12-User Access and Authentication Command Reference
HomeSupportWirelessWA6500 Series Access PointsReference GuidesCommand ReferencesH3C WA6500A Series Access Points Cloud Mode Command References(R2605P09)-6W10012-User Access and Authentication Command Reference
01-WLAN authentication commands
01-WLAN authentication commands 358.25 KB
WLAN authentication commands· 1
client url-redirect acl 1
client url-redirect enable· 1
client-security aaa attribute ip-snooping-method· 3
client-security accounting-delay time· 4
client-security accounting-restart trigger ipv4· 5
client-security accounting-start trigger 5
client-security accounting-update trigger 6
client-security authentication critical-vlan· 7
client-security authentication fail-vlan· 8
client-security authorization trigger byod· 9
client-security authentication-mode· 10
client-security authorization-fail offline· 11
client-security ignore-authentication· 12
client-security ignore-authorization· 13
client-security intrusion-protection action· 13
client-security intrusion-protection enable· 14
client-security intrusion-protection timer temporary-block· 15
client-security intrusion-protection timer temporary-service-stop· 16
display dot1x· 17
display dot1x connection· 20
display mac-authentication· 22
display mac-authentication connection· 25
display wlan client-security block-mac‌· 27
display wlan statistics accounting· 28
dot1x authentication-method· 29
dot1x domain· 30
dot1x domain-delimiter 31
dot1x eap· 32
dot1x handshake enable· 32
dot1x handshake secure enable· 33
dot1x max-user 34
dot1x re-authenticate enable· 35
dot1x retry· 36
dot1x timer 36
fail-permit enable· 38
fail-permit template· 40
mac-authentication authentication-method· 41
mac-authentication timer 42
mac-authentication domain· 43
mac-authentication max-user 44
reset dot1x statistics· 45
reset mac-authentication statistics· 45
wlan authentication optimization· 46
wlan client-security authentication clear-previous-connection· 47
Use client url-redirect acl to specify an ACL to match traffic that triggers URL redirection.
Use undo client url-redirect acl to restore the default.
client url-redirect acl acl-number
No ACL is specified to match traffic that triggers URL redirection.
Service template view
acl-number: Specifies an ACL by its number, in the range of 2000 to 3999.
By default, the device uses the authorization ACL deployed by the RADIUS server to match traffic that triggers URL redirection. Rule conflicts might exist if the authorization ACL is used by multiple features. To avoid undesirable redirection results, specify a dedicated ACL to match traffic that triggers URL redirection.
This command is configurable when the service template is disabled, and it takes effect after the service template is enabled.
# In service template service1, specify ACL 3111 to match traffic that triggers URL redirection.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] client url-redirect acl 3111
Use client url-redirect enable to enable URL redirection for WLAN clients.
Use undo client url-redirect enable to disable URL redirection for WLAN clients.
client url-redirect enable [ mode native [ https [ redirect-stop-timer seconds ] [ count number ] ] ]
URL redirection is disabled for WLAN clients
mode native: Sets the URL redirection mode to native mode. In this mode, the device redirects a MAC authentication client if it does not have a redirect URL access record for that client in the local cache.
https: Stops redirecting an HTTPS client if the number of its visits to the IP addresses of the redirect URL has reached the limit before the redirect stop timer expires.
redirect-stop-timer seconds: Sets the redirect stop timer in seconds. The value range for the seconds argument is 1 to 30 seconds and the default setting is 5 seconds.
count number: Sets the minimum number of visits to the IP addresses of the redirect URL. The value range for the number argument is 3 to 60 and the default setting is 3.
This command takes effect only on clients that use RADIUS-based MAC authentication.
In RADIUS-based MAC authentication, a client can pass authentication only if the RADIUS server has its credential information (username and password) and MAC address.
URL redirection facilitates a client to authenticate to the RADIUS server after it has failed a MAC authentication because the server does not have its credential information and MAC address. This feature redirects the client to a specified authentication webpage URL for portal authentication. After the client passes portal authentication, the RADIUS server records the client's credential information and MAC address. At the same time, the server uses DM requests to log off the client. At the next MAC authentication attempt, the client can pass MAC authentication. For information about DMs, see AAA configuration in User Access and Authentication Configuration Guide.
Typically, redirect decisions are made on the RADIUS server. If the RADIUS server contains MAC authentication information about a client, the client can pass authentication without being redirected to the redirect URL. To make sure all clients visit the redirect URL for purposes such as advertisement, set the URL redirection mode to native mode. In this mode, the device maintains a redirect URL access records for clients and makes a URL redirection decision based on the records, as follows:
·     Redirects the client if no URL access record is found for the client.
·     Stops redirecting an HTTP client if an URL access record exists for the client.
·     Stops redirecting an HTTPS client if the number of its visits to the IP addresses of the redirect URL has reached the specified limit before the redirect stop timer expires.
IMPORTANT
IMPORTANT:
The native redirection mode must be used together with the client url-redirect acl command.
# Enable native URL redirection for WLAN clients in service template service1. Stop redirecting an HTTPS client if that client has visited the IP addresses of the redirect URL for 10 times or more within 10 seconds.
[Sysname-wlan-st-service1] client url-redirect enable mode native https redirect-stop-timer 10 count 10
Use client-security aaa attribute ip-snooping-method to include the client IP snooping method in RADIUS packets.
Use undo client-security aaa attribute ip-snooping-method to restore the default.
The device does not include the client IP snooping method in RADIUS packets.
The device can obtain the IP address of a client by snooping packets such as DHCP and ARP packets. To help the RADIUS server determine whether the IP address of an 802.1X or MAC authentication client is assigned by a DHCP server, send the IP snooping method in RADIUS packets to the server.
The IP snooping method is encapsulated in the H3c-Ip-Source-Mod attribute (an extended RADIUS attribute with ID 221).
To identify the IP snooping method, the RADIUS server must support extended RADIUS attributes with a vendor ID of 25506. For more information, see AAA configuration in User Access and Authentication Configuration Guide.
# In service template service1, include the client IP snooping method in RADIUS packets.
[Sysname-wlan-st-service1] client-security aaa attribute ip-snooping-method
Use client-security accounting-delay time to configure the accounting delay.
Use undo client-security accounting-delay time to restore the default.
client-security accounting-delay time time [ no-ip-logoff ]
The device sends a start-accounting request for a client only when the device learns the IP address of that client.
time: Sets the accounting delay timer. The value range for the time argument is 1 to 600 seconds.
no-ip-logoff: Logs off a client if the device has failed to obtain the client IP address before the delay timer expires. If you do not specify this keyword, the device sends a start-accounting request immediately after the accounting delay timer expires.
The accounting delay timer operates in conjunction with an IP-based accounting-start trigger. The timer specifies the maximum interval for the device to learn the IP address of an 802.1X or MAC authenticated client before it takes the specified action.
The timer starts when a client passes 802.1X or MAC authentication. If the device has failed to learn an IP address that matches the IP-based accounting-start trigger before the accounting delay timer expires, the device takes either of the following actions:
·     Sends a start-accounting request immediately if the no-ip-logoff action is not specified.
·     Logs off the client if the no-ip-logoff action is specified.
Configure the accounting delay timer depending on the typical amount of time for the device to learn the IP address of a client. As a best practice, increase the delay timer on a low-performance network.
The timer takes effect only on clients that come online after the timer is configured.
# Set the accounting delay timer to 15 seconds in service template service1. Configure the device to log off a client if it has failed to learn the required client IP address before the delay timer expires.
[Sysname-wlan-st-service1] client-security accounting-delay time 15 no-ip-logoff
Use client-security accounting-restart trigger ipv4 to enable the IPv4 address-based accounting-restart trigger for clients.
Use undo client-security accounting-restart trigger ipv4 to disable the IPv4 address-based accounting-restart trigger for clients.
client-security accounting-restart trigger ipv4 [ delay interval ]
The IPv4 address-based accounting-restart trigger is disabled.
delay interval: Sets the delay for the device to send a start-accounting request for another accounting cycle after it sends a stop-accounting request. The value range for the interval argument is 0 to 20 seconds. The default delay time is 15 seconds.
