15-High Availability
HomeSupportRoutersSR6602-I[IE] SeriesReference GuidesMIB CompanionH3C SR6602-I[IE] AI-Powered ICT Converged Gateways MIB Reference(V9)-R9141-6W10015-High Availability
02-HH3C-BFD-STD-MIB
02-HH3C-BFD-STD-MIB 77.31 KB
HH3C-BFD-STD-MIB
About this MIB
Upper layer protocols implement fast fault detection through the link layer. The fault detection time varies by link type, and failures might not be detected sometimes. POS has the fastest detection speed of approximately 50 milliseconds, which is used to measure fault detection time for other protocols.
BFD provides a general-purpose, standard, medium- and protocol-independent fast failure detection mechanism. BFD can uniformly and quickly detect the failures of the bidirectional forwarding paths between two devices for upper-layer protocols such as routing protocols and MPLS. BFD can provide detection measured in milliseconds, which is close to the detection time implemented by POS.
This document describes the following variables required to implement BFD:
·     hh3cBfdGlobalObjects includes hh3cBfdVersionNumber (version number), hh3cBfdSysInitMode (session initialization mode), hh3cBfdSessNotificationsEnable (SNMP notifications switch), and hh3cBfdSessNumberLimit (session limit).
·     hh3cBfdIfTable describes BFD interface information.
·     hh3cBfdSessTable describes BFD session information.
·     hh3cBfdSessStatTable describes BFD session statistics information.
·     hh3cBfdSessPerfTable describes BFD session performance information.
·     In hh3cBfdNotifications, hh3cBfdSessStateChange describes session state changes (from up to another state, or from another state to up), and hh3cBfdSessAuthFail describes authentication failure information.
HH3C-BFD-STD-MIB is based on draft-ietf-bfd-base-04.txt. This MIB is used for network management protocols in the Internet communities. It describes the objects used to configure or monitor bidirectional forwarding on devices supporting BFD.
MIB file name
hh3c-bfd-std.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cBfdMIB(72)
Scalar objects
hh3cBfdSessNotificationsEnable(1.3.6.1.4.1.25506.2.72.1.1.3)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1), false(2)
Whether SNMP notifications is enabled.
As per the MIB.
Tabular objects
hh3cBfdIfTable
About this table
This table contains information about the interface enabled with BFD.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cBfdIfIndex.
Object (OID)
Access
Value range
Implementation
hh3cBfdIfIndex(1.3.6.1.4.1.25506.2.72.1.2.1.1)
accessible-for-notify
InterfaceIndex
Integer32(1..2147483647)
Index of the interface enabled with BFD.
As per the MIB.
hh3cBfdIfDesiredMinTxInterval(1.3.6.1.4.1.25506.2.72.1.2.1.2)
read-write
BfdInterval
Unsigned32(1..4294967295)
Minimum interval for transmitting BFD control packets.
Supports only the read operation.
hh3cBfdIfDesiredMinRxInterval(1.3.6.1.4.1.25506.2.72.1.2.1.3)
read-write
BfdInterval
Minimum interval for receiving BFD control packets.
hh3cBfdIfDetectMult(1.3.6.1.4.1.25506.2.72.1.2.1.4)
read-write
Unsigned32
Standard MIB values.
Detection time multiplier for control packet mode.
hh3cBfdIfAuthType(1.3.6.1.4.1.25506.2.72.1.2.1.5)
read-only
INTEGER
none(1), simple(2), md5(3), mmd5(4), sha1(5), msha1(6). The default value is none.
BFD authentication mode for BFD control packets.
As per the MIB.
hh3cBfdSessTable
About this table
This table contains BFD session information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cBfdSessIndex.
Object (OID)
Access
Value range
Implementation
hh3cBfdSessIndex (1.3.6.1.4.1.25506.2.72.1.3.1.1)
BfdSessIndexTC
Unsigned32(0..4294967295)
Session index that uniquely identifies a session.
