- 09-MPLS Configuration Guide
- 01-Basic MPLS configuration
- 02-Static LSP configuration
- 03-LDP configuration
- 04-MPLS TE configuration
- 05-Static CRLSP configuration
- 06-RSVP configuration
- 07-Tunnel policy configuration
- 08-MPLS L3VPN configuration
- 09-MPLS L2VPN configuration
- 10-VPLS configuration
- 11-L2VPN access to L3VPN or IP backbone configuration
- 12-MPLS OAM configuration
- 13-MCE configuration
08-MPLS L3VPN configuration | 5.12 MB |
MPLS L3VPN route advertisement
BGP AS number substitution and SoO attribute
Associating a VPN instance with a Layer 3 interface
Configuring route related attributes for a VPN instance
Configuring routing between a PE and a CE
Configuring static routing between a PE and a CE
Configuring RIP between a PE and a CE
Configuring OSPF between a PE and a CE
Configuring IS-IS between a PE and a CE
Configuring EBGP between a PE and a CE
Configuring IBGP between a PE and a CE
Configuring routing between PEs
Configuring BGP VPNv4 route control
Controlling BGP VPNv4 route advertisement, reception, and saving
Setting a preferred value for received routes
Configuring BGP VPNv4 route reflection
Configuring BGP VPNv4 route attributes
Configuring BGP VPNv4 route filtering
Configuring BGP VPNv4 route dampening
Configuring BGP VPNv4 optimal route selection delay
Setting the delay time for responding to BGP VPNv4 recursive next hop changes
Configuring BGP VPNv4 routes to use private network next hops
Changing the BGP VPNv4 route selection rules
Advertising BGP RPKI validation state to a peer or peer group
Enabling MPLS IP packet fragmentation
Configuring inter-AS option C (method 1)
Configuring inter-AS option C (method 2)
About configuring multirole host
Configuring route re-origination
Specifying the VPN label processing mode on the egress PE
Configuring FRR by using a routing policy
Enabling MPLS L3VPN FRR for BGP-VPN IPv4 unicast address family or BGP VPNv4 address family view
Configuring a TTL processing mode for tunnels associated with a VPN instance
Redistributing the loopback interface address
Configuring BGP AS number substitution and SoO attribute
Configuring the AIGP attribute
Configuring the BGP additional path feature
Enabling the VPN Prefix ORF feature
Configuring the public instance
Configuring route replication for public and VPN instances
Configuring BGP route replication between public and VPN instances
Enabling redistribution of multiple same-prefix routes with the same RD
Enabling prioritized withdrawal of specific routes
Enabling SNMP notifications for MPLS L3VPN
Enabling logging for BGP route flapping
Display and maintenance commands for MPLS L3VPN
Displaying and maintaining MPLS L3VPN information
MPLS L3VPN configuration examples
Example: Configuring basic MPLS L3VPN
Example: Configuring MPLS L3VPN over a GRE tunnel
Example: Configuring a hub-spoke network
Example: Configuring MPLS L3VPN inter-AS option A
Example: Configuring MPLS L3VPN inter-AS option B
Example: Configuring MPLS L3VPN carrier's carrier in the same AS
Example: Configuring nested VPN
Example: Configuring multirole host
Example: Configuring an OSPF sham link
Example: Configuring BGP AS number substitution
Example: Configuring BGP AS number substitution and SoO attribute
Example: Configuring MPLS L3VPN FRR through VPNv4 route backup for a VPNv4 route
Example: Configuring MPLS L3VPN FRR through VPNv4 route backup for an IPv4 route
Example: Configuring MPLS L3VPN FRR through IPv4 route backup for a VPNv4 route
IPv6 MPLS L3VPN network diagram
IPv6 MPLS L3VPN packet forwarding
IPv6 MPLS L3VPN routing information advertisement
IPv6 MPLS L3VPN network schemes and features
IPv6 MPLS L3VPN tasks at a glance
Restrictions and guidelines: IPv6 MPLS L3VPN configuration
Prerequisites for IPv6 MPLS L3VPN
Configuring IPv6 static routing between a PE and a CE
Configuring RIPng between a PE and a CE
Configuring OSPFv3 between a PE and a CE
Configuring IPv6 IS-IS between a PE and a CE
Configuring BGP VPNv6 route control
Controlling BGP VPNv6 route saving
Specifying a preferred value for BGP VPNv6 routes
Setting the maximum number of received routes
Configuring BGP VPNv6 route reflection
Configuring BGP VPNv6 route attributes
Configuring BGP VPNv6 route filtering
Configuring BGP VPNv6 route dampening
Configuring BGP VPNv6 optimal route selection delay
Setting the delay time for responding to BGP VPNv6 recursive next hop changes
Configuring BGP VPNv6 routes to use private network next hops
Changing the BGP VPNv6 route selection rules
Configuring inter-AS IPv6 VPN option A
Configuring inter-AS IPv6 VPN option B
Configuring inter-AS IPv6 VPN option C (method 1)
Configuring inter-AS IPv6 VPN option C (method 2)
Configuring IPv6 MPLS L3VPN FRR
Enabling MPLS L3VPN FRR for BGP-VPN IPv6 unicast address family or BGP VPNv6 address family
Configuring an OSPFv3 sham link
Display and maintenance commands for IPv6 MPLS L3VPN
Displaying and maintaining IPv6 MPLS L3VPN information
IPv6 MPLS L3VPN configuration examples
Example: Configuring IPv6 MPLS L3VPNs
Example: Configuring an IPv6 MPLS L3VPN over a GRE tunnel
Example: Configuring IPv6 MPLS L3VPN inter-AS option A
Example: Configuring IPv6 MPLS L3VPN inter-AS option B
Example: Configuring IPv6 MPLS L3VPN inter-AS option C (method 1)
Example: Configuring IPv6 MPLS L3VPN inter-AS option C (method 2)
Example: Configuring IPv6 MPLS L3VPN carrier's carrier in the same AS
Example: Configuring an OSPFv3 sham link
About MPLS L3VPN
MPLS L3VPN is a L3VPN technology used to interconnect geographically dispersed VPN sites. MPLS L3VPN uses BGP to advertise VPN routes and uses MPLS to forward VPN packets over a service provider backbone. MPLS L3VPN provides flexible networking modes, excellent scalability, and convenient support for MPLS QoS and MPLS TE.
Basic MPLS L3VPN architecture
As shown in Figure 1, a basic MPLS L3VPN architecture has the following types of devices:
· Customer edge device—A CE device resides on a customer network and has one or more interfaces directly connected to a service provider network. It does not support MPLS.
· Provider edge device—A PE device resides at the edge of a service provider network and is connected to one or more CEs. All MPLS VPN services are processed on PEs.
· Provider device—A P device is a core device on a service provider network. It is not directly connected to any CEs. A P device has only basic MPLS forwarding capability and does not handle VPN routing information.
Figure 1 Basic MPLS L3VPN architecture
MPLS L3VPN concepts
Site
A site has the following features:
· A site is a group of IP systems with IP connectivity that does not rely on any service provider networks.
· The classification of a site depends on the topology relationship of the devices, rather than the geographical positions. However, the devices at a site are, in most cases, adjacent to each other geographically.
· The devices at a site can belong to multiple VPNs, which means that a site can belong to multiple VPNs.
· A site is connected to a provider network through one or more CEs. A site can contain multiple CEs, but a CE can belong to only one site.
Sites connected to the same provider network can be classified into different sets by policies. Only the sites in the same set can access each other through the provider network. Such a set is called a VPN.
VPN instance
VPN instances implement route isolation, data independence, and data security for VPNs.
A VPN instance has the following components:
· A separate Label Forwarding Information Base (LFIB).
· An IP routing table.
· Interfaces bound to the VPN instance.
· VPN instance administration information, including route distinguishers (RDs), route targets (RTs), and route filtering policies.
To associate a site with a VPN instance, bind the VPN instance to the PE's interface connected to the site. A site can be associated with only one VPN instance, and different sites can be associated with the same VPN instance. A VPN instance contains the VPN membership and routing rules of associated sites.
VPN-IPv4 address
Each VPN independently manages its address space. The address spaces of VPNs might overlap. For example, if both VPN 1 and VPN 2 use the addresses on subnet 10.110.10.0/24, address space overlapping occurs.
BGP cannot process overlapping VPN address spaces. For example, if both VPN 1 and VPN 2 use the subnet 10.110.10.0/24 and each advertise a route destined for the subnet, BGP selects only one of them. This results in the loss of the other route.
Multiprotocol BGP (MP-BGP) can solve this problem by advertising VPN-IPv4 addresses (also called VPNv4 addresses).
Figure 2 VPN-IPv4 address structure
As shown in Figure 2, a VPN-IPv4 address consists of 12 bytes. The first eight bytes represent the RD, followed by a four-byte IPv4 prefix. The RD and the IPv4 prefix form a unique VPN-IPv4 prefix.
An RD can be in one of the following formats:
· When the Type field is 0, the Administrator subfield occupies two bytes, the Assigned number subfield occupies four bytes, and the RD format is 16-bit AS number:32-bit user-defined number. For example, 100:1.
· When the Type field is 1, the Administrator subfield occupies four bytes, the Assigned number subfield occupies two bytes, and the RD format is 32-bit IPv4 address:16-bit user-defined number. For example, 172.1.1.1:1.
· When the Type field is 2, the Administrator subfield occupies four bytes, the Assigned number subfield occupies two bytes, and the RD format is 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
To guarantee global uniqueness for a VPN-IPv4 address, do not set the Administrator subfield to any private AS number or private IP address.
Route target attribute
MPLS L3VPN uses route target (also called VPN target) community attributes to control the advertisement of VPN routing information. A VPN instance on a PE supports the following types of route target attributes:
· Export target attribute—A PE sets the export target attribute for VPN-IPv4 routes learned from directly connected sites before advertising them to other PEs.
· Import target attribute—A PE checks the export target attribute of VPN-IPv4 routes received from other PEs. If the export target attribute matches the import target attribute of a VPN instance, the PE adds the routes to the routing table of the VPN instance.
Route target attributes define which sites can receive VPN-IPv4 routes, and from which sites a PE can receive routes.
Like RDs, route target attributes can be one of the following formats:
· 16-bit integer-format AS number:32-bit user-defined number, for example, 101:3.
· 16-bit dotted-format AS number:32-bit user-defined number, for example, 0.1:1. The value range for the AS number is 0.1 to 0.65535.
· 32-bit IP address:16-bit user-defined number, for example, 192.168.122.15:1.
· 32-bit integer-format AS number:16-bit user-defined number, for example, 65536:1. The minimum value of the AS number is 65536.
· 32-bit dotted-format AS number:16-bit user-defined number, for example, 10.1:1. The minimum value of the AS number is 1.0.
MP-BGP
MP-BGP supports multiple address families, including IPv4 multicast address family and VPN-IPv4 address family.
In MPLS L3VPN, MP-BGP advertises VPN-IPv4 routes for VPN sites between PEs.
In a basic MPLS L3VPN, CEs and PEs are responsible for advertising VPN routing information. P routers maintain only the routes within the backbone. A PE maintains only routing information for directly connected VPNs, rather than for all VPNs.
VPN routing information is advertised through the path local CE—ingress PE—egress PE—remote CE.
Route advertisement from the local CE to the ingress PE
The CE advertises standard IPv4 routing information to the ingress PE over a static route, RIP route, OSPF route, IS-IS route, EBGP route, or IBGP route.
Route advertisement from the ingress PE to the egress PE
The ingress PE performs the following operations:
1. Adds RDs and route target attributes to these standard IPv4 routes to create VPN-IPv4 routes.
2. Saves the VPN-IPv4 routes to the routing table of the VPN instance created for the CE.
3. Advertises the VPN-IPv4 routes to the egress PE through MP-BGP.
PEs can also exchange labels through BGP EVPN routes. For more information, see EVPN Configuration Guide.
Route advertisement from the egress PE to the remote CE
After receiving the VPN-IPv4 routes, the egress PE performs the following operations:
1. Compares the routes' export target attributes with the local import target attributes.
2. Adds the routes to the routing table of the VPN instance if the export and local import target attributes match each other.
3. Restores the VPN-IPv4 routes to the original IPv4 routes.
4. Advertises those routes to the connected CE over a static route, RIP route, OSPF route, IS-IS route, EBGP route, or IBGP route.
In a basic MPLS L3VPN (within a single AS), a PE adds the following information into VPN packets:
· Outer tag—Identifies the public tunnel from the local PE to the remote PE. The public tunnel can be an LSP, an MPLS TE tunnel, or a GRE tunnel. Based on the outer tag, a VPN packet can be forwarded along the public tunnel to the remote PE. For a GRE public tunnel, the outer tag is the GRE encapsulation. For an LSP or MPLS TE tunnel, the outer tag is an MPLS label.
NOTE: In the current software version, the device does not support using GRE/IPv6 tunnels as public tunnels for MPLS L3VPN. |
· Inner label—Identifies the remote VPN site. The remote PE uses the inner label to forward packets to the target VPN site. MP-BGP advertises inner labels for VPN-IPv4 routes among PEs.
Figure 3 VPN packet forwarding
As shown in Figure 3, a VPN packet is forwarded from Site 1 to Site 2 by using the following process:
2. Site 1 sends an IP packet with the destination address 1.1.1.2. CE 1 transmits the packet to PE 1.
3. PE 1 performs the following operations:
a. Finds the matching VPN route based on the inbound interface and destination address of the packet.
b. Labels the packet with both the inner label and the outer tag.
c. Forwards the packet to the public tunnel.
4. P devices forward the packet to PE 2 by the outer tag.
¡ If the outer tag is an MPLS label, the label is removed from the packet at the penultimate hop.
¡ If the outer tag is GRE encapsulation, PE 2 removes the GRE encapsulation.
5. PE 2 performs the following operations:
a. Uses the inner label to find the matching VPN instance to which the destination address of the packet belongs.
b. Looks up the routing table of the VPN instance for the output interface.
c. Removes the inner label and forwards the packet out of the interface to CE 2.
6. CE 2 transmits the packet to the destination through IP forwarding.
When two sites of a VPN are connected to the same PE, the PE directly forwards packets between the two sites through the VPN routing table without adding any tag or label.
MPLS L3VPN networking schemes
In MPLS L3VPNs, route target attributes are used to control the advertisement and reception of VPN routes between sites. They work independently and can be configured with multiple values to support flexible VPN access control and implement multiple types of VPN networking schemes.
Basic VPN networking scheme
In the simplest case, all users in a VPN form a closed user group. They can forward traffic to each other but cannot communicate with any user outside the VPN.
For the basic VPN networking scheme, you must assign a route target to each VPN for identifying the export target attribute and import target attribute of the VPN. Moreover, this route target cannot be used by any other VPNs.
Figure 4 Network diagram for basic VPN networking scheme
As shown in Figure 4, the route target for VPN 1 is 100:1, while that for VPN 2 is 200:1. The two VPN 1 sites can communicate with each other, and the two VPN 2 sites can communicate with each other. However, the VPN 1 sites cannot communicate with the VPN 2 sites.
Hub and spoke networking scheme
The hub and spoke networking scheme is suitable for a VPN where all users must communicate with each other through an access control device.
In a hub and spoke network as shown in Figure 5, configure route targets as follows:
· On spoke PEs (PEs connected to spoke sites), set the export target to Spoke and the import target to Hub.
· On the hub PE (PE connected to the hub site), use two interfaces that each belong to a different VPN instance to connect the hub CE. One VPN instance receives routes from spoke PEs and has the import target set to Spoke. The other VPN instance advertises routes to spoke PEs and has the export target set to Hub.
These route targets rules produce the following results:
· The hub PE can receive all VPN-IPv4 routes from spoke PEs.
· All spoke PEs can receive VPN-IPv4 routes advertised by the hub PE.
· The hub PE advertises the routes learned from a spoke PE to the other spoke PEs so the spoke sites can communicate with each other through the hub site.
· The import target attribute of a spoke PE is different from the export target attribute of any other spoke PE. Any two spoke PEs do not directly advertise VPN-IPv4 routes to each other. Therefore, they cannot directly access each other.
Figure 5 Network diagram for hub and spoke network
A route in Site 1 is advertised to Site 2 by using the following process:
2. Spoke-CE 1 advertises a route in Site 1 to Spoke-PE 1.
3. Spoke-PE 1 changes the route to a VPN-IPv4 route and advertises the VPN-IPv4 route to Hub-PE through MP-BGP.
4. Hub-PE adds the VPN-IPv4 route into the routing table of VPN 1-in, changes it to the original IPv4 route, and advertises the IPv4 route to Hub-CE.
5. Hub-CE advertises the IPv4 route back to Hub-PE.
6. Hub-PE adds the IPv4 route to the routing table of VPN 1-out, changes it to a VPN-IPv4 route, and advertises the VPN-IPv4 route to Spoke-PE 2 through MP-BGP.
7. Spoke-PE 2 changes the VPN-IPv4 route to the original IPv4 route, and advertises the IPv4 route to Site 2.
After spoke sites exchange routes through the hub site, they can communicate with each other through the hub site.
Extranet networking scheme
The extranet networking scheme allows specific resources in a VPN to be accessed by users not in the VPN.
In this networking scheme, if a VPN instance needs to access a shared site, the export target attribute and the import target attribute of the VPN instance must be contained in the import target attribute and the export target attribute of the VPN instance of the shared site, respectively.
Figure 6 Network diagram for extranet networking scheme
As shown in Figure 6, route targets configured on PEs produce the following results:
· PE 3 can receive VPN-IPv4 routes from PE 1 and PE 2.
· PE 1 and PE 2 can receive VPN-IPv4 routes advertised by PE 3.
· Site 1 and Site 3 of VPN 1 can communicate with each other, and Site 2 of VPN 2 and Site 3 of VPN 1 can communicate with each other.
· PE 3 advertises neither the VPN-IPv4 routes received from PE 1 to PE 2 nor the VPN-IPv4 routes received from PE 2 to PE 1 (routes learned from an IBGP neighbor are not advertised to any other IBGP neighbor). Therefore, Site 1 of VPN 1 and Site 2 of VPN 2 cannot communicate with each other.
Inter-AS VPN
In an inter-AS VPN networking scenario, multiple sites of a VPN are connected to multiple ISPs in different ASs, or to multiple ASs of an ISP.
Inter AS-VPN provides the following solutions:
· VRF-to-VRF connections between ASBRs—This solution is also called inter-AS option A.
· EBGP redistribution of labeled VPN-IPv4 routes between ASBRs—ASBRs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option B.
· Multihop EBGP redistribution of labeled VPN-IPv4 routes between PE routers—PEs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option C.
Inter-AS option A
In this solution, PEs of two ASs are directly connected, and each PE is also the ASBR of its AS. Each PE treats the other as a CE and advertises unlabeled IPv4 unicast routes through EBGP. The PEs associate a VPN instance with a minimum of one interface.
Figure 7 Network diagram for inter-AS option A
As shown in Figure 7, in VPN 1, routes are advertised from CE 1 to CE 3 by using the following process:
2. PE 1 advertises the VPN routes learned from CE 1 to ASBR 1 through MP-IBGP.
3. ASBR 1 performs the following operations:
a. Adds the routes to the routing table of the VPN instance whose import target attribute matches the export target attribute of the routes.
b. Advertises the routes as IPv4 unicast routes to its CE (ASBR 2) through EBGP.
4. ASBR 2 adds the IPv4 unicast routes to the routing table of the VPN instance that is bound to the receiving interface, and advertises the routes to PE 3 through MP-IBGP.
5. PE 3 advertises the received routes to CE 3.
Packets forwarded within an AS are VPN packets that carry two labels. Packets forwarded between ASBRs are common IP packets.
Inter-AS option A is easy to carry out because no special configuration is required on the PEs acting as the ASBRs.
However, it has limited scalability because the PEs acting as the ASBRs must manage all the VPN routes and create VPN instances on a per-VPN basis. This leads to excessive VPN-IPv4 routes on the PEs. Associating a separate interface with each VPN also requires additional system resources.
Inter-AS option B
In this solution, two ASBRs use MP-EBGP to exchange VPN-IPv4 routes that they obtain from the PEs in their respective ASs.
Figure 8 Network diagram for inter-AS option B
As shown in Figure 8, in VPN 1, routes are advertised from CE 1 to CE 3 by using the following process:
Assume that the inner label assigned by PE 1 for the routes is L1.
3. ASBR 1 advertises the VPN-IPv4 routes to ASBR 2 through MP-EBGP.
Before advertising the routes, ASBR 1 modifies the next hop as its own address, assigns a new inner label (L2) to the routes, and associates L1 with L2.
4. ASBR 2 advertises the VPN-IPv4 routes to PE 3 through MP-IBGP.
Before advertising the routes, ASBR 2 modifies the next hop as its own address, assigns a new inner label (L3) to the routes, and associates L2 with L3.
A packet is forwarded from CE 3 to CE 1 by using the following process:
6. PE 3 encapsulates the received packet with two labels, and forwards the encapsulated packet to ASBR 2.
One of the labels is L3, and the other is the outer tag for the public tunnel from PE 3 to ASBR 2.
7. ASBR 2 removes the outer tag, replaces L3 with L2, and forwards the packet to ASBR 1.
Packets between ASBR 1 and ASBR 2 carry only one inner label.
8. ASBR 1 replaces L2 with L1, adds the outer tag of the public tunnel from ASBR 1 to PE 1, and forwards the packet to PE 1.
9. PE 1 removes the inner label and outer tag and forwards the packet to CE 1.
In this solution, ASBRs must receive all inter-AS VPN routes. Therefore, ASBRs cannot filter incoming VPN-IPv4 routes by route targets.
Inter-AS option B has better scalability than option A. However, it requires that ASBRs maintain and advertise VPN routes.
Inter-AS option C
The Inter-AS option A and option B solutions require that the ASBRs maintain and advertise VPN-IPv4 routes. When every AS needs to exchange a great amount of VPN routes, the ASBRs might become bottlenecks, which hinders network extension. Inter-AS option C has better scalability because it makes PEs directly exchange VPN-IPv4 routes.
In this solution, PEs exchange VPN-IPv4 routes over a multihop MP-EBGP session. Each PE must have a route to the peer PE and a label for the route so that the inter-AS public tunnel between the PEs can be set up. Inter-AS option C sets up a public tunnel by using the following methods:
· Method 1:
a. The PE and the ASBR within an AS establish a public tunnel by using a label distribution protocol such as LDP.
b. The local and remote ASBRs advertise labeled IPv4 unicast routes through BGP to establish an inter-AS public tunnel.
Labeled IPv4 unicast route advertisement refers to the process of assigning MPLS labels to IPv4 unicast routes and advertising IPv4 unicast routes and their labels.
· Method 2:
In method 2, the PE and ASBR within an AS do not need to establish an IBGP peer relationship.
c. The local ASBR redistributes IGP routes to the BGP routing table, assigns labels to the routes, and advertises the labeled routes to the remote ASBR.
d. The remote ASBR redistributes BGP routes to the IGP routing table.
e. The local and remote PEs then can learn the route s to reach each other. After the PEs learn the routes to each other, they establish a public tunnel by using a label distribution protocol such as LDP.
The following is an example of configuring inter-AS option C by using method 1.
Figure 9 Network diagram for inter-AS option C (method 1)
As shown in Figure 9, in VPN 1, routes are advertised from CE 1 to CE 3 by using the following process:
2. PE 1 advertises the VPN routes learned from CE 1 as VPN-IPv4 routes to PE 3 through multihop MP-EBGP.
Assume that the inner label assigned by PE 1 for the routes is Lx.
3. PE 3 advertises the received routes to CE 3.
Setting up an inter-AS public tunnel is difficult in this solution. A public tunnel, for example, the one from PE 3 to PE 1, is set up by using the following process:
4. Within AS 100, the public tunnel from ASBR 1 to PE 1 is set up by using a label distribution protocol, for example, LDP.
Assume that the outgoing label for the public tunnel on ASBR 1 is L1.
5. ASBR 1 advertises labeled IPv4 unicast routes to ASBR 2 through EBGP.
The route destined for PE 1 and the label (L2) assigned by ASBR 1 for the route are advertised from ASBR 1 to ASBR 2. The next hop of the route is ASBR 1. The public tunnel from ASBR 2 to ASBR 1 is set up. The incoming label for the public tunnel on ASBR 1 is L2.
6. ASBR 2 advertises labeled IPv4 unicast routes to PE 3 through IBGP.
The route destined for PE 1 and the label (L3) assigned by ASBR 2 for the route are advertised from ASBR 2 to PE 3. The next hop for the route is ASBR 2. The public tunnel from PE 3 to ASBR 2 is set up. The incoming label for the public tunnel on ASBR 2 is L3, and the outgoing label is L2.
7. MPLS packets cannot be forwarded directly from PE 3 to ASBR 2. Within AS 200, the public tunnel from PE 3 to ASBR 2 is required to be set up hop by hop through a label distribution protocol, for example, LDP.
Assume that the outgoing label for the public tunnel on PE 3 is Lv.
After route advertisement and public tunnel setup, a packet is forwarded from CE 3 to CE 1 by using the following process:
8. PE 3 performs the following routing table lookups for the packet:
a. Finds a matching route with next hop PE 1 and inner label Lx, and encapsulates the packet with label Lx.
b. Finds the route to PE 1 with next hop ASBR 2 and label L3, and encapsulates the packet with label L3 as the outer label.
c. Finds the route to ASBR 2 with outgoing label Lv, and encapsulates the packet with label Lv as the outmost label.
9. AS 200 transmits the packet to ASBR 2 by the outmost label.
10. ASBR 2 removes the outmost label, replaces L3 with L2, and forwards the packet to ASBR 1.
11. ASBR 1 replaces L2 with L1, and forwards the packet.
12. AS 100 transmits the packet to PE 1 by the outer label.
13. PE 1 removes the outer label, and forwards the packet to CE 1 according to the inner label Lx.
As shown in Figure 10, to improve scalability, you can specify a route reflector (RR) in each AS to exchange VPN-IPv4 routes with PEs in the same AS. The RR in each AS maintains all VPN-IPv4 routes. The RRs in two ASs establish a multihop MP-EBGP session to advertise VPN-IPv4 routes.
Figure 10 Network diagram for inter-AS option C using RRs
Carrier's carrier
If a customer of an MPLS L3VPN service provider is also a service provider:
· The MPLS L3VPN service provider is called the provider carrier or the Level 1 carrier.
· The customer is called the customer carrier or the Level 2 carrier.
This networking model is referred to as carrier's carrier.
The PEs of the Level 2 carrier directly exchange customer networks over a BGP session. The Level 1 carrier only learns the backbone networks of the Level 2 carrier, without learning customer networks.
For packets between customer networks to travel through the Level 1 carrier, the PE of the Level 1 carrier and the CE of the Level 2 carrier must assign labels to the backbone networks of the Level 2 carrier. The CE of the Level 2 carrier is a PE within the Level 2 carrier network.
Follow these guidelines to assign labels:
· If the PE and the CE are in the same AS, you must configure IGP and LDP between them. If they are in different ASs, you must configure MP-EBGP to assign labels to IPv4 unicast routes exchanged between them.
· You must enable MPLS on the CE of the Level 2 carrier regardless of whether the PE and CE are in the same AS.
A Level 2 carrier can be an ordinary ISP or an MPLS L3VPN service provider.
As shown in Figure 11, when the customer carrier is an ordinary ISP, its PEs and CEs run IGP to communicate with each other. The PEs do not need to run MPLS. PE 3 and PE 4 exchange customer network routes (IPv4 unicast routes) through an IBGP session.
Figure 11 Scenario where the Level 2 carrier is an ISP
As shown in Figure 12, when the customer carrier is an MPLS L3VPN service provider, its PEs and CEs must run IGP and LDP to communicate with each other. PE 3 and PE 4 exchange customer network routes (VPN-IPv4 routes) through an MP-IBGP session.
Figure 12 Scenario where the Level 2 carrier is an MPLS L3VPN service provider
NOTE: As a best practice, establish equal cost LSPs between the Level 1 carrier and the Level 2 carrier if equal cost routes exist between them. |
Nested VPN
The nested VPN technology exchanges VPNv4 routes between PEs and CEs of the ISP MPLS L3VPN and allows a customer to manage its own internal VPNs. Figure 13 shows a nested VPN network. On the service provider's MPLS VPN network, there is a customer VPN named VPN A. The customer VPN contains two sub-VPNs, VPN A-1 and VPN A-2.
The service provider PEs consider the customer's network as a common VPN user and do not join any sub-VPNs. The service provider CE devices (CE 1 and CE 2) exchange VPNv4 routes including sub-VPN routing information with the service provider PEs, which implements the propagation of the sub-VPN routing information throughout the customer network.
The nested VPN technology supports both symmetric networking and asymmetric networking. Sites of the same VPN can have the same number or different numbers of internal VPNs. Nested VPN also supports multiple-level nesting of internal VPNs.
Figure 13 Network diagram for nested VPN
In a nested VPN network, routing information is propagated by using the following process:
2. After receiving VPN routes from customer CEs, a customer PE advertises VPN-IPv4 routes to the provider CEs through MP-BGP.
3. The provider CEs advertise the VPN-IPv4 routes to a provider PE through MP-BGP.
4. After receiving a VPN-IPv4 route, the provider PE keeps the customer's internal VPN information, and appends the customer's MPLS VPN attributes on the service provider network. It replaces the RD of the VPN-IPv4 route with the RD of the customer's MPLS VPN on the service provider network. It also adds the export route-target (ERT) attribute of the customer's MPLS VPN on the service provider network to the extended community attribute list of the route. The internal VPN information for the customer is maintained on the provider PE.
5. The provider PE advertises VPN-IPv4 routes carrying the comprehensive VPN information to the other PEs of the service provider.
6. After another provider PE receives the VPN-IPv4 routes, it matches the VPN-IPv4 routes to the import targets of its local VPNs. Each local VPN accepts routes of its own and advertises them to provider CEs. If a provider CE (such as CE 7 and CE 8 in Figure 13) is connected to a provider PE through an IPv4 connection, the PE advertises IPv4 routes to the CE. If it is a VPN-IPv4 connection (a customer MPLS VPN network), the PE advertises VPN-IPv4 routes to the CE.
7. After receiving VPN-IPv4 routes from the provider CE, a customer PE matches those routes to local import targets. Each customer VPN accepts only its own routes and advertises them to connected customer CEs (such as CE 3, CE 4, CE 5, and CE 6 in Figure 13).
Multirole host
Typically, hosts in the same VPN can communicate with each other, and those in different VPNs cannot. However, a host or server in a site might need to access VPNs in addition to the VPN to which the host or server belongs. To simplify configuration, you can use the multirole host feature.
The multirole host feature enables a PE to use PBR to provide multiple VPN access for a host or server. The host or server is called a multirole host.
As shown in Figure 14, the multirole host in site 1 needs to access both VPN 1 and VPN 2. Other hosts in site 1 only need to access VPN 1. To configure the multirole host feature, configure PE 1 as follows:
· Create VPN instances vpn1 and vpn2 for VPN 1 and VPN 2, respectively.
· Associate VPN instance vpn1 with the interface connected to CE 1.
· Configure PBR to route packets from CE 1 first by the routing table of the associated VPN instance (vpn1). Then, if no matching route is found, route the packets according to the routing table of VPN instance vpn2. This configuration ensures that packets from Site 1 can be forwarded in both VPN 1 and VPN 2.
· Configure a static route for VPN instance vpn2 to reach the multirole host. Specify the next hop of the route as the IP address of CE 1 and specify the VPN instance to which the next hop belongs as VPN 1. This configuration ensures that packets from VPN 2 can be routed to the multirole host.
Configure static routes for all VPN instances that the multirole host needs to access, except the associated VPN instance.
IMPORTANT: IP addresses in all VPNs that the multirole host can access must not overlap. |
HoVPN
Hierarchy of VPN (HoVPN), also called Hierarchy of PE (HoPE), prevents PEs from being bottlenecks and is applicable to large-scale VPN deployment.
HoVPN divides PEs into underlayer PEs (UPEs) or user-end PEs, and superstratum PEs (SPEs) or service provider-end PEs. UPEs and SPEs have different functions and comprise a hierarchical PE. The HoPE and common PEs can coexist in an MPLS network.
Figure 15 Basic architecture of HoVPN
As shown in Figure 15, UPEs and SPEs play the following different roles:
· A UPE is directly connected to CEs. It provides user access. It maintains the routes of directly connected VPN sites. It does not maintain the routes of the remote sites in the VPN, or it only maintains their summary routes. A UPE assigns inner labels to the routes of its directly connected sites, and advertises the labels along with VPN routes to the SPE through MP-BGP. A UPE features high access capability, small routing table capacity, and low forwarding performance.
· An SPE is connected to UPEs and resides inside the service provider network. It manages and advertises VPN routes. It maintains all the routes of the VPNs connected through UPEs, including the routes of both the local and remote sites. An SPE advertises routes along with labels to UPEs, including the default routes of VPN instances or summary routes and the routes permitted by the routing policy. By using routing policies, you can control which sites in a VPN can communicate with each other. An SPE features large routing table capacity, high forwarding performance, and fewer interface resources.
Either MP-IBGP or MP-EBGP can run between SPE and UPE. When MP-IBGP runs between SPE and UPEs, the SPE acts as the RR of multiple UPEs and reflects routes between UPEs.
HoVPN supports HoPE recursion:
· An HoPE can act as a UPE to form a new HoPE with an SPE.
· An HoPE can act as an SPE to form a new HoPE with multiple UPEs.
HoVPN supports multilevel recursion. In HoPE recursion, the concepts of SPE and UPE are relative. A PE might be the SPE of its underlayer PEs and a UPE of its SPE at the same time.
Figure 16 shows a three-level HoPE. The PE in the middle is called the middle-level PE (MPE). MP-BGP runs between SPE and MPE, and between MPE and UPE.
MP-BGP advertises the following routes:
· All the VPN routes of UPEs to the SPEs.
· The default routes of the VPN instance of the SPEs or the VPN routes permitted by the routing policies to the UPEs.
The SPE maintains the VPN routes of all sites in the HoVPN. Each UPE maintains only VPN routes of its directly connected sites. An MPE has fewer routes than the SPE but has more routes than a UPE.
OSPF VPN extension
This section describes the OSPF VPN extension. For more information about OSPF, see Layer 3—IP Routing Configuration Guide.
OSPF for VPNs on a PE
If OSPF runs between a CE and a PE to exchange VPN routes, the PE must support multiple OSPF instances to create independent routing tables for VPN instances. Each OSPF process is bound to a VPN instance. Routes learned by an OSPF process are added into the routing table of the bound VPN instance.
OSPF area configuration between a PE and a CE
The OSPF area between a PE and a CE can be either a non-backbone area or a backbone area.
In the OSPF VPN extension application, the MPLS VPN backbone is considered the backbone area (area 0). The area 0 of each site must be connected to the MPLS VPN backbone (physically connected or logically connected through a virtual link) because OSPF requires that the backbone area be contiguous.
BGP/OSPF interaction
If OSPF runs between PEs and CEs, each PE redistributes BGP routes to OSPF and advertises the routes to CEs through OSPF. OSPF considers the routes redistributed from BGP as external routes but the OSPF routes actually belong to the same OSPF domain. This problem can be resolved by configuring the same domain ID for sites in an OSPF domain.
Figure 17 Network diagram for BGP/OSPF interaction
As shown in Figure 17, CE 11, CE 21, and CE 22 belong to the same VPN and the same OSPF domain.
Before domain ID configuration, VPN 1 routes are advertised from CE 11 to CE 21 and CE 22 by using the following process:
2. PE 1 redistributes OSPF routes from CE 11 into BGP, and advertises the VPN routes to PE 2 through BGP.
3. PE 2 redistributes the BGP routes to OSPF, and advertises them to CE 21 and CE 22 in AS External LSAs (Type 5) or NSSA External LSAs (Type 7).
After domain ID configuration, VPN 1 routes are advertised from CE 11 to CE 21 and CE 22 by using the following process:
4. PE 1 redistributes OSPF routes into BGP, adds the domain ID to the redistributed BGP VPNv4 routes as a BGP extended community attribute, and advertises the routes to PE 2.
5. PE 2 compares the domain ID in the received routes with the locally configured domain ID. If they are the same and the received routes are intra-area or inter-area routes, OSPF advertises these routes in Network Summary LSAs (Type 3). Otherwise, OSPF advertises these routes in AS External LSAs (Type 5) or NSSA External LSAs (Type 7).
Routing loop avoidance
As shown in Figure 18, Site 1 is connected to two PEs. When a PE advertises VPN routes learned from MP-BGP to Site 1 through OSPF, the routes might be received by the other PE. This results in a routing loop.
Figure 18 Network diagram for routing loop avoidance
OSPF VPN extension uses the following tags to avoid routing loops:
· Down bit, or DN bit. An OSPF process for a VPN instance uses the DN bit to avoid routing loops as follows:
When a PE redistributes BGP routes into OSPF and creates Type 3 LSAs, Type 5 LSAs, or Type 7 LSAs, it sets the DN bit for the LSAs. When receiving the LSAs advertised by CE 11, the other PE ignores the LSAs whose DN bit is set to avoid routing loops.
· VPN route tag, the external route tag in redistributed routes of a VPN instance. An OSPF process for a VPN instance uses the route tag to avoid routing loops as follows:
The two PEs connected to the same site use the same route tag. When a PE redistributes BGP routes into OSPF and creates Type 5 or 7 LSAs, it adds the route tag to the LSAs. When receiving the Type 5 or 7 LSAs advertised by CE 11, the other PE compares the route tag in the LSAs against the local route tag. If they are the same, the PE ignores the LSAs to avoid routing loops.
OSPF sham link
As shown in Figure 19, two routes exist between Site 1 and Site 2 of VPN 1:
· A route over MPLS backbone—It is an inter-area route if PE 1 and PE 2 have the same domain ID, or is an external route if PE 1 and PE 2 are configured with no domain ID or with different domain IDs.
· A direct route between CEs—It is an intra-area route that is called a backdoor link.
VPN traffic is always forwarded through the backdoor link because it has a higher priority than the inter-area route. To forward VPN traffic over the inter-area route, you can establish a sham link between the two PEs to change the inter-area route to an intra-area route.
Figure 19 Network diagram for sham link
A sham link is considered a virtual point-to-point link within a VPN and is advertised in a Type 1 LSA. It is identified by the source IP address and destination IP address that are the local PE address and the remote PE address in the VPN address space. Typically, the source and destination addresses are loopback interface addresses with a 32-bit mask.
To add a route to the destination IP address of a sham link to a VPN instance, the remote PE must advertise the source IP address of the sham link as a VPN-IPv4 address through MP-BGP. To avoid routing loops, a PE does not advertise the sham link's destination address.
BGP detects routing loops by examining AS numbers. If EBGP runs between PE and CE, you must assign different AS numbers to geographically different sites or configure the BGP AS number substitution feature to ensure correct transmission of routing information.
The BGP AS number substitution feature allows geographically different CEs to use the same AS number. If the AS_PATH of a route contains the AS number of a CE, the PE replaces the AS number with its own AS number before advertising the route to that CE.
After you enable the BGP AS number substitution feature, the PE performs BGP AS number substitution for all routes and re-advertises them to connected CEs in the peer group.
Figure 20 Application of BGP AS number substitution and SoO attribute
As shown in Figure 20, both Site 1 and Site 2 use the AS number 800. AS number substitution is enabled on PE 2 for CE 2. Before advertising updates received from CE 1 to CE 2, PE 2 substitutes its own AS number 100 for the AS number 800. In this way, CE 2 can correctly receive the routing information from CE 1.
However, the AS number substitution feature also introduces a routing loop in Site 2 because route updates originated from CE 3 can be advertised back to Site 2 through PE 2 and CE 2. To remove the routing loop, you can configure the same SoO attribute on PE 2 for CE 2 and CE 3. PE 2 adds the SoO attribute to route updates received from CE 2 or CE 3, and checks the SoO attribute of route updates to be advertised to CE 2 or CE 3. The SoO attribute of the route updates from CE 3 is the same as the SoO attribute for CE 2, and PE 2 does not advertise route updates to CE 2.
For more information about the SoO attribute, see Layer 3—IP Routing Configuration Guide.
MPLS L3VPN FRR
MPLS L3VPN Fast Reroute (FRR) is applicable to a dual-homed scenario, as shown in Figure 21. By using BFD to detect the primary link, FRR enables a PE to use the backup link when the primary link fails. The PE then selects a new optimal route, and uses the new optimal route to forward traffic.
MPLS L3VPN FRR supports the following types of backup:
· VPNv4 route backup for a VPNv4 route.
· VPNv4 route backup for an IPv4 route.
· IPv4 route backup for a VPNv4 route.
As shown in Figure 21, configure FRR on the ingress node PE 1, and specify the backup next hop for VPN 1 as PE 3. When PE 1 receives a VPNv4 route to CE 2 from both PE 2 and PE 3, it uses the route from PE 2 as the primary link, and the route from PE 3 as the backup link.
Configure BFD for LSPs or MPLS TE tunnels on PE 1 to detect the connectivity of the public tunnel from PE 1 to PE 2. When the tunnel PE 1—PE 2 operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2. When the tunnel fails, the traffic goes through the path CE 1—PE 1—PE 3—CE 2.
In this scenario, PE 1 is responsible for primary link detection and traffic switchover.
For more information about BFD for LSPs or MPLS TE tunnels, see "Configuring MPLS OAM."
As shown in Figure 22, configure FRR on the egress node PE 2, and specify the backup next hop for VPN 1 as PE 3. When PE 2 receives an IPv4 route from CE 2 and a VPNv4 route from PE 3 (both routes are destined for VPN 1 connected to CE 2), PE 2 uses the IPv4 route as the primary link, and the VPNv4 route as the backup link.
PE 2 uses ARP or echo-mode BFD to detect the connectivity of the link from PE 2 to CE 2. When the link operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2. When the link fails, PE 2 switches traffic to the link PE 2—PE 3—CE 2, and traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—PE 3—CE 2. This avoids traffic interruption before route convergence completes (switching to the link CE 1—PE 1—PE 3—CE 2).
In this scenario, PE 2 is responsible for primary link detection and traffic switchover.
As shown in Figure 23, configure FRR on PE 1, and specify the backup next hop for VPN 1 as CE 2. When PE 1 receives an IPv4 route from CE 2 and a VPNv4 route from PE 2 (both routes are destined for VPN 1 connected to CE 2), PE 1 uses the VPNv4 route as the primary link, and the IPv4 route as the backup link.
Configure BFD for LSPs or MPLS TE tunnels on PE 1 to detect the connectivity of the public tunnel from PE 1 to PE 2. When the tunnel operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2. When the tunnel fails, the traffic goes through the path CE 1—PE 1—CE 2.
Protocols and standards
· RFC 3107, Carrying Label Information in BGP-4
· RFC 4360, BGP Extended Communities Attribute
· RFC 4364, BGP/MPLS IP Virtual Private Networks (VPNs)
· RFC 4577, OSPF as the Provider/Customer Edge Protocol for BGP/MPLS IP Virtual Private Networks (VPNs)
Unless otherwise indicated, configure MPLS L3VPN on PEs.
To configure MPLS L3VPN, perform the following tasks:
1. Configuring MPLS L3VPN basics
b. Configuring routing between a PE and a CE
c. Configuring routing between PEs
d. (Optional.) Configuring BGP VPNv4 route control
e. (Optional.) Enabling MPLS IP packet fragmentation
2. Configuring advanced MPLS L3VPN networks
Perform this task when sites of a VPN are connected to different ASs of an ISP.
Deploy the nest VPN when a large number of VPNs exist and you want to hide from the outside of the customer internal VPNs.
Multirole host allows a host or server in a site to access multiple VPNs by configuring PBR on the PE.
HoVPN prevents PEs from being bottlenecks and is applicable to large-scale VPN deployment.
3. (Optional.) Specifying the VPN label processing mode on the egress PE
4. (Optional.) Configuring MPLS L3VPN FRR
5. (Optional.) Configuring a TTL processing mode for tunnels associated with a VPN instance
6. (Optional.) Controlling route advertisement and reception in an MPLS L3VPN network
¡ Configuring an OSPF sham link
¡ Configuring BGP AS number substitution and SoO attribute
¡ Configuring the AIGP attribute
¡ Configuring BGP RT filtering
Perform this task to reduce the number of routes advertised in an MPLS L3VPN.
¡ Configuring the BGP additional path feature
Perform this task to enable BGP to advertise multiple routes with the same prefix and different next hops to a peer or peer group to shorten the traffic interruption time.
¡ Enabling the VPN Prefix ORF feature
¡ Configuring route replication
¡ Enabling redistribution of multiple same-prefix routes with the same RD
¡ Enabling prioritized withdrawal of specific routes
Perform this task to configure BGP to send the withdrawal messages of specific routes prior to other routes to achieve fast switchover of traffic and reduce the traffic interruption time.
7. (Optional.) Maintaining MPLS L3VPN networks
¡ Enabling SNMP notifications for MPLS L3VPN
¡ Enabling logging for BGP route flapping
Prerequisites for MPLS L3VPN
Before you configure basic MPLS L3VPN, perform the following tasks:
1. Configure an IGP on the PEs and P devices to ensure IP connectivity within the MPLS backbone.
2. Configure basic MPLS for the MPLS backbone.
3. Configure MPLS LDP on the PEs and P devices to establish LDP LSPs.
Configuring VPN instances
All VPN instance configurations are performed on PEs.
Creating a VPN instance
A VPN instance is a collection of the VPN membership and routing rules of its associated site. A VPN instance might correspond to more than one VPN.
You can configure an RD in VPN instance view and each address family view of the VPN instance. The RD configured in address family view takes precedence over the RD configured in VPN instance view. An address family uses the RD configured in VPN instance view only when no RD is configured in the address family view.
Editing an RD will delete some configuration related to the VPN instance from the BGP process. Please be cautious.
Follow these restrictions and guidelines when deleting RDs:
· When you delete the RD configured in VPN instance view, settings configured in an address family view of the BGP-VPN instance will be deleted if no RD is configured in the address family view. For example, when you delete the RD of VPN instance vpna, settings configured in BGP-VPN IPv4 unicast address family view of VPN instance vpna will be deleted if no RD is configured in VPN instance IPv4 address family view.
· When you delete an RD configured in an address family view of the VPN instance, settings configured in the address family view of the BGP-VPN instance will be deleted if the RD configured in the address family view is different from the RD configured in VPN instance view.
· If you configure an RD for an address family that inherits the RD of the VPN instance and the two RDs are different, settings configured in the address family view of the BGP-VPN instance will be deleted.
1. Enter system view.
2. Set an MPLS label range for all VPN instances.
mpls per-vrf-label range minimum maximum
By default, no MPLS label range is configured for VPN instances.
3. Create a VPN instance and enter VPN instance view.
4. Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
5. (Optional.) Configure a description for the VPN instance.
By default, no description is configured for a VPN instance.
6. (Optional.) Configure a VPN ID for the VPN instance.
vpn-id vpn-id
By default, no VPN ID is configured for a VPN instance.
7. (Optional.) Configure an SNMP context for the VPN instance.
By default, no SNMP context is configured.
8. Enter VPN instance IPv4 address family view.
address-family ipv4
9. Configure an RD.
By default, no RD is configured.
10. Specify a label allocation mode.
apply-label { per-instance [ static static-label-value ] | per-route }
By default, BGP allocates a label to each next hop.
CAUTION: Executing this command will re-advertise all routes in the VPN instance, which will cause temporary interruption of running services in the VPN instance. Please be cautious. |
If an interface is associated with a VSI or cross-connect, the interface (including its subinterfaces) cannot associate with a VPN instance.
If a subinterface is associated with a VSI or cross-connect, the subinterface cannot associate with a VPN instance.
2. Enter interface view.
3. Associate a VPN instance with the interface.
By default, an interface is not associated with a VPN instance and belongs to the public network.
CAUTION: Associating an interface with a VPN instance or disassociating an interface from a VPN instance will clear the IP address and routing protocol settings on the interface. |
The ip binding vpn-instance command deletes the IP address of the current interface. You must re assign an IP address to the interface after configuring the command.
Configurations made in VPN instance view apply to both IPv4 VPN and IPv6 VPN.
IPv4 VPN prefers the configurations in VPN instance IPv4 address family view over the configurations in VPN instance view.
Before you perform this task, create the routing policies to be used by this task. For information about routing policies, see Layer 3—IP Routing Configuration Guide.
2. Enter VPN instance view or VPN instance IPv4 address family view.
¡ Enter VPN instance view.
¡ Execute the following commands in sequence to enter VPN instance IPv4 address family view:
address-family ipv4
3. Configure route targets.
By default, no route targets are configured.
4. Set the maximum number of active routes.
By default, the number of active routes in a VPN instance is not limited.
Setting the maximum number of active routes for a VPN instance can prevent the device from learning too many routes.
5. Apply an import routing policy.
By default, all routes matching the import target attribute are accepted.
6. Apply an export routing policy.
By default, routes to be advertised are not filtered.
7. Bind a tunnel policy to the VPN instance.
tnl-policy tunnel-policy-name
By default, no tunnel policy is bound to a VPN instance.
If no tunnel policy is bound to a VPN instance or the bound tunnel policy is not configured, the VPN instance uses the default load sharing policy for tunnel selection. For more information about tunnel policies and the default load sharing policy, see "Configuring tunnel policies."
Perform this configuration on the PE. On the CE, configure a common static route.
For more information about static routing, see Layer 3—IP Routing Configuration Guide.
2. Configure a static route for a VPN instance.
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] [ track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ track track-entry-number ] } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
Perform this configuration on the PE. On the CE, create a common RIP process.
For more information about RIP, see Layer 3—IP Routing Configuration Guide.
2. Create a RIP process for a VPN instance and enter RIP view.
rip [ process-id ] vpn-instance vpn-instance-name
A RIP process can belong to only one VPN instance.
3. Redistribute BGP routes.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | route-policy route-policy-name | tag tag ] *
By default, RIP does not redistribute routes from other routing protocols.
4. Enable RIP on the interface attached to the specified network.
By default, RIP is disabled on an interface.
Perform this configuration on the PE. On the CE, create a common OSPF process.
2. Create an OSPF process for a VPN instance and enter the OSPF view.
ospf [ process-id | router-id router-id ] * vpn-instance vpn-instance-name
Parameter |
Usage guidelines |
router-id router-id |
An OSPF process bound to a VPN instance does not use the public network router ID configured in system view. Therefore, you must specify a router ID when creating a process or assign an IP address to a minimum of one interface in the bound VPN instance. |
vpn-instance vpn-instance-name |
An OSPF process can belong to only one VPN instance. If you delete a VPN instance, all OSPF processes of the VPN instance are also deleted. |
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] *
By default, OSPF does not redistribute routes from other routing protocols.
If the vpn-instance-capability simple command is not configured for the OSPF process, the allow-ibgp keyword is optional to redistribute VPNv4 routes learned from MP-IBGP peers. In any other cases, if you do not specify the allow-ibgp keyword, the OSPF process does not redistribute VPNv4 routes learned from MP-IBGP peers.
4. (Optional.) Set an OSPF domain ID.
domain-id { domain-id [ secondary ] | null }
The default domain ID is 0.
Restrictions and guidelines |
The domain ID is carried in the routes of the OSPF process. When redistributing routes from the OSPF process, BGP adds the domain ID as an extended community attribute into BGP route. |
An OSPF process can be configured with only one primary domain ID. Domain IDs of different OSPF processes can be the same. All OSPF processes of a VPN must be configured with the same domain ID. |
5. (Optional.) Configure the type codes of OSPF extended community attributes.
The defaults are as follows:
¡ 0x0005 for Domain ID.
¡ 0x0107 for Router ID.
¡ 0x0306 for Route Type.
6. Set the DN bit in OSPF LSAs.
dn-bit-set { ase | nssa | summary }
By default, when a PE redistributes BGP routes into OSPF and creates OSPF LSAs, it sets the DN bit for the Network Summary LSA (Type 3 LSA).
7. Configure OSPF to check the DN bit in OSPF LSAs.
dn-bit-check { ase | nssa | summary }
By default, OSPF on a PE checks the DN bit of Network Summary LSA (Type 3 LSA).
8. Enable external route check for OSPF LSAs.
route-tag-check enable
By default, the external route check feature is enabled for OSPF LSAs.
9. Create an OSPF area and enter area view.
area area-id
10. Enable OSPF on the interface attached to the specified network in the area.
By default, an interface neither belongs to any area nor runs OSPF.
Perform this configuration on the PE. On the CE, configure common IS-IS.
For more information about IS-IS, see Layer 3—IP Routing Configuration Guide.
2. Create an IS-IS process for a VPN instance and enter IS-IS view.
isis [ process-id ] vpn-instance vpn-instance-name
An IS-IS process can belong to only one VPN instance.
3. Configure a network entity title for the IS-IS process.
network-entity net
By default, no NET is configured.
4. Enter IS-IS IPv4 unicast address family view.
address-family ipv4
5. Redistribute BGP routes.
import-route bgp [ as-number ] [ allow-ibgp ] [ cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
import-route bgp [ as-number ] [ allow-ibgp ] inherit-cost [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, IS-IS does not redistribute routes from other routing protocols.
6. Return to system view.
7. Enter interface view.
8. Enable the IS-IS process on the interface.
isis enable [ process-id ]
By default, no IS-IS process is enabled on the interface.
Restrictions and guidelines for configuring EBGP between a PE and a CE
After you edit or delete the RD in VPN instance view or VPN instance IPv4 address family view, the device automatically deletes the BGP-VPN IPv4 unicast address family view and all its configuration. To avoid route flapping, do not edit or delete the RD if you have configured EBGP between a PE and a CE.
Configuring the PE
2. Enable a BGP instance and enter BGP instance view.
By default, BGP is not enabled.
3. Enter BGP-VPN instance view.
Configuration commands in BGP-VPN instance view are the same as those in BGP instance view. For more information, see BGP in Layer 3—IP Routing Configuration Guide.
4. Configure the CE as the VPN EBGP peer.
peer { group-name | ip-address [ mask-length ] } as-number as-number
For more information about this command, see BGP in Layer 3—IP Routing Configuration Guide.
5. Create the BGP-VPN IPv4 unicast address family and enter its view.
6. Enable IPv4 unicast route exchange with the specified peer.
By default, BGP does not exchange IPv4 unicast routes with a peer.
7. Redistribute the routes of the local CE.
A PE must redistribute the routes of the local CE into its VPN routing table so it can advertise them to the peer PE.
8. Allow the local AS number to appear in the AS_PATH attribute of a received route, and set the maximum number of repetitions.
By default, BGP discards incoming route updates that contain the local AS number.
Execute this command in a hub-spoke network where EBGP is running between a PE and a CE to enable the PE to receive the route updates from the CE.
Configuring the CE
3. Configure the PE as a BGP peer.
4. Create the BGP IPv4 unicast address family and enter its view.
5. Enable IPv4 unicast route exchange with the specified peer or peer group.
By default, BGP does not exchange IPv4 unicast routes with any peer.
6. Configure route redistribution.
A CE must redistribute its routes to the PE so the PE can advertise them to the peer CE.
Configuring IBGP between a PE and a CE
Restrictions and guidelines for configuring IBGP between a PE and a CE
Use IBGP between PE and CE only in a basic MPLS L3VPN network. In networks such as Hub&Spoke, Extranet, inter-AS VPN, carrier's carrier, nested VPN, and HoVPN, you cannot use IBGP between PE and CE.
After you edit or delete the RD in VPN instance view or VPN instance IPv4 address family view, the device automatically deletes the BGP-VPN IPv4 unicast address family view and all its configuration. To avoid route flapping, do not edit or delete the RD if you have configured IBGP between a PE and a CE.
Configuring the PE
Configuration commands in BGP-VPN instance view are the same as those in BGP instance view. For more information, see Layer 3—IP Routing Configuration Guide.
4. Configure the CE as the VPN IBGP peer.
7. Configure the CE as a client of the RR to enable the PE to advertise routes learned from the IBGP peer CE to other IBGP peers.
By default, no RR or RR client is configured.
Configuring an RR does not change the next hop of a route. To change the next hop of a route, configure an inbound policy on the receiving side.
8. (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
9. (Optional.) Configure the cluster ID for the RR.
By default, the RR uses its own router ID as the cluster ID.
If multiple RRs exist in a cluster, use this command to configure the same cluster ID for all RRs in the cluster to avoid routing loops.
Configuring the CE
3. Configure the PE as an IBGP peer.
5. Enable IPv4 unicast route exchange with the specified peer.
3. Configure the remote PE as a BGP peer.
4. (Optional.) Specify the source interface for TCP connections.
peer { group-name | ip-address [ mask-length ] } connect-interface interface-type interface-number
By default, BGP uses the output interface of the optimal route destined for the peer as the source interface.
5. Create the BGP VPNv4 address family and enter its view.
address-family vpnv4
6. Enable BGP VPNv4 route exchange with the specified peer.
By default, BGP does not exchange BGP VPNv4 routes with a peer.
About BGP VPNv4 route control
BGP VPNv4 route control is configured similarly with BGP route control, except that it is configured in BGP VPNv4 address family view. For more information about BGP route control, see Layer 3—IP Routing Configuration Guide.
Controlling BGP VPNv4 route advertisement, reception, and saving
2. Enter BGP instance view.
3. Enter BGP VPNv4 address family view.
4. Advertise a default VPN route to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } default-route-advertise vpn-instance vpn-instance-name
By default, no default VPN route is advertised to a peer or peer group.
5. Set the maximum number of routes BGP can receive from a peer or peer group.
By default, the number of routes that BGP can receive from a peer or peer group is not limited.
6. Save all route updates from a peer or peer group.
By default, BGP does not save route updates from a peer.
Setting a preferred value for received routes
4. Set a preferred value for routes received from a peer or peer group.
By default, the preferred value for routes received from a peer or peer group is 0.
Configuring BGP VPNv4 route reflection
To ensure the connectivity of IBGP peers, you must establish full-mesh IBGP connections, which costs massive network and CPU resources.
To reduce IBGP connections in the network, you can configure a router as a route reflector (RR) and configure other routers as its clients. You only need to establish IBGP connections between the RR and its clients to enable the RR to forward routes to the clients.
4. Configure the device as a route reflector and specify a peer or peer group as its client.
By default, no route reflector or client is configured.
5. (Optional.) Enable route reflection between clients.
6. (Optional.) Configure a cluster ID for the RR.
7. (Optional.) Configure a filtering policy for reflected routes.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, the RR does not filter reflected routes.
8. (Optional.) Allow the RR to change the attributes of routes to be reflected.
By default, RR cannot change the attributes of routes to be reflected.
9. (Optional.) Specify a peer or peer group as a client of the nearby cluster.
peer { group-name | ipv4-address [ mask-length ] } reflect-nearby-group
By default, the nearby cluster does not have any clients.
The RR does not change the next hop of routes reflected to clients in the nearby cluster.
Configuring BGP VPNv4 route attributes
4. Configure the NEXT_HOP attribute. Choose one of the following tasks:
¡ Set the device as the next hop for routes sent to a peer or peer group.
¡ Configure the device to not change the next hop of routes advertised to a peer or peer group.
By default, the device uses its address as the next hop for routes advertised to peers.
On an RR in an inter-AS option C scenario, you must configure this command to not change the next hop of VPNv4 routes advertised to BGP peers and RR clients.
5. Configure the AS_PATH attribute.
¡ Allow the local AS number to appear in the AS_PATH attribute of a received route and set the maximum number of repetitions.
By default, BGP discards incoming routes that contain the local AS number.
¡ Remove private AS numbers in BGP updates sent to an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
6. Advertise the COMMUNITY attribute to a peer or peer group.
By default, BGP does not advertise the COMMUNITY attribute to a peer or peer group.
7. Advertise the Large community attribute to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise-large-community
By default, BGP does not advertise the Large community attribute to a peer or peer group.
8. Configure the SoO attribute for a peer for peer group.
By default, the SoO attribute is not configured.
9. Configure BGP to add the link bandwidth attribute to routes received from an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bandwidth
By default, BGP does not add the link bandwidth attribute to routes received from an EBGP peer or peer group.
10. Configure BGP to carry the user group ID in BGP routes sent to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise user-group-id
By default, BGP does not carry the user group ID in BGP routes sent to a peer or peer group.
Configuring BGP VPNv4 route filtering
4. Filter advertised routes.
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list prefix-list-name } export [ protocol process-id ]
By default, BGP does not filter advertised routes.
5. Filter received routes.
filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list prefix-list-name } import
By default, BGP does not filter received routes.
6. Configure AS_PATH list-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } as-path-acl as-path-acl-number { export | import }
By default, AS_PATH list-based route filtering is not configured.
7. Configure ACL-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } filter-policy { ipv4-acl-number | name ipv4-acl-name } { export | import }
By default, ACL-based route filtering is not configured.
8. Configure IP prefix list-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } prefix-list prefix-list-name { export | import }
By default, no IP prefix list-based route filtering is configured.
9. Apply a routing policy to routes advertised to or received from a peer or peer group.
By default, no routing policy is applied for a peer.
10. Enable route target filtering for received BGP VPNv4 routes.
policy vpn-target
By default, route target filtering is enabled for received VPNv4 routes. Only VPNv4 routes whose export route target attribute matches the local import route target attribute are added to the routing table.
Configuring BGP VPNv4 route dampening
This feature enables BGP to not select unstable routes as optimal routes.
If a BGP peer goes down after you configure this feature, VPNv4 routes coming from the peer are dampened but not deleted.
4. Configure BGP VPNv4 route dampening.
¡ Configure EBGP route dampening.
