08-Radio Resources Management Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Wi-Fi 7 Access Points Cloud Mode Command References(R2610P06)-6W10008-Radio Resources Management Command Reference
06-WLAN RRM commands
06-WLAN RRM commands 260.10 KB
WLAN RRM commands· 1
calibrate-bandwidth self-decisive· 1
calibrate-channel 2.4g channel-usage-threshold· 1
calibrate-channel 2.4g crc-error-threshold· 2
calibrate-channel 2.4g interference-threshold· 3
calibrate-channel 2.4g noise-threshold· 4
calibrate-channel 2.4g receive-service-traffic threshold· 4
calibrate-channel 2.4g retransmission-threshold· 5
calibrate-channel 2.4g tolerance-level 6
calibrate-channel 5g channel-usage-threshold· 7
calibrate-channel 5g crc-error-threshold· 7
calibrate-channel 5g interference-threshold· 8
calibrate-channel 5g noise-threshold· 9
calibrate-channel 5g receive-service-traffic threshold· 9
calibrate-channel 5g retransmission-threshold· 10
calibrate-channel 5g tolerance-level 11
calibrate-channel 6g channel-usage-threshold· 12
calibrate-channel 6g crc-error-threshold· 12
calibrate-channel 6g interference-threshold· 13
calibrate-channel 6g noise-threshold· 14
calibrate-channel 6g receive-service-traffic threshold· 15
calibrate-channel 6g retransmission-threshold· 15
calibrate-channel 6g tolerance-level 16
calibrate-channel self-decisive· 17
calibrate-channel track radar-detect enable· 17
calibrate-power 2.4g adjacency-factor 18
calibrate-power 2.4g threshold· 19
calibrate-power 5g adjacency-factor 19
calibrate-power 5g threshold· 20
calibrate-power 6g adjacency-factor 21
calibrate-power 6g threshold· 21
calibrate-power power-range· 22
calibrate-power self-decisive· 23
display wlan rrm baseline· 23
display wlan rrm baseline apply-history· 24
display wlan rrm-history ap· 26
display wlan rrm-status ap· 28
snmp-agent trap enable wlan rrm·· 30
wlan calibrate-channel pronto ap all 31
wlan calibrate-power pronto ap all 32
wlan rrm baseline apply· 32
wlan rrm baseline remove· 33
wlan rrm baseline save· 33
wlan rrm calibration-bandwidth interval 34
wlan rrm calibration-channel ap· 34
wlan rrm calibration-channel interval 35
wlan rrm calibration-power interval 36
WLAN RRM commands
Use calibrate-bandwidth self-decisive enable to enable automatic bandwidth adjustment.
Use undo calibrate-bandwidth self-decisive to restore the default.
calibrate-bandwidth self-decisive enable { 5g | 6g | all }
undo calibrate-bandwidth self-decisive enable { 5g | 6g | all }
Automatic bandwidth adjustment is disabled.
Global configuration view
5g: Specifies 5 GHz radios.
6g: Specifies 6 GHz radios.
all: Specifies both the 5 GHz and 6 GHz radios.
With automatic bandwidth adjustment enabled, the AP starts channel quality detection when the automatic bandwidth adjustment interval is reached, and determines whether to perform bandwidth adjustment. It decreases the bandwidth for a radio to reduce interference if the number of neighbor radios for that radio is large, and increases the bandwidth to increase transmission rate if the number is small.
This command takes effect only on 5 GHz and 6 GHz radios.
# Enable automatic bandwidth adjustment.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] calibrate-bandwidth self-decisive enable 5g
Use calibrate-channel 2.4g channel-usage-threshold to set the channel usage threshold for 2.4 GHz radios.
Use undo calibrate-channel 2.4g channel-usage-threshold to restore the default.
calibrate-channel 2.4g channel-usage-threshold percent percent
undo calibrate-channel 2.4g channel-usage-threshold percent
The channel usage threshold is 60 for 2.4 GHz radios.
percent percent: Specifies the channel usage threshold in percent. The value range is 1 to 100.
Auto DFS is triggered when both the channel usage threshold and interference ratio threshold are reached or exceeded, but the received service traffic fails to reach the service traffic threshold.
·     Channel usage threshold—Proportion of channel resources used for packet transmitting and receiving.
·     Interference ratio threshold—Proportion of channel resources used by interferences to the total used channel resources.
·     Service traffic threshold—Proportion of received service traffic to the total received traffic.
# Set the channel usage threshold to 40 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g channel-usage-threshold percent 40
Use calibrate-channel 2.4g crc-error-threshold to set the CRC error threshold for 2.4 GHz radios.
