08-Layer 3—IP Routing Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR610[810][830][1000S][2600][3600] Routers Configuration Guides(V7)-R6749-6W10208-Layer 3—IP Routing Configuration Guide
04-OSPF configuration
04-OSPF configuration 1.35 MB
Configuring OSPF· 1
About OSPF· 1
OSPF features· 1
OSPF packets· 1
LSA types· 1
OSPF areas· 2
Router types· 4
Route types· 5
Router ID·· 6
Route calculation· 6
OSPF network types· 6
DR and BDR· 7
OSPF state machines· 8
Protocols and standards· 12
Restrictions and guidelines: OSPF configuration· 12
OSPF tasks at a glance· 12
Configuring basic OSPF functions· 14
Enabling an OSPF process· 14
Creating an OSPF area· 14
Enabling OSPF· 15
Configuring OSPF dynamic host name mappings· 16
Configuring OSPF stub and NSSA areas· 17
About OSPF stub and NSSA area configuration· 17
Configuring a stub area· 17
Configuring an NSSA area· 18
Configuring a virtual link· 18
Configuring OSPF network types· 19
Restrictions and guidelines for configuring OSPF network types· 19
Configuring the broadcast network type for an interface· 19
Configuring the NBMA network type for an interface· 20
Configuring the P2MP network type for an interface· 20
Configuring the P2P network type for an interface· 21
Configuring OSPF route control 21
Configuring OSPF inter-area route summarization· 21
Configuring redistributed route summarization· 22
Configuring received OSPF route filtering· 22
Configuring Type-3 LSA filtering· 23
Setting an OSPF cost for an interface· 23
Setting the maximum number of ECMP routes· 24
Setting OSPF preference· 25
Configuring discard routes for summary networks· 25
Redistributing routes from another routing protocol 25
Redistributing a default route· 26
Advertising a host route· 27
Advertising OSPF link state information to BGP· 28
Setting OSPF timers· 28
About setting OSPF timers· 28
Configuring OSPF packet timers· 28
Setting LSA transmission delay· 29
Setting SPF calculation interval 30
Setting the minimum LSA arrival interval 30
Setting the LSA update interval 30
Setting OSPF exit overflow interval 31
Configuring OSPF packet parameters· 31
Disabling interfaces from receiving and sending OSPF packets· 31
Adding the interface MTU into DD packets· 32
Setting the DSCP value for outgoing OSPF packets· 32
Enabling OSPF to limit the LSU packet transmission rate· 33
Controlling LSA generation, advertisement, and reception· 34
Setting the maximum number of external LSAs in LSDB· 34
Filtering outbound LSAs on an interface· 34
Filtering LSAs for the specified neighbor 34
Accelerating OSPF convergence speed· 35
Enabling OSPF ISPF· 35
Configuring prefix suppression· 35
Configuring prefix prioritization· 36
Configuring OSPF PIC· 37
Configuring advanced OSPF features· 38
Configuring stub routers· 38
Configuring OSPF isolation· 39
Configuring OSPF shutdown· 40
Enabling compatibility with RFC 1583· 40
Enabling OSPF to group ECMP routes· 41
Configuring OSPF GR· 41
About OSPF GR· 41
Restrictions and guidelines for OSPF GR· 42
Configuring OSPF GR restarter 42
Configuring OSPF GR helper 43
Triggering OSPF GR· 44
Configuring OSPF NSR· 44
Configuring BFD for OSPF· 47
About BFD for OSPF· 47
Configuring bidirectional control detection· 47
Configuring single-hop echo detection· 47
Configuring OSPF FRR· 48
About OSPF FRR· 48
Restrictions and guidelines for OSPF FRR· 48
OSPF FRR tasks at a glance· 48
Configuring OSPF LFA FRR· 48
Configuring OSPF remote LFA FRR· 49
Configuring OSPF FRR to use a backup next hop specified in a routing policy· 51
Setting the priority for FRR backup path selection policies· 51
Configuring BFD control packet mode for OSPF FRR· 53
Configuring BFD echo packet mode for OSPF FRR· 53
Enabling OSPF to adjust the interface cost according to the link quality· 54
Configuring OSPF authentication· 55
About OSPF area and interface authentication· 55
Configuring OSPF area authentication· 55
Configuring OSPF interface authentication· 55
Configuring GTSM for OSPF· 56
About GTSM·· 56
Restrictions and guidelines for GTSM·· 56
Configuring GTSM in OSPF area view· 56
Configuring GTSM in interface view· 56
Configuring OSPF logging and SNMP notifications· 57
Logging neighbor state changes· 57
Configuring the OSPF logging feature· 57
Configuring OSPF network management 58
Display and maintenance commands for OSPF· 58
OSPF configuration examples· 61
Example: Configuring basic OSPF· 61
Example: Configuring OSPF route redistribution· 64
Example: Configuring OSPF route summarization· 65
Example: Configuring OSPF stub area· 68
Example: Configuring OSPF NSSA area· 71
Example: Configuring OSPF DR election· 73
Example: Configuring OSPF virtual link· 77
Example: Configuring OSPF GR· 79
Example: Configuring OSPF NSR· 81
Example: Configuring BFD for OSPF· 83
Example: Configuring OSPF FRR· 86
Troubleshooting OSPF configuration· 89
No OSPF neighbor relationship established· 89
Incorrect routing information· 90
Configuring OSPF
About OSPF
Open Shortest Path First (OSPF) is a link-state IGP developed by the OSPF working group of the IETF. OSPF version 2 is used for IPv4. OSPF refers to OSPFv2 throughout this chapter.
OSPF features
OSPF has the following features:
·     Wide scope—Supports multiple network sizes and several hundred routers in an OSPF routing domain.
·     Fast convergence—Advertises routing updates instantly upon network topology changes.
·     Loop free—Computes routes with the SPF algorithm to avoid routing loops.
·     Area-based network partition—Splits an AS into multiple areas to facilitate management. This feature reduces the LSDB size on routers to save memory and CPU resources, and reduces route updates transmitted between areas to save bandwidth.
·     ECMP routing—Supports multiple equal-cost routes to a destination.
·     Routing hierarchy—Supports a 4-level routing hierarchy that prioritizes routes into intra-area, inter-area, external Type-1, and external Type-2 routes.
·     Authentication—Supports area- and interface-based packet authentication to ensure secure packet exchange.
·     Support for multicasting—Multicasts protocol packets on some types of links to avoid impacting other devices.
OSPF packets
OSPF messages are carried directly over IP. The protocol number is 89.
OSPF uses the following packet types:
·     Hello—Periodically sent to find and maintain neighbors, containing timer values, information about the DR, BDR, and known neighbors.
·     Database description (DD)—Describes the digest of each LSA in the LSDB, exchanged between two routers for data synchronization.
·     Link state request (LSR)—Requests needed LSAs from a neighbor. After exchanging the DD packets, the two routers know which LSAs of the neighbor are missing from their LSDBs. They then exchange LSR packets requesting the missing LSAs. LSR packets contain the digest of the missing LSAs.
·     Link state update (LSU)—Transmits the requested LSAs to the neighbor.
·     Link state acknowledgment (LSAck)—Acknowledges received LSU packets. It contains the headers of received LSAs (an LSAck packet can acknowledge multiple LSAs).
LSA types
OSPF advertises routing information in Link State Advertisements (LSAs). The following LSAs are commonly used:
·     Router LSA—Type-1 LSA, originated by all routers and flooded throughout a single area only. This LSA describes the collected states of the router's interfaces to an area.
·     Network LSA—Type-2 LSA, originated for broadcast and NBMA networks by the designated router, and flooded throughout a single area only. This LSA contains the list of routers connected to the network.
·     Network Summary LSA—Type-3 LSA, originated by Area Border Routers (ABRs), and flooded throughout the LSA's associated area. Each summary-LSA describes a route to a destination outside the area, yet still inside the AS (an inter-area route).
·     ASBR Summary LSA—Type-4 LSA, originated by ABRs and flooded throughout the LSA's associated area. Type 4 summary-LSAs describe routes to Autonomous System Boundary Router (ASBR).
·     AS External LSA—Type-5 LSA, originated by ASBRs, and flooded throughout the AS (except stub and NSSA areas). Each AS-external-LSA describes a route to another AS.
·     NSSA LSA—Type-7 LSA, as defined in RFC 1587, originated by ASBRs in NSSAs and flooded throughout a single NSSA. NSSA LSAs describe routes to other ASs.
·     Opaque LSA—LSA for OSPF extensions. Its format consists of a standard LSA header and application specific information. The opaque LSA includes Type 9, Type 10, and Type 11. The Type 9 opaque LSA is flooded into the local subnet. Grace LSA, used by graceful restart, is Type 9 LSA. The Type 10 is flooded into the local area. LSA used by MPLS TE is Type 10 LSA. The Type 11 is flooded throughout the AS.
OSPF areas
Area-based OSPF network partition
In large OSPF routing domains, SPF route computations consume too many storage and CPU resources, and enormous OSPF packets generated for route synchronization occupy excessive bandwidth.
To resolve these issues, OSPF splits an AS into multiple areas. Each area is identified by an area ID. The boundaries between areas are routers rather than links. A network segment (or a link) can only reside in one area as shown in Figure 1.
You can configure route summarization on ABRs to reduce the number of LSAs advertised to other areas and minimize the effect of topology changes.
Figure 1 Area-based OSPF network partition
Backbone area
Each AS has a backbone area that distributes routing information between non-backbone areas. Routing information between non-backbone areas must be forwarded by the backbone area. OSPF has the following requirements:
·     All non-backbone areas must maintain connectivity to the backbone area.
·     The backbone area must maintain connectivity within itself.
In practice, these requirements might not be met due to lack of physical links. OSPF virtual links can solve this issue.
Virtual links
A virtual link is established between two ABRs through a non-backbone area. It must be configured on both ABRs to take effect. The non-backbone area is called a transit area.
As shown in Figure 2, Area 2 has no direct physical link to the backbone Area 0. You can configure a virtual link between the two ABRs to connect Area 2 to the backbone area.
Figure 2 Virtual link application 1
Virtual links can also be used as redundant links. If a physical link failure breaks the internal connectivity of the backbone area, you can configure a virtual link to replace the failed physical link, as shown in Figure 3.
Figure 3 Virtual link application 2
The virtual link between the two ABRs acts as a point-to-point connection. You can configure interface parameters, such as hello interval, on the virtual link as they are configured on a physical interface.
The two ABRs on the virtual link unicast OSPF packets to each other, and the OSPF routers in between convey these OSPF packets as normal IP packets.
Stub area and totally stub area
A stub area does not distribute Type-5 LSAs to reduce the routing table size and LSAs advertised within the area. The ABR of the stub area advertises a default route in a Type-3 LSA so that the routers in the area can reach external networks through the default route.
To further reduce the routing table size and advertised LSAs, you can configure the stub area as a totally stub area. The ABR of a totally stub area does not advertise inter-area routes or external routes. It advertises a default route in a Type-3 LSA so that the routers in the area can reach external networks through the default route.
NSSA area and totally NSSA area
An NSSA area does not import AS external LSAs (Type-5 LSAs) but can import Type-7 LSAs generated by the NSSA ASBR. The NSSA ABR translates Type-7 LSAs into Type-5 LSAs and advertises the Type-5 LSAs to other areas.
As shown in Figure 4, the OSPF AS contains Area 1, Area 2, and Area 0. The other two ASs run RIP. Area 1 is an NSSA area where the ASBR redistributes RIP routes in Type-7 LSAs into Area 1. Upon receiving the Type-7 LSAs, the NSSA ABR translates them to Type-5 LSAs, and advertises the Type-5 LSAs to Area 0.
The ASBR of Area 2 redistributes RIP routes in Type-5 LSAs into the OSPF routing domain. However, Area 1 does not receive Type-5 LSAs because it is an NSSA area.
Figure 4 NSSA area
Router types
As shown in Figure 5, OSPF routers are classified into different types, including internal routers, ABRs, backbone routers, and ASBRs.
Figure 5 OSPF router types
Internal router
All interfaces on an internal router belong to one OSPF area.
ABR
An ABR belongs to more than two areas, one of which must be the backbone area. ABR connects the backbone area to a non-backbone area. An ABR and the backbone area can be connected through a physical or logical link.
Backbone router
No less than one interface of a backbone router must reside in the backbone area. All ABRs and internal routers in Area 0 are backbone routers.
ASBR
An ASBR exchanges routing information with another AS. An ASBR might not reside on the border of the AS. It can be an internal router or an ABR.
Route types
OSPF prioritizes routes into the following route levels:
·     Intra-area route.
·     Inter-area route.
·     Type-1 external route.
·     Type-2 external route.
The intra-area and inter-area routes describe the network topology of the AS. The external routes describe routes to external ASs.
A Type-1 external route has high credibility. The cost of a Type-1 external route = the cost from the router to the corresponding ASBR + the cost from the ASBR to the destination of the external route.
A Type-2 external route has low credibility. OSPF considers that the cost from the ASBR to the destination of a Type-2 external route is much greater than the cost from the ASBR to an OSPF internal router. The cost of a Type-2 external route = the cost from the ASBR to the destination of the Type-2 external route. If two Type-2 routes to the same destination have the same cost, OSPF takes the cost from the router to the ASBR into consideration to determine the best route.
Router ID
A router ID uniquely identifies a router in an AS. For a router to run OSPF, it must have a router ID. You can choose to manually specify a router ID or use the global router ID for an OSPF process.
Manual configuration
When you create an OSPF process, you can manually specify a router ID. To make sure the router ID is unique in the AS, you can specify the IP address of an interface on the router as the router ID.
Autoconfiguration
When you create an OSPF process, you can enable the OSPF process to automatically obtain a router ID. The OSPF process obtains a router ID in the following ways:
·     During the startup of the OSPF process, the primary IPv4 address of the first interface that runs the process is specified as the router ID.
·     During the reboot of the router, the primary IPv4 address of the first interface that runs the process is specified as the router ID.
·     During the restart of the OSPF process, the highest primary IPv4 address of the loopback interface that runs the process is specified as the router ID. If no loopback address is available, the highest primary IPv4 address of the interface that runs the process is used, regardless of the interface state (up or down).
Using the global router ID
If you do not specify a router ID when creating an OSPF process, the global router ID is used. As a best practice, manually specify a router ID or enable the OSPF process to automatically obtain a router ID when you create the OSPF process.
Route calculation
OSPF computes routes in an area as follows:
·     Each router generates LSAs based on the network topology around itself, and sends them to other routers in update packets.
·     Each OSPF router collects LSAs from other routers to compose an LSDB. An LSA describes the network topology around a router, and the LSDB describes the entire network topology of the area.
·     Each router transforms the LSDB to a weighted directed graph that shows the topology of the area. All the routers within the area have the same graph.
·     Each router uses the SPF algorithm to compute a shortest path tree that shows the routes to the nodes in the area. The router itself is the root of the tree.
OSPF network types
OSPF classifies networks into the following types, depending on different link layer protocols:
·     Broadcast—If the link layer protocol is Ethernet or FDDI, OSPF considers the network type as broadcast by default. On a broadcast network, hello, LSU, and LSAck packets are multicast to 224.0.0.5 that identifies all OSPF routers or to 224.0.0.6 that identifies the DR and BDR. DD packets and LSR packets are unicast.
·     NBMA—If the link layer protocol is Frame Relay, ATM, or X.25, OSPF considers the network type as NBMA by default. OSPF packets are unicast on an NBMA network.
·     P2MP—No link is P2MP type by default. P2MP must be a conversion from other network types such as NBMA. On a P2MP network, OSPF packets are multicast to 224.0.0.5.
·     P2P—If the link layer protocol is PPP or HDLC, OSPF considers the network type as P2P. On a P2P network, DD packets are unicast and other OSPF packets are multicast to 224.0.0.5.
The following are the differences between NBMA and P2MP networks:
·     NBMA networks are fully meshed. P2MP networks are not required to be fully meshed.
·     NBMA networks require DR and BDR election. P2MP networks do not have DR or BDR.
·     On an NBMA network, OSPF packets are unicast, and neighbors are manually configured. On a P2MP network, OSPF packets are multicast by default, and you can configure OSPF to unicast protocol packets.
