08-Layer 3—IP Services Command Reference
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesCommand ReferencesH3C SR6602-I[IE] AI-Powered ICT Converged Gateways Command References(V9)-R9141-6W10008-Layer 3—IP Services Command Reference
17-Web caching commands
17-Web caching commands 131.48 KB
cached-data
Use cached-data to specify the types of the webpage files to be cached.
Use undo cached-data to restore the default.
cached-data { apk | bmp | doc | docx | gif | gzip | ipa | jar | jpg | jpeg | mp4 | pdf | png | ppt | pptx | rar | swf | tar | txt | xls | xlsx | zip } *
undo cached-data
No webpage file types are specified.
Web cache view
apk: Specifies .apk files.
bmp: Specifies .bmp files.
doc: Specifies .doc files.
docx: Specifies .docx files.
gif: Specifies .gif files.
gzip: Specifies .gzip files.
ipa: Specifies .ipa files.
jar: Specifies .jar files.
jpg: Specifies .jpg files.
jpeg: Specifies .jpeg files.
mp4: Specifies .mp4 files.
pdf: Specifies .pdf files.
png: Specifies .png files.
ppt: Specifies .ppt files.
pptx: Specifies .pptx files.
rar: Specifies .rar files.
swf: Specifies .swf files.
tar: Specifies .tar files.
txt: Specifies .txt files.
xls: Specifies .xls files.
xlsx: Specifies .xlsx files.
zip: Specifies .zip files.
If you do not specify the types of the webpage files to be cached, the Web caching feature does not cache any types of files on webpages.
Execute this command before enabling Web caching.
Before configuring or modifying file type settings, you must disable Web caching. After configuring or modifying file type settings, enable Web caching again.
# Configure the Web caching feature to cache .doc and .docx files on webpages.
[Sysname] web-cache slot 1
[Sysname-web-cache-slot1] cached-data doc docx
http enable
https enable
cached-extension-name
Use cached-extension-name to specify an extension of files to be cached.
Use undo cached-extension-name to remove extensions of files to be cached.
cached-extension-name extension-name
undo cached-extension-name [ extension-name ]
No extensions are specified for files to be cached.
Web cache view
extension-name: Specifies a file extension by its name, a case-sensitive string of 1 to 16 characters. Valid characters include letters, digits, underscores (_), and hyphens (-).
Use this command to specify a file type by its extension if the file type is not available for the cached-data command.
You can configure this command multiple times to specify a maximum of 64 file extensions.
Before configuring or modifying file extension settings, you must disable Web caching. After configuring or modifying file extension settings, enable Web caching again.
If you specify webpage files to be cached by file name, file type, and file extension, the device caches webpages file in the following order:
1.     Webpage files with a file name specified by using the cached-file command.
2.     Webpage files with a file type specified by using the cached-data command or file extension specified by using the cached-extension-name command.
# Configure the Web caching feature to cache files with extension name cab.
[Sysname-web-cache-slot1] cached-extension-name cab
cached-data
cached-file
cached-file
Use cached-file to specify a webpage file to be cached.
Use undo cached-file to remove webpage files to be cached.
cached-file file-name
undo cached-file [ file-name ]
No webpage files can be cached.
Web cache view
file-name: Specifies a webpage file by its name, a case-sensitive string of 1 to 127 characters.
You can repeat this command to specify multiple webpage files to be cached.
If you specify both webpage files and types of the webpage files to be cached, the device caches the matching webpage files of the specified types.
Before you add or delete a webpage file to be cached, you must disable Web caching. After adding or deleting the webpage file, enable Web caching again.
Execution of the undo cached-file command will not delete webpage files saved in the Web cache directory.
# Specify file test1.doc as a webpage file to be cached.
[Sysname-web-cache-slot1] cached-file test1.doc
cached-data
cache-ignore
Use cache-ignore to configure Web caching to ignore the specified HTTP/HTTPS response headers.
Use undo cache-ignore to restore the default.
cache-ignore { cache-control | set-cookie | vary } *
undo cache-ignore [ cache-control | set-cookie | vary ] *
Whether Web caching caches Web resources is affected by the HTTP/HTTPS response header type.
