08-Radio Resources Management Command Reference
HomeSupportWirelessWA6500 Series Access PointsReference GuidesCommand ReferencesH3C WA6500A Series Access Points Cloud Mode Command References(R2605P09)-6W10008-Radio Resources Management Command Reference
01-Radio management commands
01-Radio management commands 257.72 KB
a-mpdu
Use a-mpdu enable to enable the A-MPDU aggregation method.
Use a-mpdu disable to disable the A-MPDU aggregation method.
Use undo a-mpdu to restore the default.
a-mpdu { disable | enable }
undo a-mpdu
The A-MPDU aggregation method is enabled.
Radio interface view
This command is applicable only to 802.11n and 802.11ac 802.11ax, and 802.11gax radios. Changing the radio mode to 802.11a, 802.11b, or 802.11g invalidates the command.
# Disable the A-MPDU aggregation method.
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio1/0/1] type dot11an
[Sysname-WLAN-Radio1/0/1] a-mpdu disable
a-msdu
Use a-msdu enable to enable the A-MSDU aggregation method.
Use a-msdu disable to disable the A-MSDU aggregation method.
Use undo a-msdu to restore the default.
a-msdu { disable | enable }
undo a-msdu
The A-MSDU aggregation method is enabled.
This command is applicable only to 802.11n, 802.11ac, 802.11ax, and 802.11gax radios. Changing the radio mode to 802.11a, 802.11b, or 802.11g invalidates the command.
The device can receive but cannot send A-MSDUs.
# Disable the A-MSDU aggregation method.
[Sysname-WLAN-Radio1/0/1] a-msdu disable
antenna type
Use antenna type to set the antenna type for an AP.
Use undo antenna type to restore the default.
antenna type { antenna-type | custom gain custom-gain }
undo antenna type
The default antenna type is internal.
antenna-type: Specifies an antenna type, a string of 1 to 10 characters.
custom gain custom-gain: Specifies the gain of the third-party antenna, in the range of 0 to 20 dBi.
Perform this task to set the antenna type and the antenna gain for an AP after you change the AP antenna.
You can perform this task to specify the antenna type of an H3C antenna or a third-party antenna.
·     When an H3C antenna is used, make sure the antenna type is consistent with the actual type of the antenna used on the AP.
·     When a third-party antenna is used, make sure the antenna gain is the actual gain of the third-party antenna.
# Set the antenna type to internal.
[Sysname-WLAN-Radio1/0/1] antenna type internal
atf enable
Use atf enable to enable the ATF feature.
Use atf disable to disable the ATF feature.
Use undo atf to restore the default.
atf { disable | enable }
undo atf
The ATF feature is disabled.
When Air Time Fairness (ATF) is enabled, all clients receive equal wireless access time from the AP. High-speed clients have more chances to use wireless resources, thereby enhancing the overall forwarding efficiency of the wireless network.
Enabling this feature might further reduce the forwarding efficiency of low-speed clients. Therefore, decide whether to enable this feature after weighing the number of connected users and the sending efficiency of high-speed clients.
# Enable the ATF feature.
[Sysname-WLAN-Radio1/0/1] atf enable
beacon-interval
Use beacon-interval to set the beacon interval.
Use undo beacon-interval to restore the default.
beacon-interval interval
The beacon interval is 100 TUs.
interval: Specifies the beacon interval in the range of 32 to 8191 TUs.
# Set the beacon interval to 1000 TUs.
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] beacon-interval 1000
bss-color
Use bss-color enable to enable BSS coloring.
Use bss-color disable to disable BSS coloring.
Use undo bss-color to restore the default.
bss-color { disable | enable }
undo bss-color
BSS coloring is disabled.
This command takes effect only on 802.11ax and 802.11gax radios. Changing the radio mode to 802.11a/b/g/n/ac/gac removes the configuration.
BSS coloring enables the system to assign a color to each BSS and include the color ID in data packets for clients to identify if a packet comes from the associated AP. To avoid conflicts, clients that detect an 802.11ax data packet with the same color as its associated BSS will postpone transmission.
Enabling BSS coloring in a high density environment can improve system performance and channel usage.
# Enable BSS coloring.
[Sysname-WLAN-Radio1/0/2] bss-color enable
type dot11ax
channel
Use channel to specify a working channel for a radio interface.
Use undo channel to restore the default.
channel { channel-number | auto }
undo channel
An AP selects the working channels automatically.
channel-number: Specifies a channel by its number. The value range for this argument varies by region code and radio mode.
auto: Configures the AP to automatically select a channel.
When radar signals are detected on the working channel of a radio, the AP changes its channel, and switches back to the specified channel after 30 minutes. Then the AP starts the quiet timer. If no radar signals are detected within the quiet time, the AP starts to use the channel. If radar signals are detected within the quiet time, the AP changes its channel.
If you manually specify a channel in the range of 36 to 64, whether the 5.1 GHz band can be used outdoors depends on the device region.
·     For outdoor devices that use the 5150 to 5250 Hz band:
¡     China—Not supported.
