12-User Access and Authentication Configuration Guide
HomeSupportWirelessWA6500 Series Access PointsConfigure & DeployConfiguration GuidesH3C WA6500A Series Access Points Cloud Mode Configuration Guides(R2605P09)-6W10012-User Access and Authentication Configuration Guide
05-802.1X client configuration
05-802.1X client configuration 129.44 KB
Configuring an 802.1X client
About 802.1X clients
As shown in Figure 1, the 802.1X client feature allows the access device to act as the supplicant in the 802.1X architecture. For information about the 802.1X architecture, see "802.1X overview." For information about the 802.1X architecture, see "802.1X overview."
Figure 1 802.1X client network diagram
Restrictions and guidelines: 802.1X client configuration
Disable the 802.1X client feature with caution. The operation will log off all online users.
802.1X client tasks at a glance
To configure an 802.1X client, perform the following tasks:
1.     Enabling the 802.1X client feature
2.     Configuring an 802.1X client username and password
3.     Specifying an 802.1X client EAP authentication method
4.     (Optional.) Configuring an 802.1X client anonymous identifier
5.     Specifying an SSL client policy
This task is required when you specify PEAP-MSCHAPv2, PEAP-GTC, TTLS-MSCHAPv2, or TTLS-GTC authentication as the 802.1X client EAP authentication method.
2.     Enter Ethernet interface view.
3.     Enable the 802.1X client feature.
dot1x supplicant enable
By default, the 802.1X client feature is disabled.
To ensure successful authentication, make sure the username and password configured on the device is consistent with the username and password configured on the authentication server.
3.     Configure an 802.1X client username.
dot1x supplicant username username
By default, no 802.1X client username is configured.
4.     Set an 802.1X client password.
dot1x supplicant password { cipher | simple } string
By default, no 802.1X client password is configured.
The following EAP authentication methods are available for the 802.1X client feature:
·     MD5-Challenge.
·     PEAP-MSCHAPv2.
·     PEAP-GTC.
·     TTLS-MSCHAPv2.
·     TTLS-GTC.
·     The following matrix shows the restrictions for the selection of authentication methods on the 802.1X client and the authenticator:
Authentication method specified on the 802.1X client
Packet exchange method specified on the authenticator
MD5-Challenge
·     EAP
·     CHAP
·     PEAP-MSCHAPv2
·     PEAP-GTC
·     TTLS-MSCHAPv2
·     TTLS-GTC
EAP
For information about 802.1X packet exchange methods, see "Configuring 802.1X."
·     Make sure the specified 802.1X client EAP authentication method is supported by the authentication server.
3.     Specify an 802.1X client EAP authentication method.
dot1x supplicant eap-method { md5 | peap-gtc | peap-mschapv2 | ttls-gtc | ttls-mschapv2 }
By default, an 802.1X client-enabled interface uses the MD5-Challenge EAP authentication.
At phase 1, packets sent to the authenticator are not encrypted. The use of an 802.1X client anonymous identifier prevents the 802.1X client username from being disclosed at phase 1. The 802.1X client-enabled device sends the anonymous identifier to the authenticator instead of the 802.1X client username. The 802.1X client username will be sent to the authenticator in encrypted packets at phase 2.
If no 802.1X client anonymous identifier is configured, the device sends the 802.1X client username at phase 1.
The configured 802.1X client anonymous identifier takes effect only if one of the following EAP authentication methods is used:
·     PEAP-MSCHAPv2.
·     PEAP-GTC.
·     TTLS-MSCHAPv2.
·     TTLS-GTC.
If the MD5-Challenge EAP authentication is used, the configured 802.1X client anonymous identifier does not take effect. The device uses the 802.1X client username at phase 1.
Do not configure the 802.1X client anonymous identifier if the vendor-specific authentication server cannot identify anonymous identifiers.
3.     Configure an 802.1X client anonymous identifier.
dot1x supplicant anonymous identify identifier
By default, no 802.1X client anonymous identifier is configured.
If the PEAP-MSCHAPv2, PEAP-GTC, TTLS-MSCHAPv2, or TTLS-GTC authentication is used, the 802.1X client authentication process is as follows:
·     Phase 1—The device acts as an SSL client to negotiate with the SSL server.
The SSL client uses the SSL parameters defined in the specified SSL client policy to establish a connection with the SSL server for negotiation. The SSL parameters include a PKI domain, supported cipher suites, and the SSL version. For information about SSL client policy configuration, see "Configuring SSL."
·     Phase 2—The device uses the negotiated result to encrypt and transmit the interchanged authentication packets.