Use undo calibrate-channel 2.4g crc-error-threshold to restore the default.
calibrate-channel 2.4g crc-error-threshold percent
The CRC error threshold is 0 for 2.4 GHz radios.
percent percent: Specifies the CRC error threshold in percent. The value range is 0 to 100. Setting the threshold to 0 disables the system from using the CRC error threshold as a trigger for auto DFS.
When the AP detects that the proportion of CRC-error packets in all 802.11 packets reaches or exceeds the CRC error threshold on a 2.4 GHz radio, it performs auto DFS for the radio.
# Set the CRC error threshold to 10 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g crc-error-threshold 10
Use calibrate-channel 2.4g interference-threshold to set the interference threshold for 2.4 GHz radios.
Use undo calibrate-channel 2.4g interference-threshold to restore the default.
calibrate-channel 2.4g interference-threshold percent percent
undo calibrate-channel 2.4g interference-threshold percent
The interference threshold is 70 for 2.4 GHz radios.
percent percent: Specifies the interference threshold in percent. The value range is 0 to 100.
The smaller the threshold is, the more frequent DFS will be. Set a proper interference radio threshold as needed.
# Set the interference threshold to 50 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g interference-threshold percent 50
Use calibrate-channel 2.4g noise-threshold to set the noise threshold for 2.4 GHz radios.
Use undo calibrate-channel 2.4g noise-threshold to restore the default.
calibrate-channel 2.4g noise-threshold value
The noise threshold is 0 for 2.4 GHz radios.
value: Specifies the noise threshold in the range of 0 to 127, which represents power 0 to –127 dBm. The larger the noise threshold, the smaller the noise. Setting the threshold to 0 disables the system from using the noise threshold as a trigger for auto DFS.
Auto DFS is triggered when the noise detected by the AP in the working channel of a 2.4 GHz radio reaches or exceeds the threshold.
# Set the noise threshold to 50 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g noise-threshold 50
Use calibrate-channel 2.4g receive-service-traffic threshold to set received service traffic threshold for 2.4 GHz radios.
Use undo calibrate-channel 2.4g receive-service-traffic threshold to restore the default.
calibrate-channel 2.4g receive-service-traffic threshold value
The received service traffic threshold is 10 Mbps for 2.4 GHz radios.
threshold value: Specifies the received service traffic threshold in the range of 0 to 1000 Mbps.
Received traffic includes interference and service traffic. A low service traffic ratio indicates a severe interference condition.
# Set the received service traffic threshold to 30 Mbps for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g receive-service-traffic threshold 30
Use calibrate-channel 2.4g retransmission-threshold to set the retransmission threshold for 2.4 GHz radios.
calibrate-channel 2.4g retransmission-threshold value
undo calibrate-channel 2.4g retransmission-threshold
The retransmission threshold is 0 for 2.4 GHz radios.
value: Specifies the retransmission threshold in percent. The value range is 0 to 100. Setting the threshold to 0 disables the system from using the retransmission threshold as a trigger for auto DFS.
Auto DFS is triggered if the retransmission rate on a 2.4 GHz radio reaches or exceeds the retransmission threshold.
# Set the retransmission threshold to 50 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g retransmission-threshold 50
Use calibrate-channel 2.4g tolerance-level to set the tolerance level for 2.4 GHz radios.
Use undo calibrate-channel 2.4g tolerance-level to restore the default.
calibrate-channel 2.4g tolerance-level percent
The tolerance level is 1 for 2.4 GHz radios.
percent: Specifies the tolerance level in percent. The value range is 0 to 100. Setting the level to 0 disables the system from using the tolerance level as a trigger for auto DFS.
The tolerance level defines the quality gap between the optimal channel and the current channel that can trigger a channel change. The AP applies the optimal channel to a radio only when the tolerance level is reached.
# Set the tolerance level to 10 for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 2.4g tolerance-level 10
Use calibrate-channel 5g channel-usage-threshold to set the channel usage threshold for 5 GHz radios.
Use undo calibrate-channel 5g channel-usage-threshold to restore the default.
calibrate-channel 5g channel-usage-threshold percent percent
undo calibrate-channel 5g channel-usage-threshold percent
The channel usage threshold is 60 for 5 GHz radios.
Auto DFS is triggered when both the channel usage threshold and interference ratio threshold are reached or exceeded but the received service traffic does not reach the service traffic threshold.
# Set the channel usage threshold to 40 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g channel-usage-threshold percent 40
Use calibrate-channel 5g crc-error-threshold to set the CRC error threshold for 5 GHz radios.