¡     EU—Not supported.
¡     US—Supported if the maximum effective isotropic radiated power (EIRP) at any elevation angle above 30 degrees does not exceed 125mW and you are to deploy 1000 or fewer devices at a time. To install over 1000 devices at one deployment, contact Federal Communications Commission (FCC) and reduce the total transmit power.
¡     Canada—Not supported.
·     For outdoor devices that use the 5250 to 5350 Hz band:
¡     EU—Not supported.
¡     US—Supported if Depth First Search (DFS) is used.
¡     Canada—Supported if Depth First Search (DFS) is used.
# Specify channel 6 as the working channel.
[Sysname-WLAN-Radio1/0/2] channel 6
channel band-width
Use channel band-width to set the bandwidth mode.
Use undo channel band-width to restore the default.
channel band-width { 20 | 40 [ auto-switch ] | 80 | 160 }
The bandwidth mode is 160 MHz for 802.11eax radios, 80 MHz for 802.11ax radios, 20 MHz for 802.11gax radios, 80 MHz for 802.11ac radios,  40 MHz for 802.11an radios, and 20 MHz for 802.11gn radios. The default bandwidth mode for 802.11be radios varies by device model.
20: Sets the bandwidth mode to 20 MHz.
40: Sets the bandwidth mode to 40 MHz.
80: Sets the bandwidth mode to 80 MHz.
auto-switch: Allows a radio to switch its bandwidth mode between 20 MHz and 40 MHz. This keyword is applicable only to 802.11gn and 802.11gax radios.
160: Sets the bandwidth mode to 160 MHz. Support for this keyword depends on the AP model.
This command is applicable only to the following radio types: 802.11n, 802.11ac, 802.11ax, and 802.11gax. When you change the mode of a radio, the default setting of this command for the new radio mode is restored.
The radio uses the specified 40/80/160/320 MHz bandwidth if adjacent channels can be bound to form a 40/80/160/320 channel. If adjacent channels cannot form a 40/80/160/320 channel, the radio uses the next available bandwidth less than the specified one.
For example, the bandwidth mode is set to 80 MHz. The radio uses the 80 MHz bandwidth if adjacent channels that can be bound together exist. If adjacent channels that can be bound to an 80 MHz channel do not exist, but two adjacent channels that can be bound to a 40 MHz channel exist, the 40 MHz bandwidth is used. If no adjacent channels that can be bound together exist, the radio uses the 20 MHz bandwidth.
If the working channel is specified for the 160 MHz bandwidth mode, the device automatically selects a secondary channel. The working channel forwards all packets and the secondary channel forwards only data packets.
# Set the bandwidth mode to 40 MHz.
[Sysname-WLAN-Radio1/0/1] channel band-width 40
channel
channel-usage measure
Use channel-usage measure to perform on-demand channel usage measurement.
This feature enables an AP to scan supported channels and display the channel usage after measurement. The measurement of each channel takes about one second.
# Perform on-demand channel usage measurement on radio interface 2.
[Sysname] interface WLAN-Radio 1/0/2
[Sysname-WLAN-Radio1/0/2] channel-usage measure
Please wait..............Done.
Channel  Usage
1        23%
2        34%
3        26%
4        36%
5        42%
6        39%
7        27%
8        45%
9        29%
10       38%
11       46%
12       30%
13       33%
client dot11ac-only
Use client dot11ac-only enable to enable the client dot11ac-only feature.
Use client dot11ac-only disable to disable the client dot11ac-only feature.
Use undo client dot11ac-only to restore the default.
client dot11ac-only { disable | enable }
The client dot11ac-only feature is disabled.
This command is applicable only to 802.11ac, 802.11ax, and 802.11gax radios. Changing the radio mode invalidates the command.
After you configure this command on a radio, the radio accepts only 802.11ac and 802.11ax clients, and all non-802.11ac and non-802.11ax clients that are associated with the radio are logged off.
# Enable the client dot11ac-only feature.
[Sysname-WLAN-Radio1/0/1] client dot11ac-only enable
dot11ac mandatory maximum-nss
client dot11ax-only
Use client dot11ax-only enable to enable the client dot11ax-only feature.
Use client dot11ax-only disable to disable the client dot11ax-only feature.
Use undo client dot11ax-only to restore the default.
client dot11ax-only { disable | enable }
The client dot11ax-only feature is disabled.
This command is applicable only to 802.11ax and 802.11gax radios. Changing the radio mode invalidates the command.
After you configure this command for a radio, the radio accepts only 802.11ax clients, and all non-802.11ax clients that are associated with the radio are logged off.
# Enable the client dot11ax-only feature.
[Sysname-WLAN-Radio1/0/1] client dot11ax-only enable
client dot11b-forbidden
Use client dot11b-forbidden enable to disable access services for 802.11b clients.
Use client dot11b-forbidden disable to enable access services for 802.11b clients.
Use undo client dot11b-forbidden to restore the default.
client dot11b-forbidden { disable | enable }
Access services for 802.11b clients are enabled.
