04-Network Connectivity Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Wi-Fi 7 Access Points Cloud Mode Command References(R2610P06)-6W10004-Network Connectivity Command Reference
16-EoGRE commands
16-EoGRE commands 111.19 KB
EoGRE commands
The following compatibility matrix shows the support of hardware platforms for EoGRE:
Hardware series
Model
EoGRE compatibility
WA7200 series
WA7220
WA7220-HI
WA7220H
WA7226-C
WA7230
WA7230-LI
No
WA7300 series
WA7320i
WA7322H-HI
WA7330X
WA7338-HI
No
WA7500 series
WA7538
WA7539
Yes
WA7600 series
WA7638
No
destination
Use destination to specify the destination address for a tunnel interface.
Use undo destination to restore the default.
destination ipv4-address
undo destination
No tunnel destination address is configured.
Tunnel interface view
ipv4-address: Specifies the tunnel destination IPv4 address.
The tunnel destination address must be the address of the receiving interface on the tunnel peer. It is used as the destination address of tunneled packets.
The destination address of the local tunnel interface must be the source address of the peer tunnel interface. The source address of the local tunnel interface must be the destination address of the peer tunnel interface.
Do not specify the same tunnel source and destination addresses for the tunnel interfaces on the same device.
# The interface on Sysname 1 uses IP address 193.101.1.1 and the interface on Sysname 2 uses IP address 192.100.1.1. Configure the source address 193.101.1.1 and destination address 192.100.1.1 for the tunnel interface on Sysname 1.
<Sysname1> system-view
[Sysname1] interface tunnel 1
[Sysname1-Tunnel1] source 193.101.1.1
[Sysname1-Tunnel1] destination 192.100.1.1
# Configure source address 192.100.1.1 and destination address 193.101.1.1 for the tunnel interface on Sysname 2.
<Sysname2> system-view
[Sysname2] interface tunnel 1
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
display interface tunnel
interface tunnel
source
Use display interface tunnel to display tunnel interface information.
display interface [ tunnel [ number ] ] [ brief [ description | down ] ]
tunnel [ number ]: Specifies a tunnel interface. The number argument specifies the tunnel interface number. The specified tunnel interface must have been created. If you do not specify the tunnel keyword, this command displays information about all interfaces on the device. If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in the physical state of DOWN and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Tunnel 1.
<Sysname> display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum transmission unit: 64000
Tunnel TOS 0xC8, Tunnel TTL 255
Tunnel protocol/transport EoGRE/IP
Tunnel1
Information about the tunnel interface Tunnel 1.
Current state
Physical link state of the tunnel interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Description of the tunnel interface.
Bandwidth
Expected bandwidth of the tunnel interface.
MTU of the tunnel interface.
The interface cannot process IP packets.
Internet address
IP address of the tunnel interface. Primary indicates that the IP address is the primary IP address of the interface.
Tunnel source
Source address of the tunnel. If a source interface is specified for the tunnel interface, this field also displays the source interface in parentheses.
destination
Destination address of the tunnel.
Tunnel keepalive enabled, Period(50 s), Retries(3)
EoGRE keepalive is enabled for tunnel interface state detection. In this example, the keepalive interval is 50 seconds, and the keepalive number is 3.
Tunnel TOS
ToS of tunneled packets.
Tunnel TTL
TTL of tunneled packets.
Tunnel mode and transport protocol:
·     EoGRE/IP—EoGRE tunnel mode.
·     UDP_EoGRE/IP—UDP-encapsulated EoGRE tunnel mode.
Last time when counters were cleared.
Average input rate in the last 300 seconds.
Average output rate in the last 300 seconds.
Total input packets, total input bytes, and total input packets dropped.
Total output packets, total output bytes, and total output packets dropped.
# Display brief information about Tunnel 1.
<Sysname> display interface tunnel 1 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP     Description
Tun1                  UP    UP        1.1.1.1         Tunnel1
# Display brief information about Tunnel 1, including the complete interface description.
<Sysname> display interface tunnel 1 brief description
# Display information about interfaces in DOWN state and the causes.
<Sysname> display interface tunnel brief down
Tun0                  DOWN Not connected
Tun1                  DOWN Not connected
Abbreviated interface name.