Use undo calibrate-channel 5g crc-error-threshold to restore the default.
calibrate-channel 5g crc-error-threshold percent
The CRC error threshold is 0 for 5 GHz radios.
When the AP detects that the proportion of CRC-error packets in all 802.11 packets reaches or exceeds the CRC error threshold on a 5 GHz radio, it performs auto DFS for the radio.
# Set the CRC error threshold to 10 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g crc-error-threshold 10
Use calibrate-channel 5g interference-threshold to set the interference threshold for 5 GHz radios.
Use undo calibrate-channel 5g interference-threshold to restore the default.
calibrate-channel 5g interference-threshold percent percent
undo calibrate-channel 5g interference-threshold percent
The interference threshold is 70 for 5 GHz radios.
# Set the interference threshold to 50 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g interference-threshold percent 50
Use calibrate-channel 5g noise-threshold to set the noise threshold for 5 GHz radios.
Use undo calibrate-channel 5g noise-threshold to restore the default.
calibrate-channel 5g noise-threshold value
The noise threshold is 0 for 5 GHz radios.
Auto DFS is triggered when the noise detected by the AP in the 5 GHz working channel reaches or exceeds the threshold.
# Set the noise threshold to 50 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g noise-threshold 50
Use calibrate-channel 5g receive-service-traffic threshold to set the received service traffic threshold for 5 GHz radios.
Use undo calibrate-channel 5g receive-service-traffic threshold to restore the default.
calibrate-channel 5g receive-service-traffic threshold value
The received service traffic threshold is 10 Mbps for 5 GHz radios.
# Set the received service traffic threshold to 30 Mbps for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g receive-service-traffic threshold 30
Use calibrate-channel 5g retransmission-threshold to set the retransmission threshold for 5 GHz radios.
calibrate-channel 5g retransmission-threshold value
undo calibrate-channel 5g retransmission-threshold
The retransmission threshold for 5 GHz is 0.
Auto DFS is triggered if the retransmission rate on a 5 GHz radio reaches or exceeds the retransmission threshold.
# Set the retransmission threshold to 50 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g retransmission-threshold 50
Use calibrate-channel 5g tolerance-level to set the tolerance level for 5 GHz radios.
Use undo calibrate-channel 5g tolerance-level to restore the default.
calibrate-channel 5g tolerance-level percent
The tolerance level is 0 for 5 GHz radios.
# Set the tolerance level to 10 for 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 5g tolerance-level 10
Use calibrate-channel 6g channel-usage-threshold to set the channel usage threshold for 6 GHz radios.
Use undo calibrate-channel 6g channel-usage-threshold to restore the default.
calibrate-channel 6g channel-usage-threshold percent percent
undo calibrate-channel 6g channel-usage-threshold percent
The channel usage threshold is 60 for 6 GHz radios.
# Set the channel usage threshold to 40 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g channel-usage-threshold percent 40
Use calibrate-channel 6g crc-error-threshold to set the CRC error threshold for 6 GHz radios.
Use undo calibrate-channel 6g crc-error-threshold to restore the default.
calibrate-channel 6g crc-error-threshold percent
The CRC error threshold is 0 for 6 GHz radios.
When the device detects that the proportion of CRC-error packets in all 802.11 packets reaches or exceeds the CRC error threshold on a 6 GHz radio, it performs auto DFS for the radio.
# Set the CRC error threshold to 10 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g crc-error-threshold 10
crc-error-threshold
Use calibrate-channel 6g interference-threshold to set the interference threshold for 6 GHz radios.
Use undo calibrate-channel 6g interference-threshold to restore the default.
calibrate-channel 6g interference-threshold percent percent
undo calibrate-channel 6g interference-threshold percent
The interference threshold is 70 for 6 GHz radios.
# Set the interference threshold to 50 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g interference-threshold percent 50
Use calibrate-channel 6g noise-threshold to set the noise threshold for 6 GHz radios.
Use undo calibrate-channel 6g noise-threshold to restore the default.
calibrate-channel 6g noise-threshold value
The noise threshold is 0 for 6 GHz radios.
Auto DFS is triggered when the noise detected by the device in the 6 GHz working channel reaches or exceeds the threshold.
# Set the noise threshold to 50 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g noise-threshold 50
Use calibrate-channel 6g receive-service-traffic threshold to set the received service traffic threshold for 6 GHz radios.
Use undo calibrate-channel 6g receive-service-traffic threshold to restore the default.
calibrate-channel 6g receive-service-traffic threshold value
The received service traffic threshold is 10 Mbps for 6 GHz radios.