Enabling an 802.11g 802.11gn, or 802.11gax radio to reject 802.11b clients reduces the impact of low-speed 802.11b clients and speeds up wireless data transmission.
# Configure WLAN-radio 1/0/2 to reject 802.11b clients.
[Sysname-WLAN-Radio1/0/2] client dot11b-forbidden enable
client dot11n-only
Use client dot11n-only enable to enable the client dot11n-only feature.
Use client dot11n-only disable to disable the client dot11n-only feature.
Use undo client dot11n-only to restore the default.
client dot11n-only { disable | enable }
The client dot11n-only feature is disabled.
This command is applicable only to 802.11n, 802.11ac, and 802.11ax radios. Changing the radio mode to 802.11a, 802.11b, or 802.11g invalidates the command.
After you configure this command on a radio, the radio accepts only the 802.11n, 802.11ac, and 802.11ax clients, and all 802.11a/b/g clients that are associated with the radio are logged off.
# Enable the client dot11n-only feature.
[Sysname-WLAN-Radio1/0/1] client dot11n-only enable
client max-count
Use client max-count to set the maximum number of clients that can associate with an AP.
Use undo client max-count to restore the default.
client max-count max-number
No limit is set for the number of clients that can associate with an AP.
max-number: Specifies the maximum number of clients that can associate with an AP
When the maximum number of clients is reached on an AP, the AP stops accepting new clients.
# Set the maximum number of clients that can associate with an AP to 38.
[Sysname-WLAN-Radio1/0/2] client max-count 38
display wlan ap radio
Use display wlan ap radio to display radio information.
display wlan ap radio radio-id
radio-id: Specifies a radio by its ID.
# Display information about radio 1.
<Sysname> display wlan ap radio 1
Radio 1:
    BSSID                     : 74ea-cbdf-0640
    State                     : Up
    Type                      : 802.11acx(5GHz)
    Antenna type              : internal
    Client dot11ac-only       : Disabled
    Client dot11n-only        : Disabled
    Channel band-width        : 20/40/80MHz
    Operating band-width      : 20/40/80MHz
    Secondary channel mode    : SCA
    Short GI for 20MHz        : Supported
    Short GI for 40MHz        : Supported
    Short GI for 80MHz        : Supported
    Short GI for 160MHz       : Not supported
    MIMO                      : Not Config
    Green-Energy-Management   : Disabled
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Not Supported
    STBC                      : Supported
    Operational VHT-MCS set:
        Mandatory             : Not configured
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
                                NSS3 0,1,2,3,4,5,7,8,9
                                NSS4 0,1,2,3,4,5,6,7,8,9
        Multicast             : Not configured
    Operational HT MCS set:
        Supported             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15, 16, 17,
                                18, 19, 20, 21, 22, 23, 24, 25,
                                26, 27, 28, 29, 30, 31
    Channel                   : 36
    Channel usage(%)          : 0
    Max power                 : 24 dBm
    Operational rate:
        Mandatory             : 6, 12, 24 Mbps
        Multicast             : Auto
        Supported             : 9, 18, 36, 48, 54 Mbps
        Disabled              : Not configured
    Distance                  : 1 km
    ANI                       : Enabled
    Fragmentation threshold   : 2346 bytes
    Beacon interval           : 100 TU
    Protection threshold      : 2346 bytes
    Long retry threshold      : 4
    Short retry threshold     : 7
    Frame aging time in cache : 2000 ms
    Noise floor               : -113 dBm
    Protection mode           : cts-to-self
    MU-TxBF                   : Enabled
    SU-TxBF                   : Enabled
    Continuous mode           : N/A
    Client dot11ax-only       : Disabled
    Operational HE-MCS Set:
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9,10,11
                                NSS2 0,1,2,3,4,5,6,7,8,9,10,11
    OFDMA random access RUs   : Not Supported
    DL-OFDMA                  : Enabled
    UL-OFDMA                  : Enabled
    UL-MU-MIMO                : Disabled
    BSS-COLOR                 : Enabled
    TWT negotiation           : Enabled
    ATF                       : Enabled
    radar-detect switch       : Enabled
    HT protection mode        : No protection
Radio state:
·     Up.
·     Down.
Radio type:
·     2.4GHz—802.11b, 802.11g, 802.11n(2.4GHz), 802.11ac(2.4GHz), or 802.11ax(2.4GHz).
·     5GHz—802.11a, 802.11n(5GHz), 802.11ac(5GHz), or 802.11ax(5GHz).
Antenna type
Antenna type of the radio.
Client dot11ac-only
·     Disabled—Allows both 802.11ac and 802.11a/b/g/n clients to associate with the radio.
·     Enabled—Allows only 802.11ac clients to associate with the radio.
Client dot11n-only
·     Disabled—Allows 802.11ac, 802.11n, and 802.11a/b/g clients to associate with the radio.
·     Enabled—Allows only 802.11n and 802.11ac clients to associate with the radio.
Channel band-width
Channel bandwidth:
·     20MHz.
·     20/40MHz.
·     20/40/80MHz.
