- 14-Security Configuration Guide
- 01-ACL configuration
- 02-Time range configuration
- 03-User profile configuration
- 04-Public key management
- 05-PKI configuration
- 06-SSH configuration
- 07-SSL configuration
- 08-Session management
- 09-Attack detection and prevention configuration
- 10-ARP attack protection configuration
- 11-ND attack defense configuration
- 12-Crypto engine configuration
- 13-Connection limit configuration
- 14-Password control configuration
- 15-APR configuration
02-Time range configuration | 57.23 KB |
Restrictions and guidelines: Time range configuration
Specifying a tenant for a time range
Display and maintenance commands for time ranges
Configuring time ranges
About time ranges
You can implement a service based on the time of the day by applying a time range to it. A time-based service takes effect only in time periods specified by the time range. For example, you can implement time-based ACL rules by applying a time range to them.
The following basic types of time ranges are available:
· Periodic time range—Recurs periodically on a weekly or monthly basis.
· Absolute time range—Represents only a period of time and does not recur.
The active period of a time range is calculated as follows:
1. Combining all periodic statements.
2. Combining all absolute statements.
3. Taking the intersection of the two statement sets as the active period of the time range.
When you configure the ACL hardware mode, follow these restrictions and guidelines:
· If a time range does not exist, the service based on the time range does not take effect.
· A time range can contain a maximum of 32 periodic statements and 12 absolute statements.
Configuring a time range
1. Enter system view.
2. Create or edit a time range.
time-range time-range-name { { monthly | weekly } start-day start-time to end-day end-time [ from time1 date1 ] [ to time2 date2 ] | start-time to end-time [ days | monthly { date1 [ to date2] } &<1-31> ] * [ from time1 date1 ] [ to time2 date2 ] | from time1 date1 [ to time2 date2 ] | to time2 date2 }
If an existing time range name is provided, this command adds a statement to the time range.
3. (Optional.) Configure a description for the time range.
time-range time-range-name description text
By default, a time range does not have a description.
In a yundi scenario, a large number of tenants exist, and the controller assigns each tenant a unique tenant ID and deploys tenant IDs and associated time ranges to firewalls through NETCONF. A firewall generates this command based on the deployed information to make the security policy of the tenant take effect only during the time range. If the time range associated with a tenant does not exist, the system creates a new time range.
Tenant IDs are typically assigned by the controller. As a best practice, do not configure this feature on the device.
A time range can be associated with only one tenant.
A tenant can be associated with multiple time ranges. The time range that takes effect is the intersection of all the time ranges.
2. Specify a tenant for a time range.
time-range time-range-name yundi alias alias-name tenant tenant-id
By default, a time range does not belong to any tenant. The security policy of the tenant is always in effect.
Execute the display command in any view.
Task |
Command |
Display time range configuration and status. |
display time-range { time-range-name | all } |
