11-Network Management and Monitoring
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Diagnose & MaintainAlarms ReferencesH3C MSR5680-X3 Router Alarm Reference-R9141-6W10011-Network Management and Monitoring
06-RMON-MIB
06-RMON-MIB 62.92 KB
RMON-MIB
About this MIB
Use this MIB to monitor data traffic on a network segment or the entire network.
MIB file name
rfc2819-rmon.mib
Notifications
risingAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.2.1.16.0.1
Monitored object exceeded the threshold.
Informational
Warning
N/A
ON
Notification triggers
This notification is generated when the value of a monitored object exceeds the upper threshold and SNMP notification is configured for the corresponding alarm event.
System impact
No negative impact on the system.
Status control
ON
CLI: rmon event entry-number [ description string ] { log-trap security-string | trap security-string } [ owner text ]
OFF
CLI: rmon event entry-number [ description string ] { log | none } [ owner text ]
Objects
OID (object)
Index nodes
Value range
1.3.6.1.2.1.16.3.1.1.1 (alarmIndex)
Alarm group index.
alarmIndex
Integer32
1..65535
1.3.6.1.2.1.16.3.1.1.3 (alarmVariable)
Alarm object.
alarmIndex
OBJECT IDENTIFIER
Standard MIB values.
1.3.6.1.2.1.16.3.1.1.4 (alarmSampleType)
Sampling type.
alarmIndex
INTEGER
absoluteValue(1), deltaValue(2)
1.3.6.1.2.1.16.3.1.1.5 (alarmValue)
Sample value.
alarmIndex
Integer32
1.3.6.1.2.1.16.3.1.1.7 (alarmRisingThreshold)
Alarm rising threshold.
alarmIndex
Integer32
Recommended action
1.     Execute the display rmon alarm command in any view to view the monitored objects and their alarm thresholds. Examine the monitored object, identify the cause of the alarm, and resolve the issues.
2.     If the threshold is inappropriate, execute the rmon alarm command in system view to change the alarm threshold.
3.     If the issue persists, collect alarm information and configuration information, and contact Technical Support.
fallingAlarm
Basic information
OID
Event
Severity
Default status
1.3.6.1.2.1.16.0.2
Monitored object dropped below the threshold.
Informational
Warning
N/A
ON
This notification is generated when the value of a monitored object drops below the lower threshold and SNMP notification is configured for the corresponding alarm event.
System impact
Status control
ON
OFF
Objects
OID (object)
Index nodes
Value range
Alarm group index.
alarmIndex
Integer32
1..65535
Alarm object.
alarmIndex
OBJECT IDENTIFIER
Sampling type.
alarmIndex
INTEGER
Sample value.
alarmIndex
Integer32
1.3.6.1.2.1.16.3.1.1.8 (alarmFallingThreshold)
Alarm decreasing threshold.
alarmIndex
Integer32
Recommended action
