16-Security Configuration Guide
HomeSupportSwitchesS6550X-HI SeriesConfigure & DeployConfiguration GuidesH3C S6550X-HI Configuration Guides-R1330Pxx-6W10016-Security Configuration Guide
08-DHCP snooping configuration
08-DHCP snooping configuration 297.41 KB
Configuring DHCP snooping· 1
About DHCP snooping· 1
Application of trusted and untrusted ports· 1
DHCP snooping support for Option 82· 2
Restrictions and guidelines: DHCP snooping configuration· 3
DHCP snooping tasks at a glance· 3
Configuring basic DHCP snooping features· 4
Configuring basic DHCP snooping features in a common network· 4
Configuring basic DHCP snooping features in a VXLAN network· 5
Configuring DHCP snooping support for Option 82· 6
Configuring DHCP snooping entry auto backup· 8
Setting the maximum number of DHCP snooping entries· 8
Configuring DHCP packet rate limit 9
Configuring DHCP snooping security features· 9
Enabling DHCP starvation attack protection· 9
Enabling DHCP-REQUEST attack protection· 10
Configuring a DHCP packet blocking port 10
Enabling the giaddr field check in DHCP requests· 11
Enabling client offline detection on the DHCP snooping device· 11
Enabling DHCP snooping logging and packet drop alarm·· 12
Enabling DHCP snooping logging· 12
Configuring packet drop alarm·· 12
Enabling DHCP snooping alarm notifications· 13
About DHCP snooping alarm notifications· 13
Enabling the binding-exhaust alarm·· 13
Enabling the binding-threshold alarm·· 13
Enabling the binding-mismatch or chaddr-mismatch packet drop alarm·· 14
Enabling the rate-limit or untrust-reply packet drop alarm·· 15
Disabling DHCP snooping on an interface· 16
Verifying and maintaining DHCP snooping· 16
Verifying DHCP snooping configuration· 16
Displaying and clearing DHCP snooping entries· 16
Displaying and clearing DHCP packet statistics on the DHCP snooping device· 17
Displaying and clearing the packet drop statistics on an interface enabled with the packet drop alarm   17
DHCP snooping configuration examples· 17
Example: Configuring basic DHCP snooping features globally· 17
Example: Configuring basic DHCP snooping features for a VLAN· 18
Example: Configuring DHCP snooping support for Option 82· 19
About DHCP snooping
DHCP snooping is a security feature for DHCP.
DHCP snooping works between the DHCP client and server, or between the DHCP client and DHCP relay agent. It guarantees that DHCP clients obtain IP addresses from authorized DHCP servers. Also, it records IP-to-MAC bindings of DHCP clients (called DHCP snooping entries) for security purposes.
DHCP snooping defines trusted and untrusted ports to make sure clients obtain IP addresses only from authorized DHCP servers.
·     Trusted—A trusted port can forward DHCP messages correctly to make sure the clients get IP addresses from authorized DHCP servers.
·     Untrusted—An untrusted port discards received DHCP-ACK and DHCP-OFFER messages to prevent unauthorized servers from assigning IP addresses.
DHCP snooping reads DHCP-ACK messages received from trusted ports and DHCP-REQUEST messages to create DHCP snooping entries. A DHCP snooping entry includes the MAC and IP addresses of a client, the port that connects to the DHCP client, and the VLAN.
The following features need to use DHCP snooping entries:
·     ARP fast-reply—Uses DHCP snooping entries to reduce ARP broadcast traffic. For more information, see "Configuring ARP fast-reply."
·     ARP attack detection—Uses DHCP snooping entries to filter ARP packets from unauthorized clients. For more information, see Security Configuration Guide.
Configure ports facing the DHCP server as trusted ports, and configure other ports as untrusted ports.
As shown in Figure 1, configure the DHCP snooping device's port that is connected to the DHCP server as a trusted port. The trusted port forwards response messages from the DHCP server to the client. The untrusted port connected to the unauthorized DHCP server discards incoming DHCP response messages.
