- 15-Network Management and Monitoring
- 01-DISMAN-PING-MIB
- 02-DISMAN-TRACEROUTE-MIB
- 03-HH3C-ALARM-MIB
- 04-HH3C-NQA-MIB
- 05-HH3C-NTP-MIB
- 06-HH3C-SNMP-EXT-MIB
- 07-SNMP-FRAMEWORK-MIB
- 08-SNMP-MPD-MIB
- 09-SNMP-NOTIFICATION-MIB
- 10-SNMP-TARGET-MIB
- 11-SNMP-USER-BASED-SM-MIB
- 12-SNMP-VIEW-BASED-ACM-MIB
- 13-SNMPv2-MIB
03-HH3C-ALARM-MIB | 136.73 KB |
HH3C-ALARM-MIB
About this MIB
Use this MIB to implement the alarm resend feature.
MIB file name
hh3c-alarm.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2). hh3cAlarm (243)
Scalar objects
hh3cAlarmUuid
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmUuid ( 1.3.6.1.4.1.25506.2.243.1.1.1) |
read-only |
STRING |
OCTET STRING (SIZE(1..255)) |
Alarm UUID. |
The UUID is generated based on UUIDv4. |
hh3cAlarmSyncIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmSyncIndex ( 1.3.6.1.4.1.25506.2.243.2.1.1) |
accessible-for-notify |
Counter64 |
Standard MIB values. |
Resent alarm index. |
Not supported. |
hh3cAlarmDateAndTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmDateAndTime ( 1.3.6.1.4.1.25506.2.243.2.1.2) |
DateAndTime |
Time when the alarm was triggered. |
Not supported. |
hh3cAlarmActiveIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmActiveIndex ( 1.3.6.1.4.1.25506.2.243.2.1.3) |
Integer32 |
Integer32 (1..2147483647) |
Sequence number of the active alarm. |
Not supported. |
hh3cAlarmOrEventFlag
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmOrEventFlag ( 1.3.6.1.4.1.25506.2.243.2.1.4) |
Integer |
alarm (1) event (2) |
Alarm or event flag. |
Not supported. 1 indicates an alarm, and 2 indicates an event. |
hh3cAlarmSeverity
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmSeverity ( 1.3.6.1.4.1.25506.2.243.2.1.5) |
DisplayString |
DisplayString (SIZE (0..255)) |
Alarm severity. |
Not supported. |
hh3cAlarmPVFlag
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmPVFlag ( 1.3.6.1.4.1.25506.2.243.2.1.6) |
DisplayString |
Network element flag of the alarm. |
Not supported. |
hh3cAlarmSyncFlag
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmSyncFlag ( 1.3.6.1.4.1.25506.2.243.2.1.7) |
INTEGER |
realTime (1) syncResend (2) |
Sending type of the trap. |
Not supported. realTime indicates that the trap is sent in real time, and syncResend indicates that the trap is resent. |
hh3cAlarmStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmStatus ( 1.3.6.1.4.1.25506.2.243.2.1.8) |
TruthValue |
Alarm status. |
Not supported. True indicates that the alarm is active, and False indicates that the alarm has been cleared. |
hh3cAlarmObjectID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmObjectID ( 1.3.6.1.4.1.25506.2.243.2.1.9) |
DisplayString |
Name and unique identifier of the device that has the alarm. |
Not supported. Sysname of the corresponding device. |
hh3cAlarmCode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmCode ( 1.3.6.1.4.1.25506.2.243.2.1.10) |
Integer32 |
Unique ID of the alarm type. |
Not supported. |
hh3cAlarmType
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmType ( 1.3.6.1.4.1.25506.2.243.2.1.11) |
DisplayString |
Alarm type. |
Not supported. |
hh3cAlarmSource
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmSource ( 1.3.6.1.4.1.25506.2.243.2.1.12) |
DisplayString |
Alarm source. |
Not supported. |
hh3cAlarmSpecificProblem
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmSpecificProblem ( 1.3.6.1.4.1.25506.2.243.2.1.13) |
DisplayString |
DisplayString (SIZE (0..1024)) |
Detailed alarm cause. |
Not supported. |
hh3cAlarmAdditionalText
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmAdditionalText ( 1.3.6.1.4.1.25506.2.243.2.1.14) |
DisplayString |
Additional alarm information. |
Not supported. |
hh3cAlarmTargetAddress
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmTargetAddress ( 1.3.6.1.4.1.25506.2.243.2.1.15) |
SnmpAdminString |
SnmpAdminString (SIZE(1..255)) |
Target host of the alarm. |
Not supported. |
hh3cAlarmClearedNum
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmClearedNum ( 1.3.6.1.4.1.25506.2.243.2.1.16) |
Unsigned32 |
The number of cleared active alarms. |