¡ Configure IBGP route dampening.
dampening ibgp[ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] *
By default, BGP VPNv4 route dampening is not configured.
Configuring BGP VPNv4 optimal route selection delay
4. Set the BGP VPNv4 optimal route selection delay timer.
By default, the BGP VPNv4 optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
Setting the delay time for responding to BGP VPNv4 recursive next hop changes
4. Set the delay time for responding to recursive next hop changes.
nexthop recursive-lookup [ non-critical-event ] delay [ delay-value ]
By default, BGP responds to recursive next hop changes immediately.
Configuring BGP VPNv4 routes to use private network next hops
By default, the device does not change the next hop attribute of a received BGP VPNv4 route. The next hop address of a BGP VPNv4 route is a public address. This feature changes the next hop of a BGP VPNv4 route received from a peer or peer group to an IP address in the VPN instance. The outgoing label of the VPNv4 route is also changed to an invalid value. For example, the device received a VPNv4 route and its next hop address is 10.1.1.1, which is a public address by default. After this feature is configured, the next hop address changes to private address 10.1.1.1.
After you configure this feature, the following applies:
· The device re-establishes the BGP sessions to the specified peer or to all peers in the specified peer group.
· The device receives a BGP VPNv4 route only when its RD is the same as a local RD.
· When advertising a BGP VPNv4 route received from the specified peer or peer group, the device does not change the route target attribute of the route.
· If you delete a VPN instance or its RD, BGP VPNv4 routes received from the specified peer or peer group and in the VPN instance will be deleted.
4. Change the next hop of a BGP VPNv4 route received from a peer or peer group to a VPN instance address.
peer { group-name | ipv4-address [ mask-length ] } next-hop-vpn
By default, the device does not change the next hop attribute of a received BGP VPNv4 route, and the next hop belongs to the public network.
Changing the BGP VPNv4 route selection rules
For the priority of the settings configured by this feature in BGP route selection, see BGP overview in Layer 3—IP Routing Configuration Guide.
Preferring routes learned from a peer or peer group during optimal route selection
4. Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] } high-priority [ preferred ]
By default, routes learned from a peer or peer group do not take precedence over routes learned from other peers or peer groups.
This command takes effect only on BGP routes that are learned in the current address family, and it does not take effect on BGP routes that are added to other BGP routing tables.
Preferring routes with the specified type of next hop addresses during optimal route selection
4. Prefer routes with the specified type of next hop addresses during optimal route selection.
bestroute nexthop-priority { ipv4 | ipv6 } [ preferred ]
By default, BGP prefers routes with IPv4 next hop addresses.
Advertising BGP RPKI validation state to a peer or peer group
BGP advertises the BGP RPKI validation state to a peer or peer group through the extended community attribute. For more information about BGP RPKI, see BGP configuration in Layer 3—IP Routing Configuration Guide.
4. Advertise the BGP RPKI validation state to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise origin-as-validation
By default, BGP does not advertise the BGP RPKI validation state.
In a carrier's carrier network as shown in "Carrier's carrier," a PE does not fragment MPLS L3VPN IP packets by default. To avoid data loss caused by oversized packets from a CE to a PE, enable MPLS IP packet fragmentation and set an MPLS MTU on the PE. To set an MPLS MTU, use the mpls mtu command. For more information about the mpls mtu command, see basic MPLS commands in MPLS Command Reference.
You must enable this feature if the device (as a P device for example) receives MPLS-labeled packets from the incoming interface and performs label switching on the outgoing interface.
2. Enable MPLS IP packet fragmentation.
mpls l3vpn fragment enable
By default, MPLS IP packet fragmentation is disabled.
Configuring inter-AS VPN
Configuring inter-AS option A
Inter-AS option A applies to scenarios with a few VPNs.
To configure inter-AS option A, create VPN instances on PEs and ASBRs. The VPN instances on PEs are used to allow CEs to access the network. The VPN instances on ASBRs are used to access the peer ASBRs. An ASBR considers the peer ASBR as a CE.
The route targets configured on the PEs must match those configured on the ASBRs in the same AS to make sure VPN routes sent by the PEs (or ASBRs) can be received by the ASBRs (or PEs). Route targets configured on the PEs in different ASs do not have such requirements.
Configuring inter-AS option B
An ASBR always sets itself as the next hop of VPNv4 routes advertised to an MP-IBGP peer regardless of the peer next-hop-local command.
Configuring a PE
Configure basic MPLS L3VPN, and specify the ASBR in the same AS as an MP-IBGP peer. The route targets for the VPN instances on the PEs in different ASs must match for the same VPN.
Configuring an ASBR
2. Enable MPLS and LDP on the interface connected to an internal router of the AS:
a. Configure an LSR ID for the local LSR.
mpls lsr-id lsr-id
By default, no LSR ID is configured.
b. Enable LDP on the local LSR and enter LDP view.
mpls ldp
By default, LDP is disabled.
c. Return to system view.
d. Enter interface view of the interface connected to an internal router of the AS.
e. Enable MPLS on the interface.
mpls enable
By default, MPLS is disabled on the interface.
f. Enable MPLS LDP on the interface.
mpls ldp enable
By default, MPLS LDP is disabled on the interface.
g. Return to system view.
3. Enable MPLS on the interface connected to the remote ASBR:
a. Enter interface view of the interface connected to the remote ASBR.
b. Enable MPLS on the interface.
mpls enable
4. Enter BGP instance view.
5. Configure PE in the same AS as an IBGP peer and the ASBR in another AS as an EBGP peer.
6. Enter BGP VPNv4 address family view.
7. Enable BGP to exchange VPNv4 routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange VPNv4 routes with a peer.
8. Disable route target filtering of received VPNv4 routes.
undo policy vpn-target
Configuring inter-AS option C (method 1)
PEs are not directly connected. For the PEs to establish neighbor relationships, execute the peer ebgp-max-hop command to enable the local router to establish an EBGP session to an indirectly-connected peer.
You can perform either of the following tasks to enable BGP IPv4 labeled unicast route advertisement between PE and ASBR and between ASBRs:
· Enable BGP to exchange IPv4 labeled routes with a peer or peer group in BGP IPv4 unicast address family view.
· Enable BGP to exchange BGP IPv4 labeled unicast routes with a peer or peer group in BGP IPv4 labeled unicast address family view.
BGP routes received in BGP IPv4 labeled unicast address family cannot be added to the routing table of the public network or a VPN instance, so the PE cannot learn public network routes in another AS. As a result, the PE cannot establish an MP-EBGP session over multiple hops with a PE in another AS. To resolve this issue, redistribute the BGP routes in BGP IPv4 labeled unicast address family to the BGP routing table of the BGP IPv4 unicast address family, and add the routes received from another AS to the routing table of the public network.
Before you configure inter-AS option C (method 1), perform the following tasks:
· Configure BGP on the PE or ASBR to advertise the route to the PE. For more information, see BGP configuration in Layer 3—IP Routing Configuration Guide.
· Configure VPN instances on PEs.
· Configure routing between PE and CE.
Configuring a PE (exchanging labeled routes in BGP IPv4 unicast address family)
3. Configure the ASBR in the same AS as an IBGP peer and configure the PE in another AS as an EBGP peer.
5. Enable BGP to exchange IPv4 unicast routes with the ASBR in the same AS.
6. Enable BGP to exchange labeled IPv4 routes with the ASBR in the same AS.
peer { group-name | ipv4-address [ mask-length ] } label-route-capability
By default, BGP cannot exchange labeled routes with any IPv4 peer or peer group.
7. Return to BGP instance view.
8. Enter BGP VPNv4 address family view.
9. Enable BGP to exchange VPNv4 routes with the PE in another AS.
By default, BGP cannot exchange VPNv4 routes with any peer.
10. (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
By default, the device uses its address as the next hop of routes advertised to peers.
Configure this command on the RR so the RR does not change the next hop of advertised VPNv4 routes.
Configuring a PE (exchanging labeled routes in BGP IPv4 labeled unicast address family)
4. Create the BGP IPv4 labeled unicast address family and enter its view.
address-family ipv4 labeled-unicast
5. Enable BGP to exchange IPv4 labeled unicast routes with the ASBR in the same AS.
By default, BGP does not exchange IPv4 labeled unicast routes with any peer.
6. Return to BGP instance view.
7. Create the BGP IPv4 unicast address family and enter its view.
8. Redistribute BGP IPv4 labeled unicast routes to the BGP IPv4 unicast routing table.
import-rib { public | vpn-instance vpn-instance-name } labeled-unicast [ valid-route ] [ route-policy route-policy-name | filter-policy { ipv4-acl-number | name ipv4-acl-name | prefix-list ipv4-prefix-list-name } ]
By default, BGP IPv4 labeled unicast routes cannot be redistributed to the BGP IPv4 unicast routing table.
9. Return to BGP instance view.
10. Enter BGP VPNv4 address family view.
11. Enable BGP to exchange VPNv4 routes with the PE in another AS.
12. (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
Configuring an ASBR (exchanging labeled routes in BGP IPv4 unicast address family)
2. Configure a routing policy:
a. Create a routing policy, and enter routing policy view.
b. Match IPv4 routes carrying labels.
if-match mpls-label
By default, no MPLS label match criterion is configured.
You can configure if-match clauses in the routing policy to filter routes. Routes surviving the filtering are assigned labels, and all others are advertised as common IPv4 routes.
c. Set labels for IPv4 routes.
apply mpls-label
By default, no MPLS label is set for IPv4 routes.
d. Return to system view.
3. Enable MPLS and LDP on the interface connected to an internal router of the AS:
mpls lsr-id lsr-id
mpls ldp
mpls enable
mpls ldp enable
4. Enable MPLS on the interface connected to the remote ASBR.
mpls enable
5. Enter BGP instance view.
6. Configure the PE in the same AS as an IBGP peer and the ASBR in another AS as an EBGP peer.
7. Create BGP IPv4 unicast address family and enter its view.
8. Enable BGP to exchange IPv4 unicast routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange IPv4 unicast routes with a peer.
9. Enable BGP to exchange labeled IPv4 routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange labeled IPv4 routes with a peer.
10. Specify the device as the next hop of routes sent to a peer or peer group.
By default, the device does not set itself as the next hop for routes sent to a peer or peer group.
11. Apply a routing policy to routes advertised to or received from a peer or peer group.
By default, no routing policy is applied.
Configuring an ASBR (exchanging labeled routes in BGP IPv4 labeled unicast address family)
mpls lsr-id lsr-id
mpls ldp
mpls enable
mpls ldp enable
3. Enable MPLS on the interface connected to the remote ASBR.
mpls enable
5. Configure the PE in the same AS as an IBGP peer and the ASBR in another AS as an EBGP peer.
6. Create BGP IPv4 labeled unicast address family and enter its view.
7. Enable BGP to exchange IPv4 labeled unicast routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange IPv4 labeled unicast routes with a peer.
8. (Optional.) Apply a routing policy to routes advertised to or received from a peer or peer group.
Configuring inter-AS option C (method 2)
You can perform either of the following tasks to enable BGP IPv4 labeled unicast route advertisement between ASBRs:
Before you configure inter-AS option C (method 2), perform the following tasks:
Configuring a PE
3. Configure the PE in another AS as an EBGP peer.
4. Enter BGP VPNv4 address family view.
5. Enable BGP to exchange VPNv4 routes with the PE in another AS.
6. (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
if-match mpls-label
apply mpls-label
mpls lsr-id lsr-id
mpls ldp
mpls enable
mpls ldp enable
mpls enable
6. Configure the ASBR in another AS as an EBGP peer.
8. Enable BGP to exchange IPv4 unicast routes with the ASBR in another AS.
9. Enable BGP to exchange labeled IPv4 routes with the ASBR in another AS.
By default, the device does not set itself as the next hop for routes sent to an IBGP peer or peer group.
mpls lsr-id lsr-id
mpls ldp
mpls enable
mpls ldp enable
mpls enable
5. Configure the ASBR in another AS as an EBGP peer.
7. Enable BGP to exchange IPv4 labeled unicast routes with the ASBR in another AS.
10. Create the BGP IPv4 unicast address family view and enter its view.
11. Redistribute BGP IPv4 labeled unicast routes to the BGP IPv4 unicast routing table.
Configuring nested VPN
When you configure nested VPN, follow these guidelines:
· The address spaces of sub-VPNs of a VPN cannot overlap.
· Do not assign nested VPN peers addresses that public network peers use.
· Nested VPN does not support multihop EBGP. A provider PE and a provider CE must use the addresses of the directly connected interfaces to establish a neighbor relationship.
1. Connect the customer CE to the customer PE:
a. Configure VPN instances on the customer PE.
See "Configuring VPN instances."
b. Configure route exchange between customer PE and customer CE.
See "Configuring routing between a PE and a CE."
2. Configure the customer PE to exchange sub-VPN routing information with the provider CE:
a. Configure BGP VPNv4 route exchange between customer PE and provider CE.
See "Configuring routing between PEs."
b. Execute the following commands in sequence to configure the provider CE to receive all VPNv4 routes (not filter VPNv4 routes by route targets).
This step is not required in a nested VPN network when no provider CE is deployed and the customer PE is connected directly to the provider PE.
3. Connect the provider CE to the provider PE:
a. Configure VPN instances on the provider PE.
b. Configure route exchange between the provider CE and provider PE.
4. Configure BGP VPNv4 route exchange between the provider PE and provider CE:
This step contains only configurations on the provider PE. For information about configuring the provider CE, see "Configuring routing between PEs." If the customer PE is directly connected to the provider PE, you must configure provider CE settings on the customer PE because the PE also functions as a provider CE.
a. Execute the following commands in sequence to enter BGP VPNv4 address family view:
b. Enable nested VPN.
nesting-vpn
By default, nested VPN is disabled.
c. Return to BGP instance view.
d. Enter BGP-VPN instance view.
e. Configure the provider CE as a BGP peer.
f. Create BGP-VPN VPNv4 address family and enter BGP-VPN VPNv4 address family view.
g. Enable BGP VPNv4 route exchange with the peer CE or the peer group of the peer CE.
By default, BGP does not exchange VPNv4 routes with any peer.
h. (Optional.) Configure the SoO attribute for the BGP peer or peer group.
i. (Optional.) Prefer routes learned from the specified peer or peer group during optimal route selection.
5. Configure BGP VPNv4 route exchange between provider PEs.
Configuring multirole host
About configuring multirole host
To configure the multirole host feature, perform the following tasks on the PE connected to the CE in the site where the multirole host resides:
· Configure and apply PBR.
· Configure static routes.
Configuring and applying PBR
2. Create a policy node and enter policy node view.
policy-based-route policy-name { deny | permit } node node-number
3. Configure match criteria for the node.
See Layer 3—IP Routing Configuration Guide.
By default, no match criterion is configured. All packets match the criteria for the node.
This step matches packets from the multirole host.
4. Specify the VPN instances for forwarding the matching packets.
apply access-vpn vpn-instance vpn-instance-name&
By default, no VPN instance is specified.
You must specify multiple VPN instances for the node. The first one is the VPN instance to which the multirole host belongs, and others are the VPN instances to be accessed. A matching packet is forwarded according to the routing table of the first VPN instance that has a matching route for that packet.
5. Return to system view.
6. Enter the view of the interface connected to the CE.
7. Apply the policy to the interface.
ip policy-based-route policy-name
By default, no policy is applied to the interface.
Configuring a static route
2. Configure a static route for a VPN instance to reach the multirole host.
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } vpn-instance d-vpn-instance-name next-hop-address [ track track-entry-number ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
The d-vpn-instance-name argument represents the VPN instance to which the multirole host belongs. The next-hop-address argument represents the IP address of the CE in the site where the multirole host resides.
Configuring HoVPN
Configuring the UPE
Configure basic MPLS L3VPN settings on the UPE.
Configuring the SPE
3. Specify a BGP peer or peer group.
5. Enable BGP VPNv4 route exchange with the peer or peer group.
6. Specify the BGP peer or peer group as a UPE.
peer { group-name | ipv4-address [ mask-length ] } upe
By default, no peer is a UPE.
7. Advertise routes to the UPE.
¡ Advertise a default VPN route to the UPE.
After you configure this command, the device advertises a default route to the UPE, regardless of whether the default route exists in the local routing table. The default route uses the local address as the next hop.
¡ Advertise routes permitted by a routing policy to the UPE.
peer { group-name | ipv4-address [ mask-length ] } upe route-policy route-policy-name export
By default, no route is advertised to the UPE.
Do not configure both commands.
8. Return to BGP instance view.
9. Create a BGP-VPN instance and enter BGP-VPN instance view.
You do not need to associate the VPN instance to an interface on the SPE.
This step adds the learned VPNv4 routes to the BGP routing table of the VPN instance.
Configuring route re-origination
In an HoVPN network, different UPEs communicate with each other through MPEs and SPEs. You can configure route re-origination on MPEs to reduce the number of private network labels that a UPE receives for VPNv4 routes.
As shown in Figure 24, if a network contains many UPEs that use the per-VPN-instance label allocation mode, and the MPEs in the network use the per-next-hop label allocation mode, the SPE will receive a large number of labels, which might cause traffic forwarding errors.
To resolve this issue, you can configure route re-origination on MPEs. The MPEs then can redistribute the BGP routes received from UPEs into local VPN instances and reoriginate these routes. The MPEs can modify the information of the reoriginated routes. After setting the per-VPN instance label allocation mode, the MPEs only need to allocate the number of VPN labels equal to the number of local VPN instances, regardless of the number of UPEs. The SPE only needs to receive the VPN labels allocated by the MPEs, significantly reducing the resource load on the SPE.
Figure 24 Route re-origination
This feature can reoriginate the BGP routes that are imported into a local VPN instance and have a different RD from that of the local VPN instance. It cannot reoriginate the BGP routes that are received from remote peers and have the same RD as that of the local VPN instance.
4. Enter BGP-VPN IPv4 unicast address family view.
5. Configure the device to re-originate the optimal routes in the VPN instance and advertise the re-originated routes to VPNv4 peers.
advertise route-reoriginate [ route-policy route-policy-name ] [ replace-rt ]
By default, the device does not re-originate the optimal routes in a VPN instance, and it sends the original VPNv4 routes to VPNv4 peers.
An egress PE can process VPN labels in either POPGO or POP mode:
· POPGO forwarding—Pops the label and forwards the packet out of the output interface corresponding to the label.
· POP forwarding—Pops the label and forwards the packet through the FIB table.
The POPGO forwarding mode (vpn popgo) and per-VPN instance label allocation mode (label-allocation-mode per-vrf) are mutually exclusive. Do not configure both modes in a BGP instance. For more information about the label-allocation-mode command, see BGP commands in Layer 3—IP Routing Command Reference.
The POPGO forwarding mode (vpn popgo) cannot be used in per-VPN instance label allocation mode (apply-label per-instance). After the apply-label per-instance command is executed for a VPN instance, the device can only forward packets by looking up the FIB according to labels, and the vpn popgo command does not take effect in the VPN instance.
3. Specify the VPN label processing mode as POPGO forwarding.
vpn popgo
The default is POP forwarding.
About MPLS L3VPN FRR
You can use the following methods to configure MPLS L3VPN FRR:
· Method 1—Execute the pic command in BGP-VPN IPv4 unicast address family view or BGP VPNv4 address family view. The device calculates a backup next hop for each BGP route in the VPN instance if there are two or more unequal-cost routes to reach the destination.
· Method 2—Execute the fast-reroute route-policy command in BGP-VPN IPv4 unicast address family view to use a routing policy. In the routing policy, specify a backup next hop by using the apply fast-reroute backup-nexthop command. The backup next hop calculated by the device must be the same as the specified backup next hop. Otherwise, the device does not generate a backup next hop for the primary route. You can also configure if-match clauses in the routing policy to identify the routes protected by FRR.
If both methods are configured, Method 2 takes precedence over Method 1.
Executing the pic command in BGP-VPN IPv4 unicast address family view or BGP VPNv4 address family view might cause routing loops. Use it with caution.
To configure inter-protocol FRR, execute the inter-protocol fast-reroute command. For more information about the inter-protocol fast-reroute command, see IP routing basics commands in Layer 3—IP Routing Command Reference.
Configuring FRR by using a routing policy
2. Configure BFD.
¡ Enable MPLS BFD.
mpls bfd enable
By default, MPLS BFD is disabled.
The mpls bfd enable command applies to VPNv4 route backup for a VPNv4 route and IPv4 route backup for a VPNv4 route.
For more information about this command, see MPLS Command Reference.
¡ Configure the source IP address for BFD echo packets.
bfd echo-source-ip ip-address
By default, the source IP address for BFD echo packets is not configured.
This command is required when echo-mode BFD is used to detect primary route connectivity in VPNv4 route backup for an IPv4 route. For more information about this command, see High Availability Command Reference.
3. Use BFD to test the connectivity of an LSP or MPLS TE tunnel.
¡ Configure BFD to test the connectivity of the LSP for the specified FEC.
mpls tunnel-bfd dest-addr mask-length [ discriminator local local-id remote remote-id [ bgp-lsp | isis-srlsp | ldp-lsp | ospf-srlsp | static-lsp ] | echo | nil-fec | ldp-fec ] [ template template-name ]
¡ Execute the following commands in sequence to configure BFD to test the connectivity of the MPLS TE tunnel for the tunnel interface.
interface tunnel number mode mpls-te
mpls tunnel-bfd [ discriminator local local-id remote remote-id | echo | reverse-lsp binding-sid label label-value ] [ template template-name ]
By default, BFD is not configured to test the connectivity of the LSP or MPLS TE tunnel.
This step is required for VPNv4 route backup for a VPNv4 route and IPv4 route backup for a VPNv4 route.
For more information about the commands in this step, see MPLS Command Reference.
4. Configure a routing policy:
a. Create a routing policy and enter routing policy view.
route-policy route-policy-name permit node node-number
b. Set the backup next hop for FRR.
apply fast-reroute backup-nexthop ip-address
By default, no backup next hop address is set for FRR.
For more information about the commands, see Layer 3—IP Routing Command Reference.
6. (Optional.) Use echo-mode BFD to detect the connectivity to the next hop of the primary route.
primary-path-detect bfd echo
By default, ARP is used to detect the connectivity to the next hop.
Use this command if necessary in VPNv4 route backup an IPv4 route.
For more information about this command, see Layer 3—IP Routing Command Reference.
7. Enter BGP-VPN instance view.
8. Enter BGP-VPN IPv4 unicast address family view.
9. Apply a routing policy to FRR.
By default, no routing policy is applied to FRR.
The apply fast-reroute backup-nexthop command can take effect in the routing policy that is being used. Other apply commands do not take effect.
For more information about the command, see BGP commands in Layer 3—IP Routing Command Reference.
Enabling MPLS L3VPN FRR for BGP-VPN IPv4 unicast address family or BGP VPNv4 address family view
2. Configure BFD.
¡ Enable MPLS BFD.
mpls bfd enable
This command applies to VPNv4 route backup for a VPNv4 route and IPv4 route backup for a VPNv4 route. For more information about this command, see MPLS OAM commands in MPLS Command Reference.
This command is required when echo-mode BFD is used to detect primary route connectivity in VPNv4 route backup for an IPv4 route. For more information about this command, see BFD commands in High Availability Command Reference.
¡ Use BFD to test the connectivity of the LSP for the specified FEC.
¡ Execute the following commands in sequence to use BFD to test the connectivity of the MPLS TE tunnel for the tunnel interface:
By default, BFD is not used to test the connectivity of the LSP or MPLS TE tunnel.
For more information about the commands, see MPLS OAM commands in MPLS Command Reference.
5. (Optional.) Use echo-mode BFD to detect the connectivity to the next hop of the primary route.
6. Enter BGP-VPN IPv4 unicast address family view or BGP VPNv4 address family view.
¡ Enter BGP-VPN IPv4 unicast address family view.
¡ Enter BGP VPNv4 address family view.
7. Enable MPLS L3VPN FRR for the address family.
pic
By default, MPLS L3VPN FRR is disabled.
A tunnel associated with a VPN instance supports the following TTL processing modes:
· Pipe—When an IP or IPv6 packet enters the tunnel of the VPN instance, the ingress node adds a new header to the packet. The ingress node sets the TTL value or hop limit in the new header to 255 or the value specified by the encapsulation source-address ip-ttl command in SRv6 view. When the packet leaves the tunnel of the VPN instance, the egress node does not change the TTL value or the hop limit according to the remaining TTL value in the new header. Therefore, the public network nodes are invisible to user networks, and the tracert facility cannot show the real path in the public network.
· Uniform—When an IP or IPv6 packet enters the tunnel of the VPN instance, the ingress node adds a new header to the packet. The ingress node copies the TTL value or the hop limit of the original packet to the TTL or hop limit field of the new header. When the packet leaves the tunnel of the VPN instance, the egress node copies the remaining TTL value or hop limit back to the original packet. The TTL value or hop limit can reflect how many hops the packet has traversed in the public network. The tracert facility can show the real path along which the packet has traveled.
In the current software version, you can configure a TTL processing mode for only SRv6 tunnels associated with VPN instances. For more information about associating VPN instances with SRv6 tunnels, see MPLS L3VPN over SRv6 configuration in Segment Routing Configuration Guide.
This feature takes effect after you restart the IGP/BGP process.
2. Enter VPN instance mode.
3. Configure a TTL processing mode for the tunnel associated with a VPN instance.
ttl-mode { pipe | uniform }
By default, the TTL processing mode for the tunnel associated with a VPN instance is pipe.
About OSPF sham links
When a backdoor link exists between the two sites of a VPN, you can create a sham link between PEs to forward VPN traffic through the sham link on the backbone rather than the backdoor link. A sham link is considered an OSPF intra-area route.
The source and destination addresses of the sham link must be loopback interface addresses with 32-bit masks. The loopback interfaces must be bound to VPN instances, and their addresses are advertised through BGP.
Before you configure an OSPF sham link, perform the following tasks:
· Configure basic MPLS L3VPN (OSPF is used between PE and CE).
· Configure OSPF in the LAN where customer CEs reside.
Redistributing the loopback interface address
2. Create a loopback interface and enter loopback interface view.
interface loopback interface-number
3. Associate the loopback interface with a VPN instance.
By default, the interface is not associated with any VPN instances and belongs to the public network.
4. Assign an IP address to the loopback interface.
ip address ip-address { mask-length | mask }
By default, no IP address is configured for the loopback interface.
6. Enter BGP instance view.
9. Redistribute direct routes into BGP (including the loopback interface route).
import-route direct
By default, no direct routes are redistributed into BGP.
Creating a sham link
2. Enter OSPF view.
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ] *
As a best practice, specify a router ID.
3. Set the external route tag for imported VPN routes.
route-tag tag-value
By default, if BGP runs within an MPLS backbone, and the BGP AS number is not greater than 65535, the first two octets of the external route tag are 0xD000 and the last two octets are the local BGP AS number. If the AS number is greater than 65535, the external route tag is 0.
4. Enter OSPF area view.
area area-id
5. Configure a sham link.
sham-link source-ip-address destination-ip-address [ cost cost-value | dead dead-interval | hello hello-interval | { { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string | keychain keychain-name | simple { cipher | plain } string } | retransmit retrans-interval | trans-delay delay | ttl-security hops hop-count ] *
When CEs at different sites have the same AS number, configure the BGP AS number substitution feature to avoid route loss.
When a PE uses different interfaces to connect different CEs in a site, the BGP AS number substitution feature introduces a routing loop. To remove the routing loop, configure the SoO attribute on the PE.
For more information about the BGP AS number substitution feature and the SoO attribute, see "BGP AS number substitution and SoO attribute."
4. Enable the BGP AS number substitution feature.
peer { ipv4-address [ mask-length ] | group-name } substitute-as
By default, BGP AS number substitution is disabled.
5. Enter BGP-VPN IPv4 unicast address family view.
6. (Optional.) Configure the SoO attribute for a BGP peer or peer group.
An Accumulated Interior Gateway Protocol (AIGP) administrative domain is a collection of multiple ASs that run the same IGP under one administrative control. Within the domain, BGP accumulates the IGP metrics all along the forwarding path for a route. Then, it uses the accumulated value as the AIGP attribute for the route to implement metric-based route selection.
By default, BGP does not advertise the AIGP attribute to its peers or peer groups. When BGP receives a route carrying the AIGP attribute, it ignores and removes the attribute before advertising the route to other peers or peer groups. Perform this task to enable BGP to advertise the AIGP attribute to its peers or peer groups.
With this feature enabled, a router processes the AIGP attribute in a received route as follows:
· If the router sets itself as the next hop for the route, it adds to the AIGP attribute value the IGP metric from itself to the original next hop and advertises the new AIGP attribute value.
· If the router does not set itself as the next hop for the route, it does not change the AIGP attribute value.
BGP uses the AIGP attribute to select the optimal route as follows:
· A route carrying the AIGP attribute takes precedence over a route not carrying the AIGP attribute.
· A route that has a smaller computed AIGP attribute value has a higher priority.
When the AIGP attribute of a route changes, BGP sends update messages for the route.
As a best practice, do not configure the peer aigp command on border routers of an AIGP administrative domain.
When a router receives a route not carrying the AIGP attribute, it does not advertise the AIGP attribute to a peer or peer group if you configure only the peer aigp command. To enable the router to advertise the AIGP attribute, you must configure both the peer aigp and apply aigp commands. For information about the apply aigp command, see the routing policy configuration in Layer 3—IP Routing Configuration Guide.
4. Configure BGP to advertise the AIGP attribute to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp
By default, BGP does not advertise the AIGP attribute to a peer or peer group and ignores the AIGP attribute in routes received from the peer or peer group.
5. (Optional.) Replace the MED value with AIGP value in routes advertised to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp send med
By default, BGP does not replace the MED value with AIGP value in routes advertised to a peer or peer group.
Use this command to send the AIGP attribute to a peer or peer group that does not support AIGP.
The BGP RT filtering feature reduces the number of routes advertised in an MPLS L3VPN.
After RT filtering is configured, a PE advertises its import target attribute to the peer PEs in the RT filter address family. The peer PEs use the received import target attribute to filter routes and advertise only the routes that match the attribute to the PE.
When a large number of IBGP peers exist, the BGP RT filtering and the route reflection features are used together as a best practice. Route reflection reduces the number of IBGP connections. BGP RT filtering reduces the number of routes advertised in the network.
For more information about the BGP RT filtering commands, see Layer 3—IP Routing Command Reference.
3. Enter BGP IPv4 RT filter address family view.
address-family ipv4 rtfilter
4. Enable the device to exchange routing information with a peer or peer group.
By default, the device cannot exchange routing information with a peer or peer group.
5. (Optional.) Advertise a default route to a peer or peer group.
By default, no default route is advertised.
6. (Optional.) Set the maximum number of routes that can be received from the specified peer or peer group.
By default, no limit is set for the number of routes that can be received from a peer or peer group.
7. (Optional.) Set a preferred value for routes received from a peer or peer group.
8. (Optional.) Prefer routes learned from the specified peer or peer group during optimal route selection.
9. (Optional.) Configure the device as a route reflector and specify a peer or peer group as its client.
10. (Optional.) Enable route reflection between clients.
11. (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
Configuring the BGP additional path feature
By default, BGP advertises only one optimal route. When the optimal route fails, traffic forwarding will be interrupted until route convergence completes.
The BGP additional path (Add-Path) feature enables BGP to advertise multiple routes with the same prefix and different next hops to a peer or peer group. When the optimal route fails, the suboptimal route becomes the optimal route, which shortens the traffic interruption time.
You can enable the BGP additional path sending, receiving, or both sending and receiving capabilities on a BGP router. For two BGP peers to successfully negotiate the additional path capabilities, make sure one end has the sending capability and the other end has the receiving capability.
2. Enter BGP VPNv4 address family view or BGP-VPN VPNv4 address family view.
¡ Execute the following commands in sequence to enter BGP VPNv4 address family view:
¡ Execute the following commands in sequence to enter BGP-VPN VPNv4 address family view:
3. Configure the BGP additional path capabilities.
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
By default, no BGP additional path capabilities are configured.
4. Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
By default, the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group is 1.
5. Set the maximum total number of Add-Path optimal routes that can be advertised to all peers.
By default, the maximum total number of Add-Path optimal routes that can be advertised to all peers is 1.
This command is not supported in BGP-VPN VPNv4 address family view.
6. (Optional.) Set the optimal route selection delay timer.
By default, the optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
Configuring the rule for adding BGP routes to the IP routing table and the route advertisement rule for VPN instances
Perform this task to configure the following features:
· Route adding rule—For multiple BGP routes to the same destination, BGP adds the optimal route with matching route targets of a VPN instance to the IP routing table of the VPN instance.
After the undo policy vpn-target command is executed, VPNv4 routes without matching route targets of the local VPN instance can be received. If the VPNv4 routes have the same RD as the local VPN instance, these routes can be selected in the BGP VPNv4 routing table as optimal routes. However, routes without matching route targets are invisible and unavailable in the BGP-VPN instance routing table and cannot be added to the routing table of the VPN instance. The BGP-VPN instance routing table uses the same optimal route selection result as the BGP VPNv4 routing table. Therefore, if a route without matching route targets is selected as the only optimal route in the BGP VPNv4 routing table, no optimal route can be added to the BGP-VPN instance routing table. Only the optimal route in the BGP-VPN instance routing table can be added to the VPN instance IP routing table. Therefore, the BGP route without matching route targets cannot be added to the VPN instance IP routing table, so packets destined for the destination address of that route cannot be forwarded.
You can configure this feature to resolve this issue. With this feature configured, for BGP routes to the same destination address, BGP adds the optimal route with the same route targets as a VPN instance to the IP routing table of the VPN instance.
For example, the import target of VPN instance vpna is 10:1. The BGP routing table of VPN instance vpna contains two routes to destination address 1.1.1.1, which are 1.1.1.1 <RT: 10:1> and 1.1.1.1 <RT: 20:1>, and 1.1.1.1 <RT: 20:1> is the optimal route. After you configure this feature, BGP will add 1.1.1.1 <RT: 10:1> to the IP routing table of VPN instance vpna, because this route has the same import target as the VPN instance.
· Route advertisement rule—When the optimal route to a destination address cannot be advertised to peers, the device advertises the suboptimal route to the destination address from the routes that can be advertised. The device does not advertise any route for a destination address only if no routes to the destination address can be advertised.
The BGP routing table of a VPN instance contains the routes in the IP routing table of the VPN instance, so the routing table of a BGP address family might contain routes that are not learned from that address family. For example, an IP prefix advertisement route learned from the BGP EVPN address family is added to the IP routing table of a VPN instance, and the route also exists in the BGP routing tables of the BGP-VPN IPv4 unicast address family and BGP VPNv4 address family in the VPN instance. BGP cannot advertise the optimal route to peers in an address family if the optimal route is not learned from that address family, making the destination address of the route unreachable.
After you configure this feature, if the optimal route to a destination address cannot be advertised to peers, the device advertises the suboptimal route, and so forth until a route to the destination address is advertised successfully. The device does not advertise any route for a destination address only if no routes to the destination address can be advertised.
For example, the device learns the route with IP prefix 3.3.3.3/32 from both the BGP VPNv4 address family and BGP EVPN address family. Therefore, there will be two routes to destination address 3.3.3.3 in the BGP routing table of the BGP VPNv4 address family, and the one learned from the BGP EVPN address family is the optimal route. However, this optimal route cannot be advertised to BGP VPNv4 peers, because it was learned from the BGP EVPN address family. As a result, network nodes deployed with only BGP VPNv4 cannot obtain the route with IP prefix 3.3.3.3/32. After you configure this feature, the device will advertise the route with IP prefix 3.3.3.3/32 learned from the BGP VPNv4 address family to BGP VPNv4 peers, although this route is not the optimal route.
The bestroute same-rd command takes effect on BGP routes of all VPN instances. Use caution when you execute this command.
1. Enter system view.
3. Configure BGP to add the optimal routes with the same route targets as a VPN instance to the IP routing table of the VPN instance, and allow BGP to advertise non-optimal routes to its peers.
bestroute same-rd
By default, BGP adds the optimal routes in the BGP routing table to the IP routing table of a VPN instance and advertises only the optimal routes to its peers.
Enabling the VPN Prefix ORF feature
About VPN Prefix ORF
VPN Prefix ORF introduction
By default, in large-scale networks with route reflectors, the BGP VPNv4 routes reflected by the RR usually include the VPN routes from all BGP-VPN instances on the route originator. The current route limit measures can take effect only on address families. When the number of routes for RR reflection reaches the limit, unwanted BGP-VPN instance routes might occupy most of the receiving end's received routes, resulting in the receiving end not being able to receive the necessary BGP-VPN instance routes.
To resolve this issue, it is required to allow the RR to filter routes based on the BGP-VPN instances of the routes on the originator, implementing router filtering at the granularity of BGP-VPN instances in the BGP VPNv4 address families. Enabling the VPN Prefix Outbound Route Filtering (ORF) feature can resolve the above issue. This feature uses route-refresh messages to send VPN Prefix ORF entries (which contain information for route matching) to peers. Peers will withdraw all previously advertised routes that match the VPN Prefix ORF entries and when sending new routes to the local device, they must filter the routes using both the routing policy on the peer device and the received VPN Prefix ORF entries. Only routes that pass both filters will be sent to the local device. VPN Prefix ORF realizes the advertisement and reception of route control at the BGP-VPN instance granularity. It limits the number of routes at the source of route sending to reduce route exchanges between BGP peers and save network resources.
VPN Prefix ORF operating mechanism
After configuring this feature, the BGP session between the local device and the specified peer/peer group will be disconnected and reestablished for VPN Prefix ORF capability negotiation via Open messages. Negotiation can be successful only if the peer capability-advertise orf vpn-prefix command is configured on both ends of the BGP session. After successful negotiation, the device will be able to parse the route-refresh messages carrying VPN Prefix ORF entries sent by the remote end. A VPN Prefix ORF entry contains a <RD value, source device address> tuple.
NOTE: If the devices in the BGP session do not support the exchange of route-refresh messages, the VPN Prefix ORF entries will not be successfully sent. Configure the peer capability-advertise route-refresh command on both ends of the BGP session to enable the capability of exchanging route-refresh messages. For more information the peer capability-advertise route-refresh command, see BGP commands in Layer 3—IP Routing Command Reference. |
The VPN Prefix ORF feature uses the following conditions to determine whether to trigger sending VPN Prefix ORF entries:
· The <RD, source device address> tuple used to match VPN routes and the alarm threshold for the matching VPN routes, which is used to match VPN routes.
· The maximum number of routes supported by a BGP-VPN instance, which is set by using the route-limit command.
After these conditions are set on the device, when the number of IPv4 or IPv6 unicast routes in a BGP-VPN instance exceeds the route limit, and the percentage of the routes that match the tuple in the BGP-VPN instance exceeds the alarm threshold:
1. The device checks if there are other BGP-VPN instances configured with the same tuple.
¡ If yes, go to step 2.
¡ If not, go to step 3.
2. The device checks if the number of routes in these BGP-VPN instances has exceeded the route limit and if the number of routes matching the tuple has exceeded the alarm threshold.
¡ If yes, go to step 3.
¡ If not, the BGP-VPN instance that contains routes exceeding the route limit will continue to receive routes and repeat step 2.
3. The device sends a route-refresh message with a VPN Prefix ORF entry to the peer/peer group specified by the peer capability-advertise orf vpn-prefix command.
TIP: Among the BGP-VPN instances configured with the same tuple, if the number of routes matching the tuple in some BGP-VPN instances has exceeded the alarm threshold, while some BGP-VPN instances have not received any routes matching the tuple, it indicates that these instances cannot receive routes matching the tuple. The device will not consider these BGP-VPN instances when determining whether to trigger sending VPN Prefix ORF entries. |
A VPN Prefix ORF entry contains a <RD value, source device address> tuple. The values of RD and source device address are those specified by using the vpn-prefix-quota command.
After receiving a route-refresh message carrying a VPN Prefix ORF entry from the local device, the specified peer/peer group operates as follows:
· Withdraws all BGP VPNv4 routes that match both the RD and source device address in the VPN Prefix ORF entry. (The route information matching the source device address in the VPN Prefix ORF entry is the next hop attribute of the route.)
· No longer sends BGP VPNv4 routes that match the VPN Prefix ORF entry to the local device.
If the device has previously advertised VPN Prefix ORF entries, the entries will remain effective on the peer to filter route advertisement. You can execute the clear bgp vpn-prefix-orf command to withdraw the previously advertised VPN Prefix ORF entries, so that the peer can re-advertise routes that were withdrawn or filtered due to the VPN Prefix ORF entries.
VPN Prefix ORF application network diagram
As shown in Figure 25, VPN instances are configured on each PE. The RR reflects routes from PE 1, PE 2, and PE 3 within the same AS. Both PE 1 and PE 2 have successfully negotiated the VPN Prefix ORF capabilities with the RR. PE 1 specifies the tuple as <RD31, PE3> and the alarm threshold as 70% in the BGP-VPN instances corresponding to VPN1 and VPN2 by using the vpn-prefix-quota command. PE 2 specifies the tuple as <RD31, PE3> and the alarm threshold as 70% in the BGP-VPN instance corresponding to VPN1 by using the vpn-prefix-quota command.
Figure 25 VPN Prefix ORF application network diagram
PE 3 advertises routes of VPN1 through BGP VPNv4. When the advertised routes cause BGP-VPN instances on PE 1 and PE 2 to exceed the route limit, VPN Prefix ORF will function on PE 1 and PE 2 as follows:
· On PE 1
The number of routes in the BGP-VPN instance for VPN1 exceeded the limit, and the number of routes matching <RD31, PE3> exceeded 70% of the total routes. However, PE 1 would not send route-refresh messages carrying VPN Prefix ORF entries because the BGP-VPN instances for VPN2 and VPN1 have the same tuple <RD31, PE3>, and PE 1 could still receive VPN1 routes carrying RT 1 and RT 2 from PE 3 for the BGP-VPN instance corresponding to VPN2. PE 1 will send a route-refresh message carrying a VPN Prefix ORF entry to the RR only when both the BGP-VPN instances for VPN1 and VPN2 have exceeded the route limit and the VPN routes matching the <RD31, PE3> tuple have also exceeded the alarm threshold. The advertised VPN Prefix ORF entry contains the following information: <RD31, min (maximum route count supported by BGP-VPN instance for VPN1, maximum route count supported by BGP-VPN instance for VPN2), PE3 address>.
After receiving the route-refresh message with the VPN Prefix ORF entry, the RR will withdraw the advertised routes that meet the following conditions from PE 1 and will no longer advertise the routes that meet the following conditions to PE 1:
¡ The RD carried by the routes is RD31.
¡ The next hop address of the routes is the address of PE 3.
Figure 26 VPN Prefix ORF taking effect
· On PE 2
When the number of routes in the BGP-VPN instance for VPN1 exceeds the limit, PE 2 will immediately send a route-refresh message carrying a VPN Prefix ORF entry to the RR because no other BGP-VPN instances have specified the same tuple. The advertised VPN Prefix ORF entry contains the following information: <RD31, maximum route count supported by BGP-VPN instance for VPN1, PE3 address>.
After receiving the route-refresh message carrying the VPN Prefix ORF entry, the RR will withdraw the advertised routes that meet the following conditions from PE 2 and will no longer advertise routes that meet the following conditions to PE 2:
In the current software version, only VPN Prefix ORF within the same AS is supported. VPN Prefix ORF across ASs is not supported.
You must configure the route-limit, vpn-prefix-quota route-distinguisher, and peer capability-advertise orf vpn-prefix commands at the same time for VPN Prefix ORF to operate properly.
Configuring a VPN instance
2. Create a VPN instance and enter its view.
3. Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
4. Configure route targets for the VPN instance.
By default, no route targets are configured for a VPN instance.
Configuring the conditions that trigger the VPN Prefix ORF mechanism
2. Enter BGP instance view.
3. Enter BGP-VPN instance view.
5. Set the maximum number of routes supported by the BGP-VPN instance.
route-limit limit
By default, no limit is set to the number of routes supported by a BGP-VPN instance.
6. Set the tuple for routing matching and set the alarm threshold for routes matching the tuple.
vpn-prefix-quota route-distinguisher route-distinguisher source-address { ipv4-address | ipv6-address } quota threshold
By default, no tuple or alarm threshold is set, and no alarm information will be triggered for tuple-matching routes.
Configuring the VPN Prefix ORF feature
3. Enter BGP VPNv4 address family view.
address-family vpnv4
4. Enable negotiating VPN Prefix ORF capabilities with the specified BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] |ipv6-address [ prefix-length ] } capability-advertise orf vpn-prefix { both | send | receive }
By default, the local end does not negotiate VPN Prefix ORF capabilities with BGP peer/peer group.
5. (Optional.) Withdraw the advertised VPN Prefix ORF entries.
a. Execute the following commands in sequence to return to user view:
b. Withdraw the advertised VPN Prefix ORF entries.
clear bgp [ instance instance-name ] vpn-prefix-orf [ vpn-instance vpn-instance-name | route-distinguisher route-distinguisher source-address { ipv4-address | ipv6-address } ]
Configuring route replication
Configuring the public instance
Configure the public instance to enable the mutual access between public network and private network users.
In an MPLS L3VPN network, for the public network and the VPN network to communicate with each other through route target matching, perform the following tasks:
· Configure matching route targets for the public instance and VPN instance.
· Use the route-replicate enable command in BGP instance view to enable mutual BGP route replication between the public and VPN instances.
2. Enter public instance view.
ip public-instance
3. Configure an RD for the public instance.
By default, no RD is configured for the public instance.
4. Configure a route target for the public instance.
By default, no route target is configured for the public instance.
5. Enter public instance IPv4 address family view.
address-family ipv4
6. Configure a route target for the IPv4 address family of the public instance.
By default, no route target is configured for the IPv4 address family of the public instance.
7. Apply an import routing policy to the public instance.
By default, all routes matching the import target attribute are accepted.
8. Apply an export routing policy to the public instance.
By default, routes to be advertised are not filtered.
9. (Optional.) Set the maximum number of active route prefixes supported by the public instance. Choose one or more of the following tasks:
¡ Execute the following commands in sequence to set the maximum number of active route prefixes supported by the public instance:
¡ Set the maximum number of IPv4 route prefixes supported by the public instance.
By default, no limit is set for the number of active route prefixes supported by the public instance.
The configuration in public instance IPv4 address family view takes precedence over the configuration in public instance view.
Configuring route replication for public and VPN instances
In a BGP/MPLS L3VPN network, only VPN instances that have matching route targets can communicate with each other.
The route replication feature provides the following functions:
· Enables a VPN instance to communicate with the public network or other VPN instances by replicating routes from the public instance or other VPN instances.
· Enables the public network to communicate with a VPN instance by replicating routes from the VPN instance.
In an intelligent traffic control network, traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network, configure this feature to replicate routes from the public instance to the VPN instances.
VLINK direct routes are generated based on ARP entries learned by interfaces. The route-replicate from vpn-instance protocol direct or route-replicate from public protocol direct command replicates VLINK direct routes, but the VLINK direct routes cannot be added to the FIB, causing traffic forwarding failures. To address this issue, you can specify the vlink-direct keyword to replicate VLINK direct routes and add the routes to the FIB.
Configuring a VPN instance to replicate routes from the public instance or another VPN instance
2. Enter VPN instance view.
3. Enter VPN instance IPv4 address family view.
address-family ipv4
4. Replicate routes from the public instance or other VPN instances.
route-replicate from { public | vpn-instance vpn-instance-name } protocol eigrp eigrp-as [ advertise ] [ route-policy route-policy-name ]
route-replicate from { public | vpn-instance vpn-instance-name } protocol { bgp as-number | direct | static | unr | vlink-direct | { isis | ospf | rip } process-id } [ advertise ] [ route-policy route-policy-name ]
By default, a VPN instance cannot replicate routes from the public instance or other VPN instances.
Replicating routes from a VPN instance to the public instance
ip public-instance
3. Enter public instance IPv4 address family view.
address-family ipv4
4. Replicate routes from a VPN instance to the public instance.
route-replicate from vpn-instance vpn-instance-name protocol { bgp as-number | direct | static | unr | vlink-direct | { isis | ospf | rip } process-id } [ advertise ] [ route-policy route-policy-name ]
By default, the public instance cannot replicate routes from VPN instances.
Configuring BGP route replication between public and VPN instances
In traffic cleaning scenarios, traffic between the public and private networks are filtered by firewalls and traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network under the protection of firewalls, BGP route replication between public and VPN instances is required.
By default, only VPN instances that have matching route targets can redistribute BGP routes from each other, while the public instance and VPN instances cannot. After you configure this feature, the public instance and VPN instances that have matching route targets can replicate BGP routes from each other, enabling communication between the public network and VPN users.
This feature also replicates the BGP route attributes, so that the device can select proper forwarding paths according to the route attributes.
After this feature is enabled, the public network and VPNs cannot be isolated. Configure this feature only in specific scenarios, for example, the traffic cleaning scenario.
To use this feature to implement IPv4 route replication between the public instance and a VPN instance, make sure the VPN instance and the BGP IPv4 unicast address family have been created.
3. Enable BGP route replication between public and VPN instances.
By default, BGP route replication between public and VPN instances is disabled.
Enabling redistribution of multiple same-prefix routes with the same RD
Typically, if multiple same-prefix BGP routes have the same RD as a local BGP VPN instance or the BGP public instance, BGP redistributes only the best one of them into the routing table of that BGP VPN instance or the BGP public instance.
To redistribute multiple same-prefix routes with the same RD into a BGP routing table, perform this task.
This feature enables redistribution of multiple active same-prefix BGP routes that have the same RD, as follows:
· If these routes are in the routing table of a BGP VPN instance or the BGP public instance, BGP redistributes them into the BGP VPNv4, VPNv6, or EVPN routing table, regardless of their route priorities.
· If these routes are in the BGP VPNv4, VPNv6, or EVPN routing table, BGP redistributes them into the BGP VPN instance or the BGP public instance, regardless of their route priorities when the following conditions are met:
¡ The routes have the same RD has the VPN or public instance.
¡ The routes match the import RTs as the VPN or public instance.
Enabled in BGP instance view, this feature applies to redistribution of routes from a BGP VPN instance or the BGP public instance into the BGP VPNv4, VPNv6, or EVPN routing table, and vice versa.
Enabled in the view of an address family, this feature takes effect only on redistribution of routes into the BGP routing table for that address family.
2. Enter a BGP address family view.
¡ Enter BGP instance view.
¡ Execute the following commands in sequence to enter BGP IPv4 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv4 unicast address family view:
3. Enable redistribution of multiple same-prefix routes with the same RD.
vpn-route cross multipath
By default, redistribution of multiple same-prefix routes with the same RD is disabled.
Enabling prioritized withdrawal of specific routes
This feature enables BGP to send the withdrawal messages of specific routes prior to other routes. This can achieve fast switchover of traffic on the specified routes to available routes to reduce the traffic interruption time.
4. Enable prioritized withdrawal of the routes that match the specified routing policy.
By default, BGP does not send the withdrawal messages of specific routes prior to other routes.
Enabling SNMP notifications for MPLS L3VPN
To report critical MPLS L3VPN events to an NMS, enable SNMP notifications for MPLS L3VPN. For MPLS L3VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2. Enable SNMP notifications for MPLS L3VPN.
snmp-agent trap enable l3vpn [ vrf-down | vrf-ipv6-down | vrf-ipv6-up | vrf-up ] *
By default, SNMP notifications for MPLS L3VPN are enabled.
Enabling logging for BGP route flapping
This feature enables BGP to generate logs for BGP route flappings that trigger log generation. The generated logs are sent to the information center. For the logs to be output correctly, you must also configure information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
3. Enable logging for BGP route flapping.
By default, logging for BGP route flapping is disabled.
Display and maintenance commands for MPLS L3VPN
Resetting BGP connections
You can soft-reset or reset BGP sessions to apply new BGP configurations. A soft reset operation updates BGP routing information without tearing down BGP connections. A reset operation updates BGP routing information by tearing down, and then re-establishing BGP connections. Soft reset requires that BGP peers have route refresh capability.
Execute the following commands in user view to soft reset or reset BGP connections:
Task |
Command |
Soft-reset BGP sessions for the VPNv4 address family. |
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } vpnv4 [ vpn-instance vpn-instance-name ] |
Soft-reset BGP sessions for the BGP IPv4 RT filter family. |
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } ipv4 rtfilter |
Reset BGP sessions for the VPNv4 address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | internal | group group-name } vpnv4 [ vpn-instance vpn-instance-name ] |
Reset BGP sessions for the BGP IPv4 RT filter family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | internal | group group-name } ipv4 rtfilter |
For more information about the refresh bgp vpnv4 and reset bgp vpnv4 commands, see Layer 3—IP Routing Command Reference.
Displaying and maintaining MPLS L3VPN information
Execute the following display commands in any view and reset commands in user view to display and maintain MPLS L3VPN information:
Task |
Command |
Display BGP VPNv4 route dampening parameters. |
display bgp [ instance instance-name ] dampening parameter vpnv4 |
Display BGP RT filter peer group information. |
display bgp [ instance instance-name ] group ipv4 rtfilter [ group-name group-name ] |
Display BGP VPNv4 peer group information. |
display bgp [ instance instance-name ] group vpnv4 [ vpn-instance vpn-instance-name ] [ group-name group-name ] |
Display BGP RT filter information. |
display bgp [ instance instance-name ] ipv4 rtfilter [ peer ipv4-address [ statistics ] | statistics ] |
Display BGP RT filter peer information. |
display bgp [ instance instance-name ] peer ipv4 rtfilter [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] |
Display BGP VPNv4 peer information. |
display bgp [ instance instance-name ] peer vpnv4 [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] |
Display information about dampened BGP VPNv4 routes. |
display bgp [ instance instance-name ] routing-table dampened vpnv4 |
Display BGP VPNv4 route flapping information. |
display bgp [ instance instance-name ] routing-table flap-info vpnv4 [ ipv4-address [ { mask | mask-length } [ longest-match ] ] | as-path-acl as-path-acl-number ] |
Display incoming labels for BGP IPv4 unicast routes. |
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] inlabel |
Display outgoing labels for BGP IPv4 unicast routes. |
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] outlabel |
Display BGP IPv4 RT filter routing information. |
display bgp [ instance instance-name ] routing-table ipv4 rtfilter [ default-rt [ advertise-info ] | [ origin-as as-number ] [ route-target [ advertise-info ] ] | as-path-acl { as-path-acl-number | as-path-acl-name } | as-path-regular-expression regular-expression | peer ipv4-address { advertised-routes | received-routes } [ default-rt | [ origin-as as-number ] [ route-target ] | statistics ] | statistics ] display bgp [ instance instance-name ] routing-table ipv4 rtfilter time-range min-time max-time |
Display BGP VPNv4 routes. |
display bgp [ instance instance-name ] routing-table vpnv4 [ [ route-distinguisher route-distinguisher ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl as-path-acl-number | as-path-regular-expression regular-expression | [ statistics ] { community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ] | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } ] | [ vpn-instance vpn-instance-name ] peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] [ verbose ] | statistics ] | peer ipv6-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] [ verbose ] | statistics ] | statistics ] display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher ] [ ipv4-address [ mask-length | mask ] ] [ statistics ] { large-community [ aa:bb:cc&<1-32> ] | large-community-list { basic-large-community-list-number | adv-large-community-list-number | large-comm-list-name } } [ whole-match ] display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher ] [ ipv4-address [ mask-length | mask ] ] statistics source { evpn-remote-import | local | local-import | remote-import } display bgp [ instance instance-name ] routing-table vpnv4 [ same-rd-selected ] display bgp [ instance instance-name ] routing-table vpnv4 { [ vpn-instance vpn-instance-name ] peer ipv4-address | peer ipv6-address } { accepted-routes | not-accepted-routes } display bgp [ instance instance-name ] routing-table vpnv4 [ route-distinguisher route-distinguisher | vpn-instance vpn-instance-name peer ipv4-address ] time-range min-time max-time |
Display BGP VPNv4 route source information. |
display bgp [ instance instance-name ] routing-table vpnv4 source-type |
Display incoming labels for BGP VPNv4 routes. |
display bgp [ instance instance-name ] routing-table vpnv4 inlabel |
Display outgoing labels for BGP VPNv4 routes. |
display bgp [ instance instance-name ] routing-table vpnv4 outlabel |
Display BGP IPv4 RT filter address family update group information. |
display bgp [ instance instance-name ] update-group ipv4 rtfilter [ ipv4-address ] |
Display BGP VPNv4 address family update group information. |
display bgp [ instance instance-name ] update-group vpnv4 [ vpn-instance vpn-instance-name ] [ ipv4-address ] |
Display BGP peer and routing summary information. |
display bgp [ instance instance-name ] vpnv4 summary |
Display route targets sourcing from a VPN instance. |
display bgp [ instance instance-name ] route-target l3vpn [ ipv4 ] [ vpn-instance vpn-instance-name ] |
Display received and advertised VPN Prefix ORF entries. |
display bgp [ instance instance-name ] vpn-prefix-orf [ route-distinguisher route-distinguisher source-address { ipv4-address | ipv6-address } ] |
Display the FIB of a VPN instance. |
display fib vpn-instance vpn-instance-name |
Display FIB entries that match the specified destination IP address in the specified VPN instance. |
display fib vpn-instance vpn-instance-name ip-address [ mask-length | mask ] |
Display the routing table for a VPN instance. |
display ip routing-table vpn-instance vpn-instance-name [ statistics | verbose ] |
Display information about a specific or all VPN instances. |
display ip vpn-instance [ instance-name vpn-instance-name | count ] |
Display OSPF sham link information. |
display ospf [ process-id ] sham-link [ area area-id ] |
Clear BGP VPNv4 route dampening information and release dampened routes. |
reset bgp [ instance instance-name ] dampening vpnv4 [ ipv4-address [ mask | mask-length ] ] |
Clear BGP VPNv4 route flapping statistics. |
reset bgp [ instance instance-name ] flap-info vpnv4 [ ipv4-address [ mask | mask-length ] | as-path-acl as-path-acl-number | peer ipv4-address [ mask-length ] ] |
For more information about the following commands, see BGP commands in Layer 3—IP Routing Command Reference:
· display ip routing-table
· display bgp group vpnv4
· display bgp peer vpnv4
· display bgp update-group vpnv4
MPLS L3VPN configuration examples
Example: Configuring basic MPLS L3VPN
CE 1 and CE 3 belong to VPN 1. CE 2 and CE 4 belong to VPN 2.
VPN 1 uses route target attribute 111:1. VPN 2 uses route target attribute 222:2. Users of different VPNs cannot access each other.
A PE and its connected CE use EBGP to exchange VPN routing information.
PEs use OSPF to communicate with each other and use MP-IBGP to exchange VPN routing information.
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
10.1.1.1/24 |
P |
Loop0 |
2.2.2.9/32 |
PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/4 |
172.1.1.2/24 |
XGE3/0/1 |
10.1.1.2/24 |
XGE3/0/5 |
172.2.1.1/24 |
XGE3/0/2 |
10.2.1.2/24 |
PE 2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/4 |
172.1.1.1/24 |
XGE3/0/1 |
10.3.1.2/24 |
CE 2 |
XGE3/0/1 |
10.2.1.1/24 |
XGE3/0/2 |
10.4.1.2/24 |
CE 3 |
XGE3/0/1 |
10.3.1.1/24 |
XGE3/0/4 |
172.2.1.2/24 |
CE 4 |
XGE3/0/1 |
10.4.1.1/24 |
1. Configure OSPF on the MPLS backbone to ensure IP connectivity within the backbone:
# Configure PE 1.
[Sysname] sysname PE1
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] interface ten-gigabitethernet 3/0/4
[PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/4] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure the P device.
[Sysname] sysname P
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface ten-gigabitethernet 3/0/4
[P-Ten-GigabitEthernet3/0/4] ip address 172.1.1.2 24
[P-Ten-GigabitEthernet3/0/4] quit
[P] interface ten-gigabitethernet 3/0/5
[P-Ten-GigabitEthernet3/0/5] ip address 172.2.1.1 24
[P-Ten-GigabitEthernet3/0/5] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
[Sysname] sysname PE2
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] interface ten-gigabitethernet 3/0/4
[PE2-Ten-GigabitEthernet3/0/4] ip address 172.2.1.2 24
[PE2-Ten-GigabitEthernet3/0/4] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
# Execute the display ospf peer command to verify that OSPF adjacencies in Full state have been established between PE 1, P, and PE 2. Execute the display ip routing-table command to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
2. Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/4] mpls enable
[PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Ten-GigabitEthernet3/0/4] mpls enable
[P-Ten-GigabitEthernet3/0/4] mpls ldp enable
[P-Ten-GigabitEthernet3/0/5] mpls enable
[P-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/4] mpls enable
[PE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Execute the display mpls ldp peer command to verify that LDP sessions in Operational state have been established between PE 1, P, and PE 2. Execute the display mpls ldp lsp command to verify that the LSPs have been established by LDP. (Details not shown.)