Figure 1 Trusted and untrusted ports
In a cascaded network as shown in Figure 2, configure the DHCP snooping devices' ports facing the DHCP server as trusted ports. To save system resources, you can enable only the untrusted ports directly connected to the DHCP clients to record DHCP snooping entries.
Figure 2 Trusted and untrusted ports in a cascaded network
Option 82 records the location information about the DHCP client so the administrator can locate the DHCP client for security and accounting purposes. For more information about Option 82, see DHCP overview in Layer 3—IP Services Configuration Guide.
Sub-option 9 (Vendor-Specific) in Option 82 is supported only on DHCP snooping devices. Each DHCP snooping device adds the following information to the sub-option in the received DHCP request:
·     Node identifier of the current DHCP snooping device.
·     Information about the client-side interface.
·     VLAN of the DHCP client.
After the management device receives the DHCP request, the management device can determine the network topology that the request has travelled and locate the DHCP client.
DHCP snooping uses the same strategies as the DHCP relay agent to handle Option 82 for DHCP request messages, as shown in Table 1. If a response returned by the DHCP server contains Option 82, DHCP snooping removes Option 82 before forwarding the response to the client. If the response contains no Option 82, DHCP snooping forwards it directly.
Table 1 Handling strategies
If a DHCP request has…
Handling strategy
DHCP snooping…
Option 82
Append
·     Forwards the message after padding the Vendor-Specific sub-option with the content specified in the dhcp snooping information vendor-specific command.
·     Forwards the message without changing Option 82 if the dhcp snooping information vendor-specific command is not configured.
Drop
Drops the message.
Keep
Forwards the message without changing Option 82.
Replace
Forwards the message after replacing the original Option 82 with the Option 82 padded according to the configured padding format, padding content, and code type.
No Option 82
N/A
Forwards the message after adding the Option 82 padded according to the configured padding format, padding content, and code type.
·     The DHCP snooping configuration does not take effect on a Layer 2 Ethernet interface that is an aggregation member port. The configuration takes effect when the interface leaves the aggregation group.
·     Specify the ports connected to authorized DHCP servers as trusted ports to make sure that DHCP clients can obtain valid IP addresses. The trusted ports and the ports connected to DHCP clients must be in the same VLAN.
·     You can specify the following interfaces as trusted ports: Layer 2 Ethernet interfaces, Layer 2 aggregate interfaces, Layer 3 Ethernet interfaces, and Layer 3 aggregate interfaces. For more information about aggregate interfaces, see Ethernet link aggregation configuration in Layer 2—LAN Switching Configuration Guide.
To configure DHCP snooping, perform the following tasks:
1.     Configuring basic DHCP snooping features
2.     (Optional.) Configuring DHCP snooping support for Option 82
3.     (Optional.) Configuring DHCP snooping entry auto backup
4.     (Optional.) Setting the maximum number of DHCP snooping entries
5.     (Optional.) Configuring DHCP packet rate limit
6.     (Optional.) Configuring DHCP snooping security features
7.     (Optional.) Enabling the giaddr field check in DHCP requests
8.     (Optional.) Enabling client offline detection on the DHCP snooping device
9.     (Optional.) Enabling DHCP snooping logging and packet drop alarm
¡     Enabling DHCP snooping logging
¡     Configuring packet drop alarm
10.     (Optional.) Enabling DHCP snooping alarm notifications
11.     (Optional.) Disabling DHCP snooping on an interface
Basic DHCP snooping features refer to the following:
·     Enabling DHCP snooping.
·     Configuring DHCP snooping trusted ports.
·     Enabling recording client information in DHCP snooping entries.
If you enable DHCP snooping globally, DHCP snooping is enabled on all interfaces on the device.
You can also enable DHCP snooping for specific VLANs. After enabling DHCP snooping for a VLAN, you can configure the other basic DHCP snooping features in the VLAN.
If the basic DHCP snooping features are configured globally, you can only use the undo form of the global configuration commands to disable the settings globally. The VLAN-specific configuration commands cannot disable the settings.
If the basic DHCP snooping features are configured in a VLAN, you can only use the undo form of the VLAN-specific configuration commands to disable the settings in the VLAN. The global configuration command cannot disable the settings.