·     20/40/80/160MHz.
·     20/40/80/160/(80+80)/320MHz.
Operating bandwidth of the radio.
Secondary channel mode for 802.11n and 802.11ac radios:
·     SCA—Second Channel Above (SCA). The radio operates in 40 MHz bandwidth mode, and the secondary channel is above the primary channel.
·     SCB—Second Channel Below (SCB). The radio operates in 40 MHz bandwidth mode, and the secondary channel is below the primary channel.
·     SCN—The radio does not operate in 40 MHz bandwidth mode.
This field is available only when the operating bandwidth is 20/40/80MHz.
Short GI for 20MHz
·     Not supported.
·     Supported.
Short GI for 40MHz
·     Not supported.
·     Supported.
Short GI for 80MHz
·     Not supported.
·     Supported.
Short GI for 160MHz
·     Not supported.
·     Supported.
Short GI for 320MHz
·     Not supported.
·     Supported.
MIMO
MIMO mode:
·     1x1—The radio sends and receives signals through one spatial stream.
·     2x2—The radio sends and receives signals through two spatial streams.
·     3x3—The radio sends and receives signals through three spatial streams.
·     4x4—The radio sends and receives signals through four spatial streams.
·     Not configured—The radio sends and receives signals through the maximum number of spatial streams supported by the radio.
If this field also displays (PowerLow) after any value option to indicate low power level, the radio can send and receive signals only through one spatial stream.
·     Disabled.
·     Enabled.
A-MSDU
·     Disabled.
·     Enabled.
A-MPDU
·     Disabled.
·     Enabled.
LDPC
·     Supported.
·     Not Supported.
STBC
·     Supported.
·     Not Supported.
·     Supported—Supported VHT MCS set.
·     Mandatory—Mandatory VHT MCS set.
·     Multicast—Multicast VHT MCS set.
·     Supported—Supported MCS set.
·     Mandatory—Mandatory MCS set.
·     Multicast—Multicast MCS set.
Channel
·     Number<auto>—This field displays Number<auto> if the current channel is the optimal channel automatically selected by the AP.
·     Number—This field displays Number if the current 2.4 GHz or 5 GHz channel is manually configured.
·     Number<avoid radar>—This field displays Number<avoid radar> if the current channel is automatically selected by the AP to avoid radar signals.
·     6G_Number—This field displays 6G_Number if the current 6 GHz channel is manually configured.
Max power
Maximum transmission power of the radio.
Preamble type
Preamble type:
·     Short.
·     Long.
Operational rate
·     Mandatory.
·     Supported.
·     Multicast.
·     Disabled.
·     Not configured.
Distance
Maximum distance that the radio signal can reach.
ANI
·     Enabled.
·     Disabled.
Frame length threshold required for triggering the protection mechanism.
Maximum number of retransmission attempts for frames whose length exceeds the RTS threshold.
Maximum number of retransmission attempts for frames whose length is below the RTS threshold.
Protection mode
Conflict avoidance mode:
·     cts-to-self.
·     rts-cts.
MU-TxBF
·     Enabled.
·     Disabled.
Support for this field depends on the AP model.
SU-TxBF
·     Enabled.
·     Disabled.
Continuous mode
Continuous mode configuration:
·     Rate.
·     MCS index.
·     NSS index.
·     VHT-MCS index.
·     This field displays N/A if the continuous mode is not configured.
Client dot11ax-only
·     Disabled—Allows both 802.11ax and 802.11a/b/g/n clients to associate with the radio.
·     Enabled—Allows only 802.11ax clients to associate with the radio.
Operational HE-MCS set
·     Supported—Supported HE-MCS set.
·     Mandatory—Mandatory HE-MCS set.
·     Multicast—Multicast HE-MCS set.
Operational EHT-MCS Set
·     Supported—Supported EHT-MCS set.
·     Mandatory—Mandatory EHT-MCS set.
·     Multicast—Multicast EHT-MCS set.
OFDMA random access RUs:
·     Not supported.
·     Supported.
DL-OFDMA
DL-OFDMA:
·     Disabled.
·     Enabled.
UL-OFDMA
UL-OFDMA:
·     Disabled.
·     Enabled.
UL-MU-MIMO
UL-MU-MIMO:
·     Disabled.
·     Enabled.
BSS-COLOR
BSS-COLOR:
·     Disabled.
·     Enabled.
TWT negotiation
TWT negotiation:
·     Disabled.
·     Enabled.
ATF
ATF:
·     Disabled.
·     Enabled.
radar-detect switch
Radar detection:
·     Disabled.
·     Enabled.
HT protection mode
802.11n protection mode:
·     No protection.
¡     AP-associated clients and nearby wireless devices are operating in 802.11n mode and AP-associated clients are 802.11n clients with a bandwidth of 40 MHz.
¡     AP-associated clients are 802.11n clients with a bandwidth of 20 MHz.
·     Non-member protection.
In this mode, all AP-associated clients are 802.11n clients but some nearby wireless devices are non-802.11n clients.
·     20 MHz protection.
