- 09-MPLS Configuration Guide
- 01-Basic MPLS configuration
- 02-Static LSP configuration
- 03-LDP configuration
- 04-MPLS TE configuration
- 05-Static CRLSP configuration
- 06-RSVP configuration
- 07-Tunnel policy configuration
- 08-MPLS L3VPN configuration
- 09-MPLS L2VPN configuration
- 10-VPLS configuration
- 11-L2VPN access to L3VPN or IP backbone configuration
- 12-MPLS OAM configuration
- 13-MCE configuration
04-MPLS TE configuration | 1.31 MB |
CRLSP establishment using PCE path calculation
Establishing a CRLSP dynamically
Establishing a CRLSP by using the path calculated by PCEs
Configuring a tunnel interface
Configuring an MPLS TE tunnel to use a static CRLSP
Configuring MPLS TE attributes for a link
Advertising link TE attributes by using IGP TE extension
Restrictions and guidelines for advertising link TE attributes by using IGP TE extension
Configuring MPLS TE tunnel constraints
Configuring bandwidth constraints for an MPLS TE tunnel
Configuring the affinity attribute for an MPLS TE tunnel
Setting a setup priority and a holding priority for an MPLS TE tunnel
Configuring an explicit path for an MPLS TE tunnel
Configuring the maximum number of hops for an MPLS TE tunnel
Establishing an MPLS TE tunnel by using RSVP-TE
Controlling CRLSP path selection
Restrictions and guidelines for CRLSP path selection control
Configuring the metric type for path selection
Specifying the attribute usage preference for MPLS TE tunnel setup
Excluding overloaded nodes from establishment of CRLSPs
Configuring tunnel reoptimization
Setting TE flooding thresholds and interval
Setting the time that MPLS TE must wait before switching the traffic to the new CRLSP
Setting the time that MPLS TE must wait before deleting the old CRLSP
Controlling MPLS TE tunnel setup
About MPLS TE tunnel setup control
Restrictions and guidelines for MPLS TE tunnel setup control
Enabling route and label recording
Configuring automatic bandwidth adjustment
Configuring RSVP resource reservation style
Configuring an MPLS TE tunnel to use a CRLSP calculated by PCEs
Configuring PCEP session parameters
Configuring unequal load sharing for an MPLS TE tunnel
Configuring tunnel interface-based unequal load sharing
Configuring traffic forwarding
Configuring static routing to direct traffic to an MPLS TE tunnel
Configuring PBR to direct traffic to an MPLS TE tunnel
Configuring automatic route advertisement to direct traffic to an MPLS TE tunnel
Configuring a bidirectional MPLS TE tunnel
Creating a bidirectional MPLS TE tunnel
Configuring bit error detection for a bidirectional MPLS TE tunnel
Configuring CRLSP/SRLSP backup
Enabling CRLSP/SRLSP backup for an MPLS TE tunnel
Configuring the backup path setup mode
Configuring CSPF to include the SRLG constraint in backup path computation
Setting the time that MPLS TE must wait before switching the traffic back to the primary path
Restrictions and guidelines for MPLS TE FRR
Configuring facilicity backup FRR
Enabling one-to-one backup on the ingress node
Setting the time that MPLS TE must wait before switching the traffic back to the primary CRLSP
Configuring node fault detection
Configuring outbound traffic policing for a tunnel
Enabling SNMP notifications for MPLS TE
Enabling private SNMP notifications for MPLS TE
Enabling private SNMP notifications for PCEP
Enabling logging for PCEP messages
Display and maintenance commands for MPLS TE
MPLS TE configuration examples
Example: Establishing an MPLS TE tunnel over a static CRLSP
Example: Establishing an MPLS TE tunnel with RSVP-TE
Example: Establishing an inter-AS MPLS TE tunnel with RSVP-TE
Example: Configuring bidirectional MPLS TE tunnel
Example: Configuring CRLSP backup
Example: Configuring manual bypass tunnel for FRR
Example: Configuring bit error detection for an MPLS TE tunnel
Configuring MPLS TE
About MPLS TE
TE and MPLS TE
Network congestion can degrade the network backbone performance. It might occur when network resources are inadequate or when load distribution is unbalanced. Traffic engineering (TE) is intended to avoid the latter situation where partial congestion might occur because of improper resource allocation.
TE can make the best use of network resources and avoid uneven load distribution by using the following functionalities:
· Real-time monitoring of traffic and traffic load on network elements.
· Dynamic tuning of traffic management attributes, routing parameters, and resources constraints.
MPLS TE combines the MPLS technology and traffic engineering. It reserves resources by establishing LSP tunnels along the specified paths, allowing traffic to bypass congested nodes to achieve appropriate load distribution.
With MPLS TE, a service provider can deploy traffic engineering on the existing MPLS backbone to provide various services and optimize network resources management.
MPLS TE basic concepts
CRLSP
To establish a Constraint-based Routed Label Switched Path (CRLSP), you must configure routing, and specify constraints, such as the bandwidth and explicit paths.
SRLSP
A Segment Routing Label Switched Path (SRLSP) is the path along which SR uses MPLS labels as segment identifiers (SIDs) to forward packets.
You can manually configure SRLSPs or configure a controller to dynamically create SRLSPs. For more information, see SR-MPLS configuration in Segment Routing Configuration Guide.
MPLS TE tunnel
An MPLS TE tunnel is a virtual point-to-point connection from the ingress node to the egress node. Typically, an MPLS TE tunnel consists of one CRLSP or SRLSP. To deploy forwarding path backup or transmit traffic over multiple paths, you need to establish multiple CRLSPs or SRLSPs for one class of traffic. In this case, an MPLS TE tunnel consists of a set of CRLSPs or SRLSPs.
An MPLS TE tunnel is identified by an MPLS TE tunnel interface on the ingress node. When the outgoing interface of a traffic flow is an MPLS TE tunnel interface, the traffic flow is forwarded through the CRLSP or SRLSP of the MPLS TE tunnel. For information about configuring an MPLS TE tunnel to use static SRLSPs, see SR-MPLS configuration in Segment Routing Configuration Guide.
NOTE: The type of an MPLS TE tunnel interface is CRLSP no matter whether the tunnel consists of CRLSPs or SRLSPs. |
Static CRLSP establishment
A static CRLSP is established by manually specifying the incoming label, outgoing label, and other constraints on each hop along the path that the traffic travels. Static CRLSPs feature simple configuration, but they cannot automatically adapt to network changes.
For more information about static CRLSPs, see "Configuring a static CRLSP."
Dynamic CRLSP establishment
Dynamic CRLSPs are dynamically established as follows:
1. An IGP advertises TE attributes for links.
2. MPLS TE uses the CSPF algorithm to calculate the shortest path to the tunnel destination.
The path must meet constraints such as bandwidth and explicit routing.
3. A label distribution protocol (such as RSVP-TE) advertises labels to establish CRLSPs and reserves bandwidth resources on each node along the calculated path.
Dynamic CRLSPs adapt to network changes and support CRLSP backup and fast reroute, but they require complicated configurations.
Advertising TE attributes
MPLS TE uses extended link state IGPs, such as OSPF and IS-IS, to advertise TE attributes for links.
TE attributes include the maximum bandwidth, maximum reservable bandwidth, non-reserved bandwidth for each priority, and the link attribute. The IGP floods TE attributes on the network. Each node collects the TE attributes of all links on all routers within the local area or at the same level to build up a TE database (TEDB).
Calculating paths
Based on the TEDB, MPLS TE uses the Constraint-based Shortest Path First (CSPF) algorithm, an improved SPF algorithm, to calculate the shortest, TE constraints-compliant path to the tunnel destination.
CSPF first prunes TE constraints-incompliant links from the TEDB, and then it performs SPF calculation to identify the shortest path (a set of LSR addresses) to an egress. CSPF calculation is usually performed on the ingress node of an MPLS TE tunnel.
TE constraints are configured on the ingress node of an MPLS TE tunnel. The constraints include the following:
· Bandwidth
Bandwidth constraints specify the class of service and the required bandwidth for the traffic to be forwarded along the MPLS TE tunnel. A link complies with the bandwidth constraints when the reservable bandwidth for the class type is greater than or equal to the bandwidth required by the class type.
· Affinity
The affinity of a tunnel and the attributes of links determine which links that tunnel can use.
You can use either of the following methods to configure the link affinity of a tunnel:
¡ Mask-based—Specify an affinity value and an affinity mask. The system uses the following rules to determine whether a link can be used:
- The link attribute bits corresponding to the affinity attribute's 1 bits whose mask bits are 1 must have a minimum of one bit set to 1.
- The link attribute bits corresponding to the affinity attribute's 0 bits whose mask bits are 1 must have no bit set to 1.
- The link attribute bits corresponding to the 0 bits in the affinity mask are not checked.
For example, if the affinity is 0xfffffff0 and the mask is 0x0000ffff, a link is available for the tunnel when its attribute bits meet the following requirements:
- The highest 16 bits each can be 0 or 1 (no requirements).
- The 17th through 28th bits must have a minimum of one bit whose value is 1.
- The lowest four bits must be 0.
¡ Action-based—Specify the exclude, include-all, or include-any action with an affinity value. The system uses the following rules to determine whether a link can be used:
- exclude—The CRLSP can use a link only if the link attribute bits corresponding to the affinity's 1 bits are 0.
- include-all—The CRLSP can use a link only if the link attribute bits corresponding to the affinity's 1 bits are 1.
- include-any—The CRLSP can use a link if one or more of the link attribute bits corresponding to the affinity's 1 bits are 1.
· Setup priority and holding priority
If MPLS TE cannot find a qualified path to set up an MPLS TE tunnel, it removes an existing MPLS TE tunnel and preempts its bandwidth.
MPLS TE uses the setup priority and holding priority to make preemption decisions. For a new MPLS TE tunnel to preempt an existing MPLS TE tunnel, the setup priority of the new tunnel must be higher than the holding priority of the existing tunnel. Both setup and holding priorities are in the range of 0 to 7. A smaller value represents a higher priority.
To avoid flapping caused by improper preemptions, the setup priority value of a tunnel must be equal to or greater than the holding priority value.
· Explicit path
Explicit path specifies the nodes to pass and the nodes to not pass for a tunnel.
Explicit paths include the following types:
¡ Strict explicit path—Among the nodes that the path must traverse, a node and its previous hop must be directly connected. Strict explicit path precisely specifies the path that an MPLS TE tunnel must traverse.
¡ Loose explicit path—Among the nodes that the path must traverse, a node and its previous hop can be indirectly connected. Loose explicit path vaguely specifies the path that an MPLS TE tunnel must traverse.
Strict explicit path and loose explicit path can be used together to specify that some nodes are directly connected and some nodes have other nodes in between.
· SRLG
A Shared Risk Link Group (SRLG) is a set of links that share a resource. If one link in the group fails, all other links also fail. For example, if the primary and backup SRLSPs are established on links that belong to the same SRLG, the backup path cannot protect the primary path.
To improve TE tunnel availability, you can configure the device to include the SRLG constraint in backup path computation by using the following methods:
¡ Configure CSPF to include the SRLG constraint in the computation of a backup path. This ensures that the primary and backup paths of a tunnel do not use links in the same SRLG.
¡ Exclude SRLG links from an explicit path. The MPLS TE tunnel that uses the explicit path will avoid using the links that are in the same SRLG as the interface it is protecting.
Currently, only SRLSPs support SRLG settings. For more information about SRLSPs, see SR-MPLS in Segment Routing Configuration Guide.
Setting up a CRLSP through RSVP-TE
After calculating a path by using CSPF, MPLS TE uses a label distribution protocol to set up the CRLSP and reserves resources on each node of the path.
The device supports the label distribution protocol of RSVP-TE for MPLS TE. Resource Reservation Protocol (RSVP) reserves resources on each node along a path. Extended RSVP can support MPLS label distribution and allow resource reservation information to be transmitted with label bindings. This extended RSVP is called RSVP-TE.
For more information about RSVP, see "Configuring RSVP."
On an MPLS TE network, a Path Computation Client (PCC), usually an LSR, uses the path calculated by Path Computation Elements (PCEs) to establish a CRLSP through RSVP-TE.
Basic concepts
· PCE—An entity that provides intra-area or inter-area path calculation. A PCE can be stateless (the default) or stateful.
¡ Stateless PCE—Provides only path calculation.
¡ Stateful PCE—Knows all CRLSPs maintained by a PCC, and performs intra-area CRLSP recalculation and optimization. A stateful PCE can be active or passive.
- Active stateful PCE—Accepts CRLSP delegation requests sent by a PCC and optimizes the CRLSPs.
- Passive stateful PCE—Only maintains CRLSP information for a PCC. A passive stateful PCE does not accept CRLSP delegation requests sent by a PCC or optimize the CRLSPs.
· PCC—A PCC sends a request to PCEs for path calculation and uses the path information returned by PCEs to establish a CRLSP. By default, a PCC is a stateless PCC. For a PCC to establish a stateful PCEP session with an active or passive stateful PCE, the PCC must also be configured as active stateful or passive stateful.
· PCEP—Path Computation Element Protocol. PCEP runs between a PCC and a PCE, or between PCEs. It is used to establish PCEP sessions to exchange PCEP messages over TCP connections.
PCE discovery mechanism
A PCE can be manually specified on a PCC or automatically discovered through the PCE information advertised by OSPF TE.
PCE path calculation has the following types:
· EPC—External Path Computation. EPC path calculation is performed by one PCE. It is applicable to intra-area path calculation.
· BRPC—Backward-Recursive PCE-Based Computation. BRPC path calculation is performed by multiple PCEs. It is applicable to inter-area path calculation.
As shown in Figure 1, PCE 1 is the ABR that can calculate paths in Area 0 and Area 1. PCE 2 is the ABR that can calculate paths in Area 1 and Area 2. The CRLSP that PCC uses to reach a destination in Area 2 is established as follows:
1. PCC sends a path calculation request to PCE 1 to request the path to the CRLSP destination.
2. PCE 1 forwards the request to PCE 2.
PCE 1 cannot calculate paths in Area 2, so it forwards the request to PCE 2, the PCE responsible for Area 2 that contains the CRLSP destination.
3. After receiving the request from PCE 1, PCE 2 calculates potential paths to the CRLSP destination and sends the path information back to PCE 1 in a reply.
4. PCE 1 uses the local and received path information to select an end-to-end path for the PCC to reach the CRLSP destination, and sends the path to PCC as a reply.
5. PCC uses the path calculated by PCEs to establish the CRLSP through RSVP-TE.
Figure 1 BRPC path calculation
Traffic forwarding
After an MPLS TE tunnel is established, traffic is not forwarded on the tunnel automatically. You must direct the traffic to the tunnel by using one of the following methods:
Static routing
You can direct traffic to an MPLS TE tunnel by creating a static route that reaches the destination through the tunnel interface. This is the easiest way to implement MPLS TE tunnel forwarding. When traffic to multiple networks is to be forwarded through the MPLS TE tunnel, you must configure multiple static routes, which are complicated to configure and difficult to maintain.
For more information about static routing, see Layer 3—IP Routing Configuration Guide.
Policy-based routing
You can configure PBR on the ingress interface of traffic to direct the traffic that matches an ACL to the MPLS TE tunnel interface.
PBR can match the traffic to be forwarded on the tunnel not only by destination IP address, but also by source IP address, protocol type, and other criteria. Compared with static routing, PBR is more flexible but requires more complicated configuration.
For more information about policy-based routing, see Layer 3—IP Routing Configuration Guide.
Automatic route advertisement
You can also configure automatic route advertisement to forward traffic through an MPLS TE tunnel. Automatic route advertisement distributes the MPLS TE tunnel to the IGP (OSPF or IS-IS), so the MPLS TE tunnel can participate in IGP routing calculation. Automatic route advertisement is easy to configure and maintain.
Automatic route advertisement can be implemented by using the following methods:
· IGP shortcut—Also known as AutoRoute Announce. It considers the MPLS TE tunnel as a link that directly connects the tunnel ingress node and the egress node. Only the ingress node uses the MPLS TE tunnel during IGP route calculation.
· Forwarding adjacency—Considers the MPLS TE tunnel as a link that directly connects the tunnel ingress node and the egress node, and advertises the link to the network through an IGP. Every node in the network uses the MPLS TE tunnel during IGP route calculation.
As shown in Figure 2, an MPLS TE tunnel exists from Device D to Device C. IGP shortcut enables only the ingress node Device D to use the MPLS TE tunnel in the IGP route calculation. Device A cannot use this tunnel to reach Device C. With forwarding adjacency enabled, Device A can learn this MPLS TE tunnel and transfer traffic to Device C by forwarding the traffic to Device D.
Figure 2 IGP shortcut and forwarding adjacency diagram
Make-before-break
Make-before-break is a mechanism to change an MPLS TE tunnel with minimum data loss and without using extra bandwidth.
In cases of tunnel reoptimization, traffic forwarding is interrupted if the existing CRLSP is removed before a new CRLSP is established. The make-before-break mechanism ensures that a new CRLSP is established to take over traffic forwarding before tearing down the existing CRLSP.. However, this wastes bandwidth resources if some links on the old and new CRLSPs are the same. This is because you need to reserve bandwidth on these links for the old and new CRLSPs separately. The make-before-break mechanism uses the SE resource reservation style to address this problem.
The resource reservation style refers to the style in which RSVP-TE reserves bandwidth resources during CRLSP establishment. The resource reservation style used by an MPLS TE tunnel is determined by the ingress node, and is advertised to other nodes through RSVP.
The device supports the following resource reservation styles:
· FF—Fixed-filter, where resources are reserved for individual senders and cannot be shared among senders on the same session.
· SE—Shared-explicit, where resources are reserved for senders on the same session and shared among them. SE is mainly used for make-before-break.
As shown in Figure 3, a CRLSP with 30 M reserved bandwidth has been set up from Device A to Device D through the path Device A—Device B—Device C—Device D.
To increase the reserved bandwidth to 40 M, a new CRLSP must be set up through the path Device A—Device E—Device C—Device D. To achieve this purpose, RSVP-TE needs to reserve 30 M bandwidth for the old CRLSP and 40 M bandwidth for the new CRLSP on the link Device C—Device D. However, there is not enough bandwidth.
After the make-before-break mechanism is used, the new CRLSP can share the bandwidth reserved for the old CRLSP. After the new CRLSP is set up, traffic is switched to the new CRLSP without service interruption, and then the old CRLSP is removed.
Figure 3 Diagram for make-before-break
Route pinning
Route pinning enables CRLSPs to always use the original optimal path even if a new optimal route has been learned.
On a network where route changes frequently occur, you can use route pinning to avoid re-establishing CRLSPs upon route changes.
Tunnel reoptimization
Tunnel reoptimization allows you to manually or dynamically trigger the ingress node to recalculate a path. If the ingress node recalculates a better path, it creates a new CRLSP, switches traffic from the old CRLSP to the new, and then deletes the old CRLSP.
MPLS TE uses the tunnel reoptimization feature to implement dynamic CRLSP optimization. For example, if a link on the optimal path does not have enough reservable bandwidth, MPLS TE sets up the tunnel on another path. When the link has enough bandwidth, the tunnel optimization feature can switch the MPLS TE tunnel to the optimal path.
CRLSP backup
CRLSP backup uses a CRLSP to back up a primary CRLSP. When the ingress detects that the primary CRLSP fails, it switches traffic to the backup CRLSP. When the primary CRLSP recovers, the ingress switches traffic back.
CRLSP backup has the following modes:
· Hot standby—A backup CRLSP is created immediately after a primary CRLSP is created.
· Ordinary—A backup CRLSP is created after the primary CRLSP fails.
