02-Fundamentals
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Reference GuidesMIB CompanionH3C MSR5680-X3 Router MIB Reference-R9141-6W10002-Fundamentals
04-HH3C-UI-MAN-MIB
04-HH3C-UI-MAN-MIB 57.69 KB
HH3C-UI-MAN-MIB
About this MIB
Use this MIB to define alarms on user authentication. This MIB also contains notifications about user login changes.
MIB file name
hh3c-ui-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cUIMgt(2)
Scalar objects
hh3cTerminalUserName (1.3.6.1.4.1.25506.2.2.1.1.2.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
DisplayString
Standard MIB values.
Name of a login user.
As per the MIB.
hh3cTerminalSource (1.3.6.1.4.1.25506.2.2.1.1.2.2)
Object (OID)
Access
Value range
Implementation
DisplayString
Login method, including Console, AUX, TTY, and VTY.
As per the MIB.
Notifications
hh3cLogIn
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.1
User login
Informational
Warning
ON
Notification triggers
This notification is generated when a user logs in to the system.
System impact
No impact on the system.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index nodes
Value range
1.3.6.1.4.1.25506.2.2.1.1.2.1 (hh3cTerminalUserName)
Username.
N/A
DisplayString
OCTET STRING (SIZE (0..255))
1.3.6.1.4.1.25506.2.2.1.1.2.2 (hh3cTerminalSource)
User line, including console, AUX, TTY, and VTY.
N/A
DisplayString
Recommended action
No action is required.
hh3cLogOut
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.2.1.1.3.0.2
User logout
Informational
Warning
N/A
ON
This notification is generated when a user logs out of the system.
System impact
Status control
Objects
OID (object name)
Index nodes
Value range
Username.
N/A
DisplayString
User line, including AUX, TTY, and VTY.
N/A
DisplayString
Recommended action
