- 18-Network Management and Monitoring Configuration Guide
- 01-Ping and tracert configuration
- 02-System debugging configuration
- 03-NQA configuration
- 04-NTP configuration
- 05-PTP configuration
- 06-SNMP configuration
- 07-RMON configuration
- 08-Event MIB configuration
- 09-Sampler configuration
- 10-Mirroring configuration
- 11-sFlow configuration
- 12-VCF fabric configuration
- 13-Cloud connection configuration
- 14-Performance management configuration
- 15-IPv6 NetStream configuration
- 16-NetStream configuration
- 17-CWMP configuration
- 18-EPA configuration
- 19-NetAnalysis configuration
- 20-SmartMC configuration
- 21-SQA configuration
10-Mirroring configuration | 435.32 KB |
Layer 2 remote port mirroring (RSPAN)
Layer 3 remote port mirroring (ERSPAN)
Restrictions and guidelines: Port mirroring configuration
Configuring local port mirroring (SPAN)
Restrictions and guidelines for local port mirroring configuration
Local port mirroring tasks at a glance
Creating a local mirroring group
Configuring local port mirroring group with multiple monitoring devices
Configuring Layer 2 remote port mirroring (RSPAN)
Restrictions and guidelines for Layer 2 remote port mirroring configuration
Layer 2 remote port mirroring with configurable reflector port configuration task list
Layer 2 remote port mirroring with egress port configuration task list
Creating a remote destination group
Configuring the remote probe VLAN
Assigning the monitor port to the remote probe VLAN
Creating a remote source group
Configuring the reflector port
Configuring Layer 3 remote port mirroring (ERSPAN in encapsulation parameter mode)
Restrictions and guidelines for Layer 3 remote port mirroring in ERSPAN mode configuration
Layer 3 remote port mirroring tasks at a glance
Creating a local mirroring group on the source device
Verifying and maintaining port mirroring
Port mirroring configuration examples
Example: Configuring local port mirroring (SPAN in source port mode)
Example: Configuring local port mirroring (SPAN in source CPU mode)
Example: Configuring Layer 2 remote port mirroring (RSPAN with reflector port configurable)
Example: Configuring Layer 2 remote port mirroring (RSPAN with egress port)
Example: Configuring Layer 3 remote port mirroring (ERSPAN in encapsulation parameter mode)
Restrictions and guidelines: Flow mirroring configuration
Flow mirroring tasks at a glance
Configuring a traffic behavior
Applying a QoS policy to an interface
Applying a QoS policy to a VLAN
Applying a QoS policy globally
Applying a QoS policy to the control plane
Verifying and maintaining flow mirroring
Configuring port mirroring
About port mirroring
Port mirroring copies the packets passing through a port or CPU to a port that connects to a data monitoring device for packet analysis.
Terminology
The following terms are used in port mirroring configuration.
Mirroring source
The mirroring sources can be one or more monitored ports (called source ports) or CPUs (called source CPUs).
Packets passing through mirroring sources are copied to a port connecting to a data monitoring device for packet analysis. The copies are called mirrored packets.
Source device
The device where the mirroring sources reside is called a source device.
Mirroring destination
The mirroring destination connects to a data monitoring device and is the destination port (also known as the monitor port) of mirrored packets. Mirrored packets are sent out of the monitor port to the data monitoring device.
A monitor port might receive multiple copies of a packet when it monitors multiple mirroring sources. For example, two copies of a packet are received on Port A when the following conditions exist:
· Port A is monitoring bidirectional traffic of Port B and Port C on the same device.
· The packet travels from Port B to Port C.
Destination device
The device where the monitor port resides is called the destination device.
Mirroring direction
The mirroring direction specifies the direction of the traffic that is copied on a mirroring source.
· Inbound—Copies packets received.
· Outbound—Copies packets sent.
· Bidirectional—Copies packets received and sent.
Mirroring group
Port mirroring is implemented through mirroring groups. Mirroring groups can be classified into local mirroring groups, remote source groups, and remote destination groups.
Reflector port, egress port, and remote probe VLAN
Reflector ports, remote probe VLANs, and egress ports are used for Layer 2 remote port mirroring. The remote probe VLAN is a dedicated VLAN for transmitting mirrored packets to the destination device. Both the reflector port and egress port reside on a source device and send mirrored packets to the remote probe VLAN.