The IPv4 address-based accounting-restart trigger applies to 802.1X and MAC authentication clients.
This trigger restarts accounting for a client by sending a stop-accounting request and then a start-accounting request to the accounting server when the IPv4 address of the client changes.
This trigger has higher priority than the accounting-update trigger configured for IPv4 by using the client-security accounting-update trigger command.
This trigger is configurable when the service template is disabled, and it takes effect after the service template is enabled.
# Enable the IPv4 address-based accounting-restart trigger in service template service1.
[Sysname-wlan-st-service1] client-security accounting-restart trigger ipv4
Use client-security accounting-start trigger to configure an accounting-start trigger for clients.
Use undo client-security accounting-start trigger to restore the default.
client-security accounting-start trigger { ipv4 | ipv4-ipv6 | ipv6 | none }
The accounting-start trigger is based on IPv4 address type.
ipv4: Sends a start-accounting request if an 802.1X or MAC authenticated client uses an IPv4 address.
ipv4-ipv6: Sends a start-accounting request if an 802.1X or MAC authenticated client uses an IPv4 or IPv6 address.
ipv6: Sends a start-accounting request if an 802.1X or MAC authenticated client uses an IPv6 address.
none: Sends a start-accounting request when a client passes authentication without examining its IP address type.
This command takes effect only on clients that have passed 802.1X or MAC authentication. For more information about accounting, see AAA in Security Configuration Guide.
For the accounting-start trigger to take effect, follow these guidelines:
·     If the trigger is IP address type based, you must enable learning IP addresses of that type. For information about wireless client IP address learning, see WLAN IP snooping configuration in User Access and Authentication Configuration Guide.
·     The IP-based trigger must match the requirement of the accounting server for the IP version.
The trigger takes effect only on clients that come online after the trigger is configured.
# Configure an IPv4 address-based accounting-start trigger in service template service1.
[Sysname-wlan-st-service1] client-security accounting-start trigger ipv4
client ipv4-snooping arp-learning enable
client ipv4-snooping dhcp-learning enable
client ipv6-snooping dhcpv6-learning enable
client ipv6-snooping nd-learning enable
Use client-security accounting-update trigger to specify an event-based accounting-update trigger.
Use undo client-security accounting-update trigger to restore the default.
client-security accounting-update trigger { ipv4 | ipv4-ipv6 | ipv6 }
No event-based accounting-update trigger is configured. The device sends update-accounting requests to the accounting server only regularly at server-assigned or user-defined real-time accounting intervals.
ipv4: Sends an update-accounting request when the IPv4 address of an online 802.1X or MAC authenticated client changes.
ipv4-ipv6: Sends an update-accounting request when the IPv4 or IPv6 address of an online 802.1X or MAC authenticated client changes.
ipv6: Sends an update-accounting request when the IPv6 address of an online 802.1X or MAC authenticated client changes.
Use the accounting-update trigger in conjunction with the accounting-start trigger. The accounting-update trigger takes effect only if you have configured the accounting-start trigger by using the client-security accounting-start trigger command.
In addition to the event-based accounting-update trigger, you can set a regular accounting-update interval by using the timer realtime-accounting command.
The accounting-update trigger takes effect only on clients that come online after the trigger is configured.
# Configure an IPv4 address change-based accounting-update trigger in service template service1.
[Sysname-wlan-st-service1] client-security accounting-update trigger ipv4
Use client-security authentication critical-vlan to configure a critical VLAN for a service template.
Use undo client-security authentication critical-vlan to restore the default.
client-security authentication critical-vlan vlan-id
No critical VLAN exists for a service template.
vlan-id: Specifies the ID of the critical VLAN, in the range of 1 to 4094.
The WLAN critical VLAN accommodates clients that have failed WLAN authentication because all RADIUS servers in their ISP domains are unreachable. Clients in the critical VLAN can access a limited set of network resources depending on the configuration.
The authenticator reauthenticates a client in the critical VLAN at the interval of 30 seconds.
·     If the client passes the reauthentication, the authenticator assigns the client to the authorization VLAN. If no authorization VLAN is configured, the client is assigned to the initial VLAN.
·     If the client fails the reauthentication because all the RADIUS servers are unreachable, the client is still in the critical VLAN.
·     If the client fails the reauthentication for any reason other than unreachable servers, the device assigns the client to the Auth-Fail VLAN. If no Auth-Fail VLAN is configured, the device handles the client depending on the intrusion protection setting. If the intrusion protection feature is not configured, the device logs off the client.
The critical VLAN feature does not take effect on clients that use RSNA. When these clients fail authentication because all the RADIUS servers are unreachable, the authenticator directly logs off the clients.
# Configure VLAN 10 as the critical VLAN in service template 1.
[Sysname-wlan-st-service1] client-security authentication critical-vlan 10
Use client-security authentication fail-vlan to configure an Auth-Fail VLAN for a service template.
Use undo client-security authentication fail-vlan to restore the default.
client-security authentication fail-vlan vlan-id
No Auth-Fail VLAN exists for a service template.
vlan-id: Specifies the ID of the Auth-Fail VLAN, in the range of 1 to 4094. Make sure the VLAN has been created.
The WLAN Auth-Fail VLAN accommodates clients that have failed WLAN authentication because of the failure to comply with the organization security strategy. For example, the VLAN accommodates clients that have entered invalid passwords. The Auth-Fail VLAN does not accommodate WLAN clients that have failed authentication for authentication timeouts or network connection problems.
# Configure VLAN 10 as the Auth-Fail VLAN in service template 1.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] client-security authentication fail-vlan 10
Use client-security authorization trigger byod to enable the BYOD authorization trigger.
Use undo client-security authorization trigger byod to disable the BYOD authorization trigger.
The BYOD authorization trigger is disabled.
This command enables the access device to trigger BYOD authorization for an authenticated client after the device obtains that client's BYOD information, including its IP address. When BYOD authorization is triggered, the session-timeout timer assigned to the client restarts, extending the amount of time that the client can stay online before a reauthentication is required. On a low performance network, it might take so much time for the device to obtain the IP address of a client that the client's extended amount of online time becomes undesirable.
As a best practice to avoid this undesirable issue, use this command only if BYOD authorization is required and make sure the network performance is good. For more information about BYOD authorization, see AAA configuration in User Access and Authentication Configuration Guide.
# Enable the BYOD authorization trigger in service template service1.
[Sysname-wlan-st-service1] client-security authorization trigger byod
Use client-security authentication-mode to set the authentication mode for WLAN clients.
Use undo client-security authentication-mode to restore the default.
client-security authentication-mode { dot1x | dot1x-then-mac | mac | mac-and-dot1x | mac-then-dot1x | oui-then-dot1x }
The WLAN authentication mode is Bypass. The device does not perform authentication for WLAN clients.
dot1x: Performs only 802.1X authentication for the attached clients. A client cannot access the network if it fails 802.1X authentication.
dot1x-then-mac: Performs 802.1X authentication for the attached clients first, and then MAC authentication if they fail 802.1X authentication. If a client passes 802.1X authentication, MAC authentication is not performed. A client cannot access the network if it does not pass either authentication.
mac: Performs only MAC authentication for the attached clients. A client cannot access the network if it fails MAC authentication.
mac-and-dot1x: Performs MAC authentication for the attached clients first, and then 802.1X authentication. The attached clients must pass MAC authentication and then 802.1X authentication before they can access the network. A client cannot access the network if it fails MAC authentication or 802.1X authentication.
mac-then-dot1x: Performs MAC authentication for the attached clients first, and then 802.1X authentication if they fail MAC authentication. If a client passes MAC authentication, 802.1X authentication is not performed. A client cannot access the network if it does not pass either authentication.
oui-then-dot1x: Performs OUI authentication for the attached clients first, and then 802.1X authentication if they fail OUI authentication. If a client passes OUI authentication, 802.1X authentication is not performed. A client cannot access the network if it does not pass either authentication.