In this mode, the AP's radio has a bandwidth of 40 MHz. AP-associated clients and nearby wireless devices are operating in 802.11n mode and a minimum of one 802.11n client with a bandwidth of 20 MHz is associated with the AP's radio.
·     Non-HT mixed.
This mode applies when none of the above mentioned modes apply.
distance
Use distance to set the maximum transmission distance.
Use undo distance to restore the default.
distance distance
undo distance
The maximum transmission distance is 1 km (0.62 miles).
distance: Specifies the maximum transmission distance in the range of 1 to 40 km (0.62 to 24.86 miles).
# Set the maximum transmission distance to 5 km (3.11 miles).
[Sysname-WLAN-Radio1/0/2] type dot11g
[Sysname-WLAN-Radio1/0/2] distance 5
dl-ofdma
Use dl-ofdma enable to enable OFDMA.
Use dl-ofdma disable to disable OFDMA.
Use undo dl-ofdma to restore the default.
dl-ofdma { disable | enable }
undo dl-ofdma
Downlink OFDMA is disabled.
OFDMA can provide the following benefits if enabled in a high density environment where small data packets are transmitted:
·     Concurrent transmission to multiple users.
·     Improved radio usage.
·     Shortened transmission latency.
·     Reduced conflict backoff.
# Enable downlink OFDMA.
[Sysname-WLAN-Radio1/0/2] dl-ofdma enable
type dot11ax
Use dot11ac mandatory maximum-nss to set the maximum mandatory NSS.
Use undo dot11ac mandatory maximum-nss to restore the default.
dot11ac mandatory maximum-nss nss-number
No maximum mandatory NSS is set.
nss-number: Specifies the maximum mandatory NSS in the range of 1 to 8.
This command is applicable only to 802.11ac radios. Changing the radio mode to non-802.11ac modes invalidates the command.
The maximum mandatory NSS cannot be greater than the maximum supported NSS.
After you modify the maximum mandatory NSS, clients that are associated with the radio and that do not support the modified NSS will go offline.
# Set the maximum mandatory NSS to 7.
[Sysname-WLAN-Radio1/0/1] dot11ac mandatory maximum-nss 7
dot11ac support maximum-nss
dot11ac multicast-nss
Use dot11ac multicast-nss to set the multicast NSS and specify a VHT-MCS index.
Use undo dot11ac multicast-nss to restore the default.
dot11ac multicast-nss nss-number vht-mcs index
No multicast NSS is set.
nss-number: Specifies the multicast NSS in the range of 1 to 8.
index: Specifies a VHT-MCS index in the range of 0 to 9.
Before configuring this command, you must configure the dot11ac mandatory maximum-nss command.
The multicast NSS cannot be greater than the maximum mandatory NSS.
# Set the maximum mandatory NSS, multicast NSS, and VHT-MCS index to 2, 2, and 2, respectively.
[Sysname-WLAN-Radio1/0/1] dot11ac mandatory maximum-nss 2
[Sysname-WLAN-Radio1/0/1] dot11ac multicast-nss 2 vht-mcs 2
Use dot11ac support maximum-nss to set the maximum supported NSS.
Use undo dot11ac support maximum-nss to restore the default.
dot11ac support maximum-nss nss-number
The maximum supported NSS is 8.
nss-number: Specifies the maximum supported NSS in the range of 1 to 8.
The maximum supported NSS cannot be smaller than the maximum mandatory NSS.
# Set the maximum supported NSS to 7.
[Sysname-WLAN-Radio1/0/1] dot11ac support maximum-nss 7
dot11ax mandatory maximum-nss
Use dot11ax mandatory maximum-nss to set the maximum mandatory NSS for 802.11ax radios.
Use undo dot11ax mandatory maximum-nss to restore the default.
dot11ax mandatory maximum-nss nss-number
No maximum mandatory NSS is set for an 802.11ax radio interface.
# Set the maximum mandatory NSS to 8.
[Sysname-WLAN-Radio1/0/1] dot11ax mandatory maximum-nss 8
type dot11ax
dot11ax multicast-nss
Use dot11ax multicast-nss to set the multicast NSS and specify an HE-MCS index for 802.11ax radios.
Use undo dot11ax multicast-nss to restore the default.
dot11ax multicast-nss nss-number he-mcs index
No multicast NSS is set for an 802.11ax radio interface.
index: Specifies an HE-MCS index in the range of 0 to 11.
Before configuring this command, you must configure the dot11ax mandatory maximum-nss command.
This command is applicable only to 802.11ax and 802.11gax radios. Changing the radio mode to a non-802.11ax mode invalidates the command.
# Set the maximum mandatory NSS, multicast NSS, and HE-MCS index to 2, 2, and 2, respectively.
[Sysname-WLAN-Radio1/0/1] dot11ax mandatory maximum-nss 2
[Sysname-WLAN-Radio1/0/1] dot11ax multicast-nss 2 he-mcs 2
dot11ax support maximum-nss
Use dot11ax support maximum-nss to set the maximum supported NSS for 802.11ax radios.
