14-Network Management and Monitoring
HomeSupportRouters5G IPRAN Access RoutersDiagnose & MaintainAlarms ReferencesH3C RA5300[RA5100-G] Routers Alarm Reference-R7752-6W10014-Network Management and Monitoring
03-HH3C-ALARM-MIB
03-HH3C-ALARM-MIB 40.84 KB
HH3C-ALARM-MIB
About this MIB
Use this MIB to implement the alarm resend feature.
MIB file name
hh3c-alarm.mib
Notifications
This section contains the HH3C-ALARM-MIB notifications.
hh3cAlarmClearedReportTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.243.2.0.1
Active alarms are cleared.
Trap alarm
Warning
N/A
ON
Notification triggers
This notification is generated when the user manually clear active alarms.
System impact
No negative impact on the system.
Status control
N/A
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.243.2.1.16 (hh3cAlarmClearedNum)
The number of cleared active alarms.
N/A
Unsigned32
Standard MIB values.
1.3.6.1.4.1.25506.2.243.2.1.17 (hh3cAlarmClearedSnList)
List of the sequence numbers of the cleared active alarms.
N/A
DisplayString (SIZE (0..1024))
Recommended action
Manually clear the alarm and then send a trap.