A service template allows access of multiple authenticated clients in any authentication mode. To set the maximum number of 802.1X clients, use the dot1x max-user command. To set the maximum number of MAC authentication clients, use the mac-authentication max-user command.
The dot1x-then-mac, mac-then-dot1x, and oui-then-dot1x modes require iNode. To use such a mode, make sure the wireless endpoints have been installed with the iNode client.
# Set the authentication mode to mac for WLAN clients in service template service1.
[Sysname-wlan-st-service1] client-security authentication-mode mac
Use client-security authorization-fail offline to enable the authorization-fail-offline feature.
Use undo client-security authorization-fail offline to disable the authorization-fail-offline feature.
The authorization-fail-offline feature is disabled.
The authorization-fail-offline feature logs off WLAN clients that fail ACL or user profile authorization.
A WLAN client fails ACL or user profile authorization in the following situations:
·     The device or server fails to authorize the specified ACL or user profile to the client.
·     The authorized ACL or user profile does not exist.
If this feature is disabled, the device does not log off WLAN clients that fail ACL or user profile authorization. However, the device outputs logs to report the failure.
# Enable the authorization-fail-offline feature for service template service1.
[Sysname-wlan-st-service1] client-security authorization-fail offline
Use client-security ignore-authentication to configure the device to ignore the 802.1X or MAC authentication failures.
Use undo client-security ignore-authentication to restore the default.
The device does not ignore the authentication failures for wireless clients that use 802.1X authentication or RADIUS-based MAC authentication.
This command applies to the following clients:
·     Clients that use 802.1X authentication.
This command enables the device to ignore the 802.1X authentication failures and allow clients that have failed 802.1X authentication to come online.
·     Clients that use both RADIUS-based MAC authentication and portal authentication.
Typically, a client must pass MAC authentication and portal authentication in turn to access network resources. The client provides username and password each time portal authentication is performed.
This command simplifies the authentication process for a client as follows:
¡     If the RADIUS server already records the client's MAC authentication information, the client passes MAC authentication. The device allows the client to access network resources without performing portal authentication.
¡     If the RADIUS server does not record the client's MAC authentication information, the client fails MAC authentication. The device ignores the MAC authentication failure and performs portal authentication for the client. If the client passes portal authentication, it can access network resources. The MAC address of the portal authenticated client will be recorded as MAC authentication information on the RADIUS server.
For 802.1X clients that use RSN to roam to a new AP, do not use this command.
# Configure the device to ignore 802.1X or MAC authentication failures in service template service1.
[Sysname-wlan-st-service1] client-security ignore-authentication
Use client-security ignore-authorization to configure the device to ignore the authorization information received from the authentication server (a RADIUS server or the local device).
Use undo client-security ignore-authorization to restore the default.
The device uses the authorization information from the server.
After a client passes RADIUS or local authentication, the server performs authorization based on the authorization attributes configured for the user account. For example, the server can assign a VLAN. If you do not want the device to use these authorization attributes for clients, configure this command to ignore the authorization information from the server. Authorization information that can be ignored include VLAN and CAR rate limit.
# Configure the device to ignore the authorization information from the authentication server for service template service1.
[Sysname-wlan-st-service1] client-security ignore-authorization
Use client-security intrusion-protection action to configure the intrusion protection action that the device takes when intrusion protection detects illegal frames.
Use undo client-security intrusion-protection action to restore the default.
client-security intrusion-protection action { service-stop | temporary-block | temporary-service-stop }
The intrusion protection action is temporary-block.
service-stop: Stops the BSS where an illegal frame is received until the BSS is enabled manually on the radio interface.
temporary-block: Adds the source MAC address of an illegal frame to the blocked MAC address list for a period. To set the period, use the client-security intrusion-protection timer temporary-block command.
temporary-service-stop: Stops the BSS where an illegal frame is received for a period. To set the period, use the client-security intrusion-protection timer temporary-service-stop command.
For this command to take effect, you must also use the client-security intrusion-protection enable command to enable the intrusion protection feature.
# Configure the device to stop the BSS where intrusion protection detects illegal frames for service template service1.
[Sysname-wlan-st-service1] client-security intrusion-protection enable
[Sysname-wlan-st-service1] client-security intrusion-protection action service-stop
Use client-security intrusion-protection enable to enable the intrusion protection feature.
Use undo client-security intrusion-protection enable to disable the intrusion protection feature.
The intrusion protection feature is disabled.
When the device receives an association request from an illegal client, the device takes the predefined protection action on the BSS where the request is received. A client is illegal if its MAC address fails WLAN authentication. To set the protection action, use the client-security intrusion-protection action command.
# Enable the intrusion protection feature for service template service1.
Use client-security intrusion-protection timer temporary-block to set the period during which a MAC address is blocked by intrusion protection.
Use undo client-security intrusion-protection timer temporary-block to restore the default.
client-security intrusion-protection timer temporary-block time
An illegal MAC address is blocked for 180 seconds.
time: Specifies the period during which a MAC address is blocked. The value range is 60 to 300 seconds.
This command takes effect only when the intrusion protection action is temporary-block.
If you change the blocking period after the service template is enabled, the new setting takes effect on the subsequent detected illegal packets.
# Configure service template service1 to block illegal MAC addresses for 120 seconds.
[Sysname-wlan-st-service1] client-security intrusion-protection action temporary-block
[Sysname-wlan-st-service1] client-security intrusion-protection timer temporary-block 120
Use client-security intrusion-protection timer temporary-service-stop to set the BSS silence period for intrusion protection.
Use undo client-security intrusion-protection timer temporary-service-stop to restore the default.
client-security intrusion-protection timer temporary-service-stop time
The BSS silence period for intrusion protection is 20 seconds.
time: Specifies the period during which a BSS is disabled. The value range is 10 to 300 seconds.
This command takes effect only when the intrusion protection action is temporary-service-stop.
If you change the BSS silence period after the service template is enabled, the new setting takes effect on the subsequent detected illegal packets.
# Set the BSS silence period to 30 seconds for intrusion protection in service template service1.
[Sysname-wlan-st-service1] client-security intrusion-protection action temporary-service-stop
[Sysname-wlan-st-service1] client-security intrusion-protection timer temporary-service-stop 30
display dot1x
Use display dot1x to display information about 802.1X.
display dot1x [ sessions | statistics ] [ ap ap-name [ radio radio-id ] ]
sessions: Displays 802.1X session information.
statistics: Displays 802.1X statistics.
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify this option, this command displays 802.1X information for all radios on the specified AP.
If you do not specify the sessions keyword or the statistics keyword, this command displays all information about 802.1X, including session information, statistics, and settings.
# Display all information about 802.1X.
<Sysname> display dot1x
 Global 802.1X parameters:
   802.1X authentication                      : Enabled
   M-LAG member configuration conflict        : Unknown
   EAP authentication                         : Enabled
   Max-tx period                              : 30 s
   Handshake period                           : 15 s
   Offline detect period                      : 300 s
   Quiet timer                                : Disabled
         Quiet period                         : 60 s
   Supp timeout                               : 30 s
   Server timeout                             : 100 s
   Reauth period                              : 3600 s
   Max auth requests                          : 2
   SmartOn supp timeout                       : 30 s
   SmartOn retry counts                       : 3
   User aging period for Auth-Fail VLAN       : 1000 s
   User aging period for critical VLAN        : 1000 s
   User aging period for guest VLAN           : 1000 s
   EAD assistant function                     : Disabled
       URL                                    : http://www.dwsoft.com
       Free IP                                : 6.6.6.0         255.255.255.0
       EAD timeout                            : 30 min
   Domain delimiter                           : @
   Max EAP-TLS fragment (to-server)           : 400 bytes
 Online 802.1X wired users                    : 1
 Online 802.1X wireless users                 : 1
AP name: AP1  Radio ID: 1  SSID: wlan_dot1x_ssid
   BSSID                      : 1111-1111-1111
   Handshake                  : Enabled
   Handshake security         : Disabled
   Periodic reauth            : Disabled
   Mandatory auth domain      : Not configured
   Max online users           : 256
   EAPOL packets: Tx 3, Rx 3
   Sent EAP Request/Identity packets : 1
        EAP Request/Challenge packets: 1
        EAP Success packets: 1
        EAP Failure packets: 0
   Received EAPOL Start packets : 1
        EAPOL LogOff packets: 1
        EAP Response/Identity packets : 1
        EAP Response/Challenge packets: 1
        Error packets: 0
   Online 802.1X users: 1
          MAC address         Auth state
          0001-0000-0002      Authenticated
Global 802.1X configuration.