DR and BDR
DR and BDR mechanism
On a broadcast or NBMA network, any two routers must establish an adjacency to exchange routing information with each other. If n routers are present on the network, n(n-1)/2 adjacencies are established. Any topology change on the network results in an increase in traffic for route synchronization, which consumes a large amount of system and bandwidth resources.
Using the DR and BDR mechanisms can solve this problem.
·     DR—Elected to advertise routing information among other routers. If the DR fails, routers on the network must elect another DR and synchronize information with the new DR. Using this mechanism without BDR is time-consuming and is prone to route calculation errors.
·     BDR—Elected along with the DR to establish adjacencies with all other routers. If the DR fails, the BDR immediately becomes the new DR, and other routers elect a new BDR.
Routers other than the DR and BDR are called DR Others. They do not establish adjacencies with one another, so the number of adjacencies is reduced.
The role of a router is subnet (or interface) specific. It might be a DR on one interface and a BDR or DR Other on another interface.
As shown in Figure 6, solid lines are Ethernet physical links, and dashed lines represent OSPF adjacencies. With the DR and BDR, only seven adjacencies are established.
Figure 6 DR and BDR in a network
In OSPF, neighbor and adjacency are different concepts. After startup, OSPF sends a hello packet on each OSPF interface. A receiving router checks parameters in the packet. If the parameters match its own, the receiving router considers the sending router an OSPF neighbor. Two OSPF neighbors establish an adjacency relationship after they synchronize their LSDBs through exchange of DD packets and LSAs.
DR and BDR election
DR election is performed on broadcast or NBMA networks but not on P2P and P2MP networks.
Routers in a broadcast or NBMA network elect the DR and BDR by router priority and ID. Routers with a router priority value higher than 0 are candidates for DR and BDR election.
The election votes are hello packets. Each router sends the DR elected by itself in a hello packet to all the other routers. If two routers on the network declare themselves as the DR, the router with the higher router priority wins. If router priorities are the same, the router with the higher router ID wins.
If a router with a higher router priority becomes active after DR and BDR election, the router cannot replace the DR or BDR until a new election is performed. Therefore, the DR of a network might not be the router with the highest priority, and the BDR might not be the router with the second highest priority.
OSPF state machines
Interface state machine
On receipt of link state information, OSPF establishes adjacency relationships with neighboring devices, and then exchanges LSAs with them. The state of an OSPF interface indicates the role of the device in an OSPF link. Two neighboring devices can correctly form an adjacency relationship by checking each other's interface state.
The interface state machine involves the following interface states:
·     Down—Initial interface state.
An OSPF interface in this state cannot be used for traffic sending or receiving.
·     Loopback—The network-attached interface is looped back on the device.
A loopback interface is not available for regular data transmission. However, to obtain link quality information on the interface, you might either send ICMP ping packets to the loopback interface or have a bit error test. To meet this potential requirement, each OSPF device advertises loopback interface information in Router LSAs.
·     Waiting—The device is determining the DR and BDR for the network.
When the device does not run for the DR or BDR, the interface starts a wait timer. The hello packets sent by the device does not contain any DR or BDR information unless the wait timer expires. The device cannot be elected as the DR or BDR on the network until it exits from Waiting state. The wait timer mechanism prevents unnecessary DR and BDR changes.
This interface state is supported only on NBMA networks and broadcast networks.
·     Point-to-point—The interface is connected to a physical P2P network or to a virtual link.
If an interface enters this state, it attempts to establish an adjacency relationship with the neighboring device.
This interface state is supported only on P2P networks and P2MP networks.
·     DR Other—The interface is connected to a broadcast or NBMA network on which another device has been elected as the DR.
A device in DR Other state is neither elected as the DR nor the BDR. When DR and BDR election is complete on the network, each DR Other device establishes adjacencies with both the DR and the BDR.
·     BDRThe device is the BDR on the attached network.
As the BDR, the device establishes adjacencies with all other devices on the attached network. It will immediately become the new DR if the existing DR fails.
·     DR—The device is the DR on the attached network.
As the DR, the device establishes adjacencies with all other devices on the attached network.
A number of input events (IE) can cause OSPF interface state changes. As shown in Figure 7, the relationships between IEs and state changes form the OSPF interface state machine.
Figure 7 OSPF interface state machine
Table 1 shows the IEs that can cause interface state changes.
Table 1 Input events
Input event
IE1
InterfaceUp event: Lower-level protocols have indicated that the interface is operational.
IE2
WaitTimer event: The wait timer has expired and the device can run for the DR or the BDR.
IE3
BackupSeen event: The device has detected the existence or non-existence of a BDR on the attached network through one of the following methods:
·     The interface receives a hello packet from a neighbor that claims itself to be the BDR.
·     The interface receives a hello packet from a neighbor that claims itself to be the DR. The hello packet also indicates that there is no BDR.
This event marks an end to Waiting state and indicates that the device and the neighbor can have bidirectional communication.
IE4
The interface is elected as the DR.
IE5
The interface is elected as the BDR.
IE6
The interface is neither elected as the DR nor the BDR.
IE7
NeighborChange event: A neighbor associated with the interface has a change. The DR and BDR need to be re-elected. The following neighbor changes might lead to the re-election of DR and BDR:
·     The device can have bidirectional communication with a neighbor.
·     The device no longer has bidirectional communication with a neighbor.
·     A neighbor claims itself as DR or BDR. The device detects this event again by examining the hello packets from the neighbor.
·     A neighbor no longer claims itself as DR or BDR. The device detects this event again by examining the hello packets from the neighbor.
·     The DR priority for a neighbor has changed. The device detects this event again by examining the hello packets from the neighbor.
IE8
UnloopInd event: Network management or lower-level protocols has indicated that the interface is no longer looped back.
IE9
InterfaceDown event: Lower-level protocols has indicated that the interface is not operational. If this event occurs, the interface state might change to Down.
IE10
LoopInd event: Network management or lower-level protocols has indicated that the interface is looped back. If this event occurs, the interface state might change to Loopback.
Neighbor state machine
The process of OSPF adjacency establishment involves a series of neighbor state changes that transition from Down state to Full state.
The neighbor state machine involves the following neighbor states:
·     DownInitial state of a neighbor conversation.
This state indicates that the local device does not receive any hello packets from the neighbor within the neighbor dead interval. An OSPF device sends hello packets at intervals of PollInterval.
Whether an OSPF device sends hello packets to neighbors in Down state depends on its network type. The device sends hello packets to neighbors in Down state only when its network type is NBMA.
·     Attempt—In this state, the local device attempts to establish neighbor relationships with the manually specified neighbors by sending hello packets at intervals of HelloInterval.
This state is valid only for the neighbors on NBMA networks.
·     Init—This state indicates that the local device has received a hello packet from a neighbor before the neighbor dead interval elapses. However, the local device has not established bidirectional communication with the neighbor, because the received hello packet does not contain the local device's router ID.
·     2-Way—This state indicates that the local device has established a neighbor relationship with a neighboring device. Each of the two devices has received a hello packet from another and has seen its own router ID in the received hello packet.
If the neighbor relationship between two devices does not prompt to an adjacency, the neighbor state will remain 2-Way.
DR and BDR election starts only when the neighbor state is 2-Way or greater.
·     ExStartThis state indicates that the local device and the neighbor is deciding which is the master. This step is to determine the sequence number for initial DD packets. The devices can then exchange DD packets in order.
·     Exchange—This state indicates that the local device is exchanging DD packets with the neighbor. The local device describes its LSDB information in DD packets and sends them to the neighbor.
·     LoadingThis state indicates that the local device and the neighbor are having bidirectional LSDB synchronization. They send LSRs to each other to request the most recent LSAs, and then synchronize their LSDBs through exchanges of LSUs and LSAcks.
·     Full—This state indicates that the local device and the neighbor has completed bidirectional LSDB synchronization and they are fully adjacent.
As shown in Figure 8, the relationships between IEs and state changes form the OSPF neighbor state machine.
Figure 8 OSPF neighbor state machine
Table 2 shows the IEs that can cause neighbor state changes.
Table 2 Input events
Input event
IE1
Start event: The OSPF device attempts to establish a neighbor relationship with the neighbor by sending hello packets at intervals of HelloInterval.
This event is supported only on NBMA networks.
IE2
HelloReceived event: The OSPF device has received a hello packet from the neighbor.
IE3
2-WayReceived event: The OSPF device has received a hello packet from the neighbor and has seen its router ID in the received hello packet. The two neighboring devices have established bidirectional communication. The OSPF device then performs the following task:
·     If the OSPF device needs to form an adjacency with the neighbor, it changes the neighbor state to ExStart.
·     If the OSPF device should not form an adjacency with the neighbor, it changes the neighbor state to 2-Way.
IE4
NegotiationDone event: The OSPF device and the neighbor have completed master/secondary relationship negotiation and have determined the sequence number for initial DD packets.
IE5
ExchangeDone event: The OSPF device have exchanged DD packets with the neighbor. The OSPF device then performs the following task:
·     If the LSR list is empty, the device changes the neighbor state to Full. This neighbor state indicates that bidirectional LSDB synchronization is complete and the device has established an adjacency with the neighbor.
·     If the LSR list is not empty, the device changes the neighbor state to Loading, and then sends LSRs to the neighbor to request missing link state information.
IE6
LoadingDone event: The LSR list is already empty.
·     RFC 1245, OSPF protocol analysis
·     RFC 1246, Experience with the OSPF protocol
·     RFC 1370, Applicability Statement for OSPF
·     RFC 1403, BGP OSPF Interaction
·     RFC 1745, BGP4/IDRP for IP---OSPF Interaction
·     RFC 1765, OSPF Database Overflow
·     RFC 1793, Extending OSPF to Support Demand Circuits
·     RFC 2154, OSPF with Digital Signatures
·     RFC 2328, OSPF Version 2
·     RFC 3101, OSPF Not-So-Stubby Area (NSSA) Option
·     RFC 3166, Request to Move RFC 1403 to Historic Status
·     RFC 3509, Alternative Implementations of OSPF Area Border Routers
·     RFC 4167, Graceful OSPF Restart Implementation Report
·     RFC 4577, OSPF as the Provider/Customer Edge Protocol for BGP/MPLS IP Virtual Private Networks (VPNs)
·     RFC 4750, OSPF Version 2 Management Information Base
·     RFC 4811, OSPF Out-of-Band LSDB Resynchronization
·     RFC 4812, OSPF Restart Signaling
·     RFC 5088, OSPF Protocol Extensions for Path Computation Element (PCE) Discovery
·     RFC 5250, The OSPF Opaque LSA Option
·     RFC 5613, OSPF Link-Local Signaling
·     RFC 5642, Dynamic Hostname Exchange Mechanism for OSPF
·     RFC 5709, OSPFv2 HMAC-SHA Cryptographic Authentication
·     RFC 5786, Advertising a Router's Local Addresses in OSPF Traffic Engineering (TE) Extensions
·     RFC 6571, Loop-Free Alternate (LFA) Applicability in Service Provider (SP) Networks
·     RFC 6860, Hiding Transit-Only Networks in OSPF
·     RFC 6987, OSPF Stub Router Advertisement
To run OSPF, you must first enable OSPF on the router. Make a proper configuration plan to avoid incorrect settings that can result in route blocking and routing loops.
To configure OSPF, perform the following tasks:
1.     Configuring basic OSPF functions
¡     Enabling an OSPF process
¡     Creating an OSPF area
¡     Enabling OSPF
¡     Configuring OSPF dynamic host name mappings
2.     (Optional.) Configuring OSPF stub and NSSA areas
¡     Configuring a stub area
¡     Configuring an NSSA area
¡     Configuring a virtual link
3.     (Optional.) Configuring OSPF network types
¡     Configuring the broadcast network type for an interface
¡     Configuring the NBMA network type for an interface
¡     Configuring the P2MP network type for an interface
¡     Configuring the P2P network type for an interface
4.     (Optional.) Configuring OSPF route control
¡     Configuring OSPF inter-area route summarization
¡     Configuring redistributed route summarization
¡     Configuring received OSPF route filtering
¡     Configuring Type-3 LSA filtering
¡     Setting an OSPF cost for an interface
¡     Setting the maximum number of ECMP routes
¡     Setting OSPF preference
¡     Configuring discard routes for summary networks
¡     Redistributing routes from another routing protocol
¡     Redistributing a default route
¡     Advertising a host route
¡     Advertising OSPF link state information to BGP
5.     (Optional.) Setting OSPF timers
¡     Configuring OSPF packet timers
¡     Setting LSA transmission delay
¡     Setting SPF calculation interval
¡     Setting the minimum LSA arrival interval
¡     Setting the LSA update interval
¡     Setting OSPF exit overflow interval
6.     (Optional.) Configuring OSPF packet parameters
¡     Disabling interfaces from receiving and sending OSPF packets
¡     Adding the interface MTU into DD packets
¡     Setting the DSCP value for outgoing OSPF packets
¡     Enabling OSPF to limit the LSU packet transmission rate
7.     (Optional.) Controlling LSA generation, advertisement, and reception
¡     Setting the maximum number of external LSAs in LSDB
¡     Filtering outbound LSAs on an interface
¡     Filtering LSAs for the specified neighbor
8.     (Optional.) Accelerating OSPF convergence speed
¡     Enabling OSPF ISPF
¡     Configuring prefix suppression
¡     Configuring prefix prioritization
¡     Configuring OSPF PIC
9.     (Optional.) Configuring advanced OSPF features
¡     Configuring stub routers
¡     Configuring OSPF isolation
¡     Configuring OSPF shutdown
¡     Enabling compatibility with RFC 1583
¡     Enabling OSPF to group ECMP routes
10.     (Optional.) Enhancing OSPF availability
¡     Configuring OSPF GR
¡     Configuring OSPF NSR
¡     Configuring BFD for OSPF
¡     Configuring OSPF FRR
¡     Enabling OSPF to adjust the interface cost according to the link quality
11.     (Optional.) Configuring OSPF security features
¡     Configuring OSPF authentication
¡     Configuring GTSM for OSPF
12.     (Optional.) Configuring OSPF logging and SNMP notifications
¡     Logging neighbor state changes
¡     Configuring the OSPF logging feature
¡     Configuring OSPF network management
2.     (Optional.) Configure a global router ID.
router id router-id
By default, no global router ID is configured.
If no global router ID is configured, the highest loopback interface IP address, if any, is used as the router ID. If no loopback interface IP address is available, the highest physical interface IP address is used, regardless of the interface status (up or down).
3.     Enter OSPF view.
ospf [ process-id | router-id { auto-select | router-id } | vpn-instance vpn-instance-name ] *
By default, OSPF is disabled.
4.     (Optional.) Configure a description for the OSPF process.
By default, no description is configured for the OSPF process.
As a best practice, configure a description for each OSPF process.
router id router-id
3.     Enter OSPF view.
5.     Create an OSPF area and enter OSPF area view.
area area-id
6.     (Optional.) Configure a description for the area.
By default, no description is configured for the area.
As a best practice, configure a description for each OSPF area.
Enabling OSPF
To enable OSPF on a router, you must perform the following tasks:
1.     Create an OSPF process.
2.     Create an OSPF area for the process.
3.     Specify a network in the area.
The interface attached to the network will run the OSPF process in the area. OSPF advertises direct routes of the interface.
OSPF supports multiple processes. To run multiple OSPF processes, you must specify an ID for each process. The process IDs take effect locally and has no influence on packet exchange between routers. Two routers with different process IDs can exchange packets.
OSPF supports multiple VPNs. You can configure an OSPF process to run in a VPN instance. An OSPF process with no VPN instance specified runs on the public network. For more information about VPN, see MPLS Configuration Guide.
Restrictions and guidelines for enabling OSPF
When you configure OSPF on an interface, follow these restrictions and guidelines:
·     You can enable OSPF on the network where the interface resides or directly enable OSPF on that interface. If you configure both, the latter takes precedence.
·     If the specified OSPF process and area do not exist, the operation creates an OSPF process and area for the interface. Disabling an OSPF process on an interface does not delete the OSPF process or the area.
