| 01-H3C Router Software Upgrade Guide | 649.36 KB |
Upgrade restrictions and guidelines
Hardware-related restrictions and guidelines
Software-related restrictions and guidelines
Setting up an upgrade environment
Logging in to the router through the console port
Logging in to the router through the management Ethernet port
Verifying the running software version
Verifying the device operating status
Verifying the card or subcard status
Verifying the alarm information
Checking the storage space at the CLI
Checking the storage space from the BootWare menu
Upgrading the BootWare at the CLI on a single-MPU device (distributed devices in standalone mode)
Upgrading the BootWare at the CLI on a dual-MPU device (distributed devices in standalone mode)
Upgrading the BootWare at the CLI (distributed devices in IRF mode)
Upgrading the BootWare at the CLI (centralized devices)
Upgrading the BootWare from the BootWare menu
Upgrading the startup software
Upgrading the startup software by using the boot loader method
Upgrading the startup software from the BootWare menu
Performing a compatible upgrade by using ISSU commands (distributed devices)
Performing a compatible upgrade by using ISSU commands (centralized devices)
Performing an incompatible upgrade by using ISSU commands (distributed devices)
Performing an incompatible upgrade by using ISSU commands (centralized devices)
Installing patches and features
Installing features on a single-MPU device (distributed devices in standalone mode)
Installing features on a dual-MPU device (distributed devices in standalone mode)
Installing features (distributed devices in IRF mode/CR19000)
Installing features (centralized devices)
Verifying that the router is running the new BootWare image
Verifying that the router is running the new software images
Verifying that a patch or feature image is installed successfully
Verifying that the cards and subcards are in normal state (modular router)
Verifying that the router is in stable state
Verifying that the configuration has been recovered
Verifying that the services are normal
Rolling back the running software images
Failed to log in to the router
Failed to download software images
Failed to restart the router after an upgrade
Failed to start a card or subcard after an upgrade
Using FTP to download upgrade file
Downloading software images at the CLI
Downloading software images from the BootWare menu
Using TFTP to download software images
About software upgrade
Software types
Software types include the BootWare image and startup software images. They are required for the device to start and run and provide support, management, and other services.
BootWare image
This image contains a basic segment and an extended segment. The basic segment is the minimum code that bootstraps the system. The extended segment enables hardware initialization and provides system management menus. When the device cannot start up correctly, you can use the menus to load software and the startup configuration file or manage files.
NOTE: Typically, you do not need to upgrade the BootWare, and use the built-in BootWare of the router. |
Startup software images
Startup software image subcategories
Startup software images include the following image subcategories:
· Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
· System image—A .bin file that contains the Comware kernel and standard features, including device management, interface management, configuration management, and routing.
· Feature image—A .bin file that contains advanced or customized software features.
· Patch image—A .bin file that is released for fixing bugs without rebooting the device. A patch image does not add or remove features.
The boot image and system image are required for the device to operate and cannot be uninstalled. A feature or patch image can be uninstalled.
Software release forms
Software images are released in one of the following forms:
· Separate .bin files. You must verify compatibility between software images.
· All startup software images except patch images are released as a whole in one .ipe package file. The images in an .ipe package file are compatible. The system decompresses the file automatically, loads the .bin images and sets them as startup software images.
Main and backup startup software images
To upgrade software, you must specify the upgrade files as the startup software images for the device to load at next startup. You can specify two lists of software images: one main and one backup. The device first loads the main startup software images. If the main startup software images are not available, the device loads the backup startup software images.
Software upgrade types
Software upgrade types include BootWare upgrade, startup software upgrade, and feature and patch installation.
This document covers software upgrade procedures only for physical devices.
Unless otherwise noted, this document uses a standalone device to describe the upgrade procedures.
Before the upgrade, make sure the device is operating correctly, and make sure the LEDs of the power supply, fans, cards, and subcards are normal.
During the upgrade, do not power off the device, and do not restart or remove swappable modules.
If you store the startup software images in a hot swappable storage medium, do not remove the hot swappable storage medium during the startup process.
Read the release notes to verify the software and hardware compatibility and hardware restrictions for the device, cards, and subcards.
The command output varies by device model.
Before the upgrade:
· Use the release notes (software feature changes) to identify the differences between the new and old commands. Some functions might become unavailable due to command changes.
· Use the release notes to verify that the current software version can be upgraded to the target version.
· Back up the current software images, configuration files, and login passwords to prevent data loss if the storage medium is damaged.
· Make sure the device has sufficient storage space for the upgrade software images.
· Make sure the CPU usage of the device or a card is not high.
During the upgrade:
· Enable logging of the terminal to collect information.
· An upgrade requiring a device reboot will cause service interruption for the duration of the reboot.
· Before an upgrade operation is completed, no other upgrade operations can be performed. Upgrade operations include the install, issu, and boot-loader commands.
After the upgrade:
· The upgrade of the BootWare might cause the software version to fail to be downgraded.
· After the upgrade, do not delete the running software images.
Upgrade workflow
Figure 1 shows the upgrade workflow.
Table 1 describes each step of the upgrade workflow.
Upgrade step |
Remarks |
Prepare for the upgrade |
Describes the preparatory tasks to be performed before the upgrade (see "Preparing for the upgrade"). |
Is installing patches or features enough? |
Checks whether installing patches or features can meet requirements. To fix bugs without upgrading the software version, install a patch. To add a new feature, install a feature. |
Install patches or features |
Describes the steps to install a patch or feature (see "Installing patches and features"). |
Does BootWare need to be upgraded? |
Contact H3C Support to confirm whether the BootWare needs to be upgraded. If two software versions span many versions, the BootWare might need to be upgraded. |
Upgrade BootWare |
Describes the steps to upgrade the BootWare (see "Upgrading the BootWare"). |
Upgrade startup software |
Describes the steps to upgrade the software version (see "Upgrading the startup software"). |
Check whether the upgrade is successful |
Describes the checks to be performed after upgrade. If the upgrade fails, perform a version rollback. For more information, see "Verifying the upgrade." |
Roll back the software version |
Describes the steps to roll back the software version ("Rolling back the running software images"). |
This chapter contains the following sections:
· Setting up an upgrade environment
· Verifying the running software version
· Verifying the device operating status
Preparing tools
Prepare the following tools:
· A terminal, such as a PC or laptop.
· Network cable and console cable.
· FTP server program or TFTP server program.
· Terminal emulation program.
NOTE: The FTP server program or TFTP server program is not shipped with the router. Purpose it by yourself. |
Selecting an upgrade method
Select an appropriate upgrade method as shown in Table 2 according to your situation.