Whether 802.1X is enabled globally.
Configuration check result on the two M-LAG member devices.
·     Conflicted.
·     Not conflicted.
·     Unknown.
CHAP authentication
Performs EAP termination and uses CHAP to communicate with the RADIUS server.
EAP authentication
Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server.
PAP authentication
Performs EAP termination and uses PAP to communicate with the RADIUS server.
Max-tx period
Username request timeout in seconds.
Handshake period
Handshake timeout in seconds.
Offline detect timeout in seconds.
Quiet timer
Enabling status of the quiet timer.
Quiet period
Quiet timeout in seconds.
Supp timeout
Client timeout in seconds.
Server  timeout
Authentication server timeout in seconds.
Reauth period
Re-authentication server timer in seconds.
Max auth requests
Maximum number of attempts for sending an authentication request to a client.
SmartOn switch ID
Switch ID of SmartOn.
SmartOn client authentication timeout in seconds.
User aging time in the Auth-Fail VLAN.
User aging time in the critical VLAN.
User aging time in the guest VLAN.
Enabling status of the EAD assistant function.
URL
Redirect URL for unauthenticated users using a Web browser to access the network.
Free IP
Network segment accessible to unauthenticated users.
EAD timeout
EAD rule timeout in minutes.
Domain delimiter
Domain delimiters supported by the device.
Maximum length of an EAP-TLS fragment carried in an authentication packet sent to the authentication server.
This field displays N/A if the maximum length is not specified.
Total number of online 802.1X wired users and 802.1X wired users that are initiating 802.1X authentication.
Total number of online 802.1X wireless users and 802.1X wireless users that are initiating 802.1X authentication.
AP name
AP name.
Radio ID
Radio ID.
Enabling status of 802.1X on the port.
Handshake
Enabling status of online user handshake.
Handshake security
Enabling status of handshake security.
Periodic reauth
Enabling status of periodic re-authentication.
Mandatory authentication domain on the port.
Max online users
Maximum number of concurrent users on the port.
EAPOL packets
Number of EAPOL packets. Tx represents sent packets and Rx represents received packets.
Number of sent EAP Request/Identity packets.
Number of sent EAP Request/Challenge packets.
EAP Success packets
Number of sent EAP Success packets.
EAP Failure packets
Number of sent EAP Failure packets.
Number of received EAPOL Start packets.
Number of received EAPOL LogOff packets.
Number of received EAP Response/Identity packets.
Number of received EAP Response/Challenge packets.
Error packets
Number of received error packets.
Online 802.1X users
Total number of online 802.1X users and 802.1X users that are being authenticated on the port.
MAC address
MAC address of the 802.1X user.
Auth state
Authentication status of the 802.1X user.
Use display dot1x connection to display information about online 802.1X users.
display dot1x connection [ ap ap-name [ radio radio-id ] | slot slot-number | user-mac mac-address | user-name name-string ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify this option, the command displays information about all 802.1X online users.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify this option, this command displays online 802.1X user information for all radios on the specified AP.
slot slot-number: Specifies a member device by its member ID. If you do not specify a member device, this command displays online 802.1X user information on all member devices.
user-mac mac-address: Specifies an 802.1X user by its MAC address. The mac-address argument represents the MAC address of the user, in the form of H-H-H. If you do not specify this option, the command displays information about all 802.1X online users.
user-name name-string: Specifies an 802.1X user by its name. The name-string argument represents the username, a case-sensitive string of 1 to 253 characters. If you do not specify this option, the command displays information about all 802.1X online users.
# Display information about all online 802.1X users.
<Sysname> display dot1x connection
Total connections: 1
Slot ID: 1
User MAC address                : 0015-e9a6-7cfe
AP name                         : ap1
Radio ID                        : 1
SSID                            : wlan_dot1x_ssid
BSSID                           : 0015-e9a6-7cf0
User name                       : ias
Anonymous username              : test
Authentication domain           : 1
IPv4 address                    : 192.168.1.1
IPv6 address                    : 2000:0:0:0:1:2345:6789:abcd
Authentication method           : CHAP
Initial VLAN                    : 1
Authorization VLAN              : N/A
Authorization ACL number        : 3001
Authorization user profile      : N/A
Authorization CAR               : N/A
Authorization URL               : http://oauth.h3c.com
Authorization IPv6 URL          : N/A
Termination action              : Default
Session timeout last from     : 2023/05/30 17:32:42
Session timeout period        : 86400 s
Online from                   : 2023/05/30 11:20:41
Online duration               : 6h 18m 39s
Total connections
Total number of online 802.1X users.
User MAC address
MAC address of the user.
AP name
AP name.
Radio ID
Radio ID.
Username
Username.
Anonymous username
Username of the anonymous user. This field displays N/A if the anonymous user name is not specified.
ISP domain used for 802.1X authentication.
IPv4 address
IPv4 address of the user.
This field is not displayed if the system fails to obtain the IPv4 address of the user.
IPv6 address
IPv6 address of the user.
This field is not displayed if the system fails to obtain the IPv6 address of the user.
802.1X authentication method:
·     CHAP—Performs EAP termination and uses CHAP to communicate with the RADIUS server.
·     EAP—Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server.
·     PAP—Performs EAP termination and uses PAP to communicate with the RADIUS server.
Initial VLAN
Initial VLAN.
Authorization VLAN
Authorized VLAN.
Number of the authorized ACL. If no ACL is authorized, this field displays N/A. If ACL authorization fails, this field displays (Not effective) after the ACL number.
User profile authorized to the user.
Authorization CAR
If no authorization CAR attributes are assigned, this field displays N/A.
Authorization CAR attributes assigned by the server:
·     Average input rate—Average rate of inbound traffic in kbps.
·     Peak input rate—Peak rate of inbound traffic in kbps.
·     Average output rate—Average rate of outbound traffic in kbps.
·     Peak output rate—Peak rate of outbound traffic in kbps.
If the authorization fails, the system displays (NOT effective).
If only the average input/output rate is authorized, the peak input/output rate is the same as the average rate by default. In the current software version, the system does not support the server to authorize only the input or output peak rate.
Authorization URL
Authorized redirect URL.
Authorized IPv6 redirect URL.
Termination action
Action attribute assigned by the server to terminate the user session:
·     Default—Logs off the online 802.1X user when the session timeout timer expires. This attribute does not take effect when 802.1X periodic re-authentication is enabled and the periodic reauthentication timer value is shorter than the session timeout.
·     Radius-request—Reauthenticates the online user when the session timeout timer expires.
If the device performs local authentication, this field displays N/A.
Session timeout.
Session timeout assigned by the server, in seconds. When the timer expires for a session, the session is deleted. The action to take on the user depends on the value of the Termination action field.
Online from
Time at which the user came online.
Online duration
Online duration of the user.
Use display mac-authentication to display MAC authentication settings and statistics.
display mac-authentication [ ap ap-name [ radio radio-id ] ]
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify this option, this command displays MAC authentication information for all radios on the specified AP.
If you do not specify any parameters, this command displays all MAC authentication information, including the global settings, port-specific settings, MAC authentication packet statistics, and authenticated user statistics.
