09-Layer 3 - IP Services
HomeSupportNFVH3C VSRReference GuidesMIB CompanionH3C VSR Series Virtual Service Router MIB Reference-R1362-6W10009-Layer 3 - IP Services
10-IPV6-TCP-MIB
10-IPV6-TCP-MIB 48.08 KB
IPV6-TCP-MIB
About this MIB
This MIB is defined by RFC 2452. Use this MIB to obtain IPv6 TCP connection information.
MIB file name
rfc2452-ipv6-tcp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).tcp(6)
Tabular objects
ipv6TcpConnTable
About this table
Use this table to obtain IPv6 TCP connection information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are ipv6TcpConnLocalAddress, ipv6TcpConnLocalPort, ipv6TcpConnRemAddress, ipv6TcpConnRemPort, and ipv6TcpConnIfIndex.
Object (OID)
Access
Value range
Implementation
ipv6TcpConnLocalAddress (1.3.6.1.2.1.6.16.1.1)
Not-accessible
Ipv6Address
Standard MIB values.
Local IPv6 address for a TCP connection.
The value of ::0 indicates that the process is ready to accept a connection request from any port.
As per the MIB.
ipv6TcpConnLocalPort (1.3.6.1.2.1.6.16.1.2)
not-accessible
INTEGER
INTEGER (0..65535)
Local port number for the TCP connection.
As per the MIB.
ipv6TcpConnRemAddress (1.3.6.1.2.1.6.16.1.3)
not-accessible
Ipv6Address
Remote IPv6 address for the TCP connection.
As per the MIB.
ipv6TcpConnRemPort (1.3.6.1.2.1.6.16.1.4)
not-accessible
INTEGER
INTEGER (0..65535)
Remote port number for the TCP connection.
As per the MIB.
ipv6TcpConnIfIndex (1.3.6.1.2.1.6.16.1.5)
not-accessible
Ipv6IfIndexOrZero
Index of the interface associated with the local IPv6 address for the TCP connection.
As per the MIB.
ipv6TcpConnState (1.3.6.1.2.1.6.16.1.6)
read-write
INTEGER
closed(1)
listen(2)
synSent(3)
synReceived(4)
established(5)
finWait1(6)
finWait2(7)
closeWait(8)
lastAck(9)
closing(10)
timeWait(11)
deleteTCB(12)
TCP connection state.
The only value that a management station can set is deleteTCB(12).
If a management station tries to set the object to a value other than deleteTCB(12), the agent will return an error response.
If the object value is set to deleteTCB(12), TCB will be deleted and the corresponding TCP connection will be terminated.
Read only.