Use undo dot11ax support maximum-nss to restore the default.
dot11ax support maximum-nss nss-number
The maximum supported NSS is 8 for an 802.11ax radio interface.
# Set the maximum supported NSS to 8.
[Sysname-WLAN-Radio1/0/1] dot11ax support maximum-nss 8
type dot11ax
dot11n mandatory maximum-mcs
Use dot11n mandatory maximum-mcs to set the maximum mandatory MCS index.
Use undo dot11n mandatory maximum-mcs to restore the default.
dot11n mandatory maximum-mcs index
No maximum mandatory MCS index is set.
index: Specifies the maximum mandatory MCS index in the range of 0 to 76.
This command is applicable only to 802.11n and 802.11ac, 802.11ax, and 802.11gax radios. Changing the radio mode to 802.11a, 802.11b, or 802.11g invalidates the command.
Before configuring the dot11n multicast-mcs command, you must set the maximum mandatory MCS index.
After you modify the maximum mandatory MCS index, clients that are associated with the radio and that do not support the modified MCS index will go offline.
# Set the maximum mandatory MCS index to 14.
[Sysname-WLAN-Radio1/0/1] dot11n mandatory maximum-mcs 14
Use dot11n multicast-mcs to set the multicast MCS index.
Use undo dot11n multicast-mcs to restore the default.
dot11n multicast-mcs index
No multicast MCS index is set.
index: Specifies the multicast MCS index in the range of 0 to 76.
The multicast MCS index takes effect only when the radio associates only with 802.11n and 802.11ac clients.
If 802.11a/b/g clients exist, the AP and clients use the 802.11a/b/g multicast rate to multicast packets.
The multicast MCS index maps to a rate in 20 MHz bandwidth mode regardless of whether the bandwidth mode is 20 MHz or 40 MHz.
# Set the multicast MCS index to 14.
[Sysname-WLAN-Radio1/0/1] dot11n mandatory maximum-mcs 15
[Sysname-WLAN-Radio1/0/1] dot11n multicast-mcs 14
dot11n protection
Use dot11n protection enable to enable 802.11n protection.
Use dot11n protection disable to disable 802.11n protection.
Use undo dot11n protection to restore the default.
dot11n protection { disable | enable }
802.11n protection is disabled.
This command is applicable only to 802.11n and 802.11ac, 802.11ax, and 802.11gax radios. If you change the mode of a radio to a mode other than the three modes, the 802.11n protection configuration is removed.
802.11n, 802.11ac, and 802.11gac devices notify clients that 802.11n protection is started when 802.11a/b/g signals are detected on the channel.
802.11n protection automatically takes effect when 802.11a/b/g clients associate with an 802.11n and 802.11ac radio.
# Enable 802.11n protection.
[Sysname-WLAN-Radio1/0/1] dot11n protection enable
dot11n support maximum-mcs
Use dot11n support maximum-mcs to set the maximum supported MCS index.
Use undo dot11n support maximum-mcs to restore the default.
dot11n support maximum-mcs index
The maximum supported MCS index is 76.
index: Specifies the maximum supported MCS index in the range of 0 to 76.
The maximum supported MCS index cannot be smaller than the maximum mandatory MCS index.
# Set the maximum supported MCS index to 14.
[Sysname-WLAN-Radio1/0/1] dot11n support maximum-mcs 14
dtim
Use dtim to set the Delivery Traffic Indication Map (DTIM) interval.
Use undo dtim to restore the default.
dtim counter
undo dtim
The DTIM interval is 1. The AP sends buffered broadcast and multicast frames after every beacon frame.
counter: Specifies the DTIM interval in the range of 1 to 31.
An AP periodically broadcasts a beacon compliant with the DTIM. After the AP broadcasts the beacon, it sends buffered broadcast and multicast frames based on the value of the DTIM interval. For example, if you set the DTIM interval to 5, the AP sends buffered broadcast and multicast frames every five beacon frames.
# Set the DTIM interval to 5.
[Sysname-WLAN-Radio1/0/1] dtim 5
green-energy-management
Use green-energy-management enable to enable the energy-saving feature.
Use green-energy-management disable to disable the energy-saving feature.
Use undo green-energy-management to restore the default.
green-energy-management { disable | enable }
The energy saving feature is disabled.
After you enable the energy-saving feature, the multiple-input and multiple-output (MIMO) mode of a radio automatically changes to 1x1 if no clients associate with the radio and the radio is not enabled with WIPS. This reduces power consumption.
# Enable the energy-saving feature.
[Sysname-WLAN-Radio1/0/1] green-energy-management enable
ldpc
Use ldpc enable to enable LDPC.
Use ldpc disable to disable LDPC.
Use undo ldpc to restore the default.
ldpc { disable | enable }
undo ldpc
LDPC is enabled.
The device can receive but cannot send LDPC packets.
For 802.11ax radios, LDPC is enabled by default and cannot be disabled. The ldpc disable configuration does not take effect on 802.11ax radios.
# Disable LDPC.
[Sysname-WLAN-Radio1/0/1] ldpc disable
max-power
Use max-power to set the maximum transmit power.