# Set the received service traffic threshold to 30 Mbps for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g receive-service-traffic threshold 30
Use calibrate-channel 6g retransmission-threshold to set the retransmission threshold for 6 GHz radios.
Use undo calibrate-channel 6g retransmission-threshold to restore the default.
calibrate-channel 6g retransmission-threshold value
The retransmission threshold for 6 GHz is 0.
Auto DFS is triggered if the retransmission rate on a 6 GHz radio reaches or exceeds the retransmission threshold.
# Set the retransmission threshold to 50 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g retransmission-threshold 50
Use calibrate-channel 6g tolerance-level to set the tolerance level for 6 GHz radios.
Use undo calibrate-channel 6g tolerance-level to restore the default.
calibrate-channel 6g tolerance-level percent
The tolerance level is 0 for 6 GHz radios.
The device applies the optimal channel to a radio only when the tolerance level is reached.
# Set the tolerance level to 10 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-channel 6g tolerance-level 10
tolerance-level
Use calibrate-channel self-decisive enable to enable auto-DFS.
Use undo calibrate-channel self-decisive to restore the default.
calibrate-channel self-decisive enable { 2.4g | 5g | 6g | all }
undo calibrate-channel self-decisive enable { 2.4g | 5g | 6g | all }
Auto-DFS is disabled.
2.4g: Specifies the 2.4 GHz frequency band.
5g: Specifies the 5 GHz frequency band.
6g: Specifies the 6 GHz frequency band.
all: Specifies the 2.4 GHz, 5 GHz, and 6 GHz frequency bands.
# Enable auto-DFS.
[Sysname-wlan-global-configuration] calibrate-channel self-decisive enable all
Use calibrate-channel track radar-detect enable to enable radar detection-triggered RRM.
Use undo calibrate-channel track radar-detect enable to disable radar detection-triggered RRM.
Radar detection-triggered RRM is disabled.
With radar detection enabled, if an AP detects a radar signal on the current channel, it either switch the channel or go silent to prevent radar interference. However, the new channel might lead to a degraded wireless network experience due to high interference or other issues. In such cases, you can enable radar detection-triggered RRM. After an AP detects radar signals and switches the channel, it notifies RRM to evaluate the new channel for further adjustments. If necessary, RRM automatically adjusts the channel to improve wireless network quality.
# Enable radar detection-triggered RRM.
[Sysname-wlan-global-configuration] calibrate-channel track radar-detect enable
radar-detect disable
Use calibrate-power 2.4g adjacency-factor to set the adjacency factor for 2.4 GHz radios.
Use undo calibrate-power 2.4g adjacency-factor to restore the default.
calibrate-power 2.4g adjacency-factor neighbor
The adjacency factor is 1 for 2.4 GHz radios.
neighbor: Specifies the adjacency factor in the range of 1 to 16.
The adjacency factor defines the quantity of manageable detected radios that trigger TPC and the ranking of the RSSI used for comparison with the power adjustment threshold. An AP can manage only radios associated with it.
For example, if the adjacency factor is 3, the AP performs TPC for a radio when the radio detects 3 other manageable radios. After ranking the radio's RSSIs detected by other manageable radios in descending order, the AP selects the third largest RSSI to compare with the power adjustment threshold.
# Set the adjacency factor to 7 for the 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-power 2.4g adjacency-factor 7
Use calibrate-power 2.4g threshold to set the power adjustment threshold for 2.4 GHz radios.
Use undo calibrate-power 2.4g threshold to restore the default.
calibrate-power 2.4g threshold value
The power adjustment threshold is 65.
threshold value: Specifies the power adjustment threshold in the range of 1 to 196. The value range indicates that the power of the radio is in the range of –196 dBm to –1 dBm.
As a best practice to avoid interference among radios, set the power adjustment threshold to –80 dBm for high-density WLANs.
# Set the power adjustment threshold to 70 for the 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-power 2.4g threshold 70
Use calibrate-power 5g adjacency-factor to set the adjacency factor for 5 GHz radios.
Use undo calibrate-power 5g adjacency-factor to restore the default.
calibrate-power 5g adjacency-factor neighbor
The adjacency factor is 1 for 5 GHz radios.
# Set the adjacency factor to 7 for the 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-power 5g adjacency-factor 7
Use calibrate-power 5g threshold to set the power adjustment threshold for 5 GHz radios.
Use undo calibrate-power 5g threshold to restore the default.
calibrate-power 5g threshold value
# Set the power adjustment threshold to 75 for the 5 GHz radios.
[Sysname-wlan-global-configuration] calibrate-power 5g threshold 75
Use calibrate-power 6g adjacency-factor to set the adjacency factor for 6 GHz radios.
