14-Network Management and Monitoring
HomeSupportRouters5G IPRAN Access RoutersDiagnose & MaintainAlarms ReferencesH3C RA5300[RA5100-G] Routers Alarm Reference-R7752-6W10014-Network Management and Monitoring
05-HH3C-NTP-MIB
05-HH3C-NTP-MIB 140.93 KB
HH3C-NTP-MIB
About this MIB
Use this MIB to configure NTP of the device.
MIB file name
hh3c-ntp.mib
Notifications
This section contains HH3C-NTP-MIB notifications.
hh3cNTPSysStateChangeTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.1
NTP local time synchronization status changed.
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when the NTP local time synchronization status changes.
Possible reasons for change of the NTP time status from synchronized to unsynchronized include:
·     Reason 1: The specified time server is deleted.
·     Reason 2: The specified time server fails authentication.
·     Reason 3: The clock of the specified time server is not synchronized.
·     Reason 4: The specified time server is not reachable.
·     Reason 5: The stratum level of the clock source is larger than that of the local clock.
·     Reason 6: The clock source is lost.
System impact
The local time is inaccurate.
Status control
The notification cannot be disabled.
Objects
This table does not have indexes.
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.8.22.1.1.10
(hh3cNTPSysState)
Local clock status.
N/A
INTEGER
noUpdateClock(0), getfreqInfo(1), clockBySet(2), clockBySetAndNoFreq(3), clockBySyns(4), findError(5)
1.3.6.1.4.1.25506.8.22.1.1.19
(hh3cNTPServerIP)
IP address of the NTP server.
N/A
IpAddress
OCTET STRING (4)
1.3.6.1.4.1.25506.8.22.1.1.22
(hh3cNTPSysSrcVpnName)
VPN instance to which the NTP server belongs.
N/A
DisplayString
OCTET STRING(0..255)
Recommended action
To resolve the issue:
1.     Specify another time server.
2.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
1.     Execute the display this | include ntp-service authentication command in system view to identify whether the local device and time server are both configured with NTP authentication settings.
¡     If they are both configured with NTP authentication settings, make sure they use the same authentication key and the key is configured as a trust key.
¡     If NTP authentication settings are not configured, configure NTP authentication.
1.     Specify another NTP server.
1.     Execute the ping command to test whether the time server is reachable.
¡     If the time server is reachable, proceed to the next step.
¡     If the time server is not reachable, resolve the network connectivity issue or replace another time server.
1.     Execute the display ntp-service status command to view the stratum level of the local clock.
¡     If the stratum level of the clock source is larger than that of the local NTP clock, specify another clock source with a lower stratum level lower than the local clock.
¡     If the stratum level of the clock source is lower than that of the local NTP clock, proceed to the next step.
1.     Execute the display ntp-service sessions command to identify whether the clock source is lost. If the clock source is lost, specify another clock source.
hh3cNTPSysPeerChangeTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.2
Change of the NTP time server.
Informational
Warning
N/A
ON
This notification is generated when the NTP time server changes.
System impact
No negative impact on the system.
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.8.22.1.1.21 (hh3cNTPSysOldServerIP)
IP address of last NTP server.
N/A
IpAddress
Standard MIB values.
1.3.6.1.4.1.25506.8.22.1.1.23 (hh3cNTPSysOldSrcVpnName)
VPN instance to which the last NTP server belongs.
N/A
DisplayString
OCTET STRING (0..255)
1.3.6.1.4.1.25506.8.22.1.1.19 (hh3cNTPServerIP)
IP address of the current NTP server.
N/A
IpAddress
1.3.6.1.4.1.25506.8.22.1.1.22 (hh3cNTPSysSrcVpnName)
VPN instance to which the current NTP server belongs.
N/A
DisplayString
Recommended action
If the clock source is changed because another clock source is specified, no action is required.
If the clock source is changed because of a change in clock source properties, execute the display ntp-service sessions verbos command to view the clock source properties and conduct further investigation. You can see the recommended actions for the hh3cNTPSysStateChangeTrap.
hh3cNTPDynSessionLimit
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.3
The number of dynamic NTP sessions reached the threshold.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.4 (hh3cNTPDynSessionLimitResume)
ON
This notification is generated when the number of dynamic NTP sessions reaches the threshold.