Use undo max-power to restore the default.
max-power radio-power
undo max-power
The AP uses the maximum supported transmit power.
radio-power: Specifies the maximum transmit power. The value range depends on the region code, channel, AP model, radio mode, antenna type, and bandwidth.
The transmit power range supported by a radio varies by region code, channel, AP model, radio mode, antenna type, and bandwidth mode. If you change these attributes for a radio after you set the maximum transmit power, the configured maximum transmit power might be out of the supported transmit power range. If this happens, the system automatically adjusts the maximum transmit power to a valid value.
# Set the maximum transmit power to 15 dBm.
[Sysname-WLAN-Radio1/0/2] max-power 15
mimo
Use mimo to specify a MIMO mode for a radio.
Use undo mimo to restore the default.
mimo { 1x1 | 2x2 | 3x3 | 4x4 | 5x5 | 6x6 | 7x7 | 8x8}
undo mimo
The default setting for this command varies by AP model.
1x1: Sends and receives signals through one spatial stream.
2x2: Sends and receives signals through two spatial streams.
3x3: Sends and receives signals through three spatial streams.
4x4: Sends and receives signals through four spatial streams.
5x5: Sends and receives signals through five spatial streams.
6x6: Sends and receives signals through six spatial streams.
7x7: Sends and receives signals through seven spatial streams.
8x8: Sends and receives signals through eight spatial streams.
MIMO enables a radio to send and receive wireless signals through multiple spatial streams. This improves system capacity and spectrum usage without requiring higher bandwidth.
# Set the MIMO mode to 2x2.
[Sysname-WLAN-Radio1/0/1] mimo 2x2
[Sysname-WLAN-Radio1/0/1] undo mimo
mu-txbf
Use mu-txbf enable to enable multi-user transmit beamforming (TxBF).
Use mu-txbf disable to disable multi-user TxBF.
Use undo mu-txbf to restore the default.
mu-txbf { disable | enable }
undo mu-txbf
Multi-user TxBF is disabled.
This command is applicable only to 802.11ac, 802.11ax, and 802.11gax radios. Changing the radio mode to 802.11a, 802.11b, 802.11g, or 802.11n invalidates the command.
TxBF enables an AP to adjust transmitting parameters based on the channel information to focus RF signals on intended clients. This feature improves the RF signal quality.
Multi-user TxBF is part of 802.11ac Wave2. Multi-user TxBF enables an AP to focus different RF signals on their intended clients to reduce interference and transmission delay. This improves traffic throughput and bandwidth usage. Multi-user TxBF is applicable to WLANs that have a large number of clients and require high bandwidth usage and low transmission delay.
Multi-user TxBF takes effect only when single-user TxBF is enabled.
As a best practice, do not modify the default MIMO settings for an AP enabled with multi-user TxBF.
# Enable multi-user TxBF.
[Sysname-WLAN-Radio1/0/1] su-txbf enable
[Sysname-WLAN-Radio1/0/1] mu-txbf enable
mimo
su-txbf
radar-detect disable
Use radar-detect disable to disable radar avoidance.
Use undo radar-detect to restore the default.
undo radar-detect
Radar avoidance is enabled.
Radar avoidance enables a radio to change its working channel or keep silent when radar signals are detected on the working channel, avoiding interference on radars. After 30 minutes, the radio switches back to the previous working channel or restarts transmission. If radar signals can still be detected, the radio changes its working channel or keeps silent again.
With this feature disabled, radios continue to transmit or receive traffic on the working channels even if radar signals are detected on the channels.
Disable radar avoidance only when you perform device debugging.
# Disable radar avoidance.
[Sysname-WLAN-Radio1/0/2] radar-detect disable
rate
Use rate to set the transmission rates for a radio.
Use undo rate to restore the default.
rate { multicast { auto | rate-value } | { disabled | mandatory | supported } rate-value }
undo rate
In radio interface view:
·     802.11a/802.11an/802.11ac/802.11ax:
¡     Prohibited rates—None.
¡     Mandatory rates—6, 12, and 24.
¡     Multicast rate—Selected from the mandatory rates.
¡     Supported rates—9, 18, 36, 48, and 54.
·     802.11b:
¡     Mandatory rates—1 and 2.
¡     Supported rates—5.5 and 11.
·     802.11g/802.11gn/802.11gax:
¡     Mandatory rates—1, 2, 5.5, and 11.
¡     Supported rates—6, 9, 12, 18, 24, 36, 48, and 54.
disabled: Specifies rates that cannot be used by an AP.
mandatory: Specifies rates that the clients must support to associate with an AP.
multicast: Specifies the rate at which an AP multicasts packets. The multicast rate must be selected from the mandatory rates.
supported: Specifies rates that an AP supports. After a client associates with an AP, the client can select a higher or lower rate from the supported rates to communicate with the AP.
auto: Automatically selects a mandatory rate as the multicast rate.
rate-value: Specifies the rate value in Mbps. You can set multiple rates and separate them by spaces. The available values for this argument are as follows:
·     802.11a/802.11an/802.11ac/802.11ax—6, 9, 12, 18, 24, 36, 48, and 54.
