H3C WA7320XE Access Point Installation Guide-5W100
HomeSupportWirelessWA7300 Series Access PointsTechnical DocumentsInstall & UpgradeInstallation GuidesH3C WA7320XE Access Point Installation Guide-5W100
01-Installing the AP
01-Installing the AP 3.42 MB
1 Preparing for installation· 1-1
Site preparation· 1-1
Installation site selection· 1-1
Temperature and humidity· 1-1
Power supply· 1-1
Earth grounding and lightning protection· 1-2
Installation accessories· 1-3
Installation tools· 1-3
2 Installing the AP (fiber reinforced plastic antennas) 2-1
Pre-installation tasks and precautions· 2-1
Installation flowchart 2-2
Installing the AP by using installation kit 1· 2-3
Mounting the AP on a vertical pole· 2-3
Mounting the AP on a horizontal pole· 2-5
Mounting the AP on a wall 2-8
Installing the AP by using installation kit 2· 2-11
Mounting the AP on a vertical pole· 2-11
Mounting the AP on a horizontal pole· 2-13
Mounting the AP on a wall 2-16
3 Installing the AP (patch antennas) 3-19
Installing the AP by using installation kit 1· 3-19
Mounting the AP on a vertical pole· 3-19
Mounting the AP on a horizontal pole· 3-21
Mounting the AP on a wall 3-24
Installing the AP by using installation kit 2· 3-26
Mounting the AP on a vertical pole· 3-26
Mounting the AP on a horizontal pole· 3-28
Mounting the AP on a wall 3-31
4 Connecting cables· 4-1
Connecting the grounding cable· 4-1
Connecting an Ethernet cable· 4-2
Connecting a fiber cable· 4-3
Connecting a hybrid copper-fiber cable· 4-5
Installing fiber reinforced plastic antennas· 4-7
Installing patch antennas· 4-8
5 Connecting the power cord· 5-1
Powering the AP through PoE· 5-1
Powering the AP by using a hybrid copper-fiber cable· 5-1
Powering the AP by using a power injector 5-2
6 Labeling cables· 6-1
7 Verifying the installation· 7-1
8 Powering on the AP·· 8-1
9 Verifying the network connection· 9-1
CAUTION
CAUTION:
Please install the AP under the guidance of professional engineers and read this chapter before installation.
Site preparation
Before installing the AP, examine the installation site to ensure it will operate in a favorable environment. Check the installation conditions from the following aspects.
Install Outdoor APs primarily in outdoor locations such as residential areas, squares, parking lots, or rooftops. The installation site selection must meet the following requirements:
1.     When designing engineering projects, choose a location that meets the engineering environment design requirements for communication devices, taking into account factors such as climate, hydrology, geology, earthquakes, electricity, and transportation, based on the communication network plan and technical requirements of communication devices.
2.     Avoid installing the AP in environments that are damp, hot, dusty, have excessive harmful gases, are prone to electromagnetic interference (such as large radar stations, broadcasting stations, substations), have unstable voltage, are subject to strong vibrations, or have high noise levels.
3.     Do not install the AP in areas prone to water accumulation, seepage, dripping, or condensation.
4.     Do not store flammable or explosive materials near the AP installation site.
Make sure the temperature and humidity at the installation site meet the following requirements:
Table1-1 Operating temperature and humidity specifications
Item
Value range
–40°C to +65°C (–40°F to +149°F)
Storage temperature
–40°C to +85°C (–40°F to +185°F)
Operating humidity
0% RH to 100% RH, noncondensing
Storage humidity
IP rating
IP68
Power supply
The AP supports power supply through PoE, hybrid copper-fiber cable, and power injector. For specific connection methods, see "Connecting cables."
The power injector is not included and must be purchased separately. As a best practice, purchase an H3C power injector.