3. Configure VPN instances on PEs to allow CE access:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 222:2
[PE1-vpn-instance-vpn2] quit
[PE1] interface ten-gigabitethernet 3/0/1
[PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.2 24
[PE1-Ten-GigabitEthernet3/0/1] quit
[PE1] interface ten-gigabitethernet 3/0/2
[PE1-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn2
[PE1-Ten-GigabitEthernet3/0/2] ip address 10.2.1.2 24
[PE1-Ten-GigabitEthernet3/0/2] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 200:2
[PE2-vpn-instance-vpn2] vpn-target 222:2
[PE2-vpn-instance-vpn2] quit
[PE2] interface ten-gigabitethernet 3/0/1
[PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/1] ip address 10.3.1.2 24
[PE2-Ten-GigabitEthernet3/0/1] quit
[PE2] interface ten-gigabitethernet 3/0/2
[PE2-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn2
[PE2-Ten-GigabitEthernet3/0/2] ip address 10.4.1.2 24
[PE2-Ten-GigabitEthernet3/0/2] quit
# Configure CE 1.
[Sysname] sysname CE1
[CE1] interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.1 24
[CE1-Ten-GigabitEthernet3/0/1] quit
# Configure CE 2.
[Sysname] sysname CE2
[CE2] interface ten-gigabitethernet 3/0/1
[CE2-Ten-GigabitEthernet3/0/1] ip address 10.2.1.1 24
[CE2-Ten-GigabitEthernet3/0/1] quit
# Configure CE 3.
[Sysname] sysname CE3
[CE3] interface ten-gigabitethernet 3/0/1
[CE3-Ten-GigabitEthernet3/0/1] ip address 10.3.1.1 24
[CE3-Ten-GigabitEthernet3/0/1] quit
# Configure CE 4.
[Sysname] sysname CE4
[CE4] interface ten-gigabitethernet 3/0/1
[CE4-Ten-GigabitEthernet3/0/1] ip address 10.4.1.1 24
[CE4-Ten-GigabitEthernet3/0/1] quit
# Execute the display ip vpn-instance command on the PEs to display the configuration of the VPN instance. Use the ping command on the PEs to verify that the PEs can ping their attached CEs. (Details not shown.)
4. Establish EBGP peer relationships between PEs and CEs, and redistribute VPN routes into BGP:
# Configure CE 1.
[CE1] bgp 65410
[CE1-bgp-default] peer 10.1.1.2 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.2 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
# Configure CE 2.
[CE2] bgp 65420
[CE2-bgp-default] peer 10.2.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 10.2.1.2 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# Configure CE 3.
[CE3] bgp 65430
[CE3-bgp-default] peer 10.3.1.2 as-number 100
[CE3-bgp-default] address-family ipv4 unicast
[CE3-bgp-default-ipv4] peer 10.3.1.2 enable
[CE3-bgp-default-ipv4] import-route direct
[CE3-bgp-default-ipv4] quit
[CE3-bgp-default] quit
# Configure CE 4.
[CE4] bgp 65440
[CE4-bgp-default] peer 10.4.1.2 as-number 100
[CE4-bgp-default] address-family ipv4 unicast
[CE4-bgp-default-ipv4] peer 10.4.1.2 enable
[CE4-bgp-default-ipv4] import-route direct
[CE4-bgp-default-ipv4] quit
[CE4-bgp-default] quit
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] ip vpn-instance vpn2
[PE1-bgp-default-vpn2] peer 10.2.1.1 as-number 65420
[PE1-bgp-default-vpn2] address-family ipv4 unicast
[PE1-bgp-default-ipv4-vpn2] peer 10.2.1.1 enable
[PE1-bgp-default-ipv4-vpn2] quit
[PE1-bgp-default-vpn2] quit
[PE1-bgp-default] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10.3.1.1 as-number 65430
[PE2-bgp-default-ipv4-vpn1] peer 10.3.1.1 enable
[PE2-bgp-default-vpn1] quit
[PE2-bgp-default] ip vpn-instance vpn2
[PE2-bgp-default-vpn2] peer 10.4.1.1 as-number 65440
[PE2-bgp-default-vpn2] address-family ipv4 unicast
[PE2-bgp-default-ipv4-vpn2] peer 10.4.1.1 enable
[PE2-bgp-default-ipv4-vpn2] quit
[PE2-bgp-default-vpn2] quit
[PE2-bgp-default] quit
# Configure PE 2 in the same way that PE 1 is configured. (Details not shown.)
# Execute the display bgp peer ipv4 vpn-instance command on the PEs to verify that a BGP peer relationship in Established state has been established between a PE and a CE. (Details not shown.)
5. Create an MP-IBGP peer relationship between PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv4] quit
# Execute the display bgp peer vpnv4 command on the PEs to verify that a BGP peer relationship in Established state has been established between the PEs. (Details not shown.)
# Execute the display ip routing-table vpn-instance command on the PEs.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 6 Routes : 6
10.1.1.0/24 Direct 0 0 10.1.1.2 XGE3/0/1
10.1.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/1
10.1.1.255/32 Direct 0 0 10.1.1.2 XGE3/0/1
10.3.1.0/24 BGP 255 0 3.3.3.9 XGE3/0/4
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
The output shows that PE 1 has a route to the remote CE. Output on PE 2 is similar.
# Verify that CEs of the same VPN can ping each other, whereas those of different VPNs cannot. For example, CE 1 can ping CE 3 (10.3.1.1), but it cannot ping CE 4 (10.4.1.1). (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 111:1 import-extcommunity
vpn-target 111:1 export-extcommunity
vpn-target 222:2 import-extcommunity
vpn-target 222:2 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
interface Ten-GigabitEthernet3/0/1
interface Ten-GigabitEthernet3/0/2
ip address 10.2.1.2 255.255.255.0
interface Ten-GigabitEthernet3/0/4
ip address 172.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
ip address 172.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
interface Ten-GigabitEthernet3/0/5
ip address 172.2.1.1 255.255.255.0
mpls enable
mpls ldp enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
ip address 10.3.1.2 255.255.255.0
ip address 10.4.1.2 255.255.255.0
ip address 172.2.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
return
· CE 1:
sysname CE1
bgp 65410
import-route direct
return
· CE 2:
sysname CE2
ip address 10.2.1.1 255.255.255.0
bgp 65420
import-route direct
return
· CE 3:
sysname CE3
ip address 10.3.1.1 255.255.255.0
bgp 65430
import-route direct
return
· CE 4:
sysname CE4
ip address 10.4.1.1 255.255.255.0
bgp 65440
import-route direct
return
Example: Configuring MPLS L3VPN over a GRE tunnel
CE 1 and CE 2 belong to VPN 1. The PEs support MPLS. The P router does not support MPLS and provides only IP features.
On the backbone, use a GRE tunnel to encapsulate and forward VPN packets to implement MPLS L3VPN.
Configure tunnel policies on the PEs, and specify the tunnel type for VPN traffic as GRE.
Figure 28 Network diagram
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
10.1.1.1/24 |
P |
XGE3/0/4 |
172.1.1.2/24 |
PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/5 |
172.2.1.1/24 |
XGE3/0/1 |
10.1.1.2/24 |
PE 2 |
Loop0 |
2.2.2.9/32 |
XGE3/0/5 |
172.1.1.1/24 |
XGE3/0/1 |
10.2.1.2/24 |
Tunnel0 |
20.1.1.1/24 |
XGE3/0/4 |
172.2.1.2/24 |
CE 2 |
XGE3/0/1 |
10.2.1.1/24 |
Tunnel0 |
20.1.1.2/24 |
1. Configure an IGP on the MPLS backbone to ensure IP connectivity within the backbone.
# Configure PE 1.
[PE1] interface ten-gigabitethernet 3/0/5
[PE1-Ten-GigabitEthernet3/0/5] ip address 172.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/5] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure P.
[Sysname] sysname P
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
# Configure PE 2.
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1] quit
# Execute the display ospf peer command to verify that OSPF adjacencies in Full state have been established between PE 1, P, and PE 2. Execute the display ip routing-table command to verify that the PEs have learned the loopback route of each other. (Details not shown.)
2. Configure basic MPLS on the PEs:
# Configure PE 1.
# Configure PE 2.
[PE2] mpls lsr-id 2.2.2.9
3. Configure VPN instances on PEs to allow CE access, and apply tunnel policies to the VPN instances, using a GRE tunnel for VPN packet forwarding:
# Configure PE 1.
[PE1] tunnel-policy gre1
[PE1-tunnel-policy-gre1] select-seq gre load-balance-number 1
[PE1-tunnel-policy-gre1] quit
[PE1-vpn-instance-vpn1] vpn-target 100:1 both
[PE1-vpn-instance-vpn1] tnl-policy gre1
# Configure PE 2.
[PE2] tunnel-policy gre1
[PE2-tunnel-policy-gre1] select-seq gre load-balance-number 1
[PE2-tunnel-policy-gre1] quit
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2-vpn-instance-vpn1] vpn-target 100:1 both
[PE2-vpn-instance-vpn1] tnl-policy gre1
[PE2-Ten-GigabitEthernet3/0/1] ip address 10.2.1.2 24
# Configure CE 1.
# Configure CE 2.
# Configure CE 1.
[CE1] bgp 65410
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 next-hop-local
# Configure CE 2.
[CE2] bgp 65420
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10.2.1.1 as-number 65420
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 next-hop-local
5. Configure an MP-IBGP peer relationship between PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 2.2.2.9 enable
# Configure PE 2.
[PE2] bgp 100
6. Configure a GRE tunnel:
# Configure PE 1.
[PE1] interface tunnel 0 mode gre
[PE1-Tunnel0] source loopback 0
[PE1-Tunnel0] destination 2.2.2.9
[PE1-Tunnel0] ip address 20.1.1.1 24
[PE1-Tunnel0] mpls enable
[PE1-Tunnel0] quit
# Configure PE 2.
[PE2] interface tunnel 0 mode gre
[PE2-Tunnel0] source loopback 0
[PE2-Tunnel0] destination 1.1.1.9
[PE2-Tunnel0] ip address 20.1.1.2 24
[PE2-Tunnel0] mpls enable
[PE2-Tunnel0] quit
# Use the following command on CE 1 to verify that the CEs have learned the interface route from each other.
[CE1] display ip routing-table
Destinations : 8 Routes : 8
10.1.1.0/24 Direct 0 0 10.1.1.1 XGE3/0/1
10.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/1
10.1.1.255/32 Direct 0 0 10.1.1.1 XGE3/0/1
10.2.1.0/24 BGP 255 0 10.1.1.2 XGE3/0/1
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
tnl-policy gre1
vpn-target 100:1 import-extcommunity
vpn-target 100:1 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
tunnel-policy gre1
interface LoopBack0
interface Tunnel0 mode gre
ip address 20.1.1.1 255.255.255.0
mpls enable
source LoopBack0
destination 2.2.2.9
bgp 100
peer 2.2.2.9 connect-interface LoopBack0
peer 2.2.2.9 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
return
· PE 2:
sysname PE2
tnl-policy gre1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
tunnel-policy gre1
interface LoopBack0
ip address 20.1.1.2 255.255.255.0
mpls enable
source LoopBack0
destination 1.1.1.9
bgp 100
peer 1.1.1.9 enable
return
· CE 1:
sysname CE1
bgp 65410
import-route direct
return
· CE 2:
sysname CE2
bgp 65420
import-route direct
return
Example: Configuring a hub-spoke network
The Spoke-CEs cannot communicate directly. They can communicate only through Hub-CE.
Configure EBGP between the Spoke-CEs and Spoke-PEs and between Hub-CE and Hub-PE to exchange VPN routing information.
Configure OSPF between the Spoke-PEs and Hub-PE to implement communication between the PEs, and configure MP-IBGP between them to exchange VPN routing information.
Table 3 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Spoke-CE 1 |
XGE3/0/1 |
10.1.1.1/24 |
Hub-CE |
XGE3/0/1 |
10.3.1.1/24 |
Spoke-PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/2 |
10.4.1.1/24 |
XGE3/0/1 |
10.1.1.2/24 |
Hub-PE |
Loop0 |
2.2.2.9/32 |
XGE3/0/4 |
172.1.1.1/24 |
XGE3/0/4 |
172.1.1.2/24 |
Spoke-CE 2 |
XGE3/0/1 |
10.2.1.1/24 |
XGE3/0/5 |
172.2.1.2/24 |
Spoke-PE 2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/1 |
10.3.1.2/24 |
XGE3/0/1 |
10.2.1.2/24 |
XGE3/0/2 |
10.4.1.2/24 |
XGE3/0/4 |
172.2.1.1/24 |
1. Configure an IGP on the MPLS backbone to ensure IP connectivity within the backbone:
# Configure Spoke-PE 1.
[Sysname] sysname Spoke-PE1
[Spoke-PE1] interface loopback 0
[Spoke-PE1-LoopBack0] ip address 1.1.1.9 32
[Spoke-PE1-LoopBack0] quit
[Spoke-PE1] interface ten-gigabitethernet 3/0/4
[Spoke-PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.1 24
[Spoke-PE1-Ten-GigabitEthernet3/0/4] quit
[Spoke-PE1] ospf
[Spoke-PE1-ospf-1] area 0
[Spoke-PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Spoke-PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[Spoke-PE1-ospf-1-area-0.0.0.0] quit
[Spoke-PE1-ospf-1] quit
# Configure Spoke-PE 2.
[Sysname] sysname Spoke-PE2
[Spoke-PE2] interface loopback 0
[Spoke-PE2-LoopBack0] ip address 3.3.3.9 32
[Spoke-PE2-LoopBack0] quit
[Spoke-PE2] interface ten-gigabitethernet 3/0/4
[Spoke-PE2-Ten-GigabitEthernet3/0/4] ip address 172.2.1.1 24
[Spoke-PE2-Ten-GigabitEthernet3/0/4] quit
[Spoke-PE2] ospf
[Spoke-PE2-ospf-1] area 0
[Spoke-PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Spoke-PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[Spoke-PE2-ospf-1-area-0.0.0.0] quit
[Spoke-PE2-ospf-1] quit
# Configure Hub-PE.
[Sysname] sysname Hub-PE
[Hub-PE] interface loopback 0
[Hub-PE-LoopBack0] ip address 2.2.2.9 32
[Hub-PE-LoopBack0] quit
[Hub-PE] interface ten-gigabitethernet 3/0/4
[Hub-PE-Ten-GigabitEthernet3/0/4] ip address 172.1.1.2 24
[Hub-PE-Ten-GigabitEthernet3/0/4] quit
[Hub-PE] interface ten-gigabitethernet 3/0/5
[Hub-PE-Ten-GigabitEthernet3/0/5] ip address 172.2.1.2 24
[Hub-PE-Ten-GigabitEthernet3/0/5] quit
[Hub-PE] ospf
[Hub-PE-ospf-1] area 0
[Hub-PE-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[Hub-PE-ospf-1-area-0.0.0.0] quit
[Hub-PE-ospf-1] quit
# Execute the display ospf peer command on the devices to verify that OSPF adjacencies in Full state have been established between Spoke-PE 1, Spoke-PE 2, and Hub-PE. Execute the display ip routing-table command on the devices to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
[Spoke-PE1] mpls lsr-id 1.1.1.9
[Spoke-PE1] mpls ldp
[Spoke-PE1-ldp] quit
[Spoke-PE1-Ten-GigabitEthernet3/0/4] mpls enable
[Spoke-PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[Spoke-PE2] mpls lsr-id 3.3.3.9
[Spoke-PE2] mpls ldp
[Spoke-PE2-ldp] quit
[Spoke-PE2-Ten-GigabitEthernet3/0/4] mpls enable
[Spoke-PE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Configure Hub-PE.
[Hub-PE] mpls lsr-id 2.2.2.9
[Hub-PE] mpls ldp
[Hub-PE-ldp] quit
[Hub-PE-Ten-GigabitEthernet3/0/4] mpls enable
[Hub-PE-Ten-GigabitEthernet3/0/4] mpls ldp enable
[Hub-PE-Ten-GigabitEthernet3/0/5] mpls enable
[Hub-PE-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Execute the display mpls ldp peer command on the devices to verify that LDP sessions in Operational state have been established between Spoke-PE 1, Spoke-PE 2, and Hub-PE. Execute the display mpls ldp lsp command on the devices to verify that the LSPs have been established by LDP. (Details not shown.)
3. Configure VPN instances on the Spoke-PEs and Hub-PE:
[Spoke-PE1] ip vpn-instance vpn1
[Spoke-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[Spoke-PE1-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE1-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE1-vpn-instance-vpn1] quit
[Spoke-PE1] interface ten-gigabitethernet 3/0/1
[Spoke-PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[Spoke-PE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.2 24
[Spoke-PE1-Ten-GigabitEthernet3/0/1] quit
[Spoke-PE2] ip vpn-instance vpn1
[Spoke-PE2-vpn-instance-vpn1] route-distinguisher 100:2
[Spoke-PE2-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE2-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE2-vpn-instance-vpn1] quit
[Spoke-PE2] interface ten-gigabitethernet 3/0/1
[Spoke-PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[Spoke-PE2-Ten-GigabitEthernet3/0/1] ip address 10.2.1.2 24
[Spoke-PE2-Ten-GigabitEthernet3/0/1] quit
# Configure Hub-PE.
[Hub-PE] ip vpn-instance vpn1-in
[Hub-PE-vpn-instance-vpn1-in] route-distinguisher 100:3
[Hub-PE-vpn-instance-vpn1-in] vpn-target 222:2 import-extcommunity
[Hub-PE-vpn-instance-vpn1-in] quit
[Hub-PE] ip vpn-instance vpn1-out
[Hub-PE-vpn-instance-vpn1-out] route-distinguisher 100:4
[Hub-PE-vpn-instance-vpn1-out] vpn-target 111:1 export-extcommunity
[Hub-PE-vpn-instance-vpn1-out] quit
[Hub-PE] interface ten-gigabitethernet 3/0/1
[Hub-PE-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1-in
[Hub-PE-Ten-GigabitEthernet3/0/1] ip address 10.3.1.2 24
[Hub-PE-Ten-GigabitEthernet3/0/1] quit
[Hub-PE] interface ten-gigabitethernet 3/0/2
[Hub-PE-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn1-out
[Hub-PE-Ten-GigabitEthernet3/0/2] ip address 10.4.1.2 24
[Hub-PE-Ten-GigabitEthernet3/0/2] quit
# Configure Spoke-CE 1.
[Sysname] sysname Spoke-CE1
[Spoke-CE1] interface ten-gigabitethernet 3/0/1
[Spoke-CE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.1 24
[Spoke-CE1-Ten-GigabitEthernet3/0/1] quit
# Configure Spoke-CE 2.
[Sysname] sysname Spoke-CE2
[Spoke-CE2] interface ten-gigabitethernet 3/0/1
[Spoke-CE2-Ten-GigabitEthernet3/0/1] ip address 10.2.1.1 24
[Spoke-CE2-Ten-GigabitEthernet3/0/1] quit
# Configure Hub-CE.
[Sysname] sysname Hub-CE
[Hub-CE] interface ten-gigabitethernet 3/0/1
[Hub-CE-Ten-GigabitEthernet3/0/1] ip address 10.3.1.1 24
[Hub-CE-Ten-GigabitEthernet3/0/1] quit
[Hub-CE] interface ten-gigabitethernet 3/0/2
[Hub-CE-Ten-GigabitEthernet3/0/2] ip address 10.4.1.1 24
[Hub-CE-Ten-GigabitEthernet3/0/2] quit
4. Establish EBGP peer relationships between the PEs and CEs, and redistribute VPN routes into BGP:
[Spoke-CE1] bgp 65410
[Spoke-CE1-bgp-default] peer 10.1.1.2 as-number 100
[Spoke-CE1-bgp-default] address-family ipv4
[Spoke-CE1-bgp-default-ipv4] peer 10.1.1.2 enable
[Spoke-CE1-bgp-default-ipv4] import-route direct
[Spoke-CE1-bgp-default-ipv4] quit
[Spoke-CE1-bgp-default] quit
[Spoke-CE2] bgp 65420
[Spoke-CE2-bgp-default] peer 10.2.1.2 as-number 100
[Spoke-CE2-bgp-default] address-family ipv4
[Spoke-CE2-bgp-default-ipv4] peer 10.2.1.2 enable
[Spoke-CE2-bgp-default-ipv4] import-route direct
[Spoke-CE2-bgp-default-ipv4] quit
[Spoke-CE2-bgp-default] quit
# Configure Hub-CE.
[Hub-CE] bgp 65430
[Hub-CE-bgp-default] peer 10.3.1.2 as-number 100
[Hub-CE-bgp-default] peer 10.4.1.2 as-number 100
[Hub-CE-bgp-default] address-family ipv4
[Hub-CE-bgp-default-ipv4] peer 10.3.1.2 enable
[Hub-CE-bgp-default-ipv4] peer 10.4.1.2 enable
[Hub-CE-bgp-default-ipv4] import-route direct
[Hub-CE-bgp-default-ipv4] quit
[Hub-CE-bgp-default] quit
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] ip vpn-instance vpn1
[Spoke-PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65410
[Spoke-PE1-bgp-default-vpn1] address-family ipv4
[Spoke-PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[Spoke-PE1-bgp-default-ipv4-vpn1] quit
[Spoke-PE1-bgp-default-vpn1] quit
[Spoke-PE1-bgp-default] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] ip vpn-instance vpn1
[Spoke-PE2-bgp-default-vpn1] peer 10.2.1.1 as-number 65420
[Spoke-PE2-bgp-default-vpn1] address-family ipv4
[Spoke-PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
[Spoke-PE2-bgp-default-ipv4-vpn1] quit
[Spoke-PE2-bgp-default-vpn1] quit
[Spoke-PE2-bgp-default] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] ip vpn-instance vpn1-in
[Hub-PE-bgp-default-vpn1-in] peer 10.3.1.1 as-number 65430
[Hub-PE-bgp-default-vpn1-in] address-family ipv4
[Hub-PE-bgp-default-ipv4-vpn1-in] peer 10.3.1.1 enable
[Hub-PE-bgp-default-ipv4-vpn1-in] quit
[Hub-PE-bgp-default-vpn1-in] quit
[Hub-PE-bgp-default] ip vpn-instance vpn1-out
[Hub-PE-bgp-default-vpn1-out] peer 10.4.1.1 as-number 65430
[Hub-PE-bgp-default-vpn1-out] address-family ipv4
[Hub-PE-bgp-default-ipv4-vpn1-out] peer 10.4.1.1 enable
[Hub-PE-bgp-default-ipv4-vpn1-out] peer 10.4.1.1 allow-as-loop 2
[Hub-PE-bgp-default-ipv4-vpn1-out] quit
[Hub-PE-bgp-default-vpn1-out] quit
[Hub-PE-bgp-default] quit
5. Establish an MP-IBGP peer relationship between the Spoke-PEs and Hub-PE:
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE1-bgp-default] address-family vpnv4
[Spoke-PE1-bgp-default-vpnv4] peer 2.2.2.9 enable
[Spoke-PE1-bgp-default-vpnv4] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE2-bgp-default] address-family vpnv4
[Spoke-PE2-bgp-default-vpnv4] peer 2.2.2.9 enable
[Spoke-PE2-bgp-default-vpnv4] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] peer 1.1.1.9 as-number 100
[Hub-PE-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[Hub-PE-bgp-default] peer 3.3.3.9 as-number 100
[Hub-PE-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[Hub-PE-bgp-default] address-family vpnv4
[Hub-PE-bgp-default-vpnv4] peer 1.1.1.9 enable
[Hub-PE-bgp-default-vpnv4] peer 3.3.3.9 enable
[Hub-PE-bgp-default-vpnv4] quit
# Execute the display ip routing-table vpn-instance command on the PEs to display the routes to the CEs. This example uses Spoke-PE 1 to verify that the next hop of the route from a Spoke-PE to its connected Spoke-CE is Hub-PE.
[Spoke-PE1] display ip routing-table vpn-instance vpn1
10.2.1.0/24 BGP 255 0 2.2.2.9 XGE3/0/4
10.3.1.0/24 BGP 255 0 2.2.2.9 XGE3/0/4
10.4.1.0/24 BGP 255 0 2.2.2.9 XGE3/0/4
# Verify that Spoke-CE 1 and Spoke-CE 2 can ping each other. The TTL value indicates that traffic from Spoke-CE 1 to Spoke-CE 2 passes six hops (255-250+1) and is forwarded through Hub-CE. This example uses Spoke-CE 1 to verify their connectivity.
[Spoke-CE1] ping 10.2.1.1
Ping 10.2.1.1 (10.2.1.1): 56 data bytes, press CTRL_C to break
56 bytes from 10.2.1.1: icmp_seq=0 ttl=250 time=1.000 ms
56 bytes from 10.2.1.1: icmp_seq=1 ttl=250 time=2.000 ms
56 bytes from 10.2.1.1: icmp_seq=2 ttl=250 time=0.000 ms
56 bytes from 10.2.1.1: icmp_seq=3 ttl=250 time=1.000 ms
56 bytes from 10.2.1.1: icmp_seq=4 ttl=250 time=0.000 ms
--- Ping statistics for 10.2.1.1 ---
round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms
Configuration files
· Spoke-PE 1:
sysname Spoke-PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
return
· Spoke-PE 2:
sysname Spoke-PE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
return
· Hub-PE:
sysname Hub-PE
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 3.3.3.9 enable
return
· Spoke-CE 1:
sysname Spoke-CE1
bgp 65410
import-route direct
return
· Spoke-CE 2:
sysname Spoke-CE2
bgp 65420
import-route direct
return
· Hub-CE:
sysname Hub-CE
bgp 65430
import-route direct
return
Example: Configuring MPLS L3VPN inter-AS option A
CE 1 and CE 2 belong to the same VPN. CE 1 accesses the network through PE 1 in AS 100, and CE 2 accesses the network through PE 2 in AS 200.
Configure inter-AS option A MPLS L3VPN, and use the VRF-to-VRF method to manage VPN routes.
Run OSPF on the MPLS backbone of each AS.
Figure 30 Network diagram
Table 4 Interface and IP address assignment
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
10.1.1.1/24 |
CE 2 |
XGE3/0/1 |
10.2.1.1/24 |
PE 1 |
Loop0 |
1.1.1.9/32 |
PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
10.1.1.2/24 |
XGE3/0/1 |
10.2.1.2/24 |
XGE3/0/4 |
172.1.1.2/24 |
XGE3/0/4 |
162.1.1.2/24 |
ASBR-PE1 |
Loop0 |
2.2.2.9/32 |
ASBR-PE2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/4 |
172.1.1.1/24 |
XGE3/0/4 |
162.1.1.1/24 |
XGE3/0/5 |
192.1.1.1/24 |
XGE3/0/5 |
192.1.1.2/24 |
For the same VPN, the route targets for the VPN instance on the PE must match those for the VPN instance on the ASBR-PE in the same AS. This is not required for PEs in different ASs.
1. Configure IGP on the MPLS backbone.
# Configure PE 1.
[PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.2 24
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure ASBR-PE1.
[Sysname] sysname ASBR-PE1
[ASBR-PE1-LoopBack0] ip address 2.2.2.9 32
[ASBR-PE1-LoopBack0] quit
[ASBR-PE1] interface ten-gigabitethernet 3/0/4
[ASBR-PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.1 24
[ASBR-PE1-Ten-GigabitEthernet3/0/4] quit
[ASBR-PE1] ospf
[ASBR-PE1-ospf-1] area 0
[ASBR-PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[ASBR-PE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[ASBR-PE1-ospf-1-area-0.0.0.0] quit
[ASBR-PE1-ospf-1] quit
# Configure ASBR-PE2.
[Sysname] sysname ASBR-PE2
[ASBR-PE2] interface loopback 0
[ASBR-PE2-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE2-LoopBack0] quit
[ASBR-PE2] interface ten-gigabitethernet 3/0/4
[ASBR-PE2-Ten-GigabitEthernet3/0/4] ip address 162.1.1.1 24
[ASBR-PE2-Ten-GigabitEthernet3/0/4] quit
[ASBR-PE2] ospf
[ASBR-PE2-ospf-1] area 0
[ASBR-PE2-ospf-1-area-0.0.0.0] network 162.1.1.0 0.0.0.255
[ASBR-PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[ASBR-PE2-ospf-1-area-0.0.0.0] quit
[ASBR-PE2-ospf-1] quit
# Configure PE 2.
[PE2-LoopBack0] ip address 4.4.4.9 32
[PE2-Ten-GigabitEthernet3/0/4] ip address 162.1.1.2 24
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 162.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[PE2-ospf-1] quit
# Execute the display ospf peer command to verify that each ASBR-PE has established an OSPF adjacency in Full state with the PE in the same AS, and that PEs and ASBR-PEs in the same AS have learned the routes to the loopback interfaces of each other. Verify that each ASBR-PE and the PE in the same AS can ping each other. (Details not shown.)
# Configure basic MPLS on PE 1, and enable MPLS LDP on the interface connected to ASBR-PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure basic MPLS on ASBR-PE 1, and enable MPLS LDP on the interface connected to PE 1.
[ASBR-PE1] mpls lsr-id 2.2.2.9
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1-Ten-GigabitEthernet3/0/4] mpls enable
[ASBR-PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Configure basic MPLS on ASBR-PE 2, and enable MPLS LDP on the interface connected to PE 2.
[ASBR-PE2] mpls lsr-id 3.3.3.9
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2-Ten-GigabitEthernet3/0/4] mpls enable
[ASBR-PE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Configure basic MPLS on PE 2, and enable MPLS LDP on the interface connected to ASBR-PE 2.
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls ldp
[PE2-ldp] quit
# Execute the display mpls ldp peer command on the devices to verify that the LDP session status is Operational, and that each PE and the ASBR-PE in the same AS have established an LDP neighbor relationship. (Details not shown.)
3. Configure VPN instances on PEs:
# Configure CE 1.
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 100:2
# Configure CE 2.
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 200:2
[PE2-vpn-instance-vpn1] vpn-target 200:1 both
# On ASBR-PE 1, create a VPN instance, and bind the instance to the interface connected to ASBR-PE 2. ASBR-PE 1 considers ASBR-PE 2 to be its CE.
[ASBR-PE1] ip vpn-instance vpn1
[ASBR-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[ASBR-PE1-vpn-instance-vpn1] vpn-target 100:1 both
[ASBR-PE1-vpn-instance-vpn1] quit
[ASBR-PE1] interface ten-gigabitethernet 3/0/5
[ASBR-PE1-Ten-GigabitEthernet3/0/5] ip binding vpn-instance vpn1
[ASBR-PE1-Ten-GigabitEthernet3/0/5] ip address 192.1.1.1 24
[ASBR-PE1-Ten-GigabitEthernet3/0/5] quit
# On ASBR-PE 2, create a VPN instance, and bind the instance to the interface connected to ASBR-PE 1. ASBR-PE 2 considers ASBR-PE 1 to be its CE.
[ASBR-PE2] ip vpn-instance vpn1
[ASBR-PE2-vpn-instance-vpn1] route-distinguisher 200:1
[ASBR-PE2-vpn-instance-vpn1] vpn-target 200:1 both
[ASBR-PE2-vpn-instance-vpn1] quit
[ASBR-PE2] interface ten-gigabitethernet 3/0/5
[ASBR-PE2-Ten-GigabitEthernet3/0/5] ip binding vpn-instance vpn1
[ASBR-PE2-Ten-GigabitEthernet3/0/5] ip address 192.1.1.2 24
[ASBR-PE2-Ten-GigabitEthernet3/0/5] quit
# Execute the display ip vpn-instance command to display VPN instance configurations. Verify that the PEs can ping their attached CEs, and the ASBR-PEs can ping each other. (Details not shown.)
# Configure CE 1.
[CE1] bgp 65001
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 65001
# Configure CE 2.
[CE2] bgp 65002
[CE2-bgp-default] peer 10.2.1.2 as-number 200
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default-vpn1] peer 10.2.1.1 as-number 65002
5. Establish an MP-IBGP peer relationship between each PE and the ASBR-PE in the same AS, and an EBGP peer relationship between the ASBR-PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 2.2.2.9 next-hop-local
# Configure ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] ip vpn-instance vpn1
[ASBR-PE1-bgp-default-vpn1] peer 192.1.1.2 as-number 200
[ASBR-PE1-bgp-default-vpn1] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4-vpn1] peer 192.1.1.2 enable
[ASBR-PE1-bgp-default-ipv4-vpn1] quit
[ASBR-PE1-bgp-default-vpn1] quit
[ASBR-PE1-bgp-default] peer 1.1.1.9 as-number 100
[ASBR-PE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[ASBR-PE1-bgp-default-vpnv4] peer 1.1.1.9 enable
[ASBR-PE1-bgp-default-vpnv4] peer 1.1.1.9 next-hop-local
[ASBR-PE1-bgp-default] quit
# Configure ASBR-PE 2.
[ASBR-PE2] bgp 200
[ASBR-PE2-bgp-default] ip vpn-instance vpn1
[ASBR-PE2-bgp-default-vpn1] peer 192.1.1.1 as-number 100
[ASBR-PE2-bgp-default-vpn1] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4-vpn1] peer 192.1.1.1 enable
[ASBR-PE2-bgp-default-ipv4-vpn1] quit
[ASBR-PE2-bgp-default-vpn1] quit
[ASBR-PE2-bgp-default] peer 4.4.4.9 as-number 200
[ASBR-PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[ASBR-PE2-bgp-default-vpnv4] peer 4.4.4.9 enable
[ASBR-PE2-bgp-default-vpnv4] peer 4.4.4.9 next-hop-local
[ASBR-PE2-bgp-default] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default] peer 3.3.3.9 as-number 200
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 3.3.3.9 enable
[PE2-bgp-default-vpnv4] peer 3.3.3.9 next-hop-local
# Verify that the CEs can learn the interface routes from each other and ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
interface GigabitEthernet1/0/4
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
interface GigabitEthernet1/0/5
ip address 192.1.1.1 255.255.255.0
bgp 100
peer 1.1.1.9 enable
return
· ASBR-PE 2:
sysname ASBR-PE2
vpn-target 200:1 import-extcommunity
vpn-target 200:1 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 162.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
ip address 192.1.1.2 255.255.255.0
bgp 200
peer 4.4.4.9 connect-interface LoopBack0
peer 4.4.4.9 enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
ip address 4.4.4.9 255.255.255.255
ip address 162.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 200
peer 3.3.3.9 enable
return
· CE 1:
sysname CE1
bgp 65001
import-route direct
return
· CE 2:
sysname CE2
bgp 65002
import-route direct
return
Example: Configuring MPLS L3VPN inter-AS option B
Site 1 and Site 2 belong to the same VPN. CE 1 of Site 1 accesses the network through PE 1 in AS 100, and CE 2 of Site 2 accesses the network through PE 2 in AS 600.
PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange VPNv4 routes through MP-IBGP. PE 2 and ASBR-PE 2 exchange VPNv4 routes through MP-IBGP. ASBR-PE 1 and ASBR-PE 2 exchange VPNv4 routes through MP-EBGP.
ASBRs do not perform route target filtering of received VPN-IPv4 routes.
Figure 31 Network diagram
Table 5 Interface and IP address assignment
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
30.0.0.1/8 |
XGE3/0/1 |
20.0.0.1/8 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
30.0.0.2/8 |
CE 2 |
XGE3/0/1 |
20.0.0.2/8 |
1. Configure PE 1:
# Configure IS-IS on PE 1.
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0001.00
[PE1-isis-1] quit
# Configure LSR ID, and enable MPLS and LDP.
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls ldp
[PE1-ldp] quit
# Configure Ten-GigabitEthernet 3/0/5, and enable IS-IS, MPLS, and LDP on the interface.
[PE1-Ten-GigabitEthernet3/0/5] ip address 1.1.1.2 255.0.0.0
[PE1-Ten-GigabitEthernet3/0/5] isis enable 1
[PE1-Ten-GigabitEthernet3/0/5] mpls enable
[PE1-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Configure Loopback 0, and enable IS-IS on it.
[PE1-LoopBack0] ip address 2.2.2.9 32
[PE1-LoopBack0] isis enable 1
# Create VPN instance vpn1, and configure the RD and route target attributes.
[PE1-vpn-instance-vpn1] vpn-target 1:1 2:2 import-extcommunity
[PE1-vpn-instance-vpn1] vpn-target 1:1 export-extcommunity
# Bind the interface connected to CE 1 to the created VPN instance.
[PE1-Ten-GigabitEthernet3/0/1] ip address 30.0.0.1 8
# Enable BGP on PE 1.
[PE1] bgp 100
# Configure IBGP peer 3.3.3.9 as a VPNv4 peer.
# Specify the CE as an EBGP peer of the PE.
[PE1-bgp-default-vpn1] peer 30.0.0.2 as-number 65001
[PE1-bgp-default-ipv4-vpn1] peer 30.0.0.2 enable
2. Configure ASBR-PE 1:
# Enable IS-IS on ASBR-PE 1.
[ASBR-PE1] isis 1
[ASBR-PE1-isis-1] network-entity 10.0000.0000.0000.0002.00
[ASBR-PE1-isis-1] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1-Ten-GigabitEthernet3/0/5] ip address 1.1.1.1 255.0.0.0
[ASBR-PE1-Ten-GigabitEthernet3/0/5] isis enable 1
[ASBR-PE1-Ten-GigabitEthernet3/0/5] mpls enable
[ASBR-PE1-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Configure Ten-GigabitEthernet 3/0/4, and enable MPLS.
[ASBR-PE1-Ten-GigabitEthernet3/0/4] ip address 11.0.0.2 255.0.0.0
[ASBR-PE1-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack0] isis enable 1
# Enable BGP on ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[ASBR-PE1-bgp-default] peer 11.0.0.1 connect-interface ten-gigabitethernet 3/0/4
# Disable route target based filtering of received VPNv4 routes.
# Configure both IBGP peer 2.2.2.9 and EBGP peer 11.0.0.1 as VPNv4 peers.
3. Configure ASBR-PE 2:
# Enable IS-IS on ASBR-PE 2.
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.0000.0000.0000.0003.00
[ASBR-PE2-isis-1] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2-Ten-GigabitEthernet3/0/5] ip address 9.1.1.1 255.0.0.0
[ASBR-PE2-Ten-GigabitEthernet3/0/5] isis enable 1
[ASBR-PE2-Ten-GigabitEthernet3/0/5] mpls enable
[ASBR-PE2-Ten-GigabitEthernet3/0/5] mpls ldp enable
[ASBR-PE2-Ten-GigabitEthernet3/0/4] ip address 11.0.0.1 255.0.0.0
[ASBR-PE2-LoopBack0] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack0] isis enable 1
# Enable BGP on ASBR-PE 2.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] peer 11.0.0.2 connect-interface ten-gigabitethernet 3/0/4
[ASBR-PE2-bgp-default] peer 5.5.5.9 connect-interface loopback 0
# Configure both IBGP peer 5.5.5.9 and EBGP peer 11.0.0.2 as VPNv4 peers.
4. Configure PE 2:
# Enable IS-IS on PE 2.
[PE2] isis 1
[PE2-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE2-isis-1] quit
# Configure the LSR ID, and enable MPLS and LDP.
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface ten-gigabitethernet 3/0/5
[PE2-Ten-GigabitEthernet3/0/5] ip address 9.1.1.2 255.0.0.0
[PE2-Ten-GigabitEthernet3/0/5] isis enable 1
[PE2-Ten-GigabitEthernet3/0/5] mpls enable
[PE2-Ten-GigabitEthernet3/0/5] mpls ldp enable
[PE2-Ten-GigabitEthernet3/0/5] quit
[PE2-LoopBack0] ip address 5.5.5.9 32
[PE2-LoopBack0] isis enable 1
[PE2-vpn-instance-vpn1] route-distinguisher 12:12
[PE2-vpn-instance-vpn1] vpn-target 1:1 2:2 import-extcommunity
[PE2-vpn-instance-vpn1] vpn-target 2:2 export-extcommunity
[PE2-Ten-GigabitEthernet3/0/1] ip address 20.0.0.1 8
# Enable BGP on PE 2.
[PE2] bgp 600
# Configure IBGP peer 4.4.4.9 as a VPNv4 peer.
[PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE2-bgp-default-vpn1] peer 20.0.0.2 as-number 65002
[PE2-bgp-default-ipv4-vpn1] peer 20.0.0.2 enable
5. Configure CE 1:
# Assign IP addresses to interfaces.
[CE1-Ten-GigabitEthernet3/0/1] ip address 30.0.0.2 8
# Specify the PE as an EBGP peer of the CE and redistribute direct routes.
[CE1] bgp 65001
[CE1-bgp-default] peer 30.0.0.1 as-number 100
[CE1-bgp-default-ipv4] peer 30.0.0.1 enable
6. Configure CE 2:
[CE2-Ten-GigabitEthernet3/0/1] ip address 20.0.0.2 8
[CE2] bgp 65002
[CE2-bgp-default] peer 20.0.0.1 as-number 600
[CE2-bgp-default-ipv4] peer 20.0.0.1 enable
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
ip address 30.0.0.1 255.0.0.0
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 11.0.0.1 connect-interface Ten-GigabitEthernet3/0/4
peer 2.2.2.9 enable
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 5.5.5.9 connect-interface LoopBack0
peer 11.0.0.2 connect-interface Ten-GigabitEthernet3/0/4
peer 5.5.5.9 enable
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
ip address 5.5.5.9 255.255.255.255
isis enable 1
ip address 20.0.0.1 255.0.0.0
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 4.4.4.9 enable
return
· CE 1:
sysname CE1
ip address 30.0.0.2 255.0.0.0
bgp 65001
import-route direct
return
· CE 2:
sysname CE2
ip address 20.0.0.2 255.0.0.0
bgp 65002
import-route direct
return
Example: Configuring MPLS L3VPN inter-AS option C (method 1) (exchanging labeled routes in BGP IPv4 unicast address family)
Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100, and Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange labeled IPv4 routes through IBGP. PE 2 and ASBR-PE 2 exchange labeled IPv4 routes through IBGP. PE 1 and PE 2 are MP-EBGP peers and exchange VPNv4 routes.
ASBR-PE 1 and ASBR-PE 2 use routing policies and label the routes received from each other.
ASBR-PE 1 and ASBR-PE 2 use EBGP to exchange labeled IPv4 routes.
Figure 32 Network diagram
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
30.0.0.1/24 |
XGE3/0/1 |
20.0.0.1/24 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
30.0.0.2/24 |
CE 2 |
XGE3/0/1 |
20.0.0.2/24 |
1. Configure CE 1:
# Assign an IP address to Ten-GigabitEthernet 3/0/1.
[CE1-Ten-GigabitEthernet3/0/1] ip address 30.0.0.2 24
# Establish an EBGP peer relationship with PE 1, and redistribute VPN routes.
[CE1] bgp 65001
2. Configure PE 1:
[PE1] isis 1
[PE1-isis-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
# Associate interface Ten-GigabitEthernet 3/0/1 with VPN instance vpn1, and specify the IP address for the interface.
[PE1-Ten-GigabitEthernet3/0/1] ip address 30.0.0.1 24
[PE1] bgp 100
# Enable the capability to advertise labeled routes to IBGP peer 3.3.3.9 and to receive labeled routes from the peer.
[PE1-bgp-default] address-family ipv4 unicast
[PE1-bgp-default-ipv4] peer 3.3.3.9 enable
[PE1-bgp-default-ipv4] peer 3.3.3.9 label-route-capability
[PE1-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp-default] peer 5.5.5.9 as-number 600
[PE1-bgp-default] peer 5.5.5.9 connect-interface loopback 0
[PE1-bgp-default] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv4 peer.
[PE1-bgp-default-vpnv4] peer 5.5.5.9 enable
# Establish an EBGP peer relationship with CE 1, and add the learned BGP routes to the routing table of VPN instance vpn1.
3. Configure ASBR-PE 1:
[ASBR-PE1] isis 1
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Configure Ten-GigabitEthernet 3/0/4, and enable MPLS on it.
# Create routing policies.
[ASBR-PE1] route-policy policy1 permit node 1
[ASBR-PE1-route-policy-policy1-1] apply mpls-label
[ASBR-PE1-route-policy-policy1-1] quit
[ASBR-PE1] route-policy policy2 permit node 1
[ASBR-PE1-route-policy-policy2-1] if-match mpls-label
[ASBR-PE1-route-policy-policy2-1] apply mpls-label
[ASBR-PE1-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 1, and apply the routing policy policy2 to routes advertised to IBGP peer 2.2.2.9.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 enable
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 route-policy policy2 export
# Enable the capability to advertise labeled routes to IBGP peer 2.2.2.9 and to receive labeled routes from the peer.
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 label-route-capability
# Redistribute routes from IS-IS process 1 to BGP.
[ASBR-PE1-bgp-default-ipv4] import-route isis 1
[ASBR-PE1-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 route-policy policy1 export
# Enable the capability to advertise labeled routes to EBGP peer 11.0.0.1 and to receive labeled routes from the peer.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 label-route-capability
4. Configure ASBR-PE 2:
[ASBR-PE2] isis 1
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
# Configure Ten-GigabitEthernet 3/0/4, and enable MPLS on the interface.
[ASBR-PE2] route-policy policy1 permit node 1
[ASBR-PE2-route-policy-policy1-1] apply mpls-label
[ASBR-PE2-route-policy-policy1-1] quit
[ASBR-PE2] route-policy policy2 permit node 1
[ASBR-PE2-route-policy-policy2-1] if-match mpls-label
[ASBR-PE2-route-policy-policy2-1] apply mpls-label
[ASBR-PE2-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 2, and enable the capability to advertise labeled routes to IBGP peer 5.5.5.9 and to receive labeled routes from the peer.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 label-route-capability
# Apply routing policy policy2 to routes advertised to IBGP peer 5.5.5.9.
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 route-policy policy2 export
# Redistribute routes from IS-IS process 1.
[ASBR-PE2-bgp-default-ipv4] import-route isis 1
[ASBR-PE2-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 route-policy policy1 export
# Enable the capability to advertise labeled routes to EBGP peer 11.0.0.2 and to receive labeled routes from the peer.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 label-route-capability
5. Configure PE 2:
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
# Associate Ten-GigabitEthernet 3/0/1 with VPN instance vpn1, and specify the IP address for the interface.
[PE2-Ten-GigabitEthernet3/0/1] ip address 20.0.0.1 24
[PE2] bgp 600
# Enable the capability to advertise labeled routes to IBGP peer 4.4.4.9 and to receive labeled routes from the peer.
[PE2-bgp-default] address-family ipv4 unicast
[PE2-bgp-default-ipv4] peer 4.4.4.9 enable
[PE2-bgp-default-ipv4] peer 4.4.4.9 label-route-capability
[PE2-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp-default] peer 2.2.2.9 as-number 100
[PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE2-bgp-default] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv4 peer.
[PE2-bgp-default-vpnv4] peer 2.2.2.9 enable
# Establish an EBGP peer relationship with CE 2, and add the learned BGP routes to the routing table of VPN instance vpn1.
6. Configure CE 2:
[CE2-Ten-GigabitEthernet3/0/1] ip address 20.0.0.2 24
# Establish an EBGP peer relationship with PE 2, and redistribute VPN routes.
[CE2] bgp 65002
# Execute the display ip routing table command on CE 1 and CE 2 to verify that CE 1 and CE 2 have a route to each other. Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
ip address 30.0.0.1 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 enable
peer 5.5.5.9 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
import-route isis 1
peer 2.2.2.9 enable
apply mpls-label
if-match mpls-label
apply mpls-label
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
import-route isis 1
peer 5.5.5.9 enable
apply mpls-label
if-match mpls-label
apply mpls-label
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 1
ip address 20.0.0.1 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 4.4.4.9 enable
peer 2.2.2.9 enable
return
· CE 1:
sysname CE1
ip address 30.0.0.2 255.255.255.0
bgp 65001
import-route direct
return
· CE 2:
sysname CE2
ip address 20.0.0.2 255.255.255.0
bgp 65002
import-route direct
return
Example: Configuring MPLS L3VPN inter-AS option C (method 1) (exchanging labeled routes in BGP IPv4 labeled unicast address family)
PE 1 and ASBR-PE 1 establish a session in BGP IPv4 labeled unicast address family to exchange IPv4 labeled routes.
PE 2 and ASBR-PE 2 establish a session in BGP IPv4 labeled unicast address family to exchange IPv4 labeled routes.
PE 1 and PE 2 establish an MP-EBGP session to exchange VPNv4 routes.
ASBR-PE 1 and ASBR-PE 2 establish a session in BGP IPv4 labeled unicast address family to exchange IPv4 labeled routes.
Figure 33 Network diagram
Table 7 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
30.0.0.1/24 |
XGE3/0/1 |
20.0.0.1/24 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
30.0.0.2/24 |
CE 2 |
XGE3/0/1 |
20.0.0.2/24 |
1. Configure CE 1:
# Assign an IP address to Ten-GigabitEthernet3/0/1.
[CE1] bgp 65001
2. Configure PE 1:
[PE1] isis 1
[PE1-isis-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] bgp 100
# Configure IBGP peer 3.3.3.9 as a BGP IPv4 labeled unicast peer.
[PE1-bgp-default] address-family ipv4 labeled-unicast
[PE1-bgp-default-labeled-ipv4] peer 3.3.3.9 enable
[PE1-bgp-default-labeled-ipv4] quit
# Redistribute BGP routes in BGP IPv4 labeled unicast address family to the BGP routing table of BGP IPv4 unicast address family, and add the redistributed BGP routes to the public network routing table.
[PE1-bgp-default-ipv4] import-rib public labeled-unicast
[ASBR-PE1] isis 1
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Enable BGP on ASBR-PE 1, and configure peers 2.2.2.9 and 11.0.0.1 as BGP IPv4 labeled unicast peers.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] address-family ipv4 labeled-unicast
[ASBR-PE1-bgp-default-labeled-ipv4] peer 2.2.2.9 enable
[ASBR-PE1-bgp-default-labeled-ipv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-labeled-ipv4] import-route isis 1
[ASBR-PE1-bgp-default-labeled-ipv4] quit
[ASBR-PE2] isis 1
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
# Enable BGP on ASBR-PE 2, and configure peers 5.5.5.9 and 11.0.0.2 as BGP IPv4 labeled unicast peers.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] address-family ipv4 labeled-unicast
[ASBR-PE2-bgp-default-labeled-ipv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp-default-labeled-ipv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-labeled-ipv4] import-route isis 1
[ASBR-PE2-bgp-default-labeled-ipv4] quit
5. Configure PE 2:
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] bgp 600
# Configure IBGP peer 4.4.4.9 as BGP IPv4 labeled unicast peer.
[PE2-bgp-default] address-family ipv4 labeled-unicast
[PE2-bgp-default-labeled-ipv4] peer 4.4.4.9 enable
[PE2-bgp-default-labeled-ipv4] quit
[PE2-bgp-default-ipv4] import-rib public labeled-unicast
6. Configure CE 2:
[CE2] bgp 65002
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 enable
peer 5.5.5.9 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
import-route isis 1
peer 2.2.2.9 enable
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
import-route isis 1
peer 5.5.5.9 enable
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 4.4.4.9 enable
peer 2.2.2.9 enable
return
· CE 1:
sysname CE1
bgp 65001
import-route direct
return
· CE 2:
sysname CE2
bgp 65002
import-route direct
return
Example: Configuring MPLS L3VPN inter-AS option C (method 2) (exchanging labeled routes in BGP IPv4 unicast address family)
ASBR-PE 1 and ASBR-PE 2 label the routes received from each other, use EBGP to exchange labeled IPv4 routes, and redistribute IGP and BGP routes from each other.
Figure 34 Network diagram
Table 8 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
30.0.0.1/24 |
XGE3/0/1 |
20.0.0.1/24 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
30.0.0.2/24 |
CE 2 |
XGE3/0/1 |
20.0.0.2/24 |
1. Configure CE 1:
[CE1] bgp 65001
2. Configure PE 1:
[PE1] isis 1
[PE1-isis-1] quit
# Configure an LSR ID, and enable MPLS and LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Enable IS-IS, MPLS, and LDP on interface Ten-GigabitEthernet 3/0/5.
# Enable IS-IS on interface Loopback 0.
# Associate interface Ten-GigabitEthernet 3/0/1 with VPN instance vpn1, and specify an IP address for the interface.
[PE1] bgp 100
3. Configure ASBR-PE1:
[ASBR-PE1] isis 1
# Redistribute BGP routes.
[ASBR-PE1-isis-1] address-family ipv4 unicast
[ASBR-PE1-isis-1-ipv4] import-route bgp
[ASBR-PE1-isis-1-ipv4] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Configure interface Ten-GigabitEthernet 3/0/5, and enable IS-IS, MPLS, and LDP on the interface.
# Configure interface Loopback 0, and enable IS-IS on it.
# Create routing policy policy1.
# Enable BGP on ASBR-PE 1, and redistribute routes from IS-IS process 1.
[ASBR-PE1] bgp 100
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] address-family ipv4 unicast
[ASBR-PE2-isis-1-ipv4] import-route bgp
[ASBR-PE2-isis-1-ipv4] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
# Enable BGP on ASBR-PE 2, and redistribute routes from IS-IS process 1.
[ASBR-PE2] bgp 600
5. Configure PE 2:
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] bgp 600
6. Configure CE 2:
# Assign an IP address to interface Ten-GigabitEthernet 3/0/1.
[CE2] bgp 65002
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 5.5.5.9 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
import-route bgp
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
import-route isis 1
apply mpls-label
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
import-route bgp
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
import-route isis 1
apply mpls-label
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 2.2.2.9 enable
return
· CE 1:
sysname CE1
bgp 65001
import-route direct
return
· CE 2:
sysname CE2
bgp 65002
import-route direct
return
Example: Configuring MPLS L3VPN inter-AS option C (method 2) (exchanging labeled routes in BGP IPv4 labeled unicast address family)
ASBR-PE 1 and ASBR-PE 2 exchange labeled IPv4 routes through a session in the BGP IPv4 labeled unicast address family, and redistribute IGP and BGP routes from each other.
Figure 35 Network diagram
Table 9 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
30.0.0.1/24 |
XGE3/0/1 |
20.0.0.1/24 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
30.0.0.2/24 |
CE 2 |
XGE3/0/1 |
20.0.0.2/24 |
1. Configure CE 1:
[CE1] bgp 65001
2. Configure PE 1:
[PE1] isis 1
[PE1-isis-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] bgp 100
[ASBR-PE1] isis 1
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Enable BGP on ASBR-PE 1, and configure EBGP peer 11.0.0.1 as a BGP IPv4 labeled unicast peer.
[ASBR-PE1] bgp 100
# Redistributes BGP IPv4 labeled unicast routes in the public network instance to the BGP routing table of the BGP IPv4 unicast address family.
[ASBR-PE1-bgp-default-ipv4] import-rib public labeled-unicast
[ASBR-PE2] isis 1
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
# Enable BGP on ASBR-PE 2, and configure EBGP peer 11.0.0.2 as a BGP IPv4 labeled unicast peer.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default-ipv4] import-rib public labeled-unicast
5. Configure PE 2:
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] bgp 600
6. Configure CE 2:
[CE2] bgp 65002
# Execute the display ip routing-table command on CE 1 and CE 2 to verify that CE 1 and CE 2 have a route to each other. Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 5.5.5.9 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
import-route bgp
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
import-route isis 1
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
import-route bgp
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
import-route isis 1
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 2.2.2.9 enable
return
· CE 1:
sysname CE1
bgp 65001
import-route direct
return
· CE 2:
sysname CE2
bgp 65002
import-route direct
return
Example: Configuring MPLS L3VPN carrier's carrier in the same AS
Configure carrier's carrier for the scenario shown in Figure 36. In this scenario:
· PE 1 and PE 2 are the provider carrier's PE routers. They provide VPN services for the customer carrier.
· CE 1 and CE 2 are the customer carrier's routers. They are connected to the provider carrier's backbone as CE routers.
· PE 3 and PE 4 are the customer carrier's PE routers. They provide MPLS L3VPN services for the end customers.
· CE 3 and CE 4 are customers of the customer carrier.
· The customer carrier and the provider carrier reside in the same AS.
The key to carrier's carrier deployment is to configure exchange of two kinds of routes:
· Exchange of the customer carrier's internal routes on the provider carrier's backbone.
· Exchange of the end customers' VPN routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-IBGP peer relationship must be established between PE 3 and PE 4.
Table 10 Interface and IP address assignment
IP address |
Device |
IP address |
CE 3 |
XGE3/0/1 |
100.1.1.1/24 |
CE 4 |
XGE3/0/1 |
120.1.1.1/24 |
PE 3 |
Loop0 |
1.1.1.9/32 |
PE 4 |
Loop0 |
6.6.6.9/32 |
XGE3/0/1 |
100.1.1.2/24 |
XGE3/0/1 |
120.1.1.2/24 |
XGE3/0/5 |
10.1.1.1/24 |
XGE3/0/5 |
20.1.1.2/24 |
CE 1 |
Loop0 |
2.2.2.9/32 |
CE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/4 |
10.1.1.2/24 |
XGE3/0/4 |
21.1.1.2/24 |
XGE3/0/5 |
11.1.1.1/24 |
XGE3/0/5 |
20.1.1.1/24 |
PE 1 |
Loop0 |
3.3.3.9/32 |
PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/4 |
11.1.1.2/24 |
XGE3/0/4 |
30.1.1.2/24 |
XGE3/0/5 |
30.1.1.1/24 |
XGE3/0/5 |
21.1.1.1/24 |
1. Configure MPLS L3VPN on the provider carrier backbone. Enable IS-IS as the IGP, enable LDP between PE 1 and PE 2, and establish an MP-IBGP peer relationship between the PEs:
# Configure PE 1.
[Sysname] sysname PE1
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 3.3.3.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE1-isis-1] quit
[PE1-Ten-GigabitEthernet3/0/5] ip address 30.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.9 as-number 100
[PE1-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 4.4.4.9 enable
# Configure PE 2.
[Sysname] sysname PE2
[PE2] interface loopback 0
[PE2-LoopBack0] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] isis 1
[PE2-isis-1] network-entity 10.0000.0000.0000.0005.00
[PE2-isis-1] quit
[PE2] interface ten-gigabitethernet 3/0/4
[PE2-Ten-GigabitEthernet3/0/4] ip address 30.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/4] isis enable 1
[PE2-Ten-GigabitEthernet3/0/4] mpls enable
[PE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
[PE2-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[PE2-Ten-GigabitEthernet3/0/4] quit
[PE2] bgp 100
[PE2-bgp-default] peer 3.3.3.9 as-number 100
# On PE 1 or PE 2, execute the following commands:
¡ Execute the display mpls ldp peer command to verify that an LDP session in Operational state has been established between PE 1 and PE 2. (Details not shown.)
¡ Execute the display bgp peer vpnv4 command to verify that a BGP peer relationship in Established state has been established between PE 1 and PE 2. (Details not shown.)
¡ Execute the display isis peer command to verify that the IS-IS neighbor relationship has been established between PE 1 and PE 2. (Details not shown.)
2. Configure the customer carrier network. Enable IS-IS as the IGP, and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2:
# Configure PE 3.
[Sysname] sysname PE3
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 1.1.1.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 1.1.1.9
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] network-entity 10.0000.0000.0000.0001.00
[PE3-isis-2] quit
[PE3-LoopBack0] isis enable 2
[PE3] interface ten-gigabitethernet 3/0/5
[PE3-Ten-GigabitEthernet3/0/5] ip address 10.1.1.1 24
[PE3-Ten-GigabitEthernet3/0/5] isis enable 2
[PE3-Ten-GigabitEthernet3/0/5] mpls enable
[PE3-Ten-GigabitEthernet3/0/5] mpls ldp enable
[PE3-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE3-Ten-GigabitEthernet3/0/5] quit
# Configure CE 1.
[Sysname] sysname CE1
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 2.2.2.9 32
[CE1-LoopBack0] quit
[CE1] mpls lsr-id 2.2.2.9
[CE1] mpls ldp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] network-entity 10.0000.0000.0000.0002.00
[CE1-isis-2] quit
[CE1-LoopBack0] isis enable 2
[CE1] interface ten-gigabitethernet 3/0/4
[CE1-Ten-GigabitEthernet3/0/4] ip address 10.1.1.2 24
[CE1-Ten-GigabitEthernet3/0/4] isis enable 2
[CE1-Ten-GigabitEthernet3/0/4] mpls enable
[CE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[CE1-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[CE1-Ten-GigabitEthernet3/0/4] quit
# Configure PE 4.
[Sysname] sysname PE4
[PE4] interface loopback 0
[PE4-LoopBack0] ip address 6.6.6.9 32
[PE4-LoopBack0] quit
[PE4] mpls lsr-id 6.6.6.9
[PE4] mpls ldp
[PE4-ldp] quit
[PE4] isis 2
[PE4-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE4-isis-2] quit
[PE4-LoopBack0] isis enable 2
[PE4] interface ten-gigabitethernet 3/0/5
[PE4-Ten-GigabitEthernet3/0/5] ip address 20.1.1.2 24
[PE4-Ten-GigabitEthernet3/0/5] isis enable 2
[PE4-Ten-GigabitEthernet3/0/5] mpls enable
[PE4-Ten-GigabitEthernet3/0/5] mpls ldp enable
[PE4-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE4-Ten-GigabitEthernet3/0/5] quit
# Configure CE 2.
[Sysname] sysname CE2
[CE2] interface loopback 0
[CE2-LoopBack0] ip address 5.5.5.9 32
[CE2-LoopBack0] quit
[CE2] mpls lsr-id 5.5.5.9
[CE2] mpls ldp
[CE2-ldp] quit
[CE2] isis 2
[CE2-isis-2] network-entity 10.0000.0000.0000.0004.00
[CE2-isis-2] quit
[CE2-LoopBack0] isis enable 2
[CE2] interface ten-gigabitethernet 3/0/5
[CE2-Ten-GigabitEthernet3/0/5] ip address 20.1.1.1 24
[CE2-Ten-GigabitEthernet3/0/5] isis enable 2
[CE2-Ten-GigabitEthernet3/0/5] mpls enable
[CE2-Ten-GigabitEthernet3/0/5] mpls ldp enable
[CE2-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[CE2-Ten-GigabitEthernet3/0/5] quit
# Verify that an LDP session and IS-IS neighbor relationship can be established between PE 3 and CE 1 and between PE 4 and CE 2. (Details not shown.)
