15-Network Management and Monitoring
HomeSupportRouters5G IPRAN Access RoutersReference GuidesMIB CompanionH3C RA5300[RA5100-G] Routers MIB Reference-R7752-6W10015-Network Management and Monitoring
06-HH3C-SNMP-EXT-MIB
06-HH3C-SNMP-EXT-MIB 108.88 KB
HH3C-SNMP-EXT-MIB
About this MIB
This MIB adds objects to extend SNMP management.
MIB file name
hh3c-snmp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSnmpExt(104)
Scalar objects
hh3cSnmpExtMaxContextNum
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtMaxContextNum (1.3.6.1.4.1.25506.2.104.1.4)
read-only
Integer32
Integer32 (1..65535)
Maximum number of SNMP contexts supported by the system.
As per the MIB.
hh3cSnmpExtVersion
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtVersion (1.3.6.1.4.1.25506.2.104.1.5)
read-write
BITS
BITS { snmpV1(0), snmpV2c(1), snmpV3(2) }
SNMP version.
As per the MIB.
hh3cSnmpExtTrapSource
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtTrapSource (1.3.6.1.4.1.25506.2.104.1.6)
read-only
SnmpAdminString
OCTET STRING (0..255)
Interface, the SNMP agent uses the primary IP address of which as the source IP address in all its traps.
As per the MIB.
hh3cSnmpExtInformSource
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtInformSource (1.3.6.1.4.1.25506.2.104.1.7)
read-only
SnmpAdminString
OCTET STRING(1..63)
Interface, the SNMP agent uses the primary IP address of which as the source IP address in all its informs.
As per the MIB.
hh3cSnmpExtAclNum
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtAclNum
(1.3.6.1.4.1.25506.2.104.1.8)
read-write
Integer32
Integer32 (0 | 2000..3999)
Global IPv4 ACL number.
As per the MIB.
hh3cSnmpExtAclName
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtAclName
(1.3.6.1.4.1.25506.2.104.1.9)
read-write
OCTET STRING
OCTET STRING (0..63)
Global IPv4 ACL name.
As per the MIB.
hh3cSnmpExtIPv6AclNum
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.104.1.10)
read-write
Integer32
Global IPv6 ACL number.
As per the MIB.
hh3cSnmpExtIPv6AclName
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.104.1.11)
read-write
OCTET STRING
Global IPv6 ACL name.
As per the MIB.
hh3cSnmpExtTargetAddress
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtTargetAddress (1.3.6.1.4.1.25506.2.104.1.12)
accessible-for-notify
OCTET STRING
Address of the target host that receives SNMP notifications.
As per the MIB.
hh3cSnmpExtFallingThreshold
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtFallingThreshold (1.3.6.1.4.1.25506.2.104.1.13)
Integer32
Integer32(1..2147483647)
Falling threshold for the number of users in the SNMPv3 user denylist.
As per the MIB.
hh3cSnmpExtRisingThreshold
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtRisingThreshold (1.3.6.1.4.1.25506.2.104.1.14)
Integer32
Rising threshold for the number of users in the SNMPv3 user denylist.
As per the MIB.
Tabular objects
hh3cSnmpExtCommunityTable
About this table
Use this table to configure the extended properties for SNMP communities (SNMPv1 or SNMPv2c) and SNMP users (SNMPv3).
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cSnmpExtCommunitySecurityLevel and hh3cSnmpExtCommunitySecurityName.
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtCommunitySecurityLevel (1.3.6.1.4.1.25506.2.104.2.1.1.1)
not-accessible
SnmpSecurityModel
INTEGER (0..3)
Security model of a community or user.
As per the MIB.
hh3cSnmpExtCommunitySecurityName (1.3.6.1.4.1.25506.2.104.2.1.1.2)
not-accessible
SnmpAdminString
OCTET STRING (1..32)
Security name of the community or user.
As per the MIB.
hh3cSnmpExtCommunityName (1.3.6.1.4.1.25506.2.104.2.1.1.3)
read-only
OCTET STRING
Community name or username.
As per the MIB.
hh3cSnmpExtCommunityAclNum (1.3.6.1.4.1.25506.2.104.2.1.1.4)
read-write
Integer32
IPv4 ACL number used by the community or the user.
As per the MIB.
hh3cSnmpExtCommunityIPv6AclNum (1.3.6.1.4.1.25506.2.104.2.1.1.5)
read-write
Integer32
IPv6 ACL number used by the community or the user.
As per the MIB.
hh3cSnmpExtContextTable
About this table
Use this table to configure SNMP context extended properties.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cSnmpExtContextName.
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtContextName (1.3.6.1.4.1.25506.2.104.2.3.1.1)
not-accessible
SnmpAdminString
Context name.
As per the MIB.
hh3cSnmpExtContextRowStatus (1.3.6.1.4.1.25506.2.104.2.3.1.2)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Status of this entry.
Supports only action, createAndGo, and destroy.
Notifications
This section contains HH3C-SNMP-MIB notifications.
hh3cSnmpExtTargetHostDel
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.104.3.0.1
An SNMP notification target host configuration was cancelled.
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when the undo snmp-agent target-host command is executed to cancel an SNMP notification target host configuration. This notification is sent only to the canceled target host.
System impact
The device cannot send SNMP notifications to the destination host with the configuration cancelled.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
N/A
OCTET STRING
Standard MIB values.
Recommended action
No action is required.
hh3cSnmpExtLockThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.104.3.2
The number of users in the SNMPv3 user denylist exceeded the rising threshold.
Informational
Warning
hh3cSnmpExtLockThresholdResume
ON
This notification is generated when the number of users in the SNMPv3 user denylist exceeds the rising threshold (40% of the maximum number of users in the SNMPv3 user denylist).
System impact
No negative impact on the system.
Status control
ON
CLI: Use the snmp-agent trap enable command.
OFF
CLI: Use the undo snmp-agent trap enable command.
Objects
OID (object name)
Index nodes
Value range
N/A
Integer32
Recommended action
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.104.3.3
The number of users in the SNMPv3 denylist fell below the falling threshold.
Informational
Warning
N/A
ON
This notification is generated when the number of users in the SNMPv3 user denylist falls below the falling threshold (10% of the maximum number of users in the SNMPv3 user denylist).
System impact
Status control
ON
CLI: Use the snmp-agent trap enable standard command.
OFF
CLI: Use the undo snmp-agent trap enable standard command.
Objects
OID (object name)
Index nodes
Value range
N/A
Integer32
Recommended action
