14-User Access and Authentication Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S9820-8M[S6880] Command References-R1330Pxx-6W10014-User Access and Authentication Command Reference
08-User profile commands
08-User profile commands 61.42 KB
display user-profile
Use display user-profile to display configuration and online user information for user profiles.
display user-profile [ name profile-name ] [ slot slot-number ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, underscores (_), minus signs (–), and dots (.). The name can start with an English letter or digit, and cannot contain only digits. The name must be unique globally. If you do not specify this option, the command displays configuration and online user information for all user profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays user profile configuration and online user information for all member devices.
# Display configuration and online user information for user profile aaa.
<Sysname> display user-profile name aaa
  User-Profile: aaa
    Direction: Inbound
      Committed Access Rate:
        CIR 32 (kbps), CBS 2048 (Bytes), EBS 0 (Bytes), PIR 888 (kbps)
      Policy: p1
      Packet-filter ipv6 2222
    Direction: Outbound
        Rule: If-match acl 3000
          CIR 1000 (kbps), CBS 62500 (Bytes), EBS 0 (Bytes)
      Line Rate:
    Priority queuing: pql 1
    General Traffic Shaping:
      CIR 200 (kbps), CBS 12500 (Bytes), EBS 0 (Bytes)
    Overhead compensation length: 18
      Policy: p2
      Packet-filter 2222
    Connection-limit amount: 1000
    Connection-limit rate: 100
      Authentication-free rule:
      acl 3000
      acl name flow1
      acl ipv6 3000
      acl ipv6 name flow2
    User user_1:
      Authentication type: 802.1X
      Network attributes:
        Interface    : Twenty-FiveGigE1/0/1
        MAC address  : 0000-1111-2222
      Failed action list:
        Direction: Inbound
         Policy: p1
    User user_2:
      Authentication type: Portal
      Network attributes:
        Interface    : Twenty-FiveGigE1/0/3
        IP address   : 172.16.187.16
        VPN          : N/A
        Service VLAN : 100
User-Profile
User profile name.
Inbound
Policy applied to incoming traffic.
Outbound
Policy applied to outgoing traffic.
Line Rate
Information about user profile-based rate limiting. When the peer-advertise-bandwidth keyword is specified in the qos lr outbound command, this field displays the peer-advertise-bandwidth configuration information.
Priority queuing
Information about priority queuing applied to a user profile.
Information about GTS applied to a user profile.
Packet compensation length in bytes for outbound rate limiting.
CIR
Committed information rate, in kbps.
CBS
Committed burst size, in bytes.
EBS
Excess burst size, in bytes.
PIR
Peak information rate, in kbps.
Maximum number of user connections set by the connection limits.
Maximum connection establishment rate set by the connection limits.
User profile free rule.
Policy
Policy name.
Packet-filter
Packet filter that uses an IPv4 ACL.
Packet-filter ipv6
Packet filter that uses an IPv6 ACL.
QMProfile
Queue scheduling profile.
User user_1
Username of a user account with which a user profile or session group profile is associated.
Authentication type
·     802.1X—802.1X authentication.
·     Portal—Portal authentication.
·     MACA—MAC authentication.
Network attributes
Online user information.
Failed action list
Actions that failed to be applied to the user.
user-profile
Use user-profile to create a user profile and enter its view, or enter the view of an existing user profile.
Use undo user-profile to delete a user profile.
user-profile profile-name
undo user-profile profile-name
No user profiles exist.
# Create user profile a123 and enter the view of a123.
[Sysname] user-profile a123
[Sysname-user-profile-a123]