Enabling OSPF on a network
2.     Enter OSPF view.
3.     Create an OSPF area and enter OSPF area view.
area area-id
4.     Specify a network to enable the interface attached to the network to run the OSPF process in the area.
By default, no network is specified to enable OSPF on the interface attached to the network.
A network can be added to only one area.
Enabling OSPF on an interface
2.     Enter interface view.
3.     Enable an OSPF process on the interface.
By default, OSPF is disabled on an interface.
OSPF uses a router ID to uniquely identify a router in an AS. The length of router IDs is fixed at 4 bytes. It is inconvenient for the network administrator to memorize the router IDs in dotted decimal notation when verifying the OSPF neighbor relationships, routing tables, and LSDBs.
This task allows you to map a router ID to a host name. The mapping table is maintained by OSPF routers. Host names are more straightforward than router IDs in network maintenance, management, and failure diagnosis.
OSPF uses Type-10 LSAs and Type-11 LSAs to carry information about the dynamic host name attribute. Therefore, make sure the opaque LSA reception and advertisement capability is enabled.
2.     Enable OSPF, and enter OSPF view.
3.     Enable the opaque LSA reception and advertisement capability.
opaque-capability enable
By default, the opaque LSA reception and advertisement capability is enabled.
4.     Enable the OSPF dynamic host name mapping feature.
hostname [ host-name ]
By default, the OSPF dynamic host name mapping feature is disabled.
This task allows you to configure an OSPF area as a stub area or NSSA area. It also allows you to create a virtual link if no connectivity can be achieved between a non-backbone area and backbone area, or in the backbone area.
You can configure a non-backbone area at an AS edge as a stub area. To do so, execute the stub command on all routers attached to the area. The routing table size is reduced because Type-5 LSAs will not be flooded within the stub area. The ABR generates a default route into the stub area so all packets destined outside of the AS are sent through the default route.
To further reduce the routing table size and routing information exchanged in the stub area, configure a totally stub area by using the stub no-summary command on the ABR. AS external routes and inter-area routes will not be distributed into the area. All the packets destined for outside of the AS or area will be sent to the ABR for forwarding.
A stub or totally stub area cannot have an ASBR because external routes cannot be distributed into the area.
Do not configure the backbone area as a stub area or totally stub area.
To configure an area as a stub area, execute the stub command on all routers attached to the area.
To configure an area as a totally stub area, execute the stub command on all routers attached to the area, and execute the stub no-summary command on the ABR.
2.     Enter OSPF view.
3.     Enter area view.
area area-id
4.     Configure the area as a stub area.
By default, no stub area is configured.
5.     (Optional.) Set a cost for the default route advertised to the stub area.
default-cost cost-value
By default, the cost for the default route advertised to the stub area is 1.
This command takes effect only on the ABR of a stub area or totally stub area.
A stub area cannot import external routes, but an NSSA area can import external routes into the OSPF routing domain while retaining other stub area characteristics.
To configure an area as a totally NSSA area, use the nssa no-summary command. The ABR of the area does not advertise inter-area routes into the area.
Do not configure the backbone area as an NSSA area or totally NSSA area.
To configure an NSSA area, configure the nssa command on all the routers attached to the area.
To configure a totally NSSA area, configure the nssa command on all the routers attached to the area and configure the nssa no-summary command on the ABR.
2.     Enter OSPF view.
3.     Enter area view.
area area-id
4.     Configure the area as an NSSA area.
nssa [ default-route-advertise [ cost cost-value | nssa-only | route-policy route-policy-name | type type ] * | no-import-route | no-summary | suppress-fa | [ [ [ translate-always ] [ translate-ignore-checking-backbone ] ] | translate-never ] | translator-stability-interval value ] *
By default, no area is configured as an NSSA area.
5.     (Optional.) Set a cost for the default route advertised to the NSSA area.
By default, the cost for the default route advertised to the NSSA area is 1.
This command takes effect only on the ABR/ASBR on an NSSA area or totally NSSA area.
You can configure a virtual link to maintain connectivity between a non-backbone area and the backbone, or in the backbone itself.
A virtual link cannot traverse a stub area, totally stub area, NSSA area, or totally NSSA area.
2.     Enter OSPF view.
area area-id
4.     Configure a virtual link.
vlink-peer router-id [ dead seconds | hello seconds | { { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string | keychain keychain-name | simple { cipher | plain } string } | retransmit seconds | trans-delay seconds ] *
Configure this command on both ends of a virtual link. The hello and dead intervals must be identical on both ends of the virtual link.
Based on the link layer protocol, OSPF classifies networks into different types, including broadcast, NBMA, P2MP, and P2P.
When an NBMA network becomes fully meshed, change the network type to broadcast to avoid manual configuration of neighbors.
If any routers in a broadcast network do not support multicasting, change the network type to NBMA.
An NBMA network must be fully meshed. OSPF requires that an NBMA network be fully meshed. If a network is partially meshed, change the network type to P2MP.
If only two routers running OSPF exist on a network segment, you can change the network type to P2P to save costs.
Two broadcast-, NBMA-, and P2MP-interfaces can establish a neighbor relationship only when they are on the same network segment.
3.     Configure the OSPF network type for the interface as broadcast.
ospf network-type broadcast
By default, the network type of an interface depends on the link layer protocol.
When the link layer protocol is Ethernet or FDDI, OSPF classifies the network type as broadcast by default.
4.     (Optional.) Set a router priority for the interface.
ospf dr-priority priority
The default router priority is 1.
After you configure the network type as NBMA, you must specify neighbors and their router priorities because NBMA interfaces cannot find neighbors by broadcasting hello packets.
3.     Configure the OSPF network type for the interface as NBMA.
ospf network-type nbma
When the link layer protocol is Frame Relay, ATM, or X.25, OSPF classifies the network type as NBMA by default.
The default router priority for an interface is 1.
The router priority configured with this command is for DR election.
5.     Return to system view.
6.     Enter OSPF view.
7.     Specify an NBMA neighbor.
peer ip-address [ dr-priority priority ]
By default, no neighbor is specified.
The priority configured with this command indicates whether a neighbor has the election right or not. If you configure the router priority for a neighbor as 0, the local router determines the neighbor has no election right. It does not send hello packets to this neighbor. However, if the local router is the DR or BDR, it still sends hello packets to the neighbor for neighbor relationship establishment.
3.     Configure the OSPF network type for the interface as P2MP.
ospf network-type p2mp [ unicast ]
After you configure the OSPF network type for an interface as P2MP unicast, all packets are unicast over the interface. The interface cannot broadcast hello packets to discover neighbors, so you must manually specify the neighbors.
4.     Return to system view.
5.     Enter OSPF view.
6.     Specify a P2MP neighbor.
peer ip-address [ cost cost-value ]
This step is required if the interface network type is P2MP unicast.
3.     Configure the OSPF network type for the interface as P2P.
ospf network-type p2p [ peer-address-check ]
When the link layer protocol is PPP, LAPB, or HDLC, OSPF classifies the network type as P2P by default.
This section describes how to control the advertisement and reception of OSPF routing information, as well as route redistribution from other protocols.
OSPF inter-area route summarization reduces the routing information exchanged between areas and the size of routing tables, and improves routing performance.
OSPF inter-area route summarization enables an ABR to summarize contiguous networks into a single network and advertise the network to other areas. For example, three internal networks 19.1.1.0/24, 19.1.2.0/24, and 19.1.3.0/24 are available within an area. You can configure the ABR to summarize the three networks into network 19.1.0.0/16, and advertise the summary network to other areas in a Type-3 LSA. This configuration reduces the scale of LSDBs on routers in other areas and the influence of topology changes.
2.     Enter OSPF view.
area area-id
4.     Configure ABR route summarization.
abr-summary ip-address { mask-length | mask } [ advertise | not-advertise ] [ cost cost-value ]
By default, route summarization is not configured on an ABR.
Perform this task to enable an ASBR to summarize external routes within the specified address range into a single route. The ASBR advertises only Type-5 LSAs to reduce the number of LSAs in the LSDB.
An ASBR can summarize routes in the following LSAs:
·     Type-5 LSAs.
·     Type-7 LSAs in an NSSA area.
If an ASBR (also an ABR) is a translator in an NSSA area, it summarizes routes in Type-5 LSAs translated from Type-7 LSAs. If it is not a translator, it does not summarize routes in in Type-5 LSAs translated from Type-7 LSAs.
2.     Enter OSPF view.
3.     Configure ASBR route summarization.
asbr-summary ip-address { mask-length | mask } [ cost cost-value | not-advertise | nssa-only | tag tag ] *
By default, route summarization is not configured on an ASBR.
Perform this task to filter routes calculated using received LSAs.
The following filtering methods are available:
·     Use an ACL or IP prefix list to filter routing information by destination address.
·     Use the gateway prefix-list-name option to filter routing information by next hop.
·     Use an ACL or IP prefix list to filter routing information by destination address. At the same time use the gateway prefix-list-name option to filter routing information by next hop.
·     Use the route-policy route-policy-name option to filter routing information.
2.     Enter OSPF view.
3.     Configure OSPF to filter routes calculated using received LSAs.
filter-policy { ipv4-acl-number [ gateway prefix-list-name ] | gateway prefix-list-name | prefix-list prefix-list-name [ gateway prefix-list-name ] | route-policy route-policy-name } import
By default, OSPF accepts all routes calculated by using received LSAs.
Perform this task to filter Type-3 LSAs advertised into the local area or other areas on an ABR.
2.     Enter OSPF view.
area area-id
4.     Configure Type-3 LSA filtering.
filter { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import }
By default, the ABR does not filter Type-3 LSAs.
Set an OSPF cost for an interface by using either of the following methods:
·     Set the cost value in interface view.
·     Set a bandwidth reference value for the interface. OSPF computes the cost with this formula: Interface OSPF cost = Bandwidth reference value (100 Mbps) / Expected interface bandwidth (Mbps). The expected bandwidth of an interface is configured with the bandwidth command (see Interface Command Reference).
¡     If the calculated cost is greater than 65535, the value of 65535 is used. If the calculated cost is less than 1, the value of 1 is used.
¡     If no cost or bandwidth reference value is configured for an interface, OSPF computes the interface cost based on the interface bandwidth and default bandwidth reference value.
3.     Set an OSPF cost for the interface.
ospf cost cost-value
By default, the OSPF cost is calculated according to the interface bandwidth. For a loopback interface, the OSPF cost is 0 by default.
Setting a bandwidth reference value
2.     Enter OSPF view.
3.     Set a bandwidth reference value.
bandwidth-reference value
The default setting is 100 Mbps.
OSPF might find multiple optimal equal-cost routes to the same destination, which can be used to share the traffic load. This task allows you to set the maximum number of ECMP routes for OSPF.
As shown in Figure 9, Device A and Device B run OSPF. There are three equal-cost routes between Device A and Device B. You can use these routes to implement load sharing.
Figure 9 Equal-cost routes
2.     Enter OSPF view.
3.     Set the maximum number of ECMP routes.
maximum load-balancing number
By default, the maximum number of ECMP routes equals the maximum number of ECMP routes supported by the system.
A router can run multiple routing protocols, and each protocol is assigned a preference. If multiple routes are available to the same destination, the one with the highest protocol preference is selected as the best route.
2.     Enter OSPF view.
3.     Set a preference for OSPF.
By default, the preference of OSPF internal routes is 10 and the preference of OSPF external routes is 150.
Perform this task on an ABR or ASBR to specify whether to generate discard routes for summary networks. You can also specify a preference for the discard routes.
2.     Enter OSPF view.
3.     Configure discard routes for summary networks.
discard-route { external { preference | suppression } | internal { preference | suppression } } *
By default, the ABR or ASBR generates discard routes for summary networks and the default preference of discard routes is 255.
When an OSPF device does not have routes from a non-OSPF routing protocol, it cannot access any devices that run that non-OSPF routing protocol. To resolve this issue, you can configure OSPF to redistribute routes from other protocols, such as IS-IS and BGP. OSPF can then advertise the routes in Type-5 LSAs or Type-7 LSAs.
In addition, you can configure OSPF to filter redistributed routes so that OSPF advertises only permitted routes.
Although OSPF is a dynamic routing protocol that provides loop-free intra-area/inter-area routes, this protocol is not good at guarding against the routing loops caused by redistributed external routes. When you configure route redistribution for OSPF, make sure you have understood the potential impact.
OSPF redistributes only active routes. To view route status information, use the display ip routing-table protocol command.
2.     Enter OSPF view.
3.     Configure route redistribution.
import-route bgp [ as-number ] [ allow-ibgp ] [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { direct | guard | static } [ [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route eigrp [ eigrp-as | all-as ] [ allow-direct | [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
import-route { isis | ospf | rip } [ process-id | all-processes ] [ allow-direct | [ cost cost-value | inherit-cost ] | nssa-only | route-policy route-policy-name | tag tag | type type ] *
By default, OSPF does not redistribute routes.
The import-route bgp command redistributes only EBGP routes. The import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes, which might cause routing loops. Therefore, use it with caution.
4.     (Optional.) Configure OSPF to filter redistributed routes.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name } export [[ bgp | direct | eigrp [ eigrp-as ] | { isis | ospf | rip } [ process-id ] | static ]
By default, OSPF accepts all redistributed routes.
5.     Configure the default parameters for redistributed routes (cost, tag, and type).
default { cost cost-value | tag tag | type type } *
By default, the cost is 1, the tag is 1, and the route type is 2
On a OSPF network, multiple ABRs and ASBRs work together to implement multi-egress redundancy or load balancing. To ease the service burden on these devices and save the capacity of the routing table, you can configure default routes.
OSPF default routes are mostly used in the following scenarios:
·     After receiving a Type 3 LSA that describes a default route from the ABR, the intra-area router can use the route for packet forwarding to another area in the same AS.
·     After receiving a Type 5 or 7 LSA that describes a default route from the ASBR, the intra-area router can use the route for packet forwarding to another AS.
When a router cannot find a exactly matching route, it can use the default route for packet forwarding. The default route originated from a Type 3 LSA takes precedence over that originated from a Type 5 LSA.
As shown in Table 3, the advertisement method for a redistributed default route varies by its area type.
Table 3 Advertisement of redistributed default routes
Area type
Route redistribution condition
Advertiser
LSA type
LSA flooding scope
Common area
Use the default-route-advertise command.
ASBR
Type 5 LSA
Common area
Stub area
Automatic route redistribution.
ABR
Type 3 LSA
Stub area
NSSA area
Use the nssa [ default-route-advertise ] command.
ASBR
Type 7 LSA
NSSA area
Totally NSSA area
ABR
Type 3 LSA
NSSA area
The import-route command cannot redistribute a default route from an external routing protocol. To resolve this issue, perform this task on the ASBR to redistribute a default route.
After receiving a default route from the ASBR, the device can add the default route to its routing table only in one of the following scenarios:
·     The device does not have a static route.
·     The device has a static route, but the priority value for the default route is higher than that for the static route.
2.     Enter OSPF view.
3.     Redistribute a default route.
default-route-advertise [ [ always | permit-calculate-other ] | cost cost-value | route-policy route-policy-name | type type ] *
default-route-advertise [ summary cost cost-value ]
By default, no default route is redistributed.
This command is applicable only to VPNs. The PE router advertises a default route in a Type-3 LSA to a CE router.
4.     Configure the default parameters for redistributed routes (cost, tag, and type).
2.     Enter OSPF view.
3.     Enter area view.
area area-id
4.     Advertise a host route.
host-advertise ip-address cost-value
By default, OSPF does not advertise host routes that are not in the area.
After the device advertises OSPF link state information to BGP, BGP can advertise the information for intended applications. For more information about BGP LS, see "Configuring BGP."
2.     Enter OSPF view.
3.     Advertise OSPF link state information to BGP.
distribute bgp-ls [ instance-id id ] [ strict-link-checking ]
By default, the device does not advertise OSPF link state information to BGP.
Setting OSPF timers
This task allows you to change OSPF packet timers to adjust the convergence speed and network load and tune the delay time for sending LSAs on low-speed links.
An OSPF interface includes the following timers:
·     Hello timerInterval for sending hello packets. It must be identical on OSPF neighbors.
·     Poll timerInterval for sending hello packets to a neighbor that is down on the NBMA network.