Upgrade method |
Software types |
Remarks |
Upgrading from the CLI by using the boot loader method |
· Boot image · System image · IPE package · BootWare image |
This method is disruptive. You must reboot the entire router to complete the upgrade. |
Upgrading by using install commands |
· Patch image · Feature image |
This method does not require the reboot of the router and has a small impact on services. |
Performing an ISSU from the CLI |
· Boot image · System image · IPE package |
This method is supported on an IRF fabric. This method has a small impact on services. |
Upgrading from the BootWare menu |
Use this method when the device cannot start up correctly. To use this method, you must log in to the router through the console port. |
Set up an upgrade environment as follows:
1. Use the console cable to connect the serial port on the PC and the console port on the router.
2. Use the network cable to connect the network port on the PC and the management Ethernet port on the router.
NOTE: If the router does not have a management Ethernet port, connect the network port on the PC and an Ethernet interface on the router. |
Figure 2 Setting up an upgrade environment
To upgrade software from the BootWare menu, you can log in to the router through only the console port.
To upgrade software at the CLI, you can log in to the router through either the console port or the management Ethernet port. If the device does not have a management Ethernet port, you can log in to the router through a VLAN interface or Layer 3 Ethernet interface. The procedure for configuring a VLAN interface or Layer 3 Ethernet interface for login is similar to that for configuring the management Ethernet port.
Before you log in to the device through the console port, disable login authentication on the console port as a best practice.
1. Run a terminal emulation program on the PC and configure the following parameters:
¡ Bits per second—9600.
¡ Data bits—8.
¡ Stop bits—1.
¡ Parity—None.
¡ Flow control—None.
2. Power on the router. The following information is displayed. After you press Enter, the command prompt appears (such as <Sysname>).
* Copyright (c) 2004-2022 New H3C Technologies Co.,Ltd.All rights reserved.*
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
Line aux0 is available.
Press ENTER to get started.
<Sysname>%Mar 30 09:52:58:243 2022 H3C SHELL/5/SHELL_LOGIN:TTY logged in from aux0.
<Sysname>
1. Log in to the router through the console port, enter system view, and enable the Telnet service.
2. Assign an IP address to the management Ethernet port. The IP address must be in the same network segment as the IP address of the PC.
[Sysname] interface M-GigabitEthernet 0/0/0
[Sysname-M-GigabitEthernet0/0/0] ip address 192.168.0.105 24
[Sysname-M-GigabitEthernet0/0/0] quit
3. Configure common attributes for the VTY line.
[Sysname] line vty 0 63
[Sysname-line-vty0-63] authentication-mode none
[Sysname-line-vty0-63] user-role network-admin
[Sysname-line-vty0-63] idle-timeout 0 0
[Sysname-line-vty0-63] quit
4. Open the terminal emulation program on the PC, and log in to the router through Telnet.
<Sysname>
Obtaining the upgrade file
CAUTION: Make sure the obtained upgrade file is compatible with the device model. An incompatible software version can lead to a failure in the software upgrade. |
You can obtain the upgrade file by using the following methods:
· Log in to the H3C website at https://www.h3c.com/en and navigate to Support > Resource Center > Software Download > Routers. Then, find the target router model and download its software image file.
· Contact H3C Support to obtain the upgrade file.
# View the running software version on the router and use the release notes to verify that the running software version can be upgraded to the target software version.
The command output might vary by router model. This section uses a CR16000-F router as an example.
<Sysname> display version
H3C Comware Software, Version 7.1.075, Release 8260P22
Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.
H3C CR16010H-F uptime is 0 weeks, 0 days, 0 hours, 59 minutes
Last reboot reason : USER reboot
Boot image: cfa0:/CR16000-CMW710-BOOT-R8260P22.bin
Boot image version: 7.1.075, Release 8260P22
Compiled Dec 17 2021 11:00:00
System image: cfa0:/CR16000-CMW710-SYSTEM-R8260P22.bin
System image version: 7.1.075, Release 8260P22
Feature image(s) list:
cfa0:/CR16000-CMW710-DEVKIT-R8260P22.bin, version: 7.1.075
Verifying the device status
# Verify that the system is stable. The system is stable if the System State field displays Stable.
If the system is unstable, contact H3C Support to confirm whether the upgrade can be performed.
<Sysname> display system stable state
System state : Stable
Redundancy state : No redundancy
Slot CPU Role State
0 0 Active Stable
6 0 Other Stable
6 1 Other Stable
13 0 Other Stable
# Verify that the status of a card or subcard is normal. The card or subcard is normal if the Brd Status field displays Normal.
If the status of a card or subcard is abnormal, contact H3C Support to confirm whether the card or subcard needs to be replaced, and record the status of the card or subcard.
<Sysname> display device
Slot No. Brd Type Brd Status Software Version
0 CSR05SRP1P3 Master CR16000-CMW710-R8260P22
1 NONE Absent NONE
2 NONE Absent NONE
3 NONE Absent NONE
4 CSPEX-1504X Normal CR16000-CMW710-R8260P22
5 NONE Absent NONE
6 CSPEX-1504X Normal CR16000-CMW710-R8260P22
7 NONE Absent NONE
8 NONE Absent NONE
9 NONE Absent NONE
10 NONE Absent NONE
11 NONE Absent NONE
12 NONE Absent NONE
13 CSFC-08E1 Normal CR16000-CMW710-R8260P22
14 NONE Absent NONE
Verifying the CPU usage
# Verify that the CPU usage is lower than 80%.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# Use the display alarm command to verify that no alarms are generated for the router, cards, and subcards.
If an alarm of the Error level exists, contact H3C Support to confirm whether the upgrade can be performed.
NOTE: The display alarm command is supported only some router models. On router models that do not support the display alarm command, you can use the display logbuffer command to view the alarm information in buffered logs. |
Backing up important files
Back up the current software images, configuration files, and login passwords.
This section uses backing up configuration files in the CF card as an example.
# Save the running configuration to the CF card.
<Sysname> save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
(To leave the existing filename unchanged, press the enter key):cfa0:/startup.cfg
Validating file. Please wait.........................
The current configuration is saved to the active main board successfully.
Configuration is saved to device successfully.
# Back up all files (including configuration files and log files) to the PC through FTP.
NOTE: The operation of uploading files by using FTP is similar to that of uploading files by using TFTP. This section uses FTP as an example. For the detailed uploading operation, see "Downloading the upgrade file." |
<Sysname>ftp 192.168.33.77
Trying 192.168.33.77 ...
Press CTRL+K to abort
Connected to 192.168.33.77.
220 3Com 3CDaemon FTP Server Version 2.0
User(192.168.33.77:(none)):Username1
331 User name ok, need password
Password:
230 User logged in
ftp> binary
200 Type is Image (Binary)
ftp> put startup.cfg
227 Entering Passive Mode (192,168,77,3,8,222)
150 "D:\FTP\ startup.cfg " file ready to receive in BIN mode
226 Transfer finished successfully.
FTP: 6360 byte(s) sent in 0.170 second(s), 37.00Kbyte(s)/sec.
