13-Network Management and Monitoring Command Reference
HomeSupportNFVH3C VSRReference GuidesCommand ReferencesH3C VSR Series Virtual Services Routers Command References(V7)-R1362-6W10113-Network Management and Monitoring Command Reference
14-Mirroring commands
14-Mirroring commands 77.98 KB
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local }
group-id: Specifies a mirroring group by its ID. The value range for this argument is 1 to 128.
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Keep-link-header: Yes
    Mirroring port:
        GigabitEthernet1/0  Inbound
    Monitor port: GigabitEthernet2/0
Mirroring group
ID of the mirroring group.
Type of the mirroring group:
·     Local.
Status
Status of the mirroring group:
·     Active—The mirroring group has taken effect.
·     Incomplete—The mirroring group configuration is not complete and does not take effect.
Keep-link-header
Whether to keep the source and destination MAC addresses unchanged in mirrored packets when the packets are being transmitted:
·     Yes.
·     No.
Mirroring port
Source port.
Monitor port
Destination port.
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id local [ keep-link-header ]
undo mirroring-group { group-id | all | local [ keep-link-header ] }
No mirroring groups exist.
group-id: Specifies a mirroring group ID.The value range for this argument is 1 to 128.
keep-link-header: Keeps the source and destination MAC addresses unchanged in mirrored packets. If you do not specify this keyword, the source and destination MAC addresses in mirrored packets will change when the mirrored packets are being transmitted.
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
# Create local mirroring group 2 and keep the source and destination MAC addresses unchanged in mirrored packets when the mirrored packets are being transmitted. .
[Sysname] mirroring-group 2 local keep-link-header
mirroring-group mirroring-port (interface view)
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
A source port cannot be used as a monitor port.
# Create local mirroring group 1 to monitor the bidirectional traffic of port GigabitEthernet 1/0.
[Sysname] interface gigabitethernet 1/0
[Sysname-GigabitEthernet1/0] mirroring-group 1 mirroring-port both
mirroring-group
mirroring-group mirroring-port (system view)
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
A port can act as a source port for only one mirroring group.
# Create local mirroring group 1 to monitor the bidirectional traffic of GigabitEthernet 1/0.
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 1/0 both
mirroring-group
mirroring-group monitor-port (interface view)
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
# Create local mirroring group 1 and configure GigabitEthernet 1/0 as its monitor port.
[Sysname-GigabitEthernet1/0] mirroring-group 1 monitor-port
mirroring-group
mirroring-group monitor-port (system view)
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
Do not enable the spanning tree feature on the monitor port of a mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port gigabitethernet 1/0
mirroring-group
Flow mirroring commands
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
No mirroring actions exist to mirror traffic to interfaces.
Traffic behavior view
You can mirror traffic to only one interface. If you execute this command for a traffic behavior multiple times, the most recent configuration takes effect.
# Create traffic behavior 1 and configure the action of mirroring traffic to GigabitEthernet 1/0 for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0