On port mirroring devices, all ports except source, destination, reflector, and egress ports are called common ports.
Port mirroring classification
Port mirroring can be classified into local port mirroring and remote port mirroring.
· Local port mirroring—Also known as Switch Port Analyzer (SPAN). The source device is directly connected to a data monitoring device. The source device also acts as the destination device and forwards mirrored packets directly to the data monitoring device.
· Remote port mirroring—The source device is not directly connected to a data monitoring device. The source device sends mirrored packets to the destination device, which forwards the packets to the data monitoring device. Remote port mirroring can be further classified into Layer 2 and Layer 3 remote port mirroring:
¡ Layer 2 remote port mirroring—Also known as Remote SPAN (RSPAN). The source device and destination device are on the same Layer 2 network.
¡ Layer 3 remote port mirroring—Also known as Encapsulated Remote SPAN (ERSPAN). The source device and destination device are separated by IP networks.
Local port mirroring (SPAN)
Figure 1 Local port mirroring implementation
As shown in Figure 1, the source port (Port A) and the monitor port (Port B) reside on the same device. Packets received on Port A are copied to Port B. Port B then forwards the packets to the data monitoring device for analysis.
In Layer 2 remote port mirroring, the mirroring sources and destination reside on different devices and are in different mirroring groups.
A remote source group is a mirroring group that contains the mirroring sources. A remote destination group is a mirroring group that contains the mirroring destination. Intermediate devices are the devices between the source device and the destination device.
Layer 2 remote port mirroring can be implemented through the reflector port method or the egress port method.
Reflector port method
In Layer 2 remote port mirroring that uses the reflector port method, packets are mirrored as follows:
1. The source device copies packets received on the mirroring sources to the reflector port.
2. The reflector port broadcasts the mirrored packets in the remote probe VLAN.
3. The intermediate devices transmit the mirrored packets to the destination device through the remote probe VLAN.
4. Upon receiving the mirrored packets, the destination device determines whether the ID of the mirrored packets is the same as the remote probe VLAN ID. If the two VLAN IDs match, the destination device forwards the mirrored packets to the data monitoring device through the monitor port.
Figure 2 Layer 2 remote port mirroring implementation through the reflector port method
Egress port method
In Layer 2 remote port mirroring that uses the egress port method, packets are mirrored as follows:
1. The source device copies packets received on the mirroring sources to the egress port.
2. The egress port forwards the mirrored packets to the intermediate devices.
3. The intermediate devices flood the mirrored packets in the remote probe VLAN and transmit the mirrored packets to the destination device.
Figure 3 Layer 2 remote port mirroring implementation through the egress port method
Layer 3 remote port mirroring copies packets passing through a port, VLAN, or CPU and routes the packets to the remote monitoring device for monitoring and troubleshooting.
Layer 3 remote port mirroring in encapsulation parameter mode
To implement Layer 3 remote port mirroring in encapsulation parameter mode, perform the following tasks:
1. On the source device, create a local mirroring group and configure the mirroring sources, the monitor port, and the encapsulation parameters for mirrored packets.
2. On all devices from source to destination, configure a unicast routing protocol to ensure Layer 3 reachability between the devices.
Create a local mirroring group on the source device, and specify the source ports and monitor port for the local mirroring group. When configuring the monitor port, specify the following encapsulation parameters for mirrored packets:
· Monitoring device IP address as destination IP address.
· Monitor port IP address as source IP address.
As shown in Figure 4, Layer 3 remote port mirroring in encapsulation parameter mode works as follows:
1. The source device copies a packet passing through a source port.
2. The source device encapsulates the copied packet with the specified encapsulation parameters, monitoring device IP as destination IP and monitor port IP as source IP.
3. The encapsulated packet is routed to the monitoring device through the IP network.
4. The monitoring device decapsulates the packet and analyzes the packet contents.
The packet sent to the monitoring device through Layer 3 remote port mirroring in encapsulation parameter mode is encapsulated. In this mode, make sure the monitoring device supports decapsulating packets.
Figure 4 Layer 3 remote port mirroring in encapsulation parameter mode
The reflector port method for Layer 2 remote port mirroring can be used to implement local port mirroring with multiple monitor ports.