Check the free storage space of the storage medium to which the upgrade file will be saved to verify that the router has sufficient storage for the upgrade file.
If the free storage space is not sufficient on the router, delete unused files.
If an .ipe file is used, make sure the free storage space is greater than the sum of the size of the .ipe file and the size of the .bin files decompressed. If the free storage space is insufficient, you can download only the required .bin files (including the boot image and system image).
If the storage medium can only store software images in one version, you can first delete the software images in the old version, and then directly download the .bin files in the new version (including the boot and system images).
Identifying the storage medium
# Use the display boot-loader command to identify the storage medium. The following command output shows that the storage medium is the CF card.
<Sysname> display boot-loader
Software images on slot 0:
Current software images:
Main startup software images:
Backup startup software images:
cfa0:/CR16000-CMW710-BOOT-R7751P01.bin
cfa0:/CR16000-CMW710-SYSTEM-R7751P01.bin
Verifying the free storage space
# Use the dir command to view the free storage space.
NOTE: If the dir command does not display the file information on the storage medium of startup software images by default, first use the cd command to access the storage medium of the startup software images. |
<Sysname> cd cfa0:/
<Sysname> dir
Directory of cfa0:
0 -rw- 40403968 Aug 24 2021 13:03:11 CR16000-CMW710-BOOT-R8260P22.bin
1 -rw- 40434688 Sep 27 2021 12:43:18 CR16000-CMW710-BOOT-R7751P01.bin
6 -rw- 361966592 Aug 24 2021 13:11:46 CR16000-CMW710-SYSTEM-R8260P22.bin
7 -rw- 354719744 Sep 27 2021 12:50:55 CR16000-CMW710-SYSTEM-R7751P01.bin
2044256 KB total (1773684 KB free)
Deleting unused files
· Use the delete /unreserved command to delete an unused file permanently.
<Sysname> delete /unreserved boot.bin
The file cannot be restored. Delete cfa0:/boot.bin? [Y/N]:y
Deleting the file permanently will take a long time. Please wait...
Deleting file cfa0:/boot.bin...Done.
· Use the delete command to delete an unused file.
# Delete an unused file.
<Sysname> delete boot.bin
# Clear the recycle bin.
<Sysname> reset recycle-bin
Clear cfa0:/boot.bin? [Y/N]:y
Clearing file cfa0:/boot.bin... Done
NOTE: To delete a file permanently, use the delete /unreserved command. If you use the delete command, the file is moved to the recycle bin and still occupies the storage space. To release the storage space, you must execute the reset recycle-bin command in the file's original directory. |
Identifying the storage medium from the BootWare menu
NOTE: The BootWare menu varies by router model and BootWare version. This section uses a CR16000-F router as an example. |
· Identify the storage medium from the EXTENDED-BOOTWARE menu.
a. Access the EXTENDED-BOOTWARE menu.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> Skip Current System Configuration |
|<7> BootWare Operation Menu |
|<8> Skip Authentication for Console Login |
|<9> Storage Device Operation |
|<0> Reboot |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9):
b. Enter 4 to access the file control submenu.
===============================<File CONTROL>===============================
|Note:the operating device is cfa0 |
|<1> Display All File(s) |
|<2> Set Image File type |
|<3> Set Bin File type |
|<4> Delete File |
|<5> Copy File |
|<0> Exit To Main Menu |
Enter your choice(0-5):
c. Enter 1 to display all files.
Display all file(s) in cfa0:
'M' = MAIN 'B' = BACKUP 'N/A' = NOT ASSIGNED
|1 33086464 Nov/15/2021 17:21:50 M cfa0:/CR16000-CMW710-BOOT-R8260P|
|22.bin |
|2 278083584 Nov/15/2021 17:15:07 M cfa0:/CR16000-CMW710-SYSTEM-R826|
|0P22.bin |
|3 6952 Nov/15/2021 18:36:51 N/A cfa0:/info/info_5_3.bin |
|<4> Delete File |
|<5> Copy File |
d. Enter 0 to exit the file control submenu.
The image file of the M type shows that the storage medium is the CF card. If no image file is the M type, change the storage device to be operated.
· Change the storage device to be operated.
e. Access the EXTENDED-BOOTWARE menu.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
f. Enter 9 to access the storage device submenu.
==============================<DEVICE CONTROL>==============================
|<1> Display All Available Nonvolatile Storage Device(s) |
|<2> Set The Operating Device |
|<3> Set The Default Boot Device |
Enter your choice(0-3):
g. Enter 2 to set the operated storage medium.
Please set the operating device:
|NO. Device Name File System Total Size Available Space |
|1 flash JFFS2 262144KB 224937KB |
|2 cfa0 FAT 2044256KB 1173684KB |
|0 Exit |
Enter your choice(0-2):
h. Enter 2 to set the operated storage medium to CF card.
i. Enter 3 to set the default storage medium.
Please set the default device:
|Note:the default device is cfa0 |
|0 Exit |
j. Enter 2 to set the default storage medium to CF card.
k. Enter 0 to exit the storage device submenu.
# Access the EXTENDED-BOOTWARE menu.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
# Enter 9 to access the storage device submenu.
# Enter 1 to view the free storage space.
Display all available nonvolatile storage device(s):
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
# Enter 4 to access the File Control submenu.
|<4> Delete File |
|<5> Copy File |
# Enter 4, and enter the number of the file to delete.
Deleting the file in cfa0:
|NO. Size(B) Time Type Name |
|1 361966592 Aug/24/2021 13:04:32 N/A cfa0:/CR16000-CMW710-SYSTEM-R826|
|0P22.bin |
|2 24333312 Aug/24/2021 13:04:03 N/A cfa0:/CR16000-CMW710-PACKET-CAPT|
|URE-R8260P22.bin |
|0 Exit |
Enter file No.:2
The file you selected is
cfa0:/CR16000-CMW710-PACKET-CAPTURE-R8260P22.bin,Delete it? [Y/N]Y
Deleting....................................................Done.
You can upgrade the BootWare at the CLI or from the BootWare menu.
· Upgrading the BootWare at the CLI on a single-MPU device (distributed devices in standalone mode)
· Upgrading the BootWare at the CLI on a dual-MPU device (distributed devices in standalone mode)
· Upgrading the BootWare at the CLI (distributed devices in IRF mode)
· Upgrading the BootWare at the CLI (centralized devices)
· Upgrading the BootWare from the BootWare menu
Upgrade workflow
Figure 3 Upgrade workflow
Upgrade procedure
Commands might slightly vary by router model. This section uses a CR16000-F router as an example.
See "Preparing for the upgrade."
Download the upgrade file from an PC to the router. For more information, see "Downloading the upgrade file."