As per the MIB.
 hh3cBfdSessIfIndex (1.3.6.1.4.1.25506.2.72.1.3.1.2)
read-only
InterfaceIndexOrZero
Integer32 (0..2147483647)
Index of the interface where the BFD session resides.
As per the MIB.
hh3cBfdSessAppSupportId(1.3.6.1.4.1.25506.2.72.1.3.1.3)
read-only
Hh3cAlarmStatus
BITS
none(0), ospf(1), isis(2), bgp(3), mpls(4)
Upper-layer protocols supported by the BFD session.
As per the MIB.
hh3cBfdSessLocalDiscr(1.3.6.1.4.1.25506.2.72.1.3.1.4)
read-only
Unsigned32
Local discriminator of the BFD session, which is a unique non-zero value.
As per the MIB.
hh3cBfdSessRemoteDiscr(1.3.6.1.4.1.25506.2.72.1.3.1.5)
read-only
Unsigned32
Remote discriminator of the BFD session. The initial value is 0.
As per the MIB.
hh3cBfdSessDstPort(1.3.6.1.4.1.25506.2.72.1.3.1.6)
read-only
InetPortNumber
The default value is 3784.
UDP port number of the BFD session.
As per the MIB.
hh3cBfdSessOperMode(1.3.6.1.4.1.25506.2.72.1.3.1.7)
read-only
INTEGER
asynchModeWOEchoFun(1),              demandModeWOEchoFunction(2),            asyncModeWEchoFun(3),            demandModeWEchoFunction(4). The default value is asynchModeWOEchoFun.
BFD session mode.
As per the MIB.
hh3cBfdSessAddrType(1.3.6.1.4.1.25506.2.72.1.3.1.8)
read-only
InetAddressType
INTEGER{
unknown(0),
ipv4(1),
ipv6(2),
dns(16)
IP address type of the interface where the BFD session resides.
As per the MIB.
hh3cBfdSessLocalAddr(1.3.6.1.4.1.25506.2.72.1.3.1.9)
read-only
InetAddress
OCTET STRING (0..255)
IP address of the interface where the BFD session resides.
As per the MIB.
hh3cBfdSessRemoteAddr(1.3.6.1.4.1.25506.2.72.1.3.1.10)
read-only
InetAddress
IP address of the interface that receives BFD packets.
As per the MIB.
hh3cBfdSessLocalDiag(1.3.6.1.4.1.25506.2.72.1.3.1.11)
read-only
BfdDiag
noDiagnostic(1),                      controlDetectionTimeExpired(2),                       echoFunctionFailed(3),                      neighborSignaledSessionDown(4),                       forwardingPlaneReset(5),                     pathDown(6),                       concatenatedPathDown(7),                       administrativelyDown(8),                    reverseConcatenatedPathDown(9).
The default value is noDiagnostic.
Diagnosis code that indicates the most recent BFD session state change reason.
As per the MIB.
hh3cBfdSessState(1.3.6.1.4.1.25506.2.72.1.3.1.12)
read-only
INTEGER
adminDown(0),              down(1),                       init(2),                            up(3),
The default value is DOWN.
Current state of the BFD session.
As per the MIB.
hh3cBfdSessControlPlanIndepFlag(1.3.6.1.4.1.25506.2.72.1.3.1.13)
read-only
TruthValue
true(1), false(2).
The default value is false.
Whether the BFD session can operate independently of the control plane.
As per the MIB.
hh3cBfdSessAuthFlag(1.3.6.1.4.1.25506.2.72.1.3.1.14)
read-only
TruthValue
true(1), false(2).
Flag that indicates whether the BFD session requires authentication.
As per the MIB.
hh3cBfdSessDemandModeFlag(1.3.6.1.4.1.25506.2.72.1.3.1.15)
read-only
TruthValue
true(1),
false(2)
Whether the BFD session supports the Demand mode.
As per the MIB.