Web cache view
cache-control: Specifies Cache-Control headers.
set-cookie: Specifies Set-Cookie headers.
vary: Specifies Vary headers.
The HTTP/HTTPS response header type affects Web caching as follows:
·     If the HTTP/HTTPS response has a Cache-Control header, whether Web caching caches the requested Web resources depends on the instructions in the header.
·     If the HTTP/HTTPS response has a Set-Cookie header, Web caching does not cache the requested Web resources.
·     If the HTTP/HTTPS response has a Vary header, whether Web caching caches the requested Web resources depends on the value for the Vary field.
To make sure Web caching caches the requested Web resources, configure Web caching to ignore the specified HTTP/HTTPS response headers.
#  On slot 1, configure Web caching to ignore the Cache-Control and Vary response headers.
[Sysname-web-cache-slot1] cache-ignore cache-control vary
cache-limit
Use cache-limit to set the maximum total size for Web cache files.
Use undo cache-limit to restore the default.
cache-limit size
undo cache-limit
The maximum total size of Web cache files is 4 GB.
Web cache view
size: Specifies the maximum total size for Web cache files in GB. The value range is 1 to 4095. The default is 4.
Before changing the maximum total file size setting, you must disable Web caching. After changing the maximum total file size setting, enable Web caching again.
The maximum total size for Web cache files must be smaller than the maximum storage space size in the working directory. To display the maximum size of storage space in the working directory, execute the display web-cache command. After the effective maximum total size is reached, the device deletes the oldest Web cache file to save the new Web cache file.
The aging time for Web cache files is fixed at 30 days. When the device reboots or receives a request for the content in a Web cache file, it restarts the aging timer. If no users request the content in a file before the aging timer expires, the device deletes the file.
# Set the maximum total size for Web cache files to 3 GB.
[Sysname-web-cache-slot1] cache-limit 3
display web-cache
Use display web-cache to display Web caching information.
display web-cache [ history ] [ last { day | 30-days | 365-days | hour | minute | week } | verbose ]
history: Displays history information. If you do not specify this keyword, the command displays the current statistics, which is collected at 1-second intervals.
last: Displays statistics for a specific period of time in the past. If you do not specify this keyword, the command displays the current statistics and the statistics for specific periods of time in the past.
minute: Displays statistics for the most recent one minute.
hour: Displays statistics for the most recent one hour.
day: Displays statistics for the most recent one day.
week: Displays statistics for the most recent one week.
30-days: Displays statistics for the most recent 30 days.
365-days: Displays statistics for the most recent 365 days.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display the current Web caching statistics.
<Sysname> display web-cache history
Date        TimeRange          ConnectTop  CacheTop  BandwidthSaved  CacheHitRate