Decompressing the .ipe file
If the upgrade file for upgrading the BootWare is in an .ipe file, decompress the .ipe file and save the decompressed files in the root directory of the storage medium on the router.
<Sysname>install add cfa0:/newest.ipe cfa0:
Verifying image file...Done.
This operation will take several minutes, please wait...........................
A boot image and a system image are generated in in the root directory of the storage medium after decompression.
# Upgrade the BootWare on the MPU in slot 0.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin slot 0
This command will update bootrom file on the specified board(s),
Continue? [Y/N]:y
Now updating the Boot ROM, please wait........... ...........Done
# Upgrade the BootWare on the service module in slot 3. The upgrade step for other service modules is the same.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin slot 3
Continue? [Y/N]:y
# Upgrade the BootWare on the switching fabric module in slot 6. The upgrade step for other switching fabric modules is the same.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin slot 6
Continue? [Y/N]:y
Rebooting the router
# Reboot the router to complete the BootWare upgrade.
<Sysname> reboot
Start to check configuration with next startup configuration file, please wait.
........DONE!
Now rebooting, please wait...
Upgrade workflow
Figure 4 Upgrade workflow
Upgrade procedure
# Upgrade the BootWare on the active MPU in slot 0 and standby MPU in slot 1.
Continue? [Y/N]:y
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin slot 1
Continue? [Y/N]:y
Continue? [Y/N]:y
Continue? [Y/N]:y
<Sysname> reboot
........DONE!
NOTE: · In this section, the IRF fabric has two member devices, and each member device has two MPUs. · The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. |
Upgrade workflow
Figure 5 Upgrade workflow
Upgrade procedure
# Upgrade the BootWare on the all MPUs in the IRF fabric.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 1 slot 0
Continue? [Y/N]:y
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 1 slot 1
Continue? [Y/N]:y
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 2 slot 0
Continue? [Y/N]:y
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 2 slot 1
Continue? [Y/N]:y
# Upgrade the BootWare on the service module in slot 3 of chassis 1. The upgrade step for other service modules is the same.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 1 slot 3
Continue? [Y/N]:y
# Upgrade the BootWare on the switching fabric module in slot 6 of chassis 1. The upgrade step for other switching fabric modules is the same.
<Sysname> bootrom update file cfa0:/CR16000-CMW710-BOOT-R8260P22.bin chassis 1 slot 6
Continue? [Y/N]:y
<Sysname> reboot
........DONE!
Upgrade workflow
Figure 6 Upgrade workflow
Upgrade procedure
Commands might slightly vary by router model. This section uses an MSR 2600 router as an example.
<Sysname>install add flash:/newest.ipe flash:
# Upgrade the BootWare on the router.
<Sysname> bootrom update file flash:/msr26-CMW710-BOOT-R0821P18.bin slot 1
This command will update the Boot ROM file on the specified board(s), Continue? [Y/N]:y
Now updating the Boot ROM, please wait................Done.
<Sysname> reboot
........DONE!
Upgrade workflow
Figure 7 Upgrade workflow
Upgrade procedure
Downloading and upgrading the BootWare from the BootWare menu
NOTE: · The BootWare menu varies by router model and BootWare version. This section uses a CR16000-F router as an example. · The operation of downloading an image file through FTP is similar to that through TFTP. This section uses FTP as an example. |
1. Run the FTP server program on a PC (its IP address is 192.168.0.23), set the working directory, FTP username, and password. Store the upgrade file on the working directory of the FTP server.
2. Run the terminal emulation program on the PC, and power on the router. Press Ctrl+B at prompt to access the EXTENDED-BOOTWARE menu.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
3. (Optional.) Set the default storage medium.
IMPORTANT: If the storage medium storing the BootWare image file is not the default storage medium, set it as the default storage medium. |
# Enter 2 to set the storage medium for storing the BootWare image file.
|0 Exit |
# Enter 2 to configure the CF card as the storage medium for storing the BootWare image file.
# Enter 3 to set the default storage medium.
|0 Exit |
# Enter 2 to configure the CF card as the default storage medium.
# Enter 0 to exit the storage device submenu.
4. Download and upgrade the BootWare.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
# Enter 7 to access the BootWare Operation submenu.
=========================<BootWare Operation Menu>==========================
|<1> Backup Full BootWare |
|<2> Restore Full BootWare |
|<3> Update BootWare By Serial |
|<4> Update BootWare By Ethernet |
Enter your choice(0-4):
# Enter 4 to access the Ethernet submenu.
===================<BOOTWARE OPERATION ETHERNET SUB-MENU>===================
|<1> Update Full BootWare |
|<2> Update Extended BootWare |
|<3> Update Basic BootWare |
|<4> Modify Ethernet Parameter |
# Enter 4 to configure the network settings.
NOTE: To use the existing setting for a field, press Enter without modifying the setting. |
==========================<ETHERNET PARAMETER SET>==========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :ftp
Load File Name :test.btw
:mpu.btw
Target File Name :test.btw
:mpu.btw
Server IP Address :192.168.0.23
Local IP Address :192.168.0.105
Subnet Mask :255.255.255.0
Gateway IP Address :0.0.0.0
FTP User Name :xxx
FTP User Password :***
Table 3 Network parameter fields and shortcut keys
'.' = Clear field |
Press a dot (.) and then press Enter to clear the setting for a field. |
'-' = Go to previous field |
Press a hyphen (-) and then press Enter to return to the previous field. |
Ctrl+D = Quit |
Press Ctrl+D to exit the ETHERNET PARAMETER SET menu. |
Protocol (FTP or TFTP) |
Set the file transfer protocol to FTP or TFTP. |
Load File Name |
Set the name of the file to be downloaded. |
Target File Name |
Set a file name for saving the file on the router. The target file name must have the same extension as the source file. By default, the target file name is the same as the source file name. |
Server IP Address |
Set the IP address of the FTP or TFTP server. |
Local IP Address |
Set the IP address of the Ethernet interface that connects to the TFTP server. |
Subnet Mask |
Set the IP address mask. |
Gateway IP Address |
Set a gateway IP address if the router is on a different network than the server. |
After you finish setting the FTP parameters, the system returns to the BOOTWARE OPERATION ETHERNET submenu.
# Choose an option from options 1 to 3. For example, enter 1 to upgrade the entire BootWare image.
Loading...........Done!
447612 bytes downloaded!
Updating Basic BootWare? [Y/N]
# Enter Y to upgrade the basic BootWare segment.
Updating Basic BootWare.........Done!
Updating Extended BootWare? [Y/N]
# Enter Y to upgrade the extended BootWare segment.
Updating Extended BootWare.........Done!
