08-Radio Resources Management Command Reference
HomeSupportWirelessWA6500 Series Access PointsReference GuidesCommand ReferencesH3C WA6500A Series Access Points Cloud Mode Command References(R2605P09)-6W10008-Radio Resources Management Command Reference
07-Channel scanning commands
07-Channel scanning commands 57.26 KB
scan channel blacklist
Use scan channel blacklist to configure the channel scanning blacklist.
Use undo scan channel blacklist to remove the specified channels from the channel scanning blacklist.
scan channel blacklist channel-list
undo scan channel blacklist { channel-list | all }
No channel scanning blacklist exists.
Radio interface view
channel-list: Specifies channels by their channel numbers. The value range for the channel-list argument depends on the country code and radio mode.
all: Specifies all channels in the channel scanning blacklist.
After you configure the channel scanning blacklist for an AP, the AP will not scan non-working channels in the blacklist. You cannot configure both the channel scanning blacklist and whitelist for the same AP. Before configuring the channel scanning blacklist, remove all channels in the channel scanning whitelist.
# Add channels 1 and 6 to the channel scanning blacklist.
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] scan channel blacklist 1 6
scan channel whitelist
Use scan channel whitelist to configure the channel scanning whitelist.
Use undo scan channel whitelist to remove the specified channels from the channel scanning whitelist.
scan channel whitelist channel-list
undo scan channel whitelist { channel-list | all }
No channel scanning whitelist exists.
all: Specifies all channels in the channel scanning whitelist.
After you configure the channel scanning whitelist for an AP, the AP will scan only channels in the whitelist and the working channel. You cannot configure both the channel scanning blacklist and whitelist for the same AP. Before configuring the channel scanning whitelist, remove all channels in the channel scanning blacklist.
# Add channels 1 and 6 to the channel scanning whitelist.
[Sysname-WLAN-Radio1/0/2] scan channel whitelist 1 6
scan idle-time
Use scan idle-time to set the service idle timeout timer.
Use undo scan idle-time to restore the default.
scan idle-time idle-time
undo scan idle-time
The service idle timeout timer is 100 milliseconds.
idle-time: Specifies the service idle timeout timer in the range of 60 to 5000 milliseconds. The service idle timeout timer cannot be greater than the maximum service period.
During a service period, an AP does not begin a new scanning period until the current service period exceeds the scanning period even if the specified service idle timeout expires.
The service idle timeout timer must be a multiple of the beacon interval. The value of the beacon interval is used as the service idle timeout timer if the service idle timeout timer is smaller than the beacon interval.
# Set the service idle timeout timer to 500 milliseconds.
[Sysname-WLAN-Radio1/0/2] scan idle-time 500
beacon interval
scan max-service-time
Use scan max-service-time to set the maximum service period.
Use undo scan max-service-time to restore the default.
scan max-service-time { max-service-time | no-limit }
The maximum service period is not limited. An AP does not start a scanning period unless the service idle timeout timer expires.
max-service-time: Specifies the maximum service period in the range of 100 to 5000 milliseconds.
no-limit: Configures the radio to not limit the service period. Specify this keyword to ensure wireless service quality. The AP does not start a scanning period unless the service idle timeout expires.
When the maximum service period for an AP is reached, the AP begins a scanning period regardless of whether it has traffic to forward.
# Set the maximum service period to 3000 milliseconds.
[Sysname-WLAN-Radio1/0/2] scan max-service-time 3000
scan scan-time
Use scan scan-time to set the scanning period.
Use undo scan scan-time to restore the default.
scan scan-time scan-time
undo scan scan-time
The scanning period is 100 milliseconds.
scan-time: Specifies the scanning period in the range of 100 to 5000 milliseconds. The scanning period cannot be greater than the maximum service period.
# Set the scanning period to 500 milliseconds.
[Sysname-WLAN-Radio1/0/2] scan scan-time 500
scan work-channel-only
Use scan work-channel-only enable to enable an AP to scan only the working channel.
Use scan work-channel-only disable to disable an AP from scanning only the working channel.
Use undo scan work-channel-only to restore the default.
scan work-channel-only { disable | enable }
The AP scans all supported channels in turn.
# Configure interface WLAN-radio 1/0/2 to scan only the working channel.
[Sysname-WLAN-Radio1/0/2] scan work-channel-only enable