If the MD5-Challenge authentication is used, the device does not use an SSL client policy during the authentication process.
3.     Specify an SSL client policy.
dot1x supplicant ssl-client-policy policy-name
By default, an 802.1X client-enabled interface uses the default SSL client policy.
Display and maintenance commands for 802.1X client
Display 802.1X client information.
display dot1x supplicant [ interface interface-type interface-number ]
802.1X client configuration examples
Example: Configuring the 802.1X client
As shown in Figure 2, the switch acts as the authenticator to perform 802.1X client authentication for the AP that connects to GigabitEthernet 1/0/1.
Perform the following tasks on the AP:
·     Enable the 802.1X client feature.
·     Set the following 802.1X client parameters:
¡     Configure the authentication username as aaa.
¡     Set the password to 123456 in plaintext form.
¡     Specify PEAP-MSCHAPv2 as the EAP authentication method.
Configure the switch to meet the following requirements:
·     Use RADIUS servers to perform authentication and authorization for the AP.
·     Enable EAP relay for the switch to communicate with the RADIUS servers.
·     Assign the AP to the ISP domain bbb.
·     Set the shared key to name for secure communication between the switch and the RADIUS servers.
·     Implement 802.1X port-based access control for the AP.
Figure 2 Network diagram
Configuring the AP
1.     Assign an IP address to each interface. (Details not shown.)
2.     Configure the 802.1X client feature:
# Specify PEAP-MSCHAPv2 as the 802.1X client EAP authentication method.
<AP> system-view
[AP] interface gigabitethernet 1/0/1
[AP-GigabitEthernet1/0/1] undo shutdown
[AP-GigabitEthernet1/0/1] dot1x supplicant eap-method peap-mschapv2
# Configure the 802.1X client username as aaa, and set the password to 123456 in plaintext form.
[AP-GigabitEthernet1/0/1] dot1x supplicant username aaa
[AP-GigabitEthernet1/0/1] dot1x supplicant password simple 123456
# Configure the 802.1X client anonymous identifier as bbb.
[AP-GigabitEthernet1/0/1] dot1x supplicant anonymous identify bbb
# Enable the 802.1X client feature.
[AP-GigabitEthernet1/0/1] dot1x supplicant enable
[AP-GigabitEthernet1/0/1] quit
Configuring the switch
This section contains commands for configuring RADIUS. For more information about these commands, see AAA commands in User Access and Authentication Command Reference.
1.     Configure the RADIUS servers, add user accounts, and make sure the authentication and authorization services can function correctly. (Details not shown.)
2.     Assign an IP address to each interface. (Details not shown.)
3.     Configure a RADIUS scheme:
# Create a RADIUS scheme named radius1 and enter RADIUS scheme view.
<Switch> system-view
[Switch] radius scheme radius1
# Specify the IP address of the primary authentication RADIUS server.
[Switch-radius-radius1] primary authentication 10.1.1.1
# Specify the IP address of the secondary authentication RADIUS server.
[Switch-radius-radius1] secondary authentication 10.1.1.2
# Specify the shared key between the switch and the authentication RADIUS servers.
[Switch-radius-radius1] key authentication simple name
4.     Configure the ISP domain:
# Create an ISP domain named bbb and enter ISP domain view.
[Switch] domain bbb
# Perform authentication and authorization for 802.1X clients in ISP domain bbb based on RADIUS scheme radius1.
[Switch-isp-bbb] authentication lan-access radius-scheme radius1
[Switch-isp-bbb] authorization lan-access radius-scheme radius1
[Switch-isp-bbb] accounting lan-access none
[Switch-isp-bbb] quit
5.     Configure 802.1X:
# Enable EAP relay.
[Switch] dot1x authentication-method eap
# Enable port-based access control on GigabitEthernet 1/0/1.
[Switch-GigabitEthernet1/0/1] dot1x port-method portbased
# Specify ISP domain bbb as the mandatory domain.
[Switch-GigabitEthernet1/0/1] dot1x mandatory-domain bbb
# Enable 802.1X on GigabitEthernet 1/0/1.
# Enable 802.1X globally.
[Switch] dot1x
# Display online 802.1X client information.
[Switch] display dot1x connection
Total connections: 1
User MAC address: 70f9-6dd7-d1e0
Username: aaa
Authentication domain: bbb
Authentication method: EAP
Initial VLAN: 1
Authorization untagged VLAN: N/A
Authorization tagged VLAN list: N/A
Authorization ACL ID: N/A
Termination action: N/A
Session timeout period: N/A
Online from: 2017/06/17 20:31:43
Online duration: 0h 1m 5s