·     Dead timerInterval within which if the interface does not receive any hello packet from the neighbor, it declares the neighbor is down.
·     LSA retransmission timerInterval within which if the interface does not receive any acknowledgment packets after sending an LSA to the neighbor, it retransmits the LSA.
The default value for the hello interval and neighbor dead interval depends on the network type. When the network type for an interface is changed, the default hello interval and neighbor dead interval are restored. Make sure two neighboring interfaces are configured with the same hello interval and neighbor dead interval. Inconsistent settings will affect the OSPF neighbor relationship establishment.
3.     Set the hello interval.
ospf timer hello seconds
The default hello interval on P2P and broadcast interfaces is 10 seconds. The default hello interval on P2MP and NBMA interfaces is 30 seconds.
4.     Set the poll interval.
ospf timer poll seconds
The default setting is 120 seconds.
The poll interval is a minimum of four times the hello interval.
5.     Set the dead interval.
ospf timer dead seconds
The default dead interval on P2P and broadcast interfaces is 40 seconds. The default dead interval on P2MP and NBMA interfaces is 120 seconds.
The dead interval must be a minimum of four times the hello interval on an interface.
6.     Set the retransmission interval.
ospf timer retransmit interval
The default retransmission interval is 5 seconds.
A retransmission interval setting that is too small can cause unnecessary LSA retransmissions. Typically set a bigger interval than the round-trip time of a packet between two neighbors.
To avoid LSAs from aging out during transmission, set an LSA retransmission delay especially for low speed links.
3.     Set the LSA transmission delay.
ospf trans-delay seconds
The default LSA transmission delay is 1 second.
LSDB changes result in SPF calculations. When the topology changes frequently, a large amount of network and router resources are occupied by SPF calculation. You can adjust the SPF calculation interval to reduce the impact.
For a stable network, the minimum interval is used. If network changes become frequent, the SPF calculation interval increases by the incremental interval × 2n-2 for each calculation until the maximum interval is reached. The value n is the number of calculation times.
2.     Enter OSPF view.
3.     Set the SPF calculation interval.
spf-schedule-interval { maximum-interval [ minimum-interval [ incremental-interval ] ] | millisecond interval }
By default, the maximum interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
OSPF drops any duplicate LSAs (with the same LSA type, LS ID, and router ID) within the minimum LSA arrival interval. This helps avoid overuse of bandwidth and router resources due to frequent network changes.
On a stable network, you can set the LSA arrival interval to 0 to fasten route convergence.
2.     Enter OSPF view.
3.     Set the minimum LSA arrival interval.
lsa-arrival-interval interval
By default, the minimum LSA arrival interval is 1000 milliseconds.
Adjust the LSA update interval to protect network resources and routers from being overwhelmed by LSAs at the time of frequent network changes.
For a stable network, the minimum interval is used. If network changes become frequent, the LSA update interval increases by the incremental interval × 2n-2 for each update until the maximum interval is reached. The value n is the number of update times.
2.     Enter OSPF view.
3.     Set the LSA update interval.
When the number of LSAs in the LSDB exceeds the upper limit, the LSDB is in an overflow state. In this state, OSPF does not receive any external LSAs and deletes the external LSAs generated by itself to save system resources.
This task allows you to configure the interval that OSPF exits overflow state.
2.     Enter OSPF view.
3.     Set the interval that OSPF exits overflow state.
By default, the OSPF exit overflow interval is 300 seconds. An interval of 0 means that OSPF does not exit overflow state.
To enhance OSPF adaptability and reduce resource consumption, you can set an OSPF interface to "silent." A silent OSPF interface blocks OSPF packets and cannot establish any OSPF neighbor relationship. However, other interfaces on the router can still advertise direct routes of the interface in Router LSAs.
2.     Enter OSPF view.
3.     Disable interfaces from receiving and sending OSPF packets.
By default, an OSPF interface can receive and send OSPF packets.
This command disables only the interfaces associated with the current process rather than other processes. Multiple OSPF processes can disable the same interface from receiving and sending OSPF packets.
By default, an OSPF interface adds a value of 0 into the interface MTU field of a DD packet rather than the actual interface MTU. On receipt of a DD packet, the interface does not check the interface MTU field of that packet. Such a mechanism ensures that two interfaces in different devices can establish a neighbor relationship regardless of the interface MTU. However, the device cannot establish neighbor relationships with the devices from another manufacturer that discard the DD packets whose interface MTU value is 0.
To resolve this issue, perform this task to enable an OSPF interface to add its interface MTU into DD packets and check the interface MTU in received DD packets. If the interface MTU in a received DD packet is higher than the MTU of the local interface, the interface will discard the DD packet. To ensure that two interfaces in different devices can establish a neighbor relationship, set the same MTU for these interfaces.
3.     Enable the interface to add its MTU into DD packets.
ospf mtu-enable
By default, the interface adds an MTU value of 0 into DD packets.
The DSCP value specifies the precedence of outgoing packets.
2.     Enter OSPF view.
3.     Set the DSCP value for outgoing OSPF packets.
dscp dscp-value
By default, the DSCP value for outgoing OSPF packets is 48.
OSPF might send a large number of LSU packets during LSDB synchronization with neighbors (especially when the local device establishes has many OSPF neighbors). In this situation, the neighbors are so busy with processing the received LSU packets that they might drop hello packets, causing neighbor relationship termination. To re-establish the neighbor relationships, the devices must exchange a larger number of LSU packets with neighboring devices, which worsens the issue.
To avoid the issue, perform this task to set the maximum LSU transmission rate on the device. The LSU packet transmission rate of each OSPF interface on the device will be limited.
After you configure the ospf lsu-flood-control interval max-count-value command, the maximum LSU packet transmission rate for each OSPF interface is X/N, rounded down. N is the total number of OSPF interfaces on the device, and X is the maximum LSU packet transmission rate specified by this command. Each OSPF interface running in an OSPF process should transmit LSU packets at a rate that is not larger than X/N. OSPF limits the LSU packet transmission rate of the OSPF process as follows:
·     If the total LSU packet transmission rate of the OSPF process exceeds the upper limit specified by the transmit-pacing command, the system performs the following operations:
a.     Within the interval specified by the interval argument of the transmit-pacing command, the system no longer processes the LSU packet transmission requests initiated by the process.
b.     After the specified interval, if the process still has LSU packets to transmit, the system processes LSU transmission requests of the process at the lowest priority. It preferentially processes the LSU packet transmission requests from other OSPF processes that have not yet sent any LSU packets.
·     If the total LSU packet transmission rate in the OSPF process does not exceed the upper limit specified by the transmit-pacing command, the system processes the subsequent LSU transmission requests of the process at the lowest priority. It preferentially processes the LSU packet transmission requests from other OSPF processes that have not yet sent any LSU packets.
The above mechanism can limit the LSU packet transmission rate of the whole device and evenly process the LSU packet transmission requests of OSPF processes.
Configure the LSU packet transmission rate with caution, because inappropriate configuration might cause route anomalies. As a best practice in most cases, use the default setting.
Configuring OSPF to limit the LSU packet transmission rate of the whole device
2.     Configure OSPF to limit the LSU packet transmission rate of the whole device.
ospf lsu-flood-control { interval max-count-value | disable }
OSPF limits the LSU packet transmission rate of the device.
Configuring the LSU packet transmission rate for an OSPF process
2.     Enter OSPF view.
3.     Set the LSU transmit interval and the maximum number of LSUs that can be sent at each interval.
By default, an OSPF interface sends a maximum of three LSU packets every 20 milliseconds.
2.     Enter OSPF view.
3.     Set the maximum number of external LSAs in the LSDB.
lsdb-overflow-limit number
By default, the maximum number of external LSAs in the LSDB is not limited.
To reduce the LSDB size for the neighbor and save bandwidth, you can perform this task on an interface to filter LSAs to be sent to the neighbor.
3.     Filter outbound LSAs on the interface.
ospf database-filter { all | { ase [ acl ipv4-acl-number ] | nssa [ acl ipv4-acl-number ] | summary [ acl ipv4-acl-number ] } * }
By default, the outbound LSAs are not filtered on the interface.
On a P2MP network, a router might have multiple P2MP type OSPF neighbors. Perform this task to prevent the router from sending LSAs to the specified P2MP neighbor.
2.     Enter OSPF view.
3.     Filter LSAs for the specified P2MP neighbor.
database-filter peer ip-address { all | { ase [ acl ipv4-acl-number ] | nssa [ acl ipv4-acl-number ] | summary [ acl ipv4-acl-number ] } * }
By default, the LSAs for the specified P2MP neighbor are not filtered.
Enabling OSPF ISPF
When the topology changes, Incremental Shortest Path First (ISPF) computes only the affected part of the SPT, instead of the entire SPT.
2.     Enter OSPF view.
3.     Enable OSPF ISPF.
ispf enable
By default, OSPF ISPF is enabled.
By default, an OSPF interface advertises all of its prefixes in LSAs. To speed up OSPF convergence, you can suppress interfaces from advertising all of their prefixes. This feature helps improve network security by preventing IP routing to the suppressed networks.
When prefix suppression is enabled:
·     On P2P and P2MP networks, OSPF does not advertise Type-3 links in Type-1 LSAs. Other routing information can still be advertised to ensure traffic forwarding.
·     On broadcast and NBMA networks, the DR generates Type-2 LSAs with a mask length of 32 to suppress network routes. Other routing information can still be advertised to ensure traffic forwarding. If no neighbors exist, the DR does not advertise Type-3 links in Type-1 LSAs.
Restrictions and guidelines for prefix suppression
As a best practice, configure prefix suppression on all OSPF routers if you want to use prefix suppression.
Configuring prefix suppression for an OSPF process
2.     Enter OSPF view.
3.     Enable prefix suppression for the OSPF process.
prefix-suppression
By default, prefix suppression is disabled for an OSPF process.
This feature does not suppress the prefixes of secondary IP addresses, loopback interfaces, and passive interfaces.
Configuring prefix suppression for an interface
3.     Enable prefix suppression for the interface.
By default, prefix suppression is disabled on an interface.
This feature does not suppress prefixes of secondary IP addresses.
OSPF calculates intra-area routes, inter-area routes, and AS external routes in descending convergence priority order: critical, high, medium, and low. When a route has multiple prefix priorities, it uses the highest priority.
To prioritize the convergence of specific routes, perform this task to set a higher convergence priority value for those routes.
2.     Configure an IPv4 prefix list.
3.     Configure a routing policy.
4.     Use the IPv4 prefix list as an IPv4 route filter.
if-match ip { address | next-hop | route-source } prefix-list prefix-list-name
By default, no IPv4 route filters are configured.
5.     Set a prefix priority for matching routes.
By default, no prefix priority is set.
6.     Return to system view.
7.     Enter OSPF view.
8.     Enable prefix prioritization.
By default, prefix prioritization is disabled.
Prefix Independent Convergence (PIC) enables the device to speed up network convergence by ignoring the number of prefixes.
Restrictions and guidelines for OSPF PIC
When both OSPF PIC and OSPF FRR are configured, OSPF FRR takes effect.
OSPF PIC applies only to inter-area routes and external routes.
Enabling OSPF PIC
2.     Enter OSPF view.
3.     Enable PIC for OSPF.
By default, OSPF PIC is enabled.
Configuring BFD control packet mode for OSPF PIC
3.     Enable BFD control packet mode for OSPF PIC.
ospf primary-path-detect bfd ctrl
By default, BFD control packet mode is disabled for OSPF PIC.
This mode requires BFD configuration on both OSPF routers on the link.
Configuring BFD echo packet mode for OSPF PIC
2.     (Optional.) Configure the source IP address of BFD echo packets.
bfd echo-source-ip ip-address
By default, the source IP address of BFD echo packets is not configured.
To avoid network congest caused by too many ICMP redirect packets, use this feature and the specified source IP address cannot be on the same network segment as any local interfaces.
For more information about this command, see High Availability Command Reference.
3.     Enter interface view.
4.     Enable BFD echo packet mode for OSPF PIC.
ospf primary-path-detect bfd echo
By default, BFD echo packet mode is disabled for OSPF PIC.
This mode requires BFD configuration on one OSPF router on the link.
A stub router is used for traffic control. It reports its status as a stub router to neighboring OSPF routers. The neighboring routers can have a route to the stub router, but they do not use the stub router to forward data.
Router LSAs from the stub router might contain different link type values. A value of 3 means a link to a stub network, and the cost of the link will not be changed by default. To set the cost of the link to 65535, specify the include-stub keyword in the stub-router command. A value of 1, 2 or 4 means a point-to-point link, a link to a transit network, or a virtual link. On such links, a maximum cost value of 65535 is used. Neighbors do not send packets to the stub router as long as they have a route with a smaller cost.
As shown in Figure 10, Device A, Device B, Device C, and Device D run OSPF. Device C is the backup device for Device B. Device A and Device B, Device A and Device C, Device B and Device D, and Device C and Device D are IBGP peers.
When the network is stable, BGP and OSPF can finish route convergence completely. Device A forwards traffic destined for 10.3.1.0/30 to Device B. If Device B fails, Device C will take over to forward the traffic from Device A.
After Device B recovers, Device A immediately forwards the traffic to Device B. However, BGP might have not finished route convergence after OSPF has finished route convergence, because OSPF has a higher route convergence speed than BGP. In this situation, Device B does not have a route to 10.3.1.0/30 and will discard the traffic destined for 10.3.1.0/30. To resolve this issue, configure Device B to act as a stub router during BGP route convergence. Device A will forward traffic to Device C instead of Device B until Device B finishes BGP route convergence.
Figure 10 Network diagram
2.     Enter OSPF view.
3.     Configure the router as a stub router.
stub-router [ external-lsa [ max-metric-value ] | include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } | summary-lsa [ max-metric-value ] ] *
By default, the router is not configured as a stub router.
A stub router is not related to a stub area.
Isolation is a method used for network device maintenance. It gracefully removes a device from the packet forwarding path for maintenance and gracefully adds the device to the network after maintenance.
To reduce impact on traffic forwarding, you can isolate an OSPF device from the network before upgrading it. OSPF isolation works as follows:
1.     After OSPF isolation is enabled for a device, OSPF increases the link cost in LSAs advertised by the device based on the following rules:
¡     The link cost in Type-1 LSAs (Router LSAs) is increased to 65535.
¡     The link cost in the following LSAs is increased to 16711680:
-     Type-3 LSAs (Network Summary LSAs).
-     Type-5 LSAs (AS External LSAs).
-     Type-7 LSAs (NSSA External LSAs).
2.     Each neighbor of the device reselects an optimal route based on the LSAs and stops forwarding traffic to the device. The device is fully isolated from the network and you can upgrade the device.
3.     After the maintenance, disable OSPF isolation on the device to restore its link cost and gracefully add it back to the network.
Both the isolate enable and stub-router external-lsa 16711680 summary-lsa 16711680 include-stub commands can isolate the device from the network.
When you execute both the isolate enable and stub-router commands, follow these restrictions and guidelines:
·     If you specify the external-lsa and summary-lsa keywords in the stub-router command, the higher one of the two link costs provided by the isolation feature and the stub router feature takes effect.
·     If the on-startup keyword is specified in the stub-router command, traffic forwarding path selection is affected only by the isolation feature when the stub router feature does not take effect.
2.     Enter OSPF view.
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ] *
3.     Configure OSPF isolation.
¡     Enable OSPF isolation to gracefully isolate the device from the network.
isolate enable
¡     Disable OSPF isolation to gracefully add the device back to the network.
undo isolate enable
By default, OSPF isolation is disabled.
For maintenance purposes, you can use this feature to shut down OSPF processes on the device with small impact on the network. If you shut down a process, it will perform the following operations:
·     Send 1-way hello packets to its neighbors.
On receipt of the packets, the neighbors disconnect from the OSPF process and use the backup path to forward traffic.
·     Stop receiving and sending OSPF packets.
·     Clear its neighbor, LSDB, and OSPF route information.
After maintenance, you can use the undo shutdown process command to restart the process for neighbor relationship re-establishment.
This feature shuts down an OSPF process while retaining the process-associated settings to facilitate your maintenance.
2.     Enter OSPF view.
3.     Configure OSPF shutdown.
¡     Shut down an OSPF process to isolate it from the network.
shutdown process
¡     Restart the OSPF process to add it back to the network.
