- 06-Layer 2—LAN Switching Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-M-LAG commands
- 04-Port isolation commands
- 05-VLAN commands
- 06-MVRP commands
- 07-QinQ commands
- 08-VLAN mapping commands
- 09-Loop detection commands
- 10-Spanning tree commands
- 11-LLDP commands
- 12-PFC commands
- 13-L2PT commands
- 14-Service loopback group commands
- 15-Layer 2 forwarding commands
14-Service loopback group commands | 56.85 KB |
display service-loopback group
Use display service-loopback group to display service loopback group information.
display service-loopback group [ group-id ]
group-id: Specifies a service loopback group ID. The value range for the group-id argument is 1 to 1024. If you do not specify a service loopback group, this command displays information about all service loopback groups.
# Display information about service loopback group 5.
<Sysname> display service-loopback group 5
Group ID: 5 Service type: Tunnel
Member Status
Twenty-FiveGigE1/0/1 Selected
Twenty-FiveGigE1/0/2 Unselected
Group ID |
Service loopback group ID. |
Service type |
Service type of the service loopback group: Tunnel—Supports unicast tunnel traffic. |
Member |
Member ports of the service loopback group. |
Status |
Status of each member port in the service loopback group: · Selected—The port is in Selected state and can forward service packets. · Unselected—The port is in Unselected state. It cannot forward service packets. |
port service-loopback group
Use port service-loopback group to assign a port to a service loopback group.
Use undo port service-loopback group to remove a port from a service loopback group.
port service-loopback group group-id
A port does not belong to a service loopback group.
CAUTION: · When you assign a port to a service loopback group, the system removes the configuration on the port. Make sure you are fully aware of the impact of this command before using it on a live network. · For correct traffic processing, make sure a service loopback group has a minimum of one member port when it is being used by a feature. |
Before assigning a port to a service loopback group, make sure the port supports the service type of the group.
A port can belong to only one service loopback group.
# Assign Twenty-FiveGigE 1/0/1 to service loopback group 5.
[Sysname] interface twenty-fivegige 1/0/1
[Sysname-Twenty-FiveGigE1/0/1] port service-loopback group 5
Use service-loopback group to create a service loopback group and specify its service type.
Use undo service-loopback group to delete a service loopback group.
service-loopback group group-id type tunnel
undo service-loopback group group-id
No service loopback groups exist.
type: Specifies the service type of the service loopback group.
tunnel: Specifies the unicast tunnel service.
Service loopback groups must work with other features, such as GRE. A service loopback group can be used by multiple features.
You must create a service loopback group before you can use it with a feature.
To ensure correct traffic processing, do not delete a service loopback group that is being used by a feature.
# Create service loopback group 5 and specify the unicast tunnel service for the group.
[Sysname] service-loopback group 5 type tunnel