Use undo calibrate-power 6g adjacency-factor to restore the default.
calibrate-power 6g adjacency-factor neighbor
The adjacency factor is 1 for 6 GHz radios.
# Set the adjacency factor to 7 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-power 6g adjacency-factor 7
Use calibrate-power 6g threshold to set the power adjustment threshold for 6 GHz radios.
Use undo calibrate-power 6g threshold to restore the default.
calibrate-power 6g threshold value
# Set the power adjustment threshold to 75 for 6 GHz radios.
[Sysname-wlan-global-configuration] calibrate-power 6g threshold 75
Use calibrate-power power-range to specify the transmit power adjustment range.
Use undo calibrate-power power-range to restore the default.
calibrate-power { 2.4g | 5g | 6g } power-range min-power to max-power
undo calibrate-power { 2.4g | 5g | 6g } power-range
The minimum transmit power is 6 dBm for 2.4GHz radios, and 11 dBm for 5GHz and 6GHz radios. The maximum transmit power for the 2.4GHz, 5GHz, and 6GHz radios is consistent with the default maximum power supported by the radio band.
min-power: Specifies the minimum transmit power in the range of 1 to 20 dBm.
max-power: Specifies the maximum transmit power in the range of 1 to 27 dBm.
# Specify the transmit power range as 15-20 dBm for 2.4 GHz radios.
[Sysname-wlan-global-configuration] calibrate-power 2.4g power-range 15 to 20
Use calibrate-power self-decisive enable to enable periodic auto-TPC for the AP to perform TPC at the power calibration interval.
Use undo calibrate-power self-decisive enable to restore the default.
calibrate-power self-decisive enable { 2.4g | 5g | 6g | all }
undo calibrate-power self-decisive enable { 2.4g | 5g | 6g | all }
Auto-TPC is disabled.
all: Specifies the 2.4 GHz, 5GHz, and 6 GHz frequency bands.
# Enable periodic auto-TPC.
[Sysname-wlan-global-configuration] calibrate-power self-decisive enable all
Use display wlan rrm baseline to display radio baseline information.
display wlan rrm baseline { all | name baseline-name } [ verbose ]
all: Specifies all radio baselines.
name baseline-name: Specifies a radio baseline by its name, a case-insensitive string of 1 to 32 characters.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief radio baseline information.
You cannot display information about a radio baseline if you do not have the right to manage radios with the location identifier in the radio baseline.
# Display brief radio baseline information.
<Sysname> display wlan rrm baseline all
 Baseline name  : globalbaseline
 Radio range    : Global
 Created at     : 2015-06-22 19:55:12
Radio range
Range of radios saved in the baseline.
Created at
Time and date when the baseline was created.
# Display detailed radio baseline information.
<Sysname> display wlan rrm baseline all verbose
 APName             RadioID RadioType Bandwidth Channel Power RegionCode
 fatap              1       dot11an   40        149     20    CN
 fatap              2       dot11gn   20        13      20    CN
Radio range
Created at
Power
Transmit power of the radio in dBm.
RegionCode
Region code of the AP.
Use display wlan rrm baseline apply-history to display the history records of radio baseline application.
display wlan rrm baseline apply-history [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
This command displays information about the most recent ten baseline applications.
# Display the brief history records of radio baseline application.
<Sysname> display wlan rrm baseline apply-history
Applied at  : 2016-01-23   12:19:50
Applied to  : global
# Display the detailed history records of radio baseline application.
<Sysname> display wlan rrm baseline apply-history verbose
Applied to  : global
Radios      : 3
Success     : 2
Failure     : 1
Failure reason
  Radio doesn't exist           : 0
  Radio is down                 : 0
  Mismatching radio type        : 0
  Mismatching region code       : 0
  Ineffective service template  : 0
  Illegal channel               : 0
  Mismatching bandwidth         : 1
  Channel locked                : 0
  Channel fixed                 : 0
  Within channel holddown time  : 0
  Mismatching channel gap policy: 0
  Power locked                  : 0
  Within power holddown time    : 0
  Power lower than min. power   : 0
  Power greater than max. power : 0
Name
Radio baseline name.
Applied at
Time at which the radio baseline was applied.
Applied to
Radio baseline application range.
Radios
Number of radios in the radio baseline.
Success
Number of successful applications.
Failure
Number of failed applications.
The radio mode saved in the baseline does not match the actual radio mode.
The region code saved in the baseline does not match the actual region code of the AP.