By default, the OSPF process is not shut down.
RFC 1583 specifies a different method than RFC 2328 for selecting the optimal route to a destination in another AS. When multiple routes are available to the ASBR, OSPF selects the optimal route by using the following procedure:
1.     Selects the route with the highest preference.
¡     If RFC 2328 is compatible with RFC 1583, all these routes have equal preference.
¡     If RFC 2328 is not compatible with RFC 1583, the intra-area route in a non-backbone area is preferred to reduce the burden of the backbone area. The inter-area route and intra-area route in the backbone area have equal preference.
2.     Selects the route with the lower cost if two routes have equal preference.
3.     Selects the route with the larger originating area ID if two routes have equal cost.
To avoid routing loops, set identical RFC 1583-compatibility on all routers in a routing domain.
2.     Enter OSPF view.
3.     Enable compatibility with RFC 1583.
rfc1583 compatible
By default, compatibility with RFC 1583 is enabled.
Perform this task to enable OSPF to group ECMP routes by prefix to speed up route convergence.
This feature is applicable to a network when the network has a large number of ECMP routes and different route prefixes in the network have the same next hops. For example, OSPF learns 10000 route prefixes and all route prefixes have the same 16 next hops (1.1.1.1 to 1.1.1.16). Without this feature, OSPF has to send all ECMP routes of every route prefix (10000 × 16 routes) to the route management module. After you enable this feature, OSPF groups the ECMP routes by prefix and sends the route groups (10000 route groups) to the route management module.
2.     Enter OSPF view.
3.     Enable OSPF to group ECMP routes.
ecmp-group enable
By default, OSPF does not group ECMP routes.
Configuring OSPF GR
About OSPF GR
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process:
·     GR restarter—Graceful restarting router. It must have GR capability.
·     GR helper—A neighbor of the GR restarter. It helps the GR restarter to complete the GR process.
OSPF GR has the following types:
·     IETF GR—Uses Opaque LSAs to implement GR.
·     Non-IETF GR—Uses link local signaling (LLS) to advertise GR capability and uses out of band synchronization to synchronize the LSDB.
A device can act as a GR restarter and GR helper at the same time.
Restrictions and guidelines for OSPF GR
You cannot enable OSPF NSR on a device that acts as GR restarter.
Configuring OSPF GR restarter
Configuring the IETF OSPF GR restarter
2.     Enable OSPF and enter its view.
3.     Enable opaque LSA reception and advertisement capability.
By default, opaque LSA reception and advertisement capability is enabled.
4.     Enable the IETF GR.
graceful-restart ietf [ global | planned-only ] *
By default, the IETF GR capability is disabled.
5.     (Optional.) Set the GR interval.
By default, the GR interval is 120 seconds.
Configuring the non-IETF OSPF GR restarter
3.     Enable the link-local signaling capability.
enable link-local-signaling
By default, the link-local signaling capability is disabled.
4.     Enable the out-of-band re-synchronization capability.
enable out-of-band-resynchronization
By default, the out-of-band re-synchronization capability is disabled.
5.     Enable non-IETF GR.
graceful-restart [ nonstandard ] [ global | planned-only ] *
By default, non-IETF GR capability is disabled.
6.     (Optional.) Set the GR interval.
Configuring OSPF GR helper
Configuring the IETF OSPF GR helper
4.     Enable GR helper capability.
By default, GR helper capability is enabled.
5.     (Optional.) Enable strict LSA checking for the GR helper.
graceful-restart helper strict-lsa-checking
By default, strict LSA checking for the GR helper is disabled.
When an LSA change on the GR helper is detected, the GR helper device exits the GR helper mode.
Configuring the non-IETF OSPF GR helper
5.     Enable GR helper.
By default, GR helper is enabled.
6.     (Optional.) Enable strict LSA checking for the GR helper.
Triggering OSPF GR
You can trigger OSPF GR by performing an active/standby switchover or using the reset ospf process command.
To trigger OSPF GR, execute the reset ospf [ process-id ] process graceful-restart command in user view.
Nonstop routing (NSR) backs up OSPF link state information from the active process to the standby process. After an active/standby switchover, NSR can complete link state recovery and route regeneration without tearing down adjacencies or impacting forwarding services.
Choose OSPF NSR or OSPF GR according to the actual situation and make sure data forwarding is not interrupted. The differences between OSPF NSR and OSPF GR as follows:
·     Device requirements—The active and standby processes of OSPF must run on different IRF member devices. To run OSPF NSR, you must set up an IRF fabric that contains a minimum of two member devices. To run OSPF GR, IRF fabric setup is not required. If an IRF fabric already exists, you can run OSPF GR when the IRF fabric contains only one member device.
·     OSPF neighbor requirements—When you use OSPF NSR, OSPF neighbors cannot detect process restart or active/standby switchover on the local device. OSPF NSR can recover OSPF route information without requiring the cooperation of OSPF neighbors. OSPF GR requires OSPF neighbors to have the GR helper capability to help the GR restarter complete the GR process.
Hardware and feature compatibility
Hardware
Feature compatibility
MSR610
No
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LM-EA, MSR810-LM-EI
No
MSR810-LMS, MSR810-LUS
No
MSR810-SI, MSR810-LM-SI
No
MSR810-LMS-EA, MSR810-LME
No
MSR1004S-5G, MSR1004S-5G-CN
No
MSR1104S-W, MSR1104S-W-CAT6, MSR1104S-5G-CN, MSR1104S-W-5G-CN, MSR1104S-W-5GGL
No
MSR2600-6-X1, MSR2600-15-X1, MSR2600-15-X1-T
·     In standalone mode: No
·     In IRF mode: Yes
MSR2600-10-X1
No
MSR 2630
·     In IRF mode: Yes
MSR3600-28, MSR3600-51
·     In IRF mode: Yes
MSR3600-28-SI, MSR3600-51-SI
No
·     In IRF mode: Yes
MSR3600-28-G-DP, MSR3600-51-G-DP
·     In IRF mode: Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR-EAD-AK770, MSR3610-I-IG, MSR3610-IE-IG
No
MSR-iMC
No
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, MSR3640-X1
·     In IRF mode: Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
·     In IRF mode: Yes
MSR3610-G, MSR3620-G
·     In IRF mode: Yes
MSR3640-G
·     In IRF mode: Yes
MSR3640-X1-HI
·     In IRF mode: Yes
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
No
MSR830-4LM-WiNet
No
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
No
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
No
MSR2600-6-WiNet
·     In IRF mode: Yes
MSR2600-10-X1-WiNet
No
MSR2630-WiNet
·     In IRF mode: Yes
MSR3600-28-WiNet
·     In IRF mode: Yes
MSR3610-X1-WiNet
·     In IRF mode: Yes
MSR3620-X1-WiNet
·     In IRF mode: Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
·     In IRF mode: Yes
Hardware
MSR860-6EI-XS
No
MSR860-6HI-XS
No
MSR2630-XS
·     In IRF mode: Yes
MSR3600-28-XS
·     In IRF mode: Yes
MSR3610-XS
·     In IRF mode: Yes
MSR3620-XS
·     In IRF mode: Yes
MSR3610-I-XS
No
MSR3610-IE-XS
No
MSR3620-X1-XS
·     In IRF mode: Yes
MSR3640-XS
·     In IRF mode: Yes
MSR3660-XS
·     In IRF mode: Yes
Hardware
MSR810-LM-GL
No
MSR810-W-LM-GL
No
MSR830-6EI-GL
No
MSR830-10EI-GL
No
MSR830-6HI-GL
No
MSR830-10HI-GL
No
MSR1004S-5G-GL
No
MSR2600-6-X1-GL
·     In IRF mode: Yes
MSR3600-28-SI-GL
No
A device that has OSPF NSR enabled cannot act as GR restarter.
2.     Enter OSPF view.
3.     Enable OSPF NSR.
non-stop-routing
By default, OSPF NSR is disabled.
This command takes effect only for the current process. As a best practice, enable OSPF NSR for each process if multiple OSPF processes exist.
About BFD for OSPF
OSPF sends hello packets to neighbors at specific intervals to detect their state. If OSPF does not receive a hello packet from a neighbor within a specific period, OSPF considers the neighbor down. Such a failure detection method cannot achieve high data reliability, because it takes a long time and causes data loss.
To resolve this issue, configure Bidirectional Forwarding Detection (BFD) for OSPF. This feature improves the route convergence speed against link state changes through fast link state detection. For more information about BFD, see High Availability Configuration Guide.
OSPF supports the following BFD detection modes:
·     Bidirectional control detection—Requires BFD configuration to be made on both OSPF routers on the link.
·     Single-hop echo detection—Requires BFD configuration to be made on one OSPF router on the link.
Configuring bidirectional control detection
3.     Enable BFD bidirectional control detection.
ospf bfd enable
By default, BFD bidirectional control detection is disabled.
Both ends of a BFD session must be on the same network segment and in the same area.
Configuring single-hop echo detection
2.     (Optional.) Configure the source address of echo packets.
By default, the source address of echo packets is not configured.
4.     Enable BFD single-hop echo detection.
ospf bfd enable echo
By default, BFD single-hop echo detection is disabled.
About OSPF FRR
OSPF Fast Reroute (FRR) calculates a backup path based on the LSDB or specifies a backup path by using a routing policy. Then, it saves the backup path information to the FIB. When the primary path fails, the system immediately switches traffic to the backup path to prevent traffic loss and reduce the route convergence time.
OSPF supports Loop Free Alternate (LFA) FRR and remote LFA FRR.
The following OSPF FRR traffic protection types are available:
·     Link protection—Protects traffic that traverses a specific link.
·     Node protection—Protects traffic that traverses a specific node.
Node protection takes precedence over link protection.
Restrictions and guidelines for OSPF FRR
If both OSPF FRR and PIC are configured, OSPF FRR takes effect.
OSPF FRR tasks at a glance
To configure OSPF FRR, perform the following tasks:
1.     Configuring an OSPF backup path
Perform a minimum of one task.
¡     Configuring OSPF LFA FRR
¡     Configuring OSPF remote LFA FRR
¡     Configuring OSPF FRR to use a backup next hop specified in a routing policy
2.     (Optional.) Setting the priority for FRR backup path selection policies
3.     (Optional.) Configuring BFD for OSPF FRR
¡     Configuring BFD control packet mode for OSPF FRR
¡     Configuring BFD echo packet mode for OSPF FRR
A link or router failure on a path can cause packet loss until OSPF completes routing convergence based on the new network topology. FRR enables fast rerouting to minimize the impact of link or node failures.
Figure 11 Network diagram for OSPF FRR
As shown in Figure 11, configure FRR on Router B by using a routing policy to specify a backup next hop. When the primary link fails, OSPF directs packets to the backup next hop. At the same time, OSPF calculates the shortest path based on the new network topology. It forwards packets over the path after network convergence.
You can configure OSPF FRR to calculate a backup next hop by using the loop free alternate (LFA) algorithm, or specify a backup next hop by using a routing policy.
Do not use the fast-reroute lfa command together with the vlink-peer command.
3.     (Optional.) Enable LFA on an interface.
ospf fast-reroute lfa-backup
By default, the interface is enabled with LFA and it can be selected as a backup interface.
5.     Enter OSPF view.
6.     Enable OSPF FRR to use the LFA algorithm to calculate a backup next hop.
fast-reroute lfa [ abr-only ]
By default, OSPF FRR is disabled.
If abr-only is specified, only the route to the ABR is selected as the backup path.
In a network topology where OSPF LFA FRR cannot calculate the backup path, configure remote LFA FRR to ensure network reliability.
Remote LFA uses the following concepts:
·     P space—Use the source node of the protected link as the root to establish a shortest path tree. All nodes that are reachable from the source node without passing the protected link form the P space. Nodes in the P space are called P nodes.
·     Extended P space—Use the source node of the protected link and its neighbors as the roots to establish shortest path trees. All nodes that are reachable from the source node or one of its neighbors without passing the protected link form the extended P space. The P space is a subset of the extended P space.
·     Q space—Use the destination node of the protected link as the root to establish a reverse shortest path tree. All nodes that are reachable from the root node without passing the protected link form the Q space. Nodes in the Q space are called Q nodes.
·     PQ node—A PQ node refers to a node that resides in both the extended P space and the Q space. Remote LFA uses a PQ node as the destination node of a protected link.
As shown in Figure 12, the traffic forwarding path is PE 1—P 1—P 2—PE 2. To avoid traffic loss caused by link failures between P 1 and P 2, the system establishes an LDP tunnel between P 1 and P 4, which is the PQ node. When the link between P 1 and P 2 fails, P 1 encapsulates IP packets in MPLS packets and sends the MPLS packets to P 4 through the LDP tunnel. After receiving the MPLS packets, P 4 removes the MPLS labels of the packets and then forwards the packets to the next hop based on the IP routing table.
The system determines P 4 as the PQ node as follows:
1.     Uses P 1 (source node of the protected link) and its neighbors except P 2 (which passes the protected link) as the roots to establish shortest path trees.
2.     Finds out all nodes that are reachable from P 1 or one of its neighbors without passing the protected link, which are PE 1, P 1, P 3, and P 4.
These nodes form the extended P space.
3.     Uses P 2 (destination node of the protected link) as the root to establish a reverse shortest path tree.
4.     Finds out all nodes that are reachable from P 2 without passing the protected link, which are PE 2 and P 4.
These nodes form the Q space.
5.     Finds out all nodes that reside in both the extended P space and the Q space.
Only P 4 resides in both the extended P space and the Q space, so P 4 is the PQ node of the protected link.
Figure 12 Network diagram for OSPF remote LFA FRR
Enable MPLS and MPLS LDP on all nodes and interfaces participating in MPLS forwarding. For more information, see basic MPLS configuration and LDP configuration in MPLS Configuration Guide.
2.     Enter OSPF view.
3.     Enable OSPF remote LFA FRR.
fast-reroute remote-lfa tunnel ldp
By default, OSPF remote LFA FRR is disabled.
4.     (Optional.) Set the maximum cost from the source node of a protected link to a PQ node.
fast-reroute remote-lfa maximum-cost cost
By default, the maximum cost from the source node of a protected link to a PQ node is 16777215.
5.     (Optional.) Specify a prefix list to filter PQ nodes.
fast-reroute remote-lfa prefix-list prefix-list-name
By default, no prefix list is specified to filter PQ nodes. Any PQ node can be selected as the backup next hop.
Multiple PQ nodes might reach the source node of a specific protected link. You can use this command to specify a prefix list to filter PQ nodes.
6.     (Optional.) Disable remote LFA calculation on an interface.
a.     Return to system view.
b.     Enter interface view.
c.     Disable remote LFA calculation on the interface.
ospf fast-reroute remote-lfa disable
By default, remote LFA calculation is enabled on the interface.
Before you perform this task, use the apply fast-reroute backup-interface command to specify a backup next hop in a routing policy for OSPF FRR. For more information about the apply fast-reroute backup-interface command and routing policy configuration, see "Configuring routing policies."
2.     Enter OSPF view.
3.     Enable OSPF FRR to use a backup next hop specified in a routing policy.
By default, OSPF uses the node-protection policy to select the backup path. As shown in Figure 13, traffic forwarding path Device A->Device D->Device E->Device F has two backup paths: Device A->Device C->Device E->Device F and Device A->Device B->Device E->Device F. Because Device C has higher forwarding capability than Device B, OSPF prefers backup path Device A->Device C->Device E->Device F.
Figure 13 Node-protection backup path selection
To apply the lowest-cost policy that is more applicable in certain networks, perform this task to set a higher priority for it than the node-protection policy. As shown in Figure 14, traffic forwarding path Device A->Device D->Device E has two backup paths: Device A->Device C->Device D->Device E and Device A->Device B->Device D->Device E. By default, OSPF selects backup path Device A->Device C->Device D->Device E according to the node-protection policy. For OSPF to select backup path Device A->Device B->Device D->Device E, set a higher priority for the lowest-cost policy than the node-protection policy.
Figure 14 Lowest-cost backup path selection
If the node-protection policy has the higher priority but the backup path calculation still fails, OSPF uses the lowest-cost policy for further calculation.