# Enter 0 to return to the BootWare Operation menu.
# Enter 0 in the BootWare Operation menu to return to the EXTENDED-BOOTWARE menu.
# Enter 0 in the EXTENDED-BOOTWARE menu to reboot the router.
NOTE: For a modular router that has an active MPU and a standby MPU, you must access the BootWare menus of them through the console port to upgrade their BootWares. You also need to connect to the management Ethernet ports on both MPUs. |
You can upgrade the startup software by using the following methods:
· Upgrading the startup software by using the boot loader method
· Upgrading the startup software from the BootWare menu
· Performing a compatible upgrade by using ISSU commands (distributed devices)
· Performing a compatible upgrade by using ISSU commands (centralized devices)
· Performing an incompatible upgrade by using ISSU commands (distributed devices)
· Performing an incompatible upgrade by using ISSU commands (centralized devices)
Upgrade workflow
Table 4 Upgrade workflow
Upgrade procedure
NOTE: · You can specify an .ipe file or a boot image file and a system image file in the boot-loader file command. This section uses an .ipe file as an example. · Available commands vary by router model. This section uses a CR16000-F router as an example. · The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. |
# Specify an .ipe file as the main startup software file.
<Sysname> boot-loader file flash:/all.ipe all main
Verifying the file flash:/all.ipe on slot 1..............Done.
H3C CR16010H-F images in IPE:
boot.bin
system.bin
This command will set the main startup software images. Continue? [Y/N]:y
# Specify an .ipe file as the backup startup software file.
<Sysname> boot-loader file flash:/all2.ipe all backup
Verifying the file flash:/all2.ipe on slot 1..............Done.
boot.bin
system.bin
This command will set the backup startup software images. Continue? [Y/N]:y
# Reboot the router to complete the upgrade.
<Sysname> reboot
........DONE!
Upgrade workflow
Table 5 Upgrade workflow
Upgrade procedure
# Return to the EXTENDED-BOOTWARE menu, and enter 0 in the EXTENDED-BOOTWARE menu to reboot the router.
NOTE: For a modular router that has an active MPU and a standby MPU, you must access the BootWare menus of them through the console port to upgrade their startup software. You also need to connect to the management Ethernet ports on both MPUs. |
NOTE: · Before performing an ISSU, you must use the display version comp-matrix command to identify the recommended ISSU methods. · In this section, the IRF fabric or cluster has two member devices, and each member device has two MPUs. · The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. · The command output varies by device model. |
Upgrade workflow
Table 6 Upgrade workflow
Upgrade procedure
Identifying the recommended ISSU methods
# Display active software images.
<Sysname> display install active
Active packages on chassis 1 slot 0:
flash:/boot-t0001015.bin
flash:/system-t0001015.bin
flash:/feature-t0001015.bin
Active packages on chassis 1 slot 1:
Active packages on chassis 2 slot 0:
Active packages on chassis 2 slot 1:
# Identify the recommended ISSU methods.
<Sysname> display version comp-matrix file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin
Verifying the file flash:/boot-t0001016.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/system-t0001016.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/feature-t0001016.bin on chassis 1 slot 0..................................Done.
Identifying the upgrade methods....Done.
Chassis Slot Upgrade Way
1 0 Reboot
1 1 Reboot
2 0 Reboot
2 1 Reboot
The output shows that reboot upgrades are recommended.
# Upgrade the startup software on the subordinate member.
<Sysname> issu load file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin chassis 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Copying file flash:/boot-t0001016.bin to chassis2#slot0#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis2#slot0#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis2#slot0#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 2 slot 0...Done.
Verifying the file flash:/system-t0001016.bin on chassis 2 slot 0............Done.
Verifying the file flash:/feature-t0001016.bin on chassis 2 slot 0...Done.
Copying file flash:/boot-t0001016.bin to chassis2#slot1#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis2#slot1#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis2#slot1#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 2 slot 1...Done.
Verifying the file flash:/system-t0001016.bin on chassis 2 slot 1............Done.
Verifying the file flash:/feature-t0001016.bin on chassis 2 slot 1...Done.
Identifying the upgrade methods….Done.
Running Version New Version
Test 0001015 Test 0001016
2 0 Reboot
2 1 Reboot
This operation might take several minutes, please wait...Done.
# Verify that the ISSU is in a stable state.
<Sysname> display issu state
ISSU state: Loaded
Compatibility: Compatible
Work state: Normal
Upgrade method: Chassis by chassis
Upgraded chassis:
chassis 2
Current upgrading chassis: None
Previous version list:
boot: 7.1.070, Test 0001015
system: 7.1.070, Test 0001015
feature: 7.1.070, Test 0001015
Previous software images:
Upgrade version list:
boot: 7.1.070, Test 0001016
system: 7.1.070, Test 0001016
feature: 7.1.070, Test 0001016
Upgrade software images:
The Loaded state is a stable state, which indicates that the system is waiting for a master/subordinate switchover. Chassis 2 has completed the upgrade, and chassis 1 has not.
# Perform a master/subordinate switchover.
<Sysname> issu run switchover
Chassis Slot Switchover Way
1 0 Master subordinate switchover
This operation might take several minutes, please wait.........
ISSU state: Switchover
Work state: Normal
Upgraded chassis:
chassis 2
The Switchover state is a stable state, which indicates that the system has completed the master/subordinate switchover and is waiting for a commit operation to upgrade chassis 1.
# Upgrade the startup software on the original master.
<Sysname> issu commit chassis 1
Copying file flash:/boot-t0001016.bin to chassis1#slot1#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis1#slot1#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis1#slot1#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 1 slot 1...Done.
Verifying the file flash:/system-t0001016.bin on chassis 1 slot 1...Done.
Verifying the file flash:/feature-t0001016.bin on chassis 1 slot 1...Done.
1 0 Reboot
1 1 Reboot
# Verify that the ISSU is finished.
ISSU state: Init
Compatibility: Unknown
Upgraded chassis: None
Current version list:
The ISSU state field displays Init, which indicates that the ISSU is finished.
# Verify that both members are running the new software images.
NOTE: · Before performing an ISSU, you must use the display version comp-matrix command to identify the recommended ISSU methods. · In this section, the IRF fabric has two member devices. · The command output varies by device model. |
Upgrade workflow
Table 7 Upgrade workflow
Upgrade procedure
Download the upgrade file from an PC to the router. For more information, "Downloading the upgrade file."
Active packages on slot 1:
Active packages on slot 2:
Verifying the file flash:/boot-t0001016.bin on slot 1.......................Done.
Verifying the file flash:/system-t0001016.bin on slot 1................. .................Done.
Verifying the file flash:/feature-t0001016.bin on slot 1.................Done.
Slot Upgrade Way
1 Reboot
2 Reboot
<Sysname> issu load file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin slot 2
Copying file flash:/boot-t0001016.bin to slot2#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to slot2#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to slot2#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on slot 2...Done.
Verifying the file flash:/system-t0001016.bin on slot 2............Done.
Verifying the file flash:/feature-t0001016.bin on slot 2...Done.