In the reflector port method, the reflector port broadcasts mirrored packets in the remote probe VLAN. By assigning ports that connects to data monitoring devices to the remote probe VLAN, you can implement local port mirroring to mirror packets to multiple monitor ports. The egress port method cannot implement local port mirroring in this way.
For a mirroring group, do not assign the source port to an aggregation group other than the one that accommodates the monitor port, egress port, or reflector port. If the source port is in a different aggregation group than the other ports, mirrored LACPDUs will be transmitted between the aggregation groups and cause aggregate interface flapping.
A local mirroring group takes effect only after it is configured with the monitor port and mirroring sources.
To configure local port mirroring, perform the following tasks:
1. Configuring mirroring sources
2. Configuring the monitor port
1. Enter system view.
2. Create a local mirroring group.
mirroring-group group-id local
Restrictions and guidelines for mirroring source configuration
When you configure source ports for a local mirroring group, follow these restrictions and guidelines:
· A mirroring group can contain multiple source ports.
· A port can act as a source port for only one mirroring group.
· A source port cannot be configured as a reflector port, egress port, or monitor port.
Configuring source ports
· Configure source ports in system view:
a. Enter system view.
b. Configure source ports for a local mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
By default, no source port is configured for a local mirroring group.
· Configure source ports in interface view:
b. Enter interface view.
c. Configure the port as a source port for a local mirroring group.
mirroring-group group-id mirroring-port { both | inbound | outbound }
By default, a port does not act as a source port for any local mirroring groups.
Configuring source CPUs
2. Configure source CPUs for a local mirroring group.
mirroring-group group-id mirroring-cpu slot slot-number-list { both | inbound | outbound }
By default, no source CPU is configured for a local mirroring group.
Do not enable the spanning tree feature on the monitor port.
Only one monitor port can be specified for a local mirroring group.
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
· Configure the monitor port in system view:
b. Configure the monitor port for a local mirroring group.
mirroring-group group-id monitor-port interface-list [ truncation ]
By default, no monitor port is configured for a local mirroring group.
· Configure the monitor port in interface view:
c. Configure the port as the monitor port for a mirroring group.
mirroring-group group-id monitor-port [ truncation ]
By default, a port does not act as the monitor port for any local mirroring groups.
To monitor interested traffic passing through a device on multiple directly connected data monitoring devices, configure local port mirroring with a remote probe VLAN as follows:
1. Configure a remote source group on the device.
2. Configure mirroring sources and a reflector port for the remote source group.
3. Specify a VLAN as the remote probe VLAN and assign the ports connecting to the data monitoring devices to the VLAN.
This configuration enables the device to copy packets received on the mirroring sources to the reflector port, which broadcasts the packets in the remote probe VLAN. The packets are then sent out of the member ports of the remote probe VLAN to the data monitoring devices.
The reflector port must be a port not in use. Do not connect a network cable to the reflector port.
When a port is configured as a reflector port, all the other settings on the port are cleared. You cannot configure other features on the reflector port.
Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
A VLAN can act as the remote probe VLAN for only one remote source group. As a best practice, use the VLAN for port mirroring exclusively. Do not create a VLAN interface for the VLAN or configure other features for the VLAN.
The remote probe VLAN must be a static VLAN.
To delete a VLAN that has been configured as the remote probe VLAN for a mirroring group, remove the remote probe VLAN from the mirroring group first.
2. Create a remote source group.
mirroring-group group-id remote-source
3. Configure mirroring sources for the remote source group. Choose one of the following tasks:
¡ Configure mirroring ports in system view:
¡ Execute the following commands in sequence to enter interface view, and then configure the interface as a source port.
4. Configure the reflector port for the remote source group.
mirroring-group group-id reflector-port reflector-port
By default, no reflector port is configured for a remote source group.
5. Create a VLAN and enter VLAN view.
vlan vlan-id
6. Assign the ports that connect to the data monitoring devices to the VLAN.
port interface-list
By default, a VLAN does not contain any ports.
7. Return to system view.
8. Specify the VLAN as the remote probe VLAN for the remote source group.
mirroring-group group-id remote-probe vlan vlan-id
By default, no remote probe VLAN is configured for a remote source group
To ensure successful traffic mirroring, configure devices in the order of the destination device, the intermediate devices, and the source device.