3. Allow CEs of the customer carrier to access PEs of the provider carrier, and redistribute IS-IS routes to BGP and BGP routes to IS-IS on the PEs:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 200:1
[PE1-vpn-instance-vpn1] quit
[PE1] mpls ldp
[PE1-ldp] vpn-instance vpn1
[PE1-ldp-vpn-instance-vpn1] quit
[PE1-ldp] quit
[PE1] isis 2 vpn-instance vpn1
[PE1-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE1-isis-2] address-family ipv4
[PE1-isis-2-ipv4] import-route bgp
[PE1-isis-2-ipv4] quit
[PE1-isis-2] quit
[PE1] interface ten-gigabitethernet 3/0/4
[PE1-Ten-GigabitEthernet3/0/4] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/4] ip address 11.1.1.2 24
[PE1-Ten-GigabitEthernet3/0/4] isis enable 2
[PE1-Ten-GigabitEthernet3/0/4] mpls enable
[PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[PE1-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[PE1-Ten-GigabitEthernet3/0/4] quit
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] import-route isis 2
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] quit
# Configure CE 1.
[CE1] interface ten-gigabitethernet 3/0/5
[CE1-Ten-GigabitEthernet3/0/5] ip address 11.1.1.1 24
[CE1-Ten-GigabitEthernet3/0/5] isis enable 2
[CE1-Ten-GigabitEthernet3/0/5] mpls enable
[CE1-Ten-GigabitEthernet3/0/5] mpls ldp enable
[CE1-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[CE1-Ten-GigabitEthernet3/0/5] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] quit
[PE2] mpls ldp
[PE2-ldp] vpn-instance vpn1
[PE2-ldp-vpn-instance-vpn1] quit
[PE2-ldp] quit
[PE2] isis 2 vpn-instance vpn1
[PE2-isis-2] network-entity 10.0000.0000.0000.0006.00
[PE2-isis-2] address-family ipv4
[PE2-isis-2-ipv4] import-route bgp
[PE2-isis-2-ipv4] quit
[PE2-isis-2] quit
[PE2-Ten-GigabitEthernet3/0/5] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/5] ip address 21.1.1.1 24
[PE2-Ten-GigabitEthernet3/0/5] isis enable 2
[PE2-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] import-route isis 2
[PE2-bgp-default-vpn1] quit
[PE2-bgp-default] quit
# Configure CE 2.
[CE2] interface ten-gigabitethernet 3/0/4
[CE2-Ten-GigabitEthernet3/0/4] ip address 21.1.1.2 24
[CE2-Ten-GigabitEthernet3/0/4] isis enable 2
[CE2-Ten-GigabitEthernet3/0/4] mpls enable
[CE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
[CE2-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[CE2-Ten-GigabitEthernet3/0/4] quit
# Verify that an LDP session and IS-IS neighbor relationship can be established between PE 1 and CE 1 and between PE 2 and CE 2. (Details not shown.)
4. Connect CEs of the end customers and the PEs of the customer carrier:
# Configure CE 3.
[Sysname] sysname CE3
[CE3] interface ten-gigabitethernet 3/0/1
[CE3-Ten-GigabitEthernet3/0/1] ip address 100.1.1.1 24
[CE3-Ten-GigabitEthernet3/0/1] quit
[CE3] bgp 65410
[CE3-bgp-default] peer 100.1.1.2 as-number 100
[CE3-bgp-default] address-family ipv4 unicast
[CE3-bgp-default-ipv4] peer 100.1.1.2 enable
[CE3-bgp-default-ipv4] import-route direct
[CE3-bgp-default-ipv4] quit
[CE3-bgp-default] quit
# Configure PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 1:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface ten-gigabitethernet 3/0/1
[PE3-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE3-Ten-GigabitEthernet3/0/1] ip address 100.1.1.2 24
[PE3-Ten-GigabitEthernet3/0/1] quit
[PE3] bgp 100
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 100.1.1.1 as-number 65410
[PE3-bgp-default-vpn1] address-family ipv4 unicast
[PE3-bgp-default-ipv4-vpn1] peer 100.1.1.1 enable
[PE3-bgp-default-ipv4-vpn1] quit
[PE3-bgp-default-vpn1] quit
[PE3-bgp-default] quit
# Configure CE 4.
[Sysname] sysname CE4
[CE4] interface ten-gigabitethernet 3/0/1
[CE4-Ten-GigabitEthernet3/0/1] ip address 120.1.1.1 24
[CE4-Ten-GigabitEthernet3/0/1] quit
[CE4] bgp 65420
[CE4-bgp-default] peer 120.1.1.2 as-number 100
[CE4-bgp-default] address-family ipv4 unicast
[CE4-bgp-default-ipv4] peer 120.1.1.2 enable
[CE4-bgp-default-ipv4] import-route direct
[CE4-bgp-default-ipv4] quit
[CE4-bgp-default] quit
# Configure PE 4.
[PE4] ip vpn-instance vpn1
[PE4-vpn-instance-vpn1] route-distinguisher 100:2
[PE4-vpn-instance-vpn1] vpn-target 1:1
[PE4-vpn-instance-vpn1] quit
[PE4] interface ten-gigabitethernet 3/0/1
[PE4-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE4-Ten-GigabitEthernet3/0/1] ip address 120.1.1.2 24
[PE4-Ten-GigabitEthernet3/0/1] quit
[PE4] bgp 100
[PE4-bgp-default] ip vpn-instance vpn1
[PE4-bgp-default-vpn1] peer 120.1.1.1 as-number 65420
[PE4-bgp-default-vpn1] address-family ipv4 unicast
[PE4-bgp-default-ipv4-vpn1] peer 120.1.1.1 enable
[PE4-bgp-default-ipv4-vpn1] quit
[PE4-bgp-default-vpn1] quit
[PE4-bgp-default] quit
5. Configure an MP-IBGP peer relationship between the PEs of the customer carrier to exchange the VPN routes of the end customers:
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 6.6.6.9 as-number 100
[PE3-bgp-default] peer 6.6.6.9 connect-interface loopback 0
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] peer 6.6.6.9 enable
[PE3-bgp-default-vpnv4] quit
# Configure PE 4.
[PE4] bgp 100
[PE4-bgp-default] peer 1.1.1.9 as-number 100
[PE4-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE4-bgp-default] address-family vpnv4
[PE4-bgp-default-vpnv4] peer 1.1.1.9 enable
[PE4-bgp-default-vpnv4] quit
1. Display the public network routing table and VPN routing table on the provider carrier PEs, for example, on PE 1:
# Verify that the public network routing table contains only routes of the provider carrier network.
[PE1] display ip routing-table
Destinations : 9 Routes : 9
3.3.3.9/32 Direct 0 0 127.0.0.1 Loop0
4.4.4.9/32 IS_L1 15 10 30.1.1.2 XGE3/0/5
30.1.1.0/24 Direct 0 0 30.1.1.1 XGE3/0/5
30.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/5
30.1.1.255/32 Direct 0 0 30.1.1.1 XGE3/0/5
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Verify that the VPN routing table contains the internal routes of the customer carrier, but it does not contain the VPN routes that the customer carrier maintains.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 11 Routes : 11
1.1.1.9/32 IS_L1 15 20 11.1.1.1 XGE3/0/4
2.2.2.9/32 IS_L1 15 10 11.1.1.1 XGE3/0/4
5.5.5.9/32 BGP 255 10 4.4.4.9 XGE3/0/5
6.6.6.9/32 BGP 255 20 4.4.4.9 XGE3/0/5
10.1.1.0/24 IS_L1 15 20 11.1.1.1 XGE3/0/4
11.1.1.0/24 Direct 0 0 11.1.1.2 XGE3/0/4
11.1.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/4
11.1.1.255/32 Direct 0 0 11.1.1.2 XGE3/0/4
20.1.1.0/24 BGP 255 20 4.4.4.9 XGE3/0/5
2. Display the routing table on the customer carrier CEs, for example, on CE 1:
# Verify that the routing table contains the internal routes of the customer carrier network, but it does not contain the VPN routes that the customer carrier maintains.
[CE1] display ip routing-table
Destinations : 15 Routes : 15
1.1.1.9/32 IS_L1 15 10 10.1.1.1 XGE3/0/4
2.2.2.9/32 Direct 0 0 127.0.0.1 Loop0
5.5.5.9/32 IS_L2 15 74 11.1.1.2 XGE3/0/5
6.6.6.9/32 IS_L2 15 74 11.1.1.2 XGE3/0/5
10.1.1.0/24 Direct 0 0 10.1.1.2 XGE3/0/4
10.1.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/4
10.1.1.255/32 Direct 0 0 10.1.1.2 XGE3/0/4
11.1.1.0/24 Direct 0 0 11.1.1.1 XGE3/0/5
11.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/5
11.1.1.255/32 Direct 0 0 11.1.1.1 XGE3/0/5
20.1.1.0/24 IS_L2 15 74 11.1.1.2 XGE3/0/5
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
3. Display the public network routing table and VPN routing table on the customer carrier PEs, for example, on PE 3:
# Verify that the public network routing table contains the internal routes of the customer carrier network.
[PE3] display ip routing-table
Destinations : 13 Routes : 13
1.1.1.9/32 Direct 0 0 127.0.0.1 Loop0
2.2.2.9/32 IS_L1 15 10 10.1.1.2 XGE3/0/5
5.5.5.9/32 IS_L2 15 84 10.1.1.2 XGE3/0/5
6.6.6.9/32 IS_L2 15 84 10.1.1.2 XGE3/0/5
10.1.1.0/24 Direct 0 0 10.1.1.1 XGE3/0/5
10.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/5
10.1.1.255/32 Direct 0 0 10.1.1.1 XGE3/0/5
11.1.1.0/24 IS_L1 15 20 10.1.1.2 XGE3/0/5
20.1.1.0/24 IS_L2 15 84 10.1.1.2 XGE3/0/5
# Verify that the VPN routing table contains the route to the remote VPN customer.
Destinations : 6 Routes : 6
100.1.1.0/24 Direct 0 0 100.1.1.2 XGE3/0/1
100.1.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/1
100.1.1.255/32 Direct 0 0 100.1.1.2 XGE3/0/1
120.1.1.0/24 BGP 255 0 6.6.6.9 XGE3/0/5
4. Verify that PE 3 and PE 4 can ping each other. (Details not shown.)
5. Verify that CE 3 and CE 4 can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 1:1 import-extcommunity
isis 1
import-route bgp
mpls lsr-id 3.3.3.9
mpls ldp
vpn-instance vpn1
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
isis enable 1
ip address 11.1.1.2 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
interface Ten-GigabitEthernet3/0/5
ip address 30.1.1.1 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 4.4.4.9 enable
import-route isis 2
return
· PE 2:
sysname PE2
isis 1
import-route bgp
mpls lsr-id 4.4.4.9
mpls ldp
vpn-instance vpn1
interface LoopBack0
isis enable 1
ip address 30.1.1.2 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
ip address 21.1.1.1 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
import-route isis 2
return
· CE 1:
sysname CE1
isis 2
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
isis enable 2
isis enable 2
mpls enable
mpls ldp enable
ip address 11.1.1.1 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
return
· CE 2:
sysname CE2
isis 2
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 2
ip address 21.1.1.2 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
ip address 20.1.1.1 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
return
· PE 3:
sysname PE3
isis 2
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
isis enable 2
interface Ten-GigabitEthernet3/0/1
ip address 100.1.1.2 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 6.6.6.9 connect-interface LoopBack0
peer 6.6.6.9 enable
return
· PE 4:
sysname PE4
isis 2
mpls lsr-id 6.6.6.9
mpls ldp
interface LoopBack0
ip address 6.6.6.9 255.255.255.255
isis enable 2
ip address 120.1.1.2 255.255.255.0
ip address 20.1.1.2 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
return
· CE 3:
sysname CE3
ip address 100.1.1.1 255.255.255.0
bgp 65410
import-route direct
return
· CE 4:
sysname CE4
ip address 120.1.1.1 255.255.255.0
bgp 65420
import-route direct
return
Example: Configuring MPLS L3VPN carrier's carrier in different ASs (exchanging labeled routes in BGP IPv4 unicast address family)
Configure carrier's carrier for the scenario shown in Figure 37. In this scenario:
· The customer carrier and the provider carrier reside in different ASs.
· Exchange of the end customers' VPN routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-EBGP peer relationship must be established between PE 3 and PE 4.
Table 11 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 3 |
XGE3/0/1 |
100.1.1.1/24 |
CE 4 |
XGE3/0/1 |
120.1.1.1/24 |
PE 3 |
Loop0 |
1.1.1.9/32 |
PE 4 |
Loop0 |
6.6.6.9/32 |
XGE3/0/1 |
100.1.1.2/24 |
XGE3/0/1 |
120.1.1.2/24 |
XGE3/0/5 |
10.1.1.1/24 |
XGE3/0/5 |
20.1.1.2/24 |
CE 1 |
Loop0 |
2.2.2.9/32 |
CE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/4 |
10.1.1.2/24 |
XGE3/0/4 |
21.1.1.2/24 |
XGE3/0/5 |
11.1.1.1/24 |
XGE3/0/5 |
20.1.1.1/24 |
PE 1 |
Loop0 |
3.3.3.9/32 |
PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/4 |
11.1.1.2/24 |
XGE3/0/4 |
30.1.1.2/24 |
XGE3/0/5 |
30.1.1.1/24 |
XGE3/0/5 |
21.1.1.1/24 |
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] interface ten-gigabitethernet 3/0/5
[PE1-Ten-GigabitEthernet3/0/5] quit
[PE1] bgp 200
[PE1-bgp-default] peer 4.4.4.9 as-number 200
[PE1-bgp-default-vpnv4] quit
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 200
[PE2-bgp-default-vpnv4] quit
# Configure PE 3.
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] quit
# Configure CE 1.
[CE1] mpls ldp
[CE1-ldp] import bgp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] address-family ipv4
[CE1-isis-2-ipv4] import-route bgp
[CE1-isis-2-ipv4] quit
[CE1-isis-2] quit
# Configure PE 4.
[PE4] mpls ldp
[PE4-ldp] quit
[PE4] isis 2
[PE4-isis-2] quit
# Configure CE 2.
[CE2] mpls ldp
[CE2-ldp] import bgp
[CE2-ldp] quit
[CE2] isis 2
[CE2-isis-2] address-family ipv4
[CE2-isis-2-ipv4] import-route bgp
[CE2-isis-2-ipv4] quit
[CE2-isis-2] quit
3. Allow CEs of the customer carrier to access PEs of the provider carrier:
# Configure PE 1.
[PE1] bgp 200
[PE1-bgp-default-vpn1] peer 11.1.1.1 as-number 100
[PE1-bgp-default-ipv4-vpn1] peer 11.1.1.1 enable
[PE1-bgp-default-ipv4-vpn1] peer 11.1.1.1 label-route-capability
[PE1-bgp-default-ipv4-vpn1] peer 11.1.1.1 route-policy csc export
[PE1] route-policy csc permit node 0
[PE1-route-policy-csc-0] apply mpls-label
[PE1-route-policy-csc-0] quit
# Configure CE 1.
[CE1] bgp 100
[CE1-bgp-default] peer 11.1.1.2 as-number 200
[CE1-bgp-default-ipv4] peer 11.1.1.2 enable
[CE1-bgp-default-ipv4] peer 11.1.1.2 label-route-capability
[CE1-bgp-default-ipv4] peer 11.1.1.2 route-policy csc export
[CE1-bgp-default-ipv4] import-route isis 2
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
[CE1] route-policy csc permit node 0
[CE1-route-policy-csc-0] apply mpls-label
[CE1-route-policy-csc-0] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default-vpn1] peer 21.1.1.2 as-number 300
[PE2-bgp-default-ipv4-vpn1] peer 21.1.1.2 enable
[PE2-bgp-default-ipv4-vpn1] peer 21.1.1.2 label-route-capability
[PE2-bgp-default-ipv4-vpn1] peer 21.1.1.2 route-policy csc export
[PE2] route-policy csc permit node 0
[PE2-route-policy-csc-0] apply mpls-label
[PE2-route-policy-csc-0] quit
# Configure CE 2.
[CE2] bgp 300
[CE2-bgp-default] peer 21.1.1.1 as-number 200
[CE2-bgp-default-ipv4] peer 21.1.1.1 enable
[CE2-bgp-default-ipv4] peer 21.1.1.1 label-route-capability
[CE2-bgp-default-ipv4] peer 21.1.1.1 route-policy csc export
[CE2-bgp-default-ipv4] import-route isis 2
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
[CE2] route-policy csc permit node 0
[CE2-route-policy-csc-0] apply mpls-label
[CE2-route-policy-csc-0] quit
# Verify that PE 1 and CE 1 can establish a BGP session and exchange labeled IPv4 unicast routes through BGP. Repeat this step for PE 2 and CE 2. (Details not shown.)
# Configure CE 3.
[CE3] bgp 65410
# Configure PE 3.
[PE3] bgp 100
# Configure CE 4.
[CE4] bgp 65420
[CE4-bgp-default] peer 120.1.1.2 as-number 300
# Configure PE 4.
[PE4] bgp 300
5. Configure an MP-EBGP peer relationship between the PEs of the customer carrier to exchange the VPN routes of the end customers:
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 6.6.6.9 as-number 300
[PE3-bgp-default] peer 6.6.6.9 ebgp-max-hop 10
# Configure PE 4.
[PE4] bgp 300
[PE4-bgp-default] peer 1.1.1.9 ebgp-max-hop 10
Destinations : 7 Routes : 7
1.1.1.9/32 BGP 255 10 11.1.1.1 XGE3/0/4
6.6.6.9/32 BGP 255 10 4.4.4.9 XGE3/0/5
2. Display the routing table on the customer carrier CEs, for example, on CE 1.
6.6.6.9/32 BGP 255 0 11.1.1.2 XGE3/0/5
Destinations : 10 Routes : 10
6.6.6.9/32 IS_L2 15 74 10.1.1.2 XGE3/0/5
[PE3] display ip routing-table vpn-instance vpn1
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 200
peer 4.4.4.9 enable
apply mpls-label
Return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
mpls enable
bgp 200
peer 3.3.3.9 enable
apply mpls-label
return
· CE 1:
sysname CE1
isis 2
import-route bgp
mpls lsr-id 2.2.2.9
mpls ldp
import bgp
interface LoopBack0
isis enable 2
isis enable 2
mpls enable
mpls ldp enable
mpls enable
bgp 100
import-route isis 2
apply mpls-label
return
· CE 2:
sysname CE2
isis 2
import-route bgp
mpls lsr-id 5.5.5.9
mpls ldp
import bgp
interface LoopBack0
isis enable 2
mpls enable
isis enable 2
mpls enable
mpls ldp enable
bgp 300
import-route isis 2
apply mpls-label
return
· PE 3:
sysname PE3
isis 2
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
isis enable 2
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 6.6.6.9 enable
return
· PE 4:
sysname PE4
isis 2
mpls lsr-id 6.6.6.9
mpls ldp
interface LoopBack0
isis enable 2
isis enable 2
mpls enable
mpls ldp enable
bgp 300
peer 1.1.1.9 enable
return
· CE 3:
sysname CE3
bgp 65410
import-route direct
Return
· CE 4:
sysname CE4
bgp 65420
import-route direct
return
Example: Configuring MPLS L3VPN carrier's carrier in different ASs (exchanging labeled routes in BGP IPv4 labeled unicast address family)
Configure carrier's carrier for the scenario shown in Figure 38. In this scenario:
Table 12 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 3 |
XGE3/0/1 |
100.1.1.1/24 |
CE 4 |
XGE3/0/1 |
120.1.1.1/24 |
PE 3 |
Loop0 |
1.1.1.9/32 |
PE 4 |
Loop0 |
6.6.6.9/32 |
XGE3/0/1 |
100.1.1.2/24 |
XGE3/0/1 |
120.1.1.2/24 |
XGE3/0/5 |
10.1.1.1/24 |
XGE3/0/5 |
20.1.1.2/24 |
CE 1 |
Loop0 |
2.2.2.9/32 |
CE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/4 |
10.1.1.2/24 |
XGE3/0/4 |
21.1.1.2/24 |
XGE3/0/5 |
11.1.1.1/24 |
XGE3/0/5 |
20.1.1.1/24 |
PE 1 |
Loop0 |
3.3.3.9/32 |
PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/4 |
11.1.1.2/24 |
XGE3/0/4 |
30.1.1.2/24 |
XGE3/0/5 |
30.1.1.1/24 |
XGE3/0/5 |
21.1.1.1/24 |
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 200
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 200
# Configure PE 3.
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] quit
# Configure CE 1.
[CE1] mpls ldp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] quit
# Configure PE 4.
[PE4] mpls ldp
[PE4-ldp] quit
[PE4] isis 2
[PE4-isis-2] quit
# Configure CE 2.
[CE2] mpls ldp
[CE2-ldp] quit
[CE2] isis 2
[CE2-isis-2] quit
# Configure PE 1.
[PE1] bgp 200
[PE1-bgp-default-vpn1] address-family ipv4 labeled-unicast
[PE1-bgp-default-labeled-ipv4-vpn1] peer 11.1.1.1 enable
[PE1-bgp-default-labeled-ipv4-vpn1] quit
[PE1-bgp-default-ipv4-vpn1] import-rib vpn-instance vpn1 labeled-unicast
[PE1-bgp-default-labeled-ipv4-vpn1] import-rib vpn-instance vpn1
# Configure CE 1.
[CE1] bgp 100
[CE1-bgp-default] address-family ipv4 labeled-unicast
[CE1-bgp-default-labeled-ipv4] peer 11.1.1.2 enable
[CE1-bgp-default-labeled-ipv4] import-route isis 2
[CE1-bgp-default-labeled-ipv4] quit
[CE1-bgp-default-ipv4] import-rib public labeled-unicast
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default-vpn1] address-family ipv4 labeled-unicast
[PE2-bgp-default-labeled-ipv4-vpn1] peer 21.1.1.2 enable
[PE2-bgp-default-labeled-ipv4-vpn1] quit
[PE2-bgp-default-ipv4-vpn1] import-rib vpn-instance vpn1 labeled-unicast
[PE2-bgp-default-labeled-ipv4-vpn1] import-rib vpn-instance vpn1
[PE2] commit
# Configure CE 2.
[CE2] bgp 300
[CE2-bgp-default] address-family ipv4 labeled-unicast
[CE2-bgp-default-labeled-ipv4] peer 21.1.1.1 enable
[CE2-bgp-default-labeled-ipv4] import-route isis 2
[CE2-bgp-default-labeled-ipv4] quit
[CE2-bgp-default-ipv4] import-rib public labeled-unicast
[CE2] commit
# Verify that PE 1 and CE 1 can establish a BGP session and exchange IPv4 labeled unicast routes through BGP. Repeat this step for PE 2 and CE 2. (Details not shown.)
# Configure CE 3.
[CE3] bgp 65410
# Configure PE 3.
[PE3] bgp 100
# Configure CE 4.
[CE4] bgp 65420
[CE4] commit
# Configure PE 4.
[PE4] bgp 300
# Configure PE 3.
[PE3] bgp 100
# Configure PE 4.
[PE4] bgp 300
[PE4] commit
Destinations : 12 Routes : 12
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
11.1.1.0/32 Direct 0 0 11.1.1.2 XGE3/0/4
11.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
Destinations : 17 Routes : 17
2.2.2.9/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.0/32 Direct 0 0 10.1.1.2 XGE3/0/4
10.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
11.1.1.0/32 Direct 0 0 11.1.1.1 XGE3/0/5
11.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
1.1.1.9/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.0/32 Direct 0 0 10.1.1.1 XGE3/0/5
10.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
100.1.1.0/32 Direct 0 0 100.1.1.2 XGE3/0/1
100.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 200
peer 4.4.4.9 enable
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
mpls enable
bgp 200
peer 3.3.3.9 enable
return
· CE 1:
sysname CE1
isis 2
import-route bgp
mpls lsr-id 2.2.2.9
mpls ldp
import bgp
interface LoopBack0
isis enable 2
isis enable 2
mpls enable
mpls ldp enable
mpls enable
bgp 100
import-route isis 2
return
· CE 2:
sysname CE2
isis 2
import-route bgp
mpls lsr-id 5.5.5.9
mpls ldp
import bgp
interface LoopBack0
isis enable 2
mpls enable
isis enable 2
mpls enable
mpls ldp enable
bgp 300
import-route isis 2
return
· PE 3:
sysname PE3
isis 2
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
isis enable 2
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 6.6.6.9 enable
return
· PE 4:
sysname PE4
isis 2
mpls lsr-id 6.6.6.9
mpls ldp
interface LoopBack0
isis enable 2
isis enable 2
mpls enable
mpls ldp enable
bgp 300
peer 1.1.1.9 enable
return
· CE 3:
sysname CE3
bgp 65410
import-route direct
return
· CE 4:
sysname CE4
bgp 65420
import-route direct
return
Example: Configuring nested VPN
The service provider provides nested VPN services for users, as shown in Figure 39.
· PE 1 and PE 2 are PE devices on the service provider backbone. Both of them support the nested VPN feature.
· CE 1 and CE 2 are provider CEs connected to the service provider backbone. Both of them support VPNv4 routes.
· PE 3 and PE 4 are PE devices of the customer VPN. Both of them support MPLS L3VPN.
· CE 3 through CE 6 are CE devices of sub-VPNs in the customer VPN.
The key of nested VPN configuration is to understand the processing of routes of sub-VPNs on the service provider PEs:
· When receiving a VPNv4 route from a provider CE (CE 1 or CE 2, in this example), a provider PE performs the following operations:
a. Replaces the RD of the VPNv4 route with the RD of the MPLS VPN on the service provider network.
b. Adds the export target attribute of the MPLS VPN on the service provider network to the extended community attribute list.
c. Forwards the VPNv4 route.
· To implement exchange of sub-VPN routes between customer PEs and service provider PEs, MP-EBGP peers must be established between provider PEs and provider CEs.
Table 13 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
Loop0 |
2.2.2.9/32 |
CE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/4 |
10.1.1.2/24 |
XGE3/0/4 |
21.1.1.2/24 |
XGE3/0/5 |
11.1.1.1/24 |
XGE3/0/5 |
20.1.1.1/24 |
CE 3 |
XGE3/0/1 |
100.1.1.1/24 |
CE 4 |
XGE3/0/1 |
120.1.1.1/24 |
CE 5 |
XGE3/0/1 |
110.1.1.1/24 |
CE 6 |
XGE3/0/1 |
130.1.1.1/24 |
PE 1 |
Loop0 |
3.3.3.9/32 |
PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/4 |
11.1.1.2/24 |
XGE3/0/4 |
30.1.1.2/24 |
XGE3/0/5 |
30.1.1.1/24 |
XGE3/0/5 |
21.1.1.1/24 |
PE 3 |
Loop0 |
1.1.1.9/32 |
PE 4 |
Loop0 |
6.6.6.9/32 |
XGE3/0/1 |
100.1.1.2/24 |
XGE3/0/1 |
120.1.1.2/24 |
XGE3/0/2 |
110.1.1.2/24 |
XGE3/0/2 |
130.1.1.2/24 |
XGE3/0/5 |
10.1.1.1/24 |
XGE3/0/5 |
20.1.1.2/24 |
1. Configure MPLS L3VPN on the service provider backbone. Enable IS-IS, enable LDP, and establish an MP-IBGP peer relationship between PE 1 and PE 2:
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] quit
[PE1] bgp 100
# Configure PE 2.
[PE2-LoopBack0] ip address 4.4.4.9 32
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] isis 1
[PE2-isis-1] quit
[PE2] bgp 100
2. Configure the customer VPN. Enable IS-IS, and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2:
# Configure PE 3.
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] quit
# Configure CE 1.
[CE1] mpls ldp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] quit
# Configure PE 4.
[PE4] mpls ldp
[PE4-ldp] quit
[PE4] isis 2
[PE4-isis-2] quit
# Configure CE 2.
[CE2] mpls ldp
[CE2-ldp] quit
[CE2] isis 2
[CE2-isis-2] quit
3. Connect CE 1 and CE 2 to service provider PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 11.1.1.1 as-number 200
# Configure CE 1.
[CE1] bgp 200
[CE1-bgp-default] peer 11.1.1.2 as-number 100
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 200:2
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 21.1.1.2 as-number 200
# Configure CE 2.
[CE2] bgp 200
[CE2-bgp-default] peer 21.1.1.1 as-number 100
4. Connect sub-VPN CEs to the customer VPN PEs:
# Configure CE 3.
[CE3] bgp 65410
[CE3-bgp-default] peer 100.1.1.2 as-number 200
# Configure CE 5.
[Sysname] sysname CE5
[CE5] interface ten-gigabitethernet 3/0/1
[CE5-Ten-GigabitEthernet3/0/1] ip address 110.1.1.1 24
[CE5-Ten-GigabitEthernet3/0/1] quit
[CE5] bgp 65411
[CE5-bgp-default] peer 110.1.1.2 as-number 200
[CE5-bgp-default] address-family ipv4 unicast
[CE5-bgp-default-ipv4] peer 110.1.1.2 enable
[CE5-bgp-default-ipv4] import-route direct
[CE5-bgp-default-ipv4] quit
[CE5-bgp-default] quit
# Configure PE 3.
[PE3] ip vpn-instance SUB_VPN1
[PE3-vpn-instance-SUB_VPN1] route-distinguisher 100:1
[PE3-vpn-instance-SUB_VPN1] vpn-target 2:1
[PE3-vpn-instance-SUB_VPN1] quit
[PE3-Ten-GigabitEthernet3/0/1] ip binding vpn-instance SUB_VPN1
[PE3] ip vpn-instance SUB_VPN2
[PE3-vpn-instance-SUB_VPN2] route-distinguisher 101:1
[PE3-vpn-instance-SUB_VPN2] vpn-target 2:2
[PE3-vpn-instance-SUB_VPN2] quit
[PE3] interface ten-gigabitethernet 3/0/2
[PE3-Ten-GigabitEthernet3/0/2] ip binding vpn-instance SUB_VPN2
[PE3-Ten-GigabitEthernet3/0/2] ip address 110.1.1.2 24
[PE3-Ten-GigabitEthernet3/0/2] quit
[PE3] bgp 200
[PE3-bgp-default] ip vpn-instance SUB_VPN1
[PE3-bgp-default-SUB_VPN1] peer 100.1.1.1 as-number 65410
[PE3-bgp-default-SUB_VPN1] address-family ipv4 unicast
[PE3-bgp-default-ipv4-SUB_VPN1] peer 100.1.1.1 enable
[PE3-bgp-default-ipv4-SUB_VPN1] quit
[PE3-bgp-default-SUB_VPN1] quit
[PE3-bgp-default] ip vpn-instance SUB_VPN2
[PE3-bgp-default-SUB_VPN2] peer 110.1.1.1 as-number 65411
[PE3-bgp-default-SUB_VPN2] address-family ipv4 unicast
[PE3-bgp-default-ipv4-SUB_VPN2] peer 110.1.1.1 enable
[PE3-bgp-default-ipv4-SUB_VPN2] quit
[PE3-bgp-default-SUB_VPN2] quit
# Configure CE 4.
[CE4] bgp 65420
[CE4-bgp-default] peer 120.1.1.2 as-number 200
# Configure CE 6.
[Sysname] sysname CE6
[CE6] interface ten-gigabitethernet 3/0/1
[CE6-Ten-GigabitEthernet3/0/1] ip address 130.1.1.1 24
[CE6-Ten-GigabitEthernet3/0/1] quit
[CE6] bgp 65421
[CE6-bgp-default] peer 130.1.1.2 as-number 200
[CE6-bgp-default] address-family ipv4 unicast
[CE6-bgp-default-ipv4] peer 130.1.1.2 enable
[CE6-bgp-default-ipv4] import-route direct
[CE6-bgp-default-ipv4] quit
[CE6-bgp-default] quit
# Configure PE 4.
[PE4] ip vpn-instance SUB_VPN1
[PE4-vpn-instance-SUB_VPN1] route-distinguisher 100:2
[PE4-vpn-instance-SUB_VPN1] vpn-target 2:1
[PE4-vpn-instance-SUB_VPN1] quit
[PE4-Ten-GigabitEthernet3/0/1] ip binding vpn-instance SUB_VPN1
[PE4] ip vpn-instance SUB_VPN2
[PE4-vpn-instance-SUB_VPN2] route-distinguisher 101:2
[PE4-vpn-instance-SUB_VPN2] vpn-target 2:2
[PE4-vpn-instance-SUB_VPN2] quit
[PE4] interface ten-gigabitethernet 3/0/2
[PE4-Ten-GigabitEthernet3/0/2] ip binding vpn-instance SUB_VPN2
[PE4-Ten-GigabitEthernet3/0/2] ip address 130.1.1.2 24
[PE4-Ten-GigabitEthernet3/0/2] quit
[PE4] bgp 200
[PE4-bgp-default] ip vpn-instance SUB_VPN1
[PE4-bgp-default-SUB_VPN1] peer 120.1.1.1 as-number 65420
[PE4-bgp-default-SUB_VPN1] address-family ipv4 unicast
[PE4-bgp-default-ipv4-SUB_VPN1] peer 120.1.1.1 enable
[PE4-bgp-default-ipv4-SUB_VPN1] quit
[PE4-bgp-default-SUB_VPN1] quit
[PE4-bgp-default] ip vpn-instance SUB_VPN2
[PE4-bgp-default-SUB_VPN2] peer 130.1.1.1 as-number 65421
[PE4-bgp-default-SUB_VPN2] address-family ipv4 unicast
[PE4-bgp-default-ipv4-SUB_VPN2] peer 130.1.1.1 enable
[PE4-bgp-default-ipv4-SUB_VPN2] quit
[PE4-bgp-default-SUB_VPN2] quit
5. Establish MP-EBGP peer relationship between service provider PEs and their CEs to exchange user VPNv4 routes:
# On PE 1, enable nested VPN, and enable VPNv4 route exchange with CE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] nesting-vpn
[PE1-bgp-default-vpn1] address-family vpnv4
[PE1-bgp-default-vpnv4-vpn1] peer 11.1.1.1 enable
[PE1-bgp-default-vpnv4-vpn1] quit
# On CE 1, enable VPNv4 route exchange with PE 1.
[CE1] bgp 200
[CE1-bgp-default] address-family vpnv4
[CE1-bgp-default-vpnv4] peer 11.1.1.2 enable
# Configure CE 1 to allow the local AS number to appear in the AS-PATH attribute of the routes received.
[CE1-bgp-default-vpnv4] peer 11.1.1.2 allow-as-loop 2
# On CE 1, disable route target based filtering of received VPNv4 routes.
[CE1-bgp-default-vpnv4] undo policy vpn-target
[CE1-bgp-default-vpnv4] quit
# On PE 2, enable nested VPN, and enable VPNv4 route exchange with CE 2.
[PE2] bgp 100
[PE2-bgp-default-vpnv4] nesting-vpn
[PE2-bgp-default-vpn1] address-family vpnv4
[PE2-bgp-default-vpnv4-vpn1] peer 21.1.1.2 enable
[PE2-bgp-default-vpnv4-vpn1] quit
# On CE 2, enable VPNv4 route exchange with PE 2.
[CE2] bgp 200
[CE2-bgp-default] address-family vpnv4
[CE2-bgp-default-vpnv4] peer 21.1.1.1 enable
# Configure CE 2 to allow the local AS number to appear in the AS-PATH attribute of the routes received.
[CE2-bgp-default-vpnv4] peer 21.1.1.1 allow-as-loop 2
# On CE 2, disable route target based filtering of incoming VPNv4 routes.
[CE2-bgp-default-vpnv4] undo policy vpn-target
[CE2-bgp-default-vpnv4] quit
6. Establish MP-IBGP peer relationships between sub-VPN PEs and CEs of the customer VPN to exchange VPNv4 routes of sub-VPNs:
# Configure PE 3.
[PE3] bgp 200
[PE3-bgp-default] peer 2.2.2.9 as-number 200
[PE3-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE3-bgp-default-vpnv4] peer 2.2.2.9 enable
# Configure PE 3 to allow the local AS number to appear in the AS-PATH attribute of the routes received.
[PE3-bgp-default-vpnv4] peer 2.2.2.9 allow-as-loop 2
# Configure CE 1.
[CE1] bgp 200
[CE1-bgp-default] peer 1.1.1.9 as-number 200
[CE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[CE1-bgp-default-vpnv4] peer 1.1.1.9 enable
# Configure PE 4.
[PE4] bgp 200
[PE4-bgp-default] peer 5.5.5.9 as-number 200
[PE4-bgp-default] peer 5.5.5.9 connect-interface loopback 0
[PE4-bgp-default-vpnv4] peer 5.5.5.9 enable
# Configure PE 4 to allow the local AS number to appear in the AS-PATH attribute of the routes received.
[PE4-bgp-default-vpnv4] peer 5.5.5.9 allow-as-loop 2
# Configure CE 2.
[CE2] bgp 200
[CE2-bgp-default] peer 6.6.6.9 as-number 200
[CE2-bgp-default] peer 6.6.6.9 connect-interface loopback 0
[CE2-bgp-default-vpnv4] peer 6.6.6.9 enable
1. Display the public routing table and VPN routing table on the provider PEs, for example, on PE 1:
# Verify that the public routing table contains only routes on the service provider network.
# Verify that the VPN routing table contains sub-VPN routes.
100.1.1.0/24 BGP 255 0 11.1.1.1 XGE3/0/4
110.1.1.0/24 BGP 255 0 11.1.1.1 XGE3/0/4
120.1.1.0/24 BGP 255 0 4.4.4.9 XGE3/0/5
130.1.1.0/24 BGP 255 0 4.4.4.9 XGE3/0/5
2. Display the VPNv4 routing table on the provider CEs, for example, on CE 1.
# Verify that the VPNv4 routing table on the customer VPN contains internal sub-VPN routes.
[CE1] display bgp routing-table vpnv4
BGP local router ID is 2.2.2.9
a - additional-path
Total number of VPN routes: 4
Total number of routes from all PEs: 4
Route distinguisher: 100:1
Total number of routes: 1
* >i 100.1.1.0/24 1.1.1.9 0 100 0 65410?
Route distinguisher: 101:1
* >i 110.1.1.0/24 1.1.1.9 0 100 0 65411?
Route distinguisher: 200:2
Total number of routes: 2
* >e 120.1.1.0/24 11.1.1.2 0 100 200 65420?
* >e 130.1.1.0/24 11.1.1.2 0 100 200 65421?
3. Display the VPN routing table on the customer PEs, for example, on PE 3:
# Verify that the VPN routing table contains routes sent by the provider PE to the sub-VPN.
[PE3] display ip routing-table vpn-instance SUB_VPN1
120.1.1.0/24 BGP 255 0 2.2.2.9 XGE3/0/5
4. Display the routing table on the CEs of sub-VPNs in the customer VPN, for example, on CE 3 and CE 5:
# Verify that the routing table contains the route to the remote sub-VPN on CE 3.
[CE3] display ip routing-table
Destinations : 8 Routes : 8
100.1.1.0/24 Direct 0 0 100.1.1.1 XGE3/0/1
100.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/1
100.1.1.255/32 Direct 0 0 100.1.1.1 XGE3/0/1
120.1.1.0/24 BGP 255 0 100.1.1.2 XGE3/0/1
# Verify that the routing table contains the route to the remote sub-VPN on CE 5.
[CE5] display ip routing-table
110.1.1.0/24 Direct 0 0 110.1.1.1 XGE3/0/1
110.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/1
110.1.1.255/32 Direct 0 0 110.1.1.1 XGE3/0/1
130.1.1.0/24 BGP 255 0 110.1.1.2 XGE3/0/1
6. Verify that CE 5 and CE 6 can ping each other. (Details not shown.)
7. Verify that CE 3 and CE 6 cannot ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 1:1 export-extcommunity
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 4.4.4.9 connect-interface LoopBack0
nesting-vpn
peer 4.4.4.9 enable
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
ip address 4.4.4.9 255.255.255.255
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
mpls enable
bgp 100
nesting-vpn
peer 3.3.3.9 enable
return
· CE 1:
sysname CE1
isis 2
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 2
isis enable 2
mpls enable
mpls ldp enable
mpls enable
bgp 200
peer 1.1.1.9 enable
return
· CE 2:
sysname CE2
isis 2
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 2
mpls enable
isis enable 2
mpls enable
mpls ldp enable
bgp 200
peer 6.6.6.9 enable
return
· PE 3:
sysname PE3
vpn-target 2:1 import-extcommunity
vpn-target 2:1 export-extcommunity
vpn-target 2:2 import-extcommunity
vpn-target 2:2 export-extcommunity
isis 2
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
isis enable 2
interface Ten-GigabitEthernet3/0/2
ip address 110.1.1.2 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
bgp 200
peer 2.2.2.9 connect-interface LoopBack0
peer 2.2.2.9 enable
return
· PE 4:
sysname PE4
isis 2
mpls lsr-id 6.6.6.9
mpls ldp
interface LoopBack0
isis enable 2
ip address 130.1.1.2 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
bgp 200
peer 5.5.5.9 enable
return
· CE 3:
sysname CE3
bgp 65410
import-route direct
return
· CE 4:
sysname CE4
bgp 65420
import-route direct
return
· CE 5:
sysname CE5
ip address 110.1.1.1 255.255.255.0
bgp 65411
import-route direct
return
· CE 6:
sysname CE6
ip address 130.1.1.1 255.255.255.0
bgp 65421
import-route direct
return
Example: Configuring multirole host
Configure the multirole host feature to allow Host A to access VPN 1 and VPN 2 and Host B to access only VPN 1.
Figure 40 Network diagram
1. Configure CE 1:
# Assign IP addresses to interfaces.
[CE1] interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ip address 100.1.1.1 24
[CE1-Ten-GigabitEthernet3/0/1] quit
[CE1-Ten-GigabitEthernet3/0/5] ip address 1.1.1.2 24
# Configure a default route to PE 1.
[CE1] ip route-static 0.0.0.0 0 1.1.1.1
2. Configure PE 1:
# Configure an IGP on the MPLS backbone to enable public network connectivity between backbone PEs.
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-Ten-GigabitEthernet3/0/5] ip address 2.1.1.1 24
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 2.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/5] mpls enable
[PE1-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Establish an MP-IBGP peer relationships with PE 2.
[PE1] bgp 100
# Create VPN instances vpn1 and vpn2 for VPN 1 and VPN 2, respectively, and configure different RDs and route targets for the VPN instances.
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 100:1 both
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 100:2 both
[PE1-vpn-instance-vpn2] quit
# Associate VPN instance vpn1 with Ten-GigabitEthernet 3/0/4 (the interface connected to CE 1).
[PE1-Ten-GigabitEthernet3/0/4] ip address 1.1.1.1 255.255.255.0
# Configure a static route for VPN 2 to reach Host A and redistribute the route to BGP. This configuration ensures that packets from VPN 2 to Host A can be forwarded through the correct route in the routing table of VPN instance vpn1.
[PE1] ip route-static vpn-instance vpn2 100.1.1.0 24 vpn-instance vpn1 1.1.1.2
[PE1] bgp 100
[PE1-bgp-default] ip vpn-instance vpn2
[PE1-bgp-default-vpn2] address-family ipv4
[PE1-bgp-default-ipv4-vpn2] import-route static
[PE1-bgp-default-ipv4-vpn2] quit
[PE1-bgp-default-vpn2] quit
# Configure PBR to route packets from Host A according to the routing tables of both VPN instances vpn1 and vpn2.
[PE1] acl advanced 3001
[PE1-acl-ipv4-adv-3001] rule 0 permit ip vpn-instance vpn1 source 100.1.1.2 0
[PE1-acl-ipv4-adv-3001] quit
[PE1] policy-based-route policy1 permit node 10
[PE1-policy-based-route] if-match acl 3001
[PE1-policy-based-route] apply access-vpn vpn-instance vpn1 vpn2
[PE1-policy-based-route] quit
# Apply policy policy1 to Ten-GigabitEthernet 3/0/4.
[PE1-Ten-GigabitEthernet3/0/4] ip policy-based-route policy1
3. Configure PE 2:
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2] interface ten-gigabitethernet 3/0/5
[PE2-Ten-GigabitEthernet3/0/5] ip address 2.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/5] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/5] mpls enable
[PE2-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Establish an MP-IBGP peer relationship with PE 1.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 1.1.1.9 enable
# Create VPN instances vpn2 and configure an RD and route target for the VPN instance.
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 100:3
[PE2-vpn-instance-vpn2] vpn-target 100:2 both
[PE2-vpn-instance-vpn2] quit
# Associate VPN instance vpn2 with the interface connected to CE 2.
[PE2-Ten-GigabitEthernet3/0/4] ip binding vpn-instance vpn2
[PE2-Ten-GigabitEthernet3/0/4] ip address 3.1.1.2 255.255.255.0
# Establish an EBGP peer relationship with CE 2.
[PE2] bgp 100
[PE2-bgp-default] ip vpn-instance vpn2
[PE2-bgp-default-vpn2] peer 3.1.1.1 as-number 65420
[PE2-bgp-default-vpn2] address-family ipv4 unicast
[PE2-bgp-default-ipv4-vpn2] peer 3.1.1.1 enable
[PE2-bgp-default-ipv4-vpn2] quit
[PE2-bgp-default-vpn2] quit
4. Configure CE 2:
# Assign IP addresses to interfaces on CE 2.
[CE2] interface ten-gigabitethernet 3/0/1
[CE2-Ten-GigabitEthernet3/0/1] ip address 110.2.1.1 24
[CE2-Ten-GigabitEthernet3/0/1] quit
[CE2-Ten-GigabitEthernet3/0/5] ip address 3.1.1.1 24
# Establish an EBGP peer relationship with PE 2 and redistribute VPN routes.
[CE2] bgp 65420
[CE2-bgp-default] peer 3.1.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 3.1.1.2 enable
[CE2-bgp-default-ipv4] import-route direct
5. Configure the hosts:
Assign IP addresses to Host A, Host B, and Host C. Specify the default gateway address as 100.1.1.1 on Host A and Host B, and set the default gateway address to 110.2.1.1 on Host C.
# On PE 1, display the routing tables of VPN instances vpn1 and vpn2. Verify the following information:
· PE 1 has learned the route to the remote site's subnet 110.2.1.0/24.
· The next hop for the route to the local site's subnet 100.1.1.0/24 is CE 1 (at 1.1.1.2) in VPN instance vpn1.
[PE1] display ip routing-table vpn-instance vpn2
Destinations : 5 Routes : 5
3.1.1.0/24 BGP 255 0 3.3.3.9 XGE3/0/5
100.1.1.0/24 Static 60 0 1.1.1.2 XGE3/0/4
110.2.1.0/24 BGP 255 0 3.3.3.9 XGE3/0/5
1.1.1.0/24 Direct 0 0 1.1.1.1 XGE3/0/4
1.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/4
1.1.1.255/32 Direct 0 0 1.1.1.1 XGE3/0/4
# Verify that Host A can ping Host C, and that Host B cannot ping Host C. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 100:1 import-extcommunity
vpn-target 100:1 export-extcommunity
vpn-target 100:2 import-extcommunity
vpn-target 100:2 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
if-match acl 3001
apply access-vpn vpn-instance vpn2
mpls ldp
interface LoopBack0
interface Ten-GigabitEthernet3/0/4
ip address 2.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 enable
import-route static
acl advanced 3001
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 2.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 3.1.1.1 enable
return
· CE 1:
sysname CE1
ip address 1.1.1.2 255.255.255.0
return
· CE 2:
sysname CE2
ip address 110.2.1.1 255.255.255.0
ip address 3.1.1.1 255.255.255.0
bgp 65420
import-route direct
peer 3.1.1.2 enable
return
Example: Configuring HoVPN
As shown in Figure 41, there are two levels of networks: the backbone and the MPLS VPN networks.
· SPEs act as PEs to allow MPLS VPNs to access the backbone.
· UPEs act as PEs of the MPLS VPNs to allow end users to access the VPNs.
· Performance requirements for the UPEs are lower than those for the SPEs.
· SPEs advertise routes permitted by routing policies to UPEs, permitting CE 1 and CE 3 in VPN 1 to communicate with each other and forbidding CE 2 and CE 4 in VPN 2 from communicating with each other.
Table 14 Interface and IP address assignment
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
10.2.1.1/24 |
CE 3 |
XGE3/0/1 |
10.1.1.1/24 |
CE 2 |
XGE3/0/1 |
10.4.1.1/24 |
CE 4 |
XGE3/0/1 |
10.3.1.1/24 |
UPE 1 |
Loop0 |
1.1.1.9/32 |
UPE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
10.2.1.2/24 |
XGE3/0/1 |
172.2.1.1/24 |
XGE3/0/2 |
10.4.1.2/24 |
XGE3/0/2 |
10.1.1.2/24 |
XGE3/0/3 |
172.1.1.1/24 |
XGE3/0/3 |
10.3.1.2/24 |
SPE 1 |
Loop0 |
2.2.2.9/32 |
SPE 2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/1 |
172.1.1.2/24 |
XGE3/0/1 |
180.1.1.2/24 |
XGE3/0/2 |
180.1.1.1/24 |
XGE3/0/2 |
172.2.1.2/24 |
1. Configure UPE 1:
# Configure basic MPLS and MPLS LDP to establish LDP LSPs.
[Sysname] sysname UPE1
[UPE1] interface loopback 0
[UPE1-LoopBack0] ip address 1.1.1.9 32
[UPE1-LoopBack0] quit
[UPE1] mpls lsr-id 1.1.1.9
[UPE1] mpls ldp
[UPE1-ldp] quit
[UPE1] interface ten-gigabitethernet 3/0/3
[UPE1-Ten-GigabitEthernet3/0/3] ip address 172.1.1.1 24
[UPE1-Ten-GigabitEthernet3/0/3] mpls enable
[UPE1-Ten-GigabitEthernet3/0/3] mpls ldp enable
[UPE1-Ten-GigabitEthernet3/0/3] quit
# Configure the IGP protocol (OSPF, in this example).
[UPE1] ospf
[UPE1-ospf-1] area 0
[UPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[UPE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[UPE1-ospf-1-area-0.0.0.0] quit
[UPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 1 and CE 2 to access UPE 1.
[UPE1] ip vpn-instance vpn1
[UPE1-vpn-instance-vpn1] route-distinguisher 100:1
[UPE1-vpn-instance-vpn1] vpn-target 100:1 both
[UPE1-vpn-instance-vpn1] quit
[UPE1] ip vpn-instance vpn2
[UPE1-vpn-instance-vpn2] route-distinguisher 100:2
[UPE1-vpn-instance-vpn2] vpn-target 100:2 both
[UPE1-vpn-instance-vpn2] quit
[UPE1] interface ten-gigabitethernet 3/0/1
[UPE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[UPE1-Ten-GigabitEthernet3/0/1] ip address 10.2.1.2 24
[UPE1-Ten-GigabitEthernet3/0/1] quit
[UPE1] interface ten-gigabitethernet 3/0/2
[UPE1-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn2
[UPE1-Ten-GigabitEthernet3/0/2] ip address 10.4.1.2 24
[UPE1-Ten-GigabitEthernet3/0/2] quit
# Establish an MP-IBGP peer relationship with SPE 1.
[UPE1] bgp 100
[UPE1-bgp-default] peer 2.2.2.9 as-number 100
[UPE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[UPE1-bgp-default] address-family vpnv4
[UPE1-bgp-default-vpnv4] peer 2.2.2.9 enable
[UPE1-bgp-default-vpnv4] quit
# Establish an EBGP peer relationship with CE 1.
[UPE1-bgp-default] ip vpn-instance vpn1
[UPE1-bgp-default-vpn1] peer 10.2.1.1 as-number 65410
[UPE1-bgp-default-vpn1] address-family ipv4 unicast
[UPE1-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
[UPE1-bgp-default-ipv4-vpn1] quit
[UPE1-bgp-default-vpn1] quit
[UPE1-bgp-default] ip vpn-instance vpn2
[UPE1-bgp-default-vpn2] peer 10.4.1.1 as-number 65420
[UPE1-bgp-default-vpn2] address-family ipv4 unicast
[UPE1-bgp-default-ipv4-vpn2] peer 10.4.1.1 enable
[UPE1-bgp-default-ipv4-vpn2] quit
[UPE1-bgp-default-vpn2] quit
[UPE1-bgp-default] quit
2. Configure CE 1.
[CE1-Ten-GigabitEthernet3/0/1] ip address 10.2.1.1 255.255.255.0
[CE1] bgp 65410
[CE1-bgp-default] peer 10.2.1.2 as-number 100
[CE1-bgp-default-ipv4] peer 10.2.1.2 enable
3. Configure CE 2.
[CE2-Ten-GigabitEthernet3/0/1] ip address 10.4.1.1 255.255.255.0
[CE2] bgp 65420
[CE2-bgp-default] peer 10.4.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 10.4.1.2 enable
4. Configure UPE 2:
[Sysname] sysname UPE2
[UPE2] interface loopback 0
[UPE2-LoopBack0] ip address 4.4.4.9 32
[UPE2-LoopBack0] quit
[UPE2] mpls lsr-id 4.4.4.9
[UPE2] mpls ldp
[UPE2-ldp] quit
[UPE2] interface ten-gigabitethernet 3/0/1
[UPE2-Ten-GigabitEthernet3/0/1] ip address 172.2.1.1 24
[UPE2-Ten-GigabitEthernet3/0/1] mpls enable
[UPE2-Ten-GigabitEthernet3/0/1] mpls ldp enable
[UPE2-Ten-GigabitEthernet3/0/1] quit
[UPE2] ospf
[UPE2-ospf-1] area 0
[UPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[UPE2-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[UPE2-ospf-1-area-0.0.0.0] quit
[UPE2-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 3 and CE 4 to access UPE 2.
[UPE2] ip vpn-instance vpn1
[UPE2-vpn-instance-vpn1] route-distinguisher 300:1
[UPE2-vpn-instance-vpn1] vpn-target 100:1 both
[UPE2-vpn-instance-vpn1] quit
[UPE2] ip vpn-instance vpn2
[UPE2-vpn-instance-vpn2] route-distinguisher 400:2
[UPE2-vpn-instance-vpn2] vpn-target 100:2 both
[UPE2-vpn-instance-vpn2] quit
[UPE2] interface ten-gigabitethernet 3/0/2
[UPE2-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn1
[UPE2-Ten-GigabitEthernet3/0/2] ip address 10.1.1.2 24
[UPE2-Ten-GigabitEthernet3/0/2] quit
[UPE2] interface ten-gigabitethernet 3/0/3
[UPE2-Ten-GigabitEthernet3/0/3] ip binding vpn-instance vpn2
[UPE2-Ten-GigabitEthernet3/0/3] ip address 10.3.1.2 24
[UPE2-Ten-GigabitEthernet3/0/3] quit
# Establish an MP-IBGP peer relationship with SPE 2.
[UPE2] bgp 100
[UPE2-bgp-default] peer 3.3.3.9 as-number 100
[UPE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[UPE2-bgp-default] address-family vpnv4
[UPE2-bgp-default-vpnv4] peer 3.3.3.9 enable
[UPE2-bgp-default-vpnv4] quit
# Establish an EBGP peer relationship with CE 3.
[UPE2-bgp-default] ip vpn-instance vpn1
[UPE2-bgp-default-vpn1] peer 10.1.1.1 as-number 65430
[UPE2-bgp-default-vpn1] address-family ipv4 unicast
[UPE2-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[UPE2-bgp-default-ipv4-vpn1] quit
[UPE2-bgp-default-vpn1] quit
# Establish an EBGP peer relationship with CE 4.
[UPE2-bgp-default] ip vpn-instance vpn2
[UPE2-bgp-default-vpn2] peer 10.3.1.1 as-number 65440
[UPE2-bgp-default-vpn2] address-family ipv4 unicast
[UPE2-bgp-default-ipv4-vpn2] peer 10.3.1.1 enable
[UPE2-bgp-default-ipv4-vpn2] quit
[UPE2-bgp-default-vpn2] quit
[UPE2-bgp-default] quit
5. Configure CE 3.
[CE3-Ten-GigabitEthernet3/0/1] ip address 10.1.1.1 255.255.255.0
[CE3] bgp 65430
[CE3-bgp-default] peer 10.1.1.2 as-number 100
[CE3-bgp-default-ipv4] peer 10.1.1.2 enable
6. Configure CE 4.
[CE4-Ten-GigabitEthernet3/0/1] ip address 10.3.1.1 255.255.255.0
[CE4] bgp 65440
[CE4-bgp-default] peer 10.3.1.2 as-number 100
[CE4-bgp-default-ipv4] peer 10.3.1.2 enable
7. Configure SPE 1:
[Sysname] sysname SPE1
[SPE1] interface loopback 0
[SPE1-LoopBack0] ip address 2.2.2.9 32
[SPE1-LoopBack0] quit
[SPE1] mpls lsr-id 2.2.2.9
[SPE1] mpls ldp
[SPE1-ldp] quit
[SPE1] interface ten-gigabitethernet 3/0/1
[SPE1-Ten-GigabitEthernet3/0/1] ip address 172.1.1.2 24
[SPE1-Ten-GigabitEthernet3/0/1] mpls enable
[SPE1-Ten-GigabitEthernet3/0/1] mpls ldp enable
[SPE1-Ten-GigabitEthernet3/0/1] quit
[SPE1] interface ten-gigabitethernet 3/0/2
[SPE1-Ten-GigabitEthernet3/0/2] ip address 180.1.1.1 24
[SPE1-Ten-GigabitEthernet3/0/2] mpls enable
[SPE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
[SPE1-Ten-GigabitEthernet3/0/2] quit
# Configure the IGP protocol, OSPF, in this example.
[SPE1] ospf
[SPE1-ospf-1] area 0
[SPE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[SPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] quit
[SPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2.
[SPE1] ip vpn-instance vpn1
[SPE1-vpn-instance-vpn1] route-distinguisher 500:1
[SPE1-vpn-instance-vpn1] vpn-target 100:1 both
[SPE1-vpn-instance-vpn1] quit
[SPE1] ip vpn-instance vpn2
[SPE1-vpn-instance-vpn2] route-distinguisher 700:1
[SPE1-vpn-instance-vpn2] vpn-target 100:2 both
[SPE1-vpn-instance-vpn2] quit
# Establish MP-IBGP peer relationships with SPE 2 and UPE 1, and specify UPE 1 as a UPE.
[SPE1] bgp 100
[SPE1-bgp-default] peer 1.1.1.9 as-number 100
[SPE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[SPE1-bgp-default] peer 3.3.3.9 as-number 100
[SPE1-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[SPE1-bgp-default] address-family vpnv4
[SPE1-bgp-default-vpnv4] peer 3.3.3.9 enable
[SPE1-bgp-default-vpnv4] peer 1.1.1.9 enable
[SPE1-bgp-default-vpnv4] peer 1.1.1.9 upe
[SPE1-bgp-default-vpnv4] peer 1.1.1.9 next-hop-local
[SPE1-bgp-default-vpnv4] quit
# Create BGP-VPN instances for VPN instances vpn1 and vpn2, so the VPNv4 routes learned according to the RT attributes can be added into the BGP routing tables of the corresponding VPN instances.
[SPE1-bgp-default] ip vpn-instance vpn1
[SPE1-bgp-default-vpn1] quit
[SPE1-bgp-default] ip vpn-instance vpn2
[SPE1-bgp-default-vpn2] quit
[SPE1-bgp-default] quit
# Advertise to UPE 1 the routes permitted by a routing policy (the routes of CE 3).
[SPE1] ip prefix-list hope index 10 permit 10.1.1.1 24
[SPE1] route-policy hope permit node 0
[SPE1-route-policy-hope-0] if-match ip address prefix-list hope
[SPE1-route-policy-hope-0] quit
[SPE1] bgp 100
[SPE1-bgp-default-vpnv4] peer 1.1.1.9 upe route-policy hope export
8. Configure SPE 2:
[Sysname] sysname SPE2
[SPE2] interface loopback 0
[SPE2-LoopBack0] ip address 3.3.3.9 32
[SPE2-LoopBack0] quit
[SPE2] mpls lsr-id 3.3.3.9
[SPE2] mpls ldp
[SPE2-ldp] quit
[SPE2] interface ten-gigabitethernet 3/0/1
[SPE2-Ten-GigabitEthernet3/0/1] ip address 180.1.1.2 24
[SPE2-Ten-GigabitEthernet3/0/1] mpls enable
[SPE2-Ten-GigabitEthernet3/0/1] mpls ldp enable
[SPE2-Ten-GigabitEthernet3/0/1] quit
[SPE2] interface ten-gigabitethernet 3/0/2
[SPE2-Ten-GigabitEthernet3/0/2] ip address 172.2.1.2 24
[SPE2-Ten-GigabitEthernet3/0/2] mpls enable
[SPE2-Ten-GigabitEthernet3/0/2] mpls ldp enable
[SPE2-Ten-GigabitEthernet3/0/2] quit
[SPE2] ospf
[SPE2-ospf-1] area 0
[SPE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[SPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] quit
[SPE2-ospf-1] quit
[SPE2] ip vpn-instance vpn1
[SPE2-vpn-instance-vpn1] route-distinguisher 600:1
[SPE2-vpn-instance-vpn1] vpn-target 100:1 both
[SPE2-vpn-instance-vpn1] quit
[SPE2] ip vpn-instance vpn2
[SPE2-vpn-instance-vpn2] route-distinguisher 800:1
[SPE2-vpn-instance-vpn2] vpn-target 100:2 both
[SPE2-vpn-instance-vpn2] quit
# Establish MP-IBGP peer relationships with SPE 1 and UPE 2, and specify UPE 2 as a UPE.
[SPE2] bgp 100
[SPE2-bgp-default] peer 4.4.4.9 as-number 100
[SPE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[SPE2-bgp-default] peer 2.2.2.9 as-number 100
[SPE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[SPE2-bgp-default] address-family vpnv4
[SPE2-bgp-default-vpnv4] peer 2.2.2.9 enable
[SPE2-bgp-default-vpnv4] peer 4.4.4.9 enable
[SPE2-bgp-default-vpnv4] peer 4.4.4.9 upe
[SPE2-bgp-default-vpnv4] peer 4.4.4.9 next-hop-local
[SPE2-bgp-default-vpnv4] quit
[SPE2-bgp-default] ip vpn-instance vpn1
[SPE2-bgp-default-vpn1] quit
[SPE2-bgp-default] ip vpn-instance vpn2
[SPE2-bgp-default-vpn2] quit
[SPE2-bgp-default] quit
# Advertise to UPE 2 the routes permitted by a routing policy (the routes of CE 1).
[SPE2] ip prefix-list hope index 10 permit 10.2.1.1 24
[SPE2] route-policy hope permit node 0
[SPE2-route-policy-hope-0] if-match ip address prefix-list hope
[SPE2-route-policy-hope-0] quit
[SPE2] bgp 100
[SPE2-bgp-default-vpnv4] peer 4.4.4.9 upe route-policy hope export
# Verify that CE 1 and CE3 can learn each other's interface routes and can ping each other. CE 2 and CE 4 cannot learn each other's interface routes and cannot ping each other. (Details not shown.)