When installing an outdoor AP, grounding is essential. Ensure separate and secure grounding points for the AP's protective ground, lightning arresters, power PE protective ground, and antenna supports. Prevent any loosening and apply anti-oxidation treatment, such as rust-proof paint, silver powder, or grease.
Table1-2 Earth ground and lightning protection inspection checklist
Serial Number
Item
Requirements
1
Earth ground resistance
·     The grounding resistance should be less than 5 ohms; for regions with fewer than 20 thunderstorm days per year, the grounding resistance can be less than 10 ohms. For angle steel driven into the ground, you can relax the ground resistance requirement to less than 10 ohms. If the soil has high resistivity in the place, pour some salt water or resistance reducing agent to reduce the resistivity of the earth.
·     The upper end of the earth ground should be at least 0.7m above the ground, and in cold regions, the earth ground should be installed below the frost layer.
2
AP protection earth ground
·     When installing the AP in an environment with a grounding bar, use the provided yellow-green dual-color protective grounding cable to directly connect the AP's grounding screw to the grounding bar. If you need to make a protective grounding cable on-site due to length issues, ensure the cross-sectional area of the cable is no less than 3.3mm² and try to keep the length under 3 meters.
·     When there is no grounding bar in the AP's installation environment, you can use an angle iron or steel pipe no shorter than 0.5m, directly driven into the ground. Use angle steel that is at least 50mm x 50mm x 5mm and steel pipes with a wall thickness of at least 3.5mm, made of galvanized steel. Connect the protective earth ground cable to the angle steel using electric welding, and apply anticorrosion treatment to the weld points. The sectional area of the grounding cable must be no smaller than 3.3mm2. Make sure the cable is as short as possible, and do not twist the cable.
·     Ensure that the grounding screws of all surge protectors connected to the AP and its peer devices are reliably grounded.
3
Earth ground lead
The grounding lead is a metal conductor connecting the grounding grid to the grounding bar. Protective grounding wires of device should all be connected to the grounding bar. The length of the earth ground lead should not exceed 30 meters. Use galvanized flat steel with a cross-sectional area of 40mm×4mm or 50mm×5mm for the material. Connect the device grounding bar and the ground lead-in wire with a 35mm² yellow-green bicolor protective grounding cable, or directly weld them together. Treat the welding points with anticorrosion measures.
4
Power Earth Ground (AC)
·     Use a power cord (PWR) with a PE end and do not modify it to a two-wire cord with only L and N.
·     Do not connect the power cord (PWR) N line to the protective ground of other communication devices, and do not reverse the L and N lines.
5
Lightning Rod
·     Lightning rods need to have good electrical performance and share a common earth ground with the protective grounding of the equipment room.
·     Ensure that the lightning rod is tall enough to protect the AP and antennas on the iron tower or pole.
·     In flat areas, set the lightning rod's protection angle to less than 45°. In mountainous and lightning-prone areas, set it to less than 30°.
6
Ethernet cable
·     When installing the device outdoors, use shielded network cables as much as possible and ensure that devices connected at both ends are reliably earth grounded.
·     If you use metal pipes for cable runs, also earth ground both ends of the pipes.
Installation tools
When installing the AP, you may need to use the tools listed in the table below. This list is for reference only; please select based on the actual situation.
As a wireless device, the reasonableness of the installation directly affects the coverage of the wireless signal. Therefore, installation requirements are high and it is recommended that professionals complete the implementation.
Before installing the AP, perform the following tasks:
1.     Before permanently mounting the AP, power it and connect it to Ethernet to check the status of the power and Ethernet lights. Ensure the AP is functioning properly. For the status of the LED, see "Appendix A."
2.     Verify that the cabling at the installation site has been completed.
3.     Record the MAC address and serial number at the rear of the AP for future use.
Before installing the AP, please read the following precautions:
1.     The outdoor AP is heavier and larger in volume. Ensure safety during installation to avoid harm to people and AP.
2.     The outdoor AP must be securely installed on a pole or bracket, ensuring both are vertical. The metal materials require anti-oxidation treatment, such as applying anti-rust paint. Additionally, the installation height and location of the AP must comply with the design plan specifications.
