09-Layer 3 - IP Services
HomeSupportNFVH3C VSRReference GuidesMIB CompanionH3C VSR Series Virtual Service Router MIB Reference-R1362-6W10009-Layer 3 - IP Services
07-IP-FORWARD-MIB
07-IP-FORWARD-MIB 83.16 KB
IP-FORWARD-MIB
About this MIB
Use this MIB to configure IP routes for Classless Inter-Domain Routing (CIDR).
MIB file name
rfc4292-ip-forward.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ip(4).ipForward(24)
Scalar objects
ipCidrRouteNumber (1.3.6.1.2.1.4.24.3)
Object (OID)
Access
Value range
Implementation
ipCidrRouteNumber(1.3.6.1.2.1.4.24.3)
read-only
Gauge32
Standard MIB values.
Number of current valid ipCidrRouteTable entries.
As per the MIB.
inetCidrRouteNumber (1.3.6.1.2.1.4.24.6)
Object (OID)
Access
Value range
Implementation
read-only
Gauge32
Number of current valid inetCidrRouteTable entries.
As per the MIB.
inetCidrRouteDiscards (1.3.6.1.2.1.4.24.8)
Object (OID)
Access
Value range
Implementation
read-only
Counter32
Number of invalid entries dropped by inetCidrRouteTable.
As per the MIB.
Tabular objects
ipCidrRouteTable
About this table
Use this table to implement routing table function on an entity. This table has been replaced by the inetCidrRouteTable and is no longer in use.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are ipCidrRouteDest, ipCidrRouteMask, ipCidrRouteTos, and ipCidrRouteNextHop.
Object (OID)
Access
Value range
Implementation
ipCidrRouteDest(1.3.6.1.2.1.4.24.4.1.1)
read-only
IpAddress
(0..255)
Destination IP address of the route.
As per the MIB.
ipCidrRouteMask(1.3.6.1.2.1.4.24.4.1.2)
read-only
IpAddress
(0..255)
Address mask.
As per the MIB.
ipCidrRouteTos(1.3.6.1.2.1.4.24.4.1.3)
read-only
Integer32
ToS field value.
The value is always 0.
ipCidrRouteNextHop(1.3.6.1.2.1.4.24.4.1.4)
read-only
IpAddress
(0..255)
Address of the next hop.
As per the MIB.
ipCidrRouteIfIndex(1.3.6.1.2.1.4.24.4.1.5)
read-create
Integer32
Interface index.
Read only.
ipCidrRouteType(1.3.6.1.2.1.4.24.4.1.6)
read-create
INTEGER
Type of the route.
Read only.
ipCidrRouteProto(1.3.6.1.2.1.4.24.4.1.7)
read-only
INTEGER
Protocol type.
As per the MIB.
ipCidrRouteAge(1.3.6.1.2.1.4.24.4.1.8)
read-only
Integer32
Time since the route was last updated.
As per the MIB.
ipCidrRouteInfo(1.3.6.1.2.1.4.24.4.1.9)
read-create
OBJECT IDENTIFIER
Route information.
Read only.
ipCidrRouteNextHopAS(1.3.6.1.2.1.4.24.4.1.10)
read-create
Integer32
AS number of the next hop.
Read only.
ipCidrRouteMetric1(1.3.6.1.2.1.4.24.4.1.11)
read-create
Integer32
Primary routing metric of the route.
Read only.
ipCidrRouteMetric2(1.3.6.1.2.1.4.24.4.1.12)
read-create
Integer32
Alternate routing metric of the route.
The value is always -1.
Read only.
ipCidrRouteMetric3(1.3.6.1.2.1.4.24.4.1.13)
read-create
Integer32
Read only.
ipCidrRouteMetric4(1.3.6.1.2.1.4.24.4.1.14)
read-create
Integer32
Read only.
ipCidrRouteMetric5(1.3.6.1.2.1.4.24.4.1.15)
read-create
Integer32
Read only.
ipCidrRouteStatus(1.3.6.1.2.1.4.24.4.1.16)
read-create
INTEGER
Row status variable, used according to row installation and deletion conventions.
Read only.
inetCidrRouteTable
About this table
Use this table to obtain IP version-independent multipath CIDR routes.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are inetCidrRouteDestType, inetCidrRouteDest, inetCidrRoutePfxLen, inetCidrRoutePolicy, and inetCidrRouteNextHop.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.2.1.4.24.7.1.1)
not-accessible
Integer32
Destination address family.
As per the MIB.
inetCidrRouteDest
(1.3.6.1.2.1.4.24.7.1.2)
not-accessible
Octets
(0..255)
Destination address.
As per the MIB.
inetCidrRoutePfxLen
(1.3.6.1.2.1.4.24.7.1.3)
not-accessible
Gauge32
Prefix length of the destination address.
As per the MIB.
inetCidrRoutePolicy
(1.3.6.1.2.1.4.24.7.1.4)
not-accessible
Object Identifier
General set of route information.
As per the MIB.
inetCidrRouteNextHopType
(1.3.6.1.2.1.4.24.7.1.5)
not-accessible
Integer32
Next hop address family.
As per the MIB.
(1.3.6.1.2.1.4.24.7.1.6)
not-accessible
Octets
(0..255)
As per the MIB.
inetCidrRouteIfIndex
(1.3.6.1.2.1.4.24.7.1.7)
read-create
Integer32
Output interface.
Read only.
inetCidrRouteType
(1.3.6.1.2.1.4.24.7.1.8)
read-create
Integer32
Type of the route.
Only supports remote, local, and blackhole.
Read only.
inetCidrRouteProto
(1.3.6.1.2.1.4.24.7.1.9)
read-only
Integer32
Routing protocol type.
Supports local, netmgmt, rip, ospf, is-is, bgp, and other (unspecified).
inetCidrRouteAge
(1.3.6.1.2.1.4.24.7.1.10)
read-only
Gauge32
Lifetime of the route.
As per the MIB.
inetCidrRouteNextHopAS
(1.3.6.1.2.1.4.24.7.1.11)
read-create
Gauge32
Read only.
inetCidrRouteMetric1
(1.3.6.1.2.1.4.24.7.1.12)
read-create
Integer32
Routing metric in the protocol.
Read only.
inetCidrRouteMetric2
(1.3.6.1.2.1.4.24.7.1.13)
read-create
Integer32
Read only.
inetCidrRouteMetric3
(1.3.6.1.2.1.4.24.7.1.14)
read-create
Integer32
Read only.
inetCidrRouteMetric4
(1.3.6.1.2.1.4.24.7.1.15)
read-create
Integer32
Read only.
inetCidrRouteMetric5
(1.3.6.1.2.1.4.24.7.1.16)
read-create
Integer32
Read only.
inetCidrRouteStatus
(1.3.6.1.2.1.4.24.7.1.17)
read-create
Integer32
Row status.
Read only.
