateTime
·     When IS-IS updated the flex-algo route in the IP routing table most recently.
display isis flex-algo spf-tree
Use display isis flex-algo spf-tree to display information about the SPF tree calculated by a flexible algorithm.
display isis flex-algo flex-algo-id spf-tree { ipv4 | ipv6 } [ level-1 | level-2 ] [ source-id source-id ] [ verbose ]
ipv4: Specifies the IPv4 SPF tree.
ipv6: Specifies the IPv6 SPF tree.
level-1: Specifies the IS-IS Level-1 SPF tree.
level-2: Specifies the IS-IS Level-2 SPF tree.
source-id source-id: Specifies an advertisement source by its system ID in the format of XXXX.XXXX.XXXX.XX. If you do not specify this option, the command displays information about the SPF trees calculated on all advertisement sources.
verbose: Displays detailed SPF tree information.
If you do not specify the level-1 keyword or the level-2 keyword, the command displays information about the Level-1 and Level-2 SPF trees.
# Display information about the IPv4 SPF tree calculated by flexible algorithm 255.
<Sysname> display isis flex-algo 255 spf-tree ipv4
                     Flex Algo SPF Information for IS-IS(2)
                             Level-2 Flex Algo SPF
PostNode                   Cost       NextHopCnt     ChildLink
0000.0000.0001.00          20         1
                                                     -->0000.0000.0008.01
0000.0000.0003.00          10         1
                                                     -->0000.0000.0001.00
0000.0000.0008.00          0          0
                                                     -->0000.0000.0008.02
0000.0000.0008.01          30         1
0000.0000.0008.02          10         0
                                                     -->0000.0000.0003.00
Table 22 Command output
Flex Algo SPF Information for IS-IS(xx)
Information about the SPF tree calculated by a flexible algorithm in an IS-IS process. The xx argument represents the process ID.
Level-1 Flex Algo SPF
Level-1 SPF tree information.
Level-2 SPF tree information.
PostNode
Node ID.
Cost
Routing cost.
NextHopCnt
Number of next hops.
# Display detailed information about the IPv6 SPF tree calculated by flexible algorithm 130.
<Sysname> display isis flex-algo 130 spf-tree ipv6 verbose
                    Flex Algo SPF Information for IS-IS(10)
 SpfNode        : 0000.0000.0004.01
 Distance       : 20
 TEDistance     : 0
 DelayDistance  : 0
 Metric Type    : IGP
 Nexthop count  : 1
     Neighbor   : 0000.0000.0004.00        Interface  : XGE3/0/4
     Nexthop    : FE80::2ADF:E0FF:FEA1:809
     BkNeighbor : N/A                      BkInterface: N/A
     BkNexthop  : N/A
 SpfNode        : 0000.0000.0003.02
 Distance       : 20
 TEDistance     : 0
 DelayDistance  : 0
 Metric Type    : IGP
 Nexthop count  : 1
     Neighbor   : 0000.0000.0002.00        Interface  : XGE3/0/1
     Nexthop    : FE80::2ADF:D3FF:FE2D:606
     BkNexthop  : N/A
 SpfNode        : 0000.0000.0001.00
 Distance       : 0
 TEDistance     : 0
 DelayDistance  : 0
 Metric Type    : IGP
 Nexthop count  : 0
 SpfNode        : 0000.0000.0002.00
 Distance       : 10
 TEDistance     : 0
 DelayDistance  : 0
 Metric Type    : IGP
 Nexthop count  : 1
     BkNexthop  : N/A
 TI-LFA         :
  TiLfaNeighbor : 0000.0000.0004.00        TiLfaInterface: XGE3/0/4
  TiLfaNexthop  : FE80::2ADF:E0FF:FEA1:809
  PNode SrcID   : 0000.0000.0003.00        QNode SrcID   : 0000.0000.0003.00
  PNode prefix  : N/A                      PNode SidIndex: 3001::1:0:0
  Protect       : Link
  Label stack   : {3001::1:0:0}
 SpfNode        : 0000.0000.0004.00
 Distance       : 10
 TEDistance     : 0
 DelayDistance  : 0
 Metric Type    : IGP
 Nexthop count  : 1
     BkNexthop  : N/A
 TI-LFA         :
  TiLfaNeighbor : 0000.0000.0002.00        TiLfaInterface: XGE3/0/1
  TiLfaNexthop  : FE80::2ADF:D3FF:FE2D:606
  Protect       : Link
 SpfNode        : 0000.0000.0003.00
 Distance       : 20
 TEDistance     : 0
 DelayDistance  : 0
 Metric Type    : IGP
 Nexthop count  : 2
     BkNexthop  : N/A
     BkNexthop  : N/A
 SpfNode        : 0000.0000.0004.02
 Distance       : 10
 TEDistance     : 0
 DelayDistance  : 0
 Metric Type    : IGP
 Nexthop count  : 0
Table 23 Command output
SpfNode
ID of the topology node.
Distance
·     If the flexible algorithm uses IGP metric, this field displays the shortest distance from the root node to the local node.
·     If the flexible algorithm does not use IGP metric, this field displays 0.
TEDistance
·     If the flexible algorithm uses TE metric, this field displays the shortest distance from the root node to the local node.
·     If the flexible algorithm does not use TE metric, this field displays 0.
DelayDistance
·     If the flexible algorithm uses delay metric, this field displays the shortest distance from the root node to the local node.
·     If the flexible algorithm does not use delay metric, this field displays 0.
Metric Type
Metric type of the flexible algorithm. Options include IGP, link delay and TE cost.
Nexthop count
Neighbor
System ID of the neighbor node that is the primary next hop of the node.
Primary output interface of the node.
Nexthop
Output interface of the primary next hop.
MADuration
Flex-Algo SR microloop avoidance duration, in milliseconds.
MALStack
Flex-Algo SR microloop avoidance label stack.
BkNeighbor
System ID of the neighbor node that is the backup next hop of the node.
BkInterface
Output interface of the backup next hop.
BkNexthop
Backup next hop of the node.
TI-LFA
TI-LFA information:
·     TiLfaNeighbor—ID of the TI-LFA backup next hop neighbor.
·     TiLfaInterface—Output interface of the TI-LFA backup next hop.
·     TiLfaNexthop—TI-LFA backup next hop.
·     PNode SrcID—Source ID of the P node.
·     QNode SrcID—Source ID of the Q node.
·     PNode prefix—Prefix of the P node. N/A indicates that the destination node is in the P space.
·     PNode SidIndex—End SID of the P node. N/A indicates that the destination node is in the P space.
·     Protect—TI-LFA traffic protection type:
¡     Link—Link protection.
¡     Node—Node protection.
·     Label stack—Label stack. N/A indicates that no label stack exists.
display isis frr summary
Use display isis frr summary to display the FRR protection rate for the routes in an IS-IS process.
display isis frr summary [ ipv4 | ipv6 ] [ level-1 | level-2 ] [ process-id ]
ipv4: Displays the FRR protection rate for IPv4 routes.
ipv6: Displays the FRR protection rate for IPv6 routes.
level-1: Displays the FRR protection rate for Level-1 routes.
level-2: Displays the FRR protection rate for Level-2 routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information for all IS-IS processes.
After configuring IS-IS FRR, you can use this command to display the FRR protection rates for routes with different convergence priorities. The calculation formula for FRR protection rate is: Coverage = Protected prefix counts ÷ All reachable prefix counts × 100%.
If you do not specify the ipv4 or ipv6 keyword, the command displays IPv4 FRR protection rate.
If you do not specify a level, the command displays both Level-1 and Level-2 FRR protection rates.
# Display the FRR protection rate for IPv4 routes in IS-IS process 1.
<Sysname> display isis frr summary
                            Frr summary for IS-IS(1)
                            Level-1 IPv4 Frr summary
 Priority:                      Critical        High            Medium          Low
 All reachable prefix counts:   0               0               0               10
 Protected prefix counts:       0               0               0               3
 Coverage:                      0%              0%              0%              30%
                            Level-2 IPv6 Frr summary
 Protected prefix counts:       0               0               0               0
 Coverage:                      0%              0%              0%              0%
# Display the FRR protection rate for IPv6 routes in IS-IS process 1.
<Sysname>  display isis frr summary ipv6
                            Level-1 IPv6 Frr summary
Table 24 Command output
Priority
Route convergence priority:
·     Critical.
·     High.
·     Medium.
·     Low.
Number of routes with each convergence priority.
Number of protected routes.
Coverage
FRR protection rate for routes with each convergence priority. Coverage = Protected prefix counts/All reachable prefix counts × 100%.
display isis global-flex-algo
Use display isis global-flex-algo to display information about the FADs received or advertised by a node.
display isis global-flex-algo [ algorithm-id flex-algo-id ] [ level-1 | level-2 ] [ process-id ] [ system-id system-id ]
algorithm-id flex-algo-id: Specifies a flexible algorithm by its ID. The value range for this argument is 128 to 255. If you do not specify this option, this command displays FAD information received or advertised by the node for all flexible algorithms.
level-1: Specifies Level-1 areas.
level-2: Specifies the Level-2 area.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays FAD information for all IS-IS processes on the node.
system-id system-id: Specifies an FAD advertisement source by its system ID. If you do not specify this option, the command displays information about the FADs advertised by all sources.
If you do not specify the level-1 keyword or the level-2 keyword, the command displays the Level-1 and Level-2 FADs received or advertised by the node.
If you do not specify any keywords, the command displays the FADs received or advertised by the node.
# Display the Level-1 FADs received or advertised by the node.
<Sysname> display isis global-flex-algo level-1
            Segment routing IPv6 Flex-Algo Information for IS-IS(1)
                         Level-2 Flex-Algo Information
   Algorithm 128
         MetricType : IGP
         Flex-Algo Exclude Any Ext Admin Group:
             N/A
         Flex-Algo Include Any Ext Admin Group:
             N/A
         Flex-Algo Include All Ext Admin Group:
             N/A
         Flex-Algo Exclude SRLG:
             N/A
   SrcCount  1
         SrcInfo:
             SourceID    : 0000.0000.2001.00
             Priority    : 255
             MetricType  : IGP
                 LSPInfo
                 LSPID       0000.0000.2001.00-00
                 Priority    255
                 MetricType  IGP
Table 25 Command output
Segment routing IPv6 Flex-Algo Information for IS-IS(xx)
SRv6 flexible algorithm information for an IS-IS process. The xx argument represents the process ID.
Level-1 Flex-Algo Information
IS-IS Level-1 flexible algorithm information.
IS-IS Level-2 flexible algorithm information.
Algorithm xx
Information about flexible algorithm xx.
MetricType
Metric type of the flexible algorithm. Options include IGP, delay, and TE cost.
The exclude-any constraint in the FAD. N/A indicates that no exclude-any constraint is set.
The include-any constraint in the FAD. N/A indicates that no include-any constraint is set.
The include-all constraint in the FAD. N/A indicates that no include-all constraint is set.
SRLG links excluded by the flexible algorithm. If no exclude SRLG constraints are configured, this field displays N/A.
SrcCount
SrcInfo
Advertisement source information:
·     SourceID—System ID.
·     Priority—Flexible algorithm priority.
·     MetricType—Metric type of the flexible algorithm. Options include IGP, delay, and TE cost.
LSPInfo
LSP advertised by the source:
·     LSPID—LSP ID.
·     Priority—Priority of the flexible algorithm in the LSP.
·     MetricType—Metric type of the flexible algorithm in the LSP. Options include IGP, delay, and TE cost.
display isis global-statistics
Use display isis global-statistics to display global IS-IS statistics.
display isis global-statistics [ public | vpn-instance vpn-instance-name ]
public: Specifies the public network.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
If you do not specify any keywords, the command displays global IS-IS statistics for the public network and all VPN instances.
# Display global IS-IS statistics.
<Sysname> display isis global-statistics
  IS-IS global statistics
  Instance count:     2  Process count:     2
  Interface information:
    Type            IPv4 up/down           IPv6 up/down
    LAN                   0/0                    0/0
    P2P                   1/0                    0/0
  Peer information:
    Type              IPv4 Up/Init              IPv6 Up/Init
    LAN Level-1             0/0                       0/0
    LAN Level-2             0/0                       0/0
    P2P                     1/0                       0/0
  Packet information:
    Total output packets: 1022
    Total input packets:  1023
  LSP information:
    Total level-1 LSPs: 2
    Total level-2 LSPs: 2
  Route information:
    Type         IPv4         IPv6
    Level-1      1            0
    Level-2      2            0
Table 26 Command output
Interface status statistics.
Interface link adjacency type.
IPv4 up/down
Number of IPv4 interfaces in up or down state.
IPv6 up/down
Number of IPv6 interfaces in up or down state.
Neighbor type:
·     LAN Level-1—Number of Level-1 neighbors with the broadcast network type.
·     LAN Level-2—Number of Level-2 neighbors with the broadcast network type.
·     P2P—Number of neighbors with the point-to-point (P2P) network type.
IPv4 Up
Number of IPv4 neighbors in up state.
IPv4 Init
Number of IPv4 neighbors in init state.
IPv6 Up
Number of IPv6 neighbors in up state.
IPv6 Init
Number of IPv6 neighbors in init state.
Packet information
Statistics of received and sent protocol packets.
Number of sent protocol packets.
Total input packets
Number of received protocol packets.
LSP information
Number of LSPs in the LSDB.
Total level-1 LSPs
Number of Level-1 LSPs.
Total level-2 LSPs
Number of Level-2 LSPs.
Route Information
Route statistics:
·     Level-1—Level-1 IS-IS route statistics.
·     Level-2—Level-2 IS-IS route statistics.
·     IPv4—IPv4 IS-IS route statistics.
·     IPv6—IPv6 IS-IS route statistics.
display isis graceful-restart status
Use display isis graceful-restart status to display IS-IS GR state.
display isis graceful-restart status [ level-1 | level-2 ] [ process-id ]
level-1: Displays the IS-IS Level-1 GR state.
level-2: Displays the IS-IS Level-2 GR state.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays GR state of all IS-IS processes.
# Display IS-IS GR state.
<Sysname> display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
                          Level-1 restart information
Total number of interfaces: 1
Number of waiting LSPs: 0
                          Level-2 restart information
Table 27 Command output
Restart status
Current GR state:
·     RESTARTING—In this state, forwarding can be ensured.
·     STARTING—In this state, forwarding cannot be ensured.
·     COMPLETE—GR is completed.
Restart phase
Current Restart phase:
·     Initialization.
·     TE tunnel prepare.
·     Redistribution.
·     LSP generation.
·     Finish.
Restart t1
T1 timer, in seconds.
count
Number of T1 timer expirations.
Restart t2
T2 timer, in seconds.
Restart t3
T3 timer, in seconds.
SA Bit
Whether SA is supported.
Total number of IS-IS interfaces.
Number of LSPs not obtained by the GR restarter from GR helpers during LSDB synchronization.
display isis interface
Use display isis interface to display IS-IS interface information.
display isis interface [ [ interface-type interface-number ] [ verbose ] | statistics ] [ process-id ]
interface-type interface-number: Displays information for a specified IS-IS interface. If you do not specify this argument, the command displays information about all interfaces.
verbose: Displays detailed information about an interface. If you do not specify this keyword, the command displays brief information about an interface.
statistics: Displays IS-IS interface statistics.
process-id: Displays IS-IS interface information for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays interface information for all IS-IS processes.
# Display brief IS-IS interface information.
<Sysname> display isis interface
  Interface:  Ten-GigabitEthernet3/0/2
  Index     IPv4 state      IPv6 state     Circuit ID   MTU   Type   DIS
  00001     Up              Down           1            1497  L1/L2  No/No
# Display detailed IS-IS interface information.
<Sysname> display isis interface verbose
  SNPA address                     : 000c-29e8-1bd5
  IP address                       : 192.168.220.10
  Secondary IP address(es)         :
  IPv6 link-local address          :
  Extended circuit ID              : 1
  CSNP timer value                 : L1        10  L2        10
  Hello timer value                :           10
  Hello multiplier value           :            3
  LSP timer value                  : L12       33
  LSP transmit-throttle count      : L12        5
  Cost                             : L1       100  L2       100
  Cost source                      : L1   Default  L2   Default
  IPv6 cost                        : L1        10  L2        10
  IPv6 cost source                 : L1   Default  L2   Default
  Priority                         : L1        64  L2        64
  Retransmit timer value           : L12        5
  LDP state                        : L1      Init  L2    No-LDP
  LDP sync state                   : L1      Init  L2  Achieved
  MPLS TE status                   : L1  Disabled  L2  Disabled
  Link quality                     : GOOD
  Cost adjusted at low quality     : 50
  IPv4 BFD                         : Disabled
  IPv6 BFD                         : Disabled
  IPv4 BFD session-restrict-adj    : Enabled
  IPv6 BFD session-restrict-adj    : Disabled
  IPv4 BFD template                : TEMP1
  IPv6 BFD template                : TEMP2
  IPv4 FRR LFA backup              : L1   Enabled  L2   Enabled
  IPv6 FRR LFA backup              : L1   Enabled  L2   Enabled
  IPv4 FRR TI-LFA                  : L1   Enabled  L2   Enabled
  IPv6 FRR TI-LFA                  : L1   Enabled  L2   Enabled
  IPv4 FRR remote-LFA              : L1   Enabled  L2   Enabled
  IPv4 prefix-suppression          : Disabled
  IPv6 prefix-suppression          : Disabled
  IPv4 tag                         : 1
  IPv6 tag                         : 4294967295
  IPv6 link tag                    : 100
  IPv4 BFD adjust cost             : Maximum
  IPv6 BFD adjust cost             : Maximum
  IPv4 BFD suppress flapping       : Detect interval 60s
                                     Threshold 10
                                     Resume interval 10s (remain 6s)
  IPv6 BFD suppress flapping       : Detect interval 60s
                                     Threshold 10
  IPv4 peer suppress flapping      : Adjust cost Maximum
                                     Mode conservative
                                     Detect interval 60s
                                     Threshold 10
                                     Resume interval 120s
  IPv6 peer suppress flapping      : Adjust cost Maximum
                                     Mode conservative
                                     Detect interval 60s
                                     Threshold 10
  IPv4 primary path detection mode : BFD ctrl
  IPv6 primary path detection mode : BFD ctrl
  Average delay                    : 1000 us
  Min delay                        : 10 us
  Max delay                        : 500 us
  Delay variation                  : 200 us
  Link loss                        : 0.002997%
  Te-Metric FlexAlgo               : 100
  IPv4 Metric-delay normalize
    Interval                       : 0 ms
    Offset                         : 0 ms
  IPv6 Metric-delay normalize
    Interval                       : 0 ms
    Offset                         : 0 ms
# Display detailed information about interfaces enabled with SR.
  Interface:  LoopBack1
  00003     Up              Down           1            1536  L1/L2  --
  SNPA address                     : 0000-0000-0000
  IP address                       : 111.111.111.111
  Secondary IP addresses         :
  Extended circuit ID              : 3
  Cost                             : L1         0  L2         0
  IPv6 cost                        : L1         0  L2         0
  Link quality                     : GOOD
  IPv4 BFD                         : Disabled
  IPv6 BFD                         : Disabled
  IPv4 prefix suppression          : Disabled
  IPv6 prefix suppression          : Disabled
  IPv4 tag                         : 0
  IPv6 tag                         : 0
                                     Threshold 10
                                     Resume interval 10s
                                     Threshold 10
                                     Resume interval 10s
                                     Mode conservative
                                     Detect interval 60s
                                     Threshold 10
                                     Mode conservative
                                     Detect interval 60s
                                     Threshold 10
  IPv4 primary path detection mode : Disabled
  IPv6 primary path detection mode : Disabled
  Prefix-SID type                  : Index
  Value                            : 2
  Prefix-SID validity              : Valid
  Static adjacency SID             :
    Nexthop          Adjacency-SID     Type      Result
    100.100.100.100  15555             Absolute  Succeeded
    8.8.8.8          1000              Index     Conflicting
  Average delay                    : 4294967295 us
  Min delay                        : 4294967295 us
  Max delay                        : 4294967295 us
  Delay variation                  : 4294967295 us
    Interval                       : 0 ms
    Offset                         : 0 ms
    Interval                       : 0 ms
    Offset                         : 0 ms
Table 28 Command output
Interface type and number.
Index
Interface index.
IPv4 state
IPv4 state.
·     Up—The interface is up at both the link layer and network layer.
·     Down—The interface is down at the link layer and network layer.
·     Lnk:Up/IP:Dn—The interface is up at the link layer but is down at the network layer.
IPv6 state
IPv6 state.
CircuitID
Circuit ID.
·     0(Invalid)IS-IS is not successfully enabled on the broadcast interface.
·     1—IS-IS is successfully enabled on the broadcast interface.
MTU
Interface MTU.
DIS
Indicates whether the interface is elected as the Level-1/Level-2 DIS. On a P2P network, this field displays a hyphen (-) because DIS election is not performed.
SNPA address
Subnet access point address.
IP address
Primary IP address.
Secondary IP addresses.
IPv6 link local address.
Extended circuit ID
Extended circuit ID for a P2P link.
CSNP timer value
Interval for sending CSNP packets.
Hello timer value
Interval for sending Hello packets.
Number of invalid Hello packets.
LSP timer value
Minimum interval for sending LSP packets.
Number of LSP packets sent each time.
Cost
Cost of the interface.
Cost source
Link cost source of the interface:
·     Default—Default link cost.
·     Global—Global link cost.
·     Auto—Automatically calculated link cost.
·     Manual—Manually specified link cost.
·     IGP_LDP—Link cost advertised by LDP IGP.
·     LOW—Link cost applied when the link quality of the interface becomes LOW.
·     Fallback—Link cost applied when the bandwidth of the Layer 3 aggregate interface falls below the threshold.
·     LinkUp—Maximum link cost advertised to neighbors during the specified time period.
·     BFD—Link cost applied when the BFD session goes down.
·     SuppFlap—Link cost applied when IS-IS suppresses neighbor flapping.
·     LinkDown—Link cost applied when IS-IS suppresses member port flapping for the aggregate interface.
IPv6 cost
IPv6 link cost of the interface.
IPv6 cost source
IPv6 link cost source of the interface:
·     BFD—Link cost applied when the IPv6 BFD session goes down.
Priority
DIS priority.
Retransmission interval for LSPs on a P2P link.
MPLS TE status
MPLS TE status: Enabled or Disabled.
Link quality
Link quality:
·     GOOD—The bit error ratio is below the upper threshold or drops below the lower threshold.
·     LOW—The bit error ratio exceeds the upper threshold.
This field is displayed only when the interface is configured with the isis link-quality adjust-cost command.
Interface cost adjustment parameters:
·     xx—Value added to the interface cost. When the link quality is LOW, the interface cost is xx plus the original interface cost.
·     Maximum—Sets the interface cost to the maximum when the link quality is LOW.
LDP state
LDP state:
·     Init—LDP is not reported.
·     No-LDP—LDP is not configured.
·     Not ready—LDP session is not established.
·     Ready—LDP session is established.
LDP sync state
LDP synchronization state:
·     Init—Initialized.
·     Achieved—Synchronized.
·     Max cost—Maintain the maximum cost.
IPv4 BFD
Whether BFD for IS-IS is enabled:
·     Disabled.
·     Enabled.
·     Enabled, inherited—BFD is enabled on the IS-IS interface. The inherited attribute indicates that the interface inherits the global configuration of this feature from the IPv4 IS-IS process to which the interface belongs.
·     ExcludedThe BFD capacity of the IS-IS interface is suppressed by the isis bfd exclude command.
IPv6 BFD
Whether BFD for IPv6 IS-IS is enabled:
·     Disabled.
·     Enabled.
·     Enabled, inheritedBFD is enabled on the IS-IS interface. The inherited attribute indicates that the interface inherits the global configuration of this feature from the IPv6 IS-IS process to which the interface belongs.
·     Excluded—The BFD capacity of the IS-IS interface is suppressed by the isis ipv6 bfd exclude command.
Whether IPv4 adjacency establishment and maintenance control based on BFD session state is enabled:
·     Disabled.
·     Enabled.
·     Enabled, inherited—BFD session state-based control of adjacency establishment and maintenance is enabled on the interface. The inherited attribute indicates that the interface inherits the global configuration of this feature from the IPv4 IS-IS process to which the interface belongs.
·     Excluded—BFD session state-based control of adjacency establishment and maintenance is suppressed on the interface by the isis bfd session-restrict-adj exclude command.
Whether IPv6 adjacency establishment and maintenance control based on BFD session state is enabled:
·     Disabled.
·     Enabled.
·     Enabled, inherited—BFD session state-based control of adjacency establishment and maintenance is enabled on the interface. The inherited attribute indicates that the interface inherits the global configuration of this feature from the IPv6 IS-IS process to which the interface belongs.
·     ExcludedBFD session state-based control of adjacency establishment and maintenance is suppressed on the interface by the isis ipv6 bfd session-restrict-adj exclude command.
IPv4 BFD template
BFD template applied to the IPv4 IS-IS interface. If no BFD template is applied to the interface, this field displays the BFD template applied to the IS-IS process in IPv4 address family view. If no BFD template is applied either to the interface or to the process, this field is not displayed.
IPv6 BFD template
BFD template applied to the IPv6 IS-IS interface. If no BFD template is applied to the interface, this field displays the BFD template applied to the IS-IS process in IPv6 address family view. If no BFD template is applied either to the interface or to the process, this field is not displayed.
IPv4 FRR LFA backup
Whether LFA calculation is enabled for IPv4 FRR:
·     Disabled.
·     Enabled.
IPv6 FRR LFA backup
Whether LFA calculation is enabled for IPv6 FRR:
·     Disabled.
·     Enabled.
IPv4 FRR TI-LFA
IPv4 TI-LFA calculation status:
·     Disabled.
·     Enabled.
IPv6 FRR TI-LFA
IPv6 TI-LFA calculation status:
·     Disabled.
·     Enabled.
IPv4 FRR remote-LFA
IPv4 remote LFA calculation status:
·     Disabled.
·     Enabled.
Whether IPv4 IS-IS prefix suppression is enabled:
·     Disabled.
·     Enabled.
Whether IPv6 IS-IS prefix suppression is enabled:
·     Disabled.
·     Enabled.
IPv4 tag
IPv4 tag value of the interface.
IPv6 tag
IPv6 tag value of the interface.
IPv6 link tag
IPv6 IS-IS link tag of the interface.
Whether BFD session state-based interface cost adjustment is enabled on the IPv4 IS-IS interface:
·     Disabled.
·     cost-offsetInterface cost adjustment value. The value range for cost-offset is 1 to 16777213. When the BFD session goes down, the interface cost is cost-offset plus the original interface cost.
·     cost-offset, inherited—Interface cost adjustment value. The value range for cost-offset is 1 to 16777213. The inherited attribute indicates that the interface inherits the global configuration of cost-offset from the IPv4 IS-IS process to which the interface belongs.
·     MaximumMaximum interface cost value (16777214). When the BFD session goes down, IS-IS will adjust the interface cost to the maximum.
·     Maximum, inherited—Maximum interface cost value (16777214). When the BFD session goes down, IS-IS will adjust the interface cost to the maximum. The inherited attribute indicates that the interface inherits this configuration from the IPv4 IS-IS process to which the interface belongs.
·     Excluded—BFD session state-based interface cost adjustment is suppressed on the interface by the isis bfd adjust-cost exclude command.
Whether BFD session state-based interface cost adjustment is enabled on the IPv6 IS-IS interface:
·     Disabled.
·     cost-offset—Interface cost adjustment value. The value range for cost-offset is 1 to 16777213. When the BFD session goes down, the interface cost is cost-offset plus the original interface cost.
·     cost-offset, inherited—Interface cost adjustment value. The value range for cost-offset is 1 to 16777213. The inherited attribute indicates that the interface inherits the global configuration of cost-offset from the IPv6 IS-IS process to which the interface belongs.
·     Maximum—Maximum interface cost value (16777214). When the BFD session goes down, IS-IS will adjust the interface cost to the maximum.
·     Maximum, inherited—Maximum interface cost value (16777214). When the BFD session goes down, IS-IS will adjust the interface cost to the maximum. The inherited attribute indicates that the interface inherits this configuration from the IPv6 IS-IS process to which the interface belongs.
·     Excluded—BFD session state-based interface cost adjustment is suppressed on the interface by the isis ipv6 bfd adjust-cost exclude command.
When the BFD session flaps, BFD session state-based interface cost adjustment is suppressed for IPv4 IS-IS.
·     Detect intervalTimer for BFD session state detection, in seconds.
·     Threshold—Number of BFD session down events that triggers an interface cost adjustment. The number of BFD session down events is also displayed in the BFD down times field if it is smaller than the threshold within the detection timer.
·     Resume intervalResume timer that IPv4 IS-IS must wait before restoring the interface cost to the original, in seconds. The remain field displays the remaining time of the timer.
When the BFD session flaps, BFD session state-based interface cost adjustment is suppressed for IPv6 IS-IS.
·     Detect interval—Timer for BFD session state detection, in seconds.
·     Resume interval—Resume timer that IPv6 IS-IS must wait before restoring the interface cost to the original, in seconds. The remain field displays the remaining time of the timer.
Configuration of IPv4 IS-IS neighbor flapping suppression and configuration of IPv4 IS-IS interface cost adjustment:
·     Disabled—Neighbor flapping suppression is disabled for IPv4 IS-IS.
·     Adjust cost xx—Interface cost adjustment value. The value range for the xx argument is 1 to 16777213. When IPv4 IS-IS suppresses neighbor flapping, it will adjust the interface cost to xx plus the original interface cost.
·     Adjust cost Maximum—When IPv4 IS-IS suppresses neighbor flapping, it will adjust the interface cost to the maximum (16777214).
·     Detect interval—Neighbor flapping detection timer, in seconds.
·     Threshold—Number of neighbor flapping events that triggers neighbor flapping suppression. The down times field displays the number of neighbor down events that occur within the detection timer.
·     Resume interval—Resume timer that IPv4 IS-IS must wait before recovering the interface cost, in seconds. The remain field displays the remaining time of the timer.
Configuration of IPv6 IS-IS neighbor flapping suppression and configuration of IPv6 IS-IS interface cost adjustment:
·     Disabled—Neighbor flapping suppression is disabled for IPv6 IS-IS.
·     Adjust cost xx—Interface cost adjustment value. The value range for the xx argument is 1 to 16777213. When IPv6 IS-IS suppresses neighbor flapping, it will adjust the interface cost to xx plus the original interface cost.
·     Adjust cost Maximum—When IPv6 IS-IS suppresses neighbor flapping, it will adjust the interface cost to the maximum (16777214).
·     Resume interval—Resume timer that IPv6 IS-IS must wait before recovering the interface cost, in seconds. The remain field displays the remaining time of the timer.
IPv4 member-port suppress flapping
Interface cost adjustment configuration that takes effect when IPv4 IS-IS suppresses member port flapping for the Layer 3 aggregate interface:
·     Adjust cost xx—Adjustment value for the aggregate interface cost. The value range for the xx argument is 1 to 16777213. When IPv4 IS-IS suppresses member port flapping for the aggregate interface, it will adjust the aggregate interface cost to xx plus the original interface cost.
·     Adjust cost Maximum—When IPv4 IS-IS suppresses member port flapping for the aggregate interface, it will adjust the aggregate interface cost to the maximum (16777214).
·     Detect intervalTimer for member port flapping detection, in seconds.
·     Threshold—Number of member port flapping events that triggers member port flapping suppression. The down times field displays the number of link failures that occur within the detection timer.
·     Resume interval—Resume timer that IPv4 IS-IS must wait before restoring the aggregate interface cost, in seconds. The remain field displays the remaining time of the timer.
IPv6 member-port suppress flapping
Interface cost adjustment configuration that takes effect when IPv6 IS-IS suppresses member port flapping for the Layer 3 aggregate interface:
·     Adjust cost xx—Adjustment value for the aggregate interface cost. The value range for the xx argument is 1 to 16777213. When IPv6 IS-IS suppresses member port flapping for the aggregate interface, it will adjust the aggregate interface cost to xx plus the original interface cost.
·     Adjust cost Maximum—When IPv6 IS-IS suppresses member port flapping for the aggregate interface, it will adjust the aggregate interface cost to the maximum (16777214).
·     Detect interval—Timer for member port flapping detection, in seconds.
·     Resume interval—Resume timer that IPv6 IS-IS must wait before restoring the aggregate interface cost, in seconds. The remain field displays the remaining time of the timer.
IPv4 primary path detection mode:
·     BFD ctrl—BFD control packet mode.
·     BFD ctrl, inherited—BFD control packet mode. The inherited attribute indicates that the interface inherits this configuration from the IPv4 IS-IS process to which the interface belongs.
·     BFD echo—BFD echo packet mode.
·     BFD echo, inherited—BFD echo packet mode. The inherited attribute indicates that the interface inherits this configuration from the IPv4 IS-IS process to which the interface belongs.
·     DisabledThe IS-IS interface does not use BFD for primary link failure detection.
·     Excluded—The IS-IS interface is disabled from using BFD for primary link failure detection by the isis primary-path-detect bfd exclude command.
IPv6 primary path detection mode:
·     BFD ctrl, inherited—BFD control packet mode. The inherited attribute indicates that the interface inherits this configuration from the IPv6 IS-IS process to which the interface belongs.
·     BFD echo, inherited—BFD echo packet mode. The inherited attribute indicates that the interface inherits this configuration from the IPv6 IS-IS process to which the interface belongs.
·     Disabled—The IS-IS interface does not use BFD for primary link failure detection.
·     Excluded—The IS-IS interface is disabled from using BFD for primary link failure detection by the isis ipv6 primary-path-detect bfd exclude command.
Topology ID
IPv4 unicast topology ID.
Prefix-SID type
Prefix SID type:
·     Absolute—Absolute value of the prefix SID.
·     Index—Index value of the prefix SID.
Value
Prefix SID value.
Prefix-SID validity
Whether the prefix SID is valid:
·     Invalid—The prefix SID is invalid because it is out of the SRGB range.
·     Valid—The prefix SID is valid.
Nexthop
Next hop address. This field displays 0.0.0.0 for a P2P network.
Adjacency SID type:
·     Absolute—Absolute value of the adjacency SID.
·     Index—Index value of the adjacency SID.
Result
Adjacency SID application result:
·     Succeeded—Applied for adjacency SID successfully.
·     Conflicting—Adjacency SID conflict occurred.
·     Init—Adjacency SID application is in progress or adjacency SID assignment is not enabled.
Average delay
Average link delay in microseconds.
Max delay
Maximum link delay in microseconds.
Min delay
Minimum link delay in microseconds.
Delay variation
Acceptable link delay variation in microseconds.
Link loss
Link loss in percentage.
Te-Metric FlexAlgo
IS-IS TE cost specified for flexible algorithm.
Link delay normalization configuration on the IPv4 IS-IS interface:
·     Interval—Interval value for link delay normalization, in milliseconds.
·     Offset—Offset value for link delay normalization, in milliseconds.
When link delay normalization is disabled on the IPv4 IS-IS interface, both the Interval and Offset fields display 0.
Link delay normalization configuration on the IPv6 IS-IS interface:
When link delay normalization is disabled on the IPv6 IS-IS interface, both the Interval and Offset fields display 0.
# Display IS-IS interface statistics.
<Sysname> display isis interface statistics
                 Interface statistics information for IS-IS(1)
    LAN                   1/0                    0/0
    P2P                   0/0                    0/0
Table 29 Command output
Network type of the interface:
·     LAN—Broadcast network.
·     P2P—Point-to-point network.
IPv4 up
Number of IS-IS interfaces in up state.
IPv4 down
Number of IS-IS interfaces in down state.
IPv6 up
Number of IS-ISv6 interfaces in up state.
IPv6 down
Number of IS-ISv6 interfaces in down state.
display isis interface hello-sent
Use display isis interface hello-sent to display information about the first three and last three packets sent by an interface.
display isis interface [ interface-type interface-number ] hello-sent [ process-id ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about the first three and last three packets sent by all interfaces.
# Display information about the first three and last three packets sent by all interfaces for all IS-IS processes.
<Sysname> display isis interface hello-sent
  Interface: Ten-GigabitEthernet3/0/1
  First 3 L1 hello packets sent:
    2019-11-21 15:10:14:687, succeeded
    2019-11-21 15:10:14:698, succeeded
    2019-11-21 15:10:22:506, succeeded
  Last 3 L1 hello packets sent:
    2019-11-21 16:19:11:724, succeeded
    2019-11-21 16:19:19:440, succeeded
    2019-11-21 16:19:27:858, succeeded
  First 3 L2 hello packets sent:
    2019-11-21 15:10:14:688, succeeded
    2019-11-21 15:10:14:699, succeeded
    2019-11-21 15:10:24:404, succeeded
  Last 3 L2 hello packets sent:
    2019-11-21 16:19:11:176, succeeded
    2019-11-21 16:19:19:453, succeeded
    2019-11-21 16:19:28:544, succeeded
Table 30 Command output
Interface name.
Time when the first three Level-1 hello packets were sent, and the packet sending result.
Time when the last three Level-1 hello packets were sent before this command was executed, and the packet sending result.
Time when the first three Level-2 hello packets were sent, and the packet sending result.
Time when the last three Level-2 hello packets were sent before this command was executed, and the packet sending result.
First 3 P2P hello packets sent
Time when the first three P2P hello packets were sent, and the packet sending result.
Last 3 P2P hello packets sent
Time when the last three P2P hello packets were sent before this command was executed, and the packet sending result.
display isis local-flex-algo
Use display isis local-flex-algo to display the configuration for a flexible algorithm on a node.
display isis local-flex-algo [ algorithm-id flex-algo-id ] [ process-id ]
algorithm-id flex-algo-id: Specifies a flexible algorithm by its ID. The value range for this argument is 128 to 255. If you do not specify this option, the command displays the configuration for all flexible algorithms.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command applies to all processes on the node.
# Display the configuration for flexible algorithm 255 in all processes.
<Sysname> display isis local-flex-algo algorithm-id 255
          IS-IS(2) Protocol Information
Flex-Algo(255)
    Definition advertisement             : Enabled
    Priority                             : 128
    MetricType                           : IGP
    Fast-reroute                         : Enabled
    Fast-reroute TI-LFA                  : Enabled
    Trust-level-mapping                  : Disabled
    Microloop-avoidance                  : Enabled
        level-1                 : 5000
        level-2                 : 5000
    SR microloop avoidance               : Enabled
    SR microloop avoidance RIB-update-delay
        level-1                 : 5000
        level-2                 : 5000
    SR microloop avoidance strict-sid-only: Disabled
    Node-protecting preference
        level-1                 : 40
        level-2                 : 40
    Lowest-cost preference
        level-1                 : 20
        level-2                 : 20
Table 31 Command output
IS-IS(xx) Protocol Information
Information about an IS-IS process. The xx argument represents the process ID.
Flex-Algo(xx)
Configuration for a flexible algorithm. The xx argument represents the flexible algorithm ID.
Whether FAD advertisement is enabled.
Priority
Priority value for the flexible algorithm.
MetricType
Fast-reroute
Whether FRR is enabled.
Fast-reroute TI-LFA
Whether TI-LFA FRR is enabled.
Trust-level-mapping
Whether trust level-based FAD advertisement is enabled.
Microloop-avoidance
Whether FRR microloop avoidance is enabled for the flexible algorithm.
FRR microloop avoidance RIB-update-delay timer specified for the flexible algorithm.
Whether SR microloop avoidance is enabled for the flexible algorithm.
SR microloop avoidance RIB-update-delay timer specified for the flexible algorithm.
level-1
Microloop avoidance RIB-update-delay timer that applies to Level 1 areas, in milliseconds.
level-2
Microloop avoidance RIB-update-delay timer that applies to the Level 2 area, in milliseconds.
Whether strict SID encapsulation is enabled for flexible algorithm SR microloop avoidance.
Priority of the node-protection backup path selection policy:
·     level-1—Priority value for the backup path selection policy in Level-1 areas.
·     level-2—Priority value for the backup path selection policy in the Level-2 area.
Priority of the lowest-cost backup path selection policy:
display isis lsdb
Use display isis lsdb to display IS-IS LSDB information.
display isis lsdb [ [ level-1 | level-2 ] | local | [ lsp-id lspid | lsp-name lspname ] | verbose [ no-name ] ] * [ process-id ]
level-1: Displays the Level-1 LSDB.
level-2: Displays the Level-2 LSDB.
local: Displays LSP information generated locally.
lsp-id lspid: Specifies an LSP ID, in the form of sysID. Pseudo ID-fragment num, where sysID represents the originating node or pseudo node. Pseudo ID is separated by a dot from sysID and by a hyphen from fragment num.
lsp-name lspname: Specifies the LSP name, in the form of Symbolic name.Pseudo ID-fragment num, where Pseudo ID is separated by a dot from Symbolic name and by a hyphen from fragment num. If the Pseudo ID is 0, specify the LSP name in the form Symbolic name-fragment num.
verbose: Displays LSDB detailed information. If you do not specify this keyword, the command displays brief information about LSDB.
no-name: Displays system ID information rather than host name information specified by using the is-name command when displaying detailed LSP information. If you do not specify this keyword and you have configured host names by using the is-name command, this command displays host name information rather than system ID information when displaying detailed LSP information.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays LSDBs for all IS-IS processes.
If no level is specified, the command displays both Level-1 and Level-2 LSDB information.
# Display brief Level-1 LSDB information.
<Sysname> display isis lsdb level-1
                        Database information for IS-IS(1)
        ATTENTION: System is overloaded.
        Overload is set for isolation.