Configuration files
· SPE 1:
sysname SPE1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 172.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 180.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 1.1.1.9 upe
peer 3.3.3.9 enable
ip prefix-list hope index 10 permit 10.1.1.0 24
return
· SPE 2:
sysname SPE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 180.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 172.2.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
peer 4.4.4.9 enable
peer 4.4.4.9 upe
ip prefix-list hope index 10 permit 10.2.1.0 24
return
· UPE 1:
sysname UPE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
ip address 10.2.1.2 255.255.255.0
ip address 10.4.1.2 255.255.255.0
interface Ten-GigabitEthernet3/0/3
ip address 172.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
return
· UPE 2:
sysname UPE2
ospf 1
area 0.0.0.0
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
ip address 172.2.1.1 255.255.255.0
mpls enable
mpls ldp enable
ip address 10.3.1.2 255.255.255.0
bgp 100
peer 3.3.3.9 enable
return
· CE 1:
sysname CE1
bgp 65410
import-route direct
return
· CE 2:
sysname CE2
bgp 65420
import-route direct
return
· CE 3:
sysname CE3
bgp 65430
import-route direct
return
· CE 4:
sysname CE4
bgp 65440
import-route direct
return
Example: Configuring an OSPF sham link
As shown in Figure 42, CE 1 and CE 2 belong to VPN 1. Configure an OSPF sham link between PE 1 and PE 2 so traffic between the CEs is forwarded through the MPLS backbone instead of the backdoor link.
Table 15 Interface and IP address assignment
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
100.1.1.1/24 |
CE 2 |
XGE3/0/1 |
120.1.1.1/24 |
XGE3/0/4 |
20.1.1.1/24 |
XGE3/0/4 |
30.1.1.2/24 |
PE 1 |
Loop0 |
1.1.1.9/32 |
PE 2 |
Loop0 |
2.2.2.9/32 |
Loop1 |
3.3.3.3/32 |
Loop1 |
5.5.5.5/32 |
XGE3/0/1 |
100.1.1.2/24 |
XGE3/0/1 |
120.1.1.2/24 |
XGE3/0/4 |
10.1.1.1/24 |
XGE3/0/5 |
10.1.1.2/24 |
Router A |
XGE3/0/5 |
30.1.1.1/24 |
XGE3/0/4 |
20.1.1.2/24 |
1. Configure OSPF on the customer networks:
# Configure OSPF on CE 1 and set the cost of the link between CE 1 and Router A to 2.
[CE1-Ten-GigabitEthernet3/0/4] ip address 20.1.1.1 24
[CE1-Ten-GigabitEthernet3/0/4] ospf cost 2
[CE1] ospf 1
[CE1-ospf-1] area 1
[CE1-ospf-1-area-0.0.0.1] network 100.1.1.0 0.0.0.255
[CE1-ospf-1-area-0.0.0.1] network 20.1.1.0 0.0.0.255
[CE1-ospf-1-area-0.0.0.1] quit
[CE1-ospf-1] quit
# Configure OSPF on CE 2 and set the cost of the link between CE 2 and Router A to 2.
[CE2-Ten-GigabitEthernet3/0/1] ip address 120.1.1.1 24
[CE2-Ten-GigabitEthernet3/0/4] ip address 30.1.1.2 24
[CE2-Ten-GigabitEthernet3/0/4] ospf cost 2
[CE2] ospf 1
[CE2-ospf-1] area 1
[CE2-ospf-1-area-0.0.0.1] network 120.1.1.0 0.0.0.255
[CE2-ospf-1-area-0.0.0.1] network 30.1.1.0 0.0.0.255
[CE2-ospf-1-area-0.0.0.1] quit
[CE2-ospf-1] quit
# Configure OSPF on Router A.
[Sysname] sysname RouterA
[RouterA] interface ten-gigabitethernet 3/0/4
[RouterA-Ten-GigabitEthernet3/0/4] ip address 20.1.1.2 24
[RouterA-Ten-GigabitEthernet3/0/4] quit
[RouterA] interface ten-gigabitethernet 3/0/5
[RouterA-Ten-GigabitEthernet3/0/5] ip address 30.1.1.1 24
[RouterA-Ten-GigabitEthernet3/0/5] quit
[RouterA] ospf 1
[RouterA-ospf-1] area 1
[RouterA-ospf-1-area-0.0.0.1] network 20.1.1.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.1] network 30.1.1.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.1] quit
[RouterA-ospf-1] quit
# Execute the display ip routing-table command to verify that CE 1 and CE 2 have learned the route to each other. (Details not shown.)
2. Configure MPLS L3VPN on the backbone:
# Configure basic MPLS and MPLS LDP on PE 1 to establish LDP LSPs.
[Sysname] sysname PE1
[PE1] interface loopback 0
[PE1-LoopBack0] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/4] ip address 10.1.1.1 24
# Configure PE 1 to take PE 2 as an MP-IBGP peer.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 2.2.2.9 enable
# Configure OSPF on PE 1.
[PE1]ospf 1
[PE1-ospf-1]area 0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure basic MPLS and MPLS LDP on PE 2 to establish LDP LSPs.
[Sysname] sysname PE2
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/5] ip address 10.1.1.2 24
# Configure PE 2 to take PE 1 as an MP-IBGP peer.
[PE2] bgp 100
# Configure OSPF on PE 2.
[PE2] ospf 1
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE2-ospf-1] quit
3. Configure PEs to allow CE access:
# Configure PE 1.
[PE1-vpn-instance-vpn1] vpn-target 1:1
[PE1] interface ten-gigabitethernet 3/0/1
[PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/1] ip address 100.1.1.2 24
[PE1-Ten-GigabitEthernet3/0/1] quit
[PE1] ospf 100 vpn-instance vpn1
[PE1-ospf-100] domain-id 10
[PE1-ospf-100] area 1
[PE1-ospf-100-area-0.0.0.1] network 100.1.1.0 0.0.0.255
[PE1-ospf-100-area-0.0.0.1] quit
[PE1-ospf-100] quit
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] import-route ospf 100
[PE1-bgp-default-ipv4-vpn1] import-route direct
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2-vpn-instance-vpn1] vpn-target 1:1
[PE2] interface ten-gigabitethernet 3/0/1
[PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/1] ip address 120.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/1] quit
[PE2] ospf 100 vpn-instance vpn1
[PE2-ospf-100] domain-id 10
[PE2-ospf-100] area 1
[PE2-ospf-100-area-0.0.0.1] network 120.1.1.0 0.0.0.255
[PE2-ospf-100-area-0.0.0.1] quit
[PE2-ospf-100] quit
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] import-route ospf 100
[PE2-bgp-default-ipv4-vpn1] import-route direct
# Execute the display ip routing-table vpn-instance command on the PEs. Verify that the path to the peer CE is along the OSPF route across the customer networks, instead of the BGP route across the backbone. (Details not shown.)
4. Configure a sham link:
# Configure PE 1.
[PE1] interface loopback 1
[PE1-LoopBack1] ip binding vpn-instance vpn1
[PE1-LoopBack1] ip address 3.3.3.3 32
[PE1-LoopBack1] quit
[PE1] ospf 100
[PE1-ospf-100-area-0.0.0.1] sham-link 3.3.3.3 5.5.5.5
[PE1-ospf-100] quit
# Configure PE 2.
[PE2] interface loopback 1
[PE2-LoopBack1] ip binding vpn-instance vpn1
[PE2-LoopBack1] ip address 5.5.5.5 32
[PE2-LoopBack1] quit
[PE2] ospf 100
[PE2-ospf-100-area-0.0.0.1] sham-link 5.5.5.5 3.3.3.3
[PE2-ospf-100] quit
# Execute the display ip routing-table vpn-instance command on the PEs to verify the following results:
· The path to the peer CE is now along the BGP route across the backbone.
· A route to the sham link destination address exists.
The following is the sample output from the command on PE 1:
3.3.3.3/32 Direct 0 0 127.0.0.1 Loop1
5.5.5.5/32 BGP 255 0 2.2.2.9 XGE3/0/4
20.1.1.0/24 O_INTRA 10 3 100.1.1.1 XGE3/0/1
30.1.1.0/24 O_INTRA 10 4 100.1.1.1 XGE3/0/1
120.1.1.0/24 BGP 255 0 2.2.2.9 XGE3/0/4
# Execute the display ip routing-table command on the CEs. Verify that the next hop of the OSPF route to the peer CE is the interface connected to the PE. The VPN traffic to the peer CE will be forwarded over the backbone.
The following is the sample output from the command on CE 1:
20.1.1.0/24 Direct 0 0 20.1.1.1 XGE3/0/4
20.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/4
20.1.1.255/32 Direct 0 0 20.1.1.1 XGE3/0/4
30.1.1.0/24 O_INTRA 10 3 20.1.1.2 XGE3/0/4
120.1.1.0/24 O_INTRA 10 3 100.1.1.2 XGE3/0/1
# Verify that a sham link has been established on PEs, for example, on PE 1.
[PE1] display ospf sham-link
OSPF Process 100 with Router ID 100.1.1.2
Sham link
Area Neighbor ID Source IP Destination IP State Cost
0.0.0.1 120.1.1.2 3.3.3.3 5.5.5.5 P-2-P 1
# Verify that the peer state is Full on PE 1.
[PE1] display ospf sham-link area 1
Sham link: 3.3.3.3 --> 5.5.5.5
Neighbor ID: 120.1.1.2 State: Full
Area: 0.0.0.1
Cost: 1 State: P-2-P Type: Sham
Request list: 0 Retransmit list: 0
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
domain-id 0.0.0.10
area 0.0.0.1
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
interface LoopBack1
ip address 3.3.3.3 255.255.255.255
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
import-route direct
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
domain-id 0.0.0.10
area 0.0.0.1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
interface LoopBack1
ip address 5.5.5.5 255.255.255.255
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
import-route direct
return
· CE 1:
sysname CE1
ospf 1
area 0.0.0.1
ospf cost 2
return
· CE 2:
sysname CE2
ospf 1
area 0.0.0.1
ospf cost 2
return
· Router A:
sysname RouterA
ospf 1
area 0.0.0.1
return
Example: Configuring BGP AS number substitution
As shown in Figure 43, CE 1 and CE 2 belong to VPN 1 and are connected to PE 1 and PE 2, respectively. The two CEs have the same AS number, 600.
Configure BGP AS number substitution on the PEs to enable the CEs to communicate with each other.
Table 16 Interface and IP address assignment
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
10.1.1.1/24 |
P |
Loop0 |
2.2.2.9/32 |
XGE3/0/2 |
100.1.1.1/24 |
XGE3/0/1 |
20.1.1.2/24 |
PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/2 |
30.1.1.1/24 |
XGE3/0/1 |
10.1.1.2/24 |
PE 2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/1 |
10.2.1.2/24 |
CE 2 |
XGE3/0/1 |
10.2.1.1/24 |
XGE3/0/2 |
30.1.1.2/24 |
XGE3/0/2 |
200.1.1.1/24 |
1. Configure OSPF on the MPLS backbone to establish connectivity between the PEs and the P device.
# Configure PE 1.
[PE1] interface ten-gigabitethernet 3/0/2
[PE1-Ten-GigabitEthernet3/0/2] ip address 20.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/2] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure the P device.
[Sysname] sysname P
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface ten-gigabitethernet 3/0/1
[P-Ten-GigabitEthernet3/0/1] ip address 20.1.1.2 24
[P-Ten-GigabitEthernet3/0/1] quit
[P] interface ten-gigabitethernet 3/0/2
[P-Ten-GigabitEthernet3/0/2] ip address 30.1.1.1 24
[P-Ten-GigabitEthernet3/0/2] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
[PE2] interface ten-gigabitethernet 3/0/2
[PE2-Ten-GigabitEthernet3/0/2] ip address 30.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/2] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE2-ospf-1] quit
# Verify that OSPF neighbor relationships can be established between PE 1, the P device, and PE 2:
¡ Execute the display ospf peer command on each device to verify that their OSPF neighbors have reached the FULL state.
¡ Execute the display ip routing-table command to verify that the PEs can learn the routes to the Loopback interfaces on the remote PEs.
2. Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/2] mpls enable
[PE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Ten-GigabitEthernet3/0/1] mpls enable
[P-Ten-GigabitEthernet3/0/1] mpls ldp enable
[P-Ten-GigabitEthernet3/0/2] mpls enable
[P-Ten-GigabitEthernet3/0/2] mpls ldp enable
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/2] mpls enable
[PE2-Ten-GigabitEthernet3/0/2] mpls ldp enable
# Verify that LDP sessions can be established between PE 1, the P device, and PE 2:
¡ Execute the display mpls ldp peer command on each device to verify that their LDP sessions are in operational state.
¡ Execute the display mpls ldp lsp command to verify establishment of LDP LSPs.
3. Configure VPN instances on PEs to provide network access for CEs:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.2 24
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2-Ten-GigabitEthernet3/0/1] ip address 10.2.1.2 24
# Configure CE 1.
[Sysname] sysname CE1
[CE1-Ten-GigabitEthernet3/0/1] ip address 10.1.1.1 24
[CE1] interface ten-gigabitethernet 3/0/2
[CE1-Ten-GigabitEthernet3/0/2] ip address 100.1.1.1 24
[CE1-Ten-GigabitEthernet3/0/2] quit
# Configure CE 2.
[Sysname] sysname CE2
[CE2-Ten-GigabitEthernet3/0/1] ip address 10.2.1.1 24
[CE2] interface ten-gigabitethernet 3/0/2
[CE2-Ten-GigabitEthernet3/0/2] ip address 200.1.1.1 24
[CE2-Ten-GigabitEthernet3/0/2] quit
# Execute the display ip vpn-instance command on the PEs to verify the VPN instance configuration. Make sure the PEs can ping the CEs attached to them.
4. Establish EBGP peer relationships between each PE and the CE attached to them, and redistribute VPN IPv4 routes.
# Configure CE 1.
[CE1] bgp 600
[CE1-bgp-default] peer 10.1.1.2 as-number 100
[CE1-bgp-default-ipv4] peer 10.1.1.2 enable
# Configure CE 2.
[CE2] bgp 600
[CE2-bgp-default] peer 10.2.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 10.2.1.2 enable
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.1 as-number 600
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10.2.1.1 as-number 600
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
[PE2-bgp-default-vpn1] quit
[PE2-bgp-default] quit
# Execute the display bgp peer ipv4 vpn-instance command on the PEs to verify that they have established BGP peer relationships with their CEs and the peer relationships are in Established state.
5. Establish MP-IBGP peer relationships between PEs:
# Configure PE 1.
[PE1] bgp 100
# Configure PE 2.
[PE2] bgp 100
# Execute the display ip routing-table command on CE 2. The output shows that CE 2 has not learned the route to CE 1.
<CE2> display ip routing-table
10.2.1.0/24 Direct 0 0 10.2.1.1 XGE3/0/1
10.2.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/1
10.2.1.255/32 Direct 0 0 10.2.1.1 XGE3/0/1
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
200.1.1.0/24 Direct 0 0 200.1.1.1 XGE3/0/2
200.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/2
200.1.1.255/32 Direct 0 0 200.1.1.1 XGE3/0/2
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Execute the display ip routing-table command on CE 1 to verify that CE 1 has not learned the route to CE 2. (Details not shown.)
# Execute the display ip routing-table vpn-instance command on the PEs. The output shows the route to the VPN behind the peer CE. The following is the sample command output on PE 2:
<PE2> display ip routing-table vpn-instance vpn1
10.1.1.0/24 BGP 255 0 1.1.1.9 XGE3/0/2
10.2.1.0/24 Direct 0 0 10.2.1.2 XGE3/0/1
10.2.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/1
10.2.1.255/32 Direct 0 0 10.2.1.2 XGE3/0/1
100.1.1.0/24 BGP 255 0 1.1.1.9 XGE3/0/2
200.1.1.0/24 BGP 255 0 10.2.1.1 XGE3/0/1
# Enable BGP update packet debugging on CE 2.
<CE2> terminal monitor
<CE2> terminal logging level 7
<CE2> debugging bgp update 10.2.1.2 ipv4
# Soft-reset all BGP sessions on PE 2.
<PE2> refresh bgp all export ipv4 vpn-instance vpn1
# View the debugging messages on CE 2. The messages show that CE 2 received the route towards CE 1 from PE 2, with an AS path list of 100 600. Because AS number 600 in the AS path list is the local AS number of CE 2, CE 2 determined that a loop exited and ignored the route.
<CE2> *Apr 16 17:47:40:719 2025 CE2 BGP/7/DEBUG:
BGP.: Recv UPDATE from peer 10.2.1.2 with following destinations:
Update message length : 55
Origin : Incomplete
AS path : 100 600
Next hop : 10.2.1.2
BGP.: Error identified while receiving UPDATE message from the peer 10.2.1.2 and ignored
Reason: Looping in ASPATH value.
10.1.1.0/24 PathID 0 ,100.1.1.0/24 PathID 0
The output shows that PE 2 advertises the route to 100.1.1.0/24, and the AS_PATH is 100 600.
6. Configure BGP AS number substitution.
# Configure BGP AS number substitution on PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.1.1.1 substitute-as
# Configure BGP AS number substitution on PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10.2.1.1 substitute-as
# On CE 2, verify that among the routes advertised by PE 2 to CE 2, the AS path lists in the routes for 10.1.1.0/24 and 100.1.1.0/24 have changed from 100 600 to 100 100.
<CE2> *Apr 16 17:54:52:711 2025 CE2 BGP/7/DEBUG:
Origin : Incomplete
AS path : 100 100
Next hop : 10.2.1.2
10.1.1.0/24 PathID 0 ,100.1.1.0/24 PathID 0 ,
# Verify that CEs have learned routes to each other. Take CE 2 for example:
10.1.1.0/24 BGP 255 0 10.2.1.2 XGE3/0/1
100.1.1.0/24 BGP 255 0 10.2.1.2 XGE3/0/1
# Verify that CE 1 and CE 2 can ping the interface addresses of each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 111:1 import-extcommunity
vpn-target 111:1 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
interface Ten-GigabitEthernet3/0/1
ip address 20.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
ip address 20.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 30.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
ip address 30.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
return
· CE 1:
sysname CE1
ip address 100.1.1.1 255.255.255.0
bgp 600
import-route direct
return
· CE 2:
sysname CE2
ip address 200.1.1.1 255.255.255.0
bgp 600
import-route direct
return
Example: Configuring BGP AS number substitution and SoO attribute
CE 1, CE 2, and CE 3 belong to VPN 1, and are connected to PE1, PE 2, and PE 3, respectively.
CE 1 and CE 2 reside in the same site. CE1, CE2, and CE 3 all use AS number 600.
· To avoid route loss, configure BGP AS number substitution on PEs.
· To avoid routing loops, configure the same SoO attribute on PE 1 and PE 2 for CE 1 and CE 2.
Figure 44 Network diagram
Table 17 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
Loop0 |
100.1.1.1/32 |
CE 3 |
Loop0 |
200.1.1.1 /32 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/1 |
10.3.1.1/24 |
CE 2 |
XGE3/0/1 |
10.2.1.1/24 |
PE 2 |
Loop0 |
2.2.2.9/32 |
PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/1 |
10.2.1.2/24 |
XGE3/0/1 |
10.1.1.2/24 |
XGE3/0/2 |
40.1.1.1/24 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/3 |
20.1.1.2/24 |
XGE3/0/3 |
30.1.1.1/24 |
P |
Loop0 |
3.3.3.9/32 |
PE 3 |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
30.1.1.2/24 |
XGE3/0/1 |
10.3.1.2/24 |
XGE3/0/2 |
40.1.1.2/24 |
XGE3/0/2 |
50.1.1.2/24 |
XGE3/0/3 |
50.1.1.1/24 |
1. Configure an IGP (OSPF in this example) on the MPLS backbone to establish connectivity between the PEs and the P device.
# Configure PE 1.
[PE1] interface ten-gigabitethernet 3/0/3
[PE1-Ten-GigabitEthernet3/0/3] ip address 30.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/3] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure PE 2.
[PE2-Ten-GigabitEthernet3/0/2] ip address 40.1.1.1 24
[PE2] interface ten-gigabitethernet 3/0/3
[PE2-Ten-GigabitEthernet3/0/3] ip address 20.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/3] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[PE2-ospf-1] quit
[Sysname] sysname P
[P-LoopBack0] ip address 3.3.3.9 32
[P-LoopBack0] quit
[P-Ten-GigabitEthernet3/0/1] ip address 30.1.1.2 24
[P-Ten-GigabitEthernet3/0/2] ip address 40.1.1.2 24
[P] interface ten-gigabitethernet 3/0/3
[P-Ten-GigabitEthernet3/0/3] ip address 50.1.1.1 24
[P-Ten-GigabitEthernet3/0/3] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 50.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
# Configure PE 3.
[Sysname] sysname PE3
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 4.4.4.9 32
[PE3-LoopBack0] quit
[PE3-Ten-GigabitEthernet3/0/2] ip address 50.1.1.2 24
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 50.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[PE3-ospf-1] quit
# Verify that OSPF neighbor relationships can be established between PE 1, PE 2, the P device, and PE 3:
¡ Execute the display ip routing-table command to verify that the PEs can learn the routes to the loopback interfaces on the remote PEs.
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/3] mpls enable
[PE1-Ten-GigabitEthernet3/0/3] mpls ldp enable
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/3] mpls enable
[PE2-Ten-GigabitEthernet3/0/3] mpls ldp enable
[P] mpls lsr-id 3.3.3.9
[P] mpls ldp
[P-ldp] quit
[P-Ten-GigabitEthernet3/0/3] mpls enable
[P-Ten-GigabitEthernet3/0/3] mpls ldp enable
# Configure PE 3.
[PE3] mpls lsr-id 4.4.4.9
[PE3] mpls ldp
[PE3-ldp] quit
[PE3-Ten-GigabitEthernet3/0/2] mpls enable
[PE3-Ten-GigabitEthernet3/0/2] mpls ldp enable
# Verify that LDP sessions can be established between PE 1, PE 2, the P device, and PE 3:
# Configure PE 1.
# Configure PE 2.
# Configure PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 300:1
[PE3-vpn-instance-vpn1] vpn-target 111:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface ten-gigabitethernet 3/0/1
[PE3-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE3-Ten-GigabitEthernet3/0/1] ip address 10.3.1.2 24
[PE3-Ten-GigabitEthernet3/0/1] quit
# Configure CE 1.
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 100.1.1.1 32
[CE1-LoopBack0] quit
# Configure CE 2.
# Configure CE 3.
[Sysname] sysname CE3
[CE3] interface ten-gigabitethernet 3/0/1
[CE3-Ten-GigabitEthernet3/0/1] ip address 10.3.1.1 24
[CE3-Ten-GigabitEthernet3/0/1] quit
[CE3] interface loopback 0
[CE3-LoopBack0] ip address 200.1.1.1 32
[CE3-LoopBack0] quit
# Configure CE 1.
[CE1] bgp 600
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
# Configure CE 2.
[CE2] bgp 600
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
# Configure CE 3.
[CE3] bgp 600
[CE3-bgp-default] peer 10.3.1.2 as-number 100
[CE3-bgp-default] address-family ipv4 unicast
[CE3-bgp-default-ipv4] peer 10.3.1.2 enable
[CE3-bgp-default-ipv4] import-route direct
[CE3-bgp-default-ipv4] quit
[CE3-bgp-default] quit
5. Configure BGP AS number substitution:
[PE1] bgp 100
[PE2] bgp 100
# Configure BGP AS number substitution on PE 3.
[PE3] bgp 100
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 10.3.1.1 as-number 600
[PE3-bgp-default-vpn1] peer 10.3.1.1 substitute-as
[PE3-bgp-default-vpn1] address-family ipv4 unicast
[PE3-bgp-default-ipv4-vpn1] peer 10.3.1.1 enable
[PE3-bgp-default-ipv4-vpn1] quit
[PE3-bgp-default-vpn1] quit
[PE3-bgp-default] quit
6. Establish MP-IBGP peer relationships between PEs and specify PE 1 as the RR.
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.9 as-number 100
[PE1-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 2.2.2.9 reflect-client
[PE1-bgp-default-vpnv4] peer 4.4.4.9 enable
[PE1-bgp-default-vpnv4] peer 4.4.4.9 reflect-client
[PE1-bgp-default-vpnv4] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpnv4] quit
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.9 as-number 100
[PE3-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] peer 1.1.1.9 enable
[PE3-bgp-default-vpnv4] quit
# Display routing information on CE 2. The output shows that CE 2 has learned the route for 100.1.1.1/32 from CE 1. Routing loop occurs when the route advertised by CE 1 is re-advertised back to the site where CE 1 and CE 2 reside via PE 1, PE 2, and CE 2.
[CE2] display ip routing-table
Destinations : 11 Routes : 11
10.3.1.0/24 BGP 255 0 10.2.1.2 XGE3/0/1
100.1.1.1/32 BGP 255 0 10.2.1.2 XGE3/0/1
200.1.1.1/32 BGP 255 0 10.2.1.2 XGE3/0/1
7. Configure BGP SoO attributes:
# On PE 1, configure the SoO attribute as 1:100 for CE 1.
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] peer 10.1.1.1 soo 1:100
# On PE 2, configure the SoO attribute as 1:100 for CE 2.
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] peer 10.2.1.1 soo 1:100
# PE 2 does not advertise routes received from CE 1 to CE 2 because the same SoO attribute has been configured for the CEs. Display the routing table of CE 2. The output shows that the route 100.1.1.1/32 has been removed.
Destinations : 9 Routes : 9
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
peer 4.4.4.9 enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 40.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
ip address 40.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 50.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
return
· PE 3:
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
ip address 50.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
return
· CE 1:
sysname CE1
interface LoopBack0
ip address 100.1.1.1 255.255.255.255
bgp 600
import-route direct
return
· CE 2:
sysname CE2
bgp 600
import-route direct
return
· CE 3:
sysname CE3
interface LoopBack0
ip address 200.1.1.1 255.255.255.255
bgp 600
import-route direct
return
Example: Configuring MPLS L3VPN FRR through VPNv4 route backup for a VPNv4 route
Configure EBGP between CEs and PEs to exchange VPN routes.
Configure OSPF to ensure connectivity between PEs, and configure MP-IBGP to exchange VPNv4 routing information between PEs.
Configure MPLS L3VPN FRR on PE 1 to achieve the following purposes:
· When the link PE 1—PE 2 operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2.
· When BFD detects that the LSP between PE 1 and PE 2 fails, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 3—CE 2.
Table 18 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
Loop0 |
5.5.5.5/32 |
PE 1 |
Loop0 |
1.1.1.1/32 |
XGE3/0/1 |
10.2.1.1/24 |
XGE3/0/1 |
10.2.1.2/24 |
PE 2 |
Loop0 |
2.2.2.2/32 |
XGE3/0/2 |
172.1.1.1/24 |
XGE3/0/1 |
172.1.1.2/24 |
XGE3/0/3 |
172.2.1.1/24 |
XGE3/0/2 |
10.1.1.2/24 |
CE 2 |
Loop0 |
4.4.4.4/32 |
PE 3 |
Loop0 |
3.3.3.3/32 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/1 |
172.2.1.3/24 |
XGE3/0/2 |
10.3.1.1/24 |
XGE3/0/2 |
10.3.1.2/24 |
1. Configure an IGP (OSPF in this example) on the MPLS backbone to establish connectivity between the PEs.
# Configure PE 1.
[PE1-Ten-GigabitEthernet3/0/2] ip address 172.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/3] ip address 172.2.1.1 24
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure PE 2.
[PE2-LoopBack0] ip address 2.2.2.2 32
[PE2-Ten-GigabitEthernet3/0/1] ip address 172.1.1.2 24
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE2-ospf-1] quit
# Configure PE 3.
[PE3-LoopBack0] ip address 3.3.3.3 32
[PE3-Ten-GigabitEthernet3/0/1] ip address 172.2.1.3 24
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE3-ospf-1] quit
# Verify that OSPF neighbor relationships can be established between PE 1, PE 2, and PE 3:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
# Configure PE 2.
[PE2] mpls lsr-id 2.2.2.2
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/1] mpls enable
[PE2-Ten-GigabitEthernet3/0/1] mpls ldp enable
# Configure PE 3.
[PE3] mpls lsr-id 3.3.3.3
[PE3] mpls ldp
[PE3-ldp] quit
[PE3-Ten-GigabitEthernet3/0/1] mpls enable
[PE3-Ten-GigabitEthernet3/0/1] mpls ldp enable
# Verify that LDP sessions can be established between PE 1, PE 2, and PE 3:
# Configure PE 1.
[PE1-Ten-GigabitEthernet3/0/1] ip address 10.2.1.2 24
# Configure PE 2.
[PE2-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/2] ip address 10.1.1.2 24
# Configure PE 3.
[PE3-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn1
[PE3-Ten-GigabitEthernet3/0/2] ip address 10.3.1.2 24
# Configure CE 1.
[CE1-Ten-GigabitEthernet3/0/1] ip address 10.2.1.1 24
[CE1-LoopBack0] ip address 5.5.5.5 32
# Configure CE 2.
[CE2-Ten-GigabitEthernet3/0/1] ip address 10.1.1.1 24
[CE2-Ten-GigabitEthernet3/0/2] ip address 10.3.1.1 24
[CE2] interface loopback 0
[CE2-LoopBack0] ip address 4.4.4.4 32
[CE2-LoopBack0] quit
# Configure CE 1.
[CE1] bgp 65410
# Configure CE 2.
[CE2] bgp 65420
[CE2-bgp-default] peer 10.1.1.2 as-number 100
[CE2-bgp-default] peer 10.3.1.2 as-number 100
[CE2-bgp-default-ipv4] peer 10.1.1.2 enable
[CE2-bgp-default-ipv4] peer 10.3.1.2 enable
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10.2.1.1 as-number 65410
[PE1-bgp-default-ipv4-vpn1] peer 10.2.1.1 enable
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10.1.1.1 as-number 65420
[PE2-bgp-default-ipv4-vpn1] peer 10.1.1.1 enable
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default-vpn1] peer 10.3.1.1 as-number 65420
5. Establish MP-IBGP peer relationships between PEs.
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 3.3.3.3 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[PE1-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 2.2.2.2 enable
[PE1-bgp-default-vpnv4] peer 3.3.3.3 enable
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[PE2-bgp-default-vpnv4] peer 1.1.1.1 enable
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.1 as-number 100
[PE3-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[PE3-bgp-default-vpnv4] peer 1.1.1.1 enable
6. Configure MPLS L3VPN FRR:
On PE 1:
# Configure BFD to test the connectivity of the LSP to 2.2.2.2/32.
[PE1] mpls bfd enable
[PE1] mpls bfd 2.2.2.2 32
# Create routing policy frr, and specify the backup next hop as 3.3.3.3 for the route to 4.4.4.4/32.
[PE1] ip prefix-list abc index 10 permit 4.4.4.4 32
[PE1] route-policy frr permit node 10
[PE1-route-policy-frr-10] if-match ip address prefix-list abc
[PE1-route-policy-frr-10] apply fast-reroute backup-nexthop 3.3.3.3
[PE1-route-policy-frr-10] quit
# Configure FRR for VPN instance vpn1 to use routing policy frr.
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] fast-reroute route-policy frr
# Specify the preferred value as 100 for routes received from PE 2. This value is greater than the preferred value (0) for routes from PE 3, so PE 1 prefers the routes from PE 2.
[PE1-bgp-default-vpnv4] peer 2.2.2.2 preferred-value 100
On PE 2:
# Enable MPLS BFD on PE 2.
[PE2] mpls bfd enable
# Display detailed information about the route to 4.4.4.4/32 on PE 1. The output shows the backup next hop for the route.
[PE1] display ip routing-table vpn-instance vpn1 4.4.4.4 32 verbose
Summary count : 1
Destination: 4.4.4.4/32
Protocol: BGP instance default
Process ID: 0
SubProtID: 0x1 Age: 00h00m21s
FlushedAge: 00h00m21s
Cost: 0 Preference: 255
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active Adv
OrigTblID: 0x102 OrigVrf: default-vrf
TableID: 0x102 OrigAs: 65420
NibID: 0x1600000e LastAs: 100
AttrID: 0x1
BkAttrID: 0x2 Neighbor: 2.2.2.2
Flags: 0x110060 OrigNextHop: 2.2.2.2
Label: 1279 RealNextHop: 172.1.1.2
BkLabel: 1279 BkNextHop: 172.2.1.3
SRLabel: NULL Interface: Ten-GigabitEthernet3/0/2
BkSRLabel: NULL BkInterface: Ten-GigabitEthernet3/0/3
Tunnel ID: 0x1 IPInterface: Ten-GigabitEthernet3/0/2
BkTunnel ID: 0x3 BkIPInterface: Ten-GigabitEthernet3/0/3
InLabel: NULL ColorInterface: N/A
SIDIndex: NULL BkColorInterface: N/A
FtnIndex: 0x0 TunnelInterface: Ten-GigabitEthernet3/0/2
TrafficIndex: N/A BkTunnelInterface: Ten-GigabitEthernet3/0/3
Connector: N/A PathID: 0x0
UserID: 0xffffffff SRTunnelID: Invalid
SID Type: N/A NID: Invalid
FlushNID: 0x1 BkNID: Invalid
BkFlushNID: 0x3 StatFlags: 0x0
SID: N/A
BkSID: N/A
CommBlockLen: 0 Priority: Low
MemberPort: N/A ExtFlags: 0x0
UCMIndex: 0x0 UserVLAN: 65535
UCMMTU: 0 BrasHash: 0
SessionID: 0 UserGroupID: 0
IsoGroupID: 256 BkIsoGroupID: 256
# When the network is operating correctly, display the routing table of VPN instance vpn1 on PE 1 to verify that the next hop for PE 1 to reach 4.4.4.4/32 is PE 2.
4.4.4.4/32 BGP 255 0 2.2.2.2 XGE3/0/2
5.5.5.5/32 BGP 255 0 10.2.1.1 XGE3/0/1
10.1.1.0/24 BGP 255 0 2.2.2.2 XGE3/0/2
10.3.1.0/24 BGP 255 0 2.2.2.2 XGE3/0/2
# Shut down interface Ten-GigabitEthernet3/0/1 on CE 2. Then, display the routing table of VPN instance vpn1 on PE 1 to verify that the next hop for PE 1 to reach 4.4.4.4/32 has changed to PE 3. CE 1 and CE 2 can still ping each other.
4.4.4.4/32 BGP 255 0 3.3.3.3 XGE3/0/3
10.3.1.0/24 BGP 255 0 3.3.3.3 XGE3/0/3
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.1
mpls ldp
mpls bfd enable
interface LoopBack0
ip address 1.1.1.1 255.255.255.255
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.2 connect-interface LoopBack0
peer 3.3.3.3 connect-interface LoopBack0
peer 2.2.2.2 enable
peer 3.3.3.3 enable
mpls bfd 2.2.2.2 32
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.2
mpls ldp
mpls bfd enable
interface LoopBack0
ip address 2.2.2.2 255.255.255.255
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.1 connect-interface LoopBack0
peer 1.1.1.1 enable
return
· PE 3:
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.3
mpls ldp
interface LoopBack0
ip address 172.2.1.3 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.1 enable
return
· CE 1:
sysname CE1
interface LoopBack0
bgp 65410
import-route direct
return
· CE 2:
sysname CE2
interface LoopBack0
ip address 4.4.4.4 255.255.255.255
bgp 65420
import-route direct
return
Example: Configuring MPLS L3VPN FRR through VPNv4 route backup for an IPv4 route
Configure MPLS L3VPN FRR on PE 2 to achieve the following purposes:
· When the link PE 2—CE 2 operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2.
· When BFD detects that the link between PE 2 and CE 2 fails, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—PE 3—CE 2.
Table 19 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
Loop0 |
5.5.5.5/32 |
PE 2 |
Loop0 |
2.2.2.2/32 |
XGE3/0/1 |
10.2.1.1/24 |
XGE3/0/1 |
172.1.1.2/24 |
PE 1 |
Loop0 |
1.1.1.1/32 |
XGE3/0/2 |
10.1.1.2/24 |
XGE3/0/1 |
10.2.1.2/24 |
XGE3/0/3 |
172.3.1.2/24 |
XGE3/0/2 |
172.1.1.1/24 |
PE 3 |
Loop0 |
3.3.3.3/32 |
XGE3/0/3 |
172.2.1.1/24 |
XGE3/0/1 |
172.2.1.3/24 |
CE 2 |
Loop0 |
4.4.4.4/32 |
XGE3/0/2 |
10.3.1.2/24 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/3 |
172.3.1.3/24 |
XGE3/0/2 |
10.3.1.1/24 |
# Configure PE 1.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure PE 2.
[PE2-Ten-GigabitEthernet3/0/3] ip address 172.3.1.2 24
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.3.1.0 0.0.0.255
[PE2-ospf-1] quit
# Configure PE 3.
[PE3] interface ten-gigabitethernet 3/0/3
[PE3-Ten-GigabitEthernet3/0/3] ip address 172.3.1.3 24
[PE3-Ten-GigabitEthernet3/0/3] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 172.3.1.0 0.0.0.255
[PE3-ospf-1] quit
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
# Configure PE 3.
[PE3] mpls ldp
[PE3-ldp] quit
[PE3-Ten-GigabitEthernet3/0/3] mpls enable
[PE3-Ten-GigabitEthernet3/0/3] mpls ldp enable
# Configure PE 1.
# Configure PE 2.
# Configure PE 3.
[PE3] interface ten-gigabitethernet 3/0/2
[PE3-Ten-GigabitEthernet3/0/2] quit
# Configure CE 1.
# Configure CE 2.
# Configure CE 1.
[CE1] bgp 65410
# Configure CE 2.
[CE2] bgp 65420
# Configure PE 1.
[PE1] bgp 100
# Configure PE 2.
[PE2] bgp 100
# Configure PE 3.
[PE3] bgp 100
5. Establish MP-IBGP peer relationships between PEs and specify PE 1 as the RR.
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv4] peer 2.2.2.2 reflect-client
[PE1-bgp-default-vpnv4] peer 3.3.3.3 reflect-client
# Configure PE 2.
[PE2] bgp 100
# Configure PE 3.
[PE3] bgp 100
6. Configure MPLS L3VPN FRR on PE 2:
# Configure the source IP address of BFD echo packets as 12.1.1.1.
[PE2] bfd echo-source-ip 12.1.1.1
[PE2] ip prefix-list abc index 10 permit 4.4.4.4 32
[PE2] route-policy frr permit node 10
[PE2-route-policy-frr-10] if-match ip address prefix-list abc
[PE2-route-policy-frr-10] apply fast-reroute backup-nexthop 3.3.3.3
[PE2-route-policy-frr-10] quit
# Use echo-mode BFD to detect the primary route connectivity.
[PE2] bgp 100
[PE2-bgp-default] primary-path-detect bfd echo
[PE2-bgp-default-ipv4-vpn1] fast-reroute route-policy frr
# Specify the preferred value as 200 for BGP routes received from CE 2. This value is greater than the preferred value (0) for routes from PE 3, so PE 2 prefers the routes from CE 2.
[PE2-bgp-default-ipv4-vpn1] peer 10.1.1.1 preferred-value 200
# Display detailed information about the route to 4.4.4.4/32 on PE 2. The output shows the backup next hop for the route.
[PE2] display ip routing-table vpn-instance vpn1 4.4.4.4 32 verbose
Summary count : 1
Process ID: 0
SubProtID: 0x6 Age: 00h01m10s
FlushedAge: 00h01m10s
OrigTblID: 0x102 OrigVrf: vpn1
NibID: 0x1600000c LastAs: 65420
AttrID: 0x2
BkAttrID: 0x1 Neighbor: 10.1.1.1
Flags: 0x10060 OrigNextHop: 10.1.1.1
Label: NULL RealNextHop: 10.1.1.1
BkLabel: 1279 BkNextHop: 172.3.1.3
Tunnel ID: Invalid IPInterface: Ten-GigabitEthernet3/0/2
FtnIndex: 0x0 TunnelInterface: N/A
FlushNID: Invalid BkNID: Invalid
SID: N/A
BkSID: N/A
# When the network is operating correctly, display the routing table of VPN instance vpn1 on PE 2 to verify that the next hop for PE 2 to reach 4.4.4.4/32 is CE 2.
4.4.4.4/32 BGP 255 0 10.1.1.1 XGE3/0/2
5.5.5.5/32 BGP 255 0 1.1.1.1 XGE3/0/1
10.1.1.0/24 Direct 0 0 10.1.1.2 XGE3/0/2
10.1.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/2
10.1.1.255/32 Direct 0 0 10.1.1.2 XGE3/0/2
10.2.1.0/24 BGP 255 0 1.1.1.1 XGE3/0/1
10.3.1.0/24 BGP 255 0 10.1.1.1 XGE3/0/2
# Shut down interface Ten-GigabitEthernet3/0/1 on CE 2. Then, display the routing table of VPN instance vpn1 on PE 2 to verify that the next hop for PE 2 to reach 4.4.4.4/32 has changed to PE 3. CE 1 and CE 2 can still ping each other.
Destinations : 6 Routes : 6
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.1
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.2 enable
peer 3.3.3.3 enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.2
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
ip address 172.3.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.1 enable
return
· PE 3:
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.3
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
ip address 172.3.1.3 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.1 enable
return
· CE 1:
sysname CE1
interface LoopBack0
bgp 65410
import-route direct
return
· CE 2:
sysname CE2
interface LoopBack0
bgp 65420
import-route direct
return
Example: Configuring MPLS L3VPN FRR through IPv4 route backup for a VPNv4 route
· When BFD detects that the link between PE 1 and PE 2 fails, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—CE 2.
Table 20 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
Loop0 |
5.5.5.5/32 |
CE 2 |
Loop0 |
4.4.4.4/32 |
XGE3/0/1 |
10.2.1.1/24 |
XGE3/0/1 |
10.1.1.1/24 |
PE 1 |
Loop0 |
1.1.1.1/32 |
XGE3/0/2 |
10.3.1.1/24 |
XGE3/0/1 |
10.2.1.2/24 |
PE 2 |
Loop0 |
2.2.2.2/32 |
XGE3/0/2 |
10.1.1.2/24 |
XGE3/0/2 |
10.3.1.2/24 |
XGE3/0/3 |
172.2.1.1/24 |
XGE3/0/3 |
172.2.1.2/24 |
# Configure PE 1.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure PE 2.
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1] quit
# Configure PE 3.
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1] quit
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
# Configure PE 3.
[PE3] mpls ldp
[PE3-ldp] quit
# Configure PE 1.
# Configure PE 2.
# Configure PE 3.
# Configure CE 1.
[CE1] interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] quit
# Configure CE 2.
# Configure CE 1.
[CE1] bgp 65410
# Configure CE 2.
[CE2] bgp 65420
# Configure PE 1.
[PE1] bgp 100
# Configure PE 2.
[PE2] bgp 100
# Configure PE 3.
[PE3] bgp 100
# Configure PE 1.
[PE1] bgp 100
# Configure PE 2.
[PE2] bgp 100
# Configure PE 3.
[PE3] bgp 100
6. Configure MPLS L3VPN FRR on PE 1:
# Create routing policy frr, and specify the backup next hop as 10.1.1.1 for the route to 4.4.4.4/32.
[PE1-route-policy-frr-10] apply fast-reroute backup-nexthop 10.1.1.1
[PE1] bgp 100
# Specify the preferred value as 200 for BGP VPNv4 routes received from PE 2. This value is greater than the preferred value (0) for IPv4 unicast routes from CE 2, so PE 1 prefers the routes from PE 2.
[PE1-bgp-default-vpnv4] peer 2.2.2.2 preferred-value 200
7. Enable MPLS BFD on PE 2.
Summary count : 1
Process ID: 0
AttrID: 0x1
SID: N/A
BkSID: N/A
Destinations : 8 Routes : 8
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.1
mpls ldp
mpls bfd enable
interface LoopBack0
interface Ten-GigabitEthernet3/0/2
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.2 enable
peer 3.3.3.3 enable
mpls bfd 2.2.2.2 32
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.2
mpls ldp
mpls bfd enable
interface LoopBack0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.1 enable
return
· PE 3:
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.3
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.1 enable
return
· CE 1:
sysname CE1
interface LoopBack0
bgp 65410
import-route direct
return
· CE 2:
sysname CE2
interface LoopBack0
bgp 65420
import-route direct
return
Configuring IPv6 MPLS L3VPN
About IPv6 MPLS L3VPN
IPv6 MPLS L3VPN, also known as IPv6 VPN Provider Edge (6VPE), uses BGP to advertise IPv6 VPN routes and uses MPLS to forward IPv6 VPN packets on the service provider backbone.
IPv6 MPLS L3VPN network diagram
Figure 48 shows a typical IPv6 MPLS L3VPN model. The service provider backbone in the IPv6 MPLS L3VPN model is an IPv4 network. IPv6 runs inside the VPNs and between CE and PE. Therefore, PEs must support both IPv4 and IPv6. The PE-CE interfaces of a PE run IPv6, and the PE-P interface of a PE runs IPv4.
Figure 48 Network diagram for the IPv6 MPLS L3VPN model
IPv6 MPLS L3VPN packet forwarding
As shown in Figure 49, the IPv6 MPLS L3VPN packet forwarding procedure is as follows:
1. The PC at Site 1 sends an IPv6 packet destined for 2001:2::1, the PC at Site 2. CE 1 transmits the packet to PE 1.
2. Based on the inbound interface and destination address of the packet, PE 1 finds a matching entry from the routing table of the VPN instance, labels the packet with both a private network label (inner label) and a public network label (outer label), and forwards the packet out.
3. The MPLS backbone transmits the packet to PE 2 by outer label. The outer label is removed from the packet at the penultimate hop.
4. According to the inner label and destination address of the packet, PE 2 searches the routing table of the VPN instance to determine the outbound interface, and then forwards the packet out of the interface to CE 2.
5. CE 2 forwards the packet to the destination by IPv6 forwarding.
Figure 49 IPv6 MPLS L3VPN packet forwarding diagram
IPv6 MPLS L3VPN routing information advertisement
The routing information is advertised through the path local CE—ingress PE—egress PE—remote CE.
Routing information advertisement from the local CE to the ingress PE.
The local CE advertises standard IPv6 routing information to the ingress PE over an IPv6 static route, RIPng route, OSPFv3 route, IPv6 IS-IS route, IBGP route, or EBGP route.
Routing information advertisement from the ingress PE to the egress PE.
After receiving the standard IPv6 routes from the CE, the ingress PE performs the following operations:
1. Adds RDs and route targets to create VPN-IPv6 routes.
2. Saves the routes to the routing table of the VPN instance created for the CE.
3. Assigns VPN labels for the routes.
4. Advertises the VPN-IPv6 routes to the egress PE through MP-BGP.
The egress PE performs the following operations:
5. Compares the export target attributes of the VPN-IPv6 routes with the import target attributes that it maintains for the VPN instance.
6. Adds the routes to the routing table of the VPN instance if the export and import target attributes are the same.
The PEs use an IGP to ensure the connectivity between them.
Routing information advertisement from the egress PE to the remote peer CE.
The egress PE restores the original IPv6 routes and advertises them to the remote CE over an IPv6 static route, RIPng route, OSPFv3 route, IPv6 IS-IS route, EBGP, or IBGP route.
IPv6 MPLS L3VPN network schemes and features
IPv6 MPLS L3VPN supports the following network schemes and features:
· Basic VPN.
· Inter-AS VPN option A.
· Inter-AS VPN option B.
· Inter-AS VPN option C.
· Carrier's carrier.
· HoVPN.
· OSPFv3 VPN extension. (OSPFv3 Type 3, Type 5, and Type 7 LSAs support the DN bit. By default, OSPFv3 VPN extension uses the DN bit to avoid routing loops.)
· BGP AS number substitution and SoO.
· IPv6 MPLS L3VPN FRR.
Protocols and standards
· RFC 4659, BGP-MPLS IP Virtual Private Network (VPN) Extension for IPv6 VPN
· RFC 6565, OSPFv3 as a Provider Edge to Customer Edge (PE-CE) Routing Protocol
IPv6 MPLS L3VPN tasks at a glance
Unless otherwise indicated, configure IPv6 MPLS L3VPN on PEs.
To configure IPv6 MPLS L3VPN, perform the following tasks:
1. Configuring IPv6 MPLS L3VPN basics:
b. Configuring routing between a PE and a CE
c. Configuring routing between PEs
d. (Optional.) Configuring BGP VPNv6 route control
2. Configuring advanced IPv6 MPLS L3VPN networks
¡ Configuring inter-AS IPv6 VPN
Perform this task when sites of a VPN are connected to different ASs of an ISP.
3. (Optional.) Configuring IPv6 MPLS L3VPN FRR
4. (Optional.) Controlling MPLS L3VPN route advertisement and reception
¡ Configuring an OSPFv3 sham link
¡ Configuring BGP AS number substitution and SoO attribute
¡ Configuring the AIGP attribute
¡ Configuring the BGP additional path feature
¡ Enabling the VPN Prefix ORF feature
¡ Configuring route replication
¡ Enabling redistribution of multiple same-prefix routes with the same RD
¡ Enabling prioritized withdrawal of specific routes
5. (Optional.) Enabling logging for BGP route flapping
Restrictions and guidelines: IPv6 MPLS L3VPN configuration
The public tunnels for IPv6 MPLS L3VPN can be LSP, MPLS TE, and GRE tunnels. In the current software version, the device does not support using GRE/IPv6 tunnels as public tunnels for IPv6 MPLS L3VPN.
Prerequisites for IPv6 MPLS L3VPN
Before configuring IPv6 MPLS L3VPN, perform the following tasks:
1. Configure an IGP on the PEs and P devices to ensure IP connectivity within the MPLS backbone.
2. Configure basic MPLS for the MPLS backbone.
3. Configure MPLS LDP on PEs and P devices to establish LDP LSPs.
Configuring VPN instances
Creating a VPN instance
A VPN instance is a collection of the VPN membership and routing rules of its associated site. A VPN instance might correspond to more than one VPN.
You can configure an RD in VPN instance view and each address family view of the VPN instance. The RD configured in address family view takes precedence over the RD configured in VPN instance view. An address family uses the RD configured in VPN instance view only when no RD is configured in the address family view.
Editing an RD will delete some configuration related to the VPN instance from the BGP process. Please be cautious.
Follow these restrictions and guidelines when deleting RDs:
· When you delete the RD configured in VPN instance view, settings configured in an address family view of the BGP-VPN instance will be deleted if no RD is configured in the address family view. For example, when you delete the RD of VPN instance vpna, settings configured in BGP-VPN IPv6 unicast address family view of VPN instance vpna will be deleted if no RD is configured in VPN instance IPv6 address family view.
· When you delete an RD configured in an address family view of the VPN instance, settings configured in the address family view of the BGP-VPN instance will be deleted if the RD configured in the address family view is different from the RD configured in VPN instance view.
· If you configure an RD for an address family that inherits the RD of the VPN instance and the two RDs are different, settings configured in the address family view of the BGP-VPN instance will be deleted.
1. Enter system view.
2. Set an MPLS label range for all VPN instances.
mpls per-vrf-label range minimum maximum
By default, no MPLS label range is configured for VPN instances.
3. Create a VPN instance and enter VPN instance view.
4. Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
5. (Optional.) Configure a description for the VPN instance.
By default, no description is configured for a VPN instance.
6. (Optional.) Set an ID for the VPN instance.
vpn-id vpn-id
By default, no ID is configured for a VPN instance.
7. (Optional.) Configure an SNMP context for the VPN instance.
By default, no SNMP context is configured.
8. Enter VPN instance IPv6 address family view.
address-family ipv6
9. Configure an RD.
By default, no RD is configured.
10. Specify a label allocation mode.
apply-label { per-instance [ static static-label-value ] | per-route }
By default, BGP allocates a label to each next hop.
CAUTION: Executing this command will re-advertise all routes in the VPN instance, which will cause temporary interruption of running services in the VPN instance. Please be cautious. |
Associating a VPN instance with a Layer 3 interface
If an interface is associated with a VSI or cross-connect, the interface (including its subinterfaces) cannot associate with a VPN instance.
If a subinterface is associated with a VSI or cross-connect, the subinterface cannot associate with a VPN instance.
2. Enter interface view.
3. Associate a VPN instance with the interface.
By default, an interface is not associated with a VPN instance and belongs to the public network.
CAUTION: Associating a VPN instance with an interface or disassociating a VPN instance from an interface will clear the IP address and routing protocol settings of the interface. |
The ip binding vpn-instance command clears the IPv6 address of the interface. Therefore, reconfigure an IPv6 address for the interface after configuring this command.
Configuring route related attributes for a VPN instance
Configurations made in VPN instance view apply to both IPv4 VPN and IPv6 VPN.
IPv6 VPN prefers the configurations in VPN instance IPv6 address family view over the configurations in VPN instance view.
Before you perform this task, create the routing policies to be used by this task. For information about routing policies, see Layer 3—IP Routing Configuration Guide.
2. Enter VPN instance view or VPN instance IPv6 address family view.
¡ Enter VPN instance view.
¡ Execute the following commands in sequence to enter VPN instance IPv6 address family view:
address-family ipv6
3. Configure route targets.
By default, no route targets are configured.
4. Set the maximum number of active routes.
By default, the number of active routes in a VPN instance is not limited.
Setting the maximum number of active routes for a VPN instance can prevent the PE from storing too many routes.
5. Apply an import routing policy.
By default, all routes matching the import target attribute are accepted.
6. Apply an export routing policy.
By default, routes to be advertised are not filtered.
7. Bind a tunnel policy to the VPN instance.
tnl-policy tunnel-policy-name
By default, no tunnel policy is bound to a VPN instance.
If no tunnel policy is bount to a VPN instance or the bound tunnel policy is not configured, the VPN instance uses the default load sharing policy for tunnel selection. For more information about tunnel policies and the default load sharing policy, see "Configuring tunnel policies."
Configuring IPv6 static routing between a PE and a CE
Perform this configuration on the PE. On the CE, configure a common IPv6 static route.
For more information about IPv6 static routing, see Layer 3—IP Routing Configuration Guide.
2. Configure an IPv6 static route for a VPN instance.
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | nexthop-address [ public ] | vpn-instance d-vpn-instance-name nexthop-address } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
Configuring RIPng between a PE and a CE
Perform this configuration on the PE. On the CE, configure a common RIPng process.
For more information about RIPng, see Layer 3—IP Routing Configuration Guide.
2. Create a RIPng process for a VPN instance and enter RIPng view.
ripng [ process-id ] vpn-instance vpn-instance-name
A RIPng process can belong to only one VPN instance.
3. Redistribute BGP routes.
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ cost cost-value | route-policy route-policy-name ] *
By default, RIPng does not redistribute routes from other routing protocols.
4. Return to system view.
5. Enter interface view.
6. Enable RIPng on the interface.
ripng process-id enable
By default, RIPng is disabled on an interface.
Configuring OSPFv3 between a PE and a CE
Perform this configuration on the PE. On the CE, configure a common OSPFv3 process.
For more information about OSPFv3, see Layer 3—IP Routing Configuration Guide.
2. Create an OSPFv3 process for a VPN instance and enter OSPFv3 view.
ospfv3 [ process-id | vpn-instance vpn-instance-name ] *
An OSPFv3 process can belong to only one VPN instance.
Deleting a VPN instance also deletes all related OSPFv3 processes.
3. Set the router ID.
router-id router-id
4. Redistribute BGP routes.
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] *
By default, OSPFv3 does not redistribute routes from other routing protocols.
If the vpn-instance-capability simple command is not configured for the OSPFv3 process, the allow-ibgp keyword is optional to redistribute VPNv6 routes learned from MP-IBGP peers. In any other cases, if you do not specify the allow-ibgp keyword, the OSPFv3 process does not redistribute VPNv6 routes learned from MP-IBGP peers.
5. (Optional.) Configure OSPFv3 route attributes:
a. Set an OSPFv3 domain ID.
domain-id { domain-id [ secondary ] | null }
The default domain ID is 0.
Restrictions and guidelines |
When you redistribute OSPFv3 routes into BGP, BGP adds the primary domain ID to the redistributed BGP routes as a BGP extended community attribute. |
You can configure the same domain ID for different OSPFv3 processes. You must configure the same domain ID for all OSPFv3 processes of the same VPN to ensure correct route advertisement. |
b. Configure the type code of an OSPFv3 extended community attribute.
ext-community-type { domain-id type-code1 | route-type type-code2 | router-id type-code3 }
By default, the type codes for domain ID, route type, and router ID are 0x0005, 0x0306, 0x0107, respectively.
c. Configure an external route tag for redistributed VPN routes.
route-tag tag-value
By default, if BGP runs within an MPLS backbone, and the BGP AS number is not greater than 65535, the first two octets of the external route tag are 0xD000. The last two octets are the local BGP AS number. If the AS number is greater than 65535, the external route tag is 0.
d. Disable setting the DN bit in OSPFv3 LSAs.
disable-dn-bit-set
By default, when a PE redistributes BGP routes into OSPFv3 and creates OSPFv3 LSAs, it sets the DN bit for the LSAs.
This command might cause routing loops. Use it with caution.
e. Ignore the DN bit in OSPFv3 LSAs.
disable-dn-bit-check
By default, the PE checks the DN bit in OSPFv3 LSAs.
f. Enable the external route check feature for OSPFv3 LSAs.
route-tag-check enable
By default, the PE does not check the external route tag but checks the DN bit in OSPFv3 LSAs to avoid routing loops.
This command is only for backward compatibility with the old protocol (RFC 4577).
g. Return to system view.
6. Enter interface view.
7. Enable OSPFv3 on the interface.
ospfv3 process-id area area-id [ instance instance-id ]
By default, OSPFv3 is disabled on an interface.
For the command to be executed successfully, make sure the VPN instance to which the OSPFv3 process belongs is the VPN instance bound to the interface.
Configuring IPv6 IS-IS between a PE and a CE
Perform this configuration on the PE. On the CE, configure a common IPv6 IS-IS process.
For more information about IPv6 IS-IS, see Layer 3—IP Routing Configuration Guide.
2. Create an IPv6 IS-IS process for a VPN instance and enter IS-IS view.
isis [ process-id ] vpn-instance vpn-instance-name
An IPv6 IS-IS process can belong to only one VPN instance.
3. Configure a network entity title for the IS-IS process.
network-entity net
By default, no NET is configured.
4. Create the IS-IS IPv6 unicast address family and enter its view.
5. Redistribute BGP routes.
import-route bgp4+ [ as-number ] [ allow-ibgp ] [ [ cost cost-value | inherit-cost ] | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, IPv6 IS-IS does not redistribute routes from other routing protocols.
6. Return to system view.
7. Enter interface view.
8. Enable IPv6 for the IS-IS process on the interface.
isis ipv6 enable [ process-id ]
By default, IPv6 is disabled for the IS-IS process on the interface.
Configuring EBGP between a PE and a CE
Restrictions and guidelines for configuring EBGP between a PE and a CE
After you edit or delete the RD in VPN instance view or VPN instance IPv6 address family view, the device automatically deletes the BGP-VPN IPv6 unicast address family view and all its configuration. To avoid route flapping, do not edit or delete the RD if you have configured EBGP between a PE and a CE.
Configuring the PE
2. Enable a BGP instance and enter BGP instance view.
By default, BGP is not enabled.
3. Enter BGP-VPN instance view.
4. Configure the CE as the VPN EBGP peer.
peer { group-name | ipv6-address [ prefix-length ] } as-number as-number
5. Create the BGP-VPN IPv6 unicast address family and enter its view.
Configuration commands in BGP-VPN IPv6 unicast address family view are the same as those in BGP IPv6 unicast address family view. For more information, see BGP in Layer 3—IP Routing Configuration Guide.
6. Enable IPv6 unicast route exchange with the specified peer.
peer { group-name | ip-address [ prefix-length ] } enable
By default, BGP does not exchange IPv6 unicast routes with a peer.