2020/04/20  14:43:02-14:43:03  3           16.0KB    0               0%
2020/04/20  14:43:01-14:43:02  3           16.0KB    96.0Kbps        100%
# Display all Web caching information.
Web-cache configurations
  Cache path: flash:/var/web-cache/proxy/cache
  Max connections: 1022
  Max cache size: 3GB
Current state information
  Cache memory: 0
  Cache count: 0
Statistics for past 1 minute
  ConnectTop: 2
  CacheTop: 0
  Bandwidth saved:                      0
  Cached data transmission speed:       0
  Cached data transmitted:              0
  Download speed:                       0
  Download size:                        0
  CacheHitRate: 0%
    Hit count: 0                     Miss count: 0
Statistics for past 1 hour
  ConnectTop: 2
  CacheTop: 0
  Bandwidth saved:                      0
  Download speed:                       0
  Download size:                        0
  CacheHitRate: 0%
Statistics for past 1 day
  ConnectTop: 2
  CacheTop: 463.4MB
  Bandwidth saved:                      0
  Download speed:                       0
  Download size:                        0
  CacheHitRate: 0%
Statistics for past 30 days
  ConnectTop: 2
  CacheTop: 463.4MB
  Bandwidth saved:                      0
  Download speed:                       0
  Download size:                        0
  CacheHitRate: 0%
Statistics for past 365 days
  ConnectTop: 2
  CacheTop: 463.4MB
  Bandwidth saved:                      0
  Cached data transmission speed:       120 Kbps
  Cached data transmitted:              400MB
  Download speed:                       0
  Download size:                        0
  CacheHitRate: 0%
# Display per-second detailed Web caching statistics.
<Sysname> display web-cache history verbose
2020/04/05 09:02:47-09:02:48
  ConnectTop: 2
  CacheTop: 0
  Bandwidth saved:                      0
  Download speed:                       0
  Download size:                        0
  CacheHitRate: 0%
2020/04/05 09:02:46-09:02:47
  ConnectTop: 2
  CacheTop: 0
  Bandwidth saved:                      0
  Download speed:                       0
  Download size:                        0
  CacheHitRate: 0%
Cache path
Max connections
Maximum number of connections allowed.
Max cache size
Current maximum storage space size.
Cache memory
Current total size of Web cache files.
Cache count
Number of Web cache files.
Web caching statistics for the most recent one minute.
Web caching statistics for the most recent one hour.
Web caching statistics for the most recent one day.
Web caching statistics for the most recent 30 days.
Web caching statistics for the most recent 365 days.
ConnectTop
Maximum number of connections during the specified period of time.
CacheTop
Maximum total size (in MB) of Web cache files during the specified period of time.
Bandwidth saved
Bandwidth saved during the specified period of time.
Speed at which cached data was transferred to users during the specified period of time.
Amount of cached data that was transferred to users during the specified period of time, in kilobytes.
Download speed
Speed at which cached data was downloaded from Web servers during the specified period of time.
Download size
Amount of cached data that was downloaded from Web servers during the specified period of time, in kilobytes.
CacheHitRate
Percentage of hits of cached data.
Hit count
Number of hits of cached data.
Miss count
Number of times that cached data was not matched.
dual-gateway-channel
Use dual-gateway-channel to configure a channel for traffic direction with the peer gateway.
Use undo dual-gateway-channel to delete the traffic direction channels.
dual-gateway-channel [ vpn-instance vpn-instance-name ] interface interface-type interface-number peer ipv4-address
undo dual-gateway-channel [ vpn-instance vpn-instance-name ]
No channels are configured for traffic direction with the peer gateway.
Web cache view
vpn-instance vpn-instance-name: Specifies the VPN instance of the peer gateway. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must have existed. If you do not specify a VPN instance, this command applies to the peer gateway device in the public network.
interface interface-type interface-number: Specifies the traffic direction channel interface by its type and number.
peer ipv4-address: Specifies the IPv4 address of the peer gateway. This address must be a unicast address.
This command applies to the Web cache dual gateway scenario. In this scenario, two gateways provide the Web cache service for users simultaneously, and equal cost paths exist on both the uplink and downlink for Web cache. If the uplink and downlink traffic forwarding paths are not the same, the uplink traffic and downlink traffic will be forwarded to different gateways for processing. The downlink traffic therefore cannot be forwarded to the users and the users cannot access the requested Web resources as a result.
To avoid this issue, you can use this command to configure a traffic direction channel with the peer gateway. If the device receives Web cache downlink traffic for a user that it cannot find, the device forwards the downlink traffic to the peer gateway through the specified channel interface, so the peer gateway can provide Web resources for the user correctly.
In the Web cache dual gateway scenario, the uplink traffic refers to the HTTP/HTTPS requests sent from user hosts to Web servers, and the downlink traffic refers to the HTTP/HTTP responses sent from Web servers to user hosts.
Before you execute this command, disable the Web cache feature. After this command is executed again, enable the Web cache feature again.
Make sure the specified IPv4 address of the peer gateway is reachable, and in the routing table, the outgoing interface for this IPv4 address is the channel interface specified in this command.
You can configure multiple traffic direction channels in multiple VPN instances. If you execute this command for the same VPN instance or for the public network multiple times, the most recent configuration takes effect.
# Specify channel interface Ten-GigabitEthernet 0/0/6 for traffic direction with peer gateway 1.1.1.1 in VPN instance test.
<Sysname> system
[Sysname-web-cache-slot1] dual-gateway-channel vpn-instance test interface ten-gigabitethernet 0/0/6 peer 1.1.1.1
file-directory
Use file-directory to set the Web cache directory.