2.     Enable DHCP snooping globally.
dhcp snooping enable
By default, DHCP snooping is disabled globally.
3.     Enter interface view.
This interface must connect to the DHCP server.
4.     Specify the port as a trusted port.
dhcp snooping trust
By default, all ports are untrusted ports after DHCP snooping is enabled.
5.     (Optional.) Enable the recording of DHCP snooping entries.
a.     Return to system view.
b.     Enter interface view.
This interface must connect to the DHCP client.
c.     Enable the recording of DHCP snooping entries.
dhcp snooping binding record
By default, the recording of DHCP snooping entries is disabled.
Configuring basic DHCP snooping features for VLANs
2.     Enable DHCP snooping for VLANs.
dhcp snooping enable vlan vlan-id-list
By default, DHCP snooping is disabled for all VLANs.
3.     Enter VLAN view
vlan vlan-id
Make sure DHCP snooping is enabled for the VLAN.
4.     Configure an interface in the VLAN as a trusted port.
dhcp snooping trust interface interface-type interface-number
By default, all interfaces in the VLAN are untrusted ports.
5.     (Optional.) Enable recording of client information in DHCP snooping entries.
By default, recording of client information in DHCP snooping entries is disabled.
In a VXLAN network, you can configure the following interfaces as DHCP snooping trusted interfaces:
·     ACs that are mapped to a VSI.
·     VXLAN tunnel interfaces that are assigned to a VSI.
When the VTEP with DHCP snooping configured receives a DHCP request, the VTEP forwards this request through the trusted ACs or VXLAN tunnel interfaces.
If the DHCP server is in the local site, configure the AC that connects to the DHCP server as trusted. If the DHCP server is in a remote site, configure the VXLAN tunnel interface as trusted.
Configuring basic DHCP snooping features in a VXLAN network (DHCP server at the local site)
4.     Enter Ethernet service instance view.
service-instance instance-id
5.     Configure the AC as the DHCP snooping trusted interface.
dhcp snooping trust
By default, all ports are untrusted after DHCP snooping is enabled.
6.     (Optional.) Enable recording of client information in DHCP snooping entries on the ACs mapped to the VSI and VXLAN tunnel interfaces assigned to the VSI.
a.     Exit to interface view.
b.     Exit to the system view.
c.     Enter VSI view.
vsi vsi-name
d.     Enable recording of client information in DHCP snooping entries on the ACs mapped to the VSI and VXLAN tunnel interfaces assigned to the VSI.
Configuring basic DHCP snooping features in a VXLAN network (DHCP server at a remote site)
3.     Enter VSI view.
vsi vsi-name
4.     Configure the VXLAN tunnel interfaces as the DHCP snooping trusted interface.
dhcp snooping trust tunnel
This command sets all VXLAN tunnel interfaces in the VSI as DHCP snooping trusted interfaces.
5.     (Optional.) Enable recording of client information in DHCP snooping entries on the ACs mapped to the VSI and VXLAN tunnel interfaces assigned to the VSI.
·     The Option 82 configuration on a Layer 2 Ethernet interface that has been added to an aggregation group does not take effect unless the interface leaves the aggregation group.
·     To support Option 82, you must configure Option 82 on both the DHCP server and the DHCP snooping device. For information about configuring Option 82 on the DHCP server, see DHCP server configuration in Layer 3—IP Services Configuration Guide.
·     If Option 82 contains the device name, the device name must contain no spaces. Otherwise, DHCP snooping drops the message. You can use the sysname command to specify the device name. For more information about this command, see Fundamentals Command Reference.
2.     Enter interface view or VLAN view.
¡     Enter interface view.
¡     Enter VLAN view.
vlan vlan-id
3.     Enable DHCP snooping to support Option 82.
dhcp snooping information enable
By default, DHCP snooping does not support Option 82.
4.     (Optional.) Configure a handling strategy for DHCP requests that contain Option 82.
dhcp snooping information strategy { append | drop | keep | replace }
By default, the handling strategy is replace.
If the handling strategy is append or replace, configure a padding mode and padding format for Option 82. If the handling strategy is keep or drop, you do not need to configure any padding mode or padding format for Option 82.