                          Level-1 Link State Database
LSPID                 Seq Num      Checksum      Holdtime      Length  ATT/P/OL
0000.0000.0001.00-00* 0x00000087   0xf846        1152          183     0/0/0
0000.0000.0003.00-00  0x00000005   0x4bee        520           177     0/0/0
0000.0000.0003.00-01  0x00000004   0x7245        520           45      0/0/0
0000.0000.0011.00-00  0x0000000b   0xcdf6        815           183     0/0/0
# Display detailed Level-1 LSDB information.
<Sysname> display isis lsdb level-1 verbose
0000.0000.0001.00-00* 0x00000080   0x73f         1185          183     0/0/0
 Source       0000.0000.0001.00
 IID          10
 ITID         0
 NLPID        IPv4 IPv6
 Area address 10
 IPv4 address 192.168.220.10
 IPv6 address 100::1
 MT ID        0000   (-/-)
 MT ID        0002   (-/-)
 MT ID        0006   (-/-)
 +NBR  ID
     0000.0000.0011.00                Cost: 100
     Admin group: 0x00000000
     Physical bandwidth: 12500000 bytes/sec
     Reservable bandwidth: 0 bytes/sec
     Unreserved bandwidth for each TE class:
       TE class  0: 0 bytes/sec             TE class  1: 0 bytes/sec
       TE class  2: 0 bytes/sec             TE class  3: 0 bytes/sec
       TE class  4: 0 bytes/sec             TE class  5: 0 bytes/sec
       TE class  6: 0 bytes/sec             TE class  7: 0 bytes/sec
       TE class  8: 0 bytes/sec             TE class  9: 0 bytes/sec
       TE class 10: 0 bytes/sec             TE class 11: 0 bytes/sec
       TE class 12: 0 bytes/sec             TE class 13: 0 bytes/sec
       TE class 14: 0 bytes/sec             TE class 15: 0 bytes/sec
     TE cost: 10
     Bandwidth constraint model: Prestandard DS-TE RDM
     Bandwidth constraints:
       BC[0]      : 0 bytes/sec             BC[1]      : 0 bytes/sec
     Neighbor IP address: 192.168.220.30
     Interface IP address: 192.168.220.10
     Flag: 0, Average delay: 1000 us
     Flag: 0, Min delay: 100 us, Max delay: 1500 us
     Remaining bandwidth: 156250 bytes/sec
     Available bandwidth: 156236 bytes/sec
     Utilized bandwidth: 13 bytes/sec
     Flag: 0, Link loss: 0.002997%
     LAN-ADJ-SID
         Flags (F/B/V/L/S/P): 0/0/1/1/0/0          Weight: 0
         System ID         Adjacency SID
         0000.0000.0012    24108
     SRv6 LAN End.X SID
         System ID    : 0000.0000.0012
         SID          : 1000:0:0:15::
         Function type: End.X with PSP
         Flags (B/S/P/C): 0/0/0/0      Algorithm: 0        Weight: 0
     SRv6 LAN End.X SID
         SID          : 1000:0:0:16::
         Function type: End.X with PSP&USP&USD
 L2 bundle member attributes
     0000.0000.0011.00                Flags (P/-/-/-/-/-/-/-/): 1/0/0/0/0/0/0/0
     Interface IPv6 address: 100:1::1
     L2 bundle attribute descriptors
         Link local identifier count: 1
             0x584
     Flag: 0, Average delay: 500 us
     Flag: 0, Min delay: 1000 us, Max delay: 2000 us
     SRv6 LAN End.X SID
         System ID    : 0000.0000.0011
         SID          : 1000::1:2
         Function type: End.X (NO-FLAVOR)
     SRv6 LAN End.X SID
         SID          : 1000::1:3
     SRv6 LAN End.X SID
         SID          : 1000::1:4
         Function type: End.X with PSP, USP & USD
+NBR  ID
     2222.2222.2222.00               Cost: 10
     SR/SRv6 Link Maximum SID Depths
         MPLS MSD         : 5
     P2P-ADJ-SID
         Flags (F/B/V/L/S/P): 0/0/0/1/1/0          Weight: 0
         Adjacency SID: 24182
     SRv6 End.X SID
         SID          : 1000:0:0:18::
     SRv6 End.X SID
         SID          : 1000:0:0:19::
 IPv6 unicast NBR ID
     6464.6464.6464.01                Cost: 10         MT ID: 2
     LinkTag: 100
     Interface IPv6 address: 100::1
     NBR Interface IPv6 address: 100::2
 MT NBR ID
     6464.6464.6464.01                Cost: 10         MT ID: 6
 +IP-Extended
     192.168.220.0   255.255.255.0    Cost: 100
 +IP-Extended
     14.159.100.2    255.255.255.255  Cost: 0
     Prefix-SID: 3333            Algorithm: 0
     Prefix-SID flags (R/N/P/E/V/L): 0/1/0/0/0/0
 IPv4 unicast
     1.1.1.1         255.255.255.255  Cost: 0          MT ID: 6
 IPv4 unicast
     10.10.10.0      255.255.255.0    Cost: 10         MT ID: 6
 IPv6 unicast
     1:1:1::1/128                     Cost: 0          MT ID: 2
 IPv6 unicast
     10:10:10::/64                    Cost: 10         MT ID: 2
 IPv6
     3::3/128                         Cost: 0
       Prefix Attr Flags (X/R/N/A): 0/0/1/0
       BIER-SD: 0              BAR: 0     IPA: 0           BFR-ID: 0
         EncapType: G-BIER  Max SI: 2     BSL: 3     BIFT-ID base: -
         G-BIER MPRA: 1111::1111
 Router ID    1.1.1.1
 IPv6 router ID    1::1
 Router capability
     Router ID: 14.159.201.2            Flags (D/S): 0/0
     Segment routing (I/V/H): 1/0/0
     SRGB base: 16666                   SRGB range : 5557
     SRv6 capability flags (O): 0
     SR/SRv6 Node Maximum SID Depths
         MPLS MSD          : 5
         SRv6 Segment Left : 10
         SRv6 End Pop MSD  : 10
         SRv6 H.Encaps MSD : 10
         SRv6 End D MSD    : 10
     SR Algorithm
         Algorithm: 0
         Algorithm: 255
     Flex-Algo Definition
         Algorithm: 255 Metric-Type: IGP Alg-type: SPF Priority: 128
             0x00000002
         Flex-Algo Definition Flags:
             M-flag: 1
 +SRv6 locator
     MT ID   : 0
     Locator : 1000::/32
     Cost    : 0                     Flag (D): 0         Algorithm : 0
     End SID : 1000:0:0:1::
         Function type : End with PSP
     End SID : 1000:0:0:2::
         Function type : End with PSP&USP&USD
+SRv6 locator
     MT ID  : 0
     Locator: 1000:1:2:3::/64
     Cost   : 0                     Flag (D): 0         Algorithm: 0
     End SID: 1000:1:2:3::A00
         Flag (C)     : 0
         Function type: End with PSP
     End SID: 1000:1:2:3::B00
         Flag (C)     : 0
         Function type: End (no flavor)
 +IPV6 SRLG NBR ID
     0000.0000.0002.00
     Interface IPv6 address: 1001::1
     Neighbor IPv6 address: 1001::2
     Shared risk link group: 20
 +Application Specific SRLG NBR ID
     0000.0000.0002.00
       L flag: 0, SA-Length: 1, UDA-Length: 1
       Standard Applications: 0x10
       User Defined Applications: 0x10
0000.0000.0003.00-00  0x00000005   0x4bee        887           177     0/0/0
 Source       0000.0000.0003.00
 NLPID        IPv4
 Area address 10
 IPv4 address 10.10.10.10
 IPv4 address 192.168.220.20
 +NBR  ID
     0000.0000.0001.00                Cost: 10
     TE cost: 10
       BC[0]: 0 bytes/sec                   BC[1]: 0 bytes/sec
     Neighbor IP address: 192.168.220.10
     Interface IP address: 192.168.220.20
     Delay variation: 1000 us
     LAN-ADJ-SID
         MPLS MSD         : 5
 +IP-Extended
 Router ID    3.3.3.3
 Router capability
 SID binding
     11.11.11.11/32             Flags (F/M/S/D/A): 0/0/0/0/0
     Weight: 0                  Range: 10
     Start SID: 10              Algorithm: 0
     Prefix-SID flags (R/N/P/E/V/L): 0/0/0/0/0/0
 +SRLG NBR ID
     0000.0000.0002.00
     Interface IP address: 2.1.1.1
     Neighbor IP address: 2.1.1.2
     Shared risk link group: 45, 100
0000.0000.0003.00-01  0x00000004   0x7245        887           45      0/0/0
 +IP-Extended
 +IP-Extended
 +IP-Extended
 Router capability
0000.0000.2001.00-00* 0x0000000a   0xb870        1193          175     0/0/0
 Source       0000.0000.2001.00
 NLPID        IPv4 IPv6
 Area address 10
 IPv6
     100:1::/120                      Cost: 0
 IPv6 Router ID  100::1
 Router capability
     Router ID: 0.0.0.0         Flags (D/S): 0/0
     IPv6 Router ID: 100::1
     SRv6 capability flags (O/C): 0/0
         Segment Left: 5
         End Pop MSD : 5
         T.Insert MSD: 5
         T.Encaps MSD: 5
         End D MSD   : 5
 +SRv6 locator
     MT ID  : 0
     Locator: 100:1::/120
     Flag(A): 0
     End SID: 100:1::1
         Flag (C)     : 0
# Display detailed Level-2 LSDB information.
<Sysname> display isis lsdb level-2 verbose
                          Level-2 Link State Database
0000.0000.2001.00-00* 0x0000005b   0x7304        806           216     0/0/0
 NLPID        IPv4 IPv6
 Area address 10.0001
 IPv4 address 192.168.24.2
 +NBR  ID
     0000.0000.4001.02                Cost: 10
     Application Specific Link Attributes
       Standard Applications: 0x10 Flex-Algo
       User Defined Applications: 0x10 Flex-Algo
       Ext Admin Group:
         0x00000400
       Physical bandwidth: 0 bytes/sec
       TE cost: 100
       Flag: 0, Average delay: 50 us
     0000.0000.0002.01                Flags (P/-/-/-/-/-/-/-/): 1/0/0/0/0/0/0/0
             0x584
     SRv6 LAN End.X SID
         System ID    : 0000.0000.0002
         SID          : 1111::1:2
     SRv6 LAN End.X SID
         SID          : 1111::1:3
     SRv6 LAN End.X SID
         SID          : 1111::1:4
 +IP-Extended
     192.168.24.0    255.255.255.0    Cost: 10
 IPv6-ext
     1::/64                           Cost: 0
 IPv6-ext
     1::9/128                         Cost: 0
 Router capability
     Router ID: 192.168.24.2    Flags (D/S): 0/0
         SRv6 Segment Left: 10
         SRv6 H.Encaps MSD: 10
         SRv6 End D MSD   : 10
     SR Algorithm
         Algorithm: 0
         Algorithm: 128
         Algorithm: 129
         Algorithm: 128 Metric-Type:IGP Alg-type: SPF Priority: 255
         Algorithm: 129 Metric-Type:IGP Alg-type: SPF Priority: 128
 +SRv6 locator
     MT ID  : 0
     Flag(A): 0
     Locator: 10:1::/120
     Cost   : 0                     Flag (D): 0         Algorithm: 128
     End SID: 10:1::1
         Flag (C)     : 0
 +IPV6 SRLG NBR ID
     0000.0000.0002.00
     0000.0000.0002.00
0000.0000.4001.00-00  0x00000057   0xcaec        1098          167     0/0/0
 Source       0000.0000.4001.00
 NLPID        IPv4 IPv6
 Area address 10.0002
 IPv4 address 192.168.24.4
 IPv4 address 192.168.46.4
 IPv6 address 1::2
 IPv6 address 2::9
 +NBR  ID
 +IP-Extended
     6.6.6.6         255.255.255.255  Cost: 10
 +IP-Extended
 +IP-Extended
     192.168.46.0    255.255.255.0    Cost: 10
 IPv6
     1::/64                           Cost: 10
 IPv6
     2::9/128                         Cost: 0
 IPv6
     3::3/128                         Cost: 10
       Prefix Attr Flags (X/R/N/A): 0/1/1/0
         PHP request
0000.0000.4001.02-00  0x00000032   0xd643        1191          55      0/0/0
 Source       0000.0000.4001.02
 NLPID        IPv4 IPv6
 +NBR  ID
     0000.0000.2001.00                Cost: 0
 +NBR  ID
     0000.0000.4001.00                Cost: 0
Table 32 Command output
LSPID
LSP ID.
Seq Num
LSP sequence number.
Checksum
LSP checksum.
Holdtime
LSP lifetime, which decreases as time elapses.
Length
LSP length.
ATT/P/OL
·     ATT—Attach bit.
·     P—Partition bit.
·     OL—Overload bit.
1 means the LSP bit is set and 0 means the LSP bit is not set.
Source
System ID of the originating router.
HOST NAME
Dynamic host name of the originating router.
ORG ID
Original system ID of the virtual system of the originating router.
IID
Multi-instance process ID.
ITID
Multi-instance topology ID. The value of this field is fixed at 0 in the current software version.
NLPID
Network layer protocol the originating router runs.
Area address
Area address of the originating router.
IPv4 address
IP address of the originating router's IS-IS interface.
IPv6 address
IPv6 address of the originating router's IS-ISv6 interface.
MT ID        XXXX     (-/-)
Topology supported by the originating router (0/0/0 indicates ATT/P/OL):
·     0000—Base topology.
·     0002—IPv6 unicast topology.
·     (-/-)—Attach bit/overload bit.
If this field displays other values, the originating router supports IPv4 unicast topologies. This situation is not supported in the current software version.
NBR ID
Neighbor ID of the originating router.
Application specific link attributes, which indicate that the link attribute is associated with a flexible algorithm.
L flag
Legacy flag, which is fixed at 0.
SA-Length
Standard application identifier bit mask length in bytes.
UDA-Length
User defined application identifier bit mask length in bytes.
Standard application.
User defined application.
Ext Admin Group
Extended admin groups.
IPv6 unicast NBR ID
IPv6 unicast neighbor information about the originating router.
LinkTag
Link tag.
Admin group
Link management group attribute.
Physical bandwidth
Physical bandwidth.
Reserved bandwidth.
Available bandwidth reserved for each TE class.
TE class
Available bandwidth for each of the 8 or 16 TE classes.
TE cost
TE cost.
·     Prestandard DS-TE RDM.
·     IETF DS-TE RDM. This model is not supported in the current software version.
·     IETF DS-TE MAM. This model is not supported in the current software version.
BC
Bandwidth constraint value. The Prestandard model supports 2 BCs, and the IETF modes support a maximum of 8 BCs.
IP address of the local interface.
Neighbor IP address
IP address of the remote interface.
IPv6 address of the local interface.
IPv6 address of the remote interface.
Router ID
IPv4 router ID.
IPv6 router ID
IPv6 router ID.
IP-Internal
Internal IP address and mask of the originating router.
IP-External
External IP address and mask of the originating router.
IP-Extended
Extended information about the originating router, including the IP address, subnet mask, and prefix SID information.
Cost
Cost.
Prefix Attr Flags
Prefix attribute flags.
·     X—External prefix. If this flag is set, the prefix is imported from another protocol.
·     R—Redistributed prefix. If this flag is set, the prefix is leaked from another level.
·     N—Node identifier. If this flag is set, the prefix is used to identify the advertisement router.
·     A—Anycast prefix. If this flag is set, the prefix supports anycast.
BIER-SD
BIER sub-domain.
BAR
BIER path calculation algorithm. The value for this field is fixed at zero.
IPA
Unicast nexthop calculation algorithm. The value for this field is fixed at zero.
BFR-ID
BIER forwarding router ID.
EncapType
BIER packet encapsulation type.
·     G-BIER—Generalized BIER.
·     BIERv6—BIER IPv6.
·     MSR6—Multicast Segment Routing over IPv6.
Max SI
Maximum set identifier.
BSL
Length of the bit string.
BIFT-ID base
Base for the BIER Index Forwarding Table (BIFT) ID.
G-BIER MPRA
Multicast policy reserved address.
End.BIER SID
End.BIER SID value.
End.RGB SID
End.RGB SID value.
PHP request
Pop out the request node on the penultimate hop.
BFR-ID ranges [start, range]
BFR-ID range. The start attribute displays the start BFR ID, and the range attribute displays the number of BFR IDs.
Auth
Authentication information of the originating router.
IPV6
Internal IPv6 address and prefix of the originating router.
IPV6-Ext
External IPv6 address and prefix of the originating router.
IPv4 unicast
IPv4 unicast reachability information about the originating router.
IPv6 unicast
Internal IPv6 unicast reachability information about the originating router.
IPv6 unicast-ext
External IPv6 unicast reachability information about the originating router.
Flag
Average link delay flag indicating whether the average link delay exceeds 16777215 microseconds:
·     0—Stable link state whose average delay is shorter than or equivalent to 16777215 microseconds.
·     1—Unstable link state whose average delay is longer than 16777215 microseconds.
Average delay
Average delay in microseconds.
Flag
Min/Max link delay flag indicating whether the Min/Max link delay exceeds 16777215 microseconds.
·     0—Stable link state whose Min/Max delay is shorter than or equivalent to 16777215 microseconds.
·     1—Unstable link state whose Min/Max delay is longer than 16777215 microseconds.
Min delay
Max delay
Delay variation
Remaining bandwidth
Remaining bandwidth in byte/s. The data type of this field is 32-bit single-precision floating point. Values with precision beyond this limit will be truncated or rounded, which might result in precision loss.
Available bandwidth
Available bandwidth in byte/s. The data type of this field is 32-bit single-precision floating point. Values with precision beyond this limit will be truncated or rounded, which might result in precision loss.
Utilized bandwidth
Used bandwidth in byte/s. The data type of this field is 32-bit single-precision floating point. Values with precision beyond this limit will be truncated or rounded, which might result in precision loss.
Flag
Link loss flag indicating whether the link loss exceeds 50.331642%:
·     0—Stable link state whose link loss is lower than or equivalent to 50.331642%.
·     1—Unstable link state whose link loss is higher than 50.331642%.
Link loss
SR-MPLS/SRv6 Link Maximum SID Depths (MSD) sub-TLV information.
MPLS MSD
Maximum number of SIDs that SR-MPLS can encapsulate in a packet.
LAN-ADJ-SID
SID advertisement information from the LAN adjacency path.
P2P-ADJ-SID
SID advertisement information from the P2P adjacency path.
Flags (F/B/V/L/S/P)
Adjacency SID flag:
·     F—Address family flag. If set, the adjacency SID refers to an IPv6 adjacency. If not set, the adjacency SID refers to an IPv4 adjacency.
·     B—Backup flag. If set, the adjacency SID is eligible for link protection.
·     V—Value/Index flag. If set, the adjacency SID is an absolute value. If not set, the adjacency SID carries an index value.
·     L—Local/global flag. If set, the adjacency SID has local significance. If not set, the adjacency SID has global significance.
·     S—Set flag. If set, the adjacency SID refers to a set of adjacencies.
·     P—Permanence flag. If set, the SID is allocated to a neighbor permanently, regardless of whether the neighbor relationship is re-established.
Weight
Path weight.
Adjacency SID
SID advertised by the adjacency path.
SRv6 Lan End.X SID
LAN adjacency SRv6 End.X SID sub-TLV information.
SRv6 End.X SID
P2P adjacency SRv6 End.X SID sub-TLV information.
SID
SRv6 SID.
Function type
SID forwarding action and flavor:
·     End (NO-FLAVOR)—End SID without any flavors.
·     End with PSP—End SID with PSP.
·     End with USPEnd SID with USP.
·     End with PSP&USP—End SID with PSP and USP.
·     End with PSP&USD—End SID with PSP and USD.
·     End with PSP, USP&USD—End SID with PSP, USP, and Ultimate Segment Decapsulation (USD).
·     End.X (NO-FLAVOR)—End.X SID without any flavors.
·     End.X with PSP—End.X SID with PSP.
·     End.X with USP—End.X SID with USP.
·     End.X with PSP&USP—End.X SID with PSP and USP.
·     End.X with PSP&USD—End.X SID with PSP and USD.
·     End.X with PSP, USP&USD—End.X SID with PSP, USP, and USD.
·     End.T (no PSP, no USP)—End.T SID without PSP and USP.
·     End.T with PSP—End.T SID with PSP.
·     End.T with USP—End.T SID with USP.
·     End.T with PSP&USP—End.T SID with PSP and USP.
·     End.DT6—End.DT6 SID.
·     End.DX6End.DX6 SID.
·     End with NEXT—End SID with NEXT.
·     End with COC (NO-FLAVOR)—Compressed End SID without any flavors.
·     End with COC&NEXT—End SID with COC and NEXT.
·     End with PSP&COC—Compressed End SID with PSP.
·     End with PSP&USP&COC—Compressed End SID with PSP and USP.
·     End with PSP&USD&NEXT—End SID with PSP, USD, and NEXT.
·     End with USP&USD&COC&NEXT—Compressed End SID with USP, USD, COC, and NEXT.
·     End with PSP&USP&USD&COC—Compressed End SID with PSP, USP, and USD.
·     End with PSP&USP&USD&COC&NEXT—End SID with PSP, USP, USD, COC, and NEXT.
·     End.X with NEXT—End.X SID with NEXT.
·     End.X with COC (NO-FLAVOR)—Compressed End.X SID without any flavors.
·     End.X with COC&NEXT—End.X SID with COC and NEXT.
·     End.X with PSP&COC—Compressed End.X SID with PSP.
·     End.X with PSP&USP&COC—Compressed End.X SID with PSP and USP.
·     End.X with PSP&USD&NEXT—End.X SID with PSP, USD, and NEXT.
·     End.X with USP&USD&COC&NEXT—End.X SID with USP, USD, COC, and NEXT.
·     End.X with PSP&USP&USD&COC—Compressed End.X SID with PSP, USP, and USD.
For more information about SRv6 SID flavors, see SRv6 configuration in Segment Routing Configuration Guide.
Flags (B/S/P/C)
SRv6 flag:
·     B—Backup flag. If set, the SID can be used for link protection.
·     S—Set flag. If set, the SID can be allocated to multiple neighbors.
·     C—SRv6 compression flag. If set, the SID is compressed.
Common prefix length
Common prefix length of the compressed SID.
Node length
Node length of the compressed SID.
Function length
Function length of the compressed SID.
Args length
Args length of the compressed SID.
Prefix SID flag:
·     R—Re-advertisement flag. If set, inter-level propagation or route redistribution exists.
·     N—Node-SID flag. If set, the prefix SID is the SID to an SR node.
·     P—No-PHP flag. If set, the penultimate node cannot pop the prefix SID.
·     E—Explicit null flag. If set, the upstream neighbor must replace the prefix SID with an explicit null flag before forwarding the packets.
·     V—Value/Index flag. If set, the prefix SID is an absolute value.
·     L—Local/global flag. If set, the prefix SID has local significance.
FAPM
Flexible algorithm prefix metric.
Algorithm
Type of the algorithm associated to the prefix.
·     0—SPF algorithm.
·     128 to 255—Flexible algorithm.
Router capability
Route capability sub-TLV information.
Flags (D/S)
Inter-level leaking flag:
·     D—D flag. If set, the route capability TLV cannot be leaked from Level-1 to Level-2.
·     S—S flag. If set, the route capability TLV must be flooded across the entire routing domain. If not set, the route capability TLV cannot be leaked between levels.
SR capability sub-TLV flag:
·     IMPLS IPv4 flag. If set, the router is capable of processing SR-MPLS encapsulated IPv4 packets on all interfaces.
·     V—MPLS IPv6 flag. If set, the router is capable of processing SR-MPLS encapsulated IPv6 packets on all interfaces. This flag is not supported in the current software version.
·     H—SRv6 flag. If set, the router is capable of processing SRv6 encapsulated packets with Segment Routing Headers (SRHs) on all interfaces. This flag is not supported in the current software version.
SRGB base
Minimum label value of the SRGB range.
SRGB range
Number of labels of the SRGB.
SRv6 capability TLV.
·     If the O flag is set, the router supports the OAM flag.
·     If the C flag is set, the SID is compressed.
SR-MPLS/SRv6 node Maximum SID Depths (MSD) sub-TLV information.
MPLS MSD
SRv6 Segments Left
The maximum value of the Segment Left field in the Segment Routing Header (SRH).
SRv6 End Pop MSD
The maximum number of SIDs that can be popped out by edge nodes supporting PSP or USP.
If the destination address of a packet is the local SID of a device, the device is the edge node of the packet.
SRv6 H.Encaps MSD
The maximum number of SIDs that a transit node can encapsulate into a packet through an SRv6 TE policy.
SRv6 End D MSD
The maximum number of SIDs that an edge node can decapsulate.
SR Algorithm
SR algorithm information.
Algorithm
Advertised SR algorithm ID.
FAD advertised by an SR node:
·     Algorithm—Flexible algorithm ID. 0 represents the SPF algorithm, and a value of 128 to 255 represents the flexible algorithm.
·     Metric-Type—Metric type of the flexible algorithm.
·     Alg-type—Flexible algorithm calculation type.
·     Priority—Priority of the flexible algorithm.
·     Flexible algorithm extended administrative group.
¡     Flex-Algo Exclude Any Ext Admin Group—A link will be excluded from the flexible algorithm topology if it has an affinity that is included in the group.
¡     Flex-Algo Include All Ext Admin Group—A link will be excluded from the flexible algorithm topology if it does not have all the affinities that are included in the group.
¡     Flex-Algo Include Any Ext Admin Group—A link will be excluded from the flexible algorithm topology if it does not have an affinity that is included in the group.
·     Flex-Algo Definition Flags—FAD flag information. The M-Flag indicates whether the flexible algorithm uses FAPM to calculate inter-area route prefixes and external route prefixes. If this flag is set, the flexible algorithm uses FAPM to calculate inter-area route prefixes and external route prefixes.
SRv6 Locator
SRv6 Locator TLV.
Locator
SID locator.
Flag (D)
Leaking flag. If set, locator TLVs cannot be leaked from Level-1 to Level-2.
Algorithm
Algorithm ID that is associated to the SRv6 locator. 0 represents the SPF algorithm, and a value of 128 to 255 represents the flexible algorithm.
Flag (A)
Anycast locator flag. If set, the locator is an anycast locator.
Admin tag
Administrative tag of the SRv6 locator. If no administrative tag is configured, this field is not displayed.
End SID
SRv6 End SID.
Flag (C)
SID binding
Prefix-SID mapping information.
Flags (F/M/S/D/A)
Mapping flags:
·     F—Address family flag. If set, the peer is an IPv6 peer. If not set, the peer is an IPv4 peer.
·     M—Mirror context flag. If set, the SID is used for SR node protection.
·     S—Scope flag. If set, the route capability TLV can be leaked from Level-1 to Level-2.
·     D—Down flag. If set, the SID/Label Binding TLV is advertised from Level-2 to Level-1.
·     A—Attached flag. If set, the prefix and SID are advertised by a directly connected peer.
Range
Number of consecutive SIDs assigned.
L2 bundle member attributes TLV.
Flags (P/-/-/-/-/-/-/-)
Flag information. When the P flag is set, the TLV carries sub-TLVs used to distinguish parallel links.
L2 bundle attribute descriptors.
Link local identifiers: n
Link ID information about member interfaces. n represents the number of link IDs.
L2-Bundle-Member-LAN-ADJ-SID
Adjacency SID information about member interfaces on LAN adjacency links.
L2-Bundle-Member-ADJ-SID
Adjacency SID information about member interfaces on P2P adjacency links.
SRv6 LAN End.X SID
SRv6 End.X SID
Flags (F/*/V/L/S/P/-/-)
Prefix SID flag information:
·     P—Persistence flag. If set, the adjacency SID remains unchanged.
SRLG NBR ID
SRLG information advertised to the IPv4 IS-IS neighbor.
IPv4 address of the local interface.
Neighbor IP address
IPv4 address of the remote interface.
IPV6 SRLG NBR ID
SRLG information advertised to the IPv6 IS-IS neighbor.
Group number of the SRLG to which the local interface belongs.
Application-specific SRLG information advertised to the IPv6 IS-IS neighbor. Only flexible algorithm is supported.
is-name
display isis lsdb statistics
Use display isis lsdb statistics to display IS-IS LSDB statistics.
display isis lsdb statistics [ level-1 | level-2 ] [ process-id ]
level-1: Displays IS-IS Level-1 LSDB statistics.
level-2: Displays IS-IS Level-2 LSDB statistics.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays LSDB statistics for all IS-IS processes.
If no level is specified, the command displays both Level-1 and Level-2 LSDB statistics.
# Display IS-IS LSDB statistics.
<Sysname> display isis lsdb statistics
                   Database Statistics information for IS-IS(1)
                              Level-1 LSDB Statistics
LSP source ID                                                      LSP count
Total                                                              333
1111.1111.1111.00                                                  1
2222.2222.2222.00                                                  256
2222.2222.2222.01                                                  1
bbbb.bbbb.0001.00                                                  75
                              Level-2 LSDB Statistics
Total                                                              663
1111.1111.1111.00                                                  256
2222.2222.2222.01                                                  1
aaaa.aaaa.0001.00                                                  75
Table 33 Command output
LSP source ID
ID of the source system.
LSP count
Number of LSPs with the same source ID.
Total
Total number of LSPs.
display isis lsdb
display isis mesh-group
Use display isis mesh-group to display IS-IS mesh group configuration information.
display isis mesh-group [ process-id ]
process-id: Displays IS-IS mesh-group configuration for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays IS-IS mesh group configuration information for all IS-IS processes.
# Add Serial3/0/1:0 and Serial3/0/2:0 to mesh group 100.
[Sysname] interface serial 3/0/1:0
[Sysname-Serial3/0/1:0] isis mesh-group 100
[Sysname-Serial3/0/1:0] quit
[Sysname] interface serial 3/0/2:0
[Sysname-Serial3/0/2:0] isis mesh-group 100
# Display IS-IS mesh-group configuration information.
[Sysname-Serial3/0/2:0] display isis mesh-group
                      Mesh Group information for IS-IS(1)
 Interface          Status
 Serial3/0/1:0         Blocked
 Serial3/0/2:0         100
Table 34 Command output
Interface name.
Status
Mesh group the interface belongs to/whether a blocked interface is configured.
display isis name-table
Use display isis name-table to display the host name-to-system ID mapping table.
display isis name-table [ process-id ]
process-id: Displays the host name to system ID mapping table for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the host name to system ID mapping table for all IS-IS processes.
# Display the IS-IS host name to system ID mapping table.
<Sysname> display isis name-table
                      Name table information for IS-IS(1)
 System ID           Hostname                            Type       Level
 6789.0000.0001      RUTA                                DYNAMIC    Level-1
 6789.0000.0001      RUTA                                DYNAMIC    Level-2
 0000.0000.0041      RUTB                                STATIC     Level-1
 0000.0000.0041      RUTB                                STATIC     Level-2
 6789.0000.0001.01   DIS-A                               DYNAMIC    Level-1
 0000.0000.0041.01   DIS-B                               DYNAMIC    Level-2
Table 35 Command output
System ID
System ID.
Hostname
Host name.
Mapping type:
·     STATIC.
·     DYNAMIC.
Level
Level on which the system ID-to-host name mapping takes effect: Level-1 or Level-2.
display isis non-stop-routing status
Use display isis non-stop-routing status to display IS-IS NSR status.
display isis non-stop-routing status [ process-id ]
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays NSR status information for all IS-IS processes.
# Display IS-IS NSR status.
<Sysname> display isis non-stop-routing status
                        Nonstop Routing information for IS-IS(1)
NSR phase: Finish
Table 36 Command output
NSR phase
NSR phase:
·     Initialization.
·     Smooth.
·     First SPF computation.
·     Redistribution.
·     Second SPF computation.
·     LSP stability—Ready to generate LSPs.
·     LSP generation.
·     Finish.
display isis packet
Use display isis packet to display IS-IS packet statistics.
display isis packet { csnp | hello | lsp | psnp } by-interface [ verbose ] [ interface-type interface-number ] [ process-id ]
display isis packet { csnp | hello | lsp | psnp } [ verbose ] [ process-id ]
csnp: Displays CSNP packet statistics.
hello: Displays hello packet statistics.
lsp: Displays LSP packet statistics.
psnp: Displays PSNP packet statistics.
by-interface: Displays packet statistics on a per-interface basis.
verbose: Displays detailed packet statistics.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays IS-IS packet statistics for all interfaces.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays packet statistics for all IS-IS processes.
# Display detailed hello packet statistics on a per-interface basis.
<Sysname> display isis packet hello by-interface verbose
                     Hello packet information for IS-IS(1)
  Total output packets : 0          Total output error packets : 0
  Total input packets  : 0          Total input error packets  : 0
  Total output packets with 1.5 hello intervals : 0
  Total input packets with 0.5 holdtime         : 0
  Input packets with errors
    Bad packet length      : 0          Bad header length          : 0
    Jumbo packet           : 0          Bad protocol description   : 0
    Bad protocol ID        : 0          Bad protocol version       : 0
    Unknown packet type    : 0          Bad max area count         : 0
    Bad system ID length   : 0          Bad circuit type           : 0
    Bad auth TLV           : 0          Bad area address TLV       : 0
    Auth failure           : 0          Excessive area addresses   : 0
    Bad NBR TLV            : 0          Excessive auth TLVs        : 0
    Excessive IF Addr TLVs : 0          Excessive IF addresses     : 0
    Bad IF address TLV     : 0          Duplicate system ID        : 0
    Bad TLV length         : 0          Bad IP address             : 0
    Duplicate IP address   : 0          Mismatched area address    : 0
    Mismatched protocol    : 0          Mismatched network type    : 0
    Bad IPv6 address TLV   : 0          Bad IPv6 address           : 0
    Duplicate IPv6 address : 0          Bad MT ID TLV              : 0
    SNPA conflict (LAN)    : 0          Excessive NBR SNPAs (LAN)  : 0
    Mismatched level (LAN) : 0          Bad 3-Way option TLV (P2P) : 0
    No common MT ID (P2P)  : 0          Bad circuit ID (P2P)       : 0
    Bad BFD TLV            : 0          Bad global IPv6 address TLV: 0
    Bad IID TLV            : 0
# Display detailed hello packet statistics.
<Sysname> display isis packet hello verbose
    Bad IID TLV            : 0
Table 37 Command output
Total number of hello packets sent at intervals greater than 1.5 times the hello interval.
Total number of hello packets received at intervals greater than 0.5 times the holdtime.
Statistics for packets with the following errors:
·     Bad packet length—Invalid packet length.
·     Bad header length—Invalid header length.
·     Jumbo packet—The packet length exceeds the buffer size or the interface MTU.
·     Bad protocol description—Invalid protocol description.
·     Bad protocol ID—Invalid protocol identifier.
·     Bad protocol version—Invalid protocol version.
·     Unknown packet type—Unknown packet type.
·     Bad max area count—Invalid maximum number of area addresses.
·     Bad system ID length—Invalid system ID length.
·     Bad circuit type—Invalid interface type.
·     Bad auth TLV—Invalid authentication TLV.
·     Bad area address TLV—Invalid area address TLV.
·     Auth failure—Authentication failure.
·     Excessive area addresses—Excessive area addresses.
·     Bad NBR TLV—Invalid neighbor TLV.
·     Excessive auth TLVs—Excessive authentication TLVs.
·     Excessive IF Addr TLVs—Excessive interface address TLVs.
·     Excessive IF addresses—Excessive interface addresses.
·     Bad IF address TLV—Invalid interface address TLV.
·     Duplicate system ID—Duplicate system IDs.
·     Bad TLV length—Invalid TLV length.
·     Bad IP address—The IP address does not belong to the same network as the local interface address.
·     Duplicate IP address—Duplicate IP addresses.
·     Mismatched area address—Mismatched area addresses.
·     Mismatched protocol—Mismatched protocols.
·     Mismatched network type—Mismatched network types.
·     Bad IPv6 address TLV—Invalid IPv6 address TLV.
·     Bad IPv6 address—Invalid IPv6 address.
·     Duplicate IPv6 address—Duplicate IPv6 addresses.
·     Bad MT ID TLV—Invalid topology ID TLV.
·     SNPA conflict (LAN)—SNPA conflict.
·     Excessive NBR SNPAs (LAN)—Excessive neighbor SNPAs.
·     Mismatched level (LAN)—Mismatched levels.
·     Bad 3-Way option TLV (P2P)—Invalid three-way handshake information.
·     No common MT ID (P2P)—No common topology ID.
·     Bad circuit ID (P2P)—Invalid circuit ID.
·     Bad BFD TLV—Invalid BFD TLV.
·     Bad global IPv6 address TLV—Invalid global IPv6 address TLV.
·     Bad IID TLV—The multi-instance TLV length is smaller than the minimum length specified in the protocol.
# Display detailed LSP packet statistics on a per-interface basis.
<Sysname> display isis packet lsp by-interface verbose
                      LSP packet information for IS-IS(1)
    Jumbo packet         : 0          SNPA conflict (LAN)       : 0
    Smaller than header  : 0          Bad protocol description  : 0
    No active NBR        : 0          Bad system ID length      : 0
    Mismatched level     : 0          Illegal IS type           : 0
    Sequence number is 0 : 0          Checksum is 0             : 0
    Incorrect checksum   : 0          Bad TLV length            : 0
    Mismatched protocol  : 0          Bad auth TLV              : 0
    Auth failure         : 0          Excessive auth TLVs       : 0
    Bad NBR TLV          : 0          Bad extended IS TLV       : 0
    Bad IF address TLV   : 0          Bad IPv6 IF address TLV   : 0
    Bad alias TLV        : 0          Bad IP reachability TLV   : 0
    Bad MT IS TLV        : 0          Bad area address TLV      : 0
    Bad MT ID TLV        : 0          Bad MT IP TLV             : 0
    Bad MT IPv6 TLV      : 0          Bad IPv6 reachability TLV : 0
    Bad router ID TLV    : 0          Bad SRLG TLV              : 0
    Bad IID TLV          : 0
# Display detailed LSP packet statistics.
<Sysname> display isis packet lsp verbose
    Bad IID TLV          : 0
Table 38 Command output
·     Jumbo packet—The packet length exceeds the maximum length of packets that can be received.
·     Smaller than header—The packet length is smaller than the fixed header length.
·     No active NBR—The packet is from an unknown neighbor.
·     Mismatched level—Mismatched levels.
·     Illegal IS type—Invalid IS type.
·     Sequence number is 0—The sequence number is 0.
·     Checksum is 0—The checksum is 0.
·     Incorrect checksum—Incorrect checksum.
·     Bad extended IS TLV—Invalid extended IS TLV.
·     Bad IPv6 IF address TLV—Invalid IPv6 interface address TLV.
·     Bad alias TLV—Invalid alias TLV.
·     Bad IP reachability TLV—Invalid IP reachability TLV.
·     Bad MT IS TLV—Invalid topology IS TLV.
·     Bad MT IP TLV—Invalid IPv4 topology TLV.
·     Bad MT IPv6 TLV—Invalid IPv6 topology TLV.
·     Bad IPv6 reachability TLV—Invalid IPv6 reachability TLV.
·     Bad router ID TLV—Invalid router ID TLV.
·     Bad SRLG TLV—Invalid SRLG TLV.
# Display detailed CSNP packet statistics on a per-interface basis.
<Sysname> display isis packet csnp by-interface verbose
                      CSNP packet information for IS-IS(1)
    Mismatched level    : 0          Bad TLV length           : 0
    Auth failure        : 0          Bad auth TLV             : 0
    Bad LSP TLV length  : 0          Excessive auth TLVs      : 0
    Excessive LSPs      : 0          Bad LSP ID               : 0
    Bad IID TLV         : 0
# Display detailed CSNP packet statistics.
<Sysname> display isis packet csnp verbose
    Bad IID TLV         : 0
Table 39 Command output
·     Bad LSP TLV length—Invalid LSP TLV length.
·     Excessive LSPs—Excessive LSPs.
·     Bad LSP ID—Invalid LSP ID.
# Display detailed PSNP packet statistics on a per-interface basis.
<Sysname> display isis packet psnp by-interface verbose
                      PSNP packet information for IS-IS(1)
    Bad IID TLV         : 0
# Display detailed PSNP packet statistics.
<Sysname> display isis packet psnp verbose
    Bad IID TLV         : 0
Table 40 Command output
reset isis packet
display isis peer
Use display isis peer to display IS-IS neighbor information.
display isis peer [ statistics | verbose ] [ process-id ]
statistics: Displays IS-IS neighbor statistics.
verbose: Displays detailed IS-IS neighbor information. If you do not specify this keyword, the command displays brief IS-IS neighbor information.
process-id: Displays IS-IS neighbor information for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays neighbor information for all IS-IS processes.
# Display brief IS-IS neighbor information.
<Sysname> display isis peer
                         Peer information for IS-IS(1)
 System ID: 0000.0000.0001
 Interface: XGE1/0/2                Circuit Id:  0000.0000.0001.01
 State: Up     HoldTime:  27s       Type: L1(L1L2)     PRI: 64
 State: Up     HoldTime:  27s       Type: L2(L1L2)     PRI: 64
# Display detailed IS-IS neighbor information.
<Sysname> display isis peer verbose
 System ID: 0000.1111.2222
 Interface: XGE1/0/2                Circuit Id:  0000.1111.2222.01
 State: Up     Holdtime:   6s       Type: L1(L1L2)     PRI: 64
 Area address(es): 49
 Peer IP address(es): 12.0.0.2
 Peer IPv6 address(es): FE80::541F:98FF:FE5E:205
 Peer IPv6 global address(es): 100::2
 Peer local circuit ID: 1
 Peer circuit SNPA address: 000c-293b-c4be
 Uptime: 00:05:07
 Adj protocol:  IPv4
 IPv4 adjacency state: Up
 Adj P2P three-way handshake: No
Graceful Restart capable
   Restarting signal: No
   Suppress adjacency advertisement: No
 Local topology:
   0
 Remote topology:
   0
 Local BFD support:
   (MTID:0, IPv4)
 Remote BFD support:
   (MTID:0, IPv4)
 System ID: 0000.0000.0002
 Interface: XGE1/0/3                Circuit Id:  001
 State: Up     HoldTime: 27s        Type: L1L2         PRI: --
 Peer IP address(es): 192.168.220.30
 Peer circuit SNPA address: 000c-29fd-ed69
 Uptime: 00:05:07
 Adj protocol:  IPv4
 Adj P2P three-way handshake: Yes
   Peer extended circuit ID: 2
 Local topology:
   0
 Remote topology:
   0
 Local BFD support:
   (MTID:0, IPv4)
 Remote BFD support:
   (MTID:0, IPv4)
Table 41 Command output
System ID
System ID of the neighbor.
Interface connecting to the neighbor.
Circuit Id
Circuit ID.
·     For broadcast links, if no DIS is elected, this field displays ---. If a DIS is elected, this field displays the ID of the DIS.
·     For P2P links, this field always displays 001.
Circuit state.
HoldTime
Within the holdtime, if no hellos are received from the neighbor, the neighbor is considered down. If a hello is received, the holdtime is reset to the initial value.
Circuit type:
·     L1—Means the circuit type is Level-1 and the neighbor is a Level-1 router.
·     L2—Means the circuit type is Level-2 and the neighbor is a Level-2 router.
·     L1(L1L2)—Means the circuit type is Level-1 and the neighbor is a Level-1-2 router.
·     L2(L1L2)—Means the circuit type is Level-2 and the neighbor is a Level-1-2 router.
·     L1L2—Means the circuit type is Level-1-2 and the neighbor is a Level-1-2 router.
PRI
DIS priority of the neighbor.
Area address(es)
Area address of the neighbor.
Peer IP address(es)
IP address of the neighbor.
Peer IPv6 addresses(es)
IPv6 address of the neighbor.
Global unicast IPv6 address of the remote interface.
Uptime
Time elapsed since the neighbor relationship was formed.
Adj Protocol
Adjacency protocol: IPv4 or IPv6.
IPv4 adjacency state: Up or Down.
This field is not displayed if IPv4 is not supported.
IPv6 adjacency state
IPv6 adjacency state: Up or Down.
This field is not displayed if IPv6 is not supported.
Adjacency not up
Reason why the adjacency relationship is down: Waiting for BFD session to come up.
This field is no longer displayed after the adjacency relationship comes up.
Circuit ID of the neighbor.
SNPA address of the neighbor.
Indicates whether the neighbor supports P2P three-way handshake.
Extended circuit ID of the neighbor interface. This field is available when the neighbor supports three-way handshake.
The neighbor has the GR helper capability.
Restarting signal
RR flag.
SA flag.
Local topology
List of topologies supported by the local interface.
Remote topology
List of topologies supported by the neighbor interface.
Local BFD support
Support of the local end for adjacency establishment and maintenance control based on BFD session state:
·     (MTID:0, IPv4)—Adjacency establishment and maintenance control based on BFD session state is supported in IPv4 unicast topology 0.
·     (MTID:0, IPv6)—Adjacency establishment and maintenance control based on BFD session state is supported in IPv6 unicast topology 0.
·     (MTID:2, IPv6)—Adjacency establishment and maintenance control based on BFD session state is supported in IPv6 unicast topology 2.
This field is not displayed if the local end does not support adjacency establishment and maintenance control based on BFD session state.
Remote BFD support
Support of the remote end for adjacency establishment and maintenance control based on BFD session state:
This field is not displayed if the remote end does not support adjacency establishment and maintenance control based on BFD session state.
# Display IS-IS neighbor statistics.
<Sysname> display isis peer statistics
                    Peer Statistics information for IS-IS(1)
  Type              IPv4 Up/Init              IPv6 Up/Init
  LAN Level-1             1/0                       0/0
  LAN Level-2             1/0                       0/0
  P2P                     0/0                       0/0
Table 42 Command output
Neighbor type:
·     LAN Level-1—Number of Level-1 neighbors whose network type is broadcast.
·     LAN Level-2—Number of Level-2 neighbors whose network type is broadcast.
·     P2P—Number of neighbors whose network type is P2P.
IPv4 Up
Number of IPv4 neighbors in up state.
IPv4 Init
Number of IPv4 neighbors in init state.
IPv6 Up
Number of IPv6 neighbors in up state.
IPv6 Init
Number of IPv6 neighbors in init state.
display isis peer hello-received
Use display isis peer hello-received to display information about hello packets received from neighbors.
display isis peer hello-received [ process-id ]
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information for all IS-IS processes.
# Display information about hello packets received from neighbors for IS-IS process 1.
<Sysname> display isis peer hello-received 1
                      Peer Hello information for IS-IS(1)
 Interface: XGE3/0/1                 Circuit Id: 0000.0000.0002.01
 First 3 L1 hello packets received:
   2019-11-21 15:10:14:732
   2019-11-21 15:10:23:618
 Last 3 L1 hello packets received:
   2019-11-21 16:21:39:078
   2019-11-21 16:21:42:383
   2019-11-21 16:21:45:721
 System ID: 0000.0000.0003
 First 3 L2 hello packets received:
   2019-11-21 15:10:14:734
   2019-11-21 15:10:24:090
 Last 3 L2 hello packets received:
   2019-11-21 16:21:45:722
Table 43 Command output
System ID
Local interface connected to the neighbor.
Circuit ID
Circuit ID.
First 3 xx hello packets received
Time when the first three hello packets were received, where xx represents the hello packet type:
·     L1—Level-1 hello packets.
·     L2—Level-2 hello packets.
·     P2P—P2P hello packets.
Last 3 xx hello packets received
Time when the last three hello packets were received before this command was executed, where xx represents the hello packet type:
display isis peer lsp-purge-received
Use display isis peer lsp-purge-received to display information about the purge LSPs received from neighbors.
display isis peer lsp-purge-received [ system-id system-id ] [ process-id ]
system-id system-id: Specifies a neighbor by its system ID. A system ID is a hexadecimal string in xxxx.xxxx.xxxx format. If you do not specify any eighbor, this command displays information about all purge LSPs received from neighbors.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all purge LSPs received from neighbors in IS-IS processes.
Upon receiving an LSP with a checksum error, the local device determines that the LSP advertisement source is in abnormal state, and performs the following operations:
1.     Sets the lifetime of the LSP to 0.
2.     Deletes the route destined for the LSP advertisement source.
3.     Generates an LSP purge packet for the LSP and floods the packet within the current routing domain.
When other devices receive the LSP purge packet, they also perform the same operations as the local device unless the LSP advertisement source generates a new LSP. If those devices find that the new LSP still has a checksum error, they repeat the above operations.
To view information about the purge LSPs received from neighbors, use this command. The displayed LSP purge packet information include packet reception time, LSP ID, and LSP sequence number.
# Display information about all purge LSPs received from neighbors in IS-IS process 1.
<Sysname> display isis peer lsp-purge-received 1
                      Received purge packet information for IS-IS(1)
 Interface: XGE3/0/1                 Circuit ID: 0000.0000.0002.01
 Last 10 L1 LSP purge packets received:
   Date       Time          LSPID                Seq Num
   2023-04-17 11:34:33:311  0000.0000.0002.01-00 0x00000001
   2023-04-17 11:34:33:323  0000.0000.0002.01-01 0x00000002
   2023-04-17 11:34:41:057  0000.0000.0002.01-02 0x00000003
 Last 10 L2 LSP purge packets received:
   2023-04-17 11:34:33:312  0000.0000.0002.01-03 0x00000004
   2023-04-17 11:34:33:324  0000.0000.0002.01-04 0x00000005
   2023-04-17 11:34:41:058  0000.0000.0002.01-05 0x00000006
 Interface: XGE3/0/2                Circuit ID: 001
   2023-04-17 11:34:33:411  0000.1111.2222.01-00 0x00000001
   2023-04-17 11:34:33:423  0000.1111.2222.01-01 0x00000002
   2023-04-17 11:34:41:457  0000.1111.2222.01-02 0x00000003
   2023-04-17 11:34:33:411  0000.1111.2222.01-03 0x00000004
   2023-04-17 11:34:33:423  0000.1111.2222.01-04 0x00000005
   2023-04-17 11:34:41:457  0000.1111.2222.01-05 0x00000006
Table 44 Command output
System ID
Local IS-IS interface connected to the neighbor.
Circuit ID
Circuit ID.
Last 10 level LSP purge packets received
Last ten purge LSPs that were received before the command was executed. The level argument represents the LSP purge packet type:
·     L1—Level-1 purge LSPs.
·     L2—Level-2 purge LSPs.
Date
Date when the LSP purge packet was received, in the format of YYYY-MM-DD. YYYY represents the year, MM represents the month, and DD represents the day.
Time
Time when the LSP purge packet was received, in the format of hh:mm:ss:xxx. hh represents the hours, mm represents the minutes, and ss represents the seconds, and xxx represents the milliseconds.
LSPID
LSP ID.
Seq Num
display isis redistribute
Use display isis redistribute to display the redistributed IS-IS routing information.
display isis redistribute [ ipv4 [ ip-address mask-length ] | ipv6 [ ipv6-address prefix-length ] ] [ level-1 | level-2 ] [ process-id ]
ipv4: Displays the redistributed IPv4 routing information.
ip-address mask-length: Specifies the destination IP address and mask length.
ipv6: Displays the redistributed IPv6 routing information.
ipv6-address prefix-length: Specifies the destination IPv6 address and prefix length. The value range for the prefix-length argument is 1 to 128.
process-id: Specifies the IS-IS process by its ID in the range of 1 to 65535.
level-1: Displays the IS-IS Level-1 routing information.
level-2: Displays the IS-IS Level-2 routing information.
If you specify neither the ipv4 nor ipv6 keyword, the command displays the redistributed IPv4 routing information.
If you do not specify an IS-IS level, this command displays both Level-1 and Level-2 routing information.
# Display redistributed IPv4 routing information.
<Sysname> display isis redistribute 1
                        Level-1 IPv4 Redistribute Table
 Type IPv4 Destination     IntCost    ExtCost    Tag        State
 D    192.168.30.0/24      0          0                     Active
 D    11.11.11.11/32       0          0
 D    10.10.10.0/24        0          0
          Type: D -Direct, I -ISIS, S -Static, O -OSPF, B -BGP, R -RIP, E -EIGRP
Table 45 Command output
IS-IS process of the redistributed routing information.
