- 08-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-IP forwarding basics commands
- 06-Fast forwarding commands
- 07-Adjacency table commands
- 08-IRDP commands
- 09-IP performance optimization commands
- 10-UDP helper commands
- 11-IPv6 basics commands
- 12-IPv6 neighbor discovery commands
- 13-DHCPv6 commands
- 14-IPv6 fast forwarding commands
- 15-WAAS commands
- 16-HTTP redirect commands
- 17-Web caching commands
- 18-Multi-CPU packet distribution commands
| 05-IP forwarding basics commands | 129.37 KB |
Basic IP forwarding commands
display hpf trace filter
Use display hpf trace filter to display the configured HPF trace filters.
# Display the configured HPF trace filters.
<Sysname> display hpf trace filter
HPF Trace:
Start Node: device-input(355)
Max Number: 100
Total Number: 2000
Start Node: ip4-local-output(220)
Max Number: 100
Total Number: 2000
HPF Filter:
Filter Rule: -
Filter Node: -
Module Filter:
ETH: interface: Ten-GigabitEthernet1/0/1, ACL number: 2000
IP: ACL number: 2500
IPv6: ACL number: 3000
TCP: ACL number: 2100, ACL6 number: 2900
UDP: ACL number:2200, ACL6 number: 2600
HPF Trace |
HPF trace information. |
Start Node |
Name and index of the start node. |
Max Number |
Maximum number of HPF trace records. |
Total Number |
Total number of filtered packets. |
HPF Filter |
Information about the HPF framework-based trace filter. |
Filter Rule |
Filter rule. If no rule exists, this field displays a hyphen (-). |
Filter Node |
HPF node that acts as the HPF trace filter. If no HPF trace information filter exists, this field displays a hyphen (-). |
Module Filter |
HPF trace filter configured for modules. |
ETH |
Ethernet module. |
IP |
IP module. |
TCP |
TCP module. |
UDP |
UDP module. |
ACL number |
Number of the IPv4 ACL used for HPF trace filtering. |
ACL6 number |
Number of the IPv6 ACL used for HPF trace filtering. |
hpf trace filter
hpf trace filter ethernet
hpf trace filter ip
hpf trace filter ipv6
hpf trace filter tcp
hpf trace filter udp
display fib
Use display fib to display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ] [ slot slot-number]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN instance.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays FIB entries for the active MPU.
You can use this command to view the number of FIB entries successfully issued to hardware.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Route destination count: 5
Directly-connected host count: 0
Entries issued to hardware: 5
Flag:
U:Usable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
0.0.0.0/32 127.0.0.1 UH InLoop0 Null
1.1.1.0/24 192.168.126.1 USGF M-GE0/0/0 Null
127.0.0.0/8 127.0.0.1 U InLoop0 Null
127.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Route destination count: 8
Flag:
R:Relay F:FRR
20.20.20.0/24 20.20.20.25 U M-GE0/0/0 Null
20.20.20.0/32 20.20.20.25 UBH M-GE0/0/0 Null
20.20.20.25/32 127.0.0.1 UH InLoop0 Null
20.20.20.25/32 20.20.20.25 H M-GE0/0/0 Null
20.20.20.255/32 20.20.20.25 UBH M-GE0/0/0 Null
20.20.20.255/32 1000:2000:3000:4000:5000:6000:7000:8000 UBH MGE0
/0/0 Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
FIB entry count: 1
Entries issued to hardware: 1
Flag:
R:Relay F:FRR
10.2.1.1/32 127.0.0.1 UH InLoop0 Null
Route destination count |
Number of route destination addresses. |
Directly-connected host count |
Number of directly connected hosts learned by features such as ARP. |
Entries issued to hardware |
Number of FIB entries successfully issued to hardware. |
FIB entry count |
Total number of FIB entries. |
Destination/Mask |
Destination address and the mask length. |
Nexthop |
Next hop address. |
Flag |
Flags of routes: · U—Usable route. · G—Gateway route. · H—Host route. · B—Blackhole route. · D—Dynamic route. · S—Static route. · R—Relay route. · F—Fast reroute. |
OutInterface/Token |
Output interface/LSP index number. |
Label |
Inner label. |
display fib prefix diff
Use display fib prefix diff to display the differences in FIB entries between two slots.
display fib prefix diff [ all | [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ] ] slot slot-number1 slot slot-number2
all: Specifies all FIB entries of the public network and VPN instances.
vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters without spaces.
ip-address: Compares the FIB entries that match the specified destination IPv4 address.
mask: Specifies the mask for the IPv4 address.
mask-length: Specifies the mask length for the IPv4 address. The value range is 0 to 32.
slot slot-number1 slot slot-number2: Specifies two cards by their slot numbers. You must specify two different cards.