FRR
Fast reroute (FRR) protects CRLSPs from link and node failures. FRR can implement 50-millisecond CRLSP failover.
After FRR is enabled for an MPLS TE tunnel, once a link or node fails on the primary CRLSP, FRR reroutes the traffic to a bypass tunnel. The ingress node attempts to set up a new CRLSP. After the new CRLSP is set up, traffic is forwarded on the new CRLSP.
CRLSP backup provides end-to-end path protection for a CRLSP without time limitation. FRR provides quick but temporary protection for a link or node on a CRLSP.
Basic concepts
· Primary CRLSP—Protected CRLSP.
· Bypass tunnel—MPLS TE tunnel used to protect a link or node of the primary CRLSP in facility backup mode.
· Detour LSP—CRLSP for re-routing traffic to bypass faulty links or nodes in one-to-one backup mode.
· Point of local repair—A PLR is the ingress node of the bypass tunnel or detour LSP. It must be located on the primary CRLSP but must not be the egress node of the primary CRLSP.
· Merge point—An MP is the egress node of the bypass tunnel. It must be located on the primary CRLSP but must not be the ingress node of the primary CRLSP.
Protection modes
MPLS TE FRR supports two modes: facility backup and one-to-one backup.
· Facility backup mode
The facility backup mode protects the primary CRLSPs by creating a bypass tunnel on the PLR. A bypass tunnel can protect multiple primary CRLSPs at the same time. As shown in Figure 4, both primary CRLSP 1 and primary CRLSP 2 pass through the link from Device B to Device C. Device B, acting as a PLR, establishes a bypass tunnel from Device B to Device F to Device C, which can protect both primary CRLSP 1 and primary CRLSP 2 simultaneously.
Figure 4 Facility backup mode diagram
To use this mode, identify the links and nodes where faults might occur to determine the PLR, and create a bypass tunnel on the PLR.
When a link or node on the primary CRLSP fails, the PLR adds the MPLS label of the bypass tunnel to the traffic on the primary CRLSP to direct the traffic to the bypass tunnel, so as to bypass the faulty link or node.
· One-to-one backup mode
The one-to-one backup mode creates a detour LSP along every node (except the egress node) of a primary CRLSP to protect the primary CRLSP. A detour LSP can protect only one primary CRLSP. As shown in Figure 5, nodes Router A, Router B, and Router C on the primary CRLSP all serve as PLRs to create a detour LSP for the primary CRLSP. This detour LSP can only protect this particular primary CRLSP.
Figure 5 One-to-one backup mode diagram
To use this mode, enable the one-to-one backup feature on the ingress node of the primary CRLSP. The ingress node will automatically instruct all nodes of the primary CRLSP to create a detour LSP.
When a link or node on the primary CRLSP fails, the PLR replaces the label in the traffic on the primary CRLSP with the MPLS label of the detour LSP to bypass the faulty link or node.
The following table shows the comparison between facility backup and one-to-one backup modes:
Table 1 Compare facility backup and one-to-one backup modes
Facility backup mode |
One-to-one backup mode |
Protection tunnel creation mode |
Identify the PLR, and then manually create a bypass tunnel on the PLR or configure the PLR to automatically create a bypass tunnel. |
Enable one-to-one backup mode on the ingress node of the primary CRLSP, and then all nodes of the primary CRLSP, except the egress node, automatically create a detour LSP. |
Protection scope |
A bypass tunnel can protect multiple primary CRLSPs simultaneously. |
A detour LSP can protect only one primary CRLSP. |
Protection object |
Faulty links and faulty nodes |
Traffic forwarding mode on the protection tunnel |
Traffic forwarded through a bypass tunnel must carry both the MPLS label of the primary CRLSP and the MPLS label of the bypass tunnel. |
Traffic forwarded through a detour LSP carries only the MPLS label of the detour LSP. |
Bandwidth protection |
Manually created bypass tunnels can provide bandwidth protection for primary CRLSPs. Automatically created bypass tunnels do not provide bandwidth protection for primary CRLSPs. |
The bandwidth of a detour LSP is the same as that of the primary CRLSP, allowing the detour LSP to provide bandwidth protection for the primary CRLSP. |
Advantages and disadvantages |
Advantage: A bypass tunnel can protect multiple CRLSPs, saving bandwidth resources. Disadvantage: Manual determination of PLRs and planning of bypass tunnels is required, and the configuration is complex. |
Advantage: Simple configuration. Disadvantage: All nodes on the primary CRLSP must establish and maintain detour LSPs, and a separate detour LSP is required for each primary CRLSP, consuming considerable bandwidth resources. |
Link protection and node protection
FRR can provide protection for links and nodes.
· Link protection—The PLR and the MP are connected through a direct link and the primary CRLSP traverses this link. When the link fails, traffic is switched to the bypass tunnel or detour LSP. As shown in Figure 6, take the facility backup mode as an example, the primary CRLSP is Device A—Device B—Device C—Device D, and the bypass tunnel is Device B—Device F—Device C. This mode is also called next-hop (NHOP) protection.
· Node protection—The PLR and the MP are connected through a device and the primary CRLSP traverses this device. When the device fails, traffic is switched to the bypass tunnel or detour LSP. As shown in Figure 7, take the facility backup mode as an example, the primary CRLSP is Device A—Device B—Device C—Device D—Device E, and the bypass tunnel is Device B—Device F—Device D. Device C is the protected device. This mode is also called next-next-hop (NNHOP) protection.
Bidirectional MPLS TE tunnel
MPLS Transport Profile (MPLS-TP) uses bidirectional MPLS TE tunnels to implement 1:1 and 1+1 protection switching, and to support in-band detection tools and signaling protocols such as OAM and PSC.
A bidirectional MPLS TE tunnel includes a pair of CRLSPs in opposite directions. It can be established in the following modes:
· Co-routed mode—Uses the extended RSVP-TE protocol to establish a bidirectional MPLS TE tunnel. RSVP-TE uses a Path message to advertise the labels assigned by the upstream LSR to the downstream LSR. RSVP-TE uses a Resv message to advertise the labels assigned by the downstream LSR to the upstream LSR. During the delivery of the path message, a CRLSP in one direction is established. During the delivery of the Resv message, a CRLSP in the other direction is established. The CRLSPs of a bidirectional MPLS TE tunnel established in co-routed mode use the same path.
· Associated mode—In this mode, you establish a bidirectional MPLS TE tunnel by binding two unidirectional CRLSPs in opposite directions. The two CRLSPs can be established in different modes and use different paths. For example, one CRLSP is established statically and the other CRLSP is established dynamically by RSVP-TE.
For more information about establishing MPLS TE tunnel through RSVP-TE, the Path message, and the Resv message, see "Configuring RSVP."
CBTS
Class Based Tunnel Selection (CBTS) enables dynamic routing and forwarding of traffic with service class values over different MPLS TE tunnels between the same tunnel headend and tailend. Unlike load sharing that selects multiple tunnels to forward the matching traffic, CBTS uses a dedicated tunnel for a certain class of service.
How CBTS works
CBTS processes incoming traffic on the device as follows:
1. Uses a traffic behavior to set a service class value for the traffic. For more information about traffic behaviors, see QoS configuration in ACL and QoS Configuration Guide.
2. Compares the service class value of the traffic with the service class values of the MPLS TE tunnels and forwards the traffic to a matching tunnel.
MPLS TE tunnel selection rules
CBTS uses the following rules to select an MPLS TE tunnel for the incoming traffic:
· If the traffic matches an MPLS TE tunnel, CBTS uses this tunnel.
· If the traffic matches multiple MPLS TE tunnels, CBTS selects a tunnel based on the flow forwarding mode set on the tunnel interface:
¡ If there is only one flow and flow-based forwarding is set, CBTS randomly selects a matching tunnel for packets of the same flow.
¡ If there are multiple flows or if there is only one flow but packet-based forwarding is set, CBTS uses all matching tunnels to load share the packets.
· If the traffic does not match any MPLS TE tunnels, CBTS randomly selects a tunnel from all tunnels with the smallest service class value.
CBTS application scenario
As shown in Figure 8, CBTS selects MPLS TE tunnels for the incoming traffic as follows:
· Uses Tunnel 2 to forward traffic with service class value 3.
· Uses Tunnel 3 to forward traffic with service class value 6.
· Uses Tunnel 1 to forward traffic with no service class value.
Figure 8 CBTS application scenario
MPLS TE P2MP tunnels
MPLS TE P2MP tunnels are automatically established after multicast VPN in RSVP-TE mode is configured. After the MPLS TE P2MP tunnels are established, you can use the display mpls te p2mp tunnel-interface command to display information about the tunnels. For more information about MPLS TE P2MP tunnels, see "Configuring RSVP." For more information about multicast VPN, see IP Multicast Configuration Guide
Protocols and standards
· RFC 2702, Requirements for Traffic Engineering Over MPLS
· RFC 3564, Requirements for Support of Differentiated Service-aware MPLS Traffic Engineering
· RFC 3812, Multiprotocol Label Switching (MPLS) Traffic Engineering (TE) Management Information Base (MIB)
· RFC 4090: Fast Reroute Extensions to RSVP-TE for LSP Tunnels
· RFC 4124, Protocol Extensions for Support of Diffserv-aware MPLS Traffic Engineering
· RFC 4125, Maximum Allocation Bandwidth Constraints Model for Diffserv-aware MPLS Traffic Engineering
· RFC 4127, Russian Dolls Bandwidth Constraints Model for Diffserv-aware MPLS Traffic Engineering
· ITU-T Recommendation Y.1720, Protection switching for MPLS networks
· RFC 4655, A Path Computation Element (PCE)-Based Architecture
· RFC 5088, OSPF Protocol Extensions for Path Computation Element Discovery
· RFC 5440, Path Computation Element (PCE) Communication Protocol (PCEP)
· RFC 5441, A Backward-Recursive PCE-Based Computation (BRPC) Procedure to Compute Shortest Constrained Inter-Domain Traffic Engineering LSP
· RFC 5455, Diffserv-Aware Class-Type Object for the Path Computation Element Communication Protocol
· RFC 5521, Extensions to the Path Computation Element Communication Protocol (PCEP) for Route Exclusions
· RFC 5886, A Set of Monitoring Tools for Path Computation Element (PCE)-Based Architecture
· draft-ietf-pce-stateful-pce-07
· draft-ietf-pce-pce-initiated-lsp-09
· draft-minei-diffserv-te-multi-class-02.txt
MPLS TE tasks at a glance
Establishing a static CRLSP
Perform this task on all nodes and interfaces that the MPLS TE tunnel traverses.
2. Configuring a tunnel interface
Perform this task on the ingress node of the MPLS TE tunnel.
3. Establishing a static CRLSP
This task is required on all nodes that the MPLS TE tunnel traverses.
For more information, see "Configuring a static CRLSP."
4. Configuring an MPLS TE tunnel to use a static CRLSP
5. (Optional.) Configuring unequal load sharing for an MPLS TE tunnel
6. Configuring traffic forwarding
¡ Configuring static routing to direct traffic to an MPLS TE tunnel
¡ Configuring PBR to direct traffic to an MPLS TE tunnel
¡ Configuring automatic route advertisement to direct traffic to an MPLS TE tunnel
Perform the tasks on the ingress node of the MPLS TE tunnel.
7. (Optional.) Configuring a bidirectional MPLS TE tunnel
a. Creating a bidirectional MPLS TE tunnel
Perform this task on the ingress node and egress node of the MPLS TE tunnel.
b. Configuring bit error detection for a bidirectional MPLS TE tunnel
Perform this task on the egress nodes of the forward MPLS TE tunnels.
8. (Optional.) Configuring CBTS
9. (Optional.) Configuring outbound traffic policing for a tunnel
10. (Optional.) Maintaining the MPLS TE network
¡ Enabling SNMP notifications for MPLS TE
¡ Enabling private SNMP notifications for MPLS TE
1. Enabling MPLS TE and RSVP
¡ Enabling RSVP
For more information about enabling RSVP, see "Configuring RSVP."
3. Configuring an MPLS TE tunnel to use a CRLSP dynamically established by RSVP-TE
a. Configuring MPLS TE attributes for a link
Perform this task on all nodes that the MPLS TE tunnel traverses.
b. Advertising link TE attributes by using IGP TE extension
c. Configuring MPLS TE tunnel constraints
d. Establishing an MPLS TE tunnel by using RSVP-TE
e. (Optional.) Controlling CRLSP path selection
f. (Optional.) Controlling MPLS TE tunnel setup
4. (Optional.) Configuring unequal load sharing for an MPLS TE tunnel
5. Configuring traffic forwarding
6. (Optional.) Configuring a bidirectional MPLS TE tunnel
7. (Optional.) Enhancing MPLS TE availability
¡ Configuring CRLSP/SRLSP backup
Enable FRR on the ingress node of the primary CRLSP.
¡ Enabling RSVP
4. Configuring an MPLS TE tunnel to use a CRLSP calculated by PCEs
Perform this task on a device that acts as a PCE, regardless of whether the device is on the MPLS TE tunnel.
Perform this task on PCCs.
c. Establishing a CRLSP by using the path calculated by PCEs
e. (Optional.) Configuring stateful PCE
f. Configuring PCEP session parameters
8. (Optional.) Enhancing MPLS TE availability
9. (Optional.) Configuring CBTS
10. (Optional.) Configuring outbound traffic policing for a tunnel
11. (Optional.) Maintaining the MPLS TE network
¡ Enabling private SNMP notifications for PCEP
¡ Enabling logging for PCEP messages
Prerequisites for MPLS TE
Before you enable MPLS TE, perform the following tasks:
· Configure static routing or IGP to ensure that all LSRs can reach each other.
· Enable MPLS. For information about enabling MPLS, see "Configuring basic MPLS."
Enabling MPLS TE
1. Enter system view.
2. Enable MPLS TE for the device. Choose one option as needed:
¡ Enable MPLS TE and enter MPLS TE view.
mpls te
By default, MPLS TE is disabled.
¡ Enable TE.
te attribute enable [ ds-te ietf [ mam ] ]
By default, TE is disabled.
You can configure the DS-TE mode in both system view and MPLS TE view. MPLS TE prefers to use the configuration in MPLS TE view. It uses the configuration in system view only when the no DS-TE mode is configured in MPLS TE view.
3. Return to system view.
4. Enter interface view.
5. Enable MPLS TE for the interface.
mpls te enable
By default, MPLS TE is disabled on an interface.
To configure an MPLS TE tunnel, you must create an MPLS TE tunnel interface and enter tunnel interface view. All MPLS TE tunnel attributes are configured in tunnel interface view. For more information about tunnel interfaces, see tunneling configuration in Layer 3—IP Services Configuration Guide.
On an up MPLS TE tunnel interface, perform the following operations with caution because they can cause interface down/up flappings:
· Modifying the affinity attribute of the MPLS TE tunnel.
· Modifying the setup priority and holding priority of the MPLS TE tunnel.
· Modifying the MPLS TE tunnel configuration when the resources reservation style is FF.
· Modifying the MPLS TE tunnel configuration when the tunnel is a bidirectional MPLS TE tunnel.
· Modifying the CT of the MPLS TE tunnel.
· Specifying a primary or backup traffic processing slot for the tunnel interface.
· Restarting or swapping the specified primary or backup traffic processing slot.
For more information about specifying traffic processing slots for an interface, see tunneling configuration in Layer 3—IP Services Configuration Guide.
2. Create an MPLS TE tunnel interface and enter tunnel interface view.
interface tunnel tunnel-number mode mpls-te
3. Configure an IP address for the tunnel interface.
ip address ip-address { mask-length | mask }
By default, a tunnel interface does not have an IP address.
4. Specify the tunnel destination address.
destination ip-address
By default, no tunnel destination address is specified.
5. (Optional.) Configure the tunnel name of the MPLS TE tunnel.
mpls te signaled-name name
By default, an MPLS TE tunnel is named tunneltunnel-id, where tunnel-id is the tunnel ID.
2. Enter MPLS TE tunnel interface view.
interface tunnel tunnel-number [ mode mpls-te ]
3. Specify the MPLS TE tunnel establishment mode as static.
mpls te signaling static
By default, MPLS TE uses RSVP-TE to establish a tunnel.
4. Apply the static CRLSP to the tunnel interface.
mpls te static-cr-lsp lsp-name
By default, a tunnel does not use any static CRLSP.
Make sure the static CRLSP already exists. For more information about configuring a static CRLSP, see "Configuring a static CRLSP."
After MPLS TE attributes are configured for links, the ingress node of a tunnel can use the attributes to perform IGP computation to select links that meet the tunnel constraints.
In interface view, you can configure MPLS TE attributes by using the following forms of commands:
· The mpls te commands, which start with the mpls te keywords, for example, the mpls te link-attribute command.
¡ The mpls te commands can be used only after MPLS TE is enabled on the device.
¡ When you disable MPLS TE, if TE is also disabled on the device, the mpls te commands configured in interface view are deleted; if TE is enabled, the mpls te commands configured in interface view are displayed as the corresponding te commands.
· The te commands, which start with the te keyword, for example, the te link-attribute command.
¡ The te commands can be used only after TE is enabled for the device.
¡ When you disable TE, if MPLS TE is also disabled on the device, the te commands configured in interface view are deleted; if MPLS TE is enabled on the device, the te commands configured in interface view are displayed as the corresponding mpls te commands.
The mpls te commands and te commands have the same configuration results.
If te commands are available for configuring MPLS TE attributes, only the te commands are displayed no matter you configure the MPLS TE attributes by using the mpls te or te commands.
Configuring MPLS TE attributes for a link by using te commands
2. Enter interface view.
3. Set the maximum link bandwidth for TE traffic.
te max-link-bandwidth { bandwidth-value | percent percent-bandwidth }
By default, the maximum link bandwidth for TE traffic is 0.
4. Set the maximum reservable bandwidth.
¡ Configure the maximum reservable bandwidth of the link in prestandard DS-TE model.
te max-reservable-bandwidth { bandwidth-value | percent percent-bandwidth }
By default, the maximum reservable bandwidth of a link is 0 kbps and each BC is 0 kbps.
In RDM model, BC 0 is the maximum reservable bandwidth of a link.
5. Set the link attribute for TE.
te link-attribute attribute-value
By default, the link attribute value is 0x00000000.
6. Configure the SRLG membership of the interface for TE traffic forwarding.
te srlg srlg-number
By default, an interface does not belong to an SRLG.
Configuring MPLS TE attributes for a link by using mpls te commands
3. Set the maximum link bandwidth for MPLS TE traffic.
mpls te max-link-bandwidth { bandwidth-value | percent percent-bandwidth }
By default, the maximum link bandwidth for MPLS TE traffic is 0.
¡ Configure the maximum reservable bandwidth of the linkin prestandard DS-TE mode.
mpls te max-reservable-bandwidth { bandwidth-value | percent percent-bandwidth }
5. Set the link attribute for MPLS TE.
mpls te link-attribute attribute-value
6. Configure the SRLG membership of the interface for MPLS TE traffic forwarding.
mpls te srlg srlg-number
About IGP TE extension
Both OSPF and IS-IS are extended to advertise link TE attributes. The extensions are called OSPF TE and IS-IS TE. If both OSPF TE and IS-IS TE are available, OSPF TE takes precedence.
You must configure the IGP TE extension to establish a TEDB. Otherwise, the path is created based on IGP routing rather than computed by CSPF.
Configuring OSPF TE
OSPF TE uses Type-10 opaque LSAs to carry the TE attributes for a link. Before you configure OSPF TE, you must enable opaque LSA advertisement and reception by using the opaque-capability enable command. For more information about opaque LSA advertisement and reception, see OSPF configuration in Layer 3—IP Routing Configuration Guide.