Link
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Description of the interface.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—The tunnel is not established.
destination
interface tunnel
source
interface tunnel
Use interface tunnel to create a tunnel interface, specify the tunnel mode, and enter tunnel interface view, or enter the view of an existing tunnel interface.
Use undo interface tunnel to delete a tunnel interface.
interface tunnel number [ mode eogre ]
undo interface tunnel number
No tunnel interfaces exist.
number: Specifies the number of the tunnel interface, in the range of 0 to 1023. The number of tunnel interfaces that can be created is restricted by the total number of interfaces and the memory.
mode eogre: Specifies the EoGRE tunnel mode.
To create a new tunnel interface, you must specify the tunnel mode in this command. To enter the view of an existing tunnel interface, you do not need to specify the tunnel mode.
A tunnel interface number is locally significant. The tunnel interfaces on the two ends of a tunnel can use the same or different interface numbers.
# Create EoGRE tunnel interface Tunnel 1 and enter tunnel interface view.
[Sysname] interface tunnel 1 mode eogre
[Sysname-Tunnel1]
destination
source
eogre carry
Use eogre carry to configure EoGRE packets to carry GRE extended fields.
Use undo eogre carry to restore the default.
eogre carry network-policy-id id-value mac-address { bridge | bssid }
undo eogre carry
EoGRE packets do not carry GRE extended fields.
EoGRE tunnel interface view
network-policy-id id-value: Specifies the Network Policy ID field value, in the range of 1 to 65535. This value is the policy ID used by the peer server to identify its access device.
mac-address bridge: Specifies the bridge MAC address of the local device as the value of the AP MAC field.
mac-address bssid: Specifies the BSSID of the local device as the value of the AP MAC field.
If the EoGRE packets sent by an EoGRE tunnel interface need to carry the GRE extended fields, execute this command to configure the fields as needed.
# In EoGRE tunnel interface view, configure EoGRE packets to carry the Network Policy ID and AP MAC fields. Set the Network Policy ID to 20 and the AP MAC field value as the local bridge MAC address.
[Sysname] interface tunnel 0 mode eogre
[Sysname-Tunnel0] eogre carry network-policy-id 20 mac-address bridge
eogre udp-port
Use eogre udp-port to configure the destination UDP port number of EoGRE packets.
Use undo eogre udp-port to restore the default.
eogre udp-port port-number
undo eogre udp-port
The destination UDP port number of EoGRE packets is 4754.
port-number: Sets the destination UDP port number of EoGRE packets, in the range of 1 to 65535. As a best practice, do not configure this port number as a known port number (1 to 1023).
Use this command to configure the destination UDP port number for outgoing EoGRE packets to be encapsulated by UDP on an EoGRE tunnel.
The UDP port number of EoGRE packets specified in this command cannot be a port number that has been used by other modules (such as VXLAN) or tunnels.
An EoGRE tunnel interface can configure only one destination UDP port number for EoGRE packets. On the same device, you can configure a maximum of 32 destination UDP port numbers for EoGRE packets in addition to the default one.
# On EoGRE tunnel interface 0, set the destination UDP port number of EoGRE packets to 4755.
[Sysname-Tunnel0] eogre udp-port 4755
# In EoGRE template abc, set the destination UDP port number of EoGRE packets to 4755.
[Sysname] eogre template abc
[Sysname-eogre-template-abc] eogre udp-port 4755
keepalive
Use keepalive to enable EoGRE keepalive and set the keepalive interval and the keepalive number, and configure the keepalive mode.
Use undo keepalive to disable EoGRE keepalive.
keepalive [ interval [ times ] ]*
undo keepalive
EoGRE keepalive is disabled.
interval: Specifies the keepalive interval, in the range of 1 to 32767 seconds. The default value is 10.
times: Specifies the keepalive number, in the range of 1 to 255. The default value is 3.
This command enables the tunnel interface to send keepalive packets at the specified interval. If the device receives no response from the peer within the timeout time, it shuts down the local tunnel interface. The device brings the local tunnel interface up if it receives a keepalive acknowledgment packet from the peer. The timeout time is the result of multiplying the keepalive interval by the keepalive number.