No service template is bound to a radio in the baseline or the bound service template is disabled.
The channel in the baseline does not match the specified channel gap.
The transmit power in the baseline is lower than the specified minimum transmit power for the radio.
The transmit power in the baseline is higher than the specified maximum transmit power for the radio.
Use display wlan rrm-history ap to display historical channel and power adjustment information.
display wlan rrm-history ap { all | name ap-name }
all: Specifies the current AP.
name ap-name: Specifies an AP by its name. The name can only be fatap.
You can use this command to display detailed information about the most recent ten channel, power, and bandwidth adjustments. The detailed information includes adjustment time, cause, load, and interference.
# Display historical channel and power adjustment information for radios.
<Sysname> display wlan rrm-history ap name fatap
                         AP RRM History
 Flags : I - Interference,   P - Packets discarded,    F - Retransmission,
         R - Radar select,   C - Coverage,             B - Channelbusy
         M – Manual          D – Bandwidth             O - Others
                         AP RRM History : fatap
 Radio : 1                                Basic BSSID : 000f-e2ff-7700
        Ch  Power BW    Load Util Intf   Reason    Date         Time
            (dBm) (MHz) (%)  (%)  (%)              (yyyy-mm-dd) (hh:mm:ss)
 Before 36   20   20    24   2    21     -P------- 2014-07-07   17:31:50
 After  40   20   20    9    0    8      -         -            -
 Before 40   20   20    54   1    53     IP------- 2014-07-08   12:19:50
 After  36   20   20    10   0    10     -         -            -
 Before 36   20   20    29   1    28     -------D- 2014-07-08   12:59:50
 After  36   20   40    30   0    29     -         -            -
Radio
Radio ID.
Basic BSSID
Basic service set identifier.
Ch
Working channel of the radio.
Power (dBm)
Transmit power of the radio, in dBm.
BW (MHz)
Bandwidth for the radio, in MHz.
Load (%)
Channel load in percentage.
Util (%)
Channel usage in percentage.
Intf (%)
Interference detected on the channel, in percentage.
Reason
Channel or power adjustment reason. Options include:
·     I—Interference.
·     P—Packet loss.
·     F—Retransmission.
·     R—Radar avoidance.
·     C—Signal coverage.
·     B—Channel busy.
·     M—Manually triggered.
·     D—Bandwidth adjustment.
·     O—Other reason.
Date
Adjustment date.
Time
Adjustment time.
Use display wlan rrm-status ap to display detailed RRM information.
display wlan rrm-status ap { all | name ap-name } [ neighbor-type { managed | unmanaged } ]
name ap-name: Specifies an AP by its name. The AP name can only be fatap.
neighbor-type: Specifies RRM details by neighbor type. If you do not specify this keyword, the command displays RRM details for all neighbor types detected by the AP.
managed: Specifies managed radios.
unmanaged: Specifies unmanaged radios.
If both channel adjustment and power adjustment are disabled, this command does not display channel reports or neighbor reports.
# Display detailed information about channel and power adjustments for radios.
<Sysname> display wlan rrm-status ap name fatap
                          AP RRM Profile : fatap
 Radio   : 1                              Basic BSSID    : 70f9-6d31-2fe0
 Channel : 157                            Tx Power (dBm) : 18
    Ch    Nbrs   Load   Util   Intf   PER   Retry   Radar     Last Detected At
    36    0      0      -      0      0     -       -         2020-04-10 09:35:01
    40    0      0      -      0      0     -       -         2020-04-10 09:35:01
    44    0      0      -      0      0     -       -         2020-04-10 09:35:01
    48    0      0      -      0      0     -       -         2020-04-10 09:35:01
    52    0      0      -      0      0     -       -         2020-04-10 09:35:01
    56    0      0      -      0      0     -       -         2020-04-10 09:35:01
    60    0      0      -      0      0     -       -         2020-04-10 09:35:01
    64    0      0      -      0      0     -       -         2020-04-10 09:35:01
    100   0      0      -      0      0     -       -         2020-04-10 09:35:01
    104   0      0      -      0      0     -       -         2020-04-10 09:35:01
    108   0      0      -      0      0     -       -         2020-04-10 09:35:01
    112   0      0      -      0      0     -       -         2020-04-10 09:35:01
    116   0      0      -      0      0     -       -         2020-04-10 09:35:01