MPLS TE cannot reserve resources and distribute labels for an OSPF virtual link, and cannot establish a CRLSP through an OSPF virtual link. Therefore, make sure no virtual link exists in an OSPF area before you configure MPLS TE.
2. Enter OSPF view.
ospf [ process-id ]
3. Enable opaque LSA advertisement and reception.
By default, opaque LSA advertisement and reception are enabled.
For more information about this command, see OSPF commands in Layer 3—IP Routing Command Reference.
4. Enter area view.
area area-id
5. Enable MPLS TE for the OSPF area.
mpls te enable
By default, MPLS TE is disabled for an OSPF area.
Configuring IS-IS TE
IS-IS TE uses a sub-TLV of the extended IS reachability TLV (type 22) to carry TE attributes. Because the extended IS reachability TLV carries wide metrics, specify a wide metric-compatible metric style for the IS-IS process before enabling IS-IS TE. Available metric styles for IS-IS TE include wide, compatible, or wide-compatible. For more information about IS-IS, see IS-IS configuration in Layer 3—IP Routing Configuration Guide.
On IS-IS enabled interfaces, set the MTU to a minimum of 512 bytes to ensure that IS-IS LSPs of different lengths can be flooded to the network.
2. Create an IS-IS process and enter IS-IS view.
isis [ process-id ]
By default, no IS-IS process exists.
3. Specify a metric style.
By default, only narrow metric style packets can be received and sent.
For more information about this command, see IS-IS commands in Layer 3—IP Routing Command Reference.
4. Enable MPLS TE for the IS-IS process.
mpls te enable [ Level-1 | Level-2 ]
By default, MPLS TE is disabled for an IS-IS process.
5. Specify the types of the sub-TLVs for carrying DS-TE parameters.
te-subtlv { bw-constraint value | unreserved-subpool-bw value } *
By default, the bw-constraint parameter is carried in sub-TLV 252, and the unreserved-bw-sub-pool parameter is carried in sub-TLV 251.
3. Configure bandwidth required for the tunnel, and specify a CT for the tunnel's traffic.
mpls te bandwidth { bandwidth | { ct0 ct0-bandwidth }
By default, no bandwidth is assigned, and the class type is CT 0.
The associations between the link attribute and the affinity attribute might vary by vendor. To ensure the successful establishment of a tunnel between two devices from different vendors, correctly configure their respective link attribute and affinity attribute.
3. Set an affinity for the primary CRLSP of the MPLS TE tunnel.
mpls te affinity-attribute { attribute-value [ mask mask-value ] | { exclude | include-all | include-any } attribute-value }
By default, the affinity constraints are not configured for a primary CRLSP. The primary CRLSP can use any links.
4. (Optional.) Set an affinity for the backup CRLSP of the MPLS TE tunnel.
mpls te backup affinity-attribute { exclude | include-all | include-any } attribute-value
By default, the affinity constraints are not configured for a backup CRLSP. The backup CRLSP can use any links.
3. Set a setup priority and a holding priority for the MPLS TE tunnel.
mpls te priority setup-priority [ hold-priority ]
By default, the setup priority and the holding priority are both 7 for an MPLS TE tunnel.
An explicit path is a set of nodes. The relationship between any two neighboring nodes on an explicit path can be either strict or loose.
· Strict—The two nodes must be directly connected.
· Loose—The two nodes can have devices in between.
When establishing an MPLS TE tunnel between areas or ASs, you must perform the following tasks:
· Use a loose explicit path.
· Specify the ABR or ASBR as the next hop of the explicit path.
· Make sure the tunnel's ingress node and the ABR or ASBR can reach each other.
For information about using an explicit path to establish an SR-signaled MPLS TE tunnel, see SR-MPLS in Segment Routing Configuration Guide.
2. Create an explicit path and enter its view.
explicit-path path-name
3. Enable the explicit path.
undo disable
By default, an explicit path is enabled.
4. Add or modify a node in the explicit path.
¡ Specify a node by its IP address.
nexthop [ index index-number ] ip-address [ exclude | include [ [ loose | strict ] | [ incoming | outgoing ] ] * ]
You can specify the include keyword to have the CRLSP traverse the specified node or the exclude keyword to have the CRLSP bypass the specified node.
The incoming and outgoing keywords are supported only for explicit paths of MPLS TE tunnels signaled by using Segment Routing. For more information about SR-MPLS, see Segment Routing Configuration Guide.
¡ Specify a node by its label.
nextsid [ index index-number ] label label-value type { adjacency | binding-sid | prefix }
Use this command only to set up an SR-MPLS explicit path. For more information about SR-MPLS, see Segment Routing Configuration Guide.
¡ Exclude all links that are in the same SRLG as the specified interface (identified by the specified IP address) from the explicit path.
exclude-srlg [ index index-number] ip-address
Use this command only for setup of an SR-MPLS explicit path. For more information about SR-MPLS, see Segment Routing Configuration Guide.
By default, an explicit path does not include a node.
5. Return to system view.
6. Enter MPLS TE tunnel interface view.
7. Configure the MPLS TE tunnel interface to use the explicit path, and specify a preference value for the explicit path.
mpls te path preference value explicit-path path-name [ no-cspf ]
By default, MPLS TE uses the calculated path to establish a CRLSP/SRLSP.
8. (Optional.) Specify a BSID for the MPLS TE tunnel.
mpls te binding-sid label label-value
By default, an MPLS TE tunnel is not associated with a BSID.
This command is required when the nextsid command specifies the binding-sid keyword.
3. Configure the maximum number of hops on the primary CRLSP of the MPLS TE tunnel.
mpls te hop-limit hop-limit-value
By default, there is no limit on the number of hops on a primary CRLSP.
4. (Optional.) Configure the maximum number of hops on the backup CRLSP of the MPLS TE tunnel.
mpls te backup hop-limit hop-limit-value
By default, there is no limit on the number of hops on a backup CRLSP.
To establish an MPLS TE tunnel by using RSVP-TE, enable both MPLS TE and RSVP on the interface.
The link of an interface participates in path calculation only after you enable MPLS TE on the interface. An interface can receive and send RSVP-TE packets only after you enable RSVP on the interface.
3. Configure MPLS TE to use RSVP-TE to establish the tunnel.
mpls te signaling rsvp-te
4. Specify an explicit path for the MPLS TE tunnel, and specify the path preference value.
mpls te path preference value { dynamic | explicit-path path-name } [ no-cspf ]
By default, MPLS TE uses the calculated path to establish a CRLSP.
About CRLSP path selection
MPLS TE uses CSPF to calculate a path according to the TEDB and constraints and sets up the CRLSP through RSVP-TE. MPLS TE provides measures that affect the CSPF calculation. You can use these measures to tune the path selection for CRLSP.
Before performing the configuration tasks in this section, be aware of each configuration objective and its impact on your device.
Each MPLS TE link has two metrics: IGP metric and TE metric. By planning the two metrics, you can select different tunnels for different classes of traffic. For example, use the IGP metric to represent a link delay (a smaller IGP metric value indicates a lower link delay), and use the TE metric to represent a link bandwidth value (a smaller TE metric value indicates a bigger link bandwidth value).
You can establish two MPLS TE tunnels: Tunnel 1 for voice traffic and Tunnel 2 for video traffic. Configure Tunnel 1 to use IGP metrics for path selection, and configure Tunnel 2 to use TE metrics for path selection. As a result, the video service (with larger traffic) travels through the path that has larger bandwidth, and the voice traffic travels through the path that has lower delay.
The metric type can be explicitly specified for path selection of a tunnel or globally specified. To specify a global metric type, perform the task on the ingress node of the tunnels. To specify a metric type for a tunnel, perform the task on the tunnel interface. The metric type for a tunnel takes precedence over the global setting.
Configuring the global metric type for tunnel path selection
2. Enter MPLS TE view.
mpls te
3. Specify the global metric type for tunnel path selection.
path-metric-type { igp | te }
By default, a tunnel uses TE metrics of links for path selection when no global metric type is specified.
Configuring the metric type for path selection of a tunnel
3. Specify the metric type for path selection.
mpls te path-metric-type { igp | te }
By default, no link metric type is specified for the tunnel and the tunnel uses the global metric type.
Assigning a TE metric to a link
3. Assign a TE metric to the link. Choose one option as needed:
¡ Method 1:
mpls te metric value
¡ Method 2:
te metric value
By default, the link uses its IGP metric as the TE metric.
This command is required on every interface that the MPLS TE tunnel traverses. The maximum TE metric value that can take effect is 16777215. If you set a TE metric greater than 16777215, 16777215 takes effect.
The device can use the locally configured attributes or the attributes carried in Update or Initial messages received from a PCE to establish MPLS TE tunnels. This feature allows you to specify the attribute usage preference for establishing MPLS TE tunnels.
If only the local or pce keyword is specified, the device obtains the attributes from the attribute source specified by the keyword. For attributes that cannot be obtained from the specified attribute source, the device uses the default values of the attributes.
If both the local and pce keywords are specified, the device prefers to use the attribute source indicated by the first keyword in the command. For attributes that cannot be obtained from that attribute source, the device obtains the attributes from the attribute source specified by the second keyword. For attributes that cannot be obtained from neither the local nor the PCE attribute source, the device uses the default values of the attributes.
This feature takes effect on the following attributes: bandwidth, affinity, setup and holding priorities, explicit path, link metric type, TE metric of a link, and BSID. For other attributes, the device always uses the locally configured values.
This feature can be configured in both tunnel interface view and MPLS TE view. The configuration in MPLS TE view applies to all MPLS TE tunnels. The configuration in tunnel interface view applies only to the current MPLS TE tunnel. For an MPLS TE tunnel, the configuration in tunnel interface view has a higher priority than the configuration in MPLS TE view.
Configuring the global attribute usage preference for MPLS TE tunnel setup
mpls-te
3. Specify the global attribute usage preference for establishing the MPLS TE tunnel.
tunnel-attribute prefer { local | pce } *
By default, the device uses the attributes received from a PCE to establish MPLS TE tunnels.
Configure the attribute usage preference for an MPLS TE tunnel interface
3. Configure the attribute usage preference for establishing the MPLS TE tunnel.
mpls te tunnel-attribute prefer { local | pce } *
By default, the attribute usage preference configured in MPLS TE view applies.
Configuring route pinning
Perform this task on the ingress node of an MPLS TE tunnel.
When route pinning is enabled, you cannot configure MPLS TE tunnel reoptimization.
3. Enable route pinning.
mpls te route-pinning
By default, route pinning is disabled.
When a node carries heavy service load, you can mark the node as an overloaded node by using the set-overload command. For MPLS TE traffic to bypass such overloaded nodes, you can perform this task on the ingress node for MPLS TE. Then, the established CRLSPs will not traverse the overloaded nodes. This mechanism can reduce the burden on the overloaded nodes and improve the reliability of the CRLSPs.
After this feature is configured, CSPF excludes overloaded nodes (if any) from path calculation for new CRLSPs. For CRLSPs that are already established, CSPF recalculates paths for the CRLSPs to bypass the overloaded nodes.
This feature takes effect only when the device uses RSVP-TE to establish MPLS TE tunnels.
mpls te
3. Exclude IS-IS overloaded nodes from CSPF path calculation for CRLSPs.
path exclude overload-node
By default, the device does not exclude IS-IS overloaded nodes from CSPF path calculation.
Perform this task on the ingress node of an MPLS TE tunnel. This feature allows you to manually or dynamically trigger the ingress node to recalculate a path. If the ingress node recalculates a better path, it creates a new CRLSP, switches the traffic from the old CRLSP to the new CRLSP, and then deletes the old CRLSP.
3. Enable tunnel reoptimization.
mpls te reoptimization [ frequency seconds ]
By default, tunnel reoptimization is disabled.
4. (Optional.) Immediately reoptimize all MPLS TE tunnels that are enabled with the tunnel reoptimization feature:
a. Return to user view.
return
b. Immediately reoptimize all MPLS TE tunnels that are enabled with the tunnel reoptimization feature.
This task is configurable on all nodes that the MPLS TE tunnel traverses.
When the bandwidth of an MPLS TE link changes, IGP floods the new bandwidth information, so the ingress node can use CSPF to recalculate the path.
To prevent such recalculations from consuming too many resources, you can configure IGP to flood only significant bandwidth changes by setting the following flooding thresholds:
· Up threshold—When the percentage of the reservable-bandwidth increase to the maximum reservable bandwidth reaches the threshold, IGP floods the TE information.
· Down threshold—When the percentage of the reservable-bandwidth decrease to the maximum reservable bandwidth reaches the threshold, IGP floods the TE information.
You can also set the flooding interval at which bandwidth changes that cannot trigger immediate flooding are flooded.
3. Set the bandwidth up/down threshold for the IGP to flood TE information. Choose one option as needed:
¡ Method 1:
mpls te bandwidth change thresholds { down | up } percent
¡ Method 2:
By default, the up/down threshold is 10% of the link reservable bandwidth.
4. Return to system view.
5. Enter MPLS TE view.
mpls te
6. Set the flooding interval.
link-management periodic-flooding timer interval
By default, the flooding interval is 180 seconds.
The CRLSP switching delay time refers to the time that MPLS TE must wait before it switches traffic from the old CRLSP to the new CRLSP.
When the upstream is idle but the downstream is busy, the new CRLSP might not be able to come up on every LSR within the switching delay time. If the upstream switches traffic to the new CRLSP but the CRLSP is not up at the downstream, traffic forwarding is interrupted.
To prevent this problem, perform this task to tune the switching delay time. A proper switching delay time ensures that the new CRLSP has enough time to come up on the entire path before traffic is switched to it.
mpls te
3. Set the time that MPLS TE must wait before switching the traffic to the new CRLSP.
switch-delay time-value
By default, MPLS TE must wait 10000 milliseconds before switching the traffic to the new CRLSP.
After the new CRLSP is established, MPLS TE must wait a period of time (called the CRLSP deletion delay time) before it deletes the old CRLSP. If the new CRLSP fails during the delay time, the old CRLSP will not be deleted, so that the traffic can be switched back to the old CRLSP.
MPLS TE uses a PathErr message to report the failure of the new CRLSP from downstream to upstream. The message might not be able to reach the upstream nodes before the old CRLSP is deleted because the downstream nodes are too busy to deliver it.
To prevent this problem, perform this task to tune the CRLSP deletion delay time. A proper deletion delay time ensures enough time for the new CRLSP's failure to be reported before the old CRLSP is deleted.
mpls te
3. Set the time that MPLS TE must wait before deleting the old CRLSP.
delete-delay time-value
By default, MPLS TE must wait 10000 milliseconds before deleting the old CRLSP.
Perform the tasks on the ingress node of an MPLS TE tunnel.
When you perform the tasks, be aware of each configuration objective and its impact on your device.
Enabling loop detection
Enabling loop detection also enables the route recording feature, regardless of whether you have configured the mpls te record-route command. Loop detection enables each node of the tunnel to detect whether a loop has occurred according to the recorded route information.
3. Enable loop detection.
mpls te loop-detection
By default, loop detection is disabled.
Perform this task to record the nodes that an MPLS TE tunnel traverses and the label assigned by each node. The recorded information helps you know about the path used by the MPLS TE tunnel and the label distribution information, and when the tunnel fails, it helps you locate the fault.
3. Record routes or record both routes and labels.
¡ Record routes.
¡ Record both routes and labels.
mpls te record-route label
By default, both route recording and label recording are disabled.
Setting tunnel setup retry
If the ingress node fails to establish an MPLS TE tunnel, it waits for the retry interval, and then tries to set up the tunnel again. It repeats this process until the tunnel is established or until the number of attempts reaches the maximum. If the tunnel cannot be established when the number of attempts reaches the maximum, the ingress waits for a longer period and then repeats the previous process.
3. Set the maximum number of tunnel setup attempts.
mpls te retry retries
By default, the maximum number of attempts is 3.
4. Set the retry interval.
mpls te timer retry seconds
By default, the retry interval is 2 seconds.
mpls te
3. Enable automatic bandwidth adjustment globally and configure the output rate sampling interval.
auto-bandwidth enable [ sample-interval interval ]
By default, the global auto bandwidth adjustment is disabled.
The sampling interval configured in MPLS TE view applies to all MPLS TE tunnels. The output rates of all MPLS TE tunnels are recorded every sampling interval to calculate the actual average bandwidth of each MPLS TE tunnel in one sampling interval.
4. Enter MPLS TE tunnel interface view.
5. Enable automatic bandwidth adjustment or output rate sampling for the MPLS TE tunnel.
¡ Enable automatic bandwidth adjustment.
mpls te auto-bandwidth adjustment [ [ frequency seconds ] [ max-bw max-bandwidth | min-bw min-bandwidth ] *| threshold percent ] *
By default, automatic bandwidth adjustment is disabled for an MPLS TE tunnel.
¡ Enable output rate sampling.
mpls te auto-bandwidth collect-bw [ frequency seconds ]
By default, output rate sampling is disabled for an MPLS TE tunnel.
6. (Optional.) Reset the automatic bandwidth adjustment:
return
b. Reset the automatic bandwidth adjustment.
reset mpls te auto-bandwidth-adjustment timers
After this command is executed, the system clears the output rate sampling information and the remaining time to the next bandwidth adjustment to start a new output rate sampling and bandwidth adjustment.
3. Configure the resources reservation style for the tunnel.
mpls te resv-style { ff | se }
By default, the resource reservation style is SE.
In current MPLS TE applications, tunnels are established usually by using the make-before-break mechanism. As a best practice, use the SE style.
Configuring path verification
The path verification feature examines the label and route mapping for an SRLSP. If the configured label has been occupied or the corresponding route does not exist, the system sets the SRLSP's state to down to avoid traffic forwarding failure.
The following path verification configuration modes are available:
· Global path verification—The system examines label and route mappings for all SRLSPs.
· Path verification for an MPLS TE tunnel—The system examines the label and route mapping for the SRLSP used by the tunnel .
In the current software version, only MPLS TE tunnels that use explicit-path SRLSPs support this feature.
Enabling global path verification
mpls te
3. Enable global path verification.
path verification enable
By default, global path verification is enabled.
Configring path verification for an MPLS TE tunnel
3. Configure path verification for the tunnel.
mpls te path verification { enable | disable }
By default, the path verification configuration for an MPLS TE tunnel is the same as the global path verification configuration.
You can configure a PCE feature in either the MPLS TE view or the PCC view. Different PCE features can be configured in different views.
Configuring a PCE
An LSR acts as a PCC if no PCE IP address is specified for it. It uses its LSR ID to communicate with PCEs. To configure the LSR as a PCE, perform this task.
mpls te
3. Configure a PCE IP address.
pce address ip-address
By default, no PCE address is configured.
4. (Optional.) Enable the SR capability for the PCE device.
pce capability segment-routing
By default, a PCE device does not have the SR capability.
To establish an SR-capable stateful PCEP session, you need to enable the SR capability on both peers of the PCEP session.
Discovering PCEs
A PCE can be manually specified on a PCC by using the pce static command or automatically discovered through the PCE information advertised by OSPF TE. A PCC sends PCEP connection requests to discovered PCEs but does not accept requests from the PCEs.
Manually specifying a PCE
2. Enter MPLS TE view or PCC view.
¡ Enter MPLS TE view.
mpls te
¡ Enter PCC view.
pce-client
3. Specify the IP address of the PCE.
pce static ip-address
Dynamically discovering PCEs
OSPF TE advertises PCE IP addresses for PCCs and other PCEs to dynamically discover the PCEs and establish PCEP sessions to them. For OSPF TE configuration, see "Configuring OSPF TE."