5.     (Optional.) Configure the padding mode and padding format for the Circuit ID sub-option.
dhcp snooping information circuit-id { normal-extended | [ vlan vlan-id ] string circuit-id | { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] } [ format { ascii | hex } ] }
By default, the padding mode is normal and the padding format is hex for the Circuit ID sub-option.
If the device name (sysname) is configured as the padding content for sub-option 1, make sure the device name does not include spaces. Otherwise, the DHCP snooping device will fail to add or replace Option 82.
The vlan vlan-id option is not supported in VLAN view.
6.     (Optional.) Configure the padding mode and padding format for the Remote ID sub-option.
dhcp snooping information remote-id { normal [ format { ascii | hex } ] | [ vlan vlan-id ] { hex remote-id | string remote-id | sysname }
By default, the padding mode is normal and the padding format is hex for the Remote ID sub-option.
7.     (Optional.) Configure the padding mode for the Vendor-Specific sub-option.
dhcp snooping information vendor-specific [ vlan vlan-id ] bas [ node-identifier { mac | sysname | user-defined string } ]
By default, the device does not pad the Vendor-Specific sub-option.
The auto backup feature saves DHCP snooping entries to a backup file, and allows the DHCP snooping device to download the entries from the backup file at device reboot. The entries on the DHCP snooping device cannot survive a reboot. The auto backup helps the security features provide services if these features must use DHCP snooping entries for user authentication.
If you disable DHCP snooping with the undo dhcp snooping enable command, the device deletes all DHCP snooping entries, but entries stored in the backup file still exist. They are deleted next time the device updates the backup file.
2.     Configure the DHCP snooping device to back up DHCP snooping entries to a file.
dhcp snooping binding database filename { filename | url url [ username username [ password { cipher | simple } string ] ] }
By default, the DHCP snooping device does not back up DHCP snooping entries.
With this command executed, the DHCP snooping device backs up DHCP snooping entries immediately and runs auto backup.
This command automatically creates the file if you specify a non-existent file.
3.     (Optional.) Manually save DHCP snooping entries to the backup file.
dhcp snooping binding database update now
4.     (Optional.) Set the waiting time after a DHCP snooping entry change for the DHCP snooping device to update the backup file.
dhcp snooping binding database update interval interval
By default, the DHCP snooping device waits 300 seconds to update the backup file after a DHCP snooping entry change. If no DHCP snooping entry changes, the backup file is not updated.
Perform this task to prevent the system resources from being overused.
2.     Enter interface view.
3.     Set the maximum number of DHCP snooping entries for the interface to learn.
dhcp snooping max-learning-num max-number
By default, the number of DHCP snooping entries for an interface to learn is unlimited.
Perform this task to set the maximum rate at which an interface can receive DHCP packets. This feature discards exceeding DHCP packets to prevent attacks that send large number of DHCP packets.
The rate set on the Layer 2 aggregate interface applies to all members of the aggregate interface. If a member interface leaves the aggregation group, it uses the rate set in its Ethernet interface view.
3.     Enable DHCP snooping packet rate limit on an interface and set the limit value.
dhcp snooping rate-limit rate
By default, the DHCP snooping packet rate limit is disabled on an interface.
A DHCP starvation attack occurs when an attacker constantly sends forged DHCP requests that contain identical or different sender MAC addresses in the chaddr field to a DHCP server. This attack exhausts the IP address resources of the DHCP server so legitimate DHCP clients cannot obtain IP addresses. The DHCP server might also fail to work because of exhaustion of system resources. For information about the fields of DHCP packet, see DHCP overview in Layer 3—IP Services Configuration Guide.
You can prevent DHCP starvation attacks in the following ways:
·     If the forged DHCP requests contain different sender MAC addresses, use the mac-address max-mac-count command to set the MAC learning limit on a Layer 2 port. For more information about the command, see Layer 2—LAN Switching Command Reference.
·     If the forged DHCP requests contain the same sender MAC address, perform this task to enable MAC address check for DHCP snooping. This feature compares the chaddr field of a received DHCP request with the source MAC address field in the frame header. If they are the same, the request is considered valid and forwarded to the DHCP server. If not, the request is discarded.