Slot Upgrade Way
2 Reboot
ISSU state: Loaded
Work state: Normal
Upgrade method: Card by card
Upgraded slot:
slot 2
Current upgrading slot: None
The Loaded state is a stable state, which indicates that the system is waiting for a master/subordinate switchover. Slot 2 has completed the upgrade, and slot 1 has not.
Slot Switchover Way
1 Master subordinate switchover
Work state: Normal
Upgraded slot:
slot 2
The Switchover state is a stable state, which indicates that the system has completed the master/subordinate switchover and is waiting for a commit operation to upgrade slot 1.
<Sysname> issu commit slot 1
Slot Upgrade Way
1 Reboot
ISSU state: Init
Work state: Normal
Upgraded slot: None
NOTE: · Before performing an ISSU, you must use the display version comp-matrix command to identify the recommended ISSU methods. · In this section, the IRF fabric has two member devices, and each member device has two MPUs. · The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. · The command output varies by device model. |
Upgrade workflow
Table 8 Upgrade workflow
Upgrade procedure
<Sysname> display version comp-matrix file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin
Verifying the file flash:/boot-t0001017.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/system-t0001017.bin on chassis 1 slot 0..................................Done.
Verifying the file flash:/feature-t0001017.bin on chassis 1 slot 0..................................Done.
Incompatible upgrade
The output shows that an incompatible upgrade is recommended.
<Sysname> issu load file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin chassis 2
Copying file flash:/boot-t0001017.bin to chassis2#slot0#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis2#slot0#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis2#slot0#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 2 slot 0...Done.
Verifying the file flash:/system-t0001017.bin on chassis 2 slot 0............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 2 slot 0...Done.
Copying file flash:/boot-t0001017.bin to chassis2#slot1#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis2#slot1#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis2#slot1#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 2 slot 1...Done.
Verifying the file flash:/system-t0001017.bin on chassis 2 slot 1............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 2 slot 1...Done.
Test 0001015 Test 0001017
2 0 Reboot
2 1 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
ISSU state: Loaded
Compatibility: Incompatible
Work state: Normal
Upgraded chassis:
chassis 2
boot: 7.1.070, Test 0001017
system: 7.1.070, Test 0001017
feature: 7.1.070, Test 0001017
Copying file flash:/boot-t0001017.bin to chassis1#slot1#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis1#slot1#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis1#slot1#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 1 slot 1...Done.
Verifying the file flash:/system-t0001017.bin on chassis 1 slot 1............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 1 slot 1...Done.
1 0 Reboot
1 1 Reboot
ISSU state: Init
Work state: Normal
Upgrade workflow
Table 9 Upgrade workflow
Upgrade procedure
Verifying the file flash:/boot-t0001017.bin on slot 1.......................Done.
Verifying the file flash:/system-t0001017.bin on slot 1................. .................Done.
Verifying the file flash:/feature-t0001017.bin on slot 1.................Done.
Incompatible upgrade.
<Sysname> issu load file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin slot 2
Copying file flash:/boot-t0001017.bin to slot2#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to slot2#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to slot2#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on slot 2...Done.
Verifying the file flash:/system-t0001017.bin on slot 2............Done.
Verifying the file flash:/feature-t0001017.bin on slot 2...Done.
Slot Upgrade Way
2 Reboot
ISSU state: Loaded
Work state: Normal
Upgraded slot:
slot 2
Slot Switchover Way
ISSU state: Init
Work state: Normal
Upgraded slot: None
This chapter describes how to install patches and features.
· Installing features on a single-MPU device (distributed devices in standalone mode)
· Installing features on a dual-MPU device (distributed devices in standalone mode)
· Installing features (distributed devices in IRF mode/CR19000)
· Installing features (centralized devices)
Installing patches
Installation workflow
Figure 8 Installation workflow
Installation procedure
Downloading the image file
Download the image file from an PC to the router. For more information, see "Downloading the upgrade file."
Installing a patch
NOTE: The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. |
# Install a patch.
<Sysname> install activate patch flash:/patch1.bin all
# Commit the software change.
<Sysname> install commit
NOTE: · The install commit command enables the installed patch to take effect after the device or a card reboots. · You need to re-install the patch after the software is upgraded and then rolled back to original version. |
Uninstalling a patch
# Display active patch images.
# Uninstall a patch.
<Sysname> install deactivate patch flash:/patch1.bin all
NOTE: The install commit command enables the uninstalled patch to not take effect after the device or a card reboots. |
Figure 9 Installation workflow
If the image file for installing a feature is in an .ipe file, decompress the .ipe file.
<Sysname> install add flash:/feature1.ipe flash:/
Installing a feature
# Install a feature image on the MPU.
<Sysname> install activate feature flash:/feature1.bin slot0
NOTE: · The install commit command enables the installed feature images to take effect after the device or a card reboots. · You need to re-install the feature images after the software is upgraded and then rolled back to original version. |
Uninstalling a feature image
# Uninstall the feature image on the MPU.
<Sysname> install deactivate feature flash:/feature1.bin slot0
NOTE: The install commit command enables the uninstalled feature images to not take effect after the device or a card reboots. |
Figure 10 Installation workflow
# Install a feature image on the active MPU.
# Install a feature image on the standby MPU.
<Sysname> install activate feature flash:/feature1.bin slot1
# Uninstall the feature image on the standby MPU.
<Sysname> install deactivate feature flash:/feature1.bin slot1
# Uninstall the feature image on the active MPU.
NOTE: · To uninstall a feature image, you must begin with the standby MPU. · The install commit command enables the uninstalled feature images to not take effect after the device or a card reboots. |
NOTE: · In this section, the IRF fabric or cluster has two member devices, and each member device has two MPUs. · The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices. |
Figure 11 Installation workflow
# Install a feature image on all MPUs in the IRF fabric or cluster.
<Sysname> install activate feature flash:/feature1.bin chassis 1 slot0
<Sysname> install activate feature flash:/feature1.bin chassis 1 slot1
<Sysname> install activate feature flash:/feature1.bin chassis 2 slot0
<Sysname> install activate feature flash:/feature1.bin chassis 2 slot1
# Uninstall the feature image from all standby MPUs.
<Sysname> install deactivate feature flash:/feature1.bin chassis 1 slot1
<Sysname> install deactivate feature flash:/feature1.bin chassis 2 slot1
<Sysname> install deactivate feature flash:/feature1.bin chassis 2 slot0
# Uninstall the feature image from the active MPU.
NOTE: · To uninstall a feature image, you must begin with the standby MPUs. · The install commit command enables the uninstalled feature images to not take effect after the device or a card reboots. |
Figure 12 Installation workflow
# Install a feature image.
NOTE: · The install commit command enables the installed feature images to take effect after the device reboots. · You need to re-install the feature images after the software is upgraded and then rolled back to original version. |
# Uninstall a feature image.
NOTE: The install commit command enables the uninstalled feature images to not take effect after the device reboots. |
This chapter includes the following sections:
· Verifying that the router is running the new BootWare image
· Verifying that the router is running the new software images
· Verifying that a patch or feature image is installed successfully
· Verifying that the cards and subcards are in normal state (modular router)
· Verifying that the router is in stable state
· Verifying that the configuration has been recovered
· Verifying that the services are normal
NOTE: The verification is required only if the BootWare image has been upgraded. |
Use one of the following methods:
· Reboot the router to check whether the router is running the new BootWare image.