If intermediate devices exist, configure the intermediate devices to allow the remote probe VLAN to pass through.
For a mirrored packet to successfully arrive at the remote destination device, make sure its VLAN ID is not removed or changed.
To monitor the bidirectional traffic of a source port, disable MAC address learning for the remote probe VLAN on the source, intermediate, and destination devices. For more information about MAC address learning, see Layer 2—LAN Switching Configuration Guide.
Configuring the destination device
1. Creating a remote destination group
3. Configuring the remote probe VLAN
4. Assigning the monitor port to the remote probe VLAN
Configuring the source device
1. Creating a remote source group
2. Configuring mirroring sources
3. Configuring the reflector port
4. Configuring the remote probe VLAN
3. Configuring the egress port
Perform this task on the destination device only.
2. Create a remote destination group.
mirroring-group group-id remote-destination
Restrictions and guidelines for monitor port configuration
Only one monitor port can be specified for a remote destination group.
A monitor port can belong to only one mirroring group.
Configuring the monitor port in system view
2. Configure the monitor port for a remote destination group.
mirroring-group group-id monitor-port interface-type interface-number
By default, no monitor port is configured for a remote destination group.
Configuring the monitor port in interface view
2. Enter interface view.
3. Configure the port as the monitor port for a remote destination group.
By default, a port does not act as the monitor port for any remote destination groups.
This task is required on the both the source and destination devices.
Only an existing static VLAN can be configured as a remote probe VLAN.
When a VLAN is configured as a remote probe VLAN, use the remote probe VLAN for port mirroring exclusively.
Configure the same remote probe VLAN for the remote source group and the remote destination group.
2. Configure the remote probe VLAN for the remote source or destination group.
By default, no remote probe VLAN is configured for a remote source or destination group.
2. Enter the interface view of the monitor port.
3. Assign the port to the remote probe VLAN.
¡ Assign an access port to the remote probe VLAN.
port access vlan vlan-id
¡ Assign a trunk port to the remote probe VLAN.
port trunk permit vlan vlan-id
¡ Assign a hybrid port to the remote probe VLAN.
port hybrid vlan vlan-id { tagged | untagged }
For more information about the port access vlan, port trunk permit vlan, and port hybrid vlan commands, see Layer 2—LAN Switching Command Reference.
Perform this task on the source device only.
When you configure source ports for a remote source group, follow these restrictions and guidelines:
· Do not assign a source port of a mirroring group to the remote probe VLAN of the mirroring group.
· A source port cannot be configured as a reflector port, monitor port, or egress port.
b. Configure source ports for a remote source group.
By default, no source port is configured for a remote source group.
c. Configure the port as a source port for a remote source group.
By default, a port does not act as a source port for any remote source groups.
2. Configure source CPUs for a remote source group.
By default, no source CPU is configured for a remote source group.
Restrictions and guidelines for reflector port configuration
A remote source group supports only one reflector port.
Configuring the reflector port in system view
2. Configure the reflector port for a remote source group.
mirroring-group group-id reflector-port interface-type interface-number
CAUTION: · The port to be configured as a reflector port must be a port not in use. Do not connect a network cable to a reflector port. · When a port is configured as a reflector port, all the other settings on the port are cleared. You cannot configure other features on a reflector port. |
Configuring the reflector port in interface view
3. Configure the port as the reflector port for a remote source group.
By default, a port does not act as the reflector port for any remote source groups.
Restrictions and guidelines for egress port configuration
Disable the following features on the egress port:
· Spanning tree.
· Static ARP.
· MAC address learning.
A port of an existing mirroring group cannot be configured as an egress port.
A mirroring group supports only one egress port.
Configuring the egress port in system view
2. Configure the egress port for a remote source group.
mirroring-group group-id monitor-egress interface-type interface-number
By default, no egress port is configured for a remote source group.
3. Enter the egress port view.
4. Assign the egress port to the remote probe VLAN.
For more information about the port trunk permit vlan and port hybrid vlan commands, see Layer 2—LAN Switching Command Reference.
Configuring the egress port in interface view
3. Configure the port as the egress port for a remote source group.
By default, a port does not act as the egress port for any remote source groups.