If you configure the mpls te path command for an LSR, it uses the path calculated by PCEs to establish a CRLSP. The LSR acts as a PCC.
If you specify PCE addresses by using the mpls te path or mpls te backup-path command, the LSR establishes PCEP sessions to the specified PCEs. If you do not specify any PCE addresses, the LSR establishes PCEP sessions to all discovered PCEs.
3. Establish a CRLSP by using the path calculated by PCEs.
mpls te path preference value dynamic pce [ ip-address ]&<0-8>
By default, the automatically calculated path is used to establish a CRLSP.
Configuring stateful PCEP
For a PCC and a PCE to establish a stateful PCEP session, you must specify the same device type (active stateful or passive stateful) for the two devices.
· If they are configured as passive-stateful devices, the PCE knows all CRLSPs maintained by the PCC but does not accept delegation requests sent by the PCC.
· If they are configured as active-stateful devices, the PCC can delegate CRLSPs to the PCE. If multiple PCEs are available for CRLSP delegation in the network, the PCC chooses the PCE with the highest delegation priority.
If a PCEP session between a PCC and a PCE terminates, the PCC waits for the redelegation timeout interval before it redelegates the CRLSP.
· If the PCEP session is re-established within the redelegation timeout interval, the PCC redelegates the CRLSP to the PCE.
· If the PCEP session fails to be re-established within the interval, the PCC redelegates the CRLSP to another PCE that has a lower delegation priority.
If the redelegation fails and the CRLSP state timeout expires, the PCC uses the path calculated locally to establish the CRLSP.
If multi-delegation is enabled on a PCC, the PCC can delegate delegation-enabled dynamic CRLSPs and SRLSPs to all the PCEs specified for the PCC. The PCC updates the CRLSPs and SRLSPs according to the update requests received from any of the PCEs.
If an ingress needs to delegate only part of its CRLSPs to the PCE, the PCE does not have complete CRLSP information to calculate global bandwidth information. In this case, you can configure the ingress to report information about the undelegated CRLSPs to the PCE without delegating the CRLSPs to the PCE.
If Segment Routing (SR) is used to establish a tunnel, the PCC delegates the SRLSP to the SR-capable PCE, and establishes the SRLSP by using the update messages sent by the PCE.
The CRLSP state timeout interval must be greater than or equal to the redelegation timeout interval.
To use SR to establish a tunnel, you must enable the SR capability on the active stateful PCEP devices (by using the pce capability segment-routing command).
If you configure both the mpls te passive-delegate report-only and mpls te delegation commands for a tunnel, the mpls te passive-delegate report-only command takes effect.
In the same tunnel interface view, the mpls te delegation disable command and the mpls te passive-delegate report-only command are mutually exclusive with each other.
Enabling delegation
mpls te
¡ Enter PCC view.
pce-client
3. Configure the PCEP device type as active stateful or passive stateful.
pcep type { active-stateful | passive-stateful }
By default, the PCEP device type is stateless.
4. (Optional.) Globally configure the delegation feature for MPLS TE tunnels.
mpls te stateful-pce { delegation | report-only }
By default, the device does not delegate MPLS TE tunnels or report MPLS TE tunnel information to PCEs.
This command is supported only in MPLS TE view.
5. (Optional.) Enable the multi-delegation feature on the PCC to delegate CRLSPs and SRLSPs to all PCEs.
pce multi-delegate enable
By default, the multi-delegation feature is disabled.
6. (Optional.) Enable the SR capability of the PCEP device.
By default, the device does not have the SR capability.
To establish an SR-capable stateful PCEP session, enable the SR capability on both peers of the session.
7. Return to system view.
8. Enter MPLS TE tunnel interface view.
9. Enable CRLSP/SRLSP delegation.
mpls te delegation [ disable ]
By default, the delegation setting in MPLS TE view applies.
10. (Optional.) Configure the PCC to report CRLSP information to the PCE without delegating the CRLSP to the PCE.
11. (Optional.) Configure MPLS TE to use SR to establish the tunnel.
mpls te signaling segment-routing
Execute this command when SRLSP delegation is enabled.
Configuring delegation parameters
mpls te
¡ Enter PCC view.
pce-client
4. Set the delegation priority of a PCE.
pce peer ip-address delegation-priority priority
By default, the delegation priority of a PCE is 65535.
5. (Optional.) Set the redelegation timeout interval.
pce redelegation-timeout value
By default, the redelegation timeout interval is 30 seconds.
6. (Optional.) Set the state timeout interval on the PCC.
pce state-timeout value
By default, the state timeout interval is 60 seconds.
7. Enable the SR capability.
8. (Optional.) Configure the PCC to retain PCE-updated LSP states.
pce retain lsp-state
By default, a PCC restores the original LSP states when the state timeout interval expires.
9. (Optional.) Configure the PCC to retain PCE-initiated LSPs.
pce retain initiated-lsp
By default, a PCC deletes PCE-initiated LSPs when the state timeout interval expires.
This task allows you to configure parameters for PCCs or PCEs to establish PCEP sessions to manually specified or dynamically discovered PCEs.
mpls te
¡ Enter PCC view.
pce-client
3. Set the path calculation request timeout time.
pce request-timeout value
By default, the request timeout time is 10 seconds.
4. Set the PCEP session deadtimer.
pce deadtimer value
By default, the PCEP session deadtimer is 120 seconds.
5. Set the keepalive interval for PCEP sessions.
pce keepalive interval
By default, the keepalive interval is 30 seconds.
6. Set the minimum acceptable keepalive interval and the maximum number of allowed unknown messages received from the peer.
pce tolerance { min-keepalive value | max-unknown-messages value }
By default, the minimum acceptable keepalive interval is 10 seconds, and the maximum number of allowed unknown messages in a minute is 5.
7. Configure PCEP session authentication for a peer. Choose one option as needed:
¡ Configure the keychain authentication.
pce peer ip-address keychain keychain-name
¡ Configure the MD5 authentication.
pce peer ip-address md5 { cipher | plain } string
By default, PCEP session authentication is not configured.
For two devices to establish a PCEP session, you must configure the same authentication mode and specify the same key string on both devices.
Configuring tunnel interface-based unequal load sharing
Tunnel interface-based unequal load sharing assigns bandwidth to multiple equal-cost MPLS TE tunnels that have the same destination. Traffic to that destination is shared over the tunnels in proportion of their bandwidths.
For example, Tunnel 1, Tunnel 2, and Tunnel 3 are three equal-cost MPLS TE tunnels destined for the same address. The bandwidths of Tunnel 1, Tunnel 2, and Tunnel 3 are 10000 kbps, 10000 kbps, and 20000 kbps, respectively. The proportions of traffic forwarded over the tunnels are 1/4, 1/4, and 1/2, respectively. If you change the bandwidths of the tunnels to 1 kbps, 1 kbps, and 2 kbps, the traffic forwarding proportions of the tunnels are still 1/4, 1/4, and 1/2.
When adjacency forwarding is enabled, bandwidth assigned by the mpls te load-share command participates in IGP link cost calculation. As a result, the IGP link costs of the MPLS TE tunnels for unequal load sharing might be different. To ensure that their IGP link costs are equal, tune the IGP costs of the tunnels with the ospf cost or isis cost command. For information about the ospf cost and isis cost commands, see Layer 3—IP Routing Command Reference.
To enable unequal load sharing for TE tunnels, make sure bandwidth-based load sharing is enabled by using the bandwidth-based-sharing command, in addition to executing the mpls te load-share command.
3. Assign bandwidth to the MPLS TE tunnel for unequal load sharing.
mpls te load-share value
By default, no bandwidth is assigned to an MPLS TE tunnel for unequal load sharing. The proportion of traffic forwarded over the MPLS TE tunnel is based on the bandwidth assigned by the mpls te bandwidth command.
Creating a static route to direct traffic to an MPLS TE tunnel
2. Configure a static route to direct traffic to an MPLS TE tunnel.
ip route-static { dest-address { mask-length | mask } | group group-name } { interface-type interface-number [ next-hop-address ] [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | bfd { control-packet | echo-packet } | permanent | track track-entry-number ] | next-hop-address [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ip-address | permanent | track track-entry-number ] } [ preference preference ] [ tag tag-value ] [ description text ]
The interface specified in this command can be an MPLS TE tunnel interface.
For more information about this command, see static routing commands in Layer 3—IP Routing Command Reference.
Configuring automatic static route advertisement to direct traffic to an MPLS TE tunnel
2. Enter MPLS TE tunnel view.
3. Configure automatic static route advertisement.
tunnel route-static [ preference preference-value ]
By default, automatic static route advertisement is not configured.
This command creates a static route whose destination address and output interface are the tunnel destination address and the tunnel interface, respectively.
For more information about the commands in this task, see policy-based routing commands in Layer 3—IP Routing Command Reference.
2. Create a PBR policy node and enter policy node view.
3. Configure an ACL match criterion.
By default, no ACL match criterion is configured.
4. Specify a tunnel interface as the packet output interface.
apply output-interface { tunnel tunnel-number } [ track track-entry-number ] &<1-2>
6. Apply the PBR policy.
¡ Apply the policy to the local device.
ip local policy-based-route policy-name
¡ Execute the following commands in sequence to apply the policy to an interface:
ip policy-based-route policy-name
By default, no policy is applied.
Restrictions and guidelines for automatic route advertisement
The destination address of the MPLS TE tunnel can be the LSR ID of the egress node or the primary IP address of an interface on the egress node. As a best practice, configure the destination address of the MPLS TE tunnel as the LSR ID of the egress node.
If you configure the tunnel destination address as the primary IP address of an interface on the egress node, you must enable MPLS TE, and configure OSPF or IS-IS on that interface. This makes sure the primary IP address of the interface can be advertised to its peer.
The route to the tunnel interface address and the route to the tunnel destination must be in the same OSPF area or at the same IS-IS level.
To use forwarding adjacency, you must establish two MPLS TE tunnels in opposite directions between two nodes, and configure forwarding adjacency on both the nodes.
Only MPLS TE tunnels established by using RSVP-TE support the forwarding adjacency feature.
Prerequisites for automatic route advertisement
Before configuring automatic route advertisement, perform the following tasks:
· Enable OSPF or IS-IS on the tunnel interface to advertise the interface address to OSPF or IS-IS.
· Enable MPLS TE for an OSPF area or an IS-IS process by executing the mpls te enable command in OSPF area view or IS-IS view.
Configuring IGP shortcut (tunnel interface view)
3. Enable IGP shortcut.
mpls te igp shortcut [ isis | ospf ] [ include-ipv6 ]
By default, IGP shortcut is disabled.
If no IGP is specified, both OSPF and IS-IS will include the MPLS TE tunnel in route calculation. If you do not specify the include-ipv6 keyword, only IPv4 IGP will include the MPLS TE tunnel in route calculation.
4. Assign a metric to the MPLS TE tunnel.
mpls te igp metric { absolute value | relative value }
By default, the metric of an MPLS TE tunnel equals its IGP metric.
Metric type |
Metric of the MPLS TE tunnel |
Absolute metric |
Equals the absolute metric. |
Relative metric |
Equals the relative metric plus the IGP metric of the tunnel. |
Configuring forwarding adjacency in tunnel interface view
3. Enable forwarding adjacency.
mpls te igp advertise [ hold-time value | include-ipv6-isis ] *
By default, forwarding adjacency is disabled.
Restrictions and guidelines for bidirectional MPLS TE tunnel
To create a bidirectional MPLS TE tunnel, create an MPLS TE tunnel interface on both ends of the tunnel and enable the bidirectional tunnel feature on the tunnel interfaces:
· For a co-routed bidirectional tunnel, configure one end of the tunnel as the active end and the other end as the passive end, and specify the reverse CRLSP at the passive end.
· For an associated bidirectional tunnel, specify a reverse CRLSP at both ends of the tunnel.
Prerequisites for bidirectional MPLS TE tunnel
Before you create a bidirectional MPLS TE tunnel, perform the following tasks:
· Disable the PHP feature on both ends of the tunnel.
· To set up a bidirectional MPLS TE tunnel in co-routed mode, you must specify the signaling protocol as RSVP-TE.
Configuring the active end of a co-routed bidirectional MPLS TE tunnel
3. Configure a co-routed bidirectional MPLS TE tunnel and specify the local end as the active end of the tunnel.
mpls te bidirectional co-routed active
By default, bidirectional tunnel is disabled on the tunnel interface, and tunnels established on the tunnel interface are unidirectional MPLS TE tunnels.
Configuring the passive end of a co-routed bidirectional MPLS TE tunnel
3. Configure a co-routed bidirectional MPLS TE tunnel and specify the local end as the passive end of the tunnel.
mpls te bidirectional co-routed passive reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id
Configuring an associated bidirectional MPLS TE tunnel
3. Configure an associated bidirectional MPLS TE tunnel.
mpls te bidirectional associated reverse-lsp { binding-sid label label-value | lsp-name lsp-name | lsr-id ingress-lsr-id tunnel-id tunnel-id } }
Bit errors are digital signal bits received over a communication channel that have been altered due to wire aging, phase jitter, noise, interference, or other bit synchronization errors. Accumulated bit errors might cause degradation of the digital signal.
After bit error detection is configured for an MPLS TE tunnel, the egress node monitors the bit error rate of the primary CRLSP. If the bit error rate of the primary CRLSP reaches or exceeds the switch threshold, traffic is switched to the backup CRLSP. Traffic is switched back to the primary CRLSP after the its bit error rate drops below the revert threshold.
This feature is applicable only to bidirectional MPLS TE tunnels that are established by using RSVP-TE.
Configure this feature on the egress nodes of the forward MPLS TE tunnels.
Before configuring this feature for a tunnel, enable CRLSP hot-standby backup for the tunnel by using the mpls te backup hot-standby command.
3. Enable bit error detection for the MPLS TE tunnel.
mpls te bit-error-detection [ mode { bidirectional | unidirectional } ]
By default, bit error detection is disabled for a tunnel.
Bit error protection switching mode |
bidirectional |
The tunnel egress performs primary/backup switchovers for the reverse CRLSP of the tunnel. The tunnel ingress performs primary/backup switchovers for the forward CRLSP of the tunnel. |
unidirectional |
Only the tunnel egress performs primary/backup switchovers for the reverse CRLSP. |
4. Configure the switch and revert thresholds for bit error detection.
mpls te bit-error-detection threshold switch switch-coe switch-pow resume resume-coe resume-pow
By default, the switch threshold and revert threshold are both 0. Traffic is switched to the backup CRLSP immediately when bit errors are detected on nodes of the primary CRLSP. Traffic is switched back to the primary CRLSP after the bit errors are cleared on the primary CRLSP.
This feature provides end-to-end CRLSP/SRLSP protection for an MPLS TE tunnel.
Static CRLSPs or SRLSPs do not support the backup feature.
SRLSPs support only the hot-standby backup mode.
Enabling CRLSP/SRLSP backup for an MPLS TE tunnel
3. Enable tunnel backup and specify the backup mode.
mpls te backup { hot-standby [ wtr delay-time ] | ordinary }
By default, tunnel backup is disabled.
MPLS TE tunnels that use SRLSPs do not support the ordinary keyword.
Configuring the backup path setup mode
The primary path and backup paths of a tunnel can be established in different modes.
If both the primary and backup paths are automatically calculated, make sure there are at least two paths to reach the tunnel destination. Otherwise, the backup CRLSP/SRLSP cannot be used.
When you use the mpls te path preference or mpls te backup-path preference command to establish an SRLSP, do not specify both the dynamic and no-cspf keyword.
3. Specify the backup path setup mode. Choose one option as needed:
¡ Specify the back path and set the preference of the path.
mpls te backup-path preference value { dynamic [ pce [ ip-address ]&<0-8> | no-cspf ] | explicit-path path-name [ no-cspf ] }
By default, the automatically calculated path is used to establish a backup CRLSP/SRLSP.
If you specify the PCE option, the device acts as a PCC and establishes PCEP sessions to the specified PCEs. The PCC uses the paths computed by the PCEs to establish backup CRLSPs or SRLSPs.
¡ Enable LSP delegation to a PCE to establish backup SRLSPs or CRLSPs.
By default, CRLSP/SRLSP delegation is disabled.
Configuring CSPF to include the SRLG constraint in backup path computation
If the SRLG constraint is included in path computation, CSPF excludes all links with interfaces which belong to the same SRLG as the protected interface.
Only SRLSPs support this feature.
mpls te
3. Configure CSPF to include the SRLG constraint in the computation of a backup path.
backup-path exclude-srlg [ preferred ]
By default, CSPF does not include the SRLG constraint in the computation of a backup path.
Setting the time that MPLS TE must wait before switching the traffic back to the primary path
When the primary path recovers, MPLS TE must wait a period of time before switching the traffic back to the primary path. This task allows you to tune the delay time.
mpls te
3. Set the time that MPLS TE must wait before switching the traffic back to the primary path.
By default, MPLS TE must wait 10000 milliseconds before switching the traffic back to the primary path.
Configuring MPLS TE FRR
Restrictions and guidelines for MPLS TE FRR
MPLS TE FRR provides temporary link or node protection on a CRLSP. When you configure FRR, follow these restrictions and guidelines:
· Do not configure both FRR and RSVP authentication on the same interface.
· Only MPLS TE tunnels established through RSVP-TE support FRR.
· If both the MPLS TE FRR and bidirectional MPLS TE tunnel features are configured, only the bidirectional MPLS TE tunnel feature takes effect.
· If both the FRR facility backup mode and one-to-one backup mode are configured, the most recent configuration takes effect.
Configuring facilicity backup FRR
To configure FRR, you must configure bypass tunnels for primary CRLSPs on the PLR by using the following methods:
· Manually configuring a bypass tunnel on the PLR—Create an MPLS TE tunnel on the PLR, and configure the tunnel as a bypass tunnel for a primary CRLSP. You need to specify the bandwidth and CT that the bypass tunnel can protect, and bind the bypass tunnel to the output interface of the primary CRLSP.
You can configure a maximum of three bypass tunnels for a primary CRLSP.
· Configuring the PLR to set up bypass tunnels automatically—Configure the automatic bypass tunnel setup feature (also referred to as the auto FRR feature) on the PLR. The PLR automatically sets up two bypass tunnels for each of its primary CRLSPs: One in link protection mode and the other in node protection mode. Automatically created bypass tunnels can be used to protect any type of CT, but they cannot provide bandwidth protection. An automatically created bypass tunnel can protect multiple primary CRLSPs.
A primary tunnel can have both manually configured and automatically created bypass tunnels. The PLR will select one bypass tunnel to protect the primary CRLSP. The selected bypass tunnel is bound to the primary CRLSP.
Manually created bypass tunnels take precedence over automatically created bypass tunnels. An automatically created bypass tunnel in node protection mode takes precedence over an automatically created bypass tunnel in link protection mode. Among manually created bypass tunnels, the PLR selects the bypass tunnel for protecting the primary CRLSP by following these rules:
1. Selects a bypass tunnel according to the following factors:
¡ Bandwidth required by the primary CRLSP.
¡ Whether the primary CRLSP requires bandwidth protection or not.
¡ Whether the bypass tunnel provides bandwidth protection or not.
2. Prefers the bypass tunnel in node protection mode over the one in link protection mode.
3. Prefers the bypass tunnel with a smaller ID over the one with a bigger tunnel ID.
When a primary CRLSP that requires no bandwidth protection is associated with a bypass tunnel that provides bandwidth protection, the primary CRLSP can occupy the bandwidth of the bypass tunnel. If the bypass tunnel also protects other primary CRLSPs, the primary CRLSP that comes up first occupies the bandwidth of the bypass tunnel. A primary CRLSP that needs bandwidth protection cannot preempt the one that does not need bandwidth protection.