Use undo file-directory to restore the default.
file-directory directory
undo file-directory
The Web cache directory is not set.
Web cache view
directory: Specifies the Web cache directory, starting from the storage medium location information slotn#. The slot number n must be the same as the slot number of the Web cache view.
Before changing the Web cache directory, you must disable Web caching. After changing the Web cache directory, enable Web caching again.
Make sure the storage medium where the Web cache directory resides has sufficient storage space. The Web caching feature saves its operation data and the Web content to be cached to files in the directory. The directory typically needs a storage space of over 1 GB.
Before specifying a Web cache directory, make sure all files in the upper-level directory are using a different name than the Web cache directory or have a file extension. For example, if you want to specify flash:/web-cache as the Web cache directory, files without a file extension in the flash: directory cannot use web-cache as the file name.
The Web cache directory for a Web cache view must reside on the same slot as the Web view.
# Set the Web cache directory.
[Sysname-web-cache-slot1] file-directory slot1#flash:/aaa
http enable
Use http enable to enable HTTP-based Web caching.
Use undo http enable to disable HTTP-based Web caching.
http enable
undo http enable
HTTP-based Web caching is disabled.
Web cache view
Before enabling HTTP-based Web caching, you must configure the types of the webpage files to be cached and the Web cache directory.
# Enable HTTP-based Web caching.
[Sysname-web-cache-slot1] http enable
cached-data
file-directory
https enable
Use https enable to enable HTTPS-based Web caching.
Use undo https enable to disable HTTPS-based Web caching.
https enable
undo https enable
HTTPS-based Web caching is disabled.
Web cache view
Before enabling HTTPS-based Web caching, you must configure the types of the webpage files to be cached and the Web cache directory.
When the device enabled with HTTPS-based Web caching attempts to cache Web resources accessed by a user through HTTPS, the user will be prompted with a certificate warning. Because the certificate of the device is a private CA-issued digital certificate, it cannot pass the verification of the user host. To resolve this issue, the user can export the device's CA root certificate file (webcache_cacert.crt) from the Web caching working directory and import it to the trusted certificate authorities store. Then, the device' certificate can pass the verification of the user host so the user will not be prompted with the certificate warning.
# Enable HTTPS-based Web caching.
[Sysname-web-cache-slot1] https enable
cached-data
file-directory
https listen-port
Use https listen-port to set a port number for Web caching to listen for HTTPS packets.
Use undo https listen-port to remove listening port numbers specified for Web caching to listen for HTTPS packets.
https listen-port port-number [ server-port server-port-number ]
undo https listen-port [ port-number ]
Web caching listens to port 2043 for HTTPS packets.
Web cache view
port-number: Specifies a TCP port number in the range of 1025 to 65535.
server-port server-port-number: Specifies the listening port number of the Web server from which Web caching caches Web content. The value range is 1 to 65535, and the default is 443.
Use this command in either of the following situations:
·     The default port number used by Web caching to listen for HTTPS packets is used by another service on the device, which causes Web caching fails to be enabled.
·     A Web server does not listen for HTTPS packets on port number 443.
After receiving an HTTPS request from a host, Web cache first checks whether the destination port number in the request matches an HTTPS listening port number of a Web server. If yes, Web caching replaces the destination port number with the listening port number of the Web server and forwards the request to the Web server. Upon receiving the HTTPS response from the Web server, Web caching replaces the source port number with the listening port number for Web caching before sending the response to the host.
An HTTPS listening port number for Web caching and an HTTPS listening port number for a Web server is a listening port number pair. If Web caching caches webpage files from multiple Web servers that use different listening port numbers, you must configure multiple listening port number pairs for the Web servers. A maximum of eight pairs are supported.
If you execute this command multiple times with the same Web caching listening port number or Web server caching listening port number, the most recent configuration takes effect.
Before changing the listening port setting, you must disable Web caching. After changing the listening port setting, enable Web caching again.
To successfully specify listening port numbers, make sure the specified TCP port numbers are not being used by any other services on the device. To display TCP port numbers in use, execute the display tcp verbose command.
