- 14-Security Configuration Guide
- 01-ACL configuration
- 02-Time range configuration
- 03-User profile configuration
- 04-Public key management
- 05-PKI configuration
- 06-SSH configuration
- 07-SSL configuration
- 08-Session management
- 09-Attack detection and prevention configuration
- 10-ARP attack protection configuration
- 11-ND attack defense configuration
- 12-Crypto engine configuration
- 13-Connection limit configuration
- 14-Password control configuration
- 15-APR configuration
00-Preface | 110.04 KB |
Preface
The H3C Wi-Fi 7 Access Points Cloud Mode documentation set describes the software features for the APs(cloud mode) and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access points (Cloud mode).
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