3.     When installing an outdoor AP on the rooftop pole, do not install it hanging outward.
4.     When installing an outdoor AP on the rooftop, select a location with minimal or no direct sunlight exposure to prevent the AP from overheating due to prolonged sun exposure. If necessary, take appropriate protective measures.
Before connecting the all-in-one cable, please read the following precautions:
1.     Lay the all-in-one cable according to the design plan, ensuring a secure and aesthetically pleasing cable run without any crossing, twisting, or cracking.
2.     Do not run wiring together with high-voltage power lines, fire protection pipes, or building lightning rods to ensure no interference from strong electric or magnetic fields.
3.     Use PVC pipes, metal pipes, flexible conduits, or cable trays for cable runs. Install conduit and trunking along the walls, ensuring a neat and aesthetic arrangement. Use flexible tubing or elbow connectors at bends. Securely fix with cable ties, suspension rods, angle iron, etc., at a constant spacing of 1 to 1.5 m (3.28 to 4.92 ft). If using metal cable run conduits, earth ground both ends of the conduit.
4.     As a best practice to avoid water accumulation, cut an opening at the bottom of the PVC pipes every 6 m (19.69 ft) if you route cables by using PVC pipes.
5.     Seal the cable wall penetration with waterproof and flame-retardant materials.
The AP supports several installation methods. Please choose the appropriate method based on your application scenario. Follow the installation process shown in Figure2-1 to complete the AP installation.
Figure2-1 Installation flowchart
Attaching bracket 1 to the AP
·     When installing bracket 1 on the AP, make sure the arrow on bracket 1 faces upwards.
·     The procedure for attaching bracket 1 to the AP is the same for mounting the AP on a vertical pole and a wall.
Align bracket 1 with the screw holes on the rear of the AP, and then use M5 × 12 screws to attach bracket 1 to the AP.
Figure2-2 Vertical pole mounting
Attaching bracket 2 to the pole
The optional band clamps support poles with a diameter of 60 to 80 mm (2.36 to 3.15 in). If the diameter of the pole is not in the range, prepare band clamps yourself.
To attach bracket 2 to the pole:
1.     As shown in Figure2-3, slide the two band clamps through the mounting slots on bracket 2. Then, use the band clamps to attach bracket 2 to the vertical pole and fasten the screws.
Figure2-3 Attaching bracket 2 to the vertical pole
2.     Use M5 × 20 screws to secure bracket 1 attached to the AP to bracket 2.
Figure2-4 Attaching the AP to bracket 2
Adjusting the AP angle
The AP supports horizontal adjustment with a maximum adjustment angle of 60 degrees.
To adjust the AP angle:
1.     Use M5 × 20 screws to secure bracket 1 attached to the AP to bracket 2. Do not fully fasten the screws so that you can adjust the AP angle.
2.     Adjust the AP to the desired azimuth angle, and then fasten the M5 × 20 screws to fully secure bracket 1 attached to the AP to bracket 2.
Figure2-5 Adjusting the AP angle
When you attach bracket 1 to the AP, make sure the arrow on bracket 1 faces upwards.
Figure2-6 Attaching bracket 1 to the AP
1.     As shown in Figure2-7, slide the two band clamps through the mounting slots on bracket 2. Then, use the band clamps to attach bracket 2 to the horizontal pole and fasten the screws.
Figure2-7 Attaching bracket 2 to the horizontal pole
2.     Use M5 × 20 screws to secure the AP to bracket 2.
Figure2-8 Attaching the AP to bracket 2
Figure2-9 Adjusting the AP angle
No expansion bolts are provided with the AP. Purchase them yourself as required.
See "Attaching bracket 1 to the AP."
