02-Fundamentals
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Reference GuidesMIB CompanionH3C MSR5680-X3 Router MIB Reference-R9141-6W10002-Fundamentals
03-HH3C-SYS-MAN-MIB
03-HH3C-SYS-MAN-MIB 156.69 KB
HH3C-SYS-MAN-MIB
About this MIB
Use this MIB to manage the system time and daylight saving time, obtain the current configuration file and the version file, reboot the device, and upgrade device software. This MIB also contains notifications about configuration changes.
MIB file name
hh3c-sys-man.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSystemMan(3)
Scalar objects
hh3cSysLocalClock (1.3.6.1.4.1.25506.2.3.1.1.1)
Object (OID)
Access
Value range
Implementation
read-write
DateAndTime
OCTET STRING (8)
System time.
As per the MIB.
hh3cSysSummerTimeEnable (1.3.6.1.4.1.25506.2.3.1.1.2.1)
Object (OID)
Access
Value range
Implementation
read-only
INTEGER
enable(1)
disable(2)
Enables or disables using daylight saving time.
As per the MIB.
hh3cSysSummerTimeZone (1.3.6.1.4.1.25506.2.3.1.1.2.2)
Object (OID)
Access
Value range
Implementation
read-write
DisplayString
OCTET STRING (0..255)
Name for the daylight saving time schedule.
As per the MIB.
hh3cSysSummerTimeMethod (1.3.6.1.4.1.25506.2.3.1.1.2.4)
Object (OID)
Access
Value range
Implementation
hh3cSysSummerTimeMethod (1.3.6.1.4.1.25506.2.3.1.1.2.3)
read-write
INTEGER
oneOff(1)
repeating(2)
Implementation method of daylight saving time.
Supports only the repeating method.
hh3cSysSummerTimeStart (1.3.6.1.4.1.25506.2.3.1.1.2.4)
Object (OID)
Access
Value range
Implementation
read-write
DateAndTime
OCTET STRING (8)
Start time of the daylight saving time schedule.
As per the MIB.
hh3cSysSummerTimeEnd (1.3.6.1.4.1.25506.2.3.1.1.2.5)
Object (OID)
Access
Value range
Implementation
read-write
DateAndTime
OCTET STRING (8)
End time of the daylight saving time schedule.
As per the MIB.
hh3cSysSummerTimeOffset (1.3.6.1.4.1.25506.2.3.1.1.2.6)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Integer32 (0..86399)
Time to be added to the standard time.
As per the MIB.
hh3cSysLocalClockString (1.3.6.1.4.1.25506.2.3.1.1.3)
Object (OID)
Access
Value range
Implementation
read-write
OCTET STRING
OCTET STRING (16..24)
System time in the format of strings.
As per the MIB.
Same as hh3cSysLocalClock.
hh3cSysReloadSchedule (1.3.6.1.4.1.25506.2.3.1.3.1)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Integer32 (0..2147483647)
Reload entry index.
The device reboots if the value of the object is 1 on the occurrence of the reload operation.
hh3cSysReloadAction (1.3.6.1.4.1.25506.2.3.1.3.2)
Object (OID)
Access
Value range
Implementation
read-write
INTEGER
reloadUnavailable(1)
reloadOnSchedule(2)
reloadAtOnce(3)
reloadCancel(4)
Reload action.
As per the MIB.
hh3cSysReloadTag (1.3.6.1.4.1.25506.2.3.1.3.4)
Object (OID)
Access
Value range
Implementation
read-write
SnmpTagValue
Tag of the reload entry.
As per the MIB.
hh3cSysCFGFileNum (1.3.6.1.4.1.25506.2.3.1.5.1)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Number of configuration files.
As per the MIB.
hh3cSysPackageNum (1.3.6.1.4.1.25506.2.3.1.7.1)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Number of packages.
As per the MIB.
hh3cSysPackageOperateEntryLimit (1.3.6.1.4.1.25506.2.3.1.7.3)
Object (OID)
Access
Value range
Implementation
read-write
Integer32
Maximum number of package file operation entries.
Maximum number of instances in hh3cSysPackageOperateTable, in the range of 1 to 128. The default is 32.
If the number of the instances reaches the limit, the most recent instance overwrites the earliest one.
hh3cSysIpeFileNum (1.3.6.1.4.1.25506.2.3.1.8.1)
Object (OID)
Access
Value range
Implementation
read-only
Integer32
Number of IPE files.
As per the MIB.
Tabular objects
hh3cSysCurTable
About this table
This table contains information about the current system configuration file, device software, and bootrom files.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSysCurEntPhysicalIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysCurEntPhysicalIndex (1.3.6.1.4.1.25506.2.3.1.2.1.1.1)
not-accessible
Integer32
Device entity index.
As per the MIB.
hh3cSysCurCFGFileIndex (1.3.6.1.4.1.25506.2.3.1.2.1.1.2)
read-only
Integer32
Configuration file index.