# Display MAC authentication information.
   MAC authentication                         : Enabled
   Authentication method                      : PAP
   Username format                            : MAC address in lowercase(xx-xx-xx-xx-xx-xx)
           Username                           : mac
           Password                           : Not configured
   MAC range accounts                         : 0
            MAC address          Mask                 Username
   Quiet period                               : 60 s
   Authentication domain                      : Not configured, use default domain
   HTTP proxy port list                       : Not configured
   HTTPS proxy port list                      : Not configured
   Online MAC-auth wired users                  : 0
   Online MAC-auth wireless users               : 1
 Silent MAC users:
          MAC address       VLAN ID  From port               Port index
 AP name: AP1  Radio ID: 1  SSID: wlan_maca_ssid
   Authentication attempts    : successful 1, failed 0
   Current online users       : 2
          0001-0000-0003    Unauthenticated
MAC authentication
Enabling status of MAC authentication.
MAC authentication method:
·     CHAP.
·     PAP.
·     Conflicted.
·     Not conflicted.
·     Unknown.
Username format
Username format for MAC authentication:
·     If a MAC-based account is used, this field displays the format settings for the username. For example, MAC address in lowercase(xx-xx-xx-xx-xx-xx) indicates that the MAC address is in six-section format, and letters are in lower case.
·     If a fixed username account is used, this field displays Fixed account.
Username
Username
·     If a MAC-based account is used, this field displays mac. It indicates that the device uses the MAC address of each user as the username and password for MAC authentication.
·     If a fixed account is used, this field displays the configured username. By default, the username is mac.
Password
Password corresponding to the username.
·     If a MAC-based account is used, this field displays Not configured.
·     If a fixed account is used, this field displays a string of asterisks (******).
MAC range accounts
List of MAC authentication user account information for the specified range of MAC addresses.
MAC address
Specified MAC address.
Mask
MAC address mask.
Username
Username of the MAC authentication user.
Quiet period
Server timeout
Server connection timeout in seconds.
Reauth period
MAC authentication domain specified in system view.
If no authentication domain is specified in system view, this field displays Not configured, use default domain.
HTTP proxy server port.
HTTPS proxy server port.
Total number of online wired users and wired users that are initiating MAC authentication.
Total number of online wireless users and wireless users that are initiating MAC authentication.
Silent MAC users
Information about silent MAC addresses, including added silent MAC addresses on the device and blackhole MAC addresses issued by the server.
MAC address
Silent MAC address.
VLAN ID
ID of the VLAN to which the silent MAC address belongs.
From port
Name of the port that marks the MAC address as a silent MAC address.
Port index
Index of the port that marks the MAC address as a silent MAC address.
AP name
AP name.
Radio ID
Radio ID.
MAC authentication
Enabling status of MAC authentication on the port.
·     Enabled.
·     Enabled (but NOT effective)— MAC authentication does not take effect on the port because all ACL resources on the device are fully utilized.
·     Disabled.
MAC authentication domain used by users on the port.
Max online users
Authentication attempts: successful 1, failed 0
MAC authentication statistics, including the number of successful and unsuccessful authentication attempts.
MAC address
MAC address of the access user.
Auth state
Authentication status of the access user:
·     Authenticated.
·     Unauthenticated.
Use display mac-authentication connection to display information about online MAC authentication users.
display mac-authentication connection [ ap ap-name [ radio radio-id ] | slot slot-number | user-mac mac-address | user-name user-name ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify this option, the command displays information about all MAC authentication users.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify this option, this command displays MAC authentication information for all radios on the specified AP. If you do not specify this option, the command displays information about all MAC authentication users.
slot slot-number: Specifies a member device by its member ID. If you do not specify this option, the command displays information about MAC authentication users on all member devices.
user-mac mac-address: Specifies a MAC authentication user by its MAC address. The mac-address argument represents the MAC address of the user, in the form of H-H-H. If you do not specify this option, the command displays information about all MAC authentication users.
user-name name-string: Specifies a MAC authentication user by its username. The name-string argument represents the username (excluding or including the domain name), a case-sensitive string of 1 to 55 characters. If you do not specify this option, the command displays information about all MAC authentication users.
# Display information about all online MAC authentication users.
Slot ID: 0
AP name                       : ap1
Radio ID                      : 1
User name                     : ias
Initial VLAN                  : 1
Authorization VLAN            : 100
Authorization URL             : N/A
Authroization IPv6 URL        : N/A
Termination action            : Radius-request
Total connections
Total number of online MAC authentication users.
User MAC address
Access interface
Access interface of the user.
AP name
AP name.
Radio ID
Radio ID.
Username
Username.
ISP domain used for MAC authentication.
Initial VLAN
Initial VLAN.
Authorization  VLAN
Authorized VLAN.
Name of the authorization user profile.
Authorization CAR
Authorization URL
Termination action
·     Default—Logs off the user when the session timeout timer expires.
·     Radius-Request—Re-authenticates the online user when the session timeout timer expires.
Session timeout.
Online from
Time at which the MAC authentication user came online.
Online duration
Online duration of the MAC authentication user.
Use display wlan client-security block-mac to display blocked MAC address information for WLAN clients.
A MAC address that fails authentication is added to the blocked MAC address list when the intrusion protection action is temporary-block.
# Display information about all blocked MAC addresses.
<Sysname> display wlan client-security block-mac
MAC address         AP ID       RADIO ID     BSSID
0002-0002-0002      1           1            00ab-0de1-0001
000d-88f8-0577      1           1            0ef1-0001-02c1
Total entries: 2
Table 5 Command output
MAC address
Blocked MAC address, in the format of H-H-H.
AP ID
AP ID of the blocked MAC address.
RADIO ID
Radio ID of the blocked MAC address.
BSSID
BSS ID of the blocked MAC address, in the format of H-H-H.
Total entries
Number of blocked MAC addresses.
Related commands:
Use display wlan statistics accounting to display RADIUS accounting packet statistics about wireless clients.
# Display RADIUS accounting packet statistics about wireless clients.
<Sysname> display wlan statistics accounting
Account start request         : 1
Account start response        : 1
Account update request        : 3
Account update response       : 3
Account stop request          : 1
Account stop response         : 1
Table 6 Command output
Number of sent RADIUS start-accounting request packets.
Number of received RADIUS start-accounting response packets.
Number of sent RADIUS real-time accounting request packets.
Number of received RADIUS real-time accounting response packets.
Number of sent RADIUS stop-accounting request packets.
Number of received RADIUS stop-accounting response packets.
Use dot1x authentication-method to specify the 802.1X authentication method.
Use undo dot1x authentication-method to restore the default.
The access device performs EAP rely and uses EAP to communicate with the RADIUS server.
chap: Configures the access device to perform Extensible Authentication Protocol (EAP) termination and use the Challenge Handshake Authentication Protocol (CHAP) to communicate with the RADIUS server.
eap: Configures the access device to relay EAP packets, and supports any of the EAP authentication methods to communicate with the RADIUS server.
pap: Configures the access device to perform EAP termination and use the Password Authentication Protocol (PAP) to communicate with the RADIUS server.
The access device terminates or relays EAP packets.
·     In EAP termination mode—The access device re-encapsulates and sends the authentication data from the client in standard RADIUS packets to the RADIUS server. The device performs either CHAP or PAP authentication with the RADIUS server. In this mode, the RADIUS server supports only MD5-Challenge EAP authentication and the username and password EAP authentication initiated by an iNode client.
¡     PAP transports usernames and passwords in plaintext format. The authentication method applies to scenarios that do not require high security. To use PAP, the client can be an iNode 802.1X client.
¡     CHAP transports usernames in plaintext format and passwords in ciphertext format over the network. CHAP is more secure than PAP. Compared with PAP, CHAP provides better confidentiality and is more secure and reliable.
·     In EAP relay mode—The access device relays EAP packets between the client and the RADIUS server. The EAP relay mode supports multiple EAP authentication methods, such as MD5-Challenge, EAP-TLS, and PEAP. To use this mode, make sure the RADIUS server uses the same EAP authentication method as the client.