# Set the port number to 1655 for Web caching to listen for HTTPS packets.
[Sysname-web-cache-slot1] https listen-port 1655
# Set the port number to 1655 for Web caching to listen for HTTPS packets destined for the Web server that uses the listening port number 8655.
[Sysname-web-cache-slot1] https listen-port 1655 server-port 8655
https enable
listen-port
Use listen-port to set a port number for Web caching to listen for HTTP packets.
Use undo listen-port to remove listening port numbers specified for Web caching to listen for HTTP packets.
undo listen-port [ port-number ]
Web caching listens to port 4180 for HTTP packets.
Web cache view
port-number: Specifies a TCP port number for Web caching to listen for HTTP packets (HTTP listening port number for Web caching). The value range is 1025 to 65535.
server-port server-port-number: Specifies the listening port number of the Web server from which Web caching caches Web content. The value range is 1 to 65535, and the default is 80.
·     The default port number used by Web caching to listen for HTTP packets is used by another service on the device, which causes Web caching fails to be enabled.
·     A Web server does not listen for HTTP packets on port number 80.
After receiving an HTTP request from a host, Web cache first checks whether the destination port number in the request matches an HTTP listening port number of a Web server. If yes, Web caching replaces the destination port number with the listening port number of the Web server and forwards the request to the Web server. Upon receiving the HTTP response from the Web server, Web caching replaces the source port number with the listening port number for Web caching before sending the response to the host.
An HTTP listening port number for Web caching and an HTTP listening port number for a Web server is a listening port number pair. If Web caching caches webpage files from multiple Web servers that use different listening port numbers, you must configure multiple listening port number pairs for the Web servers. A maximum of eight pairs are supported.
# Set the port number to 1655 for Web caching to listen for HTTP packets.
[Sysname-web-cache-slot1] listen-port 1655
# Set the port number to 1655 for Web caching to listen for HTTP packets destined for the Web server that uses the listening port number 8655.
[Sysname-web-cache-slot1] listen-port 1655 server-port 8655
http enable
object-group
Use object-group to specify an IPv4 object group used to filter Web content to be cached.
Use undo object-group to remove an IPv4 object group used to filter Web content to be cached.
object-group [ source ] { ip | ipv6 } object-group-name
undo object-group [ source ] { ip | ipv6 }
No IPv4 object group is specified for filtering Web content. The Web caching feature caches webpage content from all Web servers.
Web cache view
source: Caches Web content requested by specific Web clients. If you do not specify this keyword, the Web caching feature caches Web content from specific Web servers.
ip: Uses an IPv4 object group to specify Web clients or Web servers.
ipv6: Uses an IPv6 address object group to specify Web clients or Web servers.
object-group-name: Specifies an object group by its name, a case-insensitive string of 1 to 63 characters.
Use this command to configure the Web caching feature to cache only Web content requested by specific Web clients or sent from specific Web servers.
This command requires the cooperation of the IP address object group feature. For more information about the IP address object group feature, see object group configuration in Security Configuration Guide.
Before changing the object group setting, you must disable Web caching. After changing the IPv4 object group setting, enable Web caching again.
# Configure the Web caching feature to cache only Web content from Web servers specified by IPv4 object group aaa.
[Sysname-web-cache-slot1] object-group ip aaa
object-group (Security Command Reference)
querystring-file-cache enable
Use querystring-file-cache enable to enable Web caching for files in QueryString of a URL.
Use undo querystring-file-cache enable to disable Web caching for files in QueryString of a URL.
Web caching does not cache files in QueryString of a URL.
Web cache view
After you execute this command, Web caching can cache files in QueryString of a URL, and it determines whether to cache the files according to other file filtering rules.
#  On slot 1, enable Web caching to cache files in QueryString of a URL.
[Sysname-web-cache-slot1] querystring-file-cache enable
cached-data
cached-file
web-cache
Use web-cache to create a Web cache view and enter its view, or enter an existing Web cache view.
Use undo web-cache to delete a Web cache view and all settings in the view.
web-cache slot slot-number
undo web-cache slot
No Web cache views exist.
slot slot-number: Specifies a card by its slot number.
# Create a Web cache view and enter its view.