Attaching bracket 2 to the wall
1.     Use bracket 2 to mark four installation holes on the wall, as shown in Figure2-10.
Figure2-10 Marking the installation holes
2.     Drill four holes with a diameter of 8 mm (0.32 in) at the marked locations. Use a rubber hammer to tap an expansion bolt into each hole, fasten the nut on each expansion bolt to expand the expansion sleeve, and then remove the nut and washers.
¡     Keep the drill bit perpendicular to the wall and hold the drill handle tightly with both hands when you drill holes.
¡     In a sturdy and smooth wall, use a punch to create a hole to help locate the drill bit.
¡     The depths of four holes must be the same.
¡     Do not tap the expansion bolts all the way in, leaving a certain space for hanging the AP.
Figure2-11 Installing an expansion bolt in the wall
3.     Align the installation holes on bracket 2 with the bolts on the wall, and then fasten the nuts and washers on the expansion bolts to secure bracket 2 to the wall.
Figure2-12 Attaching bracket 2 to the wall
4.     Use M5 × 20 screws to secure bracket 1 attached to the AP to bracket 2.
Figure2-13 Attaching the AP to bracket 2
You can adjust the AP angle as required. For more information, see "Adjusting the AP angle."
·     When you attach bracket 1 to the AP, make sure the arrow on bracket 1 faces upwards.
Align bracket 1 with the screw holes on the rear of the AP, and then use M5 × 18 screws to attach bracket 1 to the AP.
Figure2-14 Attaching bracket 1 to the AP
The optional band clamps support poles with a diameter of 51 to 127 mm (2.01 to 5.00 in). If the diameter of the pole is not in the range, prepare band clamps yourself.
1.     As shown in Figure2-15, slide the two band clamps through the mounting slots on bracket 2. Then, use the band clamps to attach bracket 2 to the vertical pole and fasten the screws.
Figure2-15 Attaching bracket 2 to the vertical pole
2.     Use M5 × 18 screws to secure bracket 1 attached to the AP to bracket 2.
Figure2-16 Attaching the AP to bracket 2
The adjustable angle of each arc-shaped fixing hole is 30 degrees, and the maximum adjustable angle supported by the installation kit is 120 degrees.
1.     Use M5 × 18 screws to secure bracket 1 attached to the AP to bracket 2. Do not fully fasten the screws so that you can adjust the AP angle.
2.     Adjust the AP to the desired azimuth angle, and then fasten the M5 × 18 screws to fully secure bracket 1 attached to the AP to bracket 2.
Figure2-17 Adjusting the AP angle
Figure2-18 Attaching bracket 1 to the AP
1.     As shown in Figure2-19, slide the two band clamps through the mounting slots on bracket 2. Then, use the band clamps to attach bracket 2 to the horizontal pole and fasten the screws.
Figure2-19 Attaching bracket 2 to the horizontal pole
2.     Use M5 × 18 screws to secure the AP to bracket 2.
Figure2-20 Attaching the AP to bracket 2
Figure2-21 Adjusting the AP angle
1.     Use bracket 2 to mark four installation holes on the wall, as shown in Figure2-22.
Figure2-22 Marking the installation holes
Figure2-23 Installing an expansion bolt in the wall
Figure2-24 Attaching bracket 2 to the wall
4.     Use M5 × 18 screws to secure bracket 1 attached to the AP to bracket 2.
Figure2-25 Attaching the AP to bracket 2
·     For information about pre-installation tasks and precautions, see "Pre-installation tasks and precautions."
·     For information about the installation flowchart, see "Installation flowchart."
·     As a wireless device, the reasonableness of the installation directly affects the coverage of the wireless signal. Therefore, installation requirements are high and it is recommended that professionals complete the implementation.
·     When installing bracket 1 on the AP, make sure the arrow on the AP bracket faces upwards.
