12-User Access and Authentication Command Reference
HomeSupportWirelessWA6500 Series Access PointsReference GuidesCommand ReferencesH3C WA6500A Series Access Points Cloud Mode Command References(R2605P09)-6W10012-User Access and Authentication Command Reference
02-WLAN IP snooping commands
02-WLAN IP snooping commands 71.70 KB
client ip-snooping acl
Use client ip-snooping acl to enable ACL-based learning of endpoint IP addresses.
Use undo client ip-snooping acl to restore the default.
client ip-snooping acl acl-number
ACL-based learning of endpoint IP addresses is disabled.
Service template view
acl-number: Specifies a basic ACL by its number. The value range for this argument is 2000 to 2999.
CAUTION
CAUTION:
After you configure a deny rule in the ACL to reject learning specific endpoint IP addresses, you must configure a permit rule following the deny rule. The permit rule must allow learning all endpoint IP addresses. Otherwise, the device cannot learn any endpoint IP addresses.
After connecting to a wireless network, a wireless endpoint will carry vendor information and an IP address obtained from that wireless network. If the endpoint accesses another vendor's network or another network later, the device on the new network might learn an incorrect IP address from the endpoint. To resolve this issue, enable ACL-based learning of endpoint IP addresses. This feature enables the device to learn IP addresses of new endpoints based on rules of the specified ACL.
When a wireless endpoint connects to a wireless network, the device performs the following task:
1.     Matches IP address of that wireless endpoint against the specified ACL.
2.     Determines whether to learn the endpoint IP address based on the match result as follows:
¡     If the endpoint IP address matches a permit rule in the ACL, the device will learn the endpoint IP address.
¡     If the endpoint IP address matches a deny rule or cannot match any rule in the ACL, the device will not learn the endpoint IP address.
This feature takes effect only if snooping ARP or ND packets is enabled.
If you execute this command multiple times, only the most recent configuration takes effect.
# Enable ACL-based learning of endpoint IP addresses.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] client ip-snooping acl 2000
client ipv4-snooping arp-learning enable
Use client ipv4-snooping arp-learning enable to enable snooping ARP packets.
Use undo client ipv4-snooping arp-learning enable to disable snooping ARP packets.
Snooping ARP packets is enabled.
# Disable snooping ARP packets.
[Sysname-wlan-st-service1] undo client ipv4-snooping arp-learning enable
client ipv4-snooping dhcp-learning enable
Use client ipv4-snooping dhcp-learning enable to enable snooping DHCPv4 packets.
Use undo client ipv4-snooping dhcp-learning enable to disable snooping DHCPv4 packets.
Snooping DHCPv4 packets is enabled.
# Disable snooping DHCPv4 packets.
[Sysname-wlan-st-service1] undo client ipv4-snooping dhcp-learning enable
client ipv4-snooping dhcp-learning timeout
Use client ipv4-snooping dhcp-learning timeout to set the timeout for IPv4 address learning through DHCP.
Use undo client ipv4-snooping dhcp-learning timeout to restore the default.
client ipv4-snooping dhcp-learning timeout time
The timeout is 0 and the system does not log off clients that fail to obtain an IPv4 address through DHCP.
time: Specifies the timeout in the range of 1 to 600 seconds.
With the timeout set, the system logs off clients that fail to obtain an IPv4 address through DHCP within the specified period.
Make sure the service template is enabled before you execute this command.
This configuration takes effect only on clients coming online afterwards from the AC.
# Set the timeout to 180 seconds for IPv4 address learning through DHCP.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] client ipv4-snooping dhcp-learning timeout 180
client ipv6-snooping dhcpv6-learning enable
Use client ipv6-snooping dhcpv6-learning enable to enable snooping DHCPv6 packets.
Use undo client ipv6-snooping dhcpv6-learning enable to disable snooping DHCPv6 packets.
Snooping DHCPv6 packets is enabled.
With this feature enabled, the device learns the client IPv6 addresses through DHCPv6 and records the learned client IPv6 addresses and the client MAC addresses as WLAN IP Snooping binding entries. These binding entries are primarily used for 802.1X authentication and MAC authentication accounting functions.
# Disable snooping DHCPv6 packets.
[Sysname-wlan-st-service1] client ipv6-snooping dhcpv6-learning enable
client ipv6-snooping nd-learning enable
Use client ipv6-snooping nd-learning enable to enable snooping ND packets.
Use undo client ipv6-snooping nd-learning enable to disable snooping ND packets.
Snooping ND packets is enabled.
With this feature enabled, the device learns the client IPv6 addresses through ND and records the learned client IPv6 addresses and the client MAC addresses as WLAN IP Snooping binding entries. These binding entries are primarily used for 802.1X authentication and MAC authentication accounting functions.
# Disable snooping ND packets.
[Sysname-wlan-st-service1] undo client ipv6-snooping nd-learning enable
display wlan statistics client-ip-conflict
Use display wlan statistics client-ip-conflict to display statistics about clients with conflict IP addresses.
# Display statistics about clients with conflict IP addresses.
<Sysname> display wlan statistics client-ip-conflict
IP             New-MAC/APID             Old-MAC/APID     Time
192.168.1.1    a4c1-5b79-fa5b/1     1111-e121-ff00/2     03-22 10:00:00
ff03::101      22d3-c5b7-a4b5/2     000d-88f8-0577/1     03-22 10:01:00
IP
Conflict IP obtained by the client.
New-MAC/APID
MAC address of the new client and the ID of the AP from which that client comes online.
Old-MAC/APID
MAC address of the old client and the ID of the AP to which the client is associated.
Time
Time when the client requested to add the IPCIM after it obtained a conflict IP address.