To implement ERSPAN in encapsulation parameter mode, perform the following tasks:
1. On the source device, create a local mirroring group and configure the source ports or CPUs, the monitor port, and the encapsulation parameters for mirrored packets.
For ERSPAN in encapsulation parameter mode, the data monitoring device must be able to remove the outer headers to obtain the original mirrored packets for analysis.
To configure Layer 3 remote port mirroring in ERSPAN mode, perform the following tasks:
1. Creating a local mirroring group on the source device
3. Configuring the monitor port
When you configure source ports for the local mirroring group, follow these restrictions and guidelines:
c. Enter system view.
d. Enter interface view.
e. Configure the port as a source port for a local mirroring group.
When a port is configured as a reflector port, all the other settings on the port will be cleared. You cannot configure other features on a reflector port.
In a mirroring group, make sure the monitor port is different from the reflector port for outgoing mirrored packets of mirroring source ports.
You can configure a probe VLAN only for the reflector port of a local mirroring group. You cannot configure a probe VLAN for the reflector port of a remote source or destination group.
When a VLAN is configured as a probe VLAN for a reflector port, do not use the VLAN for any other purposes.
Only a static VLAN that already exists can be configured as a probe VLAN for a reflector port. A VLAN can be configured as the probe VLAN for the reflector port of only one mirroring group.
To delete a VLAN that is configured as a probe VLAN for a reflector port, first remove the probe VLAN configuration.
b. Configure the monitor port in a local mirroring group and specify the encapsulation parameters.
mirroring-group group-id monitor-port interface-type interface-number { destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name | reflector-port interface-type interface-number probe-vlan probe-vlan-id ] * [ truncation ]
c. Specify the port as the monitor port in a local mirroring group and configure the encapsulation parameters in a local mirroring group.
mirroring-group group-id monitor-port { destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name| reflector-port interface-type interface-number probe-vlan probe-vlan-id | truncation [ truncation ]
To display mirroring group information, execute the following command in any view:
display mirroring-group { group-id | all | local | remote-destination | remote-source }
As shown in Figure 5, configure local port mirroring in source port mode to enable the server to monitor the bidirectional traffic of the two departments.
# Create local mirroring group 1.
[Device] mirroring-group 1 local
# Configure Twenty-FiveGigE 1/0/1 and Twenty-FiveGigE 1/0/2 as source ports for local mirroring group 1.
[Device] mirroring-group 1 mirroring-port twenty-fivegige 1/0/1 twenty-fivegige 1/0/2 both
# Configure Twenty-FiveGigE 1/0/3 as the monitor port for local mirroring group 1.
[Device] mirroring-group 1 monitor-port twenty-fivegige 1/0/3
# Disable the spanning tree feature on the monitor port (Twenty-FiveGigE 1/0/3).
[Device] interface twenty-fivegige 1/0/3
[Device-Twenty-FiveGigE1/0/3] undo stp enable
[Device-Twenty-FiveGigE1/0/3] quit
# Verify the mirroring group configuration.
[Device] display mirroring-group all
Mirroring group 1:
Type: Local
Status: Active
Mirroring port: Twenty-FiveGigE1/0/1 Both
Twenty-FiveGigE1/0/2 Both
Monitor port: Twenty-FiveGigE1/0/3
As shown in Figure 6, Twenty-FiveGigE 1/0/1 and Twenty-FiveGigE 1/0/2 are located on the card in slot 1.
Configure local port mirroring in source CPU mode to enable the server to monitor all packets matching the following criteria:
· Received and sent by the Marketing Department and the Technical Department.
· Processed by the CPU in slot 1 of the device.
# Configure the CPU in slot 1 of the device as a source CPU for local mirroring group 1.
[Device] mirroring-group 1 mirroring-cpu slot 1 both
Mirroring group 1:
Type: Local
Status: Active
Mirroring CPU:
Slot 1 Both
As shown in Figure 7, configure Layer 2 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing Department.