The device always acknowledges the keepalive packets it receives whether or not keepalive is enabled.
# Enable EoGRE keepalive, set the keepalive interval to 20 seconds, and set the keepalive number to 5.
[Sysname] interface tunnel 2 mode eogre
[Sysname-Tunnel2] keepalive 20 5
map bridge
Use map bridge to map a Layer 2 VEB interface to an EoGRE tunnel interface or a Layer 3 physical interface.
Use undo map bridge to remove the mapping.
map bridge { ve-bridge number | ve-bridge name }
undo map bridge
No VEB interface is mapped to an EoGRE tunnel interface or a Layer 3 physical interface.
Layer 3 physical interface view
ve-bridge number: Specifies an existing Layer 2 VEB interface by its number.
ve-bridge name: Specifies an existing Layer 2 VEB interface by its name.
Before you use an EoGRE tunnel interface, you must execute this command to bind the EoGRE tunnel interface to a Layer 2 VEB interface.
Packets sent by the Layer 2 VEB interface are passed to the mapped EoGRE tunnel interface for encapsulation and forwarding.
To ensure successful mapping, a Layer 2 VEB interface mapped to an EoGRE tunnel interface cannot be bound to other services (such as ATM).
# Enter Layer 3 physical interface view and map Layer 2 VEB interface VE-Bridge 1/0/1 to the Layer 3 physical interface.
[Sysname-GigabitEthernet1/0/1] map bridge ve-bridge 1/0/1
# Create EoGRE-mode tunnel interface Tunnel 0, enter tunnel interface view, and map VE-Bridge 1 to Tunnel 0.
[Sysname-Tunnel0] map bridge ve-bridge 1
mtu
Use mtu to set the MTU on a tunnel interface.
mtu size
undo mtu
If the tunnel interface has never been up, the MTU of the tunnel interface is 64000 bytes.
If the tunnel interface is up, its MTU is identical to the outgoing interface's MTU minus the length of the tunnel headers. The outgoing interface is automatically obtained through routing table lookup based on the tunnel destination address.
size: Specifies the MTU in the range of 100 to 64000 bytes.
If you do not configure an MTU for a tunnel interface, the effective MTU depends on the tunnel interface status.
·     If the tunnel interface is up, its MTU is identical to the outgoing interface's MTU minus the length of the tunnel headers.
·     If the tunnel interface is down, the device does not calculate or update the MTU of the tunnel interface.
If you configure an MTU for a tunnel interface, the configured MTU applies regardless of the tunnel interface status (up/down) and the outgoing interface MTU.
To avoid fragmentation after tunnel encapsulation, set the tunnel interface MTU no greater than the value of the outgoing interface MTU minus the length of the tunnel headers.
# Set the MTU on Tunnel 1 to 10000 bytes.
[Sysname-Tunnel1] mtu 1000
source
Use source to specify the source address or source interface for a tunnel interface.
Use undo source to restore the default.
source { ipv4-address | interface-type interface-number }
undo source
No source address or source interface is specified for a tunnel interface.
ipv4-address: Specifies the tunnel source IPv4 address.
interface-type interface-number: Specifies the source interface by its type and number. The interface must be up and must have an IP address.
The specified source address or the address of the specified source interface is used as the source address of tunneled packets. To display the configured tunnel source address, use the display interface tunnel command.
# Specify the source interface for Tunnel 1 as VLAN-interface 10.
[Sysname-Tunnel1] source vlan-interface 10
# Specify the source address of Tunnel 1 as 192.100.1.1.
[Sysname-Tunnel1] source 192.100.1.1
destination
interface tunnel
tunnel tos
Use tunnel tos to set the ToS of tunneled packets.
Use undo tunnel tos to restore the default.
tunnel tos tos-value
undo tunnel tos
The ToS of tunneled packets is the same as the ToS of the original packets.
tos-value: Specifies the ToS of tunneled packets, in the range of 0 to 255.
After you configure this command, all the tunneled packets of different services sent on the tunnel interface will use the same configured ToS. For more information about ToS, see QoS Configuration Guide.
# Set the ToS of tunneled packets to 20 on Tunnel 1.
[Sysname-Tunnel1] tunnel tos 20