Application scenarios
Inconsistency of FIB entries between the MPU and the interface module might cause issues such as packet loss, packet processing delay on the interface module, and packet queue overload. Use this command to display the differences in FIB entries between the MPU and interface module and check for inconsistency. If inconsistency exists, execute the display current-configuration diff command in any view to display the differences that the running configuration has as compared with the next-startup configuration and identify unnecessary configuration.
Operating mechanism
You can specify a subnet to match FIB entries when specifying the ip-address argument. If you do not specify any mask or mask length, the system compares the FIB entry that has the longest match with the specified destination IPV4 address on each slot. If you specify a mask or mask length, the system compares the FIB entry that has the exact match with the specified destination IPV4 address and mask on each slot.
# Display the differences in FIB entries between slot 0 and slot 3.
<Sysname> display fib prefix diff slot 0 slot 3
--- Slot 0 CPU 0
+++ Slot 3 CPU 0
@@ -1,19 +0,0 @@
-Destination/Mask:0.0.0.0/32 VNID:0x310000003 VPN:--
-Destination/Mask:10.0.0.0/24 VNID:0x710000007 VPN:--
-Destination/Mask:10.0.0.0/32 VNID:0x710000007 VPN:--
-Destination/Mask:10.0.0.1/32 VNID:0x310000003 VPN:--
-Destination/Mask:10.0.0.2/32 VNID:-- VPN:--
-Destination/Mask:10.0.0.255/32 VNID:0x710000007 VPN:--
-Destination/Mask:30.0.0.0/24 VNID:0x17000000 VPN:--
-Destination/Mask:127.0.0.0/8 VNID:0x310000003 VPN:--
-Destination/Mask:127.0.0.0/32 VNID:0x410000004 VPN:--
-Destination/Mask:127.0.0.1/32 VNID:0x310000003 VPN:--
-Destination/Mask:127.255.255.255/32 VNID:0x410000004 VPN:--
-Destination/Mask:172.16.94.0/24 VNID:0x610000006 VPN:--
-Destination/Mask:172.16.94.0/32 VNID:0x610000006 VPN:--
-Destination/Mask:172.16.94.100/32 VNID:0x310000003 VPN:--
-Destination/Mask:172.16.94.200/32 VNID:-- VPN:--
-Destination/Mask:172.16.94.201/32 VNID:-- VPN:--
-Destination/Mask:172.16.94.255/32 VNID:0x610000006 VPN:--
-Destination/Mask:255.255.255.255/32 VNID:0x310000003 VPN:--
\ No newline at end of file
+Destination/Mask:192.168.100.10/24 VNID:-- VPN:--
+Destination/Mask:192.168.100.20/24 VNID:-- VPN:--
--- A +++ B |
· A—Source slot number and CPU number for comparison. · B—Destination slot number and CPU number for comparison. |
@@ -linenumber1,number1 +linenumber2,number2 @@ |
· -linenumber1,number1—Display number1 entries starting from linenumber1 on the source slot. · +linenumber2,number2—Display number2 entries starting from linenumber2 on the destination slot. |
Destination/Mask |
Destination IP address and mask length. · A hyphen(-) in front of this field indicates that the entry exists on the source slot but not on the destination slot. · A plus sign(+) in front of this field indicates that the entry exists on the destination slot but not on the source slot. |
VNID |
VN ID. Two hyphens (--) indicates that no VN ID exists. |
VPN |
VPN instance name. Two hyphens (--) indicates the public network. |
No newline at end of file |
No more comparison results are available. |
display fib vn diff
Use display fib vn diff to display the differences in FIB VN entries between two slots.
display fib vn diff [ id id ] slot slot-number1 slot slot-number2
id id: Specifies the VN entry by its VN ID.
Inconsistency of VN entries between the MPU and the interface module might cause issues such as packet loss, packet processing delay on the interface module, and packet queue overload. Use this command to display the differences in VN entries between the MPU and interface module and check for inconsistency. If inconsistency exists, execute the display current-configuration diff command in any view to display the differences that the running configuration has as compared with the next-startup configuration and identify unnecessary configuration.
If you do not specify the id keyword, the command displays the differences in all FIB VN entries between two slots.