Redistributed IPv4 routing information of IS-IS Level-1.
Level-2 IPv4 Redistribute Table
Redistributed IPv4 routing information of IS-IS Level-2.
Redistributed route type.
IPv4 Destination
IPv4 destination address.
IntCost
Internal cost of the route.
ExtCost
External cost of the route.
Tag
Tag value.
Indicates whether the route is valid.
# Display information about redistributed IPv6 IS-IS routes.
<Sysname> display isis redistribute ipv6 1
                        Level-1 IPv6 Redistribute Table
Type       : direct     Destination: 12:1::/64
IntCost    : 0          Tag        :
State      : Active
                        Level-2 IPv6 Redistribute Table
IntCost    : 0          Tag        :
State      : Active
Table 46 Command output
Redistributed route information for IS-IS process 1.
Redistributed route information of IS-IS Level-1.
Redistributed route information of IS-IS Level-2.
Redistributed route types:
·     Direct.
·     IS-ISv6.
·     Static.
·     OSPFv3.
·     BGP4+.
·     RIPng.
·     UNR.
Destination
IPv6 destination address.
IntCost
Internal route cost.
Tag
Tag value.
Indicates whether the redistributed route is valid.
display isis route
Use display isis route to display IS-IS routing information.
display isis route [ ipv4 [ ip-address mask-length | priority { critical | high | low | medium } ] | ipv6 [ ipv6-address prefix-length | priority { critical | high | low | medium } ] ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv4: Displays IS-IS IPv4 routing information.
ip-address mask-length: Displays IS-IS IPv4 routing information for the specified IP address. The mask-length argument is in the range of 0 to 32.
ipv6: Displays IS-IS IPv6 routing information.
ipv6-address prefix-length: Displays IS-IS IPv6 routing information for the specified IPv6 address. The prefix-length argument is in the range of 0 to 128.
priority { critical | high | low | medium }: Specifies a route convergence priority. Options include critical, high, low, and medium. If you do not specify this keyword, this command displays IS-IS routing information for all convergence priorities.
level-1: Displays Level-1 IS-IS routing information.
level-2: Displays Level-2 IS-IS routing information.
verbose: Displays detailed IS-IS IPv4 routing information. If you do not specify this keyword, the command displays brief IS-IS IPv4 routing information
process-id: Displays IS-IS IPv4 routing information for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays routing information for all IS-IS processes.
If you specify neither the ipv4 nor ipv6 keyword, the command displays IS-IS IPv4 routing information.
If you do not specify a level, this command displays both Level-1 and Level-2 routing information.
# Display brief IS-IS IPv4 routing information.
<Sysname> display isis route
                         Level-1 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 8.8.8.0/24           10         NULL    XGE1/0/2        Direct          D/L/-
 9.9.9.0/24           20         NULL    XGE1/0/2        8.8.8.5         R/L/-
                         Level-2 IPv4 Forwarding Table
 8.8.8.0/24           10         NULL                                    D/L/-
Table 47 Command output
Route information for IS-IS process 1.
IS-IS IPv4 routing information for Level-1.
IS-IS IPv4 routing information for Level-2.
IPv4 Destination
IntCost
Internal cost.
ExtCost
External cost.
ExitInterface
Interface type and number of the output interface, name of the SRv6 TE policy, or ID of the SRv6 TE policy group.
NextHop
Next hop.
Flags
Routing state flag:
·     D—Direct route.
·     R—The route has been added into the routing table.
·     L—The route has been advertised in an LSP.
·     U—Penetration flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
# Display detailed IS-IS IPv4 routing information.
<Sysname> display isis route verbose
 IPv4 Dest : 8.8.8.0/24          Int. Cost  : 10               Ext. Cost  : NULL
 Admin Tag : -                   Src Count  : 2                Flag       : D/L/-
 InLabel   : 4294967295          InLabel Flag: -/-/-/-/-/-
 Priority  : Low
 NextHop   :                     Interface  :                  ExitIndex  :
    Direct                             XGE1/0/2                   0x00000000
 Nib ID    : 0x0                 OutLabel   : 4294967295       OutLabelFlag: -
 LabelSrc  : N/A                 Delay Flag : N/A
 FirstFlushTime: 01h21m39s       LatestUpdateTime: 01h21m39s
 IPv4 Dest : 9.9.9.0/24          Int. Cost  : 20               Ext. Cost  : NULL
 Admin Tag : -                   Src Count  : 1                Flag       : R/L/-
 Priority  : Low
    8.8.8.5                            XGE1/0/2                   0x00000003
 FirstFlushTime: 01h21m38s       LatestUpdateTime: 01h21m38s
 Remote-LFA:
  Interface : XGE3/0/3
  BkNextHop : 31.1.1.3           LsIndex    : 0x01000002
  Tunnel destination address: 4.4.4.9
  Backup label: {2174}
 TI-LFA:
  Interface : XGE3/0/2
  BkNextHop : 104.1.1.1          LsIndex    : 0x000001
  Backup label stack(top->bottom): {16020, 2174}
  Route label: 4294967295
      InLabel flags: R-Readvertisement, N-Node SID, P-no PHP
                     E-Explicit null, V-Value, L-Local
      OutLabelFlags: E-Explicit null, I-Implicit null, N-Normal, P-SR label prefer
 Priority  : Low
 Nib ID    : 0x14000003          OutLabel   : 4294967295       OutLabelFlag: -
 FirstFlushTime: 15h28m49s       LatestUpdateTime: 15h28m49s
Table 48 Command output
IPv4 Dest
IPv4 destination.
Int. Cost
Internal cost.
Ext. Cost
External cost.
Admin Tag
Tag.
Src Count
Count of advertising sources.
Flag
Route state flag:
·     R—The route has been installed into the routing table.
·     L—The route has been flooded in an LSP.
·     U—Route leaking flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
NextHop
Next hop.
ExitIndex
Index of the output interface.
Nib ID
ID assigned by the routing management module (next hop index).
InLabel
Incoming label.
InLabel flag
Incoming label flag:
Priority
Route convergence priority. Options include critical, high, medium, and low.
LabelSrc
Label source:
·     SR—The label is allocated by the SR node.
·     SRMS—The label is allocated by the segment routing mapping server (SRMS).
·     N/A—No label exists.
Delay Flag
Microloop avoidance delay flag:
·     D—Microloop avoidance is configured. Route convergence is delayed.
·     N/A—Microloop avoidance is not configured or the microloop avoidance RIB-update-delay timer has expired. Route convergence is in progress.
FirstFlushTime
Interval between the following timepoints:
·     When IS-IS installed the IPv4 route into the IP routing table for the first time.
·     When the display isis route verbose command was executed.
The value of this field is in the format of hh:mm:ss. hh represents the hours, mm represents the minutes, and ss represents the seconds.
If the route is not flushed to the RIB, this field displays N/A.
LatestUpdateTime
·     When IS-IS updated the IPv4 route in the IP routing table most recently.
OutLabel
Outgoing label.
OutLabelFlag
Outgoing label flag:
·     E—Explicit null flag. The upstream neighbor must replace the SID with an explicit null flag before forwarding the packets.
·     I—Implicit null flag. The upstream neighbor must replace the SID with an implicit null flag before forwarding the packets. This flag is not supported in the current software version.
·     N—Normal flag.
·     P—SR label preferred flag.
TI-LFA
TI-LFA backup information.
Inter-Level-TI-LFA
Inter-level TI-LFA backup information.
BKNextHop
TI-LFA/Remote LFA backup next hop.
LsIndex
Label stack index.
Backup path label stack. N/A indicates that no label stack exists.
Remote-LFA
Remote LFA backup information.
LDP tunnel destination address.
Backup label
Backup label to the PQ node. N/A indicates that no label exists.
# Display IPv6 IS-IS routing information.
<Sysname> display isis route ipv6
                         Level-1 IPv6 forwarding table
 Destination: 2001:1::                                PrefixLen: 64
 Flag       : R/L/-                                   Cost     : 20
 Next hop   : FE80::200:5EFF:FE64:8905                Interface: XGE3/0/1
 Destination: 2001:2::                                PrefixLen: 64
 Flag       : D/L/-                                   Cost     : 10
 Next hop   : Direct                                  Interface: XGE3/0/1
 Destination: 4::5                                    PrefixLen: 128
 Next hop   : 3::3                                    Interface: SRPG1
                         Level-2 IPv6 forwarding table
 Flag       : -/-/-                                   Cost     : 20
Table 49 Command output
Destination
IPv6 destination prefix.
PrefixLen
Prefix length.
Flag/Flags
Route flag:
·     D—This is a direct route.
·     U—Route leaking flag, indicating that the Level-1 route is from Level-2. U means the route will not be returned to Level-2.
Cost
Route cost.
Next hop
Next hop.
Output interface type and number, SRv6 TE policy name, or SRv6 TE policy group ID.
# Display detailed IPv6 IS-IS routing information.
<Sysname> display isis route ipv6 verbose
 IPv6 dest   : 2::2/128
 Flag        : R/L/-                       Cost        : 10
 Admin tag   : -                           Src count   : 1
 Algorithm   : 0
 Priority    : Medium
 Nexthop     : FE80::86FB:DDFF:FE3F:1007
 NexthopFlag : D
 Interface   : XGE3/0/2                    Delay Flag : N/A
 BkNexthop   : FE80::86FB:D4FF:FE1B:E05
 BkInterface : XGE3/0/1
 Nib ID      : 0x24000008
 FirstFlushTime: 01h25m56s                 LatestUpdateTime: 01h25m56s
 IPv6 dest   : 2012::/64
 Admin tag   : -                           Src count   : 2
 Algorithm   : 0
 Priority    : Low
 Nexthop     : Direct
 NexthopFlag : -
 Nib ID      : 0x0
 FirstFlushTime: 00h51m32s                 LatestUpdateTime: 00h51m32s
 IPv6 dest   : 2023::/64
 Algorithm   : 0
 Priority    : Low
 NexthopFlag : D
 Interface   : XGE3/0/1                    Delay Flag : N/A
 Nib ID      : 0x24000007
 IPv6 dest   : 2013::/64
 Algorithm   : 0
 Priority    : Low
 Nexthop     : Direct
 NexthopFlag : -
 Nib ID      : 0x0
 FirstFlushTime: 00h50m51s                 LatestUpdateTime: 00h50m51s
 IPv6 dest   : 4::5/128
 Flag        : R/-/-                       Cost        : 20
 Nexthop     : 3::3
 Interface   : SRPG1
 Nib ID      : 0x2400000c
 FirstFlushTime: 00h52m04s                 LatestUpdateTime: 00h52m04s
 Flag        : -/-/-                       Cost        : 10
 Nexthop     : -
 NexthopFlag : -
 Interface   : -
 Nib ID      : -
 Admin tag   : -                           Src count   : 3
 Algorithm   : 0
 Priority    : Low
 Nexthop     : Direct
 NexthopFlag : -
 Nib ID      : 0x0
 Nexthop     : -
 NexthopFlag : -
 Interface   : -
 Nib ID      : -
 Algorithm   : 0
 Priority    : Low
 Nexthop     : Direct
 NexthopFlag : -
 Nib ID      : 0x0
Table 50 Command output
IPv6 dest
IPv6 destination address and prefix.
Flag/Flags
Route flag:
·     D—The route is a direct route.
·     U—Route leaking flag, indicating the Level-1 route is from Level-2. U means the route will not be returned to Level-2.
Cost
Route cost.
Admin tag
Administrative tag.
Src count
Number of advertisement sources.
Algorithm
Algorithm ID. 0 represents the SPF algorithm, and a value of 128 to 255 represents the flexible algorithm.
Priority
Nexthop
Next hop.
NextthopFlag
Next hop flag. A value of D indicates that the next hop is directly connected to the advertisement source.
Output interface type and ID, SRv6 TE policy name, or , or SRv6 TE policy group ID.
Delay Flag
Mirror FRR
Mirror FRR path information.
BkNexthop
Backup next hop.
BkInterface
Backup output interface.
SR microloop label stack (top->bottom)
SR microloop label stack arranged from top to bottom.
TI-LFA
Inter-Level-TI-LFA
BKNextHop
TI-LFA backup next hop.
LsIndex
Label stack index.
Backup label stack (top->bottom)
Backup path label stack arranged from top to bottom. N/A indicates that no label stack exists.
Nib ID
Next hop index assigned by the routing management module.
FirstFlushTime
·     When IS-IS installed the IPv6 route into the IP routing table for the first time.
·     When the display isis route ipv6 verbose command was executed.
LatestUpdateTime
·     When IS-IS updated the IPv6 route in the IP routing table most recently.
display isis route bier
Use display isis route bier to display information about IS-IS BIER routes.
display isis route bier sub-domain sub-domain-id ipv6 [ ipv6-address prefix-length ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
sub-domain sub-domain-id: Specifies a BIER sub-domain by its ID. The value range for the sub-domain-id argument is 0 to 255.
ipv6: Displays information about IPv6 IS-IS BIER routes.
ipv6-address prefix-length: Specifies an IS-IS BIER route by its IPv6 destination address and prefix length. The value range for the prefix-length argument is 0 to 128. If you do not specify an IS-IS BIER route, this command displays information about all IPv6 IS-IS BIER routes.
level-1: Displays information about Level-1 BIER routes.
level-2: Displays information about Level-2 BIER routes.
verbose: Displays detailed information about IS-IS BIER routes. If you do not specify this keyword, the command displays brief IS-IS BIER route information.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, the command displays BIER route information for all IS-IS processes.
If you do not specify a level, the command displays information about Level-1 and Level-2 BIER routes.
# Display brief information about IPv6 IS-IS BIER routes.
<Sysname> display isis route bier sub-domain 0 ipv6
                      Bier Route information for IS-IS(1)
                   Level-1 Sub-domain 0 IPv6 forwarding table
 Destination   : 2020::20                                PrefixLen: 128
 Flag          : R                                       Cost     : 0
 EncapType     : G-BIER                                  BFR-ID   : 1
 Nbr BFR prefix: 2020::20                                Interface: XGE3/0/1
 Destination   : 1919::19                                PrefixLen: 128
 Flag          : R                                       Cost     : 0
                           Flags: R-Added to Bier Rib
Table 51 Command output
Destination
Prefix of the IPv6 destination address.
PrefixLen
Prefix length.
Flag
Route flag. Flag R indicates that the route has been added into the routing table.
Cost
Routing cost.
EncapType
·     BIERv6—BIER IPv6.
BFR-ID
Nbr BFR prefix
BFR prefix of the next hop.
Output interface.
# Display detailed information about IPv6 IS-IS BIER routes.
<Sysname> display isis route bier sub-domain 0 ipv6 verbose
 IPv6 dest         : 2001::1/128
 Flag              : R               Cost: 10
 BFR-ID            : 1
 G-BIER MPRA       : 3333::3333
 PHP request       : No
 EncapType         : G-BIER
   Max SI          : 2               BSL : 128             BIFT-ID base: -
 NextHopCnt        : 1
   NextHop         : FE80::200:5EFF:FE64:8905
   Nbr system ID   : 0000.0000.0010.00
   Nbr BFR prefix  : 2001::1
   PHP             : No
   Delay Flag      : N/A
 IPv6 dest         : 2001::2/128
 Flag              : R               Cost: 10
 BFR-ID            : 2
 PHP request       : No
 EncapType         : G-BIER
 NextHopCnt        : 1
   PHP             : No
   Delay Flag      : N/A
Table 52 Command output
IPv6 dest
Flag
Cost
Routing cost.
BFR-ID
G-BIER MPRA
End.BIER SID
End.BIER SID value.
End.MSR6 SID
End.MSR6 SID value.
PHP request
Whether to pop out the request node on the penultimate hop:
·     Yes—When the node is the penultimate hop, it pops out the request node.
·     No—When the node is not the penultimate hop, it pops out the request node.
EncapType
·     BIERv6—BIER IPv6.
Max SI
BSL
BIFT-ID base
NextHopCnt
Number of BIER next hops.
Output interface.
Nbr system ID
Nbr BFR prefix
BFR-ID ranges
BFR-ID ranges.
Delay Flag
TI-LFA
BkNbr BFR prefix
BFR prefix of the backup BIER route next hop.
BKNextHop
LsIndex
Label stack index.
BkNexthop
Backup next hop.
BkInterface
Backup egress interface.
PHP
Whether the node is enabled with PHP.
display isis savnet sav-table
Use display isis savnet sav-table to displays the route entries that an IS-IS process delivered to SAVNET.
display isis [ process-id ] savnet sav-table ipv6 [ ipv6-address [ prefix-length ] ] [ interface-type interface-number ]
context-admin
context-operator
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the route entries that each IS-IS process delivered to SAVNET.
ipv6-address [ prefix-length ]: Specifies an IPv6 destination address. If you do not specify the ipv6-address argument, the command displays all route entries that IS-IS delivered to SAVNET. If you specify the ipv6-address argument without specifying the prefix-length argument, the command displays the route entry whose destination address has the longest matching prefix.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays all route entries that IS-IS delivered to SAVNET.
# Display the route entries that IS-IS process 1 delivered to SAVNET.
<Sysname> display 1 isis savnet sav-table ipv6
                   SAVNET sav-table information for IS-IS(1)
  Destination/Prefix length: 1::1/128
    Total: 1
      Interface : XGE3/0/1                    Flag: F
  Destination/Prefix length: 2::2/128
    Total: 1
  Destination/Prefix length: 2024::/64
    Total: 1
Table 53 Command output
Prefix and prefix length of a network to which the device can route traffic through an IPv6 IS-IS output interface enabled with SAVNET calculation.
Total
Number of network prefixes to which the device can route traffic through an IPv6 IS-IS output interface enabled with SAVNET calculation.
Interface type and number of an IPv6 IS-IS interface enabled with SAVNET calculation.
Flag
Prefix status flag:
·     F—The prefix has been flushed to SAVNET.
·     D—The prefix is waiting for deletion.
display isis spf-tree
Use display isis spf-tree to display IS-IS SPF tree information.
display isis spf-tree [ ipv4 | ipv6 ] [ [ level-1 | level-2 ] | [ source-id source-id | verbose ] ] * [ process-id ]
ipv4: Displays IS-IS IPv4 SPF tree information.
ipv6: Displays IS-IS IPv6 SPF tree information.
level-1: Displays Level-1 IS-IS SPF tree information. If you do not specify a level, the command displays both Level-1 and Level-2 SPF tree information.
level-2: Displays Level-2 SPF tree information. If you do not specify a level, the command displays both Level-1 and Level-2 SPF tree information.
source-id source-id: Displays detailed information about an SPF node. The source-id argument represents the system ID of the SPF node, in XXXX.XXXX.XXXX.XX format.
verbose: Displays detailed IS-IS SPF tree information. If you do not specify this keyword, the command displays brief IS-IS SPF tree information.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays SPF tree information for all IS-IS processes.
If you specify neither the ipv4 nor ipv6 keyword, the command displays IS-IS IPv4 SPF tree information.
# Display brief IS-IS IPv4 SPF tree information.
<Sysname> display isis spf-tree
                        Shortest Path Tree for IS-IS(1)
      Flags: S-Node is on SPF tree       T-Node is on tent list
             O-Node is overload          R-Node is directly reachable
             I-Node or Link is isolated  D-Node or Link is to be deleted
             C-Neighbor is child         P-Neighbor is parent
             V-Link is involved          N-Link is a new path
             L-Link is on change list    U-Protocol usage is changed
             H-Nexthop is changed
                           Level-1 Shortest Path Tree
SpfNode            NodeFlag       SpfLink            LinkCost LinkFlag
0000.0000.0032.00  S/-/-/-/-/-
                               -->0000.0000.0032.01  10       -/-/C/-/-/-/-/-/-
                               -->0000.0000.0064.00  10       -/-/C/-/-/-/-/-/-
0000.0000.0032.01  S/-/-/R/-/-
                               -->0000.0000.0064.00  0        -/-/C/-/-/-/-/-/-
                               -->0000.0000.0032.00  0        -/-/-/P/-/-/-/-/-
0000.0000.0064.00  S/-/-/R/-/-
                               -->0000.0000.0032.00  10       -/-/-/P/-/-/-/-/-
                               -->0000.0000.0032.01  10       -/-/-/P/-/-/-/-/-
                           Level-2 Shortest Path Tree
# Display detailed IS-IS IPv4 SPF tree information.
<Sysname> display isis spf-tree verbose
 SpfNode        : 0000.0000.0003.01
 Distance       : 20
 TE distance    : 20
 SRP distance   : 0
 SRPG distance  : 20
 NodeFlag       : S/-/-/-/-/-
 RelayNibID     : 0x0
 TE tunnel count: 0
 SRP count      : 0
 SRPG count     : 0
 Nexthop count  : 1
     Neighbor   : 0000.0000.0002.00        Interface  : XGE3/0/1
     Nexthop    : 101.1.1.2
     BkNeighbor : N/A                      BkInterface: N/A
     BkNexthop  : N/A
 Remote-LFA:
    Protect     : Link
    RLFANeighbor: 0000.0000.0003.00
    PQNode      : 0000.0000.0004.00
    PQNodePrefix: 4.4.4.9/32
    OutLabel    : 2174
 TI-LFA:
  TiLfaNeighbor : 0000.0000.0004.00        TiLfaInterface: XGE3/0/2
  TiLfaNexthop  : 104.1.1.1
  PNode SrcID   : 0000.0000.0003.00        QNode SrcID   : 0000.0000.0002.00
  PNode prefix  : 33.33.33.33              PNode SidIndex: 20
  Protect       : Link
  Label stack   : {16020, 2174}
 SpfLink count  : 2
 -->0000.0000.0002.00
    LinkCost    : 0
    LinkNewCost : 0
    MplsTeCost  : 16777215
    DelayCost   : 16777215
    LinkFlag    : -/-/-/P/-/-/-/-/-
    LinkSrcCnt  : 1
     Type       : Remote       Interface : N/A
     Cost       : 0            Nexthop   : N/A
     InterfaceIP: 12.1.1.1     NeighborIP: N/A
     MplsTeCost : 16777215     DelayCost : 16777215
 -->0000.0000.0003.00
    LinkCost    : 0
    LinkNewCost : 0
    LinkFlag    : -/-/C/-/-/-/-/-/-
    LinkSrcCnt  : 1
 SpfNode        : 0000.0000.0004.00
 Distance       : 10
 TE distance    : 10
 SRP distance   : 0
 SRPG distance  : 10
 RelayNibID     : 0x14000000
 TE tunnel count: 1
     Destination: 4.4.4.4                  Interface  : Tun0
     TE cost    : 10                       Final cost : 10
 SRP count      : 0
 SRPG count     : 0
 Nexthop count  : 2
     Neighbor   : 0000.0000.0004.00        Interface  : Tun0
     Nexthop    : 4.4.4.4
     BkNexthop  : N/A
     Neighbor   : 0000.0000.0004.00        Interface  : XGE3/0/1
     Nexthop    : 1.1.1.3
     BkNexthop  : N/A
 SpfLink count  : 1
 -->0000.0000.0004.04
    LinkCost    : 10
    LinkNewCost : 10
    LinkSrcCnt  : 1
     Cost       : 10           Nexthop   : N/A
     AdvMtID    : 0
 SpfNode        : 0000.0000.0004.04
 Distance       : 10
 TE distance    : 10
 SRP distance   : 0
 SRPG distance  : 10
 NodeFlag       : S/-/-/R/-/-
 RelayNibID     : 0x14000001
 TE tunnel count: 0
 SRP count      : 0
 SRPG count     : 0
 Nexthop count  : 0
 SpfLink count  : 2
 -->0000.0000.0001.00
    LinkCost    : 0
    LinkNewCost : 0
    MplsTeCost  : 0
    DelayCost   : 0
    LinkSrcCnt  : 1
     InterfaceIP: N/A          NeighborIP: N/A
     MplsTeCost : 0            DelayCost : 0
 -->0000.0000.0004.00
    LinkCost    : 0
    LinkNewCost : 0
    MplsTeCost  : 0
    DelayCost   : 0
    LinkSrcCnt  : 1
     Type       : Remote       Interface : XGE3/0/1
     Cost       : 0            Nexthop   : 1.1.1.3
 Distance       : 20
 TE distance    : 20
 SRP distance   : 0
 SRPG distance  : 20
 RelayNibID     : 0x0
 TE tunnel count: 0
 SRP count      : 0
 SRPG count     : 0
 Nexthop count  : 1
     Nexthop    : 101.1.1.2
     BkNexthop  : N/A
 SpfLink count  : 2
    LinkCost    : 0
    LinkNewCost : 0
    MplsTeCost  : 0
    DelayCost   : 0
    LinkSrcCnt  : 1
    LinkCost    : 0
    LinkNewCost : 0
    MplsTeCost  : 0
    DelayCost   : 0
    LinkSrcCnt  : 1
 Distance       : 10
 TE distance    : 10
 SRP distance   : 0
 SRPG distance  : 10
 RelayNibID     : 0x0
 TE tunnel count: 1
 SRP count      : 0
 SRPG count     : 0
 Nexthop count  : 2
     Nexthop    : 4.4.4.4
     BkNexthop  : N/A
     Nexthop    : 1.1.1.3
     BkNexthop  : N/A
 SpfLink count  : 1
    LinkCost    : 10
    LinkNewCost : 10
    LinkSrcCnt  : 1
     AdvMtID: 0
 Distance       : 10
 TE distance    : 10
 SRP distance   : 0
 SRPG distance  : 10
 RelayNibID     : 0x0
 TE tunnel count: 0
 SRP count      : 0
 SRPG count     : 0
 Nexthop count  : 0
 SpfLink count  : 2
    LinkCost    : 0
    LinkNewCost : 0
    MplsTeCost  : 0
    DelayCost   : 0
    LinkSrcCnt  : 1
    LinkCost    : 0
    LinkNewCost : 0
    MplsTeCost  : 0
    DelayCost   : 0
    LinkSrcCnt  : 1
Table 54 Command output
SpfNode
ID of the topology node.
Distance
Shortest distance from the root node to the local node.
TE distance
Shortest distance from the root node to the local node (including tunnel links). If tunnel is not configured, TE distance equals to Distance.
SRP distance
Shortest distance from the root node to the local node (including SRv6 TE policy links). If no SRv6 TE policy is configured, SRP distance equals to Distance.
SRPG distance
Shortest distance from the root node to the local node (including SRv6 TE policy group links). If no SRv6 TE policy group is configured, SRPG distance equals to Distance.
NodeFlag
Node flag:
·     S—The node is on the SPF tree.
·     T—The node is on the tent list.
·     O—The node is overloaded.
·     R—The node is directly connected.
·     I—The node is isolated.
·     D—The node is to be deleted.
RelayNibID
Next hop ID of the node after route recursion.
TE tunnel count
Number of tunnels with the node as the destination.
SRP count
Number of SRv6-TE policies with the node as the endpoint.
SRPG count
Number of SRv6-TE policy groups with the node as the endpoint.
PolicyName
Name of the SRv6 TE policy with the node as the destination node.
GroupID
ID of the SRv6 TE policy group with the node as the destination node.
EndPoint
Destination node of the SRv6 TE policy or SRv6 TE policy group.
Color
Color value of the SRv6 TE policy.
Auto cost
IGP metric configured for the SRv6 TE policy or SRv6 TE policy group.
Final cost
Effective IGP metric of the SRv6 TE policy or SRv6 TE policy group.
Auto route
Type of automatic route advertisement. Only Shortcut is supported in the current software version.
Whether the SRv6 TE policy or SRv6 TE policy group is active.
Host only
Whether the nexthops of host routes can be iterated to the SRv6 TE policy or SRv6 TE policy group.
RoutePolicy
Routing policy specified for automatic route advertisement. If no routing policy is specified, this field displays a hyphen (-).
IncludeIPv4
Whether recursion to the SRv6 TE policy or SRv6 TE policy group is enabled for IPv4 IS-IS routes:
·     Enabled—Both IPv4 and IPv6 IS-IS routes can be recursed to the SRv6 TE policy or SRv6 TE policy group.
·     Disabled—IPv4 IS-IS routes cannot be recursed to the SRv6 TE policy or SRv6 TE policy group. Only IPv6 IS-IS routes can be recursed to the SRv6 TE policy or SRv6 TE policy group.
Destination
Destination router.
TE cost
IGP cost of the TE tunnel.
Final cost
Final cost of the TE tunnel.
Nexthop count
Next hop count.
Nexthop
Primary next hop of the node or the link advertising source.
MADuration
Microloop avoidance RIB-update-delay timer in milliseconds.
MALStack
Microloop avoidance label stack.
AdvMtID
Topology from which the routing information is learned:
·     0—Base topology.
·     6-4094—Other topologies.
Primary output interface of the node or the link advertising source.
BkNexthop
Backup next hop.
BkInterface
Neighbor
ID of the primary next hop neighbor.
BkNeighbor
ID of the backup next hop neighbor.
Inter-level-TI-LFA
Shortest path tree information calculated by inter-level TI-LFA.
TiLfaNeighbor
ID of the TI-LFA backup next hop neighbor.
TiLfaInterface
Output interface of the TI-LFA backup next hop.
TiLfaNexthop
PNode SrcID
Source ID of the P node.
QNode SrcID
Source ID of the Q node.
PNode prefix
Prefix of the P node. N/A indicates that the prefix of the destination node is not displayed in the P space.
PNode SidIndex
Index value of the prefix SID for the P node. N/A indicates that the prefix SID of the destination node is not displayed in the P space.
Protect
TI-LFA/Remote LFA traffic protection type:
·     Link—Link protection. The direct primary link is excluded from backup path calculation.
·     Node—Node protection. The primary next hop node is excluded from backup path calculation.
·     SrlgLink—SRLG-disjoint link protection. The following links are excluded from backup path calculation:
¡     Direct primary link.
¡     Local links in the same SRLG as the direct primary link.
·     SrlgNode—SRLG-disjoint node protection. The following items are excluded from backup path calculation:
¡     Primary next hop node.
Label stack
Label stack. N/A indicates that no label stack exists.
SpfLink
Topology link.
SpfLink count
Number of topology links.
LinkCost
Link cost.
LinkNewCost
New link cost.
MplsTeCost
TE metric of the IS-IS interface. The maximum value is 16777215.
DelayCost
Link delay of the IS-IS interface. The maximum value is 16777215.
LinkFlag
Link flag:
·     I—The link is isolated.
·     D—The link is to be deleted.
·     C—The neighbor is a child node.
·     P—The neighbor is the parent node.
·     V—The link is involved.
·     N—The link is a new path.
·     L—The link is on the change list.
·     U—The protocol usage of the link is changed.
·     H—The next hop of the link is changed.
LinkSrcCnt
Number of link advertising sources.
Type of the link advertising source:
·     Adjacent—The link advertising source is a local neighbor.
·     Remote—The link advertising source is advertised by a remote node in an LSP.
Cost
Cost of the link advertising source.
InterfaceIP
Interface IP address.
NeighborIP
Neighbor IP address.
PolicyName
Name of the SRv6 TE policy with the node as the endpoint node.
EndPoint
Destination node of the SRv6 TE policy.
Color
Auto cost
IGP metric of the SRv6 TE policy.
Final cost
Effective IGP metric of the SRv6 TE policy.
Auto route
Automatic route type. Only Shortcut is supported in the current software version.
Whether the SRv6 TE policy is active.
Remote-LFA
RLFANeighbor
System ID of the remote LFA backup next hop.
PQNode
System ID of the PQ node.
PQNodePrefix
PQ node prefix.
OutLabel
# Display brief IPv6 IS-IS SPF tree information.
<Sysname> display isis spf-tree ipv6
# Display detailed Level-1 IPv6 IS-IS SPF tree information.
<Sysname> display isis spf-tree ipv6 level-1 verbose
 SpfNode        : 0000.0000.0032.00
 Distance       : 0
 TE distance    : 0
 SRP distance   : 0
 SRPG distance  : 0
 LinkTag        : 100
 RelayNibID     : 0x0
 TE tunnel count: 0
 SRP count      : 0
     PolicyName : p1v6
     Color      : 20                       EndPoint  : 3::3
     Auto cost  : -5                       Final cost: 15
     Auto route : Shortcut                 State     : Avtive
     Host only  : Enabled
     RoutePolicy: RT1
 SRPG count     : 1
     GroupID    : 1
     EndPoint   : 4::4
     Host only  : Disabled
     RoutePolicy: RT1
 Nexthop count  : 0
 SpfLink count  : 2
    LinkCost    : 10
    LinkNewCost : 10
    LinkSrcCnt  : 1
     Type       : Adjacent     Interface : N/A
    LinkCost    : 10
    LinkNewCost : 10
    LinkSrcCnt  : 1
     Type       : Adjacent     Interface : Tun1
     Cost       : 10           Nexthop   : FE80::A0A:A40
 SpfNode        : 0000.0000.0032.01
 Distance       : 10
 TE distance    : 10
 SRP distance   : 0
 SRPG distance  : 0
 RelayNibID     : 0x0
 TE tunnel count: 0
 SRP count      : 0
 SRPG count     : 0
 Nexthop count  : 0
 SpfLink count  : 2
    LinkCost    : 0
    LinkNewCost : 0
    MplsTeCost  : 0
    DelayCost   : 0
    LinkSrcCnt  : 1
     Type       : Adjacent     Interface : XGE3/0/2
     Cost       : 10           Nexthop   : FE80::200:12FF:FE34:1
    LinkCost    : 0
    LinkNewCost : 0
    MplsTeCost  : 0
    DelayCost   : 0
    LinkSrcCnt  : 1
 SpfNode        : 0000.0000.0064.00
 Distance       : 10
 TE distance    : 10
 SRP distance   : 0
 SRPG distance  : 0
 RelayNibID     : 0x0
 TE tunnel count: 0
 SRP count      : 0
 SRPG count     : 0
 Nexthop count  : 2
     Neighbor  : 0000.0000.0064.00        Interface  : XGE3/0/2
     NextHop   : FE80::200:12FF:FE34:1
     BkNeighbor: N/A                      BkInterface: N/A
     BkNextHop : N/A
     Neighbor  : 0000.0000.0064.00        Interface  : Tun1
     NextHop   : FE80::A0A:A40
     BkNextHop : N/A
 SpfLink count  : 2
    LinkCost    : 10
    LinkNewCost : 10
    LinkSrcCnt  : 1
     AdvMtID    : 0
    LinkCost    : 10
    LinkNewCost : 10
    LinkSrcCnt  : 1
     Type       : Remote       Interface : Tun1
     AdvMtID    : 0
Table 55 Command output
SpfNode
Distance
Shortest distance from the root node to the current node.
TE distance
Shortest distance from the root node to the current node (including tunnel links). If no tunnels are configured, TE distance equals Distance.
SRP distance
SRPG distance
NodeFlag
Node flag:
LinkTag
Link tag.
TE tunnel count
SRP count
PolicyName
EndPoint
Color
Color value of the SRv6 TE policy or SRv6 TE policy group.
Auto cost
Relative IGP metric of the SRv6 TE policy or SRv6 TE policy group.
Final cost
The effective IGP metric equals the specified relative IGP metric plus the smallest IGP metric of the SRv6 TE policy or SRv6 TE policy group.
Auto route
Host only
Whether the nexthops of host routes can be iterated to SRv6 TE policy groups or SRv6 TE policies.
RoutePolicy
IncludeIPv4
SRPG count
GroupID
ID of the SRv6 TE policy group with the node as the endpoint.
Nexthop count
Number of next hops.
NextHop
AdvMtID
·     0—Base topology.
BkNextHop
Backup next hop.
BkInterface
Neighbor
BkNeighbor
MADuration
SR microloop avoidance duration in milliseconds.
MALStack
SR microloop avoidance label stack.
TiLfaNeighbor
TiLfaInterface
TiLfaNexthop
PNode SrcID
QNode SrcID
PNode prefix
PNode SidIndex
Protect
Label stack
SpfLink
Topology link.
SpfLink count
LinkCost
Link cost.
LinkNewCost
New link cost.
MplsTeCost
DelayCost
LinkFlag
Link flag:
·     U—The protocol of the link is changed.
LinkSrcCnt
Cost
InterfaceIP
NeighborIP
display isis spf-tree bier
Use display isis spf-tree bier to display IPv6 BIER SPF tree information.
display isis spf-tree bier sub-domain sub-domain-id ipv6 [ [ level-1 | level-2 ] | [ source-id source-id | verbose ] ] * [ process-id ]
ipv6: Displays information about IPv6 BIER SPF trees.
level-1: Displays information about the Level-1 BIER SPF tree.
level-2: Displays information about the Level-2 BIER SPF tree.
source-id source-id: Specifies an SPF node by its system ID in the format of XXXX.XXXX.XXXX.XX. If you do not specify this option, the command displays BIER SPF tree information from all advertisement sources.
verbose: Displays detailed information about IS-IS BIER SPF trees. If you do not specify this keyword, the command displays brief BIER SPF tree information.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, the command displays BIER SPF tree information for all IS-IS processes.
If you do not specify a level, the command displays information about Level-1 and Level-2 BIER SPF trees.
# Display brief information about IPv6 BIER SPF trees in BIER sub-domain 0.
<Sysname> display isis spf-tree bier sub-domain 0 ipv6
                       BIER SPF Information for IS-IS(1)
           Flags: G-The node supports G-BIER  P-The node supports PHP request
                  V-The node supports BIERv6  M-The node supports MSR6
                  Level-1 Sub-domain 0 BIER Shortest Path Tree
SpfNode              NodeFlag    Cost       NextHopCnt         ChildLink
0000.0000.0002.00      G          0             0
                                                           -->0000.0000.0001.01
0000.0000.0001.00      G          10            1
0000.0000.0001.01      -          10            0
                  Level-2 Sub-domain 0 BIER Shortest Path Tree
# Display detailed information about IPv6 BIER SPF trees in BIER sub-domain 0.
<Sysname> display isis spf-tree bier sub-domain 0 ipv6 verbose
SpfNode             : 0000.0000.0002.01
NodeFlag            : -
Distance            : 10
Nexthop count       : 0
Child link count  : 1
SpfNode             : 0000.0000.0002.00
NodeFlag            : G
Distance            : 10
Nexthop count       : 1
    Nbr system ID   : 0000.0000.0002.00         Interface : XGE3/0/1
    Nbr BFR prefix  : 2::2
    Nexthop         : FE80::44E1:54FF:FE57:216
    PHP             : No
Child link count  : 0
SpfNode             : 0000.0000.0001.00
NodeFlag            : G
Distance            : 0
Nexthop count       : 0
-->0000.0000.0002.01
NodeFlag            : -
Distance            : 10
Nexthop count       : 0
NodeFlag            : G
Distance            : 10
Nexthop count       : 1
    PHP             : No
NodeFlag            : G
Distance            : 0
Nexthop count       : 0
NodeFlag            : -
Distance            : 10
Nexthop count       : 0
NodeFlag            : G
Distance            : 10
Nexthop count       : 1
    Nbr system ID   : 0000.0000.0002.00         Interface : Vlan100
    PHP             : No
NodeFlag            : G
Distance            : 0
Nexthop count       : 0
NodeFlag            : -
Distance            : 10
Nexthop count       : 0
NodeFlag            : G
Distance            : 10
Nexthop count       : 1
    PHP             : No
NodeFlag            : G
Distance            : 0
Nexthop count       : 0
Table 56 Command output
SpfNode
NodeFlag
Node flag:
·     G—The node supports G-BIER.
·     P—When the node is the penultimate hop, it pops out the request node.
·     V—The node supports BIERv6.
·     MThe node supports MSR6.
Distance
Nexthop count
Nbr system ID
Output interface connecting the node to the nexthop.
Nbr BFR prefix
Nexthop
Address of the next hop. If the neighbor is not directly connected, this field displays a hyphen (-).
PHP
Child link count
Number of child links.
Cost
Routing cost.
BkNexthop
Backup next hop address.
BkInterface
Backup next hop egress interface.
BkNbr system ID
System ID of the backup next hop neighbor node.
BkNbr BFR prefix
BFR prefix of the BIER route backup next hop.
TI-LFA
TiLfaNeighbor
TI-LFA backup next hop neighbor node ID.
TiLfaInterface
TI-LFA backup next hop egress interfac.
TiLfaNexthop
TI-LFA backup next hop address.
PNode SrcID
P node Source ID.
QNode SrcID
Q node Source ID.
PNode prefix
P node prefix. N/A indicates that the destination node does not display node prefix in P space.
PNode SidIndex
P node End SID. N/A indicates that the destination node is in P space or its neighbor is a P node.
Protect
BIER TI-LFA protection type:
·     Link—Link protection. The primary link is excluded from backup path calculation.
Label stack
display isis statistics
Use display isis statistics to display IS-IS statistics.
display isis statistics [ ipv4 | ipv6 ] [ level-1 | level-1-2 | level-2 ] [ process-id ]
ipv4: Displays IS-IS IPv4 statistics. If you do not specify this option, the command displays IS-IS IPv4 and IPv6 statistics.
ipv6: Displays IS-IS IPv6 statistics.
level-1: Displays IS-IS Level-1 statistics.
level-1-2: Displays IS-IS Level-1-2 statistics.
level-2: Displays IS-IS Level-2 statistics.
process-id: Displays statistics for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays the statistics for all IS-IS processes.
# Display IS-IS statistics.
<Sysname> display isis statistics
                               Level-1 Statistics
MTR(base)
Learnt routes information:
         Total IPv4 Learnt Routes in IPv4 Routing Table: 1
Imported routes information:
        IPv4 Imported Routes:
                        Static: 0       Direct: 0
                        ISIS:   0       BGP:    0
                        RIP:    0       OSPF:   0
                        EIGRP:  0       UNR:    0
                        Total Number:   0
MTR(base)
         Total IPv6 Learnt Routes in IPv6 Routing Table: 0
         IPv6 Imported Routes:
                         Static: 0       Direct: 0
                         ISISv6: 0       BGP4+:  0
                         RIPng:  0       OSPFv3: 0
                         Total Number:   0
Lsp information:
                  LSP Source ID:          No. of used LSPs
                  7777.8888.1111                  001
                               Level-2 Statistics
MTR(base)
         Total IPv4 Learnt Routes in IPv4 Routing Table: 0
                        Static: 0       Direct: 0
                        ISIS:   0       BGP:    0
                        RIP:    0       OSPF:   0
                        EIGRP:  0       UNR:    0
                        Total Number:   0
MTR(base)
                        Static: 0       Direct: 0
                        ISISv6: 0       BGP4+:  0
                        RIPng:  0       OSPFv3: 0
                        UNR:    0
                        Total Number:   0
Lsp information:
                  7777.8888.1111                  001
Table 57 Command output
Statistics information for IS-IS(processid)
Statistics for the IS-IS process.
Level-1 Statistics
Level-1 statistics.
Level-2 Statistics
Level-2 statistics.
MTR(topo-name)
MTR topology. base represents the base topology.
·     Total IPv4 Learnt Routes in IPv4 Routing Table—Number of learned IPv4 routes.
·     Total IPv6 Learnt Routes in IPv6 Routing Table—Number of learned IPv6 routes.
Numbers of different types of redistributed IPv4 routes, including static, direct, IS-IS, BGP, RIP, user network, EIGRP, and OSPF routes.
Numbers of different types of redistributed IPv6 routes, including static, direct, IS-ISv6, BGP4+, RIPng, user network, and OSPFv3 routes.
Lsp information
LSP information:
·     LSP Source ID—ID of the source system.
·     No. of used LSPs—Number of used LSPs.
display isis troubleshooting
Use display isis troubleshooting to display IS-IS neighbor relationship troubleshooting information.
# Display IS-IS neighbor relationship troubleshooting information.
<Sysname> display isis troubleshooting
                       IS-IS troubleshooting information
Total entries: 3
Time                  Sequence  Description
2020-01-08 19:31:28   101       The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the interface went down. Please check the interface state. (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17)
2020-01-08 15:33:28   100       The state of IS-IS process 1 level-2 neighbor 0000.0000.0001 changed to DOWN because the IS-IS level was changed. Please check IS-IS configuration. (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17)
2020-01-08 15:28:00   99        The state of IS-IS process 1 level-2 neighbor 0000.0000.0001 changed to DOWN because the hold timer expired and a hello packet with bad protocol version was dropped at 15:27:59. Please execute the display isis packet hello command to check hello packet statistics. (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17, CPU usage: 5%, IPv4 ping result: 5 packets succeeded, 0 packets timed out, IPv6 ping result: 5 packets succeeded, 0 packets timed out)
Table 58 Command output
Total entries
Total number of IS-IS neighbor relationship troubleshooting entries.
Time
Time when the IS-IS neighbor was disconnected. The most recent entry is displayed first.
Sequence
Sequence number of the IS-IS neighbor relationship troubleshooting entry.
IS-IS neighbor relationship troubleshooting information, including the IS-IS process ID, IS-IS level, neighbor ID, reason, and recommended action.
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the IS-IS process was reset (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the IS-IS process was gracefully restarted (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the IS-IS process was deleted (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the reset isis peer command was executed (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the IS-IS level was changed. Please check IS-IS configuration (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the IS-IS area was deleted. Please check IS-IS configuration (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the IS-IS process was stopped. Please check IS-IS process state (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the LSP sequence number exceeds the maximum sequence number (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the interface went down. Please check the interface state (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the interface was deleted or the bound VPN instance was changed. Please check the interface state and settings (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because IS-IS interface parameters changed. Please check the interface parameters (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because IS-IS packet receiving and sending were disabled. Please check the interface settings (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the circuit level changed on the interface. Please check the interface settings (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the circuit type changed on the interface. Please check the interface settings (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the interface address was deleted or IS-IS was disabled on interface. Please check the interface settings (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the interface IPv6 address was deleted or IPv6 IS-IS was disabled on interface. Please check the interface settings (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because IPv4 IS-IS was disabled on interface. Please check the interface settings (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because IPv6 IS-IS was disabled on interface. Please check the interface settings (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the BFD session went down. Please check the BFD session state (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the BFD session was administratively down. Please check the BFD session state (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the local BFD configuration changed. Please check the BFD session information (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the remote BFD configuration changed. Please check the BFD session information on remote end (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the IPv6 topology mode changed. Please check the IPv6 topology mode settings (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the wait-to-delete BFD TLV timed out. Please check the BFD session information (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to INIT because a hello packet with mismatched circuit type was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to INIT because a hello packet with mismatched area was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because a P2P hello packet with mismatched area was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to INIT because a hello packet with mismatched protocol was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to INIT because a hello packet without SNPA address was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to INIT because a hello packet without local SNPA address was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the neighbor system ID corresponding to the SNPA address in the received hello packet is different from the neighbor system ID carried in the hello packet (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the P2P neighbor was gracefully down. Please check the GR configuration of GR helper (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because a P2P hello packet with incorrect system ID was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because a P2P hello packet with incorrect circuit ID was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because a P2P hello packet with incorrect extended circuit ID was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to INIT because a P2P hello packet with adjacency three-way state down was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because a P2P hello packet with mismatched circuit type was received (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because no hello packets were received within the hold time. Please check the connection to the neighbor (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17; CPU usage: 25%; IPv4 ping result: 0 packets succeeded, 5 packets timed out; IPv6 ping result: 0 packets succeeded, 5 packets timed out).