3.     Enable MAC address check.
dhcp snooping check mac-address
By default, MAC address check is disabled.
DHCP-REQUEST messages include DHCP lease renewal packets, DHCP-DECLINE packets, and DHCP-RELEASE packets. This feature prevents the unauthorized clients that forge the DHCP-REQUEST messages from attacking the DHCP server.
Attackers can forge DHCP lease renewal packets to renew leases for legitimate DHCP clients that no longer need the IP addresses. These forged messages disable the victim DHCP server from releasing the IP addresses.
Attackers can also forge DHCP-DECLINE or DHCP-RELEASE packets to terminate leases for legitimate DHCP clients that still need the IP addresses.
To prevent such attacks, you can enable DHCP-REQUEST check. This feature uses DHCP snooping entries to check incoming DHCP-REQUEST messages.
·     If a matching entry is found for a message, this feature compares the entry with the message information.
¡     If they are consistent, the message is considered as valid and forwarded to the DHCP server.
¡     If they are different, the message is considered as a forged message and is discarded.
·     If no matching entry is found, the message is considered valid and forwarded to the DHCP server.
3.     Enable DHCP-REQUEST check.
dhcp snooping check request-message
By default, DHCP-REQUEST check is disabled.
Perform this task to configure a port as a DHCP packet blocking port. This blocking port drops all incoming DHCP requests.
3.     Configure the port to block DHCP requests.
dhcp snooping deny
By default, the port does not block DHCP requests.
CAUTION
CAUTION:
To avoid IP address acquisition failure, configure a port to block DHCP packets only if no DHCP clients are attached to it.
A DHCP snooping device functions between DHCP clients and a DHCP server, or between DHCP clients and a DHCP relay agent. The giaddr field in a DHCP request records the address information of the first relay agent that the request passes by. If the DHCP snooping devices receives a DHCP request where the giaddr field value is not 0, it indicates that the DHCP snooping device location is not correct. In this case, the DHCP snooping device cannot function correctly.
This feature enables the DHCP snooping device to examine the giaddr field value in received DHCP packets and drop them if the giaddr field is not 0. When the number of dropped DHCP requests reaches or exceeds the threshold, the device generates a log for administrators to adjust locations of the DHCP devices.
3.     Enable the giaddr field check in DHCP requests.
dhcp snooping check giaddr
By default, the device does not check the giaddr field in DHCP requests.
When a DHCP client goes offline abnormally, it does not send a message to the DHCP server to release its IP address. As a result, the DHCP server is not aware of the offline event and cannot release the client lease timely.
With this feature enabled, the DHCP snooping device performs the following operations when the ARP entry of a client ages out:
1.     Deletes the DHCP snooping entry for the client.
2.     Sends a DHCP-RELEASE message to the DHCP server to inform the server to release the address lease of the client.
2.     Enable client offline detection.
dhcp snooping client-detect
By default, client offline detection is disabled.
The DHCP snooping logging feature enables the DHCP snooping device to generate DHCP snooping logs and send them to the information center. The information helps administrators locate and solve problems. For information about the log destination and output rule configuration in the information center, see System Management Configuration Guide.
As a best practice, disable this feature if the log generation affects the device performance.
2.     Enable DHCP snooping logging.
dhcp snooping log enable
By default, DHCP snooping logging is disabled.
After you enable the packet drop alarm for a feature, the device generates an alarm log when the number of packets dropped by this feature reaches the alarm threshold. The alarm log is sent to the information center. Then, the device clears the current packet drop statistics and counts packet drops again. If the number of packet drops reaches the alarm threshold again, the device generates a new alarm log.
You can set log message filtering and output rules by configuring the information center. For more information about the information center, see Network Management and Monitoring Configuration Guide.
To set the alarm threshold, use the dhcp snooping alarm threshold command.
For this feature to take effect, you must first execute the dhcp snooping log enable command to enable DHCP snooping logging.
2.     Enable the packet drop alarm.
dhcp snooping alarm { giaddr | mac-address | request-message } enable
By default, the packet drop alarm is disabled.