    132   0      0      -      0      0     -       -         2020-04-10 09:35:01
    136   0      0      -      0      0     -       -         2020-04-10 09:35:01
    140   0      0      -      0      0     -       -         2020-04-10 09:35:01
    149   1      0      -      0      0     -       -         2020-04-10 09:35:01
    153   4      0      -      0      0     -       -         2020-04-10 09:35:01
    157   0      0      0      0      0     0       -         2020-04-10 09:35:01
    161   2      0      -      0      0     -       -         2020-04-10 09:35:01
    165   0      0      -      0      0     -       -         2020-04-10 09:35:01
   Nbr-MACAddress   Ch    Intf   SignalStrength  Type        Last Detected At
                           (%)    (dBm)
   000f-e212-ff01   161   0      -60             Unmanaged   2020-04-10 09:39:03
   5866-ba74-e461   153   0      -72             Unmanaged   2020-04-10 09:39:03
   70f9-6d30-9020   153   0      -40             Managed     2020-04-10 09:39:03
   70f9-6d31-3080   149   0      -54             Managed     2020-04-10 09:39:03
   70f9-6d31-34e0   161   0      -59             Managed     2020-04-10 09:39:03
   7425-8a86-bbe0   153   0      -48             Unmanaged   2020-04-10 09:39:03
   7425-8a86-c720   153   0      -63             Unmanaged   2020-04-10 09:39:03
 Radio   : 2                              Basic BSSID    : 70f9-6d31-2ff0
 Channel : 1                              Tx Power (dBm) : 19
    1    6      4      0      4      0     0       -         2020-04-10 09:33:06
    6    4      2      -      2      0     -       -         2020-04-10 09:33:06
    11   6      2      -      2      0     -       -         2020-04-10 09:33:06
                           (%)    (dBm)
   000f-e212-ff11   1     49     -77             Unmanaged   2020-04-10 09:31:05
   0023-89e1-ed00   11    0      -87             Unmanaged   2020-04-10 09:31:05
   006a-55f6-ae10   1     57     -88             Unmanaged   2020-04-10 09:31:05
   5866-ba64-aa31   1     10     -60             Unmanaged   2020-04-10 09:31:05
   5866-ba74-e471   6     0      -76             Unmanaged   2020-04-10 09:31:05
   5866-baa9-a610   11    0      -62             Unmanaged   2020-04-10 09:31:05
   70f9-6d30-9030   6     0      -63             Managed     2020-04-10 09:31:05
   70f9-6d31-3090   1     51     -86             Managed     2020-04-10 09:31:05
   70f9-6d31-34f0   6     0      -85             Managed     2020-04-10 09:33:09
   7425-8a86-bbf0   6     0      -73             Unmanaged   2020-04-10 09:33:09
   7425-8a86-c731   11    0      -93             Unmanaged   2020-04-10 09:33:09
   80f6-2ec0-3330   11    0      -76             Unmanaged   2020-04-10 09:33:09
   80f6-2ec0-3331   11    0      -73             Unmanaged   2020-04-10 09:33:09
   80f6-2edd-d2d0   1     40     -60             Unmanaged   2020-04-10 09:33:09
   80f6-2edd-d2d1   1     44     -68             Unmanaged   2020-04-10 09:33:09
   80f6-2ede-0b30   11    0      -74             Unmanaged   2020-04-10 09:33:09
Table 5 Command output
Radio
Radio ID.
Basic BSSID
Channel
Tx Power
Transmit power of the radio.
Ch
Channels supported by the radio.
Nbrs
Number of detected radios.
Load
Load detected on the channel, in percentage. Channel load refers to the ratio between the outbound packets and the inbound packets as well as the interferences. Interferences refer to the error packets that are received by the radio.
Util
Channel usage in percentage. Channel usage refers to the ratio between the outbound packets and the inbound packets.
Intf
PER
Bit error rate detected on the channel, in percentage.
Retry
Retransmission rate detected on the channel, in percentage.
Radar
Radar detection status:
·     : No radar signals are detected on the channel.
·     Detected: Radar signals have been detected on the channel.
Nbr-MACAddress
MAC address of the detected radio.
SignalStrength
Signal strength of the radio, in dBm.
Type of the radio:
·     Unmanaged—Radios that can be detected by the radio but are not managed by the same AP.
·     Managed—Radios that can be detected by the radio and are managed by the same AP.
Last Detected At
Last time valid channel and neighbor data was detected.
Use snmp-agent trap enable wlan rrm to enable SNMP notifications for WLAN RRM.
Use undo snmp-agent trap enable wlan rrm to disable SNMP notifications for WLAN RRM..
SNMP notifications are disabled for WLAN RRM.
To report critical WLAN RRM events to an NMS, enable SNMP notifications for WLAN RRM. For WLAN RRM event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for WLAN RRM.