When a remote RADIUS server is used, make sure the RADIUS server supports the PAP, CHAP, or EAP method.
If this mode is used, the user-name-format configuration in RADIUS scheme view does not take effect.
# Enable the access device to terminate EAP packets and perform PAP authentication with the RADIUS server.
[Sysname] dot1x authentication-method pap
display dot1x
dot1x domain
Use dot1x domain to specify an authentication domain for 802.1X clients in a service template.
Use undo dot1x domain to restore the default.
dot1x domain domain-name
undo dot1x domain
No authentication domain is specified for 802.1X clients in a service template.
domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters.
802.1X chooses an authentication domain for WLAN clients in the following order:
1.     Authentication domain specified in the service template.
2.     Domain specified by username.
3.     Default authentication domain.
# Specify ISP domain my-domain as the authentication domain for 802.1X clients in service template service1.
[Sysname-wlan-st-service1] dot1x domain my-domain
Use dot1x domain-delimiter to specify a set of domain name delimiters supported by the device.
Use undo dot1x domain-delimiter to restore the default.
dot1x domain-delimiter string
The device supports only the at sign (@) delimiter for 802.1X users.
string: Specifies a set of 1 to 16 domain name delimiters for 802.1X users. No space is required between delimiters. Available delimiters include the at sign (@), backslash (\), dot (.), and forward slash (/). To use backslash (\) as the domain name delimiter, you must enter the escape character (\) along with the backslash (\) sign. For example, to use the backslash delimiter, specify \\.
802.1X supports using at sign (@), backslash (\), dot (.), and forward slash (/) as the domain name delimiter for 802.1X authentication users. Usernames that include domain names can use the format of username@domain-name, domain-name\username, username.domain-name, or username/domain-name. If a username string contains multiple configured delimiters, the device takes the rightmost delimiter in the username string as the domain name delimiter. For example, if you configure the forward slash (/), dot (.), and backslash (\) as delimiters, the domain name delimiter for the username string 121.123/22\@abc is the backslash (\). The username is @abc and the domain name is 121.123/22.
The delimiter set you configured overrides the default setting. If the at sign (@) is not included in the delimiter set, the device does not support the 802.1X users that use this sign as the domain name delimiter.
# Specify the at sign (@) and forward slash (/) as domain name delimiters.
[Sysname] dot1x domain-delimiter @/
display dot1x
dot1x eap
Use dot1x eap to specify the EAP mode for 802.1X authentication.
Use undo dot1x eap to restore the default.
dot1x eap { extended | standard }
undo dot1x eap
The EAP mode is standard for 802.1X authentication.
extended: Specifies the extended EAP mode. This mode requires the device to interact with clients according to the provisions and packet format defined by the proprietary EAP protocol.
standard: Specifies the standard EAP mode. This mode requires the device to interact with clients according to the provisions and packet format defined by the standard EAP protocol.
When you configure this command, specify the extended keyword for iNode clients and the standard keyword for other clients.
This command is required only when an IMC server is used as the RADIUS server.
# Set the EAP mode to extended for service template 1.
[Sysname-wlan-st-1] dot1x eap extended
Use dot1x handshake enable to enable the 802.1X online user handshake feature.
Use undo dot1x handshake enable to disable the 802.1X online user handshake feature.
The 802.1X online user handshake feature is disabled.
The online user handshake feature checks the connection status of online 802.1X clients by periodically sending handshake messages to the clients. The device sets a client to the offline state if it does not receive responses from the client after making the maximum handshake attempts within the handshake timer. To set the handshake timer, use the dot1x timer handshake-period command. To set the maximum handshake attempts, use the dot1x retry command.
The device does not respond to a client after it receives handshake responses from that client. Some clients might initiate reauthentication or go offline if they do not receive the device's responses to their handshake responses. If your network has such clients, you can disable the online user handshake feature.
# Enable the online user handshake feature for 802.1X clients in service template service1.
[Sysname-wlan-st-service1] dot1x handshake enable
dot1x retry
Use dot1x handshake secure enable to enable the 802.1X online user handshake security feature.
Use undo dot1x handshake secure enable to disable the 802.1X online user handshake security feature.
The 802.1X online user handshake security feature is disabled.
For the 802.1X online user handshake security feature to take effect, you must enable the 802.1X online user handshake feature.
The online user handshake security feature protects only authenticated online 802.1X clients.
# Enable the 802.1X online user handshake security feature in service template service1.
[Sysname-wlan-st-service1] dot1x handshake secure enable
dot1x max-user
Use dot1x max-user to set the maximum number of concurrent 802.1X clients that a service template supports on a radio.
Use undo dot1x max-user to restore the default.
dot1x max-user count
undo dot1x max-user
A service template permits a maximum of 512 concurrent 802.1X clients to access the network on a radio.
count: Specifies the maximum number of concurrent 802.1X clients. The value range is 1 to 512.
This setting takes effect on a per-radio basis. If the number of 802.1X clients of the service template reaches the limit on a radio, no additional 802.1X clients can access the network through the service template on that radio.
# In service template service1, set the maximum number of concurrent 802.1X clients on a radio to 32.
[Sysname-wlan-st-service1] dot1x max-user 500
Use dot1x re-authenticate enable to enable the 802.1X periodic online user reauthentication feature.
Use undo dot1x re-authenticate enable to disable the 802.1X periodic online user reauthentication feature.
The 802.1X periodic online user reauthentication feature is disabled.
Periodic reauthentication enables the device to periodically authenticate online 802.1X clients in a service template. This feature checks the connection status of online clients and updates the authorization attributes assigned by the server, such as the ACL, VLAN, and user profile.
You can use the dot1x timer reauth-period command to configure the interval for reauthentication.
The server-assigned session timeout timer (Session-Timeout attribute) and termination action (Termination-Action attribute) can affect the periodic online user reauthentication feature. To display the server-assigned Session-Timeout and Termination-Action attributes, use the display dot1x connection command (see Security Command Reference).
·     If the termination action is Default (logoff), periodic online user reauthentication on the template takes effect only when the periodic reauthentication timer is shorter than the session timeout timer.
·     If the termination action is Radius-request, the periodic online user reauthentication configuration on the template does not take effect. The device reauthenticates the online 802.1X clients after the session timeout timer expires.
# Enable the 802.1X periodic online user reauthentication feature in service template service1.
[Sysname-wlan-st-service1] dot1x re-authenticate enable
dot1x timer
dot1x retry
Use dot1x retry to set the maximum number of attempts for sending an authentication request to a client.
Use undo dot1x retry to restore the default.
dot1x retry retries
undo dot1x retry
The system supports a maximum of two attempts for sending an authentication request to a client.
retries: Specifies the maximum number of attempts for sending an authentication request to a client. The value range is 1 to 10.
The access device retransmits an authentication request to a client if it does not receive any responses from the client within the specified period. If the maximum number of transmission attempts is reached but no response is received, the device stops sending authentication requests. For EAP-Request/Identity packets, the timeout is set by the dot1x timer tx-period command. For EAP-Request/MD5 Challenge packets, the timeout is set by the dot1x timer supp-timeout command.
# Set the maximum number of attempts to 9 for sending an authentication request to a client.
[Sysname] dot1x retry 9
display dot1x
dot1x timer
dot1x timer
Use dot1x timer to set an 802.1X timer.
Use undo dot1x timer to restore the default of an 802.1X timer.
dot1x timer { handshake-period handshake-period-value | reauth-period reauth-period-value | server-timeout server-timeout-value | supp-timeout supp-timeout-value }
undo dot1x timer { handshake-period handshake-period-value | reauth-period reauth-period-value | server-timeout server-timeout-value | supp-timeout supp-timeout-value }
The client authentication timeout is 30 seconds, the authentication server timeout is 100 seconds, the handshake timeout is 15 seconds, and the periodic re-authentication timeout is 3600 seconds.
handshake-period handshake-period-value: Specifies the handshake timeout in the range of 5 to 1024 seconds.
reauth-period reauth-period-value: Specifies the periodic re-authentication timeout in the range of 60 to 7200 seconds.
server-timeout server-timeout-value: Specifies the authentication server timeout in the range of 100 to 300 seconds.
supp-timeout supp-timeout-value: Specifies the client authentication timeout in the range of 1 to 120 seconds.
