- 13-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-NTP commands
- 05-iFIT commands
- 06-SNMP commands
- 07-RMON commands
- 08-Event MIB commands
- 09-NETCONF commands
- 10-CWMP commands
- 11-EAA commands
- 12-Process monitoring and maintenance commands
- 13-Sampler commands
- 14-Mirroring commands
- 15-NetStream commands
- 16-IPv6 NetStream commands
- 17-sFlow commands
- 18-Fast log output commands
- 19-Performance management commands
- 20-Flow log commands
- 21-Information center commands
- 22-GOLD commands
- 23-eMDI commands
- 24-Kafka commands
- 25-SQA commands
24-Kafka commands | 61.66 KB |
Kafka commands
broker
Use broker to bind a Kafka broker to a Kafka service instance.
Use undo broker to unbind a Kafka broker from a Kafka service instance.
broker [ vpn-instance vpn-instance-name ] { host-name | ipv4-address | ipv6 ipv6-address } port port-number
undo broker [ vpn-instance vpn-instance-name ] { host-name | ipv4-address | ipv6 ipv6-address }
No Kafka broker is bound to the Kafka service instance.
Kafka service instance view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the Kafka broker is on the public network, do not specify this option.
host-name: Specifies a Kafka broker by its name, a case-insensitive string of 1 to 253 characters.
ipv4-address: Specifies a Kafka broker by its IPv4 address.
ipv6 ipv6-address: Specifies a Kafka broker by its IPv6 address.
port udp-port: Specifies the port number of the Kafka broker, in the range of 1 to 65535. For the Kafka broker to successfully receive Kafka messages generated by the device, make sure the value of this option is the same as that configured on the Kafka broker.
Application scenarios
A Kafka server acts as the recipient and storer of Kafka messages published by the device. You can use this command to specify Kafka servers.
Operating mechanism
A Kafka cluster consists of one or more Kafka servers (also called Kafka brokers).
You can execute this command multiple times to specify multiple Kafka brokers. The devices, acting as Kafka message producers, publish produced messages with specific topics to Kafka brokers in the specified format.
The device supports sending Kafka messages such as:
· Alarm and alarm clear messages for CPU usage threshold exceeding.
· Alarm and alarm clear messages for free memory dropping below threshold.
· Alarm and alarm clear messages for interface status changing from up to down.
· Alarm and alarm clear messages for expiration of basic licenses.
· Alarm and alarm clear messages for routing table entry threshold exceeding.
· Alarm and alarm clear messages for ARP table entry threshold exceeding.
· Alarm and alarm clear messages for BGP neighbor disconnections.
# Bind a Kafka broker with IP address 1.1.1.1 and port number 5145 to Kafka service instance suyan.
[Sysname] kafka-service suyan
[Sysname-kafka-service-suyan] broker 1.1.1.1 port 5145
kafka-service
format
topic
format
Use format to specify the format for messages sent to Kafka brokers.
Use undo format to restore the default.
format string
undo format
No format is specified for messages sent to Kafka brokers.
string: Specifies a format. The value for this argument can only be suyan-cloud in the current software version.
Operating mechanism
With this command configured, the device acts as a Kafka message producer and sends generated messages to the target Kafka broker in the specified format.
# Specify the format for messages sent to Kafka brokers as suyan-cloud.
[Sysname-kafka-service-suyan] format suyan-cloud
kafka-service
broker
topic
kafka-service
Use kafka-service to create a Kafka service instance and enter its view, or enter the view of an existing Kafka service instance.
Use undo kafka-service to delete a Kafka service instance.
kafka-service service-name
undo kafka-service service-name
No Kafka service instance exists.
service-name: Specify a Kafka service instance by its name, a case-insensitive string of 1 to 15 characters. The name must start with a letter.
Operating mechanism
A Kafka service instance is used to manage and configure a Kafka service. In a Kafka service instance view, you can bind Kafka brokers (servers) and configure the topics and format for messages. After the configuration, the device acts as a Kafka message producer and sends generated messages with the specified topic to the target Kafka brokers in the specified format.
You can execute this command multiple times to create multiple Kafka service instances for configuring different parameters and bind different Kafka brokers. In the current software version, only one Kafka service instance can be configured on the device.
# Create Kafka service instance suyan and enter its view.
broker
format
topic
topic
Use topic to configure a Kafka topic.
Use undo topic to delete a Kafka topic.
topic module topic-name
undo topic module
No Kafka topic is configured.
module: Specifies a service module that supports sending Kafka messages. The value for this argument can only be alarm in the current software version.
topic-name: Specifies a topic used by the service module to send messages to Kafka brokers, a case-insensitive string of 1 to 249 characters. The name can contain letters, digits, hyphens (-), and underscores (_), and cannot be empty.
Topics are an essential part of Kafka messages. You can use topics to classify the messages generated by the device as needed for management of the messages.
Operating mechanism
With this command configured, the device acts as a Kafka message producer, automatically adds the corresponding topics to the messages generated by the specified service modules, and then sends them to the Kafka brokers.
If you execute this command multiple times for the same module, the most recent configuration takes effect. Only the alarm module is supported in the current software version.
# Configure the Kafka topic for the alarm module as suyan-alarm.
[Sysname-kafka-service-suyan] topic alarm suyan-alarm
kafka-service
broker
format
