11-Network Management and Monitoring
HomeSupportRoutersMSR5600-X3 Series(Comware V9)Diagnose & MaintainAlarms ReferencesH3C MSR5680-X3 Router Alarm Reference-R9141-6W10011-Network Management and Monitoring
04-HH3C-NQA-MIB
04-HH3C-NQA-MIB 202.55 KB
HH3C-NQA-MIB
About this MIB
Use this MIB to implement the following functions:
·     Configure the extended attributes for NQA operations.
·     Display the statistical results of the NQA operations.
·     Display the extended results of the jitter operations.
·     Configure TCP/UDP server properties.
·     Save the statistical results of an operation in a certain period and save multiple statistics groups.
·     Save a certain number of history records for an operation.
·     Configure the start and end time for each operation.
·     Display the statistical results and history records in a certain period.
MIB file name
hh3c-nqa.mib
Notifications
hh3cNqaProbeTimeOverThreshold
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.8.3.3.1
Threshold violation of the probe duration.
Informational
Warning
N/A
OFF
Notification triggers
For average or consecutive threshold type, this notification is generated if the threshold status changed when a operation was completed.
For accumulative threshold type, this notification is generated if the threshold status changed when a probe was completed.
System impact
No negative impact on services.
Status control
ON
CLI: Use the reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object)
Index nodes
Value range
1.3.6.1.4.1.25506.8.3.1.13.1.1 (hh3cNqaReactOwnerIndex)
Administrator name of an operation.
hh3cNqaReactTestName
hh3cNqaReactItemIndex
SnmpAdminString
OCTET STRING(0..32)
1.3.6.1.4.1.25506.8.3.1.13.1.2 (hh3cNqaReactTestName)
Operation tag of the operation.
SnmpAdminString
OCTET STRING(0..32)
1.3.6.1.4.1.25506.8.3.1.13.1.3 (hh3cNqaReactItemIndex)
Reaction entry number.
Unsigned32
Unsigned32 (1..10)
1.3.6.1.2.1.80.1.2.1.3 (pingCtlTargetAddressType)
Type of destination address.
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
Standard MIB values.
1.3.6.1.2.1.80.1.2.1.4 (pingCtlTargetAddress)
Destination address.
pingCtlOwnerIndex
pingCtlTestName
InetAddress
1.3.6.1.2.1.80.1.2.1.16 (pingCtlType)
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
1.3.6.1.2.1.80.1.2.1.17 (pingCtlDescr)
Description of the operation.
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
OCTET STRING(0..255)
1.3.6.1.4.1.25506.8.3.1.13.1.7 (hh3cNqaReactThresholdType)
Threshold type.
INTEGER
invalid(0), average(1), consecutive(2), accumulative(3)
1.3.6.1.4.1.25506.8.3.1.13.1.11 (hh3cNqaReactCurrentStatus)
Alarm status.
INTEGER
invalid(1), overThreshold(2), belowThreshold(3),                            overUpperThreshold(4), belowLowerThreshold(5)
Recommended action
To resolve the issue:
1.     Execute the display this command in NQA operation view to identify whether the destination address configuration is correct.
¡     If the parameters are correctly configured, proceed to step 2.
¡     If the parameter configuration is incorrect, execute the destination ip command in NQA operation view to change the destination address. Restart the operation, and check whether the notification is still generated.
-     If the notification is no longer generated, the issue is resolved.
-     If the notification is still generated, proceed to step 2.
2.     Execute the ping command in NQA operation view to identify whether the route is reachable.
¡     If the route is reachable, proceed to step 3.
¡     If the route is unreachable, locate the cause for the reachability issue first. For example, you can execute the display ip routing-table command to display the routing table information and troubleshoot the route issue.
3.     Execute the probe timeout command in NQA operation view to edit the timeout timer based on the network condition. Restart the operation, and check whether the notification is still generated.
¡     If the notification is no longer generated, the issue is resolved.
¡     If the notification is still generated, proceed to step 4.
4.     Execute the display this command in NQA operation view to obtain the threshold setting, and then execute the reaction checked-element probe-duration command in NQA operation view to edit the threshold as needed. Restart the operation, and check whether the notification is still generated.
5.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cNqaJitterRTTOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.2
Threshold violation of the probe round-trip time.