·     The state of IS-IS process 1 level-1 neighbor 0000.0000.0001 changed to DOWN because the hold timer expired and a hello packet with bad protocol version was dropped at 15:27:59. Please execute the display isis packet hello command to check hello packet statistics (Interface: XGE3/0/1, neighbor IPv4 address: 10.1.1.1; neighbor IPv6 address: FE80::8ae3:1156:17; CPU usage: 25%; IPv4 ping result: 5 packets succeeded, 0 packets timed out; IPv6 ping result: 5 packets succeeded, 0 packets timed out). For more information, see Table 8.
reset isis troubleshooting
display osi
Use display osi to display OSI connection information.
display osi [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays OSI connection information for all cards.
# Display OSI connection information.
<Sysname> display osi
Total OSI socket number: 2
 Creator: isisd[1539]
 State: N/A
 Options: SO_FILTER
 Error: 0
 Receiving buffer(cc/hiwat/lowat/drop/state): 0 / 1048576 / 1 / 0 / N/A
 Sending buffer(cc/hiwat/lowat/state): 0 / 262144 / 512 / N/A
 Type: 2
 Enabled interfaces:
  Ten-GigabitEthernet3/0/1
   MAC address: 0180-c200-0014
 State: N/A
 Options: SO_FILTER
 Error: 0
 Type: 2
 Enabled interfaces:
Table 59 Command output
Total number of OSI sockets.
Creator
Name of the socket creator. The process ID of the creator is displayed in the square brackets.
This field always displays N/A.
Options
Socket options:
·     SO_FILTER—Filter option is configured.
·     N/A—No option is configured.
Error
Number of errors that affect the socket session.
Receiving buffer information, including the current used space, maximum space, minimum space, number of dropped packets, and status.
Sending buffer information, including the current used space, maximum space, minimum space, and status.
Type 2 socket, corresponding to unreliable connectionless-oriented transport layer protocols.
Enabled interfaces
Input interfaces and matched multicast MAC addresses. Only packets received from Ethernet link-layer interfaces need to match the multicast MAC addresses.
display osi statistics
Use display osi statistics to display OSI packet statistics.
display osi statistics [ slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays OSI packet statistics for all cards.
# Display OSI packet statistics.
<Sysname> display osi statistics
Received packets:
     Total: 35
     Relay received: 35
     Relay forwarded: 35
     Invalid service slot: 0
     No matched socket: 0
     Not delivered, input socket full: 0
Sent packets:
     Total: 19
     Relay forwarded: 19
     Relay received: 19
     Failed: 0
Table 60 Command output
Received packets
Statistics of received packets:
·     Total—Total number of received link layer packets.
·     Relay received—Number of inbound packets on LPUs relayed from other cards. This count is not included in the total count of received packets.
·     Relay forwarded—Number of inbound packets relayed to LPUs.
·     Invalid service slot—Number of discarded packets due to unavailable LPUs.
·     No matched socket—Number of discarded packets due to mismatches in input interfaces, MAC addresses, or connection filter criteria.
·     Not delivered, input socket full—Number of undelivered packets due to a socket receiving buffer overflow.
Sent packets
Statistics of sent packets:
·     Total—Total number of packets that IS-IS sent over OSI connections.
·     Relay forwarded—Number of outbound packets relayed to the cards that hosts the output interfaces. This count is not included in the total count of sent packets.
·     Relay received—Number of outbound packets on the cards that hosts the output interfaces. These packets are relayed from other cards.
·     Failed—Number of packets that failed to be sent.
reset osi statistics
distribute
Use distribute to advertise IS-IS link state information to other protocols.
Use undo distribute to restore the default.
distribute { bgp-ls | link-state | sr-db } [ instance-id id ] [ level-1 | level-2 ]
undo distribute { bgp-ls | link-state | sr-db } [ level-1 | level-2 ]
The device does not advertise IS-IS link state information to any other protocol.
IS-IS view
bgp-ls: Advertises IS-IS link state information only to BGP.
link-state: Advertises IS-IS link state information to all protocols, such as BGP and SR-MPLS TE Policy.
sr-db: Advertises IS-IS link state information only to the segment routing database (SR-DB).
instance-id id: Specifies an instance by its ID in the range of 0 to 65535. If you do not specify this option, the command advertises IS-IS link state information of instance 0 to BGP.
level-1: Specifies Level-1 IS-IS link state information.
level-2: Specifies Level-2 IS-IS link state information.
After the device advertises IS-IS link state information to other protocols, these protocols can then advertise the information for intended applications.
If multiple IS-IS processes have the same instance ID and link state information, only the link state information of the IS-IS process with the smallest process ID is advertised.
To advertise the same link state information of different IS-IS processes to other protocols, specify a different instance ID for each IS-IS process.
If you do not specify a level for this command, both Level-1 and Level-2 IS-IS link state information will be advertised to other protocols.
When multiple IS-IS P2P neighbors exist between two devices, use one of the following commands to add the IP address of the local interface into link state information. This operation ensures that other protocols can distinguish PPP links.
·     advertise link-attributes
·     router-id (IS-IS IPv6 address family view)
If you do not specify a keyword for the undo distribute command, IS-IS does not advertise link state information.
# Advertise link state information of IS-IS process 1 to BGP.
[Sysname] isis 1
[Sysname-isis-1] distribute bgp-ls
router-id (Segment Routing Command Reference)
domain-authentication send-only
Use domain-authentication send-only to configure IS-IS not to check the authentication information in the received Level-2 packets, including LSPs, CSNPs, and PSNPs.
Use undo domain-authentication send-only to restore the default.
When domain authentication mode and key are configured, a Level-2 or Level-1-2 router checks the authentication information in the received packets.
IS-IS view
When domain authentication mode and key are configured, a Level-2 or Level-1-2 router adds the key in the specified mode into transmitted Level-2 packets (including LSPs, CSNPs, and PSNPs). It also checks the key in the received Level-2 packets.
To prevent packet exchange failure in case of an authentication key change, configure IS-IS not to check the authentication information in the received packets.
# Configure IS-IS not to check the authentication information in the received packets.
[Sysname] isis 1
[Sysname-isis-1] domain-authentication send-only
area-authentication send-only
domain-authentication-mode
isis authentication send-only
Use domain-authentication-mode to specify the routing domain authentication mode and a key.
Use undo domain-authentication-mode to restore the default.
domain-authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ ip | osi ]
No routing domain authentication mode or key is configured.
IS-IS view
gca: Specifies the GCA mode.
key-id: Uniquely identifies an SA in the range of 1 to 65535. The sender inserts the Key ID into the authentication TLV, and the receiver authenticates the packet by using the SA that is selected based on the Key ID.
hmac-sha-1: Specifies the HMAC-SHA-1 algorithm.
hmac-sha-224: Specifies the HMAC-SHA-224 algorithm.
hmac-sha-256: Specifies the HMAC-SHA-256 algorithm.
hmac-sha-384: Specifies the HMAC-SHA-384 algorithm.
hmac-sha-512: Specifies the HMAC-SHA-512 algorithm.
nonstandard: Specifies the nonstandard GCA authentication mode.
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. In simple authentication mode and GCA authentication mode, the plaintext form of the key is a case-sensitive string of 1 to 16 characters, and the encrypted form is a case-sensitive string of 33 to 53 characters. In MD5 authentication mode, the plaintext form of the key is a case-sensitive string of 1 to 255 characters, and the encrypted form is a case-sensitive string of 33 to 373 characters.
keychain: Specifies the keychain authentication mode.
keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters.
ip: Checks IP-related fields in LSPs.
osi: Checks OSI-related fields in LSPs.
The configured key in the specified mode is inserted into all outgoing Level-2 packets (LSP, CSNP, and PSNP) and is used for authenticating the incoming Level-2 packets.
IS-IS keychain authentication supports the HMAC-MD5 and HMAC-SM3 authentication algorithms. If the HMAC-MD5 algorithm is used, the key ID can be any value in the range supported by the key-id argument. If the HMAC-SM3 algorithm is used, the key ID must be in the range of 0 to 65535.
When keychain authentication is used, IS-IS receives and sends packets as follows:
·     Before IS-IS sends a Level-2 packet, it uses the valid send key obtained from the keychain to authenticate the packet. If no valid send key exists or the valid send key does not use the HMAC-MD5 or HMAC-SM3 algorithm, the authentication fails and the packet does not contain the authentication information.
·     After IS-IS receives a Level-2 packet, it processes the packet as follows:
¡     If the authentication algorithm of the packet is HMAC-MD5, IS-IS uses a valid accept key obtained from the keychain to authenticate the packet. If no valid accept key exists or all valid accept keys fail to authenticate the packet, the authentication fails and the packet is discarded.
¡     If the authentication algorithm of the packet is HMAC-SM3, IS-IS uses the key ID of the received packet to obtain the corresponding valid accept key from the keychain. Then, IS-IS uses the accept key to authenticate the packet. If IS-IS cannot find a valid accept key based on the key ID of the received packet or the packet fails the authentication, the packet is discarded.
All the backbone routers must have the same authentication mode and key.
If neither ip nor osi is specified, the OSI-related fields in LSPs are checked.
When you specify the GCA mode, follow these guidelines:
·     If you do not specify the nonstandard keyword, the device can communicate only with devices (including non-H3C devices) that use the GCA mode.
·     If you specify the nonstandard keyword, the device can communicate only with devices that use the nonstandard GCA mode.
In MD5 authentication mode, execute the undo domain-authentication-mode command before version switch if the key lengths supported by the two versions are different.
# Set the routing domain authentication mode to simple, and set the plaintext key to 123456.
[Sysname] isis 1
[Sysname-isis-1] domain-authentication-mode plain 123456
area-authentication-mode
isis authentication-mode
event-log route-record size
Use event-log route-record size to set the maximum number of IS-IS route change log messages that the device can record.
Use undo event-log route-record size to restore the default.
event-log route-record { add | delete | modify } size count
undo event-log route-record { add | delete | modify } size
The device can record up to 5000 IPv4 IS-IS route change log messages for each log type.
The device can record up to 5000 IPv6 IS-IS route change log messages for each log type.
IS-IS view
add: Specifies the maximum number of route adding log messages.
delete: Specifies the maximum number of route deletion log messages.
modify: Specifies the maximum number of route update log messages.
count: Specifies the maximum number of log messages in the range of 0 to 1000000. If you set the value of this argument to 0 for a log type, the device does not generate log messages for the log type.
Supported IS-IS route change log messages include:
·     Route adding—The device generates a route adding log message when IS-IS adds a route into the IP routing table.
·     Route deletion—The device generates a route deletion log message when IS-IS deletes a route from the IP routing table.
·     Route update—The device generates a route update log message when IS-IS updates a route in the IP routing table.
After the device starts running, it records IS-IS route change log messages. This operation consumes memory resources. To save memory resources, use this command to adjust the maximum number of IS-IS route change log messages that the device can record.
If the number of recorded IS-IS route change log messages reaches the limit, new IS-IS route change log messages will overwrite the oldest ones.
# In IS-IS process 1, set the maximum number of route adding log messages that the device can record to 500.
[Sysname] isis 1
[Sysname-isis-1] event-log route-record add size 500
event-log size
Use event-log size to set the maximum number of log messages that IS-IS can record.
Use undo event-log size to remove the configuration.
event-log { hello { peer-change | received-abnormal | received-dropped | sent-abnormal | sent-failed } | lsp | peer | spf } size count
undo event-log { hello { peer-change | received-abnormal | received-dropped | sent-abnormal | sent-failed } | lsp | peer | spf } size
IS-IS can record 100 log messages for each log type.
IS-IS view
hello: Specifies the maximum number of log messages for received and sent hello packets.
peer-change: Specifies the maximum number of log messages for hello packets received and sent during neighbor state change.
received-abnormal: Specifies the maximum number of log messages for abnormally received hello packets, which were received at intervals greater than or equal to 0.5 times the holdtime (number of missed hello packets multiplied by the hello interval).
received-dropped: Specifies the maximum number of log messages for received hello packets that were dropped.
sent-abnormal: Specifies the maximum number of log messages for abnormally sent hello packets, which were sent at intervals greater than or equal to 1.5 times the hello interval.
sent-failed: Specifies the maximum number of log messages for hello packets that failed to be sent.
lsp: Specifies the maximum number of log messages for LSP generation, reception, and deletion.
peer: Specifies the maximum number of neighbor state change log messages.
spf: Specifies the maximum number of log messages for route calculation.
count: Specifies the maximum number of log messages in the range of 0 to 65535. If you set the value of this argument to 0 for a log type, IS-IS does not record logs for the log type.
# Set the maximum number of neighbor state change log messages that IS-IS process 1 can record to 50.
[Sysname] isis 1
[Sysname-isis-1] event-log peer size 50
event-log updated-lsp size
Use event-log updated-lsp size to set the maximum number of advertisement sources that trigger LSP update logging.
Use undo event-log updated-lsp size to restore the default.
event-log updated-lsp size count
A maximum of 200 advertisement sources can trigger LSP update logging.
IS-IS view
count: Specifies the maximum number of advertisement sources that trigger LSP update logging. The value range for this argument is 0 to 65535.
After the device starts running, it records LSP-update log information every 15 minutes. By default, it can record LSP-update log information for up to 200 advertisement sources. LSP update logging consumes memory resources. To control the memory usage by LSP update logging, use this command.
After you use this command, IS-IS only records the latest LSP-update log messages generated by count advertisement sources.
# Set the maximum number of advertisement sources that trigger LSP update logging to 500.
[Sysname] isis 1
[Sysname-isis-1] event-log updated-lsp size 500
exclude-srlg
Use exclude-srlg to configure the SRLG links to be excluded.
Use undo exclude-srlg to remove the configuration.
exclude-srlg srlg-value&<1-32>
undo exclude-srlg
All links on nodes that participate in flexible algorithm calculation join the flexible algorithm topology.
Flexible algorithm view
srlg-value&<1-32>: Specifies a Shared Risk Link Group (SRLG) by its ID in the range of 0 to 4294967295. &<1-32> indicates that you can specify a maximum of 32 SRLGs.
This command enhances the reliability of route calculation results in scenarios where SR-MPLS uses a flexible algorithm for SRLSP calculation or where SRv6 uses a flexible algorithm for SRv6 tunnel calculation. After you execute this command, the specified SRLGs will be excluded from the flexible algorithm calculation.
This command is supported only when the link cost type is wide, compatible, or wide-compatible.
# Configure flexible algorithm calculation to exclude links in SRLGs 11 and 22.
[Sysname] isis 1
[Sysname-isis-1] flex-algo 128
[Sysname-isis-1-flex-algo-128] exclude-srlg 11 22
cost-style
fast-reroute
Use fast-reroute to configure IS-IS FRR.
Use undo fast-reroute to disable IS-IS FRR.
fast-reroute { lfa [ ecmp-frr | ecmp-shared | level-1 | level-2 ] | route-policy route-policy-name }
undo fast-reroute { lfa [ ecmp-frr | ecmp-shared | level-1 | level-2 ] | route-policy }
IS-IS FRR is disabled.
IS-IS IPv4 unicast address family view
IS-IS IPv6 unicast address family view
lfa: Calculates a backup next hop through Loop Free Alternate (LFA) calculation.
ecmp-frr: Calculates backup next hops through LFA calculation for all routes, including ECMP routes. With this keyword specified, IS-IS calculates a backup next hop separately for each ECMP route. When remote LFA is enabled, this keyword does not take effect, and IS-IS calculates backup next hops through LFA calculation only for non-ECMP routes.
ecmp-shared: Calculates backup next hops through LFA calculation for all routes, including ECMP routes. ECMP routes share one backup next hop. When remote LFA is enabled, this keyword does not take effect, and IS-IS calculates backup next hops through LFA calculation only for non-ECMP routes.
level-1: Specifies Level-1 routes.
level-2: Specifies Level-2 routes.
route-policy route-policy-name: Uses the specified routing policy to designate a backup next hop. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
To calculate backup next hops through LFA calculation for ECMP routes, execute this command with the ecmp-frr or ecmp-shared keyword. If the next hop of an ECMP route fails, IS-IS uses the specified backup next hop to forward packets during the route reconvergence period. After route reconvergence is completed, the device generates equal-cost IS-IS routes again to guide packet forwarding. The calculated backup next hop is installed into the RIB as an ECMP route. The states of the route include Backup in the output from the display ip routing-table or display ipv6 routing-table command.
If neither of the ecmp-frr and ecmp-shared keywords is specified, IS-IS calculates backup next hops through LFA calculation only for non-ECMP routes.
The inter-level-tilfa level-1 enable command configured in IS-IS IPv4 unicast address family view does not take effect if the following commands are configured in IS-IS IPv4 unicast address family view or IS-IS IPv4 unicast topology view:
·     fast-reroute lfa ecmp-shared
·     fast-reroute lfa ecmp-frr
The inter-level-tilfa level-1 enable command configured in IS-IS IPv6 unicast address family view does not take effect if the following commands are configured in IS-IS IPv6 unicast address family view:
The LFA calculation of FRR and IS-IS TE are mutually exclusive.
ECMP routes do not support FRR.
Example
# Enable FRR for IS-IS process 1 and configure IS-IS FRR to calculate a backup next hop through LFA calculation for all routes.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] fast-reroute lfa
fast-reroute enable
Use fast-reroute enable to enable FRR for a flexible algorithm.
Use undo fast-reroute enable to disable FRR for a flexible algorithm.
fast-reroute enable
Flexible algorithm FRR is enabled.
The flexible algorithm FRR is similar to IS-IS LFA FRR, because it uses LFA to calculate a loop-free backup path with the lowest cost based on the topology.
If no backup paths exist in the topology, execute the undo fast-reroute enable command to disable flexible algorithm FRR to save device resources.
This feature is available only when the link cost style is wide, compatible, or wide-compatible.
# Disable FRR for flexible algorithm 128.
[Sysname] isis 1
[Sysname-isis-1-flex-algo-128] undo fast-reroute enable
cost-style
fast-reroute microloop-avoidance enable
Use fast-reroute microloop-avoidance enable to enable FRR microloop avoidance for a flexible algorithm.
Use undo fast-reroute microloop-avoidance enable to disable FRR microloop avoidance for a flexible algorithm.
FRR microloop avoidance is enabled for flexible algorithms.
After a network failure occurs, some devices along the traffic forwarding path will perform route convergence. During the route convergence process, microloops might occur and cause packet loss and disorder if the route convergence on each device is not simultaneous.
To resolve this issue, enable this feature on the nodes next to the node that failed and set the microloop avoidance RIB-update-delay timer. Traffic will be forwarded through the backup path calculated by TI-LFA before the microloop avoidance RIB-update-delay timer expires.
If you configure both FRR microloop avoidance and SR microloop avoidance for a flexible algorithm, both the FRR microloop avoidance delay timer and the SR microloop avoidance delay timer start. In this scenario, FRR microloop avoidance and SR microloop avoidance take effect as follows:
·     If the FRR microloop avoidance delay time is longer than or equivalent to the SR microloop avoidance delay time, the traffic switches to the post-convergence path immediately after the FRR microloop avoidance delay timer expires.
·     If the FRR microloop avoidance delay time is shorter than the SR microloop avoidance delay time, the traffic switches to the post-convergence path after the SR microloop avoidance delay timer expires.
# Disable FRR microloop avoidance for flexible algorithm 128.
[Sysname] isis 1
[Sysname-isis-1-flex-algo-128] undo fast-reroute microloop-avoidance enable
fast-reroute microloop-avoidance rib-update-delay
segment-routing microloop-avoidance rib-update-delay
Use fast-reroute microloop-avoidance rib-update-delay to set the FRR microloop avoidance RIB-update-delay timer for a flexible algorithm.
Use undo fast-reroute microloop-avoidance rib-update-delay to restore the default.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance rib-update-delay [ level-1 | level-2 ]
The FRR microloop avoidance RIB-update-delay timer is 5000 milliseconds.
delay-time: Sets the FRR microloop avoidance RIB-update-delay timer in milliseconds. The value range for this argument is 1 to 60000.
level-1: Applies the FRR microloop avoidance RIB-update-delay timer to Level-1 areas.
level-2: Applies the FRR microloop avoidance RIB-update-delay timer for the Level-2 area.
For the FRR microloop avoidance RIB-update-delay timer to take effect, enable FRR microloop avoidance for the flexible algorithm first.
If you do not specify the level-1 or level-2 keyword, this command sets the FRR microloop avoidance RIB-update-delay timer for all IS-IS levels.
# Set the FRR microloop avoidance RIB-update-delay timer to 6000 milliseconds for flexible algorithm 128 in IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-flex-algo-128] fast-reroute microloop-avoidance rib-update-delay 6000
fast-reroute primary-path-detect bfd
Use fast-reroute primary-path-detect bfd to enable BFD-powered primary link failure detection for an IS-IS process.
Use undo fast-reroute primary-path-detect bfd to disable BFD-powered primary link failure detection in an IS-IS process.
fast-reroute primary-path-detect bfd { ctrl | echo }
An IS-IS process does not use BFD to detect primary link failures for IS-IS FRR and PIC.
IS-IS IPv4 address family view
ctrl: Enables BFD control packet mode.
echo: Enables BFD echo packet mode.
This command enables IS-IS FRR and IS-IS PIC to use BFD to detect primary link failures. BFD can detect and report a primary link failure to IS-IS for a primary-backup path switchover. This can shorten the duration of service interruption.
To enable BFD-powered primary link failure detection, you can use the fast-reroute primary-path-detect bfd, isis primary-path-detect bfd, or isis ipv6 primary-path-detect bfd command.
These commands are different as follows:
·     The fast-reroute primary-path-detect bfd command enables BFD-powered primary link failure detection on all interfaces in an IPv4 or IPv6 IS-IS process.
·     The isis primary-path-detect bfd and isis ipv6 primary-path-detect bfd commands take effect only on one IS-IS interface. To enable BFD-powered primary link failure detection on a single IS-IS interface, perform the following tasks:
a.     Make sure the IS-IS process to which the IS-IS interface belongs is not enabled with BFD-powered primary link failure detection.
b.     You can use the undo fast-reroute primary-path-detect bfd command to disable this feature for an IS-IS process.
c.     Use the isis primary-path-detect bfd or isis ipv6 primary-path-detect bfd command to enable this feature on the IS-IS interface.
In BFD echo packet mode, the source addresses of BFD packets must be global unicast addresses. When the IPv6 next hop of the primary route is not a global unicast address, use BFD control packet mode to detect whether the next hop of the primary route is reachable.
# Enable BFD control packet mode for IS-IS FRR and PIC in IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute primary-path-detect bfd ctrl
fast-reroute remote-lfa maximum-cost
Use fast-reroute remote-lfa maximum-cost to set the maximum cost from the source node of a protected link to a PQ node.
Use undo fast-reroute remote-lfa maximum-cost to restore the default.
fast-reroute remote-lfa maximum-cost cost [ level-1 | level-2 ]
undo fast-reroute remote-lfa maximum-cost [ level-1 | level-2 ]
The maximum cost from the source node of a protected link to a PQ node is 16777215.
cost: Specifies a cost value in the range of 1 to 16777215.
level-1: Applies the configuration to Level-1 areas.
level-2: Applies the configuration to the Level-2 area.
The cost values from different PQ nodes to the source node of a specific protected link might be different. You can use this command to filter PQ nodes based on the cost value.
If you specify neither the level-1 nor the level-2 keyword, this command applies to all IS-IS areas.
# Set the maximum cost from the source node of a protected link to a PQ node to 200.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute remote-lfa maximum-cost 200
fast-reroute remote-lfa prefix-list
Use fast-reroute remote-lfa prefix-list to specify a prefix list to filter remote LFA PQ nodes.
Use undo fast-reroute remote-lfa prefix-list to restore the default.
fast-reroute remote-lfa prefix-list prefix-list-name [ level-1 | level-2 ]
undo fast-reroute remote-lfa prefix-list [ level-1 | level-2 ]
Any PQ node can be selected as the backup next hop by remote LFA FRR.
prefix-list-name: Specifies a prefix list by its name, a case-sensitive string of 1 to 63 characters.
Multiple PQ nodes might reach the source node of a specific protected link. You can use this command to specify a prefix list to filter PQ nodes.
# Use prefix list test1 to filter remote LFA PQ nodes.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute remote-lfa prefix-list test1
ip prefix-list
fast-reroute remote-lfa tunnel ldp
Use fast-reroute remote-lfa tunnel ldp to enable IS-IS remote LFA FRR.
Use undo fast-refroute remote-lfa tunnel ldp to disable IS-IS remote LFA FRR.
fast-reroute remote-lfa tunnel ldp [ level-1 | level-2 ]
undo fast-reroute remote-lfa tunnel ldp [ level-1 | level-2 ]
IS-IS remote LFA FRR is disabled.
Configure remote LFA FRR to prevent traffic loss caused by link or node failures.
Before configuring remote LFA FRR, you must perform the following tasks:
·     Use the mpls ldp command to enable MPLS LDP globally.
·     Use the mpls ldp enable command to enable MPLS LDP on all interfaces participating in MPLS forwarding.
·     Use the fast-reroute lfa command to enable LFA FRR for the IS-IS level at which remote LFA FRR will be implemented.
# Enable remote LFA FRR.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute remote-lfa tunnel ldp
fast-reroute
mpls ldp (MPLS Command Reference)
mpls ldp enable (MPLS Command Reference)
fast-reroute tiebreaker (flexible algorithm view)
Use fast-reroute tiebreaker to set the priority of an FRR backup path selection policy for a flexible algorithm.
Use undo fast-reroute tiebreaker to restore the default.
fast-reroute tiebreaker { lowest-cost | node-protecting } preference preference [ level-1 | level-2 ]
undo fast-reroute tiebreaker { lowest-cost | node-protecting } [ level-1 | level-2 ]
The priority values of the node-protection and lowest-cost backup path selection policies are 40 and 20, respectively.
lowest-cost: Sets a priority value for the lowest-cost backup path selection policy.
node-protecting: Sets a priority value for the node-protection backup path selection policy.
preference preference: Specifies a priority value in the range of 1 to 255. A higher value indicates a higher priority.
You can execute this command multiple times to specify the priorities for the lowest cost and node protection policies, respectively.
If you execute this command multiple times for a backup path selection policy, the most recent configuration takes effect.
You can configure both backup path selection policies in an address family view. The flexible algorithm will calculate a backup path by using the policies in descending order of their priorities until a backup path is calculated. If the flexible algorithm fails to calculate a backup path, it does not perform further backup path calculation.
If the flexible algorithm fails to calculate a backup path by using the lowest-cost policy, it does not perform further backup path calculation.
If you do not specify a level, the command takes effect on both Level-1 and Level-2 areas.
# Set the priority value of the node-protection backup path selection policy to 100 for flexible algorithm 255 in IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] flex-algo 255
[Sysname-isis-1-flex-algo-255] fast-reroute tiebreaker node-protecting preference 100
fast-reroute tiebreaker (IS-IS IPv4 unicast address family view/IS-IS IPv6 unicast address family view)
Use fast-reroute tiebreaker to set the priority for an FRR backup path selection policy.
fast-reroute tiebreaker { lowest-cost | node-protecting | non-ecmp | srlg-disjoint } preference preference [ level-1 | level-2 ]
undo fast-reroute tiebreaker { lowest-cost | node-protecting | non-ecmp | srlg-disjoint } [ level-1 | level-2 ]
The priority values of the node-protection, lowest-cost, non-ECMP, and SRLG-disjoint backup path selection policies are 40, 20, 15, and 10, respectively.
non-ecmp: Sets a priority value for the non-ECMP backup path selection policy. The non-ECMP policy preferentially selects non-load-balancing paths from the network as backup paths.
srlg-disjoint: Sets a priority value for the SRLG-disjoint backup path selection policy.
IS-IS FRR uses specific policies for backup path calculation. This command defines the priority for the backup path selection policy. The higher the value, the higher the priority of the associated backup path selection policy. Changing the backup path selection policy priority can affect the backup path calculation result for IS-IS FRR. The backup paths can provide node protection or link protection for traffic, or provide both node protection and link protection.
IS-IS FRR supports the following backup path selection policies that are used to generate different topologies for backup path calculation:
·     Node protection—IS-IS FRR performs backup path calculation after excluding the primary next hop node.
·     Lowest cost—IS-IS FRR performs backup path calculation after excluding the direct primary link.
·     SRLG disjoint—When one link in the SRLG fails, the other links in the SRLG might also fail. If you use a link in this SRLG as the backup link for the failed link, protection does not take effect. To avoid this issue, IS-IS FRR excludes the local links in the same SRLG as the direct primary link and then performs backup path calculation.
For IS-IS FRR, the SRLG disjoint policy depends on the node protection and lowest cost policies.
The non-ECMP policy selects backup paths from those calculated by the node protection and lowest cost policy. It preferentially selects non-ECMP primary paths as backup paths.
If multiple backup path selection policies exist in an IS-IS process, the policy with the highest priority is used to calculate the backup path. If the policy fails to calculate the backup path, another policy with higher priority is used. IS-IS performs backup path calculation by using the node protection and lowest cost policies as follows:
·     If the node protection policy has higher priority and fails to calculate the backup path, IS-IS uses the lowest cost policy to calculate the backup path. If the lowest cost policy still fails to calculate the backup path, reliability cannot be ensured upon primary link failure.
·     If the lowest cost policy has higher priority and fails to calculate the backup path, IS-IS does not perform further backup path calculation with the node protection policy. Reliability cannot be ensured upon primary link failure.
If multiple ECMP paths exist between the source and destination paths, IS-IS FRR will calculate a backup path independently for each ECMP path. By default, when using the node protection or lowest cost policy to calculate a backup path, IS-IS FRR preferentially selects the lowest-cost path as the backup path. In this case, IS-IS FRR does not determine whether the backup path is an ECMP primary path, except when the following conditions exist:
·     IS-IS FRR uses the node protection policy to perform backup path calculation as follows:
a.     When and only when the non-ECMP policy has higher priority than node protection policy, IS-IS FRR preferentially selects a non-ECMP path as the backup path.
b.     If non-ECMP backup paths do not exist, IS-IS FRR selects an ECMP path as the backup path.
c.     If backup path calculation fails, IS-IS FRR uses the lowest cost policy to calculate a backup path.
If backup path calculation still fails, reliability is not ensured when the primary link fails.
·     IS-IS FRR uses the lowest cost protection policy to perform backup path calculation as follows:
d.     When and only when the non-ECMP policy has higher priority than lowest cost policy, IS-IS FRR preferentially selects a non-ECMP path as the backup path.
e.     If non-ECMP backup paths do not exist, IS-IS FRR selects an ECMP path as the backup path.
f.     If backup path calculation fails, IS-IS FRR does not use the node protection policy to calculate a backup path. In this case, reliability is not ensured when the primary link fails.
You can execute this command multiple times to specify the priorities for the lowest cost, node protection, SRLG disjoint, and non-ECMP policies, respectively.
# Set the priority value of the node-protection backup path selection policy to 100.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute tiebreaker node-protecting preference 100
fast-reroute
fast-reroute ti-lfa enable
Use fast-reroute ti-lfa enable to enable Topology-Independent Loop-Free Alternate (TI-LFA) FRR for a flexible algorithm.
Use undo fast-refroute ti-lfa enable to disable TI-LFA FRR for a flexible algorithm.
undo fast-reroute ti-lfa enable
TI-LFA FRR is enabled for a flexible algorithm.
TI-LFA FRR calculates backup paths based on FAD of the flexible algorithm. This feature can protects links and nodes in the topology. When a link or node fails, TI-LFA FRR will use the backup path to forward traffic to ensure continuous data forwarding and reduce traffic loss.
You can enable this feature only when the link cost style is wide, compatible, or wide-compatible.
# Enable TI-LFA FRR for flexible algorithm 255.
[Sysname] isis 1
[Sysname-isis-1-flex-algo-255] fast-reroute ti-lfa enable
filter-policy export
Use filter-policy export to configure IS-IS to filter redistributed routes.
Use undo filter-policy export to remove the configuration.
In IS-IS IPv4 unicast address family view:
filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ bgp | direct | eigrp eigrp-as | { isis | ospf | rip } process-id | static | unr ]
undo filter-policy export [ bgp | direct | eigrp eigrp-as | { isis | ospf | rip } process-id | static | unr ]
In IS-IS IPv6 unicast address family view:
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ bgp4+ | direct | { isisv6 | ospfv3 | ripng } process-id | static | unr ]
undo filter-policy export [ bgp4+ | direct | { isisv6 | ospfv3 | ripng } process-id | static | unr ]
IS-IS does not filter redistributed routes.
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter redistributed routes.
prefix-list prefix-list-name: Specifies a prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes by destination address.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes.
bgp: Filters redistributed BGP routes.
bgp4+: Filters redistributed IPv6 BGP routes.
direct: Filters redistributed direct routes.
eigrp: Filters redistributed EIGRP routes.
eigrp-as: Specifies an EIGRP process by its AS number in the range of 1 to 65535.
isis: Filters redistributed IS-IS routes.
isisv6: Filters redistributed IPv6 IS-IS routes.
ospf: Filters redistributed OSPF routes.
ospfv3: Filters redistributed OSPFv3 routes.
rip: Filters redistributed RIP routes.
ripng: Filters redistributed RIPng routes.
process-id: Specifies a process by its ID in the range of 1 to 65535.
static: Filters redistributed static routes.
unr: Filters redistributed user network routes.
If you do not specify any parameters, this command filters all redistributed routes.
This command filters routes redistributed by the import-route command. Only routes that have not been filtered can be advertised.
When you specify an ACL, follow these guidelines:
·     If the ACL does not exist or does not have any rules, IS-IS does not filter any redistributed routes.
·     If a rule in the ACL is applied to a VPN instance, the rule will deny all redistributed routes.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following methods:
·     To deny or permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·     To deny or permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the route.
# Use basic ACL 2000 to filter redistributed routes.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname] isis 1
[Sysname-isis-1-ipv4] filter-policy 2000 export
# Configure advanced ACL 3000 to permit only route 113.0.0.0/16 to pass. Use advanced ACL 3000 to filter redistributed routes.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 deny ip
[Sysname] isis 1
[Sysname-isis 1] address-family ipv4
[Sysname-isis-1-ipv4] filter-policy 3000 export
display isis route
filter-policy import
Use filter-policy import to configure IS-IS to filter routes calculated using received LSPs.
Use undo filter-policy import to restore the default.
filter-policy { acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import
IS-IS does not filter routes calculated using received LSPs.
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter routes calculated using received LSPs.
prefix-list prefix-list-name: Specifies a prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes calculated using received LSPs by destination address.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter received routes.
This command filters received routes. Only routes that pass the filter can be added into the routing table.
·     If the ACL does not exist or does not have any rules, IS-IS does not filter any received routes.
·     If a rule in the ACL is applied to a VPN instance, the rule will deny all received routes.
# Use basic ACL 2000 to filter routes calculated using received LSPs.
[Sysname] isis 1
[Sysname-isis-1-ipv4] filter-policy 2000 import
# Use advanced ACL 3000 to filter routes calculated using received LSPs and install only route 113.0.0.0/16 to the IP routing table.
[Sysname] isis 1
[Sysname-isis-1-ipv4] filter-policy 3000 import
flash-flood
Use flash-flood to enable IS-IS LSP flash flooding.
Use undo flash-flood to disable IS-IS LSP flash flooding.
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval | [ level-1 | level-2 ] ] *
undo flash-flood [ level-1 | level-2 ]
IS-IS LSP flash flooding is disabled.
IS-IS view
flood-count flooding-count: Specifies the maximum number of LSPs to be flooded before the next SPF calculation, in the range of 1 to 15. The default is 5.
max-timer-interval flooding-interval: Specifies the delay of the flash flooding, in the range of 10 to 50000 milliseconds. The default is 10.
level-1: Enables flash flooding for level-1.
level-2: Enables flash flooding for level-2.
If no level is specified, the command enables IS-IS LSP flash flooding for both Level-1 and Level-2.
# Enable fast flooding, and set the maximum LSPs to be sent to 10 and the delay time to 100 milliseconds.
[Sysname] isis 1
[Sysname-isis-1] flash-flood flood-count 10 max-timer-interval 100
flex-algo (IS-IS view)
Use flex-algo to create a flexible algorithm and enter its view, or enter the view of an existing flexible algorithm.
Use undo flex-algo to delete a flexible algorithm.
flex-algo flex-algo-id
undo flex-algo flex-algo-id
No flexible algorithms exist.
IS-IS view
flex-algo-id: Specifies a flexible algorithm ID. The value range for this argument is 128 to 255. You can create multiple flexible algorithms in an IS-IS process.
You can identify a path calculation algorithm by checking the algorithm field in an IS-IS SID. The value range for this field is 0 to 255.
·     A value of 0 represents the SPF algorithm that uses IGP metric for path calculation.
·     A value of 128 to 255 represents the flexible algorithm that uses specific metric type and constraints for path calculation.
·     A flexible algorithm consists of the following parts:
·     Calculation type—Algorithm used for path calculation. In the current software version, only SPF algorithm is supported.
·     Metric type—Metric type used for the shortest path calculation. In the current software version, only IS-IS link cost is supported.
·     Constraint—Link filter criteria for topology generation. You can use a set of constraints to exclude links with specific affinity attributes from or include them in the flexible algorithm topology.
·     A flexible algorithm generates its topology as follows:
·     Excludes the nodes that does not participate in the path calculation for that flexible algorithm.
·     Excludes links according to the constraints.
·     Excludes the links that do not meet the flexible algorithm requirement on metric type.
·     In a flexible algorithm topology, all nodes calculate optimal paths based on the calculation type and metric type in the FAD.
This feature is available when the link cost style is wide, compatible, or wide-compatible.
# Create flexible algorithm 128 and enter its view.
[Sysname] isis 1
cost-style
flex-algo (segment routing view)
Use flex-algo to create and enter SR flexible algorithm view. If the SR flexible algorithm view already exists, the command directly enters SR flexible algorithm view.
Use undo flex-algo to delete the SR flexible algorithm view and all configuration in the view.
flex-algo
undo flex-algo
The SR flexible algorithm view does not exist.
Segment routing view
# Create and enter SR flexible algorithm view.
[Sysname] segment-routing
[Sysname-segment-routing] flex-algo
[Sysname-sr-flex-algo]
segment-routing (Segment Routing Command Reference)
flex-algo algorithm
Use flex-algo algorithm to associate an SRv6 locator to a flexible algorithm.
Use undo flex-algo algorithm to restore the default.
flex-algo algorithm algo-id
An SRv6 locator is associated to flexible algorithm 0. IS-IS uses the SPF algorithm to calculate optimal paths to the locator.
SRv6 locator view
algo-id: Specifies a flexible algorithm by its ID. The value range for this argument is 128 to 255.
With SRv6 enabled, IS-IS advertises SRv6 locator TLVs in LSPs. You can identify the algorithm associated to the locator by checking the algorithm field in an SRv6 locator TLV. By default, IS-IS uses the SPF algorithm to calculate the shortest path to an SRv6 locator, and the value for the algorithm field is 0.
If you associate an SRv6 locator to a flexible algorithm, IS-IS uses the flexible algorithm to calculate the shortest path to the locator.
You must associate an SRv6 locator to a flexible algorithm that already exists, or IS-IS will not advertise the locator.
If you execute this command multiple times on an interface, the most recent configuration takes effect.
# Associate SRv6 locator abc to flexible algorithm 128.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] locator abc ipv6-prefix 500::1 40 static 4
[Sysname-segment-routing-ipv6-locator-abc] flex-algo algorithm 128
graceful-restart
Use graceful-restart to enable IS-IS GR.
Use undo graceful-restart to disable IS-IS GR.
graceful-restart
IS-IS GR is disabled.
IS-IS view
# Enable GR for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart
graceful-restart suppress-sa
Use graceful-restart suppress-sa to suppress the Suppress-Advertisement (SA) bit during restart.
Use undo graceful-restart suppress-sa to restore the default.
The SA bit is set during restart.
IS-IS view
Suppressing the SA bit is mainly for avoiding black hole route. If a router starts or reboots without keeping the local forwarding table, sending packets to the router might result in severe packet loss. To avoid this, you can set the SA bit of the hello packet sent by the GR restarter to 1. Upon receiving such hello packets, the GR helpers will not advertise the GR restarter through LSP.
# Suppress the SA bit during graceful restart.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart suppress-sa
graceful-restart
graceful-restart t1
Use graceful-restart t1 to set the T1 timer.
Use undo graceful-restart t1 to restore the default.
graceful-restart t1 seconds count count
The T1 timer is 3 seconds and can expire 10 times.
IS-IS view
seconds: Specifies the T1 timer in the range of 3 to 10 seconds.
count: Specifies the number of times that the T1 timer can expire, in the range of 1 to 20.
The T1 timer specifies the number of times that GR restarter can send a Restart TLV with the RR bit set. After restart, the GR restarter sends a Restart TLV with the RR bit set to its neighbor. If the restarting router receives a Restart TLV with the RA set from its neighbor before the T1 timer expires, the GR process starts. Otherwise, the GR process fails.
To ensure successful GR timer configuration, follow these restrictions and guidelines when you configure the GR timers:
·     The product of the T1 timer and the number of times that the T1 timer can expire must be smaller than the T2 timer.
·     The T2 timer must be smaller than the T3 timer.
# Set the T1 timer of IS-IS process 1 to 5 seconds, and the expiration times to 5.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart t1 5 count 5
graceful-restart
graceful-restart t2
graceful-restart t3
graceful-restart t2
Use graceful-restart t2 to set the T2 timer.
Use undo graceful-restart t2 to restore the default.
graceful-restart t2 seconds
The T2 timer is 60 seconds.
IS-IS view
seconds: Specifies the T2 timer in the range of 30 to 65535 seconds.
The T2 timer specifies the LSDB synchronization interval. Each LSDB has a T2 timer. The Level-1-2 router has two T2 timers: a Level-1 timer and a Level-2 timer. If the LSDBs have not achieved synchronization before the two timers expire, the GR process fails.
# Set the T2 timer of IS-IS process 1 to 50 seconds.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart t2 50
graceful-restart
graceful-restart t1
graceful-restart t3
graceful-restart t3
Use graceful-restart t3 to set the T3 timer.
Use undo graceful-restart t3 to restore the default.
graceful-restart t3 seconds
The T3 timer is 300 seconds.
IS-IS view
seconds: Specifies the T3 timer in the range of 300 to 65535 seconds.
The T3 timer specifies the GR interval. The GR interval is set as the holdtime in hello PDUs. Within the interval, the neighbors maintain their adjacency with the GR restarter. If the GR process has not completed within the holdtime, the neighbors tear down the neighbor relationship and the GR process fails.
# Set the T3 timer of IS-IS process 1 to 500 seconds.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart t3 500
graceful-restart
graceful-restart t1
graceful-restart t2
ignore-att
Use ignore-att to configure IS-IS not to calculate the default route through the ATT bit.
Use undo ignore-att to restore the default.
ignore-att
undo ignore-att
IS-IS calculates the default route through the ATT bit.
IS-IS view
# Configure IS-IS not to calculate the default route through the ATT bit.
[Sysname] isis 1
[Sysname-isis-1] ignore-att
import-bier
Use import-bier to enable IS-IS to redistribute BIER information from other protocols.
Use undo import-bier to disable IS-IS from redistributing BIER information from other protocols.
import-bier bgp4+ [ as-number ]
undo import-bier bgp4+
IS-IS does not redistribute BIER information from other protocols.
bgp4+: Redistributes IPv6 BGP BIER information.
as-number: Specifies an AS by its number, an integer in the range of 1 to 4294967295. If you do not specify an AS number, IS-IS redistributes BIER information from all ASs.
IS-IS cannot advertise BIER information outside an AS. To implement inter-AS BIER traffic forwarding, you can use this command to enable BIER information redistribution from BGP into IS-IS on the ASBR.
1.     IPv6 BGP BIER information is redistributed into IS-IS.
2.     IS-IS advertises the redistributed BIER information in LSPs to neighbors in the AS.
3.     On receipt of the LSPs, the neighbors generate BIER routes for inter-AS BIER traffic forwarding.
This command redistributes only EBGP BIER information into IS-IS. For this command to take effect, enable IS-IS BIER first.
# Redistribute BGP BIER information into IS-IS.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] import-bier bgp4+
bier enable
import-route
Use import-route to enable route redistribution.
Use undo import-route to disable route redistribution.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route bgp [ as-number ] [ allow-ibgp ] inherit-cost [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { direct | static | unr } [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { direct | static | unr } inherit-cost [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route eigrp [ eigrp-as | all-as ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route eigrp [ eigrp-as | all-as ] inherit-cost [ allow-direct | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route rip [ process-id | all-processes ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route rip [ process-id | all-processes ] inherit-cost [ allow-direct | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { isis | ospf } [ process-id | all-processes ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | no-sid | route-policy route-policy-name | tag tag ] *
import-route { isis | ospf } [ process-id | all-processes ] inherit-cost [ allow-direct | [ level-1 | level-1-2 | level-2 ] | no-sid | route-policy route-policy-name | tag tag ] *
undo import-route { bgp | direct | eigrp [ eigrp-as | all-as ] | { isis | ospf | rip } [ process-id | all-processes ] | static | unr }
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ [ cost cost-value | inherit-cost ] | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { direct | static } [ [ cost cost-value | inherit-cost ] | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route { isisv6 | ospfv3 | ripng } [ process-id ] [ allow-direct | [ cost cost-value | inherit-cost ] | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
undo import-route { bgp4+ | direct | { isisv6 | ospfv3 | ripng } [ process-id ] | static | unr }
IS-IS does not redistribute routes.
bgp: Redistributes BGP routes.
bgp4+: Redistributes IPv6 BGP routes.
as-number: Specifies an AS by its number in the range of 1 to 4294967295. This argument applies only to the BGP or BGP4+ protocol. If you do not specify this argument, the command redistributes all IPv4 or IPv6 EBGP routes. As a best practice, specify an AS to prevent the system from redistributing excessive routes.
direct: Redistributes direct routes.
eigrp: Redistributes EIGRP routes.
eigrp-as: Specifies an EIGRP process by its number in the range of 1 to 65535. The default value is 1.
all-as: Redistributes routes from all EIGRP processes.
isis: Redistributes IS-IS routes.
isisv6: Redistributes IPv6 IS-IS routes.
ospf: Redistributes OSPF routes.
ospfv3: Redistributes OSPFv3 routes.
rip: Redistributes RIP routes.
ripng: Redistributes RIPng routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. The default value is 1.
static: Redistributes static routes.
unr: Redistributes user network routes. User network routes are generated by access devices for online users.
all-processes: Redistributes routes from all the processes of the IS-IS, OSPF, or RIP routing protocol.
allow-ibgp: Allows redistribution of IBGP routes.
allow-direct: Redistributes the networks of the local interfaces enabled with the specified routing protocol. By default, the networks of the local interfaces are not redistributed. If you specify both the allow-direct keyword and the route-policy route-policy-name option, make sure the if-match rule defined in the routing policy does not conflict with the allow-direct keyword. For example, if you specify the allow-direct keyword, do not configure the if-match route-type rule for the routing policy. Otherwise, the allow-direct keyword does not take effect.
cost cost-value: Specifies a cost for redistributed routes, which is in the range of 0 to 4261412864.