# Display the differences in FIB VN entries between slot 0 and slot 3.
<Sysname> display fib vn diff slot 0 slot 3
--- Slot 0 CPU 0
+++ Slot 3 CPU 0
@@ -1,19 +1,2 @@
-VNID:0x810000008 NextHopNum:1 Flag:U Nexthop:[0]10.0.0.1
-VNID:0x70000001 NextHopNum:1 Flag:-- Nexthop:[0]Invalid
-VNID:0x10000000 NextHopNum:1 Flag:U Nexthop:[0]127.0.0.1
-VNID:0x20000000 NextHopNum:1 Flag:U Nexthop:[0]::1
-VNID:0x510000005 NextHopNum:1 Flag:U Nexthop:[0]127.0.0.1
-VNID:0x520000005 NextHopNum:1 Flag:U Nexthop:[0]::
-VNID:0x210000002 NextHopNum:1 Flag:-- Nexthop:[0]0.0.0.0
-VNID:0x220000002 NextHopNum:1 Flag:U Nexthop:[0]::1
-VNID:0x710000007 NextHopNum:1 Flag:U Nexthop:[0]10.0.0.1
-VNID:0x410000004 NextHopNum:1 Flag:U Nexthop:[0]127.0.0.1
-VNID:0x420000004 NextHopNum:1 Flag:U Nexthop:[0]::
-VNID:0x110000001 NextHopNum:1 Flag:U Nexthop:[0]127.0.0.1
-VNID:0x120000001 NextHopNum:1 Flag:U Nexthop:[0]::
-VNID:0x610000006 NextHopNum:1 Flag:U Nexthop:[0]172.16.94.100
-VNID:0x17000000 NextHopNum:2 Flag:-- Nexthop:[0]172.16.94.200
-VNID:0x17000000 NextHopNum:2 Flag:-- Nexthop:[1]172.16.94.201
-VNID:0x310000003 NextHopNum:1 Flag:-- Nexthop:[0]0.0.0.0
-VNID:0x320000003 NextHopNum:1 Flag:U Nexthop:[0]::
+VNID:0x70000001 NextHopNum:1 Flag:-- Nexthop:[0]Invalid
--- A +++ B |
VNID |
Virtual next hop ID. |
NextHopNum |
Total number of next hops. |
Nexthop |
Next hop information in the [Number]IP format: · Number—Next hop index number, starting from 0. · IP—Next hop IPv4 or IPv6 address. |
Flag |
Flag bit value: · U—The next hop takes effect. · --—The next hop does not take effect. |
Use hpf trace filter ethernet to configure an HPF trace filter for the Ethernet module.
hpf trace filter ethernet { acl { [ ipv6 ] { advanced-acl-number | basic-acl-number } | mac mac-acl-number } | interface interface-type interface-number } slot slot-number
undo hpf trace filter ethernet slot slot-number
No HPF trace filter is configured for the Ethernet module.
acl: Creates an ACL-type filter.
ipv6: Specifies an IPv6 ACL.
advanced-acl-number: Specifies an advanced ACL by its number. The value range for this argument is 3000 to 3999.
basic-acl-number: Specifies a basic ACL by its number. The value range for this argument is 2000 to 2999.
mac mac-acl-number: Specifies a Layer 2 ACL by its number. The value range for this argument is 4000 to 4999.
interface interface-type interface-number: Specifies an input or output interface by its type and number. The interface-type interface-number represents the interface type and the interface number.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command takes effect on the active MPU.
With this feature configured, you can use the display hpf trace command to view the filtered trace information.
If you specify an ACL that does not exist or does not have any rules, the configured filter cannot take effect.
# On slot 1, configure IPv4 ACL 2001 as the HPF trace information filter for the Ethernet module.
<Sysname> hpf trace filter ethernet acl 2001 slot 1
# On slot 1, configure IPv6 ACL 3001 as the HPF trace information filter for the Ethernet module.
<Sysname> hpf trace filter ethernet acl ipv6 3001 slot 1
# On slot 1, configure Layer 2 ACL 4001 as the HPF trace information filter for the Ethernet module.
<Sysname> hpf trace filter ethernet mac 4001 slot 1
hpf trace filter ip
Use hpf trace filter ip to configure an HPF trace filter for the IP module.
hpf trace filter ip acl acl-number slot slot-number
undo hpf trace filter ip slot slot-number
No HPF trace filter is configured for the IP module.
acl acl-number: Specifies an IPv4 ACL by its number. The value range for the acl-number argument is 2000 to 2999 for a basic ACL and is 3000 to 3999 for an advanced ACL.
# On slot 1, configure IPv4 ACL 2001 as the HPF trace information filter for the IPv4 module.
<Sysname> hpf trace filter ip acl 2001 slot 1
Use hpf trace filter ipv6 to configure an HPF trace filter for the IPv6 module.
hpf trace filter ipv6 acl acl-number slot slot-number
undo hpf trace filter ipv6 slot slot-number
No HPF trace filter is configured for the IPv6 module.
acl acl-number: Specifies an IPv6 ACL by its number. The value range for the acl-number argument is 2000 to 2999 for a basic ACL and is 3000 to 3999 for an advanced ACL.