Informational
Warning
N/A
OFF
This notification is generated when the round-trip time of test packets in a UDP-jitter or voice operation exceeds the specified threshold.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object)
Index nodes
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
OCTET STRING(0..32)
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
1.     Execute the display this command in NQA operation view to obtain the threshold setting, and then execute the reaction checked-element rtt command in NQA operation view to edit the threshold as needed. Restart the operation, and check whether the notification is still generated.
2.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cNqaProbeFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.3
Threshold violation of the probe failure.
Informational
Warning
N/A
OFF
For consecutive threshold type, this notification is generated if the threshold status changed when an operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } action-type none command or the undo reaction item-number command.
Objects
OID (object)
Index nodes
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
4.     If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
hh3cNqaJitterPacketLoss
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.4
Threshold violation of the packet loss ratio.
Informational
Warning
N/A
OFF
This notification is generated if the threshold status changed when a UDP jitter or voice operation for monitoring threshold violation of the packet loss ratio was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences action-type none command or the undo reaction item-number command.
Objects
OID (object)
Index nodes
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
1.     Find out the cause of packet loss on the link.
2.     If the issue persists, contact H3C Support.
hh3cNqaJitterSDOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.5
Threshold violation of the one-way jitter from source to destination.
Informational
Warning
N/A
OFF
This notification is generated when the threshold violation of the one-way jitter from source to destination for UDP jitter and voice operations occurs. The object supports only accumulate and average threshold types. This notification is generated if the threshold status changed when a UDP jitter or voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element jitter-sd threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element jitter-sd threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object name)
Index nodes
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
1.3.6.1.2.1.80.1.2.1.3 (PingCtlTargetAddressType)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
1.3.6.1.2.1.80.1.2.1.4 (PingCtlTargetAddress)
pingCtlOwnerIndex
pingCtlTestName
InetAddress
1.3.6.1.2.1.80.1.2.1.16 (PingCtlType)
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
1.3.6.1.2.1.80.1.2.1.17 (PingCtlDescr)
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
1.     Execute the display this command in NQA operation view to obtain the threshold setting, and then execute the reaction checked-element { jitter-ds | jitter-sd } command in NQA operation view to edit the threshold as needed. Restart the operation, and check whether the notification is still generated.
hh3cNqaJitterDSOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.6
Threshold violation of the one-way jitter from destination to source.
Informational
Warning
N/A
OFF
This notification is generated when the threshold violation of the one-way jitter from destination to source for UDP jitter and voice operations occurs. The object supports only accumulate and average threshold types. This notification is generated if the threshold status changed when a UDP jitter or voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element jitter-ds threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element jitter-ds threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object name)
Index nodes
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Threshold type.
INTEGER
Alarm status.
INTEGER
Recommended action
hh3cNqaICPIFOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.7
Threshold violation of the ICPIF value.
Informational
Warning
N/A
OFF
This notification is generated when the ICPIF value of a voice operation exceeds the threshold. This notification is generated if the threshold status changed when a voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object name)
Index nodes
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Alarm status.
INTEGER
invalid(1), overThreshold(2),, belowThreshold(3), overUpperThreshold(4), belowLowerThreshold(5)
Recommended action
1.     Find out the cause of the ICPIF value changes on the probe link.
hh3cNqaMOSOverThreshold
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.8.3.3.8
Threshold violation of the MOS value.
Informational
Warning
N/A
OFF
This notification is generated when the MOS value of a voice operation exceeds the threshold. This notification is generated if the threshold status changed when a voice operation was completed.
System impact
Status control
ON
CLI: Use the reaction item-number checked-element mos threshold-value upper-threshold lower-threshold action-type trap-only command.
OFF
CLI: Use the reaction item-number checked-element mos threshold-value upper-threshold lower-threshold action-type none command or the undo reaction item-number command.
Objects
OID (object name)
Index nodes
Value range
SnmpAdminString
OCTET STRING(0..32)
SnmpAdminString
OCTET STRING(0..32)
Unsigned32
Unsigned32 (1..10)
pingCtlOwnerIndex
pingCtlTestName
InetAddressType
pingCtlOwnerIndex
pingCtlTestName
InetAddress
Operation type.
pingCtlOwnerIndex
pingCtlTestName
OBJECT IDENTIFIER
pingCtlOwnerIndex
pingCtlTestName
SnmpAdminString
Alarm status.
INTEGER
Recommended action
1.     Find out the cause of the MOS value changes on the probe link.