After an FRR, the primary CRLSP will be down if you modify the bandwidth that the bypass tunnel can protect and your modification results in one of the following:
· The CT type changes.
· The bypass tunnel cannot protect adequate bandwidth as configured.
· FRR protection type changes (whether or not to provide bandwidth protection for the primary CRLSP).
When you configure a bypass tunnel, follow these principles to protect and assign bandwidth:
· Use bypass tunnels to protect only critical interfaces or links when bandwidth is insufficient. Bypass tunnels are pre-established and require extra bandwidth.
· Make sure the bandwidth assigned to the bypass tunnel is no less than the total bandwidth needed by all primary CRLSPs to be protected by the bypass tunnel. Otherwise, some primary CRLSPs might not be protected by the bypass tunnel.
· A bypass tunnel typically does not forward data when the primary CRLSP operates correctly. For a bypass tunnel to also forward data during tunnel protection, you must assign adequate bandwidth to the bypass tunnel.
A bypass tunnel has the following restrictions:
· The bypass tunnel cannot be used for services such as VPN.
· FRR cannot be configured for the bypass tunnel. A bypass tunnel cannot act as a primary CRLSP.
· The bypass tunnel must not traverse the protected node or interface.
When you configure the PLR to automatically set up a bypass tunnel, follow these restrictions and guidelines:
· Interfaces automatically generated by the device support only auto FRR protection.
· If the PLR is the penultimate node of a primary CRLSP, the PLR does not create a node-protection bypass tunnel for the primary CRLSP.
Enabling facility backup FRR on the ingress mode
2. Enter tunnel interface view of the primary CRLSP.
3. Enable facility backup FRR.
mpls te fast-reroute [ bandwidth ]
By default, facility backup FRR is disabled.
If you specify the bandwidth keyword, the primary CRLSP must have bandwidth protection.
2. Create a bypass tunnel.
The bypass tunnel setup method is the same as a normal MPLS TE tunnel. For more information, see "Establishing a static CRLSP", "Establishing a CRLSP dynamically", and "Establishing a CRLSP by using the path calculated by PCEs."
3. Enter tunnel interface view of the bypass tunnel.
4. Specify the destination address of the bypass tunnel.
The bypass tunnel destination address is the LSR ID of the MP.
5. Configure the bandwidth to be protected by the bypass tunnel.
mpls te backup bandwidth { bandwidth | un-limited }
By default, the bandwidth and the CT to be protected by the bypass tunnel are not specified.
To successfully associate a primary CRLSP with a bypass tunnel, you must use this command to specify the bandwidth that the bypass tunnel can protect.
6. Return to system view.
7. Enter interface view of the output interface of a primary CRLSP.
8. Specify a bypass tunnel for the protected interface.
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
By default, no bypass tunnel is specified for an interface.
Automatically setting up bypass tunnels on the PLR
mpls te
3. Enable auto FRR globally, and enter MPLS TE auto FRR view.
auto-tunnel backup
By default, the auto FRR feature is disabled globally.
4. Specify an interface number range for the automatically created bypass tunnels.
tunnel-number min min-number max max-number
By default, no interface number range is specified, and the PLR cannot set up a bypass tunnel automatically.
5. (Optional.) Configure the PLR to create only link-protection bypass tunnels.
nhop-only
By default, the PLR automatically creates both a link-protection and a node-protection bypass tunnel for each of its primary CRLSPs.
Execution of this command deletes all existing node-protection bypass tunnels automatically created for MPLS TE auto FRR.
6. (Optional.) Set a removal timer for unused bypass tunnels.
timers removal unused seconds
By default, a bypass tunnel is removed after it is unused for 3600 seconds.
A bypass tunnel is unused when the bypass tunnel is not bound to any primary CRLSP. When a bypass tunnel is unused for the period of time configured by the timers removal unused command, MPLS TE removes the bypass tunnel.
7. (Optional.) Disable the auto FRR feature on the interface:
a. Return to system view.
b. Enter interface view.
c. Disable the auto FRR feature on the interface.
mpls te auto-tunnel backup disable
By default, the auto FRR feature is enabled on all RSVP-enabled interfaces after it is enabled globally.
Execution of this command deletes all existing bypass tunnels automatically created on the interface for MPLS TE auto FRR.
Setting the optimal bypass tunnel selection interval on the PLR
mpls te
3. Set the interval for selecting an optimal bypass tunnel.
fast-reroute timer interval
By default, the interval is 300 seconds.
If you have specified multiple bypass tunnels for a primary CRLSP, MPLS TE selects an optimal bypass tunnel to protect the primary CRLSP. Sometimes, a bypass tunnel might become better than the current optimal bypass tunnel because, for example, the reservable bandwidth changes. You can perform this task to set the interval at which MPLS TE polls the bypass tunnels to update the optimal bypass tunnel.
Enabling one-to-one backup on the ingress node
After the one-to-one backup feature is enabled for an MPLS TE tunnel, the device automatically enables the tunnel's label recording feature, regardless of whether the mpls te record-route label command is executed.
2. Enter tunnel interface view for the primary CRLSP.
3. Enable the one-to-one backup feature of MPLS TE FRR.
mpls te detour
By default, the one-to-one backup feature of MPLS TE FRR is disabled.
Setting the time that MPLS TE must wait before switching the traffic back to the primary CRLSP
When the primary CRLSP recovers, MPLS TE must wait a period of time before switching the traffic back to the primary CRLSP. This task allows you to tune the delay time.
mpls te
3. Set the time that MPLS TE must wait before switching the traffic back to the primary CRLSP.
By default, MPLS TE must wait 10000 milliseconds before switching the traffic back to the primary CRLSP.
Configuring node fault detection
You can configure this feature for FRR node protection. FRR link protection does not need this configuration.
This feature uses the RSVP hello mechanism or BFD on the PLR and the protected node to detect the node faults caused by signaling protocol faults. To detect the node faults caused by the link faults between the PLR and the protected node, you do not need to configure this feature.
Enabling BFD for link status detection
2. Enter the view of the interface that is connected to the PLR or protected node.
3. Enable BFD for link status detection.
rsvp bfd enable
By default, BFD is not enabled for RSVP link status detection.
For more information about the rsvp bfd enable command, see "Configuring RSVP."
Configuring interface-based hello detection
3. Enable RSVP hello on the interface.
rsvp hello enable
By default, RSVP hello is disabled on an interface.
For more information about the rsvp hello enable command, see "Configuring RSVP."
Configuring LSR ID-based hello detection
2. Enter RSVP view.
rsvp
3. Create an RSVP hello neighbor.
hello node-session lsr-id
To establish an RSVP hello neighbor relationship, you must execute this command on both the local and peer devices.
You can use this command to establish an RSVP hello neighbor relationship between two indirectly connected nodes.
For more information about the hello node-session command, see "Configuring RSVP."
Configuring CBTS
Before configuring CBTS, you must create QoS traffic behaviors to mark the MPLS TE service class values for packets. For more information, see QoS configuration in ACL and QoS Configuration Guide.
3. Set a service class value for the MPLS TE tunnel.
mpls te service-class service-class-value
By default, no service class value is set for an MPLS TE tunnel.
4. (Optional.) Enable forced forwarding for the MPLS TE tunnel.
mpls te forced-forwarding
By default, forced forwarding is disabled for an MPLS TE tunnel.
5. Enable tunnel traffic statistics on a per-service class basis.
mpls te statistics service-class
By default, MPLS TE tunnel traffic statistics is disabled.
After you enable tunnel traffic statistics on a per-service class basis, the system collects total traffic statistics on the tunnel interface and traffic statistics for each service class.
6. Return to the system view.
7. Configure the service class-based tunnel traffic statistics interval.
mpls te statistics service-class interval interval
By default, the service class-based tunnel traffic statistics interval is 30 seconds.
This task allows the device to record information about traffic flow that traverses an MPLS TE tunnel.
This feature does not apply to bypass tunnels. That is, the device does not perform traffic policing on bypass tunnels.
3. Enable outbound traffic policing for the tunnel.
mpls te lsp-tp outbound
By default, outbound traffic policing is disabled for the tunnel.
Enabling SNMP notifications for MPLS TE
This feature enables generating SNMP notifications for MPLS TE upon MPLS TE state changes, as defined in RFC 3812. For MPLS TE event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
1. Enter system view.
2. Enable SNMP notifications for MPLS TE.
snmp-agent trap enable te
By default, SNMP notifications for MPLS TE are disabled.
Enabling private SNMP notifications for MPLS TE
This feature enables generating SNMP notifications for the specified MPLS TE events. These notifications are not defined in an RFC and are private MPLS TE event notifications supported by the device. For SNMP to output the private MPLS TE notifications correctly, you must also configure parameters for sending SNMP notifications. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
Restrictions and guidlines
If you do not specify a parameter in the snmp-agent trap enable te-private command, the command enables all types of private SNMP notifications for MPLS TE.
2. Enable private SNMP notifications for MPLS TE.
snmp-agent trap enable te-private [ auto-tunnel-mainlsp-up | auto-tunnel-up | hsb-switch | hsblsp-up-down | lspbfd-up-down | mainlsp-up-down | ob-switch | oblsp-up-down | p2mp-sublsp-down | p2mp-tunnel-up-down | rsvpauth-fail | rsvpfrr-protect | rsvpfrr-switch | rsvpnbr-lost | scrlsp-up-down | tunnel-delete | tunnelbw-change ] *
By default, private SNMP notifications for MPLS TE are disabled.
Enabling private SNMP notifications for PCEP
This feature enables generating SNMP notifications when PCEP cancels CRLSP/SRLSP delegations or PCEP session state changes. These notifications are not defined in an RFC and are private PCEP notifications supported by the device. For SNMP to output the private PCEP notifications correctly, you must also configure parameters for sending SNMP notifications. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2. Enable private SNMP notifications for PCEP.
snmp-agent trap enable pcep-private [ pcep-redelegation | pcepsess-up-down ]
By default, private SNMP notifications for PCEP are disabled.
Enabling MPLS TE logging
After MPLS TE logging is enabled, the device generates corresponding MPLS TE logs and saves them into the local file /var/log/te.log. To view the logs in the file, use the view command in probe view.
mpls te
3. Enable MPLS TE logging.
log enable { error | event | process }
MPLS TE event logging and MPLS TE error logging are enabled. MPLS TE process logging is disabled.
Enabling logging for PCEP messages
After PCEP message logging is enabled, the device generates logs for the PCEP messages exchanged between the PCC and the PCE and saves them into the local file /var/log/pcecp.log. To view the logs in the file, use the view command in probe view.
If you do not specify a keyword when you execute the pcep log enable command, the device does not log for the PCEP messages indicated by the keyword.
2. Enter PCC view.
pce-client
3. Enable logging for PCEP messages.
pcep log enable { error | initiate | reply | report | request | update } *
Logging is enabled for PCEP Error messages, LSP Initiate Request messages, and Path Computation Update Request messages.
Logging is disabled for Path Computation Reply messages, Path Computation State Report messages, and Path Computation Request messages.
Display and maintenance commands for MPLS TE
Task |
Command |
Display information about explicit paths. |
display explicit-path [ path-name ] |
Display link and node information in an IS-IS TEDB. |
display isis mpls te advertisement [ [ level-1 | level-2 ] | [ originate-system system-id | local ] | verbose ] * [ process-id ] |
Display sub-TLV information for IS-IS TE. |
display isis mpls te configured-sub-tlvs [ process-id ] |
Display network information in an IS-IS TEDB. |
display isis mpls te network [ [ level-1 | level-2 ] | local | lsp-id lsp-id ]* [ process-id ] |
Display IS-IS tunnel interface information. |
display isis mpls te tunnel [ ipv6 ] [ level-1 | level-2 ] [ process-id ] |
Display MPLS TE tunnel traffic statistics. |
display mpls statistics tunnel-interface number [ service-class service-class-value ] |
Display information about bidirectional MPLS TE tunnels. |
display mpls te bidirectional [ segment-routing | static | rsvp-te ] [ reverse-bsid label label-value ] |
Display MPLS TE tunnel and BSID associations. |
display mpls te binding-sid [ label label-value ] |
Display information about explicit paths that use BSIDs. |
display mpls te binding-sid ref-list [ label label-value ] |
Display the bit error status and bit error rate information of an MPLS TE tunnel interface |
display mpls te bit-error-detection tunnel-interface [ tunnel-number ] |
Display global MPLS TE settings and default settings for MPLS TE tunnels. |
display mpls te default-parameter |
Display bandwidth information on MPLS TE-enabled interfaces. |
display mpls te link-management bandwidth-allocation [ interface interface-type interface-number ] |
Display SRLGs of interfaces. |
display mpls te link-management srlg [ interface interface-type interface-number ] |
Display information about MPLS TE P2MP tunnel interfaces. |
display mpls te p2mp tunnel-interface [ tunnel number ] |
Display information about discovered PCEs. |
display mpls te pce discovery [ ip-address ] [ verbose ] |
Display CRLSP information in a PCE LSPDB. |
display mpls te pce lspdb [ plsp-id plsp-id ] [ verbose ] |
Display the sending/receiving time and contents of the report/update messages that the MPLS TE tunnels sent/received most recently. |
display mpls te pce lspdb last-packet-detail |
Display local PCEP session settings. |
display mpls te pce parameter |
Display PCC and PCE peer information. |
display mpls te pce peer [ ip-address ] [ verbose ] |
Display information about stateful PCE peers on a PCC. |
display mpls te pce stateful neighbor [ ip-address ] |
Display PCC and PCE statistics. |
display mpls te pce statistics [ ip-address ] |
Display the path information of MPLS TE tunnels established by using SR. |
display mpls te segment-routing tunnel path [ tunnel number ] |
Display information about SRLGs. |
display mpls te srlg [ srlg-number ] |
Display MPLS TEDB information. |
display mpls te tedb { { isis { level-1 | level-2 } | ospf area area-id } | link ip-address | network | node [ local | mpls-lsr-id ] | summary } |
Display information about MPLS TE tunnel interfaces. |
display mpls te tunnel-interface [ tunnel number ] |
Display link and node information in an OSPF TEDB. |
display ospf [ process-id ] [ area area-id ] mpls te advertisement [ originate-router advertising-router-id | self-originate ] |
Display network information in an OSPF TEDB. |
display ospf [ process-id ] [ area area-id ] mpls te network [ originate-router advertising-router-id | self-originate ] |
Display information about PCEs discovered by OSPF. |
display ospf [ process-id ] [ area area-id ] mpls te pce [ originate-router advertising-router-id | self-originate ] |
Display OSPF tunnel interface information. |
display ospf [ process-id ] [ area area-id ] mpls te tunnel |
Display bandwidth information on TE-enabled interfaces. |
display te link-management bandwidth-allocation [ interface interface-type interface-number ] |
Display SRLGs of the interfaces for TE traffic. |
display te link-management srlg [ interface interface-type interface-number ] |
Clear MPLS TE tunnel traffic statistics. |
reset mpls statistics tunnel-interface number |
Clear PCC and PCE statistics. |
reset mpls te pce statistics [ ip-address ] |
MPLS TE configuration examples
Example: Establishing an MPLS TE tunnel over a static CRLSP
Router A, Router B, and Router C run IS-IS.
Establish an MPLS TE tunnel over a static CRLSP from Router A to Router C to transmit data between the two IP networks.
The MPLS TE tunnel requires a bandwidth of 2000 kbps. The maximum bandwidth of the link that the tunnel traverses is 10000 kbps. The maximum reservable bandwidth of the link is 5000 kbps.
Figure 9 Network diagram
1. Configure IP addresses and masks for interfaces. (Details not shown.)
2. Configure IS-IS to advertise interface addresses, including the loopback interface address:
# Configure Router A.
[RouterA] isis 1
[RouterA-isis-1] network-entity 00.0005.0000.0000.0001.00
[RouterA-isis-1] quit
[RouterA] interface ten-gigabitethernet 3/0/1
[RouterA-Ten-GigabitEthernet3/0/1] isis enable 1
[RouterA-Ten-GigabitEthernet3/0/1] quit
[RouterA-LoopBack0] isis enable 1
[RouterA-LoopBack0] quit
# Configure Router B.
<RouterB> system-view
[RouterB] isis 1
[RouterB-isis-1] network-entity 00.0005.0000.0000.0002.00
[RouterB-isis-1] quit
[RouterB] interface ten-gigabitethernet 3/0/1
[RouterB-Ten-GigabitEthernet3/0/1] isis enable 1
[RouterB-Ten-GigabitEthernet3/0/1] quit
[RouterB] interface ten-gigabitethernet 3/0/2
[RouterB-Ten-GigabitEthernet3/0/2] isis enable 1
[RouterB-Ten-GigabitEthernet3/0/2] quit
[RouterB-LoopBack0] isis enable 1
[RouterB-LoopBack0] quit
# Configure Router C.
<RouterC> system-view
[RouterC] isis 1
[RouterC-isis-1] network-entity 00.0005.0000.0000.0003.00
[RouterC-isis-1] quit
[RouterC] interface ten-gigabitethernet 3/0/1
[RouterC-Ten-GigabitEthernet3/0/1] isis enable 1
[RouterC-Ten-GigabitEthernet3/0/1] quit
[RouterC] interface loopback 0
[RouterC-LoopBack0] isis enable 1
[RouterC-LoopBack0] quit
# Execute the display ip routing-table command on each router to verify that the routers have learned the routes to one another, including the routes to the loopback interfaces. (Details not shown.)
3. Configure an LSR ID, and enable MPLS and MPLS TE:
[RouterA] mpls lsr-id 1.1.1.1
[RouterA] mpls te
[RouterA-te] quit
[RouterA-Ten-GigabitEthernet3/0/1] mpls enable
[RouterA-Ten-GigabitEthernet3/0/1] mpls te enable
[RouterB] mpls lsr-id 2.2.2.2
[RouterB] mpls te
[RouterB-te] quit
[RouterB-Ten-GigabitEthernet3/0/1] mpls enable
[RouterB-Ten-GigabitEthernet3/0/1] mpls te enable
[RouterB-Ten-GigabitEthernet3/0/2] mpls enable
[RouterB-Ten-GigabitEthernet3/0/2] mpls te enable
[RouterC] mpls lsr-id 3.3.3.3
[RouterC] mpls te
[RouterC-te] quit
[RouterC-Ten-GigabitEthernet3/0/1] mpls enable
[RouterC-Ten-GigabitEthernet3/0/1] mpls te enable
4. Configure MPLS TE attributes of links:
# Set the maximum link bandwidth and maximum reservable bandwidth on Router A.
[RouterA-Ten-GigabitEthernet3/0/1] mpls te max-link-bandwidth 10000
[RouterA-Ten-GigabitEthernet3/0/1] mpls te max-reservable-bandwidth 5000
# Set the maximum link bandwidth and maximum reservable bandwidth on Router B.
[RouterB-Ten-GigabitEthernet3/0/1] mpls te max-link-bandwidth 10000
[RouterB-Ten-GigabitEthernet3/0/1] mpls te max-reservable-bandwidth 5000
[RouterB-Ten-GigabitEthernet3/0/2] mpls te max-link-bandwidth 10000
[RouterB-Ten-GigabitEthernet3/0/2] mpls te max-reservable-bandwidth 5000
# Set the maximum link bandwidth and maximum reservable bandwidth on Router C.
[RouterC-Ten-GigabitEthernet3/0/1] mpls te max-link-bandwidth 10000
[RouterC-Ten-GigabitEthernet3/0/1] mpls te max-reservable-bandwidth 5000
5. Configure an MPLS TE tunnel on Router A:
# Configure MPLS TE tunnel interface Tunnel 0.
[RouterA] interface tunnel 0 mode mpls-te
[RouterA-Tunnel0] ip address 6.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Router C.
