| 03-Appendix A Technical specifications, LEDs, and ports | 335.86 KB |
Table 1 Technical specifications
Item |
Specification |
Dimensions (H × W × D) |
84 × 260 × 260 mm (3.31 × 10.24 × 10.24 in) |
Weight |
2.05 kg (4.52 lb) |
System power consumption |
31 W |
Antenna |
External intelligent directional antenna system |
Compliant standards |
IEEE802.11a/b/g/n/ac/ax/be |
LEDs
LED descriptions
For information about the operating modes supported by the AP, see the release notes.
The AP has one LED. This section describes the LED status for the AP. The LED color and status indicate the AP operating status.
LED descriptions before a version change
For information about the LED descriptions for the AP in versions earlier than 2615, see Table 2, Table 3, and Table 4.
Table 2 LED description (fit mode)
LED color |
Status |
N/A |
Off |
No power is present or the LED has been turned off from the CLI. |
Yellow |
Steady on |
The AP is initializing, or an initialization exception has occurred. |
Flashing twice per second |
The Ethernet ports are down and no mesh links are established. |
Green |
Steady on |
The AP has started up and registered with an AC, but is in standby state (does not have any associated clients). |
Flashing once every two seconds |
The AP has started up, but has not registered to any AC. |
The AP is upgrading the image. |
Blue |
Flashing once per second |
The radios have associated clients and the number of associated clients is less than the threshold. |
Alternating between green and blue |
Flashing (once per second) |
The number of associated clients has exceeded the threshold. |
Table 3 LED description (cloud mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
The AP is in standby state, has connected to Cloudnet, but does not have any associated clients. |
The AP has connected to Cloudnet and has associated clients. The number of associated clients is less than the threshold |
Blue |
Steady on |
The AP is in standby state, has not connected to Cloudnet, and does not have any associated clients. |
The AP has not connected to Cloudnet, but the radios have associated clients. The number of associated clients is less than the threshold. |
Table 4 LED description (anchor AC mode)
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
The AP has started up and is in standby state, but does not have any associated clients. |
Blue |
LED descriptions after a version change
For information about the LED descriptions for the AP in 2615 and later versions, see Table 5.
LED color |
Status |
N/A |
Off |
Yellow |
Steady on |
Green |
Steady on |
The AP is in standby state (does not have any associated clients). |
The AP has started up in fit mode, but has not registered to any AC. |
Flashing one per second |
Blue |
LED description for the reset button
Table 6 LED description for the reset button
Reset button |
Press and hold duration (seconds) |
LED color |
LED status |
RESET |
0 to 5 |
Green |
Steady on |
Reset the AP. |
5 to 20 |
Green |
Restore to the factory defaults. |
20 to 30 |
Yellow |
The AP is operating in fit mode. |
The AP is operating in anchor AC mode. |
Flashing four times per second |
The AP is operating in cloud mode. |
> 30 |
Yellow |
Green |
The AP is switching from fit mode to cloud mode. Note: After you release the button, if the AP has switched from fit mode to cloud mode, it will restart for the new mode to take effect. |
Ports
The AP has the following ports:
· One 2.5GE/PoE++ port.
· One 10GE/P++SFP port.
· One GE/PSE port.
· One console port.
· One USB port.