Figure3-1 Vertical pole mounting
1.     As shown in Figure3-2, slide the two band clamps through the mounting slots on bracket 2. Then, use the band clamps to attach bracket 2 to the vertical pole and fasten the screws.
Figure3-2 Attaching bracket 2 to the vertical pole
Figure3-3 Attaching the AP to bracket 2
Figure3-4 Adjusting the AP angle
Figure3-5 Attaching bracket 1 to the AP
1.     As shown in Figure3-6, slide the two band clamps through the mounting slots on bracket 2. Then, use the band clamps to attach bracket 2 to the horizontal pole and fasten the screws.
Figure3-6 Attaching bracket 2 to the horizontal pole
Figure3-7 Attaching the AP to bracket 2
Figure3-8 Adjusting the AP angle
1.     Use bracket 2 to mark four installation holes on the wall, as shown in Figure3-9.
Figure3-9 Marking the installation holes
Figure3-10 Installing an expansion bolt in the wall
Figure3-11 Attaching bracket 2 to the wall
Figure3-12 Attaching the AP to bracket 2
Figure3-13 Attaching bracket 1 to the AP
1.     As shown in Figure3-14, slide the two band clamps through the mounting slots on bracket 2. Then, use the band clamps to attach bracket 2 to the vertical pole and fasten the screws.
Figure3-14 Attaching bracket 2 to the vertical pole
Figure3-15 Attaching the AP to bracket 2
Figure3-16 Adjusting the AP angle
Figure3-17 Attaching bracket 1 to the AP
1.     As shown in Figure3-18, slide the two band clamps through the mounting slots on bracket 2. Then, use the band clamps to attach bracket 2 to the horizontal pole and fasten the screws.
Figure3-18 Attaching bracket 2 to the horizontal pole
Figure3-19 Attaching the AP to bracket 2
1.     Use four M5 × 18 screws to secure bracket 1 attached to the AP to bracket 2. Do not fully fasten the screws so that you can adjust the AP angle.
Figure3-20 Adjusting the AP angle
Figure3-21 Marking the installation holes
Figure3-22 Installing an expansion bolt in the wall
Figure3-23 Attaching bracket 2 to the wall
Figure3-24 Attaching the AP to bracket 2
4 Connecting cables
·     Make sure the adhesive side of the weatherproof tape is applied over the existing tape.
·     Stretch the tape until its length is twice the original length.
·     Start wrapping at the top of the connector, and overlap the tape to half-width. Avoid creases or wrinkles and press the tape against the connection so that there are no gaps. Smooth each wrapped layer with your hands to ensure full adhesion.
·     After you finish wrapping the tape, tightly bind cable ties at both ends of the weatherproof tape and liquid-tight adapter to prevent the tape from aging and falling off.
·     To prevent AP damage, attach weatherproof caps tightly to connectors that are not in use.
·     As a best practice to avoid water accumulation, cut an opening at the bottom of the PVC pipes every 6 m (19.69 ft) if you route cables by using PVC pipes.
·     Correctly connecting grounding cable is crucial to lightning protection and EMI protection.
·     Before you connect the AP to the power source, make sure the grounding cable is correctly connected.
No grounding cable is provided with the AP. Purchase one yourself as required.
To connect the grounding cable:
1.     Make a grounding cable.
Figure4-1 Grounding cable
2.     Connect the ring terminal-end of the grounding cable to the grounding screw on the AP, and the other end to the ground.
Figure4-2 Connection the grounding cable
Use Category-5e or above Ethernet cables only. As a best practice, use shielded twisted pair (STP) cables.
1.     Disassemble the weatherproof connector and sealing nut, and then feed the cable through the connector.
2.     Attach the split sealing washer to the cable, connect the Ethernet cable to an Ethernet port on the AP, and then insert the sealing washer into the weatherproof connector.