If the lowest-cost policy has the higher priority but the backup path calculation still fails, OSPF does not perform further backup path calculation.
2.     Enter OSPF view.
3.     Set the priority for the node-protection or lowest-cost backup path selection policy.
fast-reroute tiebreaker { lowest-cost | node-protecting } preference preference
By default, the priority values of the node-protection and lowest-cost backup path selection policies are 40 and 20, respectively.
By default, OSPF FRR does not use BFD to detect primary link failures. To speed up OSPF convergence, enable BFD control packet mode for OSPF FRR to detect primary link failures. This mode requires BFD configuration on both OSPF routers on the link.
3.     Enable BFD control packet mode for OSPF FRR.
By default, BFD control packet mode is disabled for OSPF FRR.
By default, OSPF FRR does not use BFD to detect primary link failures. To speed up OSPF convergence, enable BFD echo packet mode for OSPF FRR to detect primary link failures. This mode requires BFD configuration on one OSPF router on the link.
4.     Enable BFD echo packet mode for OSPF FRR.
By default, BFD echo packet mode is disabled for OSPF FRR.
Enabling OSPF to adjust the interface cost according to the link quality
If the device forwards OSPF packets along low-quality links, slow packet transmission and packet loss might occur. To minimize the impact of low-quality links on the OSPF network, you can enable OSPF to adjust the interface cost according to the link quality.
The following items affect the quality level of links:
·     Error codes—Error codes refer to bit differences between the received and source signals, cannot be avoided because of inevitable link aging and optical path jitter problems. A high error code ratio might cause service degradation or interruption. The link quality detection module adjusts the quality level of links based on the bit error ratio. For more information about bit errors, see error code detection configuration in High Availability Configuration Guide.
·     Card health—The health of a card is downgraded when the card fails. The link quality detection module adjusts the quality level of links based on the card health. For more information about hardware failure detection, see device management configuration in Fundamentals Configuration Guide.
After you perform this task on an interface, OSPF adjusts the interface cost as follows:
·     When the link quality detection module detects that the link quality of the interface becomes poor, the module performs the following operations:
¡     Changes the link quality level from GOOD to LOW.
¡     Reports an error code event to the OSPF module.
Upon receiving the error code event, OSPF increases the cost value for the interface.
·     When the link quality detection module detects that the link quality of the interface restores to GOOD, the module performs the following operations:
¡     Changes the link quality level from LOW to GOOD.
¡     Reports an error code clearing event to the OSPF module.
Upon receiving the error code clearing event, OSPF restores the cost value for the interface to the original value.
This interface cost adjustment mechanism enables OSPF to select good-quality forwarding links, minimizing the impact of low-quality links on the OSPF network.
This feature affects the route selection results on only one side, because it only adjusts the cost values for interfaces on the local device.
3.     Enable OSPF to adjust the interface cost according to the link quality.
ospf link-quality adjust-cost { cost-offset | max }
By default, link quality-based cost adjustment is disabled for OSPF.
Configuring OSPF authentication
About OSPF area and interface authentication
Perform this task to configure OSPF area and interface authentication.
OSPF adds the configured key into sent packets, and uses the key to authenticate received packets. Only packets that pass the authentication can be received. If a packet fails the authentication, the OSPF neighbor relationship cannot be established.
If you configure OSPF authentication for both an area and an interface in that area, the interface uses the OSPF authentication configured on it.
Configuring OSPF area authentication
2.     Enter OSPF view.
ospf [ process-id | router-id { auto-select | router-id } | vpn-instance vpn-instance-name ] *
3.     Enter area view.
area area-id
4.     Configure area authentication mode.
¡     Configure HMAC-MD5/MD5 authentication.
authentication-mode { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string
¡     Configure simple authentication.
authentication-mode simple { cipher | plain } string
¡     Configure keychain authentication.
authentication-mode keychain keychain-name
For more information about keychains, see keychain configuration in Security Configuration Guide.
By default, no authentication is configured.
You must configure the same authentication mode and key on all the routers in an area.
Configuring OSPF interface authentication
2.     Enter interface view.
3.     Configure interface authentication mode.
ospf authentication-mode simple { cipher | plain } string
ospf authentication-mode { hmac-md5 | hmac-sha-256 | md5 } key-id { cipher | plain } string
ospf authentication-mode keychain keychain-name
For information about keychains, see Security Configuration Guide.
You must configure the same authentication mode and key on both the local interface and its peer interface.
Configuring GTSM for OSPF
About GTSM
The Generalized TTL Security Mechanism (GTSM) protects the device by comparing the TTL value in the IP header of incoming OSPF packets against a valid TTL range. If the TTL value is within the valid TTL range, the packet is accepted. If not, the packet is discarded.
The valid TTL range is from 255 – the configured hop count + 1 to 255.
When GTSM is configured, the OSPF packets sent by the device have a TTL of 255.
Restrictions and guidelines for GTSM
To use GTSM, you must configure GTSM on both the local and peer devices. You can specify different hop-count values for them.
The configuration in OSPF area view applies to all OSPF interfaces in the area. The configuration in interface view takes precedence over the configuration in OSPF area view.
GTSM checks OSPF packets from common neighbors and virtual link neighbors. It does not check OSPF packets from sham link neighbors. For information about GTSM for OSPF sham links, see MPLS L3VPN configuration in MPLS Configuration Guide.
Configuring GTSM in OSPF area view
2.     Enter OSPF view.
3.     Enter OSPF area view.
area area-id
4.     Enable GTSM for the OSPF area.
ttl-security [ hops hop-count ]
By default, GTSM is disabled for the OSPF area.
Configuring GTSM in interface view
3.     Configure GTSM for the interface.
¡     Enable GTSM for the interface.
ospf ttl-security [ hops hop-count ]
¡     Disable GTSM for the interface.
ospf ttl-security disable
Disable GTSM for an interface when the following conditions exist:
-     The area to which the interface belongs is enabled with GTSM.
-     The neighbor of the interface does not support GTSM.
By default, an interface uses the GTSM configuration of the area to which the interface belongs.
Configuring OSPF logging and SNMP notifications
Logging neighbor state changes
Perform this task to enable output of neighbor state change logs to the information center. The information center processes the logs according to user-defined output rules (whether and where to output logs). For more information about the information center, see Network Management and Monitoring Configuration Guide.
2.     Enter OSPF view.
3.     Enable the logging of neighbor state changes.
log-peer-change
By default, this feature of logging neighbor state changes is enabled.
Configuring the OSPF logging feature
OSPF logs include LSA aging logs, route calculation logs, neighbor logs, OSPF route logs, and self-originated and received LSA logs.
2.     Enter OSPF view.
3.     Set the number of OSPF logs.
event-log { hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } | lsa-flush | peer | spf } size count
By default, the device can generate a maximum of 100 OSPF logs for each type.
Configuring OSPF network management
This task involves the following configurations:
·     Bind an OSPF process to MIB so that you can use network management software to manage the specified OSPF process.
·     Enable SNMP notifications for OSPF to report important events.
·     Configure the SNMP notification output interval and the maximum number of SNMP notifications that can be output at each interval.
To report critical OSPF events to an NMS, enable SNMP notifications for OSPF. For SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
2.     Bind MIB to an OSPF process.
ospf mib-binding process-id
By default, MIB is bound to the process with the smallest process ID.
3.     Enable SNMP notifications for OSPF.
snmp-agent trap enable ospf [ authentication-failure | bad-packet | config-error | grhelper-status-change | grrestarter-status-change | if-state-change | lsa-maxage | lsa-originate | lsdb-approaching-overflow | lsdb-overflow | neighbor-state-change | nssatranslator-status-change | retransmit | virt-authentication-failure | virt-bad-packet | virt-config-error | virt-retransmit | virtgrhelper-status-change | virtif-state-change | virtneighbor-state-change ] *
By default, SNMP notifications for OSPF are enabled.
4.     Enter OSPF view.
5.     Configure the SNMP notification output interval and the maximum number of SNMP notifications that can be output at each interval.
By default, OSPF outputs a maximum of seven SNMP notifications within 10 seconds.
Display and maintenance commands for OSPF
Display summary route information on the OSPF ABR.
Display OSPF FRR backup next hop information.
Display OSPF SPF information.
Display OSPF process information.
display ospf [ process-id ] [ verbose ]
Display OSPF ABR and ASBR information.
Display OSPF ASBR route summarization information.
Display OSPF log information.
In standalone mode:
display ospf [ process-id ] event-log { lsa-flush | peer | spf }
In IRF mode:
display ospf [ process-id ] event-log { lsa-flush | peer [ neighbor-id ] [ slot slot-number ] | spf }
Display OSPF log information about received or sent hello packets.
In standalone mode:
display ospf [ process-id ] event-log hello { received [ abnormal | dropped ] | sent } [ neighbor-id ]
display ospf [ process-id ] event-log hello sent { abnormal | failed } [ neighbor-address ]
In IRF mode:
display ospf [ process-id ] event-log hello { received [ abnormal | dropped ] | sent } [ neighbor-id ] [ slot slot-number ]
display ospf [ process-id ] event-log hello sent { abnormal | failed } [ neighbor-address ] [ slot slot-number  ]
Display OSPF GR information.
Display the router ID-to-host name mapping table.
display ospf [ process-id ] hostname-table
Display OSPF interface information.
display ospf [ process-id ] interface [ interface-type interface-number | verbose ]
Display information about hello packets sent by OSPF interfaces.
display ospf [ process-id ] interface [ interface-type interface-number ] hello
Display OSPF LSDB information.
 display ospf [ process-id ] [ area area-id ] lsdb { asbr | network | nssa | opaque-area | opaque-link | router | summary } [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] [ area area-id ] lsdb { asbr | network | nssa | opaque-area | opaque-link | router | summary } [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] lsdb [ brief | originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] lsdb hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
display ospf [ process-id ] lsdb { ase | opaque-as } [ link-state-id ] [ originate-router advertising-router-id | self-originate ] [ age { max-value max-age-value | min-value min-age-value } * ] [ resolve-hostname ]
display ospf [ process-id ] lsdb { ase | opaque-as } [ link-state-id ] hostname host-name [ age { max-value max-age-value | min-value min-age-value } * ]
Display OSPF next hop information.
Display OSPF NSR information.
Display OSPF neighbor information.
display ospf [ process-id ] peer [ hello | verbose ] [ interface-type interface-number ] [ [ neighbor-id ] [ resolve-hostname ] | hostname host-name ]
Display neighbor statistics for OSPF areas.
Display OSPF request queue information.
Display OSPF retransmission queue information.
Display OSPF routing table information.
display ospf [ process-id ] routing [ ip-address { mask-length | mask } ] [ interface interface-type interface-number ] [ nexthop nexthop-address ] [ verbose ]
Display OSPF statistics.
display ospf [ process-id ] statistics [ error | packet [ hello | interface-type interface-number ] ]
Display OSPF virtual link information.
Display the global route ID.
display router id
Clear OSPF log information.
 In standalone mode:
reset ospf [ process-id ] event-log [ lsa-flush | peer | spf ]
In IRF mode:
reset ospf [ process-id ] event-log [ lsa-flush | peer [ slot slot-number ] | spf ]
Clear OSPF log information about received or sent hello packets.
In standalone mode:
reset ospf [ process-id ] event-log hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] }
In IRF mode:
reset ospf [ process-id ] event-log hello { received [ abnormal | dropped ] | sent [ abnormal | failed ] } [ slot slot-number]
Restart an OSPF process.
Re-enable OSPF route redistribution.
Clear OSPF statistics.
OSPF configuration examples
Example: Configuring basic OSPF
As shown in Figure 15:
·     Enable OSPF on all routers, and split the AS into three areas.
·     Configure Router A and Router B as ABRs.
Figure 15 Network diagram
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Enable OSPF:
# Configure Router A.
[RouterA] router id 10.2.1.1
[RouterA] ospf
[RouterA-ospf-1] area 0
[RouterA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterA-ospf-1] area 1
[RouterA-ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.1] quit
[RouterA-ospf-1] quit
# Configure Router B.
<RouterB> system-view
[RouterB] router id 10.3.1.1
[RouterB] ospf
[RouterB-ospf-1] area 0
[RouterB-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterB-ospf-1] area 2
[RouterB-ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.2] quit
[RouterB-ospf-1] quit
# Configure Router C.
<RouterC> system-view
[RouterC] router id 10.4.1.1
[RouterC] ospf
[RouterC-ospf-1] area 1
[RouterC-ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.1] network 10.4.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.1] quit
[RouterC-ospf-1] quit
# Configure Router D.
<RouterD> system-view
[RouterD] router id 10.5.1.1
[RouterD] ospf
[RouterD-ospf-1] area 2
[RouterD-ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.2] network 10.5.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.2] quit
[RouterD-ospf-1] quit
# Display the OSPF neighbors of Router A.
[RouterA] display ospf peer verbose
          OSPF Process 1 with Router ID 10.2.1.1
                  Neighbors
 Area 0.0.0.0 interface 10.1.1.1(GigabitEthernet1/0/1)'s neighbors
 Router ID: 10.3.1.1         Address: 10.1.1.2         GR State: Normal
   DR: 10.1.1.1  BDR: 10.1.1.2  MTU: 0
   Dead timer due in 37  sec
   Neighbor is up for 06:03:59
   Neighbor state change count: 5
   BFD status: Disabled
 Area 0.0.0.1 interface 10.2.1.1(GigabitEthernet1/0/2)'s neighbors
 Router ID: 10.4.1.1         Address: 10.2.1.2         GR State: Normal
   DR: 10.2.1.1  BDR: 10.2.1.2  MTU: 0
   Dead timer due in 32  sec
   Neighbor is up for 06:03:12
# Display OSPF routing information on Router A.
[RouterA] display ospf routing
                   Routing Table
 Routing for network
 10.2.1.0/24        1        Transit 10.2.1.1        10.2.1.1        0.0.0.1
 10.3.1.0/24        2        Inter   10.1.1.2        10.3.1.1        0.0.0.0
 10.4.1.0/24        2        Stub    10.2.1.2        10.4.1.1        0.0.0.1
 10.5.1.0/24        3        Inter   10.1.1.2        10.3.1.1        0.0.0.0
 10.1.1.0/24        1        Transit 10.1.1.1        10.2.1.1        0.0.0.0
 Total nets: 5
 Intra area: 3  Inter area: 2  ASE: 0  NSSA: 0
# Display OSPF routing information on Router D.
[RouterD] display ospf routing
          OSPF Process 1 with Router ID 10.5.1.1
                   Routing Table
 Routing for network
 10.2.1.0/24         3       Inter   10.3.1.1        10.3.1.1        0.0.0.2
 10.3.1.0/24         1       Transit 10.3.1.2        10.3.1.1        0.0.0.2
 10.4.1.0/24         4       Inter   10.3.1.1        10.3.1.1        0.0.0.2
 10.5.1.0/24         1       Stub    10.5.1.1        10.5.1.1        0.0.0.2
 10.1.1.0/24         2       Inter   10.3.1.1        10.3.1.1        0.0.0.2
 Total nets: 5
 Intra area: 2  Inter area: 3  ASE: 0  NSSA: 0
# Ping 10.4.1.1 to test reachability.
[RouterD] ping 10.4.1.1
Ping 10.4.1.1 (10.4.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 10.4.1.1: icmp_seq=0 ttl=253 time=1.549 ms
56 bytes from 10.4.1.1: icmp_seq=1 ttl=253 time=1.539 ms
56 bytes from 10.4.1.1: icmp_seq=2 ttl=253 time=0.779 ms
56 bytes from 10.4.1.1: icmp_seq=3 ttl=253 time=1.702 ms
56 bytes from 10.4.1.1: icmp_seq=4 ttl=253 time=1.471 ms
--- Ping statistics for 10.4.1.1 ---
round-trip min/avg/max/std-dev = 0.779/1.408/1.702/0.323 ms
Example: Configuring OSPF route redistribution
As shown in Figure 16:
·     Enable OSPF on all the routers.
·     Split the AS into three areas.
·     Configure Router C as an ASBR to redistribute external routes (static routes).