NOTE: The AP also has a reset button. |
Figure 1 Ports
(1) USB port |
(2) Reset button |
(3) Console port |
(4) GE/PSE port |
(5) 2.5GE/PoE++ port |
(6) 10GE/P++SFP port |
Table 7 Port description
Port type |
Compliant standards and protocols |
2.5GE/PoE++ |
· IEEE802.3 · IEEE802.3u · IEEE802.3bt · IEEE802.3at · IEEE802.3af |
100M/1000M/2.5G copper Ethernet port, used for connecting the AP to an uplink device for Internet or MAN access. It can also act as a standard PoE port. When the AP operates in fit AP mode, the port is represented by interface number SGE1/0/1 in the MAP file and Smartrate-Ethernet 1 for configuration on the AC. |
10GE/P++SFP |
· IEEE802.3 · SFP MSA · SFF-8427 |
1000M/2.5G/5G/10G hybrid copper-fiber port When the AP operates in fit AP mode, the port is represented by interface number XGE1/0/1 in the MAP file and ten-gigabitethernet 1 for configuration on the AC. |
GE/PSE |
· IEEE802.3 · IEEE802.3u |
100M/1000M copper Ethernet port, used for connecting a downlink device. The AP can supply power through this port to a standard PD with a maximum power consumption of 15 W. When the AP operates in fit AP mode, the port is represented by interface number GE1/0/1 in the MAP file and gigabitethernet 1 for configuration on the AC. |
CONSOLE |
RS/EIA-232 |
Used by technical personnel only for device configuration and management. |
USB port |
USB2.0 |
Used for data read/write or supplying power. |
Reset button |
N/A |
For more information, see "LED description for the reset button." |
Optional transceiver modules
Common transceiver modules
Transceiver module, fiber connector, and fiber view
You must use an SFP transceiver module and optical fiber with an LC connector to connect the fiber port on the AP.
Figure 2 SFP transceiver module
Figure 3 Optical fibers with LC connectors
(1) LC connector |
(2) Optical fiber |
A transceiver module that has MM in its name supports multi-mode optical fibers. A transceiver module that has SM in its name supports single-mode optical fibers.
Table 8 SFP-GE-SX-MM850-A transceiver module specifications
Item |
SFP-GE-SX-MM850-A |
Central wavelength |
850 nm |
Max transmission distance |
550 m (1804.46 ft) |
Data rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
MMF |
Fiber diameter |
50 μm |
Output power |
–9.5 to 0 dBm |
Receiving sensitivity |
≤ –17 dBm |
Light saturation |
≤ –3 dBm |
Table 9 SFP-GE-LX-SM1310-A transceiver module specifications
Item |
SFP-GE-LX-SM1310-A |
1310 nm |
10 km (6.21 miles) |
Data rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 μm |
Output power |
–9.5 to –3 dBm |
≤ –20 dBm |
Light saturation |
≤ –3 dBm |
Table 10 SFP-GE-LH40-SM1310 transceiver module specifications
Item |
SFP-GE-LH40-SM1310 |
1310 nm |
40 km (24.86 miles) |
Data rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 μm |
Output power |
–2 to +5 dBm |
≤ –22 dBm |
Light saturation |
≤ –3 dBm |
Table 11 SFP-GE-LH40-SM1550 transceiver module specifications
Item |
SFP-GE-LH40-SM1550 |
1550 nm |
Data rate |
1250 Mbps |
Connector type |
Duplex LC |
Fiber mode |
SMF |
Fiber diameter |
9 μm |
Output power |
–4 to +1 dBm |
≤ –21 dBm |
Light saturation |
≤ –3 dBm |
Hybrid copper-fiber transceiver module
Hybrid copper-fiber transceiver module and hybrid copper-fiber connector
Hybrid copper-fiber transceiver modules support both optical and electrical transmission and PoE power supply. Insert hybrid copper-fiber transceiver modules only into the hybrid copper-fiber ports. To connect the hybrid copper-fiber ports, use hybrid copper-fiber cables with hybrid copper-fiber connectors.
Figure 1 Hybrid copper-fiber transceiver module
Figure 2 Hybrid copper-fiber cable with a hybrid copper-fiber connector
(1) Hybrid copper-fiber connector |
(2) Hybrid copper-fiber cable |
Table 12 H3C-LS5M1SFPPOE-SFP GE hybrid copper-fiber transceiver module specifications
Item |
H3C-LS5M1SFPPOE-SFP |
1310 nm |
Data rate |
1.25 Gbps |
Connector type |
LC |
Max power consumption |
1.0 W |
Operating temperature range |
–40°C to +85°C (–40°F to +185°F) |
Output optical power |
–9 to –1 dBm |
Table 13 H3C-LS5M1SFPPOEA-SFP 10GE multirate hybrid copper-fiber transceiver module specifications
Item |
H3C--LS5M1SFPPOEA-SFP |
1310 nm |
1.4 km (0.87 miles) |
Data rate |
10.3125 Gbps |
Connector type |
LC |
1.2 W |
–8.2 to +0.5 dBm |