7. Redistribute the routes of the local CE.
A PE must redistribute the routes of the local CE into its VPN routing table so that it can advertise them to the peer PE.
8. (Optional.) Allow the local AS number to appear in the AS_PATH attribute of a received route, and set the maximum number of repetitions.
peer { group-name | ipv6-address [ prefix-length ] } allow-as-loop [ number ]
By default, BGP discards incoming route updates that contain the local AS number.
Execute this command in a hub-spoke network where EBGP is running between a PE and a CE to enable the PE to receive the route updates from the CE.
Configuring the CE
2. Enter BGP instance view.
3. Configure the PE as an EBGP peer.
4. Create the BGP IPv6 unicast address family and enter its view.
5. Enable IPv6 unicast route exchange with the specified peer.
6. Configure route redistribution.
A CE must advertise its VPN routes to the connected PE so that the PE can advertise them to the peer CE.
Configuring IBGP between a PE and a CE
Restrictions and guidelines for configuring IBGP between a PE and a CE
Use IBGP between PE and CE only in a basic IPv6 MPLS L3VPN network. In networks such as inter-AS VPN and carrier's carrier, you cannot configure IBGP between PE and CE.
After you edit or delete the RD in VPN instance view or VPN instance IPv6 address family view, the device automatically deletes the BGP-VPN IPv6 unicast address family view and all its configuration. To avoid route flapping, do not edit or delete the RD if you have configured IBGP between a PE and a CE.
Configuring the PE
Configuration commands in BGP-VPN instance view are the same as those in BGP instance view. For more information, see Layer 3—IP Routing Configuration Guide.
4. Configure the CE as the VPN IBGP peer.
peer { group-name | ipv6-address [ prefix-length ] } enable
7. Configure the CE as a client of the RR to enable the PE to advertise routes learned from the IBGP peer CE to other IBGP peers.
peer { group-name | ipv6-address [ prefix-length ] } reflect-client
By default, no RR or RR client is configured.
Configuring an RR does not change the next hop of a route. To change the next hop of a route, configure an inbound policy on the receiving side.
8. (Optional.) Enable route reflection between clients.
reflect between-clients
By default, route reflection between clients is enabled.
9. (Optional.) Configure the cluster ID for the RR.
By default, the RR uses its own router ID as the cluster ID.
If multiple RRs exist in a cluster, use this command to configure the same cluster ID for all RRs in the cluster to avoid routing loops.
Configuring the CE
3. Configure the PE as an IBGP peer.
4. Create the BGP IPv6 unicast family and enter its view.
A CE must redistribute its routes to the PE so the PE can advertise them to the peer CE.
3. Configure the remote PE as the peer.
4. Specify the source interface for TCP connections.
By default, BGP uses the outbound interface of the best route to the BGP peer as the source interface.
5. Create the BGP VPNv6 address family and enter its view.
address-family vpnv6
6. Enable BGP VPNv6 route exchange with the specified peer.
By default, BGP does not exchange BGP VPNv6 routes with any peer.
About BGP VPNv6 route control
BGP VPNv6 route control is configured similarly with BGP route control, except that it is configured in BGP VPNv6 address family view. For more information about BGP route control, see Layer 3—IP Routing Configuration Guide.
Controlling BGP VPNv6 route saving
3. Enter BGP VPNv6 address family view.
4. Save all route updates from a peer or peer group.
By default, BGP does not save route updates from a peer.
Specifying a preferred value for BGP VPNv6 routes
4. Specify a preferred value for routes received from a peer or peer group.
The default preferred value is 0.
Setting the maximum number of received routes
4. Set the maximum number of routes BGP can receive from a peer or peer group.
By default, the number of routes that BGP can receive from a peer or peer group is not limited.
Configuring BGP VPNv6 route reflection
To ensure the connectivity of IBGP peers, you must establish full-mesh IBGP connections, which costs massive network and CPU resources.
To reduce IBGP connections in the network, you can configure a router as a route reflector (RR) and configure other routers as its clients. You only need to establish IBGP connections between the RR and its clients to enable the RR to forward routes to the clients.
4. Configure the local PE as the RR and specify the peer as the client.
By default, no RR or client is configured.
5. (Optional.) Enable route reflection between clients.
6. (Optional.) Configure a cluster ID for the RR.
By default, an RR uses its own router ID as the cluster ID.
7. (Optional.) Configure a filtering policy for reflected routes.
rr-filter { ext-comm-list-number | ext-comm-list-name }
By default, an RR does not filter reflected routes.
Only IBGP routes whose extended community attribute matches the specified community list are reflected.
By configuring different filtering policies on RRs, you can implement load balancing among the RRs.
8. (Optional.) Allow the RR to change the attributes of routes to be reflected.
reflect change-path-attribute
By default, RR cannot change the attributes of routes to be reflected.
9. (Optional.) Specify a peer or peer group as a client of the nearby cluster.
peer { group-name | ipv4-address [ mask-length ] } reflect-nearby-group
By default, the nearby cluster does not have any clients.
The RR does not change the next hop of routes reflected to clients in the nearby cluster.
Configuring BGP VPNv6 route attributes
4. Configure the NEXT_HOP attribute.
¡ Set the device as the next hop for routes sent to a peer or peer group.
¡ Configure the device to not change the next hop of routes advertised to a peer or peer group.
By default, the device uses its address as the next hop of routes advertised to peers.
On an RR in an inter-AS option C scenario, you must configure this command to not change the next hop of VPNv6 routes advertised to BGP peers and RR clients.
5. Configure the AS_PATH attribute.
¡ Allow the local AS number to appear in the AS_PATH attribute of routes received from a peer or peer group and set the maximum number of repetitions.
By default, BGP discards route updates that contain the local AS number.
¡ Remove private AS numbers in BGP updates sent to an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } public-as-only [ { force | limited } [ replace ] [ include-peer-as ] ]
By default, BGP updates sent to an EBGP peer or peer group can carry both public and private AS numbers.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
6. Advertise the COMMUNITY attribute to a peer or peer group.
By default, BGP does not advertise the COMMUNITY attribute to any peers or peer groups.
7. Advertise the Large community attribute to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise-large-community
By default, BGP does not advertise the Large community attribute to any peers or peer groups.
8. Configure the SoO attribute for a peer for peer group.
By default, the SoO attribute is not configured.
9. Configure BGP to add the link bandwidth attribute to routes received from an EBGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } bandwidth
By default, BGP does not add the link bandwidth attribute to routes received from an EBGP peer or peer group.
10. Configure BGP to carry the user group ID in BGP routes sent to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] | ipv6-address [ prefix-length ] } advertise user-group-id
By default, BGP does not carry the user group ID in BGP routes sent to a peer or peer group.
Configuring BGP VPNv6 route filtering
4. Filter advertised routes.
filter-policy { ipv6-acl-number | name ipv6-acl-name | prefix-list ipv6-prefix-name } export [ protocol process-id ]
By default, BGP does not filter advertised routes.
5. Filter received routes.
filter-policy { ipv6-acl-number | name ipv6-acl-name | prefix-list ipv6-prefix-name } import
By default, BGP does not filter received routes.
6. Configure AS_PATH list-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } as-path-acl as-path-acl-number { export | import }
By default, AS_PATH list-based route filtering is not configured.
7. Configure ACL-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } filter-policy { ipv6-acl-number | name ipv6-acl-name } { export | import }
By default, ACL-based route filtering is not configured.
8. Configure IPv6 prefix list-based route filtering for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } prefix-list ipv6-prefix-name { export | import }
By default, IPv6 prefix list-based route filtering is not configured.
9. Apply a routing policy to routes advertised to or received from a peer or peer group.
By default, no routing policy is applied.
10. Enable route target filtering for received BGP VPNv6 routes.
policy vpn-target
By default, route target filtering is enabled for received VPNv6 routes. Only VPNv6 routes whose export route target attribute matches the local import route target attribute are added to the routing table.
Configuring BGP VPNv6 route dampening
This feature enables BGP to not select unstable routes as optimal routes.
If a BGP peer goes down after you configure this feature, VPNv6 routes coming from the peer are dampened but not deleted.
4. Configure BGP VPNv6 route dampening.
¡ Configure EBGP route dampening.
¡ Configure IBGP route dampening.
dampening ibgp[ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] *
By default, BGP VPNv6 route dampening is not configured.
Configuring BGP VPNv6 optimal route selection delay
4. Set the BGP VPNv6 optimal route selection delay timer.
By default, the BGP VPNv6 optimal route selection delay timer is 0 seconds, which means optimal route selection is not delayed.
Setting the delay time for responding to BGP VPNv6 recursive next hop changes
4. Set the delay time for responding to recursive next hop changes.
nexthop recursive-lookup [ non-critical-event ] delay [ delay-value ]
By default, BGP responds to recursive next hop changes immediately.
Configuring BGP VPNv6 routes to use private network next hops
By default, the device does not change the next hop attribute of a received BGP VPNv6 route. The next hop address of a BGP VPNv6 route is a public address. This feature changes the next hop of a BGP VPNv6 route received from a peer or peer group to an IP address in the VPN instance. The outgoing label of the VPNv6 route is also changed to an invalid value. For example, the device received a VPNv6 route and its next hop address is 10.1.1.1, which is a public address by default. After this feature is configured, the next hop address changes to private address 10.1.1.1.
After you configure this feature, the following applies:
· The device re-establishes the BGP sessions to the specified peer or to all peers in the specified peer group.
· The device receives a BGP VPNv6 route only when its RD is the same as a local RD.
· When advertising a BGP VPNv6 route received from the specified peer or peer group, the device does not change the route target attribute of the route.
· If you delete a VPN instance or its RD, BGP VPNv6 routes received from the specified peer or peer group and in the VPN instance will be deleted.
4. Change the next hop of a BGP VPNv6 route received from a peer or peer group to a VPN instance address.
peer { group-name | ipv4-address [ mask-length ] } next-hop-vpn
By default, the device does not change the next hop attribute of a received BGP VPNv6 route, and the next hop belongs to the public network.
Changing the BGP VPNv6 route selection rules
For the priority of the settings configured by this feature in BGP route selection, see BGP overview in Layer 3—IP Routing Configuration Guide.
Preferring routes learned from a peer or peer group during optimal route selection
4. Prefer routes learned from the specified peer or peer group during optimal route selection.
peer { group-name | ipv4-address [ mask-length ] } high-priority [ preferred ]
By default, routes learned from a peer or peer group do not take precedence over routes learned from other peers or peer groups.
This command takes effect only on BGP routes that are learned in the current address family, and it does not take effect on BGP routes that are added to other BGP routing tables.
Preferring routes with the specified type of next hop addresses during optimal route selection
4. Prefer routes with the specified type of next hop addresses during optimal route selection.
bestroute nexthop-priority { ipv4 | ipv6 } [ preferred ]
By default, BGP prefers routes with IPv4 next hop addresses.
Advertising BGP RPKI validation state to a peer or peer group
BGP advertises the BGP RPKI validation state to a peer or peer group through the extended community attribute. For more information about BGP RPKI, see BGP configuration in Layer 3—IP Routing Configuration Guide.
4. Advertise the BGP RPKI validation state to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise origin-as-validation
By default, BGP does not advertise the BGP RPKI validation state.
Configuring inter-AS IPv6 VPN option A
Inter-AS IPv6 VPN option A applies to scenarios where the number of VPNs and that of VPN routes on the PEs are relatively small.
To configure inter-AS IPv6 option A, perform the following tasks:
· Configure basic IPv6 MPLS L3VPN on each AS.
· Configure VPN instances on both PEs and ASBRs. The VPN instances on PEs allow CEs to access the network, and those on ASBRs are for access of the peer ASBRs.
In the inter-AS IPv6 VPN option A solution, for the same IPv6 VPN, the route targets configured on the PEs must match those configured on the ASBRs in the same AS. This makes sure VPN routes sent by the PEs (or ASBRs) can be received by the ASBRs (or PEs). Route targets configured on the PEs in different ASs do not have such requirements.
Configuring inter-AS IPv6 VPN option B
An ASBR always uses its address as the next hop of VPNv6 routes advertised to an MP-IBGP peer regardless of the configuration of the peer next-hop-local command.
Configuring a PE
Configure basic IPv6 MPLS L3VPN, and specify the ASBR in the same AS as an MP-IBGP peer. The route targets for the VPN instances on the PEs in different ASs must match for the same IPv6 VPN.
Configuring an ASBR
2. Enable MPLS and LDP on the interface connected to an internal router of the AS:
a. Configure an LSR ID for the local LSR.
mpls lsr-id lsr-id
By default, no LSR ID is configured.
b. Enable LDP on the local LSR and enter LDP view.
mpls ldp
By default, LDP is disabled.
c. Return to system view.
d. Enter interface view of the interface connected to an internal router of the AS.
e. Enable MPLS on the interface.
mpls enable
By default, MPLS is disabled on the interface.
f. Enable MPLS LDP on the interface.
mpls ldp enable
By default, MPLS LDP is disabled on the interface.
3. Enable MPLS on the interface connected to the remote ASBR:
a. Enter interface view of the interface connected to the remote ASBR.
b. Enable MPLS on the interface.
mpls enable
4. Enter BGP instance view.
5. Configure PEs in the same AS as IBGP peers and ASBRs in different ASs as EBGP peers.
6. Enter BGP VPNv6 address family view.
7. Enable BGP to exchange VPNv6 routes with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange VPNv6 routing information with a peer.
8. Disable route target filtering of received VPNv6 routes.
undo policy vpn-target
Configuring inter-AS IPv6 VPN option C (method 1)
Before you configure inter-AS option C, perform the following tasks:
· Configure BGP on the PE or ASBR to advertise the route to the PE. For more information, see BGP configuration in Layer 3—IP Routing Configuration Guide.
· Configure a VPN instance on the PE.
· Configure routing between the PE and CE.
Configuring a PE
3. Configure the ASBR in the same AS as an IBGP peer and the PE in another AS as an EBGP peer
4. Enter BGP IPv4 unicast address family view.
5. Enable BGP to exchange BGP IPv4 unicast routes with the ASBR in the same AS.
By default, the PE does not exchange BGP IPv4 unicast routes with any peer.
6. Enable BGP to exchange labeled routes with the ASBR in the same AS.
peer { group-name | ipv4-address [ mask-length ] } label-route-capability
By default, the PE does not advertise labeled routes to any IPv4 peer or peer group.
7. Return to BGP instance view.
8. Enter BGP VPNv6 address family view.
9. Enable BGP to exchange BGP VPNv6 routing information with the EBGP peer.
peer ipv4-address [ mask-length ] enable
By default, the PE does not exchange labeled routes with an IPv4 peer.
10. (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
Execute this command on the RR so the RR does not change the next hop of advertised VPNv6 routes.
Configuring an ASBR-PE
2. Configure a routing policy:
a. Create a routing policy, and enter routing policy view.
b. Match IPv4 routes carrying labels.
if-match mpls-label
By default, no MPLS label match criterion is configured.
You can configure if-match clauses in the routing policy to filter routes. Routes surviving the filtering are assigned labels, and all others are advertised as common IPv4 routes.
c. Set labels for IPv4 routes.
apply mpls-label
By default, no MPLS label is set for IPv4 routes.
d. Return to system view.
3. Enable MPLS and LDP on the interface connected to an internal router of the AS:
mpls lsr-id lsr-id
By default, no LSR
b. Enable LDP for the local LSR and enter LDP view.
mpls ldp
mpls enable
mpls ldp enable
4. Enable MPLS on the interface connected to the remote ASBR:
mpls enable
5. Enter BGP instance view.
6. Configure the PE in the same AS as an IBGP peer and the ASBR in another AS as an EBGP peer.
7. Create the BGP IPv4 unicast address family and enter its view.
8. Enable IPv4 unicast route exchange with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange IPv4 unicast routes with any peer.
9. Enable labeled IPv4 route exchange with the PE in the same AS and the ASBR in another AS.
By default, BGP cannot exchange labeled IPv4 routes with any peer.
10. Configure the ASBR to set itself as the next hop of routes advertised to the PE in the local AS.
By default, BGP does not use its address as the next hop of routes.
11. Apply a routing policy to routes incoming from or outgoing to a peer or peer group.
Configuring inter-AS IPv6 VPN option C (method 2)
Before you configure inter-AS option C (method 2), perform the following tasks:
Configuring a PE
3. Configure the PE in another AS as an EBGP peer.
4. Enter BGP VPNv6 address family view.
5. Enable BGP to exchange BGP VPNv6 routing information with the EBGP peer.
By default, the PE does not exchange VPNv6 routes with a peer.
6. (Optional.) Configure the PE to not change the next hop of routes advertised to the peer.
if-match mpls-label
apply mpls-label
mpls lsr-id lsr-id
mpls ldp
mpls enable
mpls ldp enable
mpls enable
6. Configure the ASBR in another AS as an EBGP peer.
8. Enable IPv4 unicast route exchange with the ASBR in another AS.
By default, BGP cannot exchange IPv4 unicast routes with a peer.
9. Enable labeled IPv4 route exchange with the ASBR in another AS.
By default, BGP cannot exchange labeled IPv4 routes with a peer.
By default, BGP does not use its address as the next hop of routes advertised to IBGP peers and peer groups.
Configuring HoVPN
Configuring the UPE
Configure basic MPLS L3VPN settings on the UPE.
Configuring the SPE
3. Specify a BGP peer or peer group.
5. Enable BGP VPNv4 route exchange with the peer or peer group.
By default, BGP does not exchange VPNv4 routes with any peer.
6. Specify the BGP peer or peer group as a UPE.
peer { group-name | ipv4-address [ mask-length ] } upe
By default, no peer is a UPE.
7. Advertise routes to the UPE.
¡ Advertise a default VPN route to the UPE.
peer { group-name | ipv4-address [ mask-length ] } default-route-advertise vpn-instance vpn-instance-name
The device advertises a default route using the local address as the next hop to the UPE, regardless of whether the default route exists in the local routing table.
¡ Advertise routes permitted by a routing policy to the UPE.
peer { group-name | ipv4-address [ mask-length ] } upe route-policy route-policy-name export
By default, no route is advertised to the UPE.
Do not execute both commands.
8. Return to BGP instance view.
9. Create a BGP-VPN instance and enter BGP-VPN instance view.
You do not need to associate the VPN instance to an interface on the SPE.
This step adds the learned VPNv4 routes to the BGP routing table of the VPN instance.
Configuring route re-origination
In an HoVPN network, different UPEs communicate with each other through MPEs and SPEs. You can configure route re-origination on MPEs to reduce the number of private network labels that a UPE receives for VPNv6 routes.
As shown in Figure 50, if a network contains many UPEs that use the per-VPN-instance label allocation mode, and the MPEs in the network use the per-next-hop label allocation mode, the SPE will receive a large number of labels, which might cause traffic forwarding errors.
To resolve this issue, you can configure route re-origination on MPEs. The MPEs then can redistribute the BGP routes received from UPEs into local VPN instances and reoriginate these routes. The MPEs can modify the information of the reoriginated routes. After setting the per-VPN instance label allocation mode, the MPEs only need to allocate the number of VPN labels equal to the number of local VPN instances, regardless of the number of UPEs. The SPE only needs to receive the VPN labels allocated by the MPEs, significantly reducing the resource load on the SPE.
Figure 50 Route re-origination
This feature can reoriginate the BGP routes that are imported into a local VPN instance and have a different RD from that of the local VPN instance. It cannot reoriginate the BGP routes that are received from remote peers and have the same RD as that of the local VPN instance.
4. Enter BGP-VPN IPv6 unicast address family view.
5. Configure the device to re-originate the optimal routes in the VPN instance and advertise the re-originated routes to VPNv6 peers.
advertise route-reoriginate [ route-policy route-policy-name ] [ replace-rt ]
By default, the device does not re-originate the optimal routes in a VPN instance, and it sends the original VPNv6 routes to VPNv6 peers.
About IPv6 MPLS L3VPN FRR
You can use the following methods to configure IPv6 MPLS L3VPN FRR:
· Method 1—Execute the pic command in BGP-VPN IPv6 unicast address family view or BGP VPNv6 address family view. The device calculates a backup next hop for each BGP route in the VPN instance if there are two or more unequal-cost routes to reach the destination.
· Method 2—Execute the fast-reroute route-policy command in BGP-VPN IPv6 unicast address family view to use a routing policy. In the routing policy, specify a backup next hop by using the apply fast-reroute backup-nexthop command. The backup next hop calculated by the device must be the same as the specified backup next hop. Otherwise, the device does not generate a backup next hop for the primary route. You can also configure if-match clauses in the routing policy to identify the routes protected by FRR.
If both methods are configured, Method 2 takes precedence over Method 1.
Executing the pic command in BGP-VPN IPv6 unicast address family view or BGP VPNv6 address family view might cause routing loops. Use it with caution.
Configuring FRR by using a routing policy
2. Configure BFD.
¡ Enable MPLS BFD.
mpls bfd enable
By default, MPLS BFD is disabled.
The mpls bfd enable command applies to VPNv6 route backup for a VPNv6 route and IPv6 route backup for a VPNv6 route.
For more information about this command, see MPLS Command Reference.
¡ Configure the source IP address for BFD echo packets.
bfd echo-source-ip ip-address
By default, the source IP address for BFD echo packets is not configured.
This command is required when echo-mode BFD is used to detect primary route connectivity in VPNv6 route backup for an IPv6 route. For more information about this command, see High Availability Command Reference.
3. Use BFD to test the connectivity of an LSP or MPLS TE tunnel.
¡ Configure BFD to test the connectivity of the LSP for the specified FEC.
mpls tunnel-bfd dest-addr mask-length [ discriminator local local-id remote remote-id [ bgp-lsp | isis-srlsp | ldp-lsp | ospf-srlsp | static-lsp ] | echo | nil-fec | ldp-fec ] [ template template-name ]
¡ Execute the following commands in sequence to configure BFD to test the connectivity of the MPLS TE tunnel for the tunnel interface:
interface tunnel number mode mpls-te
mpls tunnel-bfd [ discriminator local local-id remote remote-id | echo | reverse-lsp binding-sid label label-value ] [ template template-name ]
By default, BFD is not configured to test the connectivity of the LSP or MPLS TE tunnel.
This step is required for VPNv6 route backup for a VPNv6 route and IPv6 route backup for a VPNv6 route.
For more information about the commands in this step, see MPLS Command Reference.
4. Configure a routing policy:
a. Create a routing policy and enter routing policy view.
route-policy route-policy-name permit node node-number
b. Set the backup next hop for FRR.
apply ipv6 fast-reroute backup-nexthop ipv6-address
By default, no backup next hop address is set for FRR.
For more information about the commands, see Layer 3—IP Routing Command Reference
6. (Optional.) Use echo-mode BFD to detect the connectivity to the next hop of the primary route.
By default, ARP is used to detect the connectivity to the next hop.
Use this command if necessary in VPNv6 route backup an IPv6 route.
For more information about this command, see Layer 3—IP Routing Command Reference.
7. Enter BGP-VPN instance view.
8. Enter BGP-VPN IPv6 unicast address family view.
9. Apply a routing policy to FRR.
By default, no routing policy is applied to FRR.
The apply ipv6 fast-reroute backup-nexthop command can take effect in the routing policy that is being used. Other apply commands do not take effect.
For more information about the command, see BGP commands in Layer 3—IP Routing Command Reference.
Enabling MPLS L3VPN FRR for BGP-VPN IPv6 unicast address family or BGP VPNv6 address family
2. Configure BFD.
¡ Enable MPLS BFD.
mpls bfd enable
This command applies to VPNv6 route backup for a VPNv6 route and IPv6 route backup for a VPNv6 route. For more information about this command, see MPLS OAM commands in MPLS Command Reference.
This command is required when echo-mode BFD is used to detect primary route connectivity in VPNv6 route backup for an IPv6 route. For more information about this command, see BFD commands in High Availability Command Reference.
¡ Use BFD to test the connectivity of the LSP for the specified FEC.
By default, BFD is not used to test the connectivity of the LSP or MPLS TE tunnel.
For more information about the commands, see MPLS OAM commands in MPLS Command Reference.
5. (Optional.) Use echo-mode BFD to detect the connectivity to the next hop of the primary route.
6. Enter BGP-VPN IPv6 unicast address family view or BGP VPNv6 address family view.
¡ Enter BGP-VPN IPv6 unicast address family view.
¡ Enter BGP VPNv6 address family view.
7. Enable FRR for the address family.
pic
By default, FRR is disabled.
Before you configure an OSPFv3 sham link, perform the following tasks:
· Configure basic IPv6 MPLS L3VPN (OSPFv3 is used between PE and CE).
· Configure OSPFv3 in the LAN where customer CEs reside.
Redistributing the loopback interface address
2. Create a loopback interface and enter loopback interface view.
interface loopback interface-number
3. Associate the loopback interface with a VPN instance.
By default, the interface is not associated with any VPN instances and belongs to the public network.
4. Configure an IPv6 address for the loopback interface.
See Layer 3—IP Services Configuration Guide.
By default, no IPv6 address is configured for the loopback interface.
6. Enter BGP-VPN instance view.
7. Enter BGP-VPN IPv6 unicast address family view.
8. Redistribute direct routes into BGP (including the loopback interface address).
import-route direct
By default, no direct routes are redistributed into BGP.
Creating a sham link
2. Enter OSPFv3 view.
3. Enter OSPFv3 area view.
area area-id
4. Configure an OSPFv3 sham link.
sham-link source-ipv6-address destination-ipv6-address [ cost cost-value | dead dead-interval | hello hello-interval | instance instance-id | ipsec-profile profile-name | { hmac-sha-256 | hmac-sm3 } key-id { cipher | plain } string | keychain keychain-name | retransmit retrans-interval | trans-delay delay ] *
When CEs at different sites have the same AS number, configure the BGP AS number substitution feature to avoid route loss.
When a PE uses different interfaces to connect different CEs in a site, the BGP AS number substitution feature introduces a routing loop. To remove the routing loop, configure the SoO attribute on the PE.
For more information about the BGP AS number substitution feature and the SoO attribute, see "BGP AS number substitution and SoO attribute."
4. Enable the BGP AS number substitution feature.
peer { group-name | ipv6-address [ prefix-length ] } substitute-as
By default, BGP AS number substitution is disabled.
5. Enter BGP-VPN IPv6 unicast address family view.
6. (Optional.) Configure the SoO attribute for a BGP peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } soo site-of-origin
An Accumulated Interior Gateway Protocol (AIGP) administrative domain is a collection of multiple ASs that run the same IGP under one administrative control. Within the domain, BGP accumulates the IGP metrics all along the forwarding path for a route. Then, it uses the accumulated value as the AIGP attribute for the route to implement metric-based route selection.
By default, BGP does not advertise the AIGP attribute to its peers or peer groups. When BGP receives a route carrying the AIGP attribute, it ignores and removes the attribute before advertising the route to other peers or peer groups. Perform this task to enable BGP to advertise the AIGP attribute to its peers or peer groups.
With this feature enabled, a router processes the AIGP attribute in a received route as follows:
· If the router sets itself as the next hop for the route, it adds to the AIGP attribute value the IGP metric from itself to the original next hop and advertises the new AIGP attribute value.
· If the router does not set itself as the next hop for the route, it does not change the AIGP attribute value.
BGP uses the AIGP attribute to select the optimal route as follows:
· A route carrying the AIGP attribute takes precedence over a route not carrying the AIGP attribute.
· A route that has a smaller computed AIGP attribute value has a higher priority.
When the AIGP attribute of a route changes, BGP sends update messages for the route.
As a best practice, do not configure the peer aigp command on border routers of an AIGP administrative domain.
When a router receives a route not carrying the AIGP attribute, it does not advertise the AIGP attribute to a peer or peer group if you execute only the peer aigp command. To enable the router to advertise the AIGP attribute, you must execute both the peer aigp and apply aigp commands. For information about the apply aigp command, see the routing policy configuration in Layer 3—IP Routing Configuration Guide.
4. Configure BGP to advertise the AIGP attribute to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp
By default, BGP does not advertise the AIGP attribute to a peer or peer group and ignores the AIGP attributes in routes received from the peer or peer group.
5. (Optional.) Replace the MED value with AIGP value in routes advertised to the specified peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } aigp send med
By default, BGP does not replace the MED value with AIGP value in routes advertised to a peer or peer group.
Use this command to send the AIGP attribute to a peer or peer group that does not support AIGP.
By default, BGP advertises only one optimal route. When the optimal route fails, traffic forwarding will be interrupted until route convergence completes.
The BGP additional path (Add-Path) feature enables BGP to advertise multiple routes with the same prefix and different next hops to a peer or peer group. When the optimal route fails, the suboptimal route becomes the optimal route, shortening the traffic interruption time.
You can enable the BGP additional path sending, receiving, or both sending and receiving capabilities on a BGP router. For two BGP peers to successfully negotiate the additional path capabilities, make sure one end has the sending capability and the other end has the receiving capability.
4. Configure the BGP additional path capabilities.
peer { group-name | ipv4-address [ mask-length ] } additional-paths { receive | send } *
By default, no BGP additional path capabilities are configured.
5. Set the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } advertise additional-paths best number
By default, the maximum number of Add-Path optimal routes that can be advertised to a peer or peer group is 1.
6. Set the maximum total number of Add-Path optimal routes that can be advertised to all peers.
By default, the maximum total number of Add-Path optimal routes that can be advertised to all peers is 1.
Configuring the rule for adding BGP routes to the IP routing table and the route advertisement rule for VPN instances
Perform this task to configure the following features:
· Route adding rule—For multiple BGP routes to the same destination, BGP adds the optimal route with matching route targets of a VPN instance to the IP routing table of the VPN instance.
After the undo policy vpn-target command is executed, VPNv6 routes without matching route targets of the local VPN instance can be received. If the VPNv6 routes have the same RD as the local VPN instance, these routes can be selected in the BGP VPNv6 routing table as optimal routes. However, routes without matching route targets are invisible and unavailable in the BGP-VPN instance routing table and cannot be added to the routing table of the VPN instance. The BGP-VPN instance routing table uses the same optimal route selection result as the BGP VPNv6 routing table. Therefore, if a route without matching route targets is selected as the only optimal route in the BGP VPNv6 routing table, no optimal route can be added to the BGP-VPN instance routing table. Only the optimal route in the BGP-VPN instance routing table can be added to the VPN instance IP routing table. Therefore, the BGP route without matching route targets cannot be added to the VPN instance IP routing table, so packets destined for the destination address of that route cannot be forwarded.
You can configure this feature to resolve this issue. With this feature configured, for BGP routes to the same destination address, BGP adds the optimal route with the same route targets as a VPN instance to the IP routing table of the VPN instance.
For example, the import target of VPN instance vpna is 10:1. The BGP routing table of VPN instance vpna contains two routes to destination address 3::3, which are 3::3 <RT: 10:1> and 3::3 <RT: 20:1>, and 3::3 <RT: 20:1>is the optimal route. After you configure this feature, BGP will add 3::3 <RT: 10:1> to the IP routing table of VPN instance vpna, because this route has the same import target as the VPN instance.
· Route advertisement rule—When the optimal route to a destination address cannot be advertised to peers, the device advertises the suboptimal route to the destination address from the routes that can be advertised. The device does not advertise any route for a destination address only if no routes to the destination address can be advertised.
The BGP routing table of a VPN instance contains the routes in the IP routing table of the VPN instance, so the routing table of a BGP address family might contain routes that are not learned from that address family. For example, an IP prefix advertisement route learned from the BGP EVPN address family is added to the IP routing table of a VPN instance, and the route also exists in the BGP routing tables of the BGP-VPN IPv6 unicast address family and BGP VPNv6 address family in the VPN instance. BGP cannot advertise the optimal route to peers in an address family if the optimal route is not learned from that address family, making the destination address of the route unreachable.
After you configure this feature, if the optimal route to a destination address cannot be advertised to peers, the device advertises the suboptimal route, and so forth until a route to the destination address is advertised successfully. The device does not advertise any route for a destination address only if no routes to the destination address can be advertised.
For example, the device learns the route with IP prefix 3::3/128 from both the BGP VPNv6 address family and BGP EVPN address family. Therefore, there will be two routes to destination address 3::3/128 in the BGP routing table of the BGP VPNv6 address family, and the one learned from the BGP EVPN address family is the optimal route. However, this optimal route cannot be advertised to BGP VPNv6 peers, because it was learned from the BGP EVPN address family. As a result, network nodes deployed with only BGP VPNv6 cannot obtain the route with IP prefix 3::3/128. After you configure this feature, the device will advertise the route with IP prefix 3::3/128 learned from the BGP VPNv6 address family to BGP VPNv6 peers, although this route is not the optimal route.
The bestroute same-rd command takes effect on BGP routes of all VPN instances. Use caution when you execute this command.
3. Configure BGP to add the optimal routes with the same route targets as a VPN instance to the IP routing table of the VPN instance, and allow BGP to advertise non-optimal routes to its peers.
bestroute same-rd
By default, BGP adds the optimal routes in the BGP routing table to the IP routing table of a VPN instance and advertises only the optimal routes to its peers.
About VPN Prefix ORF
VPN Prefix ORF introduction
By default, in large-scale networks with route reflectors, the BGP VPNv6 routes reflected by the RR usually include the VPN routes from all BGP-VPN instances on the route originating device. The current route limit measures can take effect only on address families. When the number of routes for RR reflection reaches the limit, unwanted BGP-VPN instance routes might occupy most of the receiving end's received routes, resulting in the receiving end not being able to receive the necessary BGP-VPN instance routes.
To resolve this issue, it is required to allow the RR to filter routes based on the BGP-VPN instances of the routes on the originator, implementing router filtering at the granularity of BGP-VPN instances in the BGP VPNv6 address families. Enabling the VPN Prefix Outbound Route Filtering (ORF) feature can resolve the above issue. This feature uses route-refresh messages to send VPN Prefix ORF entries (which contain information for route matching) to peers. Peers will withdraw all previously advertised routes that match the VPN Prefix ORF entries and when sending new routes to the local device, they must filter the routes using both the routing policy on the peer device and the received VPN Prefix ORF entries. Only routes that pass both filters will be sent to the local device. VPN Prefix ORF realizes the advertisement and reception of route control at the BGP-VPN instance granularity. It limits the number of routes at the source of route sending to reduce route exchanges between BGP peers and save network resources.
VPN Prefix ORF operating mechanism
After configuring this feature, the BGP session between the local device and the specified peer/peer group will be disconnected and reestablished for VPN Prefix ORF capability negotiation via Open messages. Negotiation can be successful only if the peer capability-advertise orf vpn-prefix command is configured on both ends of the BGP session. After successful negotiation, the device will be able to parse the route-refresh messages carrying VPN Prefix ORF entries sent by the remote end. A VPN Prefix ORF entry contains a <RD value, source device address> tuple.
NOTE: If the devices in the BGP session do not support the exchange of route-refresh messages, the VPN Prefix ORF entries will not be successfully sent. Configure the peer capability-advertise route-refresh command on both ends of the BGP session to enable the capability of exchanging route-refresh messages. For more information the peer capability-advertise route-refresh command, see BGP commands in Layer 3—IP Routing Command Reference. |
The VPN Prefix ORF feature uses the following conditions to determine whether to trigger sending VPN Prefix ORF entries:
· The <RD, source device address> tuple used to match VPN routes and the alarm threshold for the matching VPN routes, which are set by using the vpn-prefix-quota command.
· The maximum number of routes supported by a BGP-VPN instance, which is set by using the route-limit command.
After these conditions are set on the device, when the number of IPv4 or IPv6 unicast routes in a BGP-VPN instance exceeds the route limit, and the percentage of the routes that match the tuple in the BGP-VPN instance exceeds the alarm threshold:
1. The device checks if there are other BGP-VPN instances configured with the same tuple.
¡ If yes, go to step 2.
¡ If not, go to step 3.
2. The device checks if the number of routes in these BGP-VPN instances has exceeded the route limit and if the number of routes matching the tuple has exceeded the alarm threshold.
¡ If yes, go to step 3.
¡ If not, the BGP-VPN instance that contains routes exceeding the route limit will continue to receive routes and repeat step 2.
3. The device sends a route-refresh message with VPN Prefix ORF entries to the peer/peer group specified by the peer capability-advertise orf vpn-prefix command.
TIP: Among the BGP-VPN instances configured with the same tuple, if the number of routes matching the tuple in some BGP-VPN instances has exceeded the alarm threshold, while some BGP-VPN instances have not received any routes matching the tuple, it indicates that these instances cannot receive routes matching the tuple. The device will not consider these BGP-VPN instances when determining whether to trigger sending VPN Prefix ORF entries. |
A VPN Prefix ORF entry contains a <RD value, source device address> tuple. The values of RD and source device address are those specified by using the vpn-prefix-quota command.
After receiving a route-refresh message carrying a VPN Prefix ORF entry from the local device, the specified peer/peer group operates as follows:
· Withdraws all BGP VPNv6 routes that match both the RD and source device address in the VPN Prefix ORF entry. (The route information matching the source device address in the VPN Prefix ORF entry is the next hop attribute of the route.)
· No longer sends BGP VPNv6 routes that match the VPN Prefix ORF entry to the local device.
If the device has previously advertised VPN Prefix ORF entries, the entries will remain effective on the peer to filter route advertisement. You can execute the clear bgp vpn-prefix-orf command to withdraw the previously advertised VPN Prefix ORF entries, so that the peer can re-advertise routes that were withdrawn or filtered due to the VPN Prefix ORF entries.
VPN Prefix ORF networking example
As shown in Figure 51, VPN instances are configured on each PE. The RR reflects routes from PE 1, PE 2, and PE 3 within the same AS. Both PE 1 and PE 2 have successfully negotiated the VPN Prefix ORF capabilities with the RR. PE 1 specifies the tuple as <RD31, PE3> and the alarm threshold as 70% in the BGP-VPN instances corresponding to VPN1 and VPN2 by using the vpn-prefix-quota command. PE 2 specifies the tuple as <RD31, PE3> and the alarm threshold as 70% in the BGP-VPN instance corresponding to VPN1 by using the vpn-prefix-quota command.
Figure 51 VPN Prefix ORF application network diagram
PE 3 advertises routes of VPN1 through BGP VPNv6. When the advertised routes cause BGP-VPN instances on PE 1 and PE 2 to exceed the route limit, VPN Prefix ORF will function on PE 1 and PE 2 as follows:
· On PE 1
The number of routes in the BGP-VPN instance for VPN1 exceeded the limit, and the number of routes matching <RD31, PE3> exceeded 70% of the total routes. However, PE 1 would not send route-refresh messages carrying the VPN Prefix ORF entries because the BGP-VPN instances for VPN2 and VPN1 have the same tuple <RD31, PE3>, and PE 1 could still receive VPN1 routes carrying RT 1 and RT 2 from PE 3 for the BGP-VPN instance corresponding to VPN2. PE 1 will send a route-refresh message carrying a VPN Prefix ORF entry to the RR only when both the BGP-VPN instances for VPN1 and VPN2 have exceeded the route limit and the VPN routes matching the <RD31, PE3> tuple have also exceeded the alarm threshold. The advertised VPN Prefix ORF entry contains the following information: <RD31, min (maximum route count supported by BGP-VPN instance for VPN1, maximum route count supported by BGP-VPN instance for VPN2), PE3 address>.
After receiving the route-refresh message with VPN Prefix ORF entry, the RR will withdraw the advertised routes that meet the following conditions from PE 1 and will no longer advertise the routes that meet the following conditions:
¡ The RD carried by the routes is RD31.
¡ The next hop address of the routes is the address of PE 3.
Figure 52 VPN Prefix ORF taking effect
· On PE 2
When the number of routes in the BGP-VPN instance for VPN1 exceeds the limit, PE 2 will immediately send a route-refresh message carrying a VPN Prefix ORF entry to the RR because no other BGP-VPN instances have specified the same tuple. The advertised VPN Prefix ORF entry contains the following information: <RD31, maximum route count supported by BGP-VPN instance for VPN1, PE3 address>.
After receiving the route-refresh message carrying the VPN Prefix ORF entry, the RR will withdraw the advertised routes that meet the following conditions from PE 2 and will no longer advertise routes that meet the following conditions to PE 2:
In the current software version, only VPN Prefix ORF within the same AS is supported. VPN Prefix ORF across ASs is not supported.
You must configure the route-limit, vpn-prefix-quota route-distinguisher, and peer capability-advertise orf vpn-prefix commands at the same time for VPN Prefix ORF to operate properly.
Configuring a VPN instance
2. Create a VPN instance and enter its view.
3. Configure an RD for the VPN instance.
4. Configure route targets for the VPN instance.
By default, no route targets are configured for a VPN instance.
Configure the conditions that trigger the VPN Prefix ORF mechanism
5. Set the maximum number of routes supported by the BGP-VPN instance.
route-limit limit
By default, no limit is set to the number of routes supported by a BGP-VPN instance.
6. Set the tuple for routing matching and set the alarm threshold for the routes matching the tuple.
vpn-prefix-quota route-distinguisher route-distinguisher source-address { ipv4-address | ipv6-address } quota threshold
By default, no tuple or alarm threshold is set, and no alarm information will be triggered for tuple-matching routes.
Enabling the VPN Prefix ORF feature
1. Enter system view.
4. Enable negotiating VPN Prefix ORF capabilities with the specified BGP peer or peer group.
peer { group-name | ipv4-address [ mask-length ] |ipv6-address [ prefix-length ] } capability-advertise orf vpn-prefix { both | send | receive }
By default, the local end does not negotiate VPN Prefix ORF capabilities with BGP peer/peer group.
5. (Optional.) Withdraw the advertised VPN Prefix ORF entries.
a. Execute the following commands in sequence to return to user view:
b. Withdraw the advertised VPN Prefix ORF entries.
clear bgp [ instance instance-name ] vpn-prefix-orf [ vpn-instance vpn-instance-name | route-distinguisher route-distinguisher source-address { ipv4-address | ipv6-address } ]
Configuring route replication
Configuring the public instance
Configure the public instance to enable the mutual access between public network and private network users.
In an IPv6 MPLS L3VPN network, for the public network and the VPN network to communicate with each other through route target matching, perform the following tasks:
· Configure matching route targets for the public instance and VPN instance.
· Use the route-replicate enable command in BGP instance view to enable mutual BGP route replication between the public and VPN instances.
2. Enter public instance view.
ip public-instance
3. Configure an RD for the public instance.
By default, no RD is configured for the public instance.
4. Configure a route target for the public instance.
By default, no route target is configured for the public instance.
5. Enter public instance IPv6 address family view.
address-family ipv6
6. Configure a route target for the IPv6 address family view of the public instance.
By default, no route target is configured for the IPv6 address family view of the public instance.
7. Apply an import routing policy to the public instance.
8. Apply an export routing policy to the public instance.
9. (Optional.) Set the maximum number of active route prefixes supported by the public instance. Choose one or more of the following tasks:
¡ Execute the following commands in sequence to set the maximum number of active route prefixes supported by the public instance:
¡ Set the maximum number of IPv6 route prefixes supported by the public instance.
By default, no limit is set for the number of active route prefixes supported by the public network instance.
The configuration in public instance IPv6 address family view takes precedence over the configuration in public instance view.
Configuring route replication for public and VPN instances
In an IPv6 BGP/IPv6 MPLS L3VPN network, only VPN instances that have matching route targets can communicate with each other.
The route replication feature provides the following functions:
· Enables a VPN instance to communicate with the public network or other VPN instances by replicating routes from the public network or other VPN instances.
· Enables the public network to communicate with a VPN instance by replicating routes from the VPN instance.
In an intelligent traffic control network, traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network, configure this feature to replicate routes from the public network to the VPN instances.
VLINK direct routes are generated based on ND entries learned by interfaces. The route-replicate from vpn-instance protocol direct or route-replicate from public protocol direct command replicates VLINK direct routes, but the VLINK direct routes cannot be added to the IPv6 FIB, causing traffic forwarding failures. To address this issue, you can specify the vlink-direct keyword to replicate VLINK direct routes and add the routes to the IPv6 FIB.
Configuring a VPN instance to replicate routes from the public network or another VPN instance
2. Enter VPN instance view.
3. Enter VPN instance IPv6 address family view.
address-family ipv6
4. Replicate routes from the public network or other VPN instances.
route-replicate from { public | vpn-instance vpn-instance-name } protocol { bgp4+ as-number | direct | static | unr | vlink-direct | { isisv6 | ospfv3 | ripng } process-id } [ advertise ] [ route-policy route-policy-name ]
By default, a VPN instance cannot replicate routes from the public network or other VPN instances.
Replicating routes from a VPN instance to the public network
ip public-instance
3. Enter public instance IPv6 address family view.
address-family ipv6
4. Replicate routes from a VPN instance to the public network.
route-replicate from vpn-instance vpn-instance-name protocol { bgp4+ as-number | direct | static | unr | vlink-direct | { isisv6 | ospfv3 | ripng } process-id } [ advertise ] [ route-policy route-policy-name ]
By default, the public network cannot replicate routes from VPN instances.
Configuring BGP route replication between public and VPN instances
In traffic cleaning scenarios, traffic between the public and private networks are filtered by firewalls and traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network under the protection of firewalls, BGP route replication between public and VPN instances is required.
By default, only VPN instances that have matching route targets can redistribute BGP routes from each other, while the public instance and VPN instances cannot. After you configure this feature, the public instance and VPN instances that have matching route targets can replicate BGP routes from each other, enabling communication between the public network and VPN users.
This feature also replicates the BGP route attributes, so that the device can select proper forwarding paths according to the route attributes.
After this feature is enabled, the public network and VPNs cannot be isolated. Configure this feature only in specific scenarios, for example, the traffic cleaning scenario.
To use this feature to implement IPv6 route replication between the public instance and a VPN instance, make sure the VPN instance and the BGP IPv6 unicast address family have been created.
3. Enable BGP route replication between public and VPN instances.
By default, BGP route replication between public and VPN instances is disabled.
Enabling redistribution of multiple same-prefix routes with the same RD
Typically, if multiple same-prefix BGP routes have the same RD as a local BGP VPN instance or the BGP public instance, BGP redistributes only the best one of them into the routing table of that BGP VPN instance or the BGP public instance.
To redistribute multiple same-prefix routes with the same RD into a BGP routing table, perform this task.
This feature enables redistribution of multiple active same-prefix BGP routes that have the same RD, as follows:
· If these routes are in the routing table of a BGP VPN instance or the BGP public instance, BGP redistributes them into the BGP VPNv4, VPNv6, or EVPN routing table, regardless of their route priorities.
· If these routes are in the BGP VPNv4, VPNv6, or EVPN routing table, BGP redistributes them into the BGP VPN instance or the BGP public instance, regardless of their route priorities when the following conditions are met:
¡ The routes have the same RD has the VPN or public instance.
¡ The routes match the import RTs as the VPN or public instance.
Enabled in BGP instance view, this feature applies to redistribution of routes from a BGP VPN instance or the BGP public instance into the BGP VPNv4, VPNv6, or EVPN routing table, and vice versa.
Enabled in the view of an address family, this feature takes effect only on redistribution of routes into the BGP routing table for that address family.
2. Enter a BGP address family view.
¡ Enter BGP instance view.
¡ Execute the following commands in sequence to enter BGP IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP-VPN IPv6 unicast address family view:
¡ Execute the following commands in sequence to enter BGP VPNv6 address family view:
3. Enable redistribution of multiple same-prefix routes with the same RD.
vpn-route cross multipath
By default, redistribution of multiple same-prefix routes with the same RD is disabled.
Enabling prioritized withdrawal of specific routes
This feature enables BGP to send the withdrawal messages of specific routes prior to other routes. This can achieve fast switchover of traffic on the specified routes to available routes to reduce the traffic interruption time.
4. Enable prioritized withdrawal of the routes that match the specified routing policy.
By default, BGP does not send the withdrawal messages of specific routes prior to other routes.
Enabling logging for BGP route flapping
This feature enables BGP to generate logs for BGP route flappings that trigger log generation. The generated logs are sent to the information center. For the logs to be output correctly, you must also configure information center on the device. For more information about the information center, see Network Management and Monitoring Configuration Guide.
4. Enable logging for BGP route flapping.
By default, logging for BGP route flapping is disabled.
Display and maintenance commands for IPv6 MPLS L3VPN
Resetting BGP connections
You can soft-reset or reset BGP sessions to apply new BGP configurations. A soft reset operation updates BGP routing information without tearing down BGP connections. A reset operation updates BGP routing information by tearing down, and then re-establishing BGP connections. Soft reset requires that BGP peers have route refresh capability.
Execute the following commands in user view to soft reset or reset BGP connections:
Task |
Command |
Manually soft reset BGP sessions for VPNv6 address family. |
refresh bgp [ instance instance-name ] { ipv4-address [ mask-length ] | all | external | group group-name | internal } { export | import } vpnv6 |
Reset BGP sessions for VPNv6 address family. |
reset bgp [ instance instance-name ] { as-number | ipv4-address [ mask-length ] | all | external | internal | group group-name } vpnv6 |
For more information about the refresh bgp vpnv6 and reset bgp vpnv6 commands, see Layer 3—IP Routing Command Reference.
Displaying and maintaining IPv6 MPLS L3VPN information
Execute the display commands in any view and reset commands in user view to display and maintain IPv6 MPLS L3VPN:
Task |
Command |
Display BGP VPNv6 peer group information. |
display bgp [ instance instance-name ] group vpnv6 [ group-name group-name ] |
Display BGP VPNv6 peer information. |
display bgp [ instance instance-name ] peer vpnv6 [ ipv4-address mask-length | { ipv4-address | group-name group-name } log-info | [ ipv4-address ] verbose ] |
Display BGP VPNv6 routes. |
display bgp [ instance instance-name ] routing-table vpnv6 [ [ route-distinguisher route-distinguisher ] [ ipv6-address prefix-length [ advertise-info ] | as-path-acl as-path-acl-number | as-path-regular-expression regular-expression | [ statistics ] { community [ community-number&<1-32> | aa:nn&<1-32> ] [ internet | no-advertise | no-export | no-export-subconfed ] [ whole-match ] | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } ] | peer { ipv4-address | ipv6-address } { advertised-routes | received-routes } [ ipv6-address prefix-length [ verbose ] | statistics ] | statistics ] display bgp [ instance instance-name ] routing-table vpnv6 [ route-distinguisher route-distinguisher ] [ ipv6-address prefix-length ] [ statistics ] { large-community [ aa:bb:cc&<1-32> ] | large-community-list { basic-large-comm-list-number | adv-large-comm-list-number | large-comm-list-name } } [ whole-match ] display bgp [ instance instance-name ] routing-table vpnv6 [ route-distinguisher route-distinguisher ] [ ipv6-address prefix-length ] statistics source { evpn-remote-import | local | local-import | remote-import } display bgp [ instance instance-name ] routing-table vpnv6 [ same-rd-selected ] display bgp [ instance instance-name ] routing-table vpnv6 peer { ipv4-address | ipv6-address } { accepted-routes | not-accepted-routes } display bgp [ instance instance-name ] routing-table vpnv6 [ route-distinguisher route-distinguisher ] time-range min-time max-time |
Display BGP VPNv6 route dampening parameters. |
display bgp [ instance instance-name ] dampening parameter vpnv6 |
Display information about dampened BGP VPNv6 routes. |
display bgp [ instance instance-name ] routing-table dampened vpnv6 |
Display BGP VPNv6 route flapping information. |
display bgp [ instance instance-name ] routing-table flap-info vpnv6 [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } ] |
Display BGP VPNv6 route source information. |
display bgp [ instance instance-name ] routing-table vpnv6 source-type |
Display incoming labels for all BGP VPNv6 routes. |
display bgp [ instance instance-name ] routing-table vpnv6 inlabel |
Display outgoing labels for all BGP VPNv6 routes. |
display bgp [ instance instance-name ] routing-table vpnv6 outlabel |
Display BGP VPNv6 address family update group information. |
display bgp [ instance instance-name ] update-group vpnv6 [ ipv4-address ] |
Display BGP peer and routing summary information. |
display bgp [ instance instance-name ] vpnv6 summary |
Display route targets sourcing from a VPN instance. |
display bgp [ instance instance-name ] route-target l3vpn [ ipv6 ] [ vpn-instance vpn-instance-name ] |
Display received and advertised VPN Prefix ORF entries. |
display bgp [ instance instance-name ] vpn-prefix-orf [ route-distinguisher route-distinguisher source-address { ipv4-address | ipv6-address } ] evpn |
Display information about a specified VPN instance or all VPN instances. |
display ip vpn-instance [ instance-name vpn-instance-name | count ] |
Display IPv6 FIB information for a VPN instance. |
display ipv6 fib vpn-instance vpn-instance-name [ ipv6-address [ prefix-length ] ] |
Display the IPv6 routing table for a VPN instance. |
display ipv6 routing-table vpn-instance vpn-instance-name [ verbose ] |
Display OSPFv3 sham link information. |
display ospfv3 [ process-id ] [ area area-id ] sham-link [ verbose ] |
Clear BGP VPNv6 route dampening information and release dampened routes. |
reset bgp [ instance instance-name ] dampening vpnv6 [ ipv6-address prefix-length ] |
Clear BGP VPNv6 route flapping statistics. |
reset bgp [ instance instance-name ] flap-info vpnv6 [ ipv6-address prefix-length | as-path-acl { as-path-acl-number | as-path-acl-name } | peer [ ipv4-address [ mask-length ] | peer ipv6-address [ prefix-length ] ] ] |
For more information about the display ipv6 routing-table, display bgp group vpnv6, display bgp peer vpnv6, and display bgp update-group vpnv6 commands, see Layer 3—IP Routing Command Reference.
IPv6 MPLS L3VPN configuration examples
Example: Configuring IPv6 MPLS L3VPNs
CE 1 and CE 3 belong to VPN 1. CE 2 and CE 4 belong to VPN 2.
VPN 1 uses route target attributes 111:1. VPN 2 uses route target attributes 222:2. Users of different VPNs cannot access each other.
Run EBGP between CEs and PEs to exchange VPN routing information.
PEs use OSPF to communicate with each other and use MP-IBGP to exchange VPN routing information.
Table 21 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
2001:1::1/96 |
P |
Loop0 |
2.2.2.9/32 |
PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/4 |
172.1.1.2/24 |
XGE3/0/1 |
2001:1::2/96 |
XGE3/0/5 |
172.2.1.1/24 |
XGE3/0/2 |
2001:2::2/96 |
PE 2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/4 |
172.1.1.1/24 |
XGE3/0/1 |
2001:3::2/96 |
CE 2 |
XGE3/0/1 |
2001:2::1/96 |
XGE3/0/2 |
2001:4::2/96 |
CE 3 |
XGE3/0/1 |
2001:3::1/96 |
XGE3/0/4 |
172.2.1.2/24 |
CE 4 |
XGE3/0/1 |
2001:4::1/96 |
1. Configure OSPF on the MPLS backbone to ensure IP connectivity among the PEs and the P router:
# Configure PE 1.
[Sysname] sysname PE1
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] interface ten-gigabitethernet 3/0/4
[PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/4] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1] quit
# Configure the P router.
[Sysname] sysname P
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface ten-gigabitethernet 3/0/4
[P-Ten-GigabitEthernet3/0/4] ip address 172.1.1.2 24
[P-Ten-GigabitEthernet3/0/4] quit
[P] interface ten-gigabitethernet 3/0/5
[P-Ten-GigabitEthernet3/0/5] ip address 172.2.1.1 24
[P-Ten-GigabitEthernet3/0/5] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
[Sysname] sysname PE2
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 3.3.3.9 32
[PE2-LoopBack0] quit
[PE2] interface ten-gigabitethernet 3/0/4
[PE2-Ten-GigabitEthernet3/0/4] ip address 172.2.1.2 24
[PE2-Ten-GigabitEthernet3/0/4] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[PE2-ospf-1] quit
# Execute the display ospf peer command to verify that OSPF adjacencies in Full state have been established between PE 1, P, and PE 2. Execute the display ip routing-table command to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
2. Configure basic MPLS and enable MPLS LDP on the MPLS backbone to establish LDP LSPs:
# Configure PE 1.
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/4] mpls enable
[PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Ten-GigabitEthernet3/0/4] mpls enable
[P-Ten-GigabitEthernet3/0/4] mpls ldp enable
[P-Ten-GigabitEthernet3/0/5] mpls enable
[P-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Configure PE 2.
[PE2] mpls lsr-id 3.3.3.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/4] mpls enable
[PE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Execute the display mpls ldp peer command to verify that LDP sessions in Operational state have been established between PE 1, P, and PE 2. Execute the display mpls ldp lsp command to verify that the LSPs have been established by LDP. (Details not shown.)
3. Configure IPv6 VPN instances on the PEs to allow CE access:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 100:2
[PE1-vpn-instance-vpn2] vpn-target 222:2
[PE1-vpn-instance-vpn2] quit
[PE1] interface ten-gigabitethernet 3/0/1
[PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::2 96
[PE1-Ten-GigabitEthernet3/0/1] quit
[PE1] interface ten-gigabitethernet 3/0/2
[PE1-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn2
[PE1-Ten-GigabitEthernet3/0/2] ipv6 address 2001:2::2 96
[PE1-Ten-GigabitEthernet3/0/2] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-vpn-instance-vpn1] quit
[PE2] ip vpn-instance vpn2
[PE2-vpn-instance-vpn2] route-distinguisher 200:2
[PE2-vpn-instance-vpn2] vpn-target 222:2
[PE2-vpn-instance-vpn2] quit
[PE2] interface ten-gigabitethernet 3/0/1
[PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 2001:3::2 96
[PE2-Ten-GigabitEthernet3/0/1] quit
[PE2] interface ten-gigabitethernet 3/0/2
[PE2-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn2
[PE2-Ten-GigabitEthernet3/0/2] ipv6 address 2001:4::2 96
[PE2-Ten-GigabitEthernet3/0/2] quit
# Configure CE 1.
[Sysname] sysname CE1
[CE1] interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::1 96
[CE1-Ten-GigabitEthernet3/0/1] quit
# Configure CE 2.
[Sysname] sysname CE2
[CE2] interface ten-gigabitethernet 3/0/1
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::1 96
[CE2-Ten-GigabitEthernet3/0/1] quit
# Configure CE 3.
[Sysname] sysname CE3
[CE3] interface ten-gigabitethernet 3/0/1
[CE3-Ten-GigabitEthernet3/0/1] ipv6 address 2001:3::1 96
[CE3-Ten-GigabitEthernet3/0/1] quit
# Configure CE 4.
[Sysname] sysname CE4
[CE4] interface ten-gigabitethernet 3/0/1
[CE4-Ten-GigabitEthernet3/0/1] ipv6 address 2001:4::1 96
[CE4-Ten-GigabitEthernet3/0/1] quit
# Execute the display ip vpn-instance command on the PEs to display information about the VPN instances. Use the ping command on the PEs to verify that the PEs can ping their attached CEs. (Details not shown.)
4. Establish EBGP peer relationships between the PEs and CEs to allow them to exchange VPN routes:
# Configure CE 1.
[CE1] bgp 65410
[CE1-bgp-default] router-id 4.4.4.4
[CE1-bgp-default] peer 2001:1::2 as-number 100
[CE1-bgp-default] address-family ipv6 unicast
[CE1-bgp-default-ipv6] peer 2001:1::2 enable
[CE1-bgp-default-ipv6] import-route direct
[CE1-bgp-default-ipv6] quit
[CE1-bgp-default] quit
# Configure CE 2.
[CE2] bgp 65420
[CE2-bgp-default] router-id 5.5.5.5
[CE2-bgp-default] peer 2001:2::2 as-number 100
[CE2-bgp-default] address-family ipv6 unicast
[CE2-bgp-default-ipv6] peer 2001:2::2 enable
[CE2-bgp-default-ipv6] import-route direct
[CE2-bgp-default-ipv6] quit
[CE2-bgp-default] quit
# Configure CE 3.
[CE3] bgp 65430
[CE3-bgp-default] router-id 6.6.6.6
[CE3-bgp-default] peer 2001:3::2 as-number 100
[CE3-bgp-default] address-family ipv6 unicast
[CE3-bgp-default-ipv6] peer 2001:3::2 enable
[CE3-bgp-default-ipv6] import-route direct
[CE3-bgp-default-ipv6] quit
[CE3-bgp-default] quit
# Configure CE 4.
[CE4] bgp 65440
[CE4-bgp-default] router-id 7.7.7.7
[CE4-bgp-default] peer 2001:4::2 as-number 100
[CE4-bgp-default] address-family ipv6 unicast
[CE4-bgp-default-ipv6] peer 2001:4::2 enable
[CE4-bgp-default-ipv6] import-route direct
[CE4-bgp-default-ipv6] quit
[CE4-bgp-default] quit
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 2001:1::1 as-number 65410
[PE1-bgp-default-vpn1] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn1] peer 2001:1::1 enable
[PE1-bgp-default-ipv6-vpn1] quit
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] ip vpn-instance vpn2
[PE1-bgp-default-vpn2] peer 2001:2::1 as-number 65420
[PE1-bgp-default-vpn2] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn2] peer 2001:2::1 enable
[PE1-bgp-default-ipv6-vpn2] quit
[PE1-bgp-default-vpn2] quit
[PE1-bgp-default] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 2001:3::1 as-number 65430
[PE2-bgp-default-vpn1] address-family ipv6 unicast
[PE2-bgp-default-ipv6-vpn1] peer 2001:3::1 enable
[PE2-bgp-default-ipv6-vpn1] quit
[PE2-bgp-default-vpn1] quit
[PE2-bgp-default] ip vpn-instance vpn2
[PE2-bgp-default-vpn2] peer 2001:4::1 as-number 65440
[PE2-bgp-default-vpn2] address-family ipv6 unicast
[PE2-bgp-default-ipv6-vpn2] peer 2001:4::1 enable
[PE2-bgp-default-ipv6-vpn2] quit
[PE2-bgp-default-vpn2] quit
[PE2-bgp-default] quit
# Execute the display bgp peer ipv6 vpn-instance command on the PEs to verify that a BGP peer relationship in Established state has been established between a PE and a CE. (Details not shown.)