Figure 16 Network diagram
2.     Enable OSPF (see "Example: Configuring basic OSPF").
3.     Configure OSPF to redistribute routes:
# On Router C, configure a static route destined for network 3.1.2.0/24.
[RouterC] ip route-static 3.1.2.1 24 10.4.1.2
# On Router C, configure OSPF to redistribute the static route.
[RouterC] ospf 1
[RouterC-ospf-1] import-route static
# Display the ABR/ASBR information on Router D.
<RouterD> display ospf abr-asbr
                  Routing Table to ABR and ASBR
 Type        Destination     Area            Cost  Nexthop         RtType
 Intra       10.3.1.1        0.0.0.2         10    10.3.1.1        ABR
 Inter       10.4.1.1        0.0.0.2         22    10.3.1.1        ASBR
# Display the OSPF routing information on Router D.
<RouterD> display ospf routing
                   Routing Table
 Routing for network
 10.2.1.0/24        22       Inter   10.3.1.1        10.3.1.1        0.0.0.2
 10.3.1.0/24        10       Transit 10.3.1.2        10.3.1.1        0.0.0.2
 10.4.1.0/24        25       Inter   10.3.1.1        10.3.1.1        0.0.0.2
 10.5.1.0/24        10       Stub    10.5.1.1        10.5.1.1        0.0.0.2
 10.1.1.0/24        12       Inter   10.3.1.1        10.3.1.1        0.0.0.2
 Routing for ASEs
 Destination        Cost     Type    Tag         NextHop         AdvRouter
 3.1.2.0/24         1        Type2   1           10.3.1.1        10.4.1.1
 Total nets: 6
 Intra area: 2  Inter area: 3  ASE: 1  NSSA: 0
Example: Configuring OSPF route summarization
As shown in Figure 17:
·     Configure OSPF on Router A and Router B in AS 200.
·     Configure OSPF on Router C, Router D, and Router E in AS 100.
·     Configure an EBGP connection between Router B and Router C. Configure Router B and Router C to redistribute OSPF routes and direct routes into BGP and BGP routes into OSPF.
·     Configure Router B to advertise only summary route 10.0.0.0/8 to Router A.
Figure 17 Network diagram
2.     Enable OSPF:
[RouterA] router id 11.2.1.2
[RouterA] ospf
[RouterA-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[RouterB] router id 11.2.1.1
[RouterB] ospf
[RouterB-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[RouterC] router id 11.1.1.2
[RouterC] ospf
[RouterC-ospf-1] area 0
[RouterC-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterC-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[RouterD] router id 10.3.1.1
[RouterD] ospf
[RouterD-ospf-1] area 0
[RouterD-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] network 10.3.1.0 0.0.0.255
[RouterD-ospf-1-area-0.0.0.0] quit
# Configure Router E.
<RouterE> system-view
[RouterE] router id 10.4.1.1
[RouterE] ospf
[RouterE-ospf-1] area 0
[RouterE-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] network 10.4.1.0 0.0.0.255
[RouterE-ospf-1-area-0.0.0.0] quit
[RouterE-ospf-1] quit
3.     Configure BGP to redistribute OSPF routes and direct routes:
[RouterB] bgp 200
[RouterB-bgp-default] peer 11.1.1.2 as-number 100
[RouterB-bgp-default] address-family ipv4 unicast
[RouterB-bgp-default-ipv4] peer 11.1.1.2 enable
[RouterB-bgp-default-ipv4] import-route ospf
[RouterB-bgp-default-ipv4] import-route direct
[RouterB-bgp-default-ipv4] quit
[RouterB-bgp-default] quit
[RouterC] bgp 100
[RouterC-bgp-default] peer 11.1.1.1 as-number 200
[RouterC-bgp-default] address-family ipv4 unicast
[RouterC-bgp-default-ipv4] peer 11.1.1.1 enable
[RouterC-bgp-default-ipv4] import-route ospf
[RouterC-bgp-default-ipv4] import-route direct
[RouterC-bgp-default] quit
4.     Configure Router B and Router C to redistribute BGP routes into OSPF:
# Configure OSPF to redistribute routes from BGP on Router B.
[RouterB] ospf
[RouterB-ospf-1] import-route bgp
# Configure OSPF to redistribute routes from BGP on Router C.
[RouterC] ospf
[RouterC-ospf-1] import-route bgp
# Display the IP routing table on Router A.
         Destinations : 16        Routes : 16
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
10.1.1.0/24         O_ASE2 150  1            11.2.1.1        GE1/0/1
10.2.1.0/24         O_ASE2 150  1            11.2.1.1        GE1/0/1
10.3.1.0/24         O_ASE2 150  1            11.2.1.1        GE1/0/1
10.4.1.0/24         O_ASE2 150  1            11.2.1.1        GE1/0/1
11.2.1.0/24         Direct 0    0            11.2.1.2        GE1/0/1
11.2.1.0/32         Direct 0    0            11.2.1.2        GE1/0/1
11.2.1.2/32         Direct 0    0            127.0.0.1       InLoop0
11.2.1.255/32       Direct 0    0            11.2.1.2        GE1/0/1
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
5.     Configure route summarization:
# Configure route summarization on Router B to advertise a single route 10.0.0.0/8.
[RouterB-ospf-1] asbr-summary 10.0.0.0 8
         Destinations : 13        Routes : 13
10.0.0.0/8          O_ASE2 150  1            11.2.1.1        GE1/0/1
The output shows that routes 10.1.1.0/24, 10.2.1.0/24, 10.3.1.0/24 and 10.4.1.0/24 are summarized into a single route 10.0.0.0/8.
Example: Configuring OSPF stub area
As shown in Figure 18:
·     Configure Router A and Router B as ABRs to forward routing information between areas.
·     Configure Router D as the ASBR to redistribute static routes.
·     Configure Area 1 as a stub area to reduce advertised LSAs without influencing reachability.
Figure 18 Network diagram
3.     Configure route redistribution:
# Configure Router D to redistribute static routes.
[RouterD] ip route-static 3.1.2.1 24 10.5.1.2
[RouterD] ospf
[RouterD-ospf-1] import-route static
# Display ABR/ASBR information on Router C.
<RouterC> display ospf abr-asbr
          OSPF Process 1 with Router ID 10.4.1.1
 Intra       10.2.1.1        0.0.0.1         3     10.2.1.1        ABR
 Inter       10.5.1.1        0.0.0.1         7     10.2.1.1        ASBR
# Display OSPF routing information on Router C.
<RouterC> display ospf routing
                   Routing Table
 Routing for network
 10.2.1.0/24        3        Transit 0.0.0.0         10.2.1.1        0.0.0.1
 10.3.1.0/24        7        Inter   10.2.1.1        10.2.1.1        0.0.0.1
 10.4.1.0/24        3        Stub    10.4.1.1        10.4.1.1        0.0.0.1
 10.5.1.0/24        17       Inter   10.2.1.1        10.2.1.1        0.0.0.1
 10.1.1.0/24        5        Inter   10.2.1.1        10.2.1.1        0.0.0.1
 Routing for ASEs
 3.1.2.0/24         1        Type2   1           10.2.1.1        10.5.1.1
 Total nets: 6
The output shows that Router C's routing table contains an AS external route.
4.     Configure Area 1 as a stub area:
[RouterA] ospf
[RouterA-ospf-1-area-0.0.0.1] stub
[RouterC] ospf
[RouterC-ospf-1-area-0.0.0.1] stub
[RouterC] display ospf routing
                   Routing Table
 Routing for network
 0.0.0.0/0          4        Inter   10.2.1.1        10.2.1.1        0.0.0.1
 Total nets: 6
 Intra area: 2  Inter area: 4  ASE: 0  NSSA: 0
The output shows that a default route replaces the AS external route.
# Configure Area 1 as a totally stub area.
[RouterA] ospf
[RouterA-ospf-1-area-0.0.0.1] stub no-summary
                   Routing Table
 Routing for network
 10.2.1.0/24        3        Transit 0.0.0.0         10.4.1.1        0.0.0.1
 Total nets: 3
 Intra area: 2  Inter area: 1  ASE: 0  NSSA: 0
The output shows that inter-area routes are removed, and only one external route (a default route) exists on Router C.
Example: Configuring OSPF NSSA area
As shown in Figure 19:
·     Configure OSPF on all routers and split AS into three areas.
·     Configure Area 1 as an NSSA area and configure Router C as an ASBR to redistribute static routes into the AS.
Figure 19 Network diagram
3.     Configure Area 1 as an NSSA area:
[RouterA] ospf
[RouterA-ospf-1-area-0.0.0.1] nssa
[RouterC] ospf
[RouterC-ospf-1-area-0.0.0.1] nssa
# Display routing information on Router C.
                   Routing Table
 Routing for network
 10.2.1.0/24        3        Transit 10.2.1.2        10.4.1.1        0.0.0.1
 Total nets: 5
4.     Configure route redistribution:
# Configure OSPF to redistribute the static route on Router C.
[RouterC] ospf
# Display routing information on Router D.
                   Routing Table
 Routing for network
 Routing for ASEs
 3.1.2.0/24         1        Type2   1           10.3.1.1        10.2.1.1
 Total nets: 6
The output shows that an AS external route imported from the NSSA area exists on Router D.
Example: Configuring OSPF DR election
As shown in Figure 20:
·     Enable OSPF on Routers A, B, C, and D on the same network.
·     Configure Router D as the DR, and configure Router C as the BDR.
·     Change the router priorities on the interfaces to configure Router A as the DR and Router C as the BDR.
Figure 20 Network diagram
2.     Configure basic OSPF settings on all routers. (Details not shown.)
For more information, see "Example: Configuring basic OSPF."
3.     Display neighbor information on Router A.
                  Neighbors
 Area 0.0.0.0 interface 192.168.1.1(GigabitEthernet1/0/1)'s neighbors
 Router ID: 2.2.2.2          Address: 192.168.1.2      GR State: Normal
   State: 2-Way  Mode: None  Priority: 1
   DR: 192.168.1.4  BDR: 192.168.1.3  MTU: 0
   Dead timer due in 38  sec
   Neighbor is up for 00:01:31
 Router ID: 3.3.3.3          Address: 192.168.1.3      GR State: Normal
   Dead timer due in 31  sec
   Neighbor is up for 00:01:28
 Router ID: 4.4.4.4          Address: 192.168.1.4      GR State: Normal
The output shows that Router D is the DR and Router C is the BDR.
4.     Configure router priorities on interfaces:
[RouterA-GigabitEthernet1/0/1] ospf dr-priority 100
[RouterA] quit
[RouterB-GigabitEthernet1/0/1] ospf dr-priority 0
[RouterB] quit
[RouterC-GigabitEthernet1/0/1] ospf dr-priority 2
[RouterC] quit
# Display information about neighbors of Router D.
<RouterD> display ospf peer verbose
          OSPF Process 1 with Router ID 4.4.4.4
                  Neighbors
 Area 0.0.0.0 interface 192.168.1.4(GigabitEthernet1/0/1)'s neighbors
 Router ID: 1.1.1.1      Address: 192.168.1.1      GR State: Normal
   State: Full  Mode:Nbr is  slave  Priority: 100
   Neighbor is up for 00:11:17
   State: Full  Mode:Nbr is  slave  Priority: 0
   Dead timer due in 35  sec
   Neighbor is up for 00:11:19
   State: Full  Mode:Nbr is  slave  Priority: 2
   Dead timer due in 33  sec
   Neighbor is up for 00:11:15
The output shows that the DR and BDR are not changed, because the new router priority settings do not take effect immediately.
5.     Restart OSPF processes:
# Restart the OSPF process on Router A.
<RouterA> reset ospf 1 process
Warning : Reset OSPF process? [Y/N]:y
# Restart the OSPF process on Router B.
<RouterB> reset ospf 1 process
# Restart the OSPF process on Router C.
<RouterC> reset ospf 1 process
# Restart the OSPF process on Router D.
<RouterD> reset ospf 1 process
# Display neighbor information on Router D.
                  Neighbors
   State: Full  Mode: Nbr is slave  Priority: 100
   DR: 192.168.1.1  BDR: 192.168.1.3  MTU: 0
   Dead timer due in 39  sec
   Neighbor is up for 00:01:40
   State: 2-Way  Mode: None  Priority: 0
   Neighbor is up for 00:01:44
   State: Full  Mode: Nbr is slave  Priority: 2
   Neighbor is up for 00:01:41
The output shows that Router A becomes the DR and Router C becomes the BDR.
The full neighbor state means an adjacency has been established. The 2-way neighbor state means the two routers are not the DR or BDR, and they do not exchange LSAs.
# Display OSPF interface information.
<RouterA> display ospf interface
                  Interfaces
 Area: 0.0.0.0
 IP Address      Type      State   Cost  Pri   DR             BDR
 192.168.1.1     Broadcast DR      1     100   192.168.1.1    192.168.1.3
[RouterB] display ospf interface
                  Interfaces
 Area: 0.0.0.0
 192.168.1.2     Broadcast DROther  1     0     192.168.1.1    192.168.1.3
The interface state DROther means the interface is not the DR or BDR.
Example: Configuring OSPF virtual link
As shown in Figure 21, configure a virtual link between Router B and Router C to connect Area 2 to the backbone area. After configuration, Router B can learn routes to Area 2.
Figure 21 Network diagram
2.     Enable OSPF:
[RouterA] ospf 1 router-id 1.1.1.1
[RouterB] ospf 1 router-id 2.2.2.2
[RouterB-ospf-1] area 1
[RouterB–ospf-1-area-0.0.0.1] network 10.2.1.0 0.0.0.255
[RouterB–ospf-1-area-0.0.0.1] quit
[RouterC] ospf 1 router-id 3.3.3.3
[RouterC-ospf-1] area 2
[RouterC–ospf-1-area-0.0.0.2] network 10.3.1.0 0.0.0.255
[RouterC–ospf-1-area-0.0.0.2] quit
[RouterD] ospf 1 router-id 4.4.4.4
# Display OSPF routing information on Router B.
[RouterB] display ospf routing
                   Routing Table
 Routing for network
 10.2.1.0/24        2        Transit 10.2.1.1        3.3.3.3         0.0.0.1
 10.1.1.0/24        2        Transit 10.1.1.2        2.2.2.2         0.0.0.0
 Total nets: 2
 Intra area: 2  Inter area: 0  ASE: 0  NSSA: 0
The output shows that Router B does not have routes to Area 2 because Area 0 is not directly connected to Area 2.
3.     Configure a virtual link:
[RouterB] ospf
[RouterB-ospf-1-area-0.0.0.1] vlink-peer 3.3.3.3
[RouterB-ospf-1-area-0.0.0.1] quit
[RouterC] ospf
[RouterC-ospf-1-area-0.0.0.1] vlink-peer 2.2.2.2
                   Routing Table
 Routing for network
 10.3.1.0/24        5        Inter   10.2.1.2        3.3.3.3         0.0.0.0
 Total nets: 3
The output shows that Router B has learned the route 10.3.1.0/24 to Area 2.
Example: Configuring OSPF GR
As shown in Figure 22:
·     Router A, Router B, and Router C that belong to the same autonomous system and the same OSPF routing domain are GR capable.
·     Router A acts as the non-IETF GR restarter. Router B and Router C are the GR helpers, and synchronize their LSDBs with Router A through OOB communication of GR.
Figure 22 Network diagram
2.     Enable OSPF:
[RouterA] router id 1.1.1.1
[RouterA] ospf 100
[RouterA-ospf-100] area 0
[RouterA-ospf-100-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[RouterA-ospf-100-area-0.0.0.0] quit
[RouterA-ospf-100] quit
[RouterB] router id 2.2.2.2
[RouterB] ospf 100
[RouterB-ospf-100] area 0
[RouterB-ospf-100-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[RouterB-ospf-100-area-0.0.0.0] quit
[RouterB-ospf-100] quit
[RouterC] router id 3.3.3.3
[RouterC] ospf 100
[RouterC-ospf-100] area 0
[RouterC-ospf-100-area-0.0.0.0] network 192.1.1.0 0.0.0.255
[RouterC-ospf-100-area-0.0.0.0] quit
[RouterC-ospf-100] quit
3.     Configure OSPF GR:
# Configure Router A as the non-IETF OSPF GR restarter: enable the link-local signaling capability, the out-of-band re-synchronization capability, and non-IETF GR for OSPF process 100.
