| 00-Preface | 111.88 KB |
Preface
H3C Router Software Upgrade Guide guides you through the upgrade of your routers. The guide contains the following sections:
· About software upgrade
· Upgrade restrictions and guidelines
· Upgrade workflow
· Preparing for the upgrade
· Upgrading the BootWare
· Upgrading the startup software
· Installing patches and features
· Verifying the upgrade
· Rolling back the running software images
· Troubleshooting
· Downloading the upgrade file
· Upgrade record form
· Acronyms
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