·     For the styles of narrow, narrow-compatible, and compatible, the cost is in the range of 0 to 63.
·     For the styles of wide and wide-compatible, the cost is in the range of 0 to 4261412864.
cost-type { external | internal }: Specifies the cost type. The internal type indicates internal routes, and the external type indicates external routes. If external is specified, the cost of a redistributed route is added by 64 to make internal routes take priority over external routes. The type is external by default. The keywords are available only when the cost type is narrow, narrow-compatible, or compatible.
inherit-cost: Uses the original cost of redistributed routes.
level-1: Redistributes routes into the Level-1 routing table.
level-1-2: Redistributes routes into both Level-1 and Level-2 routing tables.
level-2: Redistributes routes into the Level-2 routing table. If no level is specified, the routes are redistributed into the Level-2 routing table by default.
no-sid: Redistributes routes without their SR labels. If you do not specify this keyword, IS-IS redistributes routes with their SR labels.
route-policy route-policy-name: Redistributes only routes matching the specified routing policy. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag value for marking redistributed routes, in the range of 1 to 4294967295.
IS-IS takes all the redistributed routes as external routes to destinations outside the IS-IS routing domain.
After you specify the cost or inherit-cost keyword, the effective cost varies by cost style. For the styles of narrow, narrow-compatible, and compatible, the cost is in the range of 0 to 63. If the cost is more than 63, 63 is used. For the style of wide or wide-compatible, the configured value is the effective value.
This import-route command cannot redistribute default routes. The command redistributes only active routes. To display route state information, use the display ip routing-table protocol command.
If you specify neither the cost nor inherit-cost keyword, the cost of a redistributed route is 0.
The import-route bgp or import-route bgp4+ command redistributes only EBGP routes. The import-route bgp allow-ibgp or import-route bgp4+ allow-ibgp command redistributes IBGP routes in addition to EBGP routes.
IMPORTANT
IMPORTANT:
Improper redistribution of IBGP routes might cause routing loops. When you use the allow-ibgp keyword, make sure you understand its impact on the network.
When you execute the undo form of the command, per-process setting has higher priority than the all-processes setting.
The undo import-route eigrp all-as command can remove the configuration of the import-route eigrp all-as command only. To remove the configuration of the import-route eigrp eigrp-as command, use the undo form of the command.
The undo import-route protocol all-processes command can remove the configuration of the import-route protocol all-processes command only. To remove the configuration of the import-route protocol process-id command, use the undo form of the command.
# Redistribute static routes into IS-IS, and set the cost of redistributed routes to 15.
[Sysname] isis 1
[Sysname-isis-1-ipv4] import-route static cost 15
import-route limit
import-route isis level-1 into level-2
Use import-route isis level-1 into level-2 to enable route advertisement from Level-1 to Level-2.
Use undo import-route isis level-1 into level-2 to disable route advertisement from Level-1 to Level-2.
import-route isis level-1 into level-2 [ filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | no-sid | tag tag ] *
Route advertisement from Level-1 to Level-2 is enabled.
filter-policy: Specifies a filtering policy.
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter routes from Level-1 to Level-2.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes from Level-1 to Level-2 by destination address.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter routes from Level-1 to Level-2.
no-sid: Redistributes routes from Level-1 to Level-2 without keeping their SR labels. If you do not specify this keyword, this command redistributes routes from Level-1 to Level-2 keeping their SR labels.
tag tag: Specifies a tag for marking redistributed routes, in the range of 1 to 4294967295.
If a routing policy is used, the routing policy must be specified in the import-route isis level-1 into level-2 command to filter routes from Level-1 to Level-2. Other routing policies specified for route reception and redistribution do not affect the route leaking.
If a filtering policy is configured, only Level-1 routes not filtered out can be advertised into the Level-2 area.
When you specify an IPv4 ACL, follow these guidelines:
·     If the ACL does not exist or does not have any rules, IS-IS does not filter any routes advertised from Level-1 to Level-2.
·     If a rule in the ACL is applied to a VPN instance, the rule will deny all routes advertised from Level-1 to Level-2.
# Enable route advertisement from Level-1 to Level-2.
[Sysname] isis 1
[Sysname-isis-1-ipv4] import-route isis level-1 into level-2
import-route
import-route isis level-2 into level-1
Use import-route isis level-2 into level-1 to enable route advertisement from Level-2 to Level-1.
Use undo import-route isis level-2 into level-1 to restore the default.
import-route isis level-2 into level-1 [ filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | no-sid | tag tag ] *
Route advertisement from Level-2 to Level-1 is disabled.
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter routes from Level-2 to Level-1.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes from Level-2 to Level-1 by destination address.
route-policy route-policy-name: Uses the specified routing policy to filter routes from Level-2 to Level-1. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
no-sid: Redistributes routes from Level-2 to Level-1 without keeping their SR labels. If you do not specify this keyword, this command redistributes routes from Level-2 to Level-1 keeping their SR labels.
If a routing policy is used, the routing policy must be specified in the import-route isis level-2 into level-1 command to filter routes from Level-2 to Level-1. Other routing policies specified for route reception and redistribution does not affect the route leaking.
If a filtering policy is configured, only Level-2 routes not filtered out can be advertised into the Level-1 area.
·     If the ACL does not exist or does not have any rules, IS-IS does not filter any routes advertised from Level-2 to Level-1.
·     If a rule in the ACL is applied to a VPN instance, the rule will deny all routes advertised from Level-2 to Level-1.
# Enable route advertisement from Level-2 to Level-1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] import-route isis level-2 into level-1
import-route
import-route isisv6 level-1 into level-2
Use import-route isisv6 level-1 into level-2 to enable route advertisement from Level-1 to Level-2.
Use undo import-route isisv6 level-1 into level-2 to disable route advertisement from Level-1 to Level-2.
import-route isisv6 level-1 into level-2 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
tag tag: Specifies an administrative tag for marking redistributed routes, in the range of 1 to 4294967295.
This command enables a Level-1-2 router to redistribute Level-1 routes to Level-2 routers and Level-1-2 routers in the local area.
When you specify an IPv6 ACL, follow these guidelines:
[Sysname] isis 1
[Sysname-isis-1-ipv6] import-route isisv6 level-1 into level-2
import-route isisv6 level-2 into level-1
Use import-route isisv6 level-2 into level-1 to enable IPv6 IS-IS route advertisement from Level-2 to Level-1.
Use undo import-route isisv6 level-2 into level-1 to restore the default.
import-route isisv6 level-2 into level-1 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
IPv6 IS-IS route advertisement from Level-2 to Level-1 is disabled.
This command enables a Level-1-2 router to redistribute Level-2 routes to the Level-1 and Level-1-2 routers in the local area.
# Enable IPv6 IS-IS route advertisement from Level-2 to Level-1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] import-route isisv6 level-2 into level-1
import-route limit
Use import-route limit to configure the maximum number of redistributed Level 1/Level 2 routes.
Use undo import-route limit to restore the default.
import-route limit number
The maximum number of redistributed Level 1/Level 2 IPv4 routes is not configured.
number: Specifies the maximum number of redistributed Level 1/Level 2 routes. In IS-IS IPv4 unicast address family view, the value range for this argument is 1 to 4145152. In IS-IS IPv6 unicast address family view, the value range for this argument is 1 to 2048000.
# Configure IS-IS process 1 to redistribute up to 1000 Level 1/Level 2 IPv4 routes.
[Sysname] isis 1
[Sysname-isis-1-ipv4] import-route limit 1000
import-route
import-route no-route-calculate
Use import-route no-route-calculate to exclude redistributed routes from route calculation.
Use undo import-route no-route-calculate to restore the default.
Redistributed routes can participate in route calculation.
By default, IS-IS adds only the redistributed route into the routing table if the following conditions exist:
·     The redistributed route and the learned route have the same route prefix.
·     The redistributed route has a higher preference value than the learned route.
In such a scenario, SR-MPLS and SRv6 cannot run normally because IS-IS does not generate any LSP for the learned route. To resolve this issue, use the import-route no-route-calculate command to exclude the redistributed route from route calculation. Then, IS-IS adds only the learned route into the routing table and generates an LSP for the learned route.
This command can take effect on a redistributed route only when this route has the same route prefix as a learned route.
# Exclude routes redistributed by IS-IS process 1 from route calculation.
[Sysname] isis 1
[Sysname-isis-1-ipv4] import-route no-route-calculate
import-route
preference
Use inter-level-tilfa level-1 enable to enable Level-1 TI-LFA to use a Level-2 path as the backup path.
Use undo inter-level-tilfa level-1 enable to disable Level-1 TI-LFA from using a Level-2 path as the backup path.
inter-level-tilfa level-1 enable [ prefer ]
undo inter-level-tilfa level-1 enable [ prefer ]
Level-1 TI-LFA cannot use a Level-2 path as the backup path.
prefer: Configures Level-1 TI-LFA to prefer Level-2 paths during backup path calculation. If you do not specify this keyword, Level-1 TI-LFA prefers Level-1 paths during backup path calculation.
By default, IS-IS does not support inter-level TI-LFA route calculation. If a backup path cannot be calculated in Level-1, TI-LFA cannot provide link or node protection for SR-MPLS tunnels or SRv6 tunnels. To resolve this issue, you can execute this command to enable Level-1 TI-LFA to use a Level-2 path as the backup path.
The inter-level-tilfa level-1 enable command configured in IS-IS IPv4 unicast address family view does not take effect if the following commands are configured in IS-IS IPv4 unicast address family view:
# Enable Level-1 TI-LFA to use a Level-2 path as the backup path.
[Sysname] isis 1
[Sysname-isis-1-ipv4] inter-level-tilfa level-1 enable
fast-reroute
isis
Use isis to enable IS-IS and enter IS-IS view.
Use undo isis to disable IS-IS.
isis [ process-id ] [ lite ] [ vpn-instance vpn-instance-name ]
undo isis [ process-id ]
IS-IS is disabled.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. The default is 1.
lite: Specifies the lightweight mode. If you do not specify this keyword, the specified process operates in traditional mode.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, the IS-IS process runs on the public network.
Enabling multiple IS-IS processes on a device might cause memory insufficiency. To resolve this issue, specify the lite keyword when you use this command to create IS-IS processes.
Although lightweight processes use less memory resources than traditional processes, device performance might degrade when a large number of neighbors and routes exist. As a best practice, plan the number of lightweight IS-IS processes to be enabled on the basis of the device resource condition.
To configure a traditional IS-IS process as a lightweight process, perform the following tasks:
1.     Use the undo isis command to disable the process.
2.     Use the isis command with the lite keyword specified to enable the process.
When you use this command to enter the view of an existing lightweight IS-IS process, you do not need to specify the lite keyword.
# Enable IS-IS process 1 and set the system ID to 0000.0000.0002 and area ID to 01.0001.
[Sysname] isis 1
[Sysname-isis-1] network-entity 01.0001.0000.0000.0002.00
isis enable
network-entity
isis affinity flex-algo
Use isis affinity flex-algo to assign affinity attributes to IS-IS links.
Use undo isis affinity flex-algo to restore the default.
isis process-id affinity flex-algo { affinity-name }&<1-32>
undo isis process-id affinity flex-algo
An IS-IS link has no affinity attributes.
Interface view
affinity-name&<1-32>: Specifies affinity attributes by their names. The affinity name must be a case-sensitive string of 1 to 32 characters. &<1-32> indicates that you can specify a maximum of 32 affinity names.
If you perform this task on an IS-IS interface, the links between the interface and its neighbors will carry the affinity attributes that you have specified.
In a flexible algorithm scenario, these links will be filtered for path calculation based on the link constraints in the FAD.
# Assign affinity attribute red to interface Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet 3/0/1] isis 1 affinity flex-algo red
affinity-map
isis authentication send-only
Use isis authentication send-only to configure an IS-IS interface not to check the authentication information in the received hello packets.
Use undo isis authentication send-only to remove the configuration.
isis authentication send-only [ level-1 | level-2 ]
undo isis authentication send-only [ level-1 | level-2 ]
When interface authentication mode and key are configured, an IS-IS interface checks the authentication information in the received packets.
Interface view
level-1: Configures IS-IS not to check the authentication information in the received Level-1 hello packets.
level-2: Configures IS-IS not to check the authentication information in the received Level-2 hello packets.
When peer authentication mode and key are configured, an IS-IS interface adds the key in the specified mode into transmitted hello packets. It also checks the key in the received hello packets.
To prevent packet exchange failure in case of an authentication key change, configure the IS-IS interface not to check the authentication information in the received packets.
# Configure Ten-GigabitEthernet 3/0/1 not to check the authentication information in the received Level-1 hello packets.
[Sysname-Ten-GigabitEthernet3/0/1] isis authentication send-only level-1
area-authentication send-only
domain-authentication send-only
isis authentication-mode
Use isis authentication-mode to specify the neighbor relationship authentication mode and a key.
Use undo isis authentication-mode to remove the configuration.
isis [ process-id process-id ] authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ level-1 | level-2 ] [ ip | osi ]
undo isis [ process-id process-id ] authentication-mode [ level-1 | level-2 ]
No neighbor relationship authentication mode or key is configured.
Interface view
process-id process-id: Specifies an IS-IS multi-instance process by its ID in the range of 1 to 65535. If you do not specify this option, the traditional IS-IS process is specified.
gca: Specifies the GCA mode.
key-id: Uniquely identifies an SA in the range of 1 to 65535. The sender inserts the Key ID into the authentication TLV, and the receiver authenticates the packet by using the SA that is selected based on the Key ID.
hmac-sha-1: Specifies the HMAC-SHA-1 algorithm.
hmac-sha-224: Specifies the HMAC-SHA-224 algorithm.
hmac-sha-256: Specifies the HMAC-SHA-256 algorithm.
hmac-sha-384: Specifies the HMAC-SHA-384 algorithm.
hmac-sha-512: Specifies the HMAC-SHA-512 algorithm.
nonstandard: Specifies the nonstandard GCA mode.
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. In simple authentication mode and GCA authentication mode, the plaintext form of the key is a case-sensitive string of 1 to 16 characters, and the encrypted form is a case-sensitive string of 33 to 53 characters. In MD5 authentication mode, the plaintext form of the key is a case-sensitive string of 1 to 255 characters, and the encrypted form is a case-sensitive string of 33 to 373 characters.
keychain: Specifies the keychain authentication mode.
keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters.
level-1: Configures the key for Level-1.
level-2: Configures the key for Level-2.
ip: Checks IP-related fields in LSPs and SNPs.
osi: Checks OSI-related fields in LSPs and SNPs.
The key in the specified mode is inserted into all outbound hello packets and is used for authenticating inbound hello packets. Only if the authentication succeeds can the neighbor relationship be formed.
IS-IS keychain authentication supports the HMAC-MD5 and HMAC-SM3 authentication algorithms. If the HMAC-MD5 algorithm is used, the key ID can be any value in the range supported by the key-id argument. If the HMAC-SM3 algorithm is used, the key ID must be in the range of 0 to 65535.
When keychain authentication is used, IS-IS receives and sends packets as follows:
·     Before IS-IS sends a hello packet, it uses the valid send key obtained from the keychain to authenticate the packet. If no valid send key exists or the valid send key does not use the HMAC-MD5 or HMAC-SM3 algorithm, the authentication fails and the packet does not contain the authentication information.
·     After IS-IS receives a hello packet, it processes the packet as follows:
¡     If the authentication algorithm of the packet is HMAC-MD5, IS-IS uses a valid accept key obtained from the keychain to authenticate the packet. If no valid accept key exists or all valid accept keys fail to authenticate the packet, the authentication fails and the packet is discarded.
¡     If the authentication algorithm of the packet is HMAC-SM3, IS-IS uses the key ID of the received packet to obtain the corresponding valid accept key from the keychain. Then, IS-IS uses the accept key to authenticate the packet. If IS-IS cannot find a valid accept key based on the key ID of the received packet or the packet fails the authentication, the packet is discarded.
The level-1 and level-2 keywords are configurable on an interface that has had IS-IS enabled with the isis enable command.
If you configure a key without specifying a level, the key applies to both Level-1 and Level-2.
For two routers to become neighbors, the authentication mode and key at both ends must be identical.
If neither ip nor osi is specified, the OSI-related fields in LSPs are checked.
When you specify the GCA mode, follow these guidelines:
·     If you do not specify the nonstandard keyword, the device can communicate only with devices (including non-H3C devices) that use the GCA mode.
·     If you specify the nonstandard keyword, the device can communicate only with devices that use the nonstandard GCA mode.
In MD5 authentication mode, execute the undo isis authentication-mode command before version switch if the key lengths supported by the two versions are different.
# On Ten-GigabitEthernet 3/0/1, set the authentication mode to simple, and set the plaintext key to 123456.
[Sysname-Ten-GigabitEthernet3/0/1] isis authentication-mode simple plain 123456
area-authentication-mode
domain authentication-mode
isis bfd adjust-cost
Use isis bfd adjust-cost to enable BFD session state-based interface cost adjustment on an IPv4 IS-IS interface.
Use undo isis bfd adjust-cost to restore the default.
isis bfd adjust-cost { cost-offset | max }
An IPv4 IS-IS interface inherits the configuration of the bfd all-interfaces adjust-cost command in IS-IS IPv4 unicast address family view.
Interface view
cost-offset: Specifies the interface cost adjustment value. The value range for this argument is 1 to 16777213. When the BFD session goes down, the interface cost is cost-offset plus the original interface cost, and cannot exceed 16777214.
max: Sets the interface cost to the maximum value (16777214) when the BFD session goes down.
·     IMPORTANT
IMPORTANT:
For the isis bfd adjust-cost command to take effect on an IPv4 IS-IS interface, enable BFD on that interface first.
After you enable BFD for IPv4 IS-IS link failure detection, IPv4 IS-IS neighbor relationship flapping will occur upon frequent BFD session state changes. The running of services (such as BGP) that rely on IPv4 IS-IS might be interrupted. To resolve this issue, enable IPv4 IS-IS to adjust the interface cost according to the BFD session state. IPv4 IS-IS will adjust the cost value for an interface as follows to ensure fast route convergence against link state changes:
·     When the BFD session on the interface goes down, IPv4 IS-IS increases the cost value for the interface.
·     When the BFD session on the interface comes up again, IPv4 IS-IS restores the cost value for the interface to the original value.
You can perform one of the following tasks to enable BFD session state-based interface cost adjustment for IPv4 IS-IS:
·     Use the bfd all-interfaces adjust-cost command in IPv4 IS-IS unicast address family view. This task takes effect on all interfaces in the current IPv4 IS-IS process.
·     Use the isis bfd adjust-cost command in interface view. This task takes effect only on the current IPv4 IS-IS interface.
For an IPv4 IS-IS interface, the isis bfd adjust-cost command takes precedence over the bfd all-interfaces adjust-cost command. The interface uses the configuration of the bfd all-interfaces adjust-cost command only when you do not execute the isis bfd adjust-cost command on that interface.
# Enable BFD session state-based interface cost adjustment on IPv4 IS-IS interface Ten-GigabitEthernet 3/0/1, and set the interface cost adjustment value to 100.
[Sysname-Ten-GigabitEthernet3/0/1] isis enable 1
[Sysname-Ten-GigabitEthernet3/0/1] isis bfd enable
[Sysname-Ten-GigabitEthernet3/0/1] isis bfd adjust-cost 100
display isis interface
isis bfd enable
isis bfd adjust-cost exclude
Use isis bfd adjust-cost exclude to suppress BFD session state-based interface cost adjustment on an IPv4 IS-IS interface.
Use undo isis bfd adjust-cost exclude to restore the default.
IPv4 IS-IS can adjust the cost value for an interface according to the BFD session state.
Interface view
The bfd all-interfaces adjust-cost command enables BFD session state-based interface cost adjustment on all interfaces in an IS-IS process. To disable this feature on an interface in that IS-IS process, use the isis bfd adjust-cost exclude command on the interface.
When you use the following commands together on the same IPv4 IS-IS interface, the command that is used at last takes effect:
·     isis bfd adjust-cost exclude
# Suppress BFD session state-based interface cost adjustment on IPv4 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis bfd adjust-cost exclude
isis bfd enable
Use isis bfd enable to enable BFD on an IPv4 IS-IS interface.
Use undo isis bfd enable to restore the default.
isis bfd enable
An IPv4 IS-IS interface inherits the configuration of the bfd all-interfaces enable command in IS-IS IPv4 unicast address family view.
Interface view
IPv4 IS-IS exchanges hello packets at specific intervals with its neighbors to detect neighbor state changes. If IPv4 IS-IS does not receive any hello packets from a neighbor within the advertised neighbor relationship hold time, it considers the neighbor down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval and the default hold time is 30 seconds. This mechanism is not efficient at neighbor state change detection. Serious packet loss might occur when a neighbor goes down.
To resolve this issue, use this command to enable BFD. BFD provides a single mechanism to quickly detect and monitor the connectivity of links between IPv4 IS-IS neighbors, reducing route convergence time.
You can perform one of the following tasks to enable BFD for IPv4 IS-IS:
·     Use the bfd all-interfaces enable command in IPv4 IS-IS unicast address family view. This task takes effect on all interfaces in the current IPv4 IS-IS process.
·     Use the isis bfd enable command in interface view. This task takes effect only on the current IPv4 IS-IS interface.
For an IPv4 IS-IS interface, the isis bfd enable command takes precedence over the bfd all-interfaces enable command. The interface uses the configuration of the bfd all-interfaces enable command only when you do not execute the isis bfd enable command on that interface.
# Enable BFD on IPv4 IS-IS interface Ten-GigabitEthernet 3/0/1.
isis bfd exclude
Use isis bfd exclude to suppress the BFD capacity of an IPv4 IS-IS interface.
Use undo isis bfd exclude to restore the default.
isis bfd exclude
The BFD capacity of an IPv4 IS-IS interface is not suppressed.
Interface view
The bfd all-interfaces enable command enables BFD on all interfaces in an IPv4 IS-IS process. To disable BFD on an interface in that IS-IS process, use the isis bfd exclude command on the interface.
·     isis bfd exclude
·     isis bfd enable
# Suppress the BFD capacity of IPv4 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis bfd exclude
isis bfd enable
isis bfd session-restrict-adj
Use isis bfd session-restrict-adj to enable BFD session state-based control of adjacency establishment and maintenance on an IPv4 IS-IS interface.
Use undo isis bfd session-restrict-adj to restore the default.
An IPv4 IS-IS interface inherits the configuration of the bfd all-interfaces session-restrict-adj command in IS-IS IPv4 unicast address family view.
Interface view
Application scenarios
When BFD detects a Layer 3 forwarding failure between two devices, the BFD session goes down, which causes the IPv4 IS-IS adjacency to go down. If Layer 2 forwarding is still available, the devices can exchange IS-IS packets and re-establish the adjacency, which might cause traffic loss. To avoid the issue, execute this command on the BFD-enabled interfaces of the local and remote devices.
Operating mechanism
This command enables the interfaces to carry BFD-enabled TLVs in hello packets. After the BFD session goes down, the devices do not establish an adjacency if the exchanged BFD-enabled TLVs are identical.
If you configure this command for an existing adjacency, the BFD session state does not affect the adjacency relationship within the hold time. This mechanism avoids adjacency flaps during the BFD session establishment.
If the IS-IS neighbor relationship goes down because of Layer 2 forwarding failure between the devices, the interface-associated BFD session state is not affected. That is, when the IS-IS neighbor state changes from up to down, the associated BFD session state does not go down.
IMPORTANT
IMPORTANT:
For the isis bfd session-restrict-adj command to take effect on an IPv4 IS-IS interface, enable BFD on that interface first.
You can perform one of the following tasks to enable BFD session state-based control of IPv4 IS-IS adjacency establishment and maintenance:
·     Use the bfd all-interfaces session-restrict-adj command in IPv4 IS-IS unicast address family view. This task takes effect on all interfaces in the current IPv4 IS-IS process.
·     Use the isis bfd session-restrict-adj command in interface view. This task takes effect only on the current IPv4 IS-IS interface.
For an IPv4 IS-IS interface, the isis bfd session-restrict-adj command takes precedence over the bfd all-interfaces session-restrict-adj command. The interface uses the configuration of the bfd all-interfaces session-restrict-adj command only when you do not execute the isis bfd session-restrict-adj command on that interface.
# Enable BFD session state-based control of adjacency establishment and maintenance on IPv4 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis bfd session-restrict-adj
isis bfd enable
isis bfd session-restrict-adj exclude
Use isis bfd session-restrict-adj exclude to suppress BFD session state-based control of adjacency establishment and maintenance on an IPv4 IS-IS interface.
Use undo isis bfd session-restrict-adj exclude to restore the default.
BFD session state-based control of adjacency establishment and maintenance is not suppressed on an IPv4 IS-IS interface.
Interface view
The bfd all-interfaces session-restrict-adj command enables BFD session state-based control of adjacency establishment and maintenance on all interfaces in an IPv4 IS-IS process. To disable this feature on an interface in that IS-IS process, use the isis bfd session-restrict-adj exclude command on the interface.
·     isis bfd session-restrict-adj exclude
# Suppress BFD session state-based control of adjacency establishment and maintenance on IPv4 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis bfd session-restrict-adj exclude
isis bfd template
Use isis bfd template to apply a BFD template to an IPv4 IS-IS interface.
Use undo isis bfd template to restore the default.
isis bfd template template-name
No BFD template is applied to an IPv4 IS-IS interface. Configuration of the bfd all-interfaces template command in IS-IS IPv4 unicast address family view takes effect on the interface.
Interface view
template-name: Specifies the name of a BFD template, a case-sensitive string of 1 to 63 characters.
After you enable BFD for IS-IS and apply a BFD template, IS-IS notifies BFD of the following information when using BFD to detect the link to a neighbor:
·     Destination address.
·     Source address.
·     Detection parameters defined in the BFD template.
BFD establishes a BFD session based on the information received. By editing detection parameters for the template, you can adjust the speed at which IS-IS detects link failures. For more information about BFD templates, see BFD configuration in High Availability Configuration Guide.
This command takes effect only when BFD is enabled for IS-IS and the specified BFD template exists.
You can use the bfd all-interfaces template or isis bfd template command to apply a BFD template. These commands are different as follows:
·     The bfd all-interfaces template command takes effect on all interfaces in an IPv4 IS-IS process.
·     The isis bfd template command takes effect on a specific IS-IS interface.
·     The interface-specific template configuration by the isis bfd template command takes precedence over the process-specific template configuration by the bfd all-interfaces template command.
# Apply BFD template TEMP1 to IPv4 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis bfd template TEMP1
bfd template
isis bfd enable
isis circuit-level
Use isis circuit-level to set the circuit level for the interface.
Use undo isis circuit-level to restore the default.
isis circuit-level [ level-1 | level-1-2 | level-2 ]
An interface can establish either the Level-1 or Level-2 adjacency.
Interface view
level-1: Sets the circuit level to Level-1.
level-1-2: Sets the circuit level to Level-1-2.
level-2: Sets the circuit level to Level-2.
For a Level-1 (Level-2) router, the circuit level can only be Level-1 (Level-2). For a Level-1-2 router, you must specify a circuit level for a specific interface to form only the specified level neighbor relationship.
# Ten-GigabitEthernet 3/0/1 is connected to a non-backbone router in the same area. Set the circuit level of Ethernet 1/1 to Level-1 to prevent sending and receiving Level-2 Hello packets.
[Sysname-Ten-GigabitEthernet3/0/1] isis circuit-level level-1
is-level
isis circuit-type p2p
Use isis circuit-type p2p to set the network type of an interface to P2P.
Use undo isis circuit-type to restore the default.
isis [ process-id process-id ] circuit-type p2p
isis circuit-type p2p [ mac-by-level ]
undo isis [ process-id process-id ] circuit-type
The network type of an interface varies by physical media. (The network type of a VLAN interface is broadcast.)
Interface view
mac-by-level: Enables the interface to determine the destination MAC address of hello packets by IS-IS level. The destination MAC address is 0180-c200-0014 for Level-1 hello packets and is 0180-c200-0015 for Level-2 hello packets. If you do not specify this keyword, the destination MAC address is 0900-2b00-0005 for the hello packets sent from the interface. This keyword takes effect only on the P2P interfaces enabled with traditional IS-IS processes.
Use this command only on a broadcast network with two attached routers.
Interfaces with different network types operate differently. For example, broadcast interfaces must elect a DIS and flood CSNP packets to synchronize the LSDBs. P2P interfaces do not need to elect a DIS, and use a different LSDB synchronization mechanism.
If only two routers exist on a broadcast network, set the network type of attached interfaces to P2P to avoid DIS election and CSNP flooding. This saves network bandwidth and speeds up network convergence.
The local device and the remote device might fail to establish a neighbor relationship when their hello packets use different destination MAC addresses. To avoid this issue, use this command on both the local device and the remote device to ensure that their hello packets use the same destination MAC address.
# Set the network type of Ten-GigabitEthernet 3/0/1 to P2P.
[Sysname-Ten-GigabitEthernet3/0/1] isis circuit-type p2p
isis enable
multi-instance enable
isis cost
Use isis cost to set the IS-IS cost for an interface.
Use undo isis cost to remove the configuration.
isis [ process-id process-id ] cost cost-value [ level-1 | level-2 ]
undo isis [ process-id process-id ] cost [ level-1 | level-2 ]
No IS-IS cost is configured for an interface.
Interface view
cost-value: Specifies an IS-IS cost. The value range depends on the cost style of the IS-IS process associated with the interface:
·     For styles narrow, narrow-compatible, and compatible, the cost value is in the range of 1 to 63.
·     For styles wide and wide-compatible, the cost value is in the range of 1 to 16777215. If the cost value is set to 16777215, the neighbor TLVs generated from the related links are used only for transmitting TE information and cannot be used for route calculation.
level-1: Applies the cost to Level-1.
level-2: Applies the cost to Level-2.
If neither level-1 nor level-2 is included, the cost applies to both level-1 and level-2.
# Set the Level-2 IS-IS cost to 5 for Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis cost 5 level-2
auto-cost enable
bandwidth-reference
isis cost-fallback
Use isis cost-fallback to change the link cost of a Layer 3 aggregate interface when its bandwidth falls below the threshold.
Use undo isis cost-fallback to remove the configuration.
isis cost-fallback cost-value threshold bandwidth-value [ level-1 | level-2 ]
undo isis cost-fallback [ level-1 | level-2 ]
A Layer 3 aggregate interface uses the original link cost.
cost-value: Specifies a link cost in the range of 1 to 16777215. As a best practice, set the link cost to a value higher than the original link cost of the interface.
threshold bandwidth-value: Specifies the bandwidth threshold in the range of 1 to 2147483648 Mbps.
level-1: Applies the configuration to Level-1 IS-IS.
level-2: Applies the configuration to Level-2 IS-IS.
When a member port of a Layer 3 aggregate interface goes down, the bandwidth of the aggregate interface decreases and services might be interrupted. To resolve this issue, execute this command to change the link cost of a Layer 3 aggregate interface as follows:
·     When the bandwidth of the Layer 3 aggregate interface falls below the bandwidth threshold, the aggregate interface uses the specified link cost. Then, IS-IS can select an optimal path for traffic forwarding.
·     When the bandwidth of the Layer 3 aggregate interface is equal to or larger than the bandwidth threshold, the aggregate interface uses the original link cost.
If you do not specify a level, this command applies to both Level-1 and Level-2 IS-IS.
# Change the link cost of interface Route-Aggregation 1 to 100 when its bandwidth falls below 300 Mbps.
[Sysname] interface Route-Aggregation 1
[Sysname-Route-Aggregation1] isis cost-fallback 100 threshold 300
isis dis-name
Use isis dis-name to configure a name for a DIS to represent the pseudo node on a broadcast network.
Use undo isis dis-name to restore the default.
isis dis-name symbolic-name
undo isis dis-name
No name is configured for the DIS.
Interface view
symbolic-name: Specifies a DIS name, a case-sensitive string of 1 to 64 characters.
This command takes effect only on routers that have dynamic system ID to host name mapping enabled. This command does not take effect on Point-to-Point interfaces.
# Set the DIS name to LOCALAREA.
[Sysname-Ten-GigabitEthernet3/0/1] isis dis-name LOCALAREA
display isis name-table
is-name
isis dis-priority
Use isis dis-priority to specify a DIS priority at a specified level for an interface.
Use undo isis dis-priority to remove the configuration.
isis dis-priority priority [ level-1 | level-2 ]
undo isis dis-priority [ level-1 | level-2 ]
The priority of Level-1 and Level-2 is 64.
Interface view
priority: Specifies a DIS priority in the range of 0 to 127.
level-1: Applies the DIS priority to Level-1.
level-2: Applies the DIS priority to Level-2.
On an IS-IS broadcast network, a router must be elected as the DIS at each routing level. Specify a DIS priority at a level for an interface. The greater the interface's priority is, the more likelihood it becomes the DIS. If multiple routers in the broadcast network have the same highest DIS priority, the router with the highest Subnetwork Point of Attachment (SNPA) address becomes the DIS. SNPA addresses are MAC addresses on a broadcast network.
IS-IS has no backup DIS. The router with a priority of 0 can also participate in DIS election.
If neither level-1 nor level-2 is specified, the DIS priority applies to both Level-1 and Level-2.
# Set the Level-2 DIS priority to 127 for Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis dis-priority 127 level-2
isis enable
Use isis enable to enable an IS-IS process on an interface.
Use undo isis enable to disable IS-IS.
isis enable [ process-id ]
undo isis enable
No IS-IS process is enabled on an interface.
Interface view
# Enable IS-IS process 1 globally and enable it on the Ten-GigabitEthernet 3/0/1.
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
[Sysname-isis-1] quit
isis
network-entity
isis fast-reroute lfa-backup exclude
Use isis fast-reroute lfa-backup exclude to disable LFA calculation on an interface.
Use undo isis fast-reroute lfa-backup exclude to restore the default.
isis fast-reroute lfa-backup exclude [ level-1 | level-2 ]
undo isis fast-reroute lfa-backup exclude [ level-1 | level-2 ]
LFA calculation is enabled on an interface, and the interface can be elected as a backup interface.
Interface view
level-1: Disables LFA calculation on the interface whose circuit level is Level-1.
level-2: Disables LFA calculation on the interface whose circuit level is Level-2.
When this command is configured, the interface does not participate in the LFA calculation, and cannot be elected as a backup interface.
If you do not specify the level-1 or level-2 keyword, LFA calculation is disabled on the interface regardless of its circuit level.
# Disable LFA calculation on Ten-GigabitEthernet 3/0/1.
[Sysname] isis 1
[Sysname-Ten-GigabitEthernet3/0/1] isis fast-reroute lfa-backup exclude
fast-reroute
isis fast-reroute remote-lfa disable
Use isis fast-reroute remote-lfa disable to disable remote LFA calculation on an interface.
Use undo isis fast-reroute remote-lfa disable to enable remote LFA calculation on an interface.
isis fast-reroute remote-lfa disable [ level-1 | level-2 ]
undo isis fast-reroute remote-lfa disable [ level-1 | level-2 ]
Remote LFA calculation is enabled on an interface.
Interface view
level-1: Applies the configuration to Level-1 areas.
level-2: Applies the configuration to the Level-2 area.
Use this command to disable remote LFA calculation on the interface to prevent it from participating in the calculation.
If you specify neither the level-1 nor the level-2 keyword, this command applies to all IS-IS areas.
# Disable remote LFA calculation on interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis fast-reroute remote-lfa disable
isis ipv6 bfd adjust-cost
Use isis ipv6 bfd adjust-cost to enable BFD session state-based interface cost adjustment on an IPv6 IS-IS interface.
Use undo isis ipv6 bfd adjust-cost to restore the default.
isis ipv6 bfd adjust-cost { cost-offset | max }
An IPv6 IS-IS interface inherits the configuration of the bfd all-interfaces adjust-cost command in IS-IS IPv6 unicast address family view.
Interface view
cost-offset: Specifies the value to be added to the interface cost when the BFD session goes down. The value range for this argument is 1 to 16777213. When the BFD session goes down, the interface cost is cost-offset plus the original interface cost, and cannot exceed 16777214.
IMPORTANT
IMPORTANT:
For the isis ipv6 bfd adjust-cost command to take effect on an IPv6 IS-IS interface, enable BFD on that interface first.
After you enable BFD for IPv6 IS-IS link failure detection, IPv6 IS-IS neighbor relationship flapping will occur upon frequent BFD session state changes. The running of services (such as BGP) that rely on IPv6 IS-IS might be interrupted. To resolve this issue, enable IPv6 IS-IS to adjust the interface cost according to the BFD session state. IPv6 IS-IS will adjust the cost value for an interface as follows to ensure fast route convergence against link state changes:
·     When the BFD session on the interface goes down, IPv6 IS-IS increases the cost value for the interface.
·     When the BFD session on the interface comes up again, IPv6 IS-IS restores the cost value for the interface to the original value.
You can perform one of the following tasks to enable IPv6 IS-IS to adjust the interface cost according to the BFD session state:
·     Use the bfd all-interfaces adjust-cost command in IPv6 IS-IS unicast address family view. This task takes effect on all interfaces in the current IPv6 IS-IS process.
·     Use the isis ipv6 bfd adjust-cost command in interface view. This task takes effect only on the current IPv6 IS-IS interface.
For an IPv6 IS-IS interface, the isis ipv6 bfd adjust-cost command takes precedence over the bfd all-interfaces adjust-cost command. The interface uses the configuration of the bfd all-interfaces adjust-cost command only when you do not execute the isis ipv6 bfd adjust-cost command on that interface.
# Enable BFD session state-based interface cost adjustment on IPv6 IS-IS interface Ten-GigabitEthernet 3/0/1, and set the interface cost adjustment value to 200.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 enable 1
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 bfd enable
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 bfd adjust-cost 200
isis ipv6 bfd adjust-cost exclude
Use isis ipv6 bfd adjust-cost exclude to suppress BFD session state-based interface cost adjustment on an IPv6 IS-IS interface.
Use undo isis ipv6 bfd adjust-cost exclude to restore the default.
IPv6 IS-IS can adjust the cost value for an interface according to the BFD session state.
Interface view
The bfd all-interfaces adjust-cost command enables BFD session state-based interface cost adjustment on all interfaces in an IPv6 IS-IS process. To disable this feature on an interface in that IS-IS process, use the isis ipv6 bfd adjust-cost exclude command on the interface.
When you use the following commands together on the same IPv6 IS-IS interface, the command that is used at last takes effect:
·     isis ipv6 bfd adjust-cost exclude
# Suppress BFD session state-based interface cost adjustment on IPv6 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 bfd adjust-cost exclude
Use isis ipv6 bfd enable to enable BFD on IPv6 IS-IS interface.
Use undo isis ipv6 bfd enable to restore the default.
An IPv4 IS-IS interface inherits the configuration of the bfd all-interfaces enable command in IS-IS IPv6 unicast address family view.
Interface view
IPv6 IS-IS exchanges hello packets at specific intervals with its neighbors to detect neighbor state changes. If IPv6 IS-IS does not receive any hello packets from a neighbor within the advertised neighbor relationship hold time, it considers the neighbor down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval and the default hold time is 30 seconds. This mechanism is not efficient at neighbor state change detection. Serious packet loss might occur when a neighbor goes down.
To resolve this issue, use this command to enable BFD on the IPv6 IS-IS interface. BFD provides a single mechanism to quickly detect and monitor the connectivity of links between IPv6 IS-IS neighbors, reducing route convergence time.
You can perform one of the following tasks to enable BFD for IPv6 IS-IS:
·     Use the bfd all-interfaces enable command in IPv6 IS-IS unicast address family view. This task takes effect on all interfaces in the current IPv6 IS-IS process.
·     Use the isis ipv6 bfd enable command in interface view. This task takes effect only on the current IPv6 IS-IS interface.
For an IPv6 IS-IS interface, the isis ipv6 bfd enable command takes precedence over the bfd all-interfaces enable command. The interface uses the configuration of the bfd all-interfaces enable command only when you do not execute the isis ipv6 bfd enable command on that interface.
# Enable BFD on IPv6 IS-IS interface Ten-GigabitEthernet3/0/1.
isis ipv6 bfd exclude
Use isis ipv6 bfd exclude to suppress the BFD capacity of an IPv6 IS-IS interface.
Use undo isis ipv6 bfd exclude to restore the default.
The BFD capacity of an IPv6 IS-IS interface is not suppressed.
Interface view
The bfd all-interfaces enable command enables BFD on all interfaces in an IPv6 IS-IS process. To disable BFD on an interface in that IS-IS process, use the isis ipv6 bfd exclude command on the interface.
·     isis ipv6 bfd exclude
·     isis ipv6 bfd enable
# Suppress the BFD capacity of IPv6 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 bfd exclude
isis ipv6 bfd session-restrict-adj
Use isis ipv6 bfd session-restrict-adj to enable BFD session state-based control of adjacency establishment and maintenance on an IPv6 IS-IS interface.
Use undo isis ipv6 bfd session-restrict-adj to restore the default.
An IPv6 IS-IS interface inherits the configuration of the bfd all-interfaces session-restrict-adj command in IS-IS IPv6 unicast address family view.
Interface view
When BFD detects a Layer 3 forwarding failure between two routers, the BFD session goes down, which causes the IPv6 IS-IS adjacency to go down. If Layer 2 forwarding is still available, the routers can exchange IS-IS packets and re-establish the adjacency, which might cause traffic loss. To avoid the issue, execute this command on the BFD-enabled interfaces of the local and remote routers.
Operating mechanism
This command enables the interfaces to carry BFD-enabled TLVs in hello packets. After the BFD session goes down, the routers do not establish an adjacency if the exchanged BFD-enabled TLVs are identical.
IMPORTANT
IMPORTANT:
For the isis ipv6 bfd session-restrict-adj command to take effect on an IPv6 IS-IS interface, enable BFD on that interface first.
You can perform one of the following tasks to enable BFD session state-based control of IPv6 IS-IS adjacency establishment and maintenance:
·     Use the bfd all-interfaces session-restrict-adj command in IPv6 IS-IS unicast address family view. This task takes effect on all interfaces in the current IPv6 IS-IS process.
·     Use the isis ipv6 bfd session-restrict-adj command in interface view. This task takes effect only on the current IPv6 IS-IS interface.
For an IPv6 IS-IS interface, the isis ipv6 bfd session-restrict-adj command takes precedence over the bfd all-interfaces session-restrict-adj command. The interface uses the configuration of the bfd all-interfaces session-restrict-adj command only when you do not execute the isis ipv6 bfd session-restrict-adj command on that interface.
# Enable BFD session state-based control of adjacency establishment and maintenance on IPv6 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 bfd session-restrict-adj
isis ipv6 bfd session-restrict-adj exclude
Use isis ipv6 bfd session-restrict-adj exclude to suppress BFD session state-based control of adjacency establishment and maintenance on an IPv6 IS-IS interface.
Use undo isis ipv6 bfd session-restrict-adj exclude to restore the default.
BFD session state-based control of adjacency establishment and maintenance is not suppressed on an IPv6 IS-IS interface.
Interface view
The bfd all-interfaces session-restrict-adj command enables BFD session state-based control of adjacency establishment and maintenance on all interfaces in an IPv6 IS-IS process. To disable this feature on an interface in that IS-IS process, use the isis ipv6 bfd session-restrict-adj exclude command on the interface.
·     isis ipv6 bfd session-restrict-adj exclude
# Suppress BFD session state-based control of adjacency establishment and maintenance on IPv6 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 bfd session-restrict-adj exclude
isis ipv6 bfd template
Use isis ipv6 bfd template to apply a BFD template to an IPv6 IS-IS interface.
Use undo isis ipv6 bfd template to restore the default.
isis ipv6 bfd template template-name
No BFD template is applied to an IPv6 IS-IS interface. Configuration of the bfd all-interfaces template command in IS-IS IPv6 unicast address family view takes effect on the interface.
Interface view
·     Source address.
You can use the bfd all-interfaces template or isis ipv6 bfd template command to apply a BFD template. These commands are different as follows:
·     The bfd all-interfaces template command takes effect on all interfaces in an IPv6 IS-IS process.
·     The isis ipv6 bfd template command takes effect on a specific IS-IS interface.
·     The interface-specific template configuration by the isis ipv6 bfd template command takes precedence over the process-specific template configuration by the bfd all-interfaces template command.
# Apply BFD template TEMP1 to IPv6 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 bfd template TEMP1
bfd template
isis bfd enable
isis ipv6 cost
Use isis ipv6 cost to set the IPv6 IS-IS cost for an interface.
Use undo isis ipv6 cost to remove the configuration.
isis [ process-id process-id ] ipv6 cost cost-value [ level-1 | level-2 ]
undo isis [ process-id process-id ] ipv6 cost [ level-1 | level-2 ]
No IPv6 IS-IS cost is configured for an interface.
Interface view
cost-value: Specifies an IPv6 IS-IS cost in the range of 1 to 16777215.
level-1: Applies the cost to Level-1 routes.
level-2: Applies the cost to Level-2 routes.
This command applies to interfaces that are enabled with IPv6 IS-IS.
This command takes effect only when the standard MTR mode is enabled.
# Set the IPv6 IS-IS cost to 10 for Ten-GigabitEthernet3/0/1.
[Sysname] isis 100
[Sysname-isis-100] address-family ipv6 unicast
[Sysname-isis-100-ipv6] quit
[Sysname-isis-100] quit
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 enable 100
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 cost 10
isis ipv6 cost-fallback
Use isis ipv6 cost-fallback to change the IPv6 link cost of a Layer 3 aggregate interface when its bandwidth falls below the threshold.
isis ipv6 cost-fallback cost-value threshold bandwidth-value [ level-1 | level-2 ]
undo isis ipv6 cost-fallback [ level-1 | level-2 ]
A Layer 3 aggregate interface uses the original IPv6 link cost.
cost-value: Specifies an IPv6 link cost in the range of 1 to 16777215. As a best practice, set the link cost to a value higher than the original IPv6 link cost of the interface.