3.     Set a packet drop alarm threshold.
dhcp snooping alarm { giaddr | mac-address | request-message } threshold threshold
By default, the packet drop alarm threshold is 100.
The DHCP snooping device can report critical DHCP snooping events to network administrators in the following alarm notifications:
·     Binding-exhaust alarm notifications: The DHCP snooping device generates this type of alarm notifications when the DHCP snooping entry resource is exhausted or recovers from the exhaustion condition.
·     Binding-mismatch alarm notifications: The DHCP snooping device generates this type of alarm notifications when the number of DHCP requests dropped due to DHCP snooping entry mismatch has reached the alarm threshold.
·     Binding-threshold alarm notifications: The DHCP snooping device generates this type of alarm notifications when the usage of DHCP snooping entry resources has reached or dropped below the alarm threshold.
·     Chaddr-mismatch alarm notifications: The DHCP snooping device generates this type of alarm notifications when the number of DHCP requests dropped due to MAC address mismatch has reached the alarm threshold.
·     Rate-limit alarm notifications: The DHCP snooping device generates this type of alarm notifications when the number of DHCP requests dropped due to reception rate limit exceeding has reached the alarm threshold.
·     Untrust-reply alarm notifications: The DHCP snooping device generates this type of alarm notifications when the number of DHCP server replies dropped on untrusted interfaces has reached the alarm threshold.
After you enable DHCP snooping alarm notifications, the DHCP snooping module reports critical DHCP snooping events in alarm notifications to the SNMP module. For DHCP snooping event notifications to be sent correctly, you must configure SNMP on the device. For more information about SNMP configuration, see SNMP configuration in Network Management and Monitoring Configuration Guide.
2.     Enable the binding-exhaust alarm.
snmp-agent trap enable dhcp snooping binding-exhaust
By default, the binding-exhaust alarm is disabled for DHCP snooping.
4.     (Optional.) Enable the binding-exhaust alarm on the interface.
dhcp snooping exhaustion trap enable
By default, the binding-exhaust alarm is disabled on the interface.
2.     Enable the binding-threshold alarm.
snmp-agent trap enable dhcp snooping binding-threshold
By default, the binding-threshold alarm is disabled for DHCP snooping.
4.     (Optional.) Set the alarm threshold on the usage of DHCP snooping entry resources.
dhcp snooping learning-num-threshold threshold-value
By default, the alarm threshold on the usage of DHCP snooping entry resources is 100%.
This chapter introduces how to enable the binding-mismatch or chaddr-mismatch packet drop alarm.
2.     Enable the binding-mismatch or chaddr-mismatch alarm for the SNMP module.
snmp-agent trap enable dhcp snooping [ binding-mismatch | chaddr-mismatch ] *
By default, both the binding-mismatch and chaddr-mismatch alarms are disabled for the SNMP module.
3.     Set the global alarm threshold that triggers packet drop alarm generation.
dhcp snooping alarm { mac-address | request-message } threshold threshold
By default, the global alarm threshold that triggers packet drop alarm generation is 100.
For an interface, the mac-address keyword has the same effect as the chaddr-mismatch keyword in the dhcp snooping alarm { binding-mismatch | chaddr-mismatch } threshold command.
For an interface, the request-message keyword has the same effect as the binding-mismatch keyword in the dhcp snooping alarm { binding-mismatch | chaddr-mismatch } threshold command.
4.     Enter interface view.
5.     (Optional.) Disable alarm log generation for packet drop events on the interface.
undo dhcp snooping alarm { binding-mismatch | chaddr-mismatch } enable
By default, the packet drop alarm is disabled on the interface.
6.     (Optional.) Set the global threshold that triggers alarm log generation for packet drop events on the interface.
dhcp snooping alarm { binding-mismatch | chaddr-mismatch } threshold threshold
By default, the global threshold configured in system view takes effect on the interface.
This chapter introduces how to enable the rate-limit or untrust-reply packet drop alarm.
After you enable the rate-limit or untrust-reply packet drop alarm for the SNMP module and the DHCP module, both modules generate alarm notifications when the alarm threshold is reached.