# On slot 1, configure IPv6 ACL 2001 as the HPF trace information filter for the IPv6 module.
<Sysname> hpf trace filter ipv6 acl 2001 slot 1
Use hpf trace filter tcp to configure an HPF trace filter for the TCP module.
hpf trace filter tcp { acl acl-number | acl6 ipv6-acl-number } slot slot-number
undo hpf trace filter tcp { acl | acl6 } slot slot-number
No HPF trace information filter is configured for the TCP module.
acl6 ipv6-acl-number: Specifies an IPv6 ACL by its number. The value range for the ipv6-acl-number is 2000 to 2999 for a basic ACL and is 3000 to 3999 for an advanced ACL.
With this feature configured, you can use the display hpf trace command to display the filtered trace information.
# On slot 1, configure IPv4 ACL 2001 as the HPF trace information filter for the TCP module.
<Sysname> hpf trace filter tcp acl 2001 slot 1
# On slot 1, configure IPv6 ACL 2001 as the HPF trace information filter for the TCP module.
<Sysname> hpf trace filter tcp acl6 2001 slot 1
Use hpf trace filter udp to configure an HPF trace filter for the UDP module.
hpf trace filter udp { acl acl-number | acl6 ipv6-acl-number } slot slot-number
undo hpf trace filter udp { acl | acl6 } slot slot-number
No HPF trace filter is configured for the UDP module.
# On slot 1, configure IPv4 ACL 2001 as the HPF trace information filter for the UDP module.
<Sysname> hpf trace filter udp acl 2001 slot 1
# On slot 1, configure IPv6 ACL 2001 as the HPF trace information filter for the UDP module.
<Sysname> hpf trace filter udp acl6 2001 slot 1
ip fib consistency-check enable
Use ip fib consistency-check enable to enable consistency check for IPv4 FIB entries.
Use undo ip fib consistency-check enable to disable consistency check for IPv4 FIB entries.
Consistency check for IPv4 FIB entries is disabled.
This feature enables the device to perform consistency check regularly on all the IPv4 FIB entries in the software and hardware. If the device detects any inconsistency, it updates entries in hardware based on entries in the software.
# Enable consistency check for IPv4 FIB entries.
[Sysname] ip fib consistency-check enable
ip forwarding
Use ip forwarding to enable IPv4 packet forwarding on an interface that has no IPv4 address configured.
Use undo ip forwarding to disable IPv4 packet forwarding on an interface that has no IPv4 address configured.
ip forwarding
undo ip forwarding
If an interface has no IPv4 address configured, it cannot forward IPv4 packets.
Interface view
On a device that supports both IPv4 and IPv6, the next hop of an IPv4 packet might be an IPv4 address or an IPv6 address. If the output interface has no IPv4 address configured, the interface cannot forward the IPv4 packet. To resolve this issue, execute this command on the interface. This feature allows the interface to forward IPv4 packets even though the interface has no IPv4 address configured.
# Enable IPv4 packet forwarding on Ten-GigabitEthernet 0/0/6 that has no IPv4 address configured.
[Sysname] interface ten-gigabitethernet 0/0/6
[Sysname-Ten-GigabitEthernet0/0/6] ip forwarding
ip last-hop hold
Use ip last-hop hold to enable last hop holding.
Use undo ip last-hop hold to disable last hop holding.
ip last-hop hold
Last hop holding is disabled.
Dialer interface view
Last hop holding implements symmetric routing.
When the interface enabled with this feature receives the first IP packet of a forward flow, this feature implements the following operations:
· Obtains the forward flow information and last hop information of the packet.
· Based on the information, records the neighbor information for the reverse flow.
When packets of the reverse flow arrive at the device, the device forwards those packets based on the recorded neighbor information.
On devices supporting fast forwarding, last hop holding is based on fast forwarding entries. If the MAC address of a last hop changes, this feature can function correctly only after the fast forwarding entry is updated for the MAC address.
This command is not applicable to MPLS networks.
# Enable the last hop holding feature.
[Sysname-Ten-GigabitEthernet0/0/6] ip last-hop hold
snmp-agent trap enable fib
Use snmp-agent trap enable fib to enable SNMP notifications for FIB events.
Use undo snmp-agent trap enable fib to disable SNMP notifications for FIB events.
SNMP notifications for FIB events are enabled.
This feature enables the FIB module to generate SNMP notifications for critical FIB events. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for FIB events.
[Sysname] undo snmp-agent trap enable fib
