16-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C MSR1000[2600][3600] Routers MIB Reference(V9)-R9141-6W10016-Network Management and Monitoring
14-SNMP-USER-BASED-SM-MIB
14-SNMP-USER-BASED-SM-MIB 90.38 KB
About this MIB
Use this MIB to implement the SNMP user-based security model.
MIB file name
rfc3414-snmp-usm.mib
Root object
iso(1).org(3).dod(6).internet(1).snmpV2(6).snmpModules(3).snmpUsmMIB(15)
Scalar objects
usmStatsUnsupportedSecLevels
Object (OID)
Access
Value range
Implementation
usmStatsUnsupportedSecLevels (1.3.6.1.6.3.15.1.1.1)
read-only
Counter32
Standard MIB values
Total number of packets received but dropped by the SNMP engine because they requested a security level unknown to the SNMP engine or not available.
As per the MIB.
usmStatsNotInTimeWindows
Object (OID)
Access
Value range
Implementation
usmStatsNotInTimeWindows (1.3.6.1.6.3.15.1.1.2)
read-only
Counter32
Standard MIB values
Total number of packets received but dropped by the SNMP engine because they appeared outside of the authoritative SNMP engine's window.
As per the MIB.
usmStatsUnknownUserNames
Object (OID)
Access
Value range
Implementation
usmStatsUnknownUserNames (1.3.6.1.6.3.15.1.1.3)
read-only
Counter32
Standard MIB values
Total number of packets received but dropped by the SNMP engine because they referenced a user unknown to the SNMP engine.
As per the MIB.
usmStatsUnknownEngineIDs
Object (OID)
Access
Value range
Implementation
usmStatsUnknownEngineIDs (1.3.6.1.6.3.15.1.1.4)
read-only
Counter32
Standard MIB values
Total number of packets received but dropped by the SNMP engine because they referenced an SNMP Engine ID unknown to the SNMP engine.
As per the MIB.
usmStatsWrongDigests
Object (OID)
Access
Value range
Implementation
usmStatsWrongDigests (1.3.6.1.6.3.15.1.1.5)
read-only
Counter32
Standard MIB values
Total number of packets received but dropped by the SNMP engine because they did not contain the expected digest value.
As per the MIB.
usmStatsDecryptionErrors
Object (OID)
Access
Value range
Implementation
usmStatsDecryptionErrors (1.3.6.1.6.3.15.1.1.6)
read-only
Counter32
Standard MIB values
Total number of packets received but dropped by the SNMP engine because they could not be decrypted.
As per the MIB.
usmUserSpinLock
Object (OID)
Access
Value range
Implementation
usmUserSpinLock (1.3.6.1.6.3.15.1.2.1)
read-write
TestAndIncr
Standard MIB values
An advisory lock used to allow several cooperating command generator applications to coordinate their use of facilities to alter secrets in the usmUserTable.
As per the MIB.
Tabular objects
usmUserTable
About this table
Use this table to create users.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table indexes are usmUserEngineID and usmUserName.
Object (OID)
Access
Value range
Implementation
usmUserEngineID (1.3.6.1.6.3.15.1.2.2.1.1)
not-accessible
SnmpEngineID
OCTET STRING (5..32)
Administratively unique identifier for the SNMP engine.
As per the MIB.
usmUserName (1.3.6.1.6.3.15.1.2.2.1.2)
not-accessible
SnmpAdminString
OCTET STRING (1..32)
Use name. It is the (user-based security) model dependent security ID.
The value can contain only displayable characters except question marks.
usmUserSecurityName (1.3.6.1.6.3.15.1.2.2.1.3)
read-only
SnmpAdminString
OCTET STRING (0..255)
A human readable string representing the user in security model independent format.
The default transformation of the user-based security model dependent security ID to the security name and vice versa is the identity function so that the security name is the same as the user name.