As per the MIB.
hh3cSysReloadScheduleTable
About this table
This table specifies reboot entries for device reboot.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
You must specify hh3cSysReloadScheduleIndex, hh3cSysReloadEntity, and hh3cSysReloadRowStatus when you create a row. hh3cSysReloadEntity must be a valid entity. The entity index from hh3cSysReloadScheduleIndex must be the same with the index of hh3cSysReloadEntity.
An entity supports only one reload table. Entries in Active status are not configurable.
Columns
The table index is hh3cSysReloadScheduleIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysReloadScheduleIndex (1.3.6.1.4.1.25506.2.3.1.3.3.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Index of the hh3cSysReloadScheduleTable.
As per the MIB.
hh3cSysReloadEntity (1.3.6.1.4.1.25506.2.3.1.3.3.1.2)
read-create
Integer32
Entry in entPhysicalTable, which is the entity to be reloaded.
As per the MIB.
hh3cSysReloadCfgFile (1.3.6.1.4.1.25506.2.3.1.3.3.1.3)
read-create
Integer32
Integer32 (0.. 2147483647)
Entry in hh3cSysImageFileTable.
The value 0 indicates that the entity does not specify the next-startup configuration files.
hh3cSysReloadReason (1.3.6.1.4.1.25506.2.3.1.3.3.1.5)
read-create
DisplayString
Reason for system reloading.
As per the MIB.
hh3cSysReloadScheduleTime (1.3.6.1.4.1.25506.2.3.1.3.3.1.6)
read-create
DateAndTime
OCTET STRING (8)
Time when the reload action will occur.
As per the MIB.
hh3cSysReloadRowStatus (1.3.6.1.4.1.25506.2.3.1.3.3.1.7)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
As per the MIB.
hh3cSysReloadScheduleTagList (1.3.6.1.4.1.25506.2.3.1.3.3.1.8)
read-create
SnmpTagList
Tag list for the entry.
If the value of hh3cSysReloadSchedule is valid, the value of hh3cSysReloadScheduleTagList is ignored.
hh3cSysCFGFileTable
About this table
This table contains information about the configuration files of the system, including file names and file sizes.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSysCFGFileIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysCFGFileIndex (1.3.6.1.4.1.25506.2.3.1.5.2.1.1)
not-accessible
Integer32
As per the MIB.
hh3cSysCFGFileName (1.3.6.1.4.1.25506.2.3.1.5.2.1.2)
read-only
DisplayString
Configuration file name.
As per the MIB.
hh3cSysCFGFileSize (1.3.6.1.4.1.25506.2.3.1.5.2.1.3)
read-only
Integer32
Configuration file size.
As per the MIB.
hh3cSysCFGFileLocation (1.3.6.1.4.1.25506.2.3.1.5.2.1.4)
read-only
DisplayString
Configuration file path.
As per the MIB.
hh3cSysPackageTable
About this table
This table contains information about package files of the operating system, including basic package file information and operations on package files.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cSysPackageIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysPackageIndex (1.3.6.1.4.1.25506.2.3.1.7.2.1.1)
not-accessible
Integer32
Table index.
As per the MIB.
hh3cSysPackageName (1.3.6.1.4.1.25506.2.3.1.7.2.1.2)
read-only
DisplayString
Package file name.
As per the MIB.
hh3cSysPackageSize (1.3.6.1.4.1.25506.2.3.1.7.2.1.3)
read-only
Unsigned32
Unsigned32 (1..4294967295)
Package file size, in bytes.
As per the MIB.
hh3cSysPackageLocation (1.3.6.1.4.1.25506.2.3.1.7.2.1.4)
read-only
DisplayString
Package file path.
As per the MIB.
hh3cSysPackageType (1.3.6.1.4.1.25506.2.3.1.7.2.1.5)
read-only
INTEGER
boot(1)
system(2)
feature(3)
patch(4)
Type of the package file.
As per the MIB.
hh3cSysPackageAttribute (1.3.6.1.4.1.25506.2.3.1.7.2.1.6)
read-write
INTEGER
none(1)
primary(2)
secondary(3)
primarySecondary(4)
Attribute of the package file.
As per the MIB.
hh3cSysPackageStatus (1.3.6.1.4.1.25506.2.3.1.7.2.1.7)
read-only
INTEGER
active(1)
inactive(2)
Status of the package file.
As per the MIB.
hh3cSysPackageDescription (1.3.6.1.4.1.25506.2.3.1.7.2.1.8)
read-only
DisplayString
Description of the package file.
As per the MIB.
hh3cSysPackageFeature (1.3.6.1.4.1.25506.2.3.1.7.2.1.9)
read-only
DisplayString
Feature of the package file.
As per the MIB.
hh3cSysPackageVersion (1.3.6.1.4.1.25506.2.3.1.7.2.1.10)
read-only
DisplayString
Version of the package file.
As per the MIB.
About this table
This table manages package files.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
You must specify hh3cSysPackageOperateIndex, hh3cSysPackageOperateIndex, hh3cSysPackageOperateStatus, and hh3cSysPackageOperateRowStatus when you create a row. The package file specified by hh3cSysPackageOperateIndex must a valid feature package.