If not, examine the upgrade steps and perform the upgrade steps again.
* BootWare, Version 1.51 *
· Use the display version command to verify that the router is running the new BootWare image. If not, examine the upgrade steps and perform the upgrade steps again.
NOTE: The verification is required only if the startup software has been upgraded. |
# Use the display boot-loader command to check whether the router is running the new software images.
<Sysname>display boot-loader
None
NOTE: The verification is required only if a patch or feature image has been installed. |
# Use the display install active command to check whether a patch or feature image has been installed successfully.
If the command output does not have a patch or feature image, no patch or feature image has been installed or the patch or feature image installation fails.
<Sysname>display install active
Active packages on slot 0:
cfa0:/CR16000-CMW710-SYSTEM-WEAK-R8260P22H01.bin
Active packages on slot 6:
Active packages on slot 13:
# Use the display device command to check whether the cards and subcards are in normal state.
The Brd Status field indicates the card or subcard status.
<Sysname>display device
1 NONE Absent NONE
2 NONE Absent NONE
3 NONE Absent NONE
5 NONE Absent NONE
7 NONE Absent NONE
8 NONE Absent NONE
9 NONE Absent NONE
10 NONE Absent NONE
11 NONE Absent NONE
12 NONE Absent NONE
14 NONE Absent NONE
# Use the display system stable state command to check whether the router is in stable state.
The router is stable if the System State field displays Stable.
Slot CPU Role State
0 0 Active Stable
6 0 Other Stable
6 1 Other Stable
13 0 Other Stable
# Use the display current-configuration command to view the current configuration.
# Use the display diff current-configuration startup-configuration command to check whether configurations are lost or modified.
NOTE: Before verifying the services, do not execute the save command. |
# Collect entries (such as routing entries, FIB entries, and MAC address entries) and compare them with the entries before the upgrade to check whether entries are lost.
# Check whether the service traffic before and after the upgrade is the same.
# Check whether the servers such as NMS servers are working correctly.
Application scenarios
The following are application scenarios for version rollback:
· You need to roll back the running software version to the old version due to service requirements.
· You need to roll back the running software version to the old version if the device cannot work correctly after a software upgrade.
Before the version rollback, make sure the device is operating correctly, and make sure the LEDs of the power supply, fans, cards, and subcards are normal.
During the version rollback, do not power off the device, and do not restart or remove swappable modules.
Before the version rollback:
· Use the release notes to verify that the current software version can be rolled back to the target version.
· Verify that the original configuration file before version upgrade is present on the device. If it does not exist, download the original configuration file to the device and specify it as the startup configuration file.
During the version rollback:
· As a best practice, enable logging of the terminal to collect information.
· A rollback requiring a device reboot will cause service interruption for the duration of the reboot.
· Before a rollback operation is completed, no other rollback operations can be performed. Rollback operations include the install, issu, and boot-loader commands.
After the version rollback:
· After the rollback, do not delete the running software images.
Rollback workflow
The version rollback workflow is the same as the version upgrade workflow. For more information, see "Upgrade workflow."
Rollback procedure
The version rollback procedure is the same as the version upgrade procedure. For more information, see "Upgrading the startup software."
If the replacement image files are still saved on the storage medium, you do not need to download them again. You only need to specify them as the startup software images.
Verifying the rollback
Verifying the rollback is the same as verifying the upgrade. For more information, see "Verifying the upgrade."
Troubleshooting
This chapter describes the problems that might be encountered during a software upgrade and the troubleshooting steps.
Symptom
Failed to log in to the router through the management port or console port.
Possible reasons
· Parameters of the terminal emulation program are configured incorrectly.
· Physical ports are connected incorrectly.
· The Telnet service is not enabled on the router.
· The memory is insufficient on the router.
Troubleshooting workflow
Figure 13 Troubleshooting workflow
Solution
To resolve the issue:
1. Verify that the parameters of the terminal emulation program are configured correctly. For how to configure the parameters of the terminal emulation program, see "Preparing for the upgrade."
2. Verify that the physical cable connecting the PC to the management port or console port is good.
3. Use the display current-configuration to verify that the telnet server enable command and other related commands are executed on the router. For information about the configuration, see "Preparing for the upgrade."
4. If the issue persists, collect the following information and contact H3C Support:
¡ Execution results of the preceding commands.
¡ Configuration file, log messages, and warning messages.
Symptom
Transmission is interrupted during the downloading of software images.
Possible reasons
· The free storage space is insufficient.
· The link between the PC and the router fails, or the network is unstable.
· The FTP server or TFTP server program is abnormal.
· The storage medium is abnormal.
Figure 14 Troubleshooting workflow
Solution
1. Verify that the free storage space is sufficient. If the free storage space is insufficient, delete unused files. For more information, see "Preparing for the upgrade."
2. Use the ping command to verify the connection between the PC and the router. If the connection is abnormal, replace the link media.
3. Verify that the FTP/TFTP server program works correctly and the FTP/TFTP settings are correct.
4. Check whether the storage medium is normal by deleting, reading and copying files. If the storage medium is abnormal, you can format the storage medium.
5. If the issue persists, collect the following information and contact H3C Support:
Symptom
The router fails to restart with the startup software images or cannot enter user view or system view after startup.
Possible reasons
· The power supply or fan tray fails.
· The startup software images are damaged. The startup software images might be damaged if the FTP transfer mode for downloading them is not binary mode.
· The storage medium to which the startup software images are downloaded is not the specified storage medium.
· The difference between the old version and the new version is large, so the BootWare cannot be automatically upgraded.
Figure 15 Troubleshooting workflow
Solution
1. Verify that the power supply is normal (the LED is solid green). If the power supply is abnormal, replace it.
2. Verify that the fan tray is normal (the LED is solid green) and that the air inlet and outlet vents are blocked. If the fan tray is abnormal, replace it or clean the air inlet and outlet vents.
3. Use the BootWare menu to check whether the storage medium to which the startup software images are downloaded is the specified storage medium. If not, see "Downloading the upgrade file" to set the storage medium to which the startup software images are downloaded is the specified storage medium.
4. Obtain the correct software version and upgrade the software from the BootWare menu again.
Symptom
The output from the display device command shows that a card or subcard is in Fault state.