[Sysname] snmp-agent trap enable wlan rrm
IMPORTANT
IMPORTANT:
This command consumes system resources. Use it with caution.
Use wlan calibrate-channel pronto ap all to execute on-demand DFS the specified radios.
wlan calibrate-channel pronto ap all { 2.4g | 5g | 6g | all }
2.4g: Specifies 2.4 GHz radios.
all: Specifies 2.4 GHz, 5 GHz, and 6 GHz radios.
In 10 minutes after the command execution, the system allows radios to provide services on the working channel and scan the non-working channels alternatively, which might cause packet loss. As a best practice, perform this task during the network maintenance period.
# Execute on-demand DFS for all radios.
[Sysname] wlan calibrate-channel pronto ap all all
This operation will change the working channel of all radios and might cause packet loss. Continue? [Y/N]
IMPORTANT
IMPORTANT:
Use wlan calibrate-power pronto ap all to execute on-demand TPC for the specified radios.
wlan calibrate-power pronto ap all { 2.4g | 5g | 6g | all }
The command does not take effect on radios configured with a maximum transmit power.
# Execute on-demand TPC for all radios.
[Sysname] wlan calibrate-power pronto ap all all
Use wlan rrm baseline apply to apply a radio baseline.
wlan rrm baseline apply name baseline-name
name baseline-name: Specifies a baseline name, a case-insensitive string of 1 to 32 characters.
You cannot apply a radio baseline when one of the following conditions is met:
·     You do not have the right to manage radios with the location identifier in the radio baseline.
·     The name of the radio baseline is start_config_baseline.csv.
# Apply radio baseline bl.
[Sysname] wlan rrm baseline apply name bl
Use wlan rrm baseline remove to delete a radio baseline.
wlan rrm baseline remove name baseline-name
You cannot delete a radio baseline if you do not have the right to manage radios with the location identifier in the radio baseline.
# Delete radio baseline bl.
[Sysname] wlan rrm baseline remove name bl
Use wlan rrm baseline save to create a radio baseline by saving the current radio settings.
wlan rrm baseline save name baseline-name global
A radio baseline saves the working channel, transmit rate, and other radio attributes for a radio or several radios. You can create a radio baseline by saving the current radio settings and apply the baseline to use these settings.
A radio baseline is saved in a .csv file in the file system.
# Save the settings of radio 1 and create radio baseline global.
[Sysname] wlan rrm baseline save name global global
Use wlan rrm calibration-bandwidth interval to set the interval for automatic bandwidth adjustment.
Use undo wlan rrm calibration-bandwidth interval to restore the default.
wlan rrm calibration-bandwidth interval minutes
The interval for automatic bandwidth adjustment is 29 minutes.
minutes: Specifies the automatic bandwidth adjustment interval in the range of 3 to 1440 minutes.
# Set the interval for automatic bandwidth adjustment to 10 minutes.
[Sysname] wlan rrm calibration-bandwidth interval 10
Use wlan rrm calibration-channel ap to perform on-demand DFS for radios of the specified AP.
wlan rrm calibration-channel ap name ap-name [ radio radio-id ] [ force ]
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify this option, the command takes effect on all radios of the specified AP.
force: Changes the working channel forcibly. If you do not specify this keyword, the AP determines whether to change the working channel based on the condition of the current working channel.
If you perform on-demand DFS for multiple radios, the calibration of one radio does not affect channel calibration of the other radios.
If you specify the force keyword, the new channel might not be the optimal channel.
The system will take a few minutes to scan channels and collect channel data. This might cause packet loss. During the calibration process, do not disable the radios or change channel scanning or WLAN RRM settings.
# Perform forced on-demand DFS for radio 1.
[Sysname] wlan rrm calibration-channel ap name fatap radio 1 force
Use wlan rrm calibration-channel interval to set the channel calibration interval.
Use undo wlan rrm calibration-channel interval to restore the default.
wlan rrm calibration-channel interval minutes
The channel calibration interval is 31 minutes.
minutes: Specifies the channel calibration interval, in the range of 3 to 1440 minutes.
# Set the channel calibration interval to 10 minutes.
[Sysname] wlan rrm calibration-channel interval 10
Use wlan rrm calibration-power interval to set the power calibration interval.
Use undo wlan rrm calibration-power interval to restore the default.
wlan rrm calibration-power interval minutes
The power calibration interval is 11 minutes.
minutes: Specifies the power calibration interval, in the range of 3 to 180 minutes.
# Set the power calibration interval to 10 minutes.
[Sysname] wlan rrm calibration-power interval 10