1. Configure Device C (the destination device):
# Configure Twenty-FiveGigE 1/0/1 as a trunk port, and assign the port to VLAN 2.
<DeviceC> system-view
[DeviceC] interface twenty-fivegige 1/0/1
[DeviceC-Twenty-FiveGigE1/0/1] port link-type trunk
[DeviceC-Twenty-FiveGigE1/0/1] port trunk permit vlan 2
[DeviceC-Twenty-FiveGigE1/0/1] quit
# Create a remote destination group.
[DeviceC] mirroring-group 2 remote-destination
# Create VLAN 2.
[DeviceC] vlan 2
# Disable MAC address learning for VLAN 2.
[DeviceC-vlan2] undo mac-address mac-learning enable
[DeviceC-vlan2] quit
# Configure VLAN 2 as the remote probe VLAN for the mirroring group.
[DeviceC] mirroring-group 2 remote-probe vlan 2
# Configure Twenty-FiveGigE 1/0/2 as the monitor port for the mirroring group.
[DeviceC] interface twenty-fivegige 1/0/2
[DeviceC-Twenty-FiveGigE1/0/2] mirroring-group 2 monitor-port
# Disable the spanning tree feature on Twenty-FiveGigE 1/0/2.
[DeviceC-Twenty-FiveGigE1/0/2] undo stp enable
# Assign Twenty-FiveGigE 1/0/2 to VLAN 2.
[DeviceC-Twenty-FiveGigE1/0/2] port access vlan 2
[DeviceC-Twenty-FiveGigE1/0/2] quit
2. Configure Device B (the intermediate device):
# Create VLAN 2.
[DeviceB] vlan 2
[DeviceB-vlan2] undo mac-address mac-learning enable
[DeviceB-vlan2] quit
[DeviceB] interface twenty-fivegige 1/0/1
[DeviceB-Twenty-FiveGigE1/0/1] port link-type trunk
[DeviceB-Twenty-FiveGigE1/0/1] port trunk permit vlan 2
[DeviceB-Twenty-FiveGigE1/0/1] quit
# Configure Twenty-FiveGigE 1/0/2 as a trunk port, and assign the port to VLAN 2.
[DeviceB] interface twenty-fivegige 1/0/2
[DeviceB-Twenty-FiveGigE1/0/2] port link-type trunk
[DeviceB-Twenty-FiveGigE1/0/2] port trunk permit vlan 2
[DeviceB-Twenty-FiveGigE1/0/2] quit
3. Configure Device A (the source device):
# Create a remote source group.
[DeviceA] mirroring-group 1 remote-source
# Create VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] undo mac-address mac-learning enable
[DeviceA-vlan2] quit
[DeviceA] mirroring-group 1 remote-probe vlan 2
# Configure Twenty-FiveGigE 1/0/1 as a source port for the mirroring group.
[DeviceA] mirroring-group 1 mirroring-port twenty-fivegige 1/0/1 both
# Configure Twenty-FiveGigE 1/0/3 as the reflector port for the mirroring group.
[DeviceA] mirroring-group 1 reflector-port twenty-fivegige 1/0/3
[DeviceA] interface twenty-fivegige 1/0/2
[DeviceA-Twenty-FiveGigE1/0/2] port link-type trunk
[DeviceA-Twenty-FiveGigE1/0/2] port trunk permit vlan 2
[DeviceA-Twenty-FiveGigE1/0/2] quit
# Verify the mirroring group configuration on Device C.
[DeviceC] display mirroring-group all
Mirroring group 2:
Type: Remote destination
Status: Active
Monitor port: Twenty-FiveGigE1/0/2
Remote probe VLAN: 2
# Verify the mirroring group configuration on Device A.
[DeviceA] display mirroring-group all
Mirroring group 1:
Type: Remote source
Status: Active
Reflector port: Twenty-FiveGigE1/0/3
On the Layer 2 network shown in Figure 8, configure Layer 2 remote port mirroring to enable the server to monitor the bidirectional traffic of the Marketing Department.
# Create VLAN 2.
[DeviceC] vlan 2
# Assign Twenty-FiveGigE 1/0/2 to VLAN 2 as an access port.
# Create VLAN 2.
[DeviceB] vlan 2
# Create VLAN 2.
[DeviceA] vlan 2
# Configure VLAN 2 as the remote probe VLAN of the mirroring group.
# Configure Twenty-FiveGigE 1/0/2 as the egress port for the mirroring group.
[DeviceA] mirroring-group 1 monitor-egress twenty-fivegige 1/0/2
# Disable the spanning tree feature on the port.
[DeviceA-Twenty-FiveGigE1/0/2] undo stp enable
Mirroring group 2:
Status: Active
Mirroring group 1:
Type: Remote source
Status: Active
Monitor egress port: Twenty-FiveGigE1/0/2
On a Layer 3 network shown in Figure 9, configure Layer 3 remote port mirroring in encapsulation parameter mode to enable the server to monitor the bidirectional traffic of the Marketing Department.