Possible reasons
· The startup software version does not support the card or subcard.
· The startup software version on the card or subcard is different from the startup software version on the active MPU.
· The card or subcard is faulty.
Figure 16 Troubleshooting workflow
Solution
1. Use the release notes to check whether the current version supports the card or subcard. If the current version does not support the card or subcard, use another software version and perform the upgrade again.
2. Use the display device command to check whether the startup software version on the card or subcard is the same as the startup software version on the active MPU. If not, specify the same startup software version on the card or subcard.
3. If the issue persists, collect the following information and contact H3C Support:
The router can function as the TFTP client, FTP client, or FTP server. For more information about FTP and TFTP, see the FTP and TFTP configuration in the fundamentals configuration guide.
This section uses the router as an FTP client to download files from an FTP server.
NOTE: The BootWare menu varies by router model and BootWare version. This section uses a CF16000-F router as an example. |
1. Set up an upgrade environment as described in "Preparing for the upgrade."
2. Run the FTP server program on a PC (its IP address is 192.168.0.23), and set the working directory, FTP username, and password. Store the upgrade file on the working directory of the FTP server.
3. Make sure the PC and the router can reach each other.
4. Log in to the router, and access the root directory of the storage medium for the startup software images.
<Sysname> cd cfa0:/
<Sysname>
NOTE: If the storage medium to which the startup software images are downloaded is not the specified storage medium, access the root directory of the storage medium of startup software images before downloading the software images. |
5. Download the upgrade file (newest.ipe in this example) to the storage medium on the router.
# Log in to the FTP server.
<Sysname> ftp 192.168.0.23
Connected to 192.168.0.23 (192.168.0.23).
User (192.168.0.23:(none)):username
Password:
230 Logged in successfully
Remote system type is MSDOS.
ftp>
# Set the file transfer mode to binary.
ftp> binary
# Download the upgrade file newest.ipe to the root directory of the storage medium.
ftp> get newest.ipe
227 Entering Passive Mode (192,168,0,23,7,100)
150 "C:\ newest.ipe " file ready to send (385 bytes) in in IMAGE / Binary mode
74948608 bytes received in 35.974 seconds (896.00 kbyte/s)
ftp> bye
221 Windows FTP Server (WFTPD, by Texas Imperial Software) says goodbye
# Verify that the upgrade file has been in the root directory of the storage medium.
<Sysname> dir
# Use the MD5 algorithm to calculate the digest of the file, and compare it with the MD5 digest on the H3C website to verify file integrity.
<Sysname> md5sum newest.ipe
MD5 digest:
4f22b6190d151a167105df61c35f0917
3. Run the terminal emulation program on the PC, and power on the router. Press Ctrl+B at prompt to access the EXTENDED-BOOTWARE menu.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
4. (Optional.) Set the default storage medium.
IMPORTANT: If the storage medium storing the upgrade file is not the default storage medium, set it as the default storage medium. |
# Enter 2 to set the storage medium for storing the upgrade file.
|0 Exit |
# Enter 2 to set the CF card as the storage medium for storing the upgrade file.
|0 Exit |
# Enter 2 to set the CF card as the default storage medium.
5. Download and upgrade the BootWare.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
# Enter 3 to access the Ethernet submenu.
==========================<Enter Ethernet SubMenu>==========================
|<1> Download Image Program To SDRAM And Run |
|<2> Update Main Image File |
|<3> Update Backup Image File |
|<4> Download Files(*.*) |
|<5> Modify Ethernet Parameter |
|<Ensure The Parameter Be Modified Before Downloading!> |
# Enter 5 to configure the network settings.
| Ctrl+D = Quit. |
Load File Name :newest.ipe
Target File Name :newest.ipe
FTP User Name :xxx
Table 10 Network parameter fields and shortcut keys
'.' = Clear field |
Ctrl+D = Quit |
Load File Name |
Target File Name |
Server IP Address |
Local IP Address |
Subnet Mask |
After you finish setting the FTP parameters, the system returns to the Ethernet submenu. Choose option 2 to 3. For example, enter 2 to upgrade the main startup software images.
Loading.....................................................................
.........................Done!
31911744 bytes downloaded!
Image file BOOT.bin is self-decompressing... Saving file cfa0:/ BOOT.bin ..............................................Done.
Image file SYSTEM.bin is self-decompressing...Saving file cfa0:/ SYSTEM.bin .................................. ..Done.
# Enter 0 in the Ethernet submenu to return to the EXTENDED-BOOTWARE menu.
# Enter 0 to reboot the router.
Downloading software images at the CLI
2. Run the TFTP server program on a PC (its IP address is 192.168.0.23), and set the working directory, TFTP username, and password. Store the upgrade file on the working directory of the TFTP server.
<Sysname> cd cfa0:/
<Sysname>
NOTE: If the storage medium to which the startup software images are downloaded is not the specified storage medium, access the root directory of the storage medium of startup software images before downloading software images. |
<Sysname> tftp 192.168.0.23 get newest.ipe
Press CTRL+C to abort.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 13.9M 100 13.9M 0 0 1206k 0 0:00:11 0:00:11 --:--:-- 1206k
Writing file...Done.
<Sysname> dir
MD5 digest:
Downloading software images from the BootWare menu
2. Run the TFTP server program on a PC (its IP address is 192.168.0.23), set the working directory, TFTP username, and password. Store the upgrade file on the working directory of the TFTP server.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
4. (Optional.) Set the default storage medium for downloading the upgrade file.
|0 Exit |
|0 Exit |
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-5)::
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
Load File Name :test.bin
:newest.ipe
Target File Name :test.bin
:newest.ipe
Table 11 Network parameter fields and shortcut keys
'.' = Clear field |
Ctrl+D = Quit |
Load File Name |
Target File Name |
Server IP Address |
Local IP Address |
Subnet Mask |
Upgrade record form
Site name |
Upgraded at |
Router model |
Router name |
Version before upgrade |
Version after upgrade |
Upgrade team members |
Team members from the site: Team members from H3C: |
Upgrade result |
Check items |
Result |
Unexpected situation handling |
Before the upgrade |
Check tools used to upgrade software. |
Identify the upgrade methods supported by the router. |
Check the upgrade environment. |
Check whether the router can be logged in. |
Prepare the required upgrade software images. |
View the current system software version. |
Check whether important data has been backed up. |
Check whether the storage medium has sufficient space to store the upgrade software images. |
During the upgrade |
Check the upgrade process. |
Check the TFTP or FTP server configuration. |
Check whether the software images have been downloaded successfully. |
Check the upgrade operation. |
(Optional.) Check the upgrade status of the standby MPU. |
After the upgrade |
Check the software version after the upgrade. |
Compare the memory usage and CPU usage before and after the upgrade to identify whether they are significantly different. |
Check whether services are running correctly. |