When a member port of a Layer 3 aggregate interface goes down, the bandwidth of the aggregate interface decreases and services might be interrupted. To resolve this issue, execute this command to change the IPv6 link cost of a Layer 3 aggregate interface as follows:
·     When the bandwidth of the Layer 3 aggregate interface falls below the bandwidth threshold, the aggregate interface uses the specified IPv6 link cost. Then, IS-IS can select an optimal path for traffic forwarding.
·     When the bandwidth of the Layer 3 aggregate interface is equal to or larger than the bandwidth threshold, the aggregate interface uses the original IPv6 link cost.
# Change the IPv6 link cost of interface Route-Aggregation 1 to 100 when its bandwidth falls below 300 Mbps.
[Sysname-Route-Aggregation1] isis ipv6 cost-fallback 100 threshold 300
isis ipv6 enable
Use isis ipv6 enable to enable IPv6 for IS-IS on an interface.
Use undo isis ipv6 enable to disable IPv6 for IS-IS on an interface.
isis ipv6 enable [ process-id ]
IPv6 is disabled for IS-IS on an interface.
Interface view
# Enable IPv6 for IS-IS on Ten-GigabitEthernet3/0/1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6 unicast
[Sysname-isis-1-ipv6] quit
[Sysname-Ten-GigabitEthernet3/0/1] ipv6 address 2002::1/64
isis ipv6 fast-reroute lfa-backup exclude
Use isis ipv6 fast-reroute lfa-backup exclude to disable LFA calculation on an interface.
Use undo isis ipv6 fast-reroute lfa-backup exclude to restore the default.
isis ipv6 fast-reroute lfa-backup exclude [ level-1 | level-2 ]
undo isis ipv6 fast-reroute lfa-backup exclude [ level-1 | level-2 ]
Interface view
# Disable LFA calculation on Ten-GigabitEthernet3/0/1.
[Sysname] isis 1
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 fast-reroute lfa-backup exclude
fast-reroute
isis ipv6 link-tag
Use isis ipv6 link-tag to set an IPv6 IS-IS link tag for an interface.
Use undo isis ipv6 link-tag to restore the default.
isis ipv6 link-tag tag
No IPv6 IS-IS link tag is configured for an interface.
Interface view
tag: Specifies an IPv6 IS-IS link tag in the range of 1 to 4294967295.
Execute this command together with the link-tag inherit enable command to filter routes based on IPv6 IS-IS link tags.
If you execute this command multiple times on an interface, the most recent configuration takes effect.
# Set the IPv6 IS-IS link tag for interface Ten-GigabitEthernet 3/0/1 to 222333.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 link-tag 222333
isis ipv6 member-port suppress-flapping
Use isis ipv6 member-port suppress-flapping to configure the detection parameters for IPv6 IS-IS to suppress member port flapping on an aggregate interface.
Use undo isis ipv6 member suppress-flapping to remove the configuration.
isis ipv6 member-port suppress-flapping { [ detect-interval detect-interval | threshold threshold | resume-interval resume-interval ] * | non-conservative }
undo isis ipv6 member-port suppress-flapping { [ detect-interval | threshold | resume-interval ] * | non-conservative }
The detection timer is 60 seconds, the threshold is 10, and the resume timer is 120 seconds.
detect-interval detect-interval: Specifies the timer for member port flapping detection. The value range for the detect-interval argument is 1 to 300 seconds and the default value is 60.
threshold threshold: Specifies the number of member port flapping events that triggers member port flapping suppression. The value range for the threshold argument is 1 to 1000 and the default value is 10.
resume-interval resume-interval: Specifies the resume timer that IPv6 IS-IS must wait before restoring the aggregate interface cost to the original. The value range for the resume-interval argument is 2 to 1000 seconds and the default value is 120.
non-conservative: Sets the flapping suppression mode to non-conservative. In the non-conservative mode, IPv6 IS-IS increases the number of member port flapping events by one each time a link failure occurs on a member port. To set the flapping suppression mode to conservative, do not specify this keyword. In the conservative mode, IPv6 IS-IS increases the number of member port flapping events by one only when the time gap between two link failures in a row is not longer than the detection timer.
IPv6 IS-IS supports the conservative and non-conservative modes for member port flapping suppression.
The conservative mode functions as follows:
Table 61 After you enable member port flapping suppression on an aggregate interface, the aggregate interface starts a flapping event counter to collect statistics about the flapping events that occur on its member ports. When the time gap between two link failures in a row is shorter than the detection timer, IPv6 IS-IS increases the number of member port flapping events by one.
IPv6 IS-IS resets and restarts the flapping event counter when the following conditions exist:
¡     The number of member port flapping events is less than the threshold that triggers member port flapping suppression.
¡     The time gap between two link failures in a row is longer than the resume timer.
1.     IPv6 IS-IS compares the number of member port flapping events with the threshold that triggers member port flapping suppression:
¡     If the number of member port flapping events is less than the threshold, IPv6 IS-IS does not suppress member port flapping.
¡     If the number of member port flapping events is not less than the threshold, IPv6 IS-IS starts member port flapping suppression. It increases the cost value for the aggregate interface and resets the flapping event counter to zero.
2.     The resume timer starts as IPv6 IS-IS starts member port flapping suppression. The suppression duration equals the resume timer.
If a link failure occurs on a member port during member port flapping suppression, IPv6 IS-IS restarts the resume timer.
3.     After the resume timer expires, IPv6 IS-IS restores the cost value to the original for the aggregate interface if no link failures occur on member ports before the resume timer expires.
The non-conservative mode functions as follows:
Table 62 After you enable member port flapping suppression on an aggregate interface, the aggregate interface starts a flapping event counter to collect statistics about the flapping events that occur on its member ports. IPv6 IS-IS increases the number of member port flapping events by one each time a link failure occurs on a member port.
When a link failure occurs on a member port, IPv6 IS-IS performs the following tasks:
a.     Record the timestamp of the link failure.
For brief description, the following arguments are introduced:
·     The T argument represents the timestamp that equals the link failure timestamp minus the detection timer.
·     The flapping-count argument represents the number of member port flapping events that occur later than T and not later than the link failure timestamp.
b.     Compare flapping-count with the threshold that triggers member port flapping suppression:
-     If flapping-count is less than the threshold, IPv6 IS-IS does not suppress member port flapping or reset the flapping event counter.
-     If flapping-count is not less than the threshold, IPv6 IS-IS starts member port flapping suppression. It increases the cost value for the aggregate interface and resets the flapping event counter to zero.
4.     The resume timer starts as IPv6 IS-IS starts member port flapping suppression. The suppression duration equals the resume timer.
5.     After the resume timer expires, IPv6 IS-IS restores the cost value to the original for the aggregate interface if no link failures occur on member ports before the resume timer expires.
This command takes effect only after you enable member port flapping suppression by using the isis ipv6 member-port peer suppress-flapping adjust-cost command.
The device performs member port flapping detection for IPv6 IS-IS aggregate interfaces only after you configure the multi-topology command.
# On aggregate interface Route-Aggregation 2, set the detection timer to 5 seconds, the threshold to 2, and the resume timer to 20 seconds.
[Sysname] interface route-aggregation 2
[Sysname-Route-Aggregation2] isis ipv6 enable 1
[Sysname-Route-Aggregation2] isis ipv6 member-port suppress-flapping detect-interval 5 threshold 2 resume-interval 20
isis ipv6 member-port suppress-flapping adjust-cost
Use isis ipv6 member-port suppress-flapping adjust-cost to enable member port flapping suppression on an IPv6 IS-IS aggregate interface and specify the cost adjustment value for the aggregate interface.
Use undo isis ipv6 member-port suppress-flapping adjust-cost to disable member port flapping suppression on an IPv6 IS-IS aggregate interface.
isis ipv6 member-port suppress-flapping adjust-cost { cost-offset | max }
Member port flapping suppression is disabled on an IPv6 IS-IS aggregate interface.
cost-offset: Specifies the cost adjustment value for the aggregate interface. The value range for this argument is 1 to 16777213. When IPv6 IS-IS suppresses member port flapping, the cost value for the aggregate interface is cost-offset plus the original interface cost value, and cannot exceed 16777214.
max: Sets the cost value to the maximum (16777214) for the aggregate interface when IPv6 IS-IS suppresses member port flapping.
When two IS-IS neighbors are connected by Layer 3 aggregate links and the links between member ports flap frequently, the neighbors perform link switchover frequently for traffic forwarding. To resolve this issue, enable member port flapping suppression on the aggregate interfaces.
This feature enables IPv6 IS-IS to suppress member port flapping on an aggregate interface by increasing the cost value for the aggregate interface. Traffic then does not pass through the aggregate interface during member port flapping suppression. When the resume timer for member port flapping suppression expires, IPv6 IS-IS restores the cost value to the original for the aggregate interface.
This command takes effect only after you configure the multi-topology command.
# On aggregate interface Route-Aggregation 2, enable member port flapping suppression and set the cost adjustment value to 1000.
[Sysname-Route-Aggregation2] isis ipv6 member-port suppress-flapping adjust-cost 1000
isis ipv6 metric-delay normalize interval
Use isis ipv6 metric-delay normalize interval to enable link delay normalization and configure link delay normalization settings on an IPv6 IS-IS interface.
Use undo isis ipv6 metric-delay normalize interval to restore the link delay reported by an IPv6 IS-IS interface to the original.
isis [ process-id process-id ] ipv6 metric-delay normalize interval interval-value [ offset offset-value ]
undo isis [ process-id process-id ] ipv6 metric-delay normalize
No link delay normalization settings are configured on an IPv6 IS-IS interface. The configuration of the metric-delay normalize interval command in IS-IS IPv6 unicast address family view takes effect on the IPv6 IS-IS interface.
Interface view
process-id process-id: Specifies an IS-IS multi-instance process by its ID in the range of 1 to 65535. To specify the traditional IS-IS process, do not specify this option.
interval-value: Specifies the interval value for link delay normalization, in milliseconds. The value range for this argument is 1 to 16777215.
offset-value: Specifies the offset value for link delay normalization, in milliseconds. The value range for this argument is 0 to 16777214 and the default value is 0. The offset value must be smaller than the interval value.
By default, when a flexible algorithm performs route calculation based on the link delay values reported by interfaces, it might not make full use of link resources. This is because the flexible algorithm cannot use the links with small link delay differences as equal-cost routes. To resolve this issue, use this command to enable link delay normalization and configure link delay normalization settings on the relevant IPv6 IS-IS interfaces.
When IPv6 IS-IS performs link delay normalization on an interface, it recalculates the link delay reported by the interface, and then advertises the calculation result in LSPs.
During link delay normalization, IPv6 IS-IS recalculates the link delay reported by an interface as follows:
Table 63 Calculates a. This value depends on the calculation result of dm ÷ interval-value.
¡     If the calculation result of dm ÷ interval-value is an integer, a equals dm ÷ interval-value.
¡     If the calculation result of dm ÷ interval-value is not an integer, a equals the greatest integer that is smaller than the calculation result.
1.     Calculates b by using the following formula:
b = a × interval-value + offset-value
2.     Calculates nm.
¡     If dm is not greater than b, nm equals b.
¡     If dm is greater than b, nm equals b plus interval-value.
·     The dm argument represents the link delay measured by NQA TWAMP-light.
·     The interval-value argument represents the interval value specified for link delay normalization.
·     The offset value argument represents the offset value specified for link delay normalization.
·     The nm argument represents the normalized link delay. After link delay normalization, IPv6 IS-IS will advertise the normalized link delay in LSPs.
For example, the link delay of link 1 measured by NQA TWAMP-light is 28 milliseconds, the interval value is 10 milliseconds, and the offset value is 4 milliseconds. IPv6 IS-IS normalizes the interface link delay as follows:
Table 64 Calculates a. The value of a equals 2, because 28 divided by 10 equals 2.8.
3.     Calculates b by using the following formula:
b = 2 × 10 + 4 = 24
4.     Calculates nm. The value of nm is 34 (24 +10), because the original link delay value (28) is greater than b (24).
Provided that the original link delay of link 2 is 32 milliseconds, the normalized link delay of that link is 34 milliseconds, which is the same as that of link 1. In this situation, link 1 and link 2 can be used for load sharing as equal-cost routes.
To configure IPv6 IS-IS link delay normalization, you can use either the metric-delay normalize interval command or the isis ipv6 metric-delay normalize interval command.
·     After you configure the metric-delay normalize interval command in IS-IS IPv6 unicast address family view, the configuration takes effect on all IPv6 IS-IS interfaces.
·     After you configure the isis ipv6 metric-delay normalize interval command on an IPv6 IS-IS interface, the configuration takes effect only on that interface.
·     For an IPv6 IS-IS interface, the configuration of the isis ipv6 metric-delay normalize interval command takes precedence over that of the metric-delay normalize interval command.
The configuration of the metric-delay normalize interval command can take effect on an IPv6 IS-IS interface only when you do not configure the isis ipv6 metric-delay normalize interval command on that interface.
To ensure that a flexible algorithm can calculate equal-cost routes successfully, configure link delay normalization for all nodes or interfaces in the topology of that flexible algorithm.
# Enable link delay normalization and configure link delay normalization settings on IPv6 IS-IS interface Ten-GigabitEthernet 3/0/1. The interval value and the offset value for link delay normalization are 20 milliseconds and 5 milliseconds, respectively.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 metric-delay normalize interval 20 offset 5
isis metric-delay normalize interval
isis ipv6 peer suppress-flapping
Use isis ipv6 peer suppress-flapping to configure the detection parameters for IPv6 IS-IS neighbor flapping suppression.
Use undo isis ipv6 peer suppress-flapping to remove the configuration.
isis ipv6 peer suppress-flapping { [ detect-interval detect-interval | threshold threshold | resume-interval resume-interval ] * | non-conservative }
undo isis ipv6 peer suppress-flapping { [ detect-interval | threshold | resume-interval ] * | non-conservative }
Interface view
detect-interval detect-interval: Specifies the neighbor flapping detection timer. The value range for the detect-interval argument is 1 to 300 seconds and the default value is 60.
threshold threshold: Specifies the number of neighbor flapping events that triggers neighbor flapping suppression. The value range for the threshold argument is 1 to 1000 and the default value is 10.
resume-interval resume-interval: Specifies the resume timer that IPv6 IS-IS must wait before restoring the interface cost to the original. The value range for the resume-interval argument is 2 to 1000 seconds and the default value is 120. The value for the resume-interval argument must be greater than that for the detect-interval argument.
non-conservative: Sets the flapping suppression mode to non-conservative. In the non-conservative mode, IPv6 IS-IS increases the number of neighbor flapping events by one each time a neighbor down event occurs on the interface. To set the flapping suppression mode to conservative, do not specify this keyword. In the conservative mode, IPv6 IS-IS increases the number of neighbor flapping events by one only when the time gap between two neighbor down events in a row is shorter than the detection timer.
IPv6 IS-IS supports the conservative and non-conservative modes for neighbor flapping suppression.
Table 65 After you enable neighbor flapping suppression on an interface, the interface starts a flapping event counter to collect statistics about neighbor flapping events. When the time gap between two neighbor down events in a row is shorter than the detection timer, IPv6 IS-IS increases the number of neighbor flapping events by one.
¡     The number of neighbor flapping events is less than the threshold that triggers neighbor flapping suppression.
¡     The time gap between two neighbor down events in a row is longer than the resume timer.
1.     IPv6 IS-IS compares the number of neighbor flapping events with the threshold that triggers neighbor flapping suppression:
¡     If the number of neighbor flapping events is less than the threshold, IPv6 IS-IS does not suppress neighbor flapping.
¡     If the number of neighbor flapping events is not less than the threshold, IPv6 IS-IS starts neighbor flapping suppression. It increases the cost value for the interface and resets the flapping event counter to zero.
2.     The resume timer starts as IPv6 IS-IS starts neighbor flapping suppression. The suppression duration equals the resume timer.
If a neighbor down event occurs on the interface during neighbor flapping suppression, IPv6 IS-IS restarts the resume timer.
3.     After the resume timer expires, IPv6 IS-IS restores the cost value to the original for the interface if no neighbor flapping events occur on the interface before the resume timer expires.
Table 66 After you enable neighbor flapping suppression on an interface, the interface starts a flapping event counter to collect statistics about neighbor flapping events. IPv6 IS-IS increases the number of neighbor flapping events by one each time a neighbor down event occurs on the interface.
When a neighbor down event occurs on the interface, IPv6 IS-IS performs the following tasks:
a.     Record the timestamp of the neighbor down event.
·     The T argument represents the timestamp that equals the neighbor down event timestamp minus the detection timer.
·     The flapping-count argument represents the number of neighbor flapping events that occur later than T and not later than the neighbor down event timestamp.
b.     Compare flapping-count with the threshold that triggers neighbor flapping suppression:
-     If flapping-count is less than the threshold, IPv6 IS-IS does not suppress neighbor flapping or reset the flapping event counter.
-     If flapping-count is not less than the threshold, IPv6 IS-IS starts neighbor flapping suppression. It increases the cost value for the interface and resets the flapping event counter to zero.
4.     The resume timer starts as IPv6 IS-IS starts neighbor flapping suppression. The suppression duration equals the resume timer.
5.     After the resume timer expires, IPv6 IS-IS restores the cost value to the original for the interface if no neighbor flapping events occur on the interface before the resume timer expires.
This command takes effect only after you enable neighbor flapping suppression by using the isis ipv6 peer suppress-flapping adjust-cost command.
The device performs neighbor flapping detection for IPv6 IS-IS interfaces only after you configure the multi-topology command.
# On interface Ten-GigabitEthernet 3/0/1, set the detection timer to 5 seconds, the threshold to 40, and the resume timer to 20 seconds.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 peer suppress-flapping detect-interval 5 threshold 40 resume-interval 20
Use isis ipv6 peer suppress-flapping adjust-cost to enable neighbor flapping suppression on an IPv6 IS-IS interface and specify the cost adjustment value for the interface.
Use undo isis ipv6 peer suppress-flapping adjust-cost to disable neighbor flapping suppression on an IPv6 IS-IS interface.
isis ipv6 peer suppress-flapping adjust-cost { cost-offset | max }
Neighbor flapping suppression is disabled on an IPv6 IS-IS interface.
Interface view
cost-offset: Specifies the cost adjustment value for the interface. The value range for this argument is 1 to 16777213. When IPv6 IS-IS suppresses neighbor flapping, the cost value for the interface is cost-offset plus the original interface cost value, and cannot exceed 16777214.
max: Sets the cost value to the maximum (16777214) for the interface when IPv6 IS-IS suppresses neighbor flapping.
When the state of an IPv6 IS-IS neighbor flaps frequently, IPv6 IS-IS also frequently performs neighbor relationship re-establishment, LSDB synchronization, and route calculation. Such tasks interrupt IPv6 IS-IS services and other services that depend on IPv6 IS-IS, because performing these tasks requires a large number of packet exchanges. To resolve this issue, configure IPv6 IS-IS neighbor flapping suppression. This feature enables IPv6 IS-IS to suppress neighbor flapping on an interface by increasing the cost value for the interface. Traffic then does not pass through the interface during neighbor flapping suppression. When the resume timer for neighbor flapping suppression expires, IPv6 IS-IS restores the cost value to the original for the interface.
# On interface Ten-GigabitEthernet 3/0/1, enable neighbor flapping suppression and set the cost adjustment value to 1000.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 peer suppress-flapping adjust-cost 1000
isis ipv6 prefix-suppression
Use isis ipv6 prefix-suppression to enable prefix suppression on an interface.
Use undo isis ipv6 prefix-suppression to disable prefix suppression on an interface.
Prefix suppression is disabled on an interface.
Interface view
By default, IS-IS interfaces advertise their IPv6 prefixes in LSPs. Use this command to disable an interface from advertising its IPv6 prefix in LSPs. This enhances network security by preventing IP routing to the internal nodes and speeds up network convergence.
# Enable prefix suppression on Ten-GigabitEthernet3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 prefix-suppression
isis ipv6 primary-path-detect bfd
Use isis ipv6 primary-path-detect bfd to enable BFD-powered primary link failure detection on an IPv6 IS-IS interface.
Use undo isis ipv6 primary-path-detect bfd to restore the default.
isis ipv6 primary-path-detect bfd { ctrl | echo }
An IPv6 IS-IS interface inherits the configuration of the fast-reroute primary-path-detect bfd command in IS-IS IPv6 unicast address family view.
Interface view
ctrl: Enables BFD control packet mode.
echo: Enables BFD echo packet mode.
This command enables IPv6 IS-IS FRR and PIC to use BFD to detect primary link failures. BFD can detect and report a primary link failure to IPv6 IS-IS for a primary-backup path switchover. This can shorten the duration of service interruption.
For an interface to run the BFD session in echo packet mode correctly, make sure the interface has an IPv6 global unicast address. When the IPv6 next hop of the primary route is not a global unicast address, use BFD control packet mode to detect whether the next hop of the primary route is reachable. For more information about IPv6 global unicast addresses, see IPv6 basics configuration in Layer 3—IP Services Configuration Guide.
You can perform one of the following tasks to enable BFD-powered primary link failure detection for IPv6 IS-IS FRR and PIC:
·     Use the fast-reroute primary-path-detect bfd command in IPv6 IS-IS unicast address family view. This task takes effect on all interfaces in the current IPv6 IS-IS process.
·     Use the isis ipv6 primary-path-detect bfd command in interface view. This task takes effect only on the current IPv6 IS-IS interface.
For an IPv6 IS-IS interface, the isis ipv6 primary-path-detect bfd command takes precedence over the fast-reroute primary-path-detect bfd command. The interface uses the configuration of the fast-reroute primary-path-detect bfd command only when you do not execute the isis ipv6 primary-path-detect bfd command on that interface.
# Enable BFD control packet mode for IPv6 IS-IS FRR on Ten-GigabitEthernet3/0/1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] fast-reroute lfa
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 primary-path-detect bfd ctrl
# Enable BFD echo packet mode for IPv6 IS-IS PIC on Ten-GigabitEthernet3/0/2.
[Sysname] isis 1
[Sysname-isis-1] pic additional-path-always
[Sysname] bfd echo-source-ipv6 1::1
[Sysname] interface ten-gigabitethernet 3/0/2
[Sysname-Ten-GigabitEthernet3/0/2] isis ipv6 primary-path-detect bfd echo
isis ipv6 primary-path-detect bfd exclude
Use isis ipv6 primary-path-detect bfd exclude to suppress BFD-powered primary link failure detection on an IPv6 IS-IS interface.
Use undo isis ipv6 primary-path-detect bfd exclude to restore the default.
BFD-powered primary link failure detection is not suppressed on an IPv6 IS-IS interface.
Interface view
The fast-reroute primary-path-detect bfd command enables BFD-powered primary link failure detection on all interfaces in an IPv6 IS-IS process. To disable this feature on an interface in that IS-IS process, use the isis ipv6 primary-path-detect bfd exclude command on the interface.
·     isis ipv6 primary-path-detect bfd exclude
# Suppress BFD-powered primary link failure detection on IPv6 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 primary-path-detect bfd exclude
isis ipv6 tag
Use isis ipv6 tag to configure the administrative tag value on an interface.
Use undo isis ipv6 tag to restore the default.
isis ipv6 tag tag
undo isis ipv6 tag
No administrative tag value is configured on an interface.
Interface view
tag: Specifies a tag value in the range of 1 to 4294967295.
To facilitate route filtering and management, use this command to configure the administrative tag value on an IS-IS interface. For example, after setting different administrative tag values for direct routes and non-direct routes in Level-2 area, you can then configure IS-IS to import only non-direct routes from Level-2 area to Level-1 area.
After you specify an administrative tag value, IS-IS always adds the specified tag value to the IPv6 prefix information in LSPs, regardless of the link cost style.
# Set the administrative tag value on Ten-GigabitEthernet3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 tag 4294967295
cost-style
isis link-delay
Use isis link-delay to configure link delay settings on an IS-IS interface.
Use undo isis link-delay to remove link delay settings on an IS-IS interface.
isis link-delay { average average-delay-value | min min-delay-value max max-delay-value | variation variation-value } *
undo isis link-delay [ average | min | variation ]
No link delay settings are configured on an IS-IS interface.
Interface view
average average-delay-value: Specifies the average link delay on an interface in the range of 1 to 16777215 microseconds. The average-delay-value parameter represents the average link delay for the interface to send a packet to its directly-connected peer. If you do not specify this option, the delay value is the average link delay reported by the interface.
min min-delay-value: Specifies the minimum link delay on an interface in the range of 1 to 16777215 microseconds. The min-delay-value parameter represents the minimum link delay for the interface to send a packet to its directly-connected peer. If you do not specify this option, the delay value is the minimum link delay reported by the interface.
max max-delay-value: Specifies the maximum link delay on an interface in the range of 1 to 16777215 microseconds. The max-delay-value parameter represents the maximum link delay for the interface to send a packet to its directly-connected peer. If you do not specify this option, the delay value is the maximum link delay reported by the interface.
variation variation-value: Sets the acceptable delay variation on an interface in the range of 1 to 16777215 microseconds. The variation-value parameter represents the difference between two consecutive average link delays. If you do not specify this option, the delay variation value is the variation reported by the interface.
Perform either of the following tasks to obtain link delay information of an interface:
·     Static configuration—Execute the isis link-delay command to manually configure link delay parameters on the interface.
·     Dynamic acquisition—Execute the test-session bind interface command to bind the interface as the out interface of a TWAMP Light test session. Then, TWAMP Light will send the detected link delay information to the interface, and the interface will report the link delay information to IS-IS at periodic intervals. For more information about TWAMP, see NQA TWAMP-light configuration in Network Management and Monitoring Configuration Guide.
For an interface, the isis link-delay command takes precedence over the test-session bind interface command.
The specified minimum link delay must be lower than or equal to the maximum.
# Set the average link delay, minimum link delay, maximum link delay and acceptable link delay variation to 100, 10, 1000, 20 microseconds respectively for interface Ten-GigabitEthernet3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis link-delay average 100 min 10 max 1000 variation 20
isis link-loss
Use isis link-delay to configure the link loss of an IS-IS interface.
Use undo isis link-delay to restore the default.
isis link-loss loss-value
undo isis link-loss
No link loss value is configured for an IS-IS interface.
Interface view
loss-value: Specifies a link loss value in the range of 1 to 16777214. The unit for this argument is 0.000003%. For example, if you set the value to 1000000 for this argument, the link loss is 3%.
Perform either of the following tasks to obtain link loss information of an interface:
·     Static configuration—Execute the isis link-loss command to manually configure the link loss of an IS-IS interface.
·     Dynamic acquisition—Execute the test-session bind interface command to bind the interface as the out interface of a TWAMP Light test session. Then, TWAMP Light will send the detected link loss information to the interface, and the interface will report the link loss information to IS-IS at periodic intervals. For more information about TWAMP, see NQA TWAMP-light configuration in Network Management and Monitoring Configuration Guide.
For an interface, the isis link-loss command takes precedence over the test-session bind interface command.
# Set the link loss of interface Ten-GigabitEthernet3/0/1 to 3%.
[Sysname-Ten-GigabitEthernet3/0/1] isis link-loss 1000000
test-session bind interface (Network Management and Monitoring Command Reference)
isis link-quality adjust-cost
Use isis link-quality adjust-cost to enable link quality-based interface cost adjustment for IS-IS and set the cost adjustment value.
Use undo isis link-quality adjust-cost to disable link quality-based interface cost adjustment for IS-IS.
isis [ process-id process-id ] link-quality adjust-cost { cost-offset | max }
undo [ process-id process-id ] isis link-quality adjust-cost
IS-IS adjusts the interface cost according to the link quality.
Interface view
cost-offset: Specifies the value to be added to the interface cost when the link quality changes to LOW. The value range for this argument is 1 to 16777213. When the link quality changes to LOW, the interface cost is cost-offset plus the original interface cost. The interface cost cannot exceed the maximum interface cost.
max: Sets the interface cost to the maximum interface cost when the link quality changes to LOW. The maximum interface cost varies by cost type:
·     When the cost type is narrow, narrow-compatible, or compatible, the maximum interface cost is 63.
·     When the cost type is wide or wide-compatible, the maximum interface cost is 16777215.
Application scenarios
If the device forwards IS-IS packets along low-quality links, slow packet transmission and packet loss might occur. To minimize the impact of low-quality links on the IS-IS network, you can enable IS-IS to adjust the interface cost according to the link quality.
The following items affect the quality level of links:
·     Error codes—Error codes refer to bit differences between the received and source signals, cannot be avoided because of inevitable link aging and optical path jitter problems. A high error code ratio might cause service degradation or interruption. The link quality detection module adjusts the quality level of links based on the bit error ratio. For more information about bit errors, see error code detection configuration in High Availability Configuration Guide.
·     Card health—The health of a card is downgraded when the card fails. The link quality detection module adjusts the quality level of links based on the card health. For more information about hardware failure detection, see device management configuration in Fundamentals Configuration Guide.
Operating mechanism
After you configure this command on an interface, IS-IS adjusts the interface cost as follows:
·     When the link quality detection module detects that the link quality of the interface becomes poor, the module performs the following operations:
¡     Changes the link quality level from GOOD to LOW.
¡     Reports an error code event to the IS-IS module.
Upon receiving the error code event, IS-IS increases the cost value for the interface.
·     When the link quality detection module detects that the link quality of the interface restores to GOOD, the module performs the following operations:
¡     Changes the link quality level from LOW to GOOD.
¡     Reports an error code clearing event to the IS-IS module.
Upon receiving the error code clearing event, IS-IS restores the cost value for the interface to the original value.
This interface cost adjustment mechanism enables IS-IS to select GOOD forwarding links, minimizing the impact of low-quality links on the IS-IS network.
This feature affects the route selection results on only one side, because it only adjusts the cost values for interfaces on the local device.
# Enable IS-IS to adjust the cost of interface Ten-GigabitEthernet3/0/1 according to the link quality, and set the value to be added to the interface cost to 200.
[Sysname-Ten-GigabitEthernet3/0/1] isis link-quality adjust-cost 200
cost-style
isis lsp-flood-control
Use isis lsp-flood-control to set the maximum IS-IS LSP flooding rate on a device.
Use undo isis lsp-flood-control to restore the default.
isis lsp-flood-control { interval max-count-value | disable }
IS-IS LSP flooding rate limitting is enabled.
interval: Specifies the LSP transmission period, in milliseconds. The value range for this argument is 10 to 1000.
max-count-value: Specifies the maximum number of LSPs that IS-IS can send within an LSP transmission period. The value range for the max-count-value argument is 10 to 1000.
disable: Disables IS-IS from controlling the LSP flooding rate.
In specific scenarios (such as in large network topologies), IS-IS might be required to flood a large number of LSPs at a time. However, the default LSP flooding rate is too slow to meet the requirements, degrading the network-wide convergence efficiency. To accelerate route convergence in the network, increase the IS-IS LSP flooding rate on the device by using the isis lsp-flood-control command.
In scenarios where traffic flooding is excessive, use the isis lsp-flood-control command to decrease the IS-IS LSP flooding rate on the device, easing the packet processing pressure caused by traffic bursts.
Operating mechanism
After you execute the isis lsp-flood-control interval max-count-value command, the total number of LSPs sent by IS-IS interfaces on the device cannot exceed the specified limit.
To disable IS-IS from controlling the LSP flooding rate, execute the isis lsp-flood-control disable command. The LSP sending rate of each IS-IS interface is then controlled by the isis timer lsp command. If the isis timer lsp is not executed on an IS-IS interface, the minimum interval for sending LSPs on the interface is 33 milliseconds, and the maximum number of LSPs that can be sent at a time is 5.
# Configure IS-IS to flood a maximum of 500 LSPs per 100 milliseconds.
[Sysname] isis lsp-flood-control 100 500
# Disable IS-IS from controlling the LSP flooding rate.
[Sysname] isis lsp-flood-control disable
isis timer lsp
isis member-port link-delay
Use isis member-port link-delay to configure link delay settings on a Layer 3 aggregation group member interface.
Use undo isis link-delay to remove link delay settings on a Layer 3 aggregation group member interface.
isis process-id member-port link-delay { average average-delay-value | min min-delay-value max max-delay-value | variation variation-value } *
undo isis process-id member-port link-delay [ average | min | variation ]
No link delay settings are configured on a Layer 3 aggregation group member interface.
process-id: Specifies a process by its ID in the range of 1 to 65535.
average average-delay-value: Specifies the average link delay on a member interface in the range of 1 to 16777215 microseconds. The average-delay-value parameter represents the average link delay for the interface to send a packet to its directly-connected peer. If you do not specify this option, the delay value is the average link delay reported by the interface.
min min-delay-value: Specifies the minimum link delay on a member interface in the range of 1 to 16777215 microseconds. The min-delay-value parameter represents the minimum link delay for the interface to send a packet to its directly-connected peer. If you do not specify this option, the delay value is the minimum link delay reported by the interface.
max max-delay-value: Specifies the maximum link delay on a member interface in the range of 1 to 16777215 microseconds. The max-delay-value parameter represents the maximum link delay for the interface to send a packet to its directly-connected peer. If you do not specify this option, the delay value is the maximum link delay reported by the interface.
variation variation-value: Sets the acceptable delay variation on a member interface in the range of 1 to 16777215 microseconds. The variation-value parameter represents the difference between two consecutive average link delays. If you do not specify this option, the delay variation value is the variation reported by the interface.
In an SRv6 network, certain SRv6 nodes establish IS-IS neighbors through Layer 3 aggregate links. They allocate SRv6 SIDs to member interfaces and report link delay information of the member interfaces to the controller through BGP-LS. When calculating the SRv6 TE policy path, the controller selects the link with minimum delay according to the member interface link delay parameters. Then the controller deploys the SRv6 TE policy to the device, and the device forwards traffic through the specified member interface.
Operating mechanism
Perform either of the following tasks to obtain link delay information of a member interface:
·     Static configuration—Execute the isis member-port link-delay command to manually configure link delay parameters on the interface.
·     Dynamic acquisition—Execute the test-session bind interface command to bind the member interface as the out interface of a TWAMP Light test session. Then, TWAMP Light will send the detected link delay information to the member interface, and the interface will report the link delay information to IS-IS at periodic intervals. For more information about TWAMP, see NQA TWAMP-light configuration in Network Management and Monitoring Configuration Guide.
For an interface, the isis member-port link-delay command takes precedence over the test-session bind interface command.
This command takes effect only when the process ID of the member interface is the same as that of the associated aggregate interface.
# Set the average link delay, minimum link delay, maximum link delay, and acceptable link delay variation to 100, 10, 1000, 20 microseconds respectively for Layer 3 aggregation group member interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis 1 member-port link-delay average 100 min 10 max 1000 variation 20
isis member-port link-loss
Use isis member-port link-loss to configure the link loss of a Layer 3 aggregation group member interface.
Use undo isis member-port link-loss to restore the default.
isis process-id member-port link-loss loss-value
undo isis process-id member-port link-loss
No link loss value is configured for a Layer 3 aggregation group member interface.
loss-value: Specifies a link loss value in the range of 0 to 16777214. The unit for this argument is 0.000003%. For example, if you set the value to 1000000 for this argument, the link loss is 3%.
In an SRv6 network, certain SRv6 nodes establish IS-IS neighbors through Layer 3 aggregate links. They allocate SRv6 SIDs to member interfaces and report link loss information of the member interfaces to the controller through BGP-LS. When calculating the SRv6 TE policy path, the controller selects the link with minimum loss according to the member interface link loss value. Then the controller deploys the SRv6 TE policy to the device, and the device forwards traffic through the specified member interface.
Operating mechanism
Perform either of the following tasks to obtain link loss information of a member interface:
·     Static configuration—Execute the isis member-port link-loss command to manually configure the link loss of a member interface.
·     Dynamic acquisition—Execute the test-session bind interface command to bind the member interface as the out interface of a TWAMP Light test session. Then, TWAMP Light will send the detected link loss information to the member interface, and the interface will report the link loss information to IS-IS at periodic intervals. For more information about TWAMP, see NQA TWAMP-light configuration in Network Management and Monitoring Configuration Guide.
For an interface, the isis member-port link-loss command takes precedence over the test-session bind interface command.
# Set the link loss of Layer 3 aggregation group member interface Ten-GigabitEthernet 3/0/1 to 3%.
[Sysname-Ten-GigabitEthernet3/0/1] isis 1 member-port link-loss 1000000
isis member-port suppress-flapping
Use isis member-port suppress-flapping to configure the detection parameters for IPv4 IS-IS to suppress member port flapping on an aggregate interface.
Use undo isis member suppress-flapping to remove the configuration.
isis member-port suppress-flapping { [ detect-interval detect-interval | threshold threshold | resume-interval resume-interval ] * | non-conservative }
undo isis member-port suppress-flapping { [ detect-interval | threshold | resume-interval ] * | non-conservative }
resume-interval resume-interval: Specifies the resume timer that IPv4 IS-IS must wait before restoring the aggregate interface cost to the original. The value range for the resume-interval argument is 2 to 1000 seconds and the default value is 120. The value for the resume-interval argument must be greater than that for the detect-interval argument.
non-conservative: Sets the flapping suppression mode to non-conservative. In the non-conservative mode, IPv4 IS-IS increases the number of member port flapping events by one each time a link failure occurs on a member port. To set the flapping suppression mode to conservative, do not specify this keyword. In the conservative mode, IPv4 IS-IS increases the number of member port flapping events by one only when the time gap between two link failures in a row is not longer than the detection timer.
IPv4 IS-IS supports the conservative and non-conservative modes for member port flapping suppression:
Table 67 After you enable member port flapping suppression on an aggregate interface, the aggregate interface starts a flapping event counter to collect statistics about the flapping events that occur on its member ports. When the time gap between two link failures in a row is shorter than the detection timer, IPv4 IS-IS increases the number of member port flapping events by one.
IPv4 IS-IS resets and restarts the flapping event counter when the following conditions exist:
1.     IPv4 IS-IS compares the number of member port flapping events with the threshold that triggers member port flapping suppression:
¡     If the number of member port flapping events is less than the threshold, IPv4 IS-IS does not suppress member port flapping.
¡     If the number of member port flapping events is not less than the threshold, IPv4 IS-IS starts member port flapping suppression. It increases the cost value for the aggregate interface and resets the flapping event counter to zero.
2.     The resume timer starts as IPv4 IS-IS starts member port flapping suppression. The suppression duration equals the resume timer.
If a link failure occurs on a member port during member port flapping suppression, IPv4 IS-IS restarts the resume timer.
3.     After the resume timer expires, IPv4 IS-IS restores the cost value to the original for the aggregate interface if no link failures occur on member ports before the resume timer expires.
Table 68 After you enable member port flapping suppression on an aggregate interface, the aggregate interface starts a flapping event counter to collect statistics about the flapping events that occur on its member ports. IPv4 IS-IS increases the number of member port flapping events by one each time a link failure occurs on a member port.
When a link failure occurs on a member port, IPv4 IS-IS performs the following tasks:
-     If flapping-count is less than the threshold, IPv4 IS-IS does not suppress member port flapping or reset the flapping event counter.
-     If flapping-count is not less than the threshold, IPv4 IS-IS starts member port flapping suppression. It increases the cost value for the aggregate interface and resets the flapping event counter to zero.
4.     The resume timer starts as IPv4 IS-IS starts member port flapping suppression. The suppression duration equals the resume timer.
5.     After the resume timer expires, IPv4 IS-IS restores the cost value to the original for the aggregate interface if no link failures occur on member ports before the resume timer expires.
This command takes effect only after you enable member port flapping suppression by using the isis member-port peer suppress-flapping adjust-cost command.
# On aggregate interface Route-Aggregation 2, set the detection timer to 5 seconds, the threshold to 40, and the resume timer to 20 seconds.
[Sysname-Route-Aggregation2] isis enable 1
[Sysname-Route-Aggregation2] isis member-port suppress-flapping detect-interval 5 threshold 40 resume-interval 20
isis member-port suppress-flapping adjust-cost
Use isis member-port suppress-flapping adjust-cost to enable member port flapping suppression on an IPv4 IS-IS aggregate interface and specify the cost adjustment value for the aggregate interface.
Use undo isis member-port suppress-flapping adjust-cost to disable member port flapping suppression on an IPv4 IS-IS aggregate interface.
isis member-port suppress-flapping adjust-cost { cost-offset | max }
Member port flapping suppression is disabled on an IPv4 IS-IS aggregate interface.
cost-offset: Specifies the cost adjustment value for the aggregate interface. The value range for this argument is 1 to 16777213. When IPv4 IS-IS suppresses member port flapping, the cost value for the aggregate interface is cost-offset plus the original interface cost value, and cannot exceed 16777214.
max: Sets the cost value to the maximum (16777214) for the aggregate interface when IPv4 IS-IS suppresses member port flapping.
This feature enables IPv4 IS-IS to suppress member port flapping on an aggregate interface by increasing the cost value for the aggregate interface. Traffic then does not pass through the aggregate interface during member port flapping suppression. When the resume timer for member port flapping suppression expires, IPv4 IS-IS restores the cost value to the original for the aggregate interface.
[Sysname-Route-Aggregation2] isis member-port suppress-flapping adjust-cost 1000
isis mesh-group
Use isis mesh-group to add an interface into a mesh group or block the interface.
Use undo isis mesh-group to restore the default.
isis mesh-group { mesh-group-number | mesh-blocked }
An interface does not belong to any mesh group and is not blocked.
Interface view
mesh-group-number: Specifies a mesh group by its number in the range of 1 to 4294967295.
mesh-blocked: Configures the interface to send LSPs only after receiving LSP requests.
An interface not in a mesh group floods received LSPs to other interfaces. For an NBMA network with multiple point-to-point links, this mechanism causes repeated LSP flooding and bandwidth waste.
To solve this problem, use this command to add relevant interfaces to a mesh group. An interface in a mesh group only floods a received LSP to interfaces not in the same mesh group.
You can also use this command to block an interface. A blocked interface sends LSPs only after receiving LSP requests.
The mesh-group feature takes effect only on point-to-point links.
# Add interface Serial3/1/1.1 to mesh group 3.
[Sysname] interface serial3/1/1
[Sysname-Serial3/1/1] link-protocol ppp
[Sysname-Serial3/1/1] quit
[Sysname] interface serial3/1/1.1
[Sysname-Serial3/1/1.1] isis mesh-group 3
Use isis metric-delay normalize interval to enable link delay normalization and configure link delay normalization settings on an IPv4 IS-IS interface.
Use undo isis ipv6 metric-delay normalize interval to restore the link delay reported by an IPv4 IS-IS interface to the original.
isis [ process-id process-id ] metric-delay normalize interval interval-value [ offset offset-value ]
undo isis [ process-id process-id ] metric-delay normalize
No link delay normalization settings are configured on an IPv4 IS-IS interface. The configuration of the metric-delay normalize interval command in IS-IS IPv4 unicast address family view takes effect on the IPv4 IS-IS interface.
Interface view
By default, when a flexible algorithm performs route calculation based on the link delay values reported by interfaces, it might not make full use of link resources. This is because the flexible algorithm cannot use the links with small link delay differences as equal-cost routes. To resolve this issue, use this command to enable link delay normalization and configure link delay normalization settings on the relevant IPv4 IS-IS interfaces.
When IPv4 IS-IS performs link delay normalization on an interface, it recalculates the link delay reported by the interface, and then advertises the calculation result in LSPs.
During link delay normalization, IPv4 IS-IS recalculates the link delay reported by an interface as follows:
Table 69 Calculates a. This value depends on the calculation result of dm ÷ interval-value.
2.     Calculates nm.
·     The nm argument represents the normalized link delay. After link delay normalization, IPv4 IS-IS will advertise the normalized link delay in LSPs.
For example, the link delay of link 1 measured by NQA TWAMP-light is 28 milliseconds, the interval value is 10 milliseconds, and the offset value is 4 milliseconds. IPv4 IS-IS normalizes the interface link delay as follows:
Table 70 Calculates a. The value of a equals 2, because 28 divided by 10 equals 2.8.
b = 2 × 10 + 4 = 24
To configure IPv4 IS-IS link delay normalization, you can use either the metric-delay normalize interval command or the isis metric-delay normalize interval command.
·     After you configure the metric-delay normalize interval command in IS-IS IPv4 unicast address family view, the configuration takes effect on all IPv4 IS-IS interfaces.
·     After you configure the isis metric-delay normalize interval command on an IPv4 IS-IS interface, the configuration takes effect only on that interface.
·     For an IPv4 IS-IS interface, the configuration of the isis metric-delay normalize interval command takes precedence over that of the metric-delay normalize interval command.
The configuration of the metric-delay normalize interval command can take effect on an IPv4 IS-IS interface only when you do not configure the isis metric-delay normalize interval command on that interface.
# Enable link delay normalization and configure link delay normalization settings on IPv4 IS-IS interface Ten-GigabitEthernet 3/0/1. The interval value and the offset value for link delay normalization are 20 milliseconds and 5 milliseconds, respectively.
[Sysname-Ten-GigabitEthernet3/0/1] isis process-id 12 metric-delay normalize interval 20 offset 5
isis mib-binding
Use isis mib-binding to bind an IS-IS process to MIB.
Use undo  isis mib-binding to restore the default.
isis mib-binding process-id
MIB operation is bound to the IS-IS process with the smallest process ID.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535.
If the specified the process ID does not exist, the MIB binding configuration fails.
Deleting an IS-IS process bound to MIB operation deletes the MIB binding configuration. MIB operation is bound to the IS-IS process with the smallest process ID.
# Bind IS-IS process 100 to MIB.
[Sysname] isis mib-binding 100
isis peer hold-max-cost duration
Use isis peer hold-max-cost duration to enable IS-IS to advertise the maximum link cost to neighbors within the specified period of time.
Use undo isis peer hold-max-cost duration to restore the default.
isis peer hold-max-cost duration time
IS-IS advertises the original link cost to neighbors during a route convergence.
Interface view
time: Specifies the time period during which IS-IS advertises the maximum link cost to neighbors, in the range of 100 to 1000000 milliseconds.
On an IS-IS network, when a link recovers from failures or the state of an interface changes, IS-IS will re-establish neighbor relationships and perform route convergence. During the route convergence process, routing loops and traffic loss might occur because the convergence speeds of the nodes are different. To address this issue, enable IS-IS to advertise the maximum link cost to neighbors within the specified period of time, so the traffic forwarding path remains unchanged. After the specified period of time, IS-IS advertises the original link cost to neighbors and performs optimal route selection again.
For a P2P neighbor, the timer specified by the time argument starts after the neighbor becomes up. For a broadcast neighbor, the timer specified by the time argument starts after the neighbor becomes up and the DIS is elected.
When the cost type is wide, the maximum link cost is 16777214. When the cost type is Narrow, the maximum link cost is 63.
This command applies to both IPv4 IS-IS and IPv6 IS-IS.
# On interface Ten-GigabitEthernet3/0/1, enable IS-IS to advertise the maximum link cost to neighbors within 1000 milliseconds.
[Sysname-Ten-GigabitEthernet3/0/1] isis peer hold-max-cost duration 1000
isis peer suppress-flapping
Use isis peer suppress-flapping to configure the detection parameters for IPv4 IS-IS neighbor flapping suppression.