[RouterA-Tunnel0] destination 3.3.3.3
# Configure MPLS TE to use a static CRLSP to establish the tunnel.
[RouterA-Tunnel0] mpls te signaling static
[RouterA-Tunnel0] quit
6. Create a static CRLSP:
# Configure Router A as the ingress node of the static CRLSP, and specify the next hop address as 2.1.1.2, outgoing label as 20, and bandwidth for the tunnel as 2000 kbps.
[RouterA] static-cr-lsp ingress static-cr-lsp-1 nexthop 2.1.1.2 out-label 20 bandwidth 2000
# On Router A, configure Tunnel 0 to use static CRLSP static-cr-lsp-1.
[RouterA] interface tunnel0
[RouterA-Tunnel0] mpls te static-cr-lsp static-cr-lsp-1
# Configure Router B as the transit node of the static CRLSP, and specify the incoming label as 20, next hop address as 3.2.1.2, outgoing label as 30, and bandwidth for the tunnel as 2000 kbps.
[RouterB] static-cr-lsp transit static-cr-lsp-1 in-label 20 nexthop 3.2.1.2 out-label 30 bandwidth 2000
# Configure Router C as the egress node of the static CRLSP, and specify the incoming label as 30.
[RouterC] static-cr-lsp egress static-cr-lsp-1 in-label 30
7. Configure a static route on Router A to direct traffic destined for subnet 100.1.2.0/24 to MPLS TE tunnel 0.
[RouterA] ip route-static 100.1.2.0 24 tunnel 0 preference 1
# Verify that the tunnel interface is up on Router A.
[RouterA] display interface tunnel
Tunnel0
Interface index: 13888
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum transmission unit: 1496
Internet address: 6.1.1.1/24 (primary)
Tunnel source unknown, destination 3.3.3.3
Tunnel TTL 255
# Display detailed information about the MPLS TE tunnel on Router A.
[RouterA] display mpls te tunnel-interface
Tunnel Name : Tunnel 0
Tunnel State : Up (Main CRLSP up)
Tunnel Attributes :
LSP ID : 1 Tunnel ID : 0
Admin State : Normal
Ingress LSR ID : 1.1.1.1 Egress LSR ID : 3.3.3.3
Signaling : Static Static CRLSP Name : static-cr-lsp-1
Static SRLSP Name : -
Resv Style : -
Tunnel mode : -
Reverse-LSP name : -
Class Type : - Tunnel Bandwidth : -
Reserved Bandwidth : -
Setup Priority : 0 Holding Priority : 0
Affinity Attr/Mask : -/-
Explicit Path : -
Backup Explicit Path : -
Metric Type : TE
Record Route : - Record Label : -
FRR Flag : - Bandwidth Protection : -
Backup Bandwidth Flag: - Backup Bandwidth Type: -
Backup Bandwidth : -
Bypass Tunnel : - Auto Created : -
Route Pinning : -
Retry Limit : 3 Retry Interval : 2 sec
Reoptimization : - Reoptimization Freq : -
Backup Type : - Backup LSP ID : -
Backup Restore Time : 10 sec
Auto Bandwidth : - Auto Bandwidth Freq : -
Collected Bandwidth : - Service-Class : -
Traffic Policy : Disable Reserved for binding : No
Path SetupType : -/-
Binding SID : - Binding SID State : -
Last Down Reason : Admin Down
Down Time : 2017-12-05 11:23:35:535
# Display static CRLSP information on each router.
[RouterA] display mpls lsp
FEC Proto In/Out Label Out Inter/NHLFE/LSINDEX
1.1.1.1/0/1 StaticCR -/20 XGE3/0/1
2.1.1.2 Local -/- XGE3/0/1
Tunnel0 Local -/- NHLFE1025
[RouterB] display mpls lsp
- StaticCR 20/30 XGE3/0/2
3.2.1.2 Local -/- XGE3/0/2
[RouterC] display mpls lsp
- StaticCR 30/- -
[RouterA] display mpls static-cr-lsp
Name LSR Type In/Out Label Out Interface State
static-cr-lsp-1 Ingress Null/20 XGE3/0/1 Up
[RouterB] display mpls static-cr-lsp
static-cr-lsp-1 Transit 20/30 XGE3/0/2 Up
[RouterC] display mpls static-cr-lsp
static-cr-lsp-1 Egress 30/Null - Up
# Execute the display ip routing-table command on Router A. The output shows a static route entry with interface Tunnel 0 as the output interface. (Details not shown.)
Example: Establishing an MPLS TE tunnel with RSVP-TE
Router A, Router B, Router C, and Router D run IS-IS and all of them are Level-2 routers.
Use RSVP-TE to establish an MPLS TE tunnel from Router A to Router D to transmit data between the two IP networks. The MPLS TE tunnel requires a bandwidth of 2000 kbps.
The maximum bandwidth of the link that the tunnel traverses is 10000 kbps and the maximum reservable bandwidth of the link is 5000 kbps.
Figure 10 Network diagram
IP address |
Device |
IP address |
Router A |
Loop0 |
1.1.1.9/32 |
Router C |
Loop0 |
3.3.3.9/32 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/1 |
30.1.1.1/24 |
XGE3/0/2 |
100.1.1.1/24 |
XGE3/0/2 |
20.1.1.2/24 |
Router B |
Loop0 |
2.2.2.9/32 |
Router D |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
10.1.1.2/24 |
XGE3/0/1 |
30.1.1.2/24 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/2 |
100.1.2.1/24 |
[RouterA] isis 1
[RouterA-Ten-GigabitEthernet3/0/1] isis circuit-level level-2
[RouterA-LoopBack0] isis circuit-level level-2
[RouterB] isis 1
[RouterB-Ten-GigabitEthernet3/0/1] isis circuit-level level-2
[RouterB-Ten-GigabitEthernet3/0/2] isis circuit-level level-2
[RouterB-LoopBack0] isis circuit-level level-2
[RouterC] isis 1
[RouterC-Ten-GigabitEthernet3/0/1] isis circuit-level level-2
[RouterC] interface ten-gigabitethernet 3/0/2
[RouterC-Ten-GigabitEthernet3/0/2] isis enable 1
[RouterC-Ten-GigabitEthernet3/0/2] isis circuit-level level-2
[RouterC-Ten-GigabitEthernet3/0/2] quit
[RouterC-LoopBack0] isis circuit-level level-2
# Configure Router D.
<RouterD> system-view
[RouterD] isis 1
[RouterD-isis-1] network-entity 00.0005.0000.0000.0004.00
[RouterD-isis-1] quit
[RouterD] interface ten-gigabitethernet 3/0/1
[RouterD-Ten-GigabitEthernet3/0/1] isis enable 1
[RouterD-Ten-GigabitEthernet3/0/1] isis circuit-level level-2
[RouterD-Ten-GigabitEthernet3/0/1] quit
[RouterD] interface loopback 0
[RouterD-LoopBack0] isis enable 1
[RouterD-LoopBack0] isis circuit-level level-2
[RouterD-LoopBack0] quit
3. Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE:
[RouterA] mpls lsr-id 1.1.1.9
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterA-Ten-GigabitEthernet3/0/1] rsvp enable
[RouterB] mpls lsr-id 2.2.2.9
[RouterB] mpls te
[RouterB-te] quit
[RouterB] rsvp
[RouterB-rsvp] quit
[RouterB-Ten-GigabitEthernet3/0/1] rsvp enable
[RouterB-Ten-GigabitEthernet3/0/2] rsvp enable
[RouterC] mpls lsr-id 3.3.3.9
[RouterC] mpls te
[RouterC-te] quit
[RouterC] rsvp
[RouterC-rsvp] quit
[RouterC-Ten-GigabitEthernet3/0/1] rsvp enable
[RouterC-Ten-GigabitEthernet3/0/2] mpls enable
[RouterC-Ten-GigabitEthernet3/0/2] mpls te enable
[RouterC-Ten-GigabitEthernet3/0/2] rsvp enable
[RouterD] mpls lsr-id 4.4.4.9
[RouterD] mpls te
[RouterD-te] quit
[RouterD] rsvp
[RouterD-rsvp] quit
[RouterD-Ten-GigabitEthernet3/0/1] mpls enable
[RouterD-Ten-GigabitEthernet3/0/1] mpls te enable
[RouterD-Ten-GigabitEthernet3/0/1] rsvp enable
4. Configure IS-IS TE:
[RouterA] isis 1
[RouterA-isis-1] cost-style wide
[RouterA-isis-1] mpls te enable level-2
[RouterB] isis 1
[RouterB-isis-1] cost-style wide
[RouterB-isis-1] mpls te enable level-2
[RouterC] isis 1
[RouterC-isis-1] cost-style wide
[RouterC-isis-1] mpls te enable level-2
[RouterD] isis 1
[RouterD-isis-1] cost-style wide
[RouterD-isis-1] mpls te enable level-2
5. Configure MPLS TE attributes of links:
[RouterC-Ten-GigabitEthernet3/0/2] mpls te max-link-bandwidth 10000
[RouterC-Ten-GigabitEthernet3/0/2] mpls te max-reservable-bandwidth 5000
# Set the maximum link bandwidth and maximum reservable bandwidth on Router D.
[RouterD-Ten-GigabitEthernet3/0/1] mpls te max-link-bandwidth 10000
[RouterD-Ten-GigabitEthernet3/0/1] mpls te max-reservable-bandwidth 5000
6. Configure an MPLS TE tunnel on Router A:
# Configure MPLS TE tunnel interface Tunnel 1.
[RouterA] interface tunnel 1 mode mpls-te
[RouterA-Tunnel1] ip address 7.1.1.1 255.255.255.0
# Specify the tunnel destination address as the LSR ID of Router D.
[RouterA-Tunnel1] destination 4.4.4.9
# Configure MPLS TE to use RSVP-TE to establish the tunnel.
[RouterA-Tunnel1] mpls te signaling rsvp-te
# Assign 2000 kbps bandwidth to the tunnel.
[RouterA-Tunnel1] mpls te bandwidth 2000
[RouterA-Tunnel1] quit
7. Configure a static route on Router A to direct the traffic destined for subnet 100.1.2.0/24 to MPLS TE tunnel 1.
[RouterA] ip route-static 100.1.2.0 24 tunnel 1 preference 1
Tunnel1
Current state: UP
Bandwidth: 64kbps
Internet address: 7.1.1.1/24 (primary)
Tunnel source unknown, destination 4.4.4.9
Tunnel TTL 255
Last 300 seconds input: 0 bytes/sec, 0 bits/sec, 0 packets/sec
Last 300 seconds output: 0 bytes/sec, 0 bits/sec, 0 packets/sec
Tunnel Name : Tunnel 1
Tunnel State : Up (Main CRLSP up, Shared-resource CRLSP down)
Tunnel Attributes :
LSP ID : 23331 Tunnel ID : 1
Ingress LSR ID : 1.1.1.9 Egress LSR ID : 4.4.4.9
Signaling : RSVP-TE Static CRLSP Name : -
Resv Style : SE
Tunnel mode : -
Class Type : CT0 Tunnel Bandwidth : 2000 kbps
Reserved Bandwidth : 2000 kbps
Setup Priority : 7 Holding Priority : 7
Affinity Attr/Mask : 0/0
Explicit Path : -
Metric Type : TE
Record Route : Disabled Record Label : Disabled
FRR Flag : Disabled Bandwidth Protection : Disabled
Backup Bandwidth Flag: Disabled Backup Bandwidth Type: -
Bypass Tunnel : No Auto Created : No
Route Pinning : Disabled
Reoptimization : Disabled Reoptimization Freq : -
Backup Type : None Backup LSP ID : -
Auto Bandwidth : Disabled Auto Bandwidth Freq : -
# Execute the display ip routing-table command on Router A. The output shows a static route entry with interface Tunnel 1 as the output interface. (Details not shown.)
Example: Establishing an inter-AS MPLS TE tunnel with RSVP-TE
Router A and Router B are in AS 100. Router C and Router D are in AS 200. AS 100 and AS 200 use OSPF as the IGP.
Establish an EBGP connection between ASBRs Router B and Router C. Redistribute BGP routes into OSPF and OSPF routes into BGP, so that AS 100 and AS 200 can reach each other.
Use RSVP-TE to establish an MPLS TE tunnel from Router A to Router D to transmit data between the two IP networks. The tunnel requires a bandwidth of 2000 kbps. The maximum bandwidth of the link that the tunnel traverses is 10000 kbps, and the maximum reservable bandwidth of the link is 5000 kbps.
Figure 11 Network diagram
Table 3 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop0 |
1.1.1.9/32 |
Router C |
Loop0 |
3.3.3.9/32 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/1 |
30.1.1.1/24 |
XGE3/0/2 |
100.1.1.0/24 |
XGE3/0/2 |
20.1.1.2/24 |
Router B |
Loop0 |
2.2.2.9/32 |
Router D |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
10.1.1.2/24 |
XGE3/0/1 |
30.1.1.2/24 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/2 |
100.1.2.0/24 |
2. Configure OSPF to advertise routes within the ASs, and redistribute the direct and BGP routes into OSPF on Router B and Router C:
[RouterA] ospf
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 1.1.1.9 0.0.0.0
[RouterA-ospf-1] quit
[RouterB] ospf
[RouterB-ospf-1] import-route direct
[RouterB-ospf-1] import-route bgp
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 2.2.2.9 0.0.0.0
[RouterB-ospf-1] quit
[RouterC] ospf
[RouterC-ospf-1] import-route direct
[RouterC-ospf-1] import-route bgp
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 3.3.3.9 0.0.0.0
[RouterC-ospf-1] quit
[RouterD] ospf
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 4.4.4.9 0.0.0.0
[RouterD-ospf-1-area-0.0.0.0] quit
[RouterD-ospf-1] quit
# Verify that the routers have learned the routes to one another, including the routes to the loopback interfaces. This example uses Router A.
Destinations : 6 Routes : 6
1.1.1.9/32 Direct 0 0 127.0.0.1 InLoop0
2.2.2.9/32 O_INTRA 10 1 10.1.1.2 XGE3/0/1
10.1.1.0/24 Direct 0 0 10.1.1.1 XGE3/0/1
10.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
3. Configure BGP on Router B and Router C to ensure that the ASs can communicate with each other:
[RouterB] bgp 100
[RouterB-bgp] peer 20.1.1.2 as-number 200
[RouterB-bgp] address-family ipv4 unicast
[RouterB-bgp-ipv4] peer 20.1.1.2 enable
[RouterB-bgp-ipv4] import-route ospf
[RouterB-bgp-ipv4] import-route direct
[RouterB-bgp-ipv4] quit
[RouterB-bgp] quit
[RouterC] bgp 200
[RouterC-bgp] peer 20.1.1.1 as-number 100
[RouterC-bgp] address-family ipv4 unicast
[RouterC-bgp-ipv4] peer 20.1.1.1 enable
[RouterC-bgp-ipv4] import-route ospf
[RouterC-bgp-ipv4] import-route direct
[RouterC-bgp-ipv4] quit
[RouterC-bgp] quit
# Verify that the routers have learned the AS-external routes. This example uses Router A.
Destinations : 10 Routes : 10
3.3.3.9/32 O_ASE 150 1 10.1.1.2 XGE3/0/1
4.4.4.9/32 O_ASE 150 1 10.1.1.2 XGE3/0/1
20.1.1.0/24 O_ASE 150 1 10.1.1.2 XGE3/0/1
30.1.1.0/24 O_ASE 150 1 10.1.1.2 XGE3/0/1
4. Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE:
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterB] mpls te
[RouterB-te] quit
[RouterB] rsvp
[RouterB-rsvp] quit
[RouterC] mpls te
[RouterC-te] quit
[RouterC] rsvp
[RouterC-rsvp] quit
[RouterD] mpls te
[RouterD-te] quit
[RouterD] rsvp
[RouterD-rsvp] quit
5. Configure OSPF TE:
[RouterA] ospf
[RouterA-ospf-1] opaque-capability enable
[RouterA-ospf-1-area-0.0.0.0] mpls te enable
[RouterB] ospf
[RouterB-ospf-1] opaque-capability enable
[RouterB-ospf-1-area-0.0.0.0] mpls te enable
[RouterC] ospf
[RouterC-ospf-1] opaque-capability enable
[RouterC-ospf-1-area-0.0.0.0] mpls te enable
[RouterD] ospf
[RouterD-ospf-1] opaque-capability enable
[RouterD-ospf-1-area-0.0.0.0] mpls te enable
6. Configure an explicit path on Router A. Specify Router B and Router D as loose nodes, and Router C as a strict node.
[RouterA] explicit-path atod
[RouterA-explicit-path-atod] nexthop 10.1.1.2 include loose
[RouterA-explicit-path-atod] nexthop 20.1.1.2 include strict
[RouterA-explicit-path-atod] nexthop 30.1.1.2 include loose
[RouterA-explicit-path-atod] quit
7. Configure MPLS TE attributes of links:
8. Configure an MPLS TE tunnel on Router A:
# Specify explicit path atod for the tunnel.
[RouterA-Tunnel1] mpls te path preference 5 explicit-path atod
9. Configure a static route on Router A to direct the traffic destined for subnet 100.1.2.0/24 to MPLS TE tunnel 1.
[RouterA] display interface tunnel 1
Tunnel1
Current state: UP
Bandwidth: 64kbps
Tunnel TTL 255
Tunnel Attributes :
LSP ID : 23549 Tunnel ID : 1
Resv Style : SE
Tunnel mode : -
Explicit Path : atod
Metric Type : TE
# Verify that Router A has a static route entry with interface Tunnel 1 as the output interface.
Destinations : 14 Routes : 14
7.1.1.0/24 Direct 0 0 7.1.1.1 Tun1
7.1.1.1/32 Direct 0 0 127.0.0.1 InLoop0
100.1.2.0/24 Static 1 0 0.0.0.0 Tun1
Example: Configuring bidirectional MPLS TE tunnel
Router A, Router B, Router C, and Router D all run IS-IS and they are all level-2 routers.
Use RSVP-TE to establish a bidirectional MPLS TE tunnel between Router A and Router D.
Figure 12 Network diagram
Table 4 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop0 |
1.1.1.9/32 |
Router C |
Loop0 |
3.3.3.9/32 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/1 |
30.1.1.1/24 |
XGE3/0/2 |
100.1.1.1/24 |
XGE3/0/2 |
20.1.1.2/24 |
Router B |
Loop0 |
2.2.2.9/32 |
Router D |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
10.1.1.2/24 |
XGE3/0/1 |
30.1.1.2/24 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/2 |
100.1.2.1/24 |
For more information, see "Example: Establishing an MPLS TE tunnel with RSVP-TE."
3. Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE on each router. Configure Router A and Router D to assign a non-null label to the penultimate hop:
[RouterA] mpls label advertise non-null
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterB] mpls te
[RouterB-te] quit
[RouterB] rsvp
[RouterB-rsvp] quit
[RouterC] mpls te
[RouterC-te] quit
[RouterC-] rsvp
[RouterC-rsvp] quit
[RouterD] mpls label advertise non-null
[RouterD] mpls te
[RouterD-te] quit
[RouterD] rsvp
[RouterD-rsvp] quit
[RouterA] isis 1
[RouterB] isis 1
[RouterC] isis 1
[RouterD] isis 1
5. Configure a co-routed bidirectional MPLS TE tunnel:
# Configure Router A as the active end of the co-routed bidirectional tunnel.
[RouterA-Tunnel1] mpls te resv-style ff
[RouterA-Tunnel1] mpls te bidirectional co-routed active
# Configure Router D as the passive end of the co-routed bidirectional tunnel.
[RouterD] interface tunnel 4 mode mpls-te
[RouterD-Tunnel4] ip address 8.1.1.1 255.255.255.0
[RouterD-Tunnel4] destination 1.1.1.9
[RouterD-Tunnel4] mpls te signaling rsvp-te
[RouterD-Tunnel4] mpls te resv-style ff
[RouterD-Tunnel4] mpls te bidirectional co-routed passive reverse-lsp lsr-id 1.1.1.9 tunnel-id 1
[RouterD-Tunnel4] quit
6. Creates static routes to direct the traffic to the MPLS TE tunnels.
# Create a static route on Router A to direct traffic destined for 100.1.2.0/24 to MPLS TE tunnel 1.
# Create a static route on Router D to direct traffic destined for 100.1.1.0/24 to MPLS TE tunnel 4.
[RouterD] ip route-static 100.1.1.0 24 tunnel 4 preference 1
Tunnel1
Current state: UP
Bandwidth: 64kbps
Tunnel TTL 255
Tunnel State : Up (Main CRLSP up, Reverse CRLSP up)
Tunnel Attributes :
LSP ID : 30478 Tunnel ID : 1
Resv Style : FF
Tunnel mode : Co-routed, active
Class Type : CT0 Tunnel Bandwidth : 0 kbps
Reserved Bandwidth : 0 kbps
Explicit Path : -
Metric Type : TE
# Display detailed information about the bidirectional MPLS TE tunnel on Router A.
[RouterA] display mpls lsp verbose
Destination : 4.4.4.9
FEC : 1.1.1.9/1/30478
Protocol : RSVP
LSR Type : Ingress
Service : -
NHLFE ID : 1027
State : Active
Out-Label : 1149
Nexthop : 10.1.1.2
Out-Interface: XGE3/0/1
Protocol : RSVP
LSR Type : Egress
Service : -
In-Label : 1151
State : Active
Nexthop : 127.0.0.1
Out-Interface: -
Destination : 10.1.1.2
FEC : 10.1.1.2
Protocol : Local
LSR Type : Ingress
Service : -
NHLFE ID : 1026
State : Active
Nexthop : 10.1.1.2
FEC : Tunnel1
Protocol : Local
LSR Type : Ingress
Service : -
NHLFE ID : 268435457
State : Active
Out-Interface: NHLFE74
# Verify that the tunnel interface is up on Router D.
[RouterD] display interface tunnel
Tunnel4
Current state: UP
Description: Tunnel4 Interface
Bandwidth: 64kbps
Internet address: 8.1.1.1/24 (primary)
Tunnel source unknown, destination 1.1.1.9
Tunnel TTL 255
# Display detailed information about the MPLS TE tunnel on Router D.
[RouterD] display mpls te tunnel-interface
Tunnel Name : Tunnel 4
Tunnel Attributes :
LSP ID : - Tunnel ID : 4
Ingress LSR ID : - Egress LSR ID : -
Resv Style : FF
Tunnel mode : Co-routed, passive
Reverse-LSP LSR ID : 1.1.1.9 Reverse-LSP Tunnel ID: 1
Setup Priority : - Holding Priority : -
Explicit Path : -
Metric Type : -
Route Pinning : -
Retry Limit : - Retry Interval : -
# Display detailed information about the bidirectional MPLS TE tunnel on Router D.
[RouterD] display mpls lsp verbose
Protocol : RSVP
LSR Type : Egress
Service : -
In-Label : 3
State : Active
Nexthop : 127.0.0.1
Out-Interface: -
Protocol : RSVP
LSR Type : Ingress
Service : -
NHLFE ID : 1025
State : Active
Out-Label : 1150
Nexthop : 30.1.1.1
Destination : 30.1.1.1
FEC : 30.1.1.1
Protocol : Local
LSR Type : Ingress
Service : -
NHLFE ID : 1024
State : Active
Nexthop : 30.1.1.1
Destination : 1.1.1.9
FEC : Tunnel1
Protocol : Local
LSR Type : Ingress
Service : -
State : Active
Example: Configuring CRLSP backup
Router A, Router B, Router C, and Router D run IS-IS and IS-IS TE.
Use RSVP-TE to establish an MPLS TE tunnel from Router A to Router C to transmit data between the two IP networks. Enable CRLSP hot-standby backup for the tunnel to simultaneously establish a primary CRLSP and a backup CRLSP. When the primary CRLSP fails, traffic is switched to the backup CRLSP.
Figure 13 Network diagram
Table 5 Interface and IP address assignment
IP address |
Device |
IP address |
Router A |
Loop0 |
1.1.1.9/32 |
Router D |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/1 |
30.1.1.2/24 |
XGE3/0/2 |
100.1.1.1/24 |
XGE3/0/2 |
40.1.1.1/24 |
XGE3/0/3 |
30.1.1.1/24 |
Router C |
Loop0 |
3.3.3.9/32 |
Router B |
Loop0 |
2.2.2.9/32 |
XGE3/0/1 |
20.1.1.2/24 |
XGE3/0/1 |
10.1.1.2/24 |
XGE3/0/2 |
100.1.2.1/24 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/3 |
40.1.1.2/24 |
2. Configure IS-IS to advertise interface addresses, including the loopback interface address, and configure IS-IS TE. (Details not shown.)
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterA] interface ten-gigabitethernet 3/0/3
[RouterA-Ten-GigabitEthernet3/0/3] mpls enable
[RouterA-Ten-GigabitEthernet3/0/3] mpls te enable
[RouterA-Ten-GigabitEthernet3/0/3] rsvp enable
[RouterA-Ten-GigabitEthernet3/0/3] quit
# Configure Router B, Router C, and Router D in the same way that Router A is configured. (Details not shown.)
4. Configure an MPLS TE tunnel on Router A:
# Configure MPLS TE tunnel interface Tunnel 3.
[RouterA] interface tunnel 3 mode mpls-te
[RouterA-Tunnel3] ip address 9.1.1.1 255.255.255.0
[RouterA-Tunnel3] destination 3.3.3.9
[RouterA-Tunnel3] mpls te signaling rsvp-te
# Enable CRLSP hot-standby backup for the tunnel.
[RouterA-Tunnel3] mpls te backup hot-standby
[RouterA-Tunnel3] quit
5. Configure a static route on Router A to direct the traffic destined for subnet 100.1.2.0/24 to MPLS TE tunnel 3.
[RouterA] ip route-static 100.1.2.0 24 tunnel 3 preference 1
# Verify that the tunnel interface Tunnel 3 is up on Router A.
Tunnel3
Current state: UP
Description: Tunnel3 Interface
Bandwidth: 64kbps
Internet address: 9.1.1.1/24 (primary)
Tunnel source unknown, destination 3.3.3.9
Tunnel TTL 255
# Verify that two CRLSPs exist on Router A, one with the output interface Ten-GigabitEthernet 3/0/1 and the other with the output interface Ten-GigabitEthernet 3/0/3.
1.1.1.9/3/34311 RSVP -/1150 XGE3/0/1
1.1.1.9/3/34312 RSVP -/1151 XGE3/0/3
10.1.1.2 Local -/- XGE3/0/1
30.1.1.2 Local -/- XGE3/0/3
Tunnel3 Local -/- NHLFE1026
Backup -/- NHLFE1028
# Display the paths used by the two CRLSPs on Router A.
[RouterA] display rsvp lsp verbose
Tunnel name: RouterA_t3
Destination: 3.3.3.9 Source: 1.1.1.9
Tunnel ID: 3 LSP ID: 30106
LSR type: Ingress Direction: Unidirectional
Setup priority: 7 Holding priority: 7
In-Label: - Out-Label: 1137
In-Interface: - Out-Interface: XGE3/0/1
Nexthop: 10.1.1.2 Exclude-any: 0
Include-Any: 0 Include-all: 0
Mean rate (CIR): 0 kbps Mean burst size (CBS): 1000.00 bytes
Path MTU: 1500 Class type: CT0
RRO number: 6
10.1.1.1/32 Flag: 0x00 (No FRR)
10.1.1.2/32 Flag: 0x00 (No FRR/In-Int)
2.2.2.9/32 Flag: 0x20 (No FRR/Node-ID)
20.1.1.1/32 Flag: 0x00 (No FRR)
20.1.1.2/32 Flag: 0x00 (No FRR/In-Int)
3.3.3.9/32 Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: None
Tunnel ID: 3 LSP ID: 30107
In-Label: - Out-Label: 1150
In-Interface: - Out-Interface: XGE3/0/3
Nexthop: 30.1.1.2 Exclude-any: 0
RRO number: 6
30.1.1.1/32 Flag: 0x00 (No FRR)
30.1.1.2/32 Flag: 0x00 (No FRR/In-Int)
4.4.4.9/32 Flag: 0x20 (No FRR/Node-ID)
40.1.1.1/32 Flag: 0x00 (No FRR)
40.1.1.2/32 Flag: 0x00 (No FRR/In-Int)
# Trace the path that MPLS TE tunnel 3 traverses. The output shows that the used CRLSP is the one that traverses Router B.
[RouterA] tracert mpls te tunnel 3
MPLS trace route TE tunnel Tunnel3
TTL Replier Time Type Downstream
0 Ingress 10.1.1.2/[1147]
1 10.1.1.2 1 ms Transit 20.1.1.2/[3]
2 20.1.1.2 2 ms Egress
# Shut down interface Ten-GigabitEthernet 3/0/2 on Router B, and then tracert tunnel 3. The output shows that packets are forwarded on the CRLSP that traverses Router D.
0 Ingress 30.1.1.2/[1148]
1 30.1.1.2 2 ms Transit 40.1.1.2/[3]
2 40.1.1.2 3 ms Egress
# Verify that only one CRLSP exists on Router A.
1.1.1.9/3/34313 RSVP -/1150 XGE3/0/3
Tunnel3 Local -/- NHLFE1029
# Execute the display ip routing-table command on Router A. The output shows a static route entry with interface Tunnel 3 as the output interface. (Details not shown.)
Example: Configuring manual bypass tunnel for FRR
On the primary CRLSP Router A—Router B—Router C—Router D, use FRR to protect the link Router B—Router C.
Use RSVP-TE to establish the primary CRLSP and bypass tunnel based on the constraints of the explicit paths to transmit data between the two IP networks. The bypass tunnel uses path Router B—Router E—Router C. Router B is the PLR and Router C is the MP.
Configure BFD for RSVP-TE between Router B and Router C. When the link between Router B and Router C fails, BFD can detect the failure quickly and notify RSVP-TE of the failure, so RSVP-TE can switch traffic to the bypass tunnel.
Figure 14 Network diagram
IP address |
Device |
IP address |
Router A |
Loop0 |
1.1.1.1/32 |
Router B |
Loop0 |
2.2.2.2/32 |
XGE3/0/1 |
2.1.1.1/24 |
XGE3/0/1 |
2.1.1.2/24 |
XGE3/0/2 |
100.1.1.1/24 |
XGE3/0/2 |
3.1.1.1/24 |
Router D |
Loop0 |
4.4.4.4/32 |
XGE3/0/4 |
3.2.1.1/24 |
XGE3/0/1 |
4.1.1.2/24 |
Router C |
Loop0 |
3.3.3.3/32 |
XGE3/0/2 |
100.1.2.1/24 |
XGE3/0/1 |
4.1.1.1/24 |
Router E |
Loop0 |
5.5.5.5/32 |
XGE3/0/2 |
3.1.1.2/24 |
XGE3/0/3 |
3.3.1.1/24 |
XGE3/0/4 |
3.3.1.2/24 |
XGE3/0/4 |
3.2.1.2/24 |
2. Configure IS-IS to advertise interface addresses, including the loopback interface address. (Details not shown.)
3. Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE on each router. Enable BFD for RSVP-TE on Router B and Router C:
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterB] mpls te
[RouterB-te] quit
[RouterB] rsvp
[RouterB-rsvp] quit
[RouterB-Ten-GigabitEthernet3/0/2] rsvp bfd enable
[RouterB] interface ten-gigabitethernet 3/0/4
[RouterB-Ten-GigabitEthernet3/0/4] mpls enable
[RouterB-Ten-GigabitEthernet3/0/4] mpls te enable
[RouterB-Ten-GigabitEthernet3/0/4] rsvp enable
[RouterB-Ten-GigabitEthernet3/0/4] quit
# Configure Router C in the same way that Router B is configured. Configure Router D and Router E in the same way that Router A is configured. (Details not shown.)
4. Configure an MPLS TE tunnel on Router A, the ingress node of the primary CRLSP:
# Configure an explicit path for the primary CRLSP.
[RouterA] explicit-path pri-path
[RouterA-explicit-path-pri-path] nexthop 2.1.1.2
[RouterA-explicit-path-pri-path] nexthop 3.1.1.2
[RouterA-explicit-path-pri-path] nexthop 4.1.1.2
[RouterA-explicit-path-pri-path] nexthop 4.4.4.4
[RouterA-explicit-path-pri-path] quit
# Create MPLS TE tunnel interface Tunnel 4 for the primary CRLSP.
[RouterA] interface tunnel 4 mode mpls-te
[RouterA-Tunnel4] ip address 10.1.1.1 255.255.255.0
[RouterA-Tunnel4] destination 4.4.4.4
# Specify the tunnel signaling protocol as RSVP-TE.
[RouterA-Tunnel4] mpls te signaling rsvp-te
# Specify the explicit path as pri-path.
[RouterA-Tunnel4] mpls te path preference 1 explicit-path pri-path
# Enable FRR for the MPLS TE tunnel.
[RouterA-Tunnel4] mpls te fast-reroute
[RouterA-Tunnel4] quit
# Verify that the tunnel interface Tunnel 4 is up on Router A.
Tunnel4
Current state: UP
Bandwidth: 64kbps
Tunnel source unknown, destination 4.4.4.4
Tunnel TTL 255
Last 300 seconds output rate: 1911 bytes/sec, 15288 bits/sec, 0 packets/sec
Output: 1526 packets, 22356852 bytes, 0 drops
Tunnel Attributes :
LSP ID : 48960 Tunnel ID : 4
Resv Style : SE
Tunnel mode : -
Explicit Path : pri-path
Metric Type : TE
Record Route : Enabled Record Label : Enabled
FRR Flag : Enabled Bandwidth Protection : Disabled
5. Configure a bypass tunnel on Router B (the PLR):
# Configure an explicit path for the bypass tunnel.
[RouterB] explicit-path by-path
[RouterB-explicit-path-by-path] nexthop 3.2.1.2
[RouterB-explicit-path-by-path] nexthop 3.3.1.2
[RouterB-explicit-path-by-path] nexthop 3.3.3.3
[RouterB-explicit-path-by-path] quit
# Create MPLS TE tunnel interface Tunnel 5 for the bypass tunnel.
[RouterB] interface tunnel 5 mode mpls-te
[RouterB-Tunnel5] ip address 11.1.1.1 255.255.255.0
# Specify the tunnel destination address as LSR ID of Router C.
[RouterB-Tunnel5] destination 3.3.3.3
[RouterB-Tunnel5] mpls te signaling rsvp-te
# Specify the explicit path to be used as by-path.
[RouterB-Tunnel5] mpls te path preference 1 explicit-path by-path
# Set the bandwidth that the bypass tunnel can protect.
[RouterB-Tunnel5] mpls te backup bandwidth un-limited
[RouterB-Tunnel5] quit
# Bind the bypass tunnel to the protected interface.
[RouterB-Ten-GigabitEthernet3/0/2] mpls te fast-reroute bypass-tunnel tunnel 5
# Execute the display interface tunnel command on Router B. The output shows that the tunnel interface Tunnel 5 is up. (Details not shown.)
6. Configure a static route on Router A to direct the traffic destined for subnet 100.1.2.0/24 to MPLS TE tunnel 4.
[RouterA] ip route-static 100.1.2.0 24 tunnel 4 preference 1
# Display LSP entries on each router to verify that Router B and Router C each have two CRLSPs and the bypass tunnel backs up the primary CRLSP.
1.1.1.1/4/48960 RSVP -/1245 XGE3/0/1
1.1.1.1/4/48960 RSVP 1245/3 XGE3/0/2
Backup 1245/3 Tun5
2.2.2.2/5/31857 RSVP -/3 XGE3/0/2
3.2.1.2 Local -/- XGE3/0/4
3.1.1.2 Local -/- XGE3/0/2
# Shut down the protected interface Ten-GigabitEthernet 3/0/2 on the PLR (Router B).
[RouterB-Ten-GigabitEthernet3/0/2] shutdown
# Execute the display interface tunnel 4 command on Router A to display information about the primary CRLSP. The output shows that the tunnel interface is still up. (Details not shown.)
# Display detailed information about the tunnel interface on Router A.
Tunnel State : Up (Main CRLSP up, Shared-resource CRLSP being set up)
Tunnel Attributes :
LSP ID : 18753 Tunnel ID : 4
Resv Style : SE
Tunnel mode : -
Metric Type : TE
NOTE: If you execute the display mpls te tunnel-interface command immediately after an FRR, you can see two CRLSPs in up state. This is because FRR uses the make-before-break mechanism to set up a new LSP, and the old LSP is deleted after the new one has been established for a while. |
# Verify that the bypass tunnel is in use on Router B.
1.1.1.1/4/18753 RSVP 1122/3 Tun5
2.2.2.2/5/40312 RSVP -/1150 XGE3/0/4
# On the PLR, set the interval for selecting an optimal bypass tunnel to 5 seconds.
[RouterB] mpls te
[RouterB-te] fast-reroute timer 5
[RouterB-te] quit
# On the PLR, bring up the protected interface Ten-GigabitEthernet 3/0/2.
[RouterB-Ten-GigabitEthernet3/0/2] undo shutdown
# Execute the display interface tunnel 4 command on Router A to display information about the primary CRLSP. The output shows that the tunnel interface is in up state. (Details not shown.)
# Wait for about 5 seconds, execute the display mpls lsp verbose command on Router B. The output shows that Tunnel 5 is bound to interface Ten-GigabitEthernet 3/0/2 but not in use. (Details not shown.)
# Execute the display ip routing-table command on Router A. The output shows a static route entry with interface Tunnel 4 as the output interface. (Details not shown.)
Example: Configuring auto FRR
Use RSVP-TE to set up a primary CRLSP that explicitly uses path Router A—Router B—Router C—Router D.
Configure auto FRR on Router B to automatically set up bypass tunnels for the primary CRLSP.
