10-Layer 3 - IP Routing
HomeSupportNFVH3C VSRReference GuidesMIB CompanionH3C VSR Series Virtual Service Router MIB Reference-R1362-6W10010-Layer 3 - IP Routing
02-HH3C-IPRAN-DCN-MIB
02-HH3C-IPRAN-DCN-MIB 102.68 KB
HH3C-IPRAN-DCN-MIB
About this MIB
This MIB describes how to use the network management System (NMS) to manage and control remote network elements in the data communication network (DCN) and obtain running states and online and offline notifications.
MIB file name
hh3c-ipran-dcn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpRanDcn(152)
Tabular objects
hh3cIpRanDcnInfoObject
About this table
This table contains network element information about the local device.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
This table does not contain indexes.
Object (OID)
Access
Value range
Implementation
hh3cIpRanDcnNeId (1.3.6.1.4.1.25506.2.152.1.1.1)
read-only
Hh3cIpRanNeId
OCTET STRING (4)
NE ID of the local device.
As per the MIB.
hh3cIpRanDcnNeIpType (1.3.6.1.4.1.25506.2.152.1.1.2)
read-only
InetAddressType
ipv4(1)
NE IP address type of the local device.
As per the MIB.
hh3cIpRanDcnNeIp (1.3.6.1.4.1.25506.2.152.1.1.3)
read-only
InetAddress
OCTET STRING (0..255)
NE IP address of the local device.
As per the MIB.
hh3cIpRanDcnMask (1.3.6.1.4.1.25506.2.152.1.1.4)
read-only
InetAddress
Subnet mask of the NE IP address of the local device.
As per the MIB.
hh3cIpRanDcnMAC (1.3.6.1.4.1.25506.2.152.1.1.5)
read-only
MacAddress
OCTET STRING (6)
Bridge MAC of the local device.
As per the MIB.
hh3cIpRanDcnVendor (1.3.6.1.4.1.25506.2.152.1.1.6)
read-only
DisplayString
SIZE (0..255)
Vendor of the local device.
As per the MIB.
hh3cIpRanDcnNeInfoTable
About this table
This table contains information about all network elements in the DCN network.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIpRanDcnNeInfoNeId (1.3.6.1.4.1.25506.2.152.1.1.2.1.1)
read-only
Hh3cIpRanNeId
OCTET STRING (4)
NE ID.
As per the MIB.
hh3cIpRanDcnNeInfoNeIpType (1.3.6.1.4.1.25506.2.152.1.1.2.1.2)
read-only
InetAddressType
ipv4(1)
NE IP address type.
As per the MIB.
hh3cIpRanDcnNeInfoNeIp (1.3.6.1.4.1.25506.2.152.1.1.2.1.3)
read-only
InetAddress
NE IP address.
As per the MIB.
hh3cIpRanDcnNeInfoMetric (1.3.6.1.4.1.25506.2.152.1.1.2.1.4)
read-only
Integer32
Standard MIB values.
Distance from the local NE to the remote NE.
As per the MIB.
hh3cIpRanDcnNeInfoDeviceType (1.3.6.1.4.1.25506.2.152.1.1.2.1.5)
read-only
DisplayString
Device type of the NE.
As per the MIB.
hh3cIpRanDcnNeInfoMAC (1.3.6.1.4.1.25506.2.152.1.1.2.1.6)
read-only
MacAddress
OCTET STRING (6)
Bridge MAC of the NE.
As per the MIB.
hh3cIpRanDcnNeInfoVendor (1.3.6.1.4.1.25506.2.152.1.1.2.1.7)
read-only
DisplayString
Vendor of the NE.
As per the MIB.
hh3cIpRanDcnTrapObjects
About this table
This table contains information about the NE that has state change most recently.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cIpRanDcnNeNumber (1.3.6.1.4.1.25506.2.152.1.2.1)
read-only
Integer32
Total number of online NEs in the DCN network.
As per the MIB.
hh3cIpRanDcnNeChangeMode (1.3.6.1.4.1.25506.2.152.1.2.2)
read-only
INTEGER
online (1), offline (2)
Current state of the NE that has state change most recently.
As per the MIB.
hh3cIpRanDcnCompanyName (1.3.6.1.4.1.25506.2.152.1.2.3)
read-only
DisplayString
Vendor name of the NE that has state change most recently.
As per the MIB.
hh3cIpRanDcnDeviceType (1.3.6.1.4.1.25506.2.152.1.2.4)
read-only
DisplayString
Device type of the NE that has state change most recently.
As per the MIB.
hh3cIpRanDcnDeviceMac (1.3.6.1.4.1.25506.2.152.1.2.5)
read-only
MacAddress
OCTET STRING(6)
Bridge MAC of the NE that has state change most recently.
As per the MIB.
Notifications
hh3cIpRanDcnNeOnline
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.152.1.3.0.1
An NE comes online.
Recovery
Informational
N/A
OFF
Notification triggers
This notification is generated when a new NE comes online in the DCN network.
System impact
No impact on services.
Status control
ON
CLI: Use the auto-report command.
OFF
CLI: Use the undo auto-report command.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.152.1.1.2.1.1 (hh3cIpRanDcnNeInfoNeId)
NE ID.
Hh3cIpRanNeId
OCTET STRING (4)
1.3.6.1.4.1.25506.2.152.1.1.2.1.2 (hh3cIpRanDcnNeInfoNeIpType)
NE IP address type.
InetAddressType
ipv4(1)
1.3.6.1.4.1.25506.2.152.1.1.2.1.3 (hh3cIpRanDcnNeInfoNeIp)
NE IP address.
InetAddress
1.3.6.1.4.1.25506.2.152.1.2.3 (hh3cIpRanDcnCompanyName)
Device vendor name.
N/A
DisplayString
1.3.6.1.4.1.25506.2.152.1.2.4 (hh3cIpRanDcnDeviceType)
Device type.
N/A
DisplayString
1.3.6.1.4.1.25506.2.152.1.2.5 (hh3cIpRanDcnDeviceMac)
Bridge MAC of the device.
N/A
MacAddress
OCTET STRING (6)
Recommended action
No action is required.
hh3cIpRanDcnNeOffline
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.152.1.3.0.2
An NE goes offline.
Error
Informational
1.3.6.1.4.1.25506.2.152.1.3.0.1 (hh3cIpRanDcnNeOnline)
OFF
This notification is generated when an NE goes offline in the DCN network.
System impact
Status control
ON
OFF
Objects
OID (object name)
Index nodes
Value range
NE ID.
Hh3cIpRanNeId
OCTET STRING (4)
NE IP address type.
InetAddressType
ipv4(1)
NE IP address.
InetAddress
Recommended action
