- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-GIR commands
- 09-Automatic configuration commands
- 10-Target configuration management commands
- 11-Device management commands
- 12-Tcl commands
- 13-Python commands
| 00-Preface | 110.37 KB |
Preface
This command reference covers the commands for logging in to and setting up the device.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Support for slots varies by device model. All slot-related descriptions in this documentation are for illustration only. It is normal that the slots in the examples differ from those on your device. On a device to which this documentation applies, the slot-number argument in a command represents the entire device and is fixed at 0. The command applies to the entire device regardless of whether the slot number is specified.
Documentation feedback
We appreciate your comments.