The network device uses the following 802.1X timers:
·     Handshake timer (handshake-period)—Sets the interval at which the access device sends client handshake requests to check the online status of a client that has passed authentication. If the device does not receive a response after sending the maximum number of handshake requests, it considers that the client has logged off.
·     Periodic reauthentication timer (reauth-period)—Sets the interval at which the access device periodically reauthenticates online 802.1X users. To enable 802.1X periodic reauthentication on a port, use the dot1x re-authenticate command. For online 802.1X users, the newly configured timer takes effect only on subsequent re-authentication after the current re-authentication period ends and the authentication is successful.
·     Server timeout timer (server-timeout)—Starts when the access device sends a RADIUS Access-Request packet to the authentication server. If no response is received when this timer expires, 802.1X authentication fails.
As a best practice, set the server-timeout value to be smaller or equal to the maximum number of RADIUS packet transmission attempts (retry) multiplied by the RADIUS server response timeout (timer response-timeout). If the server-timeout value is larger than the retry value multiplied by the timer response-timeout, users might be logged off before the server authentication timeout (server-timeout) is reached. For more information about the maximum number of transmission attempts for a RADIUS packet and the RADIUS server response timeout, see User Access and Authentication Configuration Guide.
·     Client timeout timer (supp-timeout)—Starts when the access device sends an EAP-Request/MD5-Challenge packet to a client. If no response is received when this timer expires, the access device retransmits the request to the client.
Under normal circumstances, you do not need to modify the values of the timers. However, in certain special or adverse network environments, this command can be used to adjust the interaction process.
The change to the periodic reauthentication timer applies to the users that have been online only after the old timer expires. Other timer changes take effect immediately on the device.
display dot1x
dot1x unauthenticated-user aging enable
retry
timer response-timeout (RADIUS scheme view)
fail-permit enable
Use fail-permit enable to enable authentication fail-permit.
Use undo fail-permit enable to disable authentication fail-permit.
fail-permit enable [ keep-online | url-user-logoff ] [ always-service ]
Authentication fail-permit is disabled.
Service template view
keep-online: Allows online fail-permit clients to stay online when an authentication fail-permit event occurs. If you do not specify this keyword, the device disconnects online fail-permit clients when an authentication fail-permit event occurs.
url-user-logoff: Enables the URL client logoff mechanism. This mechanism logs off MAC authentication clients if an authentication fail-permit event occurs after they have been assigned a redirect URL. This keyword is applicable only to MAC authentication clients.
always-service: Enables the current service template to continue providing services for clients after an authentication fail-permit event occurs, regardless of whether a fail-permit service template has been configured. If you do not specify this keyword or a fail-permit service template, MAC authentication or Bypass clients can continue using the current service template to access the network after an authentication fail-permit event occurs. If you do not specify this keyword but specify a fail-permit service template, the current service template stops providing services for clients after an authentication fail-permit event occurs. This keyword is applicable only to MAC authentication and Bypass clients.
Application scenarios
Authentication fail-permit (also called fail-open) allows 802.1X, MAC authentication, and Bypass clients to access the network after the AC disconnects from the RADIUS server or the AP. When either event occurs, the AP continues to provide access services and forward traffic for those clients.
Operating mechanism
The impact of an authentication fail-permit event on clients differs depending on their authentication method and depending on whether a fail-permit service template has been configured.
·     Bypass clients:
¡     If the fail-permit template and fail-permit enable (without the always-service keyword) commands are configured, the Bypass clients will be logged off. To access the network, the Bypass clients must manually reconnect to the SSID in the preconfigured fail-permit service template.
¡     If the fail-permit template command is not configured, or if the fail-permit enable always-service command is configured, the Bypass clients can continue using the existing service template enabled with authentication fail-permit to access the network without interruption.
·     MAC authentication clients:
¡     If the fail-permit template and fail-permit enable (without the always-service keyword) commands are configured, the MAC authentication clients will be logged off. To access the network, the MAC authentication clients must manually reconnect to the SSID in the preconfigured fail-permit service template.
¡     If the fail-permit template command is not configured, or if the fail-permit enable always-service command is configured, the MAC authentication clients can continue using the existing service template enabled with authentication fail-permit to access the network after a transient interruption. In this situation, the clients will be logged off and then automatically connected to the network.
·     The 802.1X clients will be logged off. To access the network, the 802.1X clients must manually reconnect to the SSID in a preconfigured fail-permit service template.
For authentication fail-permit to take effect, perform the following steps:
1.     Execute the radius-server test-profile command to configure a RADIUS test profile to test the reachability of the RADIUS server.
In the profile, set the interval for sending detection packets as needed. The shorter the interval is, the quicker the response to the change will be.
2.     Apply the profile to the RADIUS server in the RADIUS scheme for the authentication ISP domain.
Fail-permit will occur when the RADIUS server is determined to be unreachable.
For more information about configuring RADIUS test profiles, see AAA configuration in User Access and Authentication Configuration Guide.
Recommended configuration
In some network environments, such as the AD-Campus network solution, the RADIUS server assigns a redirect URL to MAC authentication clients when they come online. This URL is used to redirect the clients to the Web authentication page for user authentication. However, if an authentication fail-permit event occurs after an online MAC authentication client has been assigned a redirect URL, the client might remain in authenticating state due to the unavailability of the RADIUS server. To resolve this issue, you can specify the url-user-logoff keyword to force the client to log off. To continue accessing the network, the client must reconnect to the network.
You can only bind one fail-permit service template to a radio. If an authentication fail-permit event occurs, clients that use multiple service templates with authentication fail-permit enabled will all access one fail-permit service template to come online. As a result, the wireless network experience might degrade for clients. To prevent all clients from coming online through one fail-permit service template, you can specify the always-service keyword in the service templates that use MAC authentication or Bypass authentication. This keyword ensures that when an authentication fail-permit event occurs, the current service templates with authentication fail-permit enabled can continue providing wireless services regardless of whether a fail-permit service template has been configured.
The fail-permit enable command is configurable when the service template is disabled, and it takes effect after the service template is enabled.
The fail-permit enable command is mutually exclusive with the fail-permit template command in the same service template.
If you do not specify any parameters for the fail-permit enable command in a service template, all online clients in that service template will be logged off when an authentication fail-permit event occurs.
# Enable authentication fail-permit in a WLAN service template.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] fail-permit enable
client url-redirect enable
Use fail-permit template to specify a service template as a fail-permit service template.
Use undo fail-permit template to remove the fail-permit attribute of a fail-permit service template.
No service templates are specified as fail-permit service templates.
You can use this command for the following purposes:
·     Authentication fail-permit—To use the authentication fail-permit feature for clients associated with one service template, specify another service template as a fail-permit service template. If the protected service template has 802.1X clients, you must specify a fail-permit service template. This requirement is optional for other types of authentication clients. For more information about the authentication fail-permit feature, see the usage guidelines for the fail-permit enable command.
·     5G radio silence fail-permit—Allows an AP to move the clients of a service template on a 5G radio to a different 5G radio for network access when radio silence is imposed on the former radio.
You can execute the fail-permit template command only when the service template is disabled, and it takes effect after the service template is enabled.
The fail-permit template command is mutually exclusive with the fail-permit enable command in the same service template.
To ensure a successful fail-permit, follow these restrictions and guidelines:
·     Enable APs to forward client data traffic in the fail-permit service template by using the client forwarding-location command.
·     If APs are configured as the authenticator in a service template by using the client-security authentication-location command, the authenticator in the fail-permit service template of this service template must also be APs.