·     802.11b—1, 2, 5.5, and 11.
·     802.11g/802.11gn—1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54.
The mandatory rates and multicast rate cannot be null. When there is only one mandatory rate, you cannot specify the mandatory rate as a supported rate or prohibited rate.
# Set the mandatory rates to 6 Mbps, 12 Mbps, and 24 Mbps.
[Sysname-WLAN-Radio1/0/2] rate mandatory 6 12 24
stbc
Use stbc enable to enable Space-Time Block Coding (STBC).
Use stbc disable to disable STBC.
Use undo stbc to restore the default.
stbc { disable | enable }
undo stbc
STBC is enabled.
# Enable STBC.
[Sysname-WLAN-Radio1/0/1] stbc enable
su-txbf
Use su-txbf enable to enable single-user TxBF.
Use su-txbf disable to disable single-user TxBF.
Use undo su-txbf to restore the default.
su-txbf { disable | enable }
undo su-txbf
Single-user TxBF is disabled.
Single-user TxBF enables an AP to improve the signal to one intended client. Single-user TxBF is applicable to WLANs that have widely spread clients, poor network quality, and serious signal attenuation.
# Enable single-user TxBF.
mimo
mu-txbf
type
Use type to specify a radio mode.
Use undo type to restore the default.
type { dot11a | dot11ac | dot11an | dot11ax | dot11b | dot11g | dot11gax | dot11gn }
undo type
The default setting varies by radio ID.
dot11a: Specifies the 802.11a radio mode.
dot11ac: Specifies the 802.11ac (5 GHz) radio mode.
dot11an: Specifies the 802.11n (5 GHz) radio mode.
dot11ax: Specifies the 802.11ax (5 GHz) radio mode.
dot11b: Specifies the 802.11b radio mode.
dot11g: Specifies the 802.11g radio mode.
dot11gax: Specifies the 802.11ax (2.4 GHz) radio mode.
dot11gn: Specifies the 802.11n (2.4 GHz) radio mode.
CAUTION
CAUTION:
Modifying the mode of an enabled radio logs off all associated clients.
# Set the radio mode to 802.11n (5 GHz).
[Sysname-WLAN-Radio1/0/2] type dot11an
ul-mu-mimo
Use ul-mu-mimo enable to enable uplink MU-MIMO.
Use ul-mu-mimo disable to disable uplink MU-MIMO.
Use undo ul-mu-mimo to restore the default.
ul-mu-mimo { disable | enable }
undo ul-mu-mimo
Uplink MU-MIMO is disabled.
Uplink MU-MIMO enables an AP to receive data packets from multiple clients concurrently. With this feature enabled, an AP sends an HE_Trig message to all associated clients to inform the transmission time, frequency, sampling clock, and power requirements. Upon receiving the message, clients send data packets to the AP as required at the same time.
This feature is applicable to scenarios that have a large number of clients and high AP bandwidth usage and transmission latency requirements.
Only radios enabled with the client mode support this feature.
# Enable uplink MU-MIMO.
[Sysname-WLAN-Radio1/0/2] ul-mu-mimo enable
mu-txbf
ul-ofdma
Use ul-ofdma enable to enable uplink OFDMA.
Use ul-ofdma disable to disable uplink OFDMA.
Use undo ul-ofdma to restore the default.
ul-ofdma { disable | enable }
undo ul-ofdma
Uplink OFDMA is disabled.
# Enable uplink OFDMA.
[Sysname-WLAN-Radio1/0/2] ul-ofdma enable
type dot11ax
wlan error-frame optimization
Use wlan error-frame optimization to set the index for optimizing the error packet ratio.
Use undo wlan error-frame optimization to restore the default.
wlan error-frame optimization value
The index for optimizing the error packet ratio is not specified.
value: Specifies the index for optimizing the error packet ratio, in the range of 0 to 1000. The smaller the index is, the smaller the recalculated ratio will be.
The error packet ratio is the number of received error data packets divided by the total number of received data packets.
This command enables the device to recalculate the error packet ratio by using the specified index to get a smaller radio value.
# Set the index for optimizing the error packet ratio to 100.
[Sysname] wlan error-frame optimization 100
wlan retransmit-frame optimization
Use wlan retransmit-frame optimization to set the index for optimizing the retransmission ratio.
Use undo wlan retransmit-frame optimization to restore the default.
wlan retransmit-frame optimization value
The index for optimizing the retransmission ratio is not set.
Default user roles
value: Specifies the index for optimizing the retransmission ratio, in the range of 0 to 100. The smaller the index is, the smaller the recalculated ratio will be.
The retransmission ratio is the number of retransmitted data packets divided by the total number of transmitted data packets.
This command enables the device to recalculate the retransmission ratio by using the specified index to get a smaller ratio value.
# Set the index for optimizing the retransmission ratio to 100.
[Sysname] wlan retransmit-frame optimization 100