·     After you enable the rate-limit packet drop alarm for the SNMP or DHCP module, the module generates an alarm notification when the alarm threshold is reached. To set the alarm threshold that triggers the rate-limit packet drop alarm, use the dhcp snooping trap threshold rate-limit command.
·     After you enable the untrust-reply packet drop alarm for the DHCP module, this feature functions as follows:
¡     If you specify the software keyword, the software side collects statistics about the DHCP server replies dropped on each interface. When the number of DHCP server replies dropped on an interface reaches the alarm threshold, the DHCP module generates an alarm notification.
¡     If you specify the hardware keyword, the hardware side collects statistics about the DHCP server replies dropped on all untrusted interfaces of cards. When the total number of dropped DHCP server replies reaches the alarm threshold, the DHCP module generates an alarm notification.
2.     Enable the rate-limit or untrust-reply alarm for the SNMP module.
snmp-agent trap enable dhcp snooping [ rate-limit | untrust-reply ] *
By default, both the rate-limit and untrust-reply alarms are disabled for the SNMP module.
3.     Enable the rate-limit or untrust-reply alarm for the DHCP module.
dhcp snooping trap { rate-limit | untrust-reply { software | hardware } } enable
By default, all types of packet drop alarms are disabled.
4.     Set the global threshold that triggers packet drop alarm generation.
dhcp snooping trap { rate-limit | untrust-reply { software | hardware } } threshold threshold
By default, the global threshold is 100 for all packet drop types.
5.     Enter interface view.
6.     (Optional.) Disable the packet drop alarm on the interface.
undo dhcp snooping trap { rate-limit | untrust-reply } enable
By default, all types of packet drop alarms are disabled on the interface.
7.     (Optional.) Set the packet drop alarm threshold on the interface.
dhcp snooping trap { rate-limit | untrust-reply software } threshold threshold
This feature allows you to narrow down the interface range where DHCP snooping takes effect. For example, to enable DHCP snooping globally except for a specific interface, you can enable DHCP snooping globally and disable DHCP snooping on the target interface.
3.     Disable DHCP snooping on the interface.
dhcp snooping disable
By default:
¡     If you enable DHCP snooping globally or for a VLAN, DHCP snooping is enabled on all interfaces on the device or on all interfaces in the VLAN.
¡     If you do not enable DHCP snooping globally or for a VLAN, DHCP snooping is disabled on all interfaces on the device or on all interfaces in the VLAN.
·     Display information about trusted ports.
display dhcp snooping trust
·     Display Option 82 configuration information on the DHCP snooping device.
display dhcp snooping information { all | interface interface-type interface-number }
·     Display DHCP snooping entries.
display dhcp snooping binding [ interface interface-type interface-number | ip ip-address [ vlan vlan-id ] ] [ verbose ]
·     Display information about DHCP snooping entry auto backup.
display dhcp snooping binding database
To clear DHCP snooping entries, execute the following command in user view:
reset dhcp snooping binding { all | ip ip-address [ vlan vlan-id ] }
To display DHCP packet statistics on the DHCP snooping device, execute the following command in any view:
display dhcp snooping packet statistics [ slot slot-number ]
To clear DHCP packet statistics on the DHCP snooping device, execute the following command in user view:
reset dhcp snooping packet statistics [ slot slot-number ]
To display the packet drop statistics on an interface enabled with the packet drop alarm, execute the following command in any view:
display dhcp snooping alarm packet statistics interface interface-type interface-number
To clear the packet drop statistics on an interface enabled with the packet drop alarm, execute the following command in any view:
reset dhcp snooping alarm packet statistics interface interface-type interface-number
As shown in Figure 3, Switch B is connected to the authorized DHCP server through Twenty-FiveGigE 1/0/1, to the unauthorized DHCP server through Twenty-FiveGigE 1/0/3, and to the DHCP client through Twenty-FiveGigE 1/0/2.
Configure only the port connected to the authorized DHCP server to forward the responses from the DHCP server. Enable the DHCP snooping device to record clients' IP-to-MAC bindings by reading DHCP-ACK messages received from the trusted port and the DHCP-REQUEST messages.