Columns
The table index is hh3cSysPackageOperateIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysPackageOperateIndex (1.3.6.1.4.1.25506.2.3.1.7.4.1.1)
not-accessible
Integer32
Entry index.
As per the MIB.
hh3cSysPackageOperatePackIndex (1.3.6.1.4.1.25506.2.3.1.7.4.1.2)
read-create
Integer32
Index of the specified package file.
As per the MIB.
hh3cSysPackageOperateStatus(1.3.6.1.4.1.25506.2.3.1.7.4.1.3)
read-create
INTEGER
active(1)
inactive(2)
Activation or deactivation of the package file.
As per the MIB.
hh3cSysPackageOperateRowStatu (1.3.6.1.4.1.25506.2.3.1.7.4.1.4)
read-create
RowStatus
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
As per the MIB.
hh3cSysPackageOperateResult(1.3.6.1.4.1.25506.2.3.1.7.4.1.5)
read-only
INTEGER
opInProgress(1)
opSuccess(2)
opUnknownFailure(3)
opInvalidFile(4)
opNotSupport(5)
Operation result.
As per the MIB.
hh3cSysIpeFileTable
About this table
This table contains information about IPE files.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cSysIpeFileIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysIpeFileIndex (1.3.6.1.4.1.25506.2.3.1.8.2.1.1)
not-accessible
Integer32
Index of an IPE file.
As per the MIB.
hh3cSysIpeFileName (1.3.6.1.4.1.25506.2.3.1.8.2.1.2)
read-only
DisplayString
IPE file name.
As per the MIB.
hh3cSysIpeFileSize (1.3.6.1.4.1.25506.2.3.1.8.2.1.3)
read-only
Unsigned32
IPE file size, in bytes.
As per the MIB.
hh3cSysIpeFileLocation (1.3.6.1.4.1.25506.2.3.1.8.2.1.4)
read-only
DisplayString
IPE file path.
As per the MIB.
hh3cSysIpePackageTable
About this table
This table contains information about packages in IPE files.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are hh3cSysIpeFileIndex and hh3cSysIpePackageIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysIpePackageIndex (1.3.6.1.4.1.25506.2.3.1.8.3.1.1)
not-accessible
Integer32
IPE package index.
As per the MIB.
hh3cSysIpePackageName (1.3.6.1.4.1.25506.2.3.1.8.3.1.2)
read-only
DisplayString
Package file name.
As per the MIB.
hh3cSysIpePackageSize (1.3.6.1.4.1.25506.2.3.1.8.3.1.3)
read-only
Unsigned32
As per the MIB.
hh3cSysIpePackageType (1.3.6.1.4.1.25506.2.3.1.8.3.1.4)
read-only
INTEGER
boot(1)
system(2)
feature(3)
patch(4)
As per the MIB.
hh3cSysPackageDescription (1.3.6.1.4.1.25506.2.3.1.8.3.1.5)
read-only
DisplayString
As per the MIB.
hh3cSysIpePackageFeature (1.3.6.1.4.1.25506.2.3.1.8.3.1.6)
read-only
DisplayString
As per the MIB.
hh3cSysIpePackageVersion (1.3.6.1.4.1.25506.2.3.1.8.3.1.7)
read-only
DisplayString
As per the MIB.
hh3cSysIpeFileOperateTable
About this table
This table manages IPE files.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
You must specify hh3cSysIpeFileOperateInde, hh3cSysIpeFileOperateIndex, hh3cSysIpeFileOperateAttribute, and hh3cSysIpeFileOperateRowStatus when you create a row.
Columns
The table index is hh3cSysIpeFileOperateIndex.
Object (OID)
Access
Value range
Implementation
hh3cSysIpeFileOperateIndex (1.3.6.1.4.1.25506.2.3.1.8.4.1.1)
not-accessible
Integer32
Entry index.
If the entity index is 1, IPE files will be decompressed to the active MPU.
hh3cSysIpeFileOperateFileIndex (1.3.6.1.4.1.25506.2.3.1.8.4.1.2)
read-create
Integer32
The value of this object is an instance index in hh3cSysIpeFileTable.
hh3cSysIpeFileOperateAttribute(1.3.6.1.4.1.25506.2.3.1.8.4.1.3)
read-create
INTEGER
none(1)
primary(2)
secondary(3)
primarySecondary(4)
Attribute of the IPE file.
As per the MIB.
hh3cSysIpeFileOperateRowStatus (1.3.6.1.4.1.25506.2.3.1.8.4.1.4)
read-create
INTEGER
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Row status.
As per the MIB.
hh3cSysIpeFileOperateResult (1.3.6.1.4.1.25506.2.3.1.8.4.1.5)
read-only
INTEGER
opInProgress(1)
opSuccess(2)
opUnknownFailure(3)
opInvalidFile(4)
opDeviceFull(5)
opFileOpenError(6)
Operation result.
As per the MIB.