3.     Use a wrench or wear nonslip gloves to fasten the sealing nut and the weatherproof connector.
Figure4-3 Connecting an Ethernet cable
4.     Start wrapping weatherproof tape from the connection point between the AP and the liquid-tight adapter. Make sure the entire liquid-tight adapter is covered. Smooth the tape edges to ensure full adhesion and use cable ties to secure the tape.
Figure4-4 Wrapping the liquid-tight adapter
5.     As a best practice to avoid water accumulation, cut an opening at the bottom of the PVC pipes every 6 m (19.69 ft) if you route cables by using PVC pipes.
WARNING
WARNING!
·     To avoid cable damage, do not pull the fiber cable with excessive force.
·     To avoid affecting fiber performance, make sure the fiber cable is not bended or folded before you fasten the weatherproof connector.
IMPORTANT
IMPORTANT:
·     Before you connect a fiber cable, remove the dust caps from the fiber connectors.
·     To use a fiber pigtail that does not have any protective sleeve, first use weatherproof tape to wrap the fiber pigtail before you connect the fiber pigtail.
To connect a fiber cable:
1.     Use weatherproof tape to start wrapping below the fiber connector. Build up the fiber cable diameter near the opening in the split sealing washer. Smooth the tape edges to ensure full adhesion.
Figure4-5 Wrapping the fiber cable
2.     Disassemble the weatherproof connector and sealing nut, feed the cable through the connector, and then attach the split sealing washer to the cable.
Figure4-6 Feeding the cable through the weatherproof connector
3.     Insert the sealing washer into the weatherproof connector.
Figure4-7 Inserting the sealing washer into the weatherproof connector
4.     Install a transceiver module on the P++SFP port of the AP, and then insert the fiber cable into the transceiver module.
Figure4-8 Connecting a fiber cable
5.     Adjust the weatherproof connector to ensure that the fiber is not bended or folded, and then fasten the weatherproof connector.
Figure4-9 Fastening the weatherproof connector
6.     Fasten the sealing nut.
Figure4-10 Fastening the sealing nut
7.     Start wrapping weatherproof tape from the connection point between the AP and the liquid-tight adapter. Make sure the entire liquid-tight adapter is covered. Smooth the tape edges to ensure full adhesion and use cable ties to secure the tape.
Figure4-11 Wrapping the liquid-tight adapter
Before you connect a hybrid copper-fiber cable, remove the dust caps from the fiber connectors.
IMPORTANT
IMPORTANT:
·     To avoid cable damage, do not pull the hybrid copper-fiber cable with excessive force.
·     To avoid affecting fiber performance, make sure the hybrid copper-fiber cable is not bended or folded before you fasten the weatherproof connector.
To connect a hybrid copper-fiber cable:
1.     Use weatherproof tape to start wrapping below the connector. Build up the cable diameter near the opening in the split sealing washer. Smooth the tape edges to ensure full adhesion.
Figure4-12 Wrapping the hybrid copper-fiber cable
Figure4-13 Feeding the cable through the weatherproof connector
Figure4-14 Inserting the sealing washer into the weatherproof connector
4.     Install a hybrid copper-fiber transceiver module on the P++SFP port of the AP, and then insert the hybrid copper-fiber cable into the hybrid copper-fiber transceiver module.
Figure4-15 Connecting a hybrid copper-fiber cable
5.     Adjust the weatherproof connector to make sure the cable is not bended or folded, and then fasten the weatherproof connector.
Figure4-16 Fastening the weatherproof connector
Figure4-17 Fastening the sealing nut
7.     Start wrapping weatherproof tape from the connection point between the AP and the extended liquid-tight adapter. Make sure the entire extended liquid-tight adapter is covered. Smooth the tape edges to ensure full adhesion and use cable ties to secure the tape.
Figure4-18 Wrapping the extended liquid-tight adapter
Fasten four antennas on the AP.
Figure4-19 Installing fiber reinforced plastic antennas on the AP
Figure4-20 shows the installed AP and patch antennas. The antenna model in the figure is ANT-256-08P-M4. For information about the pole diameter for patch antenna installation, see the antenna specifications.