Use the following guidelines when you configure an authentication fail-permit service template:
·     As a best practice, configure only one fail-permit service template for clients on an AP. If you configure multiple fail-permit service templates, only the one that is first bound to a radio on the AP will take effect.
·     To ensure a successful fail-permit for clients, set the AKM mode to PSK or do not specify any AKM mode in the fail-permit service template.
Use the following guidelines when you configure a 5G silence fail-permit service template for 5G clients:
·     Specify one 5G silence fail-permit service template for each 5G service template on a 5G radio. These 5G silence fail-permit service templates must contain the same settings as their protected 5G service templates except that the protected 5G service templates cannot contain the fail-permit template command.
·     Bind a 5G silence fail-permit service template to a different radio than its protected 5G service template on the same AP.
# Specify a service template as a fail-permit service template.
[Sysname-wlan-st-service1] fail-permit template
akm mode
fail-permit enable
mac-authentication authentication-method
Use mac-authentication authentication-method to specify an authentication method for MAC authentication.
Use undo mac-authentication authentication-method to restore the default.
mac-authentication authentication-method { chap | pap }
The device uses PAP for MAC authentication.
chap: Configures the access device to use the Challenge Handshake Authentication Protocol (CHAP) to communicate with the RADIUS server.
pap: Configures the access device to use the Password Authentication Protocol (PAP) to communicate with the RADIUS server.
The device can use either of the following methods to perform MAC authentication with an authentication server:
·     PAP—Transports usernames and passwords in plaintext format. The authentication method applies to scenarios that do not require high security.
·     CHAP—Transports usernames in plaintext format and passwords in ciphertext format over the network. CHAP is more secure than PAP. Compared with PAP, CHAP provides better confidentiality and is more secure and reliable.
# Configure the device to use CHAP for MAC authentication.
[Sysname] mac-authentication authentication-method pap
mac-authentication timer
Use mac-authentication timer to configure a MAC authentication timer.
Use undo mac-authentication timer to restore the default.
mac-authentication timer { offline-detect offline-detect-value | quiet quiet-value | server-timeout server-timeout-value }
The offline detect timeout is 300 seconds, the quiet timeout is 60 seconds, and the server timeout is 100 seconds.
offline-detect offline-detect-value: Sets the offline detect timeout in seconds, in the range of 60 to 2147483647 seconds.
quiet quiet-value: Sets the quiet timeout in the range of 1 to 3600 seconds.
server-timeout server-timeout-value: Sets the server timeout in the range of 100 to 300 seconds.
MAC authentication uses the following timers:
·     Offline detect timer—Sets the interval that the device waits for traffic from a user before the device determines that the user is idle. If the device has not received traffic from a user before the timer expires, the device logs off that user and requests the accounting server to stop accounting for the user. To avoid unexpected user disassociations, if you set the offline detect timeout, make sure to set the MAC address aging time to the same value. The timer takes effect only when MAC authentication disassociation detection is enabled on the port.
·     Quiet timer—Sets the interval that the device must wait before the device can perform MAC authentication for a user that has failed MAC authentication. All packets from the MAC address are dropped during the quiet time. This quiet mechanism prevents repeated authentication from affecting system performance.
·     Server timeout timer—Sets the interval that the device waits for a response from a RADIUS server before the device determines that the RADIUS server is unavailable. If the timer expires during MAC authentication, the user cannot access the network.
# Set the server timeout to 150 seconds.
mac-authentication guest-vlan auth-period
mac-authentication unauthenticated-user aging enable
retry
mac-authentication domain
Use mac-authentication domain to specify an authentication domain for MAC authentication clients in a service template.
Use undo mac-authentication domain to restore the default.
No authentication domain is specified for MAC authentication clients in a service template.
This command is configurable when the service template is disabled, and it takes effect after the service template is enabled.
MAC authentication chooses an authentication domain for WLAN clients in the following order:
2.     Global authentication domain specified in system view.
# Specify ISP domain my-domain as the authentication domain for MAC authentication clients in service template service1.
[Sysname-wlan-st-service1] mac-authentication domain my-domain
Use mac-authentication max-user to set the maximum number of concurrent MAC authentication clients that a service template supports on a radio.
Use undo mac-authentication max-user to restore the default.
mac-authentication max-user count
A service template permits a maximum of 512 concurrent MAC authentication clients to access the network on a radio.
count: Sets the maximum number of concurrent MAC authentication clients. The value range for this argument is 1 to 512.
This command takes effect on a per-radio basis. If the number of MAC authentication clients of a service template reaches the limit on a radio, no additional MAC authentication clients can access the network through the service template on that radio.
# Configure service template service1 to support a maximum of 32 concurrent MAC authentication clients on a radio.
[Sysname-wlan-st-service1] mac-authentication max-user 32
reset dot1x statistics
Use reset dot1x statistics to clear 802.1X statistics.
reset dot1x statistics [ ap ap-name [ radio radio-id ] ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify this option, the command clears information on all APs.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify this option, this command clears 802.1X statistics for all radios on the specified AP.
# Clear all 802.1X statistics.
<Sysname> reset dot1x statistics
display dot1x
reset mac-authentication statistics
Use reset mac-authentication statistics to clear MAC authentication statistics.
reset mac-authentication statistics [ ap ap-name [ radio radio-id ] ]
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify this option, this command clears MAC authentication statistics for all radios on the specified AP.
# Clear all MAC authentication statistics.
<Sysname> reset mac-authentication statistics
wlan authentication optimization
Use wlan authentication optimization to configure a modifier to adjust the authentication success ratio and abnormal offline ratio for 802.1X authentication, MAC authentication, and Layer 2 portal authentication.
Use undo wlan authentication optimization to restore the default.
wlan authentication optimization value
The modifier is 0. The device does not adjust the authentication success ratio and abnormal offline ratio for 802.1X authentication, MAC authentication, and Layer 2 portal authentication.
value: Sets the modifier, in the range of 900 to 1000. The lower the value, the lower the authentication success ratio, and the higher the abnormal offline ratio.
The authentication success ratio is the ratio of the number of authentication success times to the total number of authentication times. The abnormal offline ratio is calculated by using the following formula: abnormal offline ratio = number of times that clients go offline abnormally ÷ (number of authentication success times + number of current online users).
WLAN authentication statistics optimization uses a modifier to adjust the authentication success ratio and abnormal offline ratio of 802.1X authentication, MAC authentication, and Layer 2 portal authentication.
The modifier takes effect only on RADIUS-based 802.1X authentication, MAC authentication, and Layer 2 portal authentication.
# Set the modifier to 950 to adjust the authentication success ratio and abnormal offline ratio of 802.1X authentication, MAC authentication, and Layer 2 portal authentication.
[Sysname] wlan authentication optimization 950
wlan client-security authentication clear-previous-connection
Use wlan client-security authentication clear-previous-connection to enable the clear-previous-connection feature for WLAN authentication.
Use undo wlan client-security authentication clear-previous-connection to disable the clear-previous-connection feature for WLAN authentication.
The clear-previous-connection feature is disabled for WLAN authentication.
IMPORTANT
IMPORTANT:
When this feature is enabled, the 802.1X reauthentication, WLAN Auth-Fail VLAN, and WLAN critical VLAN features cannot take effect.
Some RADIUS servers reject to authenticate a client if they have an online user entry for that client. If they fail to remove the online user entry for a client that has gone offline incorrectly, that client will be unable to get authenticated and come online again.
To resolve this issue, use the clear-previous-connection feature.
With this feature, the device checks the local online user entries before it sends an authentication request to the RADIUS server for an 802.1X or MAC authentication client. If an entry is found, the device removes the entry and sends a stop-accounting request to the RADIUS server. Upon receipt of the stop-accounting request, the RADIUS server removes the online user entry. Then, the client can be authenticated correctly.
# Enable the clear-previous-connection feature.
[Sysname] wlan client-security authentication clear-previous-connection