System impact
New dynamic NTP sessions cannot be established.
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.8.22.1.1.24 (hh3cNTPSysMaxDynamicSessions)
Maximum number of dynamic NTP sessions.
N/A
Integer32
Integer32
(0..255)
Recommended action
Execute the ntp-service max-dynamic-sessions command to set the maximum number of dynamic sessions to a value large enough.
Basic information
OID
Event
Severity
Default status
The number of dynamic NTP sessions dropped below the threshold.
Recovery
Warning
N/A
ON
This notification is generated when the number of dynamic NTP sessions drops below the threshold.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
Integer32
Integer32
(0..255)
Recommended action
No action is required.
hh3cNTPSessionsLimit
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.5
Number of NTP sessions reached the threshold.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.6(hh3cNTPSessionLimitResume)
ON
This notification is generated when the number of NTP sessions reaches the threshold.
System impact
New NTP sessions cannot be established.
Status control
Objects
OID (object name)
Index node
Value range
hh3cNTPSysMaxSessions (1.3.6.1.4.1.25506.8.22.1.1.25)
Maximum number of NTP sessions.
N/A
Unsigned32
Unsigned32 (0..65535)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
Delete unused static NTP sessions.
Basic information
OID
Event
Severity
Default status
Number of NTP sessions fell below the threshold.
Recovery
Warning
N/A
ON
This notification is generated when the number of NTP sessions falls below the threshold.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
N/A
Unsigned32
Recommended action
hh3cNTPSynchronizationResume
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.8
The local NTP clock resumed time synchronization.
Recovery
Warning
N/A
ON
This notification is generated when the local NTP clock resumes time synchronization.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
(hh3cNTPSysState)
Local clock status.
N/A
INTEGER
(hh3cNTPServerIP)
N/A
IpAddress
OCTET STRING (4)
Recommended action
hh3cNTPSysStratumChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.9
The stratum level of the local clock changed.
Informational
Warning
N/A
ON
This notification is generated when the stratum level of the local clock changes.
System impact
The downstream NTP clock might become unsynchronized.
Status control
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.8.22.1.1.2 (hh3cNTPSysStratum)
Current stratum level of the local system clock.
N/A
Integer32
Integer32 (1..16)
1.3.6.1.4.1.25506.8.22.1.1.26 (hh3cNTPSysOldStratum)
Old stratum level of the local system clock.
N/A
Integer32
Integer32 (1..16)
Recommended action
hh3cNTPTimeOffsetThresExceed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.22.1.2.0.10
NTP clock offset reached the threshold.
Error
Major
1.3.6.1.4.1.25506.8.22.1.2.0.11(hh3cNTPTimeOffsetThresResume)
OFF
This notification is generated when the time offset between the local NTP clock and the NTP time server reaches or exceeds the threshold.
System impact
The clock precision might be affected.
Status control
ON
CLI: Use the ntp-service time-offset-threshold trap trap-threshold command.
OFF
CLI: Use the undo ntp-service time-offset-threshold command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.8.22.1.1.11 (hh3cNTPSysOffset)
NTP time offset.
N/A
OCTET STRING
OCTET STRING (1..128)
1.3.6.1.4.1.25506.8.22.1.1.27 (hh3cNTPSysTimeOffsetThres)
NTP time offset threshold.
N/A
OCTET STRING
Recommended action
1.     Execute the display ntp-service sessions verbose command to view detailed information about the NTP session.
¡     If the session meets the requirements, execute the ntp-service time-offset-threshold command to correct the alarm threshold.
¡     If the session does not meet the requirements, specify another clock source.
Basic information
OID
Event
Severity
Default status
The NTP clock offset fell below the threshold to the normal range.
Recovery
Warning
N/A
OFF
This notification is generated when the NTP clock offset falls below the threshold to the normal range.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
NTP time offset.
N/A
OCTET STRING
N/A
OCTET STRING
Recommended action