Figure 15 Network diagram
Table 7 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop0 |
1.1.1.1/32 |
Router E |
Loop0 |
5.5.5.5/32 |
XGE3/0/1 |
2.1.1.1/24 |
XGE3/0/3 |
3.2.1.2/24 |
Router B |
Loop0 |
2.2.2.2/32 |
XGE3/0/4 |
3.4.1.1/24 |
XGE3/0/1 |
2.1.1.2/24 |
Router C |
Loop0 |
3.3.3.3/32 |
XGE3/0/2 |
3.1.1.1/24 |
XGE3/0/1 |
4.1.1.1/24 |
XGE3/0/3 |
3.2.1.1/24 |
XGE3/0/2 |
3.1.1.2/24 |
XGE3/0/4 |
3.3.1.1/24 |
XGE3/0/3 |
3.4.1.2/24 |
Router D |
Loop0 |
4.4.4.4/32 |
Router F |
Loop0 |
6.6.6.6/32 |
XGE3/0/1 |
4.1.1.2/24 |
XGE3/0/3 |
3.3.1.2/24 |
XGE3/0/3 |
4.2.1.2/24 |
XGE3/0/4 |
4.2.1.1/24 |
[RouterA] isis 1
[RouterA-isis-1] network-entity 10.0000.0000.0001.00
[RouterA] isis 1
[RouterC] isis 1
[RouterC-isis-1] network-entity 10.0000.0000.0003.00
[RouterC] interface 错误!未提供文档变量。
[RouterC-错误!未提供文档变量。] isis enable 1
[RouterC-错误!未提供文档变量。] isis circuit-level level-2
[RouterC-错误!未提供文档变量。] quit
[RouterD] isis 1
[RouterD-isis-1] network-entity 10.0000.0000.0004.00
[RouterD] interface 错误!未提供文档变量。
[RouterD-错误!未提供文档变量。] isis enable 1
[RouterD-错误!未提供文档变量。] isis circuit-level level-2
[RouterD-错误!未提供文档变量。] quit
# Configure Router E.
<RouterE> system-view
[RouterE] isis 1
[RouterE-isis-1] network-entity 10.0000.0000.0005.00
[RouterE] interface 错误!未提供文档变量。
[RouterE-错误!未提供文档变量。] isis enable 1
[RouterE-错误!未提供文档变量。] isis circuit-level level-2
[RouterE-错误!未提供文档变量。] quit
[RouterE] interface loopback 0
[RouterE-LoopBack0] isis enable 1
[RouterE-LoopBack0] isis circuit-level level-2
[RouterE-LoopBack0] quit
# Configure Router F.
<RouterF> system-view
[RouterF] isis 1
[RouterF-isis-1] network-entity 10.0000.0000.0006.00
[RouterF] interface 错误!未提供文档变量。
[RouterF-错误!未提供文档变量。] isis enable 1
[RouterF-错误!未提供文档变量。] isis circuit-level level-2
[RouterF-错误!未提供文档变量。] quit
[RouterF] interface loopback 0
[RouterF-LoopBack0] isis enable 1
[RouterF-LoopBack0] isis circuit-level level-2
[RouterF-LoopBack0] quit
# Execute the display ip routing-table command on each device. Verify that they have learned routes to each other, including the host routes to the Loopback interfaces on the remote devices.
4. Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE on each router. Enable BFD for RSVP-TE on Router B and Router C:
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterB] mpls te
[RouterB-te] quit
[RouterB] rsvp
[RouterB-rsvp] quit
[RouterB] interface ten-gigabitethernet 3/0/3
[RouterB-Ten-GigabitEthernet3/0/3] mpls enable
[RouterB-Ten-GigabitEthernet3/0/3] mpls te enable
[RouterB-Ten-GigabitEthernet3/0/3] rsvp enable
[RouterB-Ten-GigabitEthernet3/0/3] quit
# Configure Router C in the same way that Router B is configured. Configure Router D, Router E, and Router F in the same way that Router A is configured. (Details not shown.)
5. Configure IS-IS TE:
[RouterA] isis 1
[RouterB] isis 1
[RouterC] isis 1
[RouterD] isis 1
[RouterE] isis 1
[RouterE-isis-1] cost-style wide
[RouterE-isis-1] mpls te enable level-2
[RouterE-isis-1] quit
[RouterF] isis 1
[RouterF-isis-1] cost-style wide
[RouterF-isis-1] mpls te enable level-2
[RouterF-isis-1] quit
6. Configure an MPLS TE tunnel on Router A, the ingress node of the primary CRLSP:
# Configure an explicit path named pri-path for the primary CRLSP.
# Create MPLS TE tunnel interface Tunnel 1 for the primary CRLSP.
[RouterA-Tunnel1] ip address 10.1.1.1 255.255.255.0
[RouterA-Tunnel1] destination 4.4.4.4
[RouterA-Tunnel1] mpls te path preference 1 explicit-path pri-path
[RouterA-Tunnel1] mpls te fast-reroute
# Verify that the MPLS TE interface Tunnel 1 is up on Router A.
Tunnel1
Current state: UP
Bandwidth: 64kbps
Tunnel TTL 255
# Display detailed information about the MPLS TE tunnel interface on Router A.
Tunnel Signalled Name : tunnel1
Tunnel State : Up (Main CRLSP up. Shared-resource CRLSP down)
Tunnel Attributes :
LSP ID : 12846 Tunnel ID : 1
Ingress LSR ID : 1.1.1.1 Egress LSR ID : 4.4.4.4
Resv Style : SE
Tunnel mode : -
Reverse-LSP BSID : -
Metric Type : TE
Backup Restore Time : -
Traffic Policy : - Reserved for binding : No
Path Setup Type : -/-
Binding SID : - Binding SID Status : -
Attribute Prefer : LOCAL/-
Last Down Reason : Signal error
Down Time : 2025-02-14 14:54:46:274
7. Configure auto FRR on Router B (the PLR):
# Enable the automatic bypass tunnel setup feature globally.
[RouterB] mpls te
[RouterB-te] auto-tunnel backup
# Specify interface numbers 50 to 100 for the automatically created bypass tunnels.
[RouterB-te-auto-bk] tunnel-number min 50 max 100
[RouterB-te-auto-bk] quit
# Verify that two tunnels have been created automatically on Router B.
[RouterB] display interface tunnel brief
Protocol: (s) - spoofing
Tun50 UP DOWN --
Tun51 UP DOWN --
# Display information about Tunnel 50 and Tunnel 51 on Router B. The output shows that Tunnel 50 and Tunnel 51 are automatically created bypass tunnels. Tunnel 50 is a node-protection bypass tunnel (egress LSR ID is 4.4.4.4, the LSR ID of Router D). Tunnel 51 is a link-protection bypass tunnel (egress LSR ID is 3.3.3.3, the LSR ID of Router C).
[RouterB] display mpls te tunnel-interface tunnel 50
Tunnel Name : Tunnel 50
Tunnel Signalled Name : tunnel50
Tunnel Attributes :
LSP ID : 10249 Tunnel ID : 50
Ingress LSR ID : 2.2.2.2 Egress LSR ID : 4.4.4.4
Resv Style : SE
Tunnel mode : -
Explicit Path : -
Metric Type : TE
Record Route : Enabled Record Label : Disabled
Bypass Tunnel : Yes Auto Created : Yes
Last Down Reason : Configuration change
Down Time : 2025-02-14 14:52:30:826
[RouterB] display mpls te tunnel-interface tunnel 51
Tunnel Name : Tunnel 51
Tunnel Signalled Name : tunnel51
Tunnel Attributes :
LSP ID : 10249 Tunnel ID : 51
Ingress LSR ID : 2.2.2.2 Egress LSR ID : 3.3.3.3
Resv Style : SE
Tunnel mode : -
Explicit Path : -
Metric Type : TE
Down Time : 2025-02-14 16:11:09:375
# Verify that the current bypass tunnel that protects the primary CRLSP is Tunnel 50.
1.1.1.1/1/12846 RSVP 1144/1148 XGE3/0/2
Backup 1144/3 Tun50
2.2.2.2/50/10249 RSVP -/1151 错误!未提供文档变量。
2.2.2.2/51/10249 RSVP -/1150 错误!未提供文档变量。
3.1.1.2 Local -/- 错误!未提供文档变量。
3.2.1.2 Local -/- 错误!未提供文档变量。
3.3.1.2 Local -/- 错误!未提供文档变量。
Tunnel50 Local -/- NHLFE1
Tunnel51 Local -/- NHLFE9
# Display detailed information about MPLS TE tunnel 1 (the tunnel for the primary CRLSP) on Router B. The output shows that Tunnel1 is protected by the bypass tunnel Tunnel50, and the protected node is 3.1.1.1.
[RouterB] display rsvp lsp tunnel-id 1 verbose
Tunnel name: tunnel1
Destination: 4.4.4.4 Source: 1.1.1.1
Tunnel ID: 1 LSP ID: 12846
LSR type: Transit Type: Unidirectional
In-Label: 1144 Out-Label: 1148
In-Interface: 错误!未提供文档变量。 Out-Interface: XGE3/0/2
Nexthop: 3.1.1.2 Exclude-any: 0
RRO number: 15
2.1.1.1/32 Flag: 0x00 (No FRR)
2.1.1.2/32 Flag: 0x40 (No FRR/In-Int)
1144 Flag: 0x01 (Global label)
2.2.2.2/32 Flag: 0x29 (FRR Avail/Node-Prot/Node-ID)
3.1.1.1/32 Flag: 0x09 (FRR Avail/Node-Prot)
3.1.1.2/32 Flag: 0x40 (No FRR/In-Int)
1148 Flag: 0x01 (Global label)
3.3.3.3/32 Flag: 0x20 (No FRR/Node-ID)
4.1.1.1/32 Flag: 0x00 (No FRR)
4.1.1.2/32 Flag: 0x40 (No FRR/In-Int)
3 Flag: 0x01 (Global label)
4.4.4.4/32 Flag: 0x20 (No FRR/Node-ID)
Fast Reroute protection: Ready (Facility)
FRR inner label: 3 Bypass tunnel: Tunnel50
# Shut down interface 错误!未提供文档变量。 on Router C. On Router A, verify that interface Tunnel1 remains up and the tunnel destination 4.4.4.4 can be pinged. On Router B, execute the display mpls lsp command to verify that traffic has been rerouted to Tunnel 50 (the bypass tunnel).
1.1.1.1/1/12846 RSVP 1144/3 Tun50
# On Router B, execute the display interface tunnel brief command. The command output shows that the protocol state of the bypass tunnel is down. This is normal. No action is required.
Tun50 UP DOWN --
Tun51 UP DOWN --
Example: Configuring CBTS
As shown in Figure 16, all routers run IS-IS.
Use RSVP-TE to establish the following MPLS TE tunnels between Router A and Router E:
· Router A—Router B—Router E.
· Router A—Router C—Router E.
· Router A—Router D—Router E.
Assign the MPLS TE tunnels different service class values for different classes of services.
Table 8 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop0 |
1.1.1.1/32 |
Router D |
Loop0 |
4.4.4.4/32 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/1 |
30.1.1.2/24 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/2 |
40.1.1.1/24 |
XGE3/0/3 |
30.1.1.1/24 |
Router E |
Loop0 |
5.5.5.5/32 |
XGE3/0/4 |
100.1.1.1/24 |
XGE3/0/1 |
100.1.1.2/24 |
Router B |
Loop0 |
2.2.2.2/32 |
XGE3/0/2 |
200.1.1.2/24 |
XGE3/0/1 |
10.1.1.2/24 |
XGE3/0/3 |
40.1.1.1.2/24 |
XGE3/0/2 |
100.1.1.1/24 |
Router C |
Loop0 |
3.3.3.3/32 |
XGE3/0/1 |
20.1.1.2/24 |
XGE3/0/2 |
200.1.1.1/24 |
1. Configure IP addresses and masks for interfaces, including the loopback interfaces, as shown in Figure 16. (Details not shown.)
2. Configure IS-IS to advertise interface addresses including loopback interface addresses, and configure IS-IS TE. (Details not shown.)
3. Configure an LSR ID, and enable MPLS, MPLS TE, and RSVP-TE on each router. (Details not shown.)
4. Use RSVP-TE to establish three MPLS TE tunnels: Tunnel 1, Tunnel 2, and Tunnel 3. Tunnel 1 uses path Router A—Router B—Router E. Tunnel 2 uses path Router A—Router C—Router E. Tunnel 3 uses path Router A—Router D—Router E. (Details not shown.)
5. Configure a QoS policy on Router A.
# Create a traffic class.
[RouterA] traffic classifier class
[RouterA-classifier-class] if-match any
[RouterA-classifier-class] quit
# Create a traffic behavior.
[RouterA] traffic behavior behave
[RouterA-behavior-behave] remark service-class 3
[RouterA-behavior-behave] quit
# Create a QoS policy.
[RouterA] qos policy policy
[RouterA-qospolicy-policy] classifier class behavior behave
[RouterA-qospolicy-policy] quit
# Apply the QoS policy to GigabitEthernet 1/0/4.
[RouterA] interface ten-gigabitethernet 3/0/4
[RouterA-Ten-GigabitEthernet3/0/4] qos apply policy policy inbound
[RouterA-Ten-GigabitEthernet3/0/4] quit
6. Set the service class values for the MPLS TE tunnels.
# Set the service class value to 3 for Tunnel 2.
[RouterA]interface Tunnel 2 mode mpls-te
[RouterA-Tunnel2] mpls te service-class 3
[RouterA-Tunnel2] quit
# Set the service class value to 6 for Tunnel 3.
[RouterA]interface Tunnel 3 mode mpls-te
[RouterA-Tunnel3] mpls te service-class 6
# Display information about Tunnel 1 on Router A.
[RouterA] display mpls te tunnel-interface Tunnel 1
Tunnel Attributes :
LSP ID : 17419 Tunnel ID : 1
Ingress LSR ID : 10.1.1.1 Egress LSR ID : 40.1.1.1
Resv Style : -
Tunnel mode : -
Explicit Path : -
Metric Type : TE
Route Pinning : -
The Service-Class field has no value, indicating that no service class value is set for Tunnel 1.
# Display information about Tunnel 2 and Tunnel 3 on Router A.
[RouterA]display mpls te tunnel-interface Tunnel 2
Tunnel Name : Tunnel 2
Tunnel Attributes :
LSP ID : 17418 Tunnel ID : 2
Resv Style : -
Tunnel mode : -
Explicit Path : -
Metric Type : TE
Route Pinning : -
Collected Bandwidth : - Service-Class : 3
[RouterA]display mpls te tunnel-interface Tunnel 3
Tunnel Name : Tunnel 3
Tunnel Attributes :
LSP ID : 17418 Tunnel ID : 3
Resv Style : -
Tunnel mode : -
Explicit Path : -
Metric Type : TE
Route Pinning : -
Collected Bandwidth : - Service-Class : 6
The Service-Class fields show that the service class values of Tunnel 2 and Tunnel 3 are 3 and 6, respectively. According to the QoS policy, traffic arrives at Ten-GigabitEthernet 3/0/4 of Router A is assigned service class value 3. So CBTS uses Tunnel 2 to forward the traffic.
Example: Configuring bit error detection for an MPLS TE tunnel
Use RSVP-TE to establish a bidirectional MPLS TE tunnel between Router A and Router C.
Enable CRLSP hot-standby backup for the tunnel to simultaneously establish the primary and backup CRLSPs. Configure bit error detection for the tunnel, so when the primary CRLSP fails because of bit errors, traffic is switched to the backup CRLSP.
Figure 17 Network diagram
Table 9 Interface and IP address assignment
Device |
IP address |
Device |
IP address |
Router A |
Loop0 |
1.1.1.9/32 |
Router D |
Loop0 |
4.4.4.9/32 |
XGE3/0/1 |
10.1.1.1/24 |
XGE3/0/1 |
30.1.1.2/24 |
XGE3/0/2 |
100.1.1.1/24 |
XGE3/0/2 |
40.1.1.1/24 |
XGE3/0/3 |
30.1.1.1/24 |
Router C |
Loop0 |
3.3.3.9/32 |
Router B |
Loop0 |
2.2.2.9/32 |
XGE3/0/1 |
20.1.1.2/24 |
XGE3/0/1 |
10.1.1.2/24 |
XGE3/0/2 |
100.1.2.1/24 |
XGE3/0/2 |
20.1.1.1/24 |
XGE3/0/3 |
40.1.1.2/24 |
2. Configure IS-IS to advertise the interface addresses, including loopback interface addresses:
[RouterA] isis 1
[RouterB] isis 1
[RouterC] isis 1
[RouterD] isis 1
3. Configure LSR IDs, and enable MPLS, MPLS TE, and RSVP-TE on each router. Configure Router A and Router C to assign non-null labels to the penultimate hop:
[RouterA] mpls te
[RouterA-te] quit
[RouterA] rsvp
[RouterA-rsvp] quit
[RouterB] mpls te
[RouterB-te] quit
[RouterB] rsvp
[RouterB-rsvp] quit
[RouterC] mpls label advertise non-null
[RouterC] mpls te
[RouterC-te] quit
[RouterC-] rsvp
[RouterC-rsvp] quit
[RouterD] mpls te
[RouterD-te] quit
[RouterD] rsvp
[RouterD-rsvp] quit
[RouterA] isis 1
[RouterB] isis 1
[RouterC] isis 1
[RouterD] isis 1
5. Configure a bidirectional MPLS TE tunnel:
# Configure an associated bidirectional MPLS TE tunnel on Router A.
[RouterA-Tunnel1] destination 3.3.3.9
[RouterA-Tunnel1] mpls te bidirectional associated reverse-lsp lsr-id 3.3.3.9 tunnel-id 1
# Configure an associated bidirectional MPLS TE tunnel on Router C.
[RouterC] interface tunnel 1 mode mpls-te
[RouterC-Tunnel1] ip address 8.1.1.1 255.255.255.0
[RouterC-Tunnel1] destination 1.1.1.9
[RouterC-Tunnel1] mpls te signaling rsvp-te
[RouterC-Tunnel1] mpls te resv-style ff
[RouterC-Tunnel1] mpls te bidirectional associated reverse-lsp lsr-id 1.1.1.9 tunnel-id 1
[RouterC-Tunnel1] quit
6. Configure CRLSP backup:
# Configure Router A:
[RouterA-Tunnel1] mpls te backup hot-standby
# Configure Router C:
[RouterC-Tunnel1] mpls te backup hot-standby
7. Configure static routes to direct traffic to the MPLS TE tunnels:
# Configure a static route on Router A, so traffic destined for network 100.1.2.0/24 is forwarded through MPLS TE tunnel interface Tunnel 1.
# Configure a static route on Router C, so traffic destined for network 100.1.1.0/24 is forwarded through MPLS TE tunnel interface Tunnel 1.
[RouterC] ip route-static 100.1.1.0 24 tunnel 1 preference 1
8. Configure bit error detection for the MPLS TE tunnels:
# For the MPLS TE tunnel from Router A to Router C, enable bit error detection and configure the switch and revert thresholds on the tunnel egress node Router C.
[RouterC] mpls te bit-error-detection mode bidirectional
[RouterC] mpls te bit-error-detection threshold switch 1 4 resume 1 5
# For the MPLS TE tunnel from Router C to Router A, enable bit error detection and configure the switch and revert thresholds on the tunnel egress node Router A.
[RouterA] mpls te bit-error-detection mode bidirectional
[RouterA] mpls te bit-error-detection threshold switch 1 4 resume 1 5
Execute the display mpls te bit-error-detection tunnel-interface command on Router C. The output shows bit error information about the bidirectional tunnels that are up and configured with hot-standby CRLSP backup.
<RouterC> display mpls te bit-error-detection tunnel-interface
Tunnel ID LSP type BED state BED rate(R/L)
1 Main Start e-4/e-4
1 Backup Stop e-5/e-5
Troubleshooting MPLS TE
No TE LSA generated
Symptom
OSPF TE is configured but no TE LSAs can be generated to describe MPLS TE attributes.
Analysis
For TE LSAs to be generated, a minimum of one OSPF neighbor must reach FULL state.
Solution
1. To resolve the problem:
a. Use the display current-configuration command to verify that MPLS TE is configured on involved interfaces.
b. Use the debugging ospf mpls-te command to verify that OSPF can receive the TE LINK establishment message.
c. Use the display ospf peer command to verify that OSPF neighbors are established correctly.
2. If the problem persists, contact H3C Support.