1. Configure IP addresses for the interfaces as shown in Figure 9. (Details not shown.)
2. Configure Device A (the source device):
# Enable the OSPF protocol.
[DeviceA] ospf 1
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] quit
[DeviceA] mirroring-group 1 local
# Configure Twenty-FiveGigE 1/0/1 as a source port.
# Configure Twenty-FiveGigE 1/0/2 as the monitor port. Specify the destination and source IP addresses for mirrored packets as 40.1.1.2 and 20.1.1.1, respectively.
[DeviceA] mirroring-group 1 monitor-port twenty-fivegige 1/0/2 destination-ip 40.1.1.2 source-ip 20.1.1.1
3. Enable the OSPF protocol on Device B.
[DeviceB] ospf 1
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] quit
4. Enable the OSPF protocol on Device C.
[DeviceC] ospf 1
[DeviceC-ospf-1] area 0
[DeviceC-ospf-1-area-0.0.0.0] network 30.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 40.1.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] quit
[DeviceC-ospf-1] quit
Mirroring group 1:
Type: Local
Status: Active
Encapsulation: Destination IP address 40.1.1.2
Source IP address 20.1.1.1
Destination MAC address 000f-e241-5e5b
Configuring flow mirroring
About flow mirroring
Flow mirroring copies packets matching a class to a destination for packet analyzing and monitoring. It is implemented through QoS.
To implement flow mirroring through QoS, perform the following tasks:
· Define traffic classes and configure match criteria to classify packets to be mirrored. Flow mirroring allows you to flexibly classify packets to be analyzed by defining match criteria.
· Configure traffic behaviors to mirror the matching packets to the specified destination.
You can configure an action to mirror the matching packets to one of the following destinations:
· Interface—The matching packets are copied to an interface and then forwarded to a data monitoring device for analysis.
· Monitoring group—The matching packets are copied to all the member interfaces of a monitoring group and then forwarded to the data monitoring devices directly connected to the interfaces.
· CPU—The matching packets are copied to the CPU of an IRF member device. The CPU analyzes the packets or delivers them to upper layers.
For more information about QoS policies, traffic classes, and traffic behaviors, see ACL and QoS Configuration Guide.
For information about the configuration commands except the mirror-to command, see ACL and QoS Command Reference.
To configure flow mirroring, perform the following tasks:
1. Configuring a traffic class
A traffic class defines the criteria that filters the traffic to be mirrored.
2. Configuring a traffic behavior
A traffic behavior specifies mirroring destinations.
¡ Applying a QoS policy to an interface
¡ Applying a QoS policy to a VLAN
¡ Applying a QoS policy globally
¡ Applying a QoS policy to the control plane
2. Create a class and enter class view.
3. Configure match criteria.
if-match match-criteria
By default, no match criterion is configured in a traffic class.
4. (Optional.) Display traffic class information.
display traffic classifier { system-defined | user-defined } [ classifier-name ] [ slot slot-number ]
For more information about this command, see ACL and QoS Command Reference.
2. Configure a monitoring group.
a. Create a monitoring group.
monitoring-group group-id
b. Assign ports to the monitoring group.
Syntax I:
monitoring-port interface-list [ destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name | destination-mac mac-address ] * ]
Syntax II:
monitoring-port destination-ip destination-ip-address source-ip source-ip-address [ dscp dscp-value | vlan vlan-id | vrf-instance vrf-name | destination-mac mac-address ] *
By default, a monitoring group does not contain any port.
c. Return to system view.
3. Create a traffic behavior and enter traffic behavior view.
4. Configure mirroring destinations for the traffic behavior.
¡ Mirror traffic to interfaces.
Syntax I:
mirror-to interface interface-type interface-number
Syntax II:
mirror-to interface interface-type interface-number reflector-port interface-type interface-number strip-vlan vlan-id
undo mirror-to interface interface-type interface-number
When you use syntax III, the specified mirroring destination interface and reflector port must be assigned to a mirroring-type service loopback group. For more information about service loopback groups, see service loopback group configuration in Layer 2—LAN Switching Configuration Guide.