Figure4-20 Installing patch antennas on the AP
IMPORTANT
IMPORTANT:
·     Only the 2.5GE port of the AP supports PoE power supply compliant with the 802.3bt standard.
·     Do not connect live wires to the AP's GE/PSE port to avoid damaging it.
As shown in Figure5-1, use an Ethernet cable to connect an Ethernet port on the PoE switch to the 2.5GE port on the AP so as to power the AP through PoE.
Figure5-1 Powering the AP through PoE
As shown in Figure5-2, an uplink port on the AP uses a hybrid copper-fiber transceiver module and a hybrid copper-fiber cable for receiving power and communication. You do not need to connect other cables.
Figure5-2 Powering the AP by using a hybrid copper-fiber cable
CAUTION
CAUTION:
·     Place the power injector stably in a well-ventilated location near the switch or access controller. The switch or access controller connected to the power injector does not need to support PoE power supply. Do not suspend the power injector in the air or place it on another device.
·     Make sure the AP is installed correctly before you power on the device.
·     The PoE1 port of the power injector corresponds to the LAN1 port, and the PoE2 port corresponds to the LAN2 port.
·     If multiple power injectors are installed in one equipment room or low voltage room, use one power strip for all these injectors and lead in the power strip from the spare air switch of the AC power distribution box.
Power the AP by using a two-port Gigabit power injector.
Using a copper cable for uplink network connection
1.     Connect the PoE1 port on the injector to the 2.5GE copper port of the AP.
2.     Connect the LAN1 port on the injector to a switch or access controller.
3.     Connect the PoE injector and the Ethernet switch or access controller to AC power sources.
Figure5-3 Powering the AP by using a power injector
Table5-1 PoE injector specifications
Item
Specification
Model
EWPAM1UPOE2
Input
100 V to 240 V @ 1.5 A
Output
55 V @ 1100 mA
Using an optical fiber for uplink network connection
1.     Use an optical fiber to connect the P++SFP port on the AP to an Ethernet switch or access controller.
2.     Connect the power input end of the power injector to an AC power source.
3.     Connect the PoE1 port on the injector to the 2.5GE copper port of the AP.
Figure5-4 Powering the AP
6 Labeling cables
·     After cable connection, attach labels to each cable as a best practice for future maintenance.
·     Attach a label to both ends of a cable and every certain distance.
·     Use cable flags or cable sleeves to label Ethernet cables. Use cable flags to label fiber cables.
·     Use waterproof labels with clear content. Attach labels to proper places where they can be seen directly.
·     When you route the cables outdoors, use transparent weatherproof tape to seal the labels to prevent them from falling off.
After the installation is complete, check the following items before you power on the AP:
·     The power source meets the power specification of the AP.
·     The AP is reliably grounded.
·     The Ethernet cables are correctly connected.
·     The cables are correctly labeled.
·     The unused ports on the AP are sealed with waterproof plugs.
Switch on the external power source and verify that the AP is operating correctly by examining the LED on the AP. For more information about the LED, see "Appendix A."
When the AP operates in fit mode, it does not require configuration. All configurations are completed on the AC. Users can view the AP status on the AC using the display wlan ap all command. If the AP status is R/M, it indicates that the AP has successfully connected to the AC.
<AC> display wlan ap all
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
Total number of connected auto APs: 0
Total number of connected common APs: 1
Total number of connected WTUs: 0
Total number of inside APs: 0
Maximum supported APs: 3072
Remaining APs: 3071
Total AP licenses: 128
Remaining AP licenses: 127
                                 AP information
 State : I = Idle,       J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,     DC = DataCheck,  R  = Run   M = Master,  B = Backup
AP name                        APID  State Model           Serial ID
ap1                             1      R/M   WA7320XE         219801A6YC8246000001