Use undo isis peer suppress-flapping to remove the configuration.
isis peer suppress-flapping { [ detect-interval detect-interval | threshold threshold | resume-interval resume-interval ] * | non-conservative }
undo isis peer suppress-flapping { [ detect-interval | threshold | resume-interval ] * | non-conservative }
Interface view
resume-interval resume-interval: Specifies the resume timer that IPv4 IS-IS must wait before restoring the interface cost to the original. The value range for the resume-interval argument is 2 to 1000 seconds and the default value is 120. The value for the resume-interval argument must be greater than that for the detect-interval argument.
non-conservative: Sets the flapping suppression mode to non-conservative. In the non-conservative mode, IPv4 IS-IS increases the number of neighbor flapping events by one each time a neighbor down event occurs on the interface. To set the flapping suppression mode to conservative, do not specify this keyword. In the conservative mode, IPv4 IS-IS increases the number of neighbor flapping events by one only when the time gap between two neighbor down events in a row is shorter than the detection timer.
IPv4 IS-IS supports the conservative and non-conservative modes for neighbor flapping suppression:
Table 71 After you enable neighbor flapping suppression on an interface, the interface starts a flapping event counter to collect statistics about neighbor flapping events. When the time gap between two neighbor down events in a row is shorter than the detection timer, IPv4 IS-IS increases the number of neighbor flapping events by one.
1.     IPv4 IS-IS compares the number of neighbor flapping events with the threshold that triggers neighbor flapping suppression:
¡     If the number of neighbor flapping events is less than the threshold, IPv4 IS-IS does not suppress neighbor flapping.
¡     If the number of neighbor flapping events is not less than the threshold, IPv4 IS-IS starts neighbor flapping suppression. It increases the cost value for the interface and resets the flapping event counter to zero.
2.     The resume timer starts as IPv4 IS-IS starts neighbor flapping suppression. The suppression duration equals the resume timer.
If a neighbor down event occurs on the interface during neighbor flapping suppression, IPv4 IS-IS restarts the resume timer.
3.     After the resume timer expires, IPv4 IS-IS restores the cost value to the original for the interface if no neighbor flapping events occur on the interface before the resume timer expires.
Table 72 After you enable neighbor flapping suppression on an interface, the interface starts a flapping event counter to collect statistics about neighbor flapping events. IPv4 IS-IS increases the number of neighbor flapping events by one each time a neighbor down event occurs on the interface.
When a neighbor down event occurs on the interface, IPv4 IS-IS performs the following tasks:
-     If flapping-count is less than the threshold, IPv4 IS-IS does not suppress neighbor flapping or reset the flapping event counter.
-     If flapping-count is not less than the threshold, IPv4 IS-IS starts neighbor flapping suppression. It increases the cost value for the interface and resets the flapping event counter to zero.
4.     The resume timer starts as IPv4 IS-IS starts neighbor flapping suppression. The suppression duration equals the resume timer.
5.     After the resume timer expires, IPv4 IS-IS restores the cost value to the original for the interface if no neighbor flapping events occur on the interface before the resume timer expires.
This command takes effect only after you enable neighbor flapping suppression by using the isis peer suppress-flapping adjust-cost command.
[Sysname-Ten-GigabitEthernet3/0/1] isis peer suppress-flapping detect-interval 5 threshold 40 resume-interval 20
Use isis peer suppress-flapping adjust-cost to enable neighbor flapping suppression on an IPv4 IS-IS interface and specify the cost adjustment value for the interface.
Use undo isis peer suppress-flapping adjust-cost to disable neighbor flapping suppression on an IPv4 IS-IS interface.
isis peer suppress-flapping adjust-cost { cost-offset | max }
Neighbor flapping suppression is disabled on an IPv4 IS-IS interface.
Interface view
cost-offset: Specifies the cost adjustment value for the interface. The value range for this argument is 1 to 16777213. When IPv4 IS-IS suppresses neighbor flapping, the cost value for the interface is cost-offset plus the original interface cost value, and cannot exceed 16777214.
max: Sets the cost value to the maximum (16777214) for the interface when IPv4 IS-IS suppresses neighbor flapping.
When the state of an IPv4 IS-IS neighbor flaps frequently, IPv4 IS-IS also frequently performs neighbor relationship re-establishment, LSDB synchronization, and route calculation. Such tasks interrupt IPv4 IS-IS services and other services that depend on IPv4 IS-IS, because performing these tasks requires a large number of packet exchanges. To resolve this issue, configure IPv4 IS-IS neighbor flapping suppression. This feature enables IPv4 IS-IS to suppress neighbor flapping on an interface by increasing the cost value for the interface. Traffic then does not pass through the interface during neighbor flapping suppression. When the resume timer for neighbor flapping suppression expires, IPv4 IS-IS restores the cost value to the original for the interface.
[Sysname-Ten-GigabitEthernet3/0/1] isis enable 1
[Sysname-Ten-GigabitEthernet3/0/1] isis peer suppress-flapping adjust-cost 1000
isis peer-ip-check
Use isis peer-ip-check to enable source address check for hello packets on an IS-IS P2P interface. An IS-IS P2P interface can establish a neighbor relationship only with a peer on the same network.
Use undo isis peer-ip-check to restore the default.
isis peer-ip-check
An IS-IS P2P interface can have a peer on a different network.
Interface view
# Enable source address check for hello packets on interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis peer-ip-check
isis circuit-type p2p
isis prefix-suppression
Use isis prefix-suppression to enable prefix suppression on an interface.
Use undo isis prefix-suppression to disable prefix suppression on an interface.
Interface view
Use this command to disable an interface from advertising its prefix in LSPs. This enhances network security by preventing IP routing to the interval nodes and speeds up network convergence.
This command is also applicable to the secondary IP address of the interface.
# Enable prefix suppression on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis prefix-suppression
isis primary-path-detect bfd
Use isis primary-path-detect bfd to enable BFD-powered primary link failure detection on an IPv4 IS-IS interface.
Use undo isis primary-path-detect bfd to restore the default.
isis primary-path-detect bfd { ctrl | echo }
An IPv4 IS-IS interface inherits the configuration of the fast-reroute primary-path-detect bfd command in IS-IS IPv4 unicast address family view.
Interface view
ctrl: Specifies the BFD control packet mode.
echo: Specifies the BFD echo packet mode.
This command enables IPv4 IS-IS FRR and PIC to use BFD to detect primary link failures. BFD can detect and report a primary link failure to IPv4 IS-IS for a primary-backup path switchover. This can shorten the duration of service interruption.
You can perform one of the following tasks to enable BFD-powered primary link failure detection for IPv4 IS-IS FRR and PIC:
·     Use the fast-reroute primary-path-detect bfd command in IPv4 IS-IS unicast address family view. This task takes effect on all interfaces in the current IPv4 IS-IS process.
·     Use the isis primary-path-detect bfd command in interface view. This task takes effect only on the current IPv4 IS-IS interface.
For an IPv4 IS-IS interface, the isis primary-path-detect bfd command takes precedence over the fast-reroute primary-path-detect bfd command. The interface uses the configuration of the fast-reroute primary-path-detect bfd command only when you do not execute the isis primary-path-detect bfd command on that interface.
# Enable BFD control packet mode for IPv4 IS-IS FRR on Ten-GigabitEthernet 3/0/1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] fast-reroute lfa
[Sysname-isis-1-ipv4] quit
[Sysname-isis-1] quit
[Sysname-Ten-GigabitEthernet3/0/1] isis primary-path-detect bfd ctrl
# Enable BFD echo packet mode for IPv4 IS-IS PIC on Ten-GigabitEthernet 3/0/2.
[Sysname] isis 1
[Sysname-Ten-GigabitEthernet3/0/2] isis primary-path-detect bfd echo
isis primary-path-detect bfd exclude
Use isis primary-path-detect bfd exclude to suppress BFD-powered primary link failure detection on an IPv4 IS-IS interface.
Use undo isis primary-path-detect bfd exclude to restore the default.
BFD-powered primary link failure detection is not suppressed on an IPv4 IS-IS interface.
Interface view
The fast-reroute primary-path-detect bfd command enables BFD-powered primary link failure detection on all interfaces in an IPv4 IS-IS process. To disable this feature on an interface in that IS-IS process, use the isis primary-path-detect bfd exclude command on the interface.
When you use the following commands together on the same IPv4 IS-IS interface, the command that is used at last takes effect:
·     isis primary-path-detect bfd exclude
# Suppress BFD-powered primary link failure detection on IPv4 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis primary-path-detect bfd exclude
isis ipv6 savnet enable
Use isis ipv6 savnet enable to enable SAVNET calculation on an IPv6 IS-IS interface.
Use undo isis ipv6 savnet enable to disable SAVNET calculation on an IPv6 IS-IS interface.
SAVNET calculation is disabled on an IPv6 IS-IS interface.
Interface view
The source address spoofing attack is a common cybersecurity threat. Although ACL and uRPF can provide basic network protection, they each have notable shortcomings:
·     High maintenance cost—ACL rules require manual maintenance, which is time-consuming and error-prone.
·     Risk of misconfigurationWhen the device uses incorrect ACL configurations, it might block legitimate traffic or permit malicious traffic.
·     Risk of detection errors—uRPF verifies the legitimacy of source addresses by checking the FIB. In networks with asymmetric routing, strict uRPF might block legitimate traffic and loose uRPF might permit malicious traffic.
To resolve the above issues, IS-IS SAVNET provides an optimized SAVNET scheme. In this scheme, the SAVNET module generates SAVNET entries based on IS-IS routing information to verify the legitimacy of IPv6 source prefixes. The device can update SAVNET entries automatically.
Operating mechanism
Once enabled on each device within an IS-IS routing domain, IS-IS SAVNET functions as follows:
1.     Each device performs IS-IS route calculation and generates route entries in the format of {destination network prefix; output interface1, output interface2, ...}. Each route entry contains information about all output interfaces that can be used for traffic forwarding to a destination network.
2.     The IS-IS module delivers the generated route entries to the SAVNET module in the format of {destination network prefix; output interface}. Each route entry contains information about only one output interface that can be used for traffic forwarding to a destination network. For example, if the device can reach a network prefix (destination network prefix 1) through multiple output interfaces, the IS-IS module delivers the following route entries to the SAVNET module: {destination network prefix1; output interface 1}, {destination network prefix1; output interface 2},…{destination network prefix1; output interface n}.
3.     The SAVNET module generates SAVNET entries based on the received route entries, and then performs IPv6 packet validation accordingly.
When paths within the IS-IS routing domain change, SAVNET entries are updated as follows:
a.     IS-IS regenerates route entries in {destination network prefix; output interface} format, and delivers them to the SAVNET module.
b.     The SAVNET updates SAVNET entries based on the new route entries.
To have IS-IS generate route entries in {destination network prefix; output interface} format and deliver them to the SAVNET module, you must perform the following operations:
·     Execute the savnet enable command on each device within the IS-IS routing domain.
·     Execute the isis ipv6 savnet enable command on each network-to-network SAVNET interface.
# Enable SAVNET calculation on IPv6 IS-IS interface Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 enable 1
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 savnet enable
savnet enable
isis silent
Use isis silent to disable the interface from sending and receiving IS-IS packets.
Use undo isis silent to restore the default.
isis silent
undo isis silent
An interface can send and receive IS-IS packets.
Interface view
This command is not available in loopback interface view.
# Disable Ten-GigabitEthernet 3/0/1 from sending and receiving IS-IS packets.
<<Sysname> system-view
[Sysname-Ten-GigabitEthernet3/0/1] isis silent
isis small-hello
Use isis small-hello to configure the interface to send small hello packets without CLVs.
Use undo isis small-hello to restore the default.
isis small-hello
An interface sends standard hello packets.
Interface view
# Configure Ten-GigabitEthernet 3/0/1 to send small Hello packets.
[Sysname-Ten-GigabitEthernet3/0/1] isis small-hello
isis tag
Use isis tag to configure the administrative tag value for an interface.
Use undo isis tag to restore the default.
isis tag tag
undo isis tag
An interface is not configured with any administrative tag value.
Interface view
tag: Specifies the tag value in the range of 1 to 4294967295.
IS-IS adds the administrative tag to the network address information in LSPs only if the following conditions exist:
·     An administrative tag value is specified.
·     The link cost style is wide, wide-compatible, or compatible.
# Configure the administrative tag value for Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis tag 4294967295
cost-style
isis te-metric flex-algo
Use isis te-metric flex-algo to specify the TE cost for flexible algorithm.
Use undo isis te-metric flex-algo to restore the default.
isis te-metric flex-algo metric-value
The TE cost for flexible algorithm is not specified on an interface.
Interface view
metric-value: Specifies a TE cost in the range of 1 to 16777215.
IS-IS advertises application-specific link attributes in ASLA sub-TLVs for use by specific applications. After you use this command, IS-IS advertises TE metric information in ASLA sub-TLVs.
In the current software version, IS-IS only advertises link TE cost information for use by flexible algorithms. The source of the TE metric information advertised in ASLA sub-TLVs can be MPLS TE or configuration of the isis te-metric flex-algo command.
To enable ASLA sub-TLVs to advertise the TE cost reported by MPLS TE, make sure the following requirements are met:
·     MPLS TE is enabled for each node that participates in path calculation for that flexible algorithm.
·     MPLS and MPLS TE are enabled on each interface that participates in path calculation for that flexible algorithm.
·     TE attribute advertisement has been enabled or IPv6 TE has been enabled for the IS-IS process. To enable TE attribute advertisement, execute the te attribute enable command. To enable IPv6 TE, execute the router-id command.
·     Application-specific link attribute advertisement has been enabled for IS-IS. To enable application-specific link attribute advertisement, execute the advertise application link-attributes command.
To enable ASLA sub-TLVs to advertise the TE cost specified on the interface, execute the isis te-metric flex-algo command.
For ASLA sub-TLVs, the TE cost specified in the isis te-metric flex-algo command takes precedence over that reported by MPLS TE.
# Set the TE cost to 100 for flexible algorithm on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis te-metric flex-algo 100
·     advertise application link-attributes
·     metric-type te-cost
·     te attribute enable
isis timer csnp
Use isis timer csnp to set on the DIS of a broadcast network the interval for sending CSNP packets.
Use undo isis timer csnp to remove the configuration.
isis timer csnp seconds [ level-1 | level-2 ]
undo isis timer csnp [ level-1 | level-2 ]
The default CSNP interval is 10 seconds.
Interface view
seconds: Specifies on the DIS of a broadcast network the interval for sending CSNP packets. The value range is 1 to 600 seconds.
level-1: Applies the interval to Level-1.
level-2: Applies the interval to Level-2.
On a broadcast network, this command only applies to the DIS, because the DIS sends CSNP packets periodically for LSDB synchronization.
If no level is specified, the CSNP interval applies to both Level-1 and Level-2.
# Configure Level-2 CSNP packets to be sent every 15 seconds over Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis timer csnp 15 level-2
isis timer hello
Use isis timer hello to set the interval for sending hello packets.
Use undo isis timer hello to remove the configuration.
isis timer hello seconds [ level-1 | level-2 ]
undo isis timer hello [ level-1 | level-2 ]
The hello interval is 10 seconds.
Interface view
seconds: Specifies the interval for sending hello packets, in the range of 1 to 255 seconds.
level-1: Specifies the interval for sending Level-1 hello packets.
level-2: Specifies the interval for sending Level-2 hello packets.
If a neighbor does not receive any hello packets from the router within the advertised hold time, it considers the router down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval.
Level-1 and Level-2 hello packets are sent independently on a broadcast network, so you need to specify an interval for each level. On a P2P link, Level-1 and Level-2 packets are both sent in P2P hello packets, and you need not specify an interval for each level.
You can configure the level-1 and level-2 keywords only on broadcast interfaces. Before you configure the level-1 or level-2 keyword, enable IS-IS on the interface.
The shorter the interval, the more system resources will be occupied.
If no level is specified, the hello interval applies to both Level-1 and Level-2.
# Configure Level-2 hello packets to be sent every 20 seconds over Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis timer hello 20 level-2
isis timer holding-multiplier
Use isis timer holding-multiplier to set the IS-IS hello multiplier.
Use undo isis timer holding-multiplier to remove the configuration.
isis timer holding-multiplier value [ level-1 | level-2 ]
undo isis timer holding-multiplier [ level-1 | level-2 ]
The default IS-IS hello multiplier is 3.
Interface view
value: Specifies the number of hello intervals, in the range of 3 to 1000.
level-1: Applies the number to the Level-1 IS-IS neighbor.
level-2: Applies the number to the Level-2 IS-IS neighbor.
The hello multiplier is the number of hello packets a neighbor must miss before declaring the router is down.
Level-1 and Level-2 hello packets are sent independently on a broadcast network, so you need to specify a hello multiplier for each level. On a P2P link, Level-1 and Level-2 packets are both sent in P2P hello packets, and you need not specify Level-1 or Level-2.
If no level is specified, the hello multiplier applies to both Level-1 and Level-2.
The value of hello multiplier multiplied by hello interval cannot be more than 65535.
# Set the hello multiplier to 6 for Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis timer holding-multiplier 6 level-2
isis timer hello
isis timer lsp
Use isis timer lsp to set the minimum interval for sending LSPs on the interface and specify the maximum number of LSPs that can be sent per time.
Use undo isis timer lsp to restore the default.
isis timer lsp time [ count count ]
undo isis timer lsp
The minimum interval for sending LSPs on the interface is 33 milliseconds, and the maximum number of LSPs that can be sent at a time is 5.
Interface view
time: Specifies the minimum interval for sending link-state packets, in the range of 1 to 1000 milliseconds.
count: Specifies the maximum number of link-state packets to be sent at a time, in the range of 1 to 1000.
If a change occurs in the LSDB, IS-IS advertises the changed LSP to neighbors. You can specify the minimum interval for sending these LSPs to control the amount of LSPs on the network.
# Set the interval to 500 milliseconds for sending LSPs on Ten-GigabitEthernet 3/0/1.
[Sysname-Ten-GigabitEthernet3/0/1] isis timer lsp 500
isis timer retransmit
Use isis timer retransmit to configure the interval for retransmitting LSP packets over a point-to-point link.
Use undo isis timer retransmit to restore the default.
isis timer retransmit seconds
The retransmission interval on a P2P link is 5 seconds.
Interface view
seconds: Specifies the interval for retransmitting LSP packets, in the range of 1 to 300 seconds.
On a P2P link, IS-IS requires an advertised LSP be acknowledged. If no acknowledgment is received within a configurable interval, IS-IS will retransmit the LSP.
You do not need to use this command over a broadcast link where CSNPs are periodically broadcast to implement LSDB synchronization.
# Set the LSP retransmission interval on a P2P link to 50 seconds for Ten-GigabitEthernet 3/0/1.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] isis circuit-type p2p
[Sysname-Ten-GigabitEthernet3/0/1] isis timer retransmit 50
isis timer lsp
isis troubleshooting max-number
Use isis troubleshooting max-number to set the maximum number of IS-IS neighbor relationship troubleshooting entries.
Use undo isis troubleshooting max-number to restore the default.
isis troubleshooting max-number number
The maximum number of IS-IS neighbor relationship troubleshooting entries is 100.
number: Specifies the maximum number of IS-IS neighbor relationship troubleshooting entries, in the range of 0 to 65535. The value 0 means IS-IS does not record neighbor relationship troubleshooting entries.
# Set the maximum number of IS-IS neighbor relationship troubleshooting entries to 50.
[Sysname] isis troubleshooting max-number 50
is-level
Use is-level to specify the IS level.
Use undo is-level to restore the default.
is-level { level-1 | level-1-2 | level-2 }
undo is-level
The IS level is level-1-2.
IS-IS view
level-1: Specifies Level-1, which means IS-IS only calculates intra-area routes and maintains the Level-1 LSDB.
level-1-2: Specifies Level-1-2, which means IS-IS calculates routes and maintains the LSDBs for both Level-1 and Level-2.
level-2: Specifies Level-2, which means IS-IS calculates routes and maintains the LSDB for Level-2 only.
If only one area exists, configure all the routers as either Level-1 or Level-2, because the routers do not need to maintain two identical LSDBs at the same time.
If the only area is an IP network, configure all the routers as Level-2 for scalability.
# Set the IS level to Level-1 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] is-level level-1
is-name
Use is-name to specify a host name for the IS and enable dynamic system ID to hostname mapping.
Use undo is-name to disable dynamic system ID to hostname mapping.
is-name sys-name
undo is-name
Dynamic system ID to hostname mapping is disabled, and no host name is configured for the IS.
IS-IS view
sys-name: Specifies a host name for the local IS, a case-sensitive string of 1 to 64 characters.
To display the host name rather than the system ID of an IS by using the display isis lsdb command, first enable dynamic system ID to hostname mapping.
# Configure a host name for the local IS.
[Sysname] isis 1
[Sysname-isis-1] is-name RUTA
display isis name-table
is-name map
Use is-name map to configure a system ID to host name mapping for a remote IS.
Use undo is-name map to remove the mapping.
is-name map sys-id map-sys-name
undo is-name map sys-id
No system ID to host name mapping is configured for a remote IS.
IS-IS view
sys-id: Specifies the system ID or pseudonode ID of a remote IS.
map-sys-name: Specifies a host name for the remote IS, a case-sensitive string of 1 to 64 characters.
Each remote IS system ID corresponds to only one name.
# Map the host name RUTB to the system ID 0000.0000.0041 of the remote IS.
[Sysname] isis 1
[Sysname-isis-1] is-name map 0000.0000.0041 RUTB
isolate enable
Use isolate enable to enable IS-IS isolation.
Use undo isolate enable to disable IS-IS isolation.
isolate enable
undo isolate enable
IS-IS isolation is disabled.
IS-IS view
Isolation is a method used for network device maintenance. It gracefully removes a device from the packet forwarding path for maintenance and gracefully adds the device to the network after maintenance.
To reduce impact on traffic forwarding, you can isolate a device before upgrading it.
Operating mechanism
IS-IS isolation functions as follows:
1.     After IS-IS isolation is enabled for a device, IS-IS sets the overload bit in the LSPs advertised by the device and sets the link cost to 16777214.
2.     Each neighbor of the device reselects an optimal route based on the LSPs and stops forwarding traffic to the device. The device is fully isolated from the network and you can upgrade the device.
3.     After the maintenance, disable IS-IS isolation on the device by using the undo isolate enable command. The device can return to the network gracefully after the overload bit is cleared and the link cost restores to the original value.
With IS-IS isolation enabled, the device does not perform the following operations:
·     Advertises redistributed routes and routes leaked between IS-IS levels. To enable advertising these routes, execute the set-overload command.
·     Changes the cost values of locator routes before advertising them.
Consequently, you cannot isolate locator routes by using the IS-IS isolation feature.
If the cost value for a link has been set to 16777215 by using one of the following commands, the device will not adjust the cost value to 16777214 for that link after you enable IS-IS isolation:
·     circuit-cost
·     isis cost
·     isis ipv6 cost
# Isolate the device from the network in IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] isolate enable
circuit-cost
isis cost
isis ipv6 cost
set-overload
ispf enable
Use ispf enable to enable incremental SPF (ISPF).
Use undo ispf enable to disable ISPF.
ispf enable
undo ispf enable
ISPF is enabled.
IS-IS view
IS-IS IPv6 unicast address family view
When a network topology is changed, ISPF recomputes only the affected part of the SPT, instead of the entire SPT.
# Enable IS-IS ISPF.
[Sysname] isis 1
[Sysname-isis-1] ispf enable
link-tag inherit enable
Use link-tag inherit enable to enable IPv6 IS-IS link tag inheritance.
Use undo link-tag inherit enable to disable IPv6 IS-IS link tag inheritance.
IPv6 IS-IS link tag inheritance is disabled.
After you execute this command on a device, the device inherits the IPv6 IS-IS link tag in received LSPs. If the device receives multiple link tags from a device, it selects and inherits only one tag. Then, the device configures the link tag as the route tag for all routes that pass the link.
The IPv6 IS-IS link tag feature is usually used in Source Address Validation Architecture (SAVA) scenarios to ensure the consistency of IPv6 SAVA entries on multiple gateway devices:
1.     Set an IPv6 IS-IS link tag for the customer-side interface on the gateway device that advertises IPv6 SAVA entries.
2.     Enable IPv6 IS-IS link tag inheritance on the gateway device that receives IPv6 SAVA entries. The device generates an IPv6 SAVA entry based on a route prefix if the following two tags are the same:
¡     The route tag configured by executing the ipv6 sava import remote-route-tag command.
¡     The IPv6 IS-IS link tag that the route inherits.
For more information about SAVA, see SAVA configuration in Security Configuration Guide.
# In IS-IS process 1, enable IPv6 IS-IS link tag inheritance.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] link-tag inherit enable
isis ipv6 link-tag
log-peer-change
Use log-peer-change to enable the logging of IS-IS neighbor state changes.
Use undo log-peer-change to disable the logging.
log-peer-change
The logging of IS-IS neighbor state changes is enabled.
IS-IS view
This command enables sending logs about IS-IS neighbor state changes to the information center. For IS-IS neighbor state change logs to be sent correctly, you must also configure the information center parameters on the device. For more information about information center, see the network management and monitoring configuration guide for the device.
# Disable the logging of IS-IS neighbor state changes.
[Sysname] isis 1
[Sysname-isis-1] undo log-peer-change
lsp-fragments-extend
Use lsp-fragments–extend to enable LSP fragment extension for a level.
Use undo lsp-fragments–extend to restore the default.
lsp-fragments-extend [ level-1 | level-1-2 | level-2 ]
undo lsp-fragments-extend
LSP fragment extension is disabled.
IS-IS view
level-1: Applies the fragment extension to Level-1 LSPs.
level-1-2: Applies the fragment extension to both Level-1 and Level-2 LSPs.
level-2: Applies the fragment extension to Level-2 LSPs.
If no level is specified, the command enables LSP fragment extension for both Level-1 and Level-2.
# Enable LSP fragment extension for Level-2.
[Sysname] isis 1
[Sysname-isis-1] lsp-fragments-extend level-2
lsp-length originate
Use lsp-length originate to configure the maximum size of generated Level-1 or Level-2 LSPs.
Use undo lsp-length originate to remove the configuration.
lsp-length originate size [ level-1 | level-2 ]
undo lsp-length originate [ level-1 | level-2 ]
The maximum size of generated Level-1 and Level-2 LSPs is 1497 bytes.
IS-IS view
size: Specifies the maximum size of LSP packets, in the range of 512 to 16384 bytes.
level-1: Applies the size to Level-1 LSP packets.
level-2: Applies the size to Level-2 LSP packets.
If neither Level-1 nor Level-2 is specified in the command, the configured maximum size applies to the current IS-IS level.
# Set the maximum size of the generated Level-2 LSPs to 1024 bytes.
[Sysname] isis 1
[Sysname-isis-1] lsp-length originate 1024 level-2
lsp-length receive
Use lsp-length receive to configure the maximum size of received LSPs.
Use undo lsp-length receive to restore the default.
lsp-length receive size
The maximum size of received LSPs is 1497 bytes.
IS-IS view
size: Specifies the maximum size of received LSPs, in the range of 512 to 16384 bytes.
# Configure the maximum size of received LSPs to 1024 bytes.
[Sysname] isis 1
[Sysname-isis-1] lsp-length receive 1024
maximum load-balancing
Use maximum load-balancing to configure the maximum number of ECMP routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of IS-IS ECMP routes is 64.
number: Specifies the maximum number of ECMP routes. The value of 1 indicates that IS-IS does not perform load balancing. If the value for this argument is not greater than 64, the number of ECMP routes that you can use for load balancing is in the range of 1 to number. If the value for this argument is greater than 64, the number of ECMP routes that you can use for load balancing is in the range of 1 to 64.
# Set the maximum number of ECMP routes to 2.
[Sysname] isis 100
[Sysname-isis-100] address-family ipv4
[Sysname-isis-100-ipv4] maximum load-balancing 2
metric-bandwidth advertisement enable
Use metric-bandwidth advertisement enable to enable IS-IS to advertise link bandwidth information.
Use undo metric-bandwidth advertisement enable to disable IS-IS from advertising link bandwidth information.
In IS-IS IPv4 address family view:
metric-bandwidth advertisement enable [ level-1 | level-2 ]
undo metric-bandwidth advertisement enable [ level-1 | level-2 ]
In IS-IS IPv6 address family view:
metric-bandwidth advertisement enable [ include-member-port ] [ level-1 | level-2 ]
IS-IS does not advertise link bandwidth information.
include-member-port: Enables link bandwidth information advertisement for IPv6 IS-IS interfaces and Layer 3 aggregation group member interfaces. If you do not specify this keyword, link bandwidth information advertisement is disabled for Layer 3 aggregation group member interfaces, and is enabled for only IPv6 IS-IS interfaces (interfaces configured with the isis ipv6 enable command).
level-1: Enables link bandwidth information advertisement for Level-1 routers.
level-2: Enables link bandwidth information advertisement for Level-2 routers.
Use this command to enable IS-IS to advertise link bandwidth information and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the link bandwidth information.
Recommended configuration
In an SRv6 network, certain SRv6 nodes establish IS-IS neighbors through Layer 3 aggregate links. They allocate SRv6 SIDs to member interfaces and report bandwidth information of the member interfaces to the controller through BGP-LS. When calculating the SRv6 TE policy path, the controller selects the path with maximum bandwidth according to the member interface bandwidth parameters. Then the controller deploys the SRv6 TE policy to the device, and the device forwards traffic through the specified member interface. In this scenario, IS-IS advertises member interface bandwidth information only when the metric-bandwidth advertisement enable command is configured with the include-member-port keyword specified.
This command takes effect only when one of the following conditions exists:
·     You have enabled link attribute advertisement by executing the advertise link-attributes command.
·     You have enabled MPLS TE for the IS-IS process by executing the mpls te enable command.
# Enable IS-IS process 1 to advertise link bandwidth information.
[Sysname] isis 1
[Sysname-isis-1-ipv4] metric-bandwidth advertisement enable
distribute bgp-ls
isis ipv6 enable
mpls te enable (MPLS Command Reference)
metric-bandwidth suppression
Use metric-bandwidth suppression to configure the suppression settings used to suppress link bandwidth information advertisement.
Use undo metric-bandwidth suppression to restore the default.
metric-bandwidth suppression timer timer-value
The suppression timer of link bandwidth information advertisement is 120 seconds.
IS-IS view
timer timer-value: Specifies the suppression timer in the range of 0 to 600 seconds. To disable IS-IS from starting the suppression timer of link bandwidth information advertisement, set the timer to 0.
By suppressing link bandwidth information advertisement, you can prevent device resources from being over consumed upon frequent bandwidth changes.
Link bandwidth advertisement suppression works as follows:
·     The interface reports link bandwidth information to IS-IS at negotiated intervals.
·     IS-IS advertises link bandwidth information through BGP-LS at intervals specified by the timer-value argument. IS-IS does not advertise link bandwidth information until the suppression timer expires.
This command takes effect only after you enable link bandwidth information advertisement by executing the metric-bandwidth advertisement enable command.
As a best practice, the suppression timer you specified should not be less than the Ethernet interface measurement interval. For more information about Ethernet interfaces, see Ethernet interface configuration in Interface Management and Configuration Guide.
# Set the suppression timer of link bandwidth information advertisement to 100 seconds for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] metric-bandwidth suppression timer 100
metric-delay advertisement enable
Use metric-delay advertisement enable to enable IS-IS to advertise link delay information.
Use undo metric-delay advertisement enable to disable IS-IS from advertising link delay information.
metric-delay advertisement enable [ level-1 | level-2 ]
undo metric-delay advertisement enable [ level-1 | level-2 ]
metric-delay advertisement enable [ include-member-port ] [ level-1 | level-2 ]
IS-IS does not advertise link delay information.
include-member-port: Enables link delay information advertisement for IPv6 IS-IS interfaces and Layer 3 aggregation group member interfaces. If you do not specify this keyword, link delay information advertisement is disabled for Layer 3 aggregation group member interfaces, and is enabled for only IPv6 IS-IS interfaces (interfaces configured with the isis ipv6 enable command).
level-1: Enables link delay information advertisement for Level-1 routers.
level-2: Enables link delay information advertisement for Level-2 routers.
Application scenarios
Use this command to enable IS-IS to advertise link delay information and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the link delay information.
In an SRv6 network, certain SRv6 nodes establish IS-IS neighbors through Layer 3 aggregate links. They allocate SRv6 SIDs to member interfaces and report delay information of the member interfaces to the controller through BGP-LS. When calculating the SRv6 TE policy path, the controller selects the path with minimum delay according to the member interface delay parameters. Then the controller deploys the SRv6 TE policy to the device, and the device forwards traffic through the specified member interface. In this scenario, IS-IS advertises member interface delay information only when the metric-delay advertisement enable command is configured with the include-member-port keyword specified.
# Enable IS-IS process 1 to advertise link delay information.
[Sysname] isis 1
[Sysname-isis-1-ipv4] metric-delay advertisement enable
distribute bgp-ls
isis ipv6 enable
Use metric-delay normalize interval to enable link delay normalization and configure link delay normalization settings for an IS-IS process.
Use undo metric-delay normalize interval to restore the link delay values reported by IS-IS interfaces.
An IS-IS process does not normalize the link delay values obtained through the dynamic acquisition method.
interval-value: Specifies the interval value for link delay normalization, in milliseconds. The value range for this argument is 1 to 16777215.
offset-value: Specifies the offset value for link delay normalization, in milliseconds. The value range for this argument is 0 to 16777214 and the default value is 0. The offset value must be smaller than the interval value.
By default, when a flexible algorithm performs route calculation based on the link delay values reported by interfaces, it might not make full use of link resources. This is because the flexible algorithm cannot use the links with small link delay differences as equal-cost routes. To resolve this issue, use this command to enable link delay normalization and configure link delay normalization settings for the relevant IS-IS process.
When IS-IS performs link delay normalization on an interface, it recalculates the link delay reported by the interface, and then advertises the calculation result in LSPs.
During link delay normalization, IS-IS recalculates the link delay reported by an interface as follows:
Table 73 Calculates a. This value depends on the calculation result of dm ÷ interval-value.
¡     If the calculation result of dm ÷ interval-value is an integer, a equals dm ÷ interval-value.
¡     If the calculation result of dm ÷ interval-value is not an integer, a equals the greatest integer that is smaller than the calculation result.
1.     Calculates b by using the following formula:
b = a × interval-value + offset-value
2.     Calculates nm.
¡     If dm is not greater than b, nm equals b.
¡     If dm is greater than b, nm equals b plus interval-value.
·     The dm argument represents the link delay measured by NQA TWAMP-light.
·     The interval-value argument represents the interval value specified for link delay normalization.
·     The offset value argument represents the offset value specified for link delay normalization.
·     The nm argument represents the normalized link delay. After link delay normalization, IS-IS will advertise the normalized link delay in LSPs.
Table 74 Calculates a. The value of a equals 2, because 28 divided by 10 equals 2.8.
3.     Calculates b by using the following formula:
b = 2 × 10 + 4 = 24
4.     Calculates nm. The value of nm is 34 (24 +10), because the original link delay value (28) is greater than b (24).
Provided that the original link delay of link 2 is 32 milliseconds, the normalized link delay of that link is 34 milliseconds, which is the same as that of link 1. In this situation, link 1 and link 2 can be used for load sharing as equal-cost routes.
To configure IS-IS link delay normalization, you can use the metric-delay normalize interval, isis metric-delay normalize interval, or isis ipv6 metric-delay normalize interval command.
·     To configure link delay normalization globally, use the metric-delay normalize interval command in IS-IS IPv4 unicast address family view or IS-IS IPv6 unicast address family view. The configuration will take effect on all of the interfaces in the IS-IS process.
·     To configure link delay normalization on a single IS-IS interface, use the isis metric-delay normalize interval or isis ipv6 metric-delay normalize interval command. The configuration will take effect only on that interface.
·     For an IS-IS interface, the interface-level configuration takes precedence over the global configuration. The interface uses the configuration of the metric-delay normalize interval command only when you do not configure the isis metric-delay normalize interval or isis ipv6 metric-delay normalize interval command on that interface.
To ensure that a flexible algorithm can calculate equal-cost routes successfully, configure link delay normalization for all interfaces in the topology of that flexible algorithm.
# Enable link delay normalization and configure link delay normalization settings for IS-IS process 1. The interval value and the offset value for link delay normalization are 20 milliseconds and 5 milliseconds, respectively.
[Sysname] isis 1
[Sysname-isis-1-ipv6] metric-delay normalize interval 20 offset 5
metric-delay suppression
Use metric-delay suppression to configure the suppression settings used to suppress link delay information advertisement.
Use undo metric-delay suppression to restore the default.
metric-delay suppression timer timer-value percent-threshold percent-value absolute-threshold absolute-value
The suppression timer is 120 seconds. The suppression threshold for link delay variation ratio is 10%. The suppression threshold for the absolute value of link delay variation is 1000 microseconds.
IS-IS view
timer timer-value: Specifies the suppression timer in the range of 0 to 600 seconds. To disable IS-IS from starting the suppression timer of link delay information advertisement, set the timer to 0.
percent-value: Specifies the suppression threshold for link delay variation ratio in the range of 0 to 100%. If this argument is unnecessary, you can set it to 0.
absolute-value: Specifies the suppression threshold for the absolute value of link delay variation in the range of 0 to 10000 microseconds. If this argument is unnecessary, you can set it to 0.
By suppressing link delay information advertisement, you can prevent device resources from being over consumed upon frequent link delay changes.
Link delay advertisement suppression works as follows:
·     The link delay advertisement interval for NQA TWAMP Light is the minimum suppression timer among the link-delay advertisement suppression timers configured on the device. TWAMP Light sends the detected link delay information to the associated interface at intervals, and then the interface will report the link delay information to IS-IS.
·     You can execute both the metric-delay suppression and metric-link-loss suppression commands together on the device. In this situation, the link delay advertisement interval and the link loss advertisement interval for NQA TWAMP Light are the minimum suppression timer specified by either of the commands.
·     IS-IS advertises link delay information through BGP-LS at intervals specified by the timer-value argument. IS-IS does not advertise link delay information within the suppression timer except for the following conditions:
¡     The variation ratio between two consecutive minimum delays is larger than or equivalent to the suppression threshold for the delay variation ratio.
¡     The absolute value of the difference between two consecutive minimum delays is larger than or equivalent to the suppression threshold for the absolute the delay variation.
This command takes effect only when you execute the metric-delay advertisement enable command.
As a best practice, the suppression timer you specified should not be less than the NQA measurement interval. For more information about NQA, see NQA configuration in Network Management and Monitoring Configuration Guide.
# Configure the link delay information advertisement suppression settings for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] metric-delay suppression timer 100 percent-threshold 50 absolute-threshold 200
metric-link-loss advertisement enable
Use metric-link-loss advertisement enable to enable IS-IS to advertise link loss information.
Use undo metric-link-loss advertisement enable to disable IS-IS from advertising link loss information.
metric-link-loss advertisement enable [ level-1 | level-2 ]
undo metric-link-loss advertisement enable [ level-1 | level-2 ]
metric-link-loss advertisement enable [ include-member-port ] [ level-1 | level-2 ]
IS-IS does not advertise link loss information.
include-member-port: Enables link loss information advertisement for IPv6 IS-IS interfaces and Layer 3 aggregation group member interfaces. If you do not specify this keyword, link loss information advertisement is disabled for Layer 3 aggregation group member interfaces, and is enabled for only IPv6 IS-IS interfaces (interfaces configured with the isis ipv6 enable command).
level-1: Enables link loss information advertisement for Level-1 routers.
level-2: Enables link loss information advertisement for Level-2 routers.
Use this command to enable IS-IS to advertise link loss information and report the information to the controller through BGP-LS. Then, the controller performs optimal route calculation based on the link loss information.
In an SRv6 network, certain SRv6 nodes establish IS-IS neighbors through Layer 3 aggregate links. They allocate SRv6 SIDs to member interfaces and report link loss information of the member interfaces to the controller through BGP-LS. When calculating the SRv6 TE policy path, the controller selects the path with minimum link loss according to the member interface link loss information. Then the controller deploys the SRv6 TE policy to the device, and the device forwards traffic through the specified member interface. In this scenario, IS-IS advertises member interface link loss information only when the metric-link-loss advertisement enable command is configured with the include-member-port keyword specified.
# Enable IS-IS process 1 to advertise IPv4 link loss information.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4 unicast
[Sysname-isis-1-ipv4] metric-link-loss advertisement enable
# Enable IS-IS process 1 to advertise IPv6 link loss information.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6 unicast
[Sysname-isis-1-ipv6] metric-link-loss advertisement enable
distribute bgp-ls
isis ipv6 enable
Use metric-link-loss suppression to configure the suppression settings used to suppress link loss information advertisement.
Use undo metric-link-loss suppression to restore the default.
metric-link-loss suppression timer timer-value percent-threshold percent-value absolute-threshold absolute-value
The suppression timer is 120 seconds. The suppression threshold for link loss variation ratio is 10%. The suppression threshold for the absolute value of link loss variation is 1000.
IS-IS view
timer timer-value: Specifies the suppression timer in the range of 0 to 600 seconds. To disable IS-IS from starting the suppression timer of link loss information advertisement, set the timer to 0.
percent-threshold percent-value: Specifies the suppression threshold for link loss variation ratio in the range of 0 to 100%. Provided that the latest two link loss values are A and B (A is reported earlier than B), the link loss variation ratio is calculated by the following formula: (Absolute difference between A and B)/A. If this argument is unnecessary, you can set it to 0.
absolute-value: Specifies the suppression threshold for the absolute value of link loss variation in the range of 0 to 10000. If this argument is unnecessary, you can set it to 0.
By suppressing link loss information advertisement, you can prevent device resources from being over consumed upon frequent link loss changes.
Link loss advertisement suppression works as follows:
·     The link loss advertisement interval for NQA TWAMP Light is the minimum suppression timer among the link-loss advertisement suppression timers configured on the device. TWAMP Light sends the detected link loss information to the associated interface at intervals, and then the interface will report the link loss information to IS-IS.
·     IS-IS advertises link loss information through BGP-LS at intervals specified by the timer-value argument. IS-IS does not advertise link loss information within the suppression timer except for the following conditions:
¡     The variation ratio between two consecutive link loss values is larger than or equivalent to the suppression threshold for the link loss variation ratio.
¡     The absolute value of the difference between two consecutive link loss values is larger than or equivalent to the suppression threshold for the absolute link loss variation.
This command takes effect only when you execute the metric-link-loss advertisement enable command.
# Configure the link loss information advertisement suppression settings for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] metric-link-loss suppression timer 300 percent-threshold 20 absolute-threshold 2000
metric-type
Use metric-type to configure the metric type of a flexible algorithm.
Use undo metric-type to restore the default.
metric-type { delay | te-cost }
undo metric-type
The flexible algorithm uses IS-IS link cost for path calculation.
Flexible algorithm view
delay: Configures the metric type as link delay.
te-cost: Configures the metric type as TE cost.
By default, the flexible algorithm uses IS-IS link cost for optimal path calculation. In some scenarios, the paths calculated by the flexible algorithm might not be optimal. To resolve this issue, configure the flexible algorithm to use another metric type for optimal path calculation.
Flexible algorithm supports the following metric types:
·     IS-IS link cost.
·     Link delay. Flexible algorithm uses the minimum link delay for optimal path calculation.
·     TE cost.
·     You can use this feature only when the link cost style is wide, compatible, or wide-compatible.
# Configure the metric type of flexible algorithm 128 as TE cost.
[Sysname] isis 1
[Sysname-isis-1] flex-algo 128
[Sysname-isis-1-flex-algo-128] metric-type te-cost
cost-style
isis link-delay
mpls enable (MPLS Command Reference)
multi-instance enable
Use multi-instance enable to enable the IS-IS multi-instance process and specify an instance ID for the process.
Use undo multi-instance enable to disable the IS-IS multi-instance process.
multi-instance enable iid iid-value
IS-IS multi-instance process is disabled.
IS-IS view
iid iid-value: Specifies an instance ID for the IS-IS process, in the range of 1 to 65535.
IS-IS processes not enabled with the multi-instance process feature are called traditional IS-IS processes. IS-IS processes enabled with the multi-instance process feature are called IS-IS multi-instance processes.
By default, an interface supports only one IS-IS process. To configure multiple IS-IS processes on a device, you must add more interfaces to the device and configure the interfaces manually. To simplify configuration, use the IS-IS multi-instance process feature to configure multiple IS-IS multi-instance processes as well as a traditional IS-IS process on an interface.
After you enable the IS-IS multi-instance process feature, two devices can establish a neighbor relationship only when you configure the same instance ID for the multi-instance processes on the devices.
When you configure IS-IS multi-instance processes or disable the IS-IS multi-instance process feature, follow these restrictions and guidelines:
·     You cannot specify the same instance ID for different IS-IS processes.
·     Before enabling or disabling the IS-IS multi-instance process feature on an interface that has been configured with an IS-IS process, disable IS-IS on the interface.
# Enable IS-IS multi-instance process on IS-IS process 1 and set the instance ID to 3.
[Sysname] isis 1
[Sysname-isis-1] multi-instance enable iid 3
isis enable
multi-topology
Use multi-topology to enable IPv6 IS-IS MTR.
Use undo multiple-topology to disable IPv6 IS-IS MTR.
multi-topology [ compatible ]
undo multi-topology
IPv6 IS-IS MTR is disabled.
compatible: Specifies the compatible mode to advertise IPv6 prefixes to both IPv4 and IPv6 topologies. If you do not specify this keyword, the command advertises IPv6 prefixes only to the IPv6 topology.
Whether the compatible keyword is specified in multi-topology command affects the topologies used for computing IPv4 IS-IS routes and IPv6 IS-IS routes:
·     After you configure the multi-topology command, the device uses the base topology to compute IPv4 IS-IS routes and the IPv6 topology to compute IPv6 IS-IS routes.
In a network where IPv4 and IPv6 coexist, if some devices and links do not support IPv6, dual-stack devices will still forward IPv6 packets to them, which can result in packet loss. To resolve this issue, configure the multi-topology command.
·     After you configure the multi-topology compatible command, the device uses the base topology to compute both IPv4 IS-IS routes and IPv6 IS-IS routes.
Because both IPv6 IS-IS and IPv4 IS-IS use the same shortest path tree for route calculation, all topology information for IPv4 and IPv6 must be consistent. If inconsistent information exists, and a device that supports only IPv4 exists on the shortest path tree, IPv6 services will be affected.
This command is available when the link cost style is wide, compatible, or wide-compatible.
# Enable IPv6 IS-IS MTR.
[Sysname] isis 1
[Sysname-isis-1-ipv6] multi-topology
cost-style
network-entity
Use network-entity to configure the Network Entity Title (NET) for an IS-IS process.
Use undo network-entity to delete a NET.
network-entity net
undo network-entity net
No NET is configured.