As per the MIB.
usmUserCloneFrom (1.3.6.1.6.3.15.1.2.2.1.4)
read-create
RowPointer
Standard MIB values
A pointer to another conceptual row in this usmUserTable. The user in this other conceptual row is called the clone-from user.
This object must be specified for creating an instance.
If the object corresponds to a user created by the command line, this operation succeeds but does not take effect.
When a new user is created (a new conceptual row is instantiated in this table), the privacy and authentication parameters of the new user must be cloned from its clone-from user. These parameters are:
·     authentication protocol (usmUserAuthProtocol)
·     privacy protocol (usmUserPrivProtocol)
They will be copied regardless of what the current value is.
Cloning also causes the initial values of the secret authentication key (authKey) and the secret encryption key (privKey) of the new user to be set to the same values as the corresponding secrets of the clone-from user to allow the KeyChange process to occur as required during user creation.
The first time an instance of this object is set by a management operation (either at or after its instantiation), the cloning process is invoked.
Subsequent writes are successful but invoke no action to be taken by the receiver.
The cloning process fails with an inconsistentName error if the conceptual row representing the clone-from user does not exist or is not in an active state when the cloning process is invoked.
When this object is read, the ZeroDotZero OID is returned.
usmUserAuthProtocol (1.3.6.1.6.3.15.1.2.2.1.5)
read-create
AutonomousType
Standard MIB values
Indicates whether messages sent on behalf of this user to/from the SNMP engine identified by usmUserEngineID can be authenticated and the authentication protocol to be used.
As per the MIB.
usmUserAuthKeyChange (1.3.6.1.6.3.15.1.2.2.1.6)
read-create
KeyChange
-- typically (SIZE (0 | 32)) for HMACMD5
-- typically (SIZE (0 | 40)) for HMACSHA
An object, which when modified, causes the secret authentication key used for messages sent on behalf of this user to/from the SNMP engine identified by usmUserEngineID, to be modified via a one-way function.
When read, this object returns a zero-length string.
usmUserOwnAuthKeyChange (1.3.6.1.6.3.15.1.2.2.1.7)
read-create
KeyChange
Functions exactly as usmUserAuthKeyChange, with one notable difference: in order for the set operation to succeed, the usmUserName of the operation requester must match the usmUserName that indexes the row which is targeted by this operation.
usmUserPrivProtocol (1.3.6.1.6.3.15.1.2.2.1.8)
read-create
AutonomousType
Standard MIB values
An indication of whether messages sent on behalf of this user to/from the SNMP engine identified by usmUserEngineID can be protected from disclosure, and the type of privacy protocol to be used.
As per the MIB.
usmUserPrivKeyChange (1.3.6.1.6.3.15.1.2.2.1.9)
read-create
KeyChange
-- typically (SIZE (0 | 32)) for DES
An object, which when modified, causes the secret encryption key used for messages sent on behalf of this user to/from the SNMP engine identified by usmUserEngineID, to be modified via a one-way function.
usmUserOwnPrivKeyChange (1.3.6.1.6.3.15.1.2.2.1.10)
read-create
KeyChange
Standard MIB values
Functions exactly as usmUserPrivKeyChange, with one notable difference: in order for the Set operation to succeed, the usmUserName of the operation requester must match the usmUserName that indexes the row which is targeted by this operation.
usmUserPublic (1.3.6.1.6.3.15.1.2.2.1.11)
read-create
OCTET STRING
OCTET STRING (0..32)
A publicly-readable value that can be written as part of the procedure for changing a user's secret authentication and/or privacy key, and later read to determine whether the change of the secret was effected.
As per the MIB.
usmUserStorageType (1.3.6.1.6.3.15.1.2.2.1.12)
read-create
StorageType
other(1),
volatile(2),
nonVolatile(3),
permanent(4),
readOnly(5)
Storage type for this conceptual row.
Supports only nonVolatile(3).
usmUserStatus (1.3.6.1.6.3.15.1.2.2.1.13)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