5. Configure an MP-IBGP peer relationship between the PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] address-family vpnv6
[PE1-bgp-default-vpnv6] peer 3.3.3.9 enable
[PE1-bgp-default-vpnv6] quit
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] address-family vpnv6
[PE2-bgp-default-vpnv6] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv6] quit
# Execute the display bgp peer vpnv6 command on the PEs to verify that a BGP peer relationship in Established state has been established between the PEs. (Details not shown.)
# Execute the display ipv6 routing-table vpn-instance command on the PEs. Take PE 1 for example.
[PE1] display ipv6 routing-table vpn-instance vpn1
Destinations : 5 Routes : 5
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 2001:1::/96 Protocol : Direct
NextHop : :: Preference: 0
Interface : XGE3/0/1 Cost : 0
Destination: 2001:1::2/128 Protocol : Direct
Destination: 2001:3::/96 Protocol : BGP4+
NextHop : ::FFFF:3.3.3.9 Preference: 255
Interface : XGE3/0/4 Cost : 0
Destination: FE80::/10 Protocol : Direct
[PE1] display ipv6 routing-table vpn-instance vpn2
Destination: 2001:2::/96 Protocol : Direct
Interface : XGE3/0/2 Cost : 0
Destination: 2001:2::2/128 Protocol : Direct
Destination: 2001:4::/96 Protocol : BGP4+
The output shows that PE 1 has routes to the remote CEs. Output on PE 2 is similar.
# Verify that CEs of the same VPN can ping each other, whereas those of different VPNs cannot. For example, CE 1 can ping CE 3 (2001:3::1), but cannot ping CE 4 (2001:4::1). (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 111:1 import-extcommunity
vpn-target 111:1 export-extcommunity
vpn-target 222:2 import-extcommunity
vpn-target 222:2 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
interface Ten-GigabitEthernet3/0/1
ipv6 address 2001:1::2/96
interface Ten-GigabitEthernet3/0/2
ipv6 address 2001:2::2/96
interface Ten-GigabitEthernet3/0/4
ip address 172.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
ip address 172.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
interface Ten-GigabitEthernet3/0/5
ip address 172.2.1.1 255.255.255.0
mpls enable
mpls ldp enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
ipv6 address 2001:3::2/96
ipv6 address 2001:4::2/96
ip address 172.2.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
return
· CE 1:
sysname CE1
ipv6 address 2001:1::1/96
bgp 65410
router-id 4.4.4.4
import-route direct
return
· CE 2:
sysname CE2
ipv6 address 2001:2::1/96
bgp 65420
router-id 5.5.5.5
import-route direct
return
· CE 3:
sysname CE3
ipv6 address 2001:3::1/96
bgp 65430
router-id 6.6.6.6
import-route direct
return
· CE 4:
sysname CE4
ipv6 address 2001:4::1/96
bgp 65440
router-id 7.7.7.7
import-route direct
return
Example: Configuring an IPv6 MPLS L3VPN over a GRE tunnel
CE 1 and CE 2 belong to VPN 1. The PEs support MPLS, while the P router does not support MPLS and provides only IP features.
On the backbone, use a GRE tunnel to encapsulate and forward packets for IPv6 MPLS L3VPN.
Configure tunnel policies on the PEs, and specify the tunnel type for VPN traffic as GRE.
Table 22 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
2001:1::1/96 |
P |
XGE3/0/4 |
172.1.1.2/24 |
PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/5 |
172.2.1.1/24 |
XGE3/0/1 |
2001:1::2/96 |
PE 2 |
Loop0 |
2.2.2.9/32 |
XGE3/0/5 |
172.1.1.1/24 |
XGE3/0/1 |
2001:2::2/96 |
Tunnel0 |
20.1.1.1/24 |
XGE3/0/4 |
172.2.1.2/24 |
CE 2 |
XGE3/0/1 |
2001:2::1/96 |
Tunnel0 |
20.1.1.2/24 |
1. Configure an IGP (OSPF in this example) on the MPLS backbone to ensure IP connectivity among the PEs and the P router.
# Configure PE 1.
[PE1] interface ten-gigabitethernet 3/0/5
[PE1-Ten-GigabitEthernet3/0/5] ip address 172.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/5] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure P.
[Sysname] sysname P
[P] ospf
[P-ospf-1] area 0
[P-ospf-1] quit
# Configure PE 2.
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1] quit
2. Configure basic MPLS on the PEs:
# Configure PE 1.
# Configure PE 2.
[PE2] mpls lsr-id 2.2.2.9
3. Configure VPN instances on the PEs to allow CE access, and apply tunnel policies to the VPN instances to use a GRE tunnel for VPN packet forwarding:
# Configure PE 1.
[PE1] tunnel-policy gre1
[PE1-tunnel-policy-gre1] tunnel select-seq gre load-balance-number 1
[PE1-tunnel-policy-gre1] quit
[PE1-vpn-instance-vpn1] vpn-target 100:1 both
[PE1-vpn-instance-vpn1] tnl-policy gre1
# Configure PE 2.
[PE2] tunnel-policy gre1
[PE2-tunnel-policy-gre1] tunnel select-seq gre load-balance-number 1
[PE2-tunnel-policy-gre1] quit
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2-vpn-instance-vpn1] vpn-target 100:1 both
[PE2-vpn-instance-vpn1] tnl-policy gre1
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::2 96
# Configure CE 1.
# Configure CE 2.
# Execute the display ip vpn-instance command on the PEs to display information about the VPN instance. Use the ping command on the PEs to verify that the PEs can ping their attached CEs. (Details not shown.)
4. Establish EBGP peer relationships between PEs and CEs to allow them to exchange VPN routes:
# Configure CE 1.
[CE1] bgp 65410
# Configure PE 1.
[PE1] bgp 100
# Configure CE 2.
[CE2] bgp 65420
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 2001:2::1 as-number 65420
[PE2-bgp-default-ipv6-vpn1] peer 2001:2::1 enable
# Execute the display bgp peer ipv6 vpn-instance command on the PEs to verify that BGP peer relationships in Established state have been established between the PEs and their attached CEs. (Details not shown.)
5. Configure MP-IBGP peer relationships between the PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 connedisct-interface loopback 0
6. Configure a GRE tunnel:
# Configure PE 1.
[PE1] interface tunnel 0 mode gre
[PE1-Tunnel0] source loopback 0
[PE1-Tunnel0] destination 2.2.2.9
[PE1-Tunnel0] ip address 20.1.1.1 24
[PE1-Tunnel0] mpls enable
[PE1-Tunnel0] quit
# Configure PE 2.
[PE2] interface tunnel 0 mode gre
[PE2-Tunnel0] source loopback 0
[PE2-Tunnel0] destination 1.1.1.9
[PE2-Tunnel0] ip address 20.1.1.2 24
[PE2-Tunnel0] mpls enable
[PE2-Tunnel0] quit
# Verify that the CEs have learned the route to each other and can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
tnl-policy gre1
vpn-target 100:1 import-extcommunity
vpn-target 100:1 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
tunnel-policy gre1
interface LoopBack0
interface Tunnel0 mode gre
ip address 20.1.1.1 255.255.255.0
mpls enable
source LoopBack0
destination 2.2.2.9
bgp 100
peer 2.2.2.9 connect-interface LoopBack0
peer 2.2.2.9 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
return
· PE 2:
sysname PE2
tnl-policy gre1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
tunnel-policy gre1
interface LoopBack0
ip address 20.1.1.2 255.255.255.0
mpls enable
source LoopBack0
destination 1.1.1.9
bgp 100
peer 1.1.1.9 enable
return
· CE 1:
sysname CE1
bgp 65410
router-id 4.4.4.4
import-route direct
return
· CE 2:
sysname CE2
bgp 65420
router-id 5.5.5.5
import-route direct
return
Example: Configuring a hub-spoke network
The Spoke-CEs cannot communicate directly. They can communicate only through the Hub-CE.
Configure EBGP between the Spoke-CEs and Spoke-PEs and between the Hub-CE and Hub-PE to exchange VPN routing information.
Configure OSPF between the Spoke-PEs and Hub-PE to implement communication between the PEs. Configure MP-IBGP between the Spoke-PEs and Hub-PE to exchange VPN routing information.
Table 23 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Spoke-CE 1 |
XGE3/0/1 |
11::1/64 |
Hub-CE |
XGE3/0/1 |
13::1/64 |
Spoke-PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/2 |
14::1/64 |
XGE3/0/1 |
11::2/64 |
Hub-PE |
Loop0 |
2.2.2.9/32 |
XGE3/0/4 |
172.1.1.1/24 |
XGE3/0/4 |
172.1.1.2/24 |
Spoke-CE 2 |
XGE3/0/1 |
12::1/64 |
XGE3/0/5 |
172.2.1.2/24 |
Spoke-PE 2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/1 |
13::2/64 |
XGE3/0/1 |
12::2/64 |
XGE3/0/2 |
14::2/64 |
XGE3/0/4 |
172.2.1.1/24 |
1. Configure an IGP on the MPLS backbone to ensure IP connectivity within the backbone:
# Configure Spoke-PE 1.
[Sysname] sysname Spoke-PE1
[Spoke-PE1] interface loopback 0
[Spoke-PE1-LoopBack0] ip address 1.1.1.9 32
[Spoke-PE1-LoopBack0] quit
[Spoke-PE1] interface ten-gigabitethernet 3/0/4
[Spoke-PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.1 24
[Spoke-PE1-Ten-GigabitEthernet3/0/4] quit
[Spoke-PE1] ospf
[Spoke-PE1-ospf-1] area 0
[Spoke-PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Spoke-PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[Spoke-PE1-ospf-1-area-0.0.0.0] quit
[Spoke-PE1-ospf-1] quit
# Configure Spoke-PE 2.
[Sysname] sysname Spoke-PE2
[Spoke-PE2] interface loopback 0
[Spoke-PE2-LoopBack0] ip address 3.3.3.9 32
[Spoke-PE2-LoopBack0] quit
[Spoke-PE2] interface ten-gigabitethernet 3/0/4
[Spoke-PE2-Ten-GigabitEthernet3/0/4] ip address 172.2.1.1 24
[Spoke-PE2-Ten-GigabitEthernet3/0/4] quit
[Spoke-PE2] ospf
[Spoke-PE2-ospf-1] area 0
[Spoke-PE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Spoke-PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[Spoke-PE2-ospf-1-area-0.0.0.0] quit
[Spoke-PE2-ospf-1] quit
# Configure Hub-PE.
[Sysname] sysname Hub-PE
[Hub-PE] interface loopback 0
[Hub-PE-LoopBack0] ip address 2.2.2.9 32
[Hub-PE-LoopBack0] quit
[Hub-PE] interface ten-gigabitethernet 3/0/4
[Hub-PE-Ten-GigabitEthernet3/0/4] ip address 172.1.1.2 24
[Hub-PE-Ten-GigabitEthernet3/0/4] quit
[Hub-PE] interface ten-gigabitethernet 3/0/5
[Hub-PE-Ten-GigabitEthernet3/0/5] ip address 172.2.1.2 24
[Hub-PE-Ten-GigabitEthernet3/0/5] quit
[Hub-PE] ospf
[Hub-PE-ospf-1] area 0
[Hub-PE-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[Hub-PE-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[Hub-PE-ospf-1-area-0.0.0.0] quit
[Hub-PE-ospf-1] quit
# Execute the display ospf peer command on the PEs to verify that OSPF adjacencies in Full state have been established between the PEs. Execute the display ip routing-table command on the PEs to verify that the PEs have learned the routes to the loopback interfaces of each other. (Details not shown.)
2. Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
[Spoke-PE1] mpls lsr-id 1.1.1.9
[Spoke-PE1] mpls ldp
[Spoke-PE1-ldp] quit
[Spoke-PE1-Ten-GigabitEthernet3/0/4] mpls enable
[Spoke-PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[Spoke-PE2] mpls lsr-id 3.3.3.9
[Spoke-PE2] mpls ldp
[Spoke-PE2-ldp] quit
[Spoke-PE2-Ten-GigabitEthernet3/0/4] mpls enable
[Spoke-PE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Configure Hub-PE.
[Hub-PE] mpls lsr-id 2.2.2.9
[Hub-PE] mpls ldp
[Hub-PE-ldp] quit
[Hub-PE-Ten-GigabitEthernet3/0/4] mpls enable
[Hub-PE-Ten-GigabitEthernet3/0/4] mpls ldp enable
[Hub-PE-Ten-GigabitEthernet3/0/5] mpls enable
[Hub-PE-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Execute the display mpls ldp peer command on the PEs to verify that LDP sessions in Operational state have been established between the PEs. Execute the display mpls ldp lsp command on the PEs to verify that the LSPs have been established by LDP. (Details not shown.)
3. Configure VPN instances on the Spoke-PEs and Hub-PE:
[Spoke-PE1] ip vpn-instance vpn1
[Spoke-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[Spoke-PE1-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE1-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE1-vpn-instance-vpn1] quit
[Spoke-PE1] interface ten-gigabitethernet 3/0/1
[Spoke-PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[Spoke-PE1-Ten-GigabitEthernet3/0/1] ipv6 address 11::2 24
[Spoke-PE1-Ten-GigabitEthernet3/0/1] quit
[Spoke-PE2] ip vpn-instance vpn1
[Spoke-PE2-vpn-instance-vpn1] route-distinguisher 100:2
[Spoke-PE2-vpn-instance-vpn1] vpn-target 111:1 import-extcommunity
[Spoke-PE2-vpn-instance-vpn1] vpn-target 222:2 export-extcommunity
[Spoke-PE2-vpn-instance-vpn1] quit
[Spoke-PE2] interface ten-gigabitethernet 3/0/1
[Spoke-PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[Spoke-PE2-Ten-GigabitEthernet3/0/1] ipv6 address 12::2 24
[Spoke-PE2-Ten-GigabitEthernet3/0/1] quit
# Configure Hub-PE.
[Hub-PE] ip vpn-instance vpn1-in
[Hub-PE-vpn-instance-vpn1-in] route-distinguisher 100:3
[Hub-PE-vpn-instance-vpn1-in] vpn-target 222:2 import-extcommunity
[Hub-PE-vpn-instance-vpn1-in] quit
[Hub-PE] ip vpn-instance vpn1-out
[Hub-PE-vpn-instance-vpn1-out] route-distinguisher 100:4
[Hub-PE-vpn-instance-vpn1-out] vpn-target 111:1 export-extcommunity
[Hub-PE-vpn-instance-vpn1-out] quit
[Hub-PE] interface ten-gigabitethernet 3/0/1
[Hub-PE-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1-in
[Hub-PE-Ten-GigabitEthernet3/0/1] ipv6 address 13::2 24
[Hub-PE-Ten-GigabitEthernet3/0/1] quit
[Hub-PE] interface ten-gigabitethernet 3/0/2
[Hub-PE-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn1-out
[Hub-PE-Ten-GigabitEthernet3/0/2] ipv6 address 14::2 24
[Hub-PE-Ten-GigabitEthernet3/0/2] quit
# Configure Spoke-CE 1.
[Sysname] sysname Spoke-CE1
[Spoke-CE1] interface ten-gigabitethernet 3/0/1
[Spoke-CE1-Ten-GigabitEthernet3/0/1] ipv6 address 11::1 64
[Spoke-CE1-Ten-GigabitEthernet3/0/1] quit
# Configure Spoke-CE 2.
[Sysname] sysname Spoke-CE2
[Spoke-CE2] interface ten-gigabitethernet 3/0/1
[Spoke-CE2-Ten-GigabitEthernet3/0/1] ipv6 address 12::1 64
[Spoke-CE2-Ten-GigabitEthernet3/0/1] quit
# Configure Hub-CE.
[Sysname] sysname Hub-CE
[Hub-CE] interface ten-gigabitethernet 3/0/1
[Hub-CE-Ten-GigabitEthernet3/0/1] ipv6 address 13::1 64
[Hub-CE-Ten-GigabitEthernet3/0/1] quit
[Hub-CE] interface ten-gigabitethernet 3/0/2
[Hub-CE-Ten-GigabitEthernet3/0/2] ipv6 address 14::1 64
[Hub-CE-Ten-GigabitEthernet3/0/2] quit
# Execute the display ip vpn-instance command on the PEs to display the VPN instance configuration. Use the ping command on the PEs to verify that the PEs can ping their attached CEs. (Details not shown.)
4. Establish EBGP peer relationships between the PEs and CEs, and redistribute VPN routes into BGP:
[Spoke-CE1] bgp 65410
[Spoke-CE1-bgp-default] router-id 4.4.4.4
[Spoke-CE1-bgp-default] peer 11::2 as-number 100
[Spoke-CE1-bgp-default] address-family ipv6
[Spoke-CE1-bgp-default-ipv6] peer 11::2 enable
[Spoke-CE1-bgp-default-ipv6] import-route direct
[Spoke-CE1-bgp-default-ipv6] quit
[Spoke-CE1-bgp-default] quit
[Spoke-CE2] bgp 65420
[Spoke-CE2-bgp-default] router-id 5.5.5.5
[Spoke-CE2-bgp-default] peer 12::2 as-number 100
[Spoke-CE2-bgp-default] address-family ipv6
[Spoke-CE2-bgp-default-ipv6] peer 12::2 enable
[Spoke-CE2-bgp-default-ipv6] import-route direct
[Spoke-CE2-bgp-default-ipv6] quit
[Spoke-CE2-bgp-default] quit
# Configure Hub-CE.
[Hub-CE] bgp 65430
[Hub-CE-bgp-default] router-id 6.6.6.6
[Hub-CE-bgp-default] peer 13::2 as-number 100
[Hub-CE-bgp-default] peer 14::2 as-number 100
[Hub-CE-bgp-default] address-family ipv6
[Hub-CE-bgp-default-ipv6] peer 13::2 enable
[Hub-CE-bgp-default-ipv6] peer 14::2 enable
[Hub-CE-bgp-default-ipv6] import-route direct
[Hub-CE-bgp-default-ipv6] quit
[Hub-CE-bgp-default] quit
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] ip vpn-instance vpn1
[Spoke-PE1-bgp-default-vpn1] peer 11::1 as-number 65410
[Spoke-PE1-bgp-default-vpn1] address-family ipv6
[Spoke-PE1-bgp-default-ipv6-vpn1] peer 11::1 enable
[Spoke-PE1-bgp-default-ipv6-vpn1] quit
[Spoke-PE1-bgp-default-vpn1] quit
[Spoke-PE1-bgp-default] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] ip vpn-instance vpn1
[Spoke-PE2-bgp-default-vpn1] peer 12::1 as-number 65420
[Spoke-PE2-bgp-default-vpn1] address-family ipv6
[Spoke-PE2-bgp-default-ipv6-vpn1] peer 12::1 enable
[Spoke-PE2-bgp-default-ipv6-vpn1] quit
[Spoke-PE2-bgp-default-vpn1] quit
[Spoke-PE2-bgp-default] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] ip vpn-instance vpn1-in
[Hub-PE-bgp-default-vpn1-in] peer 13::1 as-number 65430
[Hub-PE-bgp-default-vpn1-in] address-family ipv6
[Hub-PE-bgp-default-ipv6-vpn1-in] peer 13::1 enable
[Hub-PE-bgp-default-ipv6-vpn1-in] quit
[Hub-PE-bgp-default-vpn1-in] quit
[Hub-PE-bgp-default] ip vpn-instance vpn1-out
[Hub-PE-bgp-default-vpn1-out] peer 14::1 as-number 65430
[Hub-PE-bgp-default-vpn1-out] address-family ipv6
[Hub-PE-bgp-default-ipv6-vpn1-out] peer 14::1 enable
[Hub-PE-bgp-default-ipv6-vpn1-out] peer 14::1 allow-as-loop 2
[Hub-PE-bgp-default-ipv6-vpn1-out] quit
[Hub-PE-bgp-default-vpn1-out] quit
[Hub-PE-bgp-default] quit
5. Establish an MP-IBGP peer relationship between the Spoke-PEs and Hub-PE:
[Spoke-PE1] bgp 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE1-bgp-default] address-family vpnv6
[Spoke-PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
[Spoke-PE1-bgp-default-vpnv6] quit
[Spoke-PE2] bgp 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 as-number 100
[Spoke-PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[Spoke-PE2-bgp-default] address-family vpnv6
[Spoke-PE2-bgp-default-vpnv6] peer 2.2.2.9 enable
[Spoke-PE2-bgp-default-vpnv6] quit
# Configure Hub-PE.
[Hub-PE] bgp 100
[Hub-PE-bgp-default] peer 1.1.1.9 as-number 100
[Hub-PE-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[Hub-PE-bgp-default] peer 3.3.3.9 as-number 100
[Hub-PE-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[Hub-PE-bgp-default] address-family vpnv6
[Hub-PE-bgp-default-vpnv6] peer 1.1.1.9 enable
[Hub-PE-bgp-default-vpnv6] peer 3.3.3.9 enable
[Hub-PE-bgp-default-vpnv6] quit
# Verify that Spoke-CE 1 and Spoke-CE 2 can ping each other. The TTL value indicates that traffic from Spoke-CE 1 to Spoke-CE 2 passes six hops (64-59+1) and is forwarded through Hub-CE. This example uses Spoke-CE 1.
[Spoke-CE1] ping ipv6 12::1
Ping6(56 bytes) 11::1 --> 12::1, press CTRL_C to break
56 bytes from 12::1, icmp_seq=0 hlim=59 time=0.000 ms
56 bytes from 12::1, icmp_seq=1 hlim=59 time=1.000 ms
56 bytes from 12::1, icmp_seq=2 hlim=59 time=0.000 ms
56 bytes from 12::1, icmp_seq=3 hlim=59 time=1.000 ms
56 bytes from 12::1, icmp_seq=4 hlim=59 time=0.000 ms
--- Ping6 statistics for 12::1 ---
round-trip min/avg/max/std-dev = 0.000/0.400/1.000/0.490 ms
Configuration files
· Spoke-PE 1:
sysname Spoke-PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
ipv6 address 11::2/24
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
peer 11::1 enable
return
· Spoke-PE 2:
sysname Spoke-PE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ipv6 address 12::2/24
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
peer 12::1 enable
return
· Hub-PE:
sysname Hub-PE
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ipv6 address 13::2/24
ipv6 address 14::2/24
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 3.3.3.9 enable
peer 13::1 enable
peer 14::1 enable
return
· Spoke-CE 1:
sysname Spoke-CE1
ipv6 address 11::1/64
bgp 65410
router-id 4.4.4.4
import-route direct
peer 11::2 enable
return
· Spoke-CE 2:
sysname Spoke-CE2
ipv6 address 12::1/64
bgp 65420
router-id 5.5.5.5
import-route direct
peer 12::2 enable
return
· Hub-CE:
sysname Hub-CE
ipv6 address 13::1/64
ipv6 address 14::1/64
bgp 65430
router-id 6.6.6.6
import-route direct
peer 13::2 enable
peer 14::2 enable
return
Example: Configuring IPv6 MPLS L3VPN inter-AS option A
CE 1 and CE 2 belong to the same VPN. CE 1 accesses the network through PE 1 in AS 100 and CE 2 accesses the network through PE 2 in AS 200.
Configure IPv6 MPLS L3VPN inter-AS option A, and use VRF-to-VRF method to manage VPN routes.
Run OSPF on the MPLS backbone of each AS.
Table 24 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
2001:1::1/96 |
CE 2 |
XGE3/0/1 |
2001:2::1/96 |
PE 1 |
Loop0 |
1.1.1.9/32 |
PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
2001:1::2/96 |
XGE3/0/1 |
2001:2::2/96 |
XGE3/0/4 |
172.1.1.2/24 |
XGE3/0/4 |
162.1.1.2/24 |
ASBR-PE1 |
Loop0 |
2.2.2.9/32 |
ASBR-PE2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/4 |
172.1.1.1/24 |
XGE3/0/4 |
162.1.1.1/24 |
XGE3/0/5 |
2002:1::1/96 |
XGE3/0/5 |
2002:1::2/96 |
For the same VPN, the route targets for the VPN instance on the PE must match those for the VPN instance on the ASBR-PE in the same AS. This is not required for PEs in different ASs.
1. Configure an IGP on each MPLS backbone to ensure IP connectivity within the backbone.
# Configure PE 1.
[PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.2 24
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
# Configure ASBR-PE1.
[Sysname] sysname ASBR-PE1
[ASBR-PE1-LoopBack0] ip address 2.2.2.9 32
[ASBR-PE1-LoopBack0] quit
[ASBR-PE1] interface ten-gigabitethernet 3/0/4
[ASBR-PE1-Ten-GigabitEthernet3/0/4] ip address 172.1.1.1 24
[ASBR-PE1-Ten-GigabitEthernet3/0/4] quit
[ASBR-PE1] ospf
[ASBR-PE1-ospf-1] area 0
[ASBR-PE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[ASBR-PE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[ASBR-PE1-ospf-1-area-0.0.0.0] quit
[ASBR-PE1-ospf-1] quit
# Configure ASBR-PE2.
[Sysname] sysname ASBR-PE2
[ASBR-PE2] interface loopback 0
[ASBR-PE2-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE2-LoopBack0] quit
[ASBR-PE2] interface ten-gigabitethernet 3/0/4
[ASBR-PE2-Ten-GigabitEthernet3/0/4] ip address 162.1.1.1 24
[ASBR-PE2-Ten-GigabitEthernet3/0/4] quit
[ASBR-PE2] ospf
[ASBR-PE2-ospf-1] area 0
[ASBR-PE2-ospf-1-area-0.0.0.0] network 162.1.1.0 0.0.0.255
[ASBR-PE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[ASBR-PE2-ospf-1-area-0.0.0.0] quit
[ASBR-PE2-ospf-1] quit
# Configure PE 2.
[PE2-LoopBack0] ip address 4.4.4.9 32
[PE2-Ten-GigabitEthernet3/0/4] ip address 162.1.1.2 24
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 162.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[PE2-ospf-1] quit
# Execute the display ospf peer command to verify that each ASBR-PE has established an OSPF adjacency in Full state with the PE in the same AS, and that the PEs and ASBR-PEs in the same AS have learned the routes to the loopback interfaces of each other. Execute the ping command to verify that the PEs and ASBR-PEs in the same AS can ping each other. (Details not shown.)
2. Configure basic MPLS and enable MPLS LDP on each MPLS backbone to establish LDP LSPs:
# Configure basic MPLS on PE 1, and enable MPLS LDP for both PE 1 and the interface connected to ASBR-PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure basic MPLS on ASBR-PE 1, and enable MPLS LDP for both ASBR-PE 1 and the interface connected to PE 1.
[ASBR-PE1] mpls lsr-id 2.2.2.9
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1-Ten-GigabitEthernet3/0/4] mpls enable
[ASBR-PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Configure basic MPLS on ASBR-PE 2, and enable MPLS LDP for both ASBR-PE 2 and the interface connected to PE 2.
[ASBR-PE2] mpls lsr-id 3.3.3.9
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2-Ten-GigabitEthernet3/0/4] mpls enable
[ASBR-PE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
# Configure basic MPLS on PE 2, and enable MPLS LDP for both PE 2 and the interface connected to ASBR-PE 2.
[PE2] mpls lsr-id 4.4.4.9
[PE2] mpls ldp
[PE2-ldp] quit
# Execute the display mpls ldp session command on the routers to verify that the session status is Operational, and that each PE and the ASBR-PE in the same AS have established an LDP neighbor relationship. (Details not shown.)
3. Configure a VPN instance on the PEs:
# Configure CE 1.
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 100:2
# Configure CE 2.
# Configure PE 2.
[PE2-vpn-instance-vpn1] vpn-target 200:1 both
# On ASBR-PE 1, create a VPN instance, and bind the VPN instance to the interface connected to ASBR-PE 2. ASBR-PE 1 considers ASBR-PE 2 to be its attached CE.
[ASBR-PE1] ip vpn-instance vpn1
[ASBR-PE1-vpn-instance-vpn1] route-distinguisher 100:1
[ASBR-PE1-vpn-instance-vpn1] vpn-target 100:1 both
[ASBR-PE1-vpn-instance-vpn1] quit
[ASBR-PE1] interface ten-gigabitethernet 3/0/5
[ASBR-PE1-Ten-GigabitEthernet3/0/5] ip binding vpn-instance vpn1
[ASBR-PE1-Ten-GigabitEthernet3/0/5] ipv6 address 2002:1::1 96
[ASBR-PE1-Ten-GigabitEthernet3/0/5] quit
# On ASBR-PE 2, create a VPN instance, and bind the VPN instance to the interface connected to ASBR-PE 1. ASBR-PE 2 considers ASBR-PE 1 to be its attached CE.
[ASBR-PE2] ip vpn-instance vpn1
[ASBR-PE2-vpn-instance-vpn1] route-distinguisher 200:1
[ASBR-PE2-vpn-instance-vpn1] vpn-target 200:1 both
[ASBR-PE2-vpn-instance-vpn1] quit
[ASBR-PE2] interface ten-gigabitethernet 3/0/5
[ASBR-PE2-Ten-GigabitEthernet3/0/5] ip binding vpn-instance vpn1
[ASBR-PE2-Ten-GigabitEthernet3/0/5] ipv6 address 2002:1::2 96
[ASBR-PE2-Ten-GigabitEthernet3/0/5] quit
# Execute the display ip vpn-instance command to display VPN instance information. Verify that each PE can ping its attached CE, and that ASBR-PE 1 and ASBR-PE 2 can ping each other. (Details not shown.)
# Configure CE 1.
[CE1] bgp 65001
[CE1-bgp-default] router-id 5.5.5.5
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 2001:1::1 as-number 65001
# Configure CE 2.
[CE2] bgp 65002
[CE2-bgp-default] router-id 6.6.6.6
[CE2-bgp-default] peer 2001:2::2 as-number 200
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default-vpn1] peer 2001:2::1 as-number 65002
5. Establish an IBGP peer relationship between each PE and the ASBR-PE in the same AS and an EBGP peer relationship between the ASBR-PEs:
# Configure PE 1.
[PE1] bgp 100
# Configure ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] ip vpn-instance vpn1
[ASBR-PE1-bgp-default-vpn1] peer 2002:1::2 as-number 200
[ASBR-PE1-bgp-default-vpn1] address-family ipv6 unicast
[ASBR-PE1-bgp-default-ipv6-vpn1] peer 2002:1::2 enable
[ASBR-PE1-bgp-default-ipv6-vpn1] quit
[ASBR-PE1-bgp-default-vpn1] quit
[ASBR-PE1-bgp-default] peer 1.1.1.9 as-number 100
[ASBR-PE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[ASBR-PE1-bgp-default] address-family vpnv6
[ASBR-PE1-bgp-default-vpnv6] peer 1.1.1.9 enable
[ASBR-PE1-bgp-default-vpnv6] quit
[ASBR-PE1-bgp-default] quit
# Configure ASBR-PE 2.
[ASBR-PE2] bgp 200
[ASBR-PE2-bgp-default] ip vpn-instance vpn1
[ASBR-PE2-bgp-default-vpn1] peer 2002:1::1 as-number 100
[ASBR-PE2-bgp-default-vpn1] address-family ipv6 unicast
[ASBR-PE2-bgp-default-ipv6-vpn1] peer 2002:1::1 enable
[ASBR-PE2-bgp-default-ipv6-vpn1] quit
[ASBR-PE2-bgp-default-vpn1] quit
[ASBR-PE2-bgp-default] peer 4.4.4.9 as-number 200
[ASBR-PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[ASBR-PE2-bgp-default] address-family vpnv6
[ASBR-PE2-bgp-default-vpnv6] peer 4.4.4.9 enable
[ASBR-PE2-bgp-default-vpnv6] quit
[ASBR-PE2-bgp-default] quit
# Configure PE 2.
[PE2] bgp 200
[PE2-bgp-default] peer 3.3.3.9 as-number 200
[PE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[PE2-bgp-default-vpnv6] peer 3.3.3.9 enable
# Verify that the CEs can learn the route to each other and can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
ipv6 address 2002:1::1/96
bgp 100
peer 1.1.1.9 enable
return
· ASBR-PE 2:
sysname ASBR-PE2
vpn-target 200:1 import-extcommunity
vpn-target 200:1 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 162.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
ipv6 address 2002:1::2/96
bgp 200
peer 4.4.4.9 connect-interface LoopBack0
peer 4.4.4.9 enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
ip address 4.4.4.9 255.255.255.255
ip address 162.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 200
peer 3.3.3.9 enable
return
· CE 1:
sysname CE1
bgp 65001
router-id 5.5.5.5
import-route direct
return
· CE 2:
sysname CE2
bgp 65002
router-id 6.6.6.6
import-route direct
return
Example: Configuring IPv6 MPLS L3VPN inter-AS option B
Site 1 and Site 2 belong to the same VPN. CE 1 of Site 1 accesses the network through PE 1 in AS 100, and CE 2 of Site 2 accesses the network through PE 2 in AS 600.
PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange VPNv6 routes through MP-IBGP. PE 2 and ASBR-PE 2 exchange VPNv6 routes through MP-IBGP. ASBR-PE 1 and ASBR-PE 2 exchange VPNv6 routes through MP-EBGP.
ASBRs do not perform route target filtering of received VPNv6 routes.
Figure 57 Network diagram
Table 25 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
30::1/64 |
XGE3/0/1 |
20::1/64 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
30::2/64 |
CE 2 |
XGE3/0/1 |
20::2/64 |
1. Configure PE 1:
# Configure IS-IS on PE 1.
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0001.00
[PE1-isis-1] quit
# Configure LSR ID, and enable MPLS and LDP.
[PE1] mpls lsr-id 2.2.2.9
[PE1] mpls ldp
[PE1-ldp] quit
# Configure interface Ten-GigabitEthernet 3/0/5, and enable IS-IS, MPLS, and LDP on the interface.
[PE1-Ten-GigabitEthernet3/0/5] ip address 1.1.1.2 255.0.0.0
[PE1-Ten-GigabitEthernet3/0/5] isis enable 1
[PE1-Ten-GigabitEthernet3/0/5] mpls enable
[PE1-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Configure interface Loopback 0, and enable IS-IS on it.
[PE1-LoopBack0] ip address 2.2.2.9 32
[PE1-LoopBack0] isis enable 1
# Create VPN instance vpn1, and configure the RD and route target attributes.
[PE1-vpn-instance-vpn1] vpn-target 1:1 2:2 import-extcommunity
[PE1-vpn-instance-vpn1] vpn-target 1:1 export-extcommunity
# Bind the interface connected to CE 1 to the created VPN instance.
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 30::1 64
# Enable BGP on PE 1.
[PE1] bgp 100
# Configure IBGP peer 3.3.3.9 as a VPNv6 peer.
# Establish an EBGP peer relationship between the PE and its attached CE.
[PE1-bgp-default-vpn1] peer 30::2 as-number 65001
[PE1-bgp-default-ipv6-vpn1] peer 30::2 enable
2. Configure ASBR-PE 1:
# Enable IS-IS on ASBR-PE 1.
[ASBR-PE1] isis 1
[ASBR-PE1-isis-1] network-entity 10.0000.0000.0000.0002.00
[ASBR-PE1-isis-1] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
[ASBR-PE1-Ten-GigabitEthernet3/0/5] ip address 1.1.1.1 255.0.0.0
[ASBR-PE1-Ten-GigabitEthernet3/0/5] isis enable 1
[ASBR-PE1-Ten-GigabitEthernet3/0/5] mpls enable
[ASBR-PE1-Ten-GigabitEthernet3/0/5] mpls ldp enable
# Configure interface Ten-GigabitEthernet 3/0/4, and enable MPLS.
[ASBR-PE1-Ten-GigabitEthernet3/0/4] ip address 11.0.0.2 255.0.0.0
[ASBR-PE1-LoopBack0] ip address 3.3.3.9 32
[ASBR-PE1-LoopBack0] isis enable 1
# Enable BGP on ASBR-PE 1.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[ASBR-PE1-bgp-default] peer 11.0.0.1 connect-interface ten-gigabitethernet 3/0/4
# Disable route target based filtering of received VPNv6 routes.
[ASBR-PE1-bgp-default-vpnv6] undo policy vpn-target
# Configure IBGP peer 2.2.2.9 and EBGP peer 11.0.0.1 as VPNv6 peers.
[ASBR-PE1-bgp-default-vpnv6] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
3. Configure ASBR-PE 2:
# Enable IS-IS on ASBR-PE 2.
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] network-entity 10.0000.0000.0000.0003.00
[ASBR-PE2-isis-1] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2-Ten-GigabitEthernet3/0/5] ip address 9.1.1.1 255.0.0.0
[ASBR-PE2-Ten-GigabitEthernet3/0/5] isis enable 1
[ASBR-PE2-Ten-GigabitEthernet3/0/5] mpls enable
[ASBR-PE2-Ten-GigabitEthernet3/0/5] mpls ldp enable
[ASBR-PE2-Ten-GigabitEthernet3/0/4] ip address 11.0.0.1 255.0.0.0
[ASBR-PE2-LoopBack0] ip address 4.4.4.9 32
[ASBR-PE2-LoopBack0] isis enable 1
# Enable BGP on ASBR-PE 2.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] peer 11.0.0.2 connect-interface ten-gigabitethernet 3/0/4
[ASBR-PE2-bgp-default] peer 5.5.5.9 connect-interface loopback 0
[ASBR-PE2-bgp-default-vpnv6] undo policy vpn-target
# Configure IBGP peer 5.5.5.9 and EBGP peer 11.0.0.2 as VPNv6 peers.
[ASBR-PE2-bgp-default-vpnv6] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-vpnv6] peer 5.5.5.9 enable
4. Configure PE 2:
# Enable IS-IS on PE 2.
[PE2] isis 1
[PE2-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE2-isis-1] quit
# Configure the LSR ID, and enable MPLS and LDP.
[PE2] mpls lsr-id 5.5.5.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface ten-gigabitethernet 3/0/5
[PE2-Ten-GigabitEthernet3/0/5] ip address 9.1.1.2 255.0.0.0
[PE2-Ten-GigabitEthernet3/0/5] isis enable 1
[PE2-Ten-GigabitEthernet3/0/5] mpls enable
[PE2-Ten-GigabitEthernet3/0/5] mpls ldp enable
[PE2-Ten-GigabitEthernet3/0/5] quit
[PE2-LoopBack0] ip address 5.5.5.9 32
[PE2-LoopBack0] isis enable 1
[PE2-vpn-instance-vpn1] route-distinguisher 12:12
[PE2-vpn-instance-vpn1] vpn-target 1:1 2:2 import-extcommunity
[PE2-vpn-instance-vpn1] vpn-target 2:2 export-extcommunity
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 20::1 64
# Enable BGP on PE 2.
[PE2] bgp 600
# Configure IBGP peer 4.4.4.9 as a VPNv6 peer.
[PE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE2-bgp-default-vpnv6] peer 4.4.4.9 enable
[PE2-bgp-default-vpn1] peer 20::2 as-number 65002
[PE2-bgp-default-ipv6-vpn1] peer 20::2 enable
5. Configure CE 1:
# Assign IP addresses to interfaces.
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 30::2 64
# Establish an EBGP peer relationship between the PE and its PE and redistribute directed routes.
[CE1] bgp 65001
[CE1-bgp-default] router-id 6.6.6.6
[CE1-bgp-default] peer 30::1 as-number 100
[CE1-bgp-default-ipv6] peer 30::1 enable
6. Configure CE 2:
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 20::2 64
[CE2] bgp 65002
[CE2-bgp-default] router-id 7.7.7.7
[CE2-bgp-default] peer 20::1 as-number 600
[CE2-bgp-default-ipv6] peer 20::1 enable
# Verify that the CEs can learn each other's interface routes and can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
ipv6 address 30::1/64
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 enable
peer 30::2 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 11.0.0.1 connect-interface Ten-GigabitEthernet3/0/4
peer 2.2.2.9 enable
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 5.5.5.9 connect-interface LoopBack0
peer 11.0.0.2 connect-interface Ten-GigabitEthernet3/0/4
peer 5.5.5.9 enable
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
ip address 5.5.5.9 255.255.255.255
isis enable 1
ipv6 address 20::1/64
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 4.4.4.9 enable
peer 20::2 enable
return
· CE 1:
sysname CE1
ipv6 address 30::2/64
bgp 65001
router-id 6.6.6.6
import-route direct
peer 30::1 enable
return
· CE 2:
sysname CE2
ipv6 address 20::2/64
bgp 65002
router-id 7.7.7.7
import-route direct
peer 20::1 enable
return
Example: Configuring IPv6 MPLS L3VPN inter-AS option C (method 1)
Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100. Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and ASBR-PE 1 exchange labeled IPv4 routes by IBGP. PE 2 and ASBR-PE 2 exchange labeled IPv4 routes by IBGP. PE 1 and PE 2 are MP-EBGP peers to exchange VPNv6 routes.
ASBR-PE 1 and ASBR-PE 2 use their respective routing policies and label the routes received from each other.
ASBR-PE 1 and ASBR-PE 2 use EBGP to exchange labeled IPv4 routes.
Table 26 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
2001::1/64 |
XGE3/0/1 |
2002::1/64 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
2001::2/64 |
CE 2 |
XGE3/0/1 |
2002::2/64 |
1. Configure CE 1:
# Configure an IPv6 address for Ten-GigabitEthernet 3/0/1.
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001::2 64
# Establish an EBGP peer relationship with PE 1, and redistribute VPN routes.
[CE1] bgp 65001
[CE1-bgp-default] peer 2001::1 as-number 100
[CE1-bgp-default-ipv6] peer 2001::1 enable
2. Configure PE 1:
[PE1] isis 1
[PE1-isis-1] quit
# Configure an LSR ID, and enable MPLS and LDP.
[PE1] mpls ldp
[PE1-ldp] quit
# Configure Ten-GigabitEthernet 3/0/5, and enable IS-IS, MPLS, and LDP on the interface.
# Configure Loopback 0 and enable IS-IS on it.
# Create VPN instance vpn1, and configure the RD and route target attributes for it.
[PE1-vpn-instance-vpn1] vpn-target 3:3 import-extcommunity
# Associate Ten-GigabitEthernet 3/0/1 with VPN instance vpn1, and specify the IPv6 address for the interface.
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001::1 64
[PE1] bgp 100
# Enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 3.3.3.9.
[PE1-bgp-default] address-family ipv4 unicast
[PE1-bgp-default-ipv4] peer 3.3.3.9 enable
[PE1-bgp-default-ipv4] peer 3.3.3.9 label-route-capability
[PE1-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 1 to EBGP peer 5.5.5.9 as 10.
[PE1-bgp-default] peer 5.5.5.9 as-number 600
[PE1-bgp-default] peer 5.5.5.9 connect-interface loopback 0
[PE1-bgp-default] peer 5.5.5.9 ebgp-max-hop 10
# Configure peer 5.5.5.9 as a VPNv6 peer.
[PE1-bgp-default-af-vpnv6] peer 5.5.5.9 enable
[PE1-bgp-default-af-vpnv6] quit
# Establish an EBGP peer relationship with CE 1, and add the learned BGP routes to the routing table of VPN instance vpn1.
[PE1-bgp-default-vpn1] peer 2001::2 as-number 65001
[PE1-bgp-default-ipv6-vpn1] peer 2001::2 enable
3. Configure ASBR-PE 1:
[ASBR-PE1] isis 1
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Configure Ten-GigabitEthernet 3/0/4, and enable MPLS on it.
# Configure Loopback 0, and enable IS-IS on it.
# Create routing policies.
[ASBR-PE1] route-policy policy1 permit node 1
[ASBR-PE1-route-policy-policy1-1] apply mpls-label
[ASBR-PE1-route-policy-policy1-1] quit
[ASBR-PE1] route-policy policy2 permit node 1
[ASBR-PE1-route-policy-policy2-1] if-match mpls-label
[ASBR-PE1-route-policy-policy2-1] apply mpls-label
[ASBR-PE1-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 1, and apply routing policy policy2 to routes advertised to IBGP peer 2.2.2.9.
[ASBR-PE1] bgp 100
[ASBR-PE1-bgp-default] address-family ipv4 unicast
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 enable
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 route-policy policy2 export
# Enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 2.2.2.9.
[ASBR-PE1-bgp-default-ipv4] peer 2.2.2.9 label-route-capability
# Redistribute routes from IS-IS process 1
[ASBR-PE1-bgp-default-ipv4] import-route isis 1
[ASBR-PE1-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 enable
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 route-policy policy1 export
# Enable the capability to advertise labeled routes to and receive labeled routes from EBGP peer 11.0.0.1.
[ASBR-PE1-bgp-default-ipv4] peer 11.0.0.1 label-route-capability
4. Configure ASBR-PE 2:
[ASBR-PE2] isis 1
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
[ASBR-PE2] route-policy policy1 permit node 1
[ASBR-PE2-route-policy-policy1-1] apply mpls-label
[ASBR-PE2-route-policy-policy1-1] quit
[ASBR-PE2] route-policy policy2 permit node 1
[ASBR-PE2-route-policy-policy2-1] if-match mpls-label
[ASBR-PE2-route-policy-policy2-1] apply mpls-label
[ASBR-PE2-route-policy-policy2-1] quit
# Enable BGP on ASBR-PE 2, and enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 5.5.5.9.
[ASBR-PE2] bgp 600
[ASBR-PE2-bgp-default] address-family ipv4 unicast
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 enable
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 label-route-capability
# Apply routing policy policy2 to routes advertised to IBGP peer 5.5.5.9.
[ASBR-PE2-bgp-default-ipv4] peer 5.5.5.9 route-policy policy2 export
# Redistribute routes from IS-IS process 1.
[ASBR-PE2-bgp-default-ipv4] import-route isis 1
[ASBR-PE2-bgp-default-ipv4] quit
# Apply routing policy policy1 to routes advertised to EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 enable
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 route-policy policy1 export
# Enable the capability to advertise labeled routes to and receive labeled routes from EBGP peer 11.0.0.2.
[ASBR-PE2-bgp-default-ipv4] peer 11.0.0.2 label-route-capability
5. Configure PE 2:
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-vpn-instance-vpn1] route-distinguisher 11:11
[PE2-vpn-instance-vpn1] vpn-target 3:3 import-extcommunity
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 2002::1 64
# Enable BGP.
[PE2] bgp 600
# Enable the capability to advertise labeled routes to and receive labeled routes from IBGP peer 4.4.4.9.
[PE2-bgp-default] address-family ipv4 unicast
[PE2-bgp-default-ipv4] peer 4.4.4.9 enable
[PE2-bgp-default-ipv4] peer 4.4.4.9 label-route-capability
[PE2-bgp-default-ipv4] quit
# Configure the maximum hop count from PE 2 to EBGP peer 2.2.2.9 as 10.
[PE2-bgp-default] peer 2.2.2.9 as-number 100
[PE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE2-bgp-default] peer 2.2.2.9 ebgp-max-hop 10
# Configure peer 2.2.2.9 as a VPNv6 peer.
[PE2-bgp-default-af-vpnv6] peer 2.2.2.9 enable
[PE2-bgp-default-af-vpnv6] quit
# Establish an EBGP peer relationship with CE 2, and add the learned BGP routes to the routing table of VPN instance vpn1.
[PE2-bgp-default-vpn1] peer 2002::2 as-number 65002
[PE2-bgp-default-ipv6-vpn1] peer 2002::2 enable
6. Configure CE 2:
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 2002::2 64
# Establish an EBGP peer relationship with PE 2, and redistribute VPN routes.
[CE2] bgp 65002
[CE2-bgp-default] peer 2002::1 as-number 600
[CE2-bgp-default-ipv6] peer 2002::1 enable
# Execute the display ipv6 routing table command on CE 1 and CE 2 to verify that CE 1 and CE 2 have a route to each other. Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
ipv6 address 2001::1/64
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 enable
peer 5.5.5.9 enable
peer 2001::2 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
import-route isis 1
peer 2.2.2.9 enable
apply mpls-label
if-match mpls-label
apply mpls-label
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
import-route isis 1
peer 5.5.5.9 enable
apply mpls-label
if-match mpls-label
apply mpls-label
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 1
ipv6 address 2002::1/64
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 4.4.4.9 enable
peer 2.2.2.9 enable
peer 2002::2 enable
return
· CE 1:
sysname CE1
ipv6 address 2001::2/64
bgp 65001
router-id 6.6.6.6
import-route direct
peer 2001::1 enable
return
· CE 2:
sysname CE2
ipv6 address 2002::2/64
bgp 65002
router-id 7.7.7.7
import-route direct
peer 2002::1 enable
return
Example: Configuring IPv6 MPLS L3VPN inter-AS option C (method 2)
Site 1 and Site 2 belong to the same VPN. Site 1 accesses the network through PE 1 in AS 100, and Site 2 accesses the network through PE 2 in AS 600. PEs in the same AS run IS-IS.
PE 1 and PE 2 are MP-EBGP peers and exchange VPNv6 routes.
ASBR-PE 1 and ASBR-PE 2 label the routes received from each other, use EBGP to exchange labeled IPv4 routes, and redistribute IGP and BGP routes from each other.
Figure 59 Network diagram
Table 27 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
PE 1 |
Loop0 |
2.2.2.9/32 |
PE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/1 |
2001::1/64 |
XGE3/0/1 |
2002::1/64 |
XGE3/0/5 |
1.1.1.2/8 |
XGE3/0/5 |
9.1.1.2/8 |
ASBR-PE 1 |
Loop0 |
3.3.3.9/32 |
ASBR-PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/5 |
1.1.1.1/8 |
XGE3/0/5 |
9.1.1.1/8 |
XGE3/0/4 |
11.0.0.2/8 |
XGE3/0/4 |
11.0.0.1/8 |
CE 1 |
XGE3/0/1 |
2001::2/64 |
CE 2 |
XGE3/0/1 |
2002::2/64 |
1. Configure CE 1:
[CE1] bgp 65001
2. Configure PE 1:
[PE1] isis 1
[PE1-isis-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
# Configure interface Loopback 0 and enable IS-IS on it.
# Associate Ten-GigabitEthernet 3/0/1 with VPN instance vpn1, and specify an IPv6 address for the interface.
[PE1] bgp 100
[PE1-bgp-default-vpnv6] peer 5.5.5.9 enable
[ASBR-PE1] isis 1
# Redistribute BGP routes.
[ASBR-PE1-isis-1] address-family ipv4 unicast
[ASBR-PE1-isis-1-ipv4] import-route bgp
[ASBR-PE1-isis-1-ipv4] quit
[ASBR-PE1] mpls ldp
[ASBR-PE1-ldp] quit
# Create routing policy policy1.
# Enable BGP on ASBR-PE 1, and redistribute routes from IS-IS process 1.
[ASBR-PE1] bgp 100
[ASBR-PE2] isis 1
[ASBR-PE2-isis-1] address-family ipv4 unicast
[ASBR-PE2-isis-1-ipv4] import-route bgp
[ASBR-PE2-isis-1-ipv4] quit
[ASBR-PE2] mpls ldp
[ASBR-PE2-ldp] quit
# Enable BGP on ASBR-PE 2, and redistribute routes from IS-IS process 1.
[ASBR-PE2] bgp 600
5. Configure PE 2:
[PE2] isis 1
[PE2-isis-1] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] bgp 600
[PE2-bgp-default-vpnv6] peer 2.2.2.9 enable
6. Configure CE 2:
[CE2] bgp 65002
Configuration files
· PE 1:
sysname PE1
isis 1
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 5.5.5.9 enable
peer 2001::2 enable
return
· ASBR-PE 1:
sysname ASBR-PE1
isis 1
import-route bgp
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 100
import-route isis 1
apply mpls-label
return
· ASBR-PE 2:
sysname ASBR-PE2
isis 1
import-route bgp
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
isis enable 1
mpls enable
isis enable 1
mpls enable
mpls ldp enable
bgp 600
import-route isis 1
apply mpls-label
return
· PE 2:
sysname PE2
isis 1
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 1
isis enable 1
mpls enable
mpls ldp enable
bgp 600
peer 2.2.2.9 enable
peer 2002::2 enable
return
· CE 1:
sysname CE1
bgp 65001
router-id 6.6.6.6
import-route direct
peer 2001::1 enable
return
· CE 2:
sysname CE2
bgp 65002
router-id 7.7.7.7
import-route direct
peer 2002::1 enable
return
Example: Configuring IPv6 MPLS L3VPN carrier's carrier in the same AS
Configure carrier's carrier for the scenario shown in Figure 60. In this scenario:
· PE 1 and PE 2 are the provider carrier's PE routers. They provide VPN services to the customer carrier.
· CE 1 and CE 2 are the customer carrier's routers. They are connected to the provider carrier's backbone as CE routers.
· PE 3 and PE 4 are the customer carrier's PE routers. They provide IPv6 MPLS L3VPN services to end customers.
· CE 3 and CE 4 are customers of the customer carrier.
· The customer carrier and the provider carrier reside in the same AS.
The key to the carrier's carrier deployment is to configure exchange of two kinds of routes:
· Exchange of the customer carrier's internal routes on the provider carrier's backbone.
· Exchange of the end customers' internal routes between PE 3 and PE 4, the PEs of the customer carrier. In this process, an MP-IBGP peer relationship must be established between PE 3 and PE 4.
Table 28 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 3 |
XGE3/0/1 |
2001:1::1/96 |
CE 4 |
XGE3/0/1 |
2001:2::1/96 |
PE 3 |
Loop0 |
1.1.1.9/32 |
PE 4 |
Loop0 |
6.6.6.9/32 |
XGE3/0/1 |
2001:1::2/96 |
XGE3/0/1 |
2001:2::2/96 |
XGE3/0/5 |
10.1.1.1/24 |
XGE3/0/5 |
20.1.1.2/24 |
CE 1 |
Loop0 |
2.2.2.9/32 |
CE 2 |
Loop0 |
5.5.5.9/32 |
XGE3/0/4 |
10.1.1.2/24 |
XGE3/0/4 |
21.1.1.2/24 |
XGE3/0/5 |
11.1.1.1/24 |
XGE3/0/5 |
20.1.1.1/24 |
PE 1 |
Loop0 |
3.3.3.9/32 |
PE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/4 |
11.1.1.2/24 |
XGE3/0/4 |
30.1.1.2/24 |
XGE3/0/5 |
30.1.1.1/24 |
XGE3/0/5 |
21.1.1.1/24 |
1. Configure MPLS L3VPN on the provider carrier backbone. Configure IS-IS as the IGP, enable LDP on PE 1 and PE 2, and establish an MP-IBGP peer relationship between the PEs:
# Configure PE 1.
[PE1-LoopBack0] ip address 3.3.3.9 32
[PE1] mpls lsr-id 3.3.3.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] isis 1
[PE1-isis-1] network-entity 10.0000.0000.0000.0004.00
[PE1-isis-1] quit
[PE1-Ten-GigabitEthernet3/0/5] ip address 30.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE1] bgp 100
[PE1-bgp-default] peer 4.4.4.9 as-number 100
[PE1-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[PE1-bgp-default-vpnv4] peer 4.4.4.9 enable
[PE1-bgp-default-vpnv4] quit
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] isis 1
[PE2-isis-1] network-entity 10.0000.0000.0000.0005.00
[PE2-isis-1] quit
[PE2-Ten-GigabitEthernet3/0/4] ip address 30.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/4] isis enable 1
[PE2-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[PE2] bgp 100
[PE2-bgp-default] peer 3.3.3.9 as-number 100
[PE2-bgp-default-vpnv4] peer 3.3.3.9 enable
[PE2-bgp-default-vpnv4] quit
# On PE 1 or PE 2, execute the following commands:
¡ Execute the display mpls ldp peer command to verify that an LDP session in Operational state has been established between PE 1 and PE 2. (Details not shown.)
¡ Execute the display bgp peer vpnv4 command to verify that a BGP peer relationship in Established state has been established between PE 1 and PE 2. (Details not shown.)
¡ Execute the display isis peer command to verify that the IS-IS neighbor relationship has been established between PE 1 and PE 2. (Details not shown.)
2. Configure the customer carrier network. Configure IS-IS as the IGP, and enable LDP between PE 3 and CE 1, and between PE 4 and CE 2:
# Configure PE 3.
[Sysname] sysname PE3
[PE3] interface loopback 0
[PE3-LoopBack0] ip address 1.1.1.9 32
[PE3-LoopBack0] quit
[PE3] mpls lsr-id 1.1.1.9
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] isis 2
[PE3-isis-2] network-entity 10.0000.0000.0000.0001.00
[PE3-isis-2] quit
[PE3-LoopBack0] isis enable 2
[PE3] interface ten-gigabitethernet 3/0/5
[PE3-Ten-GigabitEthernet3/0/5] ip address 10.1.1.1 24
[PE3-Ten-GigabitEthernet3/0/5] isis enable 2
[PE3-Ten-GigabitEthernet3/0/5] mpls enable
[PE3-Ten-GigabitEthernet3/0/5] mpls ldp enable
[PE3-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE3-Ten-GigabitEthernet3/0/5] quit
# Configure CE 1.
[CE1] interface loopback 0
[CE1-LoopBack0] ip address 2.2.2.9 32
[CE1-LoopBack0] quit
[CE1] mpls lsr-id 2.2.2.9
[CE1] mpls ldp
[CE1-ldp] quit
[CE1] isis 2
[CE1-isis-2] network-entity 10.0000.0000.0000.0002.00
[CE1-isis-2] quit
[CE1-LoopBack0] isis enable 2
[CE1] interface ten-gigabitethernet 3/0/4
[CE1-Ten-GigabitEthernet3/0/4] ip address 10.1.1.2 24
[CE1-Ten-GigabitEthernet3/0/4] isis enable 2
[CE1-Ten-GigabitEthernet3/0/4] mpls enable
[CE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[CE1-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[CE1-Ten-GigabitEthernet3/0/4] quit
# Configure PE 4.
[Sysname] sysname PE4
[PE4] interface loopback 0
[PE4-LoopBack0] ip address 6.6.6.9 32
[PE4-LoopBack0] quit
[PE4] mpls lsr-id 6.6.6.9
[PE4] mpls ldp
[PE4-ldp] quit
[PE4] isis 2
[PE4-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE4-isis-2] quit
[PE4-LoopBack0] isis enable 2
[PE4] interface ten-gigabitethernet 3/0/5
[PE4-Ten-GigabitEthernet3/0/5] ip address 20.1.1.2 24
[PE4-Ten-GigabitEthernet3/0/5] isis enable 2
[PE4-Ten-GigabitEthernet3/0/5] mpls enable
[PE4-Ten-GigabitEthernet3/0/5] mpls ldp enable
[PE4-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE4-Ten-GigabitEthernet3/0/5] quit
# Configure CE 2.
[CE2] interface loopback 0
[CE2-LoopBack0] ip address 5.5.5.9 32
[CE2-LoopBack0] quit
[CE2] mpls lsr-id 5.5.5.9
[CE2] mpls ldp
[CE2-ldp] quit
[CE2] isis 2
[CE2-isis-2] network-entity 10.0000.0000.0000.0004.00
[CE2-isis-2] quit
[CE2-LoopBack0] isis enable 2
[CE2] interface ten-gigabitethernet 3/0/5
[CE2-Ten-GigabitEthernet3/0/5] ip address 20.1.1.1 24
[CE2-Ten-GigabitEthernet3/0/5] isis enable 2
[CE2-Ten-GigabitEthernet3/0/5] mpls enable
[CE2-Ten-GigabitEthernet3/0/5] mpls ldp enable
[CE2-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[CE2-Ten-GigabitEthernet3/0/5] quit
# Verify that an LDP session and IS-IS neighbor relationship can be established between PE 3 and CE 1 and between PE 4 and CE 2. (Details not shown.)