As per the MIB. |
hh3cAlarmClearedSnList
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmClearedSnList ( 1.3.6.1.4.1.25506.2.243.2.1.17) |
List of the sequence numbers of the cleared active alarms (separated by commas). |
As per the MIB. |
Tabular objects
hh3cAlarmSyncIndexRangeTable
About this table
Use this table to obtain the value range for the resent alarm indexes.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is snmpTargetAddrName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMinAlarmSyncIndex (1.3.6.1.4.1.25506.2.243.1.2.1.1.1) |
read-only |
Counter64 |
Minimum resent alarm index. |
Not supported. |
hh3cMaxAlarmSyncIndex (1.3.6.1.4.1.25506.2.243.1.2.1.1.2) |
read-only |
Counter64 |
Maximum resent alarm index. |
Not supported. |
hh3cAlarmOperateTable
About this table
Use this table to implement the alarm resend feature.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cAlarmOperateIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAlarmOperateIndex (1.3.6.1.4.1.25506.2.243.1.2.2.1.1) |
not-accessible |
Integer32 |
Integer32 (1~2147483647) |
Alarm resend operation table index. |
Not supported. |
hh3cAlarmOperateTargetAddress (1.3.6.1.4.1.25506.2.243.1.2.2.1.2) |
read-write |
SnmpAdminString |
Target host address of the alarm. |
Not supported. |
hh3cAlarmOperateType (1.3.6.1.4.1.25506.2.243.1.2.2.1.3) |
read-write |
INTEGER |
resendSyncAlarm(1) resendActiveAlarm(2) |
Alarm resend type. |
Not supported. If the alarm resend type is resendSyncAlarm, all alarms are resent and you can specify the index range. If the alarm resend type is resendActiveAlarm, only active alarms are resent. The hh3cAlarmOperateStartSyncIdxHi, hh3cAlarmOperateStartSyncIdxLo, hh3cAlarmOperateEndSyncIdxHi, and hh3cAlarmOperateEndSyncIdxLo nodes no longer take effect. |
hh3cAlarmOperateStartSyncIdxHi (1.3.6.1.4.1.25506.2.243.1.2.2.1.4) |
read-write |
Unsigned32 |
High-order bits of the start index for the resent alarms. |
Not supported. This node and hh3cAlarmOperateStartSyncIdxLo form the start index for the resent alarms. It does not take effect when the hh3cAlarmOperateType is resendSyncAlarm. |
hh3cAlarmOperateStartSyncIdxLo (1.3.6.1.4.1.25506.2.243.1.2.2.1.5) |
read-write |
Unsigned32 |
Low-order bits of the start index for the resent alarms. |
Not supported. This node and hh3cAlarmOperateStartSyncIdxHi form the start index for the resent alarms. It does not take effect when the hh3cAlarmOperateType is resendSyncAlarm. |
hh3cAlarmOperateEndSyncIdxHi (1.3.6.1.4.1.25506.2.243.1.2.2.1.6) |
read-write |
Unsigned32 |
High-order bits of the end index for the resent alarms. |
Not supported. This node and hh3cAlarmOperateStartSyncIdxLo form the end index for the resent alarms. It does not take effect when the hh3cAlarmOperateType is resendSyncAlarm. |
hh3cAlarmOperateEndSyncIdxLo (1.3.6.1.4.1.25506.2.243.1.2.2.1.7) |
read-write |
Unsigned32 |
Low-order bits of the end index for the resent alarms. |
Not supported. This node and hh3cAlarmOperateStartSyncIdxHi form the end index for the resent alarms. It does not take effect when the hh3cAlarmOperateType is resendSyncAlarm. |
hh3cAlarmOperateRowStatus (1.3.6.1.4.1.25506.2.243.1.2.2.1.8) |
read-create |
RowStatus |
active(1) notInService(2) notReady(3) createAndGo(4) createAndWait(5) destroy(6) |
Row status. |
Not supported. Only the create operation is supported. |
Notifications
This section contains the HH3C-ALARM-MIB notifications.
hh3cAlarmClearedReportTrap
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.243.2.0.1 |
Active alarms are cleared. |
Trap alarm |
Warning |
N/A |
ON |
Notification triggers
This notification is generated when the user manually clear active alarms.
System impact
No negative impact on the system.
Status control
N/A
Objects
OID (object name) |
Index nodes |
Type |
Value range |
1.3.6.1.4.1.25506.2.243.2.1.16 (hh3cAlarmClearedNum) |
N/A |
Unsigned32 |
1.3.6.1.4.1.25506.2.243.2.1.17 (hh3cAlarmClearedSnList) |
List of the sequence numbers of the cleared active alarms. |
N/A |
Recommended action
Manually clear the alarm and then send a trap.