Figure 3 Network diagram
# Enable DHCP snooping globally.
[SwitchB] dhcp snooping enable
# Configure Twenty-FiveGigE 1/0/1 as a trusted port.
[SwitchB] interface twenty-fivegige 1/0/1
[SwitchB-Twenty-FiveGigE1/0/1] dhcp snooping trust
[SwitchB-Twenty-FiveGigE1/0/1] quit
# Enable recording clients' IP-to-MAC bindings on Twenty-FiveGigE 1/0/2.
[SwitchB] interface twenty-fivegige 1/0/2
[SwitchB-Twenty-FiveGigE1/0/2] dhcp snooping binding record
[SwitchB-Twenty-FiveGigE1/0/2] quit
# Verify that the DHCP client can obtain an IP address and other configuration parameters only from the authorized DHCP server. (Details not shown.)
# Display the DHCP snooping entry recorded for the client.
[SwitchB] display dhcp snooping binding
As shown in Figure 4, Switch B is connected to the authorized DHCP server through Twenty-FiveGigE 1/0/1, to the unauthorized DHCP server through Twenty-FiveGigE 1/0/3, and to the DHCP client through Twenty-FiveGigE 1/0/2.
Configure only the port in VLAN 100 connected to the authorized DHCP server to forward the responses from the DHCP server. Enable the port in VLAN 100 to record clients' IP-to-MAC bindings by reading DHCP-ACK messages received from the trusted port and the DHCP-REQUEST messages.
Figure 4 Network diagram
# Assign Twenty-FiveGigE 1/0/1, Twenty-FiveGigE 1/0/2, and Twenty-FiveGigE 1/0/3 to VLAN 100.
[SwitchB] vlan 100
[SwitchB-vlan100] port twenty-fivegige 1/0/1 to twenty-fivegige 1/0/3
[SwitchB-vlan100] quit
# Enable DHCP snooping for VLAN 100.
[SwitchB] dhcp snooping enable vlan 100
# Configure Twenty-FiveGigE 1/0/1 as DHCP snooping trusted port.
[SwitchB] vlan 100
[SwitchB-vlan100] dhcp snooping trust interface twenty-fivegige 1/0/1
# Enable recording clients' IP-to-MAC bindings in VLAN 100.
[SwitchB-vlan100] dhcp snooping binding record
As shown in Figure 5, enable DHCP snooping and configure Option 82 on Switch B as follows:
·     Configure the handling strategy for DHCP requests that contain Option 82 as replace.
·     On Twenty-FiveGigE 1/0/2, configure the padding content for the Circuit ID sub-option as company001 and for the Remote ID sub-option as device001.
·     On Twenty-FiveGigE 1/0/3, configure the padding mode for the Circuit ID sub-option as verbose, access node identifier as sysname, and padding format as ascii. Configure the padding content for the Remote ID sub-option as device001.
Figure 5 Network diagram
# Enable DHCP snooping.
# Configure Option 82 on Twenty-FiveGigE 1/0/2.
[SwitchB-Twenty-FiveGigE1/0/2] dhcp snooping information enable
[SwitchB-Twenty-FiveGigE1/0/2] dhcp snooping information strategy replace
[SwitchB-Twenty-FiveGigE1/0/2] dhcp snooping information circuit-id string company001
[SwitchB-Twenty-FiveGigE1/0/2] dhcp snooping information remote-id string device001
# Configure Option 82 on Twenty-FiveGigE 1/0/3.
[SwitchB] interface twenty-fivegige 1/0/3
[SwitchB-Twenty-FiveGigE1/0/3] dhcp snooping information enable
[SwitchB-Twenty-FiveGigE1/0/3] dhcp snooping information strategy replace
[SwitchB-Twenty-FiveGigE1/0/3] dhcp snooping information circuit-id verbose node-identifier sysname format ascii
[SwitchB-Twenty-FiveGigE1/0/3] dhcp snooping information remote-id string device001
# Display Option 82 configuration information on Twenty-FiveGigE 1/0/2 and Twenty-FiveGigE 1/0/3 on the DHCP snooping device.
[SwitchB] display dhcp snooping information