By default, no mirroring actions exist to mirror traffic to interfaces.
¡ Mirror traffic to a monitoring group.
mirror-to monitoring-group group-id
By default, no mirroring actions exist to mirror traffic to a monitoring group.
¡ Mirror traffic to the CPU.
mirror-to cpu
By default, no mirroring actions exist to mirror traffic to the CPU.
5. (Optional.) Display traffic behavior configuration.
display traffic behavior
This command is available in any view.
Configuring a QoS policy
2. Create a QoS policy and enter QoS policy view.
qos policy policy-name
3. Associate a class with a traffic behavior in the QoS policy.
classifier classifier-name behavior behavior-name
By default, no traffic behavior is associated with a class.
4. (Optional.) Display QoS policy configuration.
display qos policy
You can apply a QoS policy to an interface to mirror the traffic of the interface.
A policy can be applied to multiple interfaces.
In one traffic direction of an interface, only one QoS policy can be applied.
3. Apply a policy to the interface.
4. (Optional.) Display the QoS policy applied to the interface.
display qos policy interface
You can apply a QoS policy to a VLAN to mirror the traffic on all ports in the VLAN.
2. Apply a QoS policy to a VLAN.
3. (Optional.) Display the QoS policy applied to the VLAN.
display qos vlan-policy
You can apply a QoS policy globally to mirror the traffic on all ports.
2. Apply a QoS policy globally.
3. (Optional.) Display global QoS policies.
display qos policy global
You can apply a QoS policy to the control plane to mirror the traffic of all ports on the control plane.
2. Enter control plane view.
control-plane
3. Apply a QoS policy to the control plane.
4. (Optional.) Display QoS policies applied to the control plane
display qos policy control-plane
display monitoring-group { group-id | all }
Flow mirroring configuration examples
Example: Configuring flow mirroring
As shown in Figure 10, configure flow mirroring so that the server can monitor the following traffic:
· All traffic that the Technical Department sends to access the Internet.
· IP traffic that the Technical Department sends to the Marketing Department during working hours (8:00 to 18:00) on weekdays.
# Create working hour range work, in which working hours are from 8:00 to 18:00 on weekdays.
[DeviceA] time-range work 8:00 to 18:00 working-day
# Create IPv4 advanced ACL 3000 to allow packets from the Technical Department to access the Internet and the Marketing Department during working hours.
[DeviceA] acl advanced 3000
[DeviceA-acl-ipv4-adv-3000] rule permit tcp source 192.168.2.0 0.0.0.255 destination-port eq www
[DeviceA-acl-ipv4-adv-3000] rule permit ip source 192.168.2.0 0.0.0.255 destination 192.168.1.0 0.0.0.255 time-range work
[DeviceA-acl-ipv4-adv-3000] quit
# Create traffic class tech_c, and configure the match criterion as ACL 3000.
[DeviceA] traffic classifier tech_c
[DeviceA-classifier-tech_c] if-match acl 3000
[DeviceA-classifier-tech_c] quit
# Create traffic behavior tech_b, configure the action of mirroring traffic to Twenty-FiveGigE 1/0/3.
[DeviceA] traffic behavior tech_b
[DeviceA-behavior-tech_b] mirror-to interface twenty-fivegige 1/0/3
[DeviceA-behavior-tech_b] quit
# Create QoS policy tech_p, and associate traffic class tech_c with traffic behavior tech_b in the QoS policy.
[DeviceA] qos policy tech_p
[DeviceA-qospolicy-tech_p] classifier tech_c behavior tech_b
[DeviceA-qospolicy-tech_p] quit
# Apply QoS policy tech_p to the incoming packets of Twenty-FiveGigE 1/0/4.
[DeviceA] interface twenty-fivegige 1/0/4
[DeviceA-Twenty-FiveGigE1/0/4] qos apply policy tech_p inbound
[DeviceA-Twenty-FiveGigE1/0/4] quit
# Verify that the server can monitor the following traffic:
· All traffic sent by the Technical Department to access the Internet.
· IP traffic that the Technical Department sends to the Marketing Department during working hours on weekdays.