IS-IS view
net: Specifies a NET as a dotted hexadecimal string in the X…X.XXXX....XXXX.00 format. The X…X segment represents the area address, the XXXX....XXXX segment represents the system ID, and the 00 segment is the SEL.
CAUTION
CAUTION:
When you execute the network-entity command together with the cost-style and is-level commands for the same IS-IS process, execute the network-entity command at last. Incorrect configuration order might cause data loss because the IS-IS process will restart.
A NET is a special NSAP address with the SEL being 0. The length of the NET is in the range of 8 to 20 bytes.
A NET comprises the following parts:
·     Area ID—With a length of 1 to 13 bytes.
·     System ID—A system ID uniquely identifies a host or router in the area and has a fixed 6-byte length.
·     SEL—It has a value of 0 and a fixed 1-byte length.
For example, a NET of ab.cdef.1234.5678.9abc.00 specifies the area ID ab.cdef, the system ID 1234.5678.9abc, and the SEL 00.
When you execute the network-entity command together with the cost-style and is-level commands for the same IS-IS process, execute the network-entity command at last. Incorrect configuration order might cause data loss.
# Set the NET to 10.0001.1010.1020.1030.00, of which 10.0001 is the area ID and 1010.1020.1030 is the system ID.
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
cost-style
isis
isis enable
is-level
overload adjust-cost
Use overload adjust-cost to set the cost for all IS-IS interfaces when the device enters the overload state.
Use undo overload adjust-cost to restore the default.
overload adjust-cost { cost-offset | max }
The device does not change the cost for any IS-IS interfaces when it enters the overload state.
IS-IS view
cost-offset: Sets the cost offset in the range of 1 to 16777213. When the device enters the overload state, the cost of each IS-IS interface changes to the original interface cost plus the specified cost offset value. The new cost does not exceed the maximum cost value of the interface.
max: Sets the maximum cost value. The value range varies by cost style.
·     For styles narrow, narrow-compatible, and compatible, the maximum cost value is 63.
·     For styles wide and wide-compatible, the maximum cost value is 16777214.
Upon entering the overload state, the device sends an LSP with the OL bit set to its neighbors. The neighbor that receives the LSP performs path calculation and forwards packets as follows:
·     For packets destined for a network not directly connected to the overloaded device, the neighbor device does not forward the packets to the overloaded device.
·     For packets destined for the network directly connected to the overloaded device, the neighbor device forwards the packets to the overloaded device.
These processing methods might cause problems in an anycast scenario where the destination address of packets is an anycast address. The neighbor device will send such packets to the anycast node with the smallest cost, and that node might have already entered the overload state. To avoid such problems, use this command to enable an overloaded device to increase its cost. Neighbors will not select the device during path calculation.
The command takes effect when the device enters the overload state as follows:
·     When the device is in overload state, the system increases the cost of all IS-IS interfaces on the device. Neighbors will not select the device during path calculation.
·     When the device exits the overload state or you execute the undo overload adjust-cost command, the IS-IS interfaces resume their original costs.
# Increase the cost for all IS-IS interfaces by 50 when IS-IS process 1 enters the overload state.
[Sysname] isis 1
[Sysname-isis-1] overload adjust-cost 50
pic
Use pic to enable IS-IS PIC.
Use undo pic to disable IS-IS PIC.
undo pic
IS-IS PIC is disabled.
IS-IS view
additional-path-always: Allows the indirect suboptimal route as the backup route.
Prefix Independent Convergence (PIC) enables the device to speed up network convergence by ignoring the number of prefixes. PIC applies only to indirect routes.
When both IS-IS PIC and IS-IS FRR are configured, only IS-IS FRR takes effect.
# Configure IS-IS PIC to support the indirect suboptimal route as the backup route.
[Sysname] isis 1
[Sysname-isis-1] pic additional-path-always
preference
Use preference to configure the preference for IS-IS.
Use undo preference to restore the default.
undo preference
IS-IS preference is 15.
preference: Specifies an IS-IS protocol preference in the range of 1 to 255.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to assign a priority to the matching routes.
If multiple routing protocols find routes to the same destination, the route found by the routing protocol with the highest preference is selected as the optimal route.
If a routing policy is specified in this command, the preference set by the routing policy applies to the matching routes. Other routes use the preference set by the preference command.
# Set the preference for IS-IS to 25.
[Sysname] isis 1
[Sysname-isis-1-ipv4] preference 25
prefix-priority
Use prefix-priority to assign convergence priorities to specific IS-IS routes.
Use undo prefix-priority to remove the configuration.
prefix-priority { critical | high | medium } { prefix-list prefix-list-name | tag tag-value }
undo prefix-priority { critical | high | medium } [ prefix-list | tag ]
undo prefix-priority route-policy
IS-IS routes have the lowest convergence priority.
critical: Specifies the highest convergence priority.
high: Specifies the high convergence priority.
medium: Specifies the medium convergence priority.
prefix-list prefix-list-name: Specifies a prefix list by its name, a case-sensitive string of 1 to 63 characters.
tag tag-value: Specifies a tag value in the range of 1 to 4294967295.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
The higher the convergence priority, the faster the convergence speed.
IS-IS host routes have a medium convergence priority.
# Assign the high convergence priority to IS-IS routes permitted by IP prefix list standtest.
[Sysname] isis 1
[Sysname-isis-1-ipv4] prefix-priority high prefix-list standtest
priority
Use priority to set the priority of a flexible algorithm.
Use undo priority to restore the default.
priority priority-value
undo priority
The priority of a flexible algorithm is 128.
priority-value: Specifies a priority value in the range of 0 to 255. A higher value indicates a higher priority.
All nodes that participate in the path calculation for a flexible algorithm can have a different FAD. To avoid routing loops in an FAD advertisement scope (IS-IS area), these nodes must use the same FAD. By convention, a node selects an FAD as follows:
·     The FAD with the highest priority will be selected from the FADs advertised within the IS-IS routing domain. If the node does not advertise an FAD, it selects the FAD with the highest priority from the received FADs.
·     The FAD with the greatest system ID will be selected from the FADs that have the highest priority.
This feature is available when the link cost style is wide, compatible, or wide-compatible.
# Set the priority value to 200 for flexible algorithm 128.
[Sysname] isis 1
[Sysname-isis-1-flex-algo-128] priority 200
advertise-definition
cost-style
reset isis all
Use reset isis all to clear all IS-IS data structure information.
reset isis all [ process-id ] [ graceful-restart ]
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535 to clear the data structure information for an IS-IS process.
graceful-restart: Recovers the data through graceful restart after the data is cleared.
If no IS-IS process is specified, the command clears data structure information for all IS-IS processes.
Use this command when LSPs must be updated immediately.
# Clear all IS-IS data structure information.
<Sysname> reset isis all
reset isis event-log
Use reset isis event-log to clear IS-IS log information.
reset isis event-log { hello { peer-change | received-abnormal | received-dropped | sent-abnormal | sent-failed } | peer } [ process-id ]
hello: Clears log information about received and sent hello packets.
peer-change: Clears log information about hello packets received and sent during neighbor state change.
received-abnormal: Clears log information about abnormally received hello packets, which were received at intervals greater than or equal to 0.5 times the holdtime (number of missed hello packets multiplied by the hello interval).
received-dropped: Clears log information about received hello packets that were dropped.
sent-abnormal: Clears log information about abnormally sent hello packets, which were sent at intervals greater than or equal to 1.5 times the hello interval.
sent-failed: Clears log information about hello packets that failed to be sent.
peer: Clears neighbor state change log information.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears IS-IS log information for all processes.
# Clear neighbor state change log information for all IS-IS processes.
<Sysname> reset isis event-log peer
display isis event-log peer
reset isis event-log graceful-restart
Use reset isis event-log graceful-restart to clear IS-IS GR log information.
reset isis event-log graceful-restart slot slot-number
slot slot-number: Specifies a card by its slot number.
# Clear IS-IS GR log information for the specified slot.
<Sysname> reset isis event-log graceful-restart slot 0
reset isis event-log lsp
Use reset isis event-log lsp to clear IS-IS LSP log information.
reset isis event-log lsp { purged [ generated | received ] | refreshed } [ process-id ]
purged: Clears log information about purge LSPs.
generated: Clears log information about purge LSP generation.
received: Clears log information about purge LSP reception.
refreshed: Clears log information about refresh LSPs.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears LSP log information for all IS-IS processes.
If you use the reset isis event-log lsp purged command without specifying the generated or received keyword, the command clears log information about both purge LSP generation and purge LSP reception.
# Clear log information about refresh LSPs for IS-IS process 1.
<Sysname> reset isis event-log lsp refreshed 1
display isis event-log lsp
reset isis event-log non-stop-routing
Use reset isis event-log non-stop-routing to clear IS-IS NSR log information.
reset isis event-log non-stop-routing slot slot-number
# Clear IS-IS NSR log information for the specified slot.
<Sysname> reset isis event-log non-stop-routing slot 0
reset isis event-log route-record
Use reset isis event-log route-record to clear IS-IS route change log messages.
reset isis event-log route-record { add | delete | modify }
add: Clears route adding log messages.
delete: Clears route deletion log messages.
modify: Clears route update log messages.
# Clear IS-IS route adding log messages.
<Sysname> reset isis event-log route-record add
display isis event-log route-record
reset isis event-log spf
Use reset isis event-log spf to clear IS-IS route calculation log information.
reset isis event-log spf [ process-id ]
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears route calculation log information for all IS-IS processes.
# Clear route calculation log information for IS-IS process 1.
<Sysname> reset isis event-log spf 1
display isis event-log spf
reset isis event-log updated-lsp
Use reset isis event-log updated-lsp to clear LSP-update log information.
# Clear LSP-update log information.
<Sysname> reset isis statistics updated-lsp
display isis event-log updated-lsp
reset isis packet
Use reset isis packet to clear IS-IS packet statistics.
reset isis packet [ csnp | hello | lsp | psnp ] [ interface-type interface-number ] [ process-id ]
csnp: Clears CSNP packet statistics.
hello: Clears hello packet statistics.
lsp: Clears LSP packet statistics.
psnp: Clears PSNP packet statistics.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command clears IS-IS packet statistics for all interfaces.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears IS-IS packet statistics for all IS-IS processes.
# Clear IS-IS packet statistics for all IS-IS processes.
<Sysname> reset isis packet
display isis packet
reset isis peer
Use reset isis peer to clear data structure information for a specified IS-IS neighbor.
reset isis peer system-id [ process-id ]
system-id: Specifies an IS-IS neighbor by its system ID.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535 to clear data structure information for the neighbor in the specified IS-IS process. If you do not specify an IS-IS process, this command clears data structure information for the specified neighbor in all IS-IS processes.
Use this command when you re-establish an IS-IS neighbor relationship.
# Clear the data structure information of the neighbor with the system ID 0000.0c11.1111.
<Sysname> reset isis peer 0000.0c11.1111
reset isis troubleshooting
Use reset isis troubleshooting to clear IS-IS neighbor relationship troubleshooting information.
# Clear IS-IS neighbor relationship troubleshooting information.
<Sysname> reset isis troubleshooting
display isis troubleshooting
reset osi statistics
Use reset osi statistics to clear OSI packet statistics.
To obtain OSI packet statistics from the specified time point, first clear the existing statistics.
# Clear OSI packet statistics.
<Sysname> reset osi statistics
display osi statistics
savnet enable
Use savnet enable to enable SAVNET calculation for an IS-IS process.
Use undo savnet enable to disable SAVNET calculation for an IS-IS process.
savnet enable
undo savnet enable
SAVNET calculation is disabled for an IS-IS process.
The source address spoofing attack is a common cybersecurity threat. Although ACL and uRPF can provide basic network protection, they each have notable shortcomings:
·     High maintenance cost—ACL rules require manual maintenance, which is time-consuming and error-prone.
·     Risk of misconfiguration—When the device uses incorrect ACL configurations, it might block legitimate traffic or permit malicious traffic.
·     Risk of detection errors—uRPF verifies the legitimacy of source addresses by checking the FIB. In networks with asymmetric routing, strict uRPF might block legitimate traffic and loose uRPF might permit malicious traffic.
To resolve the above issues, IS-IS SAVNET provides an optimized SAVNET scheme. In this scheme, the SAVNET module generates SAVNET entries based on IS-IS routing information to verify the legitimacy of IPv6 source prefixes. The device can update SAVNET entries automatically.
Operating mechanism
Once enabled on each device within an IS-IS routing domain, IS-IS SAVNET functions as follows:
1.     Each device performs IS-IS route calculation and generates route entries in the format of {destination network prefix; output interface1, output interface2, ...}. Each route entry contains information about all output interfaces that can be used for traffic forwarding to a destination network.
2.     The IS-IS module delivers the generated route entries to the SAVNET module in the format of {destination network prefix; output interface}. Each route entry contains information about only one output interface that can be used for traffic forwarding to a destination network. For example, if the device can reach a network prefix (destination network prefix 1) through multiple output interfaces, the IS-IS module delivers the following route entries to the SAVNET module: {destination network prefix1; output interface 1}, {destination network prefix1; output interface 2},…{destination network prefix1; output interface n}.
3.     The SAVNET module generates SAVNET entries based on the received route entries, and then performs IPv6 packet validation accordingly.
When paths within the IS-IS routing domain change, SAVNET entries are updated as follows:
a.     IS-IS regenerates route entries in {destination network prefix; output interface} format, and delivers them to the SAVNET module.
b.     The SAVNET updates SAVNET entries based on the new route entries.
To have IS-IS generate route entries in {destination network prefix; output interface} format and deliver them to the SAVNET module, you must perform the following operations:
·     Execute the savnet enable command on each device within the IS-IS routing domain.
·     Execute the isis ipv6 savnet enable command on each network-to-network SAVNET interface.
# Enable SAVNET calculation for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] savnet enable
segment-routing microloop-avoidance enable
Use segment-routing microloop-avoidance enable to enable SR microloop avoidance for a flexible algorithm.
Use undo segment-routing microloop-avoidance enable to disable SR microloop avoidance for a flexible algorithm.
SR microloop avoidance is enabled for a flexible algorithm.
After a network failure occurs or recovers, route convergence occurs on relevant network devices. Because of non-simultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided.
# Enable SR microloop avoidance for flexible algorithm 128.
[Sysname] isis 1
[System-isis-1-flex-algo-128] segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
segment-routing microloop-avoidance strict-sid-only
Use segment-routing microloop-avoidance rib-update-delay to set the SR microloop avoidance delay timer for a flexible algorithm.
Use undo segment-routing microloop-avoidance rib-update-delay to restore the default.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo segment-routing microloop-avoidance rib-update-delay [ level-1 | level-2 ]
The SR microloop avoidance delay timer for a flexible algorithm is 5000 milliseconds.
delay-time: Specifies the SR microloop avoidance delay timer for the flexible algorithm, in the range of 1 to 60000 milliseconds.
level-1: Applies the SR microloop avoidance delay timer to Level-1 IS-IS.
level-2: Applies the SR microloop avoidance delay timer to Level-2 IS-IS.
To leave sufficient time for IS-IS to finish route convergence, specify a proper value for the SR microloop avoidance delay timer. Before the timer expires, failure relevant devices will forward traffic along the specified path. After the timer expires, traffic will traverse the usual path.
The SR microloop avoidance delay timer takes effect only after you enable SR microloop avoidance.
If you do not specify the level-1 or level-2 keyword, this command sets the SR microloop avoidance delay timer for all IS-IS levels.
If you configure both FRR microloop avoidance and SR microloop avoidance for a flexible algorithm, both the FRR microloop avoidance delay timer and the SR microloop avoidance delay timer start. In this scenario, FRR microloop avoidance and SR microloop avoidance take effect as follows:
·     If the FRR microloop avoidance delay time is longer than or equivalent to the SR microloop avoidance delay time, the traffic switches to the post-convergence path immediately after the FRR microloop avoidance delay timer expires.
·     If the FRR microloop avoidance delay time is shorter than the SR microloop avoidance delay time, the traffic switches to the post-convergence path after the SR microloop avoidance delay timer expires.
# Set the SR microloop avoidance delay timer to 6000 milliseconds for flexible algorithm 128.
[Sysname] isis 1
[System-isis-1-flex-algo-128] segment-routing microloop-avoidance rib-update-delay 6000
fast-reroute microloop-avoidance enable
Use segment-routing microloop-avoidance strict-sid-only to configure SR microloop avoidance to encapsulate only strict SIDs in the SID list.
Use undo segment-routing microloop-avoidance strict-sid-only to restore the default.
The strict-SID-only feature is not configured for SR microloop avoidance.
By default, SR microloop avoidance first calculates the End SID to the P node, and then calculates the End.X SIDs from the P node to the destination node. These SIDs form an SID list and SR microloop avoidance then encapsulates the list into the packet.
If multi-point failure exists and the forwarding path is frequently switched, there might be a microloop on the path to the P node identified by the End SID. To avoid the microloop, you can strictly constrain the path to the P node. This command strictly constrains the path to the P node by calculating an End.X SID to reach the P node. Then, the SID list encapsulated into the packet consists of the End.X SID to the P node and End.X SIDs from the P node to the destination node.
# Configure SR microloop avoidance to encapsulate strict SIDs in the SID list.
[Sysname] isis 1
[System-isis-1-flex-algo-128] segment-routing microloop-avoidance strict-sid-only
set-att
Use set-att to set the ATT bit of Level-1 LSPs.
Use undo set-att to restore the default.
set-att { always | never }
undo set-att
The Level-1-2 router sets the ATT bit for Level-1 LSPs in accordance with the default ATT bit setting rule.
IS-IS view
always: Sets the ATT bit of Level-1 LSPs.
never: Keeps the ATT bit of Level-1 LSPs not set.
The ATT bit is used to identify the connection status between a Level-1 area and other areas. By default, a Level-1-2 router sets the ATT bit for Level-1 LSPs as follows:
·     The Level-1-2 router sets the ATT bit in Level-1 LSPs to inform the Level-1 routers that it can reach other areas. After a Level-1 router receives a Level-1 LSP with the ATT bit set, it generates a default route destined for the Level-1-2 router.
·     The Level-1-2 router does not set the ATT bit in Level-1 LSPs if it can reach only one area.
To edit the default ATT bit setting rule for a Level-1-2 router, perform the following tasks as needed:
·     To enable ATT bit setting for all Level-1 LSPs, execute the set-att always command on the Level-1-2 router.
·     To disable a Level-1 router from generating a default route upon receiving an ATT-bit-set Level-1 LSP from the Level-1-2 router, you can perform one of the following tasks:
¡     Execute the ignore-att command on the Level-1 router.
¡     Execute the set-att never command on the Level-1-2 router.
The set-att command is applicable to only Level-1-2 routers.
# Set the ATT bit of Level-1 LSPs.
[Sysname] isis 1
[Sysname-isis-1] set-att always
ignore-att
set-overload
Use set-overload to set the overload bit.
Use undo set-overload to restore the default.
In IS-IS view:
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 | wait-for-bgp [ timeout3 ] ] [ route-delay-distribute delay-time ] [ send-sa-bit [ duration ] ] [ route-max-metric ] ] [ allow { external | interlevel } * ]
undo set-overload
In IS-IS IPv6 unicast address family view:
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 | wait-for-bgp4+ [ timeout3 ] ] [ route-delay-distribute delay-time ] [ send-sa-bit [ duration ] ] [ route-max-metric ] ] [ allow { external | interlevel } * ]
undo set-overload
The overload bit is not set.
IS-IS view
on-startup: Sets the overload bit upon system startup.
start-from-nbr system-id [ timeout1 [ nbr-timeout ] ]: Starts the nbr-timeout timer when the router begins to establish the neighbor relationship with the neighbor after system startup. If the neighbor relationship is formed within the nbr-timeout interval, IS-IS keeps the overload bit set. If not, the bit is cleared. IS-IS keeps the overload bit set within the timeout1 interval after the neighbor relationship is formed within the nbr-timeout interval.
·     system-id—Specifies the neighbor.
·     timeout1—The timeout1 interval is in the range of 5 to 86400 seconds, and the default is 600 seconds.
·     nbr-timeout—The timer has an interval from 5 to 86400 seconds. The default is 1200 seconds.
timeout2: Sets the overload bit within the timeout2 interval after system startup. The interval is in the range of 5 to 86400 seconds. The default value for this argument is 600 seconds.
wait-for-bgp [ timeout3 ]: Starts the timeout3 timer for BGP convergence after system startup. If BGP is not converged within the timeout3 interval, IS-IS clears the overload bit. The value range for the timeout3 argument is 5 to 86400 seconds. The default value for the timeout3 argument is 600 seconds.
wait-for-bgp4+ [ timeout3 ]: Starts the timeout3 timer for IPv6 BGP convergence after system startup. If IPv6 BGP is not converged within the timeout3 interval, IPv6 IS-IS clears the overload bit. The value range for the timeout3 argument is 5 to 86400 seconds. The default value for the timeout3 argument is 600 seconds.
route-delay-distribute delay-time: Specifies a delay timer for route advertisement. The value range for the delay-time argument is 5 to 1000 seconds. This option enables IS-IS to delay route advertisement after system startup. If IS-IS clears the overload bit before the delay timer expires, IS-IS stops delaying route advertisement. If you do not specify a delay timer for route advertisement, IS-IS does not delay route advertisement.
send-sa-bit: Sets the Suppress-Advertisement (SA) bit in the hello packets advertised after system startup. After receiving a hello packet from the local device, the IS-IS neighbor does not advertise information about the local device in its LSPs, which prevents traffic from passing through the local device.
duration: Specifies the duration for which IS-IS sets the SA bit in the hello packets advertised after system startup. The value range for this argument is 5 to 600 seconds and the default value is 30.
route-max-metric: Sets the metric value for routes generated by the local device to the maximum. This keyword allows IS-IS neighbors to select better routes for traffic forwarding.
allow: Allows advertising address prefixes. By default, no address prefixes are allowed to be advertised when the overload bit is set.
external: Allows advertising IP address prefixes redistributed from other routing protocols with the allow keyword specified.
interlevel: Allows advertising IP address prefixes learned from different IS-IS levels with the allow keyword specified.
Operating mechanism
When the system cannot save new LSPs and cannot perform LSDB synchronization normally, the system cannot calculate routes correctly. In this situation, the system will enter the overload state automatically. Alternatively, you can use the set-overload command to place the system in overload state.
When the device is in overload state, it sets the overload bit in LSPs before advertising them to its neighbors. On receipt of such an LSP, a neighbor does not forward any packets to the device except the packets destined for a directly-connected network of the device.
The recommended configuration of the set-overload command varies by service requirement as follows:
·     To immediately exclude the device from other devices' SPF calculation, configure the set-overload command on the device without specifying the on-startup keyword. The device will immediately set the overload bit in its LSPs. Only the undo set-overload command can disable the device from setting the overload bit.
·     To exclude the device from other devices' SPF calculation when the device restarts or fails, configure the set-overload command on the device and specify the on-startup keyword. The device will set the overload bit in its LSPs upon system startup and will keep setting the overload bit within the timeout2 interval.
·     To delay route advertisement on system startup, configure the set-overload command on the device and specify the route-delay-distribute keyword together with the send-sa-bit keyword.
If you specify only the route-delay-distribute keyword, other devices might still forward traffic to the device after the device restarts, because they might use the old LSPs of the device to calculate routes.
CAUTION
CAUTION:
To avoid traffic forwarding failure, configure route advertisement delay only when backup forwarding paths exist.
·     To prevent other devices from forwarding any traffic to the device, configure the set-overload command on the device and specify the send-sa-bit keyword.
·     To avoid the traffic loss caused by the speed difference between BGP route convergence and IGP route convergence, configure the set-overload command on the device and specify the wait-for-bgp or wait-for-bgp4+ keyword.
·     When the system enters the overload state automatically, it deletes the routes redistributed from other routing protocols and the routes leaked from other IS-IS areas. When you use the set-overload command, you can select whether to delete the redistributed routes or the leaked routes, according to the network requirement.
You can repeat the set-overload command to edit the settings associated with the on-startup keyword. The new settings take effect only after the device enters the overload state again. The existing timer settings do not update immediately after modification unless they expire.
To cancel an existing timer, execute the set-overload command without specifying the keyword associated with that timer. For example, to cancel the delay timer for route advertisement, execute the set-overload command without specifying the route-delay-distribute keyword.
When both IPv4 and IPv6 topologies exist, the set-overload command takes effect as follows:
·     If the multi-topology command is not configured, configuration of the set-overload command in IS-IS view takes effect for both IPv4 IS-IS and IPv6 IS-IS.
·     If the multi-topology command is not configured, and the set-overload command is not configured in IS-IS view, configuration of the set-overload command in IS-IS IPv6 unicast address family view does not take effect for IPv6 IS-IS.
·     If the multi-topology command is configured, configuration of the set-overload command in IS-IS view takes effect for only IPv4 IS-IS. To have the set-overload command take effect for IPv6 IS-IS, configure the set-overload command in IS-IS IPv6 unicast address family view.
# Set overload flag on the current router.
[Sysname] isis 1
[Sysname-isis-1] set-overload
shutdown process
Use shutdown process to shut down an IS-IS process.
Use undo shutdown process to restart an IS-IS process.
shutdown process
IS-IS process is not shut down.
IS-IS view
Both this feature and IS-IS isolation can be used for IS-IS maintenance.
After you execute the shutdown process command for an IS-IS process, the process performs the following operations:
·     Changes the state of all neighbors to down.
·     Stops receiving and sending IS-IS packets.
·     Clears its neighbor, LSDB, and IS-IS route information.
If the neighbors do not receive any hello packets from the IS-IS process within the hold time, they consider the process down and recalculate the routes.
After maintenance, you can use the undo shutdown process command to restart the IS-IS process for neighbor relationship re-establishment.
# Shut down IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] shutdown process
isolate enable
snmp context-name
Use snmp context-name to set the context name for the SNMP object for managing IS-IS.
Use undo snmp context-name to restore the default.
No context name is set for the SNMP object for managing IS-IS.
IS-IS view
context-name: Specifies a context name, a case-sensitive string of 1 to 32 characters.
# Configure the context name as isis for the SNMP object for managing IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] snmp context-name isis
snmp-agent trap enable isis
Use snmp-agent trap enable isis to enable IS-IS SNMP notifications.
Use undo snmp-agent trap enable isis to disable IS-IS SNMP notifications.
snmp-agent trap enable isis [ adjacency-state-change | area-mismatch | authentication | authentication-type | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-corrupt | lsp-parse-error | lsp-size-exceeded | manual-address-drop | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support  | rejected-adjacency | skip-sequence-number | system-id-conflict | version-skew ] *
undo snmp-agent trap enable isis [ adjacency-state-change | area-mismatch | authentication | authentication-type | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-corrupt | lsp-parse-error | lsp-size-exceeded | manual-address-drop | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support  | rejected-adjacency | skip-sequence-number | system-id-conflict | version-skew ] *
IS-IS SNMP notifications are enabled.
adjacency-state-change: Specifies notifications about IS-IS adjacency status changes.
area-mismatch: Specifies notifications about area address mismatches between hello packets.
authentication: Specifies notifications about authentication failures of IS-IS packets.
authentication-type: Specifies notifications about authentication type errors of IS-IS packets.
buffsize-mismatch: Specifies notifications about buffer size mismatches for LSPs.
id-length-mismatch: Specifies notifications about system ID length mismatches of IS-IS packets.
lsdboverload-state-change: Specifies notifications about LSDB overload state changes.
lsp-corrupt: Specifies notifications about LSP checksum errors in the LSDB.
lsp-parse-error: Specifies notifications about LSP packet parse failures.
lsp-size-exceeded: Specifies notifications about propagation failures caused by oversized LSPs.
manual-address-drop: Specifies notifications about manually configured area addresses that have been dropped.
max-seq-exceeded: Specifies notifications about attempts to exceed the maximum LSP sequence number.
maxarea-mismatch: Specifies notifications about maximum area address mismatches of hello packets.
own-lsp-purge: Specifies notifications about attempts to remove the local LSP.
protocol-support: Specifies notifications about supported-protocol mismatches.
rejected-adjacency: Specifies notifications about adjacency creation failures.
skip-sequence-number: Specifies notifications about LSP sequence number duplications.
system-id-conflict: Specifies notifications about system ID conflicts.
version-skew: Specifies notifications about hello packet version mismatches.
If you do not specify a notification, this command enables all IS-IS SNMP notifications.
If no IS-IS process exists, the configuration is not allowed.
This function does not take effect if all configured IS-IS processes are deleted.
# Disable IS-IS SNMP notifications.
[Sysname] undo snmp-agent trap enable isis
snmp-agent trap isis adjacency-state-change extended
Use snmp-agent trap isis adjacency-state-change extended to extend the format of SNMP notifications for neighbor state changes.
Use undo snmp-agent trap isis adjacency-state-change extended to restore the default.
IS-IS does not extend the format of SNMP notifications for neighbor state changes.
After you execute this command, IS-IS generates a notification in extended format when the state of a neighbor changes. Compared with notifications in standard format, notifications in extended format include interface names additionally. This setting enables the network administrator to quickly locate problems.
The NMS might fail to parse notifications in extended format if it does not support this format.
# Extend the format of SNMP notifications for neighbor state changes.
[Sysname] snmp-agent trap isis adjacency-state-change extended
summary
Use summary to configure a summary route.
Use undo summary to remove a summary route.
In IS-IS IPv4 unicast address family view:
summary ip-address { mask-length | mask } [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
undo summary ip-address { mask-length | mask } [ level-1 | level-1-2 | level-2 ]
summary ipv6-prefix prefix-length [ algorithm algo-id [ explicit ] | avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
undo summary ipv6-prefix prefix-length [ level-1 | level-1-2 | level-2 ]
No summary route is configured.
ip-address: Specifies the destination IP address of the summary route.
mask-length: Specifies the mask length of the summary route, in the range of 0 to 32.
mask: Specifies the mask of the destination IP address, in dotted decimal notation.
ipv6-prefix: Specifies an IPv6 prefix for the summary route.
prefix-length: Specifies the length of the IPv6 prefix, in the range of 0 to 128.
algorithm algo-id: Specifies a flexible algorithm ID for summary locator routes. The algorithm ID range is 128 to 255. If this option is specified, the value for the Algorithm field is the specified algorithm ID in the summary locator route generated by using this command.
explicit: Summarizes only locator routes calculated by the same flexible algorithm. If you do not specify this keyword, the device can summarize locator routes calculated by different flexible algorithms.
avoid-feedback: Avoids learning summary routes by route calculation.
generate_null0_route: Generates the Null 0 route to avoid routing loops.
level-1: Summarizes only the routes redistributed to Level-1.
level-1-2: Summarizes the routes redistributed to both Level-1 and Level-2.
level-2: Summarizes only the routes redistributed to Level-2.
tag tag: Specifies a management tag in the range of 1 to 4294967295.
To reduce the size of the routing table, as well as the size of LSP and LSDB generated by the router, summarize multiple contiguous networks into a single network. You can summarize native IS-IS routes and redistributed routes. After summarization, the cost of the summary route is the smallest cost of the summarized routes.
If no level is specified, only level-2 routes are summarized.
When the device summarizes the routes destined for an SRv6 locator, it summarizes only the routes associated with flexible algorithms. To have the device summarize the routes destined for an SRv6 locator, you must perform the following operations in sequence:
1.     Execute the flex-algo algorithm command to associate the SRv6 locator to a flexible algorithm.
2.     Execute the summary command with the SRv6 locator specified.
The router summarizes only routes generated from local LSPs.
# Configure a summary route of 202.0.0.0/8.
[Sysname] isis 1
[Sysname-isis-1-ipv4] summary 202.0.0.0 255.0.0.0
flex-algo algorithm
te attribute enable
Use te attribute enable to enable TE attribute advertisement for an IS-IS process.
Use undo te attribute enable to disable TE attribute advertisement for an IS-IS process.
te attribute enable [ level-1 | level-2 ]
undo attribute enable [ level-1 | level-2 ]
IS-IS does not advertise TE attributes.
IS-IS view
level-1: Advertises TE attributes at Level-1 areas.
level-2: Advertises TE attributes at the Level-2 area.
This feature enables IS-IS to advertise TE attributes in the sub-TLVs of extended IS reachability TLVs (TLV type 22) for use by MPLS TE, SR-TE, and SRv6-TE.
To enable TE attribute advertisement for an IS-IS process, you can also use the mpls te enable command. Only TE and SR-TE can use the advertised TE attribute information.
If you execute this command multiple times, the most recent configuration takes effect. For example, if you execute the te attribute enable command and then the te attribute enable level-1 command, TE attribute advertisement is enabled at Level-1 areas and is disabled at the Level-2 area.
If you do not specify a level, this command enables IS-IS to advertise TE attributes at Level-1 and Level-2 areas. In this case, executing the undo te attribute enable level-1 command disables TE attribute advertisement at Level-1 areas. TE attribute advertisement is still enabled at the Level-2 area. Similarly, the undo te attribute enable level-2 command only disables TE attribute advertisement at the Level-2 area.
You can enable TE attribute advertisement only when the IS-IS cost style is wide, compatible, or wide-compatible.
# Enable TE attribute advertisement for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] cost-style wide-compatible
[Sysname-isis-1] te attribute enable
cost-style
mpls te enable (MPLS Command Reference)
timer aging-lsp-lifetime
Use timer aging-lsp-lifetime to set the lifetime for expired LSPs in the LSDB.
Use undo timer aging-lsp-lifetime to restore the default.
timer aging-lsp-lifetime { non-self-originate | self-originate } lifetime
undo timer aging-lsp-lifetime { non-self-originate | self-originate }
The lifetime for an expired LSP varies by the source of this LSP as follows:
·     If this LSP is generated by the local device, the lifetime is 1200 seconds.
·     If this LSP is received from another device, the lifetime is 60 seconds.
IS-IS view
non-self-originate: Specifies the LSPs generated by the local device.
self-originate: Specifies the LSPs received from other devices.
lifetime: Sets the lifetime for expired LSPs in seconds. The value range for this argument is 1 to 65535. An expired LSP will be deleted from the LSDB after its lifetime elapses.
Each IS-IS LSP has a maximum lifetime. After a device receives an LSP, the lifetime of this LSP starts decreasing. The LSP will expire if the following conditions exist:
·     The device does not receive any update for the LSP.
·     The lifetime of the LSP has decreased to 0.
If the device still does not receive any update for the expired LSP within a specific period of time, it will delete the LSP from its LSDB.
Some LSPs might expire before flooding and are deleted from the LSDB, especially when IS-IS has multiple neighbors and the LSDB contains a large number of LSPs. As a result, IS-IS might take a long time to complete route learning, if the LSP advertisement sources cannot update LSPs in time.
To resolve this issue, increase the lifetime for expired LSPs by using this command. Then, IS-IS can flood out the expired LSPs before they are deleted, which ensures the LSP advertisement sources can update LSPs in time.
# Allow received LSPs to exist in the LSDB for 1000 seconds after they expire.
[Sysname] isis 1
[Sysname-isis-1] timer aging-lsp-lifetime non-self-originate 1000
timer lsp-refresh
timer lsp-max-age
timer lsp-arrival
Use timer lsp-arrival to set the LSP receiving interval.
Use undo timer lsp-arrival to remove the configuration.
timer lsp-arrival maximum-interval [ minimum-interval [ incremental-interval ] ] [ level-1 | level-2 ]
undo timer lsp-arrival [ level-1 | level-2 ]
The LSP receiving interval is not set.
IS-IS view
maximum-interval: Specifies the maximum LSP receiving interval in the range of 1 to 120 seconds.
minimum-interval: Specifies the minimum LSP receiving interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental interval in the range of 10 to 60000 milliseconds.
level-1: Applies the intervals to Level-1.
level-2: Applies the intervals to Level-2.
When the network is stable, IS-IS uses the minimum receiving interval. When network changes become frequent, the receiving interval increases by the incremental interval each time the same LSP is received until the maximum receiving interval is reached.
The minimum LSP receiving interval and the incremental interval cannot be greater than the maximum LSP receiving interval.
If no level is specified, the specified intervals apply to both Level-1 and Level-2.
# Set the maximum receiving interval, minimum receiving interval, and incremental interval for Level-1 LSPs to 10 seconds, 100 milliseconds, and 200 milliseconds, respectively.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-arrival 10 100 200 level-1
timer lsp-flood suppress-flapping
Use timer lsp-flood suppress-flapping to suppress LSP flooding when route flapping occurs.
Use undo timer lsp-flood suppress-flapping to remove the configuration.
timer lsp-flood suppress-flapping delay-interval [ threshold threshold-value ] [ level-1 | level-2 ]
undo timer lsp-flood suppress-flapping [ level-1 | level-2 ]
IS-IS does not suppress LSP flooding.
IS-IS view
delay-interval: Specifies the delay time in the range of 0 to 65535 seconds.
threshold threshold-value: Specifies the number of route flaps that trigger the delay timer, in the range of 3 to 100. The default number is 5.
level-1: Applies the configuration to Level-1.
level-2: Applies the configuration to Level-2.
If no level is specified, the configuration applies to both Level-1 and Level-2.
# Suppress Level-1 LSP flooding for 5 seconds after the number of route flaps reaches 10.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-flood suppress-flapping 5 threshold 10 level-1
timer lsp-generation
Use timer lsp-generation to set the LSP generation interval.
Use undo timer lsp-generation to remove the configuration.
timer lsp-generation maximum-interval [ minimum-interval [ incremental-interval ] ] [ level-1 | level-2 ]
undo timer lsp-generation [ level-1 | level-2 ]
The maximum interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
IS-IS view
maximum-interval: Specifies the maximum interval in the range of 1 to 120 seconds.
minimum-interval: Specifies the minimum interval in the range of 10 to 60000 milliseconds.
level-2: Applies the intervals to Level-2. If no level is specified, the specified intervals apply to both Level-1 and Level-2.
By adjusting the LSP generation interval, you can prevent bandwidth and router resources from being over consumed due to frequent topology changes.
If you specify only the maximum-interval argument, the LSP generation interval is maximum-interval.
If you do not specify the incremental-interval argument, the LSP generation interval is in the range of minimum-interval to maximum-interval.
If you specify the incremental-interval argument, the LSP generation interval is as follows:
·     When network changes are not frequent, the minimum-interval is adopted.
·     When network changes are frequent, the LSP generation interval increases by incremental-interval × 2n-2 (n is the number of calculation times) each time a generation occurs until the maximum-interval is reached.
The minimum interval and the incremental interval cannot be greater than the maximum interval.
# Set the maximum interval, minimum interval, and incremental interval to 10 seconds, 100 milliseconds, and 200 milliseconds, respectively.
[Sysname] isis 1
[Sysname-isis-1]timer lsp-generation 10 100 200
timer lsp-generation suppress-flapping
Use timer lsp-generation suppress-flapping to suppress LSP generation when route flapping occurs.
Use undo timer lsp-generation suppress-flapping to remove the configuration.
timer lsp-generation suppress-flapping delay-interval [ threshold threshold-value] [ level-1 | level-2 ]
undo timer lsp-generation suppress-flapping [ level-1 | level-2 ]
IS-IS does not suppress LSP generation.
IS-IS view
# Suppress Level-1 LSP generation for 3 seconds after the number of route flaps reaches 10.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-generation suppress-flapping 3 threshold 10 level-1
timer lsp-max-age
Use timer lsp-max-age to set the LSP maximum age in the LSDB.
Use undo timer lsp-max-age to restore the default.
timer lsp-max-age seconds
The LSP maximum age in the LSDB is 1200 seconds.
IS-IS view
seconds: Specifies the LSP maximum aging time in the range of 1 to 65535 seconds.
Application scenarios
Each LSP has an age that decreases in the LSDB. Any LSP with an age of 0 is deleted from the LSDB. You can adjust the age value based on the scale of a network.
The value for the seconds argument in the timer lsp-max-age command must be greater than that for the seconds argument in the timer lsp-refresh command.
The value for the seconds argument in the timer lsp-max-age command must be smaller than or equal to that for the refresh-value argument in the timer lsp-remaining-lifetime refresh command.
# Set the maximum LSP age to 1500 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-max-age 1500
timer lsp-refresh
timer lsp-refresh
Use timer lsp-refresh to set the LSP refresh interval.
Use undo timer lsp-refresh to restore the default.
timer lsp-refresh seconds
The default LSP refresh interval is 900 seconds.
IS-IS view
seconds: Specifies the LSP refresh interval in the range of 1 to 65534 seconds.
Each router refreshes its LSPs at a configurable interval and sends them to other routers to achieve the following purposes:
·     Prevent valid routes from aging out.
·     Synchronize LSPs in the network.
A smaller refresh interval speeds up network convergence but consumes more bandwidth.
To refresh LSPs before they are aged out, the interval configured by the timer lsp-refresh command must be smaller than that configured by the timer lsp-max-age command.
# Set the LSP refresh interval to 1500 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-refresh 1500
timer lsp-max-age
Use timer lsp-remaining-lifetime refresh to set the initial remaining lifetime of IS-IS LSPs in the LSDB.
Use undo timer lsp-remaining-lifetime refresh to restore the default.
timer lsp-remaining-lifetime refresh { refresh-value | lsp-max-age | disable }
When IS-IS receives an updated LSP, it sets the maximum LSP age as the initial remaining lifetime of this LSP.
IS-IS view
refresh-value: Specifies the initial remaining lifetime of IS-IS LSPs in the LSDB, in seconds. The minimum value for this argument is the LSP maximum age set by the timer lsp-max-age command and the maximum value for this argument is 65535. If the timer lsp-max-age command is not executed, the value range for the refresh-value argument is 1200 to 65535.
lsp-max-age: Specifies the LSP maximum age set by the timer lsp-max-age command as the initial remaining lifetime of IS-IS LSPs in the LSDB. If the timer lsp-max-age command is not executed, the initial remaining lifetime of IS-IS LSPs is 1200 seconds.
disable: Disables configuring the initial remaining lifetime of IS-IS LSPs in the LSDB. The local device will use the original remaining lifetime of updated IS-IS LSPs that are subsequently received.
A large number of LSPs might queue up for flooding in the LSDB of an advertisement source, which inevitably shortens their remaining lifetime. In this situation, the remaining lifetime of some LSPs might be too short when they are flooded. Such LSPs soon expire on the recipient side, causing LSP flapping or temporary unreachable routes. To resolve this issue, use this command to set the initial remaining lifetime of IS-IS LSPs in the LSDB.
Operating mechanism
The timer lsp-remaining-lifetime refresh{ refresh-value | lsp-max-age } command takes effect only when the following requirements are met:
·     The local device receives an LSP update from another device.
·     The remaining lifetime of the LSP is not 0, and is smaller than that specified by the refresh-value argument or the lsp-max-age keyword in this command.
Recommended configuration
As a best practice to prevent LSP flapping, execute the timer lsp-remaining-lifetime refresh{ refresh-value | lsp-max-age } command to adjust the remaining lifetime of IS-IS LSPs.
To have the local device use the original remaining lifetime in received newer LSPs, execute the timer lsp-remaining-lifetime refresh disable command.
# Set the initial remaining lifetime of IS-IS LSPs in the LSDB to 60000 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-remaining-lifetime refersh 60000
# Disable configuring the initial remaining lifetime of IS-IS LSPs in the LSDB.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-remaining-lifetime refersh disable
timer lsp-max-age
timer purge-zero-lsp route-calculate-delay
Use timer purge-zero-lsp route-calculate-delay to suppress route calculation after fragment 0 of a purge LSP is received.
Use undo timer purge-zero-lsp route-calculate-delay to remove the configuration.
timer purge-zero-lsp route-calculate-delay delay-interval [ level-1 | level-2 ]
undo timer purge-zero-lsp route-calculate-delay [ level-1 | level-2 ]
IS-IS suppresses route calculation for 10 seconds after fragment 0 of a purge LSP is received.
IS-IS view
level-1: Applies the delay time to Level-1.
level-2: Applies the delay time to Level-2.
If no level is specified, the delay time applies to both Level-1 and Level-2.
# Suppress route calculation for 15 seconds after fragment 0 of a purge LSP is received.
[Sysname] isis 1
[Sysname-isis-1] timer purge-zero-lsp route-calculate-delay 15 level-1
timer route-calculate suppress-flapping
Use timer route-calculate suppress-flapping to suppress route calculation when route flapping occurs.
Use undo timer route-calculate suppress-flapping to remove the configuration.
timer route-calculate suppress-flapping delay-interval [ threshold threshold-value ] [ level-1 | level-2 ]
undo timer route-calculate suppress-flapping [ level-1 | level-2 ]
IS-IS does not suppress route calculation.
IS-IS view
# Suppress route calculation for 5 seconds after the number of route flaps reaches 10.
[Sysname] isis 1
[Sysname-isis-1] timer route-calculate suppress-flapping 5 threshold 10 level-1
timer spf
Use timer spf to set the SPF calculation interval.
Use undo timer spf to restore the default.
timer spf { maximum-interval [ minimum-interval [ incremental-interval [ conservative ] ] ] | millisecond millisecond-interval } [ exclude-prc ]
undo timer spf
The maximum SPF calculation interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
IS-IS view
maximum-interval: Specifies the maximum SPF calculation interval in the range of 1 to 120 seconds.
minimum-interval: Specifies the minimum SPF calculation interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental SPF calculation interval in the range of 10 to 60000 milliseconds.
conservative: Keeps the maximum interval when route flapping occurs. If you do not specify this keyword, the minimum interval is used after SPF calculation is performed at the maximum interval for three consecutive times.
millisecond millisecond-interval: Specifies the fixed SPF calculation interval in the range of 0 to 10000 milliseconds.
exclude-prc: Configures IS-IS to perform SPF calculation immediately upon route prefix changes.
Based on the LSDB, an IS-IS router uses the SPF algorithm to calculate a shortest path tree with itself being the root, and uses the shortest path tree to determine the next hop to a destination network. By adjusting the SPF calculation interval, you can prevent bandwidth and router resources from being overused due to frequent topology changes.
When network changes are not frequent, the minimum-interval is adopted. If network changes become frequent, the SPF calculation interval increases by the incremental-interval each time a generation happens until the maximum-interval is reached.
As a best practice to speed up route convergence triggered by route prefix changes, specify the exclude-prc keyword for the timer spf command.
# Set the maximum interval to 10 seconds, the minimum interval to 100 milliseconds, and the incremental interval to 300 milliseconds, respectively.
[Sysname] isis 1
[Sysname-isis-1] timer spf 10 100 300
virtual-system
Use virtual-system to configure a virtual system ID for the IS-IS process.
Use undo virtual-system to remove a virtual system ID.
virtual-system virtual-system-id
undo virtual-system virtual-system-id
No virtual system ID is configured.
IS-IS view
virtual-system-id: Specifies a virtual system ID for the IS-IS process.
# Set a virtual system ID of 2222.2222.2222 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] virtual-system 2222.2222.2222
