16-Network Management and Monitoring
HomeSupportReference GuidesMIB CompanionH3C MSR1000[2600][3600] Routers MIB Reference(V9)-R9141-6W10016-Network Management and Monitoring
07-HH3C-SNMP-EXT-MIB
07-HH3C-SNMP-EXT-MIB 64.65 KB
HH3C-SNMP-EXT-MIB
About this MIB
This MIB adds objects to extend SNMP management.
MIB file name
hh3c-snmp-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSnmpExt(104)
Scalar objects
hh3cSnmpExtMaxContextNum
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtMaxContextNum (1.3.6.1.4.1.25506.2.104.1.4)
read-only
Integer32
Integer32 (1..65535)
Maximum number of SNMP contexts supported by the system.
As per the MIB.
hh3cSnmpExtVersion
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtVersion (1.3.6.1.4.1.25506.2.104.1.5)
read-write
BITS
BITS { snmpV1(0), snmpV2c(1), snmpV3(2) }
SNMP version.
As per the MIB.
hh3cSnmpExtTrapSource
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtTrapSource (1.3.6.1.4.1.25506.2.104.1.6)
read-only
SnmpAdminString
OCTET STRING (0..255)
Interface, the SNMP agent uses the primary IP address of which as the source IP address in all its traps.
As per the MIB.
hh3cSnmpExtInformSource
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtInformSource (1.3.6.1.4.1.25506.2.104.1.7)
read-only
SnmpAdminString
OCTET STRING(1..63)
Interface, the SNMP agent uses the primary IP address of which as the source IP address in all its informs.
As per the MIB.
Tabular objects
hh3cSnmpExtCommunityTable
About this table
Use this table to configure the extended properties for SNMP communities (SNMPv1 or SNMPv2c) and SNMP users (SNMPv3).
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are hh3cSnmpExtCommunitySecurityLevel and hh3cSnmpExtCommunitySecurityName.
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtCommunitySecurityLevel (1.3.6.1.4.1.25506.2.104.2.1.1.1)
not-accessible
SnmpSecurityModel
INTEGER (0..3)
Security model of a community or user.
As per the MIB.
hh3cSnmpExtCommunitySecurityName (1.3.6.1.4.1.25506.2.104.2.1.1.2)
not-accessible
SnmpAdminString
OCTET STRING (1..32)
Security name of the community or user.
As per the MIB.
hh3cSnmpExtCommunityName (1.3.6.1.4.1.25506.2.104.2.1.1.3)
read-only
OCTET STRING
Community name or username.
As per the MIB.
hh3cSnmpExtCommunityAclNum (1.3.6.1.4.1.25506.2.104.2.1.1.4)
read-write
Integer32
Integer32 (0 | 2000..3999)
IPv4 ACL number used by the community or the user.
As per the MIB.
hh3cSnmpExtCommunityIPv6AclNum (1.3.6.1.4.1.25506.2.104.2.1.1.5)
read-write
Integer32
IPv6 ACL number used by the community or the user.
As per the MIB.
hh3cSnmpExtContextTable
About this table
Use this table to configure SNMP contexts.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is hh3cSnmpExtContextName.
Object (OID)
Access
Value range
Implementation
hh3cSnmpExtContextName (1.3.6.1.4.1.25506.2.104.2.3.1.1)
not-accessible
SnmpAdminString
SNMP context name.
As per the MIB.
hh3cSnmpExtContextRowStatus (1.3.6.1.4.1.25506.2.104.2.3.1.2)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Status of the SNMP entity context row.
Supports only action, createAndGo, and destroy.