3. Connect the customer carrier and the provider carrier:
# Configure PE 1.
[PE1-vpn-instance-vpn1] route-distinguisher 200:1
[PE1] mpls ldp
[PE1-ldp] vpn-instance vpn1
[PE1-ldp-vpn-instance-vpn1] quit
[PE1-ldp] quit
[PE1] isis 2 vpn-instance vpn1
[PE1-isis-2] network-entity 10.0000.0000.0000.0003.00
[PE1-isis-2] address-family ipv4
[PE1-isis-2-ipv4] import-route bgp allow-ibgp
[PE1-isis-2-ipv4] quit
[PE1-isis-2] quit
[PE1] interface ten-gigabitethernet 3/0/4
[PE1-Ten-GigabitEthernet3/0/4] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/4] ip address 11.1.1.2 24
[PE1-Ten-GigabitEthernet3/0/4] isis enable 2
[PE1-Ten-GigabitEthernet3/0/4] mpls enable
[PE1-Ten-GigabitEthernet3/0/4] mpls ldp enable
[PE1-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[PE1-Ten-GigabitEthernet3/0/4] quit
[PE1] bgp 100
[PE1-bgp-default-ipv4-vpn1] import isis 2
# Configure CE 1.
[CE1] interface ten-gigabitethernet 3/0/5
[CE1-Ten-GigabitEthernet3/0/5] ip address 11.1.1.1 24
[CE1-Ten-GigabitEthernet3/0/5] isis enable 2
[CE1-Ten-GigabitEthernet3/0/5] mpls enable
[CE1-Ten-GigabitEthernet3/0/5] mpls ldp enable
[CE1-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[CE1-Ten-GigabitEthernet3/0/5] quit
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 200:2
[PE2] mpls ldp
[PE2-ldp] vpn-instance vpn1
[PE2-ldp-vpn-instance-vpn1] quit
[PE2-ldp] quit
[PE2] isis 2 vpn-instance vpn1
[PE2-isis-2] network-entity 10.0000.0000.0000.0006.00
[PE2-isis-2] address-family ipv4
[PE2-isis-2-ipv4] import-route bgp
[PE2-isis-2-ipv4] quit
[PE2-isis-2] quit
[PE2-Ten-GigabitEthernet3/0/5] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/5] ip address 21.1.1.1 24
[PE2-Ten-GigabitEthernet3/0/5] isis enable 2
[PE2-Ten-GigabitEthernet3/0/5] mpls ldp transport-address interface
[PE2] bgp 100
[PE2-bgp-default-ipv4-vpn1] import-route isis 2
# Configure CE 2.
[CE2] interface ten-gigabitethernet 3/0/4
[CE2-Ten-GigabitEthernet3/0/4] ip address 21.1.1.2 24
[CE2-Ten-GigabitEthernet3/0/4] isis enable 2
[CE2-Ten-GigabitEthernet3/0/4] mpls enable
[CE2-Ten-GigabitEthernet3/0/4] mpls ldp enable
[CE2-Ten-GigabitEthernet3/0/4] mpls ldp transport-address interface
[CE2-Ten-GigabitEthernet3/0/4] quit
# Verify that an LDP session and IS-IS neighbor relationship can be established between PE 1 and CE 1 and between PE 2 and CE 2. (Details not shown.)
4. Connect end customers and the customer carrier:
# Configure CE 3.
[Sysname] sysname CE3
[CE3] interface ten-gigabitethernet 3/0/1
[CE3-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::1 96
[CE3-Ten-GigabitEthernet3/0/1] quit
[CE3] bgp 65410
[CE3-bgp-default] router-id 7.7.7.7
[CE3-bgp-default] peer 2001:1::2 as-number 100
[CE3-bgp-default-ipv6] peer 2001:1::2 enable
# Configure PE 3.
[PE3] ip vpn-instance vpn1
[PE3-vpn-instance-vpn1] route-distinguisher 100:1
[PE3-vpn-instance-vpn1] vpn-target 1:1
[PE3-vpn-instance-vpn1] quit
[PE3] interface ten-gigabitethernet 3/0/1
[PE3-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE3-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::2 96
[PE3-Ten-GigabitEthernet3/0/1] quit
[PE3] bgp 100
[PE3-bgp-default] ip vpn-instance vpn1
[PE3-bgp-default-vpn1] peer 2001:1::1 as-number 65410
[PE3-bgp-default-vpn1] address-family ipv6 unicast
[PE3-bgp-default-ipv6-vpn1] peer 2001:1::1 enable
[PE3-bgp-default-ipv6-vpn1] quit
[PE3-bgp-default-vpn1] quit
[PE3-bgp-default] quit
# Configure CE 4.
[Sysname] sysname CE4
[CE4] interface ten-gigabitethernet 3/0/1
[CE4-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::1 96
[CE4-Ten-GigabitEthernet3/0/1] quit
[CE4] bgp 65420
[CE4-bgp-default] router-id 8.8.8.8
[CE4-bgp-default] peer 2001:2::2 as-number 100
[CE4-bgp-default-ipv6] peer 2001:2::2 enable
# Configure PE 4.
[PE4] ip vpn-instance vpn1
[PE4-vpn-instance-vpn1] route-distinguisher 100:2
[PE4-vpn-instance-vpn1] vpn-target 1:1
[PE4-vpn-instance-vpn1] quit
[PE4] interface ten-gigabitethernet 3/0/1
[PE4-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE4-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::2 96
[PE4-Ten-GigabitEthernet3/0/1] quit
[PE4] bgp 100
[PE4-bgp-default] ip vpn-instance vpn1
[PE4-bgp-default-vpn1] peer 2001:2::1 as-number 65420
[PE4-bgp-default-vpn1] address-family ipv6 unicast
[PE4-bgp-default-ipv6-vpn1] peer 2001:2::1 enable
[PE4-bgp-default-ipv6-vpn1] quit
[PE4-bgp-default-vpn1] quit
[PE4-bgp-default] quit
5. Configure an MP-IBGP peer relationship between the PEs of the customer carrier to exchange the VPN routes of the end customers:
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 6.6.6.9 as-number 100
[PE3-bgp-default] peer 6.6.6.9 connect-interface loopback 0
[PE3-bgp-default] address-family vpnv6
[PE3-bgp-default-af-vpnv6] peer 6.6.6.9 enable
[PE3-bgp-default-af-vpnv6] quit
# Configure PE 4.
[PE4] bgp 100
[PE4-bgp-default] peer 1.1.1.9 as-number 100
[PE4-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE4-bgp-default] address-family vpnv6
[PE4-bgp-default-vpnv6] peer 1.1.1.9 enable
[PE4-bgp-default-vpnv6] quit
1. Display the public network routing table and VPN routing table on the provider carrier PEs, for example, on PE 1:
# Verify that the public network routing table contains only routes of the provider carrier network.
[PE1] display ip routing-table
Destinations : 9 Routes : 9
3.3.3.9/32 Direct 0 0 127.0.0.1 Loop0
4.4.4.9/32 IS_L1 15 10 30.1.1.2 XGE3/0/5
30.1.1.0/24 Direct 0 0 30.1.1.1 XGE3/0/5
30.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/5
30.1.1.255/32 Direct 0 0 30.1.1.1 XGE3/0/5
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
# Verify that the VPN routing table contains the internal routes of the customer carrier network.
[PE1] display ip routing-table vpn-instance vpn1
Destinations : 11 Routes : 11
1.1.1.9/32 IS_L1 15 20 11.1.1.1 XGE3/0/4
2.2.2.9/32 IS_L1 15 10 11.1.1.1 XGE3/0/4
5.5.5.9/32 BGP 255 10 4.4.4.9 XGE3/0/5
6.6.6.9/32 BGP 255 20 4.4.4.9 XGE3/0/5
10.1.1.0/24 IS_L1 15 20 11.1.1.1 XGE3/0/4
11.1.1.0/24 Direct 0 0 11.1.1.2 XGE3/0/4
11.1.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/4
11.1.1.255/32 Direct 0 0 11.1.1.2 XGE3/0/4
20.1.1.0/24 BGP 255 20 4.4.4.9 XGE3/0/5
2. Display the routing table on the customer carrier CEs, for example, on CE 1:
# Verify that the routing table contains the internal routes of the customer carrier network.
[CE1] display ip routing-table
Destinations : 15 Routes : 15
1.1.1.9/32 IS_L1 15 10 10.1.1.1 XGE3/0/4
2.2.2.9/32 Direct 0 0 127.0.0.1 Loop0
5.5.5.9/32 IS_L2 15 74 11.1.1.2 XGE3/0/5
6.6.6.9/32 IS_L2 15 74 11.1.1.2 XGE3/0/5
10.1.1.0/24 Direct 0 0 10.1.1.2 XGE3/0/4
10.1.1.2/32 Direct 0 0 127.0.0.1 XGE3/0/4
10.1.1.255/32 Direct 0 0 10.1.1.2 XGE3/0/4
11.1.1.0/24 Direct 0 0 11.1.1.1 XGE3/0/5
11.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/5
11.1.1.255/32 Direct 0 0 11.1.1.1 XGE3/0/5
20.1.1.0/24 IS_L2 15 74 11.1.1.2 XGE3/0/5
3. Display the public network routing table and VPN routing table on the customer carrier PEs, for example, on PE 3:
# Verify that the public network routing table contains the internal routes of the customer carrier network.
[PE3] display ip routing-table
Destinations : 13 Routes : 13
1.1.1.9/32 Direct 0 0 127.0.0.1 Loop0
2.2.2.9/32 IS_L1 15 10 10.1.1.2 XGE3/0/5
5.5.5.9/32 IS_L2 15 84 10.1.1.2 XGE3/0/5
6.6.6.9/32 IS_L2 15 84 10.1.1.2 XGE3/0/5
10.1.1.0/24 Direct 0 0 10.1.1.1 XGE3/0/5
10.1.1.1/32 Direct 0 0 127.0.0.1 XGE3/0/5
10.1.1.255/32 Direct 0 0 10.1.1.1 XGE3/0/5
11.1.1.0/24 IS_L1 15 20 10.1.1.2 XGE3/0/5
20.1.1.0/24 IS_L2 15 84 10.1.1.2 XGE3/0/5
# Verify that the VPN routing table has the remote VPN route.
[PE3] display ipv6 routing-table vpn-instance vpn1
Destinations : 5 Routes : 5
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 2001:1::/96 Protocol : Direct
NextHop : :: Preference: 0
Interface : XGE3/0/1 Cost : 0
Destination: 2001:1::2/128 Protocol : Direct
Destination: 2001:2::/96 Protocol : BGP4+
NextHop : ::FFFF:6.6.6.9 Preference: 255
Interface : XGE3/0/5 Cost : 0
Destination: FE80::/10 Protocol : Direct
4. Verify that PE 3 and PE 4 can ping each other. (Details not shown.)
5. Verify that CE 3 and CE 4 can ping each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 1:1 import-extcommunity
isis 1
mpls lsr-id 3.3.3.9
mpls ldp
vpn-instance vpn1
interface LoopBack0
ip address 3.3.3.9 255.255.255.255
isis enable 1
ip address 11.1.1.2 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
interface Ten-GigabitEthernet3/0/5
ip address 30.1.1.1 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
bgp 100
peer 4.4.4.9 enable
import-route isis 2
return
· PE 2:
sysname PE2
isis 1
import-route bgp
mpls lsr-id 4.4.4.9
mpls ldp
vpn-instance vpn1
interface LoopBack0
isis enable 1
ip address 30.1.1.2 255.255.255.0
isis enable 1
mpls enable
mpls ldp enable
ip address 21.1.1.1 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 3.3.3.9 connect-interface LoopBack0
peer 3.3.3.9 enable
import-route isis 2
return
· CE 1:
sysname CE1
isis 2
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 2.2.2.9 255.255.255.255
isis enable 2
isis enable 2
mpls enable
mpls ldp enable
ip address 11.1.1.1 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
return
· CE 2:
sysname CE2
isis 2
mpls lsr-id 5.5.5.9
mpls ldp
interface LoopBack0
isis enable 2
ip address 21.1.1.2 255.255.255.0
isis enable 2
mpls enable
mpls ldp enable
isis enable 2
mpls enable
mpls ldp enable
return
· PE 3:
sysname PE3
isis 2
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
ip address 1.1.1.9 255.255.255.255
isis enable 2
interface Ten-GigabitEthernet3/0/1
ipv6 address 2001:1::2/96
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 6.6.6.9 connect-interface LoopBack0
peer 6.6.6.9 enable
return
· PE 4:
sysname PE4
isis 2
mpls lsr-id 6.6.6.9
mpls ldp
interface LoopBack0
ip address 6.6.6.9 255.255.255.255
isis enable 2
ipv6 address 2001:2::2/96
isis enable 2
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 connect-interface LoopBack0
peer 1.1.1.9 enable
return
· CE 3:
sysname CE3
ipv6 address 2001:1::1/96
bgp 65410
router-id 7.7.7.7
import-route direct
return
· CE 4:
sysname CE4
ipv6 address 2001:2::1/96
bgp 65420
router-id 8.8.8.8
import-route direct
return
Example: Configuring HoVPN
There are two levels of networks, the backbone and the MPLS VPN networks, as shown in Figure 61.
· SPEs act as PEs to allow MPLS VPNs to access the backbone.
· UPEs act as PEs of the MPLS VPNs to allow end users to access the VPNs.
· Performance requirements for the UPEs are lower than those for the SPEs.
· SPEs advertise routes permitted by the routing policies to UPEs, permitting CE 1 and CE 3 in VPN 1 to communicate with each other, and forbidding CE 2 and CE 4 in VPN 2 from communicating with each other.
Table 29 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
2001:1::1/96 |
CE 3 |
XGE3/0/1 |
2001:3::1/96 |
CE 2 |
XGE3/0/1 |
2001:2::1/96 |
CE 4 |
XGE3/0/1 |
2001:4::1/96 |
UPE 1 |
Loop0 |
1.1.1.9/32 |
UPE 2 |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
2001:1::2/96 |
XGE3/0/1 |
172.2.1.1/24 |
XGE3/0/2 |
2001:2::2/96 |
XGE3/0/2 |
2001:3::2/96 |
XGE3/0/3 |
172.1.1.1/24 |
XGE3/0/3 |
2001:4::2/96 |
SPE 1 |
Loop0 |
2.2.2.9/32 |
SPE 2 |
Loop0 |
3.3.3.9/32 |
XGE3/0/1 |
172.1.1.2/24 |
XGE3/0/1 |
180.1.1.2/24 |
XGE3/0/2 |
180.1.1.1/24 |
XGE3/0/2 |
172.2.1.2/24 |
1. Configure UPE 1:
# Configure basic MPLS and MPLS LDP to establish LDP LSPs.
[Sysname] sysname UPE1
[UPE1] interface loopback 0
[UPE1-LoopBack0] ip address 1.1.1.9 32
[UPE1-LoopBack0] quit
[UPE1] mpls lsr-id 1.1.1.9
[UPE1] mpls ldp
[UPE1-ldp] quit
[UPE1] interface ten-gigabitethernet 3/0/3
[UPE1-Ten-GigabitEthernet3/0/3] ip address 172.1.1.1 24
[UPE1-Ten-GigabitEthernet3/0/3] mpls enable
[UPE1-Ten-GigabitEthernet3/0/3] mpls ldp enable
[UPE1-Ten-GigabitEthernet3/0/3] quit
# Configure the IGP protocol (OSPF, in this example).
[UPE1] ospf
[UPE1-ospf-1] area 0
[UPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[UPE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[UPE1-ospf-1-area-0.0.0.0] quit
[UPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 1 and CE 2 to access UPE 1.
[UPE1] ip vpn-instance vpn1
[UPE1-vpn-instance-vpn1] route-distinguisher 100:1
[UPE1-vpn-instance-vpn1] vpn-target 100:1 both
[UPE1-vpn-instance-vpn1] quit
[UPE1] ip vpn-instance vpn2
[UPE1-vpn-instance-vpn2] route-distinguisher 100:2
[UPE1-vpn-instance-vpn2] vpn-target 100:2 both
[UPE1-vpn-instance-vpn2] quit
[UPE1] interface ten-gigabitethernet 3/0/1
[UPE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[UPE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::2 96
[UPE1-Ten-GigabitEthernet3/0/1] quit
[UPE1] interface ten-gigabitethernet 3/0/2
[UPE1-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn2
[UPE1-Ten-GigabitEthernet3/0/2] ipv6 address 2001:2::2 96
[UPE1-Ten-GigabitEthernet3/0/2] quit
# Establish an MP-IBGP peer relationship with SPE 1.
[UPE1] bgp 100
[UPE1-bgp-default] peer 2.2.2.9 as-number 100
[UPE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[UPE1-bgp-default] address-family vpnv6
[UPE1-bgp-default-vpnv6] peer 2.2.2.9 enable
[UPE1-bgp-default-vpnv6] quit
# Establish an EBGP peer relationship with CE 1.
[UPE1-bgp-default] ip vpn-instance vpn1
[UPE1-bgp-default-vpn1] peer 2001:1::1 as-number 65410
[UPE1-bgp-default-vpn1] address-family ipv6 unicast
[UPE1-bgp-default-ipv6-vpn1] peer 2001:1::1 enable
[UPE1-bgp-default-ipv6-vpn1] quit
[UPE1-bgp-default-vpn1] quit
# Establish an EBGP peer relationship with CE 2.
[UPE1-bgp-default] ip vpn-instance vpn2
[UPE1-bgp-default-vpn2] peer 2001:2::1 as-number 65420
[UPE1-bgp-default-vpn2] address-family ipv6 unicast
[UPE1-bgp-default-ipv6-vpn2] peer 2001:2::1 enable
[UPE1-bgp-default-ipv6-vpn2] quit
[UPE1-bgp-default-vpn2] quit
[UPE1-bgp-default] quit
2. Configure CE 1.
[Sysname] sysname CE1
[CE1] interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 2001:1::1 96
[CE1-Ten-GigabitEthernet3/0/1] quit
[CE1] bgp 65410
[CE1-bgp-default] peer 2001:1::2 as-number 100
[CE1-bgp-default] address-family ipv6 unicast
[CE1-bgp-default-ipv6] peer 2001:1::2 enable
[CE1-bgp-default-ipv6] import-route direct
[CE1-bgp-default-ipv6] quit
[CE1-bgp-default] quit
3. Configure CE 2.
[Sysname] sysname CE2
[CE2] interface ten-gigabitethernet 3/0/1
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 2001:2::1 96
[CE2-Ten-GigabitEthernet3/0/1] quit
[CE2] bgp 65420
[CE2-bgp-default] peer 2001:2::2 as-number 100
[CE2-bgp-default] address-family ipv6 unicast
[CE2-bgp-default-ipv6] peer 2001:2::2 enable
[CE2-bgp-default-ipv6] import-route direct
[CE2-bgp-default-ipv6] quit
[CE2-bgp-default] quit
4. Configure UPE 2:
[Sysname] sysname UPE2
[UPE2] interface loopback 0
[UPE2-LoopBack0] ip address 4.4.4.9 32
[UPE2-LoopBack0] quit
[UPE2] mpls lsr-id 4.4.4.9
[UPE2] mpls ldp
[UPE2-ldp] quit
[UPE2] interface ten-gigabitethernet 3/0/1
[UPE2-Ten-GigabitEthernet3/0/1] ip address 172.2.1.1 24
[UPE2-Ten-GigabitEthernet3/0/1] mpls enable
[UPE2-Ten-GigabitEthernet3/0/1] mpls ldp enable
[UPE2-Ten-GigabitEthernet3/0/1] quit
[UPE2] ospf
[UPE2-ospf-1] area 0
[UPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[UPE2-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[UPE2-ospf-1-area-0.0.0.0] quit
[UPE2-ospf-1] quit
# Configure VPN instances vpn1 and vpn2, allowing CE 3 and CE 4 to access UPE 2.
[UPE2] ip vpn-instance vpn1
[UPE2-vpn-instance-vpn1] route-distinguisher 300:1
[UPE2-vpn-instance-vpn1] vpn-target 100:1 both
[UPE2-vpn-instance-vpn1] quit
[UPE2] ip vpn-instance vpn2
[UPE2-vpn-instance-vpn2] route-distinguisher 400:2
[UPE2-vpn-instance-vpn2] vpn-target 100:2 both
[UPE2-vpn-instance-vpn2] quit
[UPE2] interface ten-gigabitethernet 3/0/2
[UPE2-Ten-GigabitEthernet3/0/2] ip binding vpn-instance vpn1
[UPE2-Ten-GigabitEthernet3/0/2] ipv6 address 2001:3::2 96
[UPE2-Ten-GigabitEthernet3/0/2] quit
[UPE2] interface ten-gigabitethernet 3/0/3
[UPE2-Ten-GigabitEthernet3/0/3] ip binding vpn-instance vpn2
[UPE2-Ten-GigabitEthernet3/0/3] ipv6 address 2001:4::2 96
[UPE2-Ten-GigabitEthernet3/0/3] quit
# Establish an MP-IBGP peer relationship with SPE 2.
[UPE2] bgp 100
[UPE2-bgp-default] peer 3.3.3.9 as-number 100
[UPE2-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[UPE2-bgp-default] address-family vpnv6
[UPE2-bgp-default-vpnv6] peer 3.3.3.9 enable
[UPE2-bgp-default-vpnv6] quit
# Establish an EBGP peer relationship with CE 3.
[UPE2-bgp-default] ip vpn-instance vpn1
[UPE2-bgp-default-vpn1] peer 2001:3::1 as-number 65430
[UPE2-bgp-default-vpn1] address-family ipv6 unicast
[UPE2-bgp-default-ipv6-vpn1] peer 2001:3::1 enable
[UPE2-bgp-default-ipv6-vpn1] quit
[UPE2-bgp-default-vpn1] quit
# Establish an EBGP peer relationship with CE 4.
[UPE2-bgp-default] ip vpn-instance vpn2
[UPE2-bgp-default-vpn2] peer 2001:4::1 as-number 65440
[UPE2-bgp-default-vpn2] address-family ipv6 unicast
[UPE2-bgp-default-ipv6-vpn2] peer 2001:4::1 enable
[UPE2-bgp-default-ipv6-vpn2] quit
[UPE2-bgp-default-vpn2] quit
[UPE2-bgp-default] quit
5. Configure CE 3.
[CE3-Ten-GigabitEthernet3/0/1] ipv6 address 2001:3::1 96
[CE3] bgp 65430
[CE3-bgp-default] peer 2001:3::2 as-number 100
[CE3-bgp-default] address-family ipv6 unicast
[CE3-bgp-default-ipv6] peer 2001:3::2 enable
[CE3-bgp-default-ipv6] import-route direct
[CE3-bgp-default-ipv6] quit
[CE3-bgp-default] quit
6. Configure CE 4.
[CE4-Ten-GigabitEthernet3/0/1] ipv6 address 2001:4::1 96
[CE4] bgp 65440
[CE4-bgp-default] peer 2001:4::2 as-number 100
[CE4-bgp-default] address-family ipv6 unicast
[CE4-bgp-default-ipv6] peer 2001:4::2 enable
[CE4-bgp-default-ipv6] import-route direct
[CE4-bgp-default-ipv6] quit
[CE4-bgp-default] quit
7. Configure SPE 1:
[Sysname] sysname SPE1
[SPE1] interface loopback 0
[SPE1-LoopBack0] ip address 2.2.2.9 32
[SPE1-LoopBack0] quit
[SPE1] mpls lsr-id 2.2.2.9
[SPE1] mpls ldp
[SPE1-ldp] quit
[SPE1] interface ten-gigabitethernet 3/0/1
[SPE1-Ten-GigabitEthernet3/0/1] ip address 172.1.1.2 24
[SPE1-Ten-GigabitEthernet3/0/1] mpls enable
[SPE1-Ten-GigabitEthernet3/0/1] mpls ldp enable
[SPE1-Ten-GigabitEthernet3/0/1] quit
[SPE1] interface ten-gigabitethernet 3/0/2
[SPE1-Ten-GigabitEthernet3/0/2] ip address 180.1.1.1 24
[SPE1-Ten-GigabitEthernet3/0/2] mpls enable
[SPE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
[SPE1-Ten-GigabitEthernet3/0/2] quit
[SPE1] ospf
[SPE1-ospf-1] area 0
[SPE1-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[SPE1-ospf-1-area-0.0.0.0] network 172.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE1-ospf-1-area-0.0.0.0] quit
[SPE1-ospf-1] quit
# Configure VPN instances vpn1 and vpn2.
[SPE1] ip vpn-instance vpn1
[SPE1-vpn-instance-vpn1] route-distinguisher 500:1
[SPE1-vpn-instance-vpn1] vpn-target 100:1 both
[SPE1-vpn-instance-vpn1] quit
[SPE1] ip vpn-instance vpn2
[SPE1-vpn-instance-vpn2] route-distinguisher 700:1
[SPE1-vpn-instance-vpn2] vpn-target 100:2 both
[SPE1-vpn-instance-vpn2] quit
# Establish MP-IBGP peer relationships with SPE 2 and UPE 1, and specify UPE 1 as a UPE.
[SPE1] bgp 100
[SPE1-bgp-default] peer 1.1.1.9 as-number 100
[SPE1-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[SPE1-bgp-default] peer 3.3.3.9 as-number 100
[SPE1-bgp-default] peer 3.3.3.9 connect-interface loopback 0
[SPE1-bgp-default] address-family vpnv6
[SPE1-bgp-default-vpnv6] peer 3.3.3.9 enable
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 enable
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 upe
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 next-hop-local
[SPE1-bgp-default-vpnv6] quit
# Create BGP-VPN instances for VPN instances vpn1 and vpn2, so the VPNv6 routes learned according to the RT attributes can be added into the BGP routing tables of the corresponding VPN instances.
[SPE1-bgp-default] ip vpn-instance vpn1
[SPE1-bgp-default-vpn1] quit
[SPE1-bgp-default] ip vpn-instance vpn2
[SPE1-bgp-default-vpn2] quit
[SPE1-bgp-default] quit
# Advertise to UPE 1 the routes permitted by a routing policy (the routes of CE 3).
[SPE1] ipv6 prefix-list hope index 10 permit 2001:3::1 96
[SPE1] route-policy hope permit node 0
[SPE1-route-policy-hope-0] if-match ipv6 address prefix-list hope
[SPE1-route-policy-hope-0] quit
[SPE1] bgp 100
[SPE1-bgp-default-vpnv6] peer 1.1.1.9 upe route-policy hope export
8. Configure SPE 2:
[Sysname] sysname SPE2
[SPE2] interface loopback 0
[SPE2-LoopBack0] ip address 3.3.3.9 32
[SPE2-LoopBack0] quit
[SPE2] mpls lsr-id 3.3.3.9
[SPE2] mpls ldp
[SPE2-ldp] quit
[SPE2] interface ten-gigabitethernet 3/0/1
[SPE2-Ten-GigabitEthernet3/0/1] ip address 180.1.1.2 24
[SPE2-Ten-GigabitEthernet3/0/1] mpls enable
[SPE2-Ten-GigabitEthernet3/0/1] mpls ldp enable
[SPE2-Ten-GigabitEthernet3/0/1] quit
[SPE2] interface ten-gigabitethernet 3/0/2
[SPE2-Ten-GigabitEthernet3/0/2] ip address 172.2.1.2 24
[SPE2-Ten-GigabitEthernet3/0/2] mpls enable
[SPE2-Ten-GigabitEthernet3/0/2] mpls ldp enable
[SPE2-Ten-GigabitEthernet3/0/2] quit
[SPE2] ospf
[SPE2-ospf-1] area 0
[SPE2-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[SPE2-ospf-1-area-0.0.0.0] network 172.2.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] network 180.1.1.0 0.0.0.255
[SPE2-ospf-1-area-0.0.0.0] quit
[SPE2-ospf-1] quit
[SPE2] ip vpn-instance vpn1
[SPE2-vpn-instance-vpn1] route-distinguisher 600:1
[SPE2-vpn-instance-vpn1] vpn-target 100:1 both
[SPE2-vpn-instance-vpn1] quit
[SPE2] ip vpn-instance vpn2
[SPE2-vpn-instance-vpn2] route-distinguisher 800:1
[SPE2-vpn-instance-vpn2] vpn-target 100:2 both
[SPE2-vpn-instance-vpn2] quit
# Establish MP-IBGP peer relationships with SPE 1 and UPE 2, and specify UPE 2 as a UPE.
[SPE2] bgp 100
[SPE2-bgp-default] peer 4.4.4.9 as-number 100
[SPE2-bgp-default] peer 4.4.4.9 connect-interface loopback 0
[SPE2-bgp-default] peer 2.2.2.9 as-number 100
[SPE2-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[SPE2-bgp-default] address-family vpnv6
[SPE2-bgp-default-vpnv6] peer 2.2.2.9 enable
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 enable
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 upe
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 next-hop-local
[SPE2-bgp-default-vpnv6] quit
[SPE2-bgp-default] ip vpn-instance vpn1
[SPE2-bgp-default-vpn1] quit
[SPE2-bgp-default] ip vpn-instance vpn2
[SPE2-bgp-default-vpn2] quit
[SPE2-bgp-default] quit
# Advertise to UPE 2 the routes permitted by a routing policy (the routes of CE 1).
[SPE2] ipv6 prefix-list hope index 10 permit 2001:1::1 96
[SPE2] route-policy hope permit node 0
[SPE2-route-policy-hope-0] if-match ipv6 address prefix-list hope
[SPE2-route-policy-hope-0] quit
[SPE2] bgp 100
[SPE2-bgp-default-vpnv6] peer 4.4.4.9 upe route-policy hope export
# Verify that CE 1 and CE3 can learn each other's interface routes and can ping each other. CE 2 and CE 4 cannot learn each other's interface routes and cannot ping each other. (Details not shown.)
Configuration files
· UPE 1:
sysname UPE1
vpn-target 100:1 import-extcommunity
vpn-target 100:1 export-extcommunity
vpn-target 100:2 import-extcommunity
vpn-target 100:2 export-extcommunity
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
interface Ten-GigabitEthernet3/0/2
interface Ten-GigabitEthernet3/0/3
ip address 172.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 connect-interface LoopBack0
peer 2.2.2.9 enable
return
· CE 1:
sysname CE1
bgp 65410
router-id 5.5.5.5
import-route direct
return
· CE 2:
sysname CE2
bgp 65420
router-id 6.6.6.6
import-route direct
return
· UPE 2:
sysname UPE2
ospf 1
area 0.0.0.0
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
ip address 172.2.1.1 255.255.255.0
mpls enable
mpls ldp enable
ipv6 address 2001:3::2/96
ipv6 address 2001:4::2/96
bgp 100
peer 3.3.3.9 enable
return
· CE 3:
sysname CE3
ipv6 address 2001:3::1/96
bgp 65430
router-id 7.7.7.7
import-route direct
return
· CE 4:
sysname CE4
ipv6 address 2001:4::1/96
bgp 65440
router-id 8.8.8.8
import-route direct
return
· SPE 1:
sysname SPE1
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 172.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 180.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 1.1.1.9 upe
peer 3.3.3.9 enable
ipv6 prefix-list hope index 10 permit 2001:3:: 96
return
· SPE 2:
sysname SPE2
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
ip address 180.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 172.2.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
peer 4.4.4.9 enable
peer 4.4.4.9 upe
ipv6 prefix-list hope index 10 permit 2001:1:: 96
return
Example: Configuring an OSPFv3 sham link
As shown in Figure 62, CE 1 and CE 2 belong to VPN 1. Configure an OSPFv3 sham link between PE 1 and PE 2 so traffic between the CEs is forwarded through the MPLS backbone instead of the backdoor link.
Table 30 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
100::1/64 |
CE 2 |
XGE3/0/1 |
120::1/64 |
XGE3/0/4 |
20::1/64 |
XGE3/0/4 |
30::2/64 |
PE 1 |
Loop0 |
1.1.1.9/32 |
PE 2 |
Loop0 |
2.2.2.9/32 |
Loop1 |
3::3/128 |
Loop1 |
5::5/128 |
XGE3/0/1 |
100::2/64 |
XGE3/0/1 |
120::2/64 |
XGE3/0/4 |
10.1.1.1/24 |
XGE3/0/5 |
10.1.1.2/24 |
Router A |
XGE3/0/5 |
30::1/64 |
XGE3/0/4 |
20::2/64 |
1. Configure OSPFv3 on the customer networks:
# Configure OSPFv3 on CE 1 and set the cost of the link between CE 1 and Router A to 2.
[CE1] ospfv3
[CE1-ospfv3-1] router-id 6.6.6.6
[CE1-ospfv3-1] area 1
[CE1-ospfv3-1-area-0.0.0.1] quit
[CE1-ospfv3-1] quit
[CE1]interface ten-gigabitethernet 3/0/1
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 100::1 64
[CE1-Ten-GigabitEthernet3/0/1] ospfv3 1 area 1
[CE1-Ten-GigabitEthernet3/0/4] ipv6 address 20::1 64
[CE1-Ten-GigabitEthernet3/0/4] ospfv3 cost 2
[CE1-Ten-GigabitEthernet3/0/4] ospfv3 1 area 1
[CE1] commit
# Configure OSPFv3 on CE 2 and set the cost of the link between CE 2 and Router A to 2.
[CE2] ospfv3
[CE2-ospfv3-1] router-id 8.8.8.8
[CE2-ospfv3-1] area 1
[CE2-ospfv3-1-area-0.0.0.1] quit
[CE2-ospfv3-1] quit
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 120::1 64
[CE2-Ten-GigabitEthernet3/0/1] ospfv3 1 area 1
[CE2-Ten-GigabitEthernet3/0/4] ipv6 address 30::2 64
[CE2-Ten-GigabitEthernet3/0/4] ospfv3 cost 2
[CE2-Ten-GigabitEthernet3/0/4] ospfv3 1 area 1
[CE2] commit
# Configure OSPFv3 on Router A.
[Sysname] sysname RouterA
[RouterA] ospfv3
[RouterA-ospfv3-1] router-id 7.7.7.7
[RouterA-ospfv3-1] area 1
[RouterA-ospfv3-1-area-0.0.0.1] quit
[RouterA-ospfv3-1] quit
[RouterA] interface ten-gigabitethernet 3/0/4
[RouterA-Ten-GigabitEthernet3/0/4] ipv6 address 20::2 64
[RouterA-Ten-GigabitEthernet3/0/4] ospfv3 1 area 1
[RouterA-Ten-GigabitEthernet3/0/4] quit
[RouterA] interface ten-gigabitethernet 3/0/5
[RouterA-Ten-GigabitEthernet3/0/5] ipv6 address 30::1 64
[RouterA-Ten-GigabitEthernet3/0/5] ospfv3 1 area 1
[RouterA-Ten-GigabitEthernet3/0/5] quit
[RouterA] commit
# Execute the display ipv6 routing-table command to verify that CE 1 and CE 2 have learned the route to each other. (Details not shown.)
2. Configure IPv6 MPLS L3VPN on the backbone:
# Configure basic MPLS and MPLS LDP on PE 1 to establish LDP LSPs.
[Sysname] sysname PE1
[PE1] interface loopback 0
[PE1-LoopBack0] ip address 1.1.1.9 32
[PE1-LoopBack0] quit
[PE1] mpls lsr-id 1.1.1.9
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/4] ip address 10.1.1.1 24
# Configure PE 1 to take PE 2 as an MP-IBGP peer.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.9 as-number 100
[PE1-bgp-default] peer 2.2.2.9 connect-interface loopback 0
[PE1-bgp-default] address-family vpnv6
[PE1-bgp-default-vpnv6] peer 2.2.2.9 enable
[PE1-bgp-default-vpnv6] quit
[PE1-bgp-default] quit
# Configure OSPF on PE 1.
[PE1] ospf 1
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure basic MPLS and MPLS LDP on PE 2 to establish LDP LSPs.
[Sysname] sysname PE2
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 2.2.2.9 32
[PE2-LoopBack0] quit
[PE2] mpls lsr-id 2.2.2.9
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/5] ip address 10.1.1.2 24
# Configure PE 2 to take PE 1 as an MP-IBGP peer.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.9 as-number 100
[PE2-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE2-bgp-default] address-family vpnv6
[PE2-bgp-default-vpnv6] peer 1.1.1.9 enable
[PE2-bgp-default-vpnv6] quit
[PE2-bgp-default] quit
# Configure OSPF on PE 2.
[PE2] ospf 1
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE2-ospf-1] quit
3. Configure PEs to allow CE access:
# Configure PE 1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] quit
[PE1] interface ten-gigabitethernet 3/0/1
[PE1-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 100::2 64
[PE1-Ten-GigabitEthernet3/0/1] ospfv3 100 area 1
[PE1-Ten-GigabitEthernet3/0/1] quit
[PE1] ospfv3 100
[PE1-ospfv3-100] router-id 100.1.1.1
[PE1-ospfv3-100] domain-id 10
[PE1-ospfv3-100] quit
[PE1] bgp 100
[PE1-bgp-default-vpn1] address-family ipv6 unicast
[PE1-bgp-default-ipv6-vpn1] import-route ospfv3 100
[PE1-bgp-default-ipv6-vpn1] import-route direct
[PE1-bgp-default-ipv6-vpn1] quit
[PE1-bgp-default-vpn1] quit
# Configure PE 2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] route-distinguisher 100:2
[PE2-vpn-instance-vpn1] quit
[PE2] interface ten-gigabitethernet 3/0/1
[PE2-Ten-GigabitEthernet3/0/1] ip binding vpn-instance vpn1
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 120::2 64
[PE2-Ten-GigabitEthernet3/0/1] ospfv3 100 area 1
[PE2-Ten-GigabitEthernet3/0/1] quit
[PE2] ospfv3 100
[PE2-ospfv3-100] router-id 120.1.1.1
[PE2-ospfv3-100] domain-id 10
[PE2-ospfv3-100] quit
[PE2] bgp 100
[PE2-bgp-default-vpn1] address-family ipv6 unicast
[PE2-bgp-default-ipv6-vpn1] import-route ospfv3 100
[PE2-bgp-default-ipv6-vpn1] import-route direct
[PE2-bgp-default-ipv6-vpn1] quit
[PE2-bgp-default-vpn1] quit
# Execute the display ipv6 routing-table vpn-instance command on the PEs. Verify that the path to the peer CE is along the OSPFv3 route across the customer networks, instead of the IPv6 BGP route across the backbone. (Details not shown.)
4. Configure a sham link:
# Configure PE 1.
[PE1] interface loopback 1
[PE1-LoopBack1] ip binding vpn-instance vpn1
[PE1-LoopBack1] ipv6 address 3::3 128
[PE1-LoopBack1] quit
[PE1] ospfv3 100
[PE1-ospfv3-100] area 1
[PE1-ospfv3-100-area-0.0.0.1] sham-link 3::3 5::5
[PE1-ospfv3-100-area-0.0.0.1] quit
# Configure PE 2.
[PE2] interface loopback 1
[PE2-LoopBack1] ip binding vpn-instance vpn1
[PE2-LoopBack1] ipv6 address 5::5 128
[PE2-LoopBack1] quit
[PE2] ospfv3 100
[PE2-ospfv3-100] area 1
[PE2-ospfv3-100-area-0.0.0.1] sham-link 5::5 3::3
[PE2-ospfv3-100-area-0.0.0.1] quit
# Execute the display ipv6 routing-table vpn-instance command on the PEs to verify the following results (details not shown):
· The path to the peer CE is now along the IPv6 BGP route across the backbone.
· A route to the sham link destination address exists.
The following is the sample output from the command on PE 1:
[PE1] display ipv6 routing-table vpn-instance vpn1
Destination: 3::3/128 Protocol : Direct
Interface : Loop1 Cost : 0
Destination: 5::5/128 Protocol : BGP4+
NextHop : ::FFFF:2.2.2.9 Preference: 255
Interface : XGE3/0/4 Cost : 0
Destination: 20::/64 Protocol : O_INTRA
NextHop : FE80::8824:DAFF:FEF0:306 Preference: 10
Interface : XGE3/0/1 Cost : 3
Destination: 30::/64 Protocol : O_INTRA
Interface : XGE3/0/1 Cost : 4
Destination: 100::/64 Protocol : Direct
Destination: 100::2/128 Protocol : Direct
Destination: 120::/64 Protocol : BGP4+
# Execute the display ipv6 routing-table command on the CEs. Verify that the next hop of the OSPFv3 route to the peer CE is the interface connected to the PE (Ten-GigabitEthernet 3/0/1). This means that the VPN traffic to the peer CE is forwarded over the backbone.
[CE1] display ipv6 routing-table
Destinations : 8 Routes : 8
Destination: 20::/64 Protocol : Direct
Destination: 20::1/128 Protocol : Direct
NextHop : FE80::8824:DDFF:FE48:409 Preference: 10
Interface : XGE3/0/4 Cost : 3
Destination: 100::1/128 Protocol : Direct
Destination: 120::/64 Protocol : O_INTRA
NextHop : FE80::8816:C4FF:FE9D:106 Preference: 10
# Verify that a sham link has been established on PEs, for example, on PE 1.
[PE1] display ospfv3 sham-link
OSPFv3 Process 100 with Router ID 100.1.1.1
Sham-link (Area: 0.0.0.1)
Neighbor ID State Instance ID Destination address
120.1.1.1 P-2-P 0 5::5
# Verify that the peer state is Full on PE 1.
[PE1] display ospfv3 sham-link verbose
Source : 3::3
Destination : 5::5
Interface ID: 2147483649
Neighbor ID : 120.1.1.1, Neighbor state: Full
Cost: 1 State: P-2-P Type: Sham Instance ID: 0
Timers: Hello 10, Dead 40, Retransmit 5, Transmit delay 1
Request list: 0 Retransmit list: 0
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
ospfv3 100 vpn-instance vpn1
router-id 100.1.1.1
domain-id 0.0.0.10
area 0.0.0.1
sham-link 3::3 5::5
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
interface LoopBack1
ipv6 address 3::3/128
ospfv3 100 area 0.0.0.1
ipv6 address 100::2/64
mpls enable
mpls ldp enable
bgp 100
peer 2.2.2.9 enable
import-route direct
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
router-id 120.1.1.1
domain-id 0.0.0.10
area 0.0.0.1
sham-link 5::5 3::3
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
interface LoopBack1
ipv6 address 5::5/128
ipv6 address 120::2/64
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
import-route direct
return
· CE 1:
sysname CE1
ospfv3 1
router-id 6.6.6.6
area 0.0.0.1
ospfv3 1 area 0.0.0.1
ipv6 address 100::1/64
ospfv3 cost 2
return
· CE 2:
sysname CE2
ospfv3 1
router-id 8.8.8.8
area 0.0.0.1
ipv6 address 120::1/64
ospfv3 cost 2
return
· Router A:
sysname RouterA
ospfv3 1
router-id 7.7.7.7
area 0.0.0.1
return
Example: Configuring BGP AS number substitution
As shown in Figure 63, CE 1 and CE 2 belong to VPN 1, and are connected to PE 1 and PE 2. The two CEs have the same AS number, 600. Configure BGP AS number substitution on the PEs to avoid route loss.
Table 31 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
XGE3/0/1 |
10:1::2/96 |
P |
Loop0 |
2.2.2.9/32 |
XGE3/0/2 |
100::1/96 |
XGE3/0/1 |
20.1.1.2/24 |
PE 1 |
Loop0 |
10.1.1.1/32 |
XGE3/0/2 |
30.1.1.1/24 |
XGE3/0/1 |
10:1::1/96 |
PE 2 |
Loop0 |
10.1.1.2/32 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/1 |
10:2::1/96 |
CE 2 |
XGE3/0/1 |
10:2::2/96 |
XGE3/0/2 |
30.1.1.2/24 |
XGE3/0/2 |
200::1/96 |
1. Configure an IGP (OSPF in this example) on the MPLS backbone to establish connectivity between the PEs and the P device.
# Configure PE 1.
[PE1-LoopBack0] ip address 10.1.1.1 32
[PE1] interface ten-gigabitethernet 3/0/2
[PE1-Ten-GigabitEthernet3/0/2] ip address 20.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/2] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.1 0.0.0.0
[PE1-ospf-1] quit
# Configure the P device.
[Sysname] sysname P
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.9 32
[P-LoopBack0] quit
[P] interface ten-gigabitethernet 3/0/1
[P-Ten-GigabitEthernet3/0/1] ip address 20.1.1.2 24
[P-Ten-GigabitEthernet3/0/1] quit
[P] interface ten-gigabitethernet 3/0/2
[P-Ten-GigabitEthernet3/0/2] ip address 30.1.1.1 24
[P-Ten-GigabitEthernet3/0/2] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[P-ospf-1-area-0.0.0.0] quit
[P-ospf-1] quit
# Configure PE 2.
[PE2-LoopBack0] ip address 10.1.1.2 32
[PE2] interface ten-gigabitethernet 3/0/2
[PE2-Ten-GigabitEthernet3/0/2] ip address 30.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/2] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 10.1.1.2 0.0.0.0
[PE2-ospf-1] quit
# Verify that OSPF neighbor relationships can be established between PE 1, the P device, and PE 2:
¡ Execute the display ospf peer command on each device to verify that their OSPF neighbors have reached the FULL state.
¡ Execute the display ip routing-table command to verify that the PEs can learn the routes to the Loopback interfaces on the remote PEs.
2. Configure basic MPLS and MPLS LDP on the MPLS backbone to establish LDP LSPs:
# Configure PE 1.
[PE1] mpls lsr-id 10.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/2] mpls enable
[PE1-Ten-GigabitEthernet3/0/2] mpls ldp enable
[P] mpls lsr-id 2.2.2.9
[P] mpls ldp
[P-ldp] quit
[P-Ten-GigabitEthernet3/0/1] mpls enable
[P-Ten-GigabitEthernet3/0/1] mpls ldp enable
[P-Ten-GigabitEthernet3/0/2] mpls enable
[P-Ten-GigabitEthernet3/0/2] mpls ldp enable
[P] commit
# Configure PE 2.
[PE2] mpls lsr-id 10.1.1.2
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/2] mpls enable
[PE2-Ten-GigabitEthernet3/0/2] mpls ldp enable
# Verify that LDP sessions can be established between PE 1, the P device, and PE 2:
¡ Execute the display mpls ldp peer command on each device to verify that their LDP sessions are in operational state.
¡ Execute the display mpls ldp lsp command to verify establishment of LDP LSPs.
3. Configure VPN instances on PEs to provide network access for CEs:
# Configure PE 1.
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 10:1::1 96
# Configure PE 2.
[PE2-vpn-instance-vpn1] route-distinguisher 200:1
[PE2-vpn-instance-vpn1] vpn-target 111:1
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 10:2::1 96
# Configure CE 1.
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 10:1::2 96
[CE1] interface ten-gigabitethernet 3/0/2
[CE1-Ten-GigabitEthernet3/0/2] ipv6 address 100::1 96
[CE1-Ten-GigabitEthernet3/0/2] quit
# Configure CE 2.
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 10:2::2 96
[CE2] interface ten-gigabitethernet 3/0/2
[CE2-Ten-GigabitEthernet3/0/2] ipv6 address 200::1 96
[CE2-Ten-GigabitEthernet3/0/2] quit
# Execute the display ip vpn-instance command on the PEs to verify the VPN instance configuration. Make sure the PEs can ping the CEs attached to them.
4. Establish EBGP peer relationships between each PE and the CE attached to them, and redistribute VPN IPv4 routes.
# Configure CE 1.
[CE1] bgp 600
[CE1-bgp-default] router-id 4.4.4.4
[CE1-bgp-default] peer 10:1::1 as-number 100
[CE1-bgp-default-ipv6] peer 10:1::1 enable
# Configure CE 2.
[CE2] bgp 600
[CE2-bgp-default] router-id 5.5.5.5
[CE2-bgp-default] peer 10:2::1 as-number 100
[CE2-bgp-default-ipv6] peer 10:2::1 enable
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10:1::2 as-number 600
[PE1-bgp-default-ipv6-vpn1] peer 10:1::2 enable
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10:2::2 as-number 600
[PE2-bgp-default-ipv6-vpn1] peer 10:2::2 enable
# Execute the display bgp peer ipv6 vpn-instance command on the PEs to verify that they have established BGP peer relationships with their CEs and the peer relationships are in Established state.
5. Establish MP-IBGP peer relationships between PEs:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 10.1.1.2 as-number 100
[PE1-bgp-default] peer 10.1.1.2 connect-interface loopback 0
[PE1-bgp-default-vpnv6] peer 10.1.1.2 enable
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 10.1.1.1 as-number 100
[PE2-bgp-default] peer 10.1.1.1 connect-interface loopback 0
[PE2-bgp-default-vpnv6] peer 10.1.1.1 enable
# Execute the display ipv6 routing-table command on CE 2 to verify that CE 2 has not learned the route to the VPN (100::/96) behind CE 1.
[CE2] display ipv6 routing-table
Destinations : 6 Routes : 6
Destination: 10:2::/96 Protocol : Direct
Destination: 10:2::2/128 Protocol : Direct
Destination: 200::/96 Protocol : Direct
Interface : XGE3/0/2 Cost : 0
Destination: 200::1/128 Protocol : Direct
# Execute the display ipv6 routing-table command on CE 1 to verify that CE 1 has not learned the route to the VPN behind CE 2. (Details not shown.)
# Execute the display ipv6 routing-table vpn-instance command on the PEs. The output shows the route to the VPN behind the peer CE. The following is the sample command output on PE 2:
[PE2] display ipv6 routing-table vpn-instance vpn1
Destinations : 7 Routes : 7
Destination: 10:1::/96 Protocol : BGP4+
NextHop : ::FFFF:10.1.1.1 Preference: 255
Destination: 10:2::1/128 Protocol : Direct
Destination: 100::/96 Protocol : BGP4+
Destination: 200::/96 Protocol : BGP4+
NextHop : 10:2::2 Preference: 255
# Enable BGP update packet debugging on CE 2.
<CE2> terminal monitor
<CE2> terminal logging level 7
<CE2> debugging bgp update 10:2::1 ipv6
# Soft-reset all BGP sessions on PE 2.
<PE2> refresh bgp all export ipv6 vpn-instance vpn1
# View the debugging messages on CE 2. The messages show that CE 2 received the route towards CE 1 from PE 2, with an AS path list of 100 600. Because AS number 600 in the AS path list is the local AS number of CE 2, CE 2 determined that a loop exited and ignored the route.
<CE2>*Apr 27 14:24:34:235 2025 CE2 BGP/7/DEBUG:
BGP_IPV6.: Recv UPDATE from peer 10:2::1 with following destinations:
Update message length : 107
Origin : Incomplete
AS path : 100 600
Next hop : 10:2::1
BGP.: Error identified while receiving UPDATE message from the peer 10:2::1 and ignored
Reason: Looping in ASPATH value.
10:1::/96 PathID 0 ,
100::/96 PathID 0 ,
6. Configure BGP AS number substitution:
# Configure BGP AS number substitution on PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10:1::2 substitute-as
# Configure BGP AS number substitution on PE 2.
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10:2::2 substitute-as
# On CE 2, verify that among the routes advertised by PE 2 to CE 2, the AS path lists in the routes for 10:1::/96 and 100::/96 have changed from 100 600 to 100 100.
<CE2>*Apr 27 14:26:19:224 2025 CE2 BGP/7/DEBUG:
Origin : Incomplete
AS path : 100 100
Next hop : 10:2::1
*Apr 27 14:26:19:224 2025 CE2 BGP/7/DEBUG: -MDC=1;
100::/96 PathID 0 ,
# Verify that CEs have learned routes to each other. Take CE 2 for example:
<CE2> display ipv6 routing-table
NextHop : 10:2::1 Preference: 255
# Verify that CE 1 and CE 2 can ping the interface addresses of each other. (Details not shown.)
Configuration files
· PE 1:
sysname PE1
vpn-target 111:1 import-extcommunity
vpn-target 111:1 export-extcommunity
ospf 1
area 0.0.0.0
mpls ldp
interface LoopBack0
ip address 10.1.1.1 255.255.255.255
ipv6 address 10:1::1/96
ip address 20.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 10.1.1.2 connect-interface LoopBack0
peer 10:1::2 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 20.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls ldp
interface LoopBack0
ip address 10.1.1.2 255.255.255.255
ipv6 address 10:2::1/96
mpls enable
mpls ldp enable
bgp 100
peer 10.1.1.1 connect-interface LoopBack0
peer 10:2::2 enable
return
· CE 1:
sysname CE1
ipv6 address 10:1::2/96
ipv6 address 100::1/96
bgp 600
router-id 4.4.4.4
import-route direct
peer 10:1::1 enable
return
· CE 2:
sysname CE2
ipv6 address 10:2::2/96
ipv6 address 200::1/96
bgp 600
router-id 5.5.5.5
import-route direct
peer 10:2::1 enable
return
Example: Configuring BGP AS number substitution and SoO attribute
CE 1, CE 2, and CE 3 belong to VPN 1, and are connected to PE1, PE 2, and PE 3. CE 1 and CE 2 reside in the same site. CE1, CE2, and CE 3 all use AS number 600.
To avoid route loss, configure BGP AS number substitution on PEs.
To avoid routing loops, configure the same SoO attribute on PE 1 and PE 2 for CE 1 and CE 2.
Figure 64 Network diagram
Table 32 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
CE 1 |
Loop0 |
100::1/96 |
CE 3 |
Loop0 |
200::1/96 |
XGE3/0/1 |
10:1::1/96 |
XGE3/0/1 |
10:3::1/96 |
CE 2 |
XGE3/0/1 |
10:2::1/96 |
PE 2 |
Loop0 |
2.2.2.9/32 |
PE 1 |
Loop0 |
1.1.1.9/32 |
XGE3/0/1 |
10:2::2/96 |
XGE3/0/1 |
10:1::2/96 |
XGE3/0/2 |
40.1.1.1/24 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/3 |
20.1.1.2/24 |
XGE3/0/3 |
30.1.1.1/24 |
P |
Loop0 |
3.3.3.9/32 |
PE 3 |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
30.1.1.2/24 |
XGE3/0/1 |
10:3::2/96 |
XGE3/0/2 |
40.1.1.2/24 |
XGE3/0/2 |
50.1.1.2/24 |
XGE3/0/3 |
50.1.1.1/24 |
# Configure PE 1.
[PE1] interface ten-gigabitethernet 3/0/3
[PE1-Ten-GigabitEthernet3/0/3] ip address 30.1.1.1 24
[PE1-Ten-GigabitEthernet3/0/3] quit
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure PE 2.
[PE2-Ten-GigabitEthernet3/0/2] ip address 40.1.1.1 24
[PE2] interface ten-gigabitethernet 3/0/3
[PE2-Ten-GigabitEthernet3/0/3] ip address 20.1.1.2 24
[PE2-Ten-GigabitEthernet3/0/3] quit
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE2-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[PE2-ospf-1] quit
[Sysname] sysname P
[P-LoopBack0] ip address 3.3.3.9 32
[P-LoopBack0] quit
[P-Ten-GigabitEthernet3/0/1] ip address 30.1.1.2 24
[P-Ten-GigabitEthernet3/0/2] ip address 40.1.1.2 24
[P] interface ten-gigabitethernet 3/0/3
[P-Ten-GigabitEthernet3/0/3] ip address 50.1.1.1 24
[P-Ten-GigabitEthernet3/0/3] quit
[P] ospf
[P-ospf-1] area 0
[P-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 50.1.1.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[P-ospf-1] quit
# Configure PE 3.
[PE3-LoopBack0] ip address 4.4.4.9 32
[PE3] interface ten-gigabitethernet 3/0/2
[PE3-Ten-GigabitEthernet3/0/2] ip address 50.1.1.2 24
[PE3-Ten-GigabitEthernet3/0/2] quit
[PE3] ospf
[PE3-ospf-1] area 0
[PE3-ospf-1-area-0.0.0.0] network 50.1.1.0 0.0.0.255
[PE3-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[PE3-ospf-1] quit
# Verify that OSPF neighbor relationships can be established between PE 1, PE 2, the P device, and PE 3:
¡ Execute the display ip routing-table command to verify that the PEs can learn the routes to the loopback interfaces on the remote PEs.
# Configure PE 1.
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-Ten-GigabitEthernet3/0/3] mpls enable
[PE1-Ten-GigabitEthernet3/0/3] mpls ldp enable
# Configure PE 2.
[PE2] mpls ldp
[PE2-ldp] quit
[PE2-Ten-GigabitEthernet3/0/3] mpls enable
[PE2-Ten-GigabitEthernet3/0/3] mpls ldp enable
[P] mpls lsr-id 3.3.3.9
[P] mpls ldp
[P-ldp] quit
[P-Ten-GigabitEthernet3/0/3] mpls enable
[P-Ten-GigabitEthernet3/0/3] mpls ldp enable
# Configure PE 3.
[PE3] mpls lsr-id 4.4.4.9
[PE3] mpls ldp
[PE3-ldp] quit
[PE3-Ten-GigabitEthernet3/0/2] mpls enable
[PE3-Ten-GigabitEthernet3/0/2] mpls ldp enable
# Verify that LDP sessions can be established between PE 1, PE 2, the P device, and PE 3:
# Configure PE 1.
[PE1-Ten-GigabitEthernet3/0/1] ipv6 address 10:1::2 96
# Configure PE 2.
[PE2-Ten-GigabitEthernet3/0/1] ipv6 address 10:2::2 96
# Configure PE 3.
[PE3-vpn-instance-vpn1] route-distinguisher 300:1
[PE3-vpn-instance-vpn1] vpn-target 111:1
[PE3-Ten-GigabitEthernet3/0/1] ipv6 address 10:3::2 96
# Configure CE 1.
[CE1-Ten-GigabitEthernet3/0/1] ipv6 address 10:1::1 96
[CE1-LoopBack0] ipv6 address 100::1 96
# Configure CE 2.
[CE2-Ten-GigabitEthernet3/0/1] ipv6 address 10:2::1 96
# Configure CE 3.
[CE3-Ten-GigabitEthernet3/0/1] ipv6 address 10:3::1 96
[CE3] interface loopback 0
[CE3-LoopBack0] ipv6 address 200::1 96
[CE3-LoopBack0] quit
# Configure CE 1.
[CE1] bgp 600
[CE1-bgp-default] router-id 5.5.5.5
[CE1-bgp-default] peer 10:1::2 as-number 100
[CE1-bgp-default-ipv6] peer 10:1::2 enable
# Configure CE 2.
[CE2] bgp 600
[CE2-bgp-default] router-id 6.6.6.6
[CE2-bgp-default] peer 10:2::2 as-number 100
[CE2-bgp-default-ipv6] peer 10:2::2 enable
# Configure CE 3.
[CE3] bgp 600
[CE3-bgp-default] peer 10:3::2 as-number 100
[CE3-bgp-default-ipv6] peer 10:3::2 enable
5. Configure BGP AS number substitution:
[PE1] bgp 100
[PE1-bgp-default-vpn1] peer 10:1::1 as-number 600
[PE1-bgp-default-vpn1] peer 10:1::1 substitute-as
[PE1-bgp-default-ipv6-vpn1] peer 10:1::1 enable
[PE2] bgp 100
[PE2-bgp-default-vpn1] peer 10:2::1 as-number 600
[PE2-bgp-default-vpn1] peer 10:2::1 substitute-as
[PE2-bgp-default-ipv6-vpn1] peer 10:2::1 enable
# Configure BGP AS number substitution on PE 3.
[PE3] bgp 100
[PE3-bgp-default-vpn1] peer 10:3::1 as-number 600
[PE3-bgp-default-vpn1] peer 10:3::1 substitute-as
[PE3-bgp-default-ipv6-vpn1] peer 10:3::1 enable
6. Establish MP-IBGP peer relationships between PEs and specify PE 1 as the RR.
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-vpnv6] peer 2.2.2.9 reflect-client
[PE1-bgp-default-vpnv6] peer 4.4.4.9 enable
[PE1-bgp-default-vpnv6] peer 4.4.4.9 reflect-client
# Configure PE 2.
[PE2] bgp 100
# Configure PE 3.
[PE3] bgp 100
[PE3-bgp-default] peer 1.1.1.9 as-number 100
[PE3-bgp-default] peer 1.1.1.9 connect-interface loopback 0
[PE3-bgp-default-vpnv6] peer 1.1.1.9 enable
[PE3-bgp-default-vpnv6] quit
[PE3] commit
# Display routing information on CE 2. The output shows that CE 2 has learned the route for 100.1.1.1/32 from CE 1. Routing loop occurs when the route advertised by CE 1 is re-advertised back to the site where CE 1 and CE 2 reside via PE 1, PE 2, and CE 2.
# Display routing information on CE 2. The output shows that CE 2 has learned the route 100::/96 from CE 1. Routing loop occurs when the route advertised by CE 1 is re-advertised back to the site where CE 1 and CE 2 reside via PE 1, PE 2, and CE 2.
Destination: 10:3::/96 Protocol : BGP4+
7. Configure BGP SoO attributes:
# On PE 1, configure the SoO attribute as 1:100 for CE 1.
[PE1] bgp 100
[PE1-bgp-default-ipv6-vpn1] peer 10:1::1 soo 1:100
# On PE 2, configure the SoO attribute as 1:100 for CE 2.
[PE2] bgp 100
[PE2-bgp-default-ipv6-vpn1] peer 10:2::1 soo 1:100
# Verify that PE 2 does not advertise routes received from CE 1 to CE 2 because the same SoO attribute has been configured. Display the routing table of CE 2. The output shows that the route 100::/96 has been removed.
Configuration files
· PE 1:
sysname PE1
ospf 1
area 0.0.0.0
mpls lsr-id 1.1.1.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 4.4.4.9 connect-interface LoopBack0
peer 2.2.2.9 enable
peer 4.4.4.9 enable
peer 10:1::1 enable
return
· PE 2:
sysname PE2
ospf 1
area 0.0.0.0
mpls lsr-id 2.2.2.9
mpls ldp
interface LoopBack0
ip address 40.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 10:2::1 enable
return
· P:
sysname P
ospf 1
area 0.0.0.0
mpls lsr-id 3.3.3.9
mpls ldp
interface LoopBack0
mpls enable
mpls ldp enable
ip address 40.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
ip address 50.1.1.1 255.255.255.0
mpls enable
mpls ldp enable
return
· PE 3:
sysname PE3
ospf 1
area 0.0.0.0
mpls lsr-id 4.4.4.9
mpls ldp
interface LoopBack0
ip address 4.4.4.9 255.255.255.255
ipv6 address 10:3::2/96
ip address 50.1.1.2 255.255.255.0
mpls enable
mpls ldp enable
bgp 100
peer 1.1.1.9 enable
peer 10:3::1 enable
return
· CE 1:
sysname CE1
interface LoopBack0
bgp 600
router-id 5.5.5.5
import-route direct
peer 10:1::2 enable
return
· CE 2:
sysname CE2
bgp 600
router-id 6.6.6.6
import-route direct
peer 10:2::2 enable
return
· CE 3:
sysname CE3
interface LoopBack0
ipv6 address 10:3::1/96
bgp 600
router-id 7.7.7.7
import-route direct
peer 10:3::2 enable
return