[RouterA-ospf-100] enable link-local-signaling
[RouterA-ospf-100] enable out-of-band-resynchronization
[RouterA-ospf-100] graceful-restart
# Configure Router B as the GR helper: enable the link-local signaling capability and the out-of-band re-synchronization capability for OSPF process 100.
[RouterB-ospf-100] enable link-local-signaling
[RouterB-ospf-100] enable out-of-band-resynchronization
# Configure Router C as the GR helper: enable the link-local signaling capability and the out-of-band re-synchronization capability for OSPF process 100.
[RouterC-ospf-100] enable link-local-signaling
[RouterC-ospf-100] enable out-of-band-resynchronization
# Enable OSPF GR event debugging and restart the OSPF process by using GR on Router A.
<RouterA> debugging ospf event graceful-restart
<RouterA> terminal monitor
<RouterA> terminal logging level 7
<RouterA> reset ospf 100 process graceful-restart
%Oct 21 15:29:28:727 2011 RouterA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.2(GigabitEthernet1/0/1) from Full to Down.
%Oct 21 15:29:28:729 2011 RouterA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.3(GigabitEthernet1/0/1) from Full to Down.
*Oct 21 15:29:28:735 2011 RouterA OSPF/7/DEBUG:
OSPF 100 nonstandard GR Started for OSPF Router
OSPF 100 created GR wait timer,timeout interval is 40(s).
OSPF 100 created GR Interval timer,timeout interval is 120(s).
*Oct 21 15:29:28:758 2011 RouterA OSPF/7/DEBUG:
OSPF 100 created OOB Progress timer for neighbor 192.1.1.3.
*Oct 21 15:29:28:766 2011 RouterA OSPF/7/DEBUG:
OSPF 100 created OOB Progress timer for neighbor 192.1.1.2.
%Oct 21 15:29:29:902 2011 RouterA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.2(GigabitEthernet1/0/1) from Loading to Full.
*Oct 21 15:29:29:902 2011 RouterA OSPF/7/DEBUG:
OSPF 100 deleted OOB Progress timer for neighbor 192.1.1.2.
%Oct 21 15:29:30:897 2011 RouterA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.3(GigabitEthernet1/0/1) from Loading to Full.
*Oct 21 15:29:30:897 2011 RouterA OSPF/7/DEBUG:
OSPF 100 deleted OOB Progress timer for neighbor 192.1.1.3.
*Oct 21 15:29:30:911 2011 RouterA OSPF/7/DEBUG:
OSPF GR: Process 100 Exit Restart,Reason : DR or BDR change,for neighbor : 192.1.1.3.
OSPF 100 deleted GR Interval timer.
*Oct 21 15:29:30:912 2011 RouterA OSPF/7/DEBUG:
OSPF 100 deleted GR wait timer.
%Oct 21 15:29:30:920 2011 RouterA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.2(GigabitEthernet1/0/1) from Full to Down.
%Oct 21 15:29:30:921 2011 RouterA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.3(GigabitEthernet1/0/1) from Full to Down.
%Oct 21 15:29:33:815 2011 RouterA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.3(GigabitEthernet1/0/1) from Loading to Full.
%Oct 21 15:29:35:578 2011 RouterA OSPF/5/OSPF_NBR_CHG: OSPF 100 Neighbor 192.1.1.2(GigabitEthernet1/0/1) from Loading to Full.
The output shows that Router A completes GR.
Example: Configuring OSPF NSR
As shown in Figure 23, Router S, Router A, and Router B belong to the same OSPF routing domain. Enable OSPF NSR on Router S to ensure correct routing when an active/standby switchover occurs on Router S.
Figure 23 Network diagram
1.     Configure IP addresses and subnet masks for interfaces on the routers. (Details not shown.)
2.     Configure OSPF on the routers to ensure the following: (Details not shown.)
¡     Router S, Router A, and Router B can communicate with each other at Layer 3.
¡     Dynamic route update can be implemented among them with OSPF.
3.     Enable OSPF NSR on Router S.
<RouterS> system-view
[RouterS] ospf 100
[RouterS-ospf-100] non-stop-routing
[RouterS-ospf-100] quit
# Perform an active/standby switchover on Router S.
[RouterS] placement reoptimize
Program                           Current location       New location
rib                               0/0                    0/0
staticroute                       0/0                    0/0
ospf                              0/0                    1/0
Continue? [y/n]:y
Re-optimization of the placement start. You will be notified on completion.
Re-optimization of the placement complete. Use 'display placement' to view the new placement.
# During the switchover period, display OSPF neighbors on Router A to verify the neighbor relationship between Router A and Router S.
<RouterA> display ospf peer
          OSPF Process 1 with Router ID 2.2.2.1
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 3.3.3.1         12.12.12.2      1   37         Full/BDR          GE1/0/1
# Display OSPF routes on Router A to verify if Router A has a route to the loopback interface on Router B.
<RouterA> display ospf routing
                   Routing Table
 Routing for network
 44.44.44.44/32     2        Stub    12.12.12.2      4.4.4.1         0.0.0.0
 14.14.14.0/24      2        Transit 12.12.12.2      4.4.4.1         0.0.0.0
 22.22.22.22/32     0        Stub    22.22.22.22     2.2.2.1         0.0.0.0
 12.12.12.0/24      1        Transit 12.12.12.1      2.2.2.1         0.0.0.0
 Total nets: 4
 Intra area: 4  Inter area: 0  ASE: 0  NSSA: 0
# Display OSPF neighbors on Router B to verify the neighbor relationship between Router B and Router S.
<RouterB> display ospf peer
          OSPF Process 1 with Router ID 4.4.4.1
 Area: 0.0.0.0
 3.3.3.1         14.14.14.2      1   39         Full/BDR          GE1/0/1
# Display OSPF routes on Router B to verify if Router B has a route to the loopback interface on Router A.
<RouterB> display ospf routing
                   Routing Table
 Routing for network
 44.44.44.44/32     0        Stub    44.44.44.44     4.4.4.1         0.0.0.0
 14.14.14.0/24      1        Transit 14.14.14.1      4.4.4.1         0.0.0.0
 22.22.22.22/32     2        Stub    14.14.14.2      2.2.2.1         0.0.0.0
 12.12.12.0/24      2        Transit 14.14.14.2      2.2.2.1         0.0.0.0
 Total nets: 4
The output shows the following when an active/standby switchover occurs on Router S:
·     The neighbor relationships and routing information on Router A and Router B have not changed.
·     The traffic from Router A to Router B has not been impacted.
Example: Configuring BFD for OSPF
As shown in Figure 24, run OSPF on Router A, Router B, and Router C so that they can reach each other at the network layer.
·     When the link over which Router A and Router B communicate through a Layer 2 switch fails, BFD can quickly detect the failure and notify OSPF of the failure.
·     Router A and Router B then communicate through Router C.
Figure 24 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Router A
GE1/0/1
192.168.0.102/24
Router A
GE1/0/2
10.1.1.102/24
Router A
Loop0
121.1.1.1/32
Router B
GE1/0/1
192.168.0.100/24
Router B
GE1/0/2
13.1.1.1/24
Router B
Loop0
120.1.1.1/32
Router C
GE1/0/1
10.1.1.100/24
Router C
GE1/0/2
13.1.1.2/24
2.     Enable OSPF:
[RouterA] ospf
[RouterA-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[RouterA-ospf-1-area-0.0.0.0] network 121.1.1.1 0.0.0.0
[RouterB] ospf
[RouterB-ospf-1-area-0.0.0.0] network 192.168.0.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[RouterB-ospf-1-area-0.0.0.0] network 120.1.1.1 0.0.0.0
[RouterC] ospf
[RouterC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
3.     Configure BFD:
# Enable BFD on Router A and configure BFD parameters.
[RouterA] bfd session init-mode active
[RouterA-GigabitEthernet1/0/1] ospf bfd enable
[RouterA-GigabitEthernet1/0/1] bfd min-transmit-interval 500
[RouterA-GigabitEthernet1/0/1] bfd min-receive-interval 500
[RouterA-GigabitEthernet1/0/1] bfd detect-multiplier 7
# Enable BFD on Router B and configure BFD parameters.
[RouterB] bfd session init-mode active
[RouterB-GigabitEthernet1/0/1] ospf bfd enable
[RouterB-GigabitEthernet1/0/1] bfd min-transmit-interval 500
[RouterB-GigabitEthernet1/0/1] bfd min-receive-interval 500
[RouterB-GigabitEthernet1/0/1] bfd detect-multiplier 6
# Display the BFD information on Router A.
<RouterA> display bfd session
 Total sessions: 1        Up sessions: 1        Init mode: Active
 LD/RD           SourceIP        DestinationIP   State   Holdtime    Interface
 3/1             192.168.0.102   192.168.0.100   Up      1700ms      GE1/0/1
# Display routes destined for 120.1.1.1/32 on Router A.
<RouterA> display ip routing-table 120.1.1.1 verbose
Summary Count : 1
Destination: 120.1.1.1/32
    Protocol: O_INTRA
  Process ID: 1
   SubProtID: 0x1                       Age: 04h20m37s
        Cost: 1                  Preference: 10
       IpPre: N/A                QosLocalID: N/A
         Tag: 0                       State: Active Adv
   OrigTblID: 0x0                   OrigVrf: default-vrf
     TableID: 0x2                    OrigAs: 0
       NibID: 0x26000002             LastAs: 0
      AttrID: 0xffffffff           Neighbor: 0.0.0.0
       Flags: 0x1008c           OrigNextHop: 192.168.0.100
       Label: NULL              RealNextHop: 192.168.0.100
     BkLabel: NULL                BkNextHop: N/A
     SRLabel: NULL                Interface: GigabitEthernet1/0/1
   BkSRLabel: NULL              BkInterface: N/A
    SIDIndex: NULL                  InLabel: NULL
   Tunnel ID: Invalid           IPInterface: GigabitEthernet1/0/1
 BkTunnel ID: Invalid        BkIPInterface: N/A
    FtnIndex: 0x0            ColorInterface: N/A
TrafficIndex: N/A          BkColorInterface: N/A
   Connector: N/A                 VpnPeerId: N/A
        Dscp: N/A                       Exp: N/A
  SRTunnelID: Invalid             StatFlags: 0x0
    SID Type: N/A                       SID: N/A
       BkSID: N/A                       NID: Invalid
    FlushNID: Invalid                 BkNID: Invalid
  BkFlushNID: Invalid                PathID: 0x0
CommBlockLen: 0
  OrigLinkID: 0x0                RealLinkID: 0x0
The output shows that Router A communicates with Router B through GigabitEthernet 1/0/1. Then the link over GigabitEthernet 1/0/1 fails.
Summary Count : 1
    Protocol: O_INTRA
  Process ID: 1
        Cost: 2                  Preference: 10
       Flags: 0x1008c           OrigNextHop: 10.1.1.100
       Label: NULL              RealNextHop: 10.1.1.100
     SRLabel: NULL                Interface: GigabitEthernet1/0/2
   Tunnel ID: Invalid           IPInterface: GigabitEthernet1/0/2
 BkTunnel ID: Invalid         BkIPInterface: N/ A
        Dscp: N/A                       Exp: N/A
CommBlockLen: 0
The output shows that Router A communicates with Router B through GigabitEthernet 1/0/2.
Example: Configuring OSPF FRR
As shown in Figure 25, Router A, Router B, and Router C reside in the same OSPF domain. Configure OSPF FRR so that when Link A fails, traffic is immediately switched to Link B.
Figure 25 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Router A
GE1/0/1
12.12.12.1/24
Router A
GE1/0/2
13.13.13.1/24
Router A
Loop0
1.1.1.1/32
Router B
GE1/0/1
24.24.24.4/24
Router B
GE1/0/2
13.13.13.2/24
Router B
Loop0
4.4.4.4/32
Router C
GE1/0/1
12.12.12.2/24
Router C
GE1/0/2
24.24.24.2/24
2.     Configure OSPF on the routers to ensure that Router A, Router B, and Router C can communicate with each other at the network layer. (Details not shown.)
3.     Configure OSPF FRR:
You can enable OSPF FRR to either calculate a backup next hop by using the LFA algorithm, or specify a backup next hop by using a routing policy.
¡     (Method 1.) Enable OSPF FRR to calculate a backup next hop by using the LFA algorithm:
[RouterA] ospf 1
[RouterA-ospf-1] fast-reroute lfa
[RouterB] ospf 1
[RouterB-ospf-1] fast-reroute lfa
¡     (Method 2.) Enable OSPF FRR to specify a backup next hop by using a routing policy:
[RouterA] ip prefix-list abc index 10 permit 4.4.4.4 32
[RouterA] route-policy frr permit node 10
[RouterA-route-policy-frr-10] if-match ip address prefix-list abc
[RouterA-route-policy-frr-10] apply fast-reroute backup-interface gigabitethernet 1/0/1 backup-nexthop 12.12.12.2
[RouterA-route-policy-frr-10] quit
[RouterA] ospf 1
[RouterA-ospf-1] fast-reroute route-policy frr
[RouterB] ip prefix-list abc index 10 permit 1.1.1.1 32
[RouterB] route-policy frr permit node 10
[RouterB-route-policy-frr-10] if-match ip address prefix-list abc
[RouterB-route-policy-frr-10] apply fast-reroute backup-interface gigabitethernet 1/0/1 backup-nexthop 24.24.24.2
[RouterB-route-policy-frr-10] quit
[RouterB] ospf 1
[RouterB-ospf-1] fast-reroute route-policy frr
# Display route 4.4.4.4/32 on Router A to view the backup next hop information.
[RouterA] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.4/32
    Protocol: O_INTRA
  Process ID: 1
       Flags: 0x1008c           OrigNextHop: 13.13.13.2
       Label: NULL              RealNextHop: 13.13.13.2
     BkLabel: NULL                BkNextHop: 12.12.12.2
 BkTunnel ID: Invalid         BkIPInterface: GigabitEthernet1/0/1
        Dscp: N/A                       Exp: N/A
CommBlockLen: 0
# Display route 1.1.1.1/32 on Router B to view the backup next hop information.
[RouterB] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
Destination: 1.1.1.1/32
    Protocol: O_INTRA
  Process ID: 1
       Flags: 0x1008c           OrigNextHop: 13.13.13.1
       Label: NULL              RealNextHop: 13.13.13.1
     BkLabel: NULL                BkNextHop: 24.24.24.2
        Dscp: N/A                       Exp: N/A
CommBlockLen: 0
Troubleshooting OSPF configuration
No OSPF neighbor relationship established
Symptom
No OSPF neighbor relationship can be established.
Analysis
If the physical link and lower layer protocols work correctly, verify OSPF parameters configured on interfaces. Two neighbors must have the same parameters, such as the area ID, network segment, and mask. (A P2P or virtual link can have different network segments and masks.)
Solution
To resolve the problem:
1.     Use the display ospf peer command to verify OSPF neighbor information.
2.     Use the display ospf interface command to verify OSPF interface information.
3.     Ping the neighbor router's IP address to verify that the connectivity is normal.
4.     Verify OSPF timers. The dead interval on an interface must be a minimum of four times the hello interval.
5.     On an NBMA network, use the peer ip-address command to manually specify the neighbor.
6.     A minimum of one interface must have a router priority higher than 0 on an NBMA or a broadcast network.
7.     If the problem persists, contact H3C Support.
Incorrect routing information
Symptom
OSPF cannot find routes to other areas.
Analysis
The backbone area must maintain connectivity to all other areas. If a router connects to more than one area, a minimum of one area must be connected to the backbone. The backbone cannot be configured as a stub area.
In a stub area, all routers cannot receive external routes, and all interfaces connected to the stub area must belong to the stub area.
Solution
1.     Use the display ospf peer command to verify neighbor information.
3.     Use the display ospf lsdb command to verify the LSDB.
4.     Use the display current-configuration configuration ospf command to verify area configuration. If more than two areas are configured, a minimum of one area is connected to the backbone.
5.     In a stub area, all routers attached are configured with the stub command. In an NSSA area, all routers attached are configured with the nssa command.
6.     If a virtual link is configured, use the display ospf vlink command to verify the state of the virtual link.
