10-Layer 3 - IP Routing
HomeSupportNFVH3C VSRReference GuidesMIB CompanionH3C VSR Series Virtual Service Router MIB Reference-R1362-6W10010-Layer 3 - IP Routing
03-HH3C-OSPF-MIB
03-HH3C-OSPF-MIB 66.69 KB
HH3C-OSPF-MIB
About this MIB
Use this MIB to display OSPF information.
MIB file name
hh3c-ospf.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cOspf(161)
Scalar objects
hh3cOspfSrConflictState (1.3.6.1.4.1.25506.2.161.2.14)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
DisplayString
InConflict
ConflictResolved
Conflict state.
As per the MIB.
Tabular objects
hh3cOspfNetworkTable
About this table
Use this table to obtain OSPF network configuration information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cOspfProcessId, hh3cOspfAreaId, and hh3cOspfNetworkIpAddr.
Object (OID)
Access
Value range
Implementation
hh3cOspfProcessId (1.3.6.1.4.1.25506.2.161.1.1.1)
not-accessible
Integer32
Integer32(1..65535)
OSPF process ID.
As per the MIB.
hh3cOspfAreaId (1.3.6.1.4.1.25506.2.161.1.1.2)
not-accessible
IpAddress
OCTET STRING (4)
Area ID, which uniquely identifies an area.
As per the MIB.
hh3cOspfNetworkIpAddr (1.3.6.1.4.1.25506.2.161.1.1.3)
not-accessible
IpAddress
OCTET STRING (4)
Subnet address.
As per the MIB.
hh3cOspfNetworkIpMask (1.3.6.1.4.1.25506.2.161.1.1.4)
read-only
IpAddress
OCTET STRING (4)
Wildcard mask of the subnet address, which is the inverse of a subnet mask, meaning that it changes all 0s to 1s and all 1s to 0s.
As per the MIB.
